H3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
HomeSupportSwitchesH3C S3100 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
07-Voice VLAN Operation
07-Voice VLAN Operation 211.48 KB
Chapter 1  Voice VLAN Configuration
When configuring voice VLAN, go to these sections for information you are interested in:
l           Voice VLAN Overview
l           Voice VLAN Configuration
l           Displaying and Maintaining Voice VLAN
l           Voice VLAN Configuration Example
1.1  Voice VLAN Overview
Voice VLANs are VLANs configured specially for voice traffic. By adding the ports connected with voice devices to voice VLANs, you can have voice traffic transmitted within voice VLANs and perform QoS-related configuration for voice traffic as required, thus ensuring the transmission priority of voice traffic and voice quality.
1.1.1  How an IP Phone Works
IP phones can convert analog voice signals into digital signals to enable them to be transmitted in IP-based networks. Used in conjunction with other voice devices, IP phones can offer large-capacity and low-cost voice communication solutions. As network devices, IP phones need IP addresses to operate properly in a network. An IP phone can acquire an IP address automatically or through manual configuration. The following part describes how an IP phone acquires an IP address automatically.
&  Note:
The following part only describes the common way for an IP phone to acquire an IP address. The detailed process may vary by manufacture. Refer to the corresponding user manual for the detailed information.
When an IP phone applies for an IP address from a DHCP server, the IP phone can also apply for the following extensive information from the DHCP server through the Option184 field:
l           IP address of the network call processor (NCP)
l           IP address of the secondary NCP server
l           Voice VLAN configuration
l           Failover call routing
Following describes the way an IP phone acquires an IP address.
Figure 1-1 Network diagram for IP phones
As shown in Figure 1-1, the IP phone needs to work in conjunction with the DHCP server and the NCP to establish a path for voice data transmission. An IP phone goes through the following three phases to become capable of transmitting voice data.
1)         After the IP phone is powered on, it sends an untagged DHCP request message containing four special requests in the Option 184 field besides the request for an IP address. The message is broadcast in the default VLAN of the receiving port. After receiving the DHCP request message, DHCP Server 1, which resides in the default VLAN of the port receiving the message, responds as follows:
l           If DHCP Server 1 does not support Option 184, it returns the IP address assigned to the IP phone but ignores the other four special requests in the Option 184 field. Without information about voice VLAN, the IP phone can only send untagged packets in the default VLAN of the port the IP phone is connected to. In this case, you need to manually configure the default VLAN of the port as a voice VLAN.
&  Note:
In cases where an IP phone obtains an IP address from a DHCP server that does not support Option 184, the IP phone directly communicates through the gateway after it obtains an IP address. It does not go through the steps described below.
l           If DHCP Server 1 supports Option 184, it returns the IP address assigned to the IP phone, the IP address of the NCP, the voice VLAN ID, and so on.
2)         On acquiring the voice VLAN ID and NCP address from DHCP Server 1, the IP phone communicates with the specified NCP to download software, ignores the IP address assigned by DHCP Server 1, and sends a new DHCP request message carrying the voice VLAN tag to the voice VLAN.
3)         After receiving the DHCP request, DHCP Server 2 residing in the voice VLAN assigns a new IP address to the IP phone and sends a tagged response message to the IP phone. After the IP phone receives the tagged response message, it sends voice data packets tagged with the voice VLAN tag to communicate with the voice gateway. In this case, the port connecting to the IP phone must be configured to allow the packets tagged with the voice VLAN tag to pass.
&  Note:
l      An untagged packet carries no VLAN tag.
l      A tagged packet carries the tag of a VLAN.
To set an IP address and a voice VLAN for an IP phone manually, just make sure that the voice VLAN ID to be set is consistent with that of the switch and the NCP is reachable to the IP address to be set.
