05-Network Connectivity Configuration Guide
HomeSupportWirelessWX5800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX5800X Series Access Controllers Configuration Guides(E5457)-5W10005-Network Connectivity Configuration Guide
00-Preface
00-Preface 101.52 KB
Preface
The WX5800X Series access controllers documentation set describes the software features for the access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Network Connectivity Configuration Guide describes features and tasks that help you get started with the device, including:
·     About the network connectivity configuration guide
·     MAC address table
·     Ethernet link aggregation
·     VLAN
·     Loop detection
·     Spanning tree
·     LLDP
·     Layer 2 forwarding
·     PPP
·     L2TP
·     ARP
·     IP addressing
·     DHCP
·     DHCPv6
·     DNS
·     NAT
·     IP performance optimization
·     IPv6 basics
·     Policy-based routing
·     IPv6 policy-based routing
·     IPv6 static routing
·     GRE
·     Tunneling
·     Basic IP routing
·     IP forwarding basics
·     Static routing
·     Multicast overview
·     IGMP snooping
·     MLD snooping
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
