01-基础配置命令参考
09-设备管理命令
本章节下载 09-设备管理命令  (445.88 KB)
09-设备管理命令
  录
1 设备管理
1.1 设备管理配置命令
1.1.1 clock datetime
1.1.2 clock protocol
1.1.3 clock summer-time
1.1.4 clock timezone
1.1.5 command
1.1.6 copyright-info enable
1.1.7 diagnostic monitor enable test forwardmonitor
1.1.8 diagnostic start test
1.1.9 display alarm
1.1.10 display clock
1.1.11 display copyright
1.1.12 display cpu-usage
1.1.13 display cpu-usage configuration
1.1.14 display cpu-usage history
1.1.15 display device
1.1.16 display device manuinfo
1.1.17 display device manuinfo fan
1.1.18 display device manuinfo power
1.1.19 display diagnostic content
1.1.20 display diagnostic-information
1.1.21 display diagnostic result
1.1.22 display environment
1.1.23 display exception filepath
1.1.24 display fan
1.1.25 display hardware-resource
1.1.26 display memory
1.1.27 display memory-threshold
1.1.28 display power
1.1.29 display scheduler job
1.1.30 display scheduler logfile
1.1.31 display scheduler reboot
1.1.32 display scheduler schedule
1.1.33 display system stable state
1.1.34 display system-working-mode
1.1.35 display transceiver alarm
1.1.36 display transceiver diagnosis
1.1.37 display transceiver interface
1.1.38 display transceiver itu-channel interface
1.1.39 display transceiver manuinfo
1.1.40 display version
1.1.41 display version-update-record
1.1.42 exception filepath
1.1.43 hardware-resource tcam
1.1.44 header
1.1.45 itu-channel
1.1.46 job
1.1.47 memory-threshold
1.1.48 memory-threshold usage
1.1.49 monitor cpu-usage enable
1.1.50 monitor cpu-usage interval
1.1.51 monitor cpu-usage threshold
1.1.52 password-recovery enable
1.1.53 process core
1.1.54 reboot
1.1.55 reset scheduler logfile
1.1.56 reset version-update-record
1.1.57 scheduler job
1.1.58 scheduler logfile size
1.1.59 scheduler reboot at
1.1.60 scheduler reboot delay
1.1.61 scheduler schedule
1.1.62 shutdown-interval
1.1.63 switch-fabric isolate
1.1.64 sysname
1.1.65 system-working-mode
1.1.66 temperature-limit
1.1.67 time at
1.1.68 time once
1.1.69 time repeating
1.1.70 user-role
1 设备管理
1.1  设备管理配置命令
clock datetime命令用来设置设备的UTC(Coordinated Universal Time,国际协调时间)时间。
clock datetime time date
设备的UTC时间为出厂时间。
time:设置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。比如将time参数设置为0表示零点。
date:设置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将系统时间配置准确。
# 设置设备的UTC时间为2015年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2015
# 设置设备的UTC时间为2015年1月1日8时10分。
<Sysname> clock datetime 8:10 2015/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol命令用来配置获取系统时间的方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | ntp mdc mdc-id }
undo clock protocol
由缺省MDC通过NTP协议获取系统时间。
none:表示通过本地时钟源获取系统时间。配置该参数后,用户可通过clock datetimeclock timezoneclock summer-time命令修改系统时间。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取系统时间。配置该参数后,用户不能通过命令行修改系统时间,需要配置NTP的相关参数才能获取到时钟。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号。
所有MDC共用一个时钟源,系统时间相同。这个共用时钟源可以是:
·     本地时钟源,设备上的晶体振荡器产生的时钟信号。
·     网络时钟源,通过协议从其它网络设备上获取的时钟信号。设备根据用户的配置,从指定的MDC,使用指定的协议获取时间后,同步给其它MDC作为系统时间。
多次执行本命令,最后一次执行的命令生效。
# 指定设备通过NTP协议获取系统时间。
[Sysname] clock protocol ntp
clock summer-time命令用来设置夏令时。
undo clock summer-time命令用来恢复缺省情况。
没有配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
·     直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
·     分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:JanuaryFebruaryMarchAprilMayJuneJulyAugustSeptemberOctoberNovemberDecember;然后输入开始的星期,用当月的第几个星期表示,取值如下:firstsecondthirdfourthfifthlast;最后输入起始日,取值为SundayMondayTuesdayWednesdayThursdayFridaySaturday
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
·     直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将所有网络设备的夏令时配置保持一致。
# 设置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     display clock
·     clock protocol
·     clock timezone
clock timezone命令用来对本地时区进行设置。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
本地时区采用UTC时区。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要设置成整分,则可以不输入秒;如果要设置成整点,则可以不输入分和秒。
命令行配置的系统时间由配置的UTC时间、本地时区和夏令时运算之后联合决定,通过display clock命令可以查看。为了保证与其它设备协调工作,为了更好的监控和维护设备,请将所有网络设备的时区和当地地理时区保持一致。
# 设置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock protocol
·     clock summer-time
·     display clock
1.1.5  command
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
需要注意的是,通过command指定的命令行必须是设备上可成功执行的命令行,不包括telnetftpssh2monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
# 为Job(假设名称为backupconfig)分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
·     scheduler job
copyright-info enable命令用来使能显示版权信息。
undo copyright-info enable命令用来禁止显示版权信息。
显示版权信息处于开启状态。
# 使能显示版权信息。
[Sysname] copyright-info enable
·     使用Telnet方式登录设备,会显示如下信息:
<Sysname>
·     如果当前已经使用Console口登录设备了,再退出用户视图,由于设备会自动尝试再次登录,会显示如下信息:
User interface aux0 is available.
Press ENTER to get started.
# 禁止显示版权信息。
[Sysname] undo copyright-info enable
<Sysname>
仅Release 1152及以上版本支持本命令。
diagnostic monitor enable test forwardmonitor命令用来开启ForwardMonitor诊断。
undo diagnostic monitor enable test forwardmonitor命令用来关闭ForwardMonitor诊断。
独立运行模式:
diagnostic monitor enable slot slot-number-list test forwardmonitor
undo diagnostic monitor enable slot slot-number-list test forwardmonitor
IRF模式:
diagnostic monitor enable chassis chassis-number slot slot-number-list test forwardmonitor
undo diagnostic monitor enable chassis chassis-number slot slot-number-list test forwardmonitor
ForwardMonitor诊断处于关闭状态。
chassis chassis-number:表示设备在IRF中的成员编号。(仅IRF模式支持)
slot slot-number-list:槽位号列表。表示方式为slot-number-list = { slot-number [ to slot-number ] }&<1-7>。其中,slot-number表示单板所在的槽位号,&<1-7>表示前面的参数最多可以输入7次。
ForwardMonitor诊断用于监控芯片转发是否正常。开启ForwardMonitor诊断后,设备通过芯片之间相互发包,来检查芯片的转发是否正常,每30秒进行一次诊断。设备检测到芯片转发故障后,上报日志信息。
# 开启slot 1上的ForwardMonitor诊断。(独立运行模式)
[Sysname] diagnostic monitor enable slot 1 test forwardmonitor
diagnostic start test命令用来启动全局按需诊断测试例。
diagnostic start test test-name
test test-name:指定测试例的名称,为1~31个字符的字符串,不区分大小写。
·     本命令只支持在设备处于独立运行模式时进行配置。
·     执行本测试例时,设备需要以出厂配置启动,且各业务端口不能连接电缆和光模块。
·     本测试例执行完成后,必须整机重启设备。
# 执行全局诊断测试例
<Sysname>diagnostic start test EquipSelfCheck
This command requires null configuration and reboot device aferwards. Continue?
[Y/N]:y
  ===============display clock===================
10:55:19 UTC Fri 06/27/2015
  ===============system-view=====================
  ===============undo stp enable=====================
  ===============probe-view=====================
  ===========undo monitor inner-channel=================
1.1.9  display alarm
display alarm命令用来显示设备的告警信息。
独立运行模式:
display alarm [ slot slot-number ]
IRF模式:
display alarm [ chassis chassis-number slot slot-number ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
# 显示设备的告警信息。(独立运行模式)
<Sysname> display alarm
Slot Level   Info
-    ERROR   Fan 1 is absent.
-    INFO    Power 1 is absent.
表1-1 display alarm命令显示信息描述表
Slot
产生告警的单板所在的槽位号(如果显示为“-”,则表示产生告警的元件位于机框上)(独立运行模式)
Level
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO
Info
告警的详细信息
Fan n is absent.
风扇n当前不在位
Power n is absent.
电源n当前不在位
faulty
单板处于faulty状态(该单板可能正在启动,或者当前处于故障状态)
The temperature of sensor n exceeds the lower limit.
传感器n的温度低于低温门限
The temperature of sensor n exceeds the upper limit.
