- H3C Fixed Port Campus Switches Configuration Examples-B70D022-6W100
- 01-Login Management Configuration Examples
- 02-RBAC Configuration Examples
- 03-Software Upgrade Examples
- 04-ISSU Configuration Examples
- 05-Software Patching Examples
- 06-Ethernet Link Aggregation Configuration Examples
- 07-Port Isolation Configuration Examples
- 08-Spanning Tree Configuration Examples
- 09-VLAN Configuration Examples
- 10-VLAN Tagging Configuration Examples
- 11-DHCP Snooping Configuration Examples
- 12-Cross-Subnet Dynamic IP Address Allocation Configuration Examples
- 13-IPv6 over IPv4 Manual Tunneling with OSPFv3 Configuration Examples
- 14-ISATAP Tunnel and 6to4 Tunnel Configuration Examples
- 15-GRE Tunnel Configuration Examples
- 16-GRE with OSPF Configuration Examples
- 17-OSPF Configuration Examples
- 18-IS-IS Configuration Examples
- 19-BGP Configuration Examples
- 20-Policy-Based Routing Configuration Examples
- 21-OSPFv3 Configuration Examples
- 22-IPv6 IS-IS Configuration Examples
- 23-Routing Policy Configuration Examples
- 24-IGMP Snooping Configuration Examples
- 25-IGMP Configuration Examples
- 26-BIDIR-PIM Configuration Examples
- 27-Multicast VPN Configuration Examples
- 28-MLD Snooping Configuration Examples
- 29-IPv6 Multicast VLAN Configuration Examples
- 30-Basic MPLS Configuration Examples
- 31-MPLS L3VPN Configuration Examples
- 32-ACL Configuration Examples
- 33-Control Plane-Based QoS Policy Configuration Examples
- 34-Traffic Policing Configuration Examples
- 35-GTS and Rate Limiting Configuration Examples
- 36-Priority Mapping and Queue Scheduling Configuration Examples
- 37-Traffic Filtering Configuration Examples
- 38-AAA Configuration Examples
- 39-Port Security Configuration Examples
- 40-Portal Configuration Examples
- 41-SSH Configuration Examples
- 42-IP Source Guard Configuration Examples
- 43-Ethernet OAM Configuration Examples
- 44-CFD Configuration Examples
- 45-DLDP Configuration Examples
- 46-VRRP Configuration Examples
- 47-BFD Configuration Examples
- 48-NTP Configuration Examples
- 49-SNMP Configuration Examples
- 50-NQA Configuration Examples
- 51-Mirroring Configuration Examples
- 52-sFlow Configuration Examples
- 53-OpenFlow Configuration Examples
- 54-MAC Address Table Configuration Examples
- 55-Static Multicast MAC Address Entry Configuration Examples
- 56-IP Unnumbered Configuration Examples
- 57-MVRP Configuration Examples
- 58-MCE Configuration Examples
- 59-Congestion Avoidance and Queue Scheduling Configuration Examples
- 60-Attack Protection Configuration Examples
- 61-Smart Link Configuration Examples
- 62-RRPP Configuration Examples
- 63-BGP Route Selection Configuration Examples
- 64-IS-IS Route Summarization Configuration Examples
- 65-IRF Configuration Examples
- 66-MPLS TE Configuration Examples
- 67-VXLAN Configuration Examples
- 68-VCF Fabric Configuration Examples
| 08-Spanning Tree Configuration Examples | 290.00 KB |
Applicable hardware and software versions· 2
Verifying the configuration· 5
Applicable hardware and software versions· 12
Verifying the configuration· 15
Applicable hardware and software versions· 21
Verifying the configuration· 23
Introduction
This document provides spanning tree configuration examples.
This document assumes that you have basic knowledge of spanning tree protocols.
Example: Configuring MSTP
As shown in Figure 1, Device A and Device B operate at the core layer, and Device C and Device D operate at the distribution layer. The ports on the devices have the same path cost, and they all permit VLANs 11 through 30.
Configure MSTP to meet the following requirements:
· Device A, Device B, Device C, and Device D belong to the same MST region.
· MSTIs are used to share the traffic of VLANs 11 through 20 and of VLANs 21 through 30.
