H3C MSR WiNet系列路由器 接口模块手册(V7)-6W105
01-正文
本章节下载 01-正文  (9.18 MB)
01-正文
  录
1 SIC/DSIC接口模块
1.1 以太网交换模块
1.1.1 SIC-4FSW/SIC-4FSWP/DSIC-9FSW/DSIC-9FSWP
1.1.2 SIC-4GSW
1.1.3 RT-SIC-4GSWF
1.2 以太网模
1.2.1 SIC-1FEA
1.2.2 SIC-1FEF
1.2.3 SIC-1GEC-V2
1.3 E1/T1模块
1.3.1 SIC-E1-F
1.3.2 SIC-2E1-F
1.3.3 SIC-1EPRI
1.3.4 SIC-T1-F
1.4 串口模块
1.4.1 SIC-8AS
1.4.2 SIC-16AS
1.4.3 SIC-1SAE/SIC-2SAE/SIC-4SAE
1.5 模拟调制解调器接口模块
1.5.1 SIC-1AM
1.6 xDSL模块
1.6.1 SIC-1ADSL
1.6.2 SIC-1ADSL-I
1.7 ISDN BRI模块
1.7.1 SIC-1BS
1.8 语音模块
1.8.1 SIC-1FXS/SIC-1FXO&SIC-2FXS/SIC-2FXO
1.8.2 SIC-2FXS1FXO
1.8.3 DSIC-4FXS1FXO
1.8.4 SIC-1BSV/SIC-2BSV
1.8.5 SIC-1VE1
1.8.6 SIC-1VT1
1.8.7 SIC-1VE1T1
1.9 3G模块
1.9.1 SIC-3G-TD
1.9.2 SIC-3G-HSPA
1.10 4G模块
1.10.1 SIC-4G-LTE-M
1.10.2 SIC-4G-CNDE
1.10.3 RT-SIC-4G-CAT6
1.10.4 SIC-D4G-CNDE
1.11 5G模块
1.11.1 RT-SIC-5G
1.11.2 RT-SIC-5G-CN
1.12 网络数据加密模块
1.12.1 SIC-CNDE
1.12.2 SIC-CNDE-SJK
1.12.3 SIC-4G-CNDE-SJK
1.12.4 SIC-D4G-CNDE-SJK
1.13 WLAN模块
1.13.1 SIC-AP220
1.13.2 SIC-AP320
1.14 硬盘转接模块
1.14.1 RT-SIC-M2-SATA
2 HMIM/DHMIM接口模块
2.1 以太网交换模块
2.1.1 HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE
2.1.2 HMIM-8GSWF
2.2 以太网模块
2.2.1 HMIM-2GEE/HMIM-4GEE/HMIM-8GEE
2.2.2 RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2
2.2.3 HMIM-2GEF/HMIM-4GEF/HMIM-8GEF
2.2.4 RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2
2.2.5 RT-HMIM-4XP
2.3 ATM模块
2.3.1 HMIM-1ATM-OC3
2.4 POS (SDH/SONET) 模块
2.4.1 HMIM-1POS
2.4.2 RT-HMIM-2POS-STM1
2.4.3 RT-HMIM-4POS-STM1/4
2.5 CPOS (SDH/SONET) 模块
2.5.1 HMIM-1CPOS/HMIM-2CPOS
2.6 E1/T1模块
2.6.1 HMIM-1E1/HMIM-2E1/HMIM-4E1/HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F
2.6.2 HMIM-8E1(75)/HMIM-8E1(75)-F
2.6.3 HMIM-2T1/HMIM-4T1-F
2.6.4 HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1/HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F
2.7 E3/T3模块
2.7.1 HMIM-1CE3
2.8 串口模块
2.8.1 HMIM-2SAE/HMIM-4SAE/HMIM-8SAE
2.8.2 HMIM-8ASE/HMIM-16ASE
2.8.3 RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2
2.9 语音模块
2.9.1 HMIM-16FXS
2.9.2 HMIM-8FXS8FXO
2.9.3 HMIM-2VE1
2.9.4 HMIM-2VT1
2.9.5 HMIM-1VE1
2.9.6 HMIM-1VT1
2.9.7 HMIM-4FXS/HMIM-4FXO
2.9.8 HMIM-4E&M/HMIM-8E&M
2.10 模拟Modem模块
2.10.1 HMIM-6AM
2.10.2 HMIM-6FCM
2.11 网络数据加密模块
2.11.1 HMIM-CNDE-SJK
2.12 HMIM转接模块
2.12.1 HMIM-Adapter/HMIM-Adapter-H
3 线缆及连接
3.1 接口类型为以太网接口
3.2 接口类型为光接口
3.3 接口类型为E1接口
3.4 接口类型为T1接口
3.5 接口类型为E3/T3接口
3.6 接口类型为同/异步串口
3.7 接口类型为异步串口
3.8 接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
3.9 接口类型为E&M接口
3.10 接口类型为BSV/BSE接口
3.11 接口类型为3G接口
3.12 接口类型为4G接口
3.13 接口类型为5G接口
3.14 接口类型为GPS接口
3.15 接口类型为GNSS接口
3.15.1 RT-SIC-4G-CAT6接口模块GNSS天线外观及适用款型
3.15.2 RT-SIC-4G-CAT6接口模块GNSS天线连接方法
3.16 接口类型为WLAN接口
1 SIC/DSIC接口模块
·     SIC接口模块不支持热插拔(除部分带有REMOVE按钮的SIC接口模块外)。
·     带有REMOVE按钮的SIC接口模块如需带电更换,请先通过REMOVE按钮进行操作,具体操作方法请进入该接口模块详情页面进行查看。需要注意的是,带有REMOVE按钮的SIC接口模块同时支持remove命令和REMOVE按钮,在进行带电更换时,两种方法不允许同时使用,否则可能导致接口模块不可用等情况。
·     DSIC接口模块不支持热插拔。
MSR WiNet系列路由器采用模块化结构,提供了大量可供选配的SIC(Smart Interface Card)/DSIC(Double Smart Interface Card)接口模块,其中SIC接口模块占用路由器的一个SIC槽位,DSIC接口模块占用路由器的两个SIC槽位。该系列接口卡提供了同/异步串口、以太网接口、E1/T1、ISDN BRI/PRI、ADSL、语音接口、二层交换口等丰富的接口特性。
1.1  以太网交换模块
·     SIC-4FSW
·     SIC-4FSWP
·     DSIC-9FSW
·     DSIC-9FSWP
·     SIC-4GSW
·     RT-SIC-4GSWF
1. 简介
SIC-4FSW/SIC-4FSWP和DSIC-9FSW/DSIC-9FSWP接口模块是4/9端口10M/100M以太网二层交换SIC模块,主要实现4/9路以太网的二层交换功能,也可以实现三层交换功能,可以在路由器上提供多达4/9个10/100Base-Tx以太网端口,适合在小型企业网内作为交换/路由综合设备,直接连接企业内部的PC及网络设备。SIC-4FSWP/DSIC-9FSWP可以通过PoE电源对PD设备远程供电。
模块支持的功能如下:
·     当用户采用5类双绞线(交叉和直通均支持)时,可支持100米的传输距离,以及任意端口间的100M线速转发。
·     接口可以工作在10Mbps、100Mbps两种速度下,且能实现自适应。
·     接口有全双工和半双工两种工作方式,其中全双工是比较常用的工作方式。
2. 接口属性
表1-1 SIC-4FSW/SIC-4FSWP/DSIC-9FSW/DSIC-9FSWP接口属性
属性
SIC-4FSW
SIC-4FSWP
DSIC-9FSW
DSIC-9FSWP
连接器类型
RJ-45
接口类型
MDI/MDIX
连接器数量
4
9
电缆类型
标准(直通)以太网线/交叉以太网线均支持
工作方式
10M/100Mbps自适应
全双工/半双工
MDI(Medium Dependent Interface)是以太网的介质有关接口的缩写,一般网卡上的以太网接口多为此类型。另一种为交叉的介质有关接口,缩写为MDIX,常用于HUB或LAN Switch。
3. 接口指示灯
SIC-4FSW/SIC-4FSWP面板如下图所示:
图1-1 SIC-4FSW面板
SIC-4FSW
图1-2 SIC-4FSWP面板
SIC-4FSW-POE
DSIC-9FSW/DSIC-9FSWP面板如下图所示:
图1-3 DSIC-9FSW面板
DSIC-9FSW+口
图1-4 DSIC-9FSWP面板
DSIC-9FSW-POE+口
面板上每个端口对应一个绿色的LED指示灯,指示灯含义相同,如下表所示:
表1-2 面板指示灯含义
指示灯状态
含义
常亮
端口链路连通(LINK),无数据收发
端口链路没有连通(没有LINK)
闪烁
端口链路不仅连通(LINK),且有数据收发(ACT)
另外,每个单板对外提供一个PoE的电源指示灯,是为相应的PoE功能的单板(SIC-4FSWP和DSIC-9FSWP)提供的。
4. 接口电缆及连接方法
以太网接口电缆及连接方法请参见3.1  接口类型为以太网接口
1.1.2  SIC-4GSW
1. 简介
SIC-4GSW是4端口1000M以太网二层交换SIC接口模块,对外提供4个普通的1000M的RJ-45连接器接口,SIC-4GSW模块适合在小型企业网内作为交换/路由综合设备,直接连接企业内部的PC及网络设备。
模块支持的功能如下:
·     当用户采用5类双绞线(交叉和直通均支持)时,可支持100米的传输距离。
·     当用户采用超5类双绞线(交叉和直通均支持)时,可支持任意端口间的1000M线速转发。
·     接口可以工作在10Mbps、100Mbps和1000Mbps三种速度下,且能实现自适应。
2. 接口属性
表1-3 SIC-4GSW接口属性
属性
SIC-4GSW模块
连接器类型
RJ-45接口
接口类型
MDI/MDIX
连接器数量
4
线缆类型
工作方式
4个千兆电接口:10M/100M/1000Mbps自适应
3. 接口指示灯
SIC-4GSW面板如下图所示:
图1-5 SIC-4GSW面板
面板上每个千兆以太网端口对应一个绿色LED指示灯,指示灯含义相同,如下表所示:
表1-4 SIC-4GSW千兆以太网端口指示灯含义
指示灯状态
含义
端口链路没有连通
常绿
端口链路连通,并且工作在1000M模式
绿灯闪烁
端口工作在1000M模式,并且有数据收发
常黄
端口链路连通,并且工作在10M/100M模式
黄灯闪烁
端口链路工作在10M/100M模式,并且有数据收发
4. 接口电缆及连接方法
1.1.3  RT-SIC-4GSWF
RT-SIC-4GSWF是4端口百/千兆以太网L2/L3 SIC光接口模块的简称,对外提供4个光纤连接器接口,其中G(Gigabit Ethernet)是自适应的百/千兆以太网的英文缩写,F为Fiber,表示光接口。RT-SIC-4GSWF模块适合在小型企业网内作为交换/路由综合设备,直接连接企业内部的网络设备。
RT-SIC-4GSWF支持功能如下:
·     支持多种类型百/千兆以太网的可插拔光模块,用户可根据自己的需要选购。
·     接口工作在100M/1000Mbps速率下。
·     支持全双工工作方式。
1. 接口属性
RT-SIC-4GSWF接口属性如下表所示。
表1-5 RT-SIC-4GSWF接口属性
属性
RT-SIC-4GSWF描述
接口数量
4
连接器类型
SFP/LC
接口标准
802.3/802.3u/802.3ab
工作方式
100/1000Mbps
全双工模式
2. 面板及接口指示灯
RT-SIC-4GSWF的面板如下图所示:
图1-6 RT-SIC-4GSWF面板
RT-SIC-4GSWF面板上的指示灯含义如下:
表1-6 RT-SIC-4GSWF指示灯含义
灯名称
颜色
状态
功能
端口连接器灯
绿灯
链路已连通并工作在千兆模式
千兆链路没有连通
闪烁
表示有收发,工作在千兆模式
端口连接器灯
黄灯
链路已连通并工作在百兆模式
百兆链路没有连通
闪烁
表示有收发,工作在百兆模式
3. 光模块、光纤及连接方法
光模块、光纤及连接方法请参见3.2  接口类型为光接口
1.2  以太网模块
·     SIC-1FEA
·     SIC-1FEF
·     SIC-1GEC-V2
1.2.1  SIC-1FEA
1. 简介
SIC-1FEA是1端口10M/100M以太网接口模块的简称,其中FE(Fast Ethernet)表示快速以太网,A用以区别于1FE模块。SIC-1FEA主要用于完成路由器与局域网的通信,支持功能如下:
·     当用户采用5类双绞线时,可支持100米的传输距离。
2. 接口属性
表1-7 SIC-1FEA接口属性
属性
SIC-1FEA模块
连接器类型
RJ-45
接口类型
MDI
连接器数量
1
电缆类型
标准以太网线
工作方式
10M/100Mbps自适应
全双工/半双工
3. 接口指示灯
SIC-1FEA的面板如下图所示:
图1-7 SIC-1FEA面板
SIC-1FEA
SIC-1FEA面板上的指示灯含义如下:
表1-8 SIC-1FEA指示灯含义
指示灯
含义
LINK
灭:表示链路没有连通
亮:表示链路已经连通
ACT
灭:表示没有数据收发
闪烁:表示有数据收发
4. 接口电缆及连接方法
1.2.2  SIC-1FEF
1. 简介
SIC-1FEF是1端口百兆以太网光接口模块的简称,其中FE(Fast Ethernet)是百兆以太网的英文缩写,F为Fiber,表示光接口。SIC-1FEF主要用于完成路由器与局域网的通信。
SIC-1FEF支持功能如下:
·     支持多种可插拔光模块,用户可根据自己的需要选购。
·     接口工作在100Mbps速率下。
·     支持全双工工作方式。
2. 接口属性
SIC-1FEF接口属性如下表所示。
表1-9 SIC-1FEF接口属性
属性
接口数量
1
连接器类型
SFP/LC
接口标准
工作方式
100Mbps
全双工模式
3. 接口指示灯
SIC-1FEF的面板如下图所示:
图1-8 SIC-1FEF面板
SIC-1FEF
SIC-1FEF面板上的指示灯含义如下:
表1-10 SIC-1FEF指示灯含义
指示灯
含义状态
含义
LINK/ACT
没有建立连接
绿色
光模块建立百兆连接
绿色闪烁
光模块有数据传输
黄色
信息检测未通过
4. 光模块、光纤及连接方法
1.2.3  SIC-1GEC-V2
1. 简介
SIC-1GEC-V2是1端口10M/100M/1000M电口和光口以太网接口SIC接口模块的简称,1:代表1端口;GE:代表千兆Ethernet;C:代表COMBO接口,主要功能为:
·     完成GE数据流的收发及处理。
·     提供CE电口和光口接入。
·     电口支持1000/100/10模式。
·     光口支持1000M模式。
2. 接口属性
SIC-1GEC-V2接口属性如下表所示。
表1-11 以太网口属性表
属性
连接器类型
RJ-45
接口类型
MDI
支持帧格式
Ethernet_II
Ethernet_SNAP
IEEE 802.2
IEEE 802.3
工作方式
全双工/半双工
SIC-1GEC-V2模块是COMBO接口,不能同时支持光口和电口,上电默认为电口,如果用光口,需要用命令配置。
3. 接口指示灯
SIC-1GEC-V2的面板如下图所示:
图1-9 SIC-1GEC-V2面板
SIC-1GEC-V2面板上的指示灯含义如下:
表1-12 SIC-1GEC-V2电口指示灯含义
指示灯
含义
LINK
亮:收到载波信号
灭:没有收到载波信号
绿色:1000M
黄色:100/10M
ACT
灭:表示没有数据收发
闪烁:表示有数据收发
表1-13 SIC-1GEC-V2光口指示灯含义
指示灯
含义
LINK
亮:收到载波信号
灭:没有收到载波信号
绿色:1000M
黄色:Fault
ACT
灭:表示没有数据收发
闪烁:表示有数据收发
4. 接口电缆及连接方法
1.3  E1/T1模块
·     SIC-E1-F
·     SIC-2E1-F
·     SIC-1EPRI
·     SIC-T1-F
1.3.1  SIC-E1-F
1. 简介
SIC-E1-F是1端口非通道化E1接口模块的简称,其中F表示“部分(Fractional)E1”:
·     完成E1数据流的收发及处理。
·     提供对远端环回和近端环回功能,便于测试和故障定位。
SIC-E1-F是1端口非通道化E1模块的简称,其中F表示“部分(Fractional)E1”,与SIC-1EPRI的主要区别是:
·     SIC-E1-F支持的FE1工作方式只能捆绑一次(即捆绑为一个通道,其速率为n×64K,n=1~31),而SIC-1EPRI可以将31个通道任意分组,实现多次捆绑。
·     SIC-E1-F不支持PRI方式。
2. 接口属性
SIC-E1-F接口属性如下表所示:
表1-14 SIC-E1-F接口属性
属性
连接器类型
D15
连接器数量
1
接口标准
G.703/G704
接口速率
2.048Mbps
电缆类型
75欧姆非平衡同轴电缆(D15转BNC)
工作方式
E1
CE1
支持服务
备份
终端接入
3. 接口指示灯
SIC-E1-F的面板如下图所示:
图1-10 SIC-E1-F面板
其中各指示灯的含义为:
表1-15 SIC-E1-F指示灯含义
指示灯
含义
LINK/ACT
亮:表示收到载波信号
闪烁:表示有数据收发
灭:表示没有收到载波信号
LP/AL
亮:表示接口处于环回状态(Loopback)
闪烁:表示有以下三种告警之一:AIS、LFA或者RAI
灭:表示既无环回又无告警
4. 接口电缆及连接方法
E1接口电缆及连接方法请参见3.3  接口类型为E1接口
1.3.2  SIC-2E1-F
1. 简介
SIC-2E1-F是2端口非通道化E1接口模块的简称,其中F表示“部分(Fractional)E1”:
·     完成E1数据流的收发及处理。
2. 接口属性
SIC-2E1-F接口属性如下表所示:
表1-16 SIC-2E1-F接口属性
属性
连接器类型
D15
连接器数量
1
接口标准
G.703/G.704
接口速率
2.048Mbps
电缆类型
工作方式
E1
CE1
支持服务
备份
终端接入
3. 接口指示灯
SIC-2E1-F的面板如下图所示:
图1-11 SIC-2E1-F面板
其中各指示灯的含义为:
表1-17 SIC-2E1-F指示灯含义
指示灯
含义
左侧LINK/ACT
亮:表示LINE RX1收到载波信号
闪烁:表示LINE TX1和LINE RX1有数据收发
灭:表示LINE RX1没有收到载波信号
左侧LP/AL
亮:表示LINE TX1和LINE RX1接口处于环回状态(Loopback)
闪烁:表示LINE TX1和LINE RX1接口未插线、线缆故障或者对端设备故障
灭:表示LINE TX1和LINE RX1接口既无环回又无告警
右侧LINK/ACT
亮:表示LINE RX2收到载波信号
闪烁:表示LINE2有数据收发
灭:表示LINE RX2没有收到载波信号
右侧LP/AL
闪烁:表示LINE TX2和LINE RX2接口未插线、线缆故障或者对端设备故障
灭:表示LINE TX2和LINE RX2接口既无环回又无告警
4. 接口电缆及连接方法
1.3.3  SIC-1EPRI
1. 简介
SIC-1EPRI是1端口E1/CE1/PRI SIC模块的简称,其中E表示E1,PRI(Primary Rate Interface)表示ISDN的基群速率接口。SIC-1EPRI的主要功能为:
·     完成E1数据流的收发及处理。
·     提供CE1Channel E1)接入。
·     实现ISDN PRI功能。
可以通过不同的配置达到一卡多用目的。
2. 接口属性
SIC-1EPRI接口属性如下表所示:
表1-18 SIC-1EPRI接口属性
属性
连接器类型
D15
连接器数量
1
接口标准
G.703/G.704
接口速率
2.048Mbps
电缆类型
同轴连接器、网口连接器、75欧姆-120欧姆转换器(带BNC头)
工作方式
E1/CE1/ISDN PRI
支持服务
备份
终端接入
ISDN
3. 接口指示灯
SIC-1EPRI的面板如下图所示:
图1-12 SIC-1EPRI面板
其中各指示灯的含义为:
表1-19 SIC-1EPRI指示灯含义
指示灯
含义
LINK/ACT
亮:表示收到载波信号
闪烁:表示有数据收发
灭:表示没有收到载波信号
LP/AL
灭:表示既无环回又无告警
4. 接口电缆及连接方法
SIC-1EPRI接口缺省阻抗为75欧姆,在与120欧姆线路连接时,必须使用阻抗转换器。
1.3.4  SIC-T1-F
1. 接口卡简介
SIC-T1-F是1端口非通道化T1接口卡的简称,其中F表示“部分(Fractional)T1”:
·     SIC-T1-F支持的FT1工作方式仅能捆绑一次(即捆绑为一个通道,其速率为n×64K或56K,n=1~24)。
·     SIC-T1-F不支持PRI方式。
2. 接口属性
SIC-T1-F接口属性如下表所示:
表1-20 SIC-T1-F接口属性
属性
连接器类型
RJ-45
连接器数量
1
接口标准
G.703/T1.102
G.704
AT&T TR 54016
AT&T TR 62411
ANSI T1.403
接口速率
1.544Mbps
电缆类型
T1电缆(100欧姆标准屏蔽网线)
工作方式
FT1
支持服务
备份
终端接入
3. 接口指示灯
SIC-T1-F的面板如下图所示:
图1-13 SIC-T1-F面板
SIC-1T1-F
其中各指示灯的含义为:
表1-21 SIC-T1-F指示灯含义
指示灯
含义
LINK/ACT
灯亮表示收到载波信号,灯灭没有收到载波信号。灯闪烁表示有数据收发
LP/AL
灯亮表示接口处于环回状态(loopback),灯闪烁表示有以下三种告警之一:AIS、LFA或者RAI,灯灭表示既无环回又无告警
告警信号的含义如下:
·     LFA:Loss of Frame Alignment,帧同步丢失。
·     AIS:Alarm Indication Signal,即告警指示信号。
·     RAI:Remote Alarm Indication,即远端告警指示信号。
4. 接口电缆及连接方法
T1接口电缆及连接方法请参见3.4  接口类型为T1接口
1.4  串口模块
·     SIC-8AS
·     SIC-16AS
·     SIC-1SAE
·     SIC-2SAE
·     SIC-4SAE
1.4.1  SIC-8AS
1. 简介
SIC-8AS是8端口异步串行接口模块的简称,其中AS(Asynchronous)表示异步串口。SIC-8AS的主要作用是完成异步数据流的收发及处理,其特点如下:
·     每路异步串口的最高速率达到115.2Kbps。
·     可支持终端接入服务和异步专线。
·     异步串口用于拨号时,可作为中小型ISP的拨号接入服务器使用。
2. 接口属性
SIC-8AS接口属性如下表所示:
表1-22 SIC-8AS接口属性
属性
连接器类型
D60
连接器数量
1
电缆类型
定制线缆带8端口RJ-45插座
接口标准及工作方式
RS-232
最小波特率(bps)
300
最大波特率(bps)
115.2k
支持服务
Modem拨号
备份
终端接入服务
异步专线
3. 接口指示灯
SIC-8AS面板如下图所示:
图1-14 SIC-8AS前面板
SIC-8AS+口
其中各指示灯的含义如下表所示:
表1-23 SIC-8AS指示灯含义
指示灯
含义
LINK/ACT
灭:表示对应链路没有连通。
亮:表示该端口链路已经连通。
闪烁:表示该链路有数据收发。
4. 接口电缆及连接方法
异步串口电缆及连接方法请参见3.7  接口类型为异步串口
1.4.2  SIC-16AS
1. 简介
SIC-16AS是16端口异步串行接口模块的简称,其中AS(Asynchronous)表示异步串口。SIC-16AS的主要作用是完成异步数据流的收发及处理,其特点如下:
·     每路异步串口的最高速率达到115.2Kbps;
·     可支持终端接入服务和异步专线;
2. 接口属性
SIC-16AS接口属性如下表所示:
表1-24 SIC-16AS接口属性
属性
连接器类型
D28(公)
连接器数量
1
电缆类型
定制线缆带16端口RJ-45连接器(母)
接口标准及工作方式
RS-232
最小波特率(bps)
300
最大波特率(bps)
115.2k
支持服务
Modem拨号
备份
终端接入服务
异步专线
3. 接口指示灯
SIC-16AS面板如下图所示:
图1-15 SIC-16AS前面板
SIC-16AS
其中各指示灯的含义如下表所示:
表1-25 SIC-16AS指示灯含义
指示灯
含义
LINK/ACT
灭:表示对应链路没有连通。
亮:表示该端口链路已经连通。
闪烁:表示该链路有数据收发。
4. 接口电缆及连接方法
1. 简介
SIC-1SAE/SIC-2SAE/SIC-4SAE是1/2/4端口增强型高速同/异步串口模块的简称。
2. 接口属性
SIC-1SAE/SIC-2SAE/SIC-4SAE接口属性如下:
表1-26 SIC-1SAE/SIC-2SAE/SIC-4SAE接口属性
属性
同步
异步
连接器类型
D28
连接器数量
1(SIC-1SAE)
2(SIC-2SAE)
4(SIC-4SAE)
接口标准及工作方式
V.24
V.35/RS449/X.21/RS530
RS-232
DTE/DCE
DTE/DCE
最小波特率(bps)
1200
1200
300
最大波特率(bps)
64k
2.048M
115.2
电缆类型
V.24 (RS-232)DTE电缆
V.24(RS-232)DCE电缆
V.35 DTE电缆
V.35 DCE电缆
X.21 DTE电缆
X.21 DCE电缆
RS449 DTE电缆
RS449 DCE电缆
RS530 DTE电缆
RS530 DCE电缆
支持服务
DDN专线
终端接入
Modem拨号
备份
异步专线
终端接入服务
3. 接口指示灯
SIC-1SAE/SIC-2SAE/SIC-4SAE模块面板如下图所示:
图1-16 SIC-1SAE模块面板
SIC-1SAE+口
图1-17 SIC-2SAE模块面板
图1-18 SIC-4SAE模块面板
其中各指示灯的含义如下表所示:
表1-27 SIC-1SAE/SIC-2SAE/SIC-4SAE模块指示灯含义
指示灯
含义
LINK
灯灭表示链路没有连通,灯亮表示链路已经连通
ACT
灯灭表示没有数据收发,灯闪烁表示有数据收发
4. 接口电缆及连接方法
同/异步串口电缆及连接方法请参见3.6  接口类型为同/异步串口
1.5  模拟调制解调器接口模块
·     SIC-1AM
1.5.1  SIC-1AM
1. 简介
SIC-1AM是1端口模拟调制解调器接口卡的简称,其中AM(Analog Modem)表示模拟调制解调器。SIC-1AM的主要作用相当于将异步接口和外置Modem集成到一块单板上,即允许1路远程Modem用户直接接入路由器,其主要功能是:
·     支持速率为56kbps。
·     实现对模拟信号的接入和处理,并将处理过的数据通过串口总线送到路由器主机上;或者将主机送来的数据经过处理后通过电话接口送到PSTN网络。
2. 接口属性
SIC-1AM接口属性如下表所示:
表1-28 SIC-1AM接口属性
属性
连接器类型
RJ-11
连接器数量
1
电缆类型
带磁环的电话线
最大速率
56kbps
支持协议
ITU-T V.90、K56flex、V.34 (33.6 kbps)、V.FC、V.32 bis、V.32、V.22 bis、V.22A/B、V.23、V.21、Bell 212A a、Bell 103
提供服务
Modem拨号
3. 接口指示灯
图1-19 SIC-1AM面板
表1-29 SIC-1AM指示灯含义
指示灯
含义
ACT
灭:表示链路空闲
闪烁:表示链路上有数据收发
LINK
灭:表示链路空闲
常亮:表示链路连接已经建立
闪烁:表示正在建立链路连接
4. 接口电缆及连接方法
AM接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
1.6  xDSL模块
·     SIC-1ADSL
·     SIC-1ADSL-I
1.6.1  SIC-1ADSL
1. 简介
SIC-1ADSL是1端口ADSL接口模块的简称,其中ADSL是Asymmetric Digital Subscriber's Loop的缩写。ADSL模块提供的RJ-11接口相当于广域网接口,使局域网用户可以经过普通的模拟用户线直接连接到局端的DSLAM(Digital Subscriber's Loop Access Multiplexer),然后,通过DSLAM再连接到ATM/IP骨干网或Internet,实现高速数据通信及视频点播等需求。ADSL是占用26KHz以后的高频段提供数据传输服务,不会干扰在同一条线路上进行的话音服务(占用0~4KHz的低频段)。一般能够向用户提供32Kbps~8Mbps的下行速率和32K~1Mbps的上行速率。
ADSL模块在系统中的主要作用是为路由器提供ADSL接口,其具体功能如下:
·     支持手工激活/去激活ADSL线路,提供方便的故障定位手段。
·     支持G.DMT、G.Lite、T1.413三种接口标准,并可配置为自适应方式。
·     支持ADSL接口的网格编码功能(G.Lite标准除外),增强ADSL连接的稳定性。
2. 接口属性
表1-30 SIC-1ADSL模块接口属性
属性
1ADSL模块
连接器类型
RJ-11
接口数量
1
接口速率
ADSL Full Rate模式下(即ITU-T 992.1 G.DMT/ANSI T1.413):
下行速率可以达到8Mbps、上行速率达到1024Kbps
ADSL Lite模式下(ITU-T 992.2 G.Lite):
下行速率为64Kbps1Mbps、上行速率为64Kbps512Kbps
ADSL2+ Full Rate模式下(即ITU-T 992.5):
下行速率可以达到24Mbps、上行速率达到1024Kbps
接口标准
ITU-T 992.1 G.DMT
ITU-T 992.2 G.Lite
ANSI T1.413 Issue 2
ITU-T 992.3
ITU-T 992.5
电缆类型
1ADSL模块接口电缆为电话线
提供服务
在普通电话线上的ADSL接入
最大收发帧长
1700字节
3. 接口指示灯
SIC-1ADSL模块的面板如下图所示:
图1-20 SIC-1ADSL模块面板
SIC-1ADSL
其中各指示灯的含义如下表所示:
表1-31 SIC-1ADSL模块指示灯含义
指示灯
含义
LINK
灯灭表示线路未被激活,灯亮表示线路已被激活进入Data Mode,闪亮表示正在激活过程当中
ACT
4. 接口电缆及连接方法
ADSL接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
1.6.2  SIC-1ADSL-I
1. 简介
SIC-1ADSL-I是1端口 ADSL over ISDN接口模块的简称,其中ADSL和ISDN分别是(Asymmetric Digital Subscriber's Loop)非对称数字用户线和(Integrated Services Digital Network)综合业务数字网的缩写。SIC-ADSL-I模块提供的RJ-11接口相当于广域网接口,使局域网用户可以经过普通的模拟用户线直接连接到局端的DSLAM(Digital Subscriber's Loop Access Multiplexer即数字用户线接入复接器),然后,通过DSLAM再连接到ATM/IP骨干网或Internet,实现高速数据通信及视频点播等需求。SIC-ADSL-I是占用138KHz以后的高频带提供数据传输服务,以保证ISDN业务不受影响。一般能够向用户提供32Kbps~8Mbps的下行速率和32Kbps~1Mbps的上行速率。
SIC-ADSL-I模块在系统中的具体功能特点如下:
·     支持G.992.1接口标准,并可配置为自适应方式。
·     支持ADSL接口的网格编码功能,增强ADSL连接的稳定性。
2. 接口属性
表1-32 SIC-1ADSL-I接口属性
属性
1ADSL-I模块
连接器类型
RJ-11
接口数量
1
接口速率
接口标准
ITU-T 992.1 G.DMT
ITU-T 992.2 G.Lite
ANSI T1.413 Issue 2
ITU-T 992.3
ITU-T 992.5
接口速率
下行速率可以达到8Mbps,上行速率达到1024Kbps
接口电缆类型
1ADSL-I模块接口电缆为普通电话线
提供服务
在ISDN线路上的ADSL接入
最大收发帧长
1700字节
3. 接口指示灯
SIC-1ADSL-I模块的面板如下图所示:
图1-21 SIC-1ADSL-I模块面板
SIC-1ADSL-I-新+口
其中各指示灯的含义如下表所示:
表1-33 SIC-1ADSL-I模块指示灯含义
指示灯
含义
LINK
ACT
4. 接口连接电缆及连接方法
1.7  ISDN BRI模块
·     SIC-1BS
1.7.1  SIC-1BS
1. 简介
SIC-1BS是1端口ISDN BRI S/T接口卡的简称,其主要功能是完成1路ISDN BRI S/T数据流的收发及处理。
SIC-1BS有拨号和专线两种工作模式。
2. 接口属性
SIC-1BS接口属性如下表所示:
表1-34 SIC-1BS接口属性
属性
连接器类型
RJ-45(SIC-1BS)
连接器数量
1(SIC-1BS)
电缆类型
磁环电话线
协议标准
符合ITU-T I.430/Q.921/Q.931标准。
工作方式
ISDN拨号方式
ISDN专线方式
支持服务
ISDN
ISDN补充业务
多用户号码
子地址
备份
3. 接口指示灯
SIC-1BS面板如下图所示:
图1-22 SIC-1BS面板
其中各指示灯的含义如下表所示:
表1-35 SIC-1BS指示灯含义
指示灯
含义
B1
灭:表示B1通道空闲
闪烁:表示B1通道被占用,正进行数据通信
B2
灭:表示B2通道空闲
闪烁:表示B2通道被占用,正进行数据通信
ACT
灭:表示去激活
常亮:表示激活
ON
灭:接口卡电源断开(如接口卡电源故障)
亮:接口卡已经正常上电
4. 接口电缆及连接方法
BS接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
1.8  语音模块
·     SIC-1FXS
·     SIC-1FXO
·     SIC-2FXS
·     SIC-2FXO
·     SIC-2FXS1FXO
·     DSIC-4FXS1FXO
·     SIC-1BSV
·     SIC-2BSV
·     SIC-1VE1
·     SIC-1VT1
·     SIC-1VE1T1
1. 简介
SIC-1FXS/SIC-2FXS是1/2端口语音用户电路接口模块的简称;SIC-1FXO/ SIC-2FXO是1/2端口语音AT0模拟中继接口模块的简称。SIC-1FXS/SIC-1FXO主要功能是完成1路模拟语音信号的接入及处理,实现语音信号在数据通信网络上的传输;SIC-2FXS/SIC-2FXO主要功能是完成2路模拟语音信号的接入及处理,实现语音信号在数据通信网络上的传输。SIC-FXS/SIC-FXO两种模块的不同点如下:
·     SIC-FXS:模拟用户线模块,提供普通模拟电话、传真及电话交换机AT0环路中继的接入。
·     SIC-FXO:环路中继线模块,提供电话交换机普通用户线的接入。
2. 接口属性
SIC-1FXS/SIC-1FXO和SIC-2FXS/SIC-2FXO接口属性如下表所示:
表1-36 SIC-1FXS/SIC-1FXO和SIC-2FXS/SIC-2FXO接口属性
属性
连接器类型
RJ-11
连接器数量
1(SIC-1FXS/SIC-1FXO)
2(SIC-2FXS/SIC-2FXO)
接口标准
用户电路接口(SIC-1FXS/SIC-2FXS)符合ITU Q.512
环路中继接口(SIC-1FXO/SIC-2FXO)符合ITU Q.552
对过流过压保护符合ITU K.20
电缆类型
带磁环的电话线
拨号方式
支持DTMF,符合GB3378,不支持脉冲拨号
带宽
300Hz~3400Hz
3. 接口指示灯
SIC-1FXS/SIC-2FXS/SIC-1FXO/SIC-2FXO前面板
图1-23 SIC-1FXS前面板
SIC-1FXS
图1-24 SIC-1FXO前面板
SIC-1FXO
图1-25 SIC-2FXS前面板
SIC-2FXS
图1-26 SIC-2FXO前面板
SIC-2FXO
SIC-1FXS/SIC-1FXO和SIC-2FXS/SIC-2FXO指示灯含义如下:
表1-37 SIC-1FXS/SIC-1FXO和SIC-2FXS/SIC-2FXO指示灯含义
指示灯
含义
LINK
灭:表示链路空闲
亮:表示链路被占用,正进行话路连接
ACT
灭:表示链路空闲
亮:表示链路被占用,正进行通话
闪烁:在路由器启动过程中ACT灯闪烁,表示模块硬件故障,请更换模块
4. 接口电缆及连接方法
FXS/FXO接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
1.8.2  SIC-2FXS1FXO
1. 简介
SIC-2FXS1FXO是2端口模拟用户线和1端口环路中继线电路接口模块的简称,主要功能是完成3路模拟语音信号的接入及处理,实现语音信号在数据通信网络上的传输。模块上有2个FXS端口和1个FXO端口:
·     FXS接口:模拟用户线接口,提供普通模拟电话、传真及电话交换机AT0环路中继的接入。
·     FXO接口:环路中继线接口,提供电话交换机普通用户线的接入。
2. 接口属性
SIC-2FXS1FXO接口属性如下表所示:
表1-38 SIC-2FXS1FXO接口属性
属性
连接器类型
RJ-11
连接器数量
2个FXS接口
1个FXO接口
接口标准
用户电路接口(FXS)符合ITU Q.512
环路中继接口(FXO)符合ITU Q.552
对过流过压保护符合ITU K.20
电缆类型
带磁环的电话线
拨号方式
带宽
300Hz~3400Hz
3. 接口指示灯
SIC-2FXS1FXO前面板
图1-27 SIC-2FXS1FXO前面板
SIC-2FXS1FXO+口
SIC-2FXS1FXO指示灯含义如下:
表1-39 SIC-2FXS1FXO指示灯含义
指示灯
含义
LINK/ACT
灭:表示链路空闲
绿色常亮:表示链路被占用,正进行话路连接
黄色闪烁:表示链路被占用,正进行通话
4. 接口电缆及连接方法
1.8.3  DSIC-4FXS1FXO
1. 简介
DSIC-4FXS1FXO是4端口模拟用户线和1端口环路中继线电路接口模块的简称,主要功能是完成5路模拟语音信号的接入及处理,实现语音信号在数据通信网络上的传输。模块上有4个FXS端口和1个FXO端口:
2. 接口属性
DSIC-4FXS1FXO接口属性如下表所示:
表1-40 DSIC-4FXS1FXO接口属性
属性
连接器类型
RJ-11
连接器数量
4个FXS接口
1个FXO接口
接口标准
对过流过压保护符合ITU K.20
电缆类型
带磁环的电话线
拨号方式
带宽
300Hz~3400Hz
3. 接口指示灯
DSIC-4FXS1FXO前面板
图1-28 DSIC-4FXS1FXO前面板
DSIC-4FXS1FXO+口
DSIC-4FXS1FXO指示灯含义如下:
表1-41 DSIC-4FXS1FXO指示灯含义
指示灯
含义
LINK/ACT
灭:表示链路空闲
黄色闪烁:表示链路被占用,正进行通话
4. 接口电缆及连接方法
1. 简介
SIC-1BSV/SIC-2BSV是1/2端口ISDN BRI S/T语音接口模块的简称。单板的主要功能是实现ISDN接口语音信号的接入和压缩、解压缩处理。接口符合ITU-T I.430标准要求,传输码型采用pseudo-ternary码,接口速率192Kbit/s,传输距离在点到点的方式最大为1km。上行可以连接ISDN交换机的用户接口,实现ISDN BRI接口数字语音流的接收/发送和压缩/解压缩处理;下行可以连接TE设备,语音报文经路由器的其它广域网接口送至Internet,实现VoIP。具体功能描述如下:
·     BSV接口支持用户侧和网络侧模式转换。BSV接口可以设置为user和network两种模式,分别用于连接ISDN网络设备及TE设备。
·     当BSV接口工作在network模式下,其处理流程为:从BSV接口接收的数字语音流经压缩处理之后,通过主控板CPU转发到广域网接口;从广域网接口来的IP语音报文,通过主控板CPU转发到SIC-1BSV/SIC-2BSV,由SIC-1BSV/SIC-2BSV进行解压缩处理之后发送至TE设备上。
·     当BSV接口工作在user模式下,其处理流程为:从BSV接口接收的B通道数字语音流经压缩处理之后,再通过主控板CPU转发到本地FXS或FXO模拟语音接口;本地FXS或FXO模拟语音接口接收的语音信号经VoIP处理后,通过主控板CPU转发到SIC-1BSV/SIC-2BSV模块,由SIC-1BSV/SIC-2BSV模块进行解压缩处理之后,再通过BSV接口传送到ISDN交换机上。
·     配合FXS或FXO模拟语音模块,可以实现灵活的语音呼叫选路策略。
·     ISDN BRI D通道信令由CPU单独处理。
·     BSV接口支持远程供电,可以直接接ISDN话机,省去了额外的供电设备。
·     SIC-1BSV/SIC-2BSV模块只支持语音方式应用,不支持BRI数据方式应用,这和BS模块是有区别的。
2. 接口属性
表1-42 SIC-1BSV/SIC-2BSV接口属性
属性
SIC-1BSV模块
SIC-2BSV模块
连接器类型
RJ-45
连接器数量
1
2
接口标准
接口速率
192Kbit/s
接口电缆类型
ISDN S口电缆
提供服务
ISDN S口电缆的语音接入
3. 接口指示灯
SIC-1BSV/SIC-2BSV面板图如下所示:
图1-29 SIC-1BSV模块面板
SIC-1BSV
图1-30 SIC-2BSV模块面板
SIC-2BSV
SIC-1BSV/SIC-2BSV模块各指示灯的含义如下表所示:
表1-43 SIC-1BSV/SIC-2BSV模块指示灯含义
指示灯名称
含义
B1
绿色,闪烁表示B1通道有数据收发
B2
绿色,闪烁表示B2通道有数据收发
ACT
黄色,链路激活过程中闪烁,激活后常亮
ON
绿色,电源指示灯。常亮表示电源接通
4. 接口电缆及连接方法
BSV接口电缆及连接方法请参见3.10  接口类型为BSV/BSE接口
1.8.5  SIC-1VE1
1. 简介
SIC-1VE1是1端口E1语音接口模块,是为满足在VoIP系统中处理密集信号的要求而推出的。
SIC-1VE1模块可为用户提供1个CE1/PRI/R2接口,提供最多30路语音信号的接入及处理。
2. 接口属性
SIC-1VE1接口属性如下表所示:
表1-44 SIC-1VE1接口属性
属性
连接器类型
D15
连接器数量
1
接口标准
G.703,G.704
接口速率
2.048Mbps
电缆类型
120欧姆的平衡双绞线(D15转RJ-45)
工作方式
CE1、ISDN PRI(仅SIC-1VE1支持)
R2
支持服务
备份
终端接入
ISDN(仅SIC-1VE1支持)
3. 接口指示灯
SIC-1VE1的面板如下图所示:
图1-31 SIC-1VE1面板
SIC-1VE1面板
其中各指示灯的含义为:
表1-45 SIC-1VE1指示灯含义
指示灯
含义
LINK
灭:表示链路空闲
亮:表示链路被占用,正进行话路连接
ACT
灭:表示链路空闲
亮:表示链路被占用,正进行通话
4. 接口电缆及连接方法
1.8.6  SIC-1VT1
1. 简介
SIC-1VT1是1端口T1语音接口模块,是为满足在VoIP系统中处理密集信号的要求而推出的。
SIC-1VT1模块可为用户提供1个CT1/PRI/R2接口,提供最多23路语音信号的接入及处理。
2. 接口属性
SIC-1VT1接口属性如下表所示:
表1-46 SIC-1VT1接口属性
属性
连接器类型
RJ-45
连接器数量
1
接口标准
G.703/T1.102
G.704
AT&T TR 54016
AT&T TR 62411
ANSI T1.403
接口速率
1.544Mbps
电缆类型
T1电缆(100欧姆标准屏蔽网线)
工作方式
CT1、ISDN PRI
支持服务
备份
终端接入
ISDN
