H3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
HomeSupportSwitchesH3C S3100 Switch SeriesConfigure & DeployConfiguration GuidesH3C S3100 Series Ethernet Switches Operation Manual (For Soliton)(V1.02)
00-2Product Overview
00-2Product Overview 591.42 KB
Table of Contents
Chapter 1 Obtaining the Documentation. 1-1
1.1 CD-ROM.. 1-1
1.2 H3C Website. 1-1
1.3 Software Release Notes. 1-2
Chapter 2 Correspondence Between Documentation and Software. 2-1
2.1 Manual List 2-1
2.2 Software Version. 2-1
Chapter 3 Product Overview.. 3-1
3.1 Overview. 3-1
3.2 Software Features. 3-1
Chapter 4 Network Design. 4-1
4.1 MAN Access Solution. 4-1
4.2 Education Network Solution. 4-1
4.3 Multi-Service Carrier VLAN Solution. 4-2
Hangzhou H3C Technologies Co., Ltd. provides various ways for you to obtain documentation, through which you can obtain the product documentations and those concerning newly added new features. The documentations are available in one of the following ways:
l           CD-ROMs shipped with the devices
l           H3C website
l           Software release notes
1.1  CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains the operation manual and command manual. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
1.2  H3C Website
Perform the following steps to query and download the product documentation from the H3C website.
Table 1-1 Acquire product documentation from the H3C website
Registering
Access the homepage of H3C at http:// www.h3c.com and click on Registration at the top right. In the displayed page, provide your information and click on Submit to register.
Approach 1:
In the homepage of H3C at http:// www.h3c.com, select Technical Support & Document > Technical Documents from the navigation menu at the top. Then select a product for its documents.
Approach 2:
In the homepage of H3C at http:// www.h3c.com, select Support > Technical Documents. Then select a product for its documents.
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
2.1  Manual List
Manual name
H3C S3100 Series Ethernet Switches Installation Manual (For Soliton)
H3C S3100 Series Ethernet Switches Quick Start (For Soliton)
H3C S3100 Series Ethernet Switches Compliance and Safety Manual (For Soliton)
H3C S3100 Series Ethernet Switches Command Manual (For Soliton)
H3C S5100&S3100 Series Ethernet Switches HSNS Feature Manual (For Soliton)
H3C S3100 Series Ethernet Switches Operation Manual (For Soliton) and H3C S3100 Series Ethernet Switches Command Manual (For Soliton) are for the software versions list bellow of the S3100 series switches:
l           Release 2300
l           Release 2301
New features were added into the later software versions. For details, refer to Table 2-1. Please find the appropriate features in this manual according to the software version of your switch.
Table 2-1 Added features compared with the earlier software version of S3100
Software Version
Added Features Compared With The Earlier Version
Manual
Release2301
Configure Storm Constrain by kbps (kilobits per second)
09-Port Basic Configuration
Suppressing Flooding of Unknown Multicast Traffic in a VLAN
16-Multicast
Functioning as a DHCP client supports default route creation
21-DHCP
&  Note:
For the convenience of users, units of Mega bps/1000 Mega bps in the following chapters are simplified as M/G.
3.1  Overview
The H3C S3100 Series Ethernet Switches are high-performance, high-density, easy-to-install, NMS-manageable intelligent Ethernet switches which support wire-speed Layer 2 switching.
S3100 Series Ethernet Switches have abundant software features and can meet the requirements of different applications. Table 3-1 summarizes the features provided by each module.
Table 3-1 Software features of the S3100 series
Part
Features
1 CLI
l      CLI
l      Hierarchically grouped commands
l      CLI online help
2 Login
l      Logging into a switch through the Console port
l      Logging into a switch through an Ethernet port by using Telnet or SSH
l      Logging into a switch through the Console port by using modem
l      Logging into a switch through Web or NMS
3 Configuration File Management
l      Saving and deleting the configuration file
l      Specifying the configuration file to be used the next time the device boots and the file attribute
4 VLAN
l      IEEE 802.1Q-compliant VLAN
l      Port-based VLAN
l      Protocol-based VLAN
l      MAC-based VLAN
5 Management VLAN
l      Management VLAN configuration
l      Management VLAN interface configuration
6 IP Address-IP Performance Configuration
l      Configuring an IP address for a switch
l      Configuring the TCP attributes for a switch
7 Voice VLAN
Voice VLAN
8 GVRP
GARP VLAN registration protocol (GVRP)
9 Port Basic Configuration
l      Three port states supported: Access, Trunk, and Hybrid
l      Setting broadcast storm suppression globally
l      Loopback detection supported
l      Cable test
10 Link Aggregation
l      Link aggregation control protocol (LACP)
l      Manual aggregation
l      Static aggregation
11 Port Isolation
Port isolation group
12 Port Security-Port Binding
l      Multiple security modes
l      IP address-MAC address-port binding
13 DLDP
Device link detection protocol (DLDP)
14 MAC Address Table Management
l      Manually configuring dynamic, static, and black hole MAC addresses
l      Configuring the aging time for MAC addresses
l      MAC address learning limit
l      Disabling ports in a VLAN from learning MAC addresses
15 MSTP
l      STP/RSTP/MSTP
l      Private MSTP path cost standard
16 Multicast
Internet group management protocol snooping (IGMP Snooping) v2&v3
17 802.1x-System Guard
l      802.1X authentication
l      System guard
