- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Lighttpd service commands
- 23-Web caching commands
21-WAAS commands | 260.17 KB |
display waas fec ipv4 peer-info
display waas statistics packet-dup
display waas statistics tcp compress
display waas statistics udp compress
display waas tfo auto-discovery blacklist
reset waas statistics packet-dup
reset waas statistics tcp compress
reset waas statistics udp compress
reset waas tfo auto-discovery blacklist
waas tfo auto-discovery blacklist enable
waas tfo auto-discovery blacklist hold-time
WAAS commands
The following compatibility matrixes show the support of hardware platforms for WAAS:
Hardware |
WAAS compatibility |
MSR610 |
No |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
class
Use class to specify a Wide Area Application Services (WAAS) class for a WAAS policy and enter WAAS policy class view.
Use undo class to remove a WAAS class from a WAAS policy.
class class-name [ insert-before existing-class ]
undo class class-name
No WAAS class exists in a WAAS policy.
WAAS policy view
class-name: Specifies a WAAS class by its name, a case-insensitive string of 1 to 63 characters. The specified class must already exist.
insert-before existing-class: Inserts the new class before an existing class in the WAAS policy. If you do not specify this option, the new class is placed at the end of the WAAS policy.
A WAAS policy can use system-defined WAAS classes (see Table 11).
As a best practice, configure a WAAS class by modifying a system-defined WAAS class.
You can also use this command to arrange existing WAAS classes in a WAAS policy.
A packet is checked against WAAS classes in the specified order. When a packet matches a class, the action for the class is performed on the packet, and the match process ends.
If you do not configure an action for a WAAS class, the device ignores the WAAS class.
# Specify the system-defined WAAS class AFS for the WAAS policy waas_global, and enter the view of the WAAS class AFS.
[Sysname] waas policy waas_global
[Sysname-waaspolicy-waas_global] class AFS
[Sysname-waaspolicy-waas_global-AFS]
# Specify the system-defined WAAS class AOL for the WAAS policy waas_global, insert it before AFS, and enter the view of the WAAS class AOL.
[Sysname-waaspolicy-waas_global] class AOL insert-before AFS
[Sysname-waaspolicy-waas_global-AOL]
# Change the position of the WAAS class AOL in the WAAS policy waas_global by inserting it before AFS, and enter the view of the WAAS class AOL.
display waas policy
waas class
waas policy
display waas class
Use display waas class to display WAAS classes.
display waas class [ class-name ]
class-name: Specifies a WAAS class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS class, this command displays all WAAS classes.
# Display the WAAS class class1.
<Sysname> display waas class class1
WAAS class: class1
match 1 tcp source ip-address 1.1.1.0 24 port 50000 60000
match 6 tcp destination ip-address 2.2.2.2 port 1 1024
match 11 tcp source ipv6-address 1001:: 96 port 50000 60000
match 16 tcp destination ipv6-address 2002::2222 port 1 1024
match |
Match criterion of the WAAS class. |
match tcp
waas class
Use display waas fec ipv4 peer-info to display the FEC information of peers.
display waas fec ipv4 peer-info [ source-ip source-ip ] [ source-port source-port ] [ destination-ip destination-ip ] [ destination-port destination-port ]
source-ip source-ip: Specifies a source IP address. If you do not specify a source IP address, this command displays the peer FEC information for all source IP addresses.
source-port source-port: Specifies a source port number in the range of 1 to 65535. If you do not specify a source port number, this command displays the peer FEC information for all source port numbers.
destination-ip destination-ip: Specifies a destination IP address. If you do not specify a destination IP address, this command displays the peer FEC information for all destination IP addresses.
destination-port destination-port: Specifies a destination port number in the range of 1 to 65535. If you do not specify a destination port number, this command displays the peer FEC information for all destination port numbers.
# Display the FEC information of all peers.
[Sysname] display waas fec ipv4 peer-info
Slot 0:
Slot 2:
Source IP/Port: 192.168.56.1/3230, Destination IP/Port: 192.168.157.100/3230
Type: A-FEC
A-FEC info:
Version: 1
Interface : GE2/0/1
[1]Loss ratio (time) : 5% (2020/10/29 17:20:04.409)
[2]Loss ratio (time) : 5% (2020/10/29 17:20:04.419)
[3]Loss ratio (time) : 5% (2020/10/29 17:20:04.429)
Sampling interval(ms) : 10
Average loss ratio : 5%
Receiving count : 10
Last receiving time(ms): 10
Source IP/Port: 192.168.57.1/3230, Destination IP/Port: 192.168.158.100/3230
Type: D-FEC
Source IP/Port: 192.168.58.1/3230, Destination IP/Port: 192.168.159.100/3230
Type: Unknown
Interface that sends probe packets to the peer. |
Receiving count |
Number of received sampled packets. |
Last receiving time(ms) |
Number of milliseconds that elapsed since the last receiving time. |
display waas policy
Use display waas policy to display WAAS policies.
display waas policy [ policy-name ]
policy-name: Specifies a WAAS policy by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS policy, this command displays all WAAS policies.
# Display the WAAS policy po1.
<Sysname> display waas policy po1
WAAS policy: po1
class cl1
optimize TFO DRE LZ
class cl2
optimize TFO DRE
class cl3
passthrough
class cl4
optimize TFO LZ
class cl5
WAAS class in the WAAS policy. |
Optimization actions: · TFO (works with only TCP). · DRE. · LZ compression. |
Action that does not perform any optimization. |
class
waas policy
display waas rtp-class
Use display waas rtp-class to display RTP WAAS classes.
display waas rtp-class [ class-name ]
class-name: Specifies a RTP WAAS class by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a WAAS class, this command displays all RTP WAAS classes.
# Display the RTP WAAS class class1.
<Sysname> display waas rtp-class class1
WAAS RTP class: class1
match 2 udp source 5.5.5.0 24
match 3 udp destination 6.6.6.6
match |
Match criterion of the RTP WAAS class. |
match udp
waas rtp-class
display waas session
Use display waas session to display WAAS session information.
