- 15-WLAN Command Reference (AC)
- 01-WLAN hardware compatibility (ACs)
- 02-AP management commands
- 03-Radio management commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WIPS commands
- 08-WLAN QoS commands
- 09-WLAN roaming commands
- 10-WLAN load balancing commands
- 11-WLAN radio resource measurement commands
- 12-Channel scanning commands
- 13-Band navigation commands
- 14-WLAN multicast optimization commands
- 15-WLAN RRM commands
- 16-WLAN IP snooping commands
- 17-WLAN probe commands
- 18-Spectrum management commands
09-WLAN roaming commands | 46.28 KB |
display wlan mobility roam-count
display wlan mobility roam-track mac-address
snmp-agent trap enable wlan mobility
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
Use display wlan mobility roam-count to display the number of roamings for each client on the AC.
# Display the number of roamings for each client on the home AC.
<Sysname> display wlan mobility roam-track mac-address 5250-0012-0411
<Sysname> display wlan mobility roam-count
MAC address Count
5250-0012-0411 0
9cd3-6d9d-ea3c 3
8007-3fed-aa6c 8
MAC address |
Client MAC address. |
Count |
Number of roamings. |
Use display wlan mobility roam-track mac-address to display roaming information for a client on the AC.
display wlan mobility roam-track mac-address mac-address
mac-address mac-address: Specifies a client by its MAC address, in the form of H-H-H.
Roaming information is displayed in sequence. The most recent roam-track information is displayed the first.
# Display roaming information for the specified client on the home AC.
Total entries: 2
BSSID Created at Online time AC IP address RID AP name
000f-e203-7777 2016-06-14 11:12:28 00hr 01min 02sec 127.0.0.1 1 ap2
000f-e200-4444 2016-06-14 11:12:04 00hr 03min 51sec 127.0.0.1 1 ap1
BSSID |
BSSID of the AP with which the client is associated. |
Created at |
Time when a roam-track entry was created for the client. |
Online time |
Online time of the client. |
AC IP address |
IP address of the AC with which the client is associated. This field is fixed to 127.0.0.1. |
RID |
ID of the radio with which the client is associated. |
AP name |
Name of the AP with which the client is associated. |
Use snmp-agent trap enable wlan mobility to enable SNMP notifications for WLAN roaming.
Use undo snmp-agent trap enable wlan mobility to disable SNMP notifications for WLAN roaming.
SNMP notifications are disabled for WLAN roaming.
To report critical WLAN roaming events to an NMS, enable SNMP notifications for WLAN roaming. For WLAN roaming event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for WLAN roaming.
[Sysname] snmp-agent trap enable wlan mobility