传感器n的温度高于高温门限
# 显示设备当前告警信息。(IRF模式)
Chassis Slot Level   Info
1       -    ERROR   Chassis 1 fan 1 is faulty
1       -    INFO    Chassis 1 power 6 is absent.
1       1    ERROR   Chassis 1 slot 11 temperature is too high, above the warning limit.
2       -    ERROR   Chassis 2 fan 1 is faulty
2       -    INFO    Chassis 2 power 6 is absent.
2       1    ERROR   Chassis 2 slot 11 temperature is too high, above the warning limit.
表1-2 display alarm命令显示信息描述表(IRF模式)
Chassis
告警设备的成员编号
Slot
告警单板所在的槽位号
Level
Info
告警的详细信息
Chassis x fan n is faulty
x号成员设备的风扇n故障
Chassis x power n is absent.
x号成员设备的电源n当前不在位
Chassis x slot y temperature is too high, above the warning limit.
x号成员设备的y号槽位温度高于告警门限。
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 没有配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2015
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright命令用来显示系统软件和硬件的详细版权信息。
display copyright
【缺省级别】
通过查看版权信息,可以获知系统当前使用软件和硬件版本的版权信息、版权的参照标准、版权证书等相关信息。
# 显示详细的软件版权信息。
<Sysname> display copyright
……显示信息略……
display cpu-usage命令用来显示CPU利用率的统计信息。
独立运行模式:
display cpu-usage [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display cpu-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不带该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号,取值只能为0。
系统每隔一定的时间(通常为60秒)对CPU的利用率进行统计,并把统计结果保存到历史记录区。
# 显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 4 CPU 0 CPU usage:
      10% in last 5 seconds
      10% in last 1 minute
      10% in last 5 minutes
Slot 10 CPU 0 CPU usage:
       9% in last 5 seconds
       9% in last 1 minute
       9% in last 5 minutes
Slot 11 CPU 0 CPU usage:
       9% in last 1 minute
Slot 17 CPU 0 CPU usage:
       0% in last 1 minute
# 显示所有单板CPU利用率统计信息。(IRF模式)
Chassis 1 Slot 4 CPU 0 CPU usage:
Chassis 1 Slot 10 CPU 0 CPU usage:
       9% in last 1 minute
Chassis 1 Slot 11 CPU 0 CPU usage:
       9% in last 1 minute
Chassis 1 Slot 17 CPU 0 CPU usage:
       0% in last 1 minute
表1-3 display cpu-usage命令显示信息描述表
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU的平均利用率。该字段显示的是最近一个5秒统计周期内CPU的平均利用率
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU的平均利用率
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU的平均利用率
Slot x CPU y CPU usage
x号单板上y号CPU的利用率信息(独立运行模式)
Chassis x Slot y CPU z CPU usage
x号成员设备y号单板上z号CPU的利用率信息(IRF模式)
display cpu-usage configuration命令用来显示CPU利用率历史信息记录功能相关配置。
独立运行模式:
IRF模式:
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主控板上的相应信息。(独立运行模式)
cpu cpu-number:表示指定CPU。cpu-number表示CPU的编号,取值只能为0。
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
# 查看当前主控板CPU使用率配置情况。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 99%.
表1-4 display cpu-usage configuration命令显示信息描述表
CPU利用率历史记录功能已开启。
当前CPU利用率历史记录的采样周期为60秒。
当前CPU利用率阈值为99%
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率历史信息。
独立运行模式:
IRF模式:
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息,job-id表示进程的编号。不使用该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。不带该参数时,显示的是主控板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号,取值只能为0。
系统每隔一定时间会对CPU的利用率进行统计,并把统计结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60分钟记录的CPU利用率统计值。结果以坐标的形式进行显示,显示信息中:
·     纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
·     横坐标表示时间,时间越靠左表示距离当前时间越近。
·     用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示整个系统的CPU利用率历史信息。
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 6 CPU 0) last 60 minutes (SYSTEM)
---- More ----
以上显示信息表明整个系统(用“SYSTEM”表示)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
# 以图表方式显示编号为1的进程的CPU利用率历史信息。
<Sysname> display cpu-usage history job 1
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
                      cpu-usage (Slot 16 CPU 0) last 60 minutes (scmd)
---- More ----
以上显示信息表明编号为1的进程(进程名为scmd,如果进程名带有“[]”标识则表示它是内核线程)在最近60分钟内CPU的利用率情况:20分钟前大约为5%,其它时间均小于或等于2%。
display device命令用来显示设备信息。
独立运行模式:
display device [ flash ] [ slot slot-number [ subslot subslot-number ] | verbose ]
IRF模式:
display device [ flash ] [ chassis chassis-number [ slot slot-number [ subslot subslot-number ] ] | verbose ]
flash:显示FLASH的信息。
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。目前,本系列交换机不支持子卡。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
不带flash参数时,显示设备上所有单板的信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
Slot No. Brd Type         Brd Status   Subslot Sft Ver              Patch Ver
 0       NONE             Absent       0        NONE                 None
 1       NONE             Absent       0        NONE                 None
 2       NONE             Absent       0        NONE                 None
 3       NONE             Absent       0        NONE                 None
 4       LSX1TGS48FC0     Normal       0        S12510-F-1150        None
 5       NONE             Absent       0        NONE                 None
 6       NONE             Absent       0        NONE                 None
 7       NONE             Absent       0        NONE                 None
 8       NONE             Absent       0        NONE                 None
 9       NONE             Absent       0        NONE                 None
 10      LSX1FAB10A0      Normal       0        S12510-F-1150        None
 11      LSX1FAB10A0      Normal       0        S12510-F-1150        None
 12      NONE             Absent       0        NONE                 None
 13      NONE             Absent       0        NONE                 None
 14      NONE             Absent       0        NONE                 None
 15      NONE             Absent       0        NONE                 None
 16      NONE             Absent       0        NONE                 None
 17      LSX1SUP10B0      Master       0        S12510-F-1150        None
以上显示信息表明,独立运行模式时,设备上有一个主控板(位于17号槽位),1块业务板(位于4号槽位),两块网板(位于10、11号槽位)。
表1-5 display device命令显示信息描述表(独立运行模式)
Slot No.
单板的槽位号
Brd Type
单板的硬件类型
Brd Status
单板状态:
·     Standby表示备用主控板
·     Master表示主用主控板
·     Absent表示该槽位没有插入单板
·     Fault表示该槽位单板出错,不能正常启动
·     Normal表示该槽位单板处于正常工作状态
·     Offline表示该槽位网板处于隔离状态
Subslot
单板支持子卡的最大个数
Sft Ver
当前单板上运行的软件版本
Patch Ver
当前单板上运行的热补丁版本
# 显示IRF中各成员设备的设备信息。(IRF模式)
Slot   Type             State    Subslot  Soft Ver             Patch Ver
1/0    NONE             Absent   0        NONE                 None
1/1    NONE             Absent   0        NONE                 None
1/2    NONE             Absent   0        NONE                 None
1/3    NONE             Absent   0        NONE                 None
1/4    LSX1TGS48FC0     Normal   0        S12510-F-1150        None
1/5    NONE             Absent   0        NONE                 None
1/6    NONE             Absent   0        NONE                 None
1/7    NONE             Absent   0        NONE                 None
1/8    NONE             Absent   0        NONE                 None
1/9    NONE             Absent   0        NONE                 None
