H3C MSR810 Routers Hardware Information and Specifications-6W104
HomeSupportRoutersMSR810 SeriesProduct LiteratureHardware Information & SpecificationsH3C MSR810 Routers Hardware Information and Specifications-6W104
01-Chassis Views and Technical Specifications
01-Chassis Views and Technical Specifications 3.46 MB
1 Chassis views
IMPORTANT
IMPORTANT:
The router provides a reset (RESET) button for rebooting the system and restoring the factory default settings. To reboot the router, press and hold the reset button for a short time. To reboot the router and restore the factory settings, press and hold the reset button for a minimum of 4 seconds.
The figures in this section are for illustration only.
RT-MSR810
Figure1-1 Front view
(1) Power adapter receptacle
(2) Gigabit Ethernet LAN ports (GE1 to GE4)
(3) Gigabit Ethernet WAN port (GE0)
(4) Gigabit fiber port (SFP5)
(5) Console port
(6) USB port 0
(7) Micro SD card slot
(8) USB port 1
(9) Reset button (RESET)
Figure1-2 Rear view
(1) Grounding screw
RT-MSR810-W
Figure1-3 Front view
(5) Console port
(6) USB port 0
(8) USB port 1
Figure1-4 Rear view
(1) Grounding screw
(2) 2.4G WLAN antenna port
(3) 2.4 G WLAN antenna port
RT-MSR810-W-DB
Figure1-5 Front view
(3) Gigabit Ethernet WAN ports (GE0)
(5) Console port
(6) USB port 0
(8) USB port 1
Figure1-6 Rear view
(1) Grounding screw
(2) 2.4G WLAN antenna port 1
(3) 5G WLAN antenna port 1
(4) 5G WLAN antenna port 2
(5) 2.4G WLAN antenna port 2
RT-MSR810-LM
Figure1-7 Front view
(5) Console port
(6) USB port
(8) Reset button (RESET)
Figure1-8 Rear view
(1) Grounding screw
(2) LTE antenna port 1
(3) 4G SIM card slot
(4) GPS antenna port
(5) LTE antenna port 2
RT-MSR810-LM-CNDE-SJK
Figure1-9 Front view
(5) Console port
(6) USB port
Figure1-10 Rear view
(1) Grounding screw
RT-MSR810-W-LM
Figure1-11 Front view
(5) Console port
(6) USB port
Figure1-12 Rear view
(1) Grounding screw
(3) 2.4G WLAN antenna port
(4) 4G SIM card slot
(5) GPS antenna port
(6) 2.4G WLAN antenna port
(7) LTE antenna port 2
RT-MSR810-10-PoE-Plus
Figure1-13 Front view
(1) Gigabit Ethernet LAN ports (GE2 to GE9)
(2) Gigabit Ethernet WAN port (GE0)
(3) Gigabit combo interface (GE1/SFP1)
(4) Console port
(5) Reset button (RESET)
(6) USB port
(7) SD card slot
Figure1-14 Rear view
(1) AC power receptacle
(2) Grounding screw
(3) Security slot
RT-MSR810-LM-HK
Figure1-15 Front view
(5) Console port
(6) USB port
Figure1-16 Rear view
(1) Grounding screw
RT-MSR810-W-LM-HK
Figure1-17 Front view
(5) Console port
(6) USB port
Figure1-18 Rear view
(1) Grounding screw
RT-MSR810-LM-GL
Figure1-19 Front view
(5) Console port
(6) USB port
Figure1-20 Rear view
(1) Grounding screw
RT-MSR810-W-LM-GL
Figure1-21 Front view
(5) Console port
(6) USB port
Figure1-22 Rear view
