H3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
HomeSupportSwitchesH3C S3100 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
10-Link Aggregation Operation
10-Link Aggregation Operation 100.27 KB
Chapter 1  Link Aggregation Configuration
1.1  Overview
1.1.1  Introduction to Link Aggregation
Link aggregation can aggregate multiple Ethernet ports together to form a logical aggregation group. To upper layer entities, all the physical links in an aggregation group are a single logical link.
Link aggregation is designed to increase bandwidth by implementing outgoing/incoming load sharing among the member ports in an aggregation group. Link aggregation group also allows for port redundancy, which improves connection reliability.
1.1.2  Introduction to LACP
Link aggregation control protocol (LACP) is designed to implement dynamic link aggregation and deaggregation. This protocol is based on IEEE802.3ad and uses link aggregation control protocol data units (LACPDUs) to interact with its peer.
With LACP enabled on a port, LACP notifies the following information of the port to its peer by sending LACPDUs: priority and MAC address of this system, priority, number and operation key of the port. Upon receiving the information, the peer compares the information with the information of other ports on the peer device to determine the ports that can be aggregated. In this way, the two parties can reach an agreement in adding/removing the port to/from a dynamic aggregation group.
Operation key is generated by the system. It is determined by port settings such as port speed, duplex mode, and basic configurations (refer to Requirements on Ports for Link Aggregation for description on basic configurations).
l           Selected ports in a manual aggregation group or a static aggregation group have the same operation key.
l           Member ports in a dynamic aggregation group have the same operation key.
1.1.3  Requirements on Ports for Link Aggregation
To achieve outgoing/incoming load sharing in an aggregation group, the member ports to perform load balancing must have the same speed, duplex mode, and basic configurations, which include:
l           STP configuration, including STP status (enabled or disabled), link attribute (point-to-point or not), STP priority, STP path cost, STP packet format, loop guard status, root guard status, edge port or not.
l           QoS configuration, including traffic limit, priority remarking, 802.1p priority, traffic redirection, traffic statistics, and so on.
l           VLAN configuration, including permitted VLANs, and default VLAN ID.
l           Link type configuration, which can be trunk, hybrid, or access.
l           GVRP configuration, including GVRP state (enabled/disabled), GVRP registration type, and GARP timer settings.
l           VLAN-VPN configuration, including VLAN-VPN state (enabled/disabled).
1.2  Link Aggregation Classification
Depending on different aggregation modes, the following three types of link aggregation exist:
l           Manual aggregation
l           Static LACP aggregation
l           Dynamic LACP aggregation
1.2.1  Manual Aggregation Group
I. Introduction to manual aggregation group
A manual aggregation group is manually created. All its member ports are manually added and can be manually removed (it inhibits the system from automatically adding/removing ports to/from it). Each manual aggregation group must contain at least one port. When a manual aggregation group contains only one port, you cannot remove the port unless you remove the whole aggregation group.
LACP is disabled on the member ports of manual aggregation groups, and you cannot enable LACP on ports in a manual aggregation group.
II. Port status in manual aggregation group
A port in a manual aggregation group can be in one of the two states: selected or unselected. In a manual aggregation group, only the selected ports can forward user service packets.
In a manual aggregation group, the system sets the ports to selected or unselected state according to the following rules.
l           Among the ports in an aggregation group that are in up state, the system determines the mater port with one of the following settings being the highest (in descending order) as the master port: full duplex/high speed, full duplex/low speed, half duplex/high speed, half duplex/low speed. The ports with their rate, duplex mode and link type being the same as that of the master port are selected ports, and the rest are unselected ports.
l           There is a limit on the number of selected ports in an aggregation group. Therefore, if the number of the selected ports in an aggregation group exceeds the maximum number supported by the device, those with lower port numbers operate as the selected ports, and others as unselected ports.
Among the selected ports in an aggregation group, the one with smallest port number operates as the master port. Other selected ports are the member ports.
III. Requirements on ports for manual aggregation
Generally, there is no limit on the rate and duplex mode of the ports (also including initially down port) you want to add to a manual aggregation group.
