07-IP组播命令参考
14-IPv6 PIM命令
本章节下载 14-IPv6 PIM命令  (409.17 KB)
14-IPv6 PIM命令
  录
1 IPv6 PIM
1.1 IPv6 PIM配置命令
1.1.1 anycast-rp (IPv6 PIM view)
1.1.2 bidir-pim enable (IPv6 PIM view)
1.1.3 bidir-rp-limit (IPv6 PIM view)
1.1.4 bsm-fragment enable (IPv6 PIM view)
1.1.5 bsm-reflection enable (IPv6 PIM view)
1.1.6 bsr-policy (IPv6 PIM view)
1.1.7 bsr-rp-mapping rfc2362  (IPv6 PIM view)
1.1.8 c-bsr (IPv6 PIM view)
1.1.9 c-rp (IPv6 PIM view)
1.1.10 crp-policy (IPv6 PIM view)
1.1.11 display ipv6 pim bsr-info
1.1.12 display ipv6 pim claimed-route
1.1.13 display ipv6 pim c-rp
1.1.14 display ipv6 pim df-info
1.1.15 display ipv6 pim interface
1.1.16 display ipv6 pim neighbor
1.1.17 display ipv6 pim routing-table
1.1.18 display ipv6 pim rp-info
1.1.19 display ipv6 pim statistics
1.1.20 dscp
1.1.21 embedded-rp
1.1.22 hello-option dr-priority (IPv6 PIM view)
1.1.23 hello-option holdtime (IPv6 PIM view)
1.1.24 hello-option lan-delay (IPv6 PIM view)
1.1.25 hello-option neighbor-tracking (IPv6 PIM view)
1.1.26 hello-option override-interval (IPv6 PIM view)
1.1.27 holdtime join-prune (IPv6 PIM view)
1.1.28 ipv6 pim
1.1.29 ipv6 pim bfd enable
1.1.30 ipv6 pim bsr-boundary
1.1.31 ipv6 pim dm
1.1.32 ipv6 pim hello-option dr-priority
1.1.33 ipv6 pim hello-option holdtime
1.1.34 ipv6 pim hello-option lan-delay
1.1.35 ipv6 pim hello-option neighbor-tracking
1.1.36 ipv6 pim hello-option override-interval
1.1.37 ipv6 pim holdtime join-prune
1.1.38 ipv6 pim neighbor-policy
1.1.39 ipv6 pim non-stop-routing
1.1.40 ipv6 pim passive
1.1.41 ipv6 pim require-genid
1.1.42 ipv6 pim sm
1.1.43 ipv6 pim state-refresh-capable
1.1.44 ipv6 pim timer graft-retry
1.1.45 ipv6 pim timer hello
1.1.46 ipv6 pim timer join-prune
1.1.47 ipv6 pim triggered-hello-delay
1.1.48 jp-pkt-size (IPv6 PIM view)
1.1.49 register-policy (IPv6 PIM view)
1.1.50 register-suppression-timeout (IPv6 PIM view)
1.1.51 register-whole-checksum (IPv6 PIM view)
1.1.52 snmp-agent trap enable pim6
1.1.53 source-lifetime (IPv6 PIM view)
1.1.54 source-policy (IPv6 PIM view)
1.1.55 spt-switch-threshold (IPv6 PIM view)
1.1.56 ssm-policy (IPv6 PIM view)
1.1.57 state-refresh-hoplimit (IPv6 PIM view)
1.1.58 state-refresh-interval (IPv6 PIM view)
1.1.59 state-refresh-rate-limit (IPv6 PIM view)
1.1.60 static-rp (IPv6 PIM view)
1.1.61 timer hello (IPv6 PIM view)
1.1.62 timer join-prune (IPv6 PIM view)
1 IPv6 PIM
1.1  IPv6 PIM配置命令
anycast-rp命令用来配置Anycast-RP。
undo anycast-rp命令用来删除Anycast-RP。
anycast-rp ipv6-anycast-rp-address ipv6-member-address
undo anycast-rp ipv6-anycast-rp-address ipv6-member-address
不存在Anycast-RP。
IPv6 PIM视图
ipv6-anycast-rp-address:指定Anycast-RP地址。必须是合法的IPv6全球单播地址。
ipv6-member-address:指定Anycast-RP成员地址。必须是合法的IPv6全球单播地址。
多次执行本命令,可配置多个Anycast-RP。如果配置时指定了相同的Anycast-RP地址,则将Anycast-RP成员地址添加到该Anycast-RP地址所属的Anycast-RP集中。
Anycast-RP成员地址不能与Anycast-RP地址相同。
# 在公网实例中配置如下Anycast-RP集:Anycast-RP地址为1:1::0,两个成员的地址分别为1:1::1和1:2::1(前者为本地接口LoopBack1的地址)。
[Sysname] ipv6 pim
[Sysname-pim6] anycast-rp 1:1::0 1:1::1
[Sysname-pim6] anycast-rp 1:1::0 1:2::1
·     display ipv6 pim rp-info
bidir-pim enable命令用来使能IPv6双向PIM。
undo bidir-pim enable命令用来关闭IPv6双向PIM。
bidir-pim enable
IPv6双向PIM处于关闭状态。
IPv6 PIM视图
只有在相应实例中先使能了IPv6组播路由,本命令才能生效。
# 使能公网实例中的IPv6组播路由,并使能IPv6双向PIM。
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname] ipv6 pim
[Sysname-pim6] bidir-pim enable
·     ipv6 multicast routing(IP组播命令参考/IPv6组播路由与转发)
bidir-rp-limit命令用来配置IPv6双向PIM RP的最大数目。
undo bidir-rp-limit命令用来恢复缺省情况。
bidir-rp-limit limit
undo bidir-rp-limit
配置IPv6双向PIM RP的最大数目为6。
IPv6 PIM视图
limit:指定IPv6双向PIM RP的最大数目,取值范围为1~32。
由于IPv6双向PIM为每个RP都要在所有IPv6 PIM接口上进行DF选举,因此实际组网中不建议配置多个IPv6双向PIM RP。通过本命令可以限制IPv6双向PIM RP的数目,超出限制值的RP不会生效,仅能进行DF选举而无法指导转发。
# 在公网实例中配置IPv6双向PIM RP的最大数目为3。
[Sysname] ipv6 pim
[Sysname-pim6] bidir-rp-limit 3
bsm-fragment enable命令用来开启自举报文语义分片功能。
undo bsm-fragment enable命令用来关闭自举报文语义分片功能。
bsm-fragment enable
自举报文语义分片功能处于开启状态。
IPv6 PIM视图
当IPv6 PIM-SM域或双向PIM域中存在不支持自举报文语义分片的设备时,请关闭本功能。
# 在公网实例中关闭自举报文语义分片功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-fragment enable
bsm-reflection enable命令用来开启自举报文往报文入接口方向转发功能。
undo bsm-reflection enable命令用来关闭自举报文往报文入接口方向转发功能。
自举报文往报文入接口方向转发功能处于开启状态。
IPv6 PIM视图
当IPv6 PIM-SM或IPv6双向PIM域中不需要自举报文往报文入接口方向转发时,请关闭本功能。
# 在公网实例中关闭自举报文往报文入接口方向转发功能。
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-reflection enable
bsr-policy命令用来配置合法的BSR地址范围。
undo bsr-policy命令用来恢复缺省情况。
bsr-policy ipv6-acl-number
undo bsr-policy
BSR的地址范围不受限制,即认为来自任意源的自举报文都是合法的。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。
配置合法的BSR地址范围可以防止BSR欺骗。
该ACL规则中的source参数用来指定合法BSR的源地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
若ACL中指定了vpn-instance参数则该条规则不生效。
多次执行本命令,最后一次执行的命令生效。
# 在公网实例中配置合法的BSR地址范围,只允许网段2001::2/64中的设备充当BSR。
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 2001::2 64
[Sysname] ipv6 pim
[Sysname-pim6] bsr-policy 2000
·     c-bsr (IPv6 PIM view)
bsr-rp-mapping rfc2362命令用来配置RP映射采用RFC 2362中规定的哈希算法。
undo bsr-rp-mapping rfc2362命令用来恢复缺省情况。
