- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Lighttpd service commands
- 23-Web caching commands
05-NAT commands | 582.25 KB |
display nat outbound port-block-group
nat link-switch recreate-session
nat log port-block usage threshold
nat mapping-behavior endpoint-independent
nat port-block global-share enable
nat port-block synchronization enable
nat static inbound net-to-net rule move
nat static inbound object-group
nat static outbound net-to-net
nat static outbound net-to-net rule move
NAT commands
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
You can specify a maximum of 65535 addresses in one command execution. Make sure the address ranges do not overlap.
The address command and the address interface command are mutually exclusive for one NAT address group.
# Add address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
address interface
nat address-group
address interface
Use address interface to add the IP address of an interface to a NAT address group.
Use undo address interface to restore the default.
address interface interface-type interface-number
No interface address exists in a NAT address group.
Predefines user roles
This command is applicable to Easy IP with the IP address of the NAT interface dynamically obtained through DHCP or PPPoE. After you configure this command, the primary IPv4 address of the specified interface will be added to the NAT address group.
You can specify only one interface for a NAT address group.
The IP address of an interface cannot be added to different NAT address groups.
Make sure addresses in different NAT address groups do not overlap.
# Add the IP address of GigabitEthernet 1/0/2 to NAT address group 2.
[Sysname-address-group-2] address interface gigabitethernet 1/0/2
address
nat address-group
block-size
Use block-size to set the port block size.
Use undo block-size to restore the default.
block-size block-size
undo block-size
The port block size is 256.
NAT port block group view
block-size: Specifies the number of ports for a port block. The value range for this argument is 1 to 65535.
Set an appropriate port block size based on the number of private IP addresses, the number of public IP addresses, and the port range in the port block group.
The port block size cannot be larger than the number of ports in the port range.
# Set the port block size to 1024 for port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] block-size 1024
display nat address-group
Use display nat address-group to display NAT address group information.
display nat address-group [ group-id ]
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535. If you do not specify the group-id argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
Totally 5 NAT address groups.
Address group ID: 1 Address group name: a
Port range: 1-65535
Address information:
Start address End address
202.110.10.10 202.110.10.15
Address group ID: 2
Port range: 1-65535
202.110.10.20 202.110.10.25
202.110.10.30 202.110.10.35
Address group ID: 3
Port range: 1024-65535
202.110.10.40 202.110.10.50
Address group ID: 4
Port range: 10001-65535
Port block size: 500
Extended block number: 1
202.110.10.60 202.110.10.65
Address group ID: 5
Port range: 1-1024
20.1.1.1 (GigabitEthernet1/0/1)
Address group ID: 6
Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
Port range: 1-65535
NAT address group information |
Information about the NAT address group |
Address group ID |
ID of the NAT address group. |
Totally n NAT address groups |
Total number of NAT address groups. |
Address group name |
Name of the NAT address group. If no address group name is configured, this field is not displayed. |
Port range |
Port range for public IP addresses. |
Port block size |
Number of ports in a port block. This field is not displayed if the port block size is not set. |
Extended block number |
Number of extended port blocks. This field is not displayed if the number of extended port blocks is not set. |
Address information |
Information about the IP addresses in the address group. · For addresses added by using the address command: ¡ Start address—Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---). ¡ End address—End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---). · For addresses added by using the address interface command: ¡ 20.1.1.1 (GigabitEthernet1/0/1)—IP address 20.1.1.1 of GigabitEthernet 1/0/1 has been added to the NAT address group. ¡ --- (GigabitEthernet1/0/2)—Failed to add the IP address of GigabitEthernet 1/0/2 to the NAT address group because this interface does not have an IP address. |
nat address-group
display nat alg
Use display nat alg to display the NAT ALG status for all supported protocols.
display nat alg
# Display the NAT ALG status for all supported protocols.
<Sysname> display nat alg
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Disabled
ICMP-ERROR : Enabled
ILS : Disabled
MGCP : Disabled
NBT : Disabled
PPTP : Enabled
RTSP : Enabled
RSH : Disabled
SCCP : Disabled
SCTP : Disabled
SIP : Disabled
SQLNET : Disabled
TFTP : Disabled
XDMCP : Disabled
display nat all
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# (In standalone mode.) Display all NAT configuration information.
<Sysname> display nat all
Address group 1:
Port range: 1-65535
Address group 2:
Port range: 1-65535
Address group 3:
Address group 4:
Address group 6:
Port range: 1-65535
NAT server group information:
Totally 3 NAT server groups.
Group Number Inside IP Port Weight
1 192.168.0.26 23 100
192.168.0.27 23 500
2 --- --- ---
3 192.168.0.26 69 100
NAT inbound information:
Totally 1 NAT inbound rules.
ACL: 2038
Address group ID: 2
Add route: Y NO-PAT:Y Reversible: N
VPN instance: vpn_nat
Rule name: abc
Priority: 1000
Description: NatInbound1
Config status: Active
NAT outbound information:
Totally 2 NAT outbound rules.
ACL: 2036
Address group ID: 1
Port-preserved: Y NO-PAT: N Reversible: N
Configuration mode : NETCONF (action)
Rule name: lee
Priority: 122
Description: NatOutbound1
Config status: Inactive
Reasons for inactive status:
The following items don't exist or aren't effective: ACL.
ACL: 2037
Address group ID: 1
Port-preserved: N NO-PAT: Y Reversible: Y
Rule name: rabbit
Priority: 100
NAT internal server information:
Totally 2 internal servers.
Global ACL : 2000
Local IP/port : 192.168.10.1/23
Rule name : sept
Priority : 1000
NAT counting : 0
Description : NatServerDescription1
Config status : Active
Protocol: 6(TCP)
Global IP/port: 50.1.1.1/23
Local IP/port : 192.168.10.15/23
ACL : 2000
Rule name : blue
NAT counting : 0
Static NAT mappings:
Totally 2 inbound static NAT mappings.
Net-to-net:
Global IP : 2.2.2.1 – 2.2.2.255
Local IP : 1.1.1.0
Netmask : 255.255.255.0
Global VPN : vpn2
Local VPN : vpn1
ACL : 3000
Reversible : Y
Rule name : green
Priority : 4
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
Global VPN : vpn3
Local VPN : vpn4
ACL : 2001
Reversible : Y
Rule name : blue
Priority : 4
Packet type ignore: Y
Description : NatStaticDescription1
Totally 2 outbound static NAT mappings.
Net-to-net:
Local IP : 1.1.1.1 - 1.1.1.255
Global IP : 2.2.2.0
Local VPN : vpn1
Global VPN : vpn2
ACL : 3000
Reversible : Y
Rule name : yellow
Priority : 5
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
Local VPN : vpn1
Global VPN : vpn2
ACL: : 2001
Reversible : Y
Rule name : pink
Priority : 6
Description : NatStaticDescription2
Interfaces enabled with static NAT:
Totally 2 interfaces enabled with static NAT.
Interface: GigabitEthernet1/0/3
NAT DNS mappings:
Totally 2 NAT DNS mappings.
Domain name : www.server.com
Global IP : 6.6.6.6
Global port : 23
Protocol : TCP(6)
Domain name : www.service.com
Global IP : ---
Global port : 12
Protocol : TCP(6)
The following items don't exist or aren't effective: interface IP address.
NAT logging:
Log enable : Enabled(ACL 2000)
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Enabled(10 minutes)
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NO-PAT IP usage : Disabled
NAT hairpinning:
Totally 2 interfaces enabled with NAT hairpinning.
NAT mapping behavior:
Mapping mode : Endpoint-Independent
ACL : 2050
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Disabled
ILS : Disabled
MGCP : Disabled
NBT : Disabled
PPTP : Enabled
RTSP : Enabled
RSH : Disabled
SCCP : Disabled
SCTP : Disabled
SIP : Disabled
SQLNET : Disabled
TFTP : Disabled
XDMCP : Disabled
NAT port block group information:
Totally 3 NAT port block groups.
Port block group 1:
Port range: 1-65535
Block size: 256
Local IP address information:
Start address End address VPN instance
172.16.1.1 172.16.1.254 ---
192.168.1.1 192.168.1.254 ---
192.168.3.1 192.168.3.254 ---
Global IP pool information:
201.1.1.1 201.1.1.10
201.1.1.21 201.1.1.25
Port block group 2:
Port range: 10001-30000
Block size: 500
10.1.1.1 10.1.10.255 ---
202.10.10.101 202.10.10.120
Port block group 3:
Port range: 1-65535
Block size: 256
NAT outbound port block group information:
Totally 2 outbound port block group items.
port-block-group: 2
Rule name : red
Priority : 4
port-block-group: 10
Rule name: lee
Config status : Inactive
The following items don't exist or aren't effective: port block group.
Static NAT load balancing: Disabled
NAT link-switch recreate-session: Disabled
# (In IRF mode.) Display all NAT configuration information.
Address group 1:
Port range: 1-65535
Address group 2:
Port range: 1-65535
Address group 3:
Address group 4:
Address group 6:
Port range: 1-65535
192.168.0.27 23 500
2 --- --- ---
NAT policy information:
Totally 1 NAT policy rules.
Rule name: rule1
Description : first rule
Routing-interface : GigabitEthernet1/0/2
SrcIP object group : srcObj1
SrcIP object group : srcObj2
SrcIP object group : srcObj3
DestIP object group : desObj1
DestIP object group : desObj2
DestIP object group : desObj3
Service object group : serviceObj1
Service object group : serviceObj2
Service object group : serviceObj3
Action
Address group ID: 2 Address group name: a
NO-PAT: Y
Reversible: N
Port-preserved: N
ACL: 2038
Address group ID: 2
Add route: Y NO-PAT: Y Reversible: N
Rule name: abcdefg
Priority: 1000
Service card: Slot 2
Global flow-table status: Active
ACL: 2036
Address group ID: 1
Rule name: cdefg
Priority: 1001
Service card: ---
The following items don't exist or aren't effective: address group, and ACL.
Service card not specified.
ACL: 2037
Address group ID: 1
Rule name: blue
Priority: 1002
Service card: ---
Config status: Active.
NAT internal server information (object-group):
Totally 1 object-group-based NAT server rules.
Rule name: aaa
Local IP/Port: 1.1.1.1/80
DestIP Object group: abc
NAT counting : 0
Totally 5 internal servers.
Global ACL : 2000
Rule name : cdefgab
Priority : 1000
NAT counting : 0
Protocol: 6(TCP)
ACL : 2000
Rule name : green
NAT counting : 0
Service card : Slot 2
Local flow-table status: Active
Protocol: 6(TCP)
Global IP/port: 50.1.1.1/23-30
Local IP/port : 192.168.10.15-192.168.10.22/23
Global VPN : vpn1
Local VPN : vpn3
Rule name : blue
NAT counting : 0
Interface: GigabitEthernet1/0/4
Protocol: 255(Reserved)
Global IP/port: 50.1.1.100/---
Local IP/port : 192.168.10.150/---
Global VPN : vpn2
Local VPN : vpn4
ACL : 3000
Rule name : white
NAT counting : 0
Interface: GigabitEthernet1/0/5
Protocol: 17(UDP)
Global IP/port: 50.1.1.2/23
Local IP/port : server group 1
192.168.0.26/23 (Connections: 10)
192.168.0.27/23 (Connections: 20)
Global VPN : vpn1
Local VPN : vpn3
Rule name : black
NAT counting : 0
Net-to-net:
Local IP : 1.1.1.0
Global VPN : vpn2
Local VPN : vpn1
ACL : 2000
Reversible : Y
Rule name : pink
Priority : 1000
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2001
Reversible : Y
Rule name : yellow
Priority : 1000
Net-to-net:
Global IP : 2.2.2.0
ACL : 2000
Reversible : Y
Rule name : grey
Priority : 1000
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2001
Reversible : Y
Rule name : orange
Priority : 10000
Interface: GigabitEthernet1/0/6
Service card : ---
NAT DNS mappings:
Global IP : 6.6.6.6
Global port : 23
Protocol : TCP(6)
Global IP : ---
Global port : 12
Protocol : TCP(6)
NAT logging:
Flow-end : Disabled
Alarm : Disabled
NAT hairpinning:
ACL : 2050
NAT ALG:
DNS : Enabled
FTP : Enabled
H323 : Enabled
ILS : Enabled
MGCP : Enabled
NBT : Enabled
PPTP : Enabled
RTSP : Enabled
RSH : Enabled
SCCP : Enabled
SIP : Enabled
SQLNET : Enabled
TFTP : Enabled
XDMCP : Disabled
Port block group 1:
Port range: 1-65535
Block size: 256
Port block group 2:
Block size: 500
Port block group 3:
Port range: 1-65535
Block size: 256
port-block-group: 2
Rule name: stone
The output shows all NAT configuration information. Table 2 describes only the fields for the output of the nat hairpin enable, nat mapping-behavior, and nat alg commands.
