05-Network Connectivity Configuration Guide
HomeSupportWirelessWX5800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX5800X Series Access Controllers Configuration Guides(E5457)-5W10005-Network Connectivity Configuration Guide
10-PPP configuration
10-PPP configuration 243.64 KB
Configuring PPP·· 1
About PPP· 1
PPP protocols· 1
PPP link establishment process· 1
PPP authentication· 2
PPP for IPv4· 2
PPP for IPv6· 3
Protocols and standards· 3
PPP tasks at a glance· 4
Enabling PPP encapsulation on an interface· 4
Configuring PPP authentication· 4
About PPP authentication· 4
Configuring PAP authentication· 5
Configuring CHAP authentication (authenticator name is configured) 5
Configuring CHAP authentication (authenticator name is not configured) 7
Configuring the polling feature· 7
Configuring PPP negotiation· 8
Configuring the PPP negotiation timeout time· 8
Configuring IP address negotiation on the client 9
Configuring IP address negotiation on the server 9
Enabling IP segment match· 12
Configuring DNS server IP address negotiation on the client 12
Configuring DNS server IP address negotiation on the server 13
Enabling IP header compression· 13
Configuring the NAS-Port-Type attribute· 14
Enabling PPP accounting· 15
Display and maintenance commands for PPP· 15
Configuring PPPoE·· 16
About PPPoE· 16
PPPoE network structure· 16
Protocols and standards· 17
Restrictions: Licensing requirements for PPPoE· 17
Restrictions and guidelines for PPPoE· 17
Configuring the PPPoE server 17
PPPoE server tasks at a glance· 17
Configuring a PPPoE session· 17
Configuring a VA pool 18
Setting the maximum number of PPPoE sessions· 19
Limiting the PPPoE access rate· 20
Configuring the NAS-Port-ID attribute· 21
Display and maintenance commands for PPPoE· 22
Display and maintenance commands for PPPoE server 22
Configuring PPP
About PPP
Point-to-Point Protocol (PPP) is a point-to-point link layer protocol. It provides user authentication, supports synchronous/asynchronous communication, and allows for easy extension.
PPP protocols
PPP includes the following protocols:
·     Link control protocol (LCP)—Establishes, tears down, and monitors data links.
·     Network control protocol (NCP)—Negotiates the packet format and type for data links.
·     Authentication protocols—Authenticate users. Protocols include the following:
¡     Password Authentication Protocol (PAP).
¡     Challenge Handshake Authentication Protocol (CHAP).
Figure 1 shows the PPP link establishment process.
Figure 1 PPP link establishment process
1.     Initially, PPP is in Link Dead phase. After the physical layer goes up, PPP enters the Link Establishment phase (Establish).
2.     In the Link Establishment phase, the LCP negotiation is performed. The LCP configuration options include Authentication-Protocol, Async-Control-Character-Map (ACCM), Maximum-Receive-Unit (MRU), Magic-Number, Protocol-Field-Compression (PFC), Address-and-Control-Field-Compression (ACFC), and MP.
¡     If the negotiation fails, LCP reports a Fail event, and PPP returns to the Dead phase.
¡     If the negotiation succeeds, LCP enters the Opened state and reports an Up event, indicating that the underlying layer link has been established. At this time, the PPP link is not established for the network layer, and network layer packets cannot be transmitted over the link.
3.     If authentication is configured, the PPP link enters the Authentication phase, where PAP or CHAP authentication is performed.
¡     If the client fails to pass the authentication, LCP reports a Fail event and enters the Link Termination phase. In this phase, the link is torn down and LCP goes down.
¡     If the client passes the authentication, LCP reports a Success event.
4.     If a network layer protocol is configured, the PPP link enters the Network-Layer Protocol phase for NCP negotiation, such as IPCP negotiation and IPv6CP negotiation.
¡     If the NCP negotiation succeeds, the link goes up and becomes ready to carry negotiated network-layer protocol packets.
¡     If the NCP negotiation fails, NCP reports a Down event and enters the Link Termination phase.