1.2.2  Static LACP Aggregation Group
I. Introduction to static LACP aggregation
A static LACP aggregation group is also manually created. All its member ports are manually added and can be manually removed (it inhibits the system from automatically adding/removing ports to/from it). Each static aggregation group must contain at least one port. When a static aggregation group contains only one port, you cannot remove the port unless you remove the whole aggregation group.
LACP is enabled on the member ports of static aggregation groups. When you remove a static aggregation group, all the member ports in up state form one or multiple dynamic aggregations with LACP enabled. LACP cannot be disabled on static aggregation ports.
II. Port status of static aggregation group
A port in a static aggregation group can be in one of the two states: selected or unselected.
l           Both the selected and the unselected ports in the up state can transceive LACP protocol packets.
l           Only the selected ports can transceive service packets; the unselected ports cannot.
In a static aggregation group, the system sets the ports to selected or unselected state according to the following rules.
l           Among the ports in an aggregation group that are in up state, the system determines the master port with one of the following settings being the highest (in descending order) as the master port: full duplex/high speed, full duplex/low speed, half duplex/high speed, half duplex/low speed. The ports with their rate, duplex mode and link type being the same as that of the master port are selected port, and the rest are unselected ports.
l           The ports connected to a peer device different from the one the master port is connected to or those connected to the same peer device as the master port but to a peer port that is not in the same aggregation group as the peer port of the master port are unselected ports.
l           The system sets the ports with basic port configuration different from that of the master port to unselected state.
1.2.3  Dynamic LACP Aggregation Group
I. Introduction to dynamic LACP aggregation group
A dynamic LACP aggregation group is automatically created and removed by the system. Users cannot add/remove ports to/from it. Ports can be aggregated into a dynamic aggregation group only when they are connected to the same peer device and have the same speed, duplex mode, and basic configurations, and so are/do their peer ports.
Besides multiple-port aggregation groups, the system is also able to create single-port aggregation groups, each of which contains only one port. LACP is enabled on the member ports of dynamic aggregation groups.
II. Port status of dynamic aggregation group
A port in a dynamic aggregation group can be in one of the two states: selected and unselected.
l           Both the selected and the unselected ports can receive/transmit LACP protocol packets;
l           The selected ports can receive/transmit user service packets, but the unselected ports cannot.
l           In a dynamic aggregation group, the selected port with the smallest port number serves as the master port of the group, and other selected ports serve as member ports of the group.
There is a limit on the number of selected ports in an aggregation group. Therefore, if the number of the member ports that can be set as selected ports in an aggregation group exceeds the maximum number supported by the device, the system will negotiate with its peer end, to determine the states of the member ports according to the port IDs of the preferred device (that is, the device with smaller system ID). The following is the negotiation procedure:
1)         Compare device IDs (system priority + system MAC address) between the two parties. First compare the two system priorities, then the two system MAC addresses if the system priorities are equal. The device with smaller device ID will be considered as the preferred one.
2)         Compare port IDs (port priority + port number) on the preferred device. The comparison between two port IDs is as follows: First compare the two port priorities, then the two port numbers if the two port priorities are equal; the port with the smallest port ID is the selected port and the left ports are unselected ports.
&  Note:
For an aggregation group:
l      When the rate or duplex mode of a port in the aggregation group changes, packet loss may occur on this port;
l      When the rate of a port decreases, if the port belongs to a manual or static LACP aggregation group, the port will be switched to the unselected state; if the port belongs to a dynamic LACP aggregation group, deaggregation will occur on the port.
1.3  Aggregation Group Categories
Depending on whether or not load sharing is implemented, aggregation groups can be load-sharing or non-load-sharing aggregation groups. When load sharing is implemented,
The S3100 series Ethernet switches perform load-sharing for IP packets based on the source IP address and destination IP address, and for non-IP packets based on the source MAC address.
In general, the system only provides limited load-sharing aggregation resources, so the system needs to reasonably allocate the resources among different aggregation groups.
The system always allocates hardware aggregation resources to the aggregation groups with higher priorities. When load-sharing aggregation resources are used up by existing aggregation groups, newly-created aggregation groups will be non-load-sharing ones.
