H3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
HomeSupportSwitchesH3C S3600 Switch SeriesReference GuidesCommand ReferencesH3C S3600 Series Ethernet Switches Command Manual-Release 1510(V1.04)
20-AAA-RADIUS-HWTACACS-EAD Command
20-AAA-RADIUS-HWTACACS-EAD Command 442 KB
Table of Contents
Chapter 1 AAA & RADIUS & HWTACACS Configuration Commands. 1-1
1.1 AAA Configuration Commands. 1-1
1.1.1 access-limit 1-1
1.1.2 accounting. 1-2
1.1.3 accounting optional 1-3
1.1.4 attribute. 1-4
1.1.5 authentication. 1-5
1.1.6 authorization. 1-6
1.1.7 cut connection. 1-7
1.1.8 display connection. 1-8
1.1.9 display domain. 1-10
1.1.10 display local-user 1-12
1.1.11 domain. 1-13
1.1.12 idle-cut 1-14
1.1.13 level 1-15
1.1.14 local-user 1-16
1.1.15 local-user password-display-mode. 1-17
1.1.16 messenger 1-18
1.1.17 name. 1-19
1.1.18 password. 1-20
1.1.19 radius-scheme. 1-21
1.1.20 scheme. 1-21
1.1.21 self-service-url 1-23
1.1.22 service-type. 1-24
1.1.23 state. 1-25
1.1.24 vlan-assignment-mode. 1-26
1.2 RADIUS Configuration Commands. 1-28
1.2.1 accounting optional 1-28
1.2.2 accounting-on enable. 1-28
1.2.3 data-flow-format 1-30
1.2.4 display local-server statistics. 1-31
1.2.5 display radius scheme. 1-32
1.2.6 display radius statistics. 1-34
1.2.7 display stop-accounting-buffer 1-35
1.2.8 key. 1-37
1.2.9 local-server 1-38
1.2.10 local-server nas-ip. 1-38
1.2.11 nas-ip. 1-40
1.2.12 primary accounting. 1-41
1.2.13 primary authentication. 1-42
1.2.14 radius client 1-43
1.2.15 radius nas-ip. 1-43
1.2.16 radius scheme. 1-45
1.2.17 radius trap. 1-46
1.2.18 reset radius statistics. 1-47
1.2.19 reset stop-accounting-buffer 1-47
1.2.20 retry. 1-48
1.2.21 retry realtime-accounting. 1-49
1.2.22 retry stop-accounting. 1-50
1.2.23 secondary accounting. 1-51
1.2.24 secondary authentication. 1-52
1.2.25 server-type. 1-53
1.2.26 state. 1-54
1.2.27 stop-accounting-buffer enable. 1-55
1.2.28 timer 1-56
1.2.29 timer quiet 1-57
1.2.30 timer realtime-accounting. 1-58
1.2.31 timer response-timeout 1-59
1.2.32 user-name-format 1-60
1.3 HWTACACS Configuration Commands. 1-61
1.3.1 data-flow-format 1-61
1.3.2 display hwtacacs. 1-62
1.3.3 display stop-accounting-buffer 1-63
1.3.4 hwtacacs nas-ip. 1-64
1.3.5 hwtacacs scheme. 1-65
1.3.6 key. 1-65
1.3.7 nas-ip. 1-66
1.3.8 primary accounting. 1-67
1.3.9 primary authentication. 1-68
1.3.10 primary authorization. 1-69
1.3.11 reset hwtacacs statistics. 1-70
1.3.12 reset stop-accounting-buffer 1-70
1.3.13 retry stop-accounting. 1-71
1.3.14 secondary accounting. 1-72
1.3.15 secondary authentication. 1-73
1.3.16 secondary authorization. 1-74
1.3.17 timer quiet 1-75
1.3.18 timer realtime-accounting. 1-75
1.3.19 timer response-timeout 1-77
1.3.20 user-name-format 1-77
Chapter 2 EAD Configuration Commands. 2-1
2.1 EAD Configuration Commands. 2-1
2.1.1 security-policy-server 2-1
1.1.1  access-limit
access-limit { disable | enable max-user-number }
undo access-limit
View
ISP domain view
Parameter
disable: Specifies not to limit the number of access users that can be contained in current ISP domain.
enable max-user-number: Specifies the maximum number of access users that can be contained in current ISP domain. The max-user-number argument ranges from 1 to 2,072.
Use the access-limit command to set the maximum number of access users that can be contained in current ISP domain.
Use the undo access-limit command to restore the default setting.
By default, there is no limit on the number of access users in an ISP domain.
Because resource contention may occur among access users, there is a need to limit the number of access users in an ISP domain so as to provide reliable performance to the current users in the ISP domain.
Example
# Allow ISP domain aabbc.net to contain at most 500 access users.
<H3C> system-view
[H3C] domain aabbc.net
New Domain added.
[H3C-isp-aabbcc.net] access-limit enable 500
1.1.2  accounting
accounting { none | radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name }
undo accounting
View
ISP domain view
Parameter
none: Specifies not to perform user accounting.
radius-scheme radius-scheme-name: Specifies to use a RADIUS accounting scheme. Here, radius-scheme-name is the name of a RADIUS scheme; it is a string of up to 32 characters.
hwtacacs-scheme hwtacacs-scheme-name: Specifies to use a HWTACACS accounting scheme. Here, hwtacacs-scheme-name is the name of a HWTACACS scheme; it is a string of up to 32 characters.
Use the accounting command to configure an accounting scheme for current ISP domain.
Use the undo accounting command to cancel the accounting scheme configuration for current ISP domain.
By default, no separate accounting scheme is configured for an ISP domain.
When you use the accounting command to reference a RADIUS or HWTACACS scheme in current ISP domain, the RADIUS or HWTACACS scheme must already exist.
The accounting command takes precedence over the scheme command. If the accounting command is used in ISP domain view, the system uses the scheme referenced in the accounting command to charge the users in the domain. Otherwise, the system uses the scheme referenced in the scheme command to charge the users.
Related command: scheme, radius scheme, and hwtacacs scheme.
Example
# Specify "radius" as the RADIUS accounting scheme that will be referenced by ISP domain "aabbcc.net".
<H3C> system-view
[H3C] domain aabbcc.net
New Domain added.
[H3C-isp-aabbcc.net] accounting radius-scheme radius
accounting optional
undo accounting optional
View
ISP domain view
Parameter
None
Use the accounting optional command to open the accounting-optional switch.
Use the undo accounting optional command to close the accounting-optional switch.
By default, the accounting-optional switch is closed.
Note that:
If the system does not find any available accounting server or fails to communicate with any accounting server when it performs accounting for an online user, it will not disconnect the user as usual as long as the accounting optional command has been executed. The accounting optional command is commonly used in the cases where only authentication is needed and accounting is not needed.
Example
# Open the accounting-optional switch for the ISP domain named aabbcc.net.
<H3C> system-view
New Domain added.
[H3C-isp-aabbcc.net] accounting optional
1.1.4  attribute
attribute { ip ip-address | mac mac-address | idle-cut second | access-limit max-user-number | vlan vlan-id | location { nas-ip ip-address port port-number | port port-number } }*
undo attribute { ip | mac | idle-cut | access-limit | vlan | location }*
View
Local user view
Parameter
ip ip-address: Sets the IP address of the user.
mac mac-address: Sets the MAC address of the user. Here, mac-address is in H-H-H format.
idle-cut second: Allows the local user to enable the idle-cut function. Here, second is the idle time before cutting down, which ranges from 60 to 7,200 seconds.
access-limit max-user-number: Sets the maximum number of users who can access the switch with the current user name. Here, max-user-number ranges from 1 to 1,024.
vlan vlan-id: Sets the VLAN attribute of the user (that is, specifies to which VLAN the user belongs). Here, vlan-id is an integer ranging from 1 to 4094.
nas-ip ip-address: Sets the IP address of an access server, so that the user can be bound to a port on the server. Here, ip-address is in dotted decimal notation and is 127.0.0.1 by default (representing this device). When binding the user to a remote port, you must use nas-ip ip-address to specify a remote access server IP address. When binding the user to a local port, you need not use nas-ip ip-address.
port port-number: Sets the port to which you want to bind the user. Here, port-number is in the format of device ID/slot number/port number; the device ID ranges from 1 to 8, the slot number ranges from 0 to 15 (if the bound port has no slot number, just input 0 for this item) and the port number ranges from 1 to 255.
Use the attribute command to set the attributes of a user whose service type is lan-access.
Use the undo attribute command to cancel attribute settings of the user.
Related command: display local-user.
Example
# Set the IP address of user1 to 10.110.50.1.
<H3C> system-view
[H3C] local-user user1
New local user added.
[H3C-luser-user1] attribute ip 10.110.50.1
authentication { radius-scheme radius-scheme-name [ local ] | hwtacacs-scheme hwtacacs-scheme-name [ local ] | local | none }
undo authentication
View
ISP domain view
Parameter
radius-scheme radius-scheme-name: Specifies to use a RADIUS authentication scheme. Here, radius-scheme-name is a string of up to 32 characters.
hwtacacs-scheme hwtacacs-scheme-name: Specifies to use a HWTACACS authentication scheme. Here, hwtacacs-scheme-name is a string of up to 32 characters.
local: Specifies to use local authentication scheme.
none: Specifies not to perform authentication.
Use the authentication command to configure an authentication scheme for current ISP domain.
Use the undo authentication command to restore the default authentication scheme setting of current ISP domain.
By default, no separate authentication scheme is configured for an ISP domain.
Before you can use the authentication command to reference a RADIUS scheme in current ISP domain, the RADIUS scheme must already exist.
If you execute the authentication radius-scheme radius-scheme-name local command, the local scheme is used as the secondary authentication scheme in case no RADIUS server is available. That is, if the communication between the switch and a RADIUS server is normal, no local authentication will be performed; otherwise, local authentication will be performed.
If you execute the authentication hwtacacs-scheme hwtacacs-scheme-name local command, the local scheme is used as the secondary authentication scheme in case no TACACS server is available. That is, if the communication between the switch and a TACACS server is normal, no local authentication will be performed; otherwise, local authentication will be performed.
If you execute the authentication local command, the local scheme is used as the primary scheme. In this case, only local authentication will be performed.
If you execute the authentication none command, no authentication will be performed.
The authentication command takes precedence over the scheme command. If the authentication command is configured in an ISP domain view, the system uses the authentication scheme referenced in the command to authenticate the users in the domain; otherwise it uses the scheme referenced in the scheme command to authenticate the users.
Example
# Reference the RADIUS scheme "radius" as the authentication scheme of the ISP domain aabbcc.net.
<H3C> system-view
New Domain added.
[H3C-isp-aabbcc.net] authentication radius-scheme radius
# Reference the RADIUS scheme "rd" as the authentication scheme and the local scheme as the secondary authentication scheme of the ISP domain aabbcc.
<H3C> system-view
[H3C] domain aabbcc
New Domain added.
[H3C-isp-aabbcc] authentication radius-scheme rd local
1.1.6  authorization
authorization { none | hwtacacs-scheme hwtacacs-scheme-name }
undo authorization
View
ISP domain view
Parameter
none: Specifies not to use any authorization scheme.
hwtacacs-scheme hwtacacs-scheme-name: Specifies to use a HWTACACS scheme. Here, hwtacacs-scheme-name is the name of a HWTACACS scheme; it is a string of up to 32 characters.
