H3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
HomeSupportSwitchesH3C S3100 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
09-Port Basic Configuration Operation
09-Port Basic Configuration Operation 108.39 KB
Chapter 1  Port Basic Configuration
&  Note:
The feature Configure Storm Constrain by kbps (kilobits per second) is added in the software version Release 2301. For details, refer to Configuring Storm Control on a Port.
1.1  Ethernet Port Configuration
1.1.1  Initially Configuring a Port
Table 1-1 Initially configure a port
Operation
Remarks
Enter system view
Enter Ethernet port view
Enable the Ethernet port
Optional
By default, the port is enabled.
Use the shutdown command to disable the port.
Set the description string for the Ethernet port
Optional
By default, the description string of an Ethernet port is null.
Set the duplex mode of the Ethernet port
duplex { auto | full | half }
Optional
By default, the duplex mode of the port is auto (auto-negotiation).
Set the speed of the Ethernet port
speed { 10 | 100 | 1000 | auto }
Optional
l      By default, the speed of an Ethernet port is determined through auto-negotiation (the auto keyword).
l      Use the 1000 keyword for Gigabit Ethernet ports only.
Set the medium dependent interface (MDI) mode of the Ethernet port
mdi { across | auto | normal }
Optional
Be default, the MDI mode of an Ethernet port is auto.
Set the maximum frame size allowed on the Ethernet port to 2048 bytes
jumboframe enable
Optional
By default, the maximum frame size allowed on an Ethernet port is 2048 bytes.
1.1.2  Limiting Traffic on individual Ports
By performing the following configurations, you can limit the incoming broadcast/ unknown multicast/unknown unicast traffic on individual ports. When a type of incoming traffic exceeds the threshold you set, the system drops the packets exceeding the traffic limit to reduce the traffic ratio of this type to the reasonable range, so as to keep normal network service.
Table 1-2 Limit traffic on port
Operation
Remarks
Enter system view
Limit broadcast traffic received on each port
broadcast-suppression ratio
Optional
By default, the switch does not suppress broadcast traffic.
Limit broadcast traffic received on the current port
broadcast-suppression { ratio | bps max-bps }
Optional
Limit unknown multicast and unknown unicast traffic received on the current port
multicast-suppression bps max-bps
Optional
The switch will suppress the unknown multicast and unknown unicast traffic simultaneously after the configuration.
By default, the switch does not suppress unknown multicast and unknown unicast traffic.
1.1.3  Enabling Flow Control on a Port
Flow control is enabled on both the local and peer switches. If congestion occurs on the local switch:
l           The local switch sends a message to notify the peer switch of stopping sending packets to itself or reducing the sending rate temporarily.
l           The peer switch will stop sending packets to the local switch or reduce the sending rate temporarily when it receives the message; and vice versa. By this way, packet loss is avoided and the network service operates normally.
Table 1-3 Enable flow control on a port
Operation
Remarks
Enter system view
Enable flow control on the Ethernet port
flow-control
By default, flow control is not enabled on the port.
1.1.4  Duplicating the Configuration of a Port to Other Ports
To make other ports have the same configuration as that of a specific port, you can duplicate the configuration of a port to specific ports.
Specifically, the following types of port configuration can be duplicated from one port to other ports: VLAN configuration, protocol-based VLAN configuration, LACP configuration, QoS configuration, GARP configuration, STP configuration and initial port configuration. For the detailed copy content, please refer to the Command Manual.
Table 1-4 Duplicate the configuration of a port to specific ports
Operation
Remarks
Enter system view
copy configuration source { interface-type interface-number | aggregation-group source-agg-id } destination { interface-list [ aggregation-group destination-agg-id ] | aggregation-group destination-agg-id }
Required
&  Note:
l      If you specify a source aggregation group ID, the system will use the port with the smallest port number in the aggregation group as the source.
l      If you specify a destination aggregation group ID, the configuration of the source port will be copied to all ports in the aggregation group and all ports in the group will have the same configuration as that of the source port.
1.1.5  Configuring Loopback Detection for an Ethernet Port
Loopback detection is used to monitor if a port of a switch is looped back.
