- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Lighttpd service commands
- 23-Web caching commands
20-ADVPN commands | 358.70 KB |
display vam server address-map
display vam server ipv6 address-map
display vam server ipv6 private-network
display vam server private-network
pre-shared-key (ADVPN domain view)
reset vam server ipv6 address-map
display vam client shortcut interest
display vam client shortcut ipv6 interest
pre-shared-key (VAM client view)
reset advpn ipv6 session statistics
reset advpn session statistics
ADVPN commands
VAM server commands
authentication-algorithm
Use authentication-algorithm to specify the algorithms for VAM protocol packet authentication and their priorities.
Use undo authentication-algorithm to restore the default.
authentication-algorithm { aes-xcbc-mac | md5 | none | sha-1 | sha-256 } *
SHA-1 is used for protocol packet authentication.
ADVPN domain view
aes-xcbc-mac: Uses the AES-XCBC-MAC authentication algorithm.
md5: Uses the MD5 authentication algorithm.
none: Performs no authentication.
sha-1: Uses the SHA-1 authentication algorithm.
sha-256: Uses the SHA-256 authentication algorithm.
The VAM server and client use SHA-1 for connection request and response packet authentication, and use the negotiated algorithms for negotiation acknowledgment and subsequent VAM protocol packet authentication.
An authentication algorithm specified earlier by using this command has a higher priority during algorithm negotiation between a VAM server and a client. The VAM server compares its algorithms in descending order of priority with the algorithms sent by the client, and sends the matching algorithm with the highest priority to the client.
The configuration of this command does not affect registered VAM clients. It applies to subsequently registered VAM clients.
# Specify the authentication algorithms as MD5, SHA-1, and SHA-256 in descending order of priority for ADVPN domain 1.
[Sysname] vam server advpn-domain 1
[Sysname-vam-server-domain-1] authentication-algorithm md5 sha-1 sha-256
authentication-method
Use authentication-method to specify an authentication mode that the VAM server uses to authenticate clients.
Use undo authentication-method to restore the default.
authentication-method { none | { chap | pap } [ domain isp-name ] }
The authentication method is CHAP, and the default domain is used.
ADVPN domain view
none: Performs no authentication on clients.
chap: Performs CHAP authentication.
pap: Performs PAP authentication.
domain isp-name: Specifies an ISP domain for authentication. The isp-name argument is a case-insensitive string of 1 to 24 characters. It cannot include back slashes (\), vertical bars (|), slashes (/), colons (:), asterisks (*), question marks (?), quotation marks ("), left angle brackets (<), right angle brackets (>), and at signs (@). If you do not specify this option, the default domain is used for authentication.
If the specified ISP domain does not exist, the authentication will fail.
A newly configured authentication method does not affect registered VAM clients. It applies to subsequently registered VAM clients.
# Configure the VAM server to use CHAP to authenticate clients.
[Sysname-vam-server-domain-1] authentication-method chap
Use display vam server address-map to display IPv4 private-public address mapping information for VAM clients registered with the VAM server.
display vam server address-map [ advpn-domain domain-name [ private-address private-ip-address ] ] [ verbose ]
advpn-domain domain-name: Displays IPv4 address mapping information for VAM clients in the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays address mapping information for VAM clients in all ADVPN domains.
private-address private-ip-address: Displays IPv4 address mapping information for the VAM client with the specified private IPv4 address. If you do not specify this option, the command displays mapping information for VAM clients in the specified domain or all ADVPN domains.
verbose: Displays detailed address mapping information. If you do not specify this keyword, the command displays brief address mapping information.
# Display IPv4 address mapping information for VAM clients in all ADVPN domains.
<Sysname> display vam server address-map
ADVPN domain name: 1
Total private address mappings: 2
Group Private address Public address Type NAT Holding time
1 10.0.0.1 2001::1 Hub No 0H 13M 34S
1 10.0.0.3 74.125.128.102 Spoke Yes 0H 4M 21S
ADVPN domain name: 2
Total private address mappings: 0
ADVPN domain name: 3
Total private address mappings: 1
1 30.0.0.1 113.124.136.1 Hub No 0H 0M 2S
ADVPN domain name: 4
1 40.0.0.1 4001::1 Hub No 1H 8M 22S
ADVPN domain name: 5
1 50.0.0.1 115.194.156.1 Hub No 132H 41M 29S
# Display IPv4 address mapping information for VAM clients in ADVPN domain 1.
<Sysname> display vam server address-map advpn-domain 1
# Display IPv4 address mapping information for the VAM client with private IPv4 address 10.0.0.1 in ADVPN domain 1.
<Sysname> display vam server address-map advpn-domain 1 private-address 10.0.0.1
Group |
Hub group to which the VAM client belongs. |
Private address |
Private address that the VAM client has registered with the VAM server. |
Public address |
Public address that the VAM client has registered with the VAM server. |
Type |
VAM client type: Hub or Spoke. |
NAT |
Whether NAT traversal is used: No or Yes. |
Holding time |
Duration time that elapses since the VAM client successfully registered with the server, in the format of xH yM zS. |
# Display detailed IPv4 address mapping information for VAM clients in all ADVPN domains.
<Sysname> display vam server address-map verbose
ADVPN domain name : 1
Private address : 10.0.0.1
Type : Hub
Hub group : 1
Holding time : 0H 13M 34S
Link protocol : UDP
Public address : 2001::1
Public port : 10018
Registered address: 2001::1
Registered port : 10018
Behind NAT : No
Private address : 10.0.0.3
Type : Spoke
Hub group : 1
Holding time : 0H 4M 21S
Link protocol : UDP
Public address : 74.125.128.102
Public port : 11297
Registered address: 192.168.23.6
Registered port : 2158
Behind NAT : Yes
ADVPN domain name : 3
Private address : 30.0.0.1
Type : Hub
Hub group : 1
Holding time : 0H 0M 2S
Link protocol : GRE
Public address : 113.124.136.1
Registered address: 113.124.136.1
Behind NAT : No
ADVPN domain name : 4
Private address : 40.0.0.1
Hub group : 1
Holding time : 1H 8M 22S
Link protocol : IPsec-UDP
Public address : 4001::1
Registered address: 4001::1
Registered port : 4072
Behind NAT : No
ADVPN domain name : 5
Private address : 50.0.0.1
Type : Hub
Hub group : 1
Holding time : 132H 41M 29S
Link protocol : IPsec-GRE
Public address : 115.194.156.1
Registered address: 115.194.156.1
Behind NAT : No
# Display detailed IPv4 address mapping information for VAM clients in ADVPN domain 1.
<Sysname> display vam server address-map advpn-domain 1 verbose
Type : Hub
Hub group : 1
Link protocol : UDP
Public port : 10018
Behind NAT : No
Type : Spoke
Hub group : 1
Link protocol : UDP
Public port : 11297
Behind NAT : Yes
# Display detailed IPv4 address mapping information for the VAM client with private IPv4 address 10.0.0.1 in ADVPN domain 1.
<Sysname> display vam server address-map advpn-domain 1 private-address 10.0.0.1 verbose
Type : Hub
Hub group : 1
Link protocol : UDP
Public port : 10018
Behind NAT : No
Private address |
Type |
Hub group |
Holding time |
Link protocol |
Link layer protocol used by the VAM client for ADVPN tunnel establishment: · UDP. · GRE. · IPsec-UDP. · IPsec-GRE. |
Public address |
VAM client's public IP address that has been NATed. |
Public port |
VAM client's ADVPN port number that has been NATed. This field is displayed when the Link protocol is UDP or IPsec-UDP. |
Registered address |
Registered port |
ADVPN port number that the VAM client has registered with the VAM server. This field is displayed when the Link protocol is UDP or IPsec-UDP. |
IPsec address |
IP address used by the VAM client for IPsec tunnel establishment. This field is displayed when the Link protocol is IPsec-UDP or IPsec-GRE. |
IPsec port |
UDP port number used by the VAM client for IPsec tunnel establishment. This field is displayed when the Link protocol is IPsec-UDP or IPsec-GRE. |
Behind NAT |
reset vam server address-map
Use display vam server ipv6 address-map to display IPv6 private-public address mapping information for VAM clients registered with the VAM server.
display vam server ipv6 address-map [ advpn-domain domain-name [ private-address private-ipv6-address ] ] [ verbose ]
advpn-domain domain-name: Displays IPv6 address mapping information for VAM clients in the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays address mapping information for VAM clients in all ADVPN domains.
private-address private-ipv6-address: Displays IPv6 address mapping information for the VAM client with the specified private IPv6 address. If you do not specify this option, the command displays mapping information for VAM clients in the specified domain or all ADVPN domains.
# Display IPv6 address mapping information for VAM clients in all ADVPN domains.
<Sysname> display vam server ipv6 address-map
1 1000::1:0:0:1 2001::1 Hub No 0H 13M 34S
2 1000::2:0:0:1 220.181.111.85 Spoke Yes 0H 4M 21S
1 1003::1:0:0:1 3001::1 Hub No 0H 0M 2S
1 1004::1:0:0:1 202.108.231.125 Hub No 1H 8M 22S
1 1005::1:0:0:1 5001::1 Hub No 132H 41M 29S
# Display IPv6 address mapping information for VAM clients in ADVPN domain 1.
<Sysname> display vam server ipv6 address-map advpn-domain 1
# Display IPv6 address mapping information for the VAM client with private IPv6 address 1000::1:0:0:1 in ADVPN domain 1.
<Sysname> display vam server ipv6 address-map advpn-domain 1 private-address 1000::1:0:0:1
Group |
Private address |
Public address |
Type |
NAT |
Holding time |
# Display detailed IPv6 address mapping information for VAM clients in all ADVPN domains.
<Sysname> display vam server ipv6 address-map verbose
Private address : 1000::1:0:0:1
Link local address: FE80::50:4
Type : Hub
Hub group : 1
Link protocol : UDP
Public port : 2098
Registered port : 2098
Behind NAT : No
Private address : 1000::2:0:0:1
Link local address: FE80::60:4
Type : Spoke
Hub group : 2
Link protocol : UDP
Public address : 220.181.111.85
Public port : 10018
Registered address: 10.158.26.14
Registered port : 2694
Behind NAT : Yes
Private address : 1003::1:0:0:1
Link local address: FE80::70:4
Type : Hub
Hub group : 1
Link protocol : GRE
Public address : 3001::1
Registered address: 3001::1
Behind NAT : No
Private address : 1004::1:0:0:1
Link local address: FE80::80:4
Hub group : 1
Public address : 202.108.231.125
Registered address: 202.108.231.125
Behind NAT : No
Private address : 1005::1:0:0:1
Link local address: FE80::90:4
Type : Hub
Hub group : 1
Public address : 5001::1
Registered address: 5001::1
Behind NAT : No
# Display detailed IPv6 address mapping information for VAM clients in ADVPN domain 1.
<Sysname> display vam server ipv6 address-map advpn-domain 1 verbose
Type : Hub
Hub group : 1
Link protocol : UDP
Public port : 2098
Behind NAT : No
Type : Spoke
Hub group : 2
Link protocol : UDP
Public port : 10018
Behind NAT : Yes
# Display detailed IPv6 address mapping information for the VAM client with private IPv6 address 1000::1:0:0:1 in ADVPN domain 1.