Use the authorization command to configure an authorization scheme for current ISP domain.
Use the undo authorization command to restore the default authorization scheme setting of the ISP domain.
By default, no separate authorization scheme is configured for an ISP domain.
Example
# Allow users in ISP domain aabbcc.net to access network services without being authorized.
<H3C> system-view
New Domain added.
[H3C-isp-aabbcc.net] authorization none
cut connection { all | access-type { dot1x | mac-authentication } | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | radius-scheme radius-scheme-name | vlan vlan-id | ucibindex ucib-index | user-name user-name }
View
Parameter
all: Cuts down all user connections.
access-type { dot1x | mac-authentication }: Cuts down user connections of a specified access type. dot1x is used to cut down all 802.1x user connections, and mac-authentication is used to cut down all MAC authentication user connections.
domain isp-name: Cuts down all user connections in a specified ISP domain. Here, isp-name is the name of an ISP domain, a string of up to 24 characters. You can only specify an existing ISP domain.
interface interface-type interface-number: Cuts down all user connections under a specified port. Here, interface-type is a port type and interface-number is a port number.
ip ip-address: Cuts down all user connections with a specified IP address.
mac mac-address: Cuts down the user connection with a specified MAC address. Here, mac-address is in H-H-H format.
radius-scheme radius-scheme-name: Cuts down all user connections using a specified RADIUS scheme. Here, radius-scheme-name is a string of up to 32 characters.
vlan vlan-id: Cuts down all user connections of a specified VLAN. Here, vlan-id ranges from 1 to 4094.
ucibindex ucib-index: Cuts down the user connection with a specified connection index. Here, ucib-index ranges from 0 to 2071.
user-name user-name: Cuts down the connection of a specified user. Here, user-name is a string of up to 80 characters. The string cannot contain the following characters: /:*?<>. It can contain no more than one @ character. The pure user name (user ID, that is, the part before @) cannot be longer than 55 characters, and the domain name (the part behind @) cannot be longer than 24 characters.
Use the cut connection command to forcibly cut down one user connection, one type of user connections, or all user connections.
This command cannot cut down the connections of Telnet and FTP users.
Related command: display connection.
Example
# Cut down all user connections under the ISP domain aabbcc.net.
<H3C> system-view
[H3C] cut connection domain aabbcc.net
display connection [ access-type { dot1x | mac-authentication } | domain isp-name | interface interface-type interface-number | ip ip-address | mac mac-address | radius-scheme radius-scheme-name | hwtacacs-scheme hwtacacs-scheme-name | vlan vlan-id | ucibindex ucib-index | user-name user-name ]
View
Parameter
access-type { dot1x | mac-authentication }: Displays user connections of a specified access type. Here, dot1x is used to display all 802.1x user connections, and mac-authentication is used to display all MAC authentication user connections.
domain isp-name: Displays all user connections under specified ISP domain. Here, isp-name is the name of an ISP domain, a string of up to 24 characters. You can only specify an existing ISP domain.
interface interface-type interface-number: Displays all user connections on a specified port.
ip ip-address: Displays all user connections with a specified IP address.
mac mac-address: Displays the user connection with a specified MAC address. Here, mac-address is in hexadecimal format (in the form of H-H-H).
radius-scheme radius-scheme-name: Displays all user connections using a specified RADIUS scheme. Here, radius-scheme-name is a string of up to 32 characters.
hwtacacs-scheme hwtacacs-scheme-name: Displays all user connections using a specified RADIUS scheme. Here, hwtacacs-scheme-name is a string of up to 32 characters.
vlan vlan-id: Displays all user connections of a specified VLAN. Here, vlan-id ranges from 1 to 4094.
ucibindex ucib-index: Displays the user connection with a specified connection index. Here, ucib-index ranges from 0 to 2071.
user-name user-name: Displays the connection of a specified user. Here, user-name is a character string in the format of pure-username@domain-name. The pure-username cannot be longer than 55 characters, the domain-name cannot be longer than 24 characters, and the entire user-name cannot be longer than 80 characters.
Use the display connection command to display information about specified or all user connections.
If you execute this command without specifying any parameter, all user connections will be displayed.
This command cannot display information about the connections of FTP users.
Related command: cut connection.
Example
# Display information about all user connections.
<H3C> display connection
------------------unit 1------------------------
On Unit 1: Total 0 connections matched, 0 listed.
------------------unit 2------------------------
Index=40 , Username=user1@domain1
MAC=000f-3d80-4ce5  , IP=0.0.0.0
 On Unit 2: Total 1 connections matched, 1 listed.
------------------unit 3------------------------
On Unit 3:Total 0 connections matched, 0 listed.
# Display information about the user connection with index 0.
[H3C] display connection ucibindex 0
Index=0   , Username=user1@system
MAC=000f-3d80-4ce5   , IP=192.168.0.3
Access=8021X   ,Auth=CHAP    ,Port=Ether   ,Port NO=0x10003001
Initial VLAN=1, Authorization VLAN=1
ACL Group=Disable
CAR=Disable
Priority=Disable
Start=2000-04-03 02:51:53 ,Current=2000-04-03 02:52:22 ,Online=00h00m29s
 On Unit 1:Total 1 connections matched, 1 listed.
Here, Port NO=0x10003001 means (by the binary bits):
Table 1-1 Description of the Port NO field
31 to 28 bit
27 to 24 bit
23 to 20 bit
19 to 12 bit
11 to 0 bit
UNIT ID
Slot number
Sub-slot number
Port number
VLAN ID
display domain [ isp-name ]
View
Parameter
isp-name: Name of an ISP domain, a string of up to 24 characters. This must be the name of an existing ISP domain.
Use the display domain command to display configuration information about one specific or all ISP domains.
Related command: access-limit, domain, scheme, and state.
Example
# Display configuration information about all ISP domains.
<H3C> display domain
0  Domain = system
   State = Active
   Scheme = LOCAL
   Access-limit = Disable
   Vlan-assignment-mode = Integer
   Domain User Template:
   Idle-cut = Disable
   Self-service = Disable
   Messenger Time = Disable
Default Domain Name: system
Total 1 domain(s).1 listed.
Table 1-2 Description on the fields of the display domain command
Domain
Domain name
Status of the domain
Scheme
AAA scheme
Access-Limit
Limit on the number of access users
VLAN assignment mode
Domain user template
Idle-Cut
Status of the idle-cut function
Self-service
Status of self-service
Messenger Time
Status of messenger time service
display local-user [ domain isp-name | idle-cut { disable | enable } | vlan vlan-id | service-type { ftp | lan-access | ssh | telnet | terminal } | state { active | block } | user-name user-name ]
View
Parameter
domain isp-name: Displays all local users belonging to a specified ISP domain. Here, isp-name is the name of an ISP domain, a string of up to 24 characters. You can only specify an existing ISP domain.
idle-cut { disable | enable }: Displays the local users who are inhibited from enabling the idle-cut function, or the local users who are allowed to enable the idle-cut function. Here, disable specifies the inhibited local users and enable specifies the allowed local users.
vlan vlan-id: Displays the local users belonging to a specified VLAN. Here, vlan-id ranges from 1 to 4094.
service-type: Displays the local users of a specified type. You can specify one of the following user types: ftp, lan-access (generally, this type of users are Ethernet access users, for example, 802.1x users), ssh, telnet, and terminal (this type of user is a terminal user who logs into the switch through the Console port).
state { active | block }: Displays the local users in a specified state. Here active represents the users allowed to request network services, and block represents the users inhibited from requesting network services.
user-name user-name: Displays the local user with a specified user name. Here, user-name is a string of up to 80 characters. The string cannot contain the following characters: /:*?<>. It can contain no more than one @ character. The pure user name (user ID, that is, the part before @) cannot be longer than 55 characters, and the domain name (the part behind @) cannot be longer than 24 characters.
Use the display local-user command to display information about specified or all local users.
Related command: local-user.
Example
# Display information about all local users.
<H3C> display local-user
The contents of local user user1:
 State:          Active            ServiceType Mask: None
 Idle-cut:       Disable
 Access-limit:   Disable           Current AccessNum: 0
 Bind location:  Disable
 Vlan ID:        Disable
 IP address:     Disable
 MAC address:    Disable
Total 1 local user(s) Matched, 1 listed.
ServiceType Mask Meaning: C--Terminal  F--FTP  L--LanAccess  S--SSH  T—Telnet
Table 1-3 describes the fields in the above display output.
Table 1-3 Description on the fields of the display local-user command
Status of the local user
ServiceType Mask
Service type mark
Idle-Cut
Access-Limit
Current AccessNum
Number of current access users
Bind location
Whether or not bound to a port
Vlan ID
VLAN of the user
IP address
MAC address
1.1.11  domain
domain { isp-name | default { disable | enable isp-name } }
undo domain isp-name
View
Parameter
isp-name: Name of an ISP domain, a string of up to 24 characters. This string cannot contain the following characters: /:*?<>.
default: Manually configures the default ISP domain, which is "system" by default. There is one and only one default ISP domain.
disable: Disables the configured default ISP domain.
enable: Enables the configured default ISP domain.
Use the domain command to create an ISP domain and enter its view, or enter the view of an existing ISP domain, or configure the default ISP domain.
Use the undo domain command to delete a specified ISP domain.
The ISP domain "system" is used as the default ISP domain before you manually configure the default ISP domain, and you can use the display domain command to check the settings of the default ISP domain "system".
After you execute the domain command, the system creates a new ISP domain if the specified ISP domain does not exist. Once an ISP domain is created, it is in the active state. You can manually specify an ISP domain as the default domain only when the specified domain already exists.
Related command: access-limit, scheme, state, and display domain.
Example
# Create a new ISP domain named aabbcc.net.
<H3C> system-view
New Domain added.
1.1.12  idle-cut
idle-cut { disable | enable minute flow }
View
ISP domain view
Parameter
disable: Inhibits users from enabling the idle-cut function.
enable: Allows users to enable the idle-cut function.
minute: Maximum idle time in minutes, ranging from 1 to 120.
flow: Minimum data flow in bytes, ranging from 1 to 10,240,000.
Use the idle-cut command to set the user idle-cut function in current ISP domain.
By default, this function is disabled.
Related command: domain.
Example
# Enable the idle-cut function on users in ISP domain aabbcc.net, with the maximum idle time of 50 minutes and the minimum data flow of 500 bytes. As a result, for a user in the domain, if the total traffic of the user within 50 minutes is less than 500 bytes, the user connection will be cut down.
<H3C> system-view
New Domain added.
[H3C-isp-aabbcc.net] idle-cut enable 50 500
1.1.13  level
level level
undo level
View
Local user view
Parameter
level: Privilege level to be set for the user. It is an integer ranging from 0 to 3.
Use the level command to set the privilege level of the user. The privilege level of the user corresponds to the command level of the user. For detailed information, refer to the description of the command-privilege level command in the command line interface part.
Use the undo level command to restore the default privilege level of the user.
The default privilege level is 0.
Note that:
l           If the configured authentication method is none or password authentication, the command level that a user can access after login is determined by the level of the user interface.
l           If the configured authentication method requires a user name and a password, the command level that a user can access after login is determined by the privilege level of the user. For SSH users using RSA shared key for authentication, the commands they can access are determined by the levels sets on their user interfaces.