In standalone mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ]
In IRF mode:
display waas session { ipv4 | ipv6 } [ client-ip client-ip ] [ client-port client-port ] [ server-ip server-ip ] [ server-port server-port ] [ peer-id peer-id ] [ verbose ] [ slot slot-number ]
ipv4: Specifies IPv4 sessions.
ipv6: Specifies IPv6 sessions.
client-ip client-ip: Displays the WAAS session information for the client specified by its IP address.
client-port client-port: Displays the WAAS session information for the clients specified by port number in the range of 1 to 65535.
server-ip server-ip: Displays the WAAS session information for the server specified by its IP address.
server-port server-port: Displays the WAAS session information for the servers specified by port number in the range of 1 to 65535.
peer-id peer-id: Displays the WAAS session information for the peer specified by its bridge MAC address in the format of H-H-H.
verbose: Displays detailed information about WAAS sessions. If you do not specify this keyword, the command displays brief information about WAAS sessions.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays WAAS session information for all member devices. (In IRF mode.)
If you specify only the ipv4 or ipv6 keyword, this command displays information about all IPv4 or IPv6 WAAS sessions.
# Display brief information about all IPv4 WAAS sessions.
<Sysname> display waas session ipv4
Peer ID: 0021-90ad-0012
Start Time: Fri Mar 21 10:43:05 2014
Source IP/Port: 1.1.1.1/34572
Destination IP/Port: 2.2.2.2/80
Peer ID: 0011-10ad-0012
Start Time: Fri Mar 21 10:45:05 2014
Source IP/Port: 2.2.1.1/34572
Destination IP/Port: 3.2.2.3/80
Total 2 sessions found.
# Display detailed information about all IPv4 WAAS sessions.
<Sysname> display waas session ipv4 verbose
Peer ID: 0021-90ad0-01221
Start Time: Fri Mar 21 11:43:05 2014
LAN interface: GigabitEthernet2/0/1
WAN interface: GigabitEthernet2/0/2
Configured Policy: TFO DRE LZ
Negotiated Policy: TFO DRE LZ
LAN->WAN bytes: Original 104884 Optimized 88594
WAN->LAN bytes: Original 744588 Optimized 3355445
LZ section:
Encode status:
Bytes in: 0
Bytes out: 0
Bypass bytes: 400
Space saved: 0%
Average Latency: 0 usec
Decode status:
Bytes in: 329
Bytes out: 393
Bypass bytes: 63
Space saved: 16%
Average Latency: 2 usec
DRE section:
Encode status:
Bytes in: 0
Bytes out: 0
Bypass bytes: 314
Space saved: 0%
Average latency: 0 usec
Decode status:
Bytes in: 399
Bytes out: 332
Bypass bytes: 0
Space saved: 0%
Chunk miss: 0
Collision: 0
Average latency: 23 usec
LZ section:
Encode status:
Bytes in: 0
Bytes out: 0
Bypass bytes: 400
Space saved: 0%
Decode status:
Bytes in: 329
Bytes out: 393
Bypass bytes: 63
Space saved: 16%
DRE section:
Encode status:
Bytes in: 0
Bytes out: 0
Bypass bytes: 314
Space saved: 0%
Decode status:
Bytes in: 399
Bytes out: 332
Bypass bytes: 0
Space saved: 0%
Chunk miss: 0
Collision: 0
Average latency 23 usec
Bridge MAC address of the peer device. A bridge MAC address uniquely identifies a peer device. |
Time when the WAAS session was established. |
IP address and port number of the client. |
IP address and port number of the server. |
Optimization actions configured on the local device, which can be one or any combination of the following actions: · TFO (works with only TCP). · DRE. · LZ compression. |
Optimization actions negotiated with the peer device, which can be one or any combination of the following actions: · TFO (works with only TCP). · DRE. · LZ compression. The negotiated optimization actions are the union of the optimization actions configured on the local device and those configured on the peer device. |
Statistics for LAN-to-WAN data: · Original—Number of bytes before optimization. · Optimized—Number of bytes after optimization. |
Statistics for WAN-to-LAN data: · Original—Number of bytes before optimization. · Optimized—Number of bytes after optimization. |
LZ compression statistics. |
DRE statistics. |
Compression statistics. |
Decompression statistics. |
Number of input bytes. |
Number of output bytes. |
Number of bytes that bypass DRE. |
· Compression ratio: (1–Bytes out/Bytes in) x 100. · Decompression ratio: (1–Bytes in/Bytes out) x 100. |
Average latency in milliseconds for the most recent compression or decompression. When multiple CPUs are available on a card, the average latency is the latency time divided by the number of CPUs. |
Cumulative number of times that DRE failed to find a dictionary entry according to a dictionary index. |
Cumulative number of times that data checks failed. |
display waas statistics dre
Use display waas statistics dre to display DRE statistics.
In standalone mode:
display waas statistics dre [ peer peer-id ]
In IRF mode:
display waas statistics dre [ peer peer-id ] [ slot slot-number ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, the command displays DRE statistics for all peer devices.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays DRE statistics for all member devices. (In IRF mode.)