If the interface is configured with an IP address, the IPCP negotiation is performed. IPCP configuration options include IP addresses and DNS server IP addresses. After the IPCP negotiation succeeds, the link can carry IP packets.
5.     After the NCP negotiation is performed, the PPP link remains active until either of the following events occurs:
¡     Explicit LCP or NCP frames close the link.
¡     Some external events take place (for example, the intervention of a user).
PPP authentication
PPP supports the following authentication methods:
PAP
PAP is a two-way handshake authentication protocol using the username and password.
PAP sends username/password pairs in plain text over the network. If authentication packets are intercepted in transit, network security might be threatened. For this reason, it is suitable only for low-security environments.
CHAP
CHAP is a three-way handshake authentication protocol.
CHAP transmits usernames but not passwords over the network. It transmits the result calculated from the password and random packet ID by using the MD5 algorithm. It is more secure than PAP. The authenticator may or may not be configured with a username. As a best practice, configure a username for the authenticator, which makes it easier for the peer to verify the identity of the authenticator.
PPP for IPv4
On IPv4 networks, PPP negotiates the IP address and DNS server address during IPCP negotiation.
IP address negotiation enables one end to assign an IP address to the other.
An interface can act as a client or a server during IP address negotiation:
·     Client—Obtains an IP address from the server. Use the client mode when the device accesses the Internet through an ISP.
·     Server—Assigns an IP address to the client. Before you configure the IP address of the server, you must perform one of the following tasks:
¡     Configure a local address pool and associate the pool with the ISP domain.
¡     Specify an IP address or an address pool for the client on the interface.
When IP address negotiation is enabled on a client, the server selects an IP address for the client in the following sequence:
1.     If the AAA server configures an IP address or address pool for the client, the server selects that IP address or an IP address from the pool. The IP address or address pool is configured on the AAA server instead of the PPP server. For information about AAA, see User Access and Authentication Configuration Guide.
2.     If an address pool is associated with the ISP domain used during client authentication, the server selects an IP address from the pool.
3.     If an IP address or address pool is specified for the client on the interface of the server, the server selects that IP address or an IP address from that pool.
DNS server address negotiation
IPCP negotiation can determine the DNS server IP address.
When the device is connected to a host, configure the device as the server to assign the DNS server IP address to the host.
When the device is connected to an ISP access server, configure the device as the client. Then, the device can obtain the DNS server IP address from the ISP access server.
PPP for IPv6
On IPv6 networks, PPP negotiates only the IPv6 interface identifier instead of the IPv6 address and IPv6 DNS server address during IPv6CP negotiation.
IPv6 address assignment
PPP cannot negotiate the IPv6 address.
The client can get an IPv6 global unicast address through the following methods:
·     Method 1—The client obtains an IPv6 prefix in an RA message. The client then generates an IPv6 global unicast address by combining the IPv6 prefix and the negotiated IPv6 interface identifier. The IPv6 prefix in the RA message is determined in the following sequence:
¡     IPv6 prefix authorized by AAA.
¡     RA prefix configured on the interface.
¡     Prefix of the IPv6 global unicast address configured on the interface.
For information about the ND protocol, see Network Connectivity Configuration Guide.
·     Method 2—The client requests an IPv6 global unicast address through DHCPv6. The server assigns an IPv6 address to the client from the address pool authorized by AAA. If no AAA-authorized address pool exists, DHCPv6 uses the address pool that matches the server's IPv6 address to assign an IPv6 address to the client. For information about DHCPv6, see Network Connectivity Configuration Guide.
·     Method 3—The client requests prefixes through DHCPv6 and assigns them to downstream hosts. The hosts then use the prefixes to generate global IPv6 addresses. This method uses the same principle of selecting address pools as method 2.
The device can assign a host an IPv6 address in either of the following ways:
·     When the host connects to the device directly or through a bridge device, the device can use method 1 or method 2.
·     When the host accesses the device through a router, the device can use method 3 to assign an IPv6 prefix to the router. The router assigns the prefix to the host to generate an IPv6 global unicast address.
