- H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
- 00-1Cover
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-IP Address and Performance Configuration Command
- 06-Management VLAN Command
- 07-Voice VLAN Command
- 08-GVRP Command
- 09-Port Basic Configuration Command
- 10-Link Aggregation Command
- 11-Port Isolation Command
- 12-Port Security-Port Binding Command
- 13-DLDP Command
- 14-MAC Address Table Command
- 15-Auto Detect Command
- 16-MSTP Command
- 17-Routing Protocol Command
- 18-Multicast Command
- 19-802.1x Command
- 20-AAA-RADIUS-HWTACACS-EAD Command
- 21-VRRP Command
- 22-Centralized MAC Address Authentication Command
- 23-ARP Command
- 24-DHCP Command
- 25-ACL Command
- 26-QoS-QoS Profile Command
- 27-Web Cache Redirection Command
- 28-Mirroring Command
- 29-IRF Fabric Command
- 30-Cluster Command
- 31-PoE-PoE Profile Command
- 32-UDP Helper Command
- 33-SNMP-RMON Command
- 34-NTP Command
- 35-SSH Terminal Service Command
- 36-File System Management Command
- 37-FTP and TFTP Command
- 38-Information Center Command
- 39-System Maintenance and Debugging Command
- 40-VLAN-VPN Command
- 41-HWPing Command
- 42-DNS Command
- 43-Access Management Command
- 44-Appendix
30-Cluster Command | 226 KB |
Chapter 1 HGMP V2 Configuration Commands
1.1 NDP Configuration Commands
1.2 NTDP Configuration Commands
1.2.2 display ntdp device-list
1.3 Cluster Configuration Commands
1.3.9 cluster-mac syn-interval
1.3.12 display cluster candidates
1.3.13 display cluster members
1.3.20 nm-interface Vlan-interface
1.1.1 display ndp
display ndp [ interface port-list ]
View
Parameter
interface port-list: Specifies a port list. The list can contain consecutive or separated ports, or the combination of the both. You need to provide the port-list argument in the form of interface-type interface-number [ to interface-type interface-number ] &<1-10>, where interface-type specifies the port type, and interface-number specifies the port number (in the form of unit ID/slot number/port number). to is used to specify a port range. &<1-10> means that you can provide up to ten port indexes/port index ranges for this argument.
Use the display ndp command to display all NDP configuration and operating information, including the global NDP status, the interval to send NDP packets, the holdtime of NDP information, and the NDP status and neighbor information on all ports.
Use the display ndp interface command to display NDP configuration and operating information on specified ports.
Example
# Display all NDP configuration and operating information.
Neighbor Discovery Protocol is enabled.
Neighbor Discovery Protocol Ver: 1, Hello Timer: 60(s), Aging Timer: 180(s)
Interface: Ethernet1/0/1
Status: Enabled, Pkts Snd: 15835, Pkts Rvd: 2879, Pkts Err: 0
Interface: Ethernet1/0/2
Status: Enabled, Pkts Snd: 0, Pkts Rvd: 0, Pkts Err: 0
Interface: Ethernet1/0/3
Interface: Ethernet1/0/4
Status: Enabled, Pkts Snd: 10362, Pkts Rvd: 10360, Pkts Err: 0
Interface: Ethernet1/0/5
Interface: Ethernet1/0/6
Interface: Ethernet1/0/7
Interface: Ethernet1/0/8
Interface: Ethernet1/0/9
Interface: Ethernet1/0/10
Interface: Ethernet1/0/11
Interface: Ethernet1/0/12
Interface: Ethernet1/0/13
Interface: Ethernet1/0/14
# Display NDP information about Ethernet1/0/1.
<aaa_0.H3C> display ndp interface Ethernet 1/0/1
Neighbor 1: Aging Time: 147(s)
MAC Address : 00e0-fc00-3600
Port Name : Ethernet1/0/1
Software Ver: V100R002B01D001
Device Name : H3C S3628
Port Duplex : AUTO
Product Ver : 3600-001
Table 1-1 Description on the fields of the two commands
Neighbor Discovery Protocol is enabled |
NDP is enabled globally on this switch. |
Neighbor Discovery Protocol Ver: 1 |
NDP version 1 is running. |
Hello Timer |
Interval for this switch to send NDP packets |
Aging Timer |
Holdtime for neighbors to keep the NDP information of this switch |
Port index, used to identify a port |
Status |
Enable/disable status of NDP on the port |
Pkts Snd: |
Number of NDP packets sent by the port |
Pkts Rvd: |
Number of NDP packets received by the port |
Pkts Err: |
Number of error NDP packets received by the port |
Neighbor 1: Aging Time |
Holdtime for this switch to keep the NDP information of the neighbor connected to the port |
MAC Address |
MAC address of the neighbor device |
Port name |
Port name of the neighbor device |
Software Ver |
Software version of the neighbor device |
Device Name |
Device name of the neighbor device |
Port Duplex |
Port (full/half) duplex mode of the neighbor device |
Product Ver |
Product version of the neighbor device |
1.1.2 ndp enable
ndp enable [ interface port-list ]
undo ndp enable [ interface port-list ]
View
System view, Ethernet port view
Parameter
In system view:
Use the ndp enable command to enable NDP globally.
