01-Text
本章节下载: 01-Text (1.69 MB)
Safety Information/Sicherheits informationen/安全信息/安全情報/안전 정보/Informations relatives à la sécurité/ Informazioni di sicurezza/ Información de seguridad/Informações de segurança/ Қауіпсіздік туралы ақпарат/ Информация о безопасности/ Інформація з технічної безпеки/ Güvenlik Bilgileri
Regulatory Compliance Information
Regulatory compliance standards
European Directives compliance
EU Country Restriction in 2.4GHz band
EN55032, AS/NZS CISPR 32, CISPR32 compliance
BSMI Class A Warning Statement
Waste Electrical and Electronic Equipment (WEEE)
RoHS material content declarations
Turkey RoHS material content declaration
India RoHS material content declaration
Perchlorate material — Special handling may apply
List of Tables
Table 1 Safety symbol and description/Sicherheitssymbole und Beschreibung/安全标识和描述/安全記号と説明/안전 기호 및 설명/Symbole de sécurité et de Description/Simbolo di sicurezza e la Descrizione/Símbolo de seguridad y Descripción/Símbolo de segurança e da Descrição/Сақтық белгісі және оның сипаттамасы/ Символы безопасности и их описание/Позначка безпеки та її опис/ Güvenlik sembolü ve açıklaması
Table 2 Regulatory compliance standards
Table 3 Equipment may be operated in the following country:
Table 4 Frequency band and channels in Canada and USA
Warning Installation and removal of the unit and its accessories must be carried out by qualified personnel. You must read all of the Safety Instructions supplied with your equipment before installation and operation. |
Warnung Installation und Ausbau der Anlage und ihrer Zubehörteile müssen von qualifiziertem Personal realisiert werden. Sie müssen vor der Installation oder Bedienung allen beiliegenden Sicherheitshinweise lesen. |
警告 负责安装和日常维护本设备及其配件的人员必须具备安全操作基本技能。在操作本设备前,请务必认真阅读和执行产品手册规定的安全规范。 |
警告 ユニットとその付属品の設置と取り外しは、資格のある担当者が行う必要があります。設置と操作を行う前に、装置に同梱の安全の手引きすべてに目を通してください。 |
경고 장치와 해당 액세서리의 설치 및 제거는 자격을 갖춘 사람이 수행해야 합니다. 설치 및 작동 전에 장치와 함께 제공된 안전 지침을 꼼꼼히 읽어 보시기 바랍니다. |
Avertissement L'installation et le retrait de l'unité et de ses accessoires doivent être confiés à un personnel qualifié. Veillez à lire les consignes de sécurité fournies avec votre matériel avant de procéder à son installation et de l'utiliser. |
Attenzione L’installazione e la rimozione dell’unità e dei relativi accessori devono essere eseguite esclusivamente da personale qualificato. Prima di eseguire l’installazione e di azionare l’apparecchio, leggere tutte le Informazioni di sicurezza fornite. |
Advertencia La instalación y la extracción de la unidad y sus accesorios deben estar a cargo de personal calificado. Lea todas las Instrucciones de seguridad proporcionadas con el equipo antes de instalarlo y operarlo. |
Aviso A instalação e a remoção da unidade e de seus acessórios devem ser feitas por pessoal qualificado. Você deve ler todas as Instruções de Segurança que acompanham o equipamento, antes da instalação e da operação. |
Абайлаңыз Тек білікті мамандар ғана құрылғыны және оның керек-жарақтарын орнатуы және алуы тиіс. Орнатпас және пайдаланбас бұрын, жабдықпен берілетін барлық қауіпсіздік ережелерін оқып шығу қажет. |
Предупреждение. Установка и демонтаж устройства и его аксессуаров должны выполняться квалифицированными специалистами. Перед установкой и эксплуатацией необходимо ознакомиться со всеми инструкциями по безопасности, прилагаемыми к оборудованию. |
Увага! Установлення та демонтаж пристрою та його аксесуарів має виконуватися кваліфікованими спеціалістами. Перш ніж установлювати пристрій і починати роботу з ним, ознайомтеся з інструкціями з техніки безпеки. |
Uyarı Birimin ve aksesuarlarının kurulumu ve sökümü kalifiye personel tarafından yapılmalıdır. Kurulum ve çalıştırma öncesinde, ekipmanınızla birlikte verilen Güvenlik Talimatlarının tamamını mutlaka okuyun. |
Note Before any operation is performed, please read the operation instructions and precautions carefully to minimize the possibility of accidents. The Note, Caution, Warning and Danger items in other manuals do not cover all safety precautions that should be followed. They are only the supplements to the safety precautions for operations as a whole. Therefore, the personnel in charge of the installation and maintenance of the products are required to understand these basics of safety operation. In performing various operations, please follow the local safety regulations. The safety precautions introduced in the product manuals are supplementary and subject to the local safety regulations. When various operations are executed on the products, the precautions and special safety instructions provided with the products must be followed to the full. The personnel in charge of the installation and maintenance of the products must be trained as professionals to master the proper operating methods and all safety precautions. Only the trained and qualified personnel can perform operations such as equipment installation and maintenance. |
Anmerkung Lesen Sie bitte alle Bedienungsanweisungen und Sicherheitvorschriften sorgfältig durch, bevor Sie das Gerät in Betrieb nehmen. Nur durch Beachtung dieser Hinweise lässt sich das Unfallrisiko minimieren. Die in anderen Handbüchern aufgeführten Anmerkungen, Achtungen, Warnungen und Gefahren beinhalten nicht alle zu beachtenden Sicherheitvorschriften. Sie dienen lediglich als Ergänzung. Deshalb muss sich das für die Installation und Instandhaltung der Ausrüstung verantwortliche Personal mit allen Sicherheitshinweisen vertraut machen. Bei verschiedenen Bedienungen müssen außerdem die örtlichen Sicherheitsvorschriften beachtet werden. Die in den Handbüchern der einzelnen Produkte aufgeführten Sicherheitshinweise sind Ergänzungen und unterliegen den nationalen Sicherheitsvorschriften. Bei verschiedenen Bedienungen mit den Produkten sind deshalb grundsätzlich alle Sicherheitsvorschriften und spezifischen Sicherheitshinweise genau zu beachten. Das für die Installation und Instandhaltung der Produkte verantwortliche Personal muss geschult werden, damit sie alle Sicherheitsvorschriften kennen und die Produkten richtig bedienen zu können. Nur geschultes und qualifiziertes Personal kann die Installation und Instandhaltung in korrekter Weise durchführen. |
说明 为了避免可能发生的事故,请在进行任何操作前,仔细阅读设备安装手册和本章节的安全规范。手册中 出现的说明、注意、警告、危险,不能涵盖所有的安全预防,仅仅是在整个操作过程中的安全提示和补充。因此,负责安装和日常维护本设备的人员必须具备安全操作基本技能。 操作人员要按照当地的安全规范进行操作。出现在产品手册中的安全预防措施仅仅是当地安全规范的补充。 在操作本设备时,请认真执行产品手册规定的安全规范。 设备安装、维护人员必须通过专业培训,并且掌握足够的操作技能和安规预防意识。只有专业人员才能担任本设备的安装和维护工作。 |
メモ 操作を始める前は常に、操作指示書と注意事項によく目を通し、事故の可能性を最小限にしてください。その他のマニュアルにあるメモ、注意、警告、危険の各項目は、従うべき安全上の注意事項をすべて網羅しているわけではありません。これらは、操作全般に対する安全上の注意事項を補足するものに過ぎませんしたがって、製品の設置とメンテナンスに責任を持つ担当者は、安全な操作のためのこれらの基礎を理解しておく必要があります。 さまざまな操作を行う際において、現地の安全規制に従ってください。製品マニュアルで紹介されている安全上の注意は補足的なものであり、現地の安全規制により変わる場合があります。 製品に対しさまざまな操作を実行する際において、製品に付属の注意事項と安全に関する特記事項を完全に厳守する必要があります。 製品の設置とメンテナンスを行う担当者は、専門のトレーニングを受け、正しい操作方法と安全上の注意事項をすべて習熟しておく必要があります。トレーニングを受け、認定された担当者だけが、装置の設置やメンテナンスなどの作業を行うことができます。トレーニングを受け、認定された担当者だけが、装置の設置やメンテナンスなどの運用を行うことができます。 |
참고 작업을 시작하기 전에 작업 지침 및 예방책을 자세히 살펴보고 사고 발생 가능성을 최소화하십시오. 다른 설명서의 참고, 주의, 경고 및 위험 항목에서는 준수해야 하는 일부 안전 예방책을 다루지 않습니다. 이러한 항목은 전체 작업의 안전 예방책에 대한 보충 정보만 제공합니다. 따라서 제품 설치 및 유지 보수 담당자는 이러한 안전 작업의 기본 사항을 이해해야 합니다. 여러 작업을 수행할 때 현지 안전 규정을 따르십시오. 제품 설명서에 소개된 안전 예방책은 보충적인 자료로 사용되며 현지 안전 규정의 적용을 받습니다. 제품에서 여러 작업을 실행할 때 제품과 함께 제공되는 예방책 및 특별 안전 지침을 충실히 준수해야 합니다. 제품 설치 및 유지 보수 담당자는 적절한 작동 방법 및 모든 안전 예방책을 완벽히 이해하는 전문가로서 교육을 받아야 합니다. 교육을 받고 자격을 갖춘 사람만 장치 설치 및 유지 보수와 같은 작업을 수행할 수 있습니다. |
Remarque Afin de réduire le risque d'accident, prenez connaissance des instructions et des précautions d'utilisation avant toute opération. Les sections Remarque, Mise en garde, Avertissement et Danger figurant dans les autres manuels ne couvrent pas la totalité des précautions de sécurité devant être respectées. Elles servent uniquement de complément aux précautions de sécurité générales. Il est par conséquent indispensable que le personnel chargé de l'installation et de la maintenance des produits connaissent les principes de base des opérations de sécurité. Dans le cadre des opérations, veillez à respecter la réglementation locale en matière de sécurité. Les précautions de sécurité figurant dans la documentation des produits viennent en complément de la réglementation locale en vigueur. Lorsque diverses opérations sont effectuées sur les produits, les précautions et consignes spéciales de sécurité doivent être scrupuleusement respectées. Le personnel en charge de l'installation et de la maintenance des produits doit être dûment formé aux méthodes d'exploitation et aux précautions de sécurité. Seul le personnel formé et qualifié est en mesure de procéder à des opérations telles que l'installation et la maintenance du matériel. |