1.1.2  How S3100 Series Switches Identify Voice Traffic
S3100 series Ethernet switches determine whether a received packet is a voice packet by checking its source MAC address against an organizationally unique identifier (OUI) list. If a match is found, the packet is considered as a voice packet. Ports receiving packets of this type will be added to the voice VLAN automatically for transmitting voice data.
You can configure OUI addresses for voice packets or specify to use the default OUI addresses.
&  Note:
An OUI address is a globally unique identifier assigned to a vendor by IEEE. You can determine which vendor a device belongs to according to the OUI address which forms the first 24 bits of a MAC address. S3100 series Ethernet switches support OUI address mask configuration. You can adjust the matching depth of MAC address by setting different OUI address masks.
The following table lists the five default OUI addresses on S3100 series switches.
Table 1-1 Default OUI addresses pre-defined on the switch
Number
OUI address
Vendor
1
0003-6b00-0000
Cisco phones
2
000f-e200-0000
H3C Aolynk phones
3
00d0-1e00-0000
Pingtel phones
4
00e0-7500-0000
Polycom phones
5
00e0-bb00-0000
3Com phones
1.1.3  Setting the Voice Traffic Transmission Priority
In order to improve transmission quality of voice traffic, the switch by default re-marks the priority of the traffic in the voice VLAN as follows:
l           Set the CoS (802.1p) priority to 6.
l           Set the DSCP value to 46.
1.1.4  Configuring Voice VLAN Assignment Mode of a Port
A port can work in automatic voice VLAN assignment mode or manual voice VLAN assignment mode. You can configure the voice VLAN assignment mode for a port according to data traffic passing through the port.
I. Processing mode of untagged packets sent by IP voice devices
l           Automatic voice VLAN assignment mode. An S3100 Ethernet switch automatically adds a port connecting an IP voice device to the voice VLAN by learning the source MAC address in the untagged packet sent by the IP voice device when it is powered on. The voice VLAN uses the aging mechanism to maintain the number of ports in the voice VLAN. When the aging timer expires, the ports whose OUI addresses are not updated (that is, no voice traffic passes) will be removed from the voice VLAN. In voice VLAN assignment automatic mode, ports can not be added to or removed from a voice VLAN manually.
l           Manual voice VLAN assignment mode: In this mode, you need to add a port to a voice VLAN or remove a port from a voice VLAN manually.
II. Processing mode of tagged packets sent by IP voice devices
Tagged packets from IP voice devices are forwarded based on their tagged VLAN IDs, whether the automatic or manual voice VLAN assignment mode is used.
  Caution:
If the voice traffic transmitted by an IP voice device carries VLAN tags, and 802.1x authentication and guest VLAN is enabled on the port which the IP voice device is connected to, assign different VLAN IDs for the voice VLAN, the default VLAN of the port, and the 802.1x guest VLAN to ensure the effective operation of these functions.
1.1.5  Support for Voice VLAN on Various Ports
Voice VLAN packets can be forwarded by access ports, trunk ports, and hybrid ports. You can enable a trunk or hybrid port belonging to other VLANs to forward voice and service packets simultaneously by enabling the voice VLAN.
For different types of IP phones, the support for voice VLAN varies with port types and port configuration. For IP phones capable of acquiring IP address and voice VLAN automatically, the support for voice VLAN is described in Table 1-2.
Table 1-2 Matching relationship between port types and voice devices capable of acquiring IP address and voice VLAN automatically
Voice VLAN assignment mode
Voice traffic type
Port type
Supported or not
Automatic
Tagged voice traffic
Access
Not supported
Trunk
Supported
Make sure the default VLAN of the port exists and is not a voice VLAN, and the access port permits the traffic of the default VLAN.
Hybrid
Supported
Make sure the default VLAN of the port exists and is not a voice VLAN, and the port permits the traffic of the default VLAN.
Untagged voice traffic
Access
Not supported, because the default VLAN of the port must be a voice VLAN and the access port is in the voice VLAN. This can be done by adding the port to the voice VLAN manually.