Information about the NAT address group. See Table 1 for output description. |
NAT server group information |
Information about the internal server group. See Table 15 for output description. |
NAT inbound information: |
Inbound dynamic NAT configuration. See Table 5 for output description. |
NAT outbound information |
Outbound dynamic NAT configuration. See Table 9 for output description. |
NAT internal server information |
NAT server mapping configuration. See Table 14 for output description. |
Static NAT mappings |
Static NAT mappings. See Table 17 for output description. |
NAT DNS mappings |
NAT DNS mappings. See Table 3 for output description. |
NAT logging |
NAT logging configuration. See Table 6 for output description. |
NAT hairpinning |
NAT hairpin configuration. |
Totally n interfaces enabled NAT hairpinning |
Number of interfaces with NAT hairpin enabled. |
NAT hairpin-enabled interface. |
Rule name |
Name of the NAT rule. |
Priority |
Priority of the NAT rule. |
Service card |
Service card that processes NAT traffic. If no service card is specified on the interface, this field displays hyphens (---). |
Config status |
Status of the NAT hairpin configuration: Active or Inactive. |
Reasons for inactive status |
Reasons why the NAT hairpin configuration does not take effect. This field is available when the Config status is Inactive. |
NAT mapping behavior |
Mapping behavior mode of PAT: Endpoint-Independent or Address and Port-Dependent. |
ACL |
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---). |
Config status |
Status of the NAT mapping behavior configuration: Active or Inactive. |
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status is Inactive. |
Global flow-table status |
Status of the flow entries deployed for the public IP addresses: Active or Inactive. |
Local flow-table status |
Status of the flow entries deployed for the private IP addresses: Active or Inactive. |
Reasons for flow-table inactive status |
Reasons why the flow entries do not take effect. This field is available when the global or local flow table status is Inactive. |
NAT ALG |
NAT ALG configuration for different protocols. |
NAT port block group information |
Configuration information about NAT port block groups. See Table 12 for output description. |
NAT outbound port block group information |
Configuration information about static outbound port block mapping rules. See Table 10 for output description. |
Static NAT load balancing |
Whether load balancing is enabled for static NAT on service engines: · Enabled. · Disabled. |
NAT link-switch recreate-session |
Whether NAT session recreation after link switchover is enabled: · Enabled. · Disabled. |
display nat dns-map
Use display nat dns-map to display NAT DNS mappings.
display nat dns-map
# Display NAT DNS mappings.
<Sysname> display nat dns-map
NAT DNS mapping information:
Global IP : 6.6.6.6
Global port : 23
Protocol : TCP(6)
Global IP : ---
Global port : 12
Protocol : TCP(6)
NAT DNS mapping information |
Information about NAT DNS mappings. |
Totally n NAT DNS mappings |
Total number of NAT DNS mappings. |
Domain name |
Domain name of the internal server. |
Global IP |
Public IP address of the internal server. · If Easy IP is configured, this field displays the IP address of the specified interface. · If you do not specify a public IP address, this field displays hyphens (---). |
Global port |
Public port number of the internal server. |
Protocol |
Protocol name and number of the internal server. |
Config status |
Status of the DNS mapping: Active or Inactive. |
Reasons why the DNS mapping does not take effect. This field is available when the Config status is Inactive. |
nat dns-map
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
In standalone mode:
display nat eim
In IRF mode:
display nat eim [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays EIM entry information for all member devices. (In IRF mode.)
EIM entries are created when PAT operates in EIM mode. An EIM entry is a 3-tuple entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
· The same EIM entry applies to subsequent connections initiated from the same source IP and port.
· The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
# (In standalone mode.) Display information about NAT EIM entries.
<Sysname> display nat eim
Slot 0:
Local IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Local VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Local IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
# (In IRF mode.) Display information about EIM entries for the specified slot.
<Sysname> display nat eim slot 1
Slot 1:
Local VPN: vpn1
Global VPN: vpn2
Protocol: TCP(6)
Protocol: UDP(17)
Local VPN |
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field is not displayed. |
Global VPN |
MPLS L3VPN instance to which the public IP address belongs. If the public IP address does not belong to any VPN instance, this field is not displayed. |
Protocol |
Protocol name and number. |
Total entries found |
Total number of EIM entries. |
nat outbound
display nat inbound
Use display nat inbound to display inbound dynamic NAT configuration.
display nat inbound
# (In standalone mode.) Display inbound dynamic NAT configuration.
<Sysname> display nat inbound
Totally 2 NAT inbound rules.
ACL: 2038
Address group ID: 2
VPN instance: vpn1
Rule name: abcd
Priority: 1000
NAT counting: 0
ACL: 2037
Address group ID: 1 Address group name: abc
Rule name: eif
Priority: 1000
NAT counting: 0
# (In IRF mode.) Display inbound dynamic NAT configuration.
ACL: 2038
Address group ID: 2
VPN instance: vpn1
Rule name: abcd
Priority: 1000
NAT counting: 0
Address group ID: 1
Rule name: eif
Priority: 1001
NAT counting: 0
NAT inbound information |
Information about inbound dynamic NAT configuration. |
Totally n NAT inbound rules |
Total number of inbound dynamic NAT rules. |
Interface where the inbound dynamic NAT rule is configured. |
ACL |
ACL number or name. |
Address group ID |
ID of the NAT address group used by the inbound dynamic NAT rule. |
Add route |
Whether to add a route when a packet matches the inbound dynamic NAT rule: · Y—Adds a route. · N—Does not add a route. |
NO-PAT |
Whether NO-PAT or PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
Whether reverse address translation is allowed: · Y—Reverse address translation is allowed. · N—Reverse address translation is not allowed. |
VPN instance |
MPLS L3VPN instance to which the NAT address group belongs. If the NAT address group does not belong to any VPN instance, the field is not displayed. |
Rule name |
Priority |
Description of the NAT rule. This field is not displayed if no description is configured for the rule. |
NAT counting |
Number of times the NAT rule is matched. |
Config status |
Status of the inbound dynamic NAT rule: Active or Inactive. |
Reasons why the inbound dynamic NAT rule does not take effect: This field is available when the Config status is Inactive. |
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
Flow-end : Disabled
Alarm : Disabled
NAT logging |
NAT logging configuration. |
Log enable |
Enabling status of NAT logging. If an ACL is specified for NAT logging, this field also displays the ACL number or name. |
Flow-begin |
Enabling status of logging for NAT session establishment events. |
Flow-end |
Enabling status of logging for NAT session removal events. |
Flow-active |
Enabling status of logging for active NAT flows. If it is enabled, this field also displays the interval in minutes at which active flow logs are generated. |
Port-block-assign |
Enabling status of NAT444 user logging for port block assignment. |
Port-block-withdraw |
Enabling status of NAT444 user logging for port block withdrawal. |
Alarm |
Enabling status of logging for NAT444 alarms. |
NO-PAT IP usage |
Enabling status of logging for IP usage of NAT address groups when NO-PAT mode is used. If it is enabled, this field also displays IP usage for each configured NAT address group, in percentage. |
nat log enable
nat log flow-active
nat log flow-begin
nat log no-pat ip-usage
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
In standalone mode:
display nat no-pat { ipv4 | ipv6 }
In IRF mode:
display nat no-pat { ipv4 | ipv6 } [ slot slot-number ]
Default user roles
ipv4: Displays NO-PAT entry information for IPv4 NAT sessions.
ipv6: Displays NO-PAT entry information for IPv6 NAT sessions.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NO-PAT entry information for all member devices. (In IRF mode.)
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
· The same entry applies to subsequent connections initiated from the same source IP address.
· The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# (In standalone mode.) Display information about NO-PAT entries for IPv4 NAT sessions on all cards.
<Sysname> display nat no-pat ipv4
Slot 0:
Global IPv4: 200.100.1.100
Local IPv4: 192.168.100.100
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Local IPv4: 192.168.100.200
Global IPv4: 200.100.1.200
Reversible: Y
Type : Outbound
Total Ipv4 entries found: 2
# (In IRF mode.) Display information about NO-PAT entries for IPv4 NAT sessions on the specified slot.
<Sysname> display nat no-pat ipv4 slot 1
Slot 1:
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Reversible: Y
Type : Outbound
# (In standalone mode.) Display information about NO-PAT entries for IPv6 NAT sessions on all cards.
<Sysname> display nat no-pat ipv6
Slot 0:
Global IPv6: FD01:203:405::1
Local IPv6: 2001:DB8:1::100
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Total Ipv6 entries found: 1
# (In IRF mode.) Display information about NO-PAT entries for IPv6 NAT sessions on the specified slot.
<Sysname> display nat no-pat slot 1 ipv6
Slot 1:
Global VPN: vpn2
Local VPN: vpn1
Reversible: N
Type : Inbound
Table 7 Command output
Global IPv4 |
Public IPv4 address. |
Local IPv4 |
Private IPv4 address. |
Global IPv6 |
Public IPv6 address. |
Local IPv6 |
Private IPv6 address. |
Local VPN |
Global VPN |
Reversible |
Type |
Type of the NO-PAT entry: · Inbound—A NO-PAT entry created during inbound dynamic NAT. · Outbound—A NO-PAT entry created during outbound dynamic NAT. |
Total Ipv4 entries found |
Total number of IPv4 NO-PAT entries. |
Total Ipv6 entries found |
Total number of IPv6 NO-PAT entries. |
nat inbound
nat outbound
display nat no-pat ip-usage
Use display nat no-pat ip-usage to display IP usage of NAT address groups in NO-PAT mode.
In standalone mode:
display nat no-pat ip-usage [ address-group { group-id | name group-name } ]
In IRF mode:
display nat no-pat ip-usage [ address-group { group-id | name group-name } ] [ slot slot-number ]
address-group: Displays the IP usage of the specified NAT address group. If you do not specify this keyword, the command displays the IP usage of each NAT address group.
group-id: Specifies the ID of a NAT address group. The value range is 0 to 65535.
name group-name: Specifies the name of a NAT address group, a case-insensitive string of 1 to 63 characters.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the IP usage of NAT address groups in NO-PAT mode for all member devices. (In IRF mode.)
# (In standalone mode.) Display IP usage of each NAT address group in NO-PAT mode.
<Sysname> display nat no-pat ip-usage
Slot 1:
Address group 0:
Total IP addresses :10
Used IP addresses :9
Unused IP addresses :1
NO-PAT IP usage :90%
# (In IRF mode.) Display IP usage of each NAT address group in NO-PAT mode for the specified slot.
<Sysname> display nat no-pat ip-usage slot 1
CPU 0 on slot 1:
Address group 0:
NO-PAT IP usage :90% (channel 0)
Table 8 Command output
Address group |
NAT address group ID. |
NO-PAT IP usage |
IP usage of the NAT address group in NO-PAT mode. |
channel |
Field-programmable gate array (FPGA) ID. |
nat log no-pat ip-usage threshold
Use display nat outbound to display outbound dynamic NAT configuration.