3. 接口指示灯
SIC-1VT1的面板如下图所示:
图1-32 SIC-1VT1面板
SIC-1VT1面板
其中各指示灯的含义为:
表1-47 SIC-1VT1指示灯含义
指示灯
含义
LINK
灭:表示链路空闲
亮:表示链路被占用,正进行话路连接
ACT
灭:表示链路空闲
亮:表示链路被占用,正进行通话
4. 接口电缆及连接方法
1.8.7  SIC-1VE1T1
1. 简介
SIC-1VE1T1是1端口E1/T1数字语音接口模块的简称,可满足在VoIP和FoIP系统中处理密集信号。E1模块的主要功能是完成E1语音的收发及处理,并提供CE1接入,可以实现ISDN PRI功能,提供最多30路语音信号的接入及处理。T1模块的主要功能是完成T1语音的收发及处理,并提供CT1接入,可以实现ISDN PRI功能,提供最多23路语音信号的接入及处理。
SIC-1VE1T1接口模块上的接口支持三种接口类型:75欧姆E1接口、100欧姆T1接口和120欧姆E1接口。单板在各个接口类型间切换通过软件命令行和跳线实现E1/T1的切换。具体跳线方式如下:
·     出厂默认按照75欧姆E1配置,跳线连接PIN1-PIN2、PIN7-PIN8、PIN11-PIN12、PIN13-PIN14。
·     对于T1模式以及120欧姆E1模式,跳线连接PIN1-PIN3、PIN5-PIN7、PIN9-PIN10、PIN11-PIN13。
图1-33 跳线的连接
2. 接口属性
SIC-1VE1T1接口属性如下表所示:
表1-48 SIC-1VE1T1接口属性
属性
连接器类型
RJ-45
连接器数量
1
接口标准
G.703/G.704
接口速率
2.048Mbps、1.544Mbps
电缆类型
E1 75欧姆非平衡同轴电缆
E1 120欧姆平衡双绞线电缆(2m,15m,30m)
T1电缆(100欧姆标准屏蔽网线)
同轴连接器、网口连接器、75欧姆120欧姆转换器(带BNC头)
工作方式
E1/T1/CE1T1/ISDN PRI
支持服务
备份
终端接入服务
ISDN PRI
3. 接口指示灯
SIC-1VE1T1的面板如下图所示:
图1-34 SIC-1VE1T1面板
其中各指示灯的含义为:
表1-49 SIC-1VE1T1指示灯含义
指示灯
含义
LINK/ACT
绿色常亮:表示收到载波信号
4Hz闪烁:表示有数据收发
灭:表示没有收到载波信号
LP/AL
黄色常亮:表示接口处于环回状态(Loopback)
0.5Hz闪烁:表示有以下三种告警之一:AIS、LFA或者RAI
灭:表示既无环回又无告警
4. 接口电缆及连接方法
1.9  3G模块
·     SIC-3G-TD
·     SIC-3G-HSPA
1.9.1  SIC-3G-TD
1. 简介
SIC-3G-TD模块可实现3G无线网络接入功能,支持:
·     GPRS
·     EDGE
·     TD-SCDMA
·     HSDPA
2. 接口属性
SIC-3G-TD模块接口属性如下表所示:
表1-50 SIC-3G-TD模块接口属性
属性
连接器类型
TNC RF:用于连接天线,接入无线网络
RJ-45:用于连接第三方无线网络调测软件(如高通的CAIT等)
连接器数量
TNC RF:1个
RJ-451
接口标准及工作方式
TNC RF:频段全向天线,支持GPRS/EDGE/TD-SCDMA//HSDPA
RJ-45:RS-232
电缆类型
TNC RF:无
RJ-45:AUX电缆
支持速率
HSDPA(下行2.8Mbps,上行384Kbps)
TD-SCDMA(下行384kbps,上行384Kbps)
EDGE(下行236.8Kbps,上行236.8Kbps)
GPRS(下行85.6Kbps,上行85.6Kbps)
支持服务
GPRS/EDGE/TD-SCDMA/HSDPA
3. 接口指示灯
SIC-3G-TD模块的面板如下图所示:
图1-35 SIC-3G-TD模块面板
rtvm1std
表1-51 SIC-3G-TD模块指示灯含义
指示灯
含义
WWAN
绿色长亮表示链路已经连通
绿色闪烁表示有数据收发
RSSI
绿色长亮表示强信号
绿色闪烁表示中低信号
灯灭表示信号微弱或者无信号
TD
黄色长亮表示TD-SCDMA服务有效
灯灭表示TD-SCDMA没有服务
HSPA
黄色长亮表示TD-SCDMA HSDPA服务有效
灯灭表示TD-SCDMA HSDPA没有服务
4. 天线、接口电缆及连接方法
SIC-3G-HSPA接口模块天线及接口电缆的连接方法请参见3.11  接口类型为3G接口
5. 安装SIM卡
SIM卡的缺口方向一定要与卡槽的缺口方向对应上,这样才能正确的安装SIM卡。
(1)     第一步:向卡槽上标有OPEN的箭头方向轻轻推3G SIM卡卡槽,使卡槽弹起。
(2)     第二步:将3G SIM卡沿滑道插入3G SIM卡卡槽。
(3)     第三步:将3G SIM卡卡槽合上,向卡槽上标有LOCK的箭头方向轻轻推,使卡槽扣紧。
(4)     第四步:路由器启动之后执行display cellular [ interface-number ],如果显示的信息中包含SIM Status = OK就说明SIM卡被正确识别。
1.9.2  SIC-3G-HSPA
1. 简介
通过SIC-3G-HSPA接口模块可实现3G无线网络接入功能,支持:
·     GPRS
·     EDGE
·     UMTS
·     HSDPA
·     HSUPA
2. 接口属性
SIC-3G-HSPA接口属性如下表所示:
表1-52 SIC-3G-HSPA接口属性
属性
连接器类型
TNC:用于连接天线,接入无线网络
连接器数量
TNC RF:2个
RJ-451
接口标准及工作方式
TNC RF:频段全向天线,支持GPRS/EDGE/UMTS/HSDPA
RJ-45:RS-232
电缆类型
TNC RF:无
RJ-45:AUX电缆
支持速率
HSDPA(下行7.2Mbps)、HSUPA(上行5.76Mbps)
UMTS(下行384Kbps,上行384Kbps)
支持服务
GPRS
EDGE
UMTS
HSDPA
HSUPA
支持无线频段
850/900/1900/2100MHz WCDMA/HSDPA/HSUPA
850/900/1800/1900MHz GPRS/EDGE
3. 接口指示灯
SIC-3G-HSPA模块的面板如下图所示:
图1-36 SIC-3G-HSPA模块面板
SIC-3G-HSPA
表1-53 SIC-3G-HSPA模块指示灯含义
指示灯
含义
WWAN
绿色长亮表示链路已经连通
绿色闪烁表示有数据收发
RSSI
绿色长亮表示强信号
绿色闪烁表示中低信号
灯灭表示信号微弱或者无信号
UMTS
黄色长亮表示服务有效
灯灭表示没有服务
HSPA
黄色长亮表示服务有效
灯灭表示没有服务
4. 天线、接口电缆及连接方法
随SIC-3G-HSPA接口模块提供的一根3G天线,必须安装到标有MAIN字样的天线接口上。
5. 安装SIM卡
1.10  4G模块
·     SIC-4G-LTE-M
·     SIC-4G-CNDE
·     RT-SIC-4G-CAT6
·     SIC-D4G-CNDE
1.10.1  SIC-4G-LTE-M
1. 简介
SIC-4G-LTE-M模块可实现4G无线网络接入功能,支持:
·     LTE
·     UMTS
·     HSPA+
·     TD-SCDMA
·     CDMA2000 1xRTT
·     CDMA2000 1x-Ev-Do
·     Quad-Band EDGE
·     GPRS
·     GSM
2. 接口属性
SIC-4G-LTE-M模块接口属性如下表所示:
表1-54 SIC-4G-LTE-M模块接口属性
属性
连接器类型
TNC:用于连接天线,接入无线网络
SMA:用于连接天线,接入GPS
Mini USB Type AB:用于连接第三方无线网络调测软件(如高通的CAIT等)
连接器数量
TNC:2个
SMA:1个
Mini USB Type AB:1个
接口标准及工作方式
TNC:频段全向天线,支持LTE、UMTS、HSPA+、CDMA 1x、EV-DO Rev A、Quad-Band EDGE、GPRS、GSM
SMA:GPS
Mini USB Type AB:RS-232
电缆类型
TNC:无
SMA:flexible 174 sized cable
Mini USB Type AB:USB配置线缆
支持服务
LTE
UMTS
HSPA+
TD-SCDMA
CDMA2000 1xRTT
CDMA2000 1x-Ev-Do
Quad-Band EDGE
GPRS
GSM
3. 接口指示灯
SIC-4G-LTE-M模块的面板如下图所示:
图1-37 SIC-4G-LTE-M模块面板
表1-55 SIC-4G-LTE-M模块指示灯含义
指示灯
含义
WWAN
绿色长亮表示链路已经连通
绿色快闪表示有数据收发
绿色慢闪表示网络搜索
灯灭表示链路未连通
RSSI
绿色长亮表示信号强度高(RSSI大于或等于-69dBm)
绿色快闪表示信号强度中(RSSI大于或等于-89dBm且小于-69dBm)
绿色慢闪表示信号强度低(RSSI大于或等于-99dBm且小于-89dBm)
灯灭表示信号微弱或者无信号(RSSI小于-99dBm)
HSPA+
绿色长亮表示HSPA+或HSDPA服务有效
绿色闪烁表示EVDO服务有效
灯灭表示没有服务
LTE
绿色长亮表示LTE服务有效
灯灭表示LTE没有服务
GPS
绿色长亮表示GPS服务有效
灯灭表示GPS没有服务
4. 天线、接口电缆及连接方法
SIC-4G-LTE-M接口模块天线及接口电缆的连接方法请参见3.12  接口类型为4G接口
5. 安装SIM卡
(1)     第一步:向卡槽上标有OPEN的箭头方向轻轻推4G SIM卡卡槽,使卡槽弹起。
(2)     第二步:将4G SIM卡沿滑道插入4G SIM卡卡槽。
(3)     第三步:将4G SIM卡卡槽合上,向卡槽上标有LOCK的箭头方向轻轻推,使卡槽扣紧。
1.10.2  SIC-4G-CNDE
·     SIC-4G-CNDE接口模块的SIM卡类型为Micro SIM卡。
·     SIC-4G-CNDE接口模块有两个Micro SIM卡槽位,但同一时间仅有一个槽位工作。两个槽位同时安装Micro SIM卡时,缺省情况下SIM1槽位工作,SIM2槽位作为备用槽位,可以通过sim switch-to命令切换主备槽位,命令的详细介绍请参见《H3C MSR 系列路由器 命令参考(V7)》中“二层技术-广域网接入命令参考”内的“3G Modem和4G Modem管理命令”。
1. 简介
SIC-4G-CNDE模块可实现4G无线网络接入功能,支持:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
2. 接口属性
SIC-4G-CNDE模块接口属性如下表所示:
表1-56 SIC-4G-CNDE模块接口属性
属性
连接器类型
SMA:用于连接天线,接入GPS或无线网络
连接器数量
SMA:3个
接口标准及工作方式
SMA:
·     GPS
·     频段全向天线,支持FDD-LTE/TDD-LTE/TD-SCDMA/UMTS/EDGE/
·     GPRS/GSM/EVDO/CDMA
支持服务
·     LTE-TDD Quad-band Band 38/39/40/41
·     LTE-FDD Quintuple-band Band 1/3/5/7/8
·     TD-SCDMA Dual-band Band 34/39
·     UMTS Double-band Band 1/8
·     GSM Quad-band Band 2/3/5/8
·     EVDO Single-band BC0
·     CDMA1x Single-band BC0
3. 接口指示灯
SIC-4G-CNDE模块的面板如下图所示:
图1-38 SIC-4G-CNDE模块面板
表1-57 SIC-4G-CNDE模块指示灯含义
指示灯
含义
WWAN
绿色长亮表示链路已经连通
绿色快闪表示有数据收发
绿色慢闪表示网络搜索
灯灭表示链路未连通
RSSI
黄色长亮为预留显示状态
LTE
绿色长亮表示4G-LTE服务有效
绿色闪烁(8HZ)表示高速3G服务有效(包含DC-HSPA+, HSPA+, HSDPA, HSUPA,
EVDO网络)
黄色长亮表示低速3G或2G服务有效(包含UMTS, TD-SCDMA, CDMA2000-1xRTT,EDGE, GPRS, GSM等)
黄色闪烁为预留显示状态
灯灭表示没有服务
GPS
绿色长亮表示GPS服务有效
灯灭表示没有GPS服务
CNDE
绿色长亮表示模块正常运行,与主机之间无数据收发
绿色闪烁表示模块正常运行,且与主机之间有数据收发
黄色长亮表示模块故障
灯灭表示模块不在位
4. 天线、接口电缆及连接方法
SIC-4G-CNDE接口模块天线及接口电缆的连接方法请参见3.12  接口类型为4G接口3.14  接口类型为GPS接口
5. 安装Micro SIM卡
Micro SIM卡的缺口方向一定要与卡槽丝印的缺口方向一致,这样才能正确的安装Micro SIM卡。
图1-39 安装Micro SIM卡
(2)     第一步:用十字螺丝刀逆时针取下右侧的两个螺钉。
(3)     第二步:将卡槽上盖抬起一定角度,向右抽出。
(4)     第三步:沿丝印方向水平插入2张Micro SIM卡。
(5)     第四步:盖上卡槽上盖,并用螺钉固定。
(6)     第五步:路由器启动之后执行display cellular [ interface-number ],如果显示的信息中包含SIM Status = OK就说明SIM卡被正确识别。
·     RT-SIC-4G-CAT6模块支持热插拔。请先通过执行remove命令或长按remove按钮3秒以上,待remove指示灯熄灭后再拔出模块,否则可能会导致主机意外重启。
·     RT-SIC-4G-CAT6接口模块的SIM卡类型为Micro SIM卡。
·     RT-SIC-4G-CAT6接口模块有两个Micro SIM卡槽位,但同一时间仅有一个槽位工作。两个槽位同时安装Micro SIM卡时,缺省情况下SIM0槽位工作,SIM1槽位作为备用槽位,可以通过sim switch-to命令切换主备槽位,命令的详细介绍请参见相应产品命令手册中“二层技术-广域网接入命令参考”内的“移动通信Modem管理命令”。
1. 简介
RT-SIC-4G-CAT6模块可实现4G无线网络接入功能,支持:
·     LTE-TDD
·     LTE-FDD
·     WCDMA
2. 接口属性
RT-SIC-4G-CAT6模块接口属性如下表所示:
表1-58 RT-SIC-4G-CAT6模块接口属性
属性
连接器类型
SMA:用于连接天线,接入GNSS或无线网络
连接器数量
SMA:3个
接口标准及工作方式
SMA:
·     GNSS:GPS/GLONASS/BDS/GALILEO
·     全向天线,支持FDD-LTE/TDD-LTE/WCDMA
支持服务
·     LTE-TDD
·     LTE-FDD
·     WCDMA
3. 接口指示灯
RT-SIC-4G-CAT6模块的面板如下图所示:
图1-40 RT-SIC-4G-CAT6模块面板
表1-59 RT-SIC-4G-CAT6模块指示灯含义
指示灯
状态
WWAN
绿色常亮
无线广域网链路已经连通
绿色快闪
无线广域网的无线链路内有数据收发
绿色慢闪
正在搜索并搭建无线广域网网络
未连通无线广域网
WCDMA
绿色常亮
3G信号强度高(RSSI大于或等于-70dBm)
绿色快闪
3G信号强度中(RSSI大于或等于-100dBm且小于-70dBm)
绿色慢闪
3G信号强度低(RSSI大于或等于-125dBm且小于-100dBm)
3G无服务(RSSI小于-125dBm)
LTE
绿色常亮
工作于4G模式下且信号强度高(RSSI大于或等于-70dBm)
绿色快闪
工作于4G模式下且信号强度中(RSSI大于或等于-100dBm且小于-70dBm)
绿色慢闪
工作于4G模式下且信号强度低(RSSI大于或等于-125且小于-100dBm)
4G无服务(RSSI小于-125dBm)
SIM
绿色常亮
当前SIM卡0正在工作
黄色常亮
当前SIM卡1正在工作
两个卡槽均未插卡
GNSS
绿色常亮
定位服务有效
没有定位服务
REMOVE
绿灯常亮
接口模块处于正常运行状态,可通过REMOVE按钮执行拔出操作
绿灯快闪
接口模块初始化阶段,不可按REMOVE按钮或拔出模块
若其他指示灯均熄灭,则此时可以拔卡
4. 天线、接口电缆及连接方法
RT-SIC-4G-CAT6接口模块天线及接口电缆的连接方法请参见3.12  接口类型为4G接口3.15  接口类型为GNSS接口
5. 安装Micro SIM卡
图1-41 安装Micro SIM卡
(2)     第一步:用十字螺丝刀逆时针取下卡槽盖上的两个螺钉。
(3)     第二步:将卡槽上盖抬起一定角度后抽出。
(4)     第三步:观察设备丝印所示的缺口方向,使待插Micro SIM卡的方向与丝印所示保持一致。
(5)     第四步:沿丝印方向水平插入2张Micro SIM卡。
(6)     第五步:轻推Micro SIM卡外侧边缘,插牢Micro SIM卡。
(7)     第六步:盖上卡槽上盖,并用螺钉固定。
路由器启动之后执行display cellular [ interface-number ],如果显示的信息中包含SIM Status = OK,说明SIM卡被正确识别。
1.10.4  SIC-D4G-CNDE
·     SIC-D4G-CNDE接口模块的SIM卡类型为Micro SIM卡。
·     SIC-D4G-CNDE接口模块有两个SIM槽位,两个槽位同时工作,SIM1槽位关联M0和M1天线接口,其中M0为主天线,M1为辅助天线;SIM2槽位关联M2和M3天线接口,其中M2为主天线,M3为辅助天线;主天线必须连接,仅使用辅助天线,天线无法正常工作。如果主天线出现故障,请及时更换,以免影响天线的使用。
·     SIC-D4G-CNDE 接口模块面板上接口间距较小,所以相邻的两个接口不能同时安装4G 天线,可以使用天线延长线与4G 天线配合安装。
1. 简介
SIC-D4G-CNDE模块可实现4G无线网络接入功能,支持:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
2. 接口属性
SIC-D4G-CNDE模块接口属性如下表所示:
表1-60 SIC-D4G-CNDE模块接口属性
属性
连接器类型
SMA:用于连接天线,接入GPS或无线网络。
连接器数量
SMA:5个
接口标准及工作方式
SMA:
·     GPS
支持服务
3. 接口指示灯
SIC-D4G-CNDE模块的面板如下图所示:
图1-42 SIC-D4G-CNDE模块面板
表1-61 SIC-D4G-CNDE模块指示灯含义
指示灯
含义
WWAN
绿色长亮表示链路已经连通
绿色快闪表示有数据收发
绿色慢闪表示网络搜索
灯灭表示链路未连通
RSSI
黄色长亮为预留显示状态
LTE
绿色长亮表示4G-LTE服务有效
EVDO网络)
黄色长亮表示低速3G或2G服务有效(包含UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, GSM等)
黄色闪烁为预留显示状态
灯灭表示没有服务
GPS
绿色长亮表示GPS服务有效
灯灭表示没有GPS服务
CNDE
黄色长亮表示模块故障
灯灭表示模块不在位
WWAN
绿色长亮表示链路已经连通
绿色快闪表示有数据收发
绿色慢闪表示网络搜索
灯灭表示链路未连通
4. 天线、接口电缆及连接方法
SIC-D4G-CNDE接口模块天线及接口电缆的连接方法请参见3.12  接口类型为4G接口3.14  接口类型为GPS接口
5. 安装SIM卡
Micro SIM卡的缺口方向一定要与卡槽丝印上的缺口方向一致,这样才能正确的安装Micro SIM卡。
图1-43 安装Micro SIM卡
(4)     第三步:沿丝印方向水平插入Micro SIM卡。
1.11  5G模块
·     RT-SIC-5G
·     RT-SIC-5G-CN
1.11.1  RT-SIC-5G
如需拔出RT-SIC-5G模块,请先通过执行remove命令或长按remove按钮3秒以上,待remove指示灯熄灭后再拔出模块,否则可能会导致主机意外重启。
1. 简介
RT-SIC-5G模块可实现5G无线网络接入功能,支持:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
2. 接口属性
RT-SIC-5G模块接口属性如下表所示:
表1-62 RT-SIC-5G模块接口属性
属性
连接器类型
连接器数量
SMA:4个
接口标准及工作方式
SMA:
·     GNSS:GPS/GLONASS/BeiDou/Galileo
·     频段全向天线:WCDMA/FDD-LTE/TDD-LTE /5G NR
支持服务
·     5G/4G/3G多种网络制式
·     全面覆盖5G 和 LTE-A
·     NSA 和 SA 两种模式
·     集成多星座 GNSS 接收机,满足不同环境下对快速、精准定位
的需求
3. 接口指示灯
RT-SIC-5G模块的面板如下图所示:
图1-44 RT-SIC-5G模块面板
表1-63 RT-SIC-5G模块指示灯含义
指示灯
状态
WWAN
绿色常亮
无线广域网链路已经连通
绿色快闪
无线广域网的无线链路内有数据收发
绿色慢闪
正在搜索并搭建无线广域网网络
未连通无线广域网
5G
绿色常亮(SA模式)
5G信号强度高(RSRP大于或等于-85dBm)
绿色快闪(SA模式)
5G信号强度中(RSRP大于或等于-100dBm且小于-85dBm)
绿色慢闪(SA模式)
5G信号强度低(RSRP大于或等于-115dBm且小于-100dBm)
黄色常亮(NSA模式)
黄色快闪(NSA模式)
黄色慢闪(NSA模式)
5G无服务
LTE
绿色常亮
绿色快闪
绿色慢闪
黄色常亮
工作于3G模式下且信号强度高(RSSI大于或等于-70dBm)
黄色快闪
工作于3G模式下且信号强度中(RSSI大于或等于-100dBm且小于-70dBm )
黄色慢闪
工作于3G模式下且信号强度低(RSSI大于或等于-125且小于-100dBm)
3G和4G均无服务
SIM
绿色常亮
当前SIM卡1正在工作
黄色常亮
当前SIM卡2正在工作
两个卡槽均未插卡
GNSS
绿色常亮
定位服务有效
没有定位服务
REMOVE
绿灯常亮