Load-sharing aggregation resources are allocated to aggregation groups in the following order:
l           An aggregation group containing special ports which require hardware aggregation resources has higher priority than any aggregation group containing no special port.
l           A manual or static aggregation group has higher priority than a dynamic aggregation group (unless the latter contains special ports while the former does not).
l           For aggregation groups, the one that might gain higher speed if resources were allocated to it has higher priority than others. If the groups can gain the same speed, the one with smallest master port number has higher priority than other groups.
When an aggregation group of higher priority appears, the aggregation groups of lower priorities release their hardware resources. For single-port aggregation groups, they can transceive packets normally without occupying aggregation resources
  Caution:
A load-sharing aggregation group contains at least two selected ports, but a non-load-sharing aggregation group can only have one selected port at most, while others are unselected ports.
1.4  Link Aggregation Configuration
  Caution:
l      The commands of link aggregation cannot be configured with the commands of port loopback detection feature at the same time.
l      The ports where the mac-address max-mac-count command is configured cannot be added to an aggregation group. Contrarily, the mac-address max-mac-count command cannot be configured on a port that has already been added to an aggregation group.
l      MAC-authentication-enabled ports and 802.1x-enabled ports cannot be added to an aggregation group.
l      Mirroring destination ports and mirroring reflector ports cannot be added to an aggregation group.
l      Ports configured with blackhole MAC addresses, static MAC addresses, multicast MAC addresses, or the static ARP protocol cannot be added to an aggregation group.
l      Ports where the IP-MAC address binding is configured cannot be added to an aggregation group.
l      Port-security-enabled ports cannot be added to an aggregation group.
l      The port with Voice VLAN enabled cannot be added to an aggregation group.
l      Do not add ports with IP filtering enabled to an aggregation group.
l      Do not add ports with ARP intrusion detection enabled to an aggregation group.
l      Do not add ports with source IP addresses/source MAC addresses statically bound to them to an aggregation group.
l      A port cannot belong to a port group and an aggregation group at the same time.
1.4.1  Configuring a Manual Aggregation Group
You can create a manual aggregation group, or remove an existing manual aggregation group (after that, all the member ports will be removed from the group).
For a manual aggregation group, a port can only be manually added/removed to/from the manual aggregation group.
Table 1-1 Configure a manual aggregation group
Operation
Remarks
Enter system view
Create a manual aggregation group
link-aggregation group agg-id mode manual
Required
Enter Ethernet port view
Add the Ethernet port to the aggregation group
port link-aggregation group agg-id
Required
Note that:
1)         When creating an aggregation group:
l           If the aggregation group you are creating already exists but contains no port, its type will change to the type you set.
l           If the aggregation group you are creating already exists and contains ports, the possible type changes may be: changing from dynamic or static to manual, and changing from dynamic to static; and no other kinds of type change can occur.
l           When you change a dynamic/static group to a manual group, the system will automatically disable LACP on the member ports. When you change a dynamic group to a static group, the system will remain the member ports LACP-enabled.
2)         When a manual or static aggregation group contains only one port, you cannot remove the port unless you remove the whole aggregation group.
1.4.2  Configuring a Static LACP Aggregation Group
You can create a static LACP aggregation group, or remove an existing static LACP aggregation group (after that, the system will re-aggregate the original member ports in the group to form one or multiple dynamic aggregation groups.).
For a static aggregation group, a port can only be manually added/removed to/from the static aggregation group.
&  Note:
When you add an LACP-enabled port to a manual aggregation group, the system will automatically disable LACP on the port. Similarly, when you add an LACP-disabled port to a static aggregation group, the system will automatically enable LACP on the port.
Table 1-2 Configure a static LACP aggregation group
Operation
Remarks
Enter system view
Create a static aggregation group
link-aggregation group agg-id mode static
Required
Add the port to the aggregation group
Required
&  Note:
For a static LACP aggregation group or a manual aggregation group, you are recommended not to cross cables between the two devices at the two ends of the aggregation group. For example, suppose port 1 of the local device is connected to port 2 of the peer device. To avoid cross-connecting cables, do not connect port 2 of the local device to port 1 of the peer device. Otherwise, packets may be lost.