(1) Grounding screw
RT-MSR810-LME
Figure1-23 Front view
(1) LTE antenna port
(2) DC power receptacle
(3) USB port
(4) Reset button (RESET)
(5) Megabit Ethernet ports (FE0 to FE3)
Figure1-24 Rear view
(1) Console port
(2) 4G SIM card slots (SIM0 and SIM1)
(3) Grounding screw
RT-MSR810-LMS-EA/RT-MSR810-LMS/RT-MSR810-LUS
Figure1-25 Front view
(1) LTE antenna port 0
(2) GPS antenna port (reserved for future use)
(3) LTE antenna port 1
(4) USB port
(5) DC power receptacle
(6) Reset button (RESET)
(7) Fast Ethernet ports (FE0 to FE3)
Figure1-26 Rear view
(1) Console port
(2) Grounding screw
(3) 4G SIM card slots (SIM0 and SIM1)
RT-MSR810-CNDE-SJK
Figure1-27 Front view
(5) Console port
(6) USB port
Figure1-28 Rear view
(1) Grounding screw
RT-MSR810-SI/RT-MSR810-EI
Figure1-29 Front view
(3) Console port
(6) USB port
(7) Gigabit Ethernet WAN port (GE0)
Figure1-30 Rear view
(1) Grounding screw
RT-MSR810-LM-SI/RT-MSR810-LM-EA/RT-MSR810-LM-EI
Figure1-31 Front view
(3) Console port
(6) USB port
(7) 4G SIM card slots (SIM0 and SIM1)
(8) Gigabit Ethernet WAN port (GE0)
Figure1-32 Rear view
(1) 4G LTE antenna port 0
(2) 4G LTE antenna port 1
(3) Grounding terminal
2 Technical specifications
Router specifications
Table2-1 Technical specifications (1)
Item
RT-MSR810
RT-MSR810-W
RT-MSR810-W-DB
Console port
1
1
1
1
USB port
2
2
2
1
GE WAN port
1
1
1
2 (one combo copper port)
GE SFP port
1
1
1
1 (combo fiber port)
GE LAN port
4
4
4
8
FE port
N/A
N/A
N/A
N/A
USB Bluetooth adapter
Supported
N/A
N/A
Supported
Micro SD card slot
1
1
1
N/A
SD card slot
N/A
N/A
N/A
1
Built-in 3G/4G module
N/A
N/A
N/A
N/A
LTE antenna port
N/A
N/A
N/A
N/A
WLAN antenna port
N/A
2
4
N/A
GPS antenna port
N/A
N/A
N/A
N/A
Memory
1 GB DDR3
1 GB DDR3
1 GB DDR3
1 GB DDR3
Flash
256 MB
256 MB
256 MB
256 MB
Dimensions (H × W × D) (excluding rubber feet and mounting brackets)
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
44.2 × 330 × 230 mm (1.74 × 12.99 × 9.06 in)
Input voltage
100 VAC to 240 VAC @ 50/60 Hz
Power rating
24 W
24 W
24 W
20 W
Max power output per port
N/A
N/A
N/A
15.4 W
PoE power
N/A
N/A
N/A
150 W
Operating temperature
0°C to 45°C (32°F to 113°F)
Operating humidity
5% RH to 90% RH, non-condensing
5% RH to 95% RH, non-condensing
Table2-2 Technical specifications (2)
Item
RT-MSR810-LM
RT-MSR810-W-LM
RT-MSR810-LM-HK
RT-MSR810-W-LM-HK
Console port
1
1
1
1
1
USB port
1
1
1
1
1
GE WAN port
1
1
1
1
1
GE SFP port
1
1
1
1
1
GE LAN port
4
4
4
4
4
FE port
N/A
N/A
N/A
N/A
N/A
Supported
N/A
Supported
N/A
N/A
Micro SD card slot
1
1
1
1
1
TDD-LTE, FDD-LTE, TD-SCDMA, WCDMA, EVDO, CDMA1x, and GSM
LTE, UMTS (WCDMA), HSDPA, HSUPA, HSPA+, DC-HSPA+, GSM, GPRS, EDGE, and GNSS
LTE antenna port
2
2
2
2
2
WLAN antenna port
N/A
N/A
2
N/A
2