<Sysname> display vam server ipv6 address-map advpn-domain 1 ipv6 private-address 1000::1:0:0:1 verbose
Type : Hub
Hub group : 1
Link protocol : UDP
Public port : 2098
Behind NAT : No
Private address |
Link local address |
Link local address that the VAM client has registered with the VAM server. |
Type |
Hub group |
Holding time |
Link protocol |
Public address |
Public port |
Registered port |
IPsec address |
IPsec port |
Behind NAT |
Use display vam server ipv6 private-network to display IPv6 private networks for VAM clients registered with the VAM server.
display vam server ipv6 private-network [ advpn-domain domain-name [ private-address private-ipv6-address ] ]
advpn-domain domain-name: Displays IPv6 private networks for VAM clients in the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays IPv6 private networks for VAM clients in all ADVPN domains.
private-address private-ipv6-address: Displays IPv6 private networks for the VAM client with the specified private IPv6 address. If you do not specify this option, the command displays IPv6 private networks for VAM clients in the specified domain or all ADVPN domains.
# Display IPv6 private networks for VAM clients in all ADVPN domains.
<Sysname> display vam server ipv6 private-network
Total private networks: 5
Network/Prefix Private address Preference
1000::1:0:0:0/96 1000::1:0:0:2 80
1000::1:0:0:0/100 1000::1:0:0:1 80
1000::1:1:0:0/96 1000::1:0:0:1 80
1000::2:0:0:0/96 1000::1:0:0:2 80
1000::2:0:0:0/96 1000::2:0:0:2 80
Total private networks: 0
Total private networks: 1
1001::1:0:0:0/100 1001::1:0:0:1 80
# Display IPv6 private networks for VAM clients in ADVPN domain 1.
<Sysname> display vam server ipv6 private-network advpn-domain 1
# Display IPv6 private networks for the VAM client with private IPv6 address 1000::1:0:0:1.
<Sysname> display vam server ipv6 private-network advpn-domain 1 private-address 1000::1:0:0:1
Total private networks: 2
Table 5 Command output
Network/Prefix |
Private network address/prefix length for an ADVPN tunnel interface. |
Private address |
Preference |
Preference of the private route that the VAM client has registered with the VAM server. |
Use display vam server private-network to display IPv4 private networks for VAM clients registered with the VAM server.
display vam server private-network [ advpn-domain domain-name [ private-address private-ip-address ] ]
advpn-domain domain-name: Displays IPv4 private networks for VAM clients in the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays IPv4 private networks for VAM clients in all ADVPN domains.
private-address private-ip-address: Displays IPv4 private networks for the VAM client with the specified private IPv4 address. If you do not specify this option, the command displays IPv6 private networks for VAM clients in the specified domain or all ADVPN domains.
# Display IPv4 private networks for VAM clients in all ADVPN domains.
<Sysname> display vam server private-network
Network/Mask Private address Preference
192.168.0.0/24 10.0.0.2 80
192.168.0.0/28 10.0.0.1 80
192.168.1.0/24 10.0.0.1 80
192.168.100.0/24 10.0.0.2 80
192.168.100.0/24 10.0.0.3 80
192.168.200.0/24 20.0.0.1 80
# Display IPv4 private networks for VAM clients in ADVPN domain 1.
<Sysname> display vam server private-network advpn-domain 1
# Display IPv4 private networks for the VAM client with private IPv4 address 10.0.0.1.
<Sysname> display vam server private-network advpn-domain 1 private-address 10.0.0.1
Table 6 Command output
Network/Mask |
Private network address/mask length for an ADVPN tunnel interface. |
Private address |
Preference |
display vam server statistics
Use display vam server statistics to display ADVPN domain statistics on the VAM server.
display vam server statistics [ advpn-domain domain-name ]
advpn-domain domain-name: Displays statistics for the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays statistics for all ADVPN domains on the VAM server.
# Display statistics for all ADVPN domains.
<Sysname> display vam server statistics
Total ADVPN number: 3
Total spoke number: 121
Total hub number : 3
Server status : Enabled
Holding time : 0H 1M 47S
Registered spoke number: 98
Registered hub number : 2
Packets received:
Initialization request : 100
Initialization complete : 100
Register request : 100
Authentication information : 100
Address resolution request : 203
Network registration request : 59
Update request : 196
Logout request : 0
Hub information response : 2
Data flow information response: 0
Keepalive : 642
Error notification : 0
Unknown : 0
Packets sent:
Initialization response : 100
Authentication request : 100
Register response : 100
Address resolution response : 203
Network registration response: 59
Update response : 196
Hub information request : 2
Data flow information request: 0
Logout response : 0
Keepalive : 642
ADVPN domain name : 2
Server status : Disabled
Holding time : 0H 33M 53S
Registered spoke number: 23
Registered hub number : 1
Packets received:
Initialization request : 24
Initialization complete : 24
Register request : 24
Authentication information : 24
Address resolution request : 23
Network registration request : 0
Update request : 5
Logout request : 0
Keepalive : 362
Unknown : 0
Packets sent:
Initialization response : 24
Authentication request : 24
Register response : 24
Address resolution response : 23
Network registration response: 0
Update response : 0
Logout response : 0
Keepalive : 362
# Display statistics for ADVPN domain 1.
<Sysname> display vam server statistics advpn-domain 1
Packets received:
Logout request : 0
Keepalive : 642
Unknown : 0
Packets sent:
Logout response : 0
Keepalive : 642
Table 7 Command output
Server status |
Whether the VAM server is enabled: Enabled or Disabled. |
Holding time |
Duration time that elapses after the VAM service is enabled, in the format of xH yM zS. |
reset vam server statistics
encryption-algorithm
Use encryption-algorithm to specify the algorithms for VAM protocol packet encryption and their priorities.
Use undo encryption-algorithm to restore the default.
encryption-algorithm { 3des-cbc | aes-cbc-128 | aes-cbc-192 | aes-cbc-256 | aes-ctr-128 | aes-ctr-192 | aes-ctr-256 | des-cbc | none } *
The following encryption algorithms are available (in descending order of priority):
· AES-CBC-256
· AES-CBC-192
· AES-CBC-128
· AES-CTR-256
· AES-CTR-192
· AES-CTR-128
· 3DES-CBC
· DES-CBC
ADVPN domain view
3des-cbc: Uses the 3DES-CBC encryption algorithm.
aes-cbc-128: Uses the AES-CBC encryption algorithm, with a key length of 128 bits.
aes-cbc-192: Uses the AES-CBC encryption algorithm, with a key length of 192 bits.
aes-cbc-256: Uses the AES-CBC encryption algorithm, with a key length of 256 bits.
aes-ctr-128: Uses the AES-CTR encryption algorithm, with a key length of 128 bits.
aes-ctr-192: Uses the AES-CTR encryption algorithm, with a key length of 192 bits.
aes-ctr-256: Uses the AES-CTR encryption algorithm, with a key length of 256 bits.
des-cbc: Uses the DES-CBC encryption algorithm.
none: Performs no encryption.
The VAM server and client use AES-CBC-128 for connection request and response packet encryption, and use the negotiated algorithms for negotiation acknowledgment and subsequent VAM protocol packet encryption.
An encryption algorithm specified earlier by using this command has a higher priority during algorithm negotiation between a VAM server and a client. The VAM server compares its algorithms in descending order of priority with the algorithms sent by the client, and sends the matching algorithm with the highest priority to the client.
# Specify the encryption algorithms as AES-CBC-128 and 3DES-CBC for ADVPN domain 1, where AES-CBC-128 has a higher priority.
[Sysname-vam-server-domain-1] encryption-algorithm aes-cbc-128 3des-cbc
hub ipv6 private-address
Use hub ipv6 private-address to configure a hub private IPv6 address in a hub group.
Use undo hub ipv6 private-address to remove a hub private IPv6 address from a hub group.
hub ipv6 private-address private-ipv6-address [ advpn-port port-number | public-address { public-ipv4-address | public-ipv6-address } [ advpn-port port-number ] [ link-protocol { gre | ipsec-gre | ipsec-udp [ registered-address { registered-ipv4-address | registered-ipv6-address } [ registered-advpn-port port-number ] ] | udp } link-local-address link-local-address ] ]
undo hub ipv6 private-address private-ipv6-address
No hub private IPv6 address is configured.
Hub group view
private-ipv6-address: Specifies the private IPv6 address of a hub. The address must be a global unicast address.
public-address: Specifies the public address of the hub. If you do not specify this keyword, the VAM server uses the public address registered by the hub.
public-ipv4-address: Specifies the public IPv4 address of the hub. The address must be a unicast address.
public-ipv6-address: Specifies the public IPv6 address of the hub. The address must be a global unicast address.
advpn-port port-number: Specifies the ADVPN port number of the hub, in the range of 1025 to 65535. If you do not specify this option, the VAM server uses the port number registered by the hub.
link-protocol: Specifies the link protocol of the hub.
gre: Specifies GRE.
ipsec-gre: Specifies IPsec-protected GRE.
ipsec-udp: Specifies IPsec-protected UDP.
udp: Specifies UDP.
registered-address: Specifies the registered public address of the hub (public address before NAT). Configure this parameter only when the link protocol of the hub is IPsec-protected UDP and the hub is behind a NAT gateway.
registered-ipv4-address: Specifies the registered IPv4 public address of the hub. The address must be a unicast address.
registered-ipv6-address: Specifies the registered IPv6 public address of the hub. The address must be a global unicast address.
registered-advpn-port port-number: Specifies the registered ADVPN port number of the hub (ADVPN port number before NAT). If you do not specify an ADVPN port number, the default ADVPN port number 18001 is used.
link-local-address link-local-address: Specifies the IPv6 link-local address of the hub to ensure IPv6 network connectivity.