IPv6 DNS server address assignment
On IPv6 networks, two methods are available for the IPv6 DNS address assignment:
·     AAA authorizes the IPv6 DNS address and assigns this address to the host through RA messages.
·     The DHCPv6 client requests an IPv6 DNS address from the DHCPv6 server.
RFC 1661: The Point-to-Point Protocol (PPP)
To configure PPP, perform the following tasks:
1.     Configuring PPP authentication
¡     Configuring PAP authentication
¡     Configuring CHAP authentication (authenticator name is configured)
¡     Configuring CHAP authentication (authenticator name is not configured)
Configure PPP authentication for high-security environments.
2.     (Optional.) Configuring the polling feature
3.     (Optional.) Configuring PPP negotiation
¡     Configuring the PPP negotiation timeout time
¡     Configuring IP address negotiation on the client
¡     Configuring IP address negotiation on the server
¡     Enabling IP segment match
¡     Configuring DNS server IP address negotiation on the client
¡     Configuring DNS server IP address negotiation on the server
4.     (Optional.) Enabling IP header compression
IPHC is often used for voice communications over low-speed links.
5.     (Optional.) Configuring the NAS-Port-Type attribute
6.     (Optional.) Enabling PPP accounting
2.     Enter interface view.
3.     Enable PPP encapsulation on the interface.
link-protocol ppp
By default, all interfaces except Ethernet interfaces, VLAN interfaces, and ATM interfaces use PPP as the link layer protocol.
PPP supports the following authentication modes:
·     PAP.
·     CHAP.
You can configure several authentication modes simultaneously. In LCP negotiation, the authenticator negotiates with the peer in the sequence of configured authentication modes until the LCP negotiation succeeds. If the response packet from the peer carries a recommended authentication mode, the authenticator directly uses the authentication mode if it finds the mode configured.
Restrictions and guidelines for PAP authentication
For local AAA authentication, the username and password of the peer must be configured on the authenticator.
For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server.
The username and password configured for the peer must be the same as those configured on the peer by using the ppp pap local-user command.
Configuring the authenticator
3.     Configure the authenticator to authenticate the peer by using PAP.
ppp authentication-mode pap [ [ call-in ] domain { isp-name | default enable isp-name } ]
By default, PPP authentication is disabled.
4.     Configure local or remote AAA authentication.
For more information about AAA authentication, see User Access and Authentication Configuration Guide.
Configuring the peer
3.     Configure the PAP username and password sent from the peer to the authenticator when the peer is authenticated by the authenticator by using PAP.
ppp pap local-user username password { cipher | simple } string
By default, when being authenticated by the authenticator by using PAP, the peer sends null username and password to the authenticator.
For security purposes, the password specified in plaintext form and ciphertext form will be stored in encrypted form.
Restrictions and guidelines for CHAP authentication (authenticator name is configured)
When you configure the authenticator, follow these guidelines:
·     For local AAA authentication, the username and password of the peer must be configured on the authenticator.
·     For remote AAA authentication, the username and password of the peer must be configured on the remote AAA server.
·     The username and password configured for the peer must meet the following requirements:
¡     The username configured for the peer must be the same as that configured on the peer by using the ppp chap user command.
¡     The passwords configured for the authenticator and peer must be the same.
When you configure the peer, follow these guidelines:
·     For local AAA authentication, the username and password of the authenticator must be configured on the peer.
·     For remote AAA authentication, the username and password of the authenticator must be configured on the remote AAA server.
·     The username and password configured for the authenticator must meet the following requirements:
¡     The username configured for the authenticator must be the same as that configured on the authenticator by using the ppp chap user command.
·     The peer does not support the CHAP authentication password configured by using the ppp chap password command. CHAP authentication (authenticator name is configured) will apply even if the authentication name is configured.
3.     Configure the authenticator to authenticate the peer by using CHAP.
ppp authentication-mode chap [ [ call-in ] domain { isp-name | default enable isp-name } ]
4.     Configure a username for the CHAP authenticator.
ppp chap user username
The default setting is null.
