- 15-WLAN Command Reference (AC)
- 01-WLAN hardware compatibility (ACs)
- 02-AP management commands
- 03-Radio management commands
- 04-WLAN access commands
- 05-WLAN security commands
- 06-WLAN authentication commands
- 07-WIPS commands
- 08-WLAN QoS commands
- 09-WLAN roaming commands
- 10-WLAN load balancing commands
- 11-WLAN radio resource measurement commands
- 12-Channel scanning commands
- 13-Band navigation commands
- 14-WLAN multicast optimization commands
- 15-WLAN RRM commands
- 16-WLAN IP snooping commands
- 17-WLAN probe commands
- 18-Spectrum management commands
06-WLAN authentication commands | 174.58 KB |
client-security accounting-delay time
client-security accounting-restart trigger ipv4
client-security accounting-start trigger
client-security accounting-update trigger
client-security authentication critical-vlan
client-security authentication fail-vlan
client-security authorization trigger byod
client-security authentication-location
client-security authentication-mode
client-security authorization-fail offline
client-security ignore-authentication
client-security ignore-authorization
client-security intrusion-protection action
client-security intrusion-protection enable
client-security intrusion-protection timer temporary-block
client-security intrusion-protection timer temporary-service-stop
display wlan client-security block-mac
display wlan mobility roam-track mac-address
display wlan statistics accounting
mac-authentication fast-connect enable
wlan authentication optimization
wlan client-security authentication clear-previous-connection
For information about MSR routers that can function as ACs, see "Compatibility of hardware and AC functionality."
client url-redirect acl
Use client url-redirect acl to specify an ACL to match traffic that triggers URL redirection.
Use undo client url-redirect acl to restore the default.
client url-redirect acl acl-number
No ACL is specified to match traffic that triggers URL redirection.
Service template view
acl-number: Specifies an ACL by its number, in the range of 2000 to 3999.
By default, the device uses the authorization ACL deployed by the RADIUS server to match traffic that triggers URL redirection. Rule conflicts might exist if the authorization ACL is used by multiple features. To avoid undesirable redirection results, specify a dedicated ACL to match traffic that triggers URL redirection.
This command is configurable when the service template is disabled, and it takes effect after the service template is enabled.
# In service template service1, specify ACL 3111 to match traffic that triggers URL redirection.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] client url-redirect acl 3111
client url-redirect enable
Use client url-redirect enable to enable URL redirection for WLAN clients.
Use undo client url-redirect enable to disable URL redirection for WLAN clients.
client url-redirect enable [ mode native [ https [ redirect-stop-timer seconds ] [ count number ] ] ]
URL redirection is disabled for WLAN clients
mode native: Sets the URL redirection mode to native mode. In this mode, the device redirects a MAC authentication client if it does not have a redirect URL access record for that client in the local cache.
https: Stops redirecting an HTTPS client if the number of its visits to the IP addresses of the redirect URL has reached the limit before the redirect stop timer expires.
redirect-stop-timer seconds: Sets the redirect stop timer in seconds. The value range for the seconds argument is 1 to 30 seconds and the default setting is 5 seconds.
count number: Sets the minimum number of visits to the IP addresses of the redirect URL. The value range for the number argument is 3 to 60 and the default setting is 3.
This command takes effect only on clients that use RADIUS-based MAC authentication.
In RADIUS-based MAC authentication, a client can pass authentication only if the RADIUS server has its credential information (username and password) and MAC address.
URL redirection facilitates a client to authenticate to the RADIUS server after it has failed a MAC authentication because the server does not have its credential information and MAC address. This feature redirects the client to a specified authentication webpage URL for portal authentication. After the client passes portal authentication, the RADIUS server records the client's credential information and MAC address. At the same time, the server uses DM requests to log off the client. At the next MAC authentication attempt, the client can pass MAC authentication. For information about DMs, see AAA in Security Configuration Guide.
Typically, redirect decisions are made on the RADIUS server. If the RADIUS server contains MAC authentication information about a client, the client can pass authentication without being redirected to the redirect URL. To make sure all clients visit the redirect URL for purposes such as advertisement, set the URL redirection mode to native mode. In this mode, the device maintains a redirect URL access records for clients and makes a URL redirection decision based on the records, as follows:
· Redirects the client if no URL access record is found for the client.