Nota Prima di eseguire qualsiasi operazione, leggere attentamente le relative istruzioni e precauzioni per ridurre al minimo la possibilità di incidenti. Gli elementi Nota, Avvertenza, Attenzione e Pericolo in altri manuali non trattano tutte le precauzioni di sicurezza che è necessario adottare. Si tratta esclusivamente di integrazioni alle precauzioni di sicurezza sul funzionamento nel suo complesso. Il personale incaricato dell’installazione e della manutenzione dei prodotti è quindi tenuto a comprendere i fondamenti delle operazioni di sicurezza. Nell’esecuzione delle varie operazioni, seguire le normative locali sulla sicurezza. Le precauzioni di sicurezza introdotte nei manuali del prodotto sono integrative e soggette alle normative locali sulla sicurezza. Quando vengono eseguire operazioni sui prodotti, le precauzioni e le istruzioni speciali di sicurezza in dotazione ai prodotti devono essere adottate in ogni loro parte. Il personale incaricato dell’installazione e della manutenzione dei prodotti deve essere composto da professionisti addestrati ad eseguire con sicurezza i corretti metodi di funzionamento e tutte le precauzioni di sicurezza. Operazioni quali l’installazione e la manutenzione dell’apparecchiatura sono riservati esclusivamente a personale qualificato e addestrato. |
Nota Antes de cualquier operación, lea las precauciones y las instrucciones de operación atentamente para reducir la posibilidad de accidentes. Las secciones Nota, Precaución, Advertencia y Peligro de otros manuales no cubren todas las precauciones de seguridad que deberían tenerse. Son sólo complementos para las precauciones de seguridad de la operación general. Por ende, el personal a cargo de la instalación y el mantenimiento de los productos debe conocer estas pautas básicas para la operación segura. Al realizar diferentes operaciones, respete las normas de seguridad locales. Las precauciones de seguridad señaladas en los manuales de los productos son complementos y están sujetas a las normas de seguridad locales. Cuando se llevan a cabo diferentes operaciones en los productos, deben respetarse totalmente las precauciones y las instrucciones de seguridad especiales proporcionadas junto con ellos. El personal a cargo de la instalación y el mantenimiento de los productos debe estar formado por profesionales capacitados para dominar los métodos de operación correctos y todas las precauciones de seguridad. Únicamente personal capacitado y calificado puede encargarse de operaciones como la instalación y el mantenimiento del equipo. |
Observação Antes de executar qualquer operação, leia as instruções e precauções de operação atentamente, para minimizar as chances de acidentes. Os itens Observação, Cuidado, Aviso e Perigo nos outros manuais não cobrem todas as precauções de segurança que devem ser seguidas. Eles são apenas complementos para as precauções de segurança para as operações, como um todo. Assim, o pessoal responsável pela instalação e manutenção dos equipamentos deve estar ciente dessas instruções básicas de funcionamento seguro. Ao operar o equipamento, siga as regulamentações de segurança locais. As precauções de segurança apresentadas nos manuais do produto são complementares e sujeitas às regulamentações de segurança locais. Ao operar o equipamento, siga atentamente as precauções e instruções especiais de segurança que acompanham o equipamento. O pessoal responsável pela instalação e manutenção dos equipamentos deve ter treinamento profissional para dominar os métodos de operação e todas as precauções de segurança. Somente o pessoal treinado e qualificado pode executar operações como instalação e manutenção do equipamento. |
Ескертпе Мүмкін оқиғаларды болдырмау үшін, пайдаланудың алдында пайдалану жөнінде нұсқауларды және сақтық шараларын мұқият оқыңыз. Орындалуы тиіс барлық сақтық шараларының барлығы басқа пайдалану нұсқаулықтарында берілетін Ескертпе, Ескерту, Абайлаңыз және Қауіп бөлімдерінде қамтылмайды. Олар жалпы пайдалануға арналған сақтық шараларын ғана толықтырады. Осыған байланысты, құрылғыны орнату және оған күтім көрсету үшін жауапты мамандар қауіпсіз пайдаланудың бұл негізгі ережелерін түсінуі тиіс. Түрлі әрекеттерді жүзеге асыру кезінде жергілікті сақтық ережелерін орындаңыз. Сақтық шаралары өнімді пайдалану нұсқаулықтарында қосымша түрде беріледі және жергілікті сақтық ережелері басым болады. Құрылғылар арқылы түрлі әрекеттерді жүзеге асыру кезінде құрылғылармен бірге жеткізілетін сақтық шараларын және арнайы сақтық нұсқауларын толығымен орындау қажет. Құрылғыларды орнатуға және күтім көрсетуге жауапты қызметкерлер дұрыс пайдалану әдістерін және барлық сақтық шараларын үйрену үшін маман ретінде дайындалуы тиіс. Тек дайындалған және білікті мамандарға ғана жабдықты орнату және оған күтім көрсету сияқты әрекеттерді жүзеге асыруға болады. |
Примечание. Перед работой внимательно прочитайте инструкции по эксплуатации и меры предосторожности, чтобы минимизировать вероятность возникновения несчастных случаев. Замечания с пометками «Примечание», «Внимание», «Предупреждение» и «Опасно» в других руководствах не охватывают все меры предосторожности, которые необходимо соблюдать. Они являются всего лишь дополнением к полному списку мер предосторожности при работе. Поэтому сотрудники, выполняющие установку и обслуживание продуктов, должны понимать основы безопасной эксплуатации. При выполнении различных операций соблюдайте местные правила безопасности. Меры предосторожности, перечисленные в руководствах продуктов, являются дополнительными и должны соответствовать местным правилам безопасности. При выполнении различных операций с продуктами необходимо полностью соблюдать меры предосторожности и специальные инструкции по безопасности, прилагаемые к продуктам. Сотрудники, выполняющие установку и обслуживание продуктов, должны быть высококвалифицированными специалистами, чтобы применять правильные методы эксплуатации и все меры предосторожности. Только обученные и квалифицированные сотрудники могут выполнять такие операции, как установка и обслуживание. |
Примітка. Перш ніж починати роботу із пристроєм, уважно прочитайте інструкції та попередження, щоб уникнути нещасних випадків. Інформація, що надається в інших посібниках із позначками "Примітка", "Попередження", "Увага" та "Небезпека!", не є вичерпною та не охоплює всіх заходів безпеки, яких слід уживати. Вона лише доповнює заходи безпеки, описані в основному документі. Тому персонал, відповідальний за установлення й обслуговування продуктів, має ознайомитися з описаними тут основами з охорони праці та зрозуміти їх. Під час операцій завжди дотримуйтеся вимог місцевого законодавства. Заходи безпеки, описані в посібниках до продукту, уважаються доповненнями до місцевих норм безпеки. Під час роботи із продуктами слід уживати всіх заходів безпеки та дотримуватися всіх наданих інструкцій. Персонал, відповідальний за установлення й обслуговування продуктів, має складатися зі спеціально навчених спеціалістів, яким відомі належні методи роботи з обладнанням та всі необхідні заходи безпеки. Операції з обладнанням, зокрема його установлення й обслуговування, може виконувати лише спеціально навчений і кваліфікований персонал. |
Not Kaza riskini en aza indirmek için, lütfen herhangi bir işlem yapmadan önce çalıştırma talimatlarını ve önlemleri dikkatle okuyun. Diğer el kitaplarında yer alan Not, Dikkat, Uyarı ve Tehlike öğeleri, uyulması gereken tüm güvenlik önlemlerini kapsamamaktadır. Bunlar yalnızca, tüm çalıştırma faaliyetleri için alınacak önlemleri tamamlayıcı niteliktedir. Bu sebeple, ürünlerin kurulumundan ve bakımından sorumlu personelin, güvenli çalıştırmaya dair temel bilgileri anlaması gerekmektedir. Çeşitli işlemleri gerçekleştirirken, lütfen yerel güvenlik düzenlemelerine uyun. Ürün el kitaplarında bulunan güvenlik önlemleri tamamlayıcı niteliktedir ve yerel güvenlik düzenlemelerine tabidir. Ürünlerde çeşitli işlemler gerçekleştirilirken, ürünlerle birlikte verilen önlemler ve özel güvenlik talimatlarına tam olarak uyulmalıdır. Ürünlerin kurulumundan ve bakımından sorumlu personel, uygun çalıştırma yöntemlerine ve tüm güvenlik önlemlerine hakim olmaları için uzmanlar olarak eğitimden geçirilmelidir. Ekipmanın kurulumu ve bakımı gibi işlemleri, yalnızca eğitimli ve kalifiye personel yapabilir. |
The symbols in this manual are shown in the following table. They are used to remind the reader of the safety precautions during equipment installation and maintenance.