Typically, you only need to specify the private address of a hub. Other parameters are optional. However, you must specify other parameters in addition to the private address of the hub in the following scenarios:
· Hub information can be automatically obtained and the hub is behind a NAT gateway—For the hub to traverse the NAT gateway, a static mapping between the hub's registered public address/ADVPN port number and a NATed address/port number must be configured on the NAT gateway. To execute this command for the hub, specify the NATed address and port number as the public address and ADVPN port number in the command.
· Hub information is manually configured and the hub is not behind a NAT gateway—To ensure that a spoke can come online before the hub comes online after the VAM server reboots, use this command to manually configure hub information on the VAM server. The information includes the public address, ADVPN port number, link protocol, and IPv6 link-local address of the hub. The spoke can obtain the manually configured hub information from the VAM server to establish an ADVPN tunnel with the hub after the VAM server reboots.
· Hub information is manually configured and the hub is behind a NAT gateway—If the link protocol of the hub is IPsec-protected UDP, configure the parameters as follows:
¡ Use the public-address { public-ipv4-address | public-ipv6-address } option to specify the NATed address as the public address.
¡ Use the advpn-port port-number option to specify the port number NATed from IPsec port 4500 as the ADVPN port number.
¡ Use the registered-address { registered-ipv4-address | registered-ipv6-address } option to specify the public address of the hub before NAT.
¡ Use the registered-advpn-port port-number option to specify the ADVPN port number before NAT.
If the link protocol is UDP, you only need to specify the NATed address and port number configured on the NAT gateway as the public address and ADVPN port number.
If the manually configured hub information is inconsistent with the automatically registered hub information on the VAM server, the automatically registered hub information takes effect.
You can configure multiple hub private IPv6 addresses for a hub group.
If you execute this command multiple times for a private IPv6 address, the most recent configuration takes effect.
# Add a hub to hub group 1 in ADVPN domain 1 with private IPv6 address 1000::1:0:0:1, public IPv6 address 2001::1, and ADVPN port number 8000.
[Sysname-vam-server-domain-1] hub-group 1
[Sysname-vam-server-domain-1-hub-group-1] hub ipv6 private-address 1000::1:0:0:1 public-address 2001::1 advpn-port 8000
# Add a hub to hub group 0 in ADVPN domain 2. The IPv6 private address is 192:168::1, the NATed public address is 2001:dc8:1::100, and the port number NATed from IPsec port 4500 is 8650. The link protocol used by the hub is IPsec-protected UDP, the public address before NAT is fd01:203:405::1, the ADVPN port number is 18001, and the link-local address is fe80::1.
[Sysname] vam server advpn-domain 2
[Sysname-vam-server-domain-2] hub-group 0
[Sysname-vam-server-domain-2-hub-group-0] hub ipv6 private-address 192:168::1 public-address 2001:dc8:1::100 advpn-port 8650 link-protocol ipsec-udp registered-address fd01:203:405::1 registered-advpn-port 18001 link-local-address fe80::1
hub private-address
Use hub private-address to configure a hub private IPv4 address in a hub group.
Use undo hub private-address to remove a hub private IPv4 address from a hub group.
hub private-address private-ip-address [ advpn-port port-number | public-address { public-ipv4-address | public-ipv6-address } [ advpn-port port-number ] [ link-protocol { gre | ipsec-gre | ipsec-udp [ registered-address { registered-ipv4-address | registered-ipv6-address } [ registered-advpn-port port-number ] ] | udp } ] ]
undo hub private-address private-ip-address
No hub private IPv4 address is configured.
Hub group view
private-ip-address: Specifies the private IPv4 address of a hub. The address must be a unicast address.
gre: Specifies GRE.
udp: Specifies UDP.
You can configure a maximum of four hub private IPv4 addresses for a hub group.
If you execute this command multiple times for a private IPv4 address, the most recent configuration takes effect.
# Add a hub to hub group 1 in ADVPN domain 1 with private IPv4 address 10.1.1.1, public IPv4 address 123.0.0.1, and ADVPN port number 8000.
[Sysname-vam-server-domain-1-hub-group-1] hub private-address 10.1.1.1 public-address 123.0.0.1 advpn-port 8000
# Add a hub to hub group 0 in ADVPN domain 2. The IPv4 private address is 192.168.0.1, the NATed public address is 45.0.1.5, and the port number NATed from IPsec port 4500 is 7650. The link protocol used by the hub is IPsec-protected UDP, the public address before NAT is 3.3.0.2, and the ADVPN port number is 18001.
[Sysname-vam-server-domain-2-hub-group-0] hub private-address 192.168.0.1 public-address 45.0.1.5 advpn-port 7650 link-protocol ipsec-udp registered-address 3.3.0.2 registered-advpn-port 18001
hub-group
Use hub-group to create a hub group and enter its view, or enter the view of an existing hub group.
Use undo hub-group to delete a hub group.
hub-group group-name
undo hub-group group-name
No hub groups exist.
ADVPN domain view
group-name: Specifies a group by its name. A group name is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.).
Hub groups apply to large ADVPN networks. You can classify spokes to different hub groups, and specify one or more hubs for each group.
When a VAM client registers with the VAM server, the VAM server selects a hub group for the client as follows:
1. The server matches the private address of the client against the private addresses of hubs in different hub groups in lexicographic order.
2. If a match is found, the server assigns the client to the hub group as a hub.
3. If no match is found, the server matches the client's private address against the private addresses of spokes in different hub groups in lexicographic order.
4. If a match is found, the server assigns the client to the hub group as a spoke.
5. If no match is found, the registration fails.
The VAM server only assigns hub information in the matching hub group to the client. The client only establishes permanent ADVPN tunnels to the hubs in the matching hub group.
# Create hub group 1 in ADVPN domain 1, and enter hub group view.
keepalive
Use keepalive to set a keepalive interval and a maximum number of keepalive retries for VAM clients.
Use undo keepalive to restore the default.
keepalive interval interval retry retries
undo keepalive
The keepalive interval is 180 seconds and the maximum number of keepalive retries is 3.
ADVPN domain view
interval interval: Specifies the keepalive interval in the range of 5 to 65535 seconds.
retry retries: Specifies the maximum number of keepalive retries, in the range of 1 to 6.
The VAM server assigns the configured keepalive parameters to clients in the ADVPN domain.
A client sends keepalives to the server at the specified interval. If a client receives no responses from the server after maximum keepalive attempts (keepalive retries + 1), the client stops sending keepalives. If the VAM server receives no keepalives from a client before the timeout timer expires, the server removes information about the client and logs off the client. The timeout time is the product of the keepalive interval and keepalive attempts.
Newly configured keepalive parameters do not affect registered VAM clients. They apply to subsequently registered clients.
If a device configured with dynamic NAT exists between the VAM server and VAM clients, configure the keepalive interval to be shorter than the aging time of NAT entries.
Configure proper values for the keepalive parameters depending on the network condition.
# Set the keepalive interval for VAM clients in ADVPN domain 1 to 30 seconds, and the maximum number of keepalive retries to 5.
[Sysname-vam-server-domain-1] keepalive interval 30 retry 5
Use pre-shared-key to configure a preshared key for the VAM server.
Use undo pre-shared-key to remove the configuration.
pre-shared-key { cipher | simple } string
undo pre-shared-key
No preshared key is configured.
ADVPN domain view
cipher: Specifies a preshared key in encrypted form.
simple: Specifies a preshared key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the preshared key. Its plaintext form is a case-sensitive string of 1 to 31 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
The preshared key is used to generate initial encryption and authentication keys during connection initialization. It is also used to generate encryption and authentication keys for subsequent packets if encryption and authentication are needed.
The VAM server and all clients in an ADVPN domain must have the same preshared key.
# Set the key to 123 in plaintext form for the VAM server in ADVPN domain 1.
[Sysname-vam-server-domain-1] pre-shared-key simple 123
Use reset vam server address-map to clear IPv4 private-public address mapping information for VAM clients registered with the VAM server.
reset vam server address-map [ advpn-domain domain-name [ private-address private-ip-address ] ]
advpn-domain domain-name: Clears IPv4 address mapping information for VAM clients in the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command clears address mapping information for VAM clients in all ADVPN domains.
private-address private-ip-address: Clears IPv4 address mapping information for the VAM client with the specified private IPv4 address. If you do not specify this option, the command clears address mapping information for VAM clients in the specified domain or all ADVPN domains.
CAUTION: When this command is executed, the system sends an error notification to VAM clients that have registered the private IPv4 addresses and logs off the clients. |
Executing this command also clears IPv4 private network information for the private IPv4 addresses.
# Clear IPv4 address mapping information for clients in all ADVPN domains.
<Sysname> reset vam server address-map
# Clear IPv4 address mapping information for clients in ADVPN domain 1.
<Sysname> reset vam server address-map advpn-domain 1
# Clear IPv4 address mapping information for the client with private IPv4 address 10.0.0.1 in ADVPN domain 1.
<Sysname> reset vam server address-map advpn-domain 1 private-address 10.0.0.1
Use reset vam server ipv6 address-map to clear IPv6 private-public address mapping information for VAM clients registered with the VAM server.
reset vam server ipv6 address-map [ advpn-domain domain-name [ private-address private-ipv6-address ] ]
advpn-domain domain-name: Clears IPv6 address mapping information for VAM clients in the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command clears address mapping information for VAM clients in all ADVPN domains.
private-address private-ipv6-address: Clears IPv6 address mapping information for the VAM client with the specified private IPv6 address. If you do not specify this option, the command clears address mapping information for VAM clients in the specified domain or all ADVPN domains.
CAUTION: When this command is executed, the system sends an error notification to VAM clients that have registered the private IPv6 addresses and logs off the clients. |
Executing this command also clears IPv6 private network information for the private IPv6 addresses.