· Stops redirecting an HTTP client if an URL access record exists for the client.
· Stops redirecting an HTTPS client if the number of its visits to the IP addresses of the redirect URL has reached the specified limit before the redirect stop timer expires.
IMPORTANT: The native redirection mode must be used together with the client url-redirect acl command. |
# Enable native URL redirection for WLAN clients in service template service1. Stop redirecting an HTTPS client if that client has visited the IP addresses of the redirect URL for 10 times or more within 10 seconds.
[Sysname-wlan-st-service1] client url-redirect enable mode native https redirect-stop-timer 10 count 10
Use client-security accounting-delay time to configure the accounting delay.
Use undo client-security accounting-delay time to restore the default.
client-security accounting-delay time time [ no-ip-logoff ]
The device sends a start-accounting request for a client only when the device learns the IP address of that client.
time: Sets the accounting delay timer. The value range for the time argument is 1 to 600 seconds.
no-ip-logoff: Logs off a client if the device has failed to obtain the client IP address before the delay timer expires. If you do not specify this keyword, the device sends a start-accounting request immediately after the accounting delay timer expires.
The accounting delay timer operates in conjunction with an IP-based accounting-start trigger. The timer specifies the maximum interval for the device to learn the IP address of an 802.1X or MAC authenticated client before it takes the specified action.
The timer starts when a client passes 802.1X or MAC authentication. If the device has failed to learn an IP address that matches the IP-based accounting-start trigger before the accounting delay timer expires, the device takes either of the following actions:
· Sends a start-accounting request immediately if the no-ip-logoff action is not specified.
· Logs off the client if the no-ip-logoff action is specified.
Configure the accounting delay timer depending on the typical amount of time for the device to learn the IP address of a client. As a best practice, increase the delay timer on a low-performance network.
The timer takes effect only on clients that come online after the timer is configured.
# Set the accounting delay timer to 15 seconds in service template service1. Configure the device to log off a client if it has failed to learn the required client IP address before the delay timer expires.
[Sysname-wlan-st-service1] client-security accounting-delay time 15 no-ip-logoff
Use client-security accounting-restart trigger ipv4 to enable the IPv4 address-based accounting-restart trigger for clients.
Use undo client-security accounting-restart trigger ipv4 to disable the IPv4 address-based accounting-restart trigger for clients.
client-security accounting-restart trigger ipv4 [ delay interval ]
The IPv4 address-based accounting-restart trigger is disabled.
delay interval: Sets the delay for the device to send a start-accounting request for another accounting cycle after it sends a stop-accounting request. The value range for the interval argument is 0 to 20 seconds. The default delay time is 15 seconds.
The IPv4 address-based accounting-restart trigger applies to 802.1X and MAC authentication clients.
This trigger restarts accounting for a client by sending a stop-accounting request and then a start-accounting request to the accounting server when the IPv4 address of the client changes.
This trigger has higher priority than the accounting-update trigger configured for IPv4 by using the client-security accounting-update trigger command.
This trigger is configurable when the service template is disabled, and it takes effect after the service template is enabled.
# Enable the IPv4 address-based accounting-restart trigger in service template service1.
[Sysname-wlan-st-service1] client-security accounting-restart trigger ipv4
Use client-security accounting-start trigger to configure an accounting-start trigger for clients.
Use undo client-security accounting-start trigger to restore the default.
client-security accounting-start trigger { ipv4 | ipv4-ipv6 | ipv6 | none }
The accounting-start trigger is based on IPv4 address type.
ipv4: Sends a start-accounting request if an 802.1X or MAC authenticated client uses an IPv4 address.
ipv4-ipv6: Sends a start-accounting request if an 802.1X or MAC authenticated client uses an IPv4 or IPv6 address.
ipv6: Sends a start-accounting request if an 802.1X or MAC authenticated client uses an IPv6 address.
none: Sends a start-accounting request when a client passes authentication without examining its IP address type.
This command takes effect only on clients that have passed 802.1X or MAC authentication. For more information about accounting, see AAA in Security Configuration Guide.