# (In standalone mode.) Display outbound dynamic NAT configuration.
<Sysname> display nat outbound
Address group ID: 1
Rule name: acdefg
Priority: 1000
NAT counting: 0
ACL: 2037
Address group ID: ---
Rule name: abefg
Priority: 1000
NAT counting: 0
DS-Lite B4 ACL: 2100
Address group ID: 2
Port-preserved: N NO-PAT: N Reversible: N
Priority: 0
NAT counting: 0
# (In IRF mode.) Display outbound dynamic NAT configuration.
ACL: 2036
Address group ID: 1
Rule name: abefg
Priority: 1000
NAT counting: 0
ACL: 2037
Address group ID: 2
Rule name: cdefg
Priority: 1001
NAT counting: 0
Address group ID: 2
Priority: 0
NAT counting: 0
Information about outbound dynamic NAT configuration. |
Totally n NAT outbound rules |
Total number of outbound dynamic NAT rules. |
Interface where the outbound dynamic NAT rule is configured. |
ACL |
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT rule, this field displays hyphens (---). |
DS-Lite B4 ACL |
Number or name of the IPv6 ACL used by DS-Lite B4 address translation. |
Address group ID |
ID of the address group used by the outbound dynamic NAT rule. If no address group is specified, the field displays hyphens (---). |
Port-preserved |
Whether to try to preserve the port numbers for PAT. · Y—Tries to preserve the port numbers. · N—Allows translating port numbers. |
NO-PAT |
Whether NO-PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
VPN instance |
Rule name |
Priority |
Configuration mode |
Configuration method of the device. · This field displays NETCONF (action) if the device is configured by using a NETCONF action operation. · This field is not displayed if the device is configured by using other methods. |
NAT counting |
Config status |
Status of the outbound dynamic NAT rule: Active or Inactive. |
Reasons why the outbound dynamic NAT rule does not take effect. This field is available when the Config status is Inactive. |
nat outbound
Use display nat outbound port-block-group to display static outbound port block mapping rules for NAT444.
# Display static outbound port block mapping rules for NAT444.
<Sysname> display nat outbound port-block-group
port-block-group: 2
Rule name: abcdefg
NAT counting: 0
Rule name: abcfg
NAT counting: 0
Information about static outbound port block mapping rules. |
Totally n outbound port block group items |
Total number of static outbound port block mapping rules. |
Interface where the static outbound port block mapping rules configured. |
port-block-group |
ID of the port block group. |
Rule name |
Name of the static outbound port block mapping rule |
NAT counting |
Number of times the mapping rule is matched. |
Config status |
Status of the port block mapping rule: Active or Inactive. |
Reasons why the port block mapping rule does not take effect. This field is available when the Config status is Inactive. |
display nat port-block
Use display nat port-block to display NAT port block mappings.
In standalone mode:
display nat port-block { dynamic [ address-group { group-id | name group-name } ] [ ds-lite-b4 ] | static [ port-block-group group-id ] }
In IRF mode:
display nat port-block { dynamic [ address-group { group-id | name group-name } ] [ ds-lite-b4 ] | static [ port-block-group group-id ] } [ slot slot-number ]
dynamic: Displays dynamic port block mappings.
address-group: Displays port block mappings for the specified address group. If you do not specify a NAT address group, this command displays port block mappings for all address groups.
group-id: Specifies the ID of the address group. The value range for this argument is 0 to 65535.
name group-name: Specifies the name of the address group. The name is a case-insensitive string of 1 to 63 characters.
ds-lite-b4: Displays port block mappings for DS-Lite B4 address translation.
static: Displays static port block mappings.
port-block-group group-id: Displays port block mappings for the specified port block group. The group-id argument specifies the ID of the port block group. The value range for the group-id argument is 0 to 65535. If you do not specify a port block group, this command displays port block mappings for all port block groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays port block mappings for all member devices. (In IRF mode.)
# (In standalone mode.) Display static port block mappings.
<Sysname> display nat port-block static
Slot 0:
Local VPN Local IP Global IP Port block Connections
--- 100.100.100.111 202.202.100.101 10001-10256 0
--- 100.100.100.112 202.202.100.101 10257-10512 0
--- 100.100.100.113 202.202.100.101 10513-10768 0
--- 100.100.100.113 202.202.100.101 10769-11024 0
Total entries found: 4
# (In IRF mode.) Display static port block mappings for the specified slot.
<Sysname> display nat port-block static slot 1
Slot 1:
# (In standalone mode.) Display dynamic port block mappings.
<Sysname> display nat port-block dynamic
Slot 0:
--- 101.1.1.12 192.168.135.201 10001-11024 1
Total entries found: 1
# (In IRF mode.) Display dynamic port block mappings.
<Sysname> display nat port-block dynamic slot 1
Slot 1:
# (In standalone mode.) Display port block mappings for DS-Lite B4 address translation.
<Sysname> display nat port-block dynamic ds-lite-b4
Slot 0:
Local VPN DS-Lite B4 addr Global IP Port block Connections
--- 2000::2 192.168.135.201 10001-11024 1
# (In IRF mode.) Display port block mappings for DS-Lite B4 address translation.
<Sysname> display nat port-block dynamic ds-lite-b4 slot 1
Slot 1:
Table 11 Command output
Local VPN |
MPLS L3VPN instance to which the private IP address belongs. If the private IP address does not belong to any VPN instance, this field displays hyphens (---). |
Local IP |
Private IP address. |
DS-Lite B4 addr |
IPv6 address of the DS-Lite B4 element. |
Global IP |
Public IP address. |
Port block |
Port block defined by a start port number and an end port number. |
Connections |
Number of connections established by using the ports in the port block. |
display nat port-block-group
Use display nat port-block-group to display NAT port block group configuration.
display nat port-block-group [ group-id ]
group-id: Specifies the ID of a NAT port block group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays configuration of all NAT port block groups.
# Display configuration of all NAT port block groups.
<Sysname> display nat port-block-group
Port block group 1:
Port range: 1-65535
Block size: 256
Port block group 2:
Block size: 500
Port block group 3:
Port range: 1-65535
Block size: 256
# Display information about NAT port block group 1.
<Sysname> display nat port-block-group 1
Port block group 1:
Port range: 1-65535
Block size: 256
Information about the port block group configuration. |
Totally n NAT port block groups |
Total number of port block groups. |
Port block group |
Port range |
Port range for the public IP addresses. |
Block size |
Number of ports in a port block. |
Local IP address information |
Information about the private IP addresses. |
Global IP pool information |
Information about the public IP addresses. |
Start address |
Start IP address of a private or public IP address range. If no start IP address is specified for the address range, this field displays hyphens (---). |
End address |
End IP address of a private or public IP address range. If no end IP address is specified for the address range, this field displays hyphens (---). |
VPN instance |
MPLS L3VPN instance to which the private IP address range belongs. If no VPN instance is specified for the private address range, this field displays hyphens (---). |
display nat port-block-usage
Use display nat port-block-usage to display the port block usage for address groups.
In standalone mode:
display nat port-block-usage [ address-group group-id ]
In IRF mode:
display nat port-block-usage [ address-group group-id ] [ slot slot-number ]
address-group group-id: Specifies the ID of an address group. The value range for the group-id argument is 0 to 65535. If you do not specify an address group, this command displays the port block usage for all address groups.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays the port block usage for all member devices. (In IRF mode.)
# (In standalone mode.) Display the port block usage for address groups.
<Sysname> display nat port-block-usage
Slot 1:
Address group 0 on channel 0:
Total port block entries :10
Active port block entries:9
Current port block usage :90%
Total NAT address groups found: 1
# (In IRF mode.) Display the port block usage for address groups for slot 1.
<Sysname> display nat port-block-usage slot 1
Slot 1:
Table 13 Command output
Address group |
channel |
Total port block entries |
Total number of port blocks in the address group. |
Active port block entries |
Total number of assigned port blocks in the address group. |
Current port block usage |
Port block usage in the address group. |
Total NAT address groups found |
Total number of address groups. |
display nat server
Use display nat server to display NAT server mappings.
display nat server
# (In standalone mode.) Display NAT server mappings.
<Sysname> display nat server
Protocol: 6(TCP)
Global VPN : vpn1
Local VPN : vpn3
Rule name : abcg
NAT counting : 0
Rule name : abcdefg
NAT counting : 0
# (In IRF mode.) Display NAT server mappings.
Global ACL : 2000
Rule name : cdefgab
Priority : 1000
NAT counting : 0
Protocol: 6(TCP)
Rule name : ace
NAT counting : 0
Protocol: 6(TCP)
Global VPN : vpn1
Local VPN : vpn3
Rule name : abcdef
NAT counting : 0
Rule name : cdefg
NAT counting : 0
Protocol: 17(UDP)
1.1.1.1/21 (Connections: 10)
192.168.100.200/80 (Connections: 20)
Rule name : white
NAT counting : 0
Priority |
Priority of the NAT server mapping. |
Information about NAT server mapping. |
Interface where the NAT server mapping is configured. |
Protocol |
Protocol number and name of the internal server. |
Global IP/port |
Public IP address and port number of the internal server. · Global IP—A single IP address or an IP address range. If you use Easy IP, this field displays the IP address of the specified interface. If you do not specify an address for the interface, the Global IP field displays hyphens (---). · port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---). |
Local IP/port |
For common NAT server mappings and object group-based NAT server mappings, this field displays the private IP address and port number of the internal server. · Local IP—A single IP address or an IP address range. · port—A single port number or a port number range. If no port number is in the specified protocol, the port field displays hyphens (---). For a load sharing NAT server mapping, this field displays the internal server group ID, IP address, port number, and number of connections of each member. |
Global VPN |
MPLS L3VPN instance to which the public IP addresses belong. If the public IP addresses do not belong to any VPN instance, this field is not displayed. |
Local VPN |
MPLS L3VPN instance to which the private IP addresses belong. If the private IP addresses do not belong to any VPN instance, this field is not displayed. |
ACL |
ACL number or name. If no ACL is specified, this field is not displayed. |
Rule name |
Name of the NAT server mapping. |
NAT counting |
Number of times the NAT server mapping is matched. |
Description of the NAT server mapping. This field is not displayed if no description is configured for the mapping. |
Config status |
Status of the NAT server mapping: Active or Inactive. |
Reasons why the NAT server mapping does not take effect. This field is available when the Config status is Inactive. |
nat server
display nat server-group
Use display nat server-group to display internal server group configuration.
display nat server-group [ group-id ]
group-id: Specifies the ID of the internal server group. The value range for this argument is 0 to 65535. If you do not specify this argument, the command displays the configuration of all internal server groups.
# Display the configuration of all internal server groups.
<Sysname> display nat server-group
192.168.0.27 23 500
2 --- --- ---
# Display the configuration of internal server group 1.
<Sysname> display nat server-group 1
192.168.0.27 23 500
Information about the NAT server group configuration. |
Totally n NAT server groups |
Total number of NAT server groups. |
Group Number |
ID of the internal server group. |
Inside IP |
Private IP address of a server in the internal server group. If no address is specified, this field displays hyphens (---). |
Port |
Private port number of a server in the internal server group. If no port number is specified, this field displays hyphens (---). |
Weight |
Weight of a server in the internal server group. If no weight value is specified, this field displays hyphens (---). |
nat server-group
display nat session
Use display nat session to display NAT sessions.
In standalone mode:
display nat session [ [ responder ] { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ brief | verbose ]
In IRF mode:
display nat session [ [ responder ] { source-ip source-ip | destination-ip destination-ip } * [ vpn-instance vpn-instance-name ] ] [ slot slot-number ] [ brief | verbose ]
responder: Displays NAT sessions by responder. If you do not specify this keyword, this command displays NAT sessions by initiator.
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The VPN must be the VPN inside the packet. If you do not specify a VPN instance, this command displays NAT sessions that do not belong to any VPN instance.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT sessions for all member devices. (In IRF mode.)
brief: Displays brief information about NAT sessions.
verbose: Displays detailed information about NAT sessions.
If you do not specify any parameters, this command displays detailed information about session initiators of all NAT sessions.