# Clear IPv6 address mapping information for clients in all ADVPN domains.
<Sysname> reset vam server ipv6 address-map
# Clear IPv6 address mapping information for clients in ADVPN domain 1.
<Sysname> reset vam server ipv6 address-map advpn-domain 1
# Clear IPv6 address mapping information for the client with private IPv6 address 1000::1:0:0:1 in ADVPN domain 1.
<Sysname> reset vam server ipv6 address-map advpn-domain 1 private-address 1000::1:0:0:1
Use reset vam server statistics to clear ADVPN domain statistics on the VAM server.
reset vam server statistics [ advpn-domain domain-name ]
advpn-domain domain-name: Clears statistics for the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command clears statistics for all ADVPN domains on the server.
# Clear statistics for ADVPN domain abc.
<Sysname> reset vam server statistics advpn-domain abc
# Clear statistics for all ADVPN domains.
retry interval
Use retry interval to set the retry timer for the VAM server.
Use undo retry interval to restore the default.
retry interval interval
undo retry interval
The retry timer is 5 seconds.
ADVPN domain view
interval: Specifies the retry timer in the range of 3 to 30 seconds.
The VAM server starts the retry timer after it sends a request to a client. If the server receives no response from the client before the retry timer expires, the server resends the request. The server stops sending the request after receiving a response from the client or after the timeout timer (product of the keepalive interval and keepalive attempts) expires.
# Set the retry timer to 20 seconds for the VAM server in ADVPN domain 1.
[Sysname-vam-server-domain-1] retry interval 20
server enable
Use server enable to enable the VAM server for an ADVPN domain.
Use undo server enable to disable the VAM server for an ADVPN domain.
server enable
undo server enable
The VAM server is disabled for an ADVPN domain.
ADVPN domain view
You can also execute the vam server enable command in system view to enable the VAM server for one or all ADVPN domains.
# Enable the VAM server for ADVPN domain 1.
[Sysname-vam-server-domain-1] server enable
vam server enable
shortcut interest
Use shortcut interest to specify an ACL to control establishing IPv4 spoke-to-spoke tunnels.
Use undo shortcut interest to restore the default.
shortcut interest { acl { acl-number | name acl-name } all }
Spokes are not allowed to establish direct tunnels.
Hub group view
acl: Specifies an ACL to control establishing IPv4 spoke-to-spoke tunnels.
acl-number: Specifies an IPv4 ACL by its number:
· 2000 to 2999 for IPv4 basic ACLs.
· 3000 to 3999 for IPv4 advanced ACLs.
name acl-name: Specifies an ACL by its name. An ACL name is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
all: Allows establishing IPv4 spoke-to-spoke tunnels between all spokes in different hub groups.
The VAM server assigns the specified ACL to an online hub. When receiving an IPv4 spoke-to-spoke packet from a spoke, the hub sends a redirect packet to the spoke if all is specified or if the packet matches an ACL rule. Then, the spoke sends the VAM server the destination address of the packet, obtains the remote spoke information, and establishes a direct tunnel to the remote spoke.
After a spoke-spoke tunnel is established, the spokes directly exchange packets.
When you specify an IPv4 ACL, follow these guidelines:
· If the ACL does not exist, the configuration does not take effect. The hub does not send any redirect packets to the spoke.
· If the ACL is an IPv4 basic ACL, this command supports only rules that match source addresses.
· If the ACL is an IPv4 advanced ACL, this command supports rules that match protocol numbers, source/destination addresses, and source/destination ports. It does not support rules that exclude a source/destination port.
· If the ACL contains an unsupported rule, the rule does not take effect.
# Specify ACL 3000 to control establishing IPv4 spoke-to-spoke tunnels.
[Sysname-vam-server-domain-1-hub-group-1] shortcut interest acl 3000
Use shortcut ipv6 interest to specify an ACL to control establishing IPv6 spoke-to-spoke tunnels.
Use undo shortcut ipv6 interest to restore the default.
shortcut ipv6 interest { acl { ipv6-acl-number | name ipv6-acl-name } all }
Hub group view
acl: Specifies an ACL to control establishing IPv6 spoke-to-spoke tunnels.
ipv6-acl-number: Specifies an IPv6 ACL by its number:
· 2000 to 2999 for IPv6 basic ACLs.
· 3000 to 3999 for IPv6 advanced ACLs.
name ipv6-acl-name: Specifies an IPv6 ACL by its name. An IPv6 ACL name is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
all: Allows establishing IPv6 spoke-to-spoke tunnels between all spokes in different hub groups.
The VAM server assigns the specified ACL to an online hub. When receiving an IPv6 spoke-to-spoke packet from a spoke, the hub sends a redirect packet to the spoke if all is specified or if the packet matches an ACL rule. Then, the spoke sends the destination address of the packet to the VAM server, obtains the remote spoke information, and establishes a direct tunnel to the remote spoke.
When you specify an IPv6 ACL, follow these guidelines:
· If the ACL is an IPv6 basic ACL, this command supports only rules that match source addresses.
· If the ACL is an IPv6 advanced ACL, this command supports rules that match protocol numbers, source/destination addresses, and source/destination ports. It does not support rules that exclude a source/destination port.
# Specify ACL 3000 to control establishing IPv6 spoke-to-spoke tunnels.
[Sysname-vam-server-domain-1-hub-group-1] shortcut ipv6 interest acl 3000
spoke ipv6 private-address
Use spoke ipv6 private-address to configure a spoke private IPv6 address range in a hub group.
Use undo ipv6 spoke private-address to delete a spoke private IPv6 address range in a hub group.
spoke ipv6 private-address { network prefix prefix-length | range start-ipv6-address end-ipv6-address }
undo spoke ipv6 private-address { network prefix prefix-length | range start-ipv6-address end-ipv6-address }
No spoke private IPv6 address range is configured.
Hub group view
network prefix prefix-length: Specifies a prefix and prefix length. The value range for prefix-length is 0 to 128.
range start-ipv6-address end-ipv6-address: Specifies a start IPv6 address and an end IPv6 address.
If you specify a prefix and prefix length, the system automatically transforms them to a start address and an end address.
You can configure multiple spoke private IPv6 address ranges in a hub group. The ranges are listed from low to high.
The spoke private IPv6 address range to be deleted must be the same as the configured one.
# Configure a spoke private IPv6 address range in IPv6 network address format as 1000::/64 for hub group 1.
[Sysname-vam-server-domain-1-hub-group-1] spoke ipv6 private-address network 1000:: 64
Use spoke private-address to configure a spoke private IPv4 address range in a hub group.
Use undo spoke private-address to delete a spoke private IPv4 address range in a hub group.
spoke private-address { network ip-address { mask-length | mask } | range start-ipv4-address end-ipv4-address }
undo spoke private-address { network ip-address { mask-length | mask } | range start-ipv4-address end-ipv4-address }
No spoke private IPv4 address range is configured.
Hub group view
network ip-address { mask-length | mask }: Specifies an IPv4 address and its mask length (or mask). The value range for mask-length is 0 to 32.
range start-address end-address: Specifies a start IPv4 address and an end IPv4 address.
If you specify an IPv4 address and its mask length (or mask), the system automatically transforms them to a start address and an end address.
You can configure multiple spoke private IPv4 address ranges in a hub group. The ranges are listed from low to high.
The spoke private IPv4 address range to be deleted must be the same as the configured one.
# Configure a spoke private IPv4 address range in IPv4 network address format as 1.1.1.0/24 for hub group 1.
[Sysname-vam-server-domain-1-hub-group-1] spoke private-address network 1.1.1.0 255.255.255.0
Use vam server advpn-domain to create an ADVPN domain and enter its view, or enter the view of an existing ADVPN domain.
Use undo vam server advpn-domain to remove an ADVPN domain.
vam server advpn-domain domain-name [ id domain-id ]
undo vam server advpn-domain domain-name
No ADVPN domains exist.
domain-name: Specifies an ADVPN domain by its name. An ADVPN domain name is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.).
id domain-id: Specifies the ID of an ADVPN domain, in the range of 1 to 65535.
An ADVPN domain ID is required only when you create the ADVPN domain.
You must specify a unique domain ID for an ADVPN domain.
# Create ADVPN domain 1 with domain ID 1, and enter its view.
[Sysname] vam server advpn-domain 1 id 1
vam server enable
Use vam server enable to enable the VAM server for ADVPN domains.
Use undo vam server enable to disable the VAM server for ADVPN domains.
vam server enable [ advpn-domain domain-name ]
undo vam server enable [ advpn-domain domain-name ]
advpn-domain domain-name: Enables the VAM server for the specified ADVPN domain. The domain-name argument is a case-insensitive string of 1 to 31 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command enables the VAM server for all ADVPN domains.
You can also execute the server enable command in ADVPN domain view to enable the VAM server for an ADVPN domain.
# Enable the VAM server for all ADVPN domains.
[Sysname] vam server enable
[Sysname] vam server enable advpn-domain 1
server enable
vam server listen-port
Use vam server listen-port to set the port number of the VAM server.
Use undo vam server listen-port to restore the default.
vam server listen-port port-number
The port number of the VAM server is 18000.
port-number: Specifies the port number in the range of 1025 to 65535.
The port number of the VAM server must be the same as the port configured on the VAM clients.
# Set the port number to 10000.
[Sysname] vam server listen-port 10000
server primary
server secondary
VAM client commands
advpn-domain
Use advpn-domain to specify an ADVPN domain for a VAM client.
Use undo advpn-domain to remove the ADVPN domain.
undo advpn-domain
No ADVPN domain is specified for a VAM client.
VAM client view
An ADVPN domain can contain multiple VAM clients.
# Specify ADVPN domain 100 for VAM client abc.
[Sysname] vam client name abc
[Sysname-vam-client-abc] advpn-domain 100
client enable
Use client enable to enable a VAM client.
Use undo client enable to disable a VAM client.
client enable
undo client enable
The VAM client is disabled.
VAM client view
You can also execute the vam client enable command in system view to enable one or all VAM clients.
# Enable VAM client abc.
[Sysname-vam-client-abc] client enable
vam client enable
display vam client fsm
Use display vam client fsm to display FSM information for VAM clients.
display vam client fsm [ name client-name ]
name client-name: Displays FSM information for the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays FSM information for all VAM clients.
This command only displays the configured parameters and dynamically obtained information.