For the accounting-start trigger to take effect, follow these guidelines:
· If the trigger is IP address type based, you must enable learning IP addresses of that type. For information about wireless client IP address learning, see WLAN IP snooping in WLAN Configuration Guide.
· The IP-based trigger must match the requirement of the accounting server for the IP version.
The trigger takes effect only on clients that come online after the trigger is configured.
# Configure an IPv4 address-based accounting-start trigger in service template service1.
[Sysname-wlan-st-service1] client-security accounting-start trigger ipv4
client ipv4-snooping arp-learning enable
client ipv4-snooping dhcp-learning enable
client ipv6-snooping dhcpv6-learning enable
client ipv6-snooping nd-learning enable
client ipv6-snooping snmp-nd-report enable
Use client-security accounting-update trigger to specify an event-based accounting-update trigger.
Use undo client-security accounting-update trigger to restore the default.
client-security accounting-update trigger { ipv4 | ipv4-ipv6 | ipv6 }
No event-based accounting-update trigger is configured. The device sends update-accounting requests to the accounting server only regularly at server-assigned or user-defined real-time accounting intervals.
ipv4: Sends an update-accounting request when the IPv4 address of an online 802.1X or MAC authenticated client changes.
ipv4-ipv6: Sends an update-accounting request when the IPv4 or IPv6 address of an online 802.1X or MAC authenticated client changes.
ipv6: Sends an update-accounting request when the IPv6 address of an online 802.1X or MAC authenticated client changes.
Use the accounting-update trigger in conjunction with the accounting-start trigger. The accounting-update trigger takes effect only if you have configured the accounting-start trigger by using the client-security accounting-start trigger command.
In addition to the event-based accounting-update trigger, you can set a regular accounting-update interval by using the timer realtime-accounting command.
The accounting-update trigger takes effect only on clients that come online after the trigger is configured.
# Configure an IPv4 address change-based accounting-update trigger in service template service1.
[Sysname-wlan-st-service1] client-security accounting-update trigger ipv4
timer realtime-accounting (Security Command Reference)
Use client-security authentication critical-vlan to configure a critical VLAN for a service template.
Use undo client-security authentication critical-vlan to restore the default.
client-security authentication critical-vlan vlan-id
No critical VLAN exists for a service template.
vlan-id: Specifies the ID of the critical VLAN, in the range of 1 to 4094.
The WLAN critical VLAN accommodates clients that have failed WLAN authentication because all RADIUS servers in their ISP domains are unreachable. Clients in the critical VLAN can access a limited set of network resources depending on the configuration.
The authenticator reauthenticates a client in the critical VLAN at the interval of 30 seconds.
· If the client passes the reauthentication, the authenticator assigns the client to the authorization VLAN. If no authorization VLAN is configured, the client is assigned to the initial VLAN.
· If the client fails the reauthentication because all the RADIUS servers are unreachable, the client is still in the critical VLAN.
· If the client fails the reauthentication for any reason other than unreachable servers, the device assigns the client to the Auth-Fail VLAN. If no Auth-Fail VLAN is configured, the device handles the client depending on the intrusion protection setting. If the intrusion protection feature is not configured, the device logs off the client.
The critical VLAN feature does not take effect on clients that use RSNA. When these clients fail authentication because all the RADIUS servers are unreachable, the authenticator directly logs off the clients.
# Configure VLAN 10 as the critical VLAN in service template 1.
[Sysname-wlan-st-service1] client-security authentication critical-vlan 10
Use client-security authentication fail-vlan to configure an Auth-Fail VLAN for a service template.
Use undo client-security authentication fail-vlan to restore the default.
client-security authentication fail-vlan vlan-id
No Auth-Fail VLAN exists for a service template.
vlan-id: Specifies the ID of the Auth-Fail VLAN, in the range of 1 to 4094. Make sure the VLAN has been created.
The WLAN Auth-Fail VLAN accommodates clients that have failed WLAN authentication because of the failure to comply with the organization security strategy. For example, the VLAN accommodates clients that have entered invalid passwords. The Auth-Fail VLAN does not accommodate WLAN clients that have failed authentication for authentication timeouts or network connection problems.