l      Huawei authentication bypass protocol (HABP)
l      Quick EAD Deployment
18 AAA
l      Authentication, authorization, and accounting (AAA)
l      Remote authentication dial-In user service (RADIUS)
l      Huawei terminal access controller access control system (HWTACACS)
l      Endpoint Admission Defense(EAD)
19 MAC Address Authentication
MAC address authentication
20 ARP
l      Gratuitous ARP
l      Manually configuring ARP entries
21 DHCP
l      DHCP Client
l      DHCP Snooping
l      Using Option82 in DHCP Snooping
22 ACL
l      Basic/Advanced ACLs
l      Layer 2 ACLs
23 QoS-QoS Profile
l      Quality of Service (QoS)
l      QoS Profile
24 Mirroring
l      Local port mirroring
l      Remote port mirroring
25 Stack-Cluster
l      Huawei Group Management Protocol (HGMP) v2
l      Neighbor discovery protocol (NDP)
l      Neighbor topology discovery protocol (NTDP)
l      Stack
26 SNMP-RMON
l      Simple network management protocol (SNMP) v3, compatible with SNMP v1/v2
l      Remote monitoring (RMON)
27 NTP
l      Network time protocol (NTP)
28 SSH
l      SSH1
l      SSH2
l      Operating as an SSH (Secure Shell) server/SSH client
29 File System Management
l      File system management
l      File attribute configurable
30 FTP-SFTP-TFTP
l      Operating as an FTP server/FTP client
l      Operating as an SFTP server/SFTP client
l      Operating as a TFTP client
31 Information Center
l      System logs
l      Hierarchical alarms
l      Debugging information output
32 System Maintenance and Debugging
l      Configuring system time
l      Displaying and configuring system device state
33 VLAN-VPN
l      VLAN-VPN (QinQ)
l      VLAN Mapping
l      Configuring TPID value
l      Configuring BPDU Tunnel
l      Selective QinQ
34 HWPing
HWPing
35 IPv6 Management
l      Supporting IPv6 address
l      IPv6-based Ping, Traceroute, TFTP, and Telnet
36 DNS
l      Static Domain Name System (DNS)
l      Dynamic DNS
37 Smart Link-Monitor Link
l      Smart Link
l      Monitor Link
The S3100 series can be flexibly deployed in networks. They can be used in enterprise networks, or serve as broadband access points. The following examples are three typical networks using the S3100 series.
In a metropolitan area network (MAN), the S3100 series can serve as access devices. In the downlink direction, they directly connect to users through 100 Mbps interfaces; and in the uplink direction, they connect to an aggregation layer (Layer 3) switches or MA5200 intelligent service gateways, which further connect to the core of the MAN through routers. This provides you a comprehensive gigabit-to-backbone 100-Mbps-to-desktop MAN solution.
Figure 4-1 Network diagram for a MAN using S3100 series
In a campus network, the S3100 series can serve as desktop switching devices at the access layer. They directly connect to users in education buildings through 100 Mbps downlink interfaces; and connect to the core switch in the campus through a 1000 Mbps uplink interface; the core switch further connects to the education network through a router. This enables the users in the campus to exchange information and share resources in the scope of the education network.
Figure 4-2 Network diagram for an education network using S3100 series
With development of various application technologies, enterprise users are increasingly relying on network services. They hope the networks can offer secure, reliable leased lines, VOIP and video conference services, thus reducing their operating costs. Additionally, apart from simple Internet surfing, individual users expect more abundant services from the networks, e.g., IPTV, video chatting, real-time gaming, etc. Meanwhile, construction of the NGN/3G carrier network will draw huge attention of carriers. If NGN/3G services can be carried on the broadband access network, the costs of the entire network solution can be lowered dramatically.
To carry such services with different QOS requirements, the broadband access network needs to have effective service identification and isolation capacity. VLAN is the best service identification and isolation technology at present, and is the basis for multi-service deployment. As broadband users increase explosively and services appear continuously, however, the traditional VLAN technology cannot meet the requirements of service deployments. In this situation, QinQ, VLAN mapping, etc become new choices.
The figure below shows a typical application: The IPTV service requires that the DSLAM be moved downwards into the campus to enhance users’ access bandwidth. S3100 acts as the DSLAM convergence switch. Selective QinQ is configured on the device, with the service VLAN identifying the DSLAM or the campus position and the customer VLAN identifying the customer. In this way, carriers can implement uniform planning and precise management: VLAN layout is simple, and is not affected by the customer side.
Figure 4-3 DSLAM convergence application
Another more complicated configuration example is when the LAN is connected to dense Home Gateways (HG). Generally, the ex-factory setting of an HG is simple as it uses a fixed VLAN tag to identify the attached service type (data service, IPTV, etc). Thus, precise division and management for users and services can be implemented. And VLAN mapping is then implemented on the access device S3100. In this way, respective service VLANs are “translated” into the VLANs that comply with the carrier’s deployment. In addition, QinQ is used on the upstream device to identify the campus position. Such uniform configuration implements carriers’ precise PUPSPV (respective users and respective services use their own VLANs) management.
Figure 4-4 New vlan management scheme