# Display FSM information for all VAM clients.
<Sysname> display vam client fsm
Client name : abc
Status : Enabled
Primary server: abc.com (28.1.1.23)
Private address: 10.0.0.12
Interface : Tunnel1
Current state : Online (active)
Client type : Hub
Holding time : 9H 20M 30S
Encryption algorithm : AES-CBC-128
Authentication algorithm: SHA1
Keepalive : 30 seconds, 3 times
Number of hubs : 1
Private address: 1000::22
Interface : Tunnel2
Client type : Spoke
Number of hubs : 1
Secondary server: 2811::24
Interface : Tunnel1
Current state : Offline
Client type : Unknown
Holding time : 0H 0M 0S
Keepalive : 0 seconds, 0 times
Number of hubs : 0
Interface : Tunnel2
Number of hubs : 0
Client name : hub
Status : Enabled
Primary server: 202.159.36.24
Interface : Tunnel20
Client type : Hub
Holding time : 0H 0M 47S
Number of hubs : 1
Client name : spoke
Status : Disabled
ADVPN domain name:
Table 8 Command output
Status |
VAM client status: Enabled or Disabled. |
Primary server |
Public address of the primary VAM server. |
Private address |
ADVPN tunnel interface for the VAM client. |
Current state |
Current state of the VAM client: · Offline. · Init. · Reg. · Online. · Dumb. |
Client type |
VAM client type: · Hub. · Spoke. · Unknown. |
Holding time |
Duration time since the VAM client stayed in its current state, in the format of xH yM zS. |
Encryption algorithm |
Negotiated encryption algorithm. |
Authentication algorithm |
Negotiated authentication algorithm. |
Keepalive |
Keepalive interval (in seconds) and number of retransmissions configured on the VAM server. |
Secondary server |
Public address of the secondary VAM server. |
reset vam client fsm
Use display vam client shortcut interest to display IPv4 spoke-to-spoke tunnel establishment rules for VAM clients.
display vam client shortcut interest [ name client-name ]
name client-name: Displays IPv4 spoke-to-spoke tunnel establishment rules for the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays IPv4 spoke-to-spoke tunnel establishment rules for all VAM clients.
The VAM server assigns the rules for establishing IPv4 spoke-to-spoke tunnels only to hubs. If the specified VAM client is a spoke, the number of rules is displayed as 0.
# Display IPv4 spoke-to-spoke tunnel establishment rules for all VAM clients.
<Sysname> display vam client shortcut interest
Client name : abc
Client type : Spoke
ACL rules : 0
Client name : hub
Client type : Hub
ACL rules : 2
Rule 1: Permit
Protocol : 6 (TCP)
Source : Address 0.0.0.0-255.255.255.255, port 0-65535
Destination: Address 192.168.114.100-192.168.114.200, port 10000-20000
Rule 2: Deny
Protocol : 0 (IP)
Destination: Address 0.0.0.0-255.255.255.255, port 0-65535
Client name : spoke
ACL rules : 0
# Display IPv4 spoke-to-spoke tunnel establishment rules for VAM client abc.
<Sysname> display vam client shortcut interest name abc
Client name : abc
Client type : Spoke
ACL rules : 0
Table 9 Command output
Client type |
ACL rules |
Number of ACL rules received by the VAM client. |
Rule n: Operation |
n represents the number of an ACL rule. Rule operation: · Permit—Allows the spokes to establish direct tunnels. · Deny—Disallows the spokes to establish direct tunnels. · Discard—Discards packets. |
Protocol |
Matching protocol number. |
Source |
Matching source IP address range and port number range. |
Destination |
Matching destination IP address range and port number range. |
Use display vam client shortcut ipv6 interest to display IPv6 spoke-to-spoke tunnel establishment rules for VAM clients.
display vam client shortcut ipv6 interest [ name client-name ]
name client-name: Displays IPv6 spoke-to-spoke tunnel establishment rules for the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays IPv6 spoke-to-spoke tunnel establishment rules for all VAM clients.
The VAM server assigns the rules for establishing IPv6 spoke-to-spoke tunnels only to hubs. If the specified VAM client is a spoke, the number of rules is displayed as 0.
# Display IPv6 spoke-to-spoke tunnel establishment rules for all VAM clients.
<Sysname> display vam client shortcut ipv6 interest
Client name : abc
Client type : Spoke
ACL rules : 0
Client name : hub
Client type : Hub
ACL rules : 2
Rule 1: Permit
Protocol : TCP
Start source address : 0::0
End source address : FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF
Start source port : 0
End source port : 65535
Start destination address: 2000::0
End destination address : 2000:1::0
Start destination port : 0
End destination port : 65535
Rule 2: Deny
Protocol : All
Start destination address: 0::0
End destination address : FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF:FFFF
Client name : spoke
ADVPN domain name:
ACL rules : 0
# Display IPv6 spoke-to-spoke tunnel establishment rules for VAM client abc.
<Sysname> display vam client shortcut ipv6 interest name abc
Client name : spoke
ADVPN domain name:
ACL rules : 0
Table 10 Command output
Client type |
ACL rules |
Rule n: operation |
Protocol |
Start source address |
Matching start address of the source IPv6 address range. |
End source address |
Matching end address of the source IPv6 address range. |
Start source port |
Matching start port number of the source port number range. |
End source port |
Matching end port number of the source port number range. |
Start destination address |
Matching start address of the destination IPv6 address range. |
End destination address |
Matching end address of the destination IPv6 address range. |
Start destination port |
Matching start port number of the destination port number range. |
End destination port |
Matching end port number of the destination port number range. |
display vam client statistics
Use display vam client statistics to display VAM client statistics.
display vam client statistics [ name client-name ]
name client-name: Displays statistics for the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command displays statistics for all VAM clients.
# Display statistics for all VAM clients.
<Sysname> display vam client statistics
Client name: abc
Status : Enabled
Packets sent:
Address resolution request : 9
Update request : 0
Logout request : 0
Hub information response : 0
Keepalive : 35
Packets received:
Address resolution response : 9
Update response : 0
Hub information request : 0
Logout response : 0
Keepalive : 35
Unknown : 0
Secondary server: 28.1.1.24
Packets sent:
Initialization request : 15
Initialization complete : 0
Register request : 0
Authentication information : 0
Address resolution request : 0
Update request : 0
Logout request : 0
Keepalive : 0
Packets received:
Initialization response : 0
Register response : 0
Authentication request : 0
Address resolution response : 0
Update response : 0
Logout response : 0
Keepalive : 0
Unknown : 0
Client name: hub
Status : Disabled
Client name: spoke
Status : Enabled
Primary server: test.com
Packets sent:
Initialization request : 3
Initialization complete : 3
Register request : 3
Authentication information : 3
Update request : 0
Logout request : 0
Keepalive : 124
Packets received:
Initialization response : 3
Authentication request : 3
Register response : 3
Update response : 0
Logout response : 0
Keepalive : 114
Unknown : 0
# Display statistics for VAM client abc.
<Sysname> display vam client statistics name abc
Client name: abc
Status : Enabled
Packets sent:
Update request : 0
Logout request : 0
Keepalive : 35
Packets received:
Update response : 0
Logout response : 0
Keepalive : 35
Unknown : 0
Packets sent:
Update request : 0
Logout request : 0
Keepalive : 0
Packets received:
Update response : 0
Logout response : 0
Keepalive : 0
Unknown : 0
Table 11 Command output
Status |
Primary server |
Public address or domain name of the primary VAM server. |
Secondary server |
Public address or domain name of the secondary VAM server. |
reset vam client statistics
dumb-time
Use dumb-time to set the dumb timer for a VAM client.
Use undo dumb-time to restore the default.
dumb-time time-interval
undo dumb-time
The dumb timer for a VAM client is 120 seconds.
VAM client view
time-interval: Specifies the dumb timer in the range of 10 to 600 seconds.
A VAM client starts the dumb timer after the timeout timer expires. The client does not process any packets during the dumb time. When the dumb timer expires, the client sends a new connection request to the VAM server.
# Set the dumb timer to 100 seconds.
[Sysname-vam-client-abc] dumb-time 100
Use pre-shared-key to configure a preshared key for a VAM client.
undo pre-shared-key
No preshared key is configured for a VAM client.
VAM client view
All VAM clients and the VAM server in an ADVPN domain must have the same preshared key.
# Set the key to 123 in plaintext form for VAM client abc.
[Sysname-vam-client-abc] pre-shared-key simple 123
vam client name
Use reset vam client fsm to reset FSMs for VAM clients.
reset vam client fsm [ name client-name ]
name client-name: Resets the FSM for the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command resets FSMs for all VAM clients.
CAUTION: After you use the reset vam client fsm command to reset the FSM for a VAM client, the client will immediately try to come online. |
# Reset the FSM for VAM client abc.
<Sysname> reset vam client fsm name abc
# Reset FSMs for all VAM clients.
reset vam client ipv6 fsm
Use reset vam client ipv6 fsm to reset FSMs for IPv6 VAM clients.
reset vam client ipv6 fsm [ name client-name ]
name client-name: Resets the FSM for the specified IPv6 VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command resets FSMs for all IPv6 VAM clients.
CAUTION: After you use the reset vam client ipv6 fsm command to reset the FSM for an IPv6 VAM client, the client will immediately try to come online. |
# Reset the FSM for IPv6 VAM client abc.
<Sysname> reset vam client ipv6 fsm name abc
# Reset FSMs for all IPv6 VAM clients.
Use reset vam client statistics to clear VAM client statistics.
reset vam client statistics [ name client-name ]
name client-name: Clears statistics for the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command clears statistics for all VAM clients.
# Clear statistics for VAM client abc.
<Sysname> reset vam client statistics name abc
# Clear statistics for all VAM clients.
retry
Use retry to set the retry interval and retry number for a VAM client.
Use undo retry to restore the default.
retry interval interval count retries
undo retry
The retry interval is 5 seconds and the retry number is 3.
VAM client view
interval interval: Specifies the retry interval in the range of 3 to 30 seconds.
count retries: Specifies the number of retries, in the range of 1 to 6.
After a VAM client sends a request to the server, it resends the request if it does not receive any responses within the retry interval. If the client fails to receive a response after maximum attempts (retry times + 1), the client determines that the server is unreachable.
The retry-times setting does not apply to register and update requests. The client sends those requests at the retry interval until it goes offline.
# Set the retry interval to 20 seconds and the retry number to 4 for VAM client abc.
[Sysname-vam-client-abc] retry interval 20 count 4
server primary
Use server primary to specify a primary VAM server for a VAM client.