GPS antenna port
1
1
1
1
1
Memory
1 GB DDR3
1 GB DDR3
1 GB DDR3
1 GB DDR3
1 GB DDR3
Flash
256 MB
256 MB
256 MB
256 MB
256 MB
Input voltage
Rated power
24 W
24 W
24 W
24 W
24 W
PoE power
N/A
N/A
N/A
N/A
N/A
Operating humidity
Table2-3 Technical specifications (3)
Item
RT-MSR810-LME
RT-MSR810-LMS
RT-MSR810-LMS-EA
RT-MSR810-LUS
Console port
1
1
1
1
USB port
1
1
1
1
GE WAN port
N/A
N/A
N/A
N/A
GE SFP port
N/A
N/A
N/A
N/A
GE LAN port
N/A
N/A
N/A
N/A
FE port
4
4
4
4
N/A
N/A
N/A
N/A
Micro SD card slot
N/A
N/A
N/A
N/A
TDD-LTE, FDD-LTE, TD-SCDMA, UMTS, GSM, EVDO, CDMA1x, TDD-LTE, FDD-LTE, TD-SCDMA, UMTS, and GSM
TDD-LTE, FDD-LTE, UMTS, and GSM
LTE antenna port
1
2
2
2
WLAN antenna port
N/A
N/A
N/A
N/A
GPS antenna port
N/A
Reserved
Reserved
Reserved
Memory
1 GB DDR3
512 MB DDR3
1 GB DDR3
512 MB DDR3
Flash
256 MB
256 MB
256 MB
256 MB
35 × 115 × 100 mm (1.38 × 4.53 × 3.94 in)
Input voltage
Power rating
10 W
10 W
10 W
10 W
PoE power
N/A
N/A
N/A
N/A
Operating humidity
Table2-4 Technical specifications (4)
Item
RT-MSR810-LM-GL
RT-MSR810-W-LM-GL
RT-MSR810-CNDE-SJK
Console port
1
1
1
USB port
1
1
1
GE WAN port
1
1
1
GE SFP port
1
1
1
GE LAN port
4
4
4
FE port
N/A
N/A
N/A
N/A
N/A
N/A
Micro SD card slot
1
1
1
N/A
4G LET antenna port
2
2
N/A
WLAN antenna port
N/A
2
N/A
GPS antenna port
1
1
N/A
Memory
1 GB DDR3
1 GB DDR3
1 GB DDR3
Flash
256 MB
256 MB
256 MB
Input voltage
Power rating
24 W
24 W
24 W
PoE power
N/A
N/A
N/A
Operating humidity
Table2-5 Technical specifications (5)
Item
RT-MSR810-SI
RT-MSR810-EI
RT-MSR810-LM-SI
RT-MSR810-LM-EA
RT-MSR810-LM-EI
Console port
1
1
1
1
1
USB port
1
1
1
1
1
GE WAN port
1
1
1
1
1
GE SFP port
1
1
1
1
1
Combo interface
N/A
N/A
N/A
N/A
N/A
GE LAN port
4
4
4
4
4
FE port
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Micro SD card slot
N/A
N/A
N/A
N/A
N/A
N/A
N/A
TDD-LTE, FDD-LTE, WCDMA, EGSM, DCS
TDD-LTE, FDD-LTE, WCDMA, HSPA+, GSM, EDGE
4G LET antenna port
N/A
N/A
2
2
2
WLAN antenna port
N/A
N/A
N/A
N/A
N/A
GPS antenna port
N/A
N/A
N/A
N/A
N/A
Memory
512 MB DDR3
1 GB DDR3
512 MB DDR3
1 GB DDR3
1 GB DDR3
Flash
256 MB
256 MB
256 MB
256 MB
256 MB
44 × 210 × 140 mm (1.73 × 8.27 × 5.51 in)
Input voltage
Power rating
12 W
24 W
18 W
24 W
18 W
PoE power
N/A
N/A
N/A
N/A
N/A
0°C to 40°C (32°F to 104°F)
Operating humidity
·     The RT-MSR810-10-PoE-Plus is an upgraded model of the RT-MSR810-10-PoE. The two models have the same specifications except that the RT-MSR810-10-PoE-Plus increases the PoE power to 150 W.
·     For the routers that support a USB Bluetooth adapter, you can connect a USB Bluetooth adapter to a USB port on the device for fast configuration and deployment of the device from your mobile phone. For more information, see H3C MSR&LA Router Series Deployment Guide via Bluetooth.