接口模块处于正常运行状态,可热插拔
绿灯快闪
接口模块初始化阶段,不可热插拔
若其他指示灯均熄灭,则此时可以拔卡
4. 天线、接口电缆及连接方法
RT-SIC-5G接口模块天线及接口电缆的连接方法请参见  3.12   接口类型为5G接口
5. 安装SIM卡
SIM卡的缺口方向一定要与卡槽的缺口方向对应才能正确的安装SIM卡,否则会导致接口模块或SIM卡损坏。
RT-SIC-5G接口模块拥有两个SIM卡插槽,可根据实际需要选择插入1至2张SIM卡。当插入两张SIM卡时,默认SIM卡1工作。SIM卡的具体安装方式请参见图1-45
图1-45 安装5G SIM
(2)     第一步:用适配的螺丝刀旋开5G SIM卡卡槽盖板螺钉。
(3)     第二步:将5G SIM卡外保护盖按图示方式拔出。
(4)     第三步:观察设备丝印所示的缺口方向,使待插5G SIM卡的方向与丝印所示保持一致。
(5)     第四步:将5G SIM卡沿滑道插入5G SIM卡卡槽。
(6)     第五步:轻推5G SIM卡外侧边缘,插牢5G SIM卡。
(7)     第六步:沿插脚导轨插入5G SIM卡盖板,并加装盖板螺钉。
路由器启动之后执行display cellular [ interface-number ]命令,如果显示信息中包含SIM Status = OK就说明SIM卡被正确识别。
1.11.2  RT-SIC-5G-CN
如需拔出RT-SIC-5G-CN模块,请先通过执行remove命令或长按remove按钮3秒以上,待remove指示灯熄灭后再拔出模块,否则可能会导致主机意外重启。
1. 简介
RT-SIC-5G-CN模块可实现5G无线网络接入功能,支持:
·     5G NR
·     LTE-A
·     WCDMA
·     FDD-LTE
·     TDD-LTE
2. 接口属性
RT-SIC-5G-CN模块接口属性如下表所示:
表1-64 RT-SIC-5G-CN模块接口属性
属性
连接器类型
SMA:用于连接天线,接入无线网络
连接器数量
SMA:4个
接口标准及工作方式
SMA
·     频段全向天线:WCDMA/FDD-LTE/TDD-LTE/5G NR
支持服务
·     5G/4G/3G多种网络制式
·     全面覆盖5G 和 LTE-A
·     NSA 和 SA 两种模式
3. 接口指示灯
RT-SIC-5G-CN模块的面板如下图所示:
图1-46 RT-SIC-5G-CN模块面板
表1-65 RT-SIC-5G-CN模块指示灯含义
指示灯
状态
WWAN
绿色常亮
无线广域网链路已经连通
绿色快闪
无线广域网的无线链路内有数据收发
绿色慢闪
正在搜索并搭建无线广域网网络
未连通无线广域网
5G
绿色常亮(SA模式)
绿色快闪(SA模式)
绿色慢闪(SA模式)
黄色常亮(NSA模式)
黄色快闪(NSA模式)
黄色慢闪(NSA模式)
5G无服务
LTE
绿色常亮
绿色快闪
绿色慢闪
黄色常亮
黄色快闪
工作于3G模式下且信号强度中(RSSI大于或等于-100dBm且小于-70dBm)
黄色慢闪
3G和4G均无服务
SIM
绿色常亮
当前SIM卡1正在工作
黄色常亮
当前SIM卡2正在工作
两个卡槽均未插卡
REMOVE
绿灯常亮
接口模块处于正常运行状态,可热插拔
绿灯快闪
接口模块初始化阶段,不可热插拔
若其他指示灯均熄灭,则此时可以拔卡
4. 天线、接口电缆及连接方法
RT-SIC-5G-CN接口模块天线及接口电缆的连接方法请参见3.13  接口类型为5G接口
5. 安装SIM卡
RT-SIC-5G-CN接口模块拥有两个SIM卡插槽,可根据实际需要选择插入1至2张SIM卡。当插入两张SIM卡时,默认SIM卡1工作。SIM卡的具体安装方式请参见图1-47
图1-47 安装5G SIM
1.12  网络数据加密模块
·     SIC-CNDE
·     SIC-CNDE-SJK
·     SIC-4G-CNDE-SJK
·     SIC-D4G-CNDE-SJK
1.12.1  SIC-CNDE
1. 简介
SIC-CNDE(China Network Data Encryption,中国网络数据加密)是中国网络数据加密模块的简称。SIC-CNDE支持SM1对称加密算法,通过硬件实现SM1对称加密算法,为路由器提供了高性能、高可靠性的加密特性。
SIC-CNDE安装于中低端模块化路由器的SIC插槽上,当插入SIC-CNDE模块时,路由器主板完成IP包路由转发处理并实现含有加密特性的VPN,由加密卡完成其中的SM1对称加解密操作。
2. 接口属性
表1-66 SIC-CNDE模块属性
属性
硬件实现算法
密钥算法(SM1-128、SM1-256)
3. 接口指示灯
图1-48 SIC-CNDE模块面板
表1-67 SIC-CNDE模块指示灯含义
指示灯
含义
ACT
连续闪烁:表示模块正常运行,且与主机之间有数据收发
绿色常亮:表示模块正常运行,与主机之间无数据收发
1.12.2  SIC-CNDE-SJK
1. 简介
SIC-CNDE-SJK是国密加密SIC模块的简称。SIC-CNDE-SJK支持SM1、SM2、SM4加密算法,为路由器提供了高性能、高可靠性的加密特性。
2. 接口指示灯
图1-49 SIC-CNDE-SJK模块面板
表1-68 SIC-CNDE-SJK模块指示灯含义
指示灯
含义
CNDE
绿色常亮表示模块正常运行,与主机之间无数据收发
黄色常亮表示模块故障
灯灭表示模块不在位
·     SIC-4G-CNDE-SJK接口模块的SIM卡类型为Micro SIM卡。
·     SIC-4G-CNDE-SJK接口模块有两个Micro SIM卡槽位,但同一时间仅有一个槽位工作。两个槽位同时安装Micro SIM卡时,缺省情况下SIM1槽位工作,SIM2槽位作为备用槽位,可以通过sim switch-to命令切换主备槽位,命令的详细介绍请参见相应产品命令手册中“二层技术-广域网接入命令参考”内的“移动通信Modem管理命令”。
1. 简介
SIC-4G-CNDE-SJK(China Network Data Encryption,中国网络数据加密)是4G LTE和国密加密SIC模块的简称,支持SM1、SM2、SM4加密算法,为路由器提供了高性能、高可靠性的加密特性。SIC-4G-CNDE-SJK模块可实现4G无线网络接入功能,支持:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
2. 接口属性
表1-69 SIC-4G-CNDE-SJK模块属性
属性
连接器类型
连接器数量
SMA:3个
接口标准及工作方式
SMA:
·     GPS
GPRS/GSM/EVDO/CDMA
支持服务
3. 接口指示灯
SIC-4G-CNDE-SJK模块的面板如下图所示:
图1-50 SIC-4G-CNDE-SJK模块面板
表1-70 SIC-4G-CNDE-SJK模块指示灯含义
指示灯
含义
WWAN
绿色常亮表示链路已经连通
绿色快闪表示有数据收发
绿色慢闪表示网络搜索
灯灭表示链路未连通
RSSI
绿色常亮表示信号强度高(RSSI大于或等于-69dBm)
LTE
绿色常亮表示4G-LTE服务有效
绿色闪烁(8HZ)表示高速3G服务有效(包含DC-HSPA+, HSPA+, HSDPA, HSUPA, EVDO网络)
黄色常亮表示低速3G或2G服务有效(包含UMTS, TD-SCDMA, CDMA2000-1xRTT,EDGE, GPRS, GSM等)
灯灭表示没有服务
GPS
绿色常亮表示GPS服务有效
灯灭表示没有GPS服务
CNDE
黄色常亮表示模块故障
灯灭表示模块不在位
4. 天线、接口电缆及连接方法
SIC-4G-CNDE-SJK接口模块天线及接口电缆的连接方法请参见3.12  接口类型为4G接口3.14  接口类型为GPS接口
5. 安装Micro SIM卡
图1-51 安装Micro SIM卡
·     SIC-D4G-CNDE-SJK接口模块的SIM卡类型为Micro SIM卡。
·     SIC-D4G-CNDE-SJK接口模块有两个SIM槽位,两个槽位同时工作,SIM1槽位关联M0和M1天线接口,其中M0为主天线,M1为辅助天线;SIM2槽位关联M2和M3天线接口,其中M2为主天线,M3为辅助天线;主天线必须连接,仅使用辅助天线,天线无法正常工作。如果主天线出现故障,请及时更换,以免影响天线的使用。
·     SIC-D4G-CNDE-SJK接口模块面板上接口间距较小,所以相邻的两个接口不能同时安装4G天线,可以使用天线延长线与4G天线配合安装。
1. 简介
SIC-D4G-CNDE-SJK是双4G LTE和国密加密SIC模块的简称。SIC-D4G-CNDE-SJK支持SM1、SM2、SM4加密算法,为路由器提供了高性能、高可靠性的加密特性。SIC-D4G-CNDE-SJK模块可实现4G无线网络接入功能,支持:
·     LTE-TDD
·     LTE-FDD
·     TD-SCDMA
·     UMTS
·     GSM
·     EVDO
·     CDMA1x
2. 接口属性
SIC-D4G-CNDE-SJK模块接口属性如下表所示:
表1-71 SIC-D4G-CNDE-SJK模块接口属性
属性
连接器类型
连接器数量
SMA:5个
接口标准及工作方式
SMA:
·     GPS
GPRS/GSM/EVDO/CDMA
支持服务
3. 接口指示灯
SIC-D4G-CNDE-SJK模块的面板如下图所示:
图1-52 SIC-D4G-CNDE-SJK模块面板
表1-72 SIC-D4G-CNDE-SJK模块指示灯含义
指示灯
含义
WWAN
绿色常亮表示链路已经连通
绿色快闪表示有数据收发
绿色慢闪表示网络搜索
灯灭表示链路未连通
RSSI
LTE
绿色常亮表示4G-LTE服务有效
黄色常亮表示低速3G或2G服务有效(包含UMTS, TD-SCDMA, CDMA2000-1xRTT, EDGE, GPRS, GSM等)
灯灭表示没有服务
GPS
绿色常亮表示GPS服务有效
灯灭表示没有GPS服务
CNDE
黄色常亮表示模块故障
灯灭表示模块不在位
4. 天线、接口电缆及连接方法
SIC-D4G-CNDE-SJK接口模块天线及接口电缆的连接方法请参见3.12  接口类型为4G接口3.14  接口类型为GPS接口
5. 安装SIM卡
图1-53 安装Micro SIM卡
1.13  WLAN模块
·     SIC-AP220
·     SIC-AP320
1.13.1  SIC-AP220
1. 简介
SIC-AP220是无线局域网接入接口模块,主要功能是完成无线报文的收发。模块上支持2个外置天线,支持802.11a/b/g/n/ac标准,并且同时支持2.4G和5G射频频段。
2. 接口属性
SIC-AP220接口属性如下表所示:
表1-73 SIC-AP220接口属性
属性
SIC-AP220模块
连接器类型
RJ-45
连接器数量
1个FE接口
1个Console接口
接口标准及工作方式
FE接口:802.3/802.3u,10M/100Mbps自适应,全双工/半双工
Console接口:RS/EIA-232
射频接口:Radio 1为5G射频频段,支持MIMO 1×1技术;Radio 2为2.4G射频频段,支持MIMO 2×2技术
电缆类型
FE接口:标准(直通)以太网线/交叉以太网线
Console接口:配置线缆
3. 接口指示灯
SIC-AP220前面板如下图所示:
图1-54 SIC-AP220前面板
SIC-AP220指示灯含义如下:
表1-74 SIC-AP220指示灯含义
指示灯
含义
SYS
橙色常亮:设备上电启动中
绿色闪烁:2.4G射频接口有客户端接入
橙色闪烁:5G射频接口有客户端接入
橙绿交替闪烁:2.4G和5G射频接口同时有客户端接入
4. 接口电缆及连接方法
WLAN接口电缆及连接方法请参见3.16  接口类型为WLAN接口
1.13.2  SIC-AP320
1. 简介
SIC-AP320是无线局域网接入接口模块,主要功能是完成无线报文的收发。模块上支持2个外置天线,支持802.11a/b/g/n/ac标准,并且同时支持2.4G和5G射频频段。
2. 接口属性
SIC-AP320接口属性如下表所示:
表1-75 SIC-AP320接口属性
属性
SIC-AP320模块
连接器类型
RJ-45
连接器数量
1个Console接口
接口标准及工作方式
射频接口:Radio 1为5G射频频段,支持MIMO 2×2技术;Radio 2为2.4G射频频段,支持MIMO 1×1技术
电缆类型
Console接口:配置线缆
3. 接口指示灯
SIC-AP320前面板如下图所示:
图1-55 SIC-AP320前面板
SIC-AP320指示灯含义如下:
表1-76 SIC-AP320指示灯含义
指示灯
含义
SYS
橙色常亮:设备上电启动中
绿色闪烁:2.4G射频接口有客户端接入
橙色闪烁:5G射频接口有客户端接入
4. 接口电缆及连接方法
1.14  硬盘转接模块
·     RT-SIC-M2-SATA硬盘转接模块支持热插拔。先长按REMOVE按钮3s以上松手,如果REMOVE指示灯熄灭,则可以立即执行拔出操作;如果REMOVE指示灯绿色闪烁,则需等待指示灯熄灭后才可执行拔出操作。
·     RT-SIC-M2-SATA硬盘转接模块不随机提供M.2 SSD硬盘,请用户根据实际需要自行选购。
·     RT-SIC-M2-SATA硬盘转接模块的RAID功能仅支持安装在SIC模块上并且容量相同的SSD硬盘。
1. 简介
RT-SIC-M2-SATA是M.2 SSD硬盘转接模块,通过软RAID功能来实现数据的高可靠性要求。RAID(Redundant Array of Independent Disks)功能是独立冗余磁盘阵列的英文缩写,是一种把多块独立的物理硬盘按不同的方式组合起来形成一个逻辑硬盘组,从而提供比单个硬盘更高的存储性能和数据备份技术。
2. 硬盘转接模块属性
RT-SIC-M2-SATA硬盘转接模块属性如下表所示:
表1-77 RT-SIC-M2-SATA硬盘转接模块属性
属性
硬盘类型
M.2 SATA SSD
硬盘尺寸(长×宽)
80mm×22mm
硬盘数量
1个
RAID
支持RAID1
理论传输速率
1.5Gbps/3Gbps/6Gbps
3. 面板及接口指示灯
RT-SIC-M2-SATA模块的面板如下图所示:
图1-56 RT-SIC-M2-SATA模块面板
RT-SIC-M2-SATA指示灯含义如下:
表1-78 RT-SIC-M2-SATA指示灯含义
指示灯
状态
PWR
绿色常亮
表示模块供电正常
灯灭
表示模块无电源输入
SSD
绿色常亮
表示SSD硬盘在位
黄色常亮
表示SSD硬盘损坏需要更换
灯灭
表示SSD硬盘不在位
ACT
绿色8Hz闪烁
表示在读写硬盘
灯灭
表示无访问硬盘操作
REMOVE
绿色8Hz闪烁
表示模块正在初始化,不可按REMOVE按钮或拔出模块;表示正在拔出模块中
绿色常亮
表示模块正常运行,可通过REMOVE按钮执行拔出操作
灯灭
表示可以拔出模块
4. 安装SSD硬盘方法
RT-SIC-M2-SATA硬盘转接模块要安装SSD硬盘后才能正常使用。
具体的安装步骤如下:
(1)     将SSD硬盘以45°角缓慢地推进M.2插槽。
(2)     将SSD硬盘轻轻往下压,使硬盘金手指与接口触角紧密接触。
(3)     用十字螺丝刀,顺时针旋紧SSD硬盘顶部的紧固螺钉。
图1-57 安装SSD硬盘
2 HMIM/DHMIM接口模块
·     HMIM接口模块支持热插拔,如需带电更换,拆卸之前需要执行remove命令或者通过REMOVE按钮进行操作,具体操作方法请进入该接口模块详情页面进行查看。需要注意的是,带有REMOVE按钮的HMIM接口模块同时支持remove命令和REMOVE按钮,在进行带电更换时,两种方法不允许同时使用,否则可能导致接口模块不可用等情况。
·     DHMIM接口模块支持热插拔,如需带电更换,拆卸之前需要执行remove命令。
MSR系列路由器采用模块化结构,提供了大量可供选配的HMIM(High-performance Multiplex Interface Module)/DHMIM(Double High-performance Multiplex Interface Module)接口模块。该系列接口卡提供了同/异步串口、以太网接口、E1/T1、ISDN BRI/PRI、语音接口、二层交换口等丰富的接口特性。
2.1  以太网交换模块
·     HMIM-8GSW
·     HMIM-24GSW
·     HMIM-24GSW-PoE
·     HMIM-8GSWF
1. 简介
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE是8/24/24端口1000M以太网二层交换HMIM接口模块,HMIM-8GSW/HMIM-24GSW对外提供8/24个普通的1000M的RJ-45连接器接口,HMIM-8GSW/HMIM-24GSW模块适合在小型企业网内作为交换/路由综合设备,直接连接企业内部的PC及网络设备。HMIM-24GSW-PoE可以通过PoE电源对PD设备远程供电。
模块支持的功能如下:
·     当用户采用5类双绞线(交叉和直通均支持)时,可支持任意端口间的1000M线速转发。
·     接口可以工作在1000Mbps、100Mbps和10Mbps三种速度下,且能实现自适应。
2. 接口属性
表2-1 HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE接口属性
属性
HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE模块
连接器类型
RJ-45接口
接口类型
MDI/MDIX
连接器数量
8(HMIM-8GSW)
24(HMIM-24GSW/HMIM-24GSW-PoE)
线缆类型
工作方式
24个千兆电接口:10M/100M/1000Mbps自适应
3. 接口指示灯
HMIM-8GSW面板如下图所示:
图2-1 HMIM-8GSW面板
HMIM-24GSW面板如下图所示:
图2-2 HMIM-24GSW面板
HMIM-24GSW-PoE面板如下图所示:
图2-3 HMIM-24GSW-PoE面板
面板上每个千兆端口对应一个LED指示灯,指示灯含义相同,如下表所示:
表2-2 HMIM-8GSW/HMIM-24GSW/HMIM-24GSW-PoE GE端口指示灯含义
指示灯状态
含义
端口链路没有连通
常绿
端口链路连通,并且工作在1000M模式
绿灯闪烁
常黄
端口链路连通,并且工作在100/10M模式
黄灯闪烁
端口链路工作在100/10M模式,并且有数据收发
4. 接口电缆及连接方法
2.1.2  HMIM-8GSWF
HMIM-8GSWF是8端口百/千兆以太网(4光+4光/电 Combo)L2/L3 HMIM模块的简称,其中G(Gigabit Ethernet)是自适应的百/千兆以太网的英文缩写,F为Fiber,表示光接口。HMIM-8GSWF模块适合在小型企业网内作为交换/路由综合设备,直接连接企业内部的PC及网络设备。
HMIM-8GSWF支持功能如下:
·     接口工作在100/1000Mbps速率下。
·     支持全双工工作方式。
1. 接口属性
HMIM-8GSWF接口属性如下表所示。
表2-3 HMIM-8GSWF接口属性
属性
HMIM-8GSWF描述
接口数量
8
连接器类型
SFP/LC/RJ-45
接口标准
工作方式
100/1000Mbps
全双工模式
2. 面板及接口指示灯
HMIM-8GSWF的面板如下图所示:
图2-4 HMIM-8GSWF面板
HMIM-8GSWF面板上的指示灯含义如下:
表2-4 HMIM-8GSWF指示灯含义
灯名称
颜色
状态
功能
端口连接器灯
绿灯
链路已连通并工作在千兆模式
千兆链路没有连通
闪烁
表示有收发,工作在千兆模式
端口连接器灯
黄灯
链路已连通并工作在百兆模式
百兆链路没有连通
闪烁
表示有收发,工作在百兆模式
3. 光模块、光纤及连接方法
2.2  以太网模块
·     HMIM-2GEE
·     HMIM-4GEE
·     HMIM-8GEE
·     RT-HMIM-4GEE-V2
·     RT-HMIM-8GEE-V2
·     HMIM-2GEF
·     HMIM-4GEF
·     HMIM-8GEF
·     RT-HMIM-4GEF-V2
·     RT-HMIM-8GEF-V2
·     RT-HMIM-4XP
1. 简介
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE是2/4/8端口10Base-T/100Base-TX/1000Base-T以太网电接口模块的简称,其中GE(Gigabit Ethernet)是千兆以太网的英文缩写,E为Electric,表示电接口。HMIM-GEE主要用于完成路由器与局域网的通信。
HMIM-GEE支持功能如下:
·     接口可以工作在1000Mbps、100Mbps和10Mbps三种速率下,且能实现自适应。
·     支持半双工/全双工自动协商。
2. 接口属性
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE接口属性如下表所示:
表2-5 HMIM-2GEE/HMIM-4GEE/HMIM-8GEE接口属性
属性
HMIM-2GEE描述
HMIM-4GEE描述
HMIM-8GEE描述
连接器类型
RJ-45
连接器数量
2
4
8
接口类型
MDI/MDIX
接口标准
电缆类型
直通和交叉以太网线
工作方式
10/100/1000Mbps自适应
半双工/全双工自动协商
3. 面板及接口指示灯
HMIM-2GEE/HMIM-4GEE/HMIM-8GEE的面板如下图所示:
图2-5 HMIM-2GEE面板
图2-6 HMIM-4GEE面板
图2-7 HMIM-8GEE面板
HMIM-2GE/HMIM-4GE/HMIM-8GE面板上的指示灯含义如下:
表2-6 HMIM-2GE/HMIM-4GE/HMIM-8GE指示灯含义
灯名称
颜色
状态
功能
端口连接器灯
绿灯
链路已连通并工作在千兆模式
千兆链路没有连通
闪烁
表示有收发,工作在千兆模式
端口连接器灯
黄灯
链路已连通并工作在十、百兆模式
十、百兆链路没有连通
闪烁
表示有收发,工作在十、百兆模式
4. 接口电缆及连接方法
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2接口模块支持热插拔,可长按REMOVE按钮直至RUN灯熄灭再进行拆卸操作。
1.
