04-时钟监控配置
本章节下载: 04-时钟监控配置 (198.75 KB)
1 时钟监控配置································································································································· 1-1
1.1 时钟监控模块简介···················································································································· 1-1
1.1.1 时钟监控模块概述·········································································································· 1-1
1.1.2 时钟源的分类················································································································ 1-1
1.1.3 参考源的级别················································································································ 1-1
1.1.4 时钟监控模块的工作模式································································································ 1-2
1.1.5 端口的时钟工作模式······································································································· 1-2
1.2 时钟监控模块配置任务简介······································································································· 1-3
1.3 配置时钟监控模块的工作模式··································································································· 1-3
1.4 设置参考源的优先级················································································································ 1-4
1.5 配置参考源的SSM参数··········································································································· 1-4
1.5.1 设置SSM级别的确定方式······························································································ 1-4
1.5.2 设置传输Bits时钟源SSM级别信息的比特位··································································· 1-5
1.5.3 设置参考源的SSM级别································································································· 1-5
1.5.4 设置SSM是否参与控制································································································· 1-6
1.6 设置线路时钟源的输入端口(LPU Port)··················································································· 1-6
1.7 时钟监控模块显示和维护·········································································································· 1-7
1.8 时钟监控模块典型配置举例······································································································· 1-8
时钟监控模块负责向各业务接口板提供高精度、高可靠性的同步SDH(Synchronous Digital Hierarchy,同步数字系列)线路接口时钟信号,完成输入时钟源的自动选择、软件锁相功能,并实时监测接口板的时钟状态。此外,时钟监控模块还支持时钟扣板的硬件复位。
目前时钟监控模块支持14路参考时钟源(以下简称参考源),其中第一路和第二路为Bits时钟源,分别对应主用主控板的外部时钟输入1和输入2,其它的为线路时钟源。图1-1是设备的参考源与槽位的对应关系图,可以看到S9505E设备上,2号槽位的线路时钟对应第9路参考源,3号槽位的线路时钟对应第10路参考源。
根据时钟源的来源不同,可以将时钟源分为以下三类:
· 本地时钟源:由时钟监控模块内部晶体震荡器产生的38.88MHz时钟信号。
· Bits时钟源:由专门的Bits时钟设备产生,Bits时钟通过主控板上的专用接口,直接传送给时钟监控模块,时钟监控模块再发送给所有接口板。
