05-Network Connectivity Configuration Guide
HomeSupportWirelessWX5800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX5800X Series Access Controllers Configuration Guides(E5457)-5W10005-Network Connectivity Configuration Guide
05-Loop detection configuration
05-Loop detection configuration 102.86 KB
Configuring loop detection
About loop detection
The loop detection mechanism performs periodic checking for Layer 2 loops. The mechanism immediately generates a log message when a loop occurs so that you are promptly notified to adjust network connections and configurations. You can configure loop detection to shut down the looped port. Logs are maintained in the information center. For more information, see System Management Configuration Guide.
Loop detection mechanism
The device detects loops by sending detection frames and then checking whether these frames return to any port on the device. If they do, the device considers that the port is on a looped link.
Figure 1 Ethernet frame header for loop detection
The Ethernet frame header of a loop detection packet contains the following fields:
·     DMACDestination MAC address of the frame, which is the multicast MAC address 010f-e200-0007. When a loop detection-enabled device receives a frame with this destination MAC address, it performs the following operations:
¡     Sends the frame to the CPU.
¡     Floods the frame in the VLAN from which the frame was originally received.
·     SMACSource MAC address of the frame, which is the bridge MAC address of the sending device.
·     TPIDType of the VLAN tag, with the value of 0x8100.
·     TCIInformation of the VLAN tag, including the priority and VLAN ID.
·     TypeProtocol type, with the value of 0x8918.
Figure 2 Inner frame header for loop detection
The inner frame header of a loop detection packet contains the following fields:
·     CodeProtocol sub-type, which is 0x0001, indicating the loop detection protocol.
·     VersionProtocol version, which is always 0x0000.
·     LengthLength of the frame. The value includes the inner header, but excludes the Ethernet header.
·     ReservedThis field is reserved.
Frames for loop detection are encapsulated as TLV triplets.
Table 1 TLVs supported by loop detection
TLV
Remarks
End of PDU
End of a PDU.
Optional.
Device ID
Bridge MAC address of the sending device.
Required.
Port ID
ID of the PDU sending port.
Optional.
Port Name
Name of the PDU sending port.
Optional.
System Name
Device name.
Optional.
Chassis ID
Chassis ID of the sending port.
Optional.
Slot ID
Slot ID of the sending port.
Optional.
Sub Slot ID
Sub-slot ID of the sending port.
Optional.
Loop detection interval
Loop detection is a continuous process as the network changes. Loop detection frames are sent at the loop detection interval to determine whether loops occur on ports and whether loops are removed.
Loop protection actions
When detecting a loop on a port, the device by default logs the loop event without taking any action on the port. You can configure the device to take one of the following actions:
·     Block—Disables the port from learning MAC addresses and blocks the port.
·     No-learning—Disables the port from learning MAC addresses.
·     Shutdown—Shuts down the port to disable it from receiving and sending any frames.
Port status auto recovery
When the device configured with the block or no-learning loop action detects a loop on a port, it performs the action and waits three loop detection intervals. If the device does not receive a loop detection frame within three loop detection intervals, it performs the following operations:
·     Automatically sets the port to the forwarding state.
·     Notifies the user of the event.
When the device configured with the shutdown action detects a loop on a port, the following events occur:
1.     The device automatically shuts down the port.
2.     The device automatically sets the port to the forwarding state after the detection timer set by using the shutdown-interval command expires. For more information about the shutdown-interval command, see System Management Command Reference.
3.     The device shuts down the port again if a loop is still detected on the port when the detection timer expires.
This process is repeated until the loop is removed.
Incorrect recovery can occur when loop detection frames are discarded to reduce the load. To avoid this, use the shutdown action, or manually remove the loop.
Loop detection tasks at a glance
To configure loop detection, perform the following tasks:
1.     Enabling loop detection
¡     Enabling loop detection globally
¡     Enabling loop detection on a port
2.     (Optional) Setting the loop protection action
¡     Setting the global loop protection action
¡     Setting the loop protection action on an interface
3.     (Optional) Setting the loop detection interval
Restrictions and guidelines for loop detection configuration
When you enable loop detection, you can enable loop detection globally or on a per-port basis. When a port receives a detection frame in any VLAN, the loop protection action is triggered on that port, regardless of whether loop detection is enabled on it.
2.     Globally enable loop detection.
loopback-detection global enable vlan { vlan-id--list | all }
By default, loop detection is globally disabled.
2.     Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view.
3.     Enable loop detection on the port.
loopback-detection enable vlan { vlan-id--list | all }
By default, loop detection is disabled on ports.
Restrictions and guidelines for loop protection action configuration
You can set the loop protection action globally or on a per-port basis. The global action applies to all ports. The per-port action applies to the individual ports. The per-port action takes precedence over the global action.
2.     Set the global loop protection action.
loopback-detection global action shutdown
By default, the device logs the event without taking any action on the port on which a loop is detected.
2.     Enter interface view.
3.     Set the loop protection action on the interface.
loopback-detection action { block | no-learning | shutdown }
By default, the device logs the event without taking action on the port on which a loop is detected.
Support for the keywords of this command varies by interface type. For more information, see Layer 2LAN Switching Command Reference.
With loop detection enabled, the device sends loop detection frames at the loopback detection interval. A shorter interval offers more sensitive detection but consumes more resources. Consider the system performance and loop detection speed when you set the loop detection interval.
2.     Set the loop detection interval.
loopback-detection interval-time interval
The default setting is 30 seconds.
Display and maintenance commands for loop detection
Display the loop detection configuration and status.
display loopback-detection
