H3C MSR810 Routers Hardware Information and Specifications-6W104
HomeSupportRoutersMSR810 SeriesProduct LiteratureHardware Information & SpecificationsH3C MSR810 Routers Hardware Information and Specifications-6W104
02-LEDs
02-LEDs 2.08 MB
2 LEDs
LEDs
RT-MSR810
Figure2-1 Front panel LEDs
(1) GE port yellow LED
(2) GE port green LED
(3) System status LED (SYS)
(4) Micro SD card LED
(5) VPN status LED
(6) SFP port LED
RT-MSR810-W
Figure2-2 Front panel LEDs
(3) 2.4G WLAN LED
(4) VPN status LED
(5) System status LED (SYS)
(6) Micro SD card LED
(7) SFP port LED
RT-MSR810-W-DB
Figure2-3 Front panel LEDs
(3) 5G WLAN LED
(4) 2.4G WLAN LED
(5) VPN status LED
(6) System status LED (SYS)
(7) Micro SD card LED
(8) SFP port LED
RT-MSR810-LM
Figure2-4 Front panel LEDs
(3) VPN status LED
(4) System status LED (SYS)
(5) Micro SD card LED
(6) LTE LED
(7) CNDE LED
(8) SFP port LED
RT-MSR810-LM-CNDE-SJK
Figure2-5 Front panel LEDs
(3) VPN status LED
(6) LTE LED
(7) CNDE LED
(8) SFP port LED
RT-MSR810-W-LM
Figure2-6 Front panel LEDs
(3) CNDE LED
(4) 2.4G WLAN LED
(5) VPN status LED
(8) LTE LED
(9) SFP port LED
RT-MSR810-10-PoE-Plus
Figure2-7 Front panel LEDs
(1) SD card LED
(2) PoE LED
(3) VPN status LED
RT-MSR810-LM-HK
Figure2-8 Front panel LEDs
(3) VPN status LED
(6) LTE LED
(7) CNDE LED
(8) SFP port LED
RT-MSR810-W-LM-HK
Figure2-9 Front panel LEDs
(3) CNDE LED
(4) 2.4G WLAN LED
(5) VPN status LED
(8) LTE LED
(9) SFP port LED
RT-MSR810-LM-GL
Figure2-10 Front panel LEDs
(3) VPN status LED
(6) LTE LED
(7) CNDE LED
(8) SFP port LED
RT-MSR810-W-LM-GL
Figure2-11 Front panel LEDs
(3) CNDE LED
(4) 2.4G WLAN LED
(5) VPN status LED
(8) LTE LED
(9) SFP port LED
RT-MSR810-LME
Figure2-12 Front panel LEDs
(1) System status LED (SYS)
(2) VPN status LED
(3) SIM0 slot LED
(4) SIM1 slot LED
(5) Signal strength LED
(6) FE port LEDs (FE0 through FE3)
RT-MSR810-LMS/RT-MSR810-LMS-EA/RT-MSR810-LUS
Figure2-13 Front panel LEDs
(2) VPN status LED
(3) SIM0 slot LED
(4) SIM1 slot LED
RT-MSR810-CNDE-SJK
Figure2-14 Front panel LEDs
(3) VPN status LED
(6) CNDE LED
RT-MSR810-SI/RT-MSR810-EI
Figure2-15 Front panel LEDs
(2) GE copper port LEDs (GE1 to GE4)
(3) GE copper port LED (GE0)
(4) SFP fiber port LED
(5) VPN status LED
RT-MSR810-LM-SI/RT-MSR810-LM-EA/RT-MSR810-LM-EI
Figure2-16 Front panel LEDs
(5) VPN status LED
(6) 4G LTE status LED
(7) SIM0 slot LED
(8) SIM1 slot LED
LED descriptions
Table2-1 LED descriptions
LED
Status
Steady green
The SDRAM is performing self-test.
Flashing green (8 Hz)
The system software image is being copied and decompressed.
Flashing green (1 Hz)
Comware has started with the configuration file and the router has booted up.
Flashing yellow (1 Hz)
The SDRAM has failed the self-test.
Flashing yellow (8 Hz)
The extended segment does not exist.
Steady yellow
The system software image does not exist.
Off
No power input, or exceptions have occurred.
VPN status LED (VPN)
Steady on
A minimum of one IPSec VPN tunnel is present.
Off
No IPSec VPN tunnel is present.
GE port green LED
GE port yellow LED
GE copper port LED
Steady green
A 1000 Mbps link is present.
Flashing green
Data is being received or transmitted at 1000 Mbps.
Steady yellow
A 10/100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 10/100 Mbps.
Both LEDs off
No link is present.
FE port LED (FE0 through FE3)
Steady green
Flashing green
Off
No link is present.
Micro SD card LED
Steady green
The Micro SD card is present and has passed the test.
Off
No Micro SD card is inserted or the Micro SD card is installed incorrectly.
LTE LED
Steady green
A 4G link is present.
Data is being received or transmitted on a 4G link.
Steady yellow
A 3G link is present
Data is being received or transmitted on a 3G link.
Off
No 3G/4G link is present or no 4G modem is installed.
LTE LED (applicable only to the MSR810-LM-SI/MSR810-LM-EA/MSR810-LM-EI router model)
Steady green
The device is operating in 4G mode and the 4G network signals are strong.
The device is operating in 4G mode, and the 4G network signals are moderate.
The device is operating in 4G mode, and the 4G network signals are weak.
Steady yellow
The device is operating in 2G/3G mode and the 2G/3G network signals are strong.
The device is operating in 2G/3G mode, and the 2G/3G network signals are moderate.
The device is operating in 2G/3G mode, and the 2G/3G network signals are weak.
Off
The device is not connected to a wireless network, or no 4G modem is installed.
SIM card slot LED (SIM0 and SIM1)
Steady green
A SIM card is present.
The SIM card is being used for dial-up.
The 4G port for the SIM card is sending or receiving data.
Steady yellow
The SIM card is faulty.
Off
No SIM card is present, or the 4G module is not present or is being initialized.
Signal strength LEDs
Four green LEDs on
Excellent 4G signal strength.
Three green LEDs on
Good 4G signal strength.
Two green LEDs on
Fair 4G signal strength.
One green LED on
Poor 4G signal strength.
Four yellow LEDs on
Excellent 2G/3G signal strength.
Three yellow LEDs on
Good 2G/3G signal strength.
Two yellow LEDs on
Fair 2G/3G signal strength.
One yellow LED on
Poor 2G/3G signal strength.
Four LEDs off
Faint signal strength. The network is unavailable.
2.4G WLAN status LED
Steady green
A 2.4G WLAN link is present.
Flashing green
Data is being received or transmitted on a 2.4G WLAN link.
Off
No 2.4G WLAN link is present.
5G WLAN status LED
Steady green
A 5G WLAN link is present.
Flashing green
Data is being received or transmitted on a 5G WLAN link.
Off
No 5G WLAN link is present.
CNDE LED
Steady green
A link is present between the router and another device, but data encryption is not performed.
Date is being encrypted.
Off
No power is input or no data is being encrypted.
SFP port LED
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
No link is present.
SFP port LED (applicable only to the RT-MSR810-SI/MSR810-EI/MSR810-LM-SI/MSR810-LM-EA/MSR810-LM-EI router model)
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present.
Flashing yellow
Data is being received or transmitted at 100 Mbps.
Off
No link is present.
PoE LED
Steady green
PoE is operating correctly.
PoE has failed.
Off
PoE is disabled.
SD card LED
Steady green
The SD card is present and has passed the test.
Flashing green
A write operation has occurred.
Off