RP映射采用RFC 4601中规定的哈希算法。
IPv6 PIM视图
为了确保本网络内各路由器上RP映射信息一致,请在所有路由器上配置相同的RP映射哈希算法。
# 在公网实例中RP映射采用RFC 2362中规定的哈希算法。
[Sysname] ipv6 pim
[Sysname-pim6] bsr-rp-mapping rfc2362
c-bsr命令用来配置C-BSR。
undo c-bsr命令用来删除C-BSR的相关配置。
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
undo c-bsr ipv6-address [ scope scope-id ]
不存在C-BSR。
IPv6 PIM视图
ipv6-address:指定C-BSR的IPv6地址,C-BSR的IPv6地址必须是本地接口的IPv6地址,且该接口上必须使能IPv6 PIM,否则配置不会生效。
scope scope-id:指定IPv6管理域的编号,取值范围为3~15。如果未指定本参数,表示配置服务于Global域的C-BSR。
hash-length hash-length:指定哈希掩码长度,取值范围为0~128,缺省值为126。
priority priority:指定C-BSR的优先级,取值范围为0~255,缺省值为64。数值越大,优先级越高。
如果对同一个域多次执行本命令,最后一次执行的命令生效;而针对不同域的C-BSR则允许指定相同的IPv6地址。
# 在公网实例中将IPv6地址为1101::1的设备配置为Global域的C-BSR。
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr 1101::1
c-rp命令用来配置C-RP。
undo c-rp命令用来删除C-RP的相关配置。
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy ipv6-acl-number | scope scope-id } | holdtime hold-time | priority priority ] * [ bidir ]
undo c-rp ipv6-address
不存在C-RP。
IPv6 PIM视图
ipv6-address:指定C-RP的IPv6地址,C-RP的IPv6地址必须有对应的本地接口,且该接口上必须使能IPv6 PIM,否则配置不会生效。
advertisement-interval adv-interval:指定发送宣告报文的间隔时间,取值范围为1~65535,单位为秒,缺省值为60。
group-policy ipv6-acl-number:指定IPv6基本ACL的编号,取值范围为2000~2999。如果指定了本参数,该C-RP将只为ACL规则所允许的IPv6组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则该C-RP将为所有IPv6组播组服务。
holdtime hold-time:指定C-RP的超时时间,取值范围为1~65535,单位为秒,缺省值为150。
priority priority:指定C-RP的优先级,取值范围为0~255,缺省值为192。该数值越大,优先级越低。
bidir:指定该C-RP服务于IPv6双向PIM。如果未指定本参数,该C-RP将服务于IPv6 PIM-SM。
如果设备想要成为多个组范围的C-RP,则需要在配置group-policy所对应的ACL时将多个组范围用多个rule规则表示出来。
ACL规则中的source参数用来指定C-RP所服务的IPv6组播组范围(若指定的不是IPv6组播组地址,则此规则不生效),而其它可选参数都将被忽略。该ACL规则用来定义该C-RP所服务的IPv6组播组范围,只有permit的IPv6组播组才会作为RP的服务组范围通告出去。
如果对同一IPv6地址多次执行本命令,最后一次执行的命令生效。
# 在公网实例中将IPv6地址为2001::1配置为组播组FF0E:0:1391::/96的C-RP,且C-RP的优先级为10。
[Sysname-acl-ipv6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
crp-policy命令用来配置合法的C-RP地址范围及其服务的IPv6组播组范围。
undo crp-policy命令用来恢复缺省情况。
crp-policy ipv6-acl-number
undo crp-policy
C-RP地址范围及其服务的IPv6组播组范围不受限制,即认为所有收到的C-RP报文都是合法的。
IPv6 PIM视图
ipv6-acl-number:指定IPv6高级ACL的编号,取值范围为3000~3999。
配置合法的C-RP地址范围及其服务的IPv6组播组范围可以防止C-RP欺骗。
本命令在对C-RP所宣告的IPv6组播组范围进行过滤时,只取其前缀部分进行匹配。例如,C-RP宣告的IPv6组播组范围为FF0E:0:1::/96,如果其前缀部分“FF0E:0:1::”能匹配上本命令所引用的ACL规则,就认为整个IPv6组播组范围“FF0E:0:1::/96”都通过了过滤。
该ACL规则中的source参数用来指定合法C-RP所服务的IPv6地址范围,destination参数用来指定该C-RP所服务的IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置C-RP策略,只允许2001::2/64范围内的设备充当C-RP,且只允许其为FF03::101/64范围内的IPv6组播组服务。
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ipv6 pim
[Sysname-pim6] crp-policy 3000
·     c-rp (IPv6 PIM view)
display ipv6 pim bsr-info命令用来显示IPv6 PIM-SM域中的BSR信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name:显示指定VPN实例的BSR信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的BSR信息。
# 显示公网实例IPv6 PIM-SM域中的BSR信息。
<Sysname> display ipv6 pim bsr-info
 Scope: non-scoped
     State: Accept Preferred
     Bootstrap timer: 00:01:44
     Elected BSR address: 12:12::1
       Priority: 64
       Hash mask length: 126
       Uptime: 00:21:56
 Scope: 5
     State: Accept Any
     Scope-zone expiry timer: 00:21:12
 Scope: 6
     State: Elected
     Bootstrap timer: 00:00:26
     Elected BSR address: 17:11::1
       Priority: 64
       Uptime: 02:53:37
     Candidate BSR address: 17:11::1
       Priority: 64
 Scope: 7
     State: Candidate
     Bootstrap timer: 00:01:56
     Elected BSR address: 61:37::1
       Priority: 64
       Uptime: 02:53:32
     Candidate BSR address: 17:12::1
       Priority: 64
 Scope: 8
     State: Pending
     Bootstrap timer: 00:00:07
     Candidate BSR address: 17:13::1
       Priority: 64
表1-1 display ipv6 pim bsr-info命令显示信息描述表
Scope
域状态
Bootstrap timer
BSR定时器
域老化定时器
Elected BSR address
当选BSR的地址
候选BSR的地址
Priority
BSR的优先级
Hash mask length
哈希掩码长度
Uptime
BSR已存在的时间
display ipv6 pim claimed-route命令用来显示IPv6 PIM所使用的路由信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的路由信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的路由信息。
ipv6-source-address:组播源的IPv6地址,显示到达指定组播源的路由信息。如果未指定本参数,将显示IPv6 PIM所使用的所有路由信息。
# 显示IPv6 PIM在公网实例中使用的所有路由信息。
<Sysname> display ipv6 pim claimed-route
 RPF-route selecting rule: longest-match
 Route/mask: 7:11::/64 (unicast (direct))
     RPF interface: Vlan-interface2, RPF neighbor: 8::2
     Total number of (S,G) or (*,G) dependent on this route entry: 4
     (7:11::10, ff1e::1)
     (7:11::10, ff1e::2)
     (7:11::10, ff1e::3)
     (*, ff1e::4)
 Route/mask: 7:12::/64 (unicast)
     RPF interface: Vlan-interface2, RPF neighbor: 8::3,
     Total number of (S,G) or (*,G) dependent on this route entry: 2
     (7:12::10, ff1e::1)
     (7:12::10, ff1e::2)
表1-2 display ipv6 pim claimed-route命令显示信息描述表
RPF路由的选择规则
Route/mask
路由项。括号内为路由类型,包括:
·     igp:单播路由(内部网关协议)
·     egp:单播路由(外部网关协议)
·     unicast (direct):单播路由(直连)
·     unicast:其它单播路由(如单播静态路由等)
·     mbgp:IPv6 MBGP路由
RPF interface
RPF接口的名称
RPF neighbor
RPF邻居的IPv6地址
on this route entry
基于此RPF路由的(S,G)或(*,G)个数及列表