# (In standalone mode.) Display detailed information about NAT sessions.
<Sysname> display nat session verbose
Slot 0:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
DS-Lite tunnel peer: -
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/1
Source security zone: SrcZone
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.10/1877
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6)
Inbound interface: GigabitEthernet1/0/2
Source security zone: DestZone
State: TCP_SYN_SENT
Application: SSH
Rule ID: -/-/-
Rule name:
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Total sessions found: 1
# (In IRF mode.) Display detailed information about NAT sessions for the specified slot.
<Sysname> display nat session slot 1 verbose
Slot 1:
Initiator:
Protocol: TCP(6)
Responder:
Protocol: TCP(6)
State: TCP_SYN_SENT
Application: SSH
Rule ID: -/-/-
Rule name:
# (In standalone mode.) Display brief information about NAT sessions.
<Sysname> display nat session brief
Slot 0:
Protocol Source IP/port Destination IP/port Global IP/port
TCP 2.1.1.20/1351 10.1.1.110/21 2.1.1.50/1025
# (In IRF mode.) Display brief information about NAT sessions for the specified slot.
Slot 1:
Table 16 Command output
Initiator |
Session information about the initiator. |
Responder |
Session information about the responder. |
Source IP/port |
Source IP address and port number. |
Destination IP/port |
Destination IP address and port number. |
Global IP/port |
Public IP address and port number. |
DS-Lite tunnel peer |
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
VPN instance/VLAN ID/Inline ID |
The fields identify the following information: · VPN instance—MPLS L3VPN instance to which the session belongs. · VLAN ID—VLAN ID to which the session belongs for Layer 2 forwarding. · Inline ID——INLINE to which the session belongs for Layer 2 forwarding. If no VPN instance, VLAN ID, or inline ID is specified, a hyphen (-) is displayed for the related field. |
Protocol |
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite. |
Inbound interface |
Input interface. |
Source security zone |
Security zone to which the input interface belongs. If the input interface does not belong to any security zone, this field displays a hyphen (-). |
State |
NAT session status. |
Application |
Application layer protocol type, such as FTP and DNS. This field displays OTHER for the protocol types identified by non-well-known ports. |
Rule ID |
ID of the security policy rule. |
Rule name |
Name of the security policy rule. |
Start time |
Time when the session starts. |
TTL |
Remaining NAT session lifetime in seconds. |
Initiator->Responder |
Number of packets and packet bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and packet bytes from the responder to the initiator. |
Total sessions found |
Total number of sessions. |
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# (In standalone mode.) Display static NAT mappings.
<Sysname> display nat static
Net-to-net:
Global IP : 1.1.1.1 - 1.1.1.255
Local IP : 2.2.2.0
Global VPN : vpn2
Local VPN : vpn1
ACL : 2000
Reversible : Y
NAT counting : 0
Rule name : abcdefg
Priority : 1000
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2000
Reversible : Y
Rule name : abefg
Priority : 1000
NAT counting : 0
Net-to-net:
Global IP : 2.2.2.0
ACL : 2000
Reversible : Y
Rule name : abefg
Priority : 1000
NAT counting : 0
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2001
Reversible : Y
Rule name : abcd
Priority : 1000
NAT counting : 0
# (In IRF mode.) Display static NAT mappings.
Net-to-net:
Local IP : 2.2.2.0
Global VPN : vpn2
Local VPN : vpn1
ACL : 2000
Reversible : Y
Rule name : adefg
Priority : 1000
NAT counting : 0
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2001
Reversible : Y
Rule name : abefg
Priority : 1000
NAT counting : 0
Net-to-net:
Global IP : 2.2.2.0
ACL : 2000
Reversible : Y
Rule name : abcd
Priority : 1000
NAT counting : 0
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2000
Rule name : defg
Priority : 1000
NAT counting : 0
Reversible : Y
Totally 1 interfaces enabled with static NAT.
Information about static NAT mapping configuration. |
Totally n inbound static NAT mappings |
Total number of inbound static NAT mappings. |
Totally n outbound static NAT mappings |
Total number of outbound static NAT mappings. |
Net-to-net |
Net-to-net static NAT mapping. |
IP-to-IP |
One-to-one static NAT mapping. |
Local IP |
Private IP address or address range. |
Global IP |
Public IP address or address range. |
Netmask |
Network mask. |
Local VPN |
Global VPN |
ACL |
Reversible |
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed. |
Interfaces enabled with static NAT |
Interfaces on which static NAT is enabled. |
Totally n interfaces enabled with static NAT |
Total number of interfaces where static NAT is enabled. |
Interface on which static NAT is enabled. |
Rule name |
Priority |
Packet type ignore |
Whether the NAT device checks the protocol packet type when TCP, ICMP, or SCTP packet exchanges trigger the creation of session entries. · If this field displays Y, the NAT device does not check the protocol packet type. · If this field is not displayed, the NAT device checks the protocol packet type. |
NAT counting |
Config status |
Status of the static NAT mapping: Active or Inactive. |
Reasons why the static NAT mapping does not take effect. This field is available when the Config status is Inactive. |
nat static enable
nat static inbound
nat static outbound
nat static outbound object-group
display nat statistics
Use display nat statistics to display NAT statistics.
In standalone mode:
display nat statistics [ summary ]
In IRF mode:
display nat statistics [ summary ] [ slot slot-number ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays NAT statistics for all member devices. (In IRF mode.)
# (In standalone mode.) Display detailed information about NAT statistics.
<Sysname> display nat statistics
Slot 0:
Total session entries: 100
Total EIM entries: 1
Total inbound NO-PAT entries: 0
Total outbound NO-PAT entries: 0
Total static port block entries: 10
Total dynamic port block entries: 15
Active static port block entries: 0
Active dynamic port block entries: 0
# (In IRF mode.) Display detailed information about NAT statistics.
Slot 1:
Session creation rate: 0
Table 18 Command output
Total session entries |
Number of NAT session entries. |
Total EIM entries |
Total inbound NO-PAT entries |
Total number of inbound NO-PAT entries. |
Total outbound NO-PAT entries |
Total number of outbound NO-PAT entries. |
Total static port block entries |
Total number of static NAT444 mappings. |
Total dynamic port block entries |
Total number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
Active static port block entries |
Number of static port block mappings that are in use. |
Active dynamic port block entries |
Number of dynamic port block mappings that have been created. It equals the number of dynamically assigned port blocks. |
# (In standalone mode.) Display NAT statistics summary.
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions EIM SPB DPB ASPB ADPB
0 100 1 10 15 0 0
# (In IRF mode.) Display NAT statistics summary.
2 0 0 0 1572720 0 0
Table 19 Command output
Sessions |
EIM |
Number of EIM entries. |
SPB |
Number of static NAT444 mappings. |
DPB |
Number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
ASPB |
Number of static port block mappings in use. |
ADPB |
global-ip-pool
Use global-ip-pool to add a public IP address range to a NAT port block group.
Use undo global-ip-pool to remove a public IP address range from a NAT port block group.
global-ip-pool start-address end-address
undo global-ip-pool start-address
No public IP address ranges exist.
start-address end-address: Specifies the start IP address and end IP address of a public IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one public IP address is specified.
A static port block mapping maps a public IP address to multiple private IP addresses and assigns a unique port block to each private IP address. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
Every time you execute this command, an address range can contain a maximum of 256 public IP addresses. All public IP address ranges in one port block group cannot overlap.
Public IP address ranges in different port block groups can overlap. The port ranges for overlapped public IP address ranges cannot overlap.
# Add a public IP address range to the port block group 1. The public IP address range consists of IP addresses from 202.10.1.1 to 202.10.1.10.
[Sysname-port-block-group-1] global-ip-pool 202.10.1.1 202.10.1.10
inside ip
Use inside ip to add a server to an internal server group.
Use undo inside ip to remove a server from an internal server group.
inside ip inside-ip port port-number [ weight weight-value ]
undo inside ip inside-ip port port-number
An internal server group has no server members.
Internal server group view
inside-ip: Specifies the IP address of an internal server.
port port-number: Specifies the port number of an internal server, in the range of 1 to 65535, excluding FTP port 20.
weight weight-value: Specifies the weight of the internal server. The value range is 1 to 1000, and the default value is 100.
An internal server with a larger weight receives a larger percentage of connections in the internal server group.
# Add a server with IP address 10.1.1.2 and port number 30 to internal server group 1.
[Sysname] nat server-group 1
[Sysname-nat-server-group-1] inside ip 10.1.1.2 port 30
nat server-group
local-ip-address
Use local-ip-address to add a private IP address range to a NAT port block group.
Use undo local-ip-address to remove a private IP address range from a NAT port block group.
local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
undo local-ip-address start-address end-address [ vpn-instance vpn-instance-name ]
No private IP address ranges exist in a NAT port block group.
start-address end-address: Specifies the start IP address and end IP address of a private IP address range. The end IP address cannot be lower than the start IP address. If the start and end IP addresses are the same, only one private IP address is specified.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address range belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address range does not belong to any VPN instance, do not specify this option.
A static port block mapping maps one public IP address to multiple private IP addresses and assigns a unique port block to each private IP address.
When you add multiple private IP address ranges to the same port block group, follow these restrictions:
· The private IP address ranges in the same VPN instance cannot overlap.
· The private IP address ranges that do not belong to any VPN instances cannot overlap.
In a NAT port block group, the number of private IP addresses cannot be larger than the number of assignable port blocks. Otherwise, some private IP addresses cannot obtain port blocks. The number of port blocks that a public IP address can assign is determined by dividing the number of ports in the port range by the port block size.
# Add a private IP address range to port block group 1. The private IP address range consists of IP addresses from 172.16.1.1 to 172.16.1.255.
[Sysname-port-block-group-1] local-ip-address 172.16.1.1 172.16.1.255
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id [ name group-name ]
undo nat address-group group-id
No NAT address groups exist.
name group-name: Assigns a name to the NAT address group. The group-name argument is a case-sensitive string of 1 to 63 characters.
A NAT address group is a set of address ranges. Use the address command to add an address range to a NAT address group. Dynamic NAT translates the source IP address of a packet into an IP address in the address group.
# Create a NAT address group numbered 1 and named abc.
[Sysname] nat address-group 1 name abc
address
display nat all
nat inbound
nat outbound
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sctp | sip | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | h323 | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp }
NAT ALG is enabled for DNS, FTP, ICMP error messages, PPTP, and RTSP, and is disabled for the other supported protocols.
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
h323: Enables NAT ALG for H.323.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sctp: Enables NAT ALG for SCTP.
sip: Enables NAT ALG for SIP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat dns-map
Use nat dns-map to configure a NAT DNS mapping.
Use undo nat dns-map to remove a NAT DNS mapping.
nat dns-map domain domain-name protocol pro-type { interface interface-type interface-number | ip global-ip } port global-port
undo nat dns-map domain domain-name
No NAT DNS mappings exist.
domain domain-name: Specifies the domain name of an internal server. A domain name is a dot-separated case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.) (for example, aabbcc.com). The domain name can contain a maximum of 253 characters, and each separated string contains no more than 63 characters.
protocol pro-type: Specifies the type of the protocol used by the internal server, tcp or udp.
interface interface-type interface-number: Enables Easy IP to use the IP address of the interface specified by its type and number as the public address of the internal server.
ip global-ip: Specifies the public IP address used by the internal server to provide services for the external network.
port global-port: Specifies the public port number used by the internal server to provide services for the external network. The port number format can be one of the following:
· A number in the range of 1 to 65535.
· A protocol name, a string of 1 to 15 characters. For example, ftp and telnet.
NAT DNS mapping must cooperate with the NAT Server feature.
· A NAT DNS mapping maps the domain name of an internal server to the public IP address, public port number, and protocol type of the internal server.
· A NAT server mapping maps the public IP and port to the private IP and port of the internal server.
The cooperation allows an internal host to access an internal server on the same private network by using the domain name of the internal server when the DNS server is on the public network. The DNS reply from the external DNS server contains only the domain name and public IP address of the internal server in the payload. The NAT interface might have multiple internal servers configured with the same public IP address but different private IP addresses. DNS ALG might find an incorrect internal server by using only the public IP address. If a DNS mapping is configured, DNS ALG can obtain the public IP address, public port number, and protocol type of the internal server by using the domain name. Then it can find the correct internal server by using the public IP address, public port number, and protocol type of the internal server.
You can configure multiple NAT DNS mappings.
# Configure a NAT DNS mapping to map the domain name www.server.com to the public IP address 202.112.0.1, public port number 12345, and protocol type TCP.
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port 12345
display nat all
display nat dns-map
nat server
nat hairpin enable
Use nat hairpin enable to enable NAT hairpin.