Use undo server primary to restore the default.
server primary { ip-address ipv4-address | ipv6-address ipv6-address | name host-name } [ port port-number ]
undo server primary
No primary VAM server is specified.
VAM client view
ip-address ipv4-address: Specifies a public IPv4 address for the primary VAM server. The address must be a unicast address.
ipv6-address ipv6-address: Specifies a public IPv6 address for the primary VAM server. The address must be a global unicast address.
name host-name: Specifies a domain name for the primary VAM server. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), and underscores (_). The domain name can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
port port-number: Specifies a port number for the primary VAM server, in the range of 1025 to 65535. The default is 18000.
The port number of a VAM server must be the same as the port number configured on the VAM server by using the vam server listen-port command.
If the specified primary and secondary VAM servers have the same address or name, only the primary VAM server takes effect.
# Specify the domain name of the primary VAM server as abc.com and port number as 2000 for VAM client abc.
[Sysname-vam-client-abc] server primary name abc.com port 2000
# Specify the public IP address of the primary VAM server as 1.1.1.1 and port number as 2000 for VAM client abc.
[Sysname-vam-client-abc] server primary ip-address 1.1.1.1 port 2000
# Specify the public IPv6 address of the primary VAM server as 1001::1 and port number as 2000 for VAM client abc.
[Sysname-vam-client-abc] server primary ipv6-address 1001::1 port 2000
server secondary
server secondary
Use server secondary to specify a secondary VAM server for a VAM client.
Use undo server secondary to restore the default.
server secondary { ip-address ipv4-address | ipv6-address ipv6-address | name host-name } [ port port-number ]
No secondary VAM server is specified.
VAM client view
ip-address ipv4-address: Specifies a public IPv4 address for the secondary VAM server. The address must be a unicast address.
ipv6-address ipv6-address: Specifies a public IPv6 address for the secondary VAM server. The address must be a global unicast address.
name host-name: Specifies a domain name of a secondary VAM server. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), and underscores (_). The domain name can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
port port-number: Specifies a port number for the secondary VAM server, in the range of 1025 to 65535. The default is 18000.
# Specify the domain name of the secondary VAM server as abc.com and port number as 2000 for VAM client abc.
[Sysname-vam-client-abc] server secondary name abc.com port 2000
# Specify the public IP address of the secondary VAM server as 1.1.1.2 and port number as 3000 for VAM client abc.
[Sysname-vam-client-abc] server secondary ip-address 1.1.1.2 port 3000
# Specify the public IPv6 address of the primary VAM server as 1001::2 and port number as 3000 for VAM client abc.
[Sysname-vam-client-abc] server secondary ipv6-address 1001::2 port 3000
server primary
user
Use user to configure a username and password for a VAM client.
Use undo user to restore the default.
user username password { cipher | simple } string
undo user
No username or password is configured.
VAM client view
username: Specifies a username. The username is a case-sensitive string of 1 to 253 characters. It cannot include slashes (/), back slashes (\), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), quotation marks ("), vertical bars (|), and at signs (@).
password: Specifies a password.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 63 characters. Its encrypted form is a case-sensitive string of 1 to 117 characters.
You can configure only one username for a VAM client.
# Configure the username as user and password as user in plaintext form for VAM client abc.
[Sysname-vam-client-abc] user user password simple user
vam client enable
Use vam client enable to enable VAM clients.
Use undo vam client enable to disable VAM clients.
vam client enable [ name client-name ]
undo vam client enable [ name client-name ]
name client-name: Enables the specified VAM client. The client-name argument is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.). If you do not specify this option, the command enables all VAM clients.
You can also execute the client enable command in VAM client view to enable a VAM client.
# Enable all VAM clients.
[Sysname] vam client enable
[Sysname] vam client enable name abc
client enable
vam client name
Use vam client name to create a VAM client and enter its view, or enter the view of an existing VAM client.
Use undo vam client name to remove a VAM client.
vam client name client-name
undo vam client name client-name
No VAM clients exist.
client-name: Specifies a VAM client by its name. A VAM client name is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.).
# Create VAM client abc and enter its view.
ADVPN tunnel commands
advpn group
Use advpn group to configure an ADVPN group name.
Use undo advpn group to restore the default.
advpn group group-name
undo advpn group
No ADVPN group name is configured.
Tunnel interface view
group-name: Specifies the ADVPN group name. The group name is a case-insensitive string of 1 to 63 characters that can include only letters, digits, and dots (.).
This command must be used on the tunnel interface of a spoke. The spoke sends the ADVPN group name in a hub-spoke tunnel establishment request to a hub. The hub looks for an ADVPN group-to-QoS policy mapping that matches the ADVPN group name. If a matching mapping is found, the hub applies the QoS policy in the mapping to the hub-spoke tunnel. If no match is found, the hub does not apply a QoS policy to the hub-spoke tunnel.
If you modify the ADVPN group name after the tunnel is established, the spoke will inform the hub of the modification. The hub will look for an ADVPN group-to-QoS policy mapping that matches the new ADVPN group name and apply the QoS policy in the new mapping.
As a best practice, do not configure an ADVPN group name and apply a QoS policy on the same tunnel interface.
# Configure aaa as the ADVPN group name.
[Sysname] interface tunnel1 mode advpn gre
[Sysname-Tunnel1] advpn group aaa
advpn ipv6 network
Use advpn ipv6 network to configure a private IPv6 network for an IPv6 ADVPN tunnel interface.
Use undo advpn ipv6 network to remove a private IPv6 network from an IPv6 ADVPN tunnel interface.
advpn ipv6 network prefix prefix-length [ preference preference-value ]
undo advpn ipv6 network prefix prefix-length
No private IPv6 network is configured.
prefix prefix-length: Specifies the prefix and prefix length of the private IPv6 network address. The value range for prefix-length is 0 to 128.
preference preference-value: Specifies a preference for the route to the private network, in the range of 1 to 255. The default is 8.
This command is available only for IPv6 ADVPN tunnel interfaces.
Each VAM client registers the private networks for an ADVPN tunnel with the VAM server. If another VAM client receives a packet with the destination address resolved as a registered private address, the VAM server sends the registered VAM client information to the client.
This command takes effect on a tunnel interface that has been configured with an IPv6 address and bound to a VAM client by using the vam ipv6 client command.
You can configure multiple private IPv6 networks for a tunnel interface.
Set the preference of the private network route to be higher than other dynamic routing protocols, and lower than static routing. A higher preference value represents a lower priority.
# Configure private IPv6 network 1001::/64 for Tunnel 1, and set the route preference to 20.
[Sysname] interface tunnel 1 mode advpn udp ipv6
[Sysname-Tunnel1] advpn ipv6 network 1001:: 64 preference 20
vam ipv6 client
advpn logging enable
Use advpn logging enable to enable ADVPN logging.
Use undo advpn logging enable to disable ADVPN logging.
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
Yes |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK, MSR810-EI, MSR810-LMS, MSR810-LUS |
Yes |
MSR810-LMS-EA, MSR810-LME |
Yes |
MSR1004S-5G |
Yes |
MSR2600-6-X1, MSR2600-15-X1 |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
No |
MSR3600-28, MSR3600-51 |
No |
No |
No |
No |
Yes |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
MSR2600-10-X1-WiNet |
Yes |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
ADVPN logging is disabled.
This command enables the device to generate logs for the ADVPN module and send the logs to the information center of the device. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
# Enable ADVPN logging.
[Sysname] advpn logging enable
advpn map group
Use advpn map group to configure a mapping between an ADVPN group and a QoS policy.
Use undo advpn map group to delete a mapping between an ADVPN group and a QoS policy.
advpn map group group-name qos-policy policy-name outbound
undo advpn map group group-name
No ADVPN group-to-QoS policy mappings are configured.
qos-policy policy-name: Specifies the QoS policy name, a case-sensitive string of 1 to 31 characters.
outbound: Applies the QoS policy to the outbound direction.
This command must be used on the tunnel interface of a hub. After receiving a hub-spoke tunnel establishment request from a spoke, the hub looks for an ADVPN group-to-QoS policy mapping that matches the ADVPN group name carried in the request. If a matching mapping is found, the hub applies the QoS policy in the mapping to the hub-spoke tunnel.
You can configure multiple ADVPN group-to-QoS policy mappings on a tunnel interface.
You can map multiple ADVPN groups to a QoS policy. You can map an ADVPN group to only one QoS policy.
As a best practice, do not configure an ADVPN group-to-QoS policy mapping and apply a QoS policy on the same tunnel interface.
# Configure a mapping between ADVPN group aaa and QoS policy bbb on Tunnel1.
[Sysname] interface Tunnel1 mode advpn gre
[Sysname-Tunnel1] advpn map group aaa qos-policy bbb outbound
advpn network
Use advpn network to configure a private IPv4 network for an IPv4 ADVPN tunnel interface.
Use undo advpn network to remove a private IPv4 network from an IPv4 ADVPN tunnel interface.
advpn network ip-address { mask-length | mask } [ preference preference-value ]
undo advpn network ip-address { mask-length | mask }
No private IPv4 network is configured.
ip-address: Specifies the private IPv4 network address.
mask-length: Specifies the mask length of the private IPv4 network address, in the range of 0 to 32.
mask: Specifies the mask of the private IPv4 network address.
This command is available only for IPv4 ADVPN tunnel interfaces.
This command takes effect on a tunnel interface that has been configured with an IPv4 address and bound to a VAM client by using the vam client command.
You can configure multiple private IPv4 networks for a tunnel interface.
# Configure private IPv4 network 10.0.5.0 with mask 255.255.255.0 for Tunnel 1, and set the route preference to 20.
[Sysname-Tunnel1] advpn network 10.0.5.0 255.255.255.0 preference 20
vam client
advpn session dumb-time
Use advpn session dumb-time to set the dumb time for an ADVPN tunnel interface.
Use undo advpn session dumb-time to restore the default.
advpn session dumb-time time-interval
The dumb time is 120 seconds.
time-interval: Specifies the dumb time in the range of 10 to 600 seconds.
This command is available only for ADVPN tunnel interfaces.
The new dumb time setting only applies to subsequently established tunnels.
# Set the dumb time to 100 seconds.
[Sysname-Tunnel1] advpn session dumb-time 100
advpn session idle-time
Use advpn session idle-time to set the idle timeout time for a spoke-spoke ADVPN tunnel.