5.     Configure local or remote AAA authentication.
3.     Configure a username for the CHAP peer.
Restrictions and guidelines for CHAP authentication (authenticator name is not configured)
·     The username configured for the peer must be the same as that configured on the peer by using the ppp chap user command.
·     The password configured for the peer must be the same as that configured on the peer by using the ppp chap password command.
4.     Set the CHAP authentication password.
ppp chap password { cipher | simple } string
The polling feature checks PPP link state.
On an interface that uses PPP encapsulation, the link layer sends keepalive packets at keepalive intervals to detect the availability of the peer. If the interface receives no response to keepalive packets when the keepalive retry limit is reached, it determines that the link fails and reports a link layer down event.
To set the keepalive retry limit, use the timer-hold retry command.
The value 0 disables an interface from sending keepalive packets. In this case, the interface can respond to keepalive packets from the peer.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
3.     Set the keepalive interval.
timer-hold seconds
The default setting is 10 seconds.
4.     Set the keepalive retry limit.
timer-hold retry retries
The default setting is 5.
The device starts the PPP negotiation timeout timer after sending a packet. If no response is received before the timer expires, the device sends the packet again.
If two ends of a PPP link vary greatly in the LCP negotiation packet processing rate, configure this command on the end with a higher processing rate. The LCP negotiation delay timer prevents frequent LCP negotiation packet retransmission. After the physical layer comes up, PPP starts LCP negotiation when the delay timer expires. If PPP receives LCP negotiation packets before the delay timer expires, it starts LCP negotiation immediately.
3.     Configure the negotiation timeout time.
ppp timer negotiate seconds
The default setting is 3 seconds.
4.     (Optional.) Set the LCP negotiation delay timer.
ppp lcp delay milliseconds
By default, PPP starts LCP negotiation immediately after the physical layer comes up.
3.     Enable IP address negotiation.
ip address ppp-negotiate
By default, IP address negotiation is not enabled.
If you execute this command and the ip address command multiple times, the most recent configuration takes effect. For more information about the ip address command, see Network Connectivity Command Reference.
Configure the server to assign an IP address to a client by using the following methods:
·     Method 1: Specify an IP address for the client on the server interface.
·     Method 2: Specify a PPP or DHCP address pool on the server interface.
·     Method 3: Associate a PPP or DHCP address pool with an ISP domain.
Restrictions and guidelines for IP address negotiation on the server
For clients requiring no authentication, you can use either method 1 or method 2. When both method 1 and method 2 are configured, the most recent configuration takes effect.
For clients requiring authentication, you can use one or more of the three methods. When multiple methods are configured, method 3 takes precedence over method 1 or method 2. When both method 1 and method 2 are configured, the most recent configuration takes effect.
PPP supports IP address assignment from a PPP or DHCP address pool. If you use a pool name that identifies both a PPP address pool and a DHCP address pool, the system uses the PPP address pool.
When assigning IP address to users through a PPP address pool, make sure the PPP address pool excludes the gateway IP address of the PPP address pool.
Specifying an IP address for the client on the server interface
3.     Configure the interface to assign an IP address to the peer.
remote address ip-address
By default, an interface does not assign an IP address to the peer.
4.     Configure an IP address for the interface.
ip address ip-address
By default, no IP address is configured on an interface.
Specifying a PPP address pool on the server interface
2.     Configure a PPP address pool.
ip pool pool-name start-ip-address [ end-ip-address ] [ group group-name ]
3.     (Optional.) Configure a gateway address for the PPP address pool.
ip pool pool-name gateway ip-address
By default, the PPP address pool is not configured with a gateway address.
4.     (Optional.) Configure a PPP address pool route.
ppp ip-pool route ip-address { mask-length | mask } [ vsrp-instance vsrp-instance-name ]
By default, no PPP address pool route exists.
The destination network of the PPP address pool route must include the PPP address pool.
