H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
00-1Cover
00-1Cover 72 KB
Command Manual
Hangzhou H3C Technologies Co., Ltd.
http://www.h3c.com
Manual Version: T2-08192T-20070724-C-1.04
Product Version: Release 1510
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
[email protected]
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3600 Series Ethernet Switches-Release 1510 documentation set includes the following:
Manual
H3C S3600 Series Ethernet Switches  Operation Manual-Release 1510
It is used for assisting the users in data configurations and typical applications.
H3C S3600 Series Ethernet Switches  Installation Manual
It provides information for the system installation.
Organization
H3C S3600 Series Ethernet Switches Command Manual-Release 1510 is organized as follows:
Part
1 CLI
Introduces the commands used for switching between the command levels and command level setting.
2 Login
Introduces the commands used for logging into the Ethernet switch.
3 Configuration File Management
Introduces the commands used for configuration file management.
4 VLAN
Introduces the commands used for configuring VLAN.
5 IP Address and Performance Configuration
Introduces the commands used for IP address configuration and IP performance configuration.
6 Management VLAN
Introduces the commands used for configuring the management VLAN and DHCP/BOOTP client configuration.
7 Voice VLAN
Introduces the commands used for voice VLAN configuration.
8 GVRP
Introduces the commands used for GVRP configuration.
9 Port Basic Configuration
Introduces the commands used for basic port configuration.
10 Link Aggregation
Introduces the commands used for link aggregation.
11 Port Isolation
Introduces the commands used for port isolation.
12 Port Security-Port Binding
Introduces the commands used for port security configuration and port binding.
13 DLDP
Introduces the commands used for DLDP configuration.
14 MAC Address Table
Introduces the commands used for MAC address forwarding table management.
15 Auto Detect
Introduces the commands used for auto detect configuration.
16 MSTP
Introduces the STP-related commands.
17 Routing Protocol
Introduces the commands used for routing protocol configuration.
18 Multicast
Introduces the commands used for multicast configuration.
19 802.1x
Introduces the commands used for 802.1x configuration.
20 AAA-RADIUS-HWTACACS-EAD
Introduces the commands used for AAA, RADIUS, HWTACACS, and EAD configuration.
21 VRRP
Introduces the commands used for VRRP configuration.
22 Centralized MAC Address Authentication
Introduces the commands used for centralized MAC address authentication configuration.
23 ARP
Introduces the ARP-related commands.
24 DHCP
Introduces the commands used for DHCP server, DHCP relay, and DHCP-snooping configuration.
25 ACL
Introduces the ACL-related commands.
26 QoS-QoS Profile
Introduces the commands used for QoS and QoS profile configuration.
27 Web Cache Redirection
Introduces the commands used for Web cache redirection configuration.
28 Mirroring
Introduces the commands used for port mirroring.
29 IRF Fabric
Introduces the commands used for IRF fabric configuration.
30 Cluster
Introduces the commands used for cluster management.
31 PoE-PoE Profile
Introduces the commands used for PoE and PoE profile configuration.
32 UDP Helper
Introduces the commands used for UDP Helper configuration.
33 SNMP-RMON
Introduces the commands used for SNMP and RMON configuration.
34 NTP
Introduces the NTP-related commands.
35 SSH Terminal Service
Introduces the commands used for SSH configuration.
36 File System Management
Introduces the commands used for file system management.
37 FTP and TFTP
Introduces the FTP-/TFTP-related commands.
38 Information Center
Introduces the commands used for information center configuration.
39 System Maintenance and Debugging
Introduces the commands used for system maintenance and debugging.
40 VLAN-VPN
Introduces the commands used for VLAN VPN configuration.
41 HWPing
Introduces the commands used for HWPing configuration.
42 DNS
Introduces the commands used for DNS configuration.
43 Access Management
Introduces the commands used for Access Management configuration
44 Appendix
Lists all the commands described in this command manual in an alphabetic order. The parts and pages where the commands are described are also given.
Conventions
The manual uses the following conventions:
I. Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
A line starting with the # sign is comments.
II. Symbols
Convention
  Warning
Means reader be extremely careful. Improper operation may cause bodily injury.
  Caution
Means reader be careful. Improper operation may cause data loss or damage to equipment.
&  Note
Means a complementary description.