1/10   LSX1FAB10A0      Normal   0        S12510-F-1150        None
1/11   LSX1FAB10A0      Normal   0        S12510-F-1150        None
1/12   NONE             Absent   0        NONE                 None
1/13   NONE             Absent   0        NONE                 None
1/14   NONE             Absent   0        NONE                 None
1/15   NONE             Absent   0        NONE                 None
1/16   NONE             Absent   0        NONE                 None
1/17   LSX1SUP10B0      Master   0        S12510-F-1150        None
2/0    NONE             Absent   0        NONE                 None
2/1    NONE             Absent   0        NONE                 None
2/2    NONE             Absent   0        NONE                 None
2/3    NONE             Absent   0        NONE                 None
2/4    LSX1TGS48FC0     Normal   0        S12510-F-1150        None
2/5    NONE             Absent   0        NONE                 None
2/6    NONE             Absent   0        NONE                 None
2/7    NONE             Absent   0        NONE                 None
2/8    NONE             Absent   0        NONE                 None
2/9    NONE             Absent   0        NONE                 None
2/10   LSX1FAB10A0      Normal   0        S12510-F-1150        None
2/11   LSX1FAB10A0      Normal   0        S12510-F-1150        None
2/12   NONE             Absent   0        NONE                 None
2/13   NONE             Absent   0        NONE                 None
2/14   NONE             Absent   0        NONE                 None
2/15   NONE             Absent   0        NONE                 None
2/16   NONE             Absent   0        NONE                 None
2/17   LSX1SUP10B0      Standby  0        S12510-F-1150        None
以上显示信息表明,该IRF中包含两台成员设备,编号分别为1和2。同时还显示了每个槽位上的单板信息。整个IRF的主用主控板位于1号成员设备的17号槽位,备用主控板位于2号成员设备的17号槽位。
表1-6 display device命令显示信息描述表(IRF模式)
Slot
IRF中的成员编号和成员设备上单板所在的槽位号
单板型号
单板状态:
·     Absent表示该槽位没有插入单板
·     Master表示该槽位单板为全局主用主控板(即整个IRF的主用主控板)
·     Standby表示该槽位单板为全局备用主控板(即整个IRF的备用主控板)
Subslot
单板支持子卡的最大个数
Soft Ver
当前单板上运行的软件版本
Patch Ver
当前单板上运行的热补丁版本,None表示没有补丁
display device manuinfo命令用来显示设备的电子标签信息。
独立运行模式:
IRF模式:
display device manuinfo [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。
·     不指定slot 参数时,显示所有单板的电子标签信息。(独立运行模式)
·     不指定chassis参数时,显示IRF中所有成员设备上所有单板的电子标签信息;指定chassis但不指定slot参数时,显示指定成员设备上所有单板的电子标签信息。(IRF模式)
电子标签信息也可以称为永久配置数据或档案信息等,在单板或者设备的调测(调试、测试)过程中被写入到设备的存储器件中,包括单板的名称、生产序列号、MAC地址、制造商等信息。本命令显示的是设备的部分电子标签信息。
# 显示设备的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo
Chassis self
DEVICE_NAME          : S12510-F
DEVICE_SERIAL_NUMBER : 02A0WU0128000055
MAC_ADDRESS          : 0004-7679-C101
MANUFACTURING_DATE   : 2015-05-06
VENDOR_NAME          : H3C
 Slot 1 CPU 0:
DEVICE_NAME          : LSX1TGS48FC0
DEVICE_SERIAL_NUMBER : 210231A73SA07B000075
MAC_ADDRESS          : 000F-E26A-581B
MANUFACTURING_DATE   : 2015-11-10
VENDOR_NAME          : H3C
 Slot 2 CPU 0:
DEVICE_SERIAL_NUMBER : 210231A76VX081000020
MAC_ADDRESS          : 000F-0123-4565
MANUFACTURING_DATE   : 2015-12-2
VENDOR_NAME          : H3C
 Slot 10 CPU 0:
DEVICE_NAME          : LSX1FAB10A0
MAC_ADDRESS          : 1231-2312-3123
VENDOR_NAME          : H3C
 Slot 16 CPU 0:
DEVICE_NAME          : LSX1SUP10B0
DEVICE_SERIAL_NUMBER : 210231S12500FSUP1002
VENDOR_NAME          : H3C
Fan 2
DEVICE_NAME          : LSXE110FAN
DEVICE_SERIAL_NUMBER : 210231S125F047679F02
MAC_ADDRESS          : 0004-7679-0A20
VENDOR_NAME          : H3C
Power 1
DEVICE_NAME          : LSTM2PSRA
DEVICE_SERIAL_NUMBER : 210231A0HHN128000169
MAC_ADDRESS          : 0000-FE91-3456
MANUFACTURING_DATE   : 2015-08-14
VENDOR_NAME          : H3C
Power 3
DEVICE_SERIAL_NUMBER : LBLNPW12CS15009116
VENDOR_NAME          : H3C
Power 5
DEVICE_SERIAL_NUMBER : LBLNPW12CS25012311
VENDOR_NAME          : H3C
表1-7 display device manuinfo命令信息显示描述表
slot x CPU y
单板所在的槽位号和CPU编号(独立运行模式)
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
# 显示设备的电子标签信息。(IRF模式)
Chassis 1:
Chassis self
VENDOR_NAME          : H3C
 Slot 1 CPU 0:
VENDOR_NAME          : H3C
 Slot 10 CPU 0:
VENDOR_NAME          : H3C
 Slot 16 CPU 0:
VENDOR_NAME          : H3C
Fan 2
VENDOR_NAME          : H3C
Power 1
VENDOR_NAME          : H3C
Power 3
VENDOR_NAME          : H3C
Power 5
VENDOR_NAME          : H3C
表1-8 display device manuinfo命令信息显示描述表
Chassis x
x号成员设备的相关信息
Slot x CPU y
x号单板y号CPU的相关信息
DEVICE_NAME
设备名称
设备序列号
MAC_ADDRESS
设备出厂MAC地址
MANUFACTURING_DATE
设备调测日期
VENDOR_NAME
制造商名称
display device manuinfo fan命令用来显示指定风扇的电子标签信息。
独立运行模式:
display device manuinfo fan fan-id
IRF模式:
display device manuinfo chassis chassis-number fan fan-id
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
fan-id:表示设备上风扇的ID编号。
# 显示风扇2的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo fan 2
Fan 2:
VENDOR_NAME          : H3C
# 显示成员设备1上风扇2的电子标签信息。(IRF模式)
<Sysname> display device manuinfo chassis 1 fan 2
 Chassis 1:
Fan 2:
VENDOR_NAME          : H3C
display device manuinfo power命令用来显示指定电源的电子标签信息。
独立运行模式:
display device manuinfo power power-id
IRF模式:
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号。
# 显示电源2的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 2
Power 2:
VENDOR_NAME          : H3C
# 显示成员设备1上电源监控模块2的电子标签信息。(IRF模式)
<Sysname> display device manuinfo chassis 1 power 2
 Chassis 1:
Power 2:
DEVICE_SERIAL_NUMBER   : 210231A0HHN128000008
MANUFACTURING_DATE     : 2015-08-11
VENDOR_NAME            : H3C
display diagnostic content命令用来显示全局按需诊断测试例的内容。
独立运行模式:
display diagnostic content [ slot slot-number ] [ verbose ]
IRF模式:
display diagnostic content [ chassis chassis-number [ slot slot-number ] ] [ verbose ]
slot slot-number:显示指定单板的全局按需诊断测试例的内容。slot-number表示单板所在的槽位号。
chassis chassis-number:显示指定成员设备的全局按需诊断测试例的内容。chassis-number表示设备在IRF中的成员编号。(IRF模式)
verbose:显示测试例的详细信息。不指定该参数时,显示测试例的简要信息。
·     不指定slot 参数时,显示所有单板的测试例内容。(独立运行模式)
·     不指定chassis参数时,显示IRF中所有成员设备的全局按需诊断测试例的内容;指定chassis但不指定slot参数时,显示指定成员设备上的局按需诊断测试例的内容。(IRF模式)
# 显示16号单板上全局按需诊断测试例的详细信息。(独立运行模式)
<sysname> display diagnostic content slot 16 verbose
Diagnostic test suite attributes:
#B/*: Bootup test/NA
#O/*: Ondemand test/NA
#M/*: Monitoring test/NA
#D/*: Disruptive test/Non-disruptive test
#P/*: Per port test/NA
#A/I/*: Monitoring test is active/Monitoring test is inactive/NA
Slot 16:
Test name        : IPCMonitor
Test attributes  : **M*PA
Test interval    : 00:01:00
Min interval     : 00:01:00
Correct-action   : -NA-
Description      : A Real-time test, disabled by default that checks ipc between
 switch units.
exec             : -NA-
Test name        : BoardStatusMonitor
Test interval    : 00:00:06
Min interval     : 00:00:06
Description      : A Real-time test, disabled by default that checks board statu
s between local master and other local boards.