5.     Enter interface view.
6.     Configure the interface to assign an IP address from the configured PPP address pool to the peer.
remote address pool pool-name
7.     Configure an IP address for the interface.
Specifying a DHCP address pool on the server interface
2.     Configure DHCP.
¡     If the server acts as a DHCP server, perform the following tasks:
-     Configure the DHCP server.
-     Configure a DHCP address pool on the server.
¡     If the server acts as a DHCP relay agent, perform the following tasks:
-     Configure the DHCP relay agent on the server.
-     Configure a DHCP address pool on the remote DHCP server.
-     Enable the DHCP relay agent to record relay entries.
-     Configure a DHCP relay address pool.
For information about configuring a DHCP server and a DHCP relay agent, see Network Connectivity Configuration Guide.
3.     Enter interface view.
4.     Configure the interface to assign an IP address from the configured DHCP address pool to the peer.
5.     (Optional.) Use the PPP usernames as the DHCP client IDs.
remote address dhcp client-identifier username
By default, PPP usernames are not used as DHCP client IDs.
Make sure different users use different PPP usernames to come online.
6.     Configure an IP address for the interface.
Associating a PPP address pool with an ISP domain
By default, no PPP address pool is configured.
5.     Enter ISP domain view.
domain isp-name
6.     Associate the ISP domain with the configured PPP address pool for address assignment.
authorization-attribute ip-pool pool-name
By default, no PPP address pool is associated.
For more information about this command, see User Access and Authentication Command Reference.
7.     Return to system view.
8.     Enter interface view.
9.     Configure an IP address for the interface.
Associating a DHCP address pool with an ISP domain
2.     Configure DHCP.
3.     Enter ISP domain view.
domain isp-name
4.     Associate the ISP domain with the configured DHCP address pool or DHCP relay address pool for address assignment.
By default, no DHCP address pool or DHCP relay address pool is associated.
5.     Return to system view.
6.     Enter interface view.
7.     (Optional.) Use PPP usernames as the DHCP client IDs.
8.     Configure an IP address for the interface.
This feature enables the local interface to check whether its IP address and the IP address of the remote interface are in the same network segment. If they are not, IPCP negotiation fails.
3.     Enable IP segment match.
ppp ipcp remote-address match
During PPP negotiation, the server will assign a DNS server IP address only for a client configured with the ppp ipcp dns request command. For some special devices to forcibly assign DNS server IP addresses to clients that do not initiate requests, configure the ppp ipcp dns admit-any command on these devices.
3.     Enable the device to request the peer for a DNS server IP address.
By default, a client does not request its peer for a DNS server IP address.
4.     Configure the device to accept the DNS server IP addresses assigned by the peer even though it does not request the peer for the DNS server IP addresses.
By default, a device does not accept the DNS server IP addresses assigned by the peer if it does not request the peer for the DNS server IP addresses.
This command is not necessary if the ppp ipcp dns request command is configured.
3.     Specify the primary and secondary DNS server IP addresses to be allocated to the peer in PPP negotiation.
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
By default, a device does not allocate DNS server IP addresses to its peer if the peer does not request them.
After this command is configured, the server allocate DNS server IP addresses to a client that initiates requests.
IP header compression (IPHC) compresses packet headers to speed up packet transmission. IPHC is often used for voice communications over low-speed links.
IPHC provides the following compression features:
·     RTP header compressionCompresses the IP header, UDP header, and RTP header of an RTP packet, which have a total length of 40 bytes.
·     TCP header compression—Compresses the IP header and TCP header of a TCP packet, which have a total length of 40 bytes.
To use IPHC, you must enable it on both sides of a PPP link.
Enabling or disabling IPHC on a VT interface does not immediately take effect. You must execute the shutdown and undo shutdown commands on the interface or the bound physical interface to apply the new setting.
After you enable IPHC, you can configure the maximum number of connections for RTP or TCP header compression. The configuration takes effect after you execute the shutdown and undo shutdown command on the interface. The configuration is removed after IPHC is disabled.
3.     Enable IP header compression.
ppp compression iphc enable [ nonstandard ]
By default, IP header compression is disabled.