Die in diesem Handbuch verwendeten Symbole sind in der folgenden Tabelle dargestellt. Diese Symbole sollen das Personal während der Installation und Instandhaltung der Ausrüstung an die Wichtigkeit der im Handbuch aufgeführten Sicherheitsvorschriften erinnern.
以下表格中的安全标识,是用来提示读者在进行设备安装和维护时的安全预防要求。
このマニュアルで使用される記号は、次の表のとおりです。これらの記号は、装置の設置やメンテナンスの作業中に安全上の注意を喚起させるために使用されます。
아래 표에는 본 설명서에서 사용되는 기호가 표시되어 있습니다. 이러한 기호는 장치 설치 및 유지 보수 중에 안전 예방책을 상기시키는 데 사용됩니다.
Le tableau suivant répertorie les symboles utilisés dans ce manuel. Ils servent de rappel lors des opérations d'installation et de maintenance.
I simboli contenuti in questo manuale vengono illustrati nella tabella seguente. Vengono utilizzati per ricordare ai lettori l’esistenza delle precauzioni di sicurezza da adottare durante l’installazione e la manutenzione dell’apparecchiatura.
Los símbolos empleados en este manual se presentan en la tabla siguiente. Se usan para recordar al lector las precauciones de seguridad durante la instalación y el mantenimiento del equipo.
Os símbolos deste manual são mostrados na tabela a seguir. Eles são usados para lembrar o leitor das precauções de segurança durante a instalação e manutenção do equipamento.
Осы нұсқаулықта қолданылатын белгілер мына кестеде көрсетіледі. Олар пайдаланушыны құрылғыны орнату және оған күтім көрсету кезінде сақтық шаралары туралы ескерту үшін пайдаланылады.
Следующая таблица содержит символы, используемые в данном руководстве. Они используются, чтобы напомнить читателю о мерах предосторожности, которые необходимо соблюдать во время установки и обслуживания оборудования.
У таблиці нижче представлені всі умовні позначки, що використовуються в цьому посібнику. Вони служать нагадуванням про заходи безпеки, яких слід уживати під час установлення й обслуговування обладнання.
Bu el kitabında yer alan semboller, aşağıdaki tabloda gösterilmiştir. Bu semboller, ekipmanın kurulumunda ve bakımında uygulanacak güvenlik önlemlerini okuyucuya hatırlatmak için kullanılmaktadır.
Safety Symbol Symbole 安全标识 安全記号 안전 기호 Symbole de sécurité Simbolo di sicurezza Símbolo de seguridad Símbolo de seguranç Сақтық белгісі Символ безопасности Позначка безпеки Güvenlik Sembolü |
Description Erläuterung 描述 説明 설명 Description Descrizione Descripción Descrição Сипаттама Описание Опис Açıklama |
Generic alarm symbol: To suggest a general safety concern. Alarm: Hinweis auf ein generelles Sicherheitsproblem. 一般注意标识:用于一般安全提示。 一般的な注意喚起のための記号:一般的な事において安全でない可能性があることを示唆。 일반 경보 기호: 일반적인 안전 관련 사안을 제공합니다. Symbole d'alarme générique: indique un problème de sécurité générale. Simbolo generico di allarme: indica un problema generale di sicurezza. Símbolo de alarma general: Hace referencia a una cuestión de seguridad general. Símbolo de aviso genérico: Para indicar preocupação de segurança geral. Жалпы ескерту белгісі: Жалпы сақтық мәселесін білдіреді. Общий символ предупреждения. Означает общую угрозу безопасности. Загальне попередження: указує на фактор небезпеки, що носить загальний характер. Genel alarm sembolü: Genel bir güvenlik endişesini gösterir. |
ESD protection symbol: To suggest electrostatic-sensitive equipment. ESD-Schutz: Hinweis auf ESD-gefährdete Bauteile. 防静电标识:用于表示设备对静电敏感。 ESD 保護に関する記号:静電気に弱い装置であることを示唆。 ESD 보호 기호: 정전기에 민감한 장치를 알려 줍니다. Protection contre les décharges électrostatiques: indique la présence d'éléments sensibles à l'électricité statique. Simbolo di protezione ESD: indica apparecchiature sensibili alle scariche elettrostatiche. Símbolo de protección contra descargas electrostáticas: Hace referencia a equipos sensibles a las descargas electrostáticas. Símbolo de proteção ESD: Para indicar equipamento sensível à eletricidade estática. Электростатикалық разрядтан қорғау белгісі: Электростатикалық разрядқа (ESD) сезгіш жабдықты білдіреді. Символ защиты от электростатического разряда. Означает, что оборудование чувствительно к статическому электричеству. Захист від статичної електрики: указує на обладнання, чутливе до статичної електрики. ESD koruma sembolü: Elektrostatiğe duyarlı ekipmanı gösterir. |
Electric shock symbol: To suggest a danger of hazardous Voltage. Elektrischer Schlag: Zeigt Gefährdungen durch gefährliche Spannungen an. 电击防护标识:用于表示高压危险。 電気ショック記号:危険電圧の恐れがあることを意味します。 감전 표시: 위험 전압을 주의하라는 표시입니다. Symbole de choc électrique: Pour suggérer un risque de tension dangereuse. Simbolo di scossa elettrica: per suggerire il rischio derivante da una tensione pericolosa. Símbolo de descarga eléctrica: Para sugerir el peligro de una descarga eléctrica. Símbolo de choque elétrico: Para sugerir um risco de voltagem perigosa. Электр тогына түсу туралы ескертетін белгі: Қатерлі кернеу қаупін білдіреді. Символ поражения электрическим током. Означает опасность, связанную с высоким напряжением. Ураження електричним струмом: указує на ризик ураження електричним струмом. Elektrik şoku sembolü: Tehlikeli Voltaj düzeyi tehlikesi olduğunu gösterir. |
Caution: You must read all of the installation instructions in the Installation Guide supplied with your equipment and the following safety instructions before installation or operation. Achtung: Sie müssen vor der Installation oder Bedienung das mit Ihrer Anlage mitgelieferten Installationshandbuch und die folgende Sicherheitshinweise lesen. 注意:在安装和操作本设备时,务必阅读设备安装手册的内容,以及下文的所有安全说明。 注意:設置や操作の前に、装置に同梱の設置ガイドに記載された設置の手引きを読み、次に示す安全上の手引きにもすべて目を通してください。 주의: 설치 및 작동 전에 장치와 함께 제공된 설치 안내서의 설치 지침 및 다음 안전 지침을 모두 숙지해야 합니다. Mise en garde: avant l'installation ou l'exploitation de votre matériel, veillez à lire la totalité des instructions d'installation figurant dans le guide d'installation correspondant. Avvertenza: prima di eseguire l’installazione e di azionare l’apparecchio, leggere tutte le istruzioni sull’installazione e la Guida di installazione in dotazione all’apparecchio oltre alle seguenti istruzioni di sicurezza. Precaución: Antes de la instalación y la operación, debe leer todas las instrucciones Cuidado: Você deve ler todas as instruções de instalação no Guia de Instalação que acompanha o equipamento e estas instruções de segurança, antes de instalar ou operar o equipamento. Ескерту: Жабдықпен бірге жеткізілетін Орнату жөнінде нұсқаулығындағы барлық орнату нұсқауларын және сақтық нұсқауларын орнатудың немесе пайдаланудың алдында оқыңыз. Внимание! Перед установкой и эксплуатацией необходимо прочитать все инструкции и руководства по установке, прилагаемые к оборудованию, а также следующие инструкции по безопасности. Попередження. Перш ніж починати установлення або роботу із пристроєм, обов’язково прочитайте інструкції в посібнику з установлення та наведені нижче інструкції з техніки безпеки. Dikkat: Kurulumdan veya çalıştırmadan önce ekipmanınızla birlikte verilen Kurulum Kılavuzunda yer alan tüm kurulum talimatlarını ve aşağıdaki güvenlik talimatlarını mutlaka okuyun. |