Use undo nat hairpin enable to disable NAT hairpin.
nat hairpin enable
NAT hairpin is disabled.
Interface view
NAT hairpin allows internal hosts to access each other or allows internal hosts to access internal servers. It must cooperate with NAT Server, outbound dynamic NAT, or outbound static NAT. The source and destination IP addresses of the packets are translated on the interface connected to the internal network.
# Enable NAT hairpin on interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] nat hairpin enable
display nat all
nat icmp-error reply
Use nat icmp-error reply to enable sending ICMP error messages upon NAT failures.
Use undo nat icmp-error reply to restore the default.
No ICMP error messages are sent upon NAT failures.
Disabling sending ICMP error messages upon NAT failures reduces useless packets, saves bandwidth, and avoids exposing the device IP address to the public network.
This command is required for traceroute.
# Enable sending ICMP error messages upon NAT failures.
[Sysname] nat icmp-error reply
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule.
Use undo nat inbound to delete an inbound dynamic NAT rule.
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group { group-id | name group-name } [ vpn-instance vpn-instance-name ] [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
No inbound dynamic NAT rules exist.
Interface view
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group for address translation.
group-id: Specifies the address group ID. The value range for this argument is 0 to 65535.
name group-name: Specifies the address group name, a case-insensitive string of 1 to 63 characters.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the addresses in the address group belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the addresses in the address group do not belong to any VPN instance, do not specify this option.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
add-route: Automatically adds a route to the source address after translation. The output interface is the NAT interface and the next hop is the source address before translation.
rule rule-name: Specifies a name for the rule, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the rule does not have a name.
priority priority: Specifies a priority for the rule, in the range of 0 to 2147483647. The default value is 4294967295. A smaller value represents a higher priority. If you do not specify this option, the rule has the lowest priority among the same type of NAT rules.
disable: Disables the inbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
counting: Enables NAT counting. The number of flows that use the address mapping is counted.
description text: Specifies a description for the inbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation.
· NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
· Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
· Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically cooperates with one of the following to implement bidirectional NAT:
· Outbound dynamic NAT (the nat outbound command).
· NAT Server (the nat server command).
· Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the subnets where the internal and external networks reside overlap. For other network scenarios:
· If you specify the add-route keyword, the device automatically adds a route to the source address after translation for a packet. The destination address is the NAT address in the NAT address group, the output interface is the interface where the command is executed, and the next hop is the source address before translation.
· If you do not specify the add-route keyword, you must manually add the route. As a best practice, add routes manually because automatic route adding is slow.
An ACL can be used by only one inbound dynamic NAT rule on an interface.
You can configure multiple inbound dynamic NAT rules on an interface.
The vpn-instance parameter is required if you deploy inbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
Inbound dynamic NAT rules configured with the same priority value are matched by using their ACLs.
· NAT rules with named ACLs have higher priorities than NAT rules with unnamed ACLs.
· NAT rules with named ACLs are matched in alphabetical order of their ACL names.
· NAT rules with unnamed ACLs are matched in descending order of their ACL numbers.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 in VPN vpn10 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit vpn-instance vpn10 source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Configure the MPLS L3VPN instance named vpn10.
[Sysname] ip vpn-instance vpn10
[Sysname-vpn-instance-vpn10] route-distinguisher 100:001
[Sysname-vpn-instance-vpn10] vpn-target 100:1 export-extcommunity
[Sysname-vpn-instance-vpn10] vpn-target 100:1 import-extcommunity
[Sysname-vpn-instance-vpn10] quit
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface GigabitEthernet 1/0/1. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds routes for translated packets. Set the rule name to abc, and the priority to 0.
[Sysname-GigabitEthernet1/0/1] nat inbound 2001 address-group 1 vpn-instance vpn10 no-pat add-route rule abc priority 0
display nat all
display nat inbound
display nat no-pat
nat inbound rule move
Use nat inbound rule move to change the priority of an inbound dynamic NAT rule.
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the rule be moved.
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
This command is applicable only to named inbound dynamic NAT rules.
A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound dynamic NAT rule abc to the line before the rule def.
[Sysname-GigabitEthernet1/0/1] nat inbound rule move abc before def
nat inbound
nat link-switch recreate-session
Use nat link-switch recreate-session to enable NAT session recreation after link switchover.
Use undo nat link-switch recreate-session to disable NAT session recreation after link switchover.
NAT session recreation is disabled after link switchover.
This command is applicable to a WAN network where two interfaces of the NAT device are configured with outbound dynamic NAT rules using different address groups. When the link of one interface fails, traffic on this link is switched to the link of another interface and the NAT device operates as follows:
· If the two interfaces are in different security zones, the NAT device deletes old session entries after link switchover. When user traffic later arrives, it triggers the NAT session recreation. This mechanism ensures that internal users can access the external network.
· If the two interfaces are in the same security zone, the NAT device retains old session entries after link switchover. Internal users cannot access the external network because the device uses old session entries to match the user traffic. To avoid this issue, enable this feature to ensure availability of NAT services.
# Enable NAT session recreation after link switchover.
[Sysname] nat link-switch recreate-session
display nat all
nat log alarm
Use nat log alarm to enable NAT alarm logging.
Use undo nat log alarm to disable NAT alarm logging.
nat log alarm
undo nat log alarm
NAT alarm logging is disabled.
Packets that need to be translated are dropped if the NAT resources are not enough. In NO-PAT, the NAT resources refer to the public IP addresses. In EIM PAT, the NAT resources refer to public IP addresses and ports. In NAT444, the NAT resources refer to public IP addresses, port blocks, or ports in port blocks. NAT alarm logging monitors the usage of NAT resources and outputs logs if the NAT resources are not enough.
For NAT444 dynamic port block mappings, an alarm log is generated upon the port block assignment failure or the failure that port resources cannot meet the user address translation requirement.
Before configuring alarm logging for NAT, you must configure the custom NAT log generation and outputting features. For more information about information center, see Network Management and Monitoring Configuration Guide.
This command take effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT alarm logging.
[Sysname] nat log alarm
display nat all
display nat log
nat log enable
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT logging is disabled.
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging, NAT444 user logging (including port block assignment and withdrawal logging), NAT alarm logging, or NAT NO-PAT logging.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
display nat all
display nat log
nat log alarm
nat log flow-active
nat log flow-begin
nat log flow-end
· nat log port-block-assign
· nat log port-block-withdraw
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time. The logging feature helps track active NAT flows by periodically logging the active NAT flows.
Logging for active NAT flows takes effect only after you enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
Logging for NAT session establishment events takes effect only after you enable NAT logging.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
Logging for NAT session removal events takes effect only after you enable NAT logging.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
Use nat log no-pat ip-usage to enable logging for the IP usage of a NAT address group in NO-PAT mode and set a usage threshold.
undo nat log no-pat ip-usage disable logging for the IP usage of a NAT address group in NO-PAT mode.
nat log no-pat ip-usage [ threshold value ]
Logging for the IP usage of a NAT address group is disabled.
Predefines user roles
threshold value: Specifies the IP usage threshold of a NAT address group, in percentage. The value range is 40 to 100, and the default is 90%.
The system generates a log if the IP usage of a NAT address group exceeds the threshold.
This command takes effect only after you enable the NAT logging by using the nat log enable command.
# Enable logging for the IP usage of a NAT address group in NO-PAT mode and set the threshold to 60%.
[Sysname] nat log no-pat ip-usage threshold 60
display nat log
nat log enable
nat log port-block usage threshold
Use nat log port-block usage threshold to set the port block usage threshold.
Use undo nat log port-block port-usage threshold to restore the default.
nat log port-block usage threshold threshold-value
undo nat log port-block usage threshold
The port block usage threshold is 90%.
threshold-value: Specifies a threshold in the range of 40 to 100 in percentage.
A log is generated when the port block usage exceeds the threshold.
# Set the port block usage threshold to 60%.
[Sysname] nat log port-block usage threshold 60
display nat all
display nat log
nat log enable
Use nat log port-block-assign to enable NAT444 user logging for port block assignment.
Use undo nat log port-block-assign to disable NAT444 user logging for port block assignment.
NAT444 user logging is disabled for port block assignment.
For static port block mappings, the NAT444 gateway generates a user log when it translates the first connection from a private IP address.
For dynamic port block mappings, the NAT444 gateway generates a user log when it assigns or extends a port block for a private IP address.
This command takes effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT444 user logging for port block assignment.
[Sysname] nat log port-block-assign
display nat all
display nat log
nat log enable
Use nat log port-block-withdraw to enable NAT444 user logging for port block withdrawal.
Use undo nat log port-block-withdraw to disable NAT444 user logging for port block withdrawal.
NAT444 user logging is disabled for port block withdrawal.
For static port block mappings, the NAT444 gateway generates a user log when all connections from a private IP address are disconnected.
For dynamic port block mappings, the NAT444 gateway generates a user log when all the following conditions are met:
· The port blocks (including the extended ones) assigned to the private IP address are withdrawn.
· The corresponding mapping entry is deleted.
# Enable NAT444 user logging for port block withdrawal.
[Sysname] nat log port-block-withdraw
display nat all
display nat log
nat log enable
nat mapping-behavior endpoint-independent
Use nat mapping-behavior endpoint-independent to specify the Endpoint-Independent Mapping (EIM) mode for PAT.
Use undo nat mapping-behavior to restore the default.
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat mapping-behavior endpoint-independent
Address and Port-Dependent Mapping applies.
acl: Specifies an ACL to define the applicable scope of Endpoint-Independent Mapping.
PAT supports the following NAT mapping modes:
· Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the NAT IP address and port. It allows internal hosts behind different NAT gateways to access each other.
· Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
If you specify an ACL, Endpoint-Independent Mapping applies to packets that are permitted by the ACL. If you do not specify an ACL, Endpoint-Independent Mapping applies to all packets.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping mode to FTP and HTTP packets, and the Address and Port-Dependent Mapping mode to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
nat outbound
display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group { group-id | name group-name } [ vpn-instance vpn-instance-name ] no-pat [ reversible ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group { group-id | name group-name } ] [ vpn-instance vpn-instance-name ] [ port-preserved ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
No outbound dynamic NAT rules exist.
Interface view
address-group: Specifies an address group for NAT. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
port-preserved: Tries to preserve port number for PAT. This keyword does not take effect on dynamic NAT port block mapping.
disable: Disables the outbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the outbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Outbound dynamic NAT is typically configured on the interface connected to the external network. You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
· NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡ Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡ Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Dynamic NAT444 does not support the NO-PAT mode.
When you specify a NAT address group, follow these restrictions and guidelines:
· An address group cannot be used by both the nat inbound and nat outbound commands.
· An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
· When port block parameters are specified in the NAT address group, this command configures a dynamic NAT port block mapping. Packets matching the ACL permit rule are processed by dynamic NAT444.
When you specify an ACL, follow these restrictions and guidelines:
· An ACL can be used by only one outbound dynamic NAT rule on an interface.
· If you configure multiple outbound dynamic NAT rules, only one outbound dynamic NAT rule can contain no ACL.
· If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
· Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. If two ACL-based dynamic NAT rules are configured, the rule with the higher ACL number has higher priority.
The vpn-instance parameter is required if you deploy outbound dynamic NAT for VPNs. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
Outbound dynamic NAT rules configured with the same priority value and an ACL are matched by using the ACLs in the rule.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
# Configure an outbound dynamic PAT rule on interface GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1
Or
# Configure an outbound NO-PAT rule on interface GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of GigabitEthernet 1/0/1 as the NAT address.
[Sysname-GigabitEthernet 1/0/1] nat outbound 2001
[Sysname-GigabitEthernet 1/0/1] quit
Or
# Configure an outbound NO-PAT rule on GigabitEthernet 1/0/1 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-GigabitEthernet1/0/1] nat outbound 2001 address-group 1 no-pat reversible
display nat eim
nat outbound ds-lite-b4
Use nat outbound ds-lite-b4 to configure DS-Lite B4 address translation.
Use undo nat outbound ds-lite-b4 to remove the DS-Lite B4 address translation configuration.
nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name } address-group group-id
undo nat outbound ds-lite-b4 { ipv6-acl-number | name ipv6-acl-name }
No DS-Lite B4 address translation configuration exists.