Use the undo ndp enable command to disable NDP globally.
When you execute the ndp enable command in system view without the interface keyword, NDP is enabled globally; when you do this with the interface keyword, NDP is enabled on specified ports.
In Ethernet port view:
Use the ndp enable command to enable NDP on the current port.
Use the undo ndp enable command to disable NDP on the port.
When using this command in Ethernet port view, you are not allowed to input the interface keyword and NDP is enabled on the current port only.
By default, NDP is enabled both globally and on ports.
Note that, unless NDP is enabled globally, it does not take effect on a port even when it is enabled on the port.
Example
# Enable NDP globally.
<H3C> system-view
[H3C] ndp enable
1.1.3 ndp timer aging
ndp timer aging aging-in-seconds
undo ndp timer aging
View
Parameter
aging-in-seconds: Holdtime of the NDP information sent by this device, ranging from 5 to 255 seconds.
Use the ndp timer aging command to set the holdtime of the NDP information sent by this switch. This command specifies how long receiving devices should hold the NDP neighbor information received from this device before discarding the information.
Use the undo timer aging command to restore the default holdtime of NDP information.
By default, the holdtime of NDP information is 180 seconds.
You can specify how long the adjacent devices should hold the NDP information received from this device. When an adjacent device receives a NDP packet from this device, it learns how long it should keep the NDP information of this device according to the holdtime carried in the NDP packet, and discards the NDP information when the holdtime expires.
Note that NDP information holdtime should be longer than the interval to send NDP packets. Otherwise, NDP port neighbor table will become unstable.
Example
# Set the holdtime of the NDP information sent by this switch to 60 seconds.
<H3C> system-view
[H3C] ndp timer aging 60
1.1.4 ndp timer hello
ndp timer hello timer-in-seconds
undo ndp timer hello
View
Parameter
timer-in-seconds: Interval to send NDP packets, ranging from 5 to 254 seconds.
Use the ndp timer hello command to set the interval to send NDP packets.
Use the undo ndp timer hello command to restore the default interval.
By default, this interval is 60 seconds.
The NDP information hold on neighbors for this device should be updated regularly to reflect this device's changes in real time. You can use the ndp timer hello command to adjust the frequency in which neighbors update the NDP information of this device.
Example
# Set the interval to send NDP packets to 80 seconds.
[H3C] ndp timer hello 80
1.1.5 reset ndp statistics
reset ndp statistics [ interface port-list ]
View
Parameter
Use the reset ndp statistics command to clear NDP statistics.
Example
# Clear NDP statistics.
<H3C> reset ndp statistics
1.2.1 display ntdp
display ntdp
View
Parameter
None
Use the display ntdp command to display the global NTDP information.
The displayed information includes topology collection range (hop count), topology collection interval (NTDP timer), device/port forward delay of topology collection requests, and time used by the last topology collection.
Example
# Display the global NTDP information.
NTDP is running.
Hops : 4
Timer : 0 min(disable)
Hop Delay : 100 ms
Port Delay: 10 ms
Last collection total time: 92ms
Table 1-2 Description on the fields of the display ntdp command
NTDP is running. |
NTDP is enabled globally on this device. |
Hops |
Hop count for topology collection |
Timer |
Interval to collect topology information "disable" means this switch is not a management device and does not perform periodic topology collection. |
Hop Delay |
Delay for other devices to forward topology collection requests |
Port Delay |
Delay for ports on other devices to forward topology collection requests |
Last collection total time |
Time used by the last topology collection |
display ntdp device-list [ verbose ]
View
Parameter
verbose: Displays detailed device information.
Use the display ntdp device-list command to display the device information collected by NTDP.
Example
# Display the list of devices collected by NTDP.
<H3C> display ntdp device-list
MAC HOP IP PLATFORM
00e0-fc00-3901 0 100.100.1.1/24 S3600
00e0-fc00-3190 1 16.1.1.1/24 S3600
Table 1-3 Description on the fields of the display ntdp device-list command
MAC |
MAC address of a device collected by NTDP |
HOP |
Hops from this device to the collected device |
IP |
IP address and mask length of the management VLAN interface on the collected device |
PLATFORM |
Platform information about the collected device |
# Display detailed device information collected by NTDP.
<H3C> display ntdp device-list verbose
Hostname : H3C
MAC : 00e0-fc00-3600
Hop : 0
Platform : S3600
IP : 100.100.1.1/24
Version :
H3C Comware Platform Software
Comeware Software, Version 3.10
Copyright(c)2004-2007 Hangzhou H3C Technologies Co.,Ltd. All rights reserved.