· 线路时钟源:由上一级设备提供,精度比Bits时钟源低。通过指定的WAN接口输入,系统提取时钟信号后,传送给时钟监控模块,时钟监控模块再发送给所有接口板。
参考源的级别由参考源的优先级和参考源的SSM(Synchronization Status Marker,同步状态信息)级别共同确定。
用户可以给高精度、高可靠性的参考源设置较高的优先级,以便在选择时钟源时优先被选择。
SSM也称同步质量信息,用于在同步定时传递链路中直接反映同步定时信号的等级。
参考源的SSM级别及其各自的含义按照级别由高到低的顺序排列如下:
· PRC:G.811时钟信号
· TNC:G.812转接节点时钟信号
· LNC:G.812本地节点时钟信号
· SETS:SDH设备时钟源信号
· unknown:同步质量未知
· DNU:不应用作同步
SSM级别为DNU的参考源不能用作时钟源。
时钟监控模块的工作模式,即时钟监控模块选择时钟源的模式,包括手动模式和自动模式。
手动模式下的时钟源由用户手工设置。时钟监控模块不主动切换时钟源,只跟踪用户设置的主用参考源。如果主用参考源丢失,时钟监控模块转入保持状态。
自动模式下的时钟源由系统自动设置。在当前主用时钟源丢失或不可用时,时钟监控模块会根据参考源级别来主动切换时钟源。切换时遵循以下规则:
· 如果SSM级别不参与控制,时钟监控模块直接按参考源的优先级选择时钟源。如果两个参考源优先级相同,则按照参考源的编号顺序(1~14)进行选择。当可用的最高级别的参考源丢失时,自动切换到下一个可用的最高级别的参考源。当原时钟源恢复时,自动切换回原时钟源。
· 如果SSM级别参与控制,则时钟监控模块首先按参考源的SSM级别选择时钟源,如果两个参考源的SSM级别相同,再按照参考源的优先级选择,具体方式请参见上一段中的相关说明。
以下参考源在切换时不会被选择:
· 信号丢失的参考源为不可用时钟源,不参与切换;
· 优先级为255的参考源为未配置优先级的时钟源,不参与切换;
· SSM级别为DNU的参考源为不可用时钟源,不参与切换。
根据端口时钟的来源,设备的端口支持两种时钟模式:
· 主时钟模式(Master):使用时钟监控模块提供的时钟信号。这个时钟信号包括本地时钟信号以及从LPU Port(时钟信号输入端口)提取的时钟信号。在主时钟模式下,如果设备上没有配置从LPU Port提取时钟信号,就采用本地时钟信号;如果配置了从LPU Port提取时钟信号,就采用LPU Port提取的时钟信号。
· 从时钟模式(Slave):使用线路提供的时钟信号。此时必须把设备的LPU Port指定为当前端口,系统才会从当前端口收到的线路信号中提取时钟源,然后发送给时钟监控模块,再由时钟监控模块输出到所有接口板。
当与SONET/SDH设备相连时,由于SONET/SDH网络的时钟精度高于设备本身内部时钟源的精度,应配置设备工作在从时钟模式。
表1-1 时钟监控模块配置任务简介
配置任务 |
详细配置 |
配置时钟监控模块的工作模式 |
可选 |
设置参考源的优先级 |
可选 |
配置参考源的SSM参数 |
设置SSM级别的确定方式 |
可选 |
设置传输Bits时钟源SSM级别信息的比特位 |
可选 |
设置参考源的SSM级别 |
可选 |
设置SSM是否参与控制 |
可选 |
设置线路时钟源的输入端口(LPU Port) |
可选 |
进入系统视图 |
system-view |
设置时钟监控模块的工作模式 |
clock { auto | manual source source-number } |
可选 缺省情况下,时钟监控模块的工作模式为自动模式 |
设置时钟监控模块的工作模式后设备响应需要一定时间,可通过display clock device命令和日志信息查看配置是否生效。
在自动模式下,时钟监控模块会根据SSM级别及参考源的优先级选择时钟源,并主动切换到优先级高的参考源。
表1-3 设置参考源的优先级
进入系统视图 |
system-view |
设置参考源的优先级 |
clock priority value source source-number |
必选 缺省情况下,参考源的优先级为255 |
参考源的SSM级别的确定方式有两种:
· 对于bits时钟源,SSM级别可以从接口板输入的时钟信号中提取,并上报给主控板,主控板将bits时钟源的SSM级别设置给时钟监控模块。
· 用户自行设置SSM级别,操作步骤请参见表1-6。
表1-4 设置SSM级别的确定方式
进入系统视图 |
system-view |
设置SSM级别的确定方式 |
clock forcessm { on | off } source source-number |
可选 缺省情况下,不从时钟源中提取SSM级别,即使用用户自行设置的SSM级别 |
传输Bits时钟源SSM级别信息的比特可以设置为sa4(sa4比特)、sa5(sa5比特)、sa6(sa6比特)、sa7(sa7比特)和sa8(sa8比特)。按照ITU-TG.704 CRC4规定,sa4~sa8表示复帧中偶数帧的0时隙的sa4~sa8共5个比特,可选择一个比特承载Bits时钟源的SSM级别信息。
表1-5 设置传输Bits时钟源SSM级别信息的比特位
进入系统视图 |
system-view |
clock sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 } source source-number |
可选 缺省情况下,传输Bits时钟源SSM级别信息的比特位为sa4 |
用户可以自行设置时钟源的SSM级别,但是否生效,还需遵循以下规则:
· 对于线路时钟源,设置的SSM级别为该时钟源的SSM级别。
· 对于Bits时钟源,如果输入信号为2048kbit/s(E1)信号,或输入信号为2048kbit/s信号,且执行了命令clock forcessm off source source-number,则时钟源的SSM级别为从输入信号中提取的SSM级别,设置的SSM级别被忽略。
· 对于Bits时钟源,如果输入信号为2048kHz信号,或输入信号为2048kbit/s信号,且执行了命令clock forcessm on source source-number,则设置的SSM级别为该时钟源的SSM级别。
进入系统视图 |
system-view |
设置参考源的SSM级别 |