Example
# Set the level of user1 to 3.
<H3C> system-view
[H3C-luser-user1] level 3
1.1.14  local-user
local-user user-name
undo local-user { user-name | all [ service-type { ftp | lan-access | ssh | telnet | terminal } ] }
View
Parameter
user-name: Local user name, a string of up to 80 characters. This string cannot contain the following characters: /:*?<>. It can contain no more than one @ character. The pure user name (user ID, that is, the part before @) cannot be longer than 55 characters, and the domain name (the part behind @) cannot be longer than 24 characters.
all: Specifies all local users.
service-type: Specifies the local users of a specified type. You can specify one of the following user types: ftp, lan-access (generally, this type of users are Ethernet access users, for example, 802.1x users), ssh, telnet, and terminal (terminal user who logs into the switch through the Console port).
Use the local-user command to add a local user and enter local user view.
Use the undo local-user command to delete one or more specified local users.
By default, there is no local user in the system.
Related command: display local-user and service-type.
Example
# Add a local user named user1.
<H3C> system-view
[H3C-luser-user1]
local-user password-display-mode { cipher-force | auto }
undo local-user password-display-mode
View
Parameter
cipher-force: Adopts the forcible cipher mode so that all local users' the passwords will be displayed in cipher text.
auto: Adopts the automatic mode so that each local user's password will be displayed in the mode you have set for the user by the password command.
Use the local-user password-display-mode command to set the password display mode of all local users.
Use the undo local-user password-display-mode command to restore the default password display mode of all local users.
By default, the password display mode of all access users is auto.
If the cipher-force mode is adopted, all passwords will be displayed in cipher text even though you have specified to display some users passwords in plain text by using the password command with the simple keyword.
Related command: display local-user and password.
Example
# Specify to display all local user passwords in cipher text in whatever cases.
<H3C> system-view
[H3C] local-user password-display-mode cipher-force
1.1.16  messenger
messenger time { enable limit interval | disable }
undo messenger time
View
ISP domain view
Parameter
limit: Time limit in minutes, ranging from 1 to 60. The switch will send prompt messages at regular intervals to users whose remaining online time is less than this limit.
interval: Interval to send prompt messages (in minutes). This argument ranges from 5 to 60 and must be a multiple of 5.
Use the messenger time enable command to enable the messenger function and set the related parameters.
Use the messenger time disable command to disable the messenger function.
Use the undo messenger time command to restore the messenger function to its default state.
By default, the messenger function is disabled on the switch.
The purpose of this function is to remind online users of their remaining online time through clients by message dialog box.
You can use messenger time enable command to set the remaining online time limit and the interval to send prompt messages. After that, the switch regularly sends prompt messages at the set interval to the clients of the users whose remaining online time is less than the set limit, and the clients inform the users of their remaining online time by message dialog box.
Example
# Enable the switch to send prompt messages at intervals of 5 minutes to the users in the ISP domain "system" after their remaining online time is less than 30 minutes.
<H3C> system-view
[H3C] domain system
[H3C-isp-system] messenger time enable 30 5
1.1.17  name
name string
undo name
View
VLAN view
Parameter
string: Assigned VLAN name, a string of up to 32 characters.
Use the name command to set a VLAN name, which will be used for VLAN assignment.
Use the undo name command to cancel the VLAN name.
By default, a VLAN uses its VLAN ID (like VLAN 0001) as its assigned VLAN name.
This command is used in conjunction with the dynamic VLAN assignment function. For details about dynamic VLAN assignment, refer to the vlan-assignment-mode command.
Related command: vlan-assignment-mode.
Example
# Set the name of VLAN 100 to test.
<H3C> system-view
[H3C] vlan 100
[H3C-vlan100] name test
1.1.18  password
password { simple | cipher } password
undo password
View
Local user view
Parameter
simple: Specifies to display the password in plain text.
cipher: Specifies to display the password in cipher text.
password: Password to be set:
l           For simple mode, the password you input must be a plain-text password.
l           For cipher mode, the password can be either a cipher-text password or a plain-text password, and what it is depends on your input.
A password in plain text can be a string with of up to 63 consecutive characters, for example, aabbcc. A password in cipher text can be a string with 1 to 63 characters, or 88 characters, for example, _(TT8F]Y\5SQ=^Q`MAF4<1!!.
Use the password command to set a password for the local user.
Use the undo password command to cancel the password of the local user.
Note that, after the local-user password-display-mode cipher-force command is executed, any local user password will be displayed in cipher text even though it is configured by the password command with the simple keyword.
Example
# Set the password of user1 to 20030422 and specify to display the password in plain text.
<H3C> system-view
[H3C-luser-user1] password simple 20030422
View
ISP domain view
Parameter
radius-scheme-name: Name of a RADIUS scheme, a string of up to 32 characters.
Use the radius-scheme command to configure a RADIUS scheme for current ISP domain.
After an ISP domain is initially created, it uses the local AAA scheme instead of any RADIUS scheme by default.
The RADIUS scheme you specified in the radius-scheme command must already exist. This command is equivalent to the scheme radius-scheme command.
Related command: radius scheme, scheme, and display radius scheme.
Example
# Configure the ISP domain "h3c163.net" to use the RADIUS scheme "h3c".
<H3C> system-view
[H3C] domain h3c163.net
New Domain added.
[H3C-isp-h3c163.net] radius-scheme h3c
1.1.20  scheme
scheme { local | none | radius-scheme radius-scheme-name [ local ] | hwtacacs-scheme hwtacacs-scheme-name [ local ] }
undo scheme { none | radius-scheme | hwtacacs-scheme }
View
ISP domain view
Parameter
hwtacacs-scheme-name: Name of a HWTACACS scheme, a string of up to 32 characters.
local: Specifies to use local authentication.
Use the scheme command to configure an AAA scheme for current ISP domain.
Use the undo scheme command to restore the default AAA scheme configuration for the ISP domain.
By default, the ISP domain uses the local AAA scheme.
Note that:
l           When you execute the scheme command to reference a RADIUS scheme in current ISP domain, the referenced RADIUS scheme must already exist.
l           If you execute the scheme radius-scheme radius-scheme-name local command, the local scheme is used as the secondary scheme in case no RADIUS server is available. That is, if the communication between the switch and a RADIUS server is normal, no local authentication is performed; otherwise, local authentication is performed.
l           If you execute the scheme hwtacacs-scheme hwtacacs-scheme-name local command, the local scheme is used as the secondary scheme in case no TACACS server is available. That is, if the communication between the switch and a TACACS server is normal, no local authentication is performed; otherwise, local authentication is performed.
l           If you execute the scheme local or scheme none command to adopt local or none as the primary scheme, the local authentication is performed or no authentication is performed. In this case you cannot specify any RADIUS scheme at the same time.
Related command: radius scheme.
Example
# Configure the ISP domain aabbcc.net to use RADIUS scheme radius1 as the primary AAA scheme and use the local scheme as the secondary authentication scheme.
<H3C> system-view
New Domain added.
[H3C-isp-aabbcc.net] scheme radius-scheme raduis1 local
self-service-url { disable | enable url-string }
undo self-service-url
View
ISP domain view
Parameter
url-string: URL of the web page used to modify user password on the self-service server. It is a string of 1 to 64 characters. This string cannot contain any question mark "?". If the actual URL of the self-service server contains a question mark, you should change it to an elect bar "|".
Use the self-service-url enable command to enable the self-service server location function
Use the self-service-url disable command to disable the self-service server location function
Use the undo self-service-url command to restore the default state of this function.
Note that:
l           This command must be used with the cooperation of a self-service-supported RADIUS server (such as CAMS). Through self-service, users can manage and control their accounts or card numbers by themselves. A server installed with the self-service software is called a self-service server.
l           After this command is executed on the switch, a user can locate the self-service server through the following operation: choose [change user password] on the 802.1x client, the client opens the default browser (for example, IE or Netscape) and locates the URL page used to change user password on the self-service server. Then, the user can change the password.
l           A user can choose the [change user password] option on the client only after passing the authentication. If the user fails the authentication, this option is in grey and is unavailable.
Example
# Under the default ISP domain "system", set the URL of the web page used to modify user password on the self-service server to http://10.153.89.94/selfservice/modPasswd1x.jsp|userName.
<H3C> system-view
[H3C] domain system
[H3C-isp-system] self-service-url enable http://10.153.89.94/selfservice/modPasswd1x.jsp|userName
1.1.22  service-type
service-type { ftp | lan-access | { telnet | ssh | terminal }* [ level level ] }
undo service-type { ftp | lan-access | { telnet | ssh | terminal }* }
View
Local user view
Parameter
ftp: Specifies that this is a ftp user.
lan-access: Specifies that this is a LAN access user (who is generally an Ethernet access user, for example, 802.1x user).
telnet: Authorizes the user to access the Telnet service.
ssh: Authorizes the user to access the SSH service.
terminal: Authorizes the user to access the terminal service (that is, allows the user to log into the switch through the Console port).
level level: Specifies the level of the Telnet, terminal or SSH user. Here, level is an integer ranging from 0 to 3 and defaulting to 0.
Use the service-type command to authorize the user to access specified type(s) of service.
Use the undo service-type command to inhibit the user from accessing specified type(s) of service.
By default, the user is inhibited from accessing any type of service.
Example
# Authorize user1 to access the Telnet service.
<H3C> system-view
[H3C-luser-user1] service-type telnet
1.1.23  state
View
ISP domain view, local user view
Parameter
active: Activates the current ISP domain (in ISP domain view) or local user (in local user view), to allow users in current ISP domain or current local user to access the network.
block: Blocks the current ISP domain (in ISP domain view) or local user (in local user view), to inhibit users in current ISP domain or current local user from accessing the network.
Use the state command to set the status of current ISP domain (in ISP domain view) or current local user (in local user view).
By default, an ISP domain/local user is in the active state once it is created.
After an ISP domain is set to the block state, except for online users, users in this domain are inhibited from accessing the network.
After a local user is set to the block state, the user is inhibited from accessing the network unless the user is already online.
Example
# Set the ISP domain aabbcc.net to the block state, so that all its offline users cannot access the network.
<H3C> system-view
New Domain added.
[H3C-isp-aabbcc.net] state block
# Set user1 to the block state.
<H3C> system-view
[H3C-user-user1] state block
vlan-assignment-mode { integer | string }
View
ISP domain view
Parameter
integer: Sets the VLAN assignment mode to integer.
string: Sets the VLAN assignment mode to string.
Use the vlan-assignment-mode command to set the VLAN assignment mode (integer or string) on the switch.
By default, the VLAN assignment mode is integer, that is, the switch supports its RADIUS authentication server to assign integer VLAN IDs.
The dynamic VLAN assignment feature enables a switch to dynamically add the ports of successfully authenticated users to different VLANs according to the attributes assigned by the RADIUS server, so as to control the network resources that different users can access.
In actual applications, to use this feature together with Guest VLAN, you are recommended to set port control to port-based mode.