WARNING: Installation and removal of the unit and its accessories must be carried out by qualified personnel. Warnung: Installation und Ausbau der Einheit und ihrer Zubehörteile müssen von qualifiziertem Personal durchgeführt werden. 警告:必须由专业人员来安装和移动设备以及附件。 警告:このユニットとその付属品の設置および取り外しは、資格のある担当者が行う必要があります。 경고: 장치와 해당 액세서리의 설치 및 제거는 자격을 갖춘 사람이 수행해야 합니다. AVERTISSEMENT: l'installation et le retrait de l'unité et de ses accessoires doivent être confiés à un personnel qualifié. ATTENZIONE: l’installazione e la rimozione dell’unità e dei relativi accessori devono essere eseguite esclusivamente da personale qualificato. ADVERTENCIA: La instalación y la extracción de la unidad y sus accesorios deben estar a cargo de personal calificado. AVISO: A instalação e a remoção da unidade e de seus acessórios devem ser feitas por pessoal qualificado. АБАЙЛАҢЫЗ: Білікті мамандар құрылғыны және оның керек-жарақтарын орнатуы және алуы тиіс. ОСТОРОЖНО! Установка и демонтаж устройства и его аксессуаров должны выполняться квалифицированными специалистами. УВАГА! Установлення й демонтаж пристрою та його аксесуарів має виконуватися кваліфікованими спеціалістами. UYARI: Birimin ve aksesuarlarının kurulumu ve sökümü kalifiye personel tarafından gerçekleştirilmelidir. |
Caution: Do not block ventilation openings while the system is on, and keep at least 10 cm distance from ventilation openings and walls or other things which may block the openings. Achtung: Blockieren Sie die Lüftungsmündungen nicht, wenn das System läuft. Stellen Sie die Lüftungsmündungen mindestens 10 cm entfernt von den Wänden oder anderen Sachen, die die Mündungen blockieren können. 注意:设备在工作时必须确保通风口的畅通,确保设备离墙壁或是其它的可能堵塞通风口的物体的间距至少10cm。 注意:システムがオンの間は換気口をふさがないでください。また、換気口と壁などの障害物との間は少なくとも 10 cm 空けてください。 주의: 시스템이 켜져 있는 동안 통풍구를 막지 말고 통풍구 및 벽 또는 통풍구를 막을 수 있는 기타 대상으로부터 최소 10cm의 거리를 유지해야 합니다. Mise en garde: n'obstruez pas les ouvertures de ventilation lorsque le système est sous tension et maintenez une distance d'au moins 10 cm entre les ouvertures de ventilation et la paroi murale ou d'autres objets susceptibles de les bloquer. Avvertenza: non bloccare le aperture di ventilazione mentre il sistema è attivo e tenere una distanza di almeno 10 cm dalle aperture di ventilazione e dalle pareti e altri oggetti che potrebbero bloccare le aperture. Precaución: No bloquee los orificios de ventilación cuando el sistema esté encendido, y deje al menos 10 cm entre estos orificios y las paredes u otros elementos que puedan bloquearlos. Cuidado: Não bloqueie as entradas de ventilação com o sistema ligado e mantenha uma distância de, pelo menos, 10 cm entre essas entradas e paredes ou outros obstáculos que possam bloquear as entradas. Ескерту: Жүйе қосулы кезде желдеткіш саңылауларды бітемеңіз. Желдеткіш саңылаулар мен қабырғалар немесе саңылауларды бітеуі мүмкін затт ардың арасында 10 cм арақашықтықты сақтаңыз. Внимание! Не закрывайте вентиляционные отверстия во время работы системы. Оставьте не менее 10 см между вентиляционными отверстиями и стенами или другими предметами, которые могут закрыть эти отверстия. Попередження. Не затуляйте вентиляційні отвори, коли система працює: навколо них має залишатися принаймні 10 см вільного простору. Dikkat: Sistem açıkken havalandırma boşluklarını kapatmayın ve havalandırma boşluklarıyla duvar veya bunları kapayabilecek diğer şeyler arasında en az 10 cm mesafe bırakın. |
Warning: The separate earthing terminal must be permanently connected to earth. Warnung: Die separate Erdungsschiene muss dauerhaft geerdet sein. 警告:单独的接地端子必须永久连接到地。 警告:分離した接地端子は恒久的に接地しておく必要があります。 경고: 별도의 접지 단자를 접지에 영구적으로 연결해야 합니다. AVERTISSEMENT: la mise à la masse isolée doit rester connectée à la terre en permanence. ATTENZIONE: il terminale di terra separato deve essere sempre collegato a terra. ADVERTENCIA: La terminal de conexión a tierra independiente debe estar conectada permanentemente a la tierra. AVISO: O terminal de aterramento separado deve ficar permanentemente conectado ao terra. Абайлаңыз: Жерге тұйықталатын бөлек терминал жерге бір жолға қосылуы тиіс. Предупреждение. Отдельная клемма заземления должна быть всегда подсоединена к «земле». Увага! Дріт заземлення має бути весь час підключено до клеми заземлення. Uyarı: Ayrı duran topraklama bağlantı ucu her zaman toprağa bağlı olmalıdır. |
Caution: The protective earthing / grounding conductor packaged with this product should be appropriately modified by a qualified electrician to lengths where required by local regulations. The conductor should be cut to length, and terminated with a suitably certified connector. Note that for rack mounted equipment the conductor must be terminated within the rack enclosure grounding system. The supplemental grounding cable must be maintained within the rack system at all times. Achtung: Der im Lieferumfang dieses Produkts enthaltene Schutzleiter/Erdungsleiter muss von einem qualifizierten Elektriker auf die entsprechende Länge gekürzt werden, sofern von lokalen Bestimmungen und Richtlinien verlangt. Der Schutzleiter sollte auf die korrekte Länge zugeschnitten und mit einem geeigneten zertifizierten Anschluss terminiert werden. Beachten Sie, dass bei Rack montierten Geräten die Leiter innerhalb des Erdungssystems des Rackgehäuses mit einem Abschlusswiderstand versehen werden müssen. Das zusätzliche Erdungskabel muss innerhalb des Rack-Systems stets instandgehalten werden. 注意:包装在本产品中的保护接地导体必须由合格的电工按照当地法规要求对长度进行适当的修改。该导体需要被切到适当的长度,并端接在一个通过认证的适当的连接器上。请注意,安装在机架上的设备,其保护接地导体必须端接在机架外壳的接地系统内。辅助接地电缆必须一直保持在机架系统内。 注意: この製品に付属の保護アース/接地線は、認定電気技術者が現地規制に適合する長さに適切な方法で変更する必要があります。 導体を相応の長さに切り、適切に認定されたコネクタで終端する必要があります。 装置がラックマウントされている場合、導体はラック エンクロージャ内のアース システム内で終端する必要があります。 ラック システム内に予備のアース ケーブルを常備しておく必要があります。 주의: 자격을 갖춘 전기 기술자가 본 제품과 함께 제공된 보호 접지 / 접지 도체를 현지 규정에서 요구하는 길이로 적절하게 수정해야 합니다. 도체를 해당 길이로 절단하고, 적합한 커넥터로 종단시켜야 합니다. 랙 장착 장비의 경우, 랙 인클로저 접지 시스템 내에서 도체를 종단시켜야 함을 유념하십시오. 