display ipv6 pim c-rp命令用来显示IPv6 PIM-SM域中的C-RP信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name:显示指定VPN实例的C-RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的C-RP信息。
local:显示本地配置且生效的C-RP信息。如果未指定本参数,将显示所有学习到的C-RP信息。
只有当选的BSR上才会有学习到的C-RP信息,其它设备上只能查看到本地配置生效的C-RP信息。
# 显示公网实例中学习到的C-RP信息。
<Sysname> display ipv6 pim c-rp
 Scope: non-scoped
     Group/MaskLen: FF00::/8 [B]
       C-RP address             Priority  HoldTime  Uptime    Expires
       8:12::2 (local)          192       150       00:27:48  00:01:43
     Group/MaskLen: FF23::/92 Expires: 00:02:07
# 显示本地配置生效的C-RP信息。
<Sysname> display ipv6 pim c-rp local
 Candidate RP: 8:12::2(Loop1)
     Priority: 192
     HoldTime: 150
     Advertisement interval: 60
     Next advertisement scheduled at: 00:00:46
表1-3 display ipv6 pim c-rp命令显示信息描述表
Scope
Group/MaskLen
C-RP所服务的IPv6组播组
[B]
‌表示C-RP服务于IPv6双向PIM。如果未显示本字段,则表示服务于IPv6 PIM-SM
C-RP address
C-RP的IPv6地址,local表示本地地址
Priority
C-RP的优先级
HoldTime
C-RP的超时时间
Uptime
C-RP已存在的时间,w表示星期,d表示天,h表示小时
Expires
C-RP/组播组的超时剩余时间
Candidate RP
本地C-RP的IPv6地址
本地C-RP发送通告报文时间间隔
本地C-RP发送下一个通告报文的剩余时间
display ipv6 pim df-info命令用来显示IPv6双向PIM的DF信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] df-info [ ipv6-rp-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6双向PIM DF信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6双向PIM DF信息。
ipv6-rp-address:指定IPv6双向PIM的RP地址。
# 显示公网实例中IPv6双向PIM的DF信息。
<Sysname> display ipv6 pim df-info
RP address: 12::12
  Interface: Vlan-interface4
    State     : Win        DF preference: 10
    DF metric : 1562       DF uptime    : 00:07:15
    DF address: FE80::202:FF:FE00:9 (local)
  Interface: Tunnel2, FE80::20:12
    State     : Lose       DF preference: 0
    DF metric : 0          DF uptime    : 00:07:15
    DF address: FE80::20:12
表1-4 表1-3 display ipv6 pim df-info命令显示信息描述表
RP address
IPv6双向PIM的RP地址
接口名称
DF的选举状态:
·     Win:竞选DF成功
·     Lose:竞选DF落败
·     Offer:竞选DF的初始状态
·     Backoff:正在充当DF,但有更优的设备正在竞选DF
·     -:不参与DF竞选
DF preference
DF通告的路由优先级
DF metric
DF通告的路由度量值
DF uptime
DF已存在的时间
DF address
DF的IPv6地址,local表示本地地址
display ipv6 pim interface命令用来显示接口上的IPv6 PIM信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM信息。
interface-type interface-number:显示指定接口上的IPv6 PIM信息。如果未指定本参数,将显示所有接口上的IPv6 PIM信息。
# 显示公网实例所有接口上的IPv6 PIM概要信息。
<Sysname> display ipv6 pim interface
 Interface         NbrCnt  HelloInt  DR-Pri     DR-Address
 Vlan1             1       30        1          FE80::200:5EFF:FE04:8700
表1-5 display ipv6 pim interface命令显示信息描述表
接口名称
NbrCnt
IPv6 PIM邻居的数量
HelloInt
发送Hello报文的时间间隔
DR-Pri
竞选DR的优先级
DR-Address
DR的IPv6地址(链路本地地址)
# 显示公网实例接口Vlan-interface1上的IPv6 PIM详细信息。
<Sysname> display ipv6 pim interface vlan-interface 1 verbose
 Interface: Vlan-interface1, FE80::200:5EFF:FE04:8700
     PIM version: 2
     PIM mode: Sparse
     PIM DR: FE80::200:AFF:FE01:101
     PIM DR Priority (configured): 1
     PIM neighbors count: 1
     PIM hello interval: 30 s
     PIM LAN delay (negotiated): 500 ms
     PIM LAN delay (configured): 500 ms
     PIM override interval (negotiated): 2500 ms
     PIM override interval (configured): 2500 ms
     PIM neighbor tracking (negotiated): disabled
     PIM neighbor tracking (configured): disabled
     PIM generation ID: 0xF5712241
     PIM require generation ID: disabled
     PIM hello hold interval: 105 s
     PIM assert hold interval: 180 s
     PIM triggered hello delay: 5 s
     PIM J/P interval: 60 s
     PIM J/P hold interval: 210 s
     PIM BSR domain border: disabled
     PIM BFD: disabled
     PIM passive: disabled
     Number of routers on network not using DR priority: 0
     Number of routers on network not using LAN delay: 0
     Number of routers on network not using neighbor tracking: 2
表1-6 display ipv6 pim interface verbose命令显示信息描述表
接口名称与IPv6地址(链路本地地址)
PIM version
IPv6 PIM协议的版本号
PIM mode
IPv6 PIM协议的模式,是密集模式还是稀疏模式
PIM DR
DR的IPv6地址(链路本地地址)
竞选DR优先级的配置值
PIM neighbors count
IPv6 PIM邻居的总数
PIM hello interval
发送Hello报文的时间间隔
剪枝报文传输延迟的协商值
剪枝报文传输延迟的配置值
剪枝否决时间的协商值
剪枝否决时间的配置值
邻居跟踪开启与否的协商情况
邻居跟踪开启与否的配置情况
PIM generation ID
Generation_ID参数值
是否开启不接受无Generation ID的Hello报文
保持IPv6 PIM邻居的可达状态的时间
保持断言状态的时间
发送Hello报文的最大延迟时间
PIM J/P interval
发送加入/剪枝报文的时间间隔
加入/剪枝状态的保持时间
该接口是否配置了BSR的服务边界
PIM BFD
该接口是否开启了IPv6 PIM与BFD联动功能
PIM passive
该接口是否配置了IPv6 PIM消极模式
该接口所在网段上没有使用DR优先级字段的路由器数量
该接口所在网段上未使用LAN-delay字段的路由器数量
该接口所在网段上未开启邻居跟踪的路由器数量
display ipv6 pim neighbor命令用来显示IPv6 PIM邻居信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] neighbor [ ipv6-neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM邻居信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM邻居信息。
ipv6-neighbor-address:IPv6 PIM邻居的IPv6地址,显示指定IPv6 PIM邻居的信息。如果未指定本参数,将显示所有IPv6 PIM邻居的信息。
interface interface-type interface-number:接口类型和接口编号,显示指定接口上的IPv6 PIM邻居信息。如果未指定本参数,将显示所有接口上的IPv6 PIM邻居信息。
# 显示公网实例所有IPv6 PIM邻居的概要信息。
<Sysname> display ipv6 pim neighbor
 Total Number of Neighbors = 2
 Neighbor         Interface           Uptime   Expires  DR-Priority Mode