Currently, the switch supports the following two types of assigned VLAN IDs: integer and string.
l           Integer: If the RADIUS authentication server assigns integer type of VLAN IDs, you can set the VLAN assignment mode to integer on the switch (this is also the default mode on the switch). Then, upon receiving an integer ID assigned by the RADIUS authentication server, the switch adds the port to the VLAN whose VLAN ID is equal to the assigned integer ID. If no such a VLAN exists, the switch first creates a VLAN with the assigned ID, and then adds the port to the newly created VLAN.
l           String: If the RADIUS authentication server assigns string type of VLAN IDs, you can set the VLAN assignment mode to string on the switch. Then, upon receiving a string ID assigned by the RADIUS authentication server, the switch compares the ID with existing VLAN names on the switch. If it finds a match, it adds the port to the corresponding VLAN. Otherwise, the VLAN assignment fails and the user fails the authentication.
The switch supports two dynamic VLAN assignment modes to adapt to different authentication servers. You are recommended to configure the switch according to the dynamic VLAN assignment mode used by the server.
Table 1-4 lists several commonly used RADIUS servers and their dynamic VLAN assignment modes.
Table 1-4 Commonly used servers and their dynamic VLAN assignment modes
Server
Dynamic VLAN assignment mode
CAMS
Integer
For the latest CAMS version, you can determine the assignment mode by attribute value.
ACS
String
FreeRADIUS
You can determine the assignment mode by attribute value (for example, 100 is integer; “100” is string).
Shiva Access Manager
String
Steel-Belted Radius Administrator
String
&  Note:
In string mode, if the VLAN ID assigned by the RADIUS server is a character string containing only digits (for example, 1024), the switch first regards it as an integer VLAN ID: the switch transforms the string to an integer value and judges if the value is in the valid VLAN ID range; if it is, the switch adds the authenticated port to the VLAN with the value as the VLAN ID (VLAN 1024, for example).
Related command: name.
Example
# Set the VLAN assignment mode of the domain h3c163.net to string.
<H3C> system-view
New Domain added.
[H3C-isp-h3c163.net] vlan-assignment-mode string
accounting optional
View
RADIUS scheme view
Parameter
None
Use the undo accounting optional command to close the accounting-optional switch so that accounting must be performed for users.
Note that:
l           If the system does not find any available accounting server or fails to communicate with any accounting server when it performs accounting for an online user, it will not disconnect the user as usual as long as the accounting optional command has been executed. This command is commonly used in the cases where only authentication is needed and accounting is not needed.
l           This configuration takes effect only on the ISP domains using this RADIUS scheme.
Example
# Open the accounting-optional switch in RADIUS scheme radius1.
<H3C> system-view
[H3C] radius scheme radius1
New Radius scheme
[H3C-radius-radius1] accounting optional
accounting-on enable [ send times | interval interval ]
undo accounting-on { enable | send | interval }
View
RADIUS scheme view
Parameter
times: Maximum number of attempts to send an Accounting-On message, ranging from 1 to 256 and defaulting to 15.
interval: Interval to send Accounting-On messages (in seconds), ranging from 1 to 30 and defaulting to 3.
Use the accounting-on enable command to enable the user re-authentication at restart function.
Use the undo accounting-on enable command to disable the user re-authentication at restart function and restore the default interval and maximum number of attempts to send Accounting-On messages.
Use the undo accounting-on send command to restore the default maximum number of attempts to send Accounting-On messages.
Use the undo accounting-on interval command to restore the default interval to send Accounting-On messages.
By default, the user re-authentication at restart function is disabled.
The purpose of this function is to solve this problem: users cannot re-log into the switch after the switch restarts because they are regarded as already online. After this function is enabled, every time the switch restarts:
l           The switch generates an Accounting-On message, which mainly contains the following information: NAS-ID, NAS-IP-address (source IP address), and session ID.
l           The switch sends the Accounting-On message to the CAMS at regular intervals.
l           Once the CAMS receives the Accounting-On message, it sends a response to the switch. At the same time it finds and deletes the original online information of the users who were accessing the network through the switch before the restart according to the information (NAS-ID, NAS-IP-address and session ID) contained in the message, and ends the accounting of the users based on the last accounting update message.
l           Once the switch receives the response from the CAMS, it stops sending Accounting-On messages.
l           If the switch does not receive any response from the CAMS after it has tried the configured maximum number of times to send the Accounting-On message, it will not send the Accounting-On message any more.
&  Note:
The switch can automatically generate the main attributes (NAS-ID, NAS-IP-address and session ID) in the Accounting-On messages. However, you can also manually configure the NAS-IP-address with the nas-ip command. If you choose to manually configure this attribute, be sure to configure an appropriate valid IP address. If this attribute is not configured, the switch will automatically use the IP address of a VLAN interface as the NAS-IP-address.
Related command: nas-ip.
Example
# Enable the user re-authentication at restart function for the RADIUS scheme named CAMS.
<H3C> system-view
[H3C] radius scheme CAMS
[H3C-radius-CAMS] accounting-on enable
data-flow-format data { byte | giga-byte | kilo-byte | mega-byte } packet { giga-packet | kilo-packet | mega-packet | one-packet }
undo data-flow-format
View
RADIUS scheme view
Parameter
data: Sets the data unit of outgoing RADIUS flows, which can be byte, giga-byte, kilo-byte, or mega-byte.
packet: Sets the packet unit of outgoing RADIUS flows, which can be one-packet, giga-packet, kilo-packet, or mega-packet.
Use the data-flow-format command to set the units of RADIUS data flows to RADIUS servers.
Use the undo data-flow-format command to restore the default units.
By default, the data unit and packet unit of outgoing RADIUS flows are byte and one-packet respectively.
Related command: display radius scheme.
Example
# Specify to measure data and packets in data flows to RADIUS servers in kilo-bytes and kilo-packets respectively in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] data-flow-format data kilo-byte packet kilo-packet
View
Parameter
None
Use the display local-server statistics command to display the RADIUS message statistics about local RADIUS authentication server.
Related command: local-server.
Example
# Display the RADIUS message statistics about local RADIUS authentication server.
<H3C> display local-server statistics
On Unit 1:
The localserver packet statistics:
Receive:                  30          Send:                   30
Discard:                  0           Receive Packet Error:   0
Auth Receive:             10         Auth Send:               10
Acct Receive:             20         Acct Send:               20
display radius scheme [ radius-scheme-name ]
View
Parameter
Use the display radius scheme command to display configuration information about one specific or all RADIUS schemes
Example
# Display configuration information about all RADIUS schemes.
<H3C> display radius scheme
SchemeName  =system                           Index=0    Type=extended
Primary Auth IP  =127.0.0.1        Port=1645
Primary Acct IP  =127.0.0.1        Port=1646
Second  Auth IP  =0.0.0.0          Port=1812
Second  Acct IP  =0.0.0.0          Port=1813
Auth Server Encryption Key= Not configured
Acct Server Encryption Key= Not configured
Accounting method = required
Accounting-On packet enable, send times = 15 , interval = 3s
TimeOutValue(in second)=3 RetryTimes=3 RealtimeACCT(in minute)=12
Permitted send realtime PKT failed counts       =5
Retry sending times of noresponse acct-stop-PKT =500
Quiet-interval(min)                             =5
Username format                                 =without-domain
Data flow unit                                  =Byte
Packet unit                                     =1
unit 1 :
Primary Auth State=active,   Second Auth State=block
Primary Acc  State=active,   Second Acc  State=block
Total 1 RADIUS scheme(s). 1 listed
Table 1-5 Description on the fields of the display radius scheme command
SchemeName
Name of the RADIUS scheme
Index
Index number of the RADIUS scheme
Type of the RADIUS servers
Primary Auth IP/Port
IP address/port number of the primary authentication server
Primary Acct IP/Port
IP address/port number of the primary accounting server
Second Auth IP/Port
IP address/port number of the secondary authentication server
Second Acct IP/Port
IP address/port number of the secondary accounting server
Shared key for the authentication servers
Shared key for the accounting servers
Accounting method
Accounting method
The switch sends up to 15 Accounting-On messages at intervals of 3 seconds after restarting.
RADIUS server response timeout time
RetryTimes
Maximum number of transmission attempts of a RADIUS request
Real-time accounting interval in minutes
maximum allowed number of continuous real-time accounting failures
Maximum number of transmission attempts of the buffered stop-accounting requests
Quiet-interval(min)
Time that the switch must wait before it can restore the status of a primary server to active
Username format
User name format
Data flow unit
Data unit of data flow
Packet unit
Packet unit of data flow
Primary Auth State
Status of the primary authentication server
Second Auth State
Status of the secondary authentication server
Primary Acc  State
Status of the primary accounting server
Second Acc  State
Status of the secondary accounting server
View
Parameter
None
Use the display radius statistics command to display the RADIUS message statistics.
Example
# Display RADIUS message statistics.
<H3C> display radius statistics
state statistic(total=2072):
     DEAD=2072     AuthProc=0        AuthSucc=0
AcctStart=0         RLTSend=0         RLTWait=0
 AcctStop=0          OnLine=0            Stop=0
 StateErr=0
Received and Sent packets statistic:
Unit 1........................................
Sent PKT total  :0        Received PKT total:0
RADIUS received packets statistic:
Code= 2,Num=0       ,Err=0
Code= 3,Num=0       ,Err=0
Code= 5,Num=0       ,Err=0
Code=11,Num=0       ,Err=0
Running statistic:
RADIUS received messages statistic:
Normal auth request             , Num=0       , Err=0       , Succ=0
EAP auth request                , Num=0       , Err=0       , Succ=0
Account request                 , Num=0       , Err=0       , Succ=0
Account off request             , Num=0       , Err=0       , Succ=0
PKT auth timeout                , Num=0       , Err=0       , Succ=0
PKT acct_timeout                , Num=0       , Err=0       , Succ=0
Realtime Account timer          , Num=0       , Err=0       , Succ=0
PKT response                    , Num=0       , Err=0       , Succ=0
EAP reauth_request              , Num=0       , Err=0       , Succ=0
PORTAL access                   , Num=0       , Err=0       , Succ=0
Update ack                      , Num=0       , Err=0       , Succ=0
PORTAL access ack               , Num=0       , Err=0       , Succ=0
Session ctrl pkt                , Num=0       , Err=0       , Succ=0
Set policy result               , Num=0       , Err=0       , Succ=0
RADIUS sent messages statistic:
Auth accept                     , Num=0
Auth reject                     , Num=0
EAP auth replying               , Num=0
Account success                 , Num=0
Account failure                 , Num=0
Cut req                         , Num=0
RecError_MSG_sum:0        SndMSG_Fail_sum :0
Timer_Err       :0        Alloc_Mem_Err   :0
State Mismatch  :0        Other_Error     :0
No-response-acct-stop packet =0
Discarded No-response-acct-stop packet for buffer overflow =0
display stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
View
Parameter
radius-scheme radius-scheme-name: Displays the buffered stop-accounting requests of a specified RADIUS scheme. Here, radius-scheme-name is a string of up to 32 characters.
session-id session-id: Displays the buffered stop-accounting requests of a specified session. Here, session-id is a string of up to 50 characters.
time-range start-time stop-time: Displays the buffered stop-accounting requests generated in a specified time range. Here, start-time is the start time of the time range, stop-time is the end time of the time range, and both are in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd. The parameters here are used to display all the buffered stop-accounting requests generated from start-time to stop-time.
user-name user-name: Displays the buffered stop-accounting requests of a specified user. Here, user-name is a string of up to 80 characters.