# Configure VLAN 10 as the Auth-Fail VLAN in service template 1.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] client-security authentication fail-vlan 10
Use client-security authorization trigger byod to enable the BYOD authorization trigger.
Use undo client-security authorization trigger byod to disable the BYOD authorization trigger.
The BYOD authorization trigger is disabled.
This command enables the access device to trigger BYOD authorization for an authenticated client after the device obtains that client's BYOD information, including its IP address. When BYOD authorization is triggered, the session-timeout timer assigned to the client restarts, extending the amount of time that the client can stay online before a reauthentication is required. On a low performance network, it might take so much time for a client to obtain an IP address that its extended amount of online time becomes undesirable.
As a best practice to avoid this undesirable issue, use this command only if BYOD authorization is required and make sure the network performance is good. For more information about BYOD authorization, see AAA in Security Configuration Guide.
# Enable the BYOD authorization trigger in service template service1.
[Sysname-wlan-st-service1] client-security authorization trigger byod
Use client-security authentication-location to specify the authenticator for WLAN clients.
Use undo client-security authentication-location to restore the default.
client-security authentication-location { ac | ap }
The AC acts as the authenticator to authenticate WLAN clients.
ac: Specifies the AC as the authenticator.
ap: Specifies the AP as the authenticator.
You cannot specify the AP as the authenticator if the AC is configured to forward client data traffic (by using the client forwarding-location command). For information about the client forwarding-location command, see "WLAN access commands."
# Configure the AC as the authenticator for WLAN clients in service template s1.
[Sysname] wlan service-template s1
[Sysname-wlan-st-s1] client-security authentication-location ac
Use client-security authentication-mode to set the authentication mode for WLAN clients.
Use undo client-security authentication-mode to restore the default.
client-security authentication-mode { dot1x | dot1x-then-mac | mac | mac-and-dot1x | mac-then-dot1x | oui-then-dot1x }
The WLAN authentication mode is Bypass. The device does not perform authentication for WLAN clients.
dot1x: Performs only 802.1X authentication for the attached clients. A client cannot access the network if it fails 802.1X authentication.
dot1x-then-mac: Performs 802.1X authentication for the attached clients first, and then MAC authentication if they fail 802.1X authentication. If a client passes 802.1X authentication, MAC authentication is not performed. A client cannot access the network if it does not pass either authentication.
mac: Performs only MAC authentication for the attached clients. A client cannot access the network if it fails MAC authentication.
mac-and-dot1x: Performs MAC authentication for the attached clients first, and then 802.1X authentication. The attached clients must pass MAC authentication and then 802.1X authentication before they can access the network. A client cannot access the network if it fails MAC authentication or 802.1X authentication.
mac-then-dot1x: Performs MAC authentication for the attached clients first, and then 802.1X authentication if they fail MAC authentication. If a client passes MAC authentication, 802.1X authentication is not performed. A client cannot access the network if it does not pass either authentication.
oui-then-dot1x: Performs OUI authentication for the attached clients first, and then 802.1X authentication if they fail OUI authentication. If a client passes OUI authentication, 802.1X authentication is not performed. A client cannot access the network if it does not pass either authentication.
A service template allows access of multiple authenticated clients in any authentication mode. To set the maximum number of 802.1X clients, use the dot1x max-user command. To set the maximum number of MAC authentication clients, use the mac-authentication max-user command.
# Set the authentication mode to mac for WLAN clients in service template service1.
[Sysname-wlan-st-service1] client-security authentication-mode mac
Use client-security authorization-fail offline to enable the authorization-fail-offline feature.
Use undo client-security authorization-fail offline to disable the authorization-fail-offline feature.
The authorization-fail-offline feature is disabled.
The authorization-fail-offline feature logs off WLAN clients that fail ACL or user profile authorization.
A WLAN client fails ACL or user profile authorization in the following situations:
· The device or server fails to authorize the specified ACL or user profile to the client.
· The authorized ACL or user profile does not exist.
If this feature is disabled, the device does not log off WLAN clients that fail ACL or user profile authorization. However, the device outputs logs to report the failure.
# Enable the authorization-fail-offline feature for service template service1.
[Sysname-wlan-st-service1] client-security authorization-fail offline
Use client-security ignore-authentication to configure the device to ignore the 802.1X or MAC authentication failures.