 FE80::A01:101:1  Vlan1               02:50:49 00:01:31 1           B
 FE80::A01:102:1  Vlan2               02:49:39 00:01:42 1
# 显示公网实例中IPv6地址为FE80::A01:101:1的IPv6 PIM邻居的详细信息。
<Sysname> display ipv6 pim neighbor fe80::a01:101:1 verbose
 Neighbor: FE80::A01:101:1
     Interface: Vlan-interface3
     Uptime: 00:00:10
     Expiry time: 00:00:30
     DR Priority: 1
     Generation ID: 0x2ACEFE15
     Holdtime: 105 s
     LAN delay: 500 ms
     Override interval: 2500 ms
     State refresh interval: 60 s
     Neighbor tracking: Disabled
     Bidirectional PIM: Disabled
     RPF proxy vector: Disabled
     Secondary address(es):
     1::1
表1-7 display ipv6 pim neighbor命令显示信息描述表
IPv6 PIM邻居的总数
Neighbor
IPv6 PIM邻居的IPv6主地址(链路本地地址)
IPv6 PIM邻居所在接口的名称
Uptime
IPv6 PIM邻居已存在的时间
Expires/Expiry time
IPv6 PIM邻居超时的剩余时间,never表示IPv6 PIM邻居永不超时,即永远可达
DR-Priority/DR Priority
IPv6 PIM邻居的优先级
Mode
‌IPv6 PIM邻居的模式,B表示IPv6双向PIM模式,如果该字段显示为空则表示非IPv6双向PIM模式
Generation ID
IPv6 PIM邻居的Generation ID(状态随机数)
Holdtime
IPv6 PIM邻居的生存时间,forever表示IPv6 PIM邻居永远存在,即永远可达
LAN delay
IPv6 PIM报文在共享网段中的传输延迟
Override interval
剪枝否决的时间间隔
状态刷新的时间间隔,只有当IPv6 PIM邻居工作在IPv6 PIM-DM模式下且具备状态刷新能力时才会显示本字段
Neighbor tracking
邻居跟踪功能是否开启
Bidirectional PIM
‌IPv6双向PIM是否使能
RPF proxy vector
IPv6 PIM邻居是否支持RPF代理向量功能(请参见“IP组播配置指导”中的“组播VPN”)
IPv6 PIM邻居的IPv6从地址(非链路本地地址)
display ipv6 pim routing-table命令用来显示IPv6 PIM路由表的内容。
display ipv6 pim [ vpn-instance vpn-instance-name ] routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number ] *
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 PIM路由项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6 PIM路由项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6 PIM路由项,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的IPv6 PIM路由项。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6 PIM路由项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
flags flag-value:IPv6 PIM标志,显示包含指定标志的IPv6 PIM路由项。如果未指定本参数,将显示包含所有标志的IPv6 PIM路由项。flag-value的取值及含义如下
·     act:表示已经有实际数据到达的IPv6 PIM路由项;
·     del:表示计划删除的IPv6 PIM路由项;
·     exprune:表示某些出接口被其它IPv6组播路由协议剪枝的IPv6 PIM路由项;
·     ext:表示包含了由其它IPv6组播路由协议提供出接口的IPv6 PIM路由项;
·     loc:表示在与IPv6组播源处于同一网段的设备上的IPv6 PIM路由项;
·     niif:表示未确定入接口的IPv6 PIM路由项;
·     nonbr:表示IPv6 PIM邻居查找失败的IPv6 PIM路由项;
·     rpt:表示向RP方向发送过(S,G)RPT位剪枝的IPv6 PIM路由项;
·     rq:表示Data-MDT切换接收端的IPv6 PIM路由项;
·     spt:表示SPT上的IPv6 PIM路由项;
·     sq:表示Data-MDT切换发起端的IPv6 PIM路由项;
·     swt:表示正处于向SPT切换过程中的IPv6 PIM路由项;
·     wc:表示带WC通配符的IPv6 PIM路由项。
fsm:显示有限状态机的详细信息。
incoming-interface interface-type interface-number:显示指定入接口的IPv6 PIM路由项。如果未指定本参数,将显示所有入接口的PIM路由项。
mode mode-type:IPv6 PIM模式,显示指定模式下的IPv6 PIM路由项。如果未指定本参数,将显示所有模式下的IPv6 PIM路由项。mode-type的取值及含义如下:
·     bidir:表示IPv6双向PIM模式;
·     dm:表示IPv6 PIM-DM模式;
·     sm:表示IPv6 PIM-SM模式;
·     ssm:表示IPv6 PIM-SSM模式。
outgoing-interface { exclude | include | match } interface-type interface-number:显示指定出接口的IPv6 PIM路由项。其中,exclude表示不包含指定接口;include表示包含指定接口;match表示包含且仅包含指定接口。如果未指定本参数,将显示所有出接口的IPv6 PIM路由项。
# 显示公网实例IPv6 PIM路由表的内容。
<Sysname> display ipv6 pim routing-table
 Total 0 (*, G) entries; 1 (S, G) entries
 (2001::2, FFE3::101)
     RP: FE80::A01:100:1
     Protocol: pim-sm, Flag: SPT LOC ACT
     UpTime: 02:54:43
     Upstream interface: Vlan-interface1
         Upstream neighbor: NULL
         RPF prime neighbor: NULL
     Downstream interface information:
         1: Vlan-interface2
             Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# 显示公网实例IPv6 PIM路由表的状态机信息。
<Sysname> display ipv6 pim routing-table fsm
 Abbreviations for FSM states:
     NI - no info, J - joined, NJ - not joined, P - pruned,
     NP - not pruned, PP - prune pending, W - winner, L - loser,
     F - forwarding, AP - ack pending, DR - designated router,
     NDR - non-designated router, RCV - downstream receivers
     RP: FE80::A01:100:1
     UpTime: 02:54:43
         Join/Prune FSM: [SPT: J] [RPT: NP]
         1: Vlan-interface2
             DR state: [DR]
             Join/Prune FSM: [NI]
             Assert FSM: [NI]
     FSM information for non-downstream interfaces: None
表1-8 display ipv6 pim routing-table命令显示信息描述表
IPv6 PIM路由表中(S,G)表项的总数与(*,G)表项的总数
NI - no info, J - joined, NJ - not joined, P – pruned
NP - not pruned, PP - prune pending, W - winner, L – loser
状态机的缩写:NI表示初始状态,J表示加入状态,P表示剪枝状态,NP表示未剪枝状态,PP表示剪枝未决状态,W表示断言当选,L表示断言落选,F表示转发状态,AP表示嫁接确认状态,DR表示指定路由器,NDR表示非指定路由器,RCV表示下游接收者
IPv6 PIM路由表中的(S,G)表项
RP
RP的地址
Protocol
IPv6 PIM的模式
Flag
IPv6 PIM路由表中(S,G)或(*,G)表项的标志:
·     ACT:表示已有实际数据到达
·     DEL:表示计划要删除
·     EXPRUNE:表示某些出接口被其它IPv6组播路由协议剪枝
·     EXT:表示包含了由其它IPv6组播路由协议提供的出接口
·     LOC:表示与IPv6组播源处于同一网段
·     NIIF:表示未确定入接口
·     NONBR:表示IPv6 PIM邻居查找失败
·     RPT:表示向RP方向发送过(S,G)RPT位剪枝
·     RQ:表示Data-MDT切换接收端的PIM路由项
·     SPT:表示在SPT上
·     SQ:表示Data-MDT切换发起端的PIM路由项
·     SWT:表示正在向SPT切换
·     WC:表示带WC通配符
Uptime
(S,G)或(*,G)表项已存在的时间
Upstream interface
(S,G)或(*,G)表项的入接口
Upstream neighbor
(S,G)或(*,G)表项的上游邻居
RPF prime neighbor
(S,G)或(*,G)表项的RPF邻居:
·     对(*,G)表项来说,当该路由器是RP时,(*,G)表项的RPF邻居是NULL
·     对(S,G)表项来说,当该路由器直连源时,(S,G)表项的RPF邻居是NULL
DR state
DR的状态
Join/Prune FSM
加入/剪枝状态机
Assert FSM
断言状态机
下游接口的信息,包括:
·     下游接口的总数
·     下游接口的名称
·     下游接口使用的协议类型
·     下游接口的存在时间
·     下游接口的超时时间
非下游接口的状态机信息
display ipv6 pim rp-info命令用来显示IPv6 PIM-SM域中的RP的信息。
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
vpn-instance vpn-instance-name:显示指定VPN实例的RP信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的RP信息。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组所对应的RP信息,取值范围为FFxy::/16(但不包括下列地址: FFx1::/16、FFx2::/16),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组对应的RP信息。
# 显示公网实例中IPv6组播组FF73:130:7:12::1所对应的RP信息。
<Sysname> display ipv6 pim rp-info ff73:130:7:12::1
 Embedded RP address is: 7:12::1
     Configured ACL: 2000
 BSR RP address is: 7:12::1
     Priority: 192
     HoldTime: 180
     Uptime: 03:01:10
     Expires: 00:02:30
 Static RP address is: 7:12::1
     Preferred: No
     Configured ACL: 2003
 RP mapping for this group is: 7:12::1 (local host)
 Anycast-RP 7:12::1 members:
     Member address           State
     1:1::1                   Active
     1:1::2                   Local
     1:2::1                   Remote
# 显示所有IPv6组播组对应的RP信息。
 IPv6 PIM-SM embedded RP information:
   Embedded RP ACL: 2000
       Group                    RP address
       FF73:230:8:12::          8:12::2
 BSR RP information:
   Scope: non-scoped
     Group/MaskLen: FF73:230:8:12::/64
       8:12::2 (local)          192       180       03:01:36  00:02:29
     Group/MaskLen: FF23::/92 [B]
       7:12::1 (local)          192       180       00:00:39  00:02:57
 Static RP information:
       RP address               ACL   Mode    Preferred
       3:3::1                   2000  pim-sm  No
       3:3::2                   2001  pim-sm  Yes
       3:3::3                   2002  pim-sm  No
       3:3::4                         pim-sm  No
       3:3::5                   2002  pim-sm  Yes
 Anycast-RP information:
       RP address               Member address           State
       3:3::1                   1:1::1 Active
       3:3::1                   1:1::2 Local
       3:3::1                   1:2::1                   Remote
表1-9 display ipv6 pim rp-info命令显示信息描述表
嵌入式RP的IPv6地址
IPv6 PIM-SM Embedded RP information
嵌入式RP的信息
Embedded RP ACL
嵌入式RP关联的ACL
Group
嵌入式RP对应的IPv6组播组
BSR RP address is
RP的IPv6地址
BSR RP information
BSR RP信息
Scope
Group/MaskLen
RP所服务的IPv6组播组
[B]
‌表示RP服务于IPv6双向PIM。如果不显示该字段,则表示RP服务于IPv6 PIM-SM
RP address
Priority
RP的优先级
HoldTime
RP的超时时间
Uptime
RP已存在的时间
Expires
RP超时的剩余时间
静态RP信息
Static RP address is/RP address
静态RP的IPv6地址
Preferred
是否指定了静态RP优先
Configured ACL/ACL
配置的RP所关联的ACL
Mode
为IPv6 PIM-SM服务还是为IPv6双向PIM服务
服务于当前组播组的RP的IPv6地址
Anycast-RP 7:12::1的成员
Member address
Anycast-RP成员的IPv6地址
Anycast-RP成员地址的来源:
·     Active:表示本端激活接口的地址
·     Local:表示本端未激活接口的地址
·     Remote:表示远端的地址
Anycast-RP信息
display ipv6 pim statistics命令用来显示IPv6 PIM协议报文的统计信息。
# 显示IPv6 PIM协议报文的统计信息。
<Sysname> display ipv6 pim statistics
 Received PIM packets: 3295
 Sent PIM packets    : 5975
                Valid       Invalid        Succeeded   Failed
     Hello    : 3128        0              4333        0
     Reg      : 14          0              0           0
     Reg-stop : 0           0              0           0
     JP       : 151         0              561         0
     BSM      : 0           0              1081        0
     Assert   : 0           0              0           0
     Graft    : 0           0              0           0
     Graft-ACK: 0           0              0           0
     C-RP     : 0           0              0           0
     SRM      : 0           0              0           0
     DF       : 0           0              0           0
     AutoRP   : 0           0              0           0
表1-10 display ipv6 pim statistics命令显示信息描述表
收到的IPv6 PIM协议报文总数
Sent PIM packets
发出的IPv6 PIM协议报文总数
Valid
收到的合法IPv6 PIM协议报文数量
Invalid
收到的非法IPv6 PIM协议报文数量
Succeeded
发送成功的IPv6 PIM协议报文数量
Failed
发送失败的IPv6 PIM协议报文数量
Hello
Hello报文统计
Reg
注册报文统计
Reg-stop
注册停止报文统计
JP
加入/剪枝报文统计
BSM
自举报文统计
Assert
断言报文统计
Graft
嫁接报文统计
Graft-ACK
嫁接应答报文统计
C-RP
C-RP报文统计
SRM
状态刷新报文统计
DF
指定转发者报文统计
AutoRP
自动RP报文统计
1.1.20  dscp
dscp命令用来配置设备发送IPv6 PIM协议报文的DSCP优先级。
undo dscp命令用来恢复缺省情况。
dscp dscp-value
undo dscp
设备发送IPv6 PIM协议报文的DSCP优先级为48。
IPv6 PIM视图
dscp-value:DSCP值,取值范围为0~63。
DSCP(Differentiated Services Code Point,差分服务编码点)携带在IP报文中的ToS字段,用来体现报文自身的优先等级,决定报文传输的优先程度。DSCP优先级的取值越大,报文的优先级越高。
# 配置设备发送IPv6 PIM报文的DSCP优先级为63。
[Sysname] ipv6 pim
[Sysname-pim6] dscp 63
1.1.21  embedded-rp
embedded-rp命令用来开启嵌入式RP功能。
undo embedded-rp命令用来关闭嵌入式RP功能。
embedded-rp [ ipv6-acl-number ]
undo embedded-rp
嵌入式RP功能处于关闭状态。
IPv6 PIM视图
嵌入式RP(Embedded RP)是IPv6 PIM中特有的RP发现机制,该机制使用内嵌RP地址的IPv6组播地址,使得设备可以直接从该地址中解析出RP的地址。
只有组地址在为FF7x::/12或FFFx::/12,且符合格式要求的IPv6组播组支持嵌入式RP功能。有关嵌入式RP支持的组地址格式要求的详细介绍,请参见“IP组播”中的“IPv6 PIM”。
执行本命令时,如果未指定ipv6-acl-number参数,则对该范围内的所有IPv6组播组均开启嵌入式RP功能;如果指定了ipv6-acl-number参数,则只有在该范围内且通过了ACL检查的IPv6组播组才能开启嵌入式RP功能。