The nonstandard option must be specified when the device communicates with a non-H3C device.
When the nonstandard keyword is specified, only RTP header compression is supported and TCP header compression is not supported.
4.     Set the maximum number of connections for which an interface can perform RTP header compression.
ppp compression iphc rtp-connections number
The default setting is 16.
5.     Set the maximum number of connections for which an interface can perform TCP header compression.
ppp compression iphc tcp-connections number
The NAS-Port-Type attribute is used for RADIUS authentication and accounting. For information about the NAS-Port-Type attribute, see RFC 2865.
The configuration of this feature does not affect existing users.
2.     Enter VT interface view.
interface virtual-template number
3.     Configure the NAS-Port-Type attribute.
nas-port-type { ethernet | virtual }
By default, the NAS-Port-Type attribute is determined by the service type and link type of the PPP user as follows:
¡     For the PPPoE service, the NAS-port-type attribute is ethernet.
¡     For the L2TP service, the NAS-port-type attribute is virtual.
PPP accounting collects PPP statistics, including the numbers of received and sent PPP packets and bytes. AAA can use the PPP statistics for accounting. For more information about this command, see User Access and Authentication Configuration Guide.
3.     Enable PPP accounting.
ppp account-statistics enable [ acl { acl-number | name acl-name } ]
By default, PPP accounting is disabled.
Display PPP address pools.
display ip pool [ pool-name | group group-name ]
Display information about PPP access users.
display ppp access-user { interface interface-type interface-number [ count ] | ip-address ipv4-address | ipv6-address ipv6-address | username user-name | user-type { lac | lns | pppoa | pppoe } [ count ] }
Display PPP negotiation packet statistics.
display ppp packet statistics [ slot slot-number ]
Display IPHC statistics.
display ppp compression iphc { rtp | tcp } [ interface interface-type interface-number ]
Log off a PPP user.
reset ppp access-user { ip-address ipv4-address | ipv6-address ipv6-address | username user-name }
Clear IPHC statistics.
reset ppp compression iphc [ rtp | tcp ] [ interface interface-type interface-number ]
Clear PPP negotiation packet statistics.
reset ppp packet statistics [ slot slot-number ]
Configuring PPPoE
About PPPoE
Point-to-Point Protocol over Ethernet (PPPoE) extends PPP by transporting PPP frames encapsulated in Ethernet over point-to-point links.
PPPoE specifies the methods for establishing PPPoE sessions and encapsulating PPP frames over Ethernet. PPPoE requires a point-to-point relationship between peers instead of a point-to-multipoint relationship as in multi-access environments such as Ethernet. PPPoE provides Internet access for the hosts in an Ethernet through a remote access device and implement access control, authentication, and accounting on a per-host basis. Integrating the low cost of Ethernet and scalability and management functions of PPP, PPPoE gained popularity in various application environments, such as residential access networks.
For more information about PPPoE, see RFC 2516.
PPPoE uses the client/server model. The PPPoE client initiates a connection request to the PPPoE server. After session negotiation between them is complete, a session is established between them, and the PPPoE server provides access control, authentication, and accounting to the PPPoE client.
PPPoE network structures are classified into router-initiated and host-initiated network structures depending on the starting point of the PPPoE session.
Router-initiated network structure
As shown in Figure 2, the PPPoE session is established between devices (Device A and Device B). All hosts share one PPPoE session for data transmission without being installed with PPPoE client software. This network structure is typically used by enterprises.
Figure 2 Router-initiated network structure
Host-initiated network structure
As shown in Figure 3, a PPPoE session is established between each host (PPPoE client) and the carrier device (PPPoE server). The service provider assigns an account to each host for billing and control. The host must be installed with PPPoE client software.
Figure 3 Host-initiated network structure
RFC 2516: A Method for Transmitting PPP Over Ethernet (PPPoE)
A license controls the maximum number of PPPoE sessions supported by the device. Before installing a license, make sure your device supports the license. If the device is not installed with a license, the maximum number of PPPoE sessions varies by device model.
For information about licensing, see Fundamentals Configuration Guide.
