06-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesS9500E SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17006-Layer 3 - IP Services Configuration Guide
04-DNS Configuration
04-DNS Configuration 227.29 KB
DNS overview
Domain Name System (DNS) is a distributed database used by TCP/IP applications to translate domain names into corresponding IP addresses. With DNS, you can use easy-to-remember domain names in some applications and let the DNS server translate them into correct IP addresses.
There are two types of DNS services, static and dynamic. After a user specifies a name, the switch checks the local static name resolution table for an IP address. If no IP address is available, it contacts the DNS server for dynamic name resolution, which takes more time than static name resolution. Therefore, some frequently queried name-to-IP address mappings are stored in the local static name resolution table to improve efficiency.
Static domain name resolution
Static domain name resolution means setting up mappings between domain names and IP addresses. IP addresses of the corresponding domain names can be found in the static domain resolution table when you use applications such as Telnet.
Dynamic domain name resolution
Resolving procedure
Dynamic domain name resolution is implemented by querying the DNS server. The resolution procedure is as follows:
1.      A user program sends a name query to the resolver of the DNS client.
2.      The DNS resolver looks up the local domain name cache for a match. If the resolver finds a match, it sends the corresponding IP address back. If not, it sends a query to the DNS server.
3.      The DNS server looks up the corresponding IP address of the domain name in its DNS database. If no match is found, the server sends a query to a higher level DNS server. This process continues until a result, whether successful or not, is returned.
4.      After receiving a response from the DNS server, the DNS client returns the resolution result to the application.
Figure 1 Dynamic domain name resolution
Figure 1 shows the relationship between the user program, DNS client, and DNS server.
The DNS client is made up of the resolver and cache. The user program and DNS client can run on the same switch or different switches, while the DNS server and the DNS client usually run on different switches.
Dynamic domain name resolution allows the DNS client to store latest mappings between domain names and IP addresses in the dynamic domain name cache. There is no need to send a request to the DNS server for a repeated query next time. The aged mappings are removed from the cache after some time, and latest entries are required from the DNS server. The DNS server decides how long a mapping is valid, and the DNS client gets the aging information from DNS messages.
DNS suffixes
The DNS client holds a list of suffixes, which the user sets. It is used when the name to be resolved is incomplete. The resolver can supply the missing part.
For example, a user can configure com as the suffix for aabbcc.com. The user only needs to type aabbcc to obtain the IP address of aabbcc.com, because the resolver adds the suffix and delimiter before passing the name to the DNS server.
·           If there is no dot (.) in the domain name (for example, aabbcc), the resolver considers this a host name and adds a DNS suffix before query. If no match is found after all the configured suffixes are used respectively, the original domain name (for example, aabbcc) is used for query.
·           If there is a dot in the domain name (for example, www.aabbcc), the resolver directly uses this domain name for query. If the query fails, the resolver adds a DNS suffix for another query.
·           If the dot is at the end of the domain name (for example, aabbcc.com.), the resolver considers it a fully qualified domain name (FQDN) and returns the query result, successful or failed. The dot at the end of the domain name is called a terminating symbol.
The switch supports static and dynamic DNS services.
If an alias is configured for a domain name on the DNS server, the switch can resolve the alias into the IP address of the host.
Configuring the IPv4 DNS client
Configuring static domain name resolution
Configuring static domain name resolution refers to specifying the mappings between host names and IPv4 addresses. Static domain name resolution allows applications such as Telnet to contact hosts by using host names instead of IPv4 addresses.
To configure static domain name resolution:
Step
Remarks
1.     Enter system view.
N/A
2.     Configure a mapping between a host name and an IPv4 address.
ip host hostname ip-address
Not configured by default
·       The IPv4 address you last assign to the host name will overwrite the previous one if there is any.
·       You may create up to 50 static mappings between domain names and IP addresses.
Configuring dynamic domain name resolution
To send DNS queries to a correct server for resolution, dynamic domain name resolution must be enabled and a DNS server must be configured.
In addition, you can configure a DNS suffix that the system will automatically add to the provided domain name for resolution.
Configuration guidelines
When you configure dynamic domain name resolution, follow these guidelines:
·           You can configure up to six DNS servers, including those with IPv6 addresses, in system view and on all the interfaces of the switch.
·           A DNS server configured in system view has a higher priority than one configured in interface view. A DNS server configured earlier has a higher priority than one configured later in the same view. A DNS server manually configured has a higher priority than one dynamically obtained through DHCP. A name query request is first sent to the DNS server that has the highest priority. If no reply is received, it sent to the DNS server that has the second highest priority, and thus in turn.
·           You can specify up to ten DNS suffixes.
Configuration procedure
To configure dynamic domain name resolution:
Step
Remarks
N/A
2.     Enable dynamic domain name resolution.
dns resolve
Disabled by default.
3.     Configure the IPv4 address of DNS server.
·       Approach 1 (In system view)
dns server ip-address
·       Approach 2 (In VLAN interface view)
a.   interface interface-type interface-number
b.   dns server ip-address
c.    quit
Use either approach.