2. 简介
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2是4/8端口10Base-T/100Base-TX/1000Base-T以太网电接口模块的简称,其中GE(Gigabit Ethernet)是千兆以太网的英文缩写,E为Electric,表示电接口。RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2主要用于完成路由器与局域网的通信。
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2支持功能如下:
·     支持半双工/全双工自动协商。
3. 接口属性
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2接口属性如下表所示。
表2-7 RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2接口属性
属性
RT-HMIM-4GEE-V2描述
RT-HMIM-8GEE-V2描述
连接器类型
RJ-45
连接器数量
4
8
接口类型
MDI/MDIX
接口标准
电缆类型
直通和交叉以太网线
工作方式
10/100/1000Mbps自适应
半双工/全双工自动协商
4. 面板及接口指示灯
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2的面板如下图所示:
图2-8 RT-HMIM-4GEE-V2面板
图2-9 RT-HMIM-8GEE-V2面板
RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2面板上的指示灯含义如下:
表2-8 RT-HMIM-4GEE-V2/RT-HMIM-8GEE-V2指示灯含义
指示灯
状态
LINK/ACT
绿灯亮
链路已连通并工作在千兆模式
绿灯闪烁
表示有收发,工作在千兆模式
黄灯亮
链路已连通并工作在十、百兆模式
黄灯闪烁
表示有收发,工作在十、百兆模式
灯灭
表示链路没有连通
RUN
绿色常亮
接口模块正常运行,不可以拔出
灯灭
接口模块未识别或已被移除,可以拔出
5. 接口电缆及连接方法
1. 简介
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF是2/4/8端口1000Base-SX/1000Base-LX以太网光接口模块的简称,其中GE(Gigabit Ethernet)是千兆以太网的英文缩写,F为Fiber,表示光接口。HMIM-2GEF/HMIM-4GEF/HMIM-8GEF主要用于完成路由器与局域网的通信。
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF支持功能如下:
·     接口工作在1000Mbps速率下。
·     支持全双工工作方式。
2. 接口属性
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF接口属性如下表所示。
表2-9 HMIM-2GEF/HMIM-4GEF/HMIM-8GEF接口属性
属性
HMIM-2GEF描述
HMIM-4GEF描述
HMIM-8GEF描述
接口数量
2
4
8
连接器类型
SFP/LC
接口标准
工作方式
1000Mbps
全双工模式
3. 面板及接口指示灯
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF的面板如下图所示:
图2-10 HMIM-2GEF面板
图2-11 HMIM-4GEF面板
图2-12 HMIM-8GEF面板
HMIM-2GEF/HMIM-4GEF/HMIM-8GEF面板上的指示灯含义如下:
表2-10 HMIM-2GEF/HMIM-4GEF/HMIM-8GEF指示灯含义
指示灯
含义
LINK
ACT
4. 光模块、光纤及连接方法
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2接口模块支持热插拔,可长按REMOVE按钮直至RUN灯熄灭再进行拆卸操作。
1.
2. 简介
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2是4/8端口1000Base-SX/1000Base-LX以太网光接口模块的简称,其中GE(Gigabit Ethernet)是千兆以太网的英文缩写,F为Fiber,表示光接口。RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2主要用于完成路由器与局域网的通信。
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2支持功能如下:
·     接口工作在1000Mbps速率下。
·     支持全双工工作方式。
3. 接口属性
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2接口属性如下表所示。
表2-11 RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2接口属性
属性
RT-HMIM-4GEF-V2描述
RT-HMIM-8GEF-V2描述
接口数量
4
8
连接器类型
SFP/LC
接口标准
工作方式
1000Mbps
全双工模式
4. 面板及接口指示灯
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2的面板如下图所示:
图2-13 RT-HMIM-4GEF-V2面板
图2-14 RT-HMIM-8GEF-V2面板
RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2每个端口在面板底部对应一个指示灯,各端口指示灯含义相同,含义如下:
表2-12 RT-HMIM-4GEF-V2/RT-HMIM-8GEF-V2指示灯含义
指示灯
状态
LINK/ACT
绿灯亮
链路已连通并工作在千兆模式
绿灯闪烁
表示有收发,工作在千兆模式
黄灯亮
链路已连通并工作在百兆模式
黄灯闪烁
表示有收发,工作在百兆模式
灯灭
表示链路没有连通
RUN
绿色常亮
接口模块正常运行,不可以拔出
灯灭
接口模块未识别或已被移除,可以拔出
5. 光模块、光纤及连接方法
2.2.5  RT-HMIM-4XP
RT-HMIM-4XP接口模块支持热插拔,可先长按REMOVE按钮直至RUN灯熄灭再进行拆卸操作。
1. 简介
RT-HMIM-4XP是10G以太网光接口模块,对外提供4个SFP+光接口,每个接口都是三层业务接口。RT-HMIM-4XP支持千兆速率的SFP光模块和10G速率的SFP+光模块。
2. 接口属性
RT-HMIM-4XP接口属性如下表所示。
表2-13 RT-HMIM-4XP接口属性
属性
接口数量
4个
连接器类型
SFP+/LC
接口标准
10GBASE-R
工作方式
1000Mbps/10Gbps速率自适应,全双工工作模式
3. 面板及接口指示灯
RT-HMIM-4XP的面板如下图所示:
图2-15 RT-HMIM-4XP面板
其中各指示灯的含义如下表所示。
表2-14 RT-HMIM-4XP指示灯含义
指示灯
状态
RUN
绿色常亮
接口模块正常运行
灯灭
接口模块未识别或已被移除,可以拔出
LINK/ACT
绿色常亮
端口已经建立10Gbps速率的连接
绿色12Hz闪烁
端口以10Gbps的速率收发数据
黄色常亮
端口已经建立1000Mbps速率的连接
黄色12Hz闪烁
端口以1000Mbps的速率收发数据
灯灭
端口未建立连接
4. 光模块、光纤连接方法
光模块、光纤连接方法请参见3.2  接口类型为光接口
2.3  ATM模块
·     HMIM-1ATM-OC3
2.3.1  HMIM-1ATM-OC3
1. 简介
HMIM-1ATM-OC3是1端口155M ATM光接口模块的简称,其中ATM是Asynchronous Transfer Mode的缩写。
ATM模块在系统中的主要作用是为路由器提供ATM接口,具体功能如下:
·     支持SDH STM-1、SONET OC-3两种帧格式。
·     允许发送数据时采用加扰传输。
·     支持线路时钟(作为DTE接口时使用)、内部时钟(作为DCE接口时使用)两种时钟方式。
·     支持对内信元自环、对内载荷自环、对外回波三种自环测试手段。
2. 接口属性
HMIM-1ATM-OC3接口属性如下表所示。
表2-15 HMIM-1ATM-OC3接口属性
属性
HMIM-1ATM-OC3
接口数量
1
连接器类型
SFP/LC
接口标准
SONET OC-3/SDH STM-1
工作方式
155Mbps
3. 面板及接口指示灯
HMIM-1ATM-OC3面板如下图所示:
图2-16 HMIM-1ATM-OC3面板
其中各指示灯的含义如下表所示:
表2-16 HMIM-1ATM-OC3指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 光模块、光纤及连接方法
·     HMIM-1POS
·     RT-HMIM-2POS-STM1
·     RT-HMIM-4POS-STM1/4
2.4.1  HMIM-1POS
1. 简介
HMIM-1POS是1端口SDH/SONET接口模块的简称,其中POS表示Packet Over SDH/Sonet,HMIM-1POS接口传输速率为STM-1/OC-3(155.52Mbit/s)。
HMIM-1PO在数据链路层可以使用PPP、帧中继和HDLC协议,在网络层使用IP协议。HMIM-1POS接口的功能是实现数据包在SONET/SDH上的直接传输。其特点如下:
·     提供多种可插拔光模块,用户可根据自己的需要选购。
·     为非通道化的155.52Mbps接口。
2. 接口属性
HMIM-1POS模块的接口属性如下表所示。
表2-17 HMIM-1POS接口属性
属性
接口标准
接口数量
1
连接器类型
SFP/LC
接口速率
155.52Mbps
3. 面板及接口指示灯
HMIM-1POS的前面板如下图所示:
图2-17 HMIM-1POS模块前面板
其中,各指示灯的含义如下表所示:
表2-18 HMIM-1POS指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 光模块、光纤及连接方法
RT-HMIM-2POS-STM1接口模块支持热插拔,可先长按REMOVE按钮直至RUN灯熄灭再进行拆卸操作。
1. 简介
RT-HMIM-2POS-STM1是2端口SDH/SONET接口模块的简称,其中POS表示Packet Over SDH/SONET。RT-HMIM-2POS-STM1接口传输速率为STM-1/OC-3(155.52Mbit/s)。RT-HMIM-2POS-STM1接口模块在数据链路层可以使用PPP、帧中继和HDLC协议,在网络层使用IP协议。RT-HMIM-2POS-STM1接口模块上的POS接口主要用于实现数据包在SDH/SONET上的直接传输。其特点如下:
·     为非通道化的155.52M接口。
2. 接口属性
RT-HMIM-2POS-STM1模块的接口属性如下表所示。
表2-19 RT-HMIM-2POS-STM1的接口属性
属性
接口标准
·     SONET OC-3/SDH STM-1
接口数量
2
连接器类型
SFP/LC
接口速率
155.52Mbps
3. 面板及接口指示灯
RT-HMIM-2POS-STM1的前面板如下图所示:
图2-18 RT-HMIM-2POS-STM1模块前面板
其中,各指示灯的含义如下表所示:
表2-20 RT-HMIM-2POS-STM1的指示灯说明
指示灯
状态
ACT/ALM
绿色常亮
端口已经建立155.52Mbps速率的连接
绿色闪烁
端口以155.52Mbps的速率收发数据
红灯亮
表示出现告警
灯灭
光模块未插入或端口处于shutdown状态
RUN
绿色常亮
接口模块正常运行,不可以拔出
绿色闪烁
接口模块正在升级固件
红色常亮
接口模块故障
灯灭
接口模块未识别或已被移除,可以拔出
4. 光模块、光纤及连接方法
RT-HMIM-4POS-STM1/4接口模块支持热插拔,可先长按REMOVE按钮直至RUN灯熄灭再进行拆卸操作。
1. 简介
RT-HMIM-4POS-STM1/4是4端口SDH/SONET接口模块的简称,其中POS表示Packet Over SDH/SONET。RT-HMIM-4POS-STM1/4接口传输速率为STM-1/OC-3(155.52Mbit/s)、STM-4/OC-12(622.08Mbit/s)。RT-HMIM-4POS-STM1/4接口模块在数据链路层可以使用PPP、帧中继和HDLC协议,在网络层使用IP协议。RT-HMIM-4POS-STM1/4接口模块上的POS接口主要用于实现数据包在SDH/SONET上的直接传输。
RT-HMIM-4POS-STM1/4接口模块的使用注意事项如下:
·     可以通过命令行设置接口模块的工作模式:执行命令设置接口模块的POS接口运行于STM-1/OC-3 POS模式或者STM-4/OC-12 POS模式。命令的详细介绍请参见相应产品命令手册中“接口管理命令参考”内的“POS接口命令”。
·     接口模块工作模式的设置基于端口而不是整个接口模块。
2. 接口属性
RT-HMIM-4POS-STM1/4模块的接口属性如下表所示。
表2-21 RT-HMIM-4POS-STM1/4的接口属性
属性
接口标准
·     SONET OC-12/SDH STM-4
接口数量
4
连接器类型
SFP/LC
接口速率
155.52Mbps、622.08Mbps
3. 面板及接口指示灯
RT-HMIM-4POS-STM1/4的前面板如下图所示:
图2-19 RT-HMIM-4POS-STM1/4模块前面板
其中,各指示灯的含义如下表所示:
表2-22 RT-HMIM-4POS-STM1/4的指示灯说明
指示灯
状态
ACT/ALM
绿色常亮
端口已经建立155.52Mbps/622.08Mbps速率的连接
绿色闪烁
端口以155.52Mbps/622.08Mbps的速率收发数据
红灯亮
表示出现告警
灯灭
RUN
绿色常亮
接口模块正常运行,不可以拔出
绿色闪烁
接口模块正在升级固件
红色常亮
接口模块故障
灯灭
接口模块未识别或已被移除,可以拔出
4. 光模块、光纤及连接方法
·     HMIM-1CPOS
·     HMIM-2CPOS
1. 简介
HMIM-1CPOS/HMIM-2CPOS是1/2端口通道化SDH/SONET接口模块的简称,其中C表示Channelized,POS表示Packet Over SDH/Sonet。HMIM-1CPOS/HMIM-2CPOS支持1/2个STM-1/OC3多通道模块,支持155.52Mbit/s的通信速率。
HMIM-1CPOS/HMIM-2CPOS模块支持E1和T1两种制式间的切换。
HMIM-1CPOS/HMIM-2CPOS模块插在模块化路由器HMIM插槽内,通过PCI接口与CPU进行通讯,完成STM-1通道化POS接口数据的收发。其特点如下:
·     支持净通道(非成帧)E1或T1。
·     支持非通道化(成帧)E1或T1。
·     支持通道化到64K,但是最多256个逻辑通道。
2. 属性
HMIM-1CPOS/HMIM-2CPOS接口的属性如下所示。
表2-23 HMIM-1CPOS/HMIM-2CPOS的接口属性
属性
接口标准
接口数量
1
连接器类型
SFP/LC
接口速率
155.52Mbps
长距离光接口传输距离不能太近,否则无法接收,要求传输距离大于25km。如果太近,可以使用光衰减器来减小输入光功率。
3. 面板及接口指示灯
HMIM-1CPOS/HMIM-2CPOS模块的前面板如下图所示:
图2-20 HMIM-1CPOS模块前面板
图2-21 HMIM-2CPOS模块前面板
HMIM-1CPOS/HMIM-2CPOS模块前面板各指示灯的含义如下表所示:
表2-24 HMIM-1CPOS/HMIM-2CPOS模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 光模块、光纤及连接方法
5. 接口制式切换
HMIM-1CPOS/HMIM-2CPOS模块可以通过命令行,进行E1和T1两种制式间的切换,详细操作步骤如下:
(1)     将HMIM-1CPOS/HMIM-2CPOS模块插入路由器的HMIM插槽内,然后开启设备电源。
(2)     设备启动成功后,在系统视图下执行card-mode命令,设置接口制式,以HMIM-1CPOS模块安装在设备的第4槽位为例:
# 进入系统视图。
# 设置HMIM-1CPOS模块使用E1接口制式。
[Sysname] card-mode slot 4 e1
# 设置HMIM-1CPOS模块使用T1接口制式。
[Sysname] card-mode slot 4 t1
2.6  E1/T1模块
·     HMIM-1E1
·     HMIM-2E1
·     HMIM-4E1
·     HMIM-1E1-F
·     HMIM-2E1-F
·     HMIM-4E1-F
·     HMIM-8E1(75)
·     HMIM-8E1(75)-F
·     HMIM-2T1
·     HMIM-4T1-F
·     HMIM-2E1T1
·     HMIM-4E1T1
·     HMIM-8E1T1
·     HMIM-2E1T1-F
·     HMIM-4E1T1-F
·     HMIM-8E1T1-F
1. 简介
(1)     HMIM-1E1/HMIM-2E1/HMIM-4E1模块
HMIM-1E1/HMIM-2E1/HMIM-4E1是1/2/4端口通道化CE1/PRI接口模块的简称。E1模块的主要功能是完成E1数据流的收发及处理,并提供CE1接入,可以实现ISDN PRI功能,达到一板多用目的。
(2)     HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F模块
HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F是1/2/4端口非通道化E1模块的简称,其中E1-F表示“部分(Fractional)E1”,其与HMIM-1E1/HMIM-2E1/HMIM-4E1模块主要的区别是:
¡     E1-F模块支持的FE1工作方式仅能捆绑一次(即捆绑为一个通道,其速率为n×64K,n=1~31),而CE1模块可以将31个通道任意分组,实现多次捆绑。
¡     E1-F模块不支持PRI方式。
2. 接口属性
HMIM-1E1/HMIM-2E1/HMIM-4E1和HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F模块接口属性如下表所示:
表2-25 HMIM-1E1/HMIM-2E1/HMIM-4E1和HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F模块接口属性
属性
HMIM-1E1/HMIM-1E1-F
HMIM-2E1/HMIM-2E1-F
HMIM-4E1/HMIM-4E1-F
连接器类型
DB15
DB15
DB25
连接器数量
1
2
1
接口标准
G.703/G.704
接口速率
2.048Mbps
电缆类型
E1 75欧姆非平衡同轴电缆
E1 120欧姆平衡双绞线电缆
120欧姆4E1转接电缆(HMIM-4E1/HMIM-4E1-F模块)
75欧姆4E1转接电缆(HMIM-4E1/HMIM-4E1-F模块)
工作方式
E1/CE1/ISDN PRI(仅HMIM-1E1/HMIM-2E1/HMIM-4E1模块支持)
FE1(仅HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F模块支持)
支持服务
备份
终端接入服务
3. 接口指示灯
HMIM-E1/HMIM-E1-F模块的面板如下图所示:
图2-22 HMIM-E1模块面板
图2-23 HMIM-E1-F模块面板
HMIM-2E1和HMIM-2E1-F模块的面板如下图所示:
图2-24 HMIM-2E1模块面板
图2-25 HMIM-2E1-F模块面板
HMIM-4E1和HMIM-4E1-F模块的面板如下图所示:
图2-26 HMIM-4E1模块面板
图2-27 HMIM-4E1-F模块面板
其中各指示灯的含义如下表所示:
表2-26 HMIM-1E1/HMIM-2E1/HMIM-4E1和HMIM-1E1-F/HMIM-2E1-F/HMIM-4E1-F模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
LINK
ACTIVE
灯灭表示没有数据收发,灯闪烁表示数据收发
4. 接口电缆及连接方法
1. 简介
(1)     HMIM-8E1(75)模块
HMIM-8E1(75)是8端口通道化E1/PRI接口模块的简称。HMIM-8E1(75)模块的主要功能是完成8路E1数据流的收发及处理,并提供CE1接入,可以实现ISDN PRI功能,达到一板多用目的。