---- More ----
# 显示成员设备1的16号单板上全局按需诊断测试例的简要信息。(IRF模式)
<sysname> display diagnostic content chassis 1 slot 16
Chassis 1 slot 16:
Name                            Attributes             Interval
IPCMonitor                      **M*PA                 00:01:00
BoardStatusMonitor              **M*PA                 00:00:06
TaskMonitor                     **M*PA                 00:00:10
PortMonitor                     **M*PA                 00:00:10
ComponentMonitor                **M*PA                 00:00:30
HGMonitor                       **M*PI                 00:00:10
EquipSelfCheck                  *O****                 -NA-
display diagnostic-information命令用来显示系统当前多个功能模块运行的统计信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ filename ]
hardware:收集硬件相关诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
filename:将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个功能模块的运行信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,显示系统当前多个功能模块运行的统计信息。
该命令不支持“|”、“>”和“>>”参数,执行该命令后,用户可以选择直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存。
执行display diagnostic-information命令将诊断信息保存到指定文件前,请确保主用主控板(独立运行模式下)/全局主用主控板(IRF模式下)上core文件的保存路径可访问且不能为NULL,否则,保存失败。使用display exception filepath命令可以显示core文件的保存路径。
执行display diagnostic-information命令前,请使用display cpu-usagedisplay memory命令查看CPU、内存使用率。如果CPU使用率为100%,或者内存使用率超过90%,请暂时不要执行display diagnostic-information命令,等CPU和内存使用率回落后再执行。
# 显示系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2015
其它显示信息略……。
·     display exception filepath
display diagnostic result命令用来显示诊断测试例的执行结果。
独立运行模式:
display diagnostic result [ slot slot-number [ test forwardmonitor ] ] [ verbose ]
IRF模式:
display diagnostic result [ chassis chassis-number [ slot slot-number [ test forwardmonitor ] ] ] [ verbose ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示所有单板。(独立运行模式)
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示指定成员设备的所有单板。(IRF模式)
test forwardmonitor:显示ForwardMonitor诊断测试例的执行结果。不指定该参数时,显示所有诊断测试例的执行结果,目前设备仅支持ForwardMonitor诊断测试例。
verbose:显示诊断测试例执行结果的详细信息,执行次数等于0时不显示。不指定该参数时,只显示诊断测试例执行结果的简要信息。
# 显示chassis 1 slot 2上ForwardMonitor诊断测试例的详细诊断结果。
<Sysname> display diagnostic result chassis 1 slot 2 test forwardmonitor verbose
chassis 1 slot 2:
  Test name : ForwardMonitor
  Total run count : 13569
  Total failure count : 402
  Consecutive failure count: 0
  Last execution time : Wed Mar 29 09:14:44 2017
  First failure time : Sat Mar 25 10:20:09 2017
  Last failure time : Sat Mar 25 15:06:56 2017
  Last pass time : Wed Mar 29 09:14:44 2017
  Last execution result : Success
  Last failure reason : Forwad Path Error.
  Next execution time : Wed Mar 29 09:15:14 2017
        Date     Time SrcBID SrcUnit DstBID DstUnit Status
  2017/03/25 15:06:56    1/2      0     1/4       2 DROP
  2017/03/25 15:06:56    1/2      0     1/4       1 DROP
  2017/03/25 15:06:56    1/2      0     1/4       0 DROP
  2017/03/25 15:06:26    1/2      0     1/9       1 BLOCK
  2017/03/25 15:06:26    1/2      0     1/9       0 BLOCK
  2017/03/25 15:06:26    1/2      0     1/4       3 BLOCK
  2017/03/25 15:06:26    1/2      0     1/4       2 BLOCK
  2017/03/25 15:06:26    1/2      0     1/4       1 BLOCK
  2017/03/25 15:06:26    1/2      0     1/4       0 BLOCK
  2017/03/25 15:05:56    1/2      0     1/9       1 BLOCK
  2017/03/25 15:05:56    1/2      0     1/9       0 BLOCK
  2017/03/25 15:05:56    1/2      0     1/4       3 BLOCK
  2017/03/25 15:05:56    1/2      0     1/4       2 BLOCK
  2017/03/25 15:05:56    1/2     0     1/4       1 BLOCK
  2017/03/25 15:05:56    1/2     0     1/4       0 BLOCK
表1 display diagnostic result命令显示信息描述表
Test name
诊断测试例的名称
Total run count
诊断执行的总次数
Total failure count
诊断失败的总次数
连续执行诊断测试例失败的次数
Last execution time
最近一次诊断执行的时间
First failure time
第一次诊断失败的时间。如果没有失败的诊断测试例,此字段内容为-NA-
Last failure time
最近一次诊断失败的时间。如果没有失败的诊断测试例,此字段内容为-NA-
Last pass time
最近一次诊断成功的时间。如果没有成功的诊断测试例,此字段内容为-NA-
最近一次诊断结果
Last failure reason
最近一次诊断失败的原因。当诊断未失败时,此字段内容即为-NA-
Next execution time
下次诊断执行的时间。
Forward path status : Normal
诊断报文转发正常。异常时不显示此字段,显示具体记录
Date
诊断日期
Time
诊断时间
SrcBID
检测报文源槽位编号
SrcUnit
检测报文源芯片编号
DstBID
检测报文目的槽位编号
DstUnit
检测报文目的芯片编号
Status
诊断结果,取值包括:
·     NORMAL:检测报文收发正常
·     DROP: 检测报文有丢包
·     BLOCK:阻塞,没有收到检测报文
display environment命令用来显示设备上温度传感器的温度信息,包括当前温度和设定的温度告警门限。
独立运行模式:
IRF模式:
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。
如果设备温度过高,请检查设备的通风散热环境。没有安装单板或电源的槽位请及时安装假面板,以保证风道完整性。
·     不指定slot参数时,显示设备上所有温度传感器的温度信息。(独立运行模式)
·     不指定chassis参数时,显示IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示指定成员设备上所有温度传感器的温度信息。(IRF模式)
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 4     hotspot 1 40           0      75       90     95
 4     hotspot 2 46           0      75       90     95
 4     hotspot 3 43           0      75       90     95
 10    hotspot 1 43           0      75       90     95
 10    hotspot 2 40           0      75       90     95
 10    hotspot 3 42           0      75       90     95
 17    inflow  1 42           0      57       72     77
 17    hotspot 1 43           0      76       88     93
 17    hotspot 2 40           0      76       88     93
# 显示IRF中所有温度传感器的温度信息。(IRF模式)
Chassis  Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
1        4     hotspot 1 40           0      75       90     95
1        4     hotspot 2 46           0      75       90     95
1        4     hotspot 3 43           0      75       90     95
1        10    hotspot 1 43           0      75       90     95
1        10    hotspot 2 40           0      75       90     95
1        10    hotspot 3 42           0      75       90     95
1        17    inflow  1 42           0      57       72     77
1        17    hotspot 1 43           0      76       88     93
1        17    hotspot 2 40           0      76       88     93
2        4     hotspot 1 40           0      75       90     95
2        4     hotspot 2 46           0      75       90     95
2        4     hotspot 3 43           0      75       90     95
2        10    hotspot 1 43           0      75       90     95
2        10    hotspot 2 40           0      75       90     95
2        10    hotspot 3 42           0      75       90     95
2        17    inflow  1 42           0      57       72     77
2        17    hotspot 1 43           0      76       88     93
2        17    hotspot 2 40           0      76       88     93
表1-9 display environment命令显示信息描述表
系统温度信息(单位为摄氏度)
Sensor
hotspot:表示热点温度传感器
Slot
当显示数字时表示指定槽位单板上温度传感器的温度信息(独立运行模式)
Slot
当显示chassis-number/slot-number时表示指定成员设备指定单板上温度传感器的温度信息(IRF模式)
Temperature
当前温度
Lower
低温告警门限
Warning
一般级(Warning)高温告警门限
Alarm
严重级(Alarm)高温告警门限
Shutdown
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭
display exception filepath命令用来显示core文件的保存路径。
独立运行模式:
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display exception filepath [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示主控板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number::表示指定成员设备上的指定主控板。不指定该参数时,表示全局主用主控板。(IRF模式)
cpu cpu-number:表示CPU的编号。cpu-number取值只能为0。
# 显示主用主控板上core文件的保存路径。(独立运行模式)
<Sysname> display exception filepath
The exception filepath on slot 0 is flash:.
# 显示备用主控板上core文件的保存路径。(独立运行模式)
<Sysname> display exception filepath slot 1
The exception filepath on slot 1 is flash:.
# 显示全局主用主控板上core文件的保存路径。(IRF模式)
The exception filepath on chassis 1 slot 1 is flash:.