S3600 3600-0002
Cluster : Candidate switch
Peer MAC Peer Port ID Native Port ID Speed Duplex
00e0-fc00-3190 Ethernet1/0/22 Ethernet3/0/21 100 FULL
Hostname : 3600-3
MAC : 00e0-fc00-3190
Hop : 1
Platform : S3600
IP : 16.1.1.1/24
Version :
S3600 3600-0002
00e0-fc00-3600 Ethernet3/0/21 Ethernet1/0/22 100 FULL
5600-0000-3334 GigabitEthernet1/0/32 Ethernet1/0/4 100 FULL
Table 1-4 Description on the fields of the display ntdp device-list verbose command
Hostname |
System name of a device collected by NTDP |
MAC |
MAC address of the collected device |
Hop |
Platform |
Software platform of the collected device |
IP |
IP address and mask length of the cluster management VLAN interface on the collected device |
Version |
Software version of the collected device |
Cluster |
The role of the collected device for the cluster |
Peer MAC |
MAC address of a neighbor device connected to the collected device |
Peer Port ID |
Index of the port on the neighbor device connected to the collected device |
Native Port ID |
Index of the port on the collected device connected to the neighbor device |
Speed |
Speed of the neighbor device port |
Duplex |
Duplex mode of the neighbor device port |
1.2.3 ntdp enable
ntdp enable
undo ntdp enable
View
Parameter
None
In system view:
Use the ntdp enable command to enable NTDP globally.
Use the undo ntdp enable command to disable NTDP globally.
Use the ntdp enable command to enable NTDP on the current port.
Use the undo ntdp enable command to disable NTDP on the current port.
By default, NTDP is enabled both globally and on ports.
Note that even when NTDP is enabled on a port, it cannot operate on the port if NDP is disabled on the port.
Example
# Enable NTDP globally.
[H3C] ntdp enable
1.2.4 ntdp explore
ntdp explore
View
Parameter
None
Use the ntdp explore command to manually start a topology collection process.
NTDP is able to periodically collect topology information. In addition, you can use this command to manually start a topology collection process at any moment. If you do this, NTDP collects NDP information from all devices in a specific network range as well as the connection information of all its neighbors. Through this information, the management device or the network management software knows the topology in the network range, and thus it can manage and monitor the devices in the range.
Example
# Start a topology collection process.
<H3C> ntdp explore
1.2.5 ntdp hop
ntdp hop hop-value
undo ntdp hop
View
Parameter
hop-value: Maximum hops to collect topology information, ranging from 1 to 16.
Use the ntdp hop command to set the topology collection range.
Use the undo ntdp hop command to restore the default topology collection range.
By default, the topology collection range is three hops.
With the ntdp hop command, you can specify to collect topology information from the devices within a specified range to avoid infinite collection. That is, you can limit the range of topology collection by setting the maximum hops from the collecting device to the collected devices. For example, if you set the maximum hops to two, the switch initiating the topology collection collects topology information from the switches within two hops.
Note that this command is only applicable to topology-collecting device, and a wider collection range requires more memory of the topology-collecting device.
Example
# Set the topology collection range to 5 hops.
[aaa_0.H3C] ntdp hop 5
1.2.6 ntdp timer
ntdp timer interval-in-minutes
undo ntdp timer
View
Parameter
interval-in-minutes: Interval (in minutes) to collect topology information, ranging from 0 to 65,535. Value 0 of this argument specifies not to perform periodic topology collection.
Use the ntdp timer command to configure the interval to collect topology information periodically.
Use the undo ntdp timer command to restore the default interval.
By default, this interval is one minute.
After the interval is set to a non-zero value, the switch will collect topology information periodically at this interval.
Note that:
l If the display ntdp command displays "disable" in the Timer field, it means this device is not a management device and will not perform periodic topology collection.
l After a cluster is set up on an S3600 series switch, the switch will collect the topology information of the network at the topology collection interval you set and automatically add the candidate devices it discovers into the cluster.
l If you do not want the candidate switches to be automatically added into the cluster, you can set the topology collection interval to zero.
Example
# Set the topology collection interval to 30 minutes.
[aaa_0.H3C] ntdp timer 30
1.2.7 ntdp timer hop-delay
ntdp timer hop-delay time
undo ntdp timer hop-delay
View
Parameter
time: Device forward delay in milliseconds. This argument ranges from 1 to 1,000.
Use the ntdp timer hop-delay command to set the delay for collected devices to forward topology collection requests through their first port.
Use the undo ntdp timer hop-delay command to restore the default device forward delay.
By default, the device forward delay is 200 ms.
Network congestion may occur if large amount of topology response packets reach the collecting device in a short period. To avoid this case, each collected switch in the network delays for a period before it forwards a received topology collection request through the first forwarding port. You can use the ntdp timer hop-delay command to set the delay.
You can use the command on a collecting switch. The delay value you set by the ntdp timer hop-delay command is carried in the topology collection requests sent by the collecting switch, and is used by collected devices to determine how long they should wait before they can forward the received topology collection requests through their first port.