Antenna specifications
Table2-6 Stick 4G antenna specifications
Item
Specification
Frequency range
791 to 960 MHz/1710 to 2690 MHz
Voltage standing wave ratio (VSWR)
≤ 3.5:1
Input impedance
50 ohms
Gain
·     791 to 960 MHz @ 3.1 dBi
·     1710 to 2690 MHz @ 7.2 dBi
Max power
1 W
Length
166 mm (6.54 in)
Color
Black
Weight
> 22 g (0.78 oz)
–10°C to +60°C (14°F to 140°F)
Table2-7 RT-MSR810-LM-EA stick 4G antenna specifications
Item
Specification
Frequency range
791 to 960 MHz/1700 to 2700 MHz
≤ 2.0
Input impedance
50 ohms
Gain
·     700 to 960 MHz @ 2.04 dBi
·     1700 to 2700 MHz @ 3.7 dBi
Max power
1 W
Length
195 mm (7.68 in)
Color
Black
Weight
> 22 g (0.78 oz)
–40°C to +85°C (-40°F to +185°F)
Table2-8 4G-LTE magnetic mount antenna specifications
Item
Specification
Frequency range
·     680 to 960 MHz
·     1710 to 2700 MHz
2.0:1.5
Input impedance
50 ohms
Gain
2 dBi (peak)
Polarization
Vertical
Magnetic attraction force
> 4 kg (8.82 lb)
Connector type
SMA male connector
Length
5 m (16.40 ft)
Color
Black
Weight
280 g (9.88 oz)
–40°C to +60°C (–40°F to +140°F)
Table2-9 WLAN antenna specifications
Item
Specification
Frequency range
2.4 to 2.5 GHz and 5.15 to 5.8 GHz
1.92:1
Input impedance
50 ohms
Gain
3 dBi
Max power
2 W
Length
133 mm (5.24 in)
Color
Black
Weight
25 g (0.88 oz )
–40°C to +85°C (–40°F to +185°F)
4G antenna extension cable specifications
Table2-10 4G antenna extension cable specifications
Product code
Cable length
Applicable router model
0404A0MH
5 m (16.40 ft)
·     RT-MSR810-LM
·     RT-MSR810-LM-CNDE-SJK
·     RT-MSR810-W-LM
·     RT-MSR810-LM-HK
·     RT-MSR810-W-LM-HK
·     RT-MSR810-LM-GL
·     RT-MSR810-W-LM-GL
·     RT-MSR810-LME
·     RT-MSR810-LMS
·     RT-MSR810-LMS-EA
·     RT-MSR810-LUS
·     RT-MSR810-LM-SI
·     RT-MSR810-LM-EA
·     RT-MSR810-LM-EI
0404A0MJ
10 m (32.81 ft)
3 Link mode of interfaces
Ethernet interfaces on the routers operate differently in link mode. Interfaces that operate in bridge mode are Layer 2 interfaces. Interfaces that operate in route mode are Layer 3 interfaces.
Table3-1 Interfaces that can operate only as Layer 3 Ethernet interfaces
Device model
Interfaces
RT-MSR810
N/A
RT-MSR810-W
N/A
RT-MSR810-W-DB
N/A
RT-MSR810-LM
N/A
N/A
RT-MSR810-W-LM
N/A
GE0, Combo 1 (GE1, SFP1)
RT-MSR810-LM-HK
N/A
RT-MSR810-W-LM-HK
N/A
RT-MSR810-LM-GL
N/A
RT-MSR810-W-LM-GL
N/A
RT-MSR810-LME
N/A
RT-MSR810-LMS-EA/MSR810-LMS/MSR810-LUS
N/A
RT-MSR810-CNDE-SJK
N/A
RT-MSR810-SI/MSR810-EI
N/A
RT-MSR810-LM-SI/MSR810-LM-EA/MSR810-LM-EI
N/A
Table3-2 Interfaces that support Layer 2/Layer 3 interface type switching
Device model
Interfaces
RT-MSR810
GE0 to GE4, SFP5
RT-MSR810-W
GE0 to GE4, SFP5
RT-MSR810-W-DB
GE0 to GE4, SFP5
RT-MSR810-LM
GE0 to GE4, SFP5
GE0 to GE4, SFP5
RT-MSR810-W-LM
GE0 to GE4, SFP5
GE2 to GE9
RT-MSR810-LM-HK
GE0 to GE4, SFP5
RT-MSR810-W-LM-HK
GE0 to GE4, SFP5
RT-MSR810-LM-GL
GE0 to GE4, SFP5
RT-MSR810-W-LM-GL
GE0 to GE4, SFP5
RT-MSR810-LME
FE0 to FE3
FE0 to FE3
RT-MSR810-CNDE-SJK
GE0 to GE4, SFP5
GE0 to GE4, SFP5
GE0 to GE4, SFP5
As from R6728P19, you can change the GE0 and SFP5 interfaces on the RT-MSR810-W-LM-GL router as LAN interfaces by using the command line.