# Display DRE statistics for all peer devices.
<Sysname> display waas statistics dre
Peer-ID: 0016-9d38-ca1d
Peer version: 1.0
Cache in storage: 19426304 bytes
Index number: 75884
Age: 00 weeks, 00 days, 00 hours, 00 minutes, 33 seconds
Total connections: 1
Active connections: 0
Encode Statistics
Dre msgs: 2
Bytes in: 392 bytes
Bytes out: 424 bytes
Bypass bytes: 0 bytes
Bytes Matched: 0 bytes
Space saved: -8%
Decode Statistics
Dre msgs: 196407
Bytes in: 29132703 bytes
Bytes out: 42413368 bytes
Space saved: 31%
Peer-ID: 0d38-9d38-ca1d
Peer version: 1.0
Cache in storage: 33554944 bytes
Index number: 131074
Age: 00 weeks, 00 days, 00 hours, 21 minutes, 31 seconds
Total connections: 2
Encode Statistics
Dre msgs: 514872
Bytes in: 111390296 bytes
Bytes out: 60085884 bytes
Bytes Matched: 56336640 bytes
Space saved: 46%
Decode Statistics
Dre msgs: 4
Bytes in: 849 bytes
Bytes out: 785 bytes
Space saved: -8%
# Display DRE statistics for a specific peer device.
<Sysname> display waas statistics dre peer 0016-9d38-ca1d
Peer version: 1.0
Encode Statistics
Dre msgs: 514872
Space saved: 46%
Decode Statistics
Dre msgs: 4
Bytes in: 849 bytes
Space saved: -8%
Table 6 Command output
Peer ID |
WAAS version of the peer device. |
Disk space used by metadata. Metadata are original data that have indexes in the dictionary. |
Number of dictionary indexes. |
Amount of time that has elapsed since the local device initially established an optimized TCP connection with the peer. |
Total number of DRE connections. |
Number of active DRE connections. |
Number of data blocks. |
Bytes in |
Bytes out |
Bypass bytes |
Number of bytes matched by DRE. |
Space saved |
Average Latency |
display waas statistics fec
Use display waas statistics fec to display FEC statistics.
# Display FEC packet statistics.
<Sysname> display waas statistics fec
Encoder:
Received:
Total packets : 661
Sent:
Original packets : 661
Redundant packets : 375
In-order original packets after timeout : 141
Out-of-order original packets after timeout : 0
Decoder:
Received:
Original packets : 0
Redundant packets : 0
Original packets in different group : 0
Redundant packets in different group from cached redundant packets: 0
Redundant packets in different group from cached original packets : 0
Redundant packets with sequence number less than cached ones : 0
Sent:
Recovered packets : 0
In-order original packets after timeout : 0
reset waas statistics fec
Use display waas statistics packet-dup to display packet statistics of packet duplication.
display waas statistics packet-dup { ipv4 | ipv6 }
ipv4: Specifies IPv4 packets.
ipv6: Specifies IPv6 packets.
# Display packet statistics of IPv4 packet duplication.
<Sysname> display waas statistics packet-dup ipv4
Sent to WAN:
Original packets : 522
Duplicated packets : 522
Packets exceeding MTU : 0
Received from WAN:
Discarded duplicated packets : 200
Original packets : 200
Unfragmented packets : 196
Out-of-order packets : 0
Fragmented packets : 4
Out-of-order fragmented packets : 0
Sent to LAN
Total packets : 200
Packets failing to be sent : 0
Timeout packets : 0
Timeout fragmented packets : 0
Table 7 Command output
Sent to WAN |
Statistics of packets sent to the WAN side. |
Original packets |
Number of original packets. |
Duplicated packets |
Number of duplicated packets. |
Packets exceeding MTU |
Number of packets with the length exceeding the MTU. |
Received from WAN |
Statistics of packets received from the WAN side. |
Discarded duplicated packets |
Number of duplicated packets dropped. |
Original packets |
Unfragmented packets |
Number of nonfragmented packets. |
Out-of-order packets |
Number of out-of-order packets. |
Fragmented packets |
Number of fragmented packets. |
Out-of-order fragmented packets |
Number of fragmented out-of-order packets. |
Sent to LAN |
Statistics of packets sent to the LAN side. |
Total packets |
Total number of packets transmitted. |
Number of nonfragmented packets transmitted. |
Number of fragmented packets transmitted. |
Packets failing to be sent |
Number of packets failing to be sent. |
Timeout packets |
Number of packets that time out. |
Timeout fragmented packets |
Number of fragmented packets that time out. |
Use display waas statistics tcp compress to display TCP packet compression statistics.
# Display TCP packet compression statistics.
<Sysname> display waas statistics tcp compress
Bytes in : 42413368 bytes
Bytes out : 29132703 bytes
Saved bandwidth ratio : 31%
Compressed packet ratio: 100%
Table 8 Command output
Saved bandwidth ratio |
(Number of input bytes–number of output bytes)/Number of input bytes. |
Compressed packet ratio |
Number of compressed packets/Total number of packets. |
Use display waas statistics udp compress to display UDP message compression statistics.
# Display UDP message compression statistics.
<Sysname> display waas statistics udp compress
Compressed packet ratio : 100%
display waas status
Use display waas status to display the global WAAS status.
display waas status
# Display the global WAAS status.
WAAS version: 1.0
Local ID: 02e0-011a-0000
DRE status: Disabled
LZ status: Disabled
BlackList status: Disabled
Total active connections: 7889
Total data storage size: 1468006400 bytes
Total index number: 11513600
Blacklist hold-time:5 minutes
Max TFO connections: 10000
Offset step: Normal
Aging time: 0 minutes
Symmetrical Mode : Yes
Interfaces Applied policy
GE2/0/1 waas_global
GE2/0/2 waas_default
GE2/0/3 waas_global
Total policy interfaces: 3
Table 9 Command output
Bridge MAC address of the local device. A bridge MAC address uniquely identifies a local device. |
Total number of active WAAS connections. |
Disk space used by all metadata. Metadata are original data that have indexes in the dictionary. |
Total number of dictionary indexes. |
Max TFO connections |
Maximum number of concurrent connections allowed. |
Offset step |
DRE match offset step: · Fastest. · Faster. · Fast. · Normal. |
Aging time |
Aging time for entries in the data dictionary, in minutes. |
Aging time for blacklist entries. |
List of interfaces with WAAS policies applied. |
Number of interfaces with WAAS policies applied. |
Use display waas tfo auto-discovery blacklist to display autodiscovered blacklist information.
In standalone mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 }
In IRF mode:
display waas tfo auto-discovery blacklist { ipv4 | ipv6 } [ slot slot-number ]
ipv4: Specifies IPv4 blacklist information.
ipv6: Specifies IPv6 blacklist information.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays autodiscovered blacklist information for all member devices. (In IRF mode.)
# Display all IPv4 blacklist information.
<Sysname> display waas tfo auto-discovery blacklist ipv4
Server IP address/Port Insert Time
1.1.1.1/8080 Fri Mar 21 10:43:05 2014
1.1.1.2/8080 Fri Mar 21 10:43:06 2014
2.2.2.2/443 Fri Mar 21 10:20:37 2014
Total 3 entries found.