This feature supports the VLAN interface view.
To configure PPPoE server, perform the following tasks:
1.     Configuring a PPPoE session
2.     (Optional.) Configuring a VA pool
3.     (Optional.) Setting the maximum number of PPPoE sessions
4.     (Optional.) Limiting the PPPoE access rate
5.     (Optional.) Configuring the NAS-Port-ID attribute
2.     Create a VT interface and enter VT interface view.
3.     Set PPP parameters.
For more information setting PPP parameters, see "Configuring PPP."
When configuring PPP authentication, use the PPPoE server as the authenticator.
4.     Enable MRU verification for PPPoE applications.
ppp lcp echo mru verify [ minimum value ]
By default, MRU verification is disabled for PPPoE applications.
7.     Enable the PPPoE server on the interface and bind this interface to the specified VT interface.
pppoe-server bind virtual-template number
By default, the PPPoE server is disabled on the interface.
8.     (Optional.) Configure an access concentrator (AC) name for the PPPoE server.
pppoe-server tag ac-name name
By default, the AC name for the PPPoE server is the device name.
PPPoE clients can choose a PPPoE server according to the AC name. The PPPoE client on H3C devices do not support this feature.
9.     (Optional.) Enable the PPPoE server to support the ppp-max-payload tag and specify a range for the PPP maximum payload.
pppoe-server tag ppp-max-payload [ minimum minvalue maximum maxvalue ]
By default, The PPPoE server does not support the ppp-max-payload tag.
10.     (Optional.) Set a service name for the PPPoE server
pppoe-server tag service-name name
By default, the PPPoE server does not have a service name.
11.     (Optional) Set the response delay time for user access.
pppoe-server access-delay delay-time
By default, no response delay time is set.
12.     Return to system view.
13.     Configure the PPPoE server to perform authentication, authorization, and accounting for PPP users.
For more information, see User Access and Authentication Configuration Guide.
The PPPoE server creates a VA interface for a PPPoE session to transmit packets between PPPoE and PPP, and removes the VA interface when the user goes offline. Creating and removing VA interfaces take time.
You can configure VA pools to improve the performance of PPPoE session establishment and termination. A VA pool contains a group of automatically numbered VA interfaces. The PPPoE server selects a VA interface from the pool for a requesting user and release the VA interface  when the user goes offline. When a VA pool is exhausted, the system creates VA interfaces for new PPPoE sessions, and removes those VA interfaces when the users go offline.
On a VT interface, you can create one global VA pool and one regional VA pool per member device for interfaces bound with the VT interface.
·     The global VA pool contains VA interfaces for logical interfaces that might span multiple devices, such as Ethernet aggregate interfaces.
·     The regional VA pool contains VA interfaces for interfaces that do not span multiple devices, such as Ethernet interfaces.
To change the capacity of a VA pool, you must delete the previous configuration and reconfigure the VA pool.
Creating or removing a VA pool takes time. During the process of creating or removing a VA pool, users can go online or offline, but the VA pool does not take effect.
If the system fails to create a VA pool because of insufficient resources, you can view the available resources by using the display pppoe-server va-pool command.
VA pools are memory intensive. Set their capacity depending on your network requirements.
Deleting a VA pool does not log off the users who are using VA interfaces in the VA pool.
2.     Create a VA pool.
pppoe-server virtual-template template-number [ slot slot-number ] va-pool va-volume
PPPoE can establish a session when none of the following limits are reached:
·     Limit for a user on an interface.
·     Limit for a VLAN on an interface.
·     Limit on an interface.
·     Limit on a card.
·     Limit on an IRF member device.
·     Limit on a device.
Restrictions and guidelines for maximum number of PPPoE sessions
New maximum number settings apply only to subsequently established PPPoE sessions.
The maximum number of PPPoE sessions supported by a device varies by license or device model.
The maximum number of PPPoE sessions set for a device cannot be greater than the maximum number of PPPoE sessions supported by the device.