# 为组地址在FF7E:140:20::101/64范围内的IPv6组播组开启嵌入式RP功能。
[Sysname-acl-ipv6-basic-2000] rule permit source ff7e:140:20::101 64
[Sysname] ipv6 pim
[Sysname-pim6] embedded-rp 2000
hello-option dr-priority命令用来全局配置竞选DR的优先级。
undo hello-option dr-priority命令用来恢复缺省情况。
竞选DR的优先级为1。
IPv6 PIM视图
priority:指定竞选DR的优先级,取值范围为0~4294967295。该数值越大,优先级越高。
本配置既可在IPv6 PIM视图又可在接口视图下进行,前者对所有接口都生效,而后者只对当前接口生效,但后者的配置优先级较高。
# 在公网实例中全局配置竞选DR的优先级为3。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option dr-priority 3
·     ipv6 pim hello-option dr-priority
hello-option holdtime命令用来全局配置保持IPv6 PIM邻居可达状态的时间。
undo hello-option holdtime命令用来恢复缺省情况。
hello-option holdtime time
保持IPv6 PIM邻居可达状态的时间为105秒。
IPv6 PIM视图
time:指定保持IPv6 PIM邻居可达状态的超时时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在公网实例中全局配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option holdtime 120
·     ipv6 pim hello-option holdtime
hello-option lan-delay命令用来全局配置IPv6 PIM报文在共享网段中的传输延迟。
undo hello-option lan-delay命令用来恢复缺省情况。
hello-option lan-delay delay
IPv6 PIM报文在共享网段中的传输延迟为500毫秒。
IPv6 PIM视图
delay:指定IPv6 PIM报文在共享网段中的传输延迟,取值范围为1~32767,单位为毫秒。
# 在公网实例中全局配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option lan-delay 200
·     hello-option override-interval (IPv6 PIM view)
·     ipv6 pim hello-option lan-delay
·     ipv6 pim hello-option override-interval
hello-option neighbor-tracking命令用来全局开启邻居跟踪功能。
undo hello-option neighbor-tracking命令用来全局关闭邻居跟踪功能。
邻居跟踪功能处于关闭状态。
IPv6 PIM视图
# 在公网实例中全局开启邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option neighbor-tracking
·     ipv6 pim hello-option neighbor-tracking
hello-option override-interval命令用来全局配置剪枝否决时间。
undo hello-option override-interval命令用来恢复缺省情况。
剪枝否决时间为2500毫秒。
IPv6 PIM视图
interval:指定剪枝的否决时间,取值范围为1~65535,单位为毫秒。
# 在公网实例中全局配置剪枝否决时间为2000毫秒。
[Sysname] ipv6 pim
[Sysname-pim6] hello-option override-interval 2000
·     hello-option lan-delay (IPv6 PIM view)
holdtime join-prune命令用来全局配置加入/剪枝状态的保持时间。
undo holdtime join-prune命令用来恢复缺省情况。
holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
IPv6 PIM视图
time:指定加入/剪枝状态的保持时间,取值范围为1~65535,单位为秒。
IPv6 PIM接口向上游邻居发送加入/剪枝报文的时间间隔必须小于加入/剪枝状态的保持时间,以免上游邻居老化超时。
# 在公网实例中全局配置加入/剪枝状态的保持时间为280秒。
[Sysname] ipv6 pim
[Sysname-pim6] holdtime join-prune 280
·     ipv6 pim holdtime join-prune
·     timer join-prune (IPv6 PIM view)
1.1.28  ipv6 pim
ipv6 pim命令用来进入IPv6 PIM视图。
undo ipv6 pim命令用来清除IPv6 PIM视图下的所有配置。
undo ipv6 pim [ vpn-instance vpn-instance-name ]
# 先使能公网实例中的IPv6组播路由,再进入公网实例的IPv6 PIM视图。
[Sysname] ipv6 pim
[Sysname-pim6]
# 先使能VPN实例mvpn中的IPv6组播路由,再进入该VPN实例的IPv6 PIM视图。
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn] quit
[Sysname] ipv6 pim vpn-instance mvpn
[Sysname-pim6-mvpn]
ipv6 pim bfd enable命令用来开启IPv6 PIM与BFD联动功能。
undo ipv6 pim bfd enable命令用来关闭IPv6 PIM与BFD联动功能。
ipv6 pim bfd enable
IPv6 PIM与BFD联动功能处于关闭状态。
只有在接口上先使能了IPv6 PIM-DM或IPv6 PIM-SM,本命令才能生效。
# 使能公网实例中的IPv6组播路由,在接口Vlan-interface100上使能IPv6 PIM-DM,并开启IPv6 PIM与BFD联动功能。
[Sysname-Vlan-interface100] ipv6 pim dm
[Sysname-Vlan-interface100] ipv6 pim bfd enable
·     ipv6 pim dm
·     ipv6 pim sm
ipv6 pim bsr-boundary命令用来配置BSR的服务边界,即IPv6 PIM-SM域的边界。
undo ipv6 pim bsr-boundary命令用来恢复缺省情况。
不存在BSR的服务边界。
# 配置接口Vlan-interface100为BSR的服务边界。
[Sysname-Vlan-interface100] ipv6 pim bsr-boundary
·     ipv6 multicast boundary(IP组播命令参考/IPv6组播路由与转发)
1.1.31  ipv6 pim dm
ipv6 pim dm命令用来使能IPv6 PIM-DM。
undo ipv6 pim dm命令用来关闭IPv6 PIM-DM。
ipv6 pim dm
undo ipv6 pim dm
IPv6 PIM-DM处于关闭状态。
# 使能公网实例中的IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-DM。
ipv6 pim hello-option dr-priority命令用来在接口上配置竞选DR的优先级。
undo ipv6 pim hello-option dr-priority命令用来恢复缺省情况。
ipv6 pim hello-option dr-priority priority
竞选DR的优先级为1。
# 在接口Vlan-interface100上配置竞选DR的优先级为3。
[Sysname-Vlan-interface100] ipv6 pim hello-option dr-priority 3
·     hello-option dr-priority (IPv6 PIM view)
ipv6 pim hello-option holdtime命令用来在接口上配置保持IPv6 PIM邻居的可达状态的时间。
undo ipv6 pim hello-option holdtime命令用来恢复缺省情况。
ipv6 pim hello-option holdtime time
time:指定保持IPv6 PIM邻居可达状态的时间,取值范围为1~65535,单位为秒。如果指定为65535秒,则表示PIM邻居永远可达。
# 在接口Vlan-interface100上配置保持IPv6 PIM邻居可达状态的时间为120秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option holdtime 120
·     hello-option holdtime (IPv6 PIM view)
ipv6 pim hello-option lan-delay命令用来在接口上配置IPv6 PIM报文在共享网段中的传输延迟。
undo ipv6 pim hello-option lan-delay命令用来恢复缺省情况。
ipv6 pim hello-option lan-delay delay
# 在接口Vlan-interface100上配置IPv6 PIM报文在共享网段中的传输延迟为200毫秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option lan-delay 200
ipv6 pim hello-option neighbor-tracking命令用来在接口上开启邻居跟踪功能。
ipv6 pim hello-option neighbor-tracking disable命令用来在全局开启了邻居跟踪功能的情况下,关闭当前接口上的邻居跟踪功能。
undo ipv6 pim hello-option neighbor-tracking命令用来取消接口上的邻居跟踪功能配置,使得接口与全局配置保持一致。
接口上的邻居跟踪功能处于关闭状态。
# 在接口Vlan-interface100上开启邻居跟踪功能。
[Sysname-Vlan-interface100] ipv6 pim hello-option neighbor-tracking
# 在公网实例全局开启了邻居跟踪功能的情况下,关闭接口Vlan-interface100上的邻居跟踪功能。
[Sysname] ipv6 pim
[Sysname-pim6] quit