(2)     HMIM-8E1(75)-F模块
HMIM-8E1(75)-F是8端口非通道化E1接口模块的简称,其中HMIM-E1(75)-F表示“部分(Fractional)E1”,其与HMIM-8E1(75)模块主要的区别是:
¡     HMIM-8E1(75)-F模块支持的FE1工作方式仅能捆绑一次(即捆绑为一个通道,其速率为n×64K,n=1~31),而HMIM-8E1(75)模块可以将31个通道任意分组,实现多次捆绑。
¡     HMIM-8E1(75)-F模块不支持PRI方式。
对于HMIM-8E1(75)模块,在Controller E1接口上使用时隙捆绑命令时,系统会自动产生相应的Serial口,并在Serial口下进行配置。
2. 接口属性
HMIM-8E1(75)和HMIM-8E1(75)-F接口属性如下表所示:
表2-27 HMIM-8E1(75)和HMIM-8E1(75)-F接口属性
属性
连接器类型
D68
连接器数量
1
接口标准
G.703
接口速率
2.048Mbps
接口电缆类型
75欧姆8E1转接电缆
电缆特性阻抗
75欧姆
工作方式
E1/CE1/ISDN PRI(仅HMIM-8E1(75)模块支持)
FE1(仅HMIM-8E1(75)-F模块支持)
支持服务
备份
终端接入服务
3. 接口指示灯
HMIM-8E1(75)和HMIM-8E1(75)-F模块的面板如下图所示:
图2-28 HMIM-8E1(75)模块面板
图2-29 HMIM-8E1(75)-F模块面板
其中各指示灯的含义如下表所示:
表2-28 HMIM-8E1(75)和HMIM-8E1(75)-F模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 接口电缆及连接方法
1. 简介
(1)     HMIM-2T1模块
HMIM-2T1是2端口通道化T1/PRI接口模块的简称。
T1模块的主要功能是完成T1数据流的收发及处理,并提供CT1接入,可以实现ISDN PRI功能,达到一板多用目的。
(2)     HMIM-4T1-F模块
HMIM-4T1-F是4端口非通道化T1接口模块的简称,其中F表示“部分(Fractional)T1”,其与4CT1模块主要的区别是:
¡     T1-F模块支持的FT1工作方式仅能捆绑一次(即捆绑为一个通道,其速率为n×64K或56K,n=1~24),而CT1模块可以将24个通道任意分组,实现多次捆绑。
¡     T1-F模块不支持PRI方式。
对于T1模块,在Controller T1接口上使用时隙捆绑命令时,系统会自动产生相应的Serial口,并在Serial口下进行配置。
2. 接口属性
HMIM-2T1/HMIM-4T1-F接口属性如下表所示:
表2-29 HMIM-2T1/HMIM-4T1-F接口属性
属性
连接器类型
RJ-45
连接器数量
2(HMIM-2T1模块)
4(HMIM-4T1-F模块)
接口标准
G.703/T1 102
G.704
AT&T TR 54016
AT&T TR 62411
ANSI T1.403
接口速率
1.544Mbps
电缆类型
T1电缆(100欧姆标准屏蔽网线)
工作方式
CT1/ISDN PRI(仅HMIM-2T1模块支持)
FT1(仅HMIM-4T1-F模块支持)
支持服务
备份
终端接入服务
3. 接口指示灯
HMIM-2T1模块的前面板如下图所示:
图2-30 HMIM-2T1模块面板
HMIM-4T1-F的前面板如下图所示:
图2-31 HMIM-4T1-F模块面板
表2-30 HMIM-2T1/HMIM-4T1-F模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 接口电缆及连接方法
1. 简介
(1)     HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1模块
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1是2/4/8端口通道化E1/CE1/T1/CT1/PRI接口模块的简称。E1模块的主要功能是完成E1数据流的收发及处理,并提供CE1接入,可以实现ISDN PRI功能,达到一板多用目的。T1模块的主要功能是完成T1数据流的收发及处理,并提供CT1接入,可以实现ISDN PRI功能,达到一板多用目的。
(2)     HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F模块
HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F是2/4/8端口非通道化E1/T1/Fractional E1/T1模块的简称,其中E1T1-F表示“部分(FractionalE1T1”,其与HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1模块主要的区别是:
¡     E1T1-F模块支持的FE1T1工作方式仅能捆绑一次(即捆绑为一个通道,其速率为n×64K,n=1~31),而CE1T1模块可以将31个通道任意分组,实现多次捆绑。
¡     E1T1-F模块不支持PRI方式。
(3)     HMIM-2/4/8E1T1(-F)接口跳线说明
¡     出厂默认按照75欧姆E1配置,跳线连接PIN1-PIN2,PIN7-PIN8,PIN11-PIN12,PIN13-PIN14。
¡     对于T1模式以及120欧姆E1模式,跳线连接PIN1-PIN3,PIN5-PIN7,PIN9-PIN10,PIN11-PIN13。
图2-32 跳线的连接
·     接口模块上的每个端口都对应一个跳线座且跳线座的PIN定义相同。
·     发货时,接口模块每个端口提供4个跳线帽。
·     所有接口必须同时处于同一种模式下。
2. 接口属性
HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F模块接口属性如下表所示:
表2-31 HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F模块接口属性
属性
HMIM-2E1T1/ HMIM-2E1T1-F
HMIM-4E1T1/ HMIM-4E1T1-F
HMIM-8E1T1/ HMIM-8E1T1-F
连接器类型
RJ-45
RJ-45
RJ-45
连接器数量
2
4
8
接口标准
G.703/G.704
T1 102
AT&T TR 54016
AT&T TR 62411
ANSI T1.403
接口速率
1.544Mbps、2.048Mbps
电缆类型
E1 75欧姆非平衡同轴电缆
T1电缆(100欧姆标准屏蔽网线)
工作方式
E1/T1/CE1T1/ISDN PRI(仅HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1模块支持)
FE1T1(仅HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F模块支持)
支持服务
备份
终端接入服务
3. 接口指示灯
HMIM-2E1T1/HMIM-2E1T1-F模块的面板如下图所示:
图2-33 HMIM-2E1T1模块面板
图2-34 HMIM-2E1T1-F模块面板
HMIM-4E1T1/HMIM-4E1T1-F模块的面板如下图所示:
图2-35 HMIM-4E1T1模块面板
图2-36 HMIM-4E1T1-F模块面板
HMIM-8E1T1/HMIM-8E1T1-F模块的面板如下图所示:
图2-37 HMIM-8E1T1模块面板
图2-38 HMIM-8E1T1-F模块面板
其中各指示灯的含义如下表所示:
表2-32 HMIM-2E1T1/HMIM-4E1T1/HMIM-8E1T1HMIM-2E1T1-F/HMIM-4E1T1-F/HMIM-8E1T1-F模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 接口电缆及连接方法
2.7  E3/T3模块
·     HMIM-1CE3
2.7.1  HMIM-1CE3
1. 简介
HMIM-1CE3是1端口通道化E3/非通道化E3接口模块的简称。
HMIM-1CE3模块的主要功能为:
·     当工作在E3方式时,可完成一路E3高速数据流的收发和处理,并提供E3数据流的接入服务;
·     当工作在CE3方式时,可为用户提供N×64kbps(N小于等于128)的低速接入服务。
E3表示时分复用系统中E系列的三次群速率,即34.368Mbps。一路E3通过E23(表示E2到E3的复用/E3到E2解复用过程,这里指解复用过程)和E12(表示E1到E2的复用/E2到E1解复用过程,这里指解复用过程)两次解复用可以通道化为16个E1,而每路E1又可支持E1/CE1两种工作方式。
2. 接口属性
表2-33 HMIM-1CE3接口属性
属性
连接器类型
SMB
连接器数量
2
接口标准
G.703/G.704/G.751
接口速率
34.368Mbps
接口电缆类型
E3电缆(75欧姆同轴电缆)
工作方式
E3
CE3
支持服务
E3专线
3. 接口指示灯
HMIM-1CE3模块的面板如下图所示:
图2-39 HMIM-1CE3模块面板
其中各指示灯的含义如下表所示:
表2-34 HMIM-1CE3模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
告警信号的含义如下:
4. 接口电缆及连接方法
E3接口电缆及连接方法请参见3.5  接口类型为E3/T3接口
2.8  串口模块
·     HMIM-2SAE
·     HMIM-4SAE
·     HMIM-8SAE
·     HMIM-8ASE
·     HMIM-16ASE
·     RT-HMIM-8ASE-V2
·     RT-HMIM-16ASE-V2
1. 简介
HMIM-2SAE/HMIM-4SAE/HMIM-8SAE是2/4/8端口增强型高速同/异步串口模块的简称。SAE模块主要功能与SA模块相似,不同的是SAE模块的串口支持更多的协议,如RS449、X.21、RS530等。
2. 接口属性
SAE接口属性如下:
表2-35 HMIM-2SAE/HMIM-4SAE/HMIM-8SAE接口属性
属性
同步
异步
连接器类型
D28
连接器数量
2(HMIM-2SAE)
4HMIM-4SAE
8HMIM-8SAE
接口标准及工作方式
V.24
RS-232
DTE/DCE
DT/DCE
最小波特率(bps)
1200
1200
300
最大波特率(bps)
64k
2.048M
115.2
电缆类型
V.24 (RS-232)DTE电缆
V.24(RS-232)DCE电缆
V.35 DTE电缆
V.35 DCE电缆
X.21 DTE电缆
X.21 DCE电缆
RS449 DTE电缆
RS449 DCE电缆
RS530 DTE电缆
RS530 DCE电缆
支持服务
DDN专线
终端接入
Modem拨号
备份
异步专线
终端接入服务
3. 接口指示灯
HMIM-2SAE模块面板如下图所示:
图2-40 HMIM-2SAE模块面板
HMIM-4SAE模块面板如下图所示:
图2-41 HMIM-4SAE模块面板
其中各指示灯的含义如下表所示:
表2-36 HMIM-2SAE/HMIM-4SAE模块指示灯含义
指示灯
含义
LINK
ACT
HMIM-8SAE模块面板如下图所示:
图2-42 HMIM-8SAE模块面板
HMIM-8SAE模块每个通道只有一个指示灯,灯常亮表示LINK(链路已经连通),灯闪烁表示ACTIVE(有数据收发),灯灭表示链路未连接通。
4. 接口电缆及连接方法
1. 简介
HMIM-8ASE/HMIM-16ASE是增强型8/16端口异步串口模块的简称。
ASE模块的作用与AS模块相同,主要是完成异步串口数据流的收发及处理,不同之处是采用的连接器和接口电缆不同,ASE模块的连接器为RJ-45,电缆为AUX电缆。
2. 接口属性
HMIM-8ASE、HMIM-16ASE接口属性如下表所示:
表2-37 HMIM-8ASE/HMIM-16ASE接口属性
属性
HMIM-8ASE模块
HMIM-16ASE模块
连接器类型
RJ-45
连接器数量
8HMIM-8ASE
16HMIM-16ASE
接口标准及工作方式
RS-232
电缆类型
AUX电缆
以太网标准网线
8ASE/16ASE哑终端电缆
最小波特率(bps)
300
最大波特率(bps)
115.2k
支持服务
Modem拨号
备份
终端接入服务
异步专线
3. 接口指示灯
HMIM-8ASE模块的面板如下图所示:
图2-43 HMIM-8ASE模块面板
HMIM-16ASE模块的面板如下图所示:
图2-44 HMIM-16ASE模块面板
HMIM-8ASE、HMIM-16ASE模块每个通道只有一个指示灯,位置为面板最下方一排的圆孔内,其中各指示灯的含义:灯常亮表示LINK(链路已经连通),灯闪烁表示ACTIVE(有数据收发),灯灭表示链路未连通。
表2-38 接口电缆及连接方法
RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2接口模块支持热插拔,可长按REMOVE按钮直至RUN灯熄灭再进行拆卸操作。
1.
2. 简介
RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2是增强型8/16端口异步串口模块的简称。
3. 接口属性
RT-HMIM-8ASE-V2、RT-HMIM-16ASE-V2接口属性如下表所示:
表2-39 RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2接口属性
属性
RT-HMIM-8ASE-V2模块
RT-HMIM-16ASE-V2模块
连接器类型
RJ-45
连接器数量
8RT-HMIM-8ASE-V2
16RT-HMIM-16ASE-V2
接口标准及工作方式
RS-232
电缆类型
AUX电缆
以太网标准网线
哑终端电缆
最小波特率(bps)
300
最大波特率(bps)
115.2k
支持服务
Modem拨号
备份
终端接入服务
异步专线
4. 接口指示灯
RT-HMIM-8ASE-V2模块的面板如下图所示:
图2-45 RT-HMIM-8ASE-V2模块面板
RT-HMIM-16ASE-V2模块的面板如下图所示:
图2-46 RT-HMIM-16ASE-V2模块面板
RT-HMIM-8ASE-V2、RT-HMIM-16ASE-V2模块每个通道只有一个指示灯,位置为面板最下方一排的圆孔内,其中各指示灯的含义:灯常亮表示LINK(链路已经连通),灯闪烁表示ACTIVE(有数据收发),灯灭表示链路未连通。
5. 接口电缆及连接方法
2.9  语音模块
·     HMIM-16FXS
·     HMIM-8FXS8FXO
·     HMIM-2VE1
·     HMIM-2VT1
·     HMIM-1VE1
·     HMIM-1VT1
·     HMIM-4FXS
·     HMIM-4FXO
·     HMIM-4E&M
2.9.1  HMIM-16FXS
1. 简介
HMIM-16FXS是16端口环路中继的简称,主要功能是完成16路模拟语音信号的接入及处理,实现语音信号在数据通信网络上的传输。接口模块上有16个FXS端口:
2. 接口属性
HMIM-16FXS接口属性如下表所示:
表2-40 HMIM-16FXS接口属性
属性
连接器类型
RJ-11
连接器数量
16个FXS接口
接口标准
对过流过压保护符合ITU K.20
电缆类型
带磁环的电话线
拨号方式
支持DTMF,符合GB3378。不支持脉冲拨号
带宽
300~3400Hz
振铃电压
40V
3. 接口指示灯
HMIM-16FXS前面板如下图所示:
图2-47 HMIM-16FXS前面板
HMIM-16FXS指示灯含义如下:
表2-41 HMIM-16FXS指示灯含义
指示灯
含义
LINK/ACT
灭:表示链路空闲
黄色闪烁:表示链路被占用,正进行通话
4. 接口电缆及连接方法
FXS接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
2.9.2  HMIM-8FXS8FXO
1. 简介
HMIM-8FXS8FXO是8端口模拟用户线和8端口环路中继线电路接口卡的简称,主要功能是完成16路模拟语音信号的接入及处理,实现语音信号在数据通信网络上的传输。接口卡上有8个FXS端口和8个FXO端口:
使用HMIM-8FXS8FXO的时候,必须保证模块化设备已经可以连接至IP网或其它广域网。
2. 接口属性
HMIM-8FXS8FXO接口属性如下表所示:
表2-42 HMIM-8FXS8FXO接口属性
属性
连接器类型
RJ-11
连接器数量
8个FXS接口
8个FXO接口
接口标准
对过流过压保护符合ITU K.20
电缆类型
带磁环的电话线
拨号方式
带宽
300Hz~3400Hz
振铃电压
40V
3. 接口指示灯
HMIM-8FXS8FXO前面板
图2-48 HMIM-8FXS8FXO前面板
HMIM-8FXS8FXO指示灯含义如下:
表2-43 HMIM-8FXS8FXO指示灯含义
指示灯
含义
LINK/ACT
灭:表示链路空闲
黄色闪烁:表示链路被占用,正进行通话
4. 接口电缆及连接方法
2.9.3  HMIM-2VE1
1. 简介
HMIM-2VE1是2端口E1语音接口模块的简称。是为满足在VoIP系统中处理密集信号的要求而推出的。
HMIM-2VE1模块可为用户提供两个CE1/PRI/R2接口,提供最多60路语音信号的接入及处理。
2. 接口属性
HMIM-2VE1接口属性如下表所示:
表2-44 HMIM-2VE1接口属性
属性
连接器类型
D15
连接器数量
2
工作方式
CE1
ISDN PRI
R2
接口速率
2.048Mbps
电缆类型
E1 75欧姆非平衡同轴电缆
E1 120欧姆平衡双绞线电缆
支持服务
支持R2信令(中国1号信令与之类似)
支持DSS1信令
支持IP Fax
支持Comware中通用VoIP特性
3. 接口指示灯
HMIM-2VE1模块的面板如下图所示:
图2-49 HMIM-2VE1模块面板
其中各指示灯的含义如下表所示。
表2-45 HMIM-2VE1模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
告警信号的含义如下:
4. 接口电缆及连接方法
2.9.4  HMIM-2VT1
1. 简介
HMIM-2VT1是2端口T1语音接口模块的简称,是为满足在VoIP系统中处理密集信号的要求而推出的。
HMIM-2VT1模块可为用户提供两个CT1/PRI接口,提供最多48路语音信号的接入及处理。
2. 接口属性
HMIM-2VT1接口属性如下表所示:
表2-46 HMIM-2VT1接口属性
属性
连接器类型
RJ-45
连接器数量
2
接口标准
G.703/T1.102
G.704
AT&T TR 54016
AT&T TR 62411
ANSI T1.403
接口速率
1.544Mbps
电缆类型
T1电缆(100欧姆标准屏蔽网线)
工作方式
CT1/ISDN PRI
支持服务
备份
终端接入
ISDN
3. 接口指示灯
HMIM-2VT1模块的面板如下图所示:
图2-50 HMIM-2VT1模块面板
其中各指示灯的含义如下表所示。
表2-47 HMIM-2VT1模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
告警信号的含义如下:
4. 接口电缆及连接方法
2.9.5  HMIM-1VE1
1. 简介
HMIM-1VE1是1端口E1语音接口模块,是为满足在VoIP系统中处理密集信号的要求而推出的。
HMIM-1VE1模块可为用户提供一个CE1/PRI/R2接口,提供最多30路语音信号的接入及处理。
2. 接口属性
HMIM-1VE1接口属性如下表所示:
表2-48 HMIM-1VE1接口属性
属性
连接器类型
D15
连接器数量
1
工作方式
CE1
ISDN PRI
R2
接口速率
2.048Mbps
电缆类型
E1 75欧姆非平衡同轴电缆
E1 120欧姆平衡双绞线电缆
支持服务
支持R2信令(中国1号信令与之类似)
支持DSS1信令
支持IP Fax
支持Comware中通用VoIP特性
3. 接口指示灯
HMIM-1VE1模块的面板如下图所示:
图2-51 HMIM-1VE1模块面板
其中各指示灯的含义如下表所示。
表2-49 HMIM-1VE1模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
4. 接口电缆及连接方法
2.9.6  HMIM-1VT1
1. 简介
HMIM-1VT1是1端口T1语音接口模块的简称。HMIM-1VT1模块是为满足在VoIP系统中处理密集信号的要求而推出的。
HMIM-1VT1模块可为用户提供一个CT1/PRI接口,完成24路语音信号的接入及处理。
2. 接口属性
HMIM-1VT1接口属性如下表所示:
表2-50 HMIM-1VT1接口属性
属性
连接器类型
RJ-45
连接器数量
1
接口标准
G.703/T1.102
G.704
AT&T TR 54016
AT&T TR 62411
ANSI T1.403