Table 10 Command output
Time when a blacklist entry was generated. |
fec average-ratio
Use fec average-ratio to set the FEC average ratio.
Use undo fec average-ratio to restore the default.
fec average-ratio ratio
The FEC average ratio is 35%.
RTP WAAS class view
ratio: Specifies the FEC average ratio in the range of 1 to 50, in percentage.
The FEC average ratio determines the number of redundant packets generated for a group of original packets. The greater the FEC average ratio, the more the redundant packets generated. FEC average ratio must be greater than the actual packet loss ratio.
Number of redundant packets = Round up (number of original packets x (FEC average ratio/(1–FEC average ratio))
# Set the FEC average ratio to 30%.
[Sysname] waas policy waas_rtp
[Sysname-waaspolicy-waas_rtp] rtp-class rtpclass1
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec average-ratio 30
fec block-size
fec block-size
Use fec block-size to set the maximum number of original packets that can be encoded at a time.
Use undo fec block-size to restore the default.
fec block-size block-size
undo fec block-size
A maximum of 20 original packets can be encoded at a time.
RTP WAAS class view
block-size: Specifies the maximum number of original packets that can be encoded at a time, in the range of 1 to 150
In addition to the block size, the encoding timeout time affects the number of original packets that can be encoded at a time. If the maximum number of encoded packets is reached before the encoding timeout time expires, that number applies. If the encoding timeout time expires before the maximum number is reached, the number of actually encoded packets applies. If the block size is too small, the number of generated redundant packets is small. If the block size is too large, the decoder side will take a long time to recover lost packets. You can set an appropriate block size according to your network bandwidth.
# Set the maximum number of original packets that can be encoded at a time to 20.
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec block-size 20
fec average-ratio
fec decode-timeout
Use fec decode-timeout to set the decoding timeout time.
Use undo fec decode-timeout to restore the default.
fec decode-timeout milliseconds
The decoding timeout time is 800 milliseconds.
RTP WAAS class view
milliseconds: Specifies the decoding timeout time in the range of 30 to 1000 milliseconds.
When the total number of cached original packets and redundant packets reaches or exceeds the set number of original packets before the decoding timeout time expires, the decoder performs the following operations:
1. Decodes the cached packets.
2. Recovers lost packets.
3. Sends original packets and recovered packets, and drops redundant packets.
Otherwise, the decoder sends cached original packets and drops cached redundant packets without decoding any packets.
# Set the decoding timeout time to 500 milliseconds.
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec decode-timeout 500
fec block-size
fec encode-timeout
fec encode-timeout
Use fec encode-timeout to set the encoding timeout time.
Use undo fec encode-timeout to restore the default.
fec encode-timeout milliseconds
The encoding timeout time is 500 milliseconds.
RTP WAAS class view
milliseconds: Specifies the encoding timeout time in the range of 30 to 1000 milliseconds.
In addition to the encoding timeout time, the block size affects the number of original packets that can be encoded at a time. If the maximum number of encoded packets is reached before the encoding timeout time expires, that number applies. If the encoding timeout time expires before the maximum number is reached, the number of actually encoded packets applies.
# Set the encoding timeout time to 60 milliseconds.
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec encode-timeout 60
fec block-size
fec loss-recovery-type
Use fec loss-recovery-type to specify the FEC type.
Use undo fec loss-recovery-type to restore the default.
fec loss-recovery-type { adaptive-fec | determined-fec }
The FEC type is D-FEC.
RTP WAAS class view
adaptive-fec: Specifies adaptive FEC (A-FEC).
determined-fec: Specifies determined FEC (D-FEC).
If the FEC average ratio is set to a greater value, more bandwidth will be consumed. If the FEC average ratio is set to a small value, lost packets cannot be recovered. A-FEC adjusts the FEC average ratio based on the calculated real-time packet loss ratio. The adjusted FEC average ratio will not be greater than the set FEC average ratio. D-FEC always uses the set FEC average ratio.
# Set the FEC type to A-FEC.
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec loss-recovery-type adaptive-fec
fec probe aging-time
Use fec probe aging-time to set the aging time for A-FEC decoder information.
Use undo fec probe aging-time to restore the default.
fec probe aging-time seconds
The aging time for A-FEC decoder information is 1 second.
RTP WAAS class view
seconds: Specifies the aging time in the range of 0 to 60 seconds.
If the encoder receives sampled packets within the aging time, it adjusts the FEC average ratio based on the real-time packet loss ratio. If the encoder does not receive sampled packets within the aging time, it deletes the local decoder information and uses the set FEC average ratio.
# Set the aging time for A-FEC decoder information to 5 seconds.
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec probe aging-time 5
fec sample-interval
Use fec sample-interval to set the A-FEC sampling interval.
Use undo fec sample-interval to restore the default.
fec sample-interval interval
The A-FEC sampling interval is 100 milliseconds.
RTP WAAS class view
interval: Specifies the A-FEC sampling interval in the range of 1 to 1000 milliseconds.
The decoder regularly sends sampled packets to notify the encoder of the real-time packet loss ratio. The encoder adjusts the FEC average ratio based on the real-time packet loss ratio.
# Set the aging time for A-FEC decoder information to 50 milliseconds.
[Sysname-waaspolicy-waas_rtp-rtpclass1] fec sample-interval 50
match tcp
Use match tcp to configure a match criterion.
Use undo match tcp to delete a match criterion.
match [ match-id ] tcp any [ ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } | ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } ] [ port { port-list | object-group port-object-group-name } ]
match [ match-id ] tcp { destination ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] | source ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] } *
match [ match-id ] tcp { destination ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } [ port { port-list | object-group port-object-group-name } ] | source ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name } [ port { port-list | object-group port-object-group-name } ] } *
match [ match-id ] tcp { destination | source } port { object-group port-object-group-name | port-list }
undo match match-id
No match criterion exists.