Example
# Set the delay for collected switches to forward topology collection requests through their first port to 300 ms.
[aaa_0.H3C] ntdp timer hop-delay 300
1.2.8 ntdp timer port-delay
ntdp timer port-delay time
undo ntdp timer port-delay
View
Parameter
time: Port forward delay in milliseconds. This argument ranges from 1 to 100.
Use the ntdp timer port-delay command to set the delay for collected switches to forward topology collection requests through the next port.
Use the undo ntdp timer port-delay command to restore the default port forward delay.
By default, the port forward delay is 20 ms.
Network congestion may occur if large amount of topology response packets reach the collecting device in a short period. To avoid this case, after a collected switch forwards a received topology collection request through a port, it delays for a period before it forwards the request through the next port. You can use the ntdp timer port-delay command to set the delay.
You can use the command on a collecting switch. The delay value you set by the ntdp timer port-delay command is carried in the topology collection requests sent by the collecting switch, and is used by collected devices to determine how long they should wait before they forward the received topology collection requests through the next port.
Example
# Set the delay for collected switches to forward topology collection requests through the next port to 40 ms.
<aaa_0.H3C> system-view
[aaa_0.H3C] ntdp timer port-delay 40
1.3.1 add-member
add-member [ member-number ] mac-address H-H-H [ password password ]
View
Cluster view
Parameter
member-number: Member number assigned to the candidate device to be added to the cluster. This argument ranges from 1 to 255.
H-H-H: MAC address of the candidate device to be added (in hexadecimal).
password: Password of the candidate device, a string of 1 to 256 characters. Password authentication is required when you add a candidate device to a cluster unless the candidate device is not configured with a password (in this case, you need not input this argument).
Use the add-member command to add a candidate device to the cluster.
You can only use this command on the management device of a cluster.
If you do not specify the member number when adding a new cluster member, the management device assigns the next available member number to the new member.
After you add a candidate device to the cluster, the password of the device automatically changes to the management device password.
Note that, after a cluster is set up on an S3600 series switch, the switch will collect the topology information of the network at the topology collection interval you set and automatically add the candidate devices it discovers into the cluster. If you do not want the candidate switches to be automatically added into the cluster, you can set the topology collection interval to zero (by the ntdp timer command), which specifies not to perform periodic topology collection.
Example
# Add a candidate device to the cluster, setting the member number to 6. (Assume that the MAC address and user password of the candidate device are 00E0-fc00-35e7 and 123456 respectively.)
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] add-member 6 mac-address 00E0-fc00-35e7 password 123456
1.3.2 administrator-address
administrator-address mac-address name name
undo administrator-address
View
Cluster view
Parameter
mac-address: MAC address of the management device to be set.
name: Name of an existing cluster, a string of up to 8 characters, which can only be alphanumeric characters, minus signs (-), and underscores (_).
Use the administrator-address command to add a device to a cluster by setting the management device MAC address and cluster name of a cluster on the device.
Use the undo administrator-address command to remove a member device from the cluster.
The commands here are generally used for debugging and restore purpose.
By default, a switch does not belong to any cluster.
A cluster has one and only one management device. After you set the MAC address of the management device on a member device, the member device is still able to identify the management device after system reboot.
It is recommended to use the delete-member command to remove a member from a cluster on the management device.
Example
# Remove a member device from the cluster.
[aaa_1.H3C] cluster
[aaa_1.H3C-cluster] undo administrator-address
1.3.3 auto-build
auto-build [ recover ]
View
Cluster view
Parameter
recover: Recovers all member devices automatically.
Use the auto-build command to start an automatic cluster building process.
You can execute this command on a candidate device as well as on a management device.
When you execute this command on a candidate device, you are prompted to enter a cluster name to build a cluster. Then, the system automatically collects candidate devices and adds them to the cluster.
When you execute this command on a management device, the system directly collects candidate devices ant automatically adds them to the cluster.
The recover keyword is used to recover a cluster. After you execute the auto-build recover command, the system looks for the down members in the member list and add them to the cluster again.
Note that, the collection of candidate/member devices are based on NTDP. So you must first enable NTDP. In addition, you can use the ntdp hop command in system view to change the collection range.
When the system automatically adds a device to the cluster, if the user password configured for the device is different from that of the management device, the device will not be successfully added to the cluster.
& Note:
l After a cluster is built automatically, ACL 3998 and ACL 3999 will be generated automatically.
l After a cluster is built automatically, ACL 3998 and ACL 3999 can neither be configured/modified nor removed.
Example
# Start an automatic cluster building process.
<H3C> system-view
[H3C] cluster
[H3C-cluster] auto-build
Please input cluster name:aaa
Collecting candidate list, please wait...
Candidate list:
Name Hops MAC Address Device
Processing...please wait
Cluster auto-build Finish!
0 member(s) added successfully.
[aaa_0.H3C-cluster]
1.3.4 build
build name
undo build
View
Cluster view
Parameter
name: Name to be set for the cluster, a string of up to 8 characters, which can only be alphanumeric characters, minus signs (-), and underscores (_).
Use the build command to build a cluster with a cluster name or change the cluster name.