Trunk
Hybrid
Manual
Access
Not supported
Trunk
Supported
Make sure the default VLAN of the port exists and is not a voice VLAN, and the access port permits the traffic of the default VLAN and the voice VLAN.
Hybrid
Supported
Make sure the default VLAN of the port exists and is not a voice VLAN, the port permits the traffic of the default VLAN, and the voice VLAN is in the list of the tagged VLANs whose traffic is permitted by the access port.
Access
Supported
Make sure the default VLAN of the port is a voice VLAN.
Trunk
Supported
Make sure the default VLAN of the port is a voice VLAN and the port permits the traffic of the VLAN.
Hybrid
Supported
Make sure the default VLAN of the port is a voice VLAN and is in the list of untagged VLANs whose traffic is permitted by the port.
IP phones acquiring IP address and voice VLAN through manual configuration can forward only tagged traffic, so the matching relationship is relatively simple, as shown in Table 1-3:
Table 1-3 Matching relationship between port types and voice devices acquiring voice VLAN through manual configuration
Port type
Supported or not
Automatic
Access
Not supported
Trunk
Supported
Hybrid
Supported
Make sure the default VLAN of the port exists and is not a voice VLAN, and the default VLAN is in the list of the tagged VLANs whose traffic is permitted by the access port.
Manual
Access
Not supported
Trunk
Supported
Hybrid
Supported
Make sure the default VLAN of the port exists and is not a voice VLAN, and the default VLAN and the voice VLAN is in the list of the tagged VLANs whose traffic is permitted by the access port.
1.1.6  Security Mode of Voice VLAN
On S3100 series Ethernet switches, a voice VLAN can operate in the security mode. Voice VLANs operating in this mode only permit voice data, enabling you to perform voice traffic-specific priority configuration. With the security mode disabled, both voice data and service data can be transmitted in a voice VLAN.
1.2  Voice VLAN Configuration
1.2.1  Configuration Prerequisites
l           Create the corresponding VLAN before configuring a voice VLAN.
l           VLAN 1 (the default VLAN) cannot be configured as a voice VLAN.
1.2.2  Configuring the Voice VLAN to Operate in Automatic Voice VLAN Assignment Mode
Follow these steps to configure a voice VLAN to operate in automatic voice VLAN assignment mode:
To do…
Use the command…
Remarks
Enter system view
Set an OUI address that can be identified by the voice VLAN
voice vlan mac-address oui mask oui-mask [ description text ]
Optional
By default, the switch determines the voice traffic according to the default OUI address.
Enable the voice VLAN security mode
voice vlan security enable
Optional
By default, the voice VLAN security mode is enabled.
Set the voice VLAN aging timer
voice vlan aging minutes
Optional
The default aging timer is 1440 minutes.
Enable the voice VLAN function globally
voice vlan vlan-id enable
Required
Enter Ethernet port view
Required
Enable the voice VLAN function on a port
voice vlan enable
Required
By default, voice VLAN is disabled.
Enable the voice VLAN legacy function on the port
voice vlan legacy
Optional
By default, voice VLAN legacy is disabled.
Set the voice VLAN assignment mode of the port to automatic
voice vlan mode auto
Optional
The default voice VLAN assignment mode on a port is automatic.
  Caution:
l      A port working in automatic voice VLAN assignment mode cannot be assigned to the voice VLAN manually. Therefore, if a VLAN is configured as the voice VLAN and a protocol-based VLAN at the same time, the protocol-based VLAN function cannot be bound with the port. For information about protocol-based VLANs, refer to VLAN Configuration in this manual.
l      For a port operating in automatic voice VLAN assignment mode, its default VLAN cannot be configured as the voice VLAN; otherwise the system prompts you for unsuccessful configuration.