WAAS class view
match-id: Specifies the ID of the match criterion, in the range of 1 to 65535. If you specify an unused ID, you can create a new match criterion. If you specify a used ID, you can modify the existing match criterion. If you do not specify an ID, the system automatically assigns the lowest available ID.
tcp: Matches TCP packets.
any: Matches any TCP packets.
destination: Specifies destination elements for matching TCP packets.
source: Specifies source elements for matching TCP packets.
ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name }: Specifies IPv4 addresses for matching TCP packets.
· ip-address: Specifies an IPv4 address in dotted decimal notation.
· mask-length: Specifies the mask length for the IPv4 address, in the range of 0 to 32. The default is 32.
· mask: Specifies the mask for the IPv4 address. The default is 255.255.255.255.
· object-group ip-object-group-name: Specifies an IPv4 address object group by its name, a case-insensitive string of 1 to 63 characters.
ipv6-address { ipv6-address [ prefix-length ] | object-group ipv6-object-group-name }: Specifies IPv6 addresses for matching TCP packets.
· ipv6-address: Specifies an IPv6 address.
· prefix-length: Specifies the prefix length for the IPv6 address, in the range of 0 to 128. The default is 128.
· object-group ipv6-object-group-name: Specifies an IPv6 address object group by its name, a case-insensitive string of 1 to 63 characters.
port { port-list | object-group port-object-group-name }: Specifies port numbers for matching TCP packets.
· port port-list: Specifies a space-separated list of up to 10 port items. Each item specifies a port number or a range of port numbers in the form of port-number1 to port-number2. The value for port-number2 must be greater than or equal to the value for port-number1. The value range for the port-number argument is 1 to 65535. If you do not specify a port list, all port numbers are matched.
· object-group port-object-group-name: Specifies a port object group by its name, a case-insensitive string of 1 to 63 characters.
If you specify the destination or source keyword, you must specify the ip-address (or ipv6-address) option, the port option, or both.
If you specify the any keyword, the ip-address (or ipv6-address) option, and the port option, the ip-address (or ipv6-address) and port options match either source or destination fields of packets.
You cannot configure the same match criteria with different match IDs.
A WAAS class can have a maximum of 65535 match criteria. A packet is checked against match criteria in their order of appearance. The packet belongs to the WAAS class if it matches any one of the match criteria.
A WAAS class without any match criteria is not used to match packets.
# Create a WAAS class named http_class, and configure the class to match packets with source IP address 192.168.0.1/16 and port number 80 or port number in the range of 8000 to 8080.
[Sysname] waas class http_class
[Sysname-waasclass-http_class] match tcp source ip-address 192.168.0.1 16 port 80 8000 to 8080
# Create a WAAS class named http_class, and configure the class to match any TCP packets.
[Sysname-waasclass-http_class] match tcp any
# Create a WAAS class named http_class, and configure the class to match TCP packets with source IP address 10.0.3.1/24 and destination IP address 11.0.3.1/24.
[Sysname-waasrtpclass-http_class] match tcp source ip-address 10.0.0.1 24 destination ip-address 11.0.3.1 24
# Create a WAAS class named http_class, and configure the class to match TCP packets with the source IP address in the address object group group1 and the destination IP address in the address object group group2.
[Sysname-waasrtpclass-http_class] match tcp source ip-address object-group group1 destination ip-address object-group group2
display waas policy
waas class
match udp
Use match udp to configure a UDP match criterion.
Use undo match udp to delete a UDP match criterion.
match [ match-id ] udp any [ ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name } ] [ port { port-list | object-group port-object-group-name } ]
match [ match-id ] udp { destination { ip-address { ip-address [ mask-legnth | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] } | source { ip-address { ip-address [ mask-legnth | mask ] | object-group ip-object-group-name } [ port { port-list | object-group port-object-group-name } ] } } *
match [ match-id ] udp { destination | source } port { port-list | object-group port-object-group-name }
undo match match-id
No UDP match criterion exists.
RTP WAAS class view
udp: Matches UDP packets.
any: Matches any UDP packets.
destination: Specifies destination elements for matching UDP packets.
source: Specifies source elements for matching UDP packets.
ip-address { ip-address [ mask-length | mask ] | object-group ip-object-group-name }: Specifies IPv4 addresses for matching UDP packets.
· ipv4-address: Specifies an IPv4 address in dotted decimal notation.
port { port-list | object-group port-object-group-name }: Specifies port numbers for matching UDP packets.
If you specify the destination or source keyword, you must specify the ip-address option.
If you specify the any keyword, the ip-address option matches either source or destination IP address of packets.
An RTP WAAS class can have a maximum of 65535 match criteria. A packet is checked against match criteria in their order of appearance. The packet belongs to the WAAS class if it matches any one of the match criteria.
# Create an RTP WAAS class named http_class, and configure the class to match UDP packets with source IP address 192.168.0.1/16.
[Sysname-waasrtpclass-http_class] match udp source ip-address 192.168.0.1 16
# Create an RTP WAAS class named udp_class, and configure the class to match any UDP packets.
[Sysname] waas rtp-class udp_class
[Sysname-waasrtpclass-udp_class] match udp any
# Create an RTP WAAS class named http_class, and configure the class to match UDP packets with source IP address 10.0.3.1/24 and destination IP address 11.0.3.1/24.
[Sysname] waas rtp-class http_class
[Sysname-waasrtpclass-http_class] match udp source ip-address 10.0.0.1 24 destination ip-address 11.0.3.1 24
# Create an RTP WAAS class named http_class, and configure the class to match UDP packets with the source IP address in the address object group group1 and the destination IP address in the address object group group2.
[Sysname-waasrtpclass-http_class] match udp source ip-address object-group group1 destination ip-address object-group group2
waas rtp-class
optimize
Use optimize to configure optimization actions for a WAAS class or RTP WAAS class.
Use undo optimize to restore the default.
optimize { packet-dup | tfo [ dre | lz ] * }
undo optimize
RTP WAAS class view:
optimize { fec | packet-dup }
undo optimize
No optimization actions are configured.
WAAS policy RTP class view
packet-dup: Specifies the packet duplication optimization action.
tfo: Specifies TFO.
dre: Specifies DRE.
lz: Specifies LZ compression.
fec: Specifies FEC.