Interface view
ipv6-acl-number: Specifies the number of an IPv6 ACL to match the IPv6 addresses of B4 elements. The value range for the argument is 2000 to 2999.
name ipv6-acl-name: Specifies the name of an IPv6 ACL to match the IPv6 addresses of B4 elements. The ACL name is a case-insensitive string of 1 to 63 characters. It must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group by its ID. The value range for the group-id argument is 0 to 65535. Port block parameters are required in the address group for DS-Lite B4 address translation.
DS-Lite B4 address translation applies to the scenario where a DS-Lite tunnel connects an IPv6 network to an IPv4 network. DS-Lite port block mapping is configured on the AFTR's interface connected to the external IPv4 network and performs dynamic port block mapping based on the B4 element. The B4 element refers to a B4 router or a DS-Lite host.
DS-Lite B4 address translation dynamically maps a public IPv4 address and a port block to the IPv6 address of the B4 element. The DS-Lite host or hosts behind the B4 router use the mapped public IPv4 address and port block to access the public IPv4 network.
# Configure IPv6 ACL 2100 to identify packets from subnet 2000::/64.
[Sysname] acl ipv6 basic 2100
[Sysname-acl-ipv6-basic-2100] rule permit source 2000::/64
[Sysname-acl-ipv6-basic-2100] quit
# Create address group 1 and add public addresses 202.110.10.10 through 202.110.10.12 to the group.
[Sysname-nat-address-group-1] address 202.110.10.10 202.110.10.12
# Set the port block size to 256.
[Sysname-nat-address-group-1] port-block block-size 256
[Sysname-nat-address-group-1] quit
# Configure DS-Lite port block mapping on GigabitEthernet 1/0/1 to use address group 1 to translate packets permitted by ACL 2100.
[Sysname-GigabitEthernet1/0/1] nat outbound ds-lite-b4 2100 address-group 1
display nat outbound
nat outbound port-block-group
Use nat outbound port-block-group to configure a static outbound port block mapping rule on an interface.
Use undo nat outbound port-block-group to delete a static port block mapping rule on an interface.
nat outbound port-block-group group-id [ rule rule-name ] [ counting ]
undo nat outbound port-block-group group-id
No static outbound port block mapping rule is configured on an interface.
Interface view
group-id: Specifies a NAT port block group by its ID. The value range for this argument is 0 to 65535.
After you configure this command on an interface, the system automatically computes the mappings and creates entries for them. When a private IP address accesses the public network, the private IP address is translated to the mapped public IP address, and the ports are translated to ports in the selected port block.
You can configure multiple port block mapping rules on an interface.
In an IRF fabric, you must execute the ip fast-forwarding load-sharing command. Otherwise, the port assignment conflict will occur.
# Configure a static outbound port block mapping rule on GigabitEthernet 1/0/1, and specify the rule name as abc.
[Sysname-GigabitEthernet1/0/1] nat outbound port-block-group 1 rule abc
display nat all
display nat outbound port-block-group
nat outbound rule move
Use nat outbound rule move to change the priority of an outbound dynamic NAT rule.
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound dynamic NAT rules.
# Move the outbound dynamic NAT rule abc to the line before the rule def.
[Sysname-GigabitEthernet1/0/1] nat outbound rule move abc before def
nat outbound
nat port-block global-share enable
Use nat port-block global-share enable to enable port block global sharing.
Use undo nat port-block global-share enable to disable port block global sharing.
Port block global sharing is disabled.
When multiple interfaces have dynamic NAT port block mapping configured, the interfaces might create different port block mappings for packets from the same IP address. You can use this command to configure the interfaces to use the same port block mapping for translating packets from the same IP address.
# Enable port block global sharing.
[Sysname] nat port-block global-share enable
port-block
nat port-block synchronization enable
Use nat port-block synchronization enable to enable dynamic NAT port block mapping synchronization.
Use undo nat port-block synchronization enable to disable dynamic NAT port block mapping synchronization.
The following compatibility matrixes show the support of hardware platforms for this command:
Hardware |
Command compatibility |
MSR610 |
Yes |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR810-SI, MSR810-LM-SI |
No |
MSR810-LMS-EA, MSR810-LME |
No |
MSR1004S-5G |
No |
No |
MSR2600-10-X1 |
No |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
Yes |
No |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
No |
MSR2600-10-X1-WiNet |
No |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
No |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
No |
MSR3600-28-SI-GL |
No |
Dynamic NAT port block mapping synchronization is disabled.
Dynamic NAT port block mapping synchronization enables the master and the backup to synchronize dynamic port block mappings, which ensures smooth switchover without service interruption.
# Enable dynamic NAT port block mapping synchronization.
[Sysname] nat port-block synchronization enable
nat port-block-group
Use nat port-block-group to create a NAT port block group and enter its view, or enter the view of an existing NAT port block group.
Use undo nat port-block-group to delete a NAT port block group.
nat port-block-group group-id
undo nat port-block-group group-id
No NAT port block groups exist.
group-id: Assigns an ID to the NAT port block group. The value range for this argument is 0 to 65535.
A NAT port block group is configured to implement static port block mapping for NAT444.
You must configure the following items for a NAT port block group:
· A minimum of one private IP address range (see the local-ip-address command).
· A minimum of one public IP address range (see the global-ip-address command).
· A port range (see the port-range command).
· A port block size (see the block-size command).
The system computes static port block mappings according to the port block group configuration, and creates entries for the mappings.
# Create NAT port block group 1.
<Sysname>system-view
[Sysname]nat port-block-group 1
block-size
display nat all
display nat port-block-group
global-ip-pool
local-ip-address
port-range
nat port-load-balance enable
Use nat port-load-balance enable to enable NAT port halving.
Use undo nat port-load-balance enable to disable NAT port halving.
nat port-load-balance enable slot slot-number
undo nat port-load-balance enable slot slot-number
Hardware |
MSR610 |
Yes |
Yes |
No |
No |
No |
MSR1004S-5G |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
No |
No |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
No |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
No |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
No |
MSR3640-XS |
No |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
NAT port halving is disabled.
slot slot-number: Specifies an IRF member device by its member ID. This device will use the lower half portion of the port block. (In IRF mode.)
After you enable NAT port halving in VRRP load balancing on an IRF fabric, each port block will be equally divided between the two devices. The two devices will use different ports to translate packets from the same IP address, avoiding port assignment conflicts.
Before enabling this feature, for successfully port allocation, make sure the address group meets the following requirements:
· For dynamic outbound NAT, the number of ports for the public IP addresses in the address group must not less than 2.
· For dynamic NAT444, the number of port blocks and ports for public IP addresses in the address group must not less than 2.
Do not use this feature in VRRP standard mode on an IRF fabric or when the device works in standalone mode.
# Enable NAT port halving.
<Sysname> system
[Sysname] nat port-load-balance enable slot 1
port-block
port-range
nat redirect reply-route
Use nat redirect reply-route enable to enable NAT reply redirection.
Use undo nat redirect reply-route enable to disable NAT reply redirection.
NAT reply redirection is disabled.
Interface view
NAT reply redirection allows an interface to use the NAT session entry information to translate the destination IP addresses for NAT reply packets and find the output interfaces for the NATed reply packets.
# Enable NAT reply redirection on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] nat redirect reply-route enable
nat remote-backup port-alloc
Use nat remote-backup port-alloc to specify NAT port ranges for the two devices in the HA group.
Use undo nat remote-backup port-alloc to restore the default.
nat remote-backup port-alloc { primary | secondary }
Hardware |
MSR610 |
Yes |
Yes |
No |
No |
No |
MSR1004S-5G |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
Yes |
No |
No |
MSR3640-X1-HI |
No |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
No |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
The two devices in the HA group share NAT port resources.
primary: Specifies the first half of the port range.
secondary: Specifies the second half of the port range.
In the HA group in dual-active mode, different IP+port combinations on the two devices might be translated to the same NAT IP+port resources due to the following reasons:
· The two devices in the HA group share NAT addresses.
· The same NAT port range is assigned to each device.
To avoid this situation, execute this command on the primary device to equally divide the port resources for the two devices. Executing the command on the primary device also makes the remaining half of the port range be automatically assigned to the secondary device. For example, if you execute the nat remote-backup port-alloc secondary command on the primary device, the nat remote-backup port-alloc primary command is automatically executed on the secondary device. For more information about the HA group, see High Availability Configuration Guide.
You do not need to execute this command for active/standby HA. No port conflict exists in this mode because only one device processes NAT services.
# Specify one device in the HA group to use the first half of the port range.
[Sysname] nat remote-backup port-alloc primary
nat server
Use nat server to create a NAT server mapping (also called NAT server rule). The mapping maps the private IP address and port of an internal server to a public address and port.
Use undo nat server to delete a NAT server mapping.
Common NAT server mapping:
· A single public address with no or a single public port:
nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ] inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ reversible ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server [ protocol pro-type ] global { global-address | current-interface | interface interface-type interface-number } [ global-port ] [ vpn-instance global-vpn-instance-name ]
· A single public address with consecutive public ports:
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ] inside { { local-address | local-address1 local-address2 } local-port | local-address local-port1 local-port2 } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 [ vpn-instance global-vpn-instance-name ]
· Consecutive public addresses with no public port:
nat server protocol pro-type global global-address1 global-address2 [ vpn-instance global-vpn-instance-name ] inside { local-address | local-address1 local-address2 } [ local-port ] [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global global-address1 global-address2 [ global-port ] [ vpn-instance global-vpn-instance-name ]
· Consecutive public addresses with one single public port:
nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ] inside { local-address [ local-port1 local-port2 ] | [ local-address | local-address1 local-address2 ] [ local-port ] } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global global-address1 global-address2 global-port [ vpn-instance global-vpn-instance-name ]
Load sharing NAT server mapping:
nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ] inside server-group group-id [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } ] [ vrrp virtual-router-id ] [ rule rule-name ] [ disable ] [ counting ] [ description text ]
undo nat server protocol pro-type global { { global-address | current-interface | interface interface-type interface-number } { global-port | global-port1 global-port2 } | global-address1 global-address2 global-port } [ vpn-instance global-vpn-instance-name ]
ACL-based NAT server mapping:
nat server global { ipv4-acl-number | name ipv4-acl-name } inside local-address [ local-port ] [ vpn-instance local-vpn-instance-name ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ description text ]
undo nat server global { ipv4-acl-number | name ipv4-acl-name }
No NAT server mappings exist.
Interface view
protocol pro-type: Specifies a protocol type. When the protocol is TCP or UDP, NAT Server can be configured with port information. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
· A number in the range of 1 to 255.
· A protocol name of icmp, tcp, or udp.
global: Specifies the public network information about the internal server.
global-address: Specifies the public address of an internal server.
global-address1 global address2: Specifies a public IP address range, which can include a maximum of 10000 addresses. The global-address1 argument specifies the start address, and the global address2 argument specifies the end address that must be greater than the start address.
current-interface: Enables Easy IP on the current interface. The primary IP address of the interface is used as the public address for the internal server.
interface interface-type interface-number: Enables Easy IP on the interface specified by its type and number. The primary IP address of the interface is used as the public address for the internal server. Only loopback interfaces are supported.
global-port1 global-port2: Specifies a public port number range, which can include a maximum of 10000 ports. The global-port1 argument specifies the start port, and the global-port2 argument specifies the end port that must be greater than the start port. The public port number format can be one of the following:
· A number in the range of 1 to 65535. Both the start port and the end port support this format.
· A protocol name, a string of 1 to 15 characters. For example, http and telnet. Only the start port supports this format.
inside: Specifies the private network information about the internal server.
local-address1 local-address2: Specifies a private IP address range. The local-address1 argument specifies the start address, and the local-address2 argument specifies the end address that must be greater than the start address. The number of addresses in the range must equal the number of ports in the public port number range.
local-port: Specifies the private port number. The private port number format can be one of the following:
· A number in the range of 1 to 65535, excluding FTP port 20.
global-port: Specifies the public port number. The default value and value range are the same as those for the local-port argument.
local-address: Specifies the private IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the advertised public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the internal server belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the internal server does not belong to any VPN instance, do not specify this option.
server-group group-id: Specifies the internal server group to which the internal server belongs. With this parameter, the load sharing NAT Server feature is configured. The group-id argument specifies the internal server group ID. The value range for the group-id argument is 0 to 65535.
acl: Specifies an ACL. If you specify an ACL, only packets permitted by the ACL can be translated by using the mapping.