Use undo client-security ignore-authentication to restore the default.
The device does not ignore the authentication failures for wireless clients that use 802.1X authentication or RADIUS-based MAC authentication.
This command applies to the following clients:
· Clients that use 802.1X authentication.
This command enables the device to ignore the 802.1X authentication failures and allow clients that have failed 802.1X authentication to come online.
· Clients that use both RADIUS-based MAC authentication and portal authentication.
Typically, a client must pass MAC authentication and portal authentication in turn to access network resources. The client provides username and password each time portal authentication is performed.
This command simplifies the authentication process for a client as follows:
¡ If the RADIUS server already records the client's MAC authentication information, the client passes MAC authentication. The device allows the client to access network resources without performing portal authentication.
¡ If the RADIUS server does not record the client's MAC authentication information, the client fails MAC authentication. The device ignores the MAC authentication failure and performs portal authentication for the client. If the client passes portal authentication, it can access network resources. The MAC address of the portal authenticated client will be recorded as MAC authentication information on the RADIUS server.
For 802.1X clients that use RSN to roam to a new AP, do not use this command.
# Configure the device to ignore 802.1X or MAC authentication failures in service template service1.
[Sysname-wlan-st-service1] client-security ignore-authentication
Use client-security ignore-authorization to configure the device to ignore the authorization information received from the authentication server (a RADIUS server or the local device).
Use undo client-security ignore-authorization to restore the default.
The device uses the authorization information from the server.
After a client passes RADIUS or local authentication, the server performs authorization based on the authorization attributes configured for the user account. For example, the server can assign a VLAN. If you do not want the device to use these authorization attributes for clients, configure this command to ignore the authorization information from the server.
# Configure the device to ignore the authorization information from the authentication server for service template service1.
[Sysname-wlan-st-service1] client-security ignore-authorization
Use client-security intrusion-protection action to configure the intrusion protection action that the device takes when intrusion protection detects illegal frames.
Use undo client-security intrusion-protection action to restore the default.
client-security intrusion-protection action { service-stop | temporary-block | temporary-service-stop }
The intrusion protection action is temporary-block.
service-stop: Stops the BSS where an illegal frame is received until the BSS is enabled manually on the radio interface.
temporary-block: Adds the source MAC address of an illegal frame to the blocked MAC address list for a period. To set the period, use the client-security intrusion-protection timer temporary-block command.
temporary-service-stop: Stops the BSS where an illegal frame is received for a period. To set the period, use the client-security intrusion-protection timer temporary-service-stop command.
For this command to take effect, you must also use the client-security intrusion-protection enable command to enable the intrusion protection feature.
# Configure the device to stop the BSS where intrusion protection detects illegal frames for service template service1.
[Sysname-wlan-st-service1] client-security intrusion-protection enable
[Sysname-wlan-st-service1] client-security intrusion-protection action service-stop
Use client-security intrusion-protection enable to enable the intrusion protection feature.
Use undo client-security intrusion-protection enable to disable the intrusion protection feature.
The intrusion protection feature is disabled.
When the device receives an association request from an illegal client, the device takes the predefined protection action on the BSS where the request is received. A client is illegal if its MAC address fails WLAN authentication. To set the protection action, use the client-security intrusion-protection action command.
# Enable the intrusion protection feature for service template service1.
Use client-security intrusion-protection timer temporary-block to set the period during which a MAC address is blocked by intrusion protection.
Use undo client-security intrusion-protection timer temporary-block to restore the default.
client-security intrusion-protection timer temporary-block time
An illegal MAC address is blocked for 180 seconds.
time: Specifies the period during which a MAC address is blocked. The value range is 60 to 300 seconds.
This command takes effect only when the intrusion protection action is temporary-block.
If you change the blocking period after the service template is enabled, the new setting takes effect on the subsequent detected illegal packets.
# Configure service template service1 to block illegal MAC addresses for 120 seconds.
[Sysname-wlan-st-service1] client-security intrusion-protection action temporary-block
[Sysname-wlan-st-service1] client-security intrusion-protection timer temporary-block 120
Use client-security intrusion-protection timer temporary-service-stop to set the BSS silence period for intrusion protection.