After you enable loopback detection on Ethernet ports, the switch can monitor if an external loopback occurs on them. If there is a loopback port found, the switch will deal with the loopback port according to your configuration.
1)         If a loop is found on an access port, the system will set the port to the block state (ports in this state cannot forward data packets), send log messages to the terminal, and remove the corresponding MAC forwarding entry.
l           If you have additionally enabled the loopback port auto-shutdown function on the port, the system will shut down the port, and send log messages to the terminal. After the loop is removed, you need to use the undo shutdown command to bring up the port.
l           If you have not enabled the loopback port auto-shutdown function on the port, the port will automatically resume the normal forwarding state after the loop is removed.
2)         If a loop is found on a trunk or hybrid port, the system sends log messages to the terminal. If you have additionally enabled the loopback port control function or the loopback port auto-shutdown function, the system will deal with the port accordingly:
l           If the loopback port control function is enabled on the port, the system will set the port to the block state (ports in this state cannot forward data packets), send log messages to the terminal, and remove the corresponding MAC forwarding entry. After the loop is removed, the port will automatically resume the normal forwarding state.
l           If the loopback port auto-shutdown function is enabled on the port, the system will shut down the port and send log messages to the terminal. After the loop is removed, you need to use the undo shutdown command to bring up the port.
&  Note:
You cannot enable both the loopback port control function and the loopback port auto-shutdown function on a port. If you do so, the function configured later will take effect.
1.1.6  Configuring Loopback Detection for Ethernet Port(s)
Table 1-5 Configure loopback detection for Ethernet port(s)
Operation
Remarks
Enter system view
Enable loopback detection globally
loopback-detection enable
Optional
By default, the global loopback detection function is enabled if the device boots with the default configuration file (config.def); if the device boots with null configuration, this function is disabled.
Enable loopback detection on the specified ports in bulk
loopback-detection interface-list enable
Optional
By default, the loopback detection function is enabled on ports if the device boots with the default configuration file (config.def); if the device boots with null configuration, this function is disabled.
Set the interval for performing port loopback detection
loopback-detection interval-time time
Optional
The default is 30 seconds.
Enable loopback detection on a specified port
Optional
Enable loopback port control on the trunk or hybrid port
loopback-detection control enable
Optional
By default, the loopback port control function is enabled on ports if the device boots with the default configuration file (config.def); if the device boots with null configuration, this function is disabled.
Enable the loopback port auto-shutdown function
loopback-detection shutdown enable
Optional
By default, the loopback port auto-shutdown function is enabled on ports if the device boots with the default configuration file (config.def); if the device boots with null configuration, this function is disabled.
Configure the system to run loopback detection on all VLANs of the current trunk or hybrid port
loopback-detection per-vlan enable
Optional
By default, the system runs loopback detection only on the default VLAN of the current trunk or hybrid port.
  Caution:
l      To enable loopback detection on a specific port, you must use the loopback-detection enable command in both system view and the specific port view.
l      After you use the undo loopback-detection enable command in system view, loopback detection will be disabled on all ports.
1.1.7  Enabling Loopback Test
You can configure the Ethernet port to run loopback test to check if it operates normally. The port running loopback test cannot forward data packets normally. The loopback test terminates automatically after a specific period.
Table 1-6 Enable loopback test
Operation
Remarks
Enter system view
Optional
&  Note:
l      external: Performs external loop test. In the external loop test, self-loop headers  must be used on the port of the switch ( for 100M port, the self-loop headers are made from four cores of the 8-core cables, for 1000M port, the self-loop header are made from eight cores of the 8-core cables, then the packets forwarded by the port will be received by itself.). The external loop test can locate the hardware failures on the port.
l      internal: Performs internal loop test. In the internal loop test, self loop is established in the switching chip to locate the chip failure which is related to the port.
Note that:
l           After you use the shutdown command on a port, the port cannot run loopback test.
l           You cannot use the speed, duplex, mdi and shutdown commands on the ports running loopback test.
l           Some ports do not support loopback test, and corresponding prompts will be given when you perform loopback test on them.
1.1.8  Configuring a Port Group
To make the configuration task easier for users, certain devices allow users to configure on a single port as well as on multiple ports in a port group. In port group view, the user only needs to input the configuration command once on one port and that configuration will apply to all ports in the port group. This effectively reduces redundant configurations.