항상 보조 접지 케이블을 랙 시스탬 내에 유지해야 합니다. Attention: le conducteur de terre de protection livré avec ce produit doit être correctement modifié par un électricien qualifié à des longueurs définies conformément aux réglementations locales. Le conducteur de terre doit être coupé à la longueur appropriée, et terminé avec un connecteur disposant de la certification adéquate. Notez que pour l'équipement monté en rack, le conducteur doit être terminé à l'intérieur du système de mise à la terre du boîtier du rack. Le câble de mise à la terre supplémentaire doit être maintenu en permanence dans le système de rack. Attenzione: la lunghezza del conduttore di messa a terra incluso nella confezione di questo prodotto deve essere correttamente modificata da un elettricista specializzato, qualora sia richiesto dalle normative locali. Il conduttore deve essere tagliato a misura e dotato di terminazione con un connettore certificato adatto. Tenere presente che per le apparecchiature montate a rack il conduttore deve disporre di terminazione all'interno del sistema di messa a terra del contenitore a rack. Il cavo di messa a terra supplementare deve sempre essere mantenuto all'interno del sistema rack. Precaución: El conductor de protección de conexión a tierra suministrado con este producto debería ser modificado como corresponde por un electricista calificado para la longitud que exijan las regulaciones locales. El conductor debería cortarse tras una determinada longitud y cerrarse con un conector certificado adecuado. Recuerde que, para equipos montados en bastidor, el conductor debe cerrarse dentro del sistema de conexión a tierra de la carcasa del bastidor. El cable de conexión a tierra complementario debe mantenerse en todo momento dentro del sistema del bastidor. Cuidado: o condutor de aterramento protetor incluído na embalagem do produto deve ser adequadamente modificado, por um eletricista qualificado, com o comprimento exigido pelas regulamentações locais. O condutor deverá ser cortado no comprimento correto e terminar com um conector adequadamente certificado. Observe que, no caso de equipamentos montados em rack, o condutor deverá terminar dentro do sistema de aterramento do compartimento do rack. O cabo de aterramento complementar deverá ser mantido sempre dentro do sistema de rack. Абайлаңыз: Осы өніммен берілген қорғаныс жерге тұйықтау / жерге қосу өткізгішін жергілікті заңдары талап етілетін орында ұзарту үшін кәсіби маман арқылы орындалу керек. Өткізгіштің ұзындығын кесу және ыңғайлы бекітілген қосқышпен тұйықтау керек. Тірекке орнатылған жабдықта өткізгішті тіректегі жерге тұйықтау жүйесінде аяқтау керек. Қосышма жерге тұйықтау кабелін барлық уақытта тірек жүйесінде жүзеге асыру керек. Внимание! Поставляемый с данным продуктом защитный провод заземления должен быть изменен соответствующим образом квалифицированным электриком до необходимой длины, которая требуется согласно местным регулятивным органам. Проводник следует обрезать до необходимой длины и на конце подключить подходящий сертифицированный разъем. Следует иметь в виду, что для оборудования, устанавливаемого в стойку, оконечное подключение должно выполняться внутри системы заземления корпуса стойки. Внутри системы стойки должен постоянно находиться дополнительный кабель заземления. Увага! Довжина провідника захисного заземлення, що постачається в комплекті з цим виробом, має бути відрегульована кваліфікованим електриком згідно з місцевими нормами. Провідник слід обрізати до необхідної довжини, а потім підключити до роз’єму, що пройшов відповідну сертифікацію. Зверніть увагу на те, що у разі монтажу обладнання на стійці, цей провідник має бути підключено до системи заземлення корпусу стійки. У системі стійки завжди має бути додатковий кабель заземлення. Uyarı: Bu ürünle birlikte paketlenen koruyucu topraklama iletkeni, yerel düzenlemelerin şart koştuğu durumlarda, kalifiye bir elektrikçi tarafından gereken uzunluğa getirilmelidir. İletken, gereken uzunlukta kesilmeli ve ucunda uygun sertifikaya sahip bir konektör bulunmalıdır. Rafa monte edilen ekipmanlarda iletkenin mutlaka raf muhafazası topraklama sistemi içinde sonlandırılması gerektiğini unutmayın. Ek topraklama kablosu her zaman raf sisteminin içinde muhafaza edilmelidir. |
Warning: When installing the unit, always make the ground connection first and disconnect it last. Never defeat the ground conductor or operate the equipment in the absence of a suitably installed ground conductor. Check installation before operation. Warnung: Beachten Sie, dass bei der Installation des Systems stets zuerst die Erdverbindung angebracht wird und die Erdverbindung stets als letztes getrennt wird. Betreiben Sie die Ausrüstung niemals ohne eine passende, installierte Erdung. Trennen Sie das System nicht von der Erdung. Überprüfen Sie die Erdung vor der Inbetriebnahme. 警告:进行设备安装时,必须确保接地连接是最先连接和最后断开。不允许破坏设备的接地导线或是在无接地连接的情况下操作设备,操作前要进行检查。 警告:ユニットを設置するときは、必ず最初にアースを接続し、またアースを最後に外すようにしてください。接地導体を破損させたり、適切に取り付けられた接地導体のない状態で装置を操作したりしないでください。設置状況を使用前に確認してください。 경고: 장치를 설치할 때 항상 처음에 접지한 후 맨 나중에 접지를 해제해야 합니다. 접지 도체를 손상시키거나 접지 도체를 적절히 설치하지 않은 상태에서 장치를 작동해서는 안 됩니다. 작동 전에 설치 상태를 확인하십시오. AVERTISSEMENT: lors de l'installation de l'unité, veillez à effectuer d'abord le branchement à la terre. Déconnectez le câble secteur en dernier lorsque vous mettez l'unité hors tension. Ne bloquez jamais le conducteur à la terre et évitez de manipuler le matériel en l'absence d'une prise à la terre correctement installée. Vérifiez l'état de l'installation avant de commencer une opération. ATTENZIONE: durante l’installazione dell’unità, innestare sempre per prima e disconnettere per ultima la connessione di terra. Non annullare mai il conduttore di terra né azionare l’apparecchiatura in assenza di un conduttore di terra correttamente installato. Prima di azionare, verificare l’installazione. ADVERTENCIA: Al instalar la unidad, siempre lo primero que debe establecer y lo último que debe desconectar es la conexión a tierra. Nunca anule el conductor a tierra ni opere el equipo sin un conductor a tierra bien instalado. Revise la instalación antes de operar. AVISO: Ao instalar a unidade, sempre faça primeiro a conexão com o terra e a desconecte por último. Nunca desconecte o terra ou opere o equipamento sem um condutor de terra instalado adequadamente. Verifique a instalação, antes de operar o equipamento. Абайлаңыз: Құрылғыны орнату кезінде алдымен жерге қосып та, ең соңғы ажырату қажет. Жерге қосу сымын ешқашан алмаңыз немесе жерге қосу сымы дұрыс орнатылмаған жабдықты ешқашан пайдаланбаңыз. Пайдаланбас бұрын орнатуды тексеріңіз. Предупреждение. Во время установки устройства всегда сначала устанавливайте заземляющее соединение и отсоединяйте его в последнюю очередь. Никогда не отключайте проводник заземления и не используйте оборудование без подходящего установленного проводника заземления. Перед работой выполните проверку установки. Увага! Під час установлення пристрою заземлення має підключатися першим і відключатись останнім. Ніколи не працюйте з обладнанням без підключеного дроту заземлення. Перед початком роботи перевірте правильність установлення обладнання. Uyarı: Birimi kurarken her zaman ilk olarak toprak bağlantısını takın ve en son onu sökün. Topraklama iletkenini asla çıkarmayın veya ekipmanı uygun şekilde bağlanmış bir topraklama iletkeni olmadan çalıştırmayın. Çalıştırmadan önce kurulumu kontrol edin. |