Use the undo build command to remove the cluster.
You can use this command on a candidate device as well as on a management device.
Executing the build command on a candidate device will change the device to a management device and assign a name to the cluster created on the device.
Executing the build command on a management device will change the cluster name of the management device.
The member number of a management device is 0.
& Note:
To reduce the risk of being attacked by malicious users against opened socket and enhance switch security, the S3600 series Ethernet switches provide the following functions, so that a cluster socket is opened only when it is needed:
l Opening UDP port 40000 (used for cluster) only when the cluster function is implemented,
l Closing UDP port 40000 at the same time when the cluster function is closed.
On the management device, the preceding functions are implemented as follows:
l When you create a cluster by using the build or auto-build command, UDP port 40000 is opened at the same time.
l When you remove a cluster by using the undo build or undo cluster enable command, UDP port 40000 is closed at the same time.
On member devices, the preceding functions are implemented as follows:
l When you execute the add-member command on the management device to add a candidate device to a cluster, the candidate device changes to a member device and its UDP port 40000 is opened at the same time.
l When you execute the auto-build command on the management device to have the system automatically add candidate devices to a cluster, the candidate devices change to member devices and their UDP port 40000 is opened at the same time.
l When you execute the administrator-address command on a device, the device's UDP port 40000 is opened at the same time.
l When you execute the delete-member command on the management device to remove a member device from a cluster, the member device's UDP port 40000 is closed at the same time.
l When you execute the undo build command on the management device to remove a cluster, UDP port 40000 of all the member devices in the cluster is closed at the same time.
l When you execute the undo administrator-address command on a member device, UDP port 40000 of the member device is closed at the same time.
Example
# Configure the current switch as a management device and set the cluster name to aaa.
[H3C] cluster
[H3C-cluster] build aaa
1.3.5 cluster
cluster
View
Parameter
None
Use the cluster command to enter cluster view.
Example
# Enter cluster view.
<H3C> system-view
[H3C] cluster
[H3C-cluster]
1.3.6 cluster enable
cluster enable
undo cluster enable
View
Parameter
None
Use the cluster enable command to enable the cluster function.
Use the undo cluster enable command to disable the cluster function.
By default, the cluster function is enabled.
To create a cluster on a device with the build command, you must first execute the cluster enable command.
You can use the two commands on any devices that support the cluster function.
l When you execute the undo cluster enable command on a management device, the cluster and all its members are removed, the device stops operating as a management device, and the cluster function is disabled on the device.
l When you execute the undo cluster enable command on a member device, the device leaves the cluster, and the cluster function is disabled on the device.
l When you execute undo cluster enable command on a device that does not belong to any cluster, the cluster function is disabled on the device.
Example
# Enable the cluster function on a switch.
[H3C] cluster enable
1.3.7 cluster switch-to
cluster switch-to { member-number | mac-address H-H-H | administrator }
View
Parameter
member-number: Member number of a member device, ranging from 1 to 255.
mac-address H-H-H: Specifies the MAC address of a member device.
administrator: Switches back from the member device to the management device.
Use the cluster switch-to command to switch between the management device and a member device for configuration and management.
On the management device, you can switch to the view of a member device to configure and manage the member device, and then switch back to the management device.
Both switching directions (from the management device to a member device, and from a member device to the management device) will use Telnet connection. Switching is performed based on the following rules:
l Both switching directions will perform authentication. In a switching process, the system will authenticate the level-3 super password. If the super password on the device that requests the switching is inconsistent with that on the requested device, the switching fails. When a candidate device joins the cluster, its super password will automatically synchronize to the supper password on the management device. It is recommended not to change the super password of any cluster member or the management device, so as to avoid switching failure resulting from authentication failure.
l After you switch from the management device to a member device, the member device view will inherit the user privilege level of the current management device view.
l After you switch from a member device to the management device, the privilege level on the management device view will be determined by the configuration on the management device.
l If all the Telnet resources on the requested device are used up, the switching to the device will not succeed.
When you execute this command on the management device with an inexistent member number or a MAC address that is not in the member list, an error will occur. In this case, you can enter quit to end the switching.
Example
# Switch from the management device to number-6 member device and then switch back to the management device.
<aaa_0.H3C> cluster switch-to 6
<aaa_6.H3C> quit
<aaa_0.H3C>
1.3.8 cluster-mac
cluster-mac H-H-H
undo cluster-mac
View
Cluster view
Parameter
H-H-H: Multicast MAC address to be set for the cluster, in hexadecimal format. This argument can be one of the following addresses: 0180-C200-0000, 0180-C200-000A, 0180-C200-0020 to 0180-C200-002F.
Use the cluster-mac command to configure a multicast MAC address for the cluster.
Use the undo cluster-mac command to restore the default multicast MAC address.
The default multicast MAC address is 0180-C200-000A.
Note that, you can only use this command on a management device.