&  Note:
When the voice VLAN is working normally, if the device restarts or the Unit ID of a device in a stack changes, in order to make the established voice connections work normally, the system does not need to be triggered by the voice traffic to add the port in automatic voice VLAN assignment mode to the local devices as well as the IRF of the voice VLAN but does so immediately after the restart or the changes.
1.2.3  Configuring the Voice VLAN to Operate in Manual Voice VLAN Assignment Mode
Follow these steps to configure a voice VLAN to operate in manual voice VLAN assignment mode:
To do…
Use the command…
Remarks
Enter system view
Optional
Without this address, the default OUI address is used.
Optional
Optional
The default aging timer is 1,440 minutes.
Required
Enter port view
Required
Enable voice VLAN on a port
voice vlan enable
Required
By default, voice VLAN is disabled on a port.
voice vlan legacy
Optional
Set voice VLAN assignment mode on a port to manual
undo voice vlan mode auto
Required
Quit to system view
Add a port in manual voice VLAN assignment mode to the voice VLAN
Access port
Enter VLAN view
vlan vlan-id
Required
By default, all the ports belong to VLAN 1.
Add the port to the VLAN
port interface-list
Trunk or Hybrid port
Enter port view
interface interface-type interface-num
port trunk permit vlan vlan-id
port hybrid vlan vlan-id { tagged | untagged }
Configure the voice VLAN to be the default VLAN of the port
port trunk pvid vlan vlan-id
port hybrid pvid vlan vlan-id
Optional
Refer to Table 1-2 to determine whether or not this operation is needed.
  Caution:
l      The voice VLAN function can be enabled for only one VLAN at one time.
l      If the Link Aggregation Control Protocol (LACP) is enabled on a port, voice VLAN feature cannot be enabled on it.
l      Voice VLAN function can be enabled only for the static VLAN. A dynamic VLAN cannot be configured as a voice VLAN.
l      When ACL number applied to a port reaches to its threshold, voice VLAN cannot be enabled on this port. You can use the display voice vlan error-info command to locate such ports.
l      When a voice VLAN operates in security mode, the device in it permits only the packets whose source addresses are the identified voice OUI addresses. Packets whose source addresses cannot be identified, including certain authentication packets (such as 802.1x authentication packets), will be dropped. Therefore, you are suggested not to transmit both voice data and service data in a voice VLAN. If you have to do so, make sure that the voice VLAN does not operate in security mode.
l      The voice VLAN legacy feature realizes the communication between H3C device and other vendor's voice device by automatically adding the voice VLAN tag to the voice data coming from other vendors’ voice device. The voice vlan legacy command can be executed before voice VLAN is enabled globally and on a port, but it takes effect only after voice VLAN is enabled globally and on the port.
To assign a trunk port or a hybrid port to the voice VLAN, refer to VLAN Configuration of this manual for the related command.
1.3  Displaying and Maintaining Voice VLAN
To do…
Use the command…
Remarks
Display information about the ports on which voice VLAN configuration fails
In any view
Display the voice VLAN configuration status
display voice vlan status
Display the OUI list
display voice vlan oui
Display the ports operating in the voice VLAN
display vlan vlan-id
1.4  Voice VLAN Configuration Example
1.4.1  Voice VLAN Configuration Example (Automatic Voice VLAN Assignment Mode)
I. Network requirements
Create a voice VLAN and configure it to operate in automatic voice VLAN assignment mode to enable the port to which an IP phone is connected to join or exit the voice VLAN automatically and voice traffic to be transmitted within the voice VLAN.
l           Create VLAN 2 and configure it as the voice VLAN, with the aging timer being 100 minutes.
l           The IP phone sends tagged packets. It is connected to Ethernet 1/0/1, a hybrid port, with VLAN 6 being its default VLAN. Set this port to operate in automatic voice VLAN assignment mode.
l           You need to add a user-defined OUI address 0011-2200-000, with the mask being ffff-ff00-0000 and the description string being “test”.