[Sysname-Vlan-interface100] ipv6 pim hello-option neighbor-tracking disable
·     hello-option neighbor-tracking (IPv6 PIM view)
ipv6 pim hello-option override-interval命令用来在接口上配置剪枝否决时间。
undo ipv6 pim hello-option override-interval命令用来恢复缺省情况。
ipv6 pim hello-option override-interval interval
剪枝否决时间为2500毫秒。
# 在接口Vlan-interface100上配置剪枝否决时间为2000毫秒。
[Sysname-Vlan-interface100] ipv6 pim hello-option override-interval 2000
ipv6 pim holdtime join-prune命令用来在接口上配置加入/剪枝状态的保持时间。
undo ipv6 pim holdtime join-prune命令用来恢复缺省情况。
ipv6 pim holdtime join-prune time
加入/剪枝状态的保持时间为210秒。
# 在接口Vlan-interface100上配置加入/剪枝状态的保持时间为280秒。
[Sysname-Vlan-interface100] ipv6 pim holdtime join-prune 280
·     holdtime join-prune (IPv6 PIM view)
·     ipv6 pim timer join-prune
ipv6 pim neighbor-policy命令用来配置合法Hello报文的源地址范围。
undo ipv6 pim neighbor-policy命令用来恢复缺省情况。
ipv6 pim neighbor-policy ipv6-acl-number
Hello报文的源地址范围不受限制,即认为所有收到的Hello报文都是合法的。
配置合法Hello报文的源地址范围可以防止Hello报文欺骗。
该ACL规则中的source参数用来指定合法Hello报文的源组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
若ACL中指定了vpn-instance参数则该规则不生效。
# 在接口Vlan-interface100上配置合法Hello报文的源地址范围,只允许与来自网段FE80:101::101/64中的设备建立IPv6 PIM邻居关系。
[Sysname-acl-ipv6-basic-2000] rule permit source fe80:101::101 64
[Sysname-Vlan-interface100] ipv6 pim neighbor-policy 2000
ipv6 pim non-stop-routing命令用来开启IPv6 PIM协议的NSR功能。
undo ipv6 pim non-stop-routing命令用来关闭IPv6 PIM协议的NSR功能。
IPv6 PIM协议的NSR功能处于关闭状态。
# 开启IPv6 PIM NSR功能。
[Sysname] ipv6 pim non-stop-routing
ipv6 pim passive命令用来在接口上开启IPv6 PIM消极模式。
undo ipv6 pim passive命令用来在接口上关闭IPv6 PIM消极模式。
ipv6 pim passive
接口上的IPv6 PIM消极模式处于关闭状态。
# 使能公网实例中的IPv6组播路由,在接口Vlan-interface100上使能IPv6 PIM-DM,并开启IPv6 PIM消极模式。
[Sysname-Vlan-interface100] ipv6 pim passive
ipv6 pim require-genid命令用来配置拒绝无Generation ID的Hello报文。
undo ipv6 pim require-genid命令用来恢复缺省情况。
接受无Generation ID的Hello报文。
# 配置接口Vlan-interface100拒绝无Generation ID的Hello报文。
[Sysname-Vlan-interface100] ipv6 pim require-genid
1.1.42  ipv6 pim sm
ipv6 pim sm命令用来使能IPv6 PIM-SM。
undo ipv6 pim sm命令用来关闭IPv6 PIM-SM。
ipv6 pim sm
undo ipv6 pim sm
IPv6 PIM-SM处于关闭状态。
# 使能公网实例中的IPv6组播路由,并在接口Vlan-interface100上使能IPv6 PIM-SM。
[Sysname-Vlan-interface100] ipv6 pim sm
ipv6 pim state-refresh-capable命令用来开启状态刷新能力。
undo ipv6 pim state-refresh-capable命令用来关闭状态刷新能力。
状态刷新能力处于开启状态。
# 在接口Vlan-interface100上关闭状态刷新能力。
[Sysname-Vlan-interface100] undo ipv6 pim state-refresh-capable
·     state-refresh-hoplimit (IPv6 PIM view)
·     state-refresh-interval (IPv6 PIM view)
·     state-refresh-rate-limit (IPv6 PIM view)
ipv6 pim timer graft-retry命令用来配置嫁接报文的重传时间。
undo ipv6 pim timer graft-retry命令用来恢复缺省情况。
ipv6 pim timer graft-retry interval
嫁接报文的重传时间为3秒。
interval:指定嫁接报文的重传时间,取值范围为1~65535,单位为秒。
# 在接口Vlan-interface100上配置嫁接报文的重传时间为80秒。
[Sysname-Vlan-interface100] ipv6 pim timer graft-retry 80
ipv6 pim timer hello命令用来在接口上配置发送Hello报文的时间间隔。
undo ipv6 pim timer hello命令用来恢复缺省情况。
ipv6 pim timer hello interval
发送Hello报文的时间间隔为30秒。
interval:指定发送Hello报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送Hello报文。
# 在接口Vlan-interface100上配置发送Hello报文的时间间隔为40秒。
[Sysname-Vlan-interface100] ipv6 pim timer hello 40
·     timer hello (IPv6 PIM view)
ipv6 pim timer join-prune命令用来在接口上配置发送加入/剪枝报文的时间间隔。
undo ipv6 pim timer join-prune命令用来恢复缺省情况。
ipv6 pim timer join-prune interval
发送加入/剪枝报文的时间间隔为60秒。
interval:指定发送加入/剪枝报文的时间间隔,取值范围为0~18000,单位为秒。0表示无穷大,即永不发送加入/剪枝报文。
本命令不会立即生效,新配置的发送间隔将在当前发送间隔完成后生效。
# 在接口Vlan-interface100上配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname-Vlan-interface100] ipv6 pim timer join-prune 80
ipv6 pim triggered-hello-delay命令用来配置触发Hello报文的最大延迟时间。
undo ipv6 pim triggered-hello-delay命令用来恢复缺省情况。
ipv6 pim triggered-hello-delay delay
触发Hello报文的最大延迟时间为5秒。
delay:指定触发Hello报文的最大延迟时间,取值范围为1~60,单位为秒。
# 在接口Vlan-interface100上配置触发Hello报文的最大延迟时间为3秒。
[Sysname-Vlan-interface100] ipv6 pim triggered-hello-delay 3
jp-pkt-size命令用来配置加入/剪枝报文的最大长度。
undo jp-pkt-size命令用来恢复缺省情况。
jp-pkt-size size
undo jp-pkt-size
加入/剪枝报文的最大长度为1200字节。
IPv6 PIM视图
# 在公网实例中配置加入/剪枝报文的最大长度为1500字节。
[Sysname] ipv6 pim
[Sysname-pim6] jp-pkt-size 1500
register-policy命令用来配置注册报文的过滤策略。
undo register-policy命令用来恢复缺省情况。
register-policy ipv6-acl-number
不存在注册报文的过滤策略。
IPv6 PIM视图
该ACL规则中的source参数用来指定注册报文中的IPv6组播源地址范围,destination参数用来指定IPv6组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
只有与该ACL规则中的permit语句匹配的注册报文才会被RP接受。
# 在公网实例中配置RP上对注册报文的过滤策略,只接收来自3:1::/64网段的IPv6组播源发向FF0E:13::/64网段的IPv6组播组的注册报文。
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] ipv6 pim
[Sysname-pim6] register-policy 3000
register-suppression-timeout命令用来配置注册抑制时间。
undo register-suppression-timeout命令用来恢复缺省情况。
注册抑制时间为60秒。
IPv6 PIM视图
interval:指定注册抑制时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置注册抑制时间为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] register-suppression-timeout 70
register-whole-checksum命令用来配置根据注册报文的全部内容来计算校验和。
undo register-whole-checksum命令用来恢复缺省情况。
仅根据注册报文头来计算校验和。
IPv6 PIM视图
# 在公网实例中配置根据注册报文的全部内容来计算校验和。
[Sysname] ipv6 pim
[Sysname-pim6] register-whole-checksum
snmp-agent trap enable pim6命令用来开启IPv6 PIM的告警功能。