Use the display stop-accounting-buffer command to display the non-response stop-accounting requests buffered in the device.
&  Note:
l      You can choose to display the buffered stop-accounting requests of a specified RADIUS scheme, session (by session ID), or user (by user name). You can also specify a time range to display those generated within the specified time range. The displayed information helps you diagnose and resolve RADIUS problems.
l      If the switch gets no response in a specified time period after sending a stop-accounting request to a RADIUS server, it will buffer the request and transmit the buffered one until the maximum number of transmission attempts (set by the retry stop-accounting command) is reached.
Related command: reset stop-accounting-buffer, stop-accounting-buffer enable and retry stop-accounting.
Example
# Display the buffered stop-accounting requests generated from 0:0:0 08/31/2002 to 23:59:59 08/31/2002.
<H3C> display stop-accounting-buffer time-range 00:00:00-08/31/2002 23:59:59-08/31/2002
Total find    0 record
display stop-accounting-buffer time-range 00:00:00-2002/08/31 23:59:59-2002/08/31
1.2.8  key
key { accounting | authentication } string
undo key { accounting | authentication }
View
RADIUS scheme view
Parameter
accounting: Sets a shared key for RADIUS accounting messages.
authentication: Sets a shared key for RADIUS authentication/authorization messages.
string: Shared key to be set, a string of up to 16 characters.
Use the key command to set a shared key for RADIUS authentication/authorization messages or accounting messages.
Use the undo key command to restore the corresponding default shared key setting.
By default, no shared key exists.
Both RADIUS client and server adopt MD5 algorithm to encrypt RADIUS messages before exchanging the messages with each other. The two parties verify the validity of the RADIUS messages received from each other by using the shared keys that have been set on them, and can accept and respond to the messages only when both parties have same shared key. The authentication/authorization shared key and the accounting shared key you set on the switch must be respectively consistent with the shared key on the authentication/authorization server and the shared key on the accounting server.
Related command: primary accounting, primary authentication and radius scheme.
Example
# Set "hello" as the shared key for RADIUS authentication/authorization messages in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] key authentication hello
# Set "ok" as the shared key for RADIUS accounting messages in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] key accounting ok
1.2.9  local-server
local-server enable
undo local-server
View
Parameter
None
Use the local-server enable command to enable UDP port for local RADIUS authentication server.
Use the undo local-server command to disable UDP port for local RADIUS authentication server.
By default, the UDP port for local RADIUS authentication server is enabled.
Related command: radius scheme, state, and local-server nas-ip.
Example
# Enable UDP port for local RADIUS authentication server.
<H3C> system-view
[H3C] local-server enable
local-server nas-ip ip-address key password
undo local-server nas-ip ip-address
View
Parameter
nas-ip ip-address: Sets the IP address of a network access server (NAS), so that the NAS is allowed by the local RADIUS authentication server. Here, ip-address is in dotted decimal notation.
key password: Sets the shared key between the local RADIUS authentication server and the NAS. Here, password is a string of up to 16 characters.
Use the local-server nas-ip command to set the related parameters of the local RADIUS authentication server.
Use the undo local-server nas-ip command to cancel a specified NAS setting for the local RADIUS authentication server.
By default, the local RADIUS authentication server is enabled and it allows the access of NAS 127.0.0.1. That is, the local device serves as both a RADIUS authentication server and a network access server, and all authentications are performed locally.
Note that:
l           The switch not only supports the traditional RADIUS client service to accomplish user AAA management through remote authentication/authorization server and accounting server, but also provides a simple local RADIUS server function for authentication and authorization. This function is called local RADIUS authentication server function.
l           When you use the local RADIUS authentication server function, the UDP port number of the authentication/authorization server must be 1645, the UDP port number of the accounting server must be 1646.
l           The message encryption key set by the local-server nas-ip ip-address key password command must be identical with the authentication/authorization message encryption key set by the key authentication command in the RADIUS scheme view of the RADIUS scheme on the specified NAS that uses this switch as its authentication server.
l           The switch supports the IP addresses and shared keys of at most 16 network access servers (including the local device); that is, when the switch serves as a RADIUS authentication server, it can provide authentication service to at most 16 NASs simultaneously.
l           When serving as a local RADIUS authentication server, the switch does not support EAP authentication.
Related command: radius scheme, state, local-server enable.
Example
# Allow the local RADIUS authentication server to provide service to NAS 10.110.1.2 with shared key aabbcc.
<H3C> system-view
[H3C] local-server nas-ip 10.110.1.2 key aabbcc
1.2.11  nas-ip
nas-ip ip-address
undo nas-ip
View
RADIUS scheme view
Parameter
ip-address: Source IP address for RADIUS messages, an IP address of this device. This address can neither be the all 0's address nor be a Class-D address.
Use the nas-ip command to set the source IP address of outgoing RADIUS messages.
Use the undo nas-ip command to remove the source IP address setting.
By default, the IP address of the outbound interface is used as the source IP address of RADIUS messages.
&  Note:
The nas-ip command in RADIUS scheme view has the same function as the radius nas-ip command in system view; and the configuration in RADIUS scheme view takes precedence over that in system view.
You can set the source IP address of outgoing RADIUS messages to avoid messages returned from RADIUS server from being unable to reach their destination due to physical interface trouble. It is recommended to use a loopback interface address as the source IP address.
Related command: display radius scheme, radius nas-ip.
Example
# Set source IP address 10.1.1.1 for outgoing RADIUS messages in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] nas-ip 10.1.1.1
primary accounting ip-address [ port-number ]
undo primary accounting
View
RADIUS scheme view
Parameter
ip-address: IP address of the primary accounting server to be used, in dotted decimal notation.
port-number: UDP port number of the primary accounting server, ranging from 1 to 65535.
Use the primary accounting command to set the IP address and port number of the primary RADIUS accounting server to be used by the current scheme.
Use the undo primary accounting command to restore the default IP address and port number of the primary RADIUS accounting server, which are 0.0.0.0 and 1813 respectively.
The IP address and UDP port number of the primary accounting server used by the default RADIUS scheme "system" are 127.0.0.1 and 1646 respectively.
Related command: key, radius scheme and state.
Example
# Set the IP address and UDP port number of the primary accounting server for RADIUS scheme radius1 to 10.110.1.2 and 1813 respectively.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] primary accounting 10.110.1.2 1813
primary authentication ip-address [ port-number ]
undo primary authentication
View
RADIUS scheme view
Parameter
ip-address: IP address of the primary authentication/authorization server to be used, in dotted decimal notation.
port-number: UDP port number of the primary authentication/authorization server, ranging from 1 to 65535.
Use the primary authentication command to set the IP address and port number of the primary RADIUS authentication/authorization server used by the current RADIUS scheme.
Use the undo primary authentication command to restore the default IP address and port number of the primary RADIUS authentication/authorization server, which are 0.0.0.0 and 1812 respectively.
Note that:
l           After creating a new RADIUS scheme, you should configure the IP address and UDP port number of each RADIUS server you want to use in this scheme. These RADIUS servers fall into two types: authentication/authorization, and accounting. For each kind of server, you can configure two servers in a RADIUS scheme: primary and secondary servers.
l           In an actual network environment, you can make RADIUS server-related configuration as required. But you should configure at least one authentication/authorization server and one accounting server, and at the same time, you should keep the RADIUS server port settings on the switch consistent with those on the RADIUS servers.
l           The IP address and port number of the primary authentication server used by the default RADIUS scheme "system" are 127.0.0.1 and 1645 respectively.
Example
# Set the IP address and UDP port number of the primary authentication/authorization server for RADIUS scheme radius1 to 10.110.1.1 and 1812 respectively.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] primary authentication 10.110.1.1 1812
radius client enable
undo radius client
View
Parameter
None
Use the radius client enable command to enable RADIUS authentication and accounting ports.
Use the undo radius client command to disable RADIUS authentication and accounting ports.
By default, RADIUS authentication and accounting ports are enabled.
Example
# Enable RADIUS authentication and accounting ports.
<H3C> system-view
[H3C] radius client enable
radius nas-ip ip-address
undo radius nas-ip
View
Parameter
ip-address: Source IP address to be set, an IP address of this device. This address can neither be the all 0's address nor be a Class-D address.
Use the radius nas-ip command to set the source IP address of outgoing RADIUS messages.
Use the undo radius nas-ip command to restore the default setting.
By default, no source IP address is set, and the IP address of corresponding outbound interface is used as the source IP address of RADIUS messages.
&  Note:
Note that:
l           You can set the source IP address of outgoing RADIUS messages to avoid messages returned from RADIUS server from being unable to reach their destination due to physical interface trouble. It is recommended to use a loopback interface address as the source IP address.
l           You can set only one source IP address by using this command. When you re-execute this command again, the newly set source IP address will overwrite the old one.
Example
# Set source address 129.10.10.1 for outgoing RADIUS messages.
<H3C> system-view
[H3C] radius nas-ip 129.10.10.1
1.2.16  radius scheme
radius scheme radius-scheme-name
undo radius scheme radius-scheme-name
View
Parameter
radius-scheme-name: Name of the RADIUS scheme to be created, a string of up to 32 characters.
Use the radius scheme command to create a RADIUS scheme and enter its view.
Use the undo radius scheme command to delete a specified RADIUS scheme.
By default, a RADIUS scheme named "system" has already been created in the system.
Note that:
l           All the attributes of RADIUS scheme "system" take the default values, which you can see by using the display radius scheme command.
l           The RADIUS protocol configuration is performed on a RADIUS scheme basis. For each RADIUS scheme, you should specify at least the IP addresses and UDP port numbers of the RADIUS authentication/authorization and accounting servers, and the parameters required for the RADIUS client to interact with the RADIUS servers. You should first create a RADIUS scheme and enter its view before performing other RADIUS protocol configurations.
l           A RADIUS scheme can be referenced by multiple ISP domains simultaneously.
l           The undo radius scheme command cannot delete the default RADIUS scheme. In addition, you are not allowed to delete a RADIUS scheme which is being used by an online user.
Related command: key, retry realtime-accounting, scheme, timer realtime-accounting, stop-accounting-buffer enable, retry stop-accounting, server-type, state, user-name-format, retry, display radius scheme and display radius statistics.
Example
# Create a RADIUS scheme named radius1 and enter its view.
<H3C> system-view
New Radius scheme
1.2.17  radius trap
radius trap { authentication-server-down | accounting-server-down }
undo radius trap { authentication-server-down | accounting-server-down }
View
Parameter
authentication-server-down: Enables/disables the switch to send trap messages when a RADIUS authentication server turns down.
accounting-server-down: Enables/disables the switch to send trap messages when a RADIUS accounting server turns down.
Use the radius trap command to enable the switch to send trap messages when a RADIUS server turns down.
Use the undo radius trap command to disable the switch from sending trap messages when a RADIUS authentication server or a RADIUS accounting server turns down.
This configuration takes effect on all RADIUS scheme.
&  Note:
The switch considers a RADIUS server as being down if it has tried the configured maximum number of times to send a message to the RADIUS server but does not receive any response.
Example
# Enable the switch to send trap messages when a RADIUS authentication server turns down.
<H3C> system-view
[H3C] radius trap authentication-server-down
1.2.18  reset radius statistics
View
Parameter
None
Use the reset radius statistics command to clear RADIUS message statistics.