1.1.24  display fan
display fan命令用来显示设备风扇的工作状态。
独立运行模式:
display fan [ fan-id ]
IRF模式:
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number:显示指定成员设备上风扇的状态信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备上的所有风扇。(IRF模式)
fan-id:显示指定风扇的状态信息。fan-id表示设备内置风扇的编号。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan-tray 1:
 Status    : Absent
Fan-tray 2:
 Status    : Normal
 Fan number: 5
 Fan mode  : Auto
 Airflow Direction: Back-to-front
 Fan  Status      Speed(rpm)
  1   Normal      7142
  2   Fault       3546
  3   Normal      1665
  4   Fault       3578
  5   Normal      1660
display hardware-resource命令用来显示硬件资源模式。
display hardware-resource [ tcam | vxlan | mcast ]
tcam:显示TCAM(Ternary Content Addressable Memory,三态内容寻址存储器)的硬件资源模式。
vxlan:显示VXLAN的硬件资源模式。
mcast:显示组播的硬件资源模式。
不指定可选参数时,将显示所有类型的硬件资源模式。
# 显示硬件资源模式。
<Sysname> display hardware-resource
Tcam resource(tcam), all supported modes:
  routing           The routing working mode
  normal            The normal working mode
  acl               The acl working mode
  Default         Current         Next
  routing         routing         routing
Vxlan resource(vxlan), all supported modes:
  normal            The normal mode
  mac               The mac mode
  normal          normal          normal
Mcast resource(mcast), all supported modes:
  enhance           The enhance mode
表1-10 display hardware-resource命令显示信息描述表
设备支持的TCAM的硬件资源模式
TCAM的缺省硬件资源模式
Current
TCAM的当前硬件资源模式
Next
最新配置的TCAM的硬件资源模式
设备支持的VXLAN的硬件资源模式
设备支持的组播的硬件资源模式
·     hardware-resource mcast(IP组播/组播路由与转发)
·     hardware-resource tcam
·     hardware-resource vxlan(VXLAN/VXLAN)
display memory命令用来显示内存使用情况。
独立运行模式:
display memory [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
display memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定时显示当前所有单板的内存使用情况。(IRF模式)
# 显示设备的内存使用情况。(独立运行模式)
<Sysname> display memory
The statistics about memory is measured in KB:
Slot 4:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       3415304    830292   2585012         0         0     13132       75.7%
-/+ Buffers/Cache:    817160   2598144
Swap:           0         0         0
Slot 10:
Mem:       1366400    506312    860088         0         0     13132       62.9%
-/+ Buffers/Cache:    493180    873220
Swap:           0         0         0
Slot 17:
Mem:       8143312   1168820   6974492         0        68    304148       85.6%
-/+ Buffers/Cache:    864604   7278708
Swap:           0         0         0
# 显示设备的内存使用情况。(IRF模式)
Chassis 1 Slot 4:
Swap:           0         0         0
Chassis 1 Slot 10:
Swap:           0         0         0
Chassis 1 Slot 17:
Swap:           0         0         0
Chassis 2 Slot 4:
Swap:           0         0         0
Chassis 2 Slot 10:
Swap:           0         0         0
Chassis 2 Slot 17:
Swap:           0         0         0
表1-11 display memory命令显示信息描述表
系统内存使用情况,以下统计信息均以KB为单位
Slot
单板所在的槽位号(独立运行模式)
Chassis x Slot y
X成员设备上y号单板(IRF模式)
Mem
内存使用信息
Total
系统可分配的物理内存的大小
设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小
Used
整个系统已用的物理内存大小
Free
整个系统可用的物理内存大小
Shared
多个进程共享的物理内存总额
Buffers
已使用的文件缓冲区的大小
Cached
高速缓冲寄存器已使用的内存大小
FreeRatio
整个系统物理内存的空闲率
-/+ Buffers/Cache
-/+ Buffers/Cache:Used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小
-/+Buffers/Cache:Free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小
Swap
交换分区的使用信息
display memory-threshold命令用来显示内存告警门限相关信息。
独立运行模式:
IRF模式:
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,表示全局主用主控板。(IRF模式)
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
表1-12 display memory-threshold命令显示信息描述表
内存利用率阈值
         Minor:
         Severe:
         Critical:
         Normal:
剩余内存门限阈值:
·     Minor:一级告警门限,单位为MB
·     Severe:二级告警门限,单位为MB
·     Critical:三级告警门限,单位为MB
·     Normal:恢复到正常状态的阈值,单位为MB
系统当前内存使用状态:
·     Normal:正常状态
·     Minor:一级告警门限状态
·     Severe:二级告警门限状态
·     Critical:三级告警门限状态
Event statistics:
门限事件统计信息,事件分为:
·     Back to normal state:内存恢复到正常状态
·     Enter minor low-memory state:进入一级告警门限状态
·     Back to minor low-memory state:恢复到一级告警门限状态
·     Enter severe low-memory state:进入二级告警门限状态
·     Back to severe low-memory state:恢复到二级告警门限状态
·     Enter critical low-memory state:进入三级告警门限状态
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
Lastest notification at
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec
事件发生的总次数
display power命令用来显示设备电源的信息。
独立运行模式:
display power [ power-id ]
IRF模式:
display power [ chassis chassis-number [ power-id ] ]
chassis chassis-number:显示指定成员设备上电源的信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
power-id:查看指定电源的信息。power-id表示电源的编号。不指定该参数时,表示所有电源。
# 显示设备电源的状况。
<Sysname> display power
PowerID State    Current(A)  Voltage(V)  Power(W)
 1       Normal    10.40       54.00      561.60
 2       Fault       --          --          --
 3       Absent      --          --          --
 4       Absent      --          --          --
 5       Absent      --          --          --
 6       Absent      --          --          --
 7       Absent      --          --          --
 8       Absent      --          --          --
表1-13 display power命令显示信息描述表
PowerID
电源编号
电源模块的工作状态:
·     Absent:电源不在位
·     Normal:电源正常工作
·     Fault:电源故障
Current(A)
输入电流,以安为单位
Voltage(V)
输入电压,以伏为单位
Power(W)
电源功率,以瓦为单位
表示不支持显示此项
display scheduler job命令用来查看Job的配置信息,包括Job的名称和分配的命令。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Schedule日志文件的相关信息,包括Job的名称、对应的Schedule的名称、执行时间以及执行结果。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2015
Completion time : Tue Dec 27 10:44:47 2015
<Sysname>system-view
[Sysname]interface range fortygige 1/0/1 to fortygige 1/0/3
[Sysname-if-range]shutdown
表1-14 display scheduler logfile命令显示信息描述表
Logfile Size
Schedule日志文件的大小,单位为字节
Job name
Job的名称
Schedule name
Schedule的名称
Execution time
开始执行Job的时间
Completion time
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息)
Job output
Job中的命令执行时的输出信息
·     reset scheduler logfile
display scheduler reboot命令用来查看定时重启功能的相关配置。
# 查看定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2015 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
display scheduler schedule命令用来查看Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 查看所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2015
Last execution time  : Tue Dec 27 10:44:42 2015
Last completion time : Tue Dec 27 10:44:47 2015
Execution counts     : 1
shutdown                                          Successful
表1-15 display scheduler schedule命令显示信息描述表
Schedule name
Schedule的名称
Schedule type
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息
Start time
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Last execution time
Schedule上一开始执行的时间
·     如果没有为Schedule配置执行时间,则不会显示该信息
·     如果还没有执行,则显示Yet to be executed
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息
Execution counts
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息
Job name
Schedule下关联的Job的名称
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看)
·     Successful:表示执行成功
·     Failed:表示执行失败
·     Waiting:表示正在等待被执行
·     In process:表示正在执行
·     -NA-:表示还没有到执行时间
display system stable state命令用来显示系统的稳定状态。
display system stable state [ mdc { id | all } ]
mdc { id | all }:显示指定或所有MDC的系统稳定状态。id表示MDC的编号。不指定该参数时,显示系统的稳定状态。
在进行ISSU升级或主备倒换前,请先执行该命令,检查设备是否处于稳定状态。如果System State未处于Stable状态,不能进行ISSU升级;如果Redundancy Stable未处于Stable状态,不能进行主备倒换。
设备/单板/MDC启动需要一定的时间,才能达到Stable状态。如果设备/单板/MDC长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板/MDC,根据其具体状态,采取进一步措施。
操作时,建议多次执行命令,以确认稳定状态的连续性。
# 显示系统的稳定状态。(独立运行模式)
<Sysname> display system stable state
System state    : Stable
Redundancy state: Stable
  Slot   CPU   Role      State
* 1      0     Active    Stable
表1-16 display system stable state命令显示信息描述表
System state
系统状态:
·     Stable:稳定运行
·     Not ready:未稳定,此时不能进行ISSU升级
Redundancy state
主备状态:
·     Stable:主备状态稳定,可以倒换
·     No Redundance:系统无冗余,不能倒换
·     Not Ready:未稳定,不可以倒换
Role
单板在系统中的身份:
·     Active:主用主控板
·     Standby:备用主控板,提供冗余备份
·     Other:其它类型单板
单板状态:
·     Stable:单板稳定运行
·     Board Inserted:单板插入
·     Kernel Init:单板内核初始化
·     Service Starting:单板上的服务正在启动
·     Service Stopping:单板上的服务正在关闭
·     HA Batch Backup:HA批量备份中
·     Interface Data Batch Backup:接口管理批量备份未完成
·     MDC Starting:MDC正在启动
·     MDC Stopping:MDC正在关闭
当前对象处于未稳定状态
·     display device
·     display mdc(虚拟化技术命令参考/MDC)