II. Network diagram
Figure 1-2 Network diagram for voice VLAN configuration (automatic voice VLAN assignment mode)
III. Configuration procedure
# Create VLAN 2 and VLAN 6.
[DeviceA] vlan 2
[DeviceA-vlan2] quit
[DeviceA] vlan 6
[DeviceA-vlan6] quit
# Set the voice VLAN aging timer.
[DeviceA] voice vlan aging 100
# Add a user-defined OUI address 0011-2200-000 and set the description string to “test”.
[DeviceA] voice vlan mac-address 0011-2200-0000 mask ffff-ff00-0000 description test
# Enable the voice VLAN function globally.
[DeviceA] voice vlan 2 enable
# Configure the vocie VLAN to operate in automatic voice VLAN assignment mode on Ethernet 1/0/1. This operation is optional. By default, a port operates in automatic voice VLAN assignment mode.
[DeviceA] interface Ethernet 1/0/1
[DeviceA-Ethernet1/0/1] voice vlan mode auto
# Configure Ethernet 1/0/1 as a hybrid port.
[DeviceA-Ethernet1/0/1] port link-type hybrid
# Configure VLAN 6 as the default VLAN of Ethernet 1/0/1, and configure Ethernet 1/0/1 to permit packets with the tag of VLAN 6.
[DeviceA-Ethernet1/0/1] port hybrid pvid vlan 6
[DeviceA-Ethernet1/0/1] port hybrid vlan 6 tagged
# Enable the voice VLAN function on Ethernet 1/0/1.
[DeviceA-Ethernet1/0/1] voice vlan enable
1.4.2  Voice VLAN Configuration Example (Manual Voice VLAN Assignment Mode)
Create a voice VLAN and configure it to operate in manual voice VLAN assignment mode. Add the port to which an IP phone is connected to the voice VLAN to enable voice traffic to be transmitted within the voice VLAN.
l           Create VLAN 2 and configure it as a voice VLAN. Set the voice VLAN to operate in security mode
l           The IP phone sends untagged packets. It is connected to Ethernet 1/0/1, a hybrid port. Set this port to operate in manual voice VLAN assignment mode.
l           Set the CoS priority to 5 and DSCP to 40 for the received voice traffic.
II. Network diagram
Figure 1-3 Network diagram for voice VLAN configuration (manual voice VLAN assignment mode)
# Enable the security mode for the voice VLAN so that the ports in the voice VLAN permit valid voice packets only. This operation is optional. The security mode is enabled by default.
[DeviceA] voice vlan security enable
# Create VLAN 2 and configure it as a voice VLAN.
[DeviceA] vlan 2
# Configure Ethernet 1/0/1 to operate in manual voice VLAN assignment mode.
[DeviceA-Ethernet1/0/1] undo voice vlan mode auto
# Configure the voice VLAN as the default VLAN of Ethernet 1/0/1, and add the voice VLAN to the list of untagged VLANs whose traffic is permitted by the port.
[DeviceA-Ethernet1/0/1] port hybrid pvid vlan 2
[DeviceA-Ethernet1/0/1] port hybrid vlan 2 untagged
# Set the CoS priority to 5 and DSCP to 40 for the received voice traffic.
[DeviceA-Ethernet1/0/1] voice vlan qos 5 40
IV. Verification
# Display the OUI addresses, the corresponding OUI address masks and the corresponding description strings that the system supports.
<DeviceA> display voice vlan oui
Oui Address     Mask            Description
0003-6b00-0000  ffff-ff00-0000  Cisco phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
0011-2200-0000  ffff-ff00-0000  test
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
# Display the status of the current voice VLAN.
<DeviceA> display voice vlan status
Voice Vlan status: ENABLE
Voice Vlan ID: 2
Voice Vlan security mode: Security
Voice Vlan aging time: 1440 minutes
Current voice vlan enabled port mode:
PORT                   MODE
Ethernet1/0/1          MANUAL