Analysis
To assign the devices to the same MST region, make sure the following MST region parameters are the same on the devices:
· Spanning tree mode (the default mode MSTP is used).
· Region name (test in this example).
· Revision level (the default value 0 is used).
· VLAN-to-instance mappings (VLANs 11 through 20 to MIST 1, and VLANs 21 through 30 to MIST 2).
To use redundant links to share the traffic of different VLANs (as shown in Figure 2), perform the following tasks:
· Configure Device A as the root bridge of MSTI 1.
· Configure Device B as the root bridge of MIST 2.
· Assign priorities to Device A, Device B, Device C, and Device D in MSTI 0 in descending order for Device A to be the regional root bridge.
Figure 2 MSTIs mapped to different VLANs
Hardware | Software version |
S6520XE-HI switch series | Supported in Release 11xx |
S5560X-EI switch series | Supported in Release 111x |
S5500V2-EI switch series | Supported in Release 111x |
MS4520V2-30F switch | Supported in Release 111x |
S5560S-EI switch series S5560S-SI switch series | Supported in Release 612x |
S5130S-HI switch series S5130S-EI switch series S5130S-SI switch series S5130S-LI switch series | Supported in Release 612x |
S5120V2-SI switch series S5120V2-LI switch series | Supported in Release 612x |
S3100V3-EI switch series S3100V3-SI switch series | Supported in Release 612x |
S5110V2 switch series | Supported in Release 612x |
S5110V2-SI switch series | Supported in Release 612x |
S5000V3-EI switch series | Supported in Release 612x |
S5000E-X switch series | Supported in Release 612x |
WAS6000 switch series | Supported in Release 612x |
E128C switch E152C switch E500C switch series E500D switch series | Supported in Release 612x |
MS4520V2 switch series (except the MS4520V2-30F switch) | Supported in Release 612x |
MS4320V2 switch series MS4300V2 switch series MS4320 switch series MS4200 switch series | Supported in Release 612x |
WS5850-WiNet switch series | Supported in Release 612x |
WS5820-WiNet switch series WS5810-WiNet switch series | Supported in Release 612x |
Procedures
Configuring Device A
# Create VLANs 11 through 30.
[DeviceA] vlan 11 to 30
# Configure GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3 to trunk VLANs 11 through 30.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceA-if-range] port link-type trunk
[DeviceA-if-range] port trunk permit vlan 11 to 30
[DeviceA-if-range] quit
# Configure the MST region name as test.
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name test
# Map VLANs 11 through 20 to MSTI 1, and map VLANs 21 through 30 to MSTI 2.
[DeviceA-mst-region] instance 1 vlan 11 to 20
[DeviceA-mst-region] instance 2 vlan 21 to 30
# Activate the MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Configure Device A as the root bridge of MSTI 0 and MSTI 1.
[DeviceA] stp instance 0 to 1 root primary
# Enable the spanning tree feature globally.
[DeviceA] stp global enable
Configuring Device B
[DeviceB] vlan 11 to 30
[DeviceB] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/3
[DeviceB-if-range] port link-type trunk
[DeviceB-if-range] port trunk permit vlan 11 to 30
[DeviceB-if-range] quit
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name test
[DeviceB-mst-region] instance 1 vlan 11 to 20
[DeviceB-mst-region] instance 2 vlan 21 to 30
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Configure Device B as the root bridge of MSTI 2 and a secondary root bridge of MSTI 0.
[DeviceB] stp instance 2 root primary
[DeviceB] stp instance 0 root secondary
[DeviceB] stp global enable
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 11 to 30
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk VLANs 11 through 30.