Use undo client-security intrusion-protection timer temporary-service-stop to restore the default.
client-security intrusion-protection timer temporary-service-stop time
The BSS silence period for intrusion protection is 20 seconds.
time: Specifies the period during which a BSS is disabled. The value range is 10 to 300 seconds.
This command takes effect only when the intrusion protection action is temporary-service-stop.
If you change the BSS silence period after the service template is enabled, the new setting takes effect on the subsequent detected illegal packets.
# Set the BSS silence period to 30 seconds for intrusion protection in service template service1.
[Sysname-wlan-st-service1] client-security intrusion-protection action temporary-service-stop
[Sysname-wlan-st-service1] client-security intrusion-protection timer temporary-service-stop 30
Use display wlan client-security block-mac to display blocked MAC address information for WLAN clients.
display wlan client-security block-mac [ ap ap-name [ radio radio-id ] ]
ap ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and minus signs (-). If you do not specify this option, the command displays information about all blocked MAC addresses.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify this option, the command displays blocked MAC address information for all radios on the specified AP.
A MAC address that fails authentication is added to the blocked MAC address list when the intrusion protection action is temporary-block.
# Display information about all blocked MAC addresses.
<Sysname> display wlan client-security block-mac
MAC address AP ID RADIO ID BSSID
0002-0002-0002 1 1 00ab-0de1-0001
000d-88f8-0577 1 1 0ef1-0001-02c1
Total entries: 2
MAC address |
Blocked MAC address, in the format of H-H-H. |
AP ID |
AP ID of the blocked MAC address. |
RADIO ID |
Radio ID of the blocked MAC address. |
BSSID |
BSS ID of the blocked MAC address, in the format of H-H-H. |
Number of blocked MAC addresses. |
Related commands:
Use display wlan mobility roam-track mac-address to display roaming track information on the home AC for a client.
display wlan mobility roam-track mac-address mac-address
mac-address: Specifies a client by its MAC address, in the format of H-H-H.
The roaming track entries are displayed in reverse chronological order, with the most recent roaming event displayed first.
If the number of roaming track entries has reached 128, the device deletes the 126th entry when it adds a new track entry.
# Display roaming track information on the home AC for the client with MAC address 5250-0012-0411.
<Sysname> display wlan mobility roam-track mac-address 5250-0012-0411
Total entries : 2
Current entries: 2
BSSID Created at Online time AC IP address RID AP name
3ce5-a68d-2280 2016-06-14 11:12:28 00hr 48min 46sec 192.168.0.2 2 ap1
0026-3e08-1150 2016-06-14 11:12:05 00hr 40min 46sec 127.0.0.1 2 ap2
BSSID |
BSSID of the AP associated with the client. |
Created at |
Time when the roaming track entry was created. |
Online time |
Online duration of the client. |
AC IP address |
IP address of the AC where the client came online. If the client came online on the home AC, this field displays 127.0.0.1. |
RID |
ID of the radio associated with the client. |
AP name |
Name of the AP associated with the client. |
Use display wlan statistics accounting to display RADIUS accounting packet statistics about wireless clients.
# Display RADIUS accounting packet statistics about wireless clients.
<Sysname> display wlan statistics accounting
Account start request : 1
Account start response : 1
Account update request : 3
Account update response : 3
Account stop request : 1
Account stop response : 1
Account start request |
Number of sent RADIUS start-accounting request packets. |
Account start response |
Number of received RADIUS start-accounting response packets. |
Account update request |
Number of sent RADIUS real-time accounting request packets. |
Account update response |
Number of received RADIUS real-time accounting response packets. |
Account stop request |
Number of sent RADIUS stop-accounting request packets. |
Account stop response |
Number of received RADIUS stop-accounting response packets. |
dot1x domain
Use dot1x domain to specify an authentication domain for 802.1X clients in a service template.
Use undo dot1x domain to restore the default.
dot1x domain domain-name
No authentication domain is specified for 802.1X clients in a service template.
domain-name: Specifies an ISP domain by its name, a case-insensitive string of 1 to 255 characters.