No DNS server is specified by default.
4.     Configure a domain name suffix.
dns domain domain-name
Optional.
Not configured by default. Only the provided domain name is resolved.
Displaying and maintaining IPv4 DNS
Remarks
Display the static IPv4 domain name resolution table.
display ip host [ | { begin | exclude | include } regular-expression ]
Available in any view
Display IPv4 DNS server information.
display dns server [ dynamic ] [ | { begin | exclude | include } regular-expression ]
Display DNS suffixes.
display dns domain [ dynamic ] [ | { begin | exclude | include } regular-expression ]
Display the information of the dynamic IPv4 domain name cache.
display dns host ip [ | { begin | exclude | include } regular-expression ]
Clear the information of the dynamic IPv4 domain name cache.
reset dns host ip
Available in user view
IPv4 DNS configuration examples
By default, the Ethernet interface, VLAN interfaces, and aggregate interfaces are down. Before configuring them, bring them up with the undo shutdown command.
Static domain name resolution configuration example
Network requirements
As shown in Figure 1, Device uses the static domain name resolution to access Host with IP address 10.1.1.2 through domain name host.com.
Figure 2 Network diagram
# Configure a mapping between host name host.com and IP address 10.1.1.2.
[Sysname] ip host host.com 10.1.1.2
# Execute the ping host.com command to verify that the device can use the static domain name resolution to get the IP address 10.1.1.2 corresponding to host.com.
[Sysname] ping host.com
  PING host.com (10.1.1.2):
  56  data bytes, press CTRL_C to break
    Reply from 10.1.1.2: bytes=56 Sequence=1 ttl=128 time=1 ms
    Reply from 10.1.1.2: bytes=56 Sequence=2 ttl=128 time=4 ms
    Reply from 10.1.1.2: bytes=56 Sequence=3 ttl=128 time=3 ms
    Reply from 10.1.1.2: bytes=56 Sequence=4 ttl=128 time=2 ms
    Reply from 10.1.1.2: bytes=56 Sequence=5 ttl=128 time=3 ms
  --- host.com ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 1/2/4 ms
Dynamic domain name resolution configuration example
As shown in Figure 3, the IP address of the DNS server is 2.1.1.2/16 and the name suffix is com. The mapping between domain name Host and IP address 3.1.1.1/16 is stored in the com domain.
Device serves as a DNS client, and uses the dynamic domain name resolution and the suffix to access the host with the domain name host.com and the IP address 3.1.1.1/16.
Figure 3 Network diagram
·       Before performing the following configuration, make sure that there is a route between the device and the host, and the IP addresses of the interfaces are configured as shown Figure 3.
·       This configuration may vary with different DNS servers. The following configuration is performed on a Windows server 2000.
Configuring the DNS server
1.      Enter DNS server configuration page:
Select Start > Programs > Administrative Tools > DNS.
2.      Create zone com:
In Figure 4, right click Forward Lookup Zones, select New zone, and then follow the instructions to create a new zone named com.
Figure 4 Creating a zone
3.      Create a mapping between the host name and IP address:
Figure 5 Adding a host
In Figure 5, right click zone com, and then select New Host to bring up a dialog box as shown in Figure 6. Enter host name host and IP address 3.1.1.1.
Figure 6 Adding a mapping between domain name and IP address
Configuring the DNS client
1.      Enable dynamic domain name resolution.
[Sysname] dns resolve
2.      Specify the DNS server 2.1.1.2.
[Sysname] dns server 2.1.1.2
3.      Configure com as the name suffix.
[Sysname] dns domain com
# Execute the ping host command on the device to verify that the communication between the device and the host is normal and that the corresponding destination IP address is 3.1.1.1.
[Sysname] ping host
 Trying DNS resolve, press CTRL_C to break
 Trying DNS server (2.1.1.2)
  PING host.com (3.1.1.1):
    Reply from 3.1.1.1: bytes=56 Sequence=1 ttl=126 time=3 ms
    Reply from 3.1.1.1: bytes=56 Sequence=2 ttl=126 time=1 ms
    Reply from 3.1.1.1: bytes=56 Sequence=3 ttl=126 time=1 ms
    Reply from 3.1.1.1: bytes=56 Sequence=4 ttl=126 time=1 ms
    Reply from 3.1.1.1: bytes=56 Sequence=5 ttl=126 time=1 ms
    0.00% packet loss
    round-trip min/avg/max = 1/1/3 ms
Troubleshooting IPv4 DNS configuration
Symptom
After enabling the dynamic domain name resolution, the user cannot get the correct IP address.
Solution
·           Use the display dns host ip command to verify that the specified domain name is in the cache.
·           If the specified domain name does not exist, check that dynamic domain name resolution is enabled and the DNS client can communicate with the DNS server.
·           If the specified domain name is in the cache, but the IP address is incorrect, check that the DNS client has the correct IP address of the DNS server.
·           Verify the mapping between the domain name and IP address is correct on the DNS server.