Warning: For SELV DC input: the DC power source shall comply with the Safety Extra-Low Voltage (SELV) requirements of IEC 60950-1. Warnung: Mit Gleichstrom betriebenes Modell: Das Gerät arbeitet mit Gleichstrom, wobei die Anforderungen der Norm (IEC60950-1) für Schutzkleinspannung eingehalten werden müssen. 警告:SELV DC电源输入:设备使用满足IEC60950-1安规标准的安全特低电压(SELV)电源。 警告:SELV DC 入力の場合: DC 電源は、安全特別低電圧 (SELV) 要件 (IEC 60950-1) に適合するものとします。 경고: SELV DC 입력: DC 전원은 IEC 60950-1의 SELV(안전 초저전압)를 준수해야 합니다. Avertissement: pour l’entrée CC SELV: la source d'alimentation en CC doit être conforme aux exigences relatives aux très basses tensions (SELV) des normes de sécurité IEC 60950-1. Attenzione: per l'ingresso c.c. SELV: la fonte di alimentazione c.c. deve essere conforme ai requisiti per i circuiti a bassissima tensione di sicurezza (SELV, Safety Extra-Low Voltage) riportati in IEC 60950-1. Advertencia: Para entrada de CC SELV: la fuente de alimentación de CC debe cumplir con los requisitos de voltaje muy bajo de seguridad (SELV) indicados en IEC 60950-1. Aviso: Para entrada CC SELV: a fonte de alimentação CA deve estar de acordo com os os requisitos de Tensão Extrabaixa de Segurança (SELV) da IEC 60950-1. Абайлаңыз: Өте төмен вольтті кернеудің кірісін пайдалану кезінде: тұрақты токтың қуат көзі IEC 60950-1 стандартының Өте төмен вольтті кернеу (SELV) талаптарына сай болуы тиіс. Предупреждение. Для входа SELV DC: источник питания постоянного тока должен соответствовать требованиям IEC 60950-1 относительно цепей безопасного низковольтного напряжения (SELV). Увага! Підключення типу SELV DC: джерело живлення постійного струму має відповідати вимогам до безпечної наднизької напруги (SELV), описаним в IEC 60950-1. Uyarı: SELV DC girişi için: DC güç kaynağı, IEC 60950-1 standardının Güvenli Ekstra Düşük Voltaj (SELV) şartlarına uygun olmalıdır. |
Caution: The moveable equipment label is on the exterior of the bottom of equipment.( Achtung: Die entfernbare Gerätekennzeichnung befindet sich außen am Boden des Geräts. 注意:本可移动设备的标签在设备底部的外侧。注意:可動装置のラベルは、機器の底部外側にあります。 주의: 이동식 장비 레이블이 장비 바닥의 외부에 있습니다. Attention: l’étiquette de l’équipement mobile est à l’extérieur du bas de l’équipement.Attenzione: L'etichetta di apparecchiatura mobile è all’esterno della parte inferiore dell'apparecchiatura. Precaución: La etiqueta de equipo movible está en el exterior de la parte inferior del equipo. Cuidado: A etiqueta removível do equipamento está na parte externa da parte inferior do equipamento.Ескерту: Жылжытылатын жабдық жапсырмасы құрылғының астыңғы жағында орналасқан.Внимание! Наклейка со сведениями об оборудовании находится в нижней части оборудования.Обережно! Маркування рухомої частини обладнання нанесено ззовні на нижній стороні обладнання.Dikkat: Taşınabilir ekipman etiketi ekipmanın alt tarafının dışında bulunur. |
Warning: Before an ac power cable is either plugged in to or removed from a unit, the ac power source supplying this cable must be switched off. Warnung: Bevor ein Wechselstromnetzkabel entweder an eine Einheit angeschlossen oder von dieser abgezogen wird, muss die Wechselstromquelle, die dieses Kabel speist, ausgeschaltet werden. 警告:在安装、移动电源线之前,请切断电源。 警告:AC 電源ケーブルを本体と接続する前、または本体から取り外す前には、当該ケーブルが接続されている電源のスイッチはオフにしておく必要があります。 경고: AC 전원 케이블을 유닛과 연결 또는 분리할 때는 반드시 케이블에 공급되는 AC 전원을 끈 상태에서 작업하십시오. Avertissement: Avant de brancher ou de retirer un câble d'alimentation CA de l'unité, la source CA alimentant ce câble doit être mise hors tension. Avvertenza. Prima che un cavo di alimentazione di corrente alternata sia collegato o rimosso da un'unità, occorre spegnere la fonte di alimentazione di corrente alternata che trasmette corrente in questo cavo. Advertencia: Antes de que el cable de alimentación de CA esté conectado o se haya quitado de la unidad, la fuente de alimentación de CA que suministra este cable debe desconectarse. Aviso: Antes de plugar ou remover um cabo de força CA de uma unidade, a fonte de energia CA que abastece este cabo deve ser desligada. Абайлаңыз: Айнымалы токтың қуат сымын құрылғыға қоспас немесе ажыратпас бұрын, бұл кабельге қуат беретін айнымалы ток көзі өшірулі болуы тиіс. Предупреждение. Прежде чем подключать кабель питания переменного тока к устройству или отключать его, сначала необходимо отключить источник питания, к которому подсоединен этот кабель. Увага! Перш ніж підключати до пристрою кабель живлення змінного струму або відключати його, необхідно вимкнути джерело, що його живить. Uyarı: Bir birime AC güç kablosunun takılmasından veya çıkarılmasından önce, bu kabloya güç sağlayan AC güç kaynağı kapatılmalıdır. |
Warning: To reduce the risk of fire, use only No. 26 AWG or larger telecommunication line cord. Warnung: Um die Brandgefahr zu minimieren dürfen ausschließlich Nr. 26 AWG oder Telekommunikationskabel mit größerem Drahtdurchmesser verwendet werden. 警告:为了降低发生火灾的危险,请使用NO.26 AWG或更粗的通信线缆。 警告:火災の危険性を減らすため、No. 26 AWG 以上の通信線コードのみを使用してください。 경고: 화재의 위험을 줄이려면 No. 26AWG 이상의 통신선 코드만 사용하십시오. AVERTISSEMENT: pour limiter les risques d'incendie, veillez à utiliser exclusivement un câble de transmission N 26 AWG ou de calibre supérieur. ATTENZIONE: per ridurre il rischio di incendi, utilizzare esclusivamente un cavo per linea di telecomunicazioni 26 AWG. ADVERTENCIA: Para reducir el peligro de incendio, use únicamente un cable de línea de telecomunicaciones n° 26 AWG o superior. AVISO: Para reduzir o risco de incêndios, use apenas um cabo de linha de telecomunicação no. 26 AWG ou maior. Абайлаңыз: Өрт шығу қаупін азайту үшін, тек нөмірі 26 AWG немесе одан жоғары телекоммуникациялық желі сымын пайдаланыңыз. Предупреждение. Во избежание возгорания используйте только кабель линии связи № 26 AWG. Увага! Щоб знизити ризик займання, використовуйте тільки телекомунікаційні кабелі №26 AWG або вищого класу. Uyarı: Yangın riskini azaltmak için yalnızca No. 26 AWG veya daha büyük telekomünikasyon hat kablosu kullanın. |
Warning: No operation can be done on the device and cables during a thunder storm. Warnung: Wenn die Gefahr eines Blitzeinschlages besteht, darf weder an der Vorrichtung noch an den Kabeln gearbeitet werden. 警告:雷雨风暴期间不要操作设备或者电缆。 警告:雷雨のときはデバイスやケーブルで作業できません。 경고: 천둥 번개가 치는 동안에는 장치 및 케이블에 대해 어떤 작업도 수행하지 마십시오. AVERTISSEMENT: ne manipulez pas l'équipement ni les câbles par temps d'orage. ATTENZIONE: non eseguire alcuna operazione sul dispositivo o sui cavi durante i temporali. ADVERTENCIA: No puede realizarse ninguna operación con el dispositivo y los cables durante tormentas eléctricas. AVISO: Não opere o dispositivo ou mexa nos cabos durante uma tempestade Абайлаңыз: Найзағай ойнаған кезде құрылғыны және кабельдерді пайдалануға болмайды. Предупреждение. Во время грозы запрещается выполнять операции с устройством и кабелями. Увага! Під час грози забороняється працювати із пристроєм або кабелями. Uyarı: Fırtınalı havalarda aygıt ve kablolar üzerinde herhangi bir işlem yapılmamalıdır. |