[DeviceC] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceC-if-range] port link-type trunk
[DeviceC-if-range] port trunk permit vlan 11 to 30
[DeviceC-if-range] quit
[DeviceC-mst-region] region-name test
# Map VLANs 11 through 20 through MSTI 1, and map VLANs 21 through 30 to MSTI 2.
[DeviceC-mst-region] instance 1 vlan 11 to 20
[DeviceC-mst-region] instance 2 vlan 21 to 30
[DeviceC-mst-region] quit
[DeviceC] stp global enable
Configuring Device D
<DeviceD> system-view
[DeviceD] vlan 11 to 30
[DeviceD] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceD-if-range] port link-type trunk
[DeviceD-if-range] port trunk permit vlan 11 to 30
[DeviceD-if-range] quit
[DeviceD-mst-region] region-name test
[DeviceD-mst-region] instance 1 vlan 11 to 20
[DeviceD-mst-region] instance 2 vlan 21 to 30
[DeviceD-mst-region] quit
# Set the device priority to 36864 in MSTI 0, which is lower than the default priority 32768 of Device C.
[DeviceD] stp instance 0 priority 36864
[DeviceD] stp global enable
1. Verify that Layer 2 loops have been eliminated in each MSTI:
Use the display stp brief command to display brief spanning tree information on each device.
# Display brief spanning tree information on Device A.
[DeviceA] display stp brief
MST ID Port Role STP State Protection
0 GigabitEthernet1/0/1 DESI FORWARDING NONE
0 GigabitEthernet1/0/2 DESI FORWARDING NONE
0 GigabitEthernet1/0/3 DESI FORWARDING NONE
1 GigabitEthernet1/0/1 DESI FORWARDING NONE
1 GigabitEthernet1/0/2 DESI FORWARDING NONE
1 GigabitEthernet1/0/3 DESI FORWARDING NONE
2 GigabitEthernet1/0/1 DESI FORWARDING NONE
2 GigabitEthernet1/0/2 DESI FORWARDING NONE
2 GigabitEthernet1/0/3 ROOT FORWARDING NONE
# Display brief spanning tree information on Device B.
[DeviceB] display stp brief
0 GigabitEthernet1/0/3 ROOT FORWARDING NONE
1 GigabitEthernet1/0/3 ROOT FORWARDING NONE
2 GigabitEthernet1/0/3 DESI FORWARDING NONE
# Display brief spanning tree information on Device C.
[DeviceC] display stp brief
0 GigabitEthernet1/0/1 ROOT FORWARDING NONE
0 GigabitEthernet1/0/2 ALTE DISCARDING NONE
1 GigabitEthernet1/0/1 ROOT FORWARDING NONE
1 GigabitEthernet1/0/2 ALTE DISCARDING NONE
2 GigabitEthernet1/0/1 ALTE DISCARDING NONE
2 GigabitEthernet1/0/2 ROOT FORWARDING NONE
# Display brief spanning tree information on Device D.
[DeviceD] display stp brief
0 GigabitEthernet1/0/1 ALTE DISCARDING NONE
0 GigabitEthernet1/0/2 ROOT FORWARDING NONE
1 GigabitEthernet1/0/1 ALTE DISCARDING NONE
1 GigabitEthernet1/0/2 ROOT FORWARDING NONE
2 GigabitEthernet1/0/1 ROOT FORWARDING NONE
2 GigabitEthernet1/0/2 ALTE DISCARDING NONE
Based on the output, the topology for each MSTI is shown in Figure 3.
2. Verify that the network can accommodate topology changes:
# Shut down GigabitEthernet 1/0/1 on Device C. (Details not shown.)
# Display brief spanning tree information on all devices.
Based on the output, the topology for each MSTI is shown in Figure 4.
Configuration files
| IMPORTANT: The port link-mode bridge command is available only on the following switches: · S6520XE-HI switch series. · S5560X-EI switch series. · S5500V2-EI switch series. · MS4520V2-30F switch. |
· Device A:
vlan 1
vlan 11 to 30
region-name test
stp global enable
port trunk permit vlan 1 11 to 30
· Device B:
vlan 1
vlan 11 to 30
region-name test
stp global enable
· Device C:
vlan 1
vlan 11 to 30
region-name test
stp global enable
· Device D:
vlan 1
vlan 11 to 30
region-name test
stp global enable
Example: Configuring PVST
As shown in Figure 5, Device A and Device B operate at the distribution layer, and Device C and Device D operate at the access layer. The ports on the devices have the same path cost.
Configure PVST to meet the following requirements:
· Redundant links are used for load sharing.
· Packets of each VLAN are forwarded along its spanning tree.