1.4.3  Configuring a Dynamic LACP Aggregation Group
A dynamic LACP aggregation group is automatically created by the system based on LACP-enabled ports. The adding and removing of ports to/from a dynamic aggregation group are automatically accomplished by LACP.
You need to enable LACP on the ports which you want to participate in dynamic aggregation of the system, because, only when LACP is enabled on those ports at both ends, can the two parties reach agreement in adding/removing ports to/from dynamic aggregation groups.
&  Note:
You cannot enable LACP on a port which is already in a manual aggregation group.
Table 1-3 Configure a dynamic LACP aggregation group
Operation
Remarks
Enter system view
Configure the system priority
lacp system-priority system-priority
Optional
By default, the system priority is 32,768.
Enable LACP on the port
lacp enable
Required
By default, LACP is disabled on a port.
Configure the port priority
lacp port-priority port-priority
Optional
By default, the port priority is 32,768.
&  Note:
Changing the system priority may affect the priority relationship between the aggregation peers, and thus affect the selected/unselected status of member ports in the dynamic aggregation group.
1.4.4  Configuring a Description for an Aggregation Group
Perform the following tasks to configure a description for an aggregation group.
Table 1-4 Configure a description for an aggregation group
Operation
Remarks
Enter system view
link-aggregation group agg-id description agg-name
Optional
By default, no description is configured for an aggregation group.
  Caution:
If you have saved the current configuration with the save command, after system reboot, the configuration concerning manual and static aggregation groups and their descriptions still exists, but that of dynamic aggregation groups and their descriptions gets lost.
1.5  Displaying and Maintaining Link Aggregation Configuration
After the above configuration, you can execute the display command in any view to display the running status after the link aggregation configuration and verify your configuration. Execute the reset command in user view to clear LACP statistics on ports.
Table 1-5 Display and maintain link aggregation configuration
Operation
Remarks
Display summary information of all aggregation groups
display link-aggregation summary
Available in any view
Display detailed information of a specific aggregation group or all aggregation groups
display link-aggregation verbose [ agg-id ]
Display link aggregation details of a specified port or port range
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
Display local device ID
display lacp system-id
Clear LACP statistics about a specified port or port range
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
Available in user view
1.6  Link Aggregation Configuration Example
1.6.1  Ethernet Port Aggregation Configuration Example
I. Network requirements
l           Switch A connects to Switch B with three ports Ethernet1/0/1 to Ethernet1/0/3. It is required that incoming/outgoing load between the two switches can be shared among the three ports.
l           Adopt three different aggregation modes to implement link aggregation on the three ports between switch A and B.
II. Network diagram
Figure 1-1 Network diagram for link aggregation configuration
III. Configuration procedure
&  Note:
The following only lists the configuration on Switch A; you must perform the similar configuration on Switch B to implement link aggregation.
1)         Adopting manual aggregation mode
# Create manual aggregation group 1.
[Sysname] link-aggregation group 1 mode manual
# Add Ethernet1/0/1 through Ethernet1/0/3 to aggregation group 1.
[Sysname] interface Ethernet1/0/1
[Sysname-Ethernet1/0/1] port link-aggregation group 1
[Sysname-Ethernet1/0/1] quit
[Sysname] interface Ethernet1/0/2
[Sysname-Ethernet1/0/2] port link-aggregation group 1
[Sysname-Ethernet1/0/2] quit
[Sysname] interface Ethernet1/0/3
[Sysname-Ethernet1/0/3] port link-aggregation group 1
2)         Adopting static LACP aggregation mode
# Create static aggregation group 1.
[Sysname] link-aggregation group 1 mode static
3)         Adopting dynamic LACP aggregation mode
# Enable LACP on Ethernet1/0/1 through Ethernet1/0/3.
[Sysname-Ethernet1/0/1] lacp enable
[Sysname-Ethernet1/0/2] lacp enable
[Sysname-Ethernet1/0/3] lacp enable
  Caution:
The three LACP-enabled ports can be aggregated into one dynamic aggregation group to implement load sharing only when they have the same basic configuration (such as rate, duplex mode, and so on).