Use undo advpn session idle-time to restore the default.
advpn session idle-time time-interval
The idle timeout time is 600 seconds.
time-interval: Specifies the idle timeout time in the range of 60 to 65535 seconds.
The new idle timeout setting applies to both established and subsequently established spoke-spoke tunnels.
If no data is forwarded along a spoke-spoke tunnel during the idle timeout time, the tunnel will be removed automatically.
# Set the idle timeout time to 800 seconds.
[Sysname-tunnel1] advpn session idle-time 800
advpn source-port
Use advpn source-port to set the source UDP port number for ADVPN packets.
Use undo advpn source-port to restore the default.
advpn source-port port-number
The source UDP port number is 18001.
port-number: Specifies the UDP port number in the range of 1025 to 65535.
This command is available only for UDP-encapsulated ADVPN tunnels.
If the vam client command configured on the tunnel interface has the compatible keyword, the tunnel interface must have a different source UDP port number than other tunnel interfaces.
# Set the source UDP port number to 6000.
[Sysname-Tunnel1] advpn source-port 6000
vam client
display advpn group-qos-map
Use display advpn group-qos-map to display ADVPN group-to-QoS policy mappings.
display advpn group-qos-map [ interface tunnel number [ group group-name ] ]
interface tunnel number: Specifies an ADVPN tunnel interface by its tunnel interface number. The value range for the number argument is 0 to 1023. If you do not specify a tunnel interface, this command displays ADVPN group-to-QoS policy mappings for all ADVPN tunnel interfaces.
group group-name: Specifies an ADVPN group by its name. If you do not specify an ADVPN group, this command displays ADVPN group-to-QoS policy mappings for all ADVPN groups.
# Display ADVPN group-to-QoS policy mappings for all ADVPN tunnel interfaces.
<Sysname> display advpn group-qos-map
Interface: Tunnel1
ADVPN group: group1
QoS policy: policy1
Session list:
Private address Public address
10.0.0.3 192.168.180.136
10.0.1.4 192.168.180.137
ADVPN group: bb
QoS policy: bb-policy
No sessions match the ADVPN group-to-QoS policy mapping.
Interface: Tunnel2
ADVPN group: group2
QoS policy: policy2
Session list:
20.0.0.3 200::3
Table 12 Command output
ADVPN tunnel interface. |
ADVPN group |
ADVPN group name. |
QoS policy |
QoS policy to which the ADVPN group is mapped. |
Session list |
List of ADVPN tunnels that use the QoS policy on the tunnel interface. |
Private address |
Private address of the ADVPN tunnel peer. |
Public address |
Public address of the ADVPN tunnel peer. |
No sessions match the ADVPN group-to-QoS policy mapping |
No ADVPN tunnels match the ADVPN group-to-QoS policy mapping on the tunnel interface. |
advpn group
advpn map group
display advpn ipv6 session
Use display advpn ipv6 session to display IPv6 ADVPN tunnel information.
display advpn ipv6 session [ interface tunnel number [ private-address private-ipv6-address ] ] [ verbose ]
interface tunnel number: Displays information about IPv6 ADVPN tunnels on an IPv6 ADVPN tunnel interface specified by the interface number. If you do not specify this option, the command displays information about all IPv6 ADVPN tunnels.
private-address private-ipv6-address: Displays information about the IPv6 ADVPN tunnel with the specified peer private IPv6 address. If you do not specify this option, the command displays information about the specified IPv6 ADVPN tunnel or all IPv6 ADVPN tunnels.
verbose: Displays detailed IPv6 ADVPN tunnel information. If you do not specify this keyword, the command displays brief IPv6 ADVPN tunnel information.
# Display brief information about all IPv6 ADVPN tunnels.
<Sysname> display advpn ipv6 session
Interface : Tunnel1
Number of sessions: 2
Private address Public address Port Type State Holding time
1001::3 2000::180:136 1139 H-S Success 5H 38M 8S
1001::4 2000::180:137 3546 H-S Dumb 0H 0M 27S
Interface : Tunnel2
Number of sessions: 1
1002::4 202.0.180.137 -- S-H Establish 0H 0M 2S
Interface : Tunnel3
1003::4 2003::180:137 2057 S-S Success 1H 12M 26S
Interface : Tunnel4
1004::4 204.1.181:157 -- H-H Success 10H 48M 19S
Interface : Tunnel5
Number of sessions: 0
# Display brief information about IPv6 ADVPN tunnels on Tunnel 1.
<Sysname> display advpn ipv6 session interface tunnel 1
Interface : Tunnel1
# Display brief information about the IPv6 ADVPN tunnel with peer private IPv6 address 1001::3 on Tunnel 1.
<Sysname> display advpn ipv6 session interface tunnel 1 private-address 1001::3
Table 13 Command output
Number of sessions |
Number of ADVPN tunnels established on the tunnel interface. |
Private address |
Public address |
Port |
Port number of the ADVPN tunnel peer. |
Type |
ADVPN tunnel type: · H-H—Both the local end and the remote end are hubs. · H-S—The local end is a hub and the remote end is a spoke. · S-H—The local end is a spoke and the remote end is a hub. · S-S—Both the local end and the remote end are spokes. |
State |
ADVPN tunnel state: · Success—The tunnel has been successfully established. · Establishing—The tunnel is being established. · Dumb—The tunnel failed to be established and is now quiet. |
Holding time |
Duration time since the tunnel stayed in the current state, in the format of xH yM zS. |
# Display detailed information about all IPv6 ADVPN tunnels.
<Sysname> display advpn ipv6 session verbose
Interface : Tunnel1
Client name : vpn1
ADVPN domain name : 1
Link protocol : UDP
Private address: 1001::3
Public address : 2000::180:136
ADVPN port : 1139
Session type : Hub-Spoke
State : Success
Holding time : 5H 38M 8S
Input : 2201 packets, 2198 data packets, 3 control packets
2191 multicasts, 0 errors
Output: 2169 packets, 216 data packets, 1 control packets
2163 multicasts, 0 errors
Private address: 1001::4
Public address : 2000::180:137
ADVPN port : 3546
State : Dumb
Holding time : 0H 0M 27S
Input : 1 packets, 0 data packets, 1 control packets
0 multicasts, 0 errors
Output: 16 packets, 0 data packets, 16 control packets
Interface : Tunnel2
Client name : vpn2
ADVPN domain name : 2
Link protocol : GRE
Private address: 1002::4
Public address : 202.0.180.137
Session type : Spoke-Hub
State : Establish
Holding time : 0H 0M 2S
Input: 0 packets, 0 data packets, 0 control packets
Output: 1 packets, 0 data packets, 1 control packets
Interface : Tunnel3
Client name : vpn3
ADVPN domain name : 3
Link protocol : IPsec-UDP
Private address: 1003::4
Public address : 2003::180:137
ADVPN port : 2057
SA's SPI :
Inbound : 187199087 (0xb286e6f) [ESP]
Outbound: 3562274487 (0xd453feb7) [ESP]
Session type : Spoke-Spoke
State : Establish
Interface : Tunnel4
Client name : vpn4
ADVPN domain name : 4
Link protocol : IPsec-GRE
Private address: 1004::4
Public address : 204.1.181:157
SA's SPI :
Inbound: 187199087 (0xb286e6f) [ESP]
Session type : Hub-Hub
State : Success
Holding time : 10H 48M 19S
Output: 2169 packets, 2168 data packets, 1 control packets
Interface : Tunnel5
Client name : vpn5
ADVPN domain name : 5
Link protocol : UDP
# Display detailed information about IPv6 ADVPN tunnels on Tunnel 1.
<Sysname> display advpn ipv6 session interface tunnel 1 verbose
Interface : Tunnel1
Client name : vpn1
Link protocol : UDP
ADVPN port : 1139
State : Success
ADVPN port : 3546
State : Dumb
# Display detailed information about the IPv6 ADVPN tunnel with peer private IPv6 address 1001::3 on Tunnel 1.
<Sysname> display advpn ipv6 session interface tunnel 1 private-address 1001::3 verbose
ADVPN port : 1139
State : Success
Table 14 Command output
Client name |
Name of the VAM client bound to the tunnel interface. |
Link protocol |
Link layer protocol for the ADVPN tunnel: · UDP. · GRE. · IPsec-UDP. · IPsec-GRE. |
Private address |
Public address |
ADVPN port |
UDP port number for the ADVPN tunnel when the link layer protocol is UDP or IPsec-UDP. |
SA's SPI |
SPIs for the inbound and outbound SAs when link layer protocol is IPsec-UDP or IPsec-GRE. |
Session type |
ADVPN tunnel type: · Hub-Hub—Both the local end and the remote end are hubs. · Hub-Spoke—The local end is a hub and the remote end is a spoke. · Spoke-Hub—The local end is a spoke and the remote end is a hub. · Spoke-Spoke—Both the local end and the remote end are spokes. |
State |
Holding time |
Input |
Statistics for incoming packets, including the numbers of all packets, data packets, control packets, multicast packets, and erroneous packets. |
Output |
Statistics for outgoing packets, including the numbers of all packets, data packets, control packets, multicast packets, and erroneous packets. |
reset advpn ipv6 session
display advpn session
Use display advpn session to display IPv4 ADVPN tunnel information.
display advpn session [ interface tunnel number [ private-address private-ip-address ] ] [ verbose ]
interface tunnel number: Displays information about IPv4 ADVPN tunnels on an IPv4 ADVPN tunnel interface specified by the interface number. If you do not specify this option, the command displays information about all IPv4 ADVPN tunnels.
private-address private-ip-address: Displays information about the IPv4 ADVPN tunnel with the specified peer private IPv4 address. If you do not specify this option, the command displays information about the specified IPv4 ADVPN tunnel or all IPv4 ADVPN tunnels.
verbose: Displays detailed IPv4 ADVPN tunnel information. If you do not specify this keyword, the command displays brief IPv4 ADVPN tunnel information.