The total maximum number of PPPoE sessions set for all cards or IRF member devices cannot be greater than the maximum number of PPPoE sessions supported by the device.
Setting the maximum number of PPPoE sessions in interface view
The PPPoE server is enabled on the interface.
3.     Set the maximum number of PPPoE sessions.
¡     Set the maximum number of PPPoE sessions on an interface.
pppoe-server session-limit number
By default, the number of PPPoE sessions on an interface is not limited.
¡     Set the maximum number of PPPoE sessions for a user.
pppoe-server session-limit per-mac number
By default, a user is allowed to create a maximum of 100 PPPoE sessions.
Setting the maximum number of PPPoE sessions in system view
2.     Set the maximum number of PPPoE sessions.
pppoe-server session-limit slot slot-number total number
By default, the number of PPPoE sessions is not limited.
The device can limit the rate at which a user (identified by an MAC address) can create PPPoE sessions on an interface. If the number of PPPoE requests within the monitoring time exceeds the configured threshold, the device discards the excessive requests, and outputs log messages. If the blocking time is set to 0, the device does not block any requests, and it only outputs log messages.
The device uses a monitoring table and a blocking table to control PPP access rates:
·     Monitoring table—Stores a maximum of 8000 monitoring entries. Each entry records the number of PPPoE sessions created by a user within the monitoring time. When the monitoring entries reach the maximum, the system stops monitoring and blocking session requests from new users. The aging time of monitoring entries is determined by the session-request-period argument. When the timer expires, the system starts a new round of monitoring for the user.
·     Blocking table—Stores a maximum of 8000 blocking entries. The system creates a blocking entry if the access rate of a user reaches the threshold, and blocks requests from that user. When the blocking entries reach the maximum number, the system stops blocking session requests from new users and it only outputs log messages. The aging time of the blocking entries is determined by the blocking-period argument. When the timer expires, the system starts a new round of monitoring for the user.
If the access rate setting is changed, the system removes all monitoring and blocking entries, and uses the new settings to limit PPPoE access rates.
3.     Set the PPPoE access limit.
pppoe-server throttle per-mac session-requests session-request-period blocking-period
By default, the PPPoE access rate is not limited.
The PPPoE server on a BAS device uses the RADIUS NAS-Port-ID attribute to send the access line ID received from a DSLAM device to the RADIUS server. The access line ID includes the circuit-id and remote-id. The RADIUS server compares the received NAS-Port-ID attribute with the local line ID information to verify the location of the user.
You can configure the content of the NAS-Port-ID attribute that the PPPoE server sends to the RADIUS server.
3.     Configure the content of the NAS-Port-ID attribute.
pppoe-server access-line-id content { all [ separator ] | circuit-id | remote-id }
By default, the NAS-Port-ID attribute contains only the circuit-id.
4.     Configure the NAS-Port-ID attribute to include the BAS information automatically.
pppoe-server access-line-id bas-info [ cn-163 ]
By default, the NAS-Port-ID attribute does not include the BAS information automatically.
5.     Configure the PPPoE server to trust the access line ID in received packets.
pppoe-server access-line-id trust
By default, the PPPoE server does not trust the access line ID in received packets.
6.     Configure the format that is used to parse the circuit-id.
pppoe-server access-line-id circuit-id parse-mode { cn-telecom | tr-101 }
The default mode is TR-101.
7.     Configure the transmission format for the circuit-id.
pppoe-server access-line-id circuit-id trans-format { ascii | hex }
The default format is a string of characters.
8.     Configure the transmission format for the remote-id.
pppoe-server access-line-id remote-id trans-format { ascii | hex }
Display packet statistics for PPPoE sessions.
display pppoe-server session packet { slot slot-number | interface interface-type interface-number }
Display summary information for PPPoE sessions.
display pppoe-server session summary { slot slot-number | interface interface-type interface-number }
Display information about blocked users.
display pppoe-server throttled-mac { slot slot-number | interface interface-type interface-number }
Display VA pool information.
Clear PPPoE sessions.
reset pppoe-server { all | interface interface-type interface-number | virtual-template number }