Analysis
For traffic of different VLANs to be shared along the spanning trees in Figure 6, perform the following tasks:
· Configure Device A as the root bridge of the spanning trees for VLAN 10 and VLAN 30.
· Configure Device B as the root bridge of the spanning tree for VLAN 20.
Figure 6 VLAN spanning tree topologies
Procedures
# Create VLAN 10, VLAN 20, and VLAN 30.
[DeviceA] vlan 10
[DeviceA-vlan10] vlan 20
[DeviceA-vlan20] vlan 30
[DeviceA-vlan30] quit
# Configure GigabitEthernet 1/0/1 to trunk VLAN 10 and VLAN 20.
[DeviceA-GigabitEthernet1/0/1] port trunk permit vlan 10 20
# Configure GigabitEthernet 1/0/2 to trunk VLAN 20 and VLAN 30.
[DeviceA-GigabitEthernet1/0/2] port trunk permit vlan 20 30
# Configure GigabitEthernet 1/0/3 to trunk VLAN 10, VLAN 20, and VLAN 30.
[DeviceA-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-GigabitEthernet1/0/3] port trunk permit vlan 10 20 30
# Set the spanning tree mode to PVST.
[DeviceA] stp mode pvst
# Configure Device A as the root bridge of VLAN 10 and VLAN 30.
[DeviceA] stp vlan 10 30 root primary
[DeviceB] vlan 10
[DeviceB-vlan10] vlan 20
[DeviceB-vlan20] vlan 30
[DeviceB-vlan30] quit
# Configure GigabitEthernet 1/0/1 to trunk VLAN 20 and VLAN 30.
[DeviceB-GigabitEthernet1/0/1] port trunk permit vlan 20 30
# Configure GigabitEthernet 1/0/2 to trunk VLAN 10 and VLAN 20.
[DeviceB-GigabitEthernet1/0/2] port trunk permit vlan 10 20
[DeviceB] interface gigabitethernet 1/0/3
[DeviceB-GigabitEthernet1/0/3] port link-type trunk
[DeviceB-GigabitEthernet1/0/3] port trunk permit vlan 10 20 30
[DeviceB] stp mode pvst
# Configure Device B as the root bridge of VLAN 20.
[DeviceB] stp vlan 20 root primary
# Create VLAN 10 and VLAN 20.
[DeviceC] vlan 10
[DeviceC-vlan10] vlan 20
[DeviceC-vlan20] quit
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk VLAN 10 and VLAN 20.
[DeviceC-if-range] port trunk permit vlan 10 20
[DeviceC] stp mode pvst
# Create VLAN 20 and VLAN 30.
[DeviceD] vlan 20
[DeviceD-vlan20] vlan 30
[DeviceD-vlan30] quit
# Configure GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to trunk VLAN 20 and VLAN 30.
[DeviceD-if-range] port trunk permit vlan 20 30
[DeviceD] stp mode pvst
VLAN ID Port Role STP State Protection
1 GigabitEthernet1/0/3 DESI DISCARDING NONE
10 GigabitEthernet1/0/1 DESI FORWARDING NONE
10 GigabitEthernet1/0/3 DESI FORWARDING NONE
20 GigabitEthernet1/0/1 DESI FORWARDING NONE
20 GigabitEthernet1/0/2 DESI FORWARDING NONE
20 GigabitEthernet1/0/3 ROOT FORWARDING NONE
30 GigabitEthernet1/0/2 DESI FORWARDING NONE
30 GigabitEthernet1/0/3 DESI FORWARDING NONE
10 GigabitEthernet1/0/2 DESI FORWARDING NONE
10 GigabitEthernet1/0/3 ROOT FORWARDING NONE
20 GigabitEthernet1/0/3 DESI FORWARDING NONE
30 GigabitEthernet1/0/1 DESI FORWARDING NONE
30 GigabitEthernet1/0/3 ROOT FORWARDING NONE
10 GigabitEthernet1/0/1 ROOT FORWARDING NONE
10 GigabitEthernet1/0/2 ALTE DISCARDING NONE
20 GigabitEthernet1/0/1 ALTE DISCARDING NONE
20 GigabitEthernet1/0/2 ROOT FORWARDING NONE
20 GigabitEthernet1/0/1 ROOT FORWARDING NONE
20 GigabitEthernet1/0/2 ALTE DISCARDING NONE
30 GigabitEthernet1/0/1 ALTE DISCARDING NONE
30 GigabitEthernet1/0/2 ROOT FORWARDING NONE
Based on the output, the topology for each VLAN is shown in Figure 7.