# Display brief information about all IPv4 ADVPN tunnels.
<Sysname> display advpn session
Interface : Tunnel1
10.0.0.3 192.168.180.136 1139 H-S Success 5H 38M 8S
10.0.1.4 192.168.180.137 3546 H-S Dumb 0H 0M 27S
Interface : Tunnel2
20.0.0.3 200::3 -- S-H Establish 0H 0M 2S
Interface : Tunnel3
30.0.0.3 192.168.200.22 2057 S-S Success 1H 12M 26S
Interface : Tunnel4
40.0.0.3 4::4 -- H-H Success 10H 48M 19S
Interface : Tunnel5
# Display brief information about IPv4 ADVPN tunnels on Tunnel 1.
<Sysname> display advpn session interface tunnel 1
Interface : Tunnel1
# Display brief information about the IPv4 ADVPN tunnel with peer private IP address 10.0.1.3 on Tunnel 1.
<Sysname> display advpn session interface tunnel 1 private-address 10.0.1.3
Table 15 Command output
Private address |
Public address |
Port |
Type |
State |
Holding time |
# Display detailed information about all IPv4 ADVPN tunnels.
<Sysname> display advpn session verbose
Interface : Tunnel1
Client name : vpn1
Link protocol : UDP
Private address: 10.0.1.3
Public address : 192.168.180.136
ADVPN port : 1139
Behind NAT : No
State : Success
Input : 2201 packets, 218 data packets, 3 control packets
Private address: 10.0.1.4
Public address : 192.168.180.137
ADVPN port : 3546
Behind NAT : No
State : Dumb
ADVPN group : group1
Outbound QoS policy: policy1
Interface : Tunnel2
Client name : vpn2
Link protocol : GRE
Private address: 20.0.0.3
Public address : 200::3
Behind NAT : No
State : Establish
Interface : Tunnel3
Client name : vpn3
Private address: 30.0.0.3
Public address : 192.168.200.32
ADVPN port : 2057
SA's SPI :
Behind NAT : No
State : Establish
Interface : Tunnel4
Client name : vpn4
Private address: 40.0.0.3
Public address : 4::4
SA's SPI :
Behind NAT : No
State : Success
Interface : Tunnel5
Client name : vpn5
Link protocol : UDP
# Display detailed information about IPv4 ADVPN tunnels on Tunnel 1.
<Sysname> display advpn session interface tunnel 1 verbose
Interface : Tunnel1
Client name : vpn1
Link protocol : UDP
ADVPN port : 1139
Behind NAT : No
State : Success
ADVPN port : 3546
Behind NAT : No
State : Dumb
# Display detailed information about the IPv4 ADVPN tunnel with peer private IP address 10.0.1.3 on Tunnel 1.
<Sysname> display advpn session verbose interface tunnel 1 private-address 10.0.1.3
ADVPN port : 1139
Behind NAT : No
State : Success
Table 16 Command output
Client name |
Link protocol |
Private address |
Public address |
ADVPN port |
SA's SPI |
Behind NAT |
Whether NAT traversal is used. |
Session type |
State |
Holding time |
ADVPN group |
ADVPN group name. |
Outbound QoS policy |
Input |
Output |
reset advpn session
display advpn session count
Use display advpn session count to display the number of ADVPN sessions in different states.
# Display the number of ADVPN sessions in different states.
<Sysname> display advpn session count
Total ADVPN sessions: 7
IPv4 sessions: 3
Success: 3
Establishing: 0
Dumb: 0
IPv6 sessions: 4
Success: 4
Establishing: 0
Dumb: 0
Table 17 Command output
IPv4 sessions: |
Number of ADVPN sessions in IPv4 private networks. |
IPv6 sessions: |
Number of ADVPN sessions in IPv6 private networks. |
Success |
Number of ADVPN sessions that have been successfully established. |
Establishing |
Number of ADVPN sessions that are being established. |
Dumb |
Number of ADVPN sessions that failed to be established and are now quiet. |
keepalive
Use keepalive to set the keepalive interval and the maximum number of keepalive attempts for an ADVPN tunnel interface.
undo keepalive
The keepalive interval is 180 seconds, and the maximum number of keepalive attempts is 3.
interval interval: Sets the keepalive interval in the range of 1 to 32767 seconds.
retry retries: Sets the maximum number of keepalive attempts, in the range of 1 to 255.
If no keepalives is received before the timeout timer (product of the keepalive interval and keepalive attempts) expires, the tunnel will be removed automatically.
The keepalive interval and the maximum number of keepalive attempts must be the same on the tunnel interfaces in an ADVPN domain.
After this command is executed, the keepalive timer does not start immediately. It starts until the ADVPN tunnel is established.
# Set the keepalive interval to 20 seconds and the maximum number of keepalive attempts to 5.
[Sysname-Tunnel1] keepalive interval 20 retry 5
Use reset advpn ipv6 session to delete IPv6 ADVPN tunnels.
reset advpn ipv6 session [ interface tunnel number [ private-address private-ipv6-address ] ]
interface tunnel number: Deletes IPv6 ADVPN tunnels on an IPv6 ADVPN tunnel interface specified by the interface number. If you do not specify this option, the command deletes all IPv6 ADVPN tunnels.
private-address private-ipv6-address: Deletes the IPv6 ADVPN tunnel with the specified peer private IPv6 address. If you do not specify this option, the command deletes the specified IPv6 ADVPN tunnel or all IPv6 ADVPN tunnels.
If the remote tunnel end is a hub in the same group as the local end, the tunnel will be re-established after it is deleted.
# Delete all IPv6 ADVPN tunnels.
<Sysname> reset advpn ipv6 session
# Delete IPv6 ADVPN tunnels on Tunnel 1.
<Sysname> reset advpn ipv6 session interface tunnel 1
# Delete the IPv6 ADVPN tunnel with peer private IPv6 address 1000::1 on Tunnel 1.
<Sysname> reset advpn ipv6 session interface tunnel 1 private-address 1000::1
reset advpn ipv6 session statistics
Use reset advpn ipv6 session statistics to clear statistics for IPv6 ADVPN tunnels.
reset advpn ipv6 session statistics [ interface tunnel number [ private-address private-ipv6-address ] ]
interface tunnel number: Clears statistics for IPv6 ADVPN tunnels on an IPv6 ADVPN tunnel interface specified by the interface number. If you do not specify this option, the command clears statistics for all IPv6 ADVPN tunnels.
private-address private-ipv6-address: Clears statistics for the IPv6 ADVPN tunnel with the specified peer private IPv6 address. If you do not specify this option, the command clears statistics for the specified IPv6 ADVPN tunnel or all IPv6 ADVPN tunnels.
# Clear statistics for all IPv6 ADVPN tunnels.
<Sysname> reset advpn ipv6 session statistics
# Clear statistics for IPv6 ADVPN tunnels on Tunnel 1.
<Sysname> reset advpn ipv6 session statistics interface tunnel 1
# Clear statistics for the IPv6 ADVPN tunnel with peer private IPv6 address 1::1 on Tunnel 1.
<Sysname> reset advpn ipv6 session statistics interface tunnel 1 private-address 1::1
reset advpn session
Use reset advpn session to delete IPv4 ADVPN tunnels.
reset advpn session [ interface tunnel number [ private-address private-ip-address ] ]
interface tunnel number: Deletes IPv4 ADVPN tunnels on an IPv4 ADVPN tunnel interface specified by the interface number. If you do not specify this option, the command deletes all IPv4 ADVPN tunnels.
private-address private-ip-address: Deletes the IPv4 ADVPN tunnel with the specified peer private IPv4 address. If you do not specify this option, the command deletes the specified IPv4 ADVPN tunnel or all IPv4 ADVPN tunnels.
# Delete all IPv4 ADVPN tunnels.
<Sysname> reset advpn session
# Delete IPv4 ADVPN tunnels on Tunnel 1.
<Sysname> reset advpn session interface tunnel 1
# Delete the IPv4 ADVPN tunnel with peer private IPv4 address 169.254.0.1 on Tunnel 1.
<Sysname> reset advpn session interface tunnel 1 private-address 169.254.0.1
reset advpn session statistics
Use reset advpn session statistics to clear statistics for IPv4 ADVPN tunnels.
reset advpn session statistics [ interface tunnel number [ private-address private-ip-address ] ]
interface tunnel number: Clears statistics for IPv4 ADVPN tunnels on an IPv4 ADVPN tunnel interface specified by the interface number. If you do not specify this option, the command clears statistics for all IPv4 ADVPN tunnels.
private-address private-ip-address: Clears statistics for the IPv4 ADVPN tunnel with the specified peer private IPv4 address. If you do not specify this option, the command clears statistics for the specified IPv4 ADVPN tunnel or all IPv4 ADVPN tunnels.
# Clear statistics for all IPv4 ADVPN tunnels.
<Sysname> reset advpn session statistics
# Clear statistics for IPv4 ADVPN tunnels on Tunnel 1.
<Sysname> reset advpn session statistics interface tunnel 1
# Clear statistics for the IPv4 ADVPN tunnel with peer private IPv4 address 169.254.0.1 on Tunnel 1.
<Sysname> reset advpn session statistics interface tunnel 1 private-address 169.254.0.1
vam client
Use vam client to bind a VAM client to an IPv4 ADVPN tunnel interface.
Use undo vam client to remove the binding.
vam client client-name [ compatible advpn0 ]
undo vam client
No VAM client is bound to an IPv4 ADVPN tunnel interface.
compatible advpn0: Specifies ADVPN V0 packet format. If you do not specify this keyword, packets are not compatible with ADVPN V0 format.
After a VAM client is bound to an IPv4 ADVPN tunnel interface, the client registers IPv4 private networks for the tunnel interface with the VAM server.
A VAM client can be bound to only one IPv4 ADVPN tunnel interface.
The compatible keyword is required if a device that supports only ADVPN V0 packet format exists in the hub group for the bound VAM client. After the compatible keyword is specified, make sure the tunnel interface has a unique source UDP port number on the device.
# Bind VAM client abc to IPv4 ADVPN tunnel interface Tunnel 1.
[Sysname-Tunnel1] vam client abc
advpn source-port
vam ipv6 client
vam ipv6 client
Use vam ipv6 client to bind a VAM client to an IPv6 ADVPN tunnel interface.
Use undo vam ipv6 client to remove the binding.
vam ipv6 client client-name
No VAM client is bound to an IPv6 ADVPN tunnel interface.
After a VAM client is bound to an IPv6 ADVPN tunnel interface, the client registers IPv6 private networks for the tunnel interface with the VAM server.
A VAM client can be bound to only one IPv6 ADVPN tunnel interface.
# Bind VAM client abc to IPv6 ADVPN tunnel interface Tunnel 1.
[Sysname-Tunnel1] vam ipv6 client abc
vam client