An optimization action takes effect only when the corresponding feature is enabled.
An optimization action does not optimize the traffic that matches a blacklist entry.
If you configure both this command and the passthrough command, the most recent configuration takes effect.
The undo optimize command delete the optimization actions configured in both WAAS policy class view and WAAS policy RTP class view.
# Configure optimization actions TFO, DRE, and LZ for the WAAS class AFS.
[Sysname-waaspolicy-waas_global-AFS] optimize tfo dre lz
# Configure optimization action FEC for the RTP WAAS class rtpclass1.
[Sysname-waaspolicy-waas_rtp-rtpclass1] optimize fec
# Configure the packet duplication optimization action for WAAS class PKT.
[Sysname-waaspolicy-waas_global] class PKT
[Sysname-waaspolicy-waas_global-PKT] optimize packet-dup
class
display waas policy
passthrough
rtp-class
waas policy
waas tfo optimize dre
waas tfo optimize lz
passthrough
Use passthrough to configure the pass-through action for a WAAS class.
Use undo passthrough to restore the default.
passthrough
undo passthrough
The pass-through action is not configured.
The pass-through action allows packets to pass through unoptimized.
If you configure both this command and the optimize command, the most recent configuration takes effect.
# Configure the pass-through action for the WAAS class AFS.
class
display waas policy
optimize
waas policy
reset waas cache dre
Use reset waas cache dre to clear DRE data dictionaries.
reset waas cache dre [ peer-id peer-id ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, this command clears DRE data dictionaries for all peer devices.
# Clear the DRE data dictionary for the peer device with the bridge MAC address 0789-445d-effa.
<Sysname> reset waas cache dre peer 0789-445d-effa
reset waas statistics dre
Use reset waas statistics dre to clear DRE statistics.
reset waas statistics dre [ peer-id peer-id ]
peer-id peer-id: Specifies a peer device by its bridge MAC address in the format of H-H-H. If you do not specify a peer device, this command clears DRE statistics for all peer devices.
# Clear DRE statistics for all peer devices.
<Sysname> reset waas statistics dre
Use reset waas statistics fec to clear FEC packet statistics.
# Clear FEC packet statistics.
Use reset waas statistics packet-dup to clear packet statistics of packet duplication.
reset waas statistics packet-dup { ipv4 | ipv6 }
# Clear packet statistics of IPv4 packet duplication.
<Sysname> reset waas statistics packet-dup ipv4
Use reset waas statistics udp compress to clear TCP packet compression statistics.
# Clear TCP packet compression statistics.
<Sysname> reset waas statistics udp compress
Use reset waas statistics udp compress to clear UDP message compression statistics.
# Clear UDP message compression statistics.
Use reset waas tfo auto-discovery blacklist to clear all autodiscovered blacklist entries.
# Clear all autodiscovered blacklist entries.
<Sysname> reset waas tfo auto-discovery blacklist
rtp-class
Use rtp-class to specify an RTP WAAS class for a WAAS policy and enter WAAS policy RTP class view.
Use undo rtp-class to remove an RTP WAAS class from a WAAS policy.
rtp-class class-name [ insert-before existing-class ]
undo rtp-class class-name
No RTP WAAS class exists in a WAAS policy.
WAAS policy view
class-name: Specifies an RTP WAAS class by its name, a case-insensitive string of 1 to 63 characters. The specified class must already exist.
A packet is checked against RTP WAAS classes in the order they are specified. When a packet matches a class, the action for the class is performed on the packet, and the match process ends.
If you do not configure an action for a RTP WAAS class, the device ignores the WAAS class.
# Specify RTP WAAS class rtpclass1 for WAAS policy waas_rtp, and enter the view of the WAAS class.
display waas policy
waas rtp-class
waas policy
waas apply policy
Use waas apply policy to apply a WAAS policy to an interface.
Use undo waas apply policy to restore the default.
waas apply policy [ policy-name ]
No WAAS policy is applied to an interface.
Interface view
policy-name: Specifies a WAAS policy by its name, a case-insensitive string of 1 to 63 characters. The specified policy must already exist. If you do not specify a WAAS policy, this command applies the system-defined WAAS policy waas_default.
Apply a WAAS policy to an interface that connects to the WAN (not an interface that connects to the LAN). The device optimizes or passes through the traffic entering and leaving the WAN according to the configured policy. If the incoming and outgoing interfaces of the traffic are both connected to the WAN, the traffic is not optimized.
A global logical interface (such as a Layer 3 aggregate interface or VLAN interface) that spans multiple cards or IRF member devices can be used to connect to the WAN. To ensure the traffic optimization effect for such an interface, use the service command to specify one of these cards or IRF member devices to forward traffic for the interface.
# Apply the WAAS policy global_policy to the interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] waas apply policy global_policy
display waas policy
display waas status
waas policy
waas asymmetric
Use waas asymmetric to configure WAAS to operate in asymmetric mode.
Use undo waas asymmetric to restore the default.
waas asymmetric
WAAS operates in symmetric mode.
Configure this command if the device sends and receives packets on different interfaces.
If the device sends and receives packets on the same interface, the device should operate in symmetric mode.
# Configure WAAS to operate in asymmetric mode.
[Sysname] waas asymmetric
waas class
Use waas class to create a WAAS class and enter its view, or enter the view of an existing WAAS class.
Use undo waas class to delete a WAAS class.
waas class class-name
undo waas class class-name
Only system-defined WAAS classes exist.
class-name: Specifies a name for the WAAS class, a case-insensitive string of 1 to 63 characters.
As a best practice, configure a WAAS class by modifying a system-defined WAAS class (see Table 11).
# Create a WAAS class named waas_global and enter WAAS class view.
[Sysname] waas class waas_global
[Sysname-waasclass-waas_global]
class
display waas class
waas config remove-all
Use waas config remove-all to delete all WAAS settings.
This command deletes all configuration data and running data for WAAS and exits the WAAS process.
# Delete all WAAS settings.
[Sysname] waas config remove-all
The command will clear all the WAAS configuration. Continue? [Y/N]:y
waas config restore-default
Use waas config restore-default to restore system-defined WAAS settings.