The management device in a cluster is able to periodically broadcast HGMP V2 multicast MAC synchronization packets. After you configure a multicast MAC address on the management device, all the member/candidate devices of the cluster will synchronize to the same multicast MAC address by receiving multicast MAC synchronization packets. This guarantees that the member/candidate devices of the cluster can receive the multicast packets from the management device.
Example
# Configure multicast MAC address 0180-C200-0028 for the cluster.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] cluster-mac 0180-C200-0028
cluster-mac syn-interval time-interval
View
Cluster view
Parameter
time-interval: Interval to send HGMP V2 multicast MAC synchronization packets, ranging from 0 to 30 minutes.
Use the cluster-mac syn-interval command to set the interval for the management device to send HGMP V2 multicast MAC synchronization packets periodically. You can only use this command on a management device.
If you set this interval to zero on a management device, the management device will not send HGMP V2 multicast MAC synchronization packets to other devices.
Example
# Set the interval for the management device to send HGMP V2 multicast MAC synchronization packets to one minute.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] cluster-mac syn-interval 1
1.3.10 delete-member
delete-member member-number
View
Cluster view
Parameter
Use the delete-member command to remove a member device from the cluster.
You can only perform the operation on a management device. Otherwise, error will occur.
Example
# Remove number-2 member device from the cluster.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] delete-member 2
1.3.11 display cluster
display cluster
View
Parameter
None
Use the display cluster command to display the status and statistics information of the cluster to which the current switch belongs.
Executing this command on a member device will display the following information: cluster name, member number of the current switch, MAC address and status of the management device, holdtime, and interval to send handshake packets.
Executing this command on a management device will display the following information: cluster name, number of the member devices in the cluster, cluster status, holdtime, and interval to send handshake packets.
Executing this command on a device that does not belong to any cluster will display an error.
Example
# Display cluster information on a management device.
<aaa_0.H3C-cluster> display cluster
Cluster name:"aaa"
Role:Administrator
Management-vlan:100
Handshake timer:10 sec
Handshake hold-time:60 sec
IP-Pool:20.1.1.1/24
cluster-mac:0180-c200-000a
No logging host configured
No SNMP host configured
No FTP server configured
No TFTP server configured
3 member(s) in the cluster, and 0 of them down.
# Display cluster information on a member device.
[aaa_2.3600-3] display cluster
Cluster name:"aaa"
Role:Member
Member number:2
Management-vlan:100
Administrator device mac address:00e0-fc00-3901
Administrator status:Up
Table 1-5 Description on the fields of the display cluster command
Cluster name |
Name of the cluster |
Role |
Role of this switch |
Member number |
Member number of this switch |
Handshake timer |
Interval to send handshake packets |
Handshake hold-time |
Holdtime |
Administrator device mac address |
MAC address of the management device |
Administrator status |
Status of the management device |
display cluster candidates [ mac-address H-H-H | verbose ]
View
Parameter
mac-address H-H-H: Specifies the MAC address of a candidate device.
verbose: Displays detailed information about candidate devices.
Use the display cluster candidates command to display information about one specified or all candidate devices of a cluster.
Note that, after a cluster is set up on an S3600 series switch, the switch will collect the topology information of the network at the topology collection interval you set and automatically add the candidate devices it discovers into the cluster. As a result, if the topology collection interval is too short (the default interval is 1 minute), the switches acting as candidate devices will not keep in candidate state for a long time – they will change to member devices within a short time. If you do not want the candidate switches to be automatically added into the cluster, you can set the topology collection interval to zero (by using the ntdp timer command), which specifies not to perform topology collection periodically.
Example
# Display information about all candidate devices.
<aaa_0.H3C-cluster> display cluster candidates
MAC HOP IP PLATFORM
3600-0000-3334 2 16.1.1.11/24 S3600
Table 1-6 Description on the fields of the display cluster candidates command
MAC |
MAC address of a candidate device |
Hop |
Hops from the management device to the candidate device |
IP |
IP address of the candidate device |
Platform |
Platform of the candidate device |
# Display information about a specified candidate device.
<aaa_0.H3C-cluster> display cluster candidates mac-address 00e0-fc00-3190
Hostname : 3600-3
Hop : 1
Platform : S3600
IP : 16.1.1.1/24
# Display information about all candidate device.
[aaa_0.H3C-cluster] display cluster candidates verbose
Hostname : H3C
MAC : 3600-0000-3334
Hop : 2
Platform : S3600
IP : 16.1.1.11/24
Hostname : 3600-3
Hop : 1
Platform : S3600
IP : 16.1.1.1/24
Table 1-7 Description on the fields of the display cluster candidates verbose command
Hostname |
Name of a candidate device |
MAC |
MAC address of the candidate device |
Hop |
IP |
Platform |
display cluster members [ member-number | verbose ]
View
Parameter
member-number: Member number of a device, ranging from 0 to 255.
verbose: Displays detailed information about all the devices in a cluster.
Use the display cluster members command to display information about one specific or all devices in a cluster.