Example
# Clear RADIUS message statistics.
<H3C> reset radius statistics
1.2.19  reset stop-accounting-buffer
reset stop-accounting-buffer { radius-scheme radius-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
View
Parameter
radius-scheme radius-scheme-name: Deletes the buffered stop-accounting requests of a specified RADIUS scheme. Here, radius-scheme-name is the name of a RADIUS scheme, which is a string of up to 32 characters.
session-id session-id: Deletes the buffered stop-accounting requests of a specified session. Here, session-id is a session ID, which is a string of up to 50 characters.
time-range start-time stop-time: Deletes the buffered stop-accounting requests generated within a specified time period. Here, start-time is the start time of the time period, stop-time is the end time of the time period, and both are in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Deletes the buffered stop-accounting requests of a specified user. Here, user-name is the name of a user, which is a string of up to 80 characters.
Use the reset stop-accounting-buffer command to delete stop-accounting requests that are buffered on the switch due to getting no response.
Related command: stop-accounting-buffer enable, retry stop-accounting and display stop-accounting-buffer.
Example
# Delete the stop-accounting requests buffered for user [email protected].
<H3C> reset stop-accounting-buffer user-name [email protected]
# Delete the stop-accounting requests buffered from 0:0:0 08/31/2002 to 23:59:59 08/31/2002.
<H3C> reset stop-accounting-buffer time-range 00:00:00-08/31/2002 23:59:59-08/31/2002
1.2.20  retry
retry retry-times
undo retry
View
RADIUS scheme view
Parameter
retry-times: Maximum number of transmission attempts of a RADIUS request, ranging from 1 to 20.
Use the retry command to set the maximum number of transmission attempts of a RADIUS request.
Use the undo retry command to restore the default maximum number of transmission attempts (that is, 3).
Note that:
l           The communication in RADIUS is unreliable because this protocol adopts UDP packets to carry its data. Therefore, it is necessary for the switch to retransmit a RADIUS request if it gets no response from the RADIUS server after the server response timeout timer expires. If the switch gets no answer after it has tried the maximum number of times to transmit a RADIUS request, the switch considers that the request fails.
l           Appropriately setting this maximum number of transmission attempts according to your network situation can improve the reacting speed of the system.
Example
# Set the maximum number of RADIUS request transmission attempts for RADIUS scheme radius1 to five.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] retry 5
1.2.21  retry realtime-accounting
retry realtime-accounting retry-times
undo retry realtime-accounting
View
RADIUS scheme view
Parameter
retry-times: Maximum allowed number of continuous real-time accounting failures, ranging from 1 to 255.
Use the retry realtime-accounting command to set the maximum allowed number of continuous real-time accounting failures.
Use the undo retry realtime-accounting command to restore the default maximum number of continuous real-time accounting failures.
By default, the maximum number of continuous real-time accounting failures is five.
Note that:
l           Generally, a RADIUS server uses the connection timeout timer to determine whether a user is currently online. If the RADIUS server receives no real-time accounting message for a specified period of time, it considers that the switch or the line is in trouble and stop accounting for the user. To make the switch cooperate with the RADIUS server in this feature, it is necessary to cut down the user connection on the switch to synchronize with the RADIUS server when the server terminates the accounting and connection of a user in case of unforeseen trouble. You can limit the number of continuous real-time accounting requests that fail due to getting no response, and then the switch will cut down user connection if the limit is reached.
l           A real-time account request may be transmitted multiple times in an accounting attempt (the maximum number of transmission attempts is set by the retry command in RADIUS scheme view). If no response is received after the switch tries the maximum number of attempts to send the request, the switch considers the accounting fails. Suppose that the response timeout time of RADIUS server is three seconds (set by the timer response-timeout command), the maximum number of transmission attempts is 3 (set by the retry command), the real-time accounting interval is 12 minutes (set by the timer realtime-accounting command), the maximum allowed number of real-time accounting failures is 5 (set by the retry realtime-accounting command). In this case, the switch initiates an accounting request every 12 minutes; if the switch does not receive a response within 3 seconds after it sends out the accounting request, it resends the request; if the switch continuously sends the accounting request for three times but does not receive any response; it considers this real-time accounting a failure. Then, the switch reinitiates the accounting request every 12 minutes; if five continuous accounting failures occur, the switch cuts down the user connection.
Related command: radius scheme and timer realtime-accounting.
Example
# Set the maximum allowed number of continuous real-time accounting failures for RADIUS scheme radius1 to 10.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] retry realtime-accounting 10
1.2.22  retry stop-accounting
retry stop-accounting retry-times
undo retry stop-accounting
View
RADIUS scheme view
Parameter
retry-times: Maximum number of transmission attempts of a buffered stop-accounting request, ranging from 10 to 65,535.
Use the retry stop-accounting command to set the maximum number of transmission attempts of a stop-accounting request buffered due to no response.
Use the undo retry stop-accounting command to restore the default maximum number of transmission attempts of a buffered stop-accounting request (that is, 500).
Stop-accounting requests are critical to billing and will eventually affect the charges of users; they are important to both users and ISPs. Therefore, the switch should do its best to transmit them to RADIUS accounting servers. When getting no response to such a request, the switch should first buffer the request on itself, and then retransmit the request to the RADIUS accounting server until it gets a response, or the maximum number of transmission attempts is reached (in this case, it discards the request).
Related command: reset stop-accounting-buffer, radius scheme and display stop-accounting-buffer.
Example
# In RADIUS scheme radius1, specify that the switch can transmit a buffered stop-accounting request at most 1000 times
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] retry stop-accounting 1000
1.2.23  secondary accounting
secondary accounting ip-address [ port-number ]
undo secondary accounting
View
RADIUS scheme view
Parameter
ip-address: IP address of the secondary accounting server to be used, in dotted decimal notation.
port-number: UDP port number of the secondary accounting server, ranging from 1 to 65535.
Use the secondary accounting command to set the IP address and port number of the secondary RADIUS accounting server to be used by the current scheme.
Use the undo secondary accounting command to restore the default IP address and port number of the secondary RADIUS accounting server, which are 0.0.0.0 and 1813 respectively.
Example
# Set the IP address and UDP port number of the secondary accounting server for RADIUS scheme radius1 to 10.110.1.1 and 1813 respectively.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] secondary accounting 10.110.1.1 1813
1.2.24  secondary authentication
secondary authentication ip-address [ port-number ]
undo secondary authentication
View
RADIUS scheme view
Parameter
ip-address: IP address of the secondary authentication/authorization server to be used, in dotted decimal notation.
port-number: UDP port number of the secondary authentication/authorization server, ranging from 1 to 65535.
Use the secondary authentication command to set the IP address and port number of the secondary RADIUS authentication/authorization server to be used by the current scheme.
Use the undo secondary authentication command to restore the default IP address and port number of the secondary RADIUS authentication/authorization server, which is 0.0.0.0 and 1812 respectively.
Example
# Set the IP address and UDP port number of the secondary authentication/authorization server for RADIUS scheme radius1 to 10.110.1.2 and 1812 respectively.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] secondary authentication 10.110.1.2 1812
1.2.25  server-type
server-type { extended | standard }
undo server-type
View
RADIUS scheme view
Parameter
extended: Specifies to support H3C's RADIUS server (which is generally a CAMS), that is, use the procedure and message format of private RADIUS protocol to interact with an H3C's RADIUS server.
standard: Specifies to support standard RADIUS server, that is, use the procedure and message format of a standard RADIUS protocol (RFC 2865/2866 or above) to interact with a standard RADIUS server.
Use the server-type command to configure the switch to support a specified type of RADIUS server.
Use the undo server-type command to restore the default setting.
By default, what type of RADIUS server the switch supports is not specified.
Example
# Configure the switch to support H3C's RADIUS server in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] server-type extended
1.2.26  state
state { primary | secondary } { accounting | authentication } { block | active }
View
RADIUS scheme view
Parameter
primary: Specifies that the server to be set is a primary RADIUS server.
secondary: Specifies that the server to be set is a secondary RADIUS server.
accounting: Specifies that the server to be set is a RADIUS accounting server.
authentication: Specifies that the server to be set is a RADIUS authentication/authorization server.
block: Sets the status of the specified RADIUS server to block (that is, the down state).
active: Sets the status of the specified RADIUS server to active (that is, the normal working state).
Use the state command to set the status of a RADIUS server.
By default, all RADIUS servers in any customized RADIUS scheme are in the block state; the primary RADIUS servers in the default RADIUS scheme "system" are in the active state, and the secondary RADIUS servers in "system" are in the block state.
For the primary and secondary servers (authentication/authorization servers, or accounting servers) in a RADIUS scheme, note that:
l           When the switch fails to communicate with the primary server due to some server trouble, the switch will turn to the secondary server and exchange messages with the secondary server.
l           After the primary server remains in the block state for a set time (set by the timer quiet command), the switch will try to communicate with the primary server again when it receives a RADIUS request. If it finds that the primary server has recovered, the switch immediately restores the communication with the primary server instead of communicating with the secondary server, and at the same time restores the status of the primary server to active while keeping the status of the secondary server unchanged.
l           When both primary and secondary servers are in the active or block state, the switch sends messages only to the primary server.
Related command: radius scheme, primary authentication, secondary authentication, primary accounting and secondary accounting.
Example
# Set the status of the secondary authentication server in RADIUS scheme radius1 to active.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] state secondary authentication active
1.2.27  stop-accounting-buffer enable
undo stop-accounting-buffer enable
View
RADIUS scheme view
Parameter
None
Use the stop-accounting-buffer enable command to enable the switch to buffer the stop-accounting requests that get no response.
Use the undo stop-accounting-buffer enable command to disable the switch from buffering the stop-accounting requests that get no response.
By default, the switch is enabled to buffer the stop-accounting requests that get no response.
Stop-accounting requests are critical to billing and will eventually affect the charges; they are important to both users and ISPs. Therefore, the switch should do its best to transmit them to RADIUS accounting servers. When getting no response to such a request, the switch should first buffer the request on itself, and then retransmit the request to the RADIUS accounting server until it gets a response, or the maximum number of transmission attempts is reached (in this case, it discards the request).
Example
# Enable the switch to buffer the stop-accounting requests that get no response from the servers in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] stop-accounting-buffer enable
1.2.28  timer
timer seconds
undo timer
View
RADIUS scheme view
Parameter
seconds: Response timeout time of RADIUS servers, ranging from 1 to 10 seconds.
Use the timer command to set the response timeout time of RADIUS servers (that is, the timeout time of the response timeout timer of RADIUS servers).
Use the undo timer command to restore the default response timeout timer of RADIUS servers.
By default, the response timeout time of RADIUS servers is 3 seconds.
Note that:
l           After sending out a RADIUS request (authentication/authorization request or accounting request) to a RADIUS server, the switch waits for a response from the server. The maximum time that the switch can wait for the response is called the response timeout time of RADIUS servers, and the corresponding timer in the switch system is called the response timeout timer of RADIUS servers. You can use the timer command to set the timeout time of this timer, and if the switch gets no answer before the response timeout timer expires, it needs to retransmit the request to ensure that the user can obtain RADIUS service.
l           Appropriately setting the timeout time of this timer according to your network situation can improve the performance of your system.
l           The timer command has the same function with the timer response-timeout command.