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by internal servers to the external network. It translates the private IP addresses of the internal servers to their public IP addresses.
vrrp virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
The following compatibility matrixes show the support of hardware platforms for the vrrp virtual-router-id option:
Hardware |
Parameter compatibility |
MSR610 |
Yes |
Yes |
No |
No |
No |
MSR1004S-5G |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
Yes |
No |
No |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
rule rule-name: Specifies a name for the mapping, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the mapping does not have a name.
priority priority: Specifies a priority for the mapping, in the range of 0 to 2147483647. The default value is 4294967295. A smaller value represents a higher priority. If you do not specify this option, the mapping has the lowest priority among the same type of NAT rules.
disable: Disables the NAT server mapping. If you do not specify this keyword, the mapping is enabled.
description text: Specifies a description for the NAT server mapping. The text argument is a case-insensitive string of 1 to 63 characters.
You can configure the NAT server mapping to allow servers (such as Web, FTP, Telnet, POP3, and DNS servers) in the internal network or an MPLS VPN instance to provide services for external users.
NAT server mappings are usually configured on the interface connected to the external network on a NAT device. By using the global-address and global-port arguments, external users can access the internal server at local-address and local-port. When the protocol type is not udp (protocol number 17) or tcp (protocol number 6), you can configure only one-to-one IP address mappings. The following table describes the address-port mappings between an external network and an internal network for NAT Server.
Table 20 Address-port mappings for NAT Server
External network |
Internal network |
One public address |
One private address |
One public address and one public port number |
One private address and one private port number |
One public address and N consecutive public port numbers |
· One private address and one private port number · N consecutive private addresses and one private port number · One private address and N consecutive private port numbers |
N consecutive public addresses |
· One private address · N consecutive private addresses |
N consecutive public addresses and one public port number |
One internal server group |
Public addresses matching an ACL |
One private address and one private port |
A maximum of 256 nat server commands can be configured on an interface. The mapping of the protocol type, public address, and public port number must be unique for an internal server on an interface. This restriction also applies when Easy IP is used. The maximum number of NAT server mappings equals the number of public ports in the specified public port range.
The vpn-instance parameter is required if you configure NAT server mappings in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
As a best practice, do not configure Easy IP for multiple NAT server mappings by using the same interface.
If the IP address of an interface used by Easy IP changes and conflicts with the IP address of a NAT server mapping not using Easy IP, the Easy IP configuration becomes invalid. If the conflicting IP address is modified to another IP address or the NAT server mapping without Easy IP is removed, the Easy IP configuration takes effect.
When you configure a load sharing NAT server mapping, you must make sure a user uses the same public address and public port to access the same service on an internal server. For this purpose, make sure value N in the following mappings is equal to or less than the number of servers in the internal server group:
· One public address and N consecutive public port numbers are mapped to one internal server group.
· N consecutive public addresses and a public port number are mapped to one internal server group.
ACL-based NAT server mappings that are configured with the same priority value are matched by using the ACLs in their rules:
· Mappings with named ACLs have higher priorities than mappings with unnamed ACLs.
· Mappings with named ACLs are matched in alphabetical order of their ACL names.
· Mappings with unnamed ACLs are matched in descending order of their ACL numbers.
When you configure a NAT server mapping on the primary device in the HA group for high availability, specify a VRRP group facing the external network. This operation ensures that both forward and reverse user traffic is translated on the same master device.
An error message for a rollback failure when you perform a configuration rollback for an internal server in the following situation:
· In the running configuration, the name of a NAT server mapping is assigned automatically by the system.
· In the replacement configuration file, the name does not exist.
The system will compare the running configuration file and the replacement file, and display an error message about the mismatch. You can ignore the error message because the NAT server mapping configuration in the configuration file is installed successfully. For example, the NAT server mapping configuration is nat server global 112.1.1.1 inside 192.168.20.1 in the running configuration, and the is nat server global 112.1.1.1 inside 192.168.20.1 rule ServerRule_num in the replacement configuration file. After the rollback operation, the new NAT server configuration is successfully installed.
# Allow external users to access the internal Web server at 10.110.10.10 through http://202.110.10.10:8080.
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 http
# Allow external users to access the internal FTP server at 10.110.10.11 in the VPN instance vrf10 through ftp://202.110.10.10.
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 21 inside 10.110.10.11 vpn-instance vrf10
# Allow external hosts to ping the host at 10.110.10.12 in the VPN instance vrf10 by using the ping 202.110.10.11 command.
[Sysname-GigabitEthernet1/0/1] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12 vpn-instance vrf10
# Allow external hosts to access the Telnet services of internal servers at 10.110.10.1 to 10.110.10.100 in the VPN instance vrf10 through the public address 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-GigabitEthernet1/0/1] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet vpn-instance vrf10
# Configure an ACL-based NAT server mapping to allow users to use IP addresses in subnet 192.168.0.0/24 to access the internal server at 10.0.0.172.
[Sysname-acl-ipv4-adv-3000] rule 5 permit ip destination 192.168.0.0 0.0.0.255
[Sysname-GigabitEthernet1/0/1] nat server global 3000 inside 10.0.0.172
display nat all
display nat server
nat server-group
nat server rule move
Use nat server rule move to change the priority of an ACL-based NAT server rule.
nat server rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
This command is applicable only to named ACL-based NAT server rules.
# Move the ACL-based NAT server rule abc to the line before the ACL-based NAT server rule def.
[Sysname-GigabitEthernet1/0/1] nat server rule move abc before def
nat server
nat server-group
Use nat server-group to create an internal server group and enter its view, or enter the view of an existing internal server group.
Use undo nat server-group to delete an internal server group.
nat server-group group-id
undo nat server-group group-id
No internal server groups exist.
group-id: Assigns an ID to the internal server group. The value range for this argument is 0 to 65535.
An internal server group can contain multiple members configured by the inside ip command.
# Create internal server group 1.
[Sysname] nat server-group 1
display nat all
display nat server-group
inside ip
nat server
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on GigabitEthernet 1/0/1.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-GigabitEthernet1/0/1] nat static enable
display nat all
display nat static
nat static
nat static net-to-net
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ packet-type-ignore ] [ description text ]
undo nat static inbound global-ip [ vpn-instance global-vpn-instance-name ] local-ip [ vpn-instance local-vpn-instance-name ]
No NAT mappings exist.
global-ip: Specifies a public IP address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP address does not belong to any VPN instance, do not specify this option.
local-ip: Specifies a private IP address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP address does not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to identify the internal hosts that can access the external network.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address.
disable: Disables the one-to-one inbound static mapping. If you do not specify this keyword, the mapping is enabled.
packet-type-ignore: Ignores the protocol packet type when the device creates session entries for TCP, ICMP, or SCTP. If you do not specify this keyword, the NAT device checks the protocol packet type and creates session entries for only protocol packets that pass the check. For example, the NAT device creates session entries for TCP packets only when the packet type is SYN or ACK.
The following compatibility matrixes show the support of hardware platforms for the packet-type-ignore keyword:
Hardware |
MSR610 |
Yes |
Yes |
Yes |
No |
Yes |
MSR1004S-5G |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
description text: Specifies a description for the one-to-one inbound static mapping. The text argument is a case-insensitive string of 1 to 63 characters.
When the source IP address of a packet from the external network to the internal network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the internal network to the external network matches the local-ip, the destination IP address is translated into the global-ip.
In an asymmetric routing scenario, if a session contains different types of protocol packets that are forwarded by different NAT devices, protocol packets of some types might be discarded. As a result, session status cannot be updated through protocol packet exchanges, causing abnormal service traffic forwarding. To avoid such an issue, specify the packet-type-ignore keyword when you use this command.
· If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡ Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
The vpn-instance parameter is required if you deploy inbound static NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
One-to-one mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound net-to-net global-start-address global-end-address [ vpn-instance global-vpn-instance-name ] local local-network { mask-length | mask } [ vpn-instance local-vpn-instance-name ]
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 256 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public IP addresses belong. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public IP addresses do not belong to any VPN instance, do not specify this option.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private network address belongs. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private network address does not belong to any VPN instance, do not specify this option.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses.
disable: Disables the net-to-net inbound static mapping. If you do not specify this keyword, the mapping is enabled.
counting: Enables NAT counting. The number of flows that use the address mapping is counted.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
When the source address of a packet from the external network matches the public address range, the source address is translated into a private address in the private address range. When the destination address of a packet from the internal network matches the private address range, the destination address is translated into a public address in the public address range.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Net-to-net mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
nat static inbound net-to-net rule move
Use nat static inbound net-to-net rule move to change the priority of an inbound net-to-net static NAT rule.
nat static inbound net-to-net rule move nat-rule-name1 { after | before } nat-rule-name2
An inbound net-to-net static NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound net-to-net static NAT rule abc to the line before the inbound net-to-net static NAT rule def.
[Sysname] nat static inbound net-to-net rule move abc before def
nat static inbound object-group
Use nat static inbound object-group to configure an object group-based inbound static NAT mapping.
Use undo nat static inbound object-group to remove an object group-based inbound static NAT mapping.
nat static inbound object-group global-object-group-name [ vpn-instance global-vpn-instance-name ] object-group local-object-group-name [ vpn-instance local-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ disable ] [ counting ]
undo nat static inbound object-group global-object-group-name [ vpn-instance global-vpn-instance-name ]
object-group global-object-group-name: Specifies an object group of public IPv4 addresses. The global-object-group-name argument is a case-insensitive string of 1 to 31 characters.
object-group local-object-group-name: Specifies an object group of private IPv4 addresses. The local-object-group-name argument is a case-insensitive string of 1 to 31 characters.
vpn-instance local-vpn-instance-name: Specifies the MPLS L3VPN instance to which the private IP addresses belong. The local-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the private IP addresses do not belong to any VPN instance, do not specify this option.
acl: Specifies an ACL to identify the packets that can use the mapping.
reversible: Enables reverse address translation. Reverse address translation applies to connections actively initiated by internal hosts to the external hosts. It uses the mapping to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
disable: Disables the object group based inbound static mapping. If you do not specify this keyword, the mapping is enabled.
This command specifies public and private IP addresses through IPv4 address object groups.
When the source address of an income packet matches the public address object group, the source address is translated into a private address in the private address object group. When the destination address of an outgoing packet matches the private address object group, the destination address is translated into a public address in the public address object group.
When you specify object groups for an inbound static mapping, follow these restrictions and guidelines:
· The public or private IPv4 address object group can contain only one IPv4 address object.
· The quantity of IPv4 addresses in the private IPv4 address object group cannot be smaller than that in the public IPv4 address object group.
· The object in the private IPv4 address object group cannot be an address range.
· If the private IPv4 object group contains a host address, the host address cannot be on the same subnet as the interface configured with this mapping.
· One IPv4 address object group can only contain one host object or subnet object. Otherwise, the mapping does not take effect.
· A subnet object cannot have excluded addresses. Otherwise, the mapping does not take effect.
· If you do not specify an ACL, the source addresses of all incoming packets and the destination addresses of all outgoing packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source addresses of incoming packets permitted by the ACL are translated. The destination addresses of packets are not translated for connections actively initiated by internal hosts to the external hosts.
· If you specify both an ACL and the reversible keyword, the source addresses of incoming packets permitted by the ACL are translated. If packets of connections actively initiated by internal hosts to the external hosts are permitted by ACL reverse matching, the destination addresses are translated. ACL reverse matching works as follows:
Static NAT takes precedence over dynamic NAT when they are both configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound, nat static inbound net-to-net, and nat static inbound object-group commands.