Example
# Display information about all devices in a cluster.
<aaa_0.H3C-cluster> display cluster members
SN Device MAC Address Status Name
0 S3600 00e0-fc00-3901 Admin aaa_0.H3C
1 S3600 3600-0000-3334 Up aaa_1.H3C
2 S3600 00e0-fc00-3190 Up aaa_2.3600-3
Table 1-8 Description on the fields of the display cluster members command
SN |
Member number of a device in the cluster |
Device |
Device type |
MAC Address |
Device MAC address |
Status |
Device status |
Name |
Device name |
# Display detailed information about all devices in a cluster.
<aaa_0.H3C-cluster> display cluster members verbose
Member number:0
Device:S3600
MAC Address:00e0-fc00-3901
Member status:Admin
Hops to administrator device:0
IP: 100.100.1.1/24
Version:
S3600 3600-0002
Member number:1
Device:S3600
MAC Address:3600-0000-3334
Member status:Up
Hops to administrator device:2
IP: 16.1.1.11/24
Version:
S3600 3600-0002
Member number:2
Device:S3600
MAC Address:00e0-fc00-3190
Member status:Up
Hops to administrator device:1
IP: 16.1.1.1/24
Version:
S3600 3600-0002
Table 1-9 Description on the fields of the display cluster members verbose command
Member number |
Name |
Device name |
Device |
Device type |
MAC Address |
Member status |
Device status |
Hops to administrator device |
Hops from the device to the management device |
IP |
Device IP address |
Version |
Software version of the device |
1.3.14 ftp cluster
ftp cluster
View
Parameter
None
Use the ftp cluster command to connect to the shared FTP server of the cluster and enter FTP Client view.
Example
# Connect to the remote FTP server shared by the cluster.
<123_1.H3C> ftp cluster
Trying ...
Press CTRL+K to abort
Connected.
220 FTP service ready.
User(none):hello
331 Password required for hello.
Password:
230 User logged in.
1.3.15 ftp-server
ftp-server ip-address
undo ftp-server
View
Cluster view
Parameter
ip-address: IP address of the FTP server to be configured for the cluster.
Use the ftp-server command to configure a shared FTP server for the cluster on the management device.
Use the undo ftp-server command to remove the shared FTP server setting.
By default, the management device acts as the shared FTP server.
After setting the IP address of an FTP server for the cluster, the member devices in the cluster can access the FTP server through the management device.
Example
# Configure FTP server 1.0.0.9 on the management device of a cluster.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] ftp-server 1.0.0.9
1.3.16 holdtime
holdtime seconds
undo holdtime
View
Cluster view
Parameter
seconds: Holdtime in seconds, ranging from 1 to 255.
Use the holdtime command to configure the holdtime of member switches.
Use the undo holdtime command to restore the default holdtime value.
By default, the holdtime is 60 seconds.
l If the management switch does not receive any information from a member device within the holdtime, it sets the status of the member device to “down”. When the communication between the two devices resumes, the member device will be re-added to the cluster automatically.
l If the downtime of a member device does not exceed the holdtime, the member device stays in the normal state and does not need to be added again.
Note that, you need only execute the command on a management device, which will advertise the holdtime value to all member devices in the cluster.
Example
# Set the holdtime to 30 seconds on a management device.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] holdtime 30
1.3.17 ip-pool
ip-pool administrator-ip-address { ip-mask | ip-mask-length }
undo ip-pool
View
Cluster view
Parameter
administrator-ip-address: IP address for the device to be set as the management device of a cluster.
ip-mask: Mask of the cluster IP address pool.
ip-mask-length: Mask length of the cluster IP address pool.
Use the ip-pool command to configure a private IP address pool on the switch to be set as the management device. After the switch becomes a management device, it can assign the IP addresses in this pool to its member devices.
Use the undo ip-pool command to cancel the IP address pool configuration.
Before creating a cluster on a device, you must first configure a private IP address pool on the device. When a candidate device joins a cluster, the management device dynamically assigns a private IP address in the pool to it, so that the candidate device can communicate with other devices in the cluster. This enables the management device to manage and maintain member devices in the cluster.
Note that, you can only execute the command on a device that does not belong to any cluster. After a cluster is created on a device, you will not be able to change the IP address pool on it.
Example
# Configure a private IP address pool for a cluster.
[H3C] cluster
[H3C-cluster] ip-pool 10.200.0.1 20
1.3.18 logging-host
logging-host ip-address
undo logging-host
View
Cluster view
Parameter
ip-address: IP address of the logging host to be configured for the cluster.
Use the logging-host command to configure a shared logging host for the cluster on the management device.
Use the undo logging-host command to remove the shared logging host setting.
By default, no shared logging host is configured.
After setting the IP address of a logging host for the cluster, the member devices in the cluster can send logs to the logging host through the management device.
Example
# Configure logging host 10.10.10.9 on the management device of a cluster.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] logging-host 10.10.10.9
1.3.19 management-vlan
management-vlan vlan-id
undo management-vlan
View
Parameter
vlan-id: ID of the VLAN to be specified as the management VLAN.