Related command: radius scheme and retry.
Example
# Set the timeout time of the response timeout timer for RADIUS scheme radius1 to 5 seconds.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] timer 5
1.2.29  timer quiet
timer quiet minutes
undo timer quiet
View
RADIUS scheme view
Parameter
minutes: Wait time before primary server state restoration, ranging from 1 to 255 minutes.
Use the timer quiet command to set the time that the switch waits before it tries to re-communicate with the primary server and restore the status of the primary server to active.
Use the undo timer quiet command to restore the default wait time.
By default, the switch waits five minutes.
Example
# Configure the switch to wait 10 minutes before it tries to restore the status of the primary server to active.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] timer quiet 10
1.2.30  timer realtime-accounting
timer realtime-accounting minutes
undo timer realtime-accounting
View
RADIUS scheme view
Parameter
minutes: Real-time accounting interval, in minutes. It ranges from 3 to 60 and must be a multiple of 3.
Use the timer realtime-accounting command to set the real-time accounting interval.
Use the undo timer realtime-accounting command to restore the default real-time accounting interval.
By default, this interval is 12 minutes.
Note that:
l           To control the interval at which users are charged in real time, you can set the real-time accounting interval. After the setting, the switch periodically sends online users' accounting information to the RADIUS server at the set interval.
l           The setting of the real-time accounting interval depends, to some degree, on the performance of the switch and the RADIUS server. The higher the performance of the switch and the RADIUS server is, the shorter the interval can be. It is recommended to set the interval as long as possible when the number of users is relatively great (≥1000). Table 1-6 lists the recommended intervals for different numbers of users.
Table 1-6 Numbers of users and recommended intervals
Number of users
1 to 99
3
100 to 499
6
500 to 999
12
≥1000
≥15
Related command: retry realtime-accounting and radius scheme.
Example
# Set the real-time accounting interval of RADIUS scheme radius1 to 51 minutes.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] timer realtime-accounting 51
1.2.31  timer response-timeout
timer response-timeout seconds
undo timer response-timeout
View
RADIUS scheme view
Parameter
Use the timer response-timeout command to set the response timeout time of RADIUS servers.
Use the undo timer response-timeout command to restore the default response timeout time of RADIUS servers.
Note that:
l           After sending out a RADIUS request (authentication/authorization request or accounting request) to a RADIUS server, the switch waits for a response from the server. The maximum time that the switch can wait for the response is called the response timeout time of RADIUS servers, and the corresponding timer in the switch system is called the response timeout timer of RADIUS servers. You can use the timer response-timeout command to set the timeout time of this timer, and if the switch gets no answer before the response timeout timer expires, it needs to retransmit the request to ensure that the user can obtain RADIUS service.
l           This command has the same function with the timer command.
Example
# Set the response timeout time in RADIUS scheme radius1 to five seconds.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] timer response-timeout 5
1.2.32  user-name-format
user-name-format { with-domain | without-domain }
View
RADIUS scheme view
Parameter
with-domain: Specifies to include ISP domain names in the user names to be sent to RADIUS server.
without-domain: Specifies to exclude ISP domain names from the user names to be sent to RADIUS server.
Use the user-name-format command to set the format of the user names to be sent to RADIUS server
By default, except for the default RADIUS scheme "system", the user names sent to RADIUS servers in any RADIUS scheme carry ISP domain names.
Note that:
l           Generally, an access user is named in the userid@isp-name format. Here, isp-name behind the @ character represents the ISP domain name, by which the device determines which ISP domain a user belongs to. However, some old RADIUS servers cannot accept the user names that carry ISP domain names. In this case, it is necessary to remove domain names from user names before sending user names to RADIUS server. For this reason, the user-name-format command is designed for you to specify whether or not ISP domain names are carried in the user names to be sent to the RADIUS server.
l           For a RADIUS scheme, if you have specified to exclude ISP domain names from user names, you should not use this RADIUS scheme in more than one ISP domain. Otherwise, such errors may occur: the RADIUS server regards two different users having the same name but belonging to different ISP domains as the same user (because the user names sent to it are the same).
Example
# Specify to exclude ISP domain names from the user names to be sent to RADIUS server in RADIUS scheme radius1.
<H3C> system-view
New Radius scheme
[H3C-radius-radius1] user-name-format without-domain
1.3  HWTACACS Configuration Commands
1.3.1  data-flow-format
data-flow-format packet { giga-packet | kilo-packet | mega-packet | one-packet }
undo data-flow-format { data | packet }
View
HWTACACS scheme view
Parameter
data: Sets the data unit of outgoing HWTACACS data flows, which can be byte, giga-byte, kilo-byte, or mega-byte.
packet: Sets the packet unit of outgoing HWTACACS data flows, which can be one-packet, giga-packet, kilo-packet, or mega-packet.
Use the data-flow-format command to set the units of data flows to TACACS servers.
By default, the data unit and packet unit for outgoing HWTACACS flows are byte and one-packet respectively.
Related command: display hwtacacs.
Example
# Specify to measure data and packets in data flows to TACACS servers in kilo-bytes and kilo-packets respectively in HWTACACS scheme hwt1.
<H3C> system-view
[H3C] hwtacacs scheme hwt1
[H3C- hwtacacs-hwt1] data-flow-format data kilo-byte
[H3C- hwtacacs-hwt1] data-flow-format packet kilo-packet
1.3.2  display hwtacacs
display hwtacacs [ hwtacacs-scheme-name [ statistics ] ]
View
Parameter
hwtacacs-scheme-name: HWTACACS scheme name, a string of 1 to 32 characters. This name is case-insensitive. If this argument is not specified, the system displays information about all HWTACACS schemes.
statistics: Displays statistics about one or all HWTACACS schemes.
Use the display hwtacacs command to display configuration or statistics information of one specified or all HWTACACS schemes.
Related command: hwtacacs scheme.
Example
# Display configuration information of HWTACACS scheme gy.
<H3C> display hwtacacs gy
--------------------------------------------------------------------  HWTACACS-server template name   : gy
  Primary-authentication-server   : 172.31.1.11:49
  Primary-authorization-server    : 172.31.1.11:49
  Primary-accounting-server       : 172.31.1.11:49
  Secondary-authentication-server : 0.0.0.0:0
  Secondary-authorization-server  : 0.0.0.0:0
  Secondary-accounting-server     : 0.0.0.0:0
  Current-authentication-server   : 172.31.1.11:49
  Current-authorization-server    : 172.31.1.11:49
  Current-accounting-server       : 172.31.1.11:49
  Source-IP-address               : 0.0.0.0
  key authentication              : 790131
  key authorization               : 790131
  key accounting                  : 790131
  Quiet-interval(min)             : 5
  Response-timeout-Interval(sec)  : 5
  Domain-included                 : No
  Traffic-unit                    : B
  Packet traffic-unit             : one-packet
1.3.3  display stop-accounting-buffer
display stop-accounting-buffer { hwtacacs-scheme hwtacacs-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
View
Parameter
hwtacacs-scheme hwtacacs-scheme-name: Displays the buffered stop-accounting requests of a specified HWTACACS scheme. Here, hwtacacs-scheme-name is a string of up to 32 characters.
time-range start-time stop-time: Displays the buffered stop-accounting requests generated in a specified time range. Here, start-time is the start time of the time range; stop-time is the end time of the time range; both are in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd. The parameters here are used to display all the buffered stop-accounting requests generated from start-time to stop-time.
Use the display stop-accounting-buffer command to display stop-accounting requests buffered in the switch.
Related command: reset stop-accounting-buffer, stop-accounting-buffer enable, and retry stop-accounting.
Example
# Display stop-accounting requests buffered for HWTACACS scheme hwt1.
<H3C> display stop-accounting-buffer hwtacacs-scheme hwt1
1.3.4  hwtacacs nas-ip
hwtacacs nas-ip ip-address
undo hwtacacs nas-ip
View
Parameter
ip-address: Source IP address to be set, an IP address of this device. This address can neither be the all 0's address nor be a Class D address.
Use the hwtacacs nas-ip command to set the source address of outgoing HWTACACS messages.
Use the undo hwtacacs nas-ip command to restore the default setting.
By default, no source address is specified, and the IP address of corresponding outbound interface is used as the source address.
Note that:
l           You can specify the source address of outgoing HWTACACS messages to avoid messages returned from server from being unable to reach their destination due to physical interface trouble. It is recommended to use a loopback interface address as the source IP address.
l           You can specify only one source IP address by using this command. When you re-execute this command again, the newly set source IP address will overwrite the old one.
Example
# Configure the switch to use source address 129.10.10.1 for outgoing HWTACACS messages.
<H3C> system-view
[H3C] hwtacacs nas-ip 129.10.10.1
1.3.5  hwtacacs scheme
hwtacacs scheme hwtacacs-scheme-name
undo hwtacacs scheme hwtacacs-scheme-name
View
Parameter
Use the hwtacacs scheme command to create an HWTACACS scheme and enter its view.
Use the undo hwtacacs scheme command to delete an HWTACACS scheme.
By default, no HWTACACS scheme exists.
&  Note:
If the fabric function is enabled on the switch, you cannot create an HWTACACS scheme because they are exclusive to each other.
Example
# Create an HWTACACS scheme named "hwt1" and enter the corresponding HWTACACS scheme view.
<H3C> system-view
[H3C-hwtacacs-hwt1]
1.3.6  key
key { accounting | authentication | authorization } string
undo key { accounting | authentication | authorization }
View
Parameter
accounting: Sets a shared key for HWTACACS accounting messages.
authentication: Sets a shared key for HWTACACS authentication messages.
authorization: Sets a shared key for HWTACACS authorization messages.
Use the key command to configure a shared key for HWTACACS authentication, authorization or accounting messages.
Use the undo key command to delete such a configuration.
By default, no key is set for HWTACACS messages.
Example
# Use hello as the shared key for HWTACACS accounting messages in HWTACACS scheme hwt1.
<H3C> system-view
[H3C-hwtacacs-hwt1] key accounting hello
1.3.7  nas-ip
nas-ip ip-address
undo nas-ip
View
Parameter
Use the nas-ip command to set the source address of outgoing HWTACACS messages.
Use the undo nas-ip command to restore the default setting.
Note that:
l           You can set the source address of HWTACACS messages to avoid messages returned from server from being unable to reach their destination due to physical interface trouble. It is recommended to use a loopback interface address as the source IP address.
Example
# Set source IP address 10.1.1.1 for outgoing HWTACACS messages in HWTACACS scheme hwt1.
<H3C> system-view
[H3C-hwtacacs-hwt1] nas-ip 10.1.1.1
1.3.8  primary accounting
primary accounting ip-address [ port ]
View
Parameter
ip-address: IP address of the primary accounting server to be used, a valid unicast address in dotted decimal notation.
port: Port number of the primary accounting server, ranging from 1 to 65535.
Use the primary accounting command to set the IP address and port number of the primary HWTACACS accounting server to be used by the current scheme.
Use the undo primary accounting command to restore the default IP address and port number of the primary HWTACACS accounting server, which are 0.0.0.0 and 49 respectively.
Note that:
l           You are not allowed to set the same IP address for both primary and secondary accounting servers. If you do this, your setting will fail.
l           If you re-execute the command, the new setting will overwrite the old one.
l           You can remove an accounting server setting only when there is no active TCP connection that is sending accounting messages to the server.