This command restores the system-defined WAAS policy and WAAS classes to their settings at the time when the WAAS process starts for the first time.
To successfully restore system-defined WAAS settings, make sure none of the interfaces has a WAAS policy applied.
# Restore system-defined WAAS settings.
[Sysname] waas config restore-default
The command will restore all the WAAS configuration to default. Continue? [Y/N]:y
waas dre cache aging
Use waas dre cache aging to set the aging time for entries in the data dictionary.
Use undo waas dre cache aging to restore the default.
waas dre cache aging minutes
Entries in the data dictionary are not aged out, and the newly created entry overwrites the oldest entry if the number of data dictionary entries reaches the limit.
minutes: Specifies the aging time for entries in the data dictionary, in the range of 10 to 60 minutes.
The device polls all data dictionary entries and deletes the entries that are not hit within the aging time. If the number of data dictionary entries reaches the limit, the device no longer creates new entries.
The amount of time used by the device to poll all data dictionary entries depends on the number of data dictionary entries on the device.
You must set the same aging time on the local and peer devices.
# Set the aging time to 10 minutes for entries in the data dictionary.
[Sysname] waas dre cache aging 10
waas dre offset-step
Use waas dre offset-step to set the DRE match offset step.
Use undo waas dre offset-step to restore the default.
waas dre offset-step { general | fast | fastest | normal }
The DRE match offset step is normal.
general: Specifies the DRE match offset step as general.
fast: Specifies the DRE match offset step as fast.
fastest: Specifies the DRE match offset step as fastest.
normal: Specifies the DRE match offset step as normal.
The following DRE match offset step levels are listed from high to low:
· fastest.
· fast.
· general.
· normal.
The higher the step level, the lower the match precision. As a best practice, use a higher-level offset step on high-speed links to improve match efficiency. Use a lower-level offset step on low-speed links to ensure match precision.
# Set the DRE match offset step to fast.
[Sysname] waas dre offset-step fast
waas policy
Use waas policy to create a WAAS policy and enter its view, or enter the view of an existing WAAS policy.
Use undo waas policy to delete a WAAS policy.
waas policy policy-name
undo waas policy policy-name
Only the system-defined WAAS policy waas_default exists.
policy-name: Specifies a name for the WAAS policy, a case-insensitive string of 1 to 63 characters.
To delete a WAAS policy applied to an interface, first remove the WAAS policy from the interface.
As a best practice, configure a WAAS policy by entering the system-defined WAAS policy view and modifying the system-defined WAAS policy. The system-defined WAAS policy is created by the system when the WAAS process starts for the first time. The system-defined WAAS policy uses all system-defined WAAS classes. Only system-defined WAAS classes FTP-Data and FTPS-Data use source ports as match options. All other system-defined WAAS classes use destination ports as match options.
Table 11 System-defined WAAS policy
WAAS actions |
Source ports |
Destination ports |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
3200–3219, 3221–3224, 3226–3267, 3270–3282, 3284–3305, 3307–3388, 3390–3399, 3600–3659, 3662–3699 |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
N/A |
N/A |
N/A |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
Passthrough |
N/A |
N/A |
N/A |
Passthrough |
N/A |
# Enter system-defined WAAS policy view.
[Sysname] waas policy waas_default
[Sysname-waaspolicy-waas_default]
display waas policy
waas rtp-class
Use waas rtp-class to create an RTP WAAS class and enter its view, or enter the view of an existing RTP WAAS class.
Use undo waas rtp-class to delete an RTP WAAS class.
waas rtp-class class-name
undo waas rtp-class class-name
No RTP WAAS classes exist.
class-name: Specifies a name for the RTP WAAS class, a case-insensitive string of 1 to 63 characters.
If an RTP WAAS class does not contain match criteria, it is not used to match packets.
# Create an RTP WAAS class named waas_rtp and enter RTP WAAS class view.
[Sysname] waas rtp-class waas_rtp
[Sysname-waasrtpclass-waas_rtp]
rtp-class
waas tcp
Use waas tcp to enable TCP packet compression or decompression.
Use undo waas tcp to disable TCP packet compression or decompression.
waas tcp { compress [ max max-number ] | decompress }
undo waas tcp
TCP packet compression and decompression is disabled.
compress: Enables TCP packet compression.
max max-number: Specifies the maximum number of TCP packets to be compressed per time, in the number of 2 to 20. The default is 5.
decompress: Enables TCP packet decompression.
This command takes effect only on TCP packets with the destination IP address and destination port number specified in the waas tcp destination command.
Enable TCP packet compression on the upstream device and enable TCP packet decompression on the downstream device. The upstream device compresses packets and forwards them to the downstream device. The downstream device decompresses the received packets and then forwards them.
You can enable TCP packet compression or decompression for the same destination IP address, but not both.
# Enables TCP packet compression and set the maximum number of TCP packets to be compressed to 8.
[Sysname] waas tcp compress max 8
waas tcp ip
Use waas tcp destination to specify the destination IP address and destination port number of TCP packets to be compressed or decompressed.
Use undo waas tcp destination to remove the specified destination IP address and destination port number.
waas tcp destination ip-address port port-number
undo waas tcp destination ip-address port port-number
No destination IP address and destination port number are specified.
ip-address: Specifies the destination IP address of TCP packets to be compressed or decompressed.
port port-number: Specifies the destination port number of TCP packets, in the range of 1 to 65535.
TCP packet compression and decompression takes effect only on TCP packets with the destination IP address and destination port number specified in this command.
You can execute this command multiple times to specify multiple IP address-port number pairs.
# Specify that TCP packets with destination IP address 172.16.105.50 and destination port number 8000 are compressed.
[Sysname] waas tcp destination 172.16.105.50 port 8000
waas tcp
Use waas tfo auto-discovery blacklist enable to enable the TFO blacklist autodiscovery feature.
Use undo waas tfo auto-discovery blacklist enable to disable the TFO blacklist autodiscovery feature.
The TFO blacklist autodiscovery feature is disabled.