Figure 7 VLAN spanning tree topologies
Configuration files
· Device A:
vlan 1
vlan 10
vlan 20
vlan 30
stp mode pvst
stp global enable
port trunk permit vlan 1 10 20
port trunk permit vlan 1 20 30
port trunk permit vlan 1 10 20 30
· Device B:
vlan 1
vlan 10
vlan 20
vlan 30
stp mode pvst
stp global enable
· Device C:
vlan 1
vlan 10
vlan 20
stp mode pvst
stp global enable
· Device D:
vlan 1
vlan 20
vlan 30
stp mode pvst
stp global enable
Example: Configuring RSTP
As shown in Figure 8, Device A operates at the core layer, Device B and Device C operate at the distribution layer, and Device D and Device E operate at the access layer. The ports on the devices have the same path cost.
Configure RSTP as follows:
· Configure Device A as the root bridge, and enable root guard to retain its root bridge role when configuration errors or malicious attacks occur.
· Configure Device C as a backup of Device B. When Device B fails, traffic is forwarded through Device C.
· Configure GigabitEthernet 1/0/4 on Device D and GigabitEthernet 1/0/4 on Device E as edge ports, and enable BPDU guard on the ports.
Analysis
For Device C to be a backup of Device B, make sure Device C's priority is lower than Device B's priority. In this example, configure the priorities of Device B and Device C as 4096 and 8192.
For Device A to be the root bridge, make sure Device A has the lowest bridge ID (containing the device's priority and MAC address) in the network. In this example, because Device A already has the lowest MAC address, configure the priority as 4096 for Device A to hold the lowest bridge ID.
| NOTE: To configure a device as the root bridge, you also can use the stp root primary or stp priority 0 command to set the device's priority to 0. |
To retain Device A's root bridge role, enable root guard on the designated ports of Device A, Device B, and Device C. To identify the designated ports, use either of the following methods:
· Use the display stp brief command to display the brief spanning tree information. The role is DESI for a designated port.
· Identify the designated ports in the RSTP topology that is calculated based on the device configuration, as shown in Figure 9.
Procedures
# Set the spanning tree mode to RSTP.
[DeviceA] stp mode rstp
# Configure the priority as 4096 for Device A.
[DeviceA] stp priority 4096
# Enable root guard on designated ports GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[DeviceA] interface range gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceA-if-range] stp root-protection
[DeviceB] stp mode rstp
# Configure the priority as 4096 for Device B.
[DeviceB] stp priority 4096
# Enable root guard on designated ports GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3.
[DeviceB-if-range] stp root-protection
[DeviceC] stp mode rstp
# Configure the priority as 8192 for Device C.
[DeviceC] stp priority 8192
[DeviceC-if-range] stp root-protection
[DeviceD] stp mode rstp
# Configure GigabitEthernet 1/0/4 as an edge port, and enable BPDU guard.
[DeviceD] interface gigabitethernet 1/0/4
[DeviceD-GigabitEthernet1/0/4] stp edged-port
[DeviceD-GigabitEthernet1/0/4] quit
[DeviceD] stp bpdu-protection
Configuring Device E
# Configure Device E in the same way you configure Device D. (Details not shown.)
1. Verify that Layer 2 loops have been eliminated in the network:
# Display the brief spanning tree information on Device A.
# Display the brief spanning tree information on Device B.
0 GigabitEthernet1/0/4 ROOT FORWARDING NONE
# Display the brief spanning tree information on Device C.
0 GigabitEthernet1/0/3 ALTE DISCARDING NONE
# Display the brief spanning tree information on Device D.
0 GigabitEthernet1/0/4 DESI FORWARDING BPDU
# Display the brief spanning tree information on Device E.
[DeviceE] display stp brief
Based on the output, the topology for the network is shown in Figure 10.