Example
# Set the IP address and UDP port number of the primary accounting server for HWTACACS scheme test1 to 10.163.155.12 and 49 respectively.
<H3C> system-view
[H3C] hwtacacs scheme test1
[H3C-hwtacacs-test1] primary accounting 10.163.155.12 49
1.3.9  primary authentication
primary authentication ip-address [ port ]
View
Parameter
ip-address: IP address of the primary authentication server to be used, a valid unicast address in dotted decimal notation.
port: Port number of the primary authentication server, ranging from 1 to 65535.
Use the primary authentication command to set the IP address and port number of the primary HWTACACS authentication server to be used by the current scheme.
Use the undo primary authentication command to restore the default IP address and port number of the primary HWTACACS authentication server, which are 0.0.0.0 and 49 respectively.
Note that:
l           You are not allowed to set the same IP address for both primary and secondary authentication servers. If you do this, your setting will fail.
l           You can remove an authentication server setting only when there is no active TCP connection that is sending authentication messages to the server.
Example
# Set the IP address and UDP port number of the primary authentication server for HWTACACS scheme hwt1 to 10.163.155.13 and 49 respectively.
<H3C> system-view
[H3C-hwtacacs-hwt1] primary authentication 10.163.155.13 49
1.3.10  primary authorization
primary authorization ip-address [ port ]
undo primary authorization
View
Parameter
ip-address: IP address of the primary authorization server to be used, a valid unicast address in dotted decimal notation.
port: Port number of the primary authorization server, ranging from 1 to 65535.
Use the primary authorization command to set the IP address and port number of the primary HWTACACS authorization server to be used by the current scheme.
Use the undo primary authorization command to restore the default IP address and port number of the primary authorization server, which are 0.0.0.0 and 49 respectively.
Note that:
l           You are not allowed to set the same IP address for both primary and secondary authorization servers. If you do this, your setting will fail.
l           You can remove an authorization server setting only when there is no active TCP connection that is sending authorization messages to the server.
Example
# Set the IP address and UDP port number of the primary authorization server for HWTACACS scheme hwt1 to 10.163.155.13 and 49 respectively.
<H3C> system-view
[H3C-hwtacacs-hwt1] primary authorization 10.163.155.13 49
1.3.11  reset hwtacacs statistics
reset hwtacacs statistics { accounting | authentication | authorization | all }
View
Parameter
accounting: Clears HWTACACS accounting statistics.
authentication: Clears HWTACACS authentication statistics.
authorization: Clears HWTACACS authorization statistics.
all: Clears all HWTACACS statistics.
Use the reset hwtacacs statistics command to clear HWTACACS statistics.
Example
# Clear all HWTACACS protocol statistics.
<H3C> reset hwtacacs statistics all
1.3.12  reset stop-accounting-buffer
reset stop-accounting-buffer { hwtacacs-scheme hwtacacs-scheme-name | session-id session-id | time-range start-time stop-time | user-name user-name }
View
Parameter
hwtacacs-scheme hwtacacs-scheme-name: Deletes the buffered stop-accounting requests of a specified HWTACACS scheme. Here, hwtacacs-scheme-name is the name of a HWTACACS scheme, which is a string of up to 32 characters that does not contain any of the following characters: /:*?<>.
time-range start-time stop-time: Deletes the buffered stop-accounting requests generated within a specified time period, Here, start-time is the start time of the time period; stop-time is the end time of the time period, and both are in the format of hh:mm:ss-mm/dd/yyyy or hh:mm:ss-yyyy/mm/dd.
user-name user-name: Deletes the buffered stop-accounting requests of a specified user. Here, user-name is the name of a user, which is a string of up to 80 characters. This string cannot contain any of the following characters: /:*?<>, and can contain no more than one @ character. The pure user name (user ID, that is, the part before @) cannot be longer than 55 characters, and the domain name (the part behind @) cannot be longer than 24 characters.
Use the reset stop-accounting-buffer command to clear stop-accounting requests that are buffered on the switch due to getting no response.
Related command: stop-accounting-buffer enable, retry stop-accounting, display stop-accounting-buffer.
Example
# Delete the stop-accounting requests buffered for HWTACACS scheme hwt1.
<H3C> reset stop-accounting-buffer hwtacacs-scheme hwt1
1.3.13  retry stop-accounting
View
Parameter
retry-times: Maximum number of transmission attempts of a stop-accounting request, ranging from 1 to 300.
Use the retry stop-accounting command to enable the stop-accounting request retransmission function and set the maximum number of attempts to transmit a stop-accounting request.
Use the undo retry stop-accounting command to restore the default setting.
By default, this function is enabled and the maximum number of transmission attempts is 100.
Related command: reset stop-accounting-buffer, hwtacacs scheme, and display stop-accounting-buffer.
Example
# Enable the stop-accounting request retransmission function and set the maximum number of transmission attempts of a request to 50.
<H3C> system-view
[H3C-hwtacacs-hwt1] retry stop-accounting 50
1.3.14  secondary accounting
secondary accounting ip-address [ port ]
View
Parameter
ip-address: IP address of the secondary accounting server to be used, a valid unicast address in dotted decimal notation.
port: Port number of the secondary accounting server, ranging from 1 to 65535.
Use the secondary accounting command to set the IP address and port number of the secondary HWTACACS accounting server to be used by the current scheme.
Use the undo secondary accounting command to restore the default IP address and port number of the secondary HWTACACS accounting server, which are 0.0.0.0 and 49 respectively.
Note that:
Example
# Set the IP address and UDP port number of the secondary accounting server for HWTACACS scheme hwt1 to 10.163.155.12 and 49 respectively.
<H3C> system-view
[H3C-hwtacacs-hwt1] secondary accounting 10.163.155.12 49
1.3.15  secondary authentication
secondary authentication ip-address [ port ]
View
Parameter
ip-address: IP address of the secondary authentication server to be used, a valid unicast address in dotted decimal notation.
port: Port number of the secondary authentication server, ranging from 1 to 65535.
Use the secondary authentication command to set the IP address and port number of the secondary HWTACACS authentication server to be used by the current scheme.
Use the undo secondary authentication command to restore the default IP address and port number of the secondary HWTACACS authentication server, which are 0.0.0.0 and 49 respectively.
Note that:
l           If you re-execute the command, the new setting overwrites the old one.
Example
# Set the IP address and UDP port number of the secondary authentication server for HWTACACS scheme hwt1 to 10.163.155.13 and 49 respectively.
<H3C> system-view
[H3C-hwtacacs-hwt1] secondary authentication 10.163.155.13 49
1.3.16  secondary authorization
secondary authorization ip-address [ port ]
undo secondary authorization
View
Parameter
ip-address: IP address of the secondary authorization server, a valid unicast address in dotted decimal notation.
port: Port number of the secondary authorization server, ranging from 1 to 65535.
Use the secondary authorization command to set the IP address and port number of the secondary HWTACACS authorization server to be used by the current scheme.
Use the .undo secondary authorization command to restore the default IP address and port number of the secondary HWTACACS authorization server, which are 0.0.0.0 and 49 respectively.
Note that:
Example
# Set the IP address and UDP port number of the secondary authorization server for HWTACACS scheme hwt1 to 10.163.155.13 and 49 respectively.
<H3C> system-view
[H3C-hwtacacs-hwt1] secondary authorization 10.163.155.13 49
1.3.17  timer quiet
timer quiet minutes
undo timer quiet
View
Parameter
Example
<H3C> system-view
[H3C-hwtacacs-hwt1] timer quiet  10
1.3.18  timer realtime-accounting
View
Parameter
By default, the real-time accounting interval is 12 minutes.
Note that:
l           To control the interval at which users are charged in real time, you can set the real-time accounting interval. After the setting, the switch periodically sends online users' accounting information to TACACS accounting server at the set interval.
l           The setting of the real-time accounting interval depends, to some degree, on the performance of the switch and the TACACS server. The higher the performance of the switch and the TACACS server is, the shorter the interval can be. It is recommended to set the interval as long as possible when the number of users is relatively great (≥1000). The following table lists the recommended intervals for different numbers of users.
Table 1-7 Numbers of users and recommended intervals
Number of users
1 to 99
3
100 to 499
6
500 to 999
12
≥1000
≥15
Example
# Set the real-time accounting interval in HWTACACS scheme hwt1 to 51 minutes.
<H3C> system-view
[H3C-hwtacacs-hwt1] timer realtime-accounting 51
1.3.19  timer response-timeout
View
Parameter
seconds: Response timeout time of TACACS servers, ranging from 1 to 300 seconds.
Use the timer response-timeout command to set the response timeout time of TACACS servers.
Use the undo timer response-timeout command to restore the default response timeout time of TACACS servers.
By default, the response timeout time of TACACS servers is five seconds.
As HWTACACS is based on TCP, both server response timeout and TCP timeout may cause disconnection from TACACS server.
Example
# Set the response timeout time of TACACS servers to 30 seconds for HWTACACS scheme hwt1.
<H3C> system-view
[H3C-hwtacacs-hwt1] timer response-timeout 30
1.3.20  user-name-format
View
Parameter
with-domain: Specifies to include ISP domain names in the user names to be sent to TACACS server.
without-domain: Specifies to exclude ISP domain names from the user names to be sent to TACACS server.
Use the user-name-format command to set the format of the user names to be sent to TACACS server.
By default, the user names sent to TACACS server in a HWTACACS scheme carry ISP domain names.
Note that:
l           Generally, an access user is named in the userid@isp-name format. Here, isp-name behind the @ character represents the ISP domain name, by which the device determines which ISP domain a user belongs to. However, some old TACACS servers cannot accept the user names that carry ISP domain names. In this case, it is necessary to remove domain names from user names before sending user names to TACACS server. For this reason, the user-name-format command is designed for you to specify whether or not ISP domain names are carried in the user names to be sent to TACACS server.
l           For a HWTACACS scheme, if you have specified to exclude ISP domain names from user names, you should not use this scheme in more than one ISP domain. Otherwise, such errors may occur: the TACACS server regards two different users having the same name but belonging to different ISP domains as the same user (because the user names sent to it are the same).
Example
# Specify to exclude ISP domain names from the user names to be sent to TACACS server in HWTACACS scheme hwt1.
<H3C> system-view
[H3C-hwtacacs-hwt1] user-name-format without-domain
Chapter 2  EAD Configuration Commands
2.1  EAD Configuration Commands
2.1.1  security-policy-server
security-policy-server ip-address
undo security-policy-server [ ip-address | all ]
View
RADIUS scheme view
Parameter
ip-address: IP address of a security policy server.
all: IP addresses of all security policy servers.
Use the security-policy-server command to set the IP address of a security policy server.
Use the undo security-policy-server command to remove one specified or all security policy server address settings.
You can configure up to eight security policy server addresses in each RADIUS scheme. The switch only responds to those session control messages that come from authentication server or security policy server.
Example
# Set a security policy server address 192.168.0.1 on the switch.
<H3C>system-view
[H3C] radius scheme H3C
[H3C-radius-H3C] security-policy-server 192.168.0.1
[H3C-radius-H3C] display current-configuration
radius scheme H3C
primary authentication 1.1.11.29 1812
secondary authentication 127.0.0.1 1645