undo snmp-agent trap enable pim6命令用来关闭IPv6 PIM的告警功能。
snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
undo snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
IPv6 PIM的告警功能处于开启状态。
candidate-bsr-win-election:表示C-BSR成功当选BSR的告警信息。
elected-bsr-lost-election:表示原BSR在新的选举中失败的告警信息。
neighbor-loss:表示邻居丢失的告警信息。
如果未指定任何可选参数,表示开启或关闭IPv6 PIM的全部告警功能。
开启了IPv6 PIM的告警功能之后,IPv6 PIM会生成告警信息,以向网管软件报告本模块的重要事件。该信息将发送至SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭IPv6 PIM的全部告警功能。
[Sysname] undo snmp-agent trap enable pim6
source-lifetime命令用来配置IPv6组播源的生存时间。
undo source-lifetime命令用来恢复缺省情况。
source-lifetime time
IPv6组播源的生存时间为210秒。
IPv6 PIM视图
time:指定IPv6组播源的生存时间,取值范围为0~31536000,单位为秒。0表示无穷大,即IPv6组播源永不老化。
# 在公网实例中配置IPv6组播源的生存时间为200秒。
[Sysname] ipv6 pim
[Sysname-pim6] source-lifetime 200
source-policy命令用来配置IPv6组播数据过滤器。
undo source-policy命令用来恢复缺省情况。
source-policy ipv6-acl-number
undo source-policy
不存在IPv6组播数据过滤器,不对组播数据进行过滤。
IPv6 PIM视图
ipv6-acl-number:指定IPv6基本或高级ACL的编号,取值范围为2000~3999。
对于IPv6基本ACL,该ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
对于IPv6高级ACL,该ACL规则中的source参数用来指定IPv6组播数据报文的源地址范围,destination参数用来指定组播组地址范围,并且该规则中除sourcedestinationfragmenttime-range以外的其它可选参数都将被忽略。
# 在公网实例中配置接收IPv6组播源3121::1的IPv6组播数据报文,丢弃IPv6组播源3121::2的IPv6组播数据报文。
[Sysname-acl-ipv6-basic-2000] rule permit source 3121::1 128
[Sysname-acl-ipv6-basic-2000] rule deny source 3121::2 128
[Sysname] ipv6 pim
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold命令用来配置发起SPT切换的条件。
undo spt-switch-threshold命令用来删除指定的发起SPT切换的条件。
spt-switch-threshold { immediacy | infinity } [ group-policy ipv6-acl-number ]
undo spt-switch-threshold [ immediacy | infinity ] [ group-policy ipv6-acl-number ]
设备收到第一个IPv6组播数据包后便立即向SPT切换。
IPv6 PIM视图
immediacy:表示立即发起SPT切换。
infinity:表示永不发起SPT切换。
group-policy ipv6-acl-number:表示组策略列表中的一项,与该组策略匹配的IPv6组播组将应用本配置。ipv6-acl-number表示IPv6基本ACL的编号,取值范围为2000~2999。如果未指定本参数指定的ACL不存在或ACL中未配置有效规则,则本配置将应用于所有IPv6组播组。
该ACL规则中的source参数用来指定IPv6组播组地址范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
由于某些设备无法将IPv6组播报文封装在注册报文中发给RP,因此在可能成为RP的设备上不建议配置永不发起SPT切换,以免导致IPv6组播报文转发失败。
# 在接收者侧DR的公网实例中配置永不发起SPT切换。
[Sysname] ipv6 pim
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy命令用来配置IPv6 SSM组播组的范围。
undo ssm-policy命令用来恢复缺省情况。
ssm-policy ipv6-acl-number
undo ssm-policy
IPv6 SSM组播组的范围为FF3x::/32,其中x表示任意合法的scope。
IPv6 PIM视图
通过本命令可以定义允许或拒绝的IPv6组播组的地址范围:如果匹配通过,则组播运行模式为IPv6 PIM-SSM,否则为IPv6 PIM-SM。
该ACL规则中的source参数用来指定IPv6 SSM组播组范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
# 配置IPv6 SSM组播组的范围为FF3E:0:8192::/96。
[Sysname-acl-ipv6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] ipv6 pim
[Sysname-pim6] ssm-policy 2000
state-refresh-hoplimit命令用来配置状态刷新报文的Hop Limit值。
undo state-refresh-hoplimit命令用来恢复缺省情况。
state-refresh-hoplimit hoplimit-value
状态刷新报文的Hop Limit值为255。
IPv6 PIM视图
hoplimit-value:指定状态刷新报文的Hop Limit值,取值范围为1~255。
# 在公网实例中配置状态刷新报文的Hop Limit值为45。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-hoplimit 45
·     ipv6 pim state-refresh-capable
state-refresh-interval命令用来配置发送状态刷新报文的时间间隔。
undo state-refresh-interval命令用来恢复缺省情况。
发送状态刷新报文的时间间隔为60秒。
IPv6 PIM视图
interval:指定发送状态刷新报文的时间间隔,取值范围为1~255,单位为秒。
# 在公网实例中配置发送状态刷新报文的时间间隔为70秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-interval 70
state-refresh-rate-limit命令用来配置接收新状态刷新报文的等待时间。
undo state-refresh-rate-limit命令用来恢复缺省情况。
state-refresh-rate-limit time
接收新状态刷新报文的等待时间为30秒。
IPv6 PIM视图
time:指定接收新状态刷新报文的等待时间,取值范围为1~65535,单位为秒。
# 在公网实例中配置接收新状态刷新报文的等待时间为45秒。
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-rate-limit 45
static-rp命令用来配置静态RP。
undo static-rp命令用来删除静态RP。
static-rp ipv6-rp-address [ ipv6-acl-number | bidir | preferred ] *
undo static-rp ipv6-rp-address
不存在静态RP。
IPv6 PIM视图
ipv6-rp-address:指定静态RP的IPv6地址。该地址必须是合法的IPv6全球单播地址。
ipv6-acl-number:指定基本IPv6基本ACL的编号,取值范围为2000~2999。如果指定了本参数,该静态RP将只为能够通过该过滤规则的IPv6组播组服务;如果未指定本参数、指定的ACL不存在或ACL中未配置有效规则,则该静态RP将为所有IPv6组播组服务。
bidir:指定该静态RP服务于IPv6双向PIM。如果未指定本参数,该静态RP将服务于IPv6 PIM-SM。
preferred:表示当网络中同时存在动态RP和静态RP时,优先选择静态RP,只有当静态RP失效时,动态RP才能生效。如果未指定本参数,则表示优先选择动态RP,只有当未配置动态RP或动态RP失效时,静态RP才能生效。
作为静态RP的接口不必使能IPv6 PIM。
该ACL规则中的source参数用来指定静态RP所服务的IPv6组播组范围,并且该规则中除sourcefragmenttime-range以外的其它可选参数都将被忽略。
当某个静态RP引用的ACL规则发生变化时,需要为所有IPv6组播组重新选举RP。
重复执行本命令,可以配置多个静态RP。但是,如果配置时所指定的静态RP地址或ACL规则相同,最后一次执行的命令生效;如果存在多个静态RP服务于同一组播组的情况,则选择IPv6地址最大的静态RP为该组服务。
# 在公网实例中配置IPv6地址为2001::2的接口为静态RP,为IPv6组播组FF03::101/64提供服务,并优先选择静态RP。
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source ff03::101 64
[Sysname] ipv6 pim
[Sysname-pim6] static-rp 2001::2 2001 preferred
timer hello命令用来全局配置发送Hello报文的时间间隔。
undo timer hello命令用来恢复缺省情况。
undo timer hello
发送Hello报文的时间间隔为30秒。
IPv6 PIM视图
# 在公网实例中全局配置发送Hello报文的时间间隔为40秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer hello 40
·     ipv6 pim timer hello
timer join-prune命令用来全局配置发送加入/剪枝报文的时间间隔。
undo timer join-prune命令用来恢复缺省情况。
发送加入/剪枝报文的时间间隔为60秒。
IPv6 PIM视图
# 在公网实例中全局配置发送加入/剪枝报文的时间间隔为80秒。
[Sysname] ipv6 pim
[Sysname-pim6] timer join-prune 80