A Port group could be manually created by users. Multiple Ethernet ports can be added to the same port group but one Ethernet port can only be added to one port group.
Table 1-7 Configuring a Port Group
Operation
Remarks
Enter system view
Create a port group or enter the specified port group view
port-group group-id
Required
Add an Ethernet port to a specified port group
port interface-list
Required
&  Note:
A port can not be added to a port group if it has been added to an aggregation group, and vice versa.
1.1.9  Enabling the System to Test Connected Cable
You can enable the system to test the cable connected to a specific port. The test result will be returned in five seconds. The system can test these attributes of the cable: Receive and transmit directions (RX and TX), short circuit/open circuit or not, the length of the faulty cable.
Table 1-8 Enable the system to test connected cables
Operation
Remarks
Enter system view
virtual-cable-test
Required
&  Note:
l      Currently, the device is only capable of testing the cable status and cable length. For the testing items that are currently not supported, “-” is displayed in the corresponding output fields.
l      Cable test cannot be performed on an optical port.
1.1.10  Configuring the Interval to Perform Statistical Analysis on Port Traffic
By performing the following configuration, you can set the interval to perform statistical analysis on the traffic of a port.
When you use the display interface interface-type interface-number command to display the information of a port, the system performs statistical analysis on the traffic flow passing through the port during the specified interval and displays the average rates in the interval. For example, if you set this interval to 100 seconds, the displayed information is as follows:
 Last 100 seconds input:  0 packets/sec 0 bytes/sec
 Last 100 seconds output:  0 packets/sec 0 bytes/sec
Table 1-9 Set the interval to perform statistical analysis on port traffic
Operation
Enter system view
flow-interval interval
Optional
By default, this interval is 300 seconds.
1.1.11  Disabling Up/Down Log Output on a Port
An Ethernet port has two physical link statuses: UP and Down. When the physical link status of an Ethernet port changes, the switch will send log to the log server, which in turn acts accordingly. If the status of Ethernet ports in a network changes frequently, large amount of log information may be sent, which increases work load of the log server and consumes more network resources.
You can limit the amount of the log information sent to the log server by disabling the Up/Down log output function on Ethernet ports.
&  Note:
I. Disable Up/Down log output on a port
Table 1-10 Disable UP/Down log output on a port
Operation
Remarks
Enter system view
Disable a port from outputting UP/Down Log Information
undo enable log updown
Required
By default, UP/Down log information output is enabled.
II. Configuration example
# By default, a port is allowed to output the Up/Down log information. Execute the shutdown command or the undo shutdown command on Ethernet 1/0/1, and the system outputs Up/Down log information of Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] shutdown
%Apr  5 07:25:37:634 2000 Sysname L2INF/5/PORT LINK STATUS CHANGE:- 1 -
 Ethernet1/0/1 is DOWN
[Sysname-Ethernet1/0/1] undo shutdown
%Apr  5 07:25:56:244 2000 Sysname L2INF/5/PORT LINK STATUS CHANGE:- 1 -
 Ethernet1/0/1 is UP
# After you disable Ethernet 1/0/1 from outputting Up/Down log information and execute the shutdown command or the undo shutdown command on Ethernet 1/0/1, no Up/Down log information is output for Ethernet 1/0/1.
[Sysname-Ethernet1/0/1] undo enable log updown
1.1.12  Configuring Storm Control on a Port
The storm control function is used to control traffic received on an Ethernet port.
l           With traffic upper and lower thresholds specified on a port, the system periodically collects statistics about the broadcast/multicast/unicast traffic on the port. Once it finds that a type of traffic exceeds the specified upper threshold, it blocks this type of traffic on the port or directly shuts down the port, and outputs trap/log information according to your configuration.
l           When a type of traffic on the port falls back to the specified lower threshold, the system cancels the blocking of this type of traffic on the port or brings up the port to restore traffic forwarding for the port, and outputs log/trap information according to your configuration.
Follow these steps to configure storm control on a port:
To do...
Use the command...