Use the management-vlan command to specify the management VLAN on the switch.
Use the undo management-vlan command to restore the default management VLAN.
By default, VLAN 1 is used as the management VLAN.
When specifying the management VLAN, note that:
l The management VLANs on all the devices in a cluster must be the same.
l You can specify the management VLAN on a device only when no cluster is created on the device. You cannot change the management VLAN on a device that already joins a cluster. If you want to change the management VLAN on a device where a cluster has already been created, you must first remove the cluster configuration on the device, then re-specify a VLAN as the management VLAN, and finally re-created the cluster.
Example
# Specify VLAN 2 as the management VLAN of the current switch.
[H3C] management-vlan 2
nm-interface Vlan-interface vlan-id
View
Cluster view
Parameter
vlan-id: VLAN ID.
Use the nm-interface Vlan-interface command to configure a network management (NM) interface on a management device.
After an NM interface is specified on the management device of a cluster, the network administrator can log onto the management device through the NM interface to manage the devices in the cluster.
& Note:
l By default, the management VLAN interface is used as the NM interface.
l There is only one NM interface on a management device; any newly configured NM interface will overwrite the old one.
Example
# Configure VLAN-interface 2 as the NM interface.
[H3C] cluster
[H3C-cluster] nm-interface Vlan-interface 2
1.3.21 reboot member
reboot member { member-number | mac-address H-H-H } [ eraseflash ]
View
Cluster view
Parameter
mac-address H-H-H: Specifies the MAC address of the member device to be rebooted.
eraseflash: Deletes the configuration file when the member device reboots.
Use the reboot member command to reboot a specified member device on the management device.
When a member device is in trouble due to some configuration errors, you can use the remote control function on the management device to control the member device remotely on the management device. For example, from the management device, you can delete the configuration file on a member device and reboot the member device to recover it to the normal state.
The eraseflash keyword specifies to delete the startup configuration file when the member device reboots.
Example
# Reboot number-2 member device.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] reboot member 2
1.3.22 snmp-host
snmp-host ip-address
undo snmp-host
View
Cluster view
Parameter
ip-address: IP address of a SNMP host to be configured for the cluster.
Use the snmp-host command to configure a shared SNMP host for the cluster on the management device.
Use the undo snmp-host command to remove the shared SNMP host setting.
By default, no shared SNMP host is configured.
After setting the IP address of an SNMP host for the cluster, the member devices in the cluster can send trap messages to the SNMP host through the management device.
Note that, you can only use the commands on a management device.
Example
# Configure SNMP host 1.0.0.9 on the management device of a cluster.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] snmp-host 1.0.0.9
1.3.23 tftp cluster get
tftp cluster get source-file [ destination-file ]
View
Parameter
source-file: Name of the file to be downloaded from the shared TFTP server of the cluster.
destination-file: Name of the file to which the downloaded file will be saved on the switch.
Use the tftp cluster get command to download a file from a specific directory on the shared TFTP server to the switch.
Related command: tftp cluster put.
Example
# Download file LANSwitch.app from the shared TFTP server of the cluster to the switch and save it to file vs.app.
<123_1.H3C> tftp cluster get LANSwitch.app vs.app
1.3.24 tftp cluster put
tftp cluster put source-file [ destination-file ]
View
Parameter
source-file: File to be uploaded to the shared TFTP server.
destination-file: Name of the file to which the uploaded file will be saved in the storage directory of the TFTP server.
Use the tftp put command to upload a file from the switch to a specified directory on the TFTP server.
Related command: tftp cluster get.
Example
# Upload file vrpcfg.txt on the switch to the shared TFTP server of the cluster and save it to file temp.txt.
<123_1.H3C> tftp cluster put vrpcfg.txt temp.txt
1.3.25 tftp-server
tftp-server ip-address
undo tftp-server
View
Cluster view
Parameter
ip-address: IP address of a TFTP server to be configured for the cluster.
Use the tftp-server command to configure a shared TFTP server for the cluster on the management device.
Use the undo tftp-server command to remove the shared TFTP server setting.
By default, no shared TFTP server is configured.
After setting the IP address of a TFTP server for the cluster, the member devices in the cluster can access the TFTP server through the management device.
Example
# Configure TFTP server 1.0.0.9 on the management device of a cluster.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] tftp-server 1.0.0.9
1.3.26 timer
timer interval
undo timer
View
Cluster view
Parameter
interval: Interval (in seconds) to send handshake packets. This argument ranges from 1 to 255.
Use the timer command to set the interval to send handshake packets.
Use the undo timer command to restore the default value of the interval.
By default, the interval to send handshake packets is 10 seconds.
In a cluster, the management device keeps connections with the member devices through handshake packets. Through the periodic handshaking between the management and member devices, the management device monitors the member status and link status.
Note that, you need only execute the command on a management device, which will advertise the handshake interval setting to all member devices in the cluster.
Example
# Set the interval to send handshake packets to 3 seconds.
[aaa_0.H3C] cluster
[aaa_0.H3C-cluster] timer 3