clock ssm { dnu | lnc | prc | sets | tnc | unknown } source source-number |
必选 缺省情况下,所有参考源的SSM级别为unknown |
· SSM级别为DNU的参考源为不可用时钟源,当时钟监控模块工作在自动方式时,此类参考源不参与切换。
· 设置参考源的SSM级别后设备响应需要一定时间,可通过display clock ssm-level命令和日志信息查看配置是否生效。
不管时钟源SSM级别是从时钟信号中提取还是用户自行设定,要使SSM级别生效,还需要设置SSM是否参与控制。
· SSM参与控制:自动切换时钟源时,时钟源的级别将首先按照时钟源的SSM级别,再按照时钟源的优先级确定。
· SSM不参与控制:用户可以设置和查看SSM级别,但是在自动切换时钟源时,时钟源的SSM级别被忽略,直接照时钟源的优先级确定。
表1-7 设置SSM是否参与控制
进入系统视图 |
system-view |
设置SSM是否参与控制 |
clock ssmcontrol { on | off } |
可选 缺省情况下,时钟监控模块SSM不参与控制 |
表1-8 选择线路时钟源的输入端口
进入系统视图 |
system-view |
选择线路时钟源的输入端口 |
clock lpuport interface-type interface-number |
可选 缺省情况下,时钟源输入端口是该接口板上按用户端口名字典序排列的第一个可设置端口 |
进入接口视图 (POS接口) |
设置输入接口的时钟模式为Slave模式 |
clock slave |
可选 缺省情况下,接口的时钟模式为Slave模式 |
对于POS接口板来说,当端口的时钟工作在Slave模式下时,必须通过clock lpuport命令来设置接口板时钟源的输入端口。
在完成上述配置后,在任意视图下执行display命令可以显示配置后主控板时钟监控模块的运行情况,通过查看显示信息验证配置的效果。
表1-9 时钟监控模块显示和维护
查看时钟监控模块的当前配置 |
display clock config [ | { begin | exclude | include } regular-expression ] |
查看时钟监控模块的详细信息 |
display clock device [ | { begin | exclude | include } regular-expression ] |
查看线路板输入时钟源的端口 |
display clock lpuport [ | { begin | exclude | include } regular-expression ] |
查看时钟监控模块的锁相状态 |
display clock phase-lock-state [ | { begin | exclude | include } regular-expression ] |
查看所有参考源的优先级 |
display clock priority [ | { begin | exclude | include } regular-expression ] |
查看时钟监控模块的自检结果 |
display clock self-test-result [ | { begin | exclude | include } regular-expression ] |
查看所有参考源的状态 |
display clock source [ | { begin | exclude | include } regular-expression ] |
查看所有参考源的SSM级别 |
display clock ssm-level [ | { begin | exclude | include } regular-expression ] |
查看输出时钟信号的SSM级别 |
display clock ssm-output [ | { begin | exclude | include } regular-expression ] |
查看时钟监控模块的版本信息 |
display clock version [ | { begin | exclude | include } regular-expression ] |
查看主控板时钟监控模块的工作模式 |
display clock work-mode [ | { begin | exclude | include } regular-expression ] |
缺省情况下,以太网接口、VLAN接口及聚合接口处于DOWN状态。如果要对这些接口进行配置,请先使用undo shutdown命令使这些接口处于UP状态。
· Device A与Device B通过POS接口相连接,Device A设备的主控板上需要带时钟监控模块。
· Device A的同步时钟由主控板上的时钟监控模块提供。
· Device B上的同步时钟通过提取Device A过来的线路时钟保持同Device A的SDH线路同步。
图1-2 配置时钟监控模块组网图
(1) 配置Device A(主时钟)
# 设置POS3/1/1接口为主时钟模式,使用本地时钟信号。
[DeviceA] interface pos 3/1/1
[DeviceA-Pos3/1/1] clock master
(2) 配置Device B(从时钟)
# 配置Device B的线路时钟源输入接口为POS3/1/1。
[DeviceB] clock lpuport pos 3/1/1
# 设置接口POS3/1/1的时钟工作模式为Slave。
[DeviceB] interface pos 3/1/1
[DeviceB-Pos3/1/1] clock slave
[DeviceB-Pos3/1/1] quit
# 使从POS3/1/1提取的时钟源生效:设置时钟工作模式为手动模式,以S9508E为例,使用第8路时钟源为主用时钟源,即3号槽(线路时钟源与槽位的对应关系请参见图1-1)。
[DeviceB] clock manual source 8
通过以上设置,Device B的其他WAN接口板的同步时钟都是时钟监控模块通过3号槽位POS接口板的1号端口线路时钟提取出来的。这样保持了整个设备的各业务接口板都有一样的高精度、高可靠性的同步SDH线路接口时钟信号。