接口速率
1.544Mbps
电缆类型
T1电缆(100欧姆标准屏蔽网线)
工作方式
CT1/ISDN PRI
支持服务
备份
终端接入
ISDN
3. 接口指示灯
HMIM-1VT1模块的面板如下图所示:
图2-52 HMIM-1VT1模块面板
其中各指示灯的含义如下表所示。
表2-51 HMIM-1VT1模块指示灯含义
指示灯
含义
LINK/ACT
LP/AL
告警信号的含义如下:
4. 接口电缆及连接方法
1. 简介
HMIM-4FXS是4端口语音用户电路接口模块的简称,其主要功能是提供2/4路普通模拟电话、Fax或电话交换机AT0环路中继的接入及处理,实现语音信号在数据通信网络上的传输;HMIM-4FXO是4端口语音AT0模拟中继接口模块的简称,其主要功能是提供2/4路电话交换机普通用户线的接入及处理,实现语音信号在数据通信网络上的传输;
2. 接口属性
HMIM-4FXS/HMIM-4FXO接口属性如下表所示:
表2-52 HMIM-4FXS/HMIM-4FXO接口属性
属性
连接器类型
RJ-45
连接器数量
4
电缆类型
带磁环的电话线
E&M中继线(E&M模块使用,应由用户根据使用情况现场制作)
接口标准
用户电路接口(HMIM-4FXS)符合ITU Q.512
环路中继接口(HMIM-4FXO)符合ITU Q.552
对过流过压保护符合ITU K.20
拨号方式
支持DTMF(Dual-Tone MultiFrequency),符合GB3378。不支持脉冲拨号。
带宽
300~3400Hz
3. 面板及接口指示灯
图2-53 HMIM-4FXS面板
图2-54 HMIM-4FXO面板
表2-53 HMIM-4FXS/HMIM-4FXO指示灯含义
指示灯
含义
LINK
灭表示连接没有建立,亮表示连接已经建立
ACT
灭表示通道空闲,亮表示有呼叫发生
4. 接口电缆及连接方法
FXS / FXO接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
1. 简介
HMIM-4E&M/HMIM-8E&M是4/8端口语音E&M模拟中继接口模块的简称,其主要功能是提供4/8路E&M模拟中继线的接入及处理,实现语音信号在数据通信网络上的传输。
2. 接口属性
HMIM-4E&M/HMIM-8E&M接口属性如下表所示:
表2-54 HMIM-4E&M/HMIM-8E&M接口属性
属性
连接器类型
RJ-45
连接器数量
·     4(HMIM-4E&M模块)
·     8(HMIM-8E&M模块)
电缆类型
带磁环的电话线
接口标准
E&M中继接口(HMIM-4E&M/HMIM-8E&M)符合G.712、E&M接口(支持Bell type I、II、III、V,支持2线4线)
对过流过压保护符合ITU K.20
拨号方式
带宽
300~3400Hz
3. 接口指示灯
图2-55 HMIM-4E&M模块面板
图2-56 HMIM-8E&M模块面板
面板上每个端口对应一个绿色与一个黄色的指示灯,各端口指示灯含义相同,如下表所示:
表2-55 HMIM-4E&M/HMIM-8E&M模块指示灯含义
指示灯
含义
LINK(绿色)
灯灭表示连接没有建立,灯亮表示连接已经建立
ACT(黄色)
灯灭表示通道空闲,灯亮表示有呼叫发生
4. 接口电缆及连接方法
E&M接口电缆及连接方法请参见3.9  接口类型为E&M接口
2.10  模拟Modem模块
·     HMIM-6AM
·     HMIM-6FCM
2.10.1  HMIM-6AM
1. 简介
HMIM-6AM是6端口模拟调制解调器接口模块的简称,其中AM(Analog Modem)是模拟调制解调器接口的英文缩写。
AM模块能实现模拟用户拨号接入和拨号呼出功能,支持ITU-T V.32、V.90 Modem等协议,连接速率可高达56kbps(V.90时)。
HMIM-6AM模块支持6路模拟用户拨号接入和拨号呼出功能,与MSR系列模块化路由器结合,可实现一个理想的中密度远端接入服务器(RAS)功能。
2. 接口属性
HMIM-6AM模块接口属性如下表所示:
表2-56 HMIM-6AM模块接口属性
属性
连接器类型
RJ-45
连接器数量
6
电缆类型
电话线
最大速率
56kbps
支持协议
ITU-T V.90/K56flex/ V.34 (33.6 kbps)/V.FC/V.32 bis/V.32/V.22 bis/V.22A/B/V.23/V.21/Bell 212A a/Bell 103
支持服务
Modem拨号
3. 接口指示灯
HMIM-6AM模块的面板如下图所示:
图2-57 HMIM-6AM模块面板
HMIM-6AM模块指示灯含义如下:
表2-57 HMIM-6AM/12AM模块指示灯含义
指示灯
含义
LINK
灯灭表示链路空闲,灯常亮表示链路连接已经建立,灯闪烁表示正在建立链路连接
ACT
灯灭表示链路空闲,灯闪烁表示链路正在进行数据收发
4. 接口电缆及连接方法
2.10.2  HMIM-6FCM
1. 简介
HMIM-6FCM是6端口快速连接调制解调器接口模块的简称,其中FCM(Fast Connect Modem)是快速连接调制解调器的英文缩写。FCM模块定位于销售点终端服务POS(Point Of Sale)的快速拨号接入到银行的卡帐务处理系统。
POS是指广泛应用于商场、加油站等地的一种刷卡消费业务,该业务通过将商户端的POS机(位于商场、加油站等地的刷卡机)接入到银行的卡帐务处理系统上,从而完成用户刷卡消费业务。
2. 接口属性
HMIM-6FCM模块接口属性如下表所示:
表2-58 HMIM-6FCM模块接口属性
属性
连接器类型
RJ-45(6FCM)
连接器数量
6(6FCM)
电缆类型
带磁环的电话线
支持协议
ITU-T V.22
3. 接口指示灯
HMIM-6FCM模块的面板如下图所示:
图2-58 HMIM-6FCM模块面板
每个POS接入端口的连接器上都有两个指示灯,一个为CD灯,另一个为ACT灯,分别表示是否有载波及数据收发。
表2-59 HMIM-6FCM模块指示灯含义
指示灯
含义
CD
通道载波检测指示灯(Carrier Detect),灯常亮表示端口检测到载波信号,灯灭表示端口未检测到载波信号
ACT
数据收发指示灯(Active),灯闪烁表示端口有数据收发,灯灭表示端口无数据收发
4. 接口电缆及连接方法
FCM接口电缆及连接方法请参见3.8  接口类型为ADSL/BS/FXS/FXO/AM/FCM接口
2.11  网络数据加密模块
1. 简介
HMIM-CNDE-SJK是国密加密HMIM模块的简称。HMIM-CNDE-SJK支持SM1、SM2、SM4加密算法,为路由器提供了高性能、高可靠性的加密特性。
2. 接口指示灯
图2-59 HMIM-CNDE-SJK模块面板
表2-60 HMIM-CNDE-SJK模块指示灯含义
指示灯
含义
RUN
黄色常亮表示接口模块上的国密模块故障
灯灭表示接口模块不在位或故障
2.12  HMIM转接模块
·     HMIM-Adapter
·     HMIM-Adapter-H
1. 简介
HMIM-Adapter/HMIM-Adapter-H是针对MIM卡研发的转换模块,部分MIM接口模块可通过连接HMIM-Adapter/HMIM-Adapter-H转换为HMIM接口模块,并具备其对应HMIM接口模块的功能,具体适配关系请参见“附录B 适配关系”。
2. 转换模块面板
HMIM-Adapter面板如下图所示:
图2-60 HMIM-Adapter面板
HMIM-Adapter-H面板如下图所示:
图2-61 HMIM-Adapter-H面板
3 线缆及连接
3.1  接口类型为以太网接口
1. 以太网线缆外观及适用款型
表3-1 以太网线缆外观及适用款型
线缆
外观
适用款型
以太网线缆
1 × RJ-45 < ---- > 1 × RJ-45
SIC-4FSW
SIC-4FSWP
SIC-4GSW
DSIC-9FSW
DSIC-9FSWP
SIC-1FEA
SIC-1GEC-V2
SIC-AP220
HMIM-8GSW
HMIM-24GSW
HMIM-24GSW-PoE
HMIM-2GEE
HMIM-4GEE
HMIM-8GEE
RT-HMIM-4GEE-V2
RT-HMIM-8GEE-V2
目前,10M/100M以太网使用五类双绞线,1000M以太网推荐使用超五类双绞线或六类双绞线,双绞线又分为标准网线和交叉网线两种。
五类线的传输频率为100MHz,用于语音传输和数据传输,主要用于100BASE-T和10BASE-T网络。这是最常用的以太网电缆,也可以用来传输1000M以太网数据。
超五类具有衰减小,串扰少,具有更高的衰减串扰比(ACR),更小的时延误差,性能较五类线得到很大的提高。超五类线主要用于1000M以太网。
六类线的传输频率为1MHz~250MHz,六类线改善了在串扰及回波损耗方面的性能,对于新一代全双工的高速网络应用而言,优良的回波损耗性能是极重要的。六类布线系统在200MHz时综合衰减串扰比(PS-ACR)应该有较大的余量,它提供2倍于超五类的带宽,其传输性能远远高于超五类标准,最适用于传输速率高于1Gbps的应用。
需要注意的是,10/100M以太网只使用橙白、橙、绿白、绿这两对线来收发数据,而1000M以太网使用双绞线的四对线来收发数据。
下面介绍几种常用双绞线的线序,A和B分别代表双绞线的两端:
表3-2 标准网线线序关系表
引脚号
A
B
1
橙白
橙白
2
3
绿白
绿白
4
5
蓝白
蓝白
6
绿
绿
7
棕白
棕白
8
表3-3 交叉网线线序关系表
引脚号
A
B
1
橙白
绿白
2
绿
3
绿白
橙白
4
5
蓝白
蓝白
6
绿
7
棕白
棕白
8
区分和制作两种以太网线时可参考上表,制作时应严格按照上表排列线序,否则即使可以连通两端设备,也会影响通信质量。
2. 连接方法
连接以太网线的方法:
(1)     连接网线:连接网线的一端到模块的以太网接口,连接网线另一端到对端设备的以太网接口。由于模块的以太网接口支持MDI/MDIX自适应,因此连接时采用标准网线、交叉网线均可。
(2)     连好网线后请检查:接口模块和业务模块面板指示灯的状态说明,请参见本手册中相应模块的介绍。
3.2  接口类型为光接口
1. 光模块、光纤外观及适用款型
接口类型为光接口时,需要配合SFP光模块使用,将采用带LC型光纤连接器的光纤。关于接口模块和光模块的适配关系,具体请参见《H3C MSR系列路由器 光模块适配关系表》。
2. 光模块及光纤连接方法
·     光接口在没有连接光连接器或防尘盖被打开的情况下可能会有不可见的射线从光接口射出来,所以请不要直视光接口。
·     如果光接口未装光连接器,则一定要盖上防尘盖。
连接光接口的光纤方法:
(1)     将SFP光模块插入接口模块或者业务模块的SFP接口。
(2)     确认光模块的Rx口和Tx口,并将光纤一端的两个LC连接器分别插入Rx口和Tx口,再将光纤另一端的两个LC连接器插入对端的Tx口和Rx口。
(3)     连好光纤后请检查模块面板上的LINK指示灯状态:
¡     灯亮表示光纤链路已经连通。
¡     灯灭表示链路没有连通,可能是由于光纤的发送端和接收端连接错误,请先尝试对调光纤一端的Rx口和Tx口。
3.3  接口类型为E1接口
1. E1电缆外观及适用款型
表3-4 E1电缆外观及适用款型
线缆
外观
适用款型
1端口E1 75欧姆电缆
图一 1端口E1 75欧姆电缆
1 × D15 < ---- > 2 × BNC
SIC-E1-F
SIC-EPRI
SIC-1EPRI
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
SIC-1VE1
HMIM-1VE1
HMIM-2VE1
1端口E1 120欧姆电缆
图二   1端口E1 120欧姆电缆
1 × D15 < ---- > 1 × RJ-45
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
SIC-1VE1
HMIM-1VE1
HMIM-2VE1
1端口E1 120欧姆电缆(2m,15m,30m)-RJ-45
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
SIC-1VE1T1
2端口E1 75欧姆电缆
图三  2端口E1 75欧姆电缆
1 × D15 < ---- > 4 × BNC
SIC-2E1-F
4端口E1 75欧姆电缆
图四  4端口E1 75欧姆电缆
1 × D25 < ---- > 4 × D15
HMIM-4E1
HMIM-4E1-F
4端口E1 120欧姆电缆
图五  4端口E1 120欧姆电缆
HMIM-4E1
HMIM-4E1-F
8端口E1 75欧姆线缆
1 × D68 < ---- > 16 × BNC
HMIM-8E1(75)
HMIM-8E1(75)-F
1端口E1 75欧姆电缆-RJ-45
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
SIC-1VE1T1
75欧姆中继电缆
图六  75欧姆中继电缆
1 × BNC < ---- > 1 × BNC
根据需要选择
同轴连接器
图七  同轴连接器
根据需要选择
阻抗转换器
图八 阻抗转换器
2 × BNC < ---- > 1 × RJ-45
根据需要选择
2. 接口拨码开关
E1/E1-F/VE1接口模块提供接口拨码开关(DIP),拨码开关的设置决定了接口阻抗和接地方式。
表3-5 接口拨码开关(DIP)与接口的对应关系
DIP开关
对应的E1接口
支持的模块
S1
接口0
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
HMIM-4E1
HMIM-4E1-F
SIC-1VE1
HMIM-1VE1
HMIM-2VE1
S2
接口1
HMIM-1E1
HMIM-1E1-F
HMIM-2E1
HMIM-2E1-F
HMIM-4E1
HMIM-4E1-F
HMIM-2VE1
S3
接口2
HMIM-4E1
HMIM-4E1-F
S4
接口3
HMIM-4E1
HMIM-4E1-F
接口拨码开关(DIP)缺省设置为全ON,即E1接口阻抗为75欧姆,如下图所示:
图3-1 接口拨码开关(DIP)缺省设置示意图
接口拨码开关(DIP)推荐使用方式为:外接75欧姆电缆时,BIT1~8全部拨到ON;外接120欧姆电缆时,BIT1~8全部拨到OFF。接口拨码开关(DIP)的具体含义及设置方法如下表所示:
表3-6 接口拨码开关(DIP)含义及设置方法
DIP开关
含义
75欧姆阻抗设置方法
120欧姆阻抗设置方法
1BIT
75欧姆120欧姆选择开关
ON
OFF
2BIT
ON
OFF
3BIT
ON
OFF
4BIT
ON
OFF
5BIT
ON
OFF
6BIT
RxRing接地方式选择开关
OFF:RxRing通过电容接地
ON:RxRing直接接地
7BIT
RxShield接地选择开关
ON:RxShield接地
OFF:RxShield不接地
8BIT
RxShield接地方式选择开关
OFF:RxShield通过电容接地
ON:RxShield直接接地
3. 1/2/8端口E1 75欧姆电缆连接方法(D15/D68 <----> BNC)
连接时请认准接口上的标识,以免误插入其它接口,导致接口模块或设备主机的损坏。
·     如果不需要延长转接电缆,可将E1 75欧姆电缆的BNC头直接连至对端网络设备:
a.     ‍将E1 75欧姆电缆的D15/D68与接口模块的D15/D68接口相连,并拧紧电缆固定旋钮。
b.     电缆的另一端为一对或多对75欧姆BNC接头,确认每对BNC接头的序号,应将标记为TX的接线与对端设备标记为RX的接线相连,标记为RX的接线与对端设备标记为TX的接线相连。
图3-2 E1 75欧姆电缆连接示意图
·     如果需要延长电缆,可将E1 75欧姆转接电缆的BNC头连接到同轴连接器,同轴连接器的另一侧通过75欧姆E1中继电缆连接对端网络设备:
图3-3 E1 75欧姆电缆连接示意图
·     如果对端设备的E1接口的阻抗为120欧姆,则需要通过阻抗转换器转接:
图3-4 阻抗转换连接器示意图
4. 4端口E1 75欧姆电缆连接方法(D25 <----> D15)
(1)     ‍将4端口E1 75欧姆电缆的D25与接口模块的D25接口相连,并拧紧电缆固定旋钮。
(2)     电缆的另一端为4个D15接头,根据需要直接与对端网络设备的D15接口相连。
图3-5 4端口E1 75欧姆电缆连接示意图
5. 1端口E1 120欧姆电缆连接方法(D15 <----> RJ-45)
(1)     ‍将1端口E1 120欧姆电缆的D15与接口模块的D15接口相连,并拧紧电缆固定旋钮。
(2)     电缆的另一端为一个或多个RJ-45接头,根据需要直接与对端网络设备的RJ-45接口相连。
图3-6 1端口E1 120欧姆电缆连接示意图
表3-7 DB15转BNC/RJ-45线序关系表
DB15
BNC(75W同轴电缆)
RJ-45(120W双绞线电缆)
9
Tx Tip
Tx Tip
4
Tx Tip
2
Tx Ring
Tx Ring
5
Tx Ring
10
Tx Shield
6
Tx Shield
8
Rx Tip
Rx Tip
1
Rx Tip
15
Rx Ring
Rx Ring
2
Rx Ring
7
Rx Shield
3
Rx Shield
6. 4端口E1 120欧姆电缆连接方法(D25 <----> D15)
(1)     ‍将4端口E1 120欧姆电缆的D25与接口模块的D25接口相连,并拧紧电缆固定旋钮。
图3-7 4端口E1 120欧姆电缆连接示意图
3.4  接口类型为T1接口
1. T1线缆外观及适用款型
表3-8 T1线缆外观及适用款型
线缆
外观
适用款型
1端口T1电缆
(100欧姆标准屏蔽网线)
SIC-T1-F
HMIM-2T1
HMIM-4T1-F
SIC-1VT1
SIC-1VE1T1
HMIM-1VT1
HMIM-2VT1
HMIM-2E1T1
HMIM-4E1T1
HMIM-8E1T1
HMIM-2E1T1-F
HMIM-4E1T1-F
HMIM-8E1T1-F
RJ-45连接器
图十八 RJ45连接器
根据需要选择
2. 1端口T1电缆连接方法
1端口T1电缆的两端均为RJ-45接口,将一端与接口模块的T1(RJ-45)接口相连,另一端与对端网络设备的T1(RJ-45)接口相连。
3.5  接口类型为E3/T3接口
1. E3/T3线缆外观及适用款型
表3-9 E3/T3线缆外观及适用款型
线缆
外观
适用款型
E3/T3接口电缆
1 × BNS < ---- > 1 × SMB
HMIM-1CE3
2. 连接方法
(1)     将一根E3/T3电缆一端的SMB连接器连接到接口模块的Tx口上,将另一端连接到对端设备的Rx口上;
(2)     将另一根E3/T3电缆一端的SMB连接器连接到接口模块的Rx口上,将另一端连接到对端设备的Tx口上;
3.6  接口类型为同/异步串口
1. 同/异步串口线缆外观及适用款型
表3-10 同/异步串口线缆外观及适用款型
线缆
外观
适用款型
V.24 DTE电缆
1 × D25(公) < ---- > 1 × D28
SIC-1SAE
SIC-2SAE
SIC-4SAE
HMIM-2SAE
HMIM-4SAE
HMIM-8SAE
V.24 DCE电缆
1 × D25(母) < ---- > 1 × D28
V.35 DTE电缆
1 × D28 < ---- > 1 × D34(公)
V.35 DCE电缆
1 × D28 < ---- > 1 × D34(母)
X.21 DTE电缆
1 × D15(公) < ---- > 1 × D28
X.21 DCE电缆
1 × D15(母) < ---- > 1 × D28
RS449 DTE电缆
1 × D28 < ---- > 1 × D37(公)
RS449 DCE电缆
1 × D28 < ---- > 1 × D37(母)
RS530 DTE电缆
RS530 DCE电缆
2. 连接方法
(1)     确认对端设备的接口类型,并选择正确的同步串口电缆。
(2)     将同步串口电缆的D28一端插入SAE接口模块上的D28接口。
(3)     对于广域网是DDN的线路,请将电缆与CSU/DSU的接口相连。
(4)     连好电缆后请检查SAE接口模块面板上的链路状态指示灯(LINK):
¡     灯亮表示链路已经连通。
¡     灯灭表示线路出现故障,信号失去同步,请检查线路。
3.7  接口类型为异步串口
1. 异步串口线缆外观及适用款型
表3-11 异步串口线缆外观及适用款型
线缆
外观
适用款型
8端口异步串口转接电缆
图九 8端口异步串口转接电缆
1 × D60 < ---- > 8 × RJ-45(母)
SIC-8AS
4端口异步串口转接电缆
图十  4端口异步串口转接电缆
1 × D28 < ---- > 4 × RJ-45(母)
SIC-16AS
串口服务器电缆
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
哑终端转接电缆
图十一  哑终端转接电缆
1 × RJ-45(母) < ---- > 1 × RJ-45(公)
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