2. Verify that root guard can retain Device A's root bridge role:
# Verify that Device A is the root bridge in the network.
-------[CIST Global Info] [Mode RSTP] -------
Bridge ID : 32768.00e0-fc00-c518
Bridge times : Hello 2s MaxAge 20s FwdDelay 15s MaxHops 20
Root ID/ERPC : 4096.0000-fc00-47cd, 40
RegRoot ID/IRPC : 32768.00e0-fc00-c518, 0
# Set the priority to 0 for Device D. Because the priority is higher than the priority of Device A, Device D considers itself as the root bridge and sends BPDUs that contain its bridge ID 0.00e0-fc00-c518.
[DeviceD] stp priority 0
Bridge ID : 0.00e0-fc00-c518
Root ID/ERPC : 0.00e0-fc00-c518, 0
RegRoot ID/IRPC : 0.00e0-fc00-c518, 0
# Set the priority to 0 for Device E. Because the priority is higher than the priority of Device A. Device E considers itself as the root bridge and sends BPDUs that contain its bridge ID 0.7425-8a0f-8000.
[DeviceE] stp priority 0
Bridge ID : 0.7425-8a0f-8000
Root ID/ERPC : 0.7425-8a0f-8000, 0
RegRoot ID/IRPC : 0.7425-8a0f-8000, 0
# Verify that Device A is still the root bridge in the network.
Bridge ID : 4096.7425-8a02-4c00
Root ID/ERPC : 4096.0000-fc00-47cd, 20
RegRoot ID/IRPC : 4096.7425-8a02-4c00, 0
Bridge ID : 8192.0cda-41b1-d1c0
RegRoot ID/IRPC : 8192.0cda-41b1-d1c0, 0
# Verify that Device A cannot retain its root bridge role when root guard is disabled on a designated port on Device B (for example, GigabitEthernet 1/0/2).
[DeviceB-GigabitEthernet1/0/2] undo stp root-protection
[DeviceB-GigabitEthernet1/0/2] display stp
Root ID/ERPC : 0.7425-8a0f-8000, 20
[DeviceB-GigabitEthernet1/0/2] display stp brief
0 GigabitEthernet1/0/1 DESI DISCARDING ROOT
0 GigabitEthernet1/0/4 DESI FORWARDING NONE
3. Verify that traffic is forwarded through Device C when Device B fails:
# Reboot Device B. (Details not shown.)
# Display the brief spanning tree information on Device A, Device C, Device D, and Device E before Device B completes the reboot.
[DeviceA] dis stp brief
0 GigabitEthernet1/0/2 DESI FORWARDING ROOT
[DeviceC] dis stp brief
0 GigabitEthernet1/0/1 DESI FORWARDING ROOT
[DeviceD] dis stp brief
[DeviceE] dis stp brief
Based on the network topology, the topology for the network is shown in Figure 11.
4. Verify that BPDU guard can protect edge ports from attacks:
# Verify that the edge port GigabitEthernet 1/0/4 on Device D goes down when the port receives configuration BPDUs.
[DeviceD] display stp down-port
Down Port Reason
GigabitEthernet1/0/4 BPDU-Protected
# Verify that GigabitEthernet 1/0/4 goes up when it does not receive any configuration BPDUs from the peer end.
[DeviceD] display interface brief | include UP
InLoop0 UP UP(s) --
M-E0/0/0 UP UP 192.168.2.125
NULL0 UP UP(s) --
GE1/0/1 UP 1G(a) F(a) T 1
GE1/0/2 UP 1G(a) F(a) T 1
GE1/0/4 UP 1G(a) F(a) A 1
Configuration files
· Device A:
vlan 1
stp instance 0 priority 4096
stp mode rstp
stp global enable
stp root-protection
stp root-protection
· Device B:
vlan 1
stp mode rstp
stp global enable
stp root-protection
stp root-protection
stp root-protection
· Device C:
vlan 1
stp instance 0 priority 8192
stp mode rstp
stp global enable
stp root-protection
stp root-protection
· Device D:
vlan 1
stp mode rstp
stp bpdu-protection
stp global enable
interface GigabitEthernet1/0/4
stp edged-port
· Device E:
vlan 1
stp mode rstp
stp bpdu-protection
stp global enable
stp edged-port