This feature automatically discovers servers that cannot receive TCP packets with options and adds the server IP addresses and port numbers to a blacklist.
During the 3-way handshake, the local device considers the TCP connection attempt failed if either of the following situations occurs:
· The peer device does not respond within the specified time period.
· The peer device closes the TCP connection.
# Enable the TFO blacklist autodiscovery feature.
[Sysname] waas tfo auto-discovery blacklist enable
Use waas tfo auto-discovery blacklist hold-time to set the aging time for autodiscovered blacklist entries.
Use undo waas tfo auto-discovery blacklist hold-time to restore the default.
waas tfo auto-discovery blacklist hold-time minutes
The aging time for autodiscovery blacklist entries is 5 minutes.
minutes: Specifies the aging time for autodiscovered blacklist entries, in the range of 1 to 10080 minutes.
An aging timer is started when a blacklist entry is created. The system automatically deletes an autodiscovered blacklist entry to make room for a new blacklist entry when the aging timer expires.
# Set the aging time to 30 minutes for autodiscovered blacklist entries.
[Sysname] waas tfo auto-discovery blacklist hold-time 30
waas tfo base-congestion-window
Use waas tfo base-congestion-window to set the initial congestion window size for slow start.
Use undo waas tfo base-congestion-window to restore the default.
waas tfo base-congestion-window segments
The initial congestion window size is two TCP segments.
segments: Specifies the initial congestion window size in the range of 1 to 10 TCP segments.
The congestion window size changes with the congestion status and transmission speed. An appropriate initial congestion window size can quickly restore the network to its full transmission capacity after congestion occurs.
# Set the initial congestion window size to three segments.
[Sysname] waas tfo base-congestion-window 3
waas tfo congestion-method
Use waas tfo congestion-method to specify a TCP congestion control algorithm for the WAN side.
Use undo waas tfo congestion-method to restore the default.
waas tfo congestion-method { bic | reno }
WAAS uses BIC as the TCP congestion control algorithm on the WAN side.
bic: Specifies BIC as the TCP congestion control algorithm.
reno: Specifies Reno as the TCP congestion control algorithm.
# Specify Reno as the TCP congestion control algorithm for the WAN side.
[Sysname] waas tfo congestion-method reno
waas tfo connect-limit
Use waas tfo connect-limit to set the maximum number of concurrent connections.
Use undo waas tfo connect-limit to restore the default.
waas tfo connect-limit limit
The maximum number of concurrent connections is 10000.
limit: Specifies the maximum number of concurrent connections, in the range of 1000 to 4294967295.
After the maximum number of concurrent connections is reached, WAAS does not optimize traffic for newly established connections. Configure the maximum number of concurrent connections according to your available memory resources, because optimizing TCP flows consumes memory resources.
You must set the same maximum number of concurrent connections on the local and peer devices.
# Set the maximum number of concurrent connections to 20000.
[Sysname] waas tfo connect-limit 20000
waas tfo keepalive
Use waas tfo keepalive to enable TFO keepalives.
Use undo waas tfo keepalive to disable TFO keepalives.
waas tfo keepalive
TFO keepalives are enabled.
After you enable TFO keepalives, the system starts the 2-hour TCP keepalive timer. If the local device does not send or receive any data when the timer expires, it sends a keepalive to the peer to maintain the connection.
# Disable TFO keepalives.
[Sysname] undo waas tfo keepalive
Use waas tfo optimize dre to enable DRE.
Use undo waas tfo optimize dre to disable DRE.
DRE is enabled.
The DRE optimization action configured in a WAAS policy takes effect only when DRE is enabled.
# Disable DRE.
[Sysname] undo waas tfo optimize dre
display waas status
Use waas tfo optimize lz to enable LZ compression.
Use undo waas tfo optimize lz to disable LZ compression.
LZ compression is enabled.
The LZ optimization action configured in a WAAS policy takes effect only when LZ compression is enabled.
# Disable LZ compression.
[Sysname] undo waas tfo optimize lz
display waas status
waas tfo receive-buffer
Use waas tfo receive-buffer to set the TFO receiving buffer size.
Use undo waas tfo receive-buffer to restore the default.
waas tfo receive-buffer buffer-size
The TFO receiving buffer size is 64 KB.
buffer-size: Specifies the TFO receiving buffer size in the range of 32 to 16384 KB.
The TFO receiving buffer size affects network throughput.
# Set the TFO receiving buffer size to 1024 KB.
[Sysname] waas tfo receive-buffer 1024
waas udp
Use waas udp to enable UDP message compression or decompression.
Use undo waas udp to disable UDP message compression or decompression.
waas udp { compress [ max max-number ] | decompress }
undo waas udp
UDP message compression and decompression is disabled.
compress: Enables UDP message compression.
max max-number: Specifies the maximum number of UDP messages to be compressed.
decompress: Enables UDP message decompression.
This command takes effect only on UDP messages with the destination IP address and destination port number specified in the waas udp destination command.
Enable UDP message compression on the upstream device and enable UDP message decompression on the downstream device. The upstream device compresses packets and forwards them to the downstream device. The downstream device decompresses the received packets and then forwards them.
You can enable UDP message compression or decompression for the same destination IP address, but not both.
# Enables UDP message compression and set the maximum number of UDP messages to be compressed to 10.
[Sysname] waas udp compress max 10
Use waas udp destination to specify the destination IP address and destination port number of UDP messages to be compressed or decompressed.
Use undo waas udp destination to remove the specified destination IP address and destination port number.
waas udp destination ip-address port port-number
undo waas udp destination ip-address port port-number
ip-address: Specifies the destination IP address of UDP messages to be compressed or decompressed.
port port-number: Specifies the destination port number of UDP messages, in the range of 1 to 65535.
UDP message compression and decompression takes effect only on UDP messages with the destination IP address and destination port number specified in this command.
You can configure this command multiple times to specify multiple IP address-port number pairs.
# Specify that UDP messages with destination IP address 172.16.105.48 and destination port number 5000 are compressed.
[Sysname] waas udp destination 172.16.105.48 port 5000
waas udp