display system-working-mode命令用来显示设备的工作模式。
# 显示设备的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The next system working mode is standard.
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见表1-17。如果没有故障,则显示为None。
表1-17 display transceiver alarm命令输出信息描述表
SFP/SFP+
RX loss of signal
接收信号丢失
RX power high
接收光功率高告警
RX power low
接收光功率低告警
TX fault
发送错误
TX bias high
偏置电流高告警
TX bias low
偏置电流低告警
TX power high
发送光功率高告警
TX power low
发送光功率低告警
Temp high
温度高告警
Temp low
温度低告警
Voltage high
电压高告警
Voltage low
电压低告警
Transceiver info I/O error
模块信息读写错误
Transceiver info checksum error
模块信息校验和错误
Transceiver type and port configuration mismatch
模块类型和端口配置不匹配
Transceiver type not supported by port hardware
端口不支持该模块类型
TEC fault
TEC(Thermoelectric Cooler,热点冷却器)错误。当接口插入SFP-XG-LH80-Tunable光模块时,才支持该信息
Wavelength unlocked
光信号波长失锁。当接口插入SFP-XG-LH80-Tunable光模块时,才支持该信息
Tx is not ready due to tunning
光信号波长改变时发射端处于准备过程状态告警。当接口插入SFP-XG-LH80-Tunable光模块时,才支持该信息
QSFP+
RX loss signal (channel x)
通道x接收信号丢失
TX fault (channel x)
通道x发送错误
TX loss signal (channel x)
通道x发送信号丢失
RX power high (channel x)
通道x接收光功率高告警
RX power low (channel x)
通道x接收光功率低告警
TX bias high (channel x)
通道x偏置电流高告警
TX bias low (channel x)
通道x偏置电流低告警
Temp high
温度高告警
Temp low
温度低告警
Voltage high
电压高告警
Voltage low
电压低告警
模块信息读写错误
模块信息校验错误
模块类型和端口配置不匹配
端口不支持该模块类型
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface fortygige 1/0/1
FortyGigE1/0/1 transceiver current alarm information:
  RX loss of signal(channel 1)
  RX loss of signal(channel 2)
  RX loss of signal(channel 3)
  RX loss of signal(channel 4)
  RX power low(channel 1)
  RX power low(channel 2)
  RX power low(channel 3)
  RX power low(channel 4)
表1-18 display transceiver alarm显示信息描述表
接口光模块当前故障告警信息
RX loss of signal (channel 1)
通道1接收信号丢失
RX power low (channel 1)
通道1接收光功率低告警
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface fortygige 1/0/1
FortyGigE1/0/1 transceiver diagnostic information:
[module]  Temp.(°C) Voltage(V)
          33         3.29
[channel] Bias(mA)  RX power(dBm)  TX power(dBm)
    1     7.96      -1.03          -0.64
    2     7.69      -0.83          -0.56
    3     7.79      -0.42          -0.59
    4     8.08      -0.55          -0.47
  Alarm thresholds:
          Temp.(°C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    High  75         3.63        10.00     3.40           N/A
    Low   -5         2.97        0.50      -13.51         N/A
表1-19 display transceiver diagnosis显示信息描述表
接口插入的光模块的数字诊断信息
当前的诊断参数
Wave.er(nm)
波长偏移,单位为nm,精确到0.001nm。当接口插入SFP-XG-LH80-Tunable光模块时,才支持该信息
Freq.er(GHz)
频率偏移,单位为GHZ,精确到0.1GHZ。当接口插入SFP-XG-LH80-Tunable光模块时,才支持该信息
module
光模块
channel
通道
Temp.(°C)
数字诊断参数——温度,单位为°C,精确到1°C
Voltage(V)
数字诊断参数——电压,单位为V,精确到0.01V
Bias(mA)
数字诊断参数——偏置电流,单位为mA,精确到0.01mA
RX power(dBm)
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm
TX power(dBm)
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm
Alarm thresholds
告警门限
High
高告警门限
Low
低告警门限
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface fortygige 1/0/1
FortyGigE1/0/1 transceiver information:
  Transceiver Type              : 40G_BASE_SR4_QSFP_PLUS
  Connector Type                : MPO
  Wavelength(nm)                : 850
  Transfer Distance(m)          : 100(OM3)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
表1-20 display transceiver interface命令显示信息描述表
可插拔接口模块信息
Transceiver Type
可插拔接口模块的物理型号
Connector Type
可插拔接口模块的连接器类型,包括:
·     MPO(Multi-fiber Push On)
·     RJ-45
Wavelength(nm)
·     光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块,各个波长值之间用逗号分隔
·     电模块:显示为“N/A”
Transfer Distance(xx)
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称:
·     9um:表示9/125um单模光纤
·     50um:表示50/125um多模光纤
·     62.5um:表示62.5/125um多模光纤
·     TP:表示双绞线
对数字诊断功能的支持情况,其中:
·     YES:表示支持数字诊断
·     NO:表示不支持数字诊断
Vendor Name
模块生产或定制厂商名称
仅插入SFP-XG-LH80-Tunable光模块的接口支持本命令。
display transceiver itu-channel interface命令用来显示光模块的ITU通道信息。
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface-type interface-number:显示指定光模块当前使用的ITU通道的信息。interface-type interface-number表示接口类型和接口编号。不指定该参数时,表示所有接口上光模块当前使用的ITU通道的信息。
supported-channel:仅显示接口支持配置的ITU通道的信息。不指定该参数时,仅显示光模块当前使用的ITU通道的信息。
# 显示所有接口上插入的光模块当前使用的ITU通道的信息。
<Sysname> display transceiver itu-channel interface
Interface                           Channel        WaveLength(nm)  Frequency(THz)
XGE1/0/1                            1              1566.72         191.35
XGE1/0/2                            -              -               -
XGE1/0/3                            3              1565.90         191.45
……其它显示信息略……
# 显示Ten-GigabitEthernet1/0/1上插入的光模块当前使用的ITU通道的信息。
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 1/0/1
# 显示Ten-GigabitEthernet1/0/1上插入的光模块支持配置的ITU通道的信息。
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 1/0/1 supported-channel
ITU channel settings supported on Ten-GigabitEthernet1/0/1 :
1          1566.72           191.35
2          1566.31           191.40
3          1565.90           191.45
4          1565.50           191.50
5          1565.09           191.55
6          1564.68           191.60
7          1564.27           191.65
8          1563.86           191.70
……其它显示信息略……
表1-21 display transceiver itu-channel interface命令显示信息描述表
光模块所在接口的简称
Channel
ITU通道编号
WaveLength(nm)
通道编号对应的波长,单位为nm,精确到0.01nm
Frequency(THz)
通道编号对应的频率,单位为THZ,精确到0.01THZ
表示对应接口显示ITU通道信息失败,失败原因有:
·     该接口上未插入光模块
·     该接口上光模块不支持配置ITU通道编号
·     光模块获取ITU通道信息失败
·     设备不支持光模块上当前存储的ITU通道编号
·     itu-channel
display transceiver manuinfo命令用于显示可插拔接口模块的部分电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口FortyGigE1/0/1上插入的可插拔接口模块的部分电子标签信息。
<Sysname> display transceiver manuinfo interface fortygige 1/0/1
FortyGigE1/0/1 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2015-09-01
  Vendor Name          : H3C
表1-22 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number
在生产过程中生成的序列号
Manufacturing Date
写入电子标签的日期
Vendor Name
厂商名称
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
……显示信息略……
display version-update-record命令用来显示主控板启动软件包版本更新操作的记录。(独立运行模式)
display version-update-record命令用来显示全局主用主控板启动软件包版本更新操作的记录。(IRF模式)
【描述】
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
目前最多可以保存10条更新记录。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Name                                   Version                 Compile time
Record 1  (updated on Sep 10 2015 at 18:06:28):
* S12500-F-CMW710-BOOT-R1150.bin       7.1.045 Release 1150   Aug 14 2015 16:33:12
* S12500-F-CMW710-SYSTEM-R1150.bin     7.1.045 Release 1150   Aug 14 2015 16:33:12
表1-23 display version-update-record命令显示信息描述表
Name
软件包的名称
Version
软件包的版本号
Compile time
版本编译时间
Record 1
最近的第n次更新的时间,Record 1为最新的一次更新
表示软件包的版本和升级前的版本有变化,没有星号的表示版本没有变化
·     reset version-update-record
exception filepath命令用来设置core文件的保存路径。
undo exception filepath命令用来取消core文件保存路径的配置(core文件保存路径将显示为NULL)。
exception filepath directory
undo exception filepath directory
core文件的保存路径为flash:。
directory:表示core文件的保存路径,只能为存储介质的根目录。
本命令配置成功后,设备会将生成的core文件存放到当前主用主控板/全局主用主控板上、指定存储介质根目录下的core文件夹下。如果存储介质根目录下没有core文件夹,则会先创建core文件夹,再保存core文件。
需要注意的是,使用undo exception filepath命令取消core文件保存路径的配置,或者core文件的保存路径无法正常访问时,系统将无法保存core文件和display diagnostic-information命令生成的诊断信息文件。
# 设置core文件的保存路径。
<Sysname> exception filepath flash:
·     process core
hardware-resource tcam命令用来配置TCAM硬件资源模式。
undo hardware-resource tcam命令用来恢复缺省情况。
hardware-resource tcam { routing | normal | acl | ipv6 }
TCAM硬件资源模式为路由模式。
routing:路由模式,此时系统将FE单板的TCAM硬件资源仅分配给ARP和IPv4路由表项,可以扩大ARP和IPv4路由表项的规模。
normal:普通模式,此时系统不使用FE单板的TCAM硬件资源。
acl:ACL模式,此时系统将FE单板的TCAM硬件资源仅分配给IPv4 ACL表项,可以扩大IPv4 ACL路由表项的规模。
ipv6:IPv6模式,此时系统将FE单板的TCAM硬件资源仅分配给IPv4路由表项和IPv6路由表项,可以扩大IPv4路由表项和IPv6路由表项的规模。
·     本命令仅对FE单板生效。
·     配置TCAM硬件资源模式后,请先将当前配置保存到下次启动配置文件,再删除下次启动配置文件对应的.mdb文件,最后重启设备,以确保配置的模式生效。
# 将TCAM硬件资源模式配置为路由模式。
[Sysname] hardware-resource tcam routing
Do you want to change the specified hardware resource working mode? [Y/N]:y
The hardware resource working mode is changed, please save the configuration and reboot the system to make it effective.