# Configure an object group-based inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] object-group ip address global
[Sysname-obj-grp-ip-global] network host address 2.2.2.2
[Sysname-obj-grp-ip-global] quit
[Sysname] object-group ip address local
[Sysname-obj-grp-ip-local] network host address 192.168.1.1
[Sysname-obj-grp-ip-local] quit
[Sysname] nat static inbound object-group global object-group local
display nat all
display nat static
nat static enable
nat static inbound rule move
Use nat static inbound rule move to change the priority of an inbound one-to-one static NAT rule.
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
This command is applicable only to named inbound one-to-one static NAT rules.
A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound one-to-one static NAT rule abc to the line before the inbound one-to-one static NAT rule def.
[Sysname] nat static inbound rule move abc before def
nat static inbound
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ] [ packet-type-ignore ] [ description text ]
undo nat static outbound local-ip [ vpn-instance local-vpn-instance-name ] global-ip [ vpn-instance global-vpn-instance-name ]
acl: Specifies an ACL to define the destination IP addresses that internal hosts can access.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP address.
vrrp virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255. For active/standby HA, specify this keyword on the primary device in the HA group. For dual-active HA, specify different VRRP groups for one-to-one outbound static NAT mappings with different public IP addresses on the primary device. This operation ensures that the master devices load share the translation of reverse user traffic.
Hardware |
MSR610 |
Yes |
Yes |
No |
No |
No |
MSR1004S-5G |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
Yes |
No |
No |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
disable: Disables the one-to-one outbound static mapping. If you do not specify this keyword, the mapping is enabled.
Hardware |
MSR610 |
Yes |
Yes |
Yes |
No |
Yes |
MSR1004S-5G |
Yes |
Yes |
MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
Yes |
MSR2600-6-WiNet |
Yes |
Yes |
MSR2630-WiNet |
Yes |
MSR3600-28-WiNet |
Yes |
MSR3610-X1-WiNet |
Yes |
Yes |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
Yes |
MSR2630-XS |
Yes |
MSR3600-28-XS |
Yes |
MSR3610-XS |
Yes |
MSR3620-XS |
Yes |
MSR3610-I-XS |
Yes |
MSR3610-IE-XS |
Yes |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
Yes |
MSR830-10HI-GL |
Yes |
MSR1004S-5G-GL |
Yes |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
Yes |
description text: Specifies a description for the one-to-one outbound static mapping. The text argument is a case-insensitive string of 1 to 63 characters.
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
· If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
The vpn-instance parameter is required if you deploy outbound static NAT in VPN networks. The specified VPN instance must be the VPN instance to which the NAT interface belongs.
One-to-one mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound net-to-net local-start-address local-end-address [ vpn-instance local-vpn-instance-name ] global global-network { mask-length | mask } [ vpn-instance global-vpn-instance-name ]
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 256 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
global-network: Specifies a public network address.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
vpn-instance global-vpn-instance-name: Specifies the MPLS L3VPN instance to which the public network address belongs. The global-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the public network address does not belong to any VPN instance, do not specify this option.
ipv4-acl-number: Specifies an ACL number in the range of 2000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses.
vrrp virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255. For active/standby HA, specify this keyword on the primary device in the HA group. For dual-active HA, specify different VRRP groups for net-to-net outbound static NAT mappings with different public IP ranges on the primary device. This operation ensures that the master devices load share the translation of reverse user traffic.
Hardware |
MSR610 |
Yes |
Yes |
No |
No |
No |
MSR1004S-5G |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
Yes |
No |
No |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
disable: Disables the net-to-net outbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡ Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
Net-to-net mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
nat static outbound net-to-net rule move
Use nat static outbound net-to-net rule move to change the priority of an outbound net-to-net static NAT rule.
nat static outbound net-to-net rule move nat-rule-name1 { after | before } nat-rule-name2
An outbound net-to-net static NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the outbound net-to-net static NAT rule abc to the line before the outbound net-to-net static NAT rule def.
[Sysname] nat static outbound net-to-net rule move abc before def
nat static outbound object-group
Use nat static outbound object-group to configure an object group-based outbound static NAT mapping.
Use undo nat static outbound object-group to remove an object group-based outbound static NAT mapping.
nat static outbound object-group local-object-group-name [ vpn-instance local-vpn-instance-name ] object-group global-object-group-name [ vpn-instance global-vpn-instance-name ] [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ vrrp virtual-router-id ] [ disable ] [ counting ]
undo nat static outbound object-group local-object-group-name [ vpn-instance local-vpn-instance-name ]
reversible: Allows reverse address translation. Reverse address translation applies to connections actively initiated by external hosts to the internal hosts. It uses the mapping to translate destination addresses for packets of these connections if the packets are permitted by ACL reverse matching.
vrrp virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255. For active/standby HA, specify this keyword on the primary device in the HA group. For dual-active HA, specify different VRRP groups for object group-based NAT server mappings with different public IP addresses on the primary device. This operation ensures that the master devices load share the translation of reverse user traffic.
Hardware |
MSR610 |
Yes |
Yes |
No |
No |
No |
MSR1004S-5G |
No |
Yes |
MSR2600-10-X1 |
No |
MSR 2630 |
No |
No |
No |
No |
No |
No |
Yes |
No |
No |
MSR3640-X1-HI |
Yes |
Hardware |
Yes |
MSR830-4LM-WiNet |
Yes |
Yes |
No |
MSR2600-6-WiNet |
Yes |
No |
MSR2630-WiNet |
No |
MSR3600-28-WiNet |
No |
MSR3610-X1-WiNet |
Yes |
No |
Hardware |
MSR860-6EI-XS |
Yes |
MSR860-6HI-XS |
No |
MSR2630-XS |
Yes |
MSR3600-28-XS |
No |
MSR3610-XS |
Yes |
MSR3620-XS |
No |
MSR3610-I-XS |
No |
MSR3610-IE-XS |
No |
MSR3620-X1-XS |
Yes |
MSR3640-XS |
Yes |
MSR3660-XS |
Yes |
Hardware |
MSR810-LM-GL |
Yes |
MSR810-W-LM-GL |
Yes |
MSR830-6EI-GL |
Yes |
MSR830-10EI-GL |
Yes |
MSR830-6HI-GL |
No |
MSR830-10HI-GL |
No |
MSR1004S-5G-GL |
No |
MSR2600-6-X1-GL |
Yes |
MSR3600-28-SI-GL |
No |
disable: Disables the object group based outbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source address of a packet from the private network matches the private address object group, the source address is translated into a public address in the public address object group. When the destination address of a packet from the public network matches the public address object group, the destination address is translated into a private address in the private address object group.
When you specify object groups for an outbound static mapping, follow these restrictions and guidelines:
· The quantity of IPv4 addresses in the private IPv4 address object group cannot be larger than that in the public IPv4 address object group.
· The object in the public IPv4 address object group cannot be an address range.
· An IPv4 address object group can only contain a host object or a subnet object. Otherwise, the mapping does not take effect.
· A subnet object cannot have excluded IPv4 addresses. Otherwise, the mapping does not take effect.
When you specify an ACL, follow these restrictions and guidelines:
· If you do not specify an ACL, the source addresses of all outgoing packets and the destination addresses of all incoming packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source addresses of outgoing packets permitted by the ACL are translated. The destination addresses of packets are not translated for connections actively initiated by external hosts to the internal hosts.
· If you specify both an ACL and the reversible keyword, the source addresses of outgoing packets permitted by the ACL are translated. If packets of connections actively initiated by external hosts to the internal hosts are permitted by ACL reverse matching, the destination addresses are translated. ACL reverse matching works as follows:
You can configure multiple outbound static NAT mappings by using the nat static outbound, nat static outbound net-to-net, and nat static outbound object-group commands.
# Configure an object group-based outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2.
[Sysname] nat static outbound object-group local object-group global
display nat all
display nat static
nat static outbound rule move
Use nat static outbound rule move to change the priority of an outbound one-to-one static NAT rule.
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound one-to-one static NAT rules..
# Move the outbound one-to-one static NAT rule abc to the line before the outbound one-to-one static NAT rule def.
[Sysname] nat static outbound rule move abc before def
nat static outbound
nat timestamp delete
Use nat timestamp delete to enable the deletion of timestamps in TCP SYN and SYN ACK packets.
Use undo nat timestamp delete to restore the default.
nat timestamp delete [ vpn-instance vpn-instance-name ]
undo nat timestamp delete [ vpn-instance vpn-instance-name ]
The TCP SYN and SYN ACK packets carry the timestamp.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the TCP SYN and SYN ACK packets belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command applies to TCP SYN and SYN ACK packets on the public network.
With this feature configured, the system deletes the timestamps from the TCP SYN and SYN ACK packets after dynamic address translation.
If PAT mode is configured on an interface by using nat inbound or nat outbound, and the tcp_timestamp and tcp_tw_recycle function is configured on the TCP server, TCP connections might not be established. To solve the problem, you can shut down the tcp_tw_recycle function or configure the nat timestamp delete command.
You can enable this feature for multiple VPN instances by repeating the command with different VPN parameters.
# Enable the deletion of the timestamp for TCP SYN and SYN ACK packets on the public network.
[Sysname] nat timestamp delete
# Enable the deletion of the timestamp for TCP SYN and SYN ACK packets on the VPN instance aa.
[Sysname] nat timestamp delete vpn-instance aa
nat outbound
nat inbound
port-block
Use port block to configure port block parameters for a NAT address group.
Use undo port block to restore the default.
port block block-size block-size [ extended-block-number extended-block-number ]
undo port block
No port block parameters are configured for a NAT address group.
NAT address group view
block-size block-size: Specifies the port block size. The value range is 1 to 65535. In a NAT address group, the port block size cannot be larger than the number of ports in the port range.
extended-block-number extended-block-number: Specifies the number of extended port blocks, in the range of 1 to 5. When a private IP address accesses the public network, but the ports in the selected port block are all occupied, the NAT444 gateway extends port blocks one by one for the private IP address.
To configure dynamic port block mappings, port block parameters are required in the NAT address group. When a private IP address initiates a connection to the public network, the NAT444 gateway assigns it a public IP address and a port block, and creates an entry for the mapping. For subsequent connections from the private IP address, the NAT444 gateway translates the private IP address to the mapped public IP address and the ports to ports in the selected port block.
# Set the port block size to 256 and the number of extended port blocks to 1 in NAT address group 2.
[Sysname] nat address-group 2
[Sysname-address-group-2] port-block block-size 256 extended-block-number 1
nat address-group
port-range
Use port-range to specify a port range for public IP addresses.
Use undo port-range to restore the default.
port-range start-port-number end-port-number
undo port-range
The port range for public IP addresses is 1 to 65535.
NAT port block group view
start-port-number end-port-number: Specifies the start port number and end port number for the port range. The end port number cannot be smaller than the start port number. As a best practice, set the start port number to be equal to or larger than 1024 to avoid an application protocol identification error.
The port range must include all ports that public IP addresses use for address translation.
The number of ports in a port range cannot be smaller than the port block size.
# Specify the port range as 1024 to 65535 for NAT address group 1.
[Sysname] nat address-group 1
[Sysname-address-group-1] port-range 1024 65535
# Specify the port range as 30001 to 65535 for NAT port block group 1.
[Sysname] nat port-block-group 1
[Sysname-port-block-group-1] port-range 30001 65535
nat address-group
reset nat count statistics
Use reset nat count statistics to clear NAT counting statistics.
reset nat count statistics { all | dynamic | server | static | static-port-block }
all: Clears all counting statistics for NAT mappings.
dynamic: Clears counting statistics for dynamic NAT mappings.
server: Clears counting statistics for NAT server mappings.
static: Clears counting statistics for static NAT mappings.
static-port-block: Clears counting statistics for NAT444 mappings.
# Clear all counting statistics for static NAT mappings.
<Sysname> reset nat count statistics all
display nat inbound
display nat outbound
display nat outbound port-block-group
display nat port-block
display nat static
display nat server
reset nat session
Use reset nat session to clear NAT sessions.
In standalone mode:
In IRF mode:
reset nat session [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears NAT sessions for all member devices. (In IRF mode.)
# (In standalone mode.) Clear all NAT sessions.
<Sysname> reset nat session
# (In IRF mode.) Clear NAT sessions for the specified slot.
<Sysname> reset nat session slot 1
display nat session