802.1X chooses an authentication domain for WLAN clients in the following order:
1. Authentication domain specified in the service template.
2. Domain specified by username.
3. Default authentication domain.
# Specify ISP domain my-domain as the authentication domain for 802.1X clients in service template service1.
[Sysname-wlan-st-service1] dot1x domain my-domain
dot1x eap
Use dot1x eap to specify the EAP mode for 802.1X authentication.
Use undo dot1x eap to restore the default.
dot1x eap { extended | standard }
undo dot1x eap
The EAP mode is standard for 802.1X authentication.
extended: Specifies the extended EAP mode. This mode requires the device to interact with clients according to the provisions and packet format defined by the proprietary EAP protocol.
standard: Specifies the standard EAP mode. This mode requires the device to interact with clients according to the provisions and packet format defined by the standard EAP protocol.
When you configure this command, specify the extended keyword for iNode clients and the standard keyword for other clients.
This command is required only when an IMC server is used as the RADIUS server.
# Set the EAP mode to extended for service template 1.
[Sysname-wlan-st-1] dot1x eap extended
dot1x handshake enable
Use dot1x handshake enable to enable the 802.1X online user handshake feature.
Use undo dot1x handshake enable to disable the 802.1X online user handshake feature.
The 802.1X online user handshake feature is disabled.
The online user handshake feature checks the connection status of online 802.1X clients by periodically sending handshake messages to the clients. The device sets a client to the offline state if it does not receive responses from the client after making the maximum handshake attempts within the handshake timer. To set the handshake timer, use the dot1x timer handshake-period command. To set the maximum handshake attempts, use the dot1x retry command.
# Enable the online user handshake feature for 802.1X clients in service template service1.
[Sysname-wlan-st-service1] dot1x handshake enable
dot1x handshake secure enable
dot1x retry (Security Command Reference)
dot1x timer handshake-period (Security Command Reference)
Use dot1x handshake secure enable to enable the 802.1X online user handshake security feature.
Use undo dot1x handshake secure enable to disable the 802.1X online user handshake security feature.
The 802.1X online user handshake security feature is disabled.
For the 802.1X online user handshake security feature to take effect, you must enable the 802.1X online user handshake feature.
The online user handshake security feature protects only authenticated online 802.1X clients.
# Enable the 802.1X online user handshake security feature in service template service1.
[Sysname-wlan-st-service1] dot1x handshake secure enable
dot1x max-user
Use dot1x max-user to set the maximum number of concurrent 802.1X clients in a service template.
Use undo dot1x max-user to restore the default.
dot1x max-user count
A maximum of 4096 concurrent 802.1X clients are allowed in a service template.
count: Specifies the maximum number of concurrent 802.1X clients. The value range is 1 to 4096.
When the maximum number is reached, the service template denies subsequent 802.1X clients.
# Set the maximum number of concurrent 802.1X clients to 32 in service template service1.
[Sysname-wlan-st-service1] dot1x max-user 500
dot1x re-authenticate enable
Use dot1x re-authenticate enable to enable the 802.1X periodic online user reauthentication feature.
Use undo dot1x re-authenticate enable to disable the 802.1X periodic online user reauthentication feature.
The 802.1X periodic online user reauthentication feature is disabled.
Periodic reauthentication enables the device to periodically authenticate online 802.1X clients in a service template. This feature checks the connection status of online clients and updates the authorization attributes assigned by the server, such as the ACL, VLAN, and user profile.
You can use the dot1x timer reauth-period command to configure the interval for reauthentication.
The server-assigned session timeout timer (Session-Timeout attribute) and termination action (Termination-Action attribute) can affect the periodic online user reauthentication feature. To display the server-assigned Session-Timeout and Termination-Action attributes, use the display dot1x connection command (see Security Command Reference).
· If the termination action is Default (logoff), periodic online user reauthentication on the template takes effect only when the periodic reauthentication timer is shorter than the session timeout timer.
· If the termination action is Radius-request, the periodic online user reauthentication configuration on the template does not take effect. The device reauthenticates the online 802.1X clients after the session timeout timer expires.
# Enable the 802.1X periodic online user reauthentication feature in service template service1.
[Sysname-wlan-st-service1] dot1x re-authenticate enable
dot1x timer (Security Command Reference)
mac-authentication domain
Use mac-authentication domain to specify an authentication domain for MAC authentication clients in a service template.