·     display hardware-resource
1.1.44  header
header命令用来设置欢迎信息。
undo header命令用来关闭欢迎信息。
header { legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
没有配置任何欢迎信息。
legal:设置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:设置登录验证时的欢迎信息。
motd:设置登录终端界面前的欢迎信息。
shell:设置非Modem登录用户登录进入用户视图时的欢迎信息。
text:输入欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 先后配置legalloginmotdshell欢迎信息,并验证配置效果。
[Sysname] header legal
Welcome to legal (header legal)%
[Sysname] header login
Welcome to login(header login)%
[Sysname] header motd
Welcome to motd(header motd)%
[Sysname] header shell
Welcome to shell(header shell)%
本例中,“%”为text的起始/结束字符,在显示文本后输入“%”表示文本结束,退出header命令。作为起始与结束字符,“%”不会成为所设置欢迎信息的一部分。
采用Telnet方式远程登录设备,测试以上设置(只有设置了登录认证之后,才会显示login欢迎信息)。
 Press Y or ENTER to continue, N to exit.
Password:
1.1.45  itu-channel
itu-channel命令用来配置光模块的ITU通道编号。
undo itu-channel命令用来恢复缺省情况。
itu-channel channel-number
undo itu-channel
光模块的ITU通道编号为1。
以太网接口视图
channel-number:表示光模块的ITU通道编号。
配置该命令后,设备会将ITU通道编号保存在光模块内部的寄存器中,不会保存到配置文件中。
# 将Ten-GigabitEthernet1/0/1上插入的光模块的ITU通道编号配置为2。
[Sysname-Ten-GigabitEthernet1/0/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
·     display transceiver itu-channel
1.1.46  job
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
没有为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold命令用来配置剩余内存告警的门限值。
undo memory-threshold命令用来恢复剩余内存告警的门限值。
独立运行模式:
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
对于Release 1150版本,一级告警门限为96MB,二级告警门限为64MB,三级告警门限为48MB,系统恢复到正常的内存门限为128MB。
对于Release 1152及以上版本,一级告警门限为256MB,二级告警门限为64MB,三级告警门限为48MB,系统恢复到正常的内存门限为320MB。
minor minor-value:一级告警门限,单位为兆字节(MB);该值应小于等于单板内存大小;为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB);该值必须小于等于一级告警门限;为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB);该值必须小于等于二级告警门限;为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB);该值必须大于等于一级告警门限,且小于等于实际内存大小。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定该参数时,表示全局主用主控板。(IRF模式)
系统实时监控系统剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
设备支持三级告警门限:
·     当系统剩余空闲内存小于等于一级告警门限时,产生一级告警;
·     当系统剩余空闲内存小于等于二级告警门限时,产生二级告警;
·     当系统剩余空闲内存小于等于三级告警门限时,产生三级告警。
·     当系统剩余空闲内存大于等于二级告警门限时,产生三级告警解除通知;
·     当系统剩余空闲内存大于等于一级告警门限时,产生二级告警解除通知;
·     当系统剩余空闲内存大于等于正常内存大小时,产生一级告警解除通知。
同一级别的告警/告警解除通知是交替进行的:当系统剩余空闲内存小于等于某级告警门限,设备产生相应级别的告警,后续只有该告警解除了,系统剩余空闲内存再次小于等于某级告警门限时,才会再次生成该级别的告警。
# 一级、二级、三级告警门限分别为64MB、48MB、32MB,当系统剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
·     display memory-threshold
·     memory-threshold usage
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
独立运行模式:
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
IRF模式:
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold chassis 1 slot 2 cpu 1 usage 80
·     memory-threshold
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
独立运行模式:
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定表示全局主用主控板。(IRF模式)
# 打开CPU使用率历史记录功能。
[Sysname] monitor cpu-usage enable
·     display cpu-usage
·     display cpu-usage configuration
·     display cpu-usage history
monitor cpu-usage interval命令用来配置CPU使用率历史记录采样周期。
独立运行模式:
monitor cpu-usage interval interval-value [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
monitor cpu-usage interval interval-value [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval-value:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU使用率历史记录采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
·     display cpu-usage
monitor cpu-usage threshold命令用来配置CPU利用率阈值。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
独立运行模式:
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
monitor cpu-usage threshold cpu-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率阈值为99%。
cpu-threshold:CPU利用率阈值百分比,取值范围为0~100。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的CPU利用率阈值比较。当采样值大时,则认为CPU利用率过高,设备会发送Trap报文。
# 配置CPU利用率阈值为80%。
[Sysname] monitor cpu-usage threshold 80
·     display cpu-usage
password-recovery enable命令用来使能密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于使能状态。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见产品的相关手册。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
1.1.53  process core
process core命令用来开启/关闭用户态进程异常时生成core文件的功能,以及配置能生成的core文件的最大个数。
独立运行模式:
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
IRF模式:
process core { maxcore value | off } { job job-id | name process-name } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
同一用户态进程在首次异常时会生成core文件,后续异常不再生成core文件。即maxcore的最大数值为1。
off:表示关闭用户态进程异常时生成core文件的功能。
maxcore value:表示开启用户态进程的core文件生成功能,并配置能生成的core文件的最大个数。value表示用户态进程能生成的core文件的最大个数,取值范围为1~10,缺省值为1。
name process-name:用户态进程的名称,为1~15个字符的字符串,不区分大小写。process core命令的配置对用户态进程下的所有实例有效。
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-numberchassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
开启用户态进程的core文件生成功能,并配置能生成的core文件的最大个数后,用户态进程异常重启一次,就会产生一个core文件并记录用户态进程的异常信息。如果生成的core文件的数目达到最大值,则不再生成新的core文件。软件开发和维护人员能够根据core文件的内容来定位异常的原因和异常的位置。
因为生成的core文件会占用系统存储资源,如果用户对某些用户态进程的异常退出不关心,可以关闭这些用户态进程的core文件记录功能。
# 关闭用户态进程routed的core文件生成功能。
<Sysname> process core off name routed
# 开启用户态进程dbmd的core文件生成功能,并且最多可生成5个core文件。
<Sysname> process core maxcore 5 name dbmd
·     exception filepath
1.1.54  reboot
reboot命令用来重启指定单板、主控板或整个设备。(独立运行模式)
reboot命令用来重启指定成员设备或所有成员设备。(IRF模式)
独立运行模式:
IRF模式:
force:强制重启设备。
·     不指定该参数时,重启设备,系统会进行保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备。
·     指定该参数时,系统将不进行任何检查,直接执行重启操作。
·     重新启动可能会导致业务中断,请谨慎使用该命令。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(1)     独立运行模式:
不指定slot参数,会导致整个设备重启。
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
(2)     IRF模式:
·     不指定chassisslot参数,则会重启所有成员设备。
·     只指定chassis不指定slot参数,则会重启IRF中指定的成员设备。
·     同时指定chassisslot参数,则会重启IRF中指定的单板。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 当配置没有变化时,重启设备。
<Sysname> reboot
 Now rebooting, please wait...