Warning: To avoid electric shock, do not connect safety extra-low voltage (SELV) circuits to telephone network voltage (TNV) circuits Warnung: Um den elektrischen Schlag zu vermeiden, schließen Sie den Kreis von Schutzkleinspannung(SELV) nicht an den Kreis von Telefonnetzspannung(TNV) an. 警告:为了防止电击危险,不要把安全特低电压电路(SELV)连接到通信网络电压电路(TNV)上。 警告:電気ショックを防ぐため、安全特別低電圧 (SELV) 回路を電話網電圧 (TNV) 回路に接続しないでください。 경고: 감전을 피하려면 SELV(안전 초저전압) 회로를 TNV(전화망 전압) 회로에 연결하지 마십시오. AVERTISSEMENT: pour éviter tout risque d’électrocution, assurez-vous de ne pas raccorder les circuits SELV (très basse tension) aux circuits TNV (tension du réseau téléphonique). ATTENZIONE: per evitare shock elettrici, non collegare circuiti a bassissima tensione di sicurezza (SELV) ai circuiti a tensione di rete telefonica (TNV). ADVERTENCIA: Para evitar descargas eléctricas, no conecte circuitos de voltaje muy bajo de seguridad (SELV) a circuitos de voltaje de redes telefónicas (TNV). AVISO: Para evitar choques elétricos, não conecte circuitos de tensão extra baixa de segurança (SELV) a circuitos de tensão de rede telefônica (TNV) Абайлаңыз: Электр тогына түспеу үшін Өте төмен вольтті кернеу (SELV) тізбегін телефон желілерінің кернеу (TNV) тізбегіне қоспаңыз. Предупреждение. Во избежание поражения электрическим током не подключайте цепи безопасного низковольтного напряжения (SELV) к цепям телефонных сетей (TNV). Увага! Щоб уникнути ураження електричним струмом, не підключайте кола безпечної наднизької напруги (SELV) до кіл напруги телефонної мережі (TNV). Uyarı: Elektrik çarpmasını önlemek için koruyucu çok düşük gerilim (SELV) devrelerini, telefon şebekesi gerilim (TNV) devrelerine bağlamayın |
Caution: To ensure the equipment is mounted on the wall firmly, please use a screw at least 6 mm diameter and the screw head at least 12 mm diameter. Achtung: Um das Gerät an der Wand zu befestigen, benutzen Sie Nagel mit einem Mindestdurchmesser von 6 mm. Der Durchmesser der Nagelkappe muss mindestens 12 mm betragen. 注意:为确保设备紧固的安装在墙上,请用直径最小是6mm螺钉,并且螺帽的直径要大于12mm。 注意:壁面にマウントした装置を確実にしっかりと締めるには、直径が少なくとも6mm のねじと、直径が少なくとも12 mm のねじぶたを使用してください。 주의: 장치를 벽에 단단히 고정하려면 직경이6mm 이상인 나사와 직경이 12mm 이상인 나사 캡을 사용하십시오. Mise en garde: fixez solidement l'équipement au mur à l'aide de vis d'au moins 6 mm de diamètre et utilisez des bouchons à vis d'un diamètre au moins égal à 12mm. Avvertenza: per assicurarsi di fissare saldamente l’apparecchiatura alla parete, utilizzare una vite di almeno 6 mm di diametro e un tappo a vite di almeno 12 mm di diametro. Precaución: Para asegurarse de que el equipo quede montado firmemente en la pared, use un tornillo de al menos 6 mm de diámetro con una tapa de al menos 12 mm de diámetro. Cuidado: Para garantir que o equipamento fique firme na parede, use parafusos de, pelo menos, 6 mm de diâmetro e uma cabeça de, pelo menos, 12 mm de diâmetro. Ескерту: Жабдықтың қабырғаға мықты бекітілгеніне көз жеткізу үшін, диаметрі кем дегенде 6 мм-ге тең бұранданы және диаметрі кем дегенде 12 мм-ге тең бұранда бүркеншігін пайдаланыңыз. Внимание! Чтобы гарантировать надежное закрепление оборудования на стене, используйте винты диаметром не менее 6 мм и с диаметром головки не менее 12 мм. Попередження. Для надійного монтажу пристрою на стіні використовуйте гвинти діаметром щонайменше 6 мм і діаметром головки мінімум 12 мм. Uyarı: Ekipmanın duvara sıkıca monte edildiğinden emin olmak için lütfen en az 6 mm çapında ve vida başı en az 12 mm çapında olan vidalar kullanın. |
Warning: When installing the product on the wall you must choose a suitable fixing. Achtung: Wenn Sie das Produkt an der Wand anbringen, müssen Sie eine passende Befestigungslösung wählen. 警告:将设备安装到墙上时,必须选取合适的固定方式。 警告: 本製品を壁に設置するときは、適切な取り付け部品を選択する必要があります。 경고: 장치를 벽에 설치할 때 적절한 고정 장치를 사용해야 합니다. Avertissement: lors de l'installation de l'appareil sur le mur, vous devez choisir un système de fixation approprié. Avvertenza: quando si installa il prodotto su una parete, è necessario scegliere un metodo di fissaggio adatto. Atención: cuando instale el producto sobre la pared, debe elegir una montura adecuada. Aviso: Ao instalar o produto na parede, escolha um meio adequado de fixação. Ескерту: өнімді қабырғаға бекіту кезінде, сәйкес бекіткішті таңдау қажет. Предупреждение. При настенной установке следует выбрать подходящее крепление. Попередження. У разі монтування продукту на стіну необхідно вибрати належне кріплення. Uyarı: Ürünün duvara kurulumunu yaparken uygun bir sabitleme yöntemi seçmeniz gerekmektedir. |
Warning: When mounting the product on a wall, do not mount it with ventilation holes facing up or down. Warnung: Wenn das Produkt an einer Wand montiert wird, installieren Sie ihn nicht mit den Lüftungsöffnungen nach oben oder unten gerichtet. 警告:将设备安装到墙上时,请勿将散热孔朝上或朝下。 警告: 製品を壁に取り付ける場合、上または下向きの通気孔を使用して取り付けないでください。 경고: 벽에 제품을 장착할 때는 환기 구멍이 위나 아래를 향하게 하여 장착하지 마십시오. Avertissement: lorsque vous montez le produit sur un mur, ne le montez pas avec les trous d'aération orientés vers le haut ou le bas. Avviso: Quando si monta il prodotto su una parete, non eseguire il montaggio con i fori di ventilazione rivolti verso l'alto o verso il basso. Advertencia: Al colocar el producto en una pared, no lo coloque con los orificios de ventilación hacia arriba o hacia abajo. Aviso: ao montar o produto em uma parede, não o monte com os orifícios de ventilação para cima ou para baixo. Абайлаңыз! Өнімді қабырғаға бекіту кезінде, оның желдеткіш саңылауларын жоғарыға немесе төменге қаратып орнатуға болмайды. Предупреждение. При креплении устройства на стене вентиляционные отверстия не должны быть направлены вверх или вниз. Увага! У разі розміщення виробу на стіні не допускайте, щоб його вентиляційні отвори було спрямовано вгору або вниз. Uyarı: Anahtarı duvara monte ederken ağ bağlantı noktaları yukarı veya aşağı bakabilir. Anahtarı, havalandırma kanalları aşağı veya yukarı bakacak şekilde monte etmeyin. |
Warning: When making connections, be careful not to push the product up and off the wall. Warnung: Achten Sie darauf, das Produkt nicht nach oben und von der Wand zu schieben, wenn Sie die Anschlüsse vornehmen. 警告:进行连接时,请不要向上推动设备,以免设备从墙上掉落。 警告: 接続を行う際には、製品を壁に押し付けないように注意してください。 경고: 제품을 연결할 때는, 제품이 밀려서 벽에서 떨어지지 않도록 주의하십시오. Avertissement: lors de l'établissement de connexions, veillez à ne pas appuyer le produit contre le mur. Avviso: Quando si monta il prodotto su una parete, non eseguire il montaggio con i fori di ventilazione rivolti verso l'alto o verso il basso. Advertencia: Al realizar conexiones, tenga cuidado de no desplazar el producto hacia arriba y retirarlo de la pared. Aviso: Ao fazer conexões, tome cuidado para não empurrar o produto para cima e para fora da parede. Абайлаңыз! Қосу кезінде, өнімді жоғарыға итеріп қабырғадан алып тастаудан сақ болыңыз! Предупреждение. При подключении будьте осторожны, чтобы устройство не слетело с крепления и не упало на пол. Увага! Під час встановлення з’єднання не допускайте зміщення виробу в напрямі вгору або від стіни. Uyarı: Bağlantı yaparken, anahtarı duvardan yukarı ve dışarı doğru itmemeye dikkat edin. |