Use undo mac-authentication domain to restore the default.
No authentication domain is specified for MAC authentication clients in a service template.
MAC authentication chooses an authentication domain for WLAN clients in the following order:
2. Global authentication domain specified in system view.
# Specify ISP domain my-domain as the authentication domain for MAC authentication clients in service template service1.
[Sysname-wlan-st-service1] mac-authentication domain my-domain
Use mac-authentication fast-connect enable to enable fast-connect for MAC authenticated intra-AC roaming clients.
Use undo mac-authentication fast-connect enable to disable fast-connect for MAC authenticated intra-AC roaming clients.
Fast-connect is disabled for MAC authenticated intra-AC roaming clients.
This command allows a MAC authentication roaming client that has been authenticated once on the AC to come online from any APs attached to the AC without re-authentication.
This feature applies only to MAC authentication wireless clients whose authentication location and association location are both on the AC.
This feature affects the displayed roaming state of inter-AC roaming clients that use MAC authentication and requires special configuration for them.
· If a client has roamed between ACs, its roaming state is N/A in the output from the display wlan client verbose command.
· If the inter-AC roaming clients belong to different VLANs, you must make sure the upstream ports of all the ACs in the same roaming group permit traffic from these VLANs to pass through.
# Enable fast-connect for MAC authenticated intra-AC roaming clients in service template service1.
[Sysname-wlan-st-service1] mac-authentication fast-connect enable
Use mac-authentication max-user to set the maximum number of concurrent MAC authentication clients in a service template.
Use undo mac-authentication max-user to restore the default.
mac-authentication max-user count
A maximum of 512 concurrent MAC authentication clients are allowed in a service template.
count: Sets the maximum number of concurrent MAC authentication clients. The value range for this argument is 1 to 512.
When the maximum number is reached, the service template denies subsequent MAC authentication clients.
# Configure service template service1 to support a maximum of 32 concurrent MAC authentication clients.
[Sysname-wlan-st-service1] mac-authentication max-user 32
Use wlan authentication optimization to configure a modifier to adjust the authentication success ratio and abnormal offline ratio for 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
Use undo wlan authentication optimization to restore the default.
wlan authentication optimization value
The modifier is 0. The device does not adjust the authentication success ratio and abnormal offline ratio for 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
value: Sets the modifier, in the range of 900 to 1000. The lower the value, the lower the authentication success ratio, and the higher the abnormal offline ratio.
The authentication success ratio is the ratio of the number of authentication success times to the total number of authentication times. The abnormal offline ratio is calculated by using the following formula: abnormal offline ratio = number of times that clients go offline abnormally ÷ (number of authentication success times + number of current online users).
WLAN authentication statistics optimization uses a modifier to adjust the authentication success ratio and abnormal offline ratio of 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
The modifier takes effect only on RADIUS-based 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
# Set the modifier to 950 to adjust the authentication success ratio and abnormal offline ratio of 802.1X authentication, MAC authentication, and Layer 2 portal authentication.
[Sysname] wlan authentication optimization 950
Use wlan client-security authentication clear-previous-connection to enable the clear-previous-connection feature for WLAN authentication.
Use undo wlan client-security authentication clear-previous-connection to disable the clear-previous-connection feature for WLAN authentication.
The clear-previous-connection feature is disabled for WLAN authentication.
IMPORTANT: When this feature is enabled, the 802.1X reauthentication, WLAN Auth-Fail VLAN, and WLAN critical VLAN features cannot take effect. |
Some RADIUS servers reject to authenticate a client if they have an online user entry for that client. If they fail to remove the online user entry for a client that has gone offline incorrectly, that client will be unable to get authenticated and come online again.
To resolve this issue, use the clear-previous-connection feature.
With this feature, the device checks the local online user entries before it sends an authentication request to the RADIUS server for an 802.1X or MAC authentication client. If an entry is found, the device removes the entry and sends a stop-accounting request to the RADIUS server. Upon receipt of the stop-accounting request, the RADIUS server removes the online user entry. Then, the client can be authenticated correctly.
# Enable the clear-previous-connection feature.
[Sysname] wlan client-security authentication clear-previous-connection
