- 15-WLAN Command Reference (AC)
- 01-WLAN hardware compatibility (ACs)
- 02-AP management commands
- 03-Radio management commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WIPS commands
- 08-WLAN QoS commands
- 09-WLAN roaming commands
- 10-WLAN load balancing commands
- 11-WLAN radio resource measurement commands
- 12-Channel scanning commands
- 13-Band navigation commands
- 14-WLAN multicast optimization commands
- 15-WLAN RRM commands
- 16-WLAN IP snooping commands
- 17-WLAN probe commands
- 18-Spectrum management commands
18-Spectrum management commands | 55.32 KB |
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
channel-capability mode
Use channel-capability mode to set the client channel capability match mode.
Use undo channel-capability mode to restore the default.
channel-capability mode { all | none | partial }
In radio view, the configuration in an AP group's radio view is used.
In an AP group's radio view, client channel capabilities are not checked.
Radio view
all: Specifies the all mode. A client is allowed to associate with a radio only when all its supported channels match the radio's supported channels.
none: Specifies the none mode. Client channel capabilities are not checked.
partial: Specifies the partial mode. A client is allowed to associate with a radio as long as one of its supported channels matches any one of the radio's supported channels.
This command is available only for 5 GHz radios.
The configuration in radio view takes precedence over the configuration in an AP group's radio view.
# Set the client channel capability match mode to all for radio 1 of AP ap1.
[Sysname] wlan ap ap1 model WA4320i-ACN
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] spectrum-management enable
[Sysname-wlan-ap-ap1-radio-1] channel-capability mode all
# Set the client channel capability match mode to all for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-ACN
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] spectrum-management enable
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] channel-capability mode all
spectrum-management
channel-switch mode
Use channel-switch mode to set the channel switch mode.
Use undo channel-switch mode to restore the default.
channel-switch mode { continuous | suspend }
In an AP group's radio view, all online clients stop sending frames during channel switch.
Radio view
AP group radio view
continuous: Configures the online clients to continue sending frames during channel switch.
suspend: Configures the online clients to stop sending frames during channel switch until channel switch is complete.
This command takes effect on a radio only when the radio operates in 5 GHz mode and is enabled with spectrum management.
# Set the channel switch mode to continuous for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] channel-switch mode continuous
# Set the channel switch mode to continuous for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] channel-switch mode continuous
spectrum-management
power-capability mode
Use power-capability mode to set the transmit power capability match mode.
Use undo power-capability mode to restore the default.
power-capability mode { all | none | partial }
In an AP group's radio view, client transmit power capabilities are not checked.
Radio view
AP group radio view
all: Specifies the all mode. A client is allowed to associate with a radio only when all its transmit power capabilities match the radio's transmit power capabilities.
none: Specifies the none mode. Client transmit power capabilities are not checked.
partial: Specifies the partial mode. A client is allowed to associate with a radio as long as one of its transmit power capabilities matches the radio's transmit power capabilities.
This command takes effect only when you enable spectrum management or radio resource measurement. For more information about radio resource measurement, see WLAN Configuration Guide.
# Set the client power capability match mode to all for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] power-capability mode all
# Set the client power capability match mode to all for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] power-capability mode all
resource-measure
spectrum-management
power-constraint mode
Use power-constraint mode to set the power constraint mode.
Use undo power-constraint mode to restore the default.
power-constraint mode { auto [ anpi-interval anpi-interval-value ] | manual power-constraint }
In an AP group's radio view, the power constraint mode is auto.
Radio view
AP group radio view
auto: Specifies the auto mode.
anpi-interval anpi-interval-value: Adds a value to the average noise power indicator (ANPI) for the device to calculate the power constraint value, in the range of 0 to 30 in dBm. The default value is 10 dBm.
manual power-constraint: Specifies the power constraint value in the range of 0 to 30 dBm.
If you specify the auto mode, the device calculates the power constraint value by using this formula: power-constraint = Received Channel Power Indicator (RCPI) minus (ANPI + anpi-interval-value).
# Set the power constraint mode to manual and set the power constraint value to 5 dBm for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] power-constraint mode manual 5
# Set the power constraint mode to manual and set the power constraint value to 5 dBm for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-ACN-radio-1] power-constraint mode manual 5
resource-measure
spectrum-management
spectrum-management
Use spectrum-management enable to enable spectrum management.
Use spectrum-management disable to disable spectrum management.
Use undo spectrum-management to restore the default.
spectrum-management { disable | enable }
In an AP group's radio view, spectrum management is disabled.
Radio view
AP group radio view
# Enable spectrum management for radio 1 of AP ap1.
# Enable spectrum management for radio 1 of APs with model WA4320i-ACN in AP group apgroup1.