Remarks
Enter system view
Set the upper and lower thresholds of broadcast/multicast/unicast traffic received on the port
storm-constrain { broadcast | multicast } max-packets min-packets { pps | kbps }
Required
Set the action to be taken when a type of traffic received on the port exceeds the upper threshold.
Optional
By default, no action is taken when a type of traffic reaches the upper threshold.
Enable log/trap information to be output when a type of traffic received on the port exceeds the upper threshold or falls below the lower threshold
storm-constrain enable { log | trap }
Optional
Enabled by default.
Return to system view
Set the interval at which the port collects traffic statistics
storm-constrain interval interval-value
Optional
It is 10 seconds by default.
&  Note:
l      You are not recommended to set the upper and lower traffic thresholds to the same value.
l      If you specify the block keyword when executing the storm-constrain control command, only the packets beyond the upper thresholds are blocked when the overall traffic exceeds the upper threshold. In this case, the blocked packets are still taken into account when generating traffic statistics. If you specify the shutdown keyword when executing the command, the port will be shut down when the traffic passing through the port exceeds the upper threshold. You bring up the port again by executing the undo shutdown or the undo storm-constrain { all | broadcast | multicast } command.
1.1.13  Setting the Port State Change Delay
During a short period after you connect your switch to another device, the connecting port may go up and down frequently due to hardware compatibility, resulting in service interruption.
To avoid situations like this, you may introduce a port state change delay.
  Caution:
The port state change delay takes effect when the port goes down but not when the port goes up.
Follow these steps to set the port state change delay:
To do …
Use the command …
Remarks
Enter system view
Enter Ethernet interface view
Set the port state change delay
link-delay delay-time
Required
Defaults to 0, which indicates that no delay is introduced.
&  Note:
The delay configured in this way does not take effect for ports in DLDP down state. For information about the DLDP down state, refer to DLDP.
1.1.14  Displaying and Maintaining Basic Port Configuration
Table 1-11 Display and maintain basic port configuration
Operation
Remarks
Display port configuration information
display interface [ interface-type | interface-type interface-number ]
You can execute the display commands in any view.
Display the enable/disable status of port loopback detection
display loopback-detection
Display brief information about port configuration
display brief interface [ interface-type [ interface-number ] ] [ | { begin | include | exclude } regular-expression ]
Display the combo ports on the current device
display port combo
Display the storm control configurations
display storm-constrain [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
Display the information about the port with the link-delay command configured
display link-delay
Display port information about a specified unit
display unit unit-id interface
Clear port statistics
reset counters interface [ interface-type | interface-type interface-number ]
You can execute the reset command in user view.
After 802.1x is enabled on a port, clearing the statistics on the port will not work.
1.2  Ethernet Port Configuration Example
I. Network requirements
l           Switch A and Switch B are connected to each other through two trunk port (Ethernet 1/0/1).
l           Configure the default VLAN ID of both Ethernet 1/0/1 to 100.
l           Allow the packets of VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 to pass both Ethernet 1/0/1.
II. Network diagram
Figure 1-1 Network diagram for Ethernet port configuration
III. Configuration procedure
&  Note:
l      Only the configuration for Switch A is listed below. The configuration for Switch B is similar to that of Switch A.
l      This example supposes that VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 have been created.
# Enter Ethernet 1/0/1 port view.
[Sysname] interface ethernet1/0/1
# Set Ethernet 1/0/1 as a trunk port.
[Sysname-Ethernet1/0/1] port link-type trunk
# Allow packets of VLAN 2, VLAN 6 through VLAN 50 and VLAN 100 to pass Ethernet1/0/1.
[Sysname-Ethernet1/0/1] port trunk permit vlan 2 6 to 50 100
# Configure the default VLAN ID of Ethernet1/0/1 to 100.
[Sysname-Ethernet1/0/1] port trunk pvid vlan 100
1.3  Troubleshooting Ethernet Port Configuration
Symptom: Fail to configure the default VLAN ID of an Ethernet port.
Solution: Take the following steps.
l           Use the display interface or display port command to check if the port is a trunk port or a hybrid port.
l           If the port is not a trunk or hybrid port, configure it to be a trunk or hybrid port.
l           Configure the default VLAN ID of the port.