AUX电缆
图十二  AUX电缆
1 × D25 & 1 × D9 < ---- > 1 × RJ-45
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
哑终端转接器
图十九 哑终端转接器
1 × D25 < ---- > 1 × RJ-45
HMIM-8ASE
HMIM-16ASE
RT-HMIM-8ASE-V2
RT-HMIM-16ASE-V2
配置电缆
1 × DB-9 < ---- > 1 × RJ-45
SIC-AP220
SIC-AP320
2. SIC-8AS/SIC-16AS接口模块连接方法
连接SIC-8AS接口模块线缆时,首先需要将8端口异步串口转接电缆的D60端与SIC-8AS接口模块相连。
连接SIC-16AS接口模块线缆时,首先需要将4端口异步串口转接电缆的D28端与SIC-16AS接口模块相连,最多可以连接四根4端口异步串口转接电缆。
异步串口转接电缆接好后,可以根据对端设备类型,选择相应的电缆连接:
·     如果对端设备接口为网络设备的Console口,则使用串口服务器电缆将其与异步串口转接电缆的RJ-45接口相连,如下图所示:
图3-8 串口服务器线缆连接示意图
·     如果对端设备为银行哑终端设备,则将哑终端电缆的RJ-45连接器(公)与异步串口转接电缆的RJ-45接口相连,将哑终端电缆另一端RJ-45连接器(母)通过直连网线与哑终端转接器的RJ-45接口相连,哑终端转换器另一端为D25接口,与银行哑终端设备相连,如下图所示:
图3-9 连接哑终端设备示意图
·     如果对端设备接口为D25/D9接口,一般为Modem,则使用AUX电缆将其与异步串口转接电缆相连:
图3-10 连接Modem示意图
3. HMIM-8ASE/HMIM-16ASE/RT-HMIM-8ASE-V2/RT-HMIM-16ASE-V2接口模块连接方法
连接时请认准接口上的标识,以免误插入其它接口,导致模块或路由器主机的损坏。
·     如果对端设备接口为网络设备的Console口,则使用串口服务器电缆将其与接口模块的RJ-45接口相连,如下图所示:
图3-11 串口服务器线缆连接示意图
·     如果对端设备为银行哑终端设备,则将哑终端电缆的RJ-45连接器(公)与接口模块的RJ-45接口相连,哑终端电缆另一端RJ-45连接器(母)通过直连网线与哑终端转接器的RJ-45接口相连,哑终端转换器另一端为D25接口,与银行哑终端设备相连,如下图所示:
图3-12 银行哑终端设备连接示意图
·     如果对端设备接口为D25/D9接口,一般为Modem,则使用AUX电缆将其与接口模块的RJ-45接口相连,如下图所示:
图3-13 Modem连接示意图
4. SIC-AP220/SIC-AP320接口模块连接方法
(1)     将Console口配置电缆的DB-9孔式插头连接到要对设备进行配置的计算机的串口,再将RJ-45一端连接到设备的Console口;
(2)     在拆除连接时,建议用户先拔出RJ-45端,再拔出DB-9端。
1. 带磁环的电话线外观及适用款型
表3-12 带磁环的电话线外观及适用款型
线缆
外观
适用款型
带磁环的电话线
图十三  带磁环的电话线
1 × RJ-11 < ---- > 1 × RJ-11
SIC-1ADSL
SIC-1ADSL-I
SIC-1BS
SIC-1FXS
SIC-1FXO
SIC-2FXS
SIC-2FXO
SIC-2FXS1FXO
DSIC-4FXS1FXO
SIC-1AM
HMIM-4FXS
HMIM-4FXO
HMIM-16FXS
HMIM-8FXS8FXO
HMIM-6AM
HMIM-6FCM
2. ADSL/FXS/FXO/AM/FCM接口模块电缆连接方法
(1)     将带磁环的电话线一端与接口模块的RJ-11或RJ-45接口相连;
(2)     另一端与对端设备接口相连。
3. BS/BU接口模块电缆连接方法
(1)     若运营商提供ISDN U接口线路,则需要通过NT1设备转接。将带磁环的电话线的一端与SIC-1BS接口模块的RJ-45接口相连,另一端与NT1设备相连,运营商提供的ISDN U接口电缆与NT1设备的U口相连。
图3-14 连接运营商U接口线路到SIC-1BS接口模块示意图
(2)     若运营商提供ISDN S/T接口线路,则直接将运营商电缆接入SIC-1BS接口模块的RJ-45接口。
图3-15 连接运营商S/T接口线路到SIC-1BS接口模块示意图
3.9  接口类型为E&M接口
1. E&M接口电缆外观及适用款型
E&M模块支持Bell I、II、III、V类的交换机类型,支持2线和4线音频两种方式。
使用时,推荐按Bell V类4线方式进行路由器与交换机的连接。
E&M模块RJ-45插座的管脚顺序如下图所示,从插座往里看,缺口朝下,从左至右依次为1~8脚:
图3-16 RJ-45接口管脚排序示意图
表3-13 E&M模块接口电缆线序(Bell V类4线)
E&M模块接口电缆线序
信号
信号方向
1
2
E
IN
3
RING0
IN
4
RING1
OUT
5
TIP1
OUT
6
TIP0
IN
7
M
OUT
8
SG
由于无法确定对端交换机的接口类型(Bell I/II/III/V)、连接线类型(2线/4线)以及线序(E/M/收/发),E&M模块的接口电缆只能根据现场实际情况进行制作,为保证路由器整机的电磁兼容效果,请用户在制作的E&M接口电缆靠近路由器一侧的电缆接头附近套上磁环。
2. 连接方法
(1)     将带磁环的电话线一端与接口模块的RJ-45接口相连;
(2)     另一端与对端设备相连。
3.10  接口类型为BSV/BSE接口
1. BSV/BSE接口电缆外观及适用款型
表3-14 BSV/BSE接口电缆外观及适用款型
线缆
外观
适用款型
ISDN S/T接口标准电缆
SIC-1BSV
SIC-2BSV
ISDN S/T接口交叉电缆
图十一  哑终端转接电缆
SIC-1BSV
SIC-2BSV
2. SIC-1BSV/SIC-2BSV/MIM-4BSV接口模块电缆连接方法
BSV接口支持User和Network两种工作模式。若连接至ISDN网络,BSV接口应工作在User模式;若连接至TE设备(如数字电话或设置为User模式的BSV接口),BSV接口应工作在Network模式。
根据工作模式的不同,选择对应的电缆连接:
·     如果BSV接口工作在User模式,则需要根据运营商线路类型确认连接方式:
a.     ‍若运营商提供ISDN U接口线路,则需要通过NT1设备转接。将ISDN S/T口标准电缆的一端与BSV接口模块的RJ-45接口相连,另一端与NT1设备相连,运营商提供的ISDN U接口电缆与NT1设备的U口相连。
图3-17 连接运营商U接口线路到BSV接口模块示意图
b.     若运营商提供ISDN S/T接口线路,则直接将运营商电缆接入BSV接口。
图3-18 连接运营商S/T接口线路到BSV接口模块示意图
·     如果BSV接口工作在Network模式,与TE设备(如数字电话或设置为user模式的BSV接口)相连,则需要使用ISDN S/T接口交叉电缆转接:
将ISDN S/T接口交叉电缆的RJ-45(公)一端连接至BSV接口模块的RJ-45接口,另一端RJ-45(母)与ISDN S/T接口标准电缆连接;将ISDN S/T接口标准电缆的另一端连接至TE设备。
图3-19 连接TE设备到BSV接口模块示意图
3.11  接口类型为3G接口
1. SIC-3G-TD / SIC-3G-HSPA接口模块天线外观及适用款型
表3-15 SIC-3G-TD / SIC-3G-HSPA接口模块天线外观及适用款型
线缆
外观
适用款型
天线
TZD-EW618-04_页面_1_图像_0003
SIC-3G-TD
SIC-3G-HSPA
AUX电缆
图十二  AUX电缆
表3-16 SIC-3G-TD / SIC-3G-HSPA接口模块天线详细规格
属性
参数
频率范围
824-960 MHz / 1710-2170 MHz
电压驻波比
≤2
输入阻抗
50Ω
增益
1.5dBi
极化形式
垂直
最大输入功率
10W
接口形式
TNC-Male
雷电保护
直流接地
高度
153mm
重量
26g
电缆长度
天线颜色
黑色
工作温度
-30~60℃
2. SIC-3G-TD / SIC-3G-HSPA接口模块天线连接方法
(1)     为便于将天线安装到接口模块上,先将天线的弯折角度调整成180º;
(2)     将天线按顺时针方向旋紧到标有MAIN字样的天线接头上,注意不要过量用力,以免造成天线损坏。为达到良好的信号区域覆盖,通常将天线调整成与地面或天花板垂直的状态。
3. SIC-3G-TD / SIC-3G-HSPA接口模块调测电缆连接方法
SIC-3G-TD / SIC-3G-HSPA模块面板上的Diag Port(RJ-45)接口为调测口,通过AUX电缆连接对端设备,用于第三方软件对SIC-3G-HSPA接口模块的调测,模块正常运行时不需要连接AUX电缆。
当需要对SIC-3G-TD / SIC-3G-HSPA模块进行调测时,将AUX电缆的RJ-45接口与模块面板上的Diag Port接口相连,将另一端的D25/D9连接器连接到对端设备,一般为PC。
3.12  接口类型为4G接口
1. 4G天线及延长线外观和适用款型
表3-17 4G天线及延长线外观和适用款型
线缆
外观
适用款型
4G天线
SIC-4G-LTE-M
4G天线
SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK
4G天线
RT-SIC-4G-CAT6
4G天线延长线
表3-18 SIC-4G-LTE-M接口模块4G天线详细规格
属性
参数
频率范围
698~960MHz
1.71~2.7GHz
电压驻波比
2.5
输入阻抗
50 ohms
增益
2 dBi
极化形式
垂直
最大输入功率
5W
接口形式
TNC
高度
21.4 cm
重量
50.5 g
天线颜色
黑色
工作温度
-40°C to +85°C
表3-19 SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK接口模块4G天线详细规格
属性
参数
频率范围
791~960MHz
1710~2690MHz
电压驻波比
≤3.5:1
输入阻抗
50 ohms
增益
791MHz~960MHz @ 3.1 dBi
1710MHz~2690MHz @ 7.2dBi
极化形式
垂直
最大输入功率
1W
接口形式
SMA
高度
16.6 cm
重量
>22g
天线颜色
黑色
工作温度
-10°C to +60°C
表3-20 RT-SIC-4G-CAT6接口模块4G天线详细规格
属性
参数
频率范围
617~960MHz
1400~1612MHz
1710~2170MHz
2300~2700 MHz
3300~3800 MHz
4400~5000 MHz
5150~5850 MHz
电压驻波比
4 MAX
输入阻抗
50 ohms
增益
617-960MHz/0.59dBi
1400~1612MHz/1.87dBi
1710-2170MHz/3.74dBi
2300-2700MHz/3.51dBi
3300-3800MHz/3.7dBi
4400-5000MHz/4.0dBi
5150-5850MHz/4.87dBi
极化形式
垂直
最大输入功率
1W
接口形式
SMA-Male
高度
20.3 cm
重量
19.63 g
天线颜色
黑色
工作温度
-20°C to +65°C
表3-21 SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK接口模块4G天线延长线详细规格
属性
参数
频率范围
698~960 MHz
1710~2700 MHz
电压驻波比
≤2.0
输入阻抗
50 ohms
增益
2.0 dBi
极化形式
垂直
接口形式
SMA
高度
16.4+(-)0.2 cm
重量
134+(-)5g
天线颜色
黑色
线缆长度
200+(-)2 cm
工作温度
-40°C to +60°C
2. 4G天线以及延长线连接方法
SIC-4G-LTE-M/SIC-4G-CNDE/SIC-D4G-CNDE/SIC-4G-CNDE-SJK/SIC-D4G-CNDE-SJK接口模块的4G天线以及延长线连接方法,具体请参见《H3C MSR 4G SIC模块 SIM卡及天线延长线 安装指导》(用户也可通过登录H3C官网查阅该安装指导http://www.h3c.com/cn/home/qr/default.htm?id=1976)。
RT-SIC-4G-CAT6接口模块的4G天线以及延长线连接方法,具体请参见《H3C MSR SIC-4G-CAT6模块 SIM卡及天线延长线 安装指导》(用户也可通过登录H3C官网查阅该安装指导http://www.h3c.com/cn/home/qr/default.htm?id=1975)。
3. SIC-4G-LTE-M接口模块调测电缆连接方法
SIC-4G-LTE-M模块面板上的Mini USB接口为调测口,通过USB配置电缆连接对端设备,用于第三方软件对SIC-4G-LTE-M接口模块的调测,模块正常运行时不需要连接USB配置电缆。
当需要对SIC-4G-LTE-M模块进行调测时,将USB配置电缆的USB接口端连接到对端设备,一般为PC,将另一端连接到接口模块的Mini USB接口上。
3.13  接口类型为5G接口
1. 棒状天线及天线延长线外观和适用款型
表3-22 棒状天线及天线延长线外观和适用款型
线缆
外观
适用款型
棒状天线一
cid:image004.jpg@01D68CDF.2C973130
RT-SIC-5G
棒状天线二
RT-SIC-5G-CN
棒状天线三
RT-SIC-5G-CN
3m磁吸底座延长线
cid:image005.jpg@01D68CDF.2C973130
RT-SIC-5G
RT-SIC-5G-CN
1m磁吸底座延长线
RT-SIC-5G
RT-SIC-5G-CN
10cm线缆
RT-SIC-5G
RT-SIC-5G-CN
5m/10m延长线
RT-SIC-5G
RT-SIC-5G-CN
天线支架
RT-SIC-5G
RT-SIC-5G-CN
棒状天线存在新旧版本差异,具体请以实际发货为准,图片仅供参考。
表3-23 棒状天线一详细规格
属性
参数
频率范围
698~960MHz
1710~2170MHz
2300~2700 MHz
3300~3800 MHz
4400~5000 MHz
5150~5850 MHz
电压驻波比
4 MAX
输入阻抗
50 ohms
增益
617-960MHz/0.59dBi
3300-3800MHz/3.7dBi
4400-5000MHz/4.0dBi
极化形式
垂直
最大输入功率
1W
接口形式
SMA-Male
高度
20.3 cm
重量
19.63 g
天线颜色
黑色
工作温度
-20°C to +65°C
表3-24 棒状天线二详细规格
属性
参数
频率范围
0.6~6GHz
电压驻波比
6 MAX
输入阻抗
50 ohms
增益
2.74 dBi [email protected]~0.96GHz
1.01 dBi [email protected]~1.612GHz
4.48 dBi [email protected]~2.17GHz
3.98 dBi [email protected]~2.7GHz
4.74 dBi [email protected]~4.0GHz
5.50 dBi [email protected]~5.0GHz
5.82 dBi [email protected]~5.85GHz
极化形式
垂直
最大输入功率
1W
接口形式
SMA-Male
高度
17.6 cm
重量
20g
天线颜色
黑色
工作温度
-20°C to +70°C
表3-25 棒状天线三详细规格
属性
参数
频率范围
0.6~5GHz
电压驻波比
2.8 MAX
输入阻抗
50 ohms
增益
0.24 dBi [email protected]~0.96GHz
2.32 dBi [email protected]~1.612GHz
1.89 dBi [email protected]~2.17GHz
3.00 dBi [email protected]~2.7GHz
4.18 dBi [email protected]~4.0GHz
4.18 dBi [email protected]~5.0GHz
极化形式
线性极化
最大输入功率
10W
接口形式
SMA-Male
高度
22.93 cm
重量
27.5g
天线颜色
黑色
表3-26 3m磁吸底座延长线规格
属性
参数
频率范围
DC~6GHz
电压驻波比
5 MAX
输入阻抗
50 ohms
线材
RG-174
最大输入功率
1W
接口形式
SMA
线缆长度
3000mm
重量
65.3 g
天线颜色
黑色
工作温度
-40°C to +85°C
表3-27 1m磁吸底座延长线规格
属性
参数
频率范围
DC~6GHz
电压驻波比
≤1.7
输入阻抗
50 ohms
线材
RG-174
接口形式
SMA
线缆长度
1m
重量
202g
天线颜色
黑色
工作温度
-20°C to +70°C
表3-28 10cm线缆规格
属性
参数
频率范围
DC~6GHz
电压驻波比
≤1.2@(3GHz),≤1.4@(3~6GHz)
输入阻抗
50 ohms
线材
RG174
最大输入功率
接口形式
SMA
线缆长度
10cm
重量
天线颜色
黑色
工作温度
-40°C to +85°C
表3-29 5m延长线规格
属性
参数
频率范围
DC~6GHz
电压驻波比
<1.20(0.3---2.4GHZ);<1.4(5-6GHZ)
输入阻抗
50 ohms
线材
RG8
最大输入功率
接口形式
SMA
线缆长度
5m
重量
天线颜色
白色
工作温度
-40°C to +85°C
表3-30 10m延长线规格
属性
参数
频率范围
DC~6GHz
电压驻波比
≤1.2@(2.4GHz),≤1.5@(5~6GHz)
输入阻抗
50 ohms
线材
RG8
最大输入功率
接口形式
SMA
线缆长度
10m
重量
天线颜色
白色
工作温度
-40°C to +85°C
2. 棒状天线及天线延长线的连接方法
由于不同用户在选购时对天线延长长度以及使用场景的要求不同,所以选择的天线配置方案有所差异。不同的天线配置方案安装方法也不尽相同,具体请参见《H3C MSR 5G SIC模块 SIM卡及天线延长线 安装指导》(用户也可通过登录H3C官网查阅该安装指导http://www.h3c.com/cn/home/qr/default.htm?id=1974)。
3.14  接口类型为GPS接口
1. SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK接口模块GPS天线外观及适用款型
表3-31 SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK接口模块GPS天线外观及适用款型
线缆
外观
适用款型
GPS天线
表3-32 SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK接口模块GPS天线详细规格
属性
参数
频率范围
1575.42±3 MHz
电压驻波比
1.92:1 Max
输入阻抗
50 ohms
增益
1.5 dBic Typ.
回波损耗
10 dB Min
接口形式
SMA公头
延长线长度
5M
延长线类型
RG-174 Coaxial Cable
天线颜色
黑色
工作温度
-30℃~+80℃
2. SIC-4G-CNDE / SIC-D4G-CNDE / SIC-4G-CNDE-SJK / SIC-D4G-CNDE-SJK接口模块GPS天线连接方法
(1)     将天线的SMA公头对准面板的GPS接口,顺时针旋紧插头。
(2)     将延长线另一端的外置天线置于室外,保证信号的接收。
3.15  接口类型为GNSS接口
3.15.1  RT-SIC-4G-CAT6接口模块GNSS天线外观及适用款型
表3-33 RT-SIC-4G-CAT6接口模块GNSS天线外观及适用款型
线缆
外观
适用款型
GNSS天线
RT-SIC-4G-CAT6
表3-34 RT-SIC-4G-CAT6接口模块GNSS天线详细规格
属性
参数
频率范围
1561±3/1575.42±3 /1602±0.5 MHz
支持模式
输入阻抗
50 ohms
增益
-2.91 dBi Typ
接口形式
SMA公头
延长线长度
5M
延长线类型
天线颜色
黑色
工作温度
-40℃~+85℃
3.15.2  RT-SIC-4G-CAT6接口模块GNSS天线连接方法
(1)     ‍将天线的SMA公头对准面板的GNSS接口,顺时针旋紧插头。
3.16  接口类型为WLAN接口
1. WLAN接口模块天线外观及适用款型
表3-35 WLAN接口模块天线外观及适用款型
线缆
外观
适用款型
WLAN接口模块天线
天线渲染图
SIC-AP220
SIC-AP320
2. WLAN接口模块天线连接方法
(2)     将天线按顺时针方向旋紧到接口模块的天线接头上,注意不要过量用力,以免造成天线损坏。为达到良好的信号区域覆盖,通常将天线调整成与地面或天花板垂直的状态。