# 当配置有变化时,重启设备,并选择保存配置文件。
<Sysname> reboot
 Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
# 当配置有变化时,重启设备,但不保存配置文件。
<Sysname> reboot
 Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
# 强制重启设备。
<Sysname> reboot force
 A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
# 重启业务板(业务板所在的槽位号为2)。(独立运行模式)
<Sysname> reboot slot 2
 This command will reboot the specified slot, Continue? [Y/N]:y
# 强制重启业务板(业务板所在的槽位号为2)。
<Sysname> reboot slot 2 force
# 重启成员设备2。(IRF模式)
<Sysname> reboot chassis 2
 This command will reboot the specified chassis, Continue? [Y/N]:y
# 强制重启成员设备2。
<Sysname> reboot chassis 2 force
# 重启成员设备2上的2号业务板。(IRF模式)
<Sysname> reboot chassis 2 slot 2
# 强制重启成员设备2上的2号业务板。
<Sysname> reboot chassis 2 slot 2 force
·     display system stable state
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
·     display scheduler logfile
reset version-update-record命令用来清除主用主控板启动软件包版本更新操作的记录。(独立运行模式)
reset version-update-record命令用来清除全局主用主控板启动软件包版本更新操作的记录。(IRF模式)
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
·     display version-update-record
scheduler job命令用来创建Job并进入Job视图。如果Job已创建,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
没有创建Job。
【缺省级别】
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
·     command
scheduler logfile size命令用来设置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户设置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 设置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来指定设备重启的具体时间和日期。
undo scheduler reboot命令用来取消重启时间的设置。
没有指定设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MMHH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     YYYY的取值范围为2000~2035;
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
如果没有指定date参数,并且:
·     设置的时间点在当前时间之后,则设备将在当天的该时间点重启;
·     设置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot atscheduler reboot delay命令,最新配置生效。
需要注意的是,该命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
# 假设系统的当前时间为2015年6月6日11:43,设置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2015 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
undo scheduler reboot命令用来取消延时重启配置。
scheduler reboot delay time
没有配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
·     使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2015年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2015(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule并进入相应的Schedule视图。如果Schedule已创建,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
没有创建Schedule。
schedule-name:Schedule的名字,为1~47个字符的字符串,区分大小写。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1)     使用scheduler job命令创建Job。
(2)     在Job视图下,使用command命令配置需要执行的命令。
(3)     使用scheduler schedule命令创建Schedule
(4)     在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5)     在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6)     在Schedule视图下,使用time attime once或者time repeating命令来配置任务执行的时间。一个Schedule下只能设置一个执行时间。
# 创建名为saveconfig的Schedule。
·     job
·     time at
·     time once
1.1.62  shutdown-interval
shutdown-interval命令用来设定定时检测的时间间隔。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval time
定时检测的时间间隔为30秒。
time:定时检测的时间间隔,取值范围为0~300,单位为秒。取值为0时,表示不进行定时检测。
某些协议模块在特定情况下会自动关闭某个端口,比如当使能了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。同时,系统会启动一个检测定时器,如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,协议模块则自动激活该端口,令其恢复到真实的物理状态。
需要注意的是,如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。若T<T1,则被关闭的端口会再经过T1-T时间后被恢复;若T>=T1,则被关闭的端口会立即恢复。例如当前time设置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 设定定时检测时间间隔为100秒。
[Sysname] shutdown-interval 100
1.1.63  switch-fabric isolate
switch-fabric isolate命令用来将网板从转发平面隔离出去,所有数据流量都不经过指定网板。
undo switch-fabric isolate命令用来恢复缺省情况。
独立运行模式:
switch-fabric isolate slot slot-number [ channel channel-number ]
undo switch-fabric isolate slot slot-number [ channel channel-number ]
IRF模式:
switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
undo switch-fabric isolate chassis chassis-number slot slot-number [ channel channel-number ]
网板处于转发平面,数据流量会经过网板进行转发。
slot slot-number:表示网板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定网板。(IRF模式)
channel channel-number:表示网板的指定通道号。若不指定该参数,将隔离整块网板。
配置该功能后主控板与网板的正常通信,控制平面上协议报文的解析与协议的计算等功能均不受影响,从而保证了通过undo switch-fabric isolate 命令快速恢复网板的转发能力。
每块网板都有一定的转发带宽,隔离一块网板后会减少相应的转发带宽,使设备整体转发带宽降低。如果设备只装配了一块网板,隔离之后便不能转发报文,导致设备失去转发能力。
将网板的故障通道单独隔离出去,可以减小了因隔离整块网板对设备转发能力的影响。
# 将10号槽位网板隔离。(独立运行模式)
[Sysname] switch-fabric isolate slot 10
The command will isolate the switch fabric or a channel from the system. Continue? [Y/N]
# 将IRF中1号成员设备上10号槽位网板的1号通道隔离。(IRF模式)
[Sysname] switch-fabric isolate chassis 1 slot 10 channel 1
1.1.64  sysname
sysname命令用来设置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备的名称为H3C。
sysname:设备名称,取值范围为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 设置设备的名称为R2000。
[Sysname] sysname R2000
[R2000]
1.1.65  system-working-mode
system-working-mode命令用来配置设备的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { advance | bridgee | standard }
设备工作在标准模式。
advance:将设备的工作模式设置为高级模式。
bridgee:将设备的工作模式设置为二层增强模式。
standard:将设备的工作模式设置为标准模式。
切换工作模式后,请先将当前配置保存到下次启动配置文件,再删除下次启动配置文件对应的.mdb文件,最后重启设备,以确保修改后的工作模式生效。
不同模式下设备支持的特性不同,请根据实际需要配置。例如:
·     只有当设备工作在高级模式才支持配置EVI功能和FCoE功能。有关EVI功能和FCoE功能的详细介绍,请分别参见“EVI配置指导”和“FCoE配置指导”。
·     只有当设备工作在二层增强模式才支持配置SPBM功能。有关SPBM功能的详细介绍,请参见“SPB配置指导”。
·     只有当设备工作在标准模式才支持配置VXLAN功能。有关VXLAN功能的详细介绍,请参见“VXLAN配置指导”。
切换设备的工作模式会造成配置丢失,请谨慎使用本特性。
# 将设备工作模式配置为高级模式。
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
1.1.66  temperature-limit
temperature-limit命令用于设置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
独立运行模式:
temperature-limit slot slot-number { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow } sensor-number
IRF模式:
temperature-limit chassis chassis-number { slot slot-number } { hotspot | inflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number { slot slot-number } { hotspot | inflow } sensor-number
请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看单板的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
sensor-number:温度传感器的编号,取值为从1开始的正整数,每一个数字对应设备(单板)上的一个温度传感器。
lowlimit:低温告警门限,单位为摄氏度。
warninglimit:一般级(Warning)高温告警门限,单位为摄氏度。一般级高温告警门限必须大于低温告警门限。
alarmlimit:严重级(Alarm)高温告警门限,单位为摄氏度。严重级高温告警门限必须大于一般级高温告警门限。
·     不同单板支持的温度传感器类型不同,请通过display environment命令查看单板支持的温度传感器类型。
·     不同单板的传感器编号和温度告警门限取值范围不同,输入传感器编号或温度告警门限值时请通过<?>查看设备提示信息,以获取温度告警门限的取值范围。
·     如果温度低于低温告警门限,系统会生成日志信息和告警信息提示用户。
·     如果温度高于Warning高温门限,系统会生成日志信息和告警信息提示用户。
·     如果温度高于Alarm高温门限,系统一方面通过反复打印日志信息和告警信息提示用户,另一方面还会通过设备面板上的指示指示灯来告警。
·     如果业务板或网板温度高于关断级(Shutdown)高温告警门限,除生成日志和告警信息提示用户外,设备还会自动将该单板断电。
# 配置1号单板上1号热点传感器,低温门限为-10摄氏度,Warning级高温门限为70摄氏度,Alarm级高温门限为90摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 hotspot 1 -10 70 90
# 配置1号成员设备1号单板上1号热点传感器,低温门限为-10摄氏度,Warning级高温门限为70摄氏度,Alarm级高温门限为90摄氏度。(IRF模式)
[sysname] temperature-limit chassis 1 slot 1 hotspot 1 -10 70 90
1.1.67  time at
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
没有为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time attime oncetime repeating命令时,最新配置生效。
# 配置2015年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2015/05/11
1.1.68  time once
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
没有为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun,&<1-7>表示前面的参数最多可以输入7次。设置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
1.1.69  time repeating
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval-time
undo time
没有配置重复执行Schedule的时间。
Schedule视图
time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
·     MM的取值范围为1~12;
·     DD的取值范围与具体月份有关。
interval interval-time:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
·     使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
·     使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:MonTueWedThuFriSatSun,&<1-7>表示前面的参数最多可以输入7次。设置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval-time表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
1.1.70  user-role
user-role命令用来配置执行定时任务时使用的用户角色。
undo user-role命令用来删除执行定时任务时的用户角色。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:执行定时任务时使用的用户角色,为1~63个字符,区分大小写。可以是系统预定义的角色名称,包括network-admin、mdc-admin、network-operator、mdc- operator、level-0~level-15、security-audit,也可以是自定义的用户角色名称。
本命令用来指定执行定时任务时的用户角色。通过配置和删除执行定时任务时的用户角色可以控制定时任务下的各个命令的执行。
用户在创建schedule后继承当前用户的权限。只有管理员角色才可以通过user-role命令给Schedule添加/删除角色,且配置的用户角色权限要小于当前用户的权限,否则配置不生效。
多次执行本命令可给Schedule配置多个用户角色,系统会使用这些用户角色权限的并集去执行Schedule。同一个Schedule最多可以配置64个用户角色。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
# 配置执行定时任务test时使用的用户角色为rolename。
<sysname> system-view
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
[Sysname-schedule-test] display this
 user-role network-admin
 user-role network-operator
 user-role rolename
return
·     command