Warning: The unit must be permanently connected to the protective ground before operation. The cross-sectional area of the protective earthing / grounding conductor shall be at least 0.75mm2 or 18AWG Warnung: Diese Anlage muss vor der Inbetriebnahme ständig an den Schutzleiter angeschlossen werden. Die Querschnittsfläche des Schutzerdungsleiters soll mindestens 0.75 mm2 oder 18 AWG betragen. 警告:进行设备操作前,请确保设备永久接地,并且确保接地线截面不小于0.75 mm2 或18 AWG警告:ユニットは操作の前に恒久的に保護接地しておく必要があります。保護アース接地導体の断面積は、少なくとも0.75 mm 2 または18AWGである必要があります。 경고: 장치를 작동하기 전에 보호 접지에 영구적으로 연결해야 합니다. 보호 접지 도체의 단면적은 최소 0.75 mm2또는 18AWG 이어야 합니다. AVERTISSEMENT: l'unité doit être connectée en permanence à la mise à terre de protection avant d'être utilisée. Le conducteur de mise à la terre de protection doit avoir une section de 0.75 mm2 ou de calibre 18AWG au minimum. ATTENZIONE: prima di essere azionata, l’unità deve sempre essere collegata in modo permanente alla terra. La sezione trasversale del conduttore protettivo di terra deve essere di almeno 0.75 mm2 o 18AWG. ADVERTENCIA: La unidad debe tener una conexión permanente a tierra antes de la operación. El área transversal del conductor a tierra debe ser de al menos 0.75 mm2 o 18 AWG. AVISO: A unidade deve estar sempre conectada ao terra, antes da operação. A área de seção transversal do condutor terra deve ser de, pelo menos, 0.75 mm2 ou 18 AWG. Абайлаңыз: Пайдаланудың алдында құрылғы бір жолға жерге қосылуы тиіс. Қорғағыш жерге қосу/жерге тұйықтау сымының кесік алаңы кем дегенде 0.75мм2 немесе 18AWGболуы тиіс. Предупреждение. Перед работой устройство необходимо подключить к защитному заземлению. Площадь сечения защитного кабеля/проводника заземления должна быть не менее 0.75мм2 или 18AWG Увага! Перш ніж почати роботу із пристроєм, його необхідно підключити до заземлення. Площа перерізу дроту заземлення має становити щонайменше 0.75мм2 або 18AWGUyarı: Birim çalıştırılmadan önce, koruyucu topraklama bağlantısının kalıcı şekilde yapılmış olması gerekmektedir. Koruyucu topraklama iletkeninin kesit alanı en az 0.75 mm2 veya 18 AWG olmalıdır. |
Warning Power Cord Table: The power cord set must be approved for the country where it is used. WARNUNG Netzkabel Tabelle: Das Netzkabel muss für das Land, in dem es verwendet wird, zugelassen werden. 警告:电源线表格: 电源线组件必须满足使用的国家认证要求。 警告:電源ケーブルの表: 電源コード セットは使用する国で承認を受ける必要があります。 전원 코드 표 경고: 전원 코드 세트는 사용되는 국가에서 승인된 것이어야 합니다. AVERTISSEMENT - Tableau des cordons d'alimentation: les cordons d'alimentation doivent être approuvés par un organisme agréé dans le pays où ils seront utilisés. ATTENZIONE - tabella cavo di alimentazione: il gruppo cavo di alimentazione deve avere l’approvazione relativa al paese di utilizzo. ADVERTENCIA Tabla de cables de alimentación: El juego de cables de alimentación debe estar aprobado para el país donde se utilice. AVISO da tabela de cabo de alimentação: O conjunto do cabo de alimentação deve ser aprovado no país em que será usado. үшін Ескертетін қуат сымдары кестесі: Қуат сымдарының жинағы пайдаланылатын елде бекітілуі тиіс. Таблица предупреждений для кабелей питания для маршрутизаторов: Набор кабелей питания должен быть одобрен для использования в данной стране. Таблиця дротів живлення для маршрутизаторів: Необхідно використовувати дроти живлення, затверджені національними нормами відповідної країни. Uyarı Güç Kablosu Tablosu: Güç kablosu seti, kullanıldığı ülkede onaylanmış olmalıdır. |
U.S.A. and Canada 米国およびカナダ 미국 및 캐나다 États-Unis et Canada Stati Uniti e Canada EE.UU. y Canadá EUA e Canadá АҚШ және Канада США и Канада США та Канада |
· The cord set must be UL approved and CSA certified · The minimum specification for the flexible cord is: · No. 18 AWG · Type SPT-2 · 2 conductor. · The cord set must have a rated current carrying capacity of at least 2.5A. · The attachment plug must be an earth-grounding type with a NEMA 1-15 (15A, 125V) configuration · コード セットは UL 規格認定取得済み、かつ CSA 認定済みである必要があります。 · 可撓コードの最小仕様は次のとおりです。 · No. 18 AWG。 · タイプSPT-2。 · 2 導体。 · コード セットには少なくとも 2.5A の定格通電容量が必要です。 · 電源プラグは NEMA 1-15(15A, 125V) に準拠している必要があります。 · 코드 세트는 UL 승인 및 CSA 인증을 받아야 합니다. · 플렉시블 코드의 최소 사양은 다음과 같습니다. · No. 18 AWG. · SPT-2형식. · 2본 도체. · 코드 세트는 최소 2.5A의 정격 전류를 공급해야 합니다. · 부착 플러그는NEMA 1-15(15A, 125V)구성의 접지형이어야 합니다. · Le cordon doit être agréé par l'UL et certifié CSA. · Configuration requise pour le cordon souple: · N° 18 AWG. · Type SPT-2. · 2 conducteurs. · La capacité de transport de courant nominal du cordon doit être d'au moins 2.5A. · L'utilisation d'une prise de terre avec une configuration NEMA 1-15(15A, 125V)est requise. · Il gruppo cavo deve avere l’approvazione UL e la certificazione CSA. · La specifica minima per il cavo flessibile è: · n. 18 AWG. · Tipo PT-2. · 2 conduttori. · Il gruppo cavo deve avere una capacità di corrente nominale di almeno 2.5 A. · La spina dell’accessorio deve essere di tipo con messa a terra con configurazione NEMA 1-15(15A, 125V). · El juego debe tener la aprobación de UL y la certificación de CSA. · La especificación mínima para el cable flexible es: · 18 AWG. · Tipo SPT-2. · 2 conductores. · El juego debe tener una capacidad de transmisión de corriente nominal de al menos 2.5 A. · El enchufe de conexión debe ser del tipo con conexión a tierra con una configuración NEMA 1-15(15A, 125V). · O conjunto do cabo deve ser aprovado pela UL e certificado pela CSA. · A especificação mínima para o cabo flexível é: · No. 18 AWG. · Tipo SPT-2. · 2 condutores. · O conjunto do cabo deve ter uma capacidade de transporte de corrente verificada de, pelo menos, 2.5A. · O plugue de conexão deve ser do tipo de aterramento com uma configuração NEMA 1-15(15A, 125V) · Сым UL арқылы бекітілген және CSA арқылы сертификатталған болуы тиіс. · Иілгіш сымның минималды сипаттамасы: · № 18 AWG · Түрі –SPT-2 · 2 сымды · Сымдар жинағының номиналды ток мөлшері кем дегенде 2.5 A болуы тиіс. · NEMA 1-15(15A, 125V) конфигурациясы бар электр розеткасы жерге қосылған болуы тиіс. · Набор кабелей должен быть одобрен UL и иметь сертификат CSA · Минимальные требования для гибких кабелей · № 18 AWG · Тип SPT-2 · Трехжильный · Номинальный допустимый ток набора кабелей должен быть не менее 2.5 А. · Вилка должна иметь заземление с типом конфигурации NEMA 1-15(15A, 125V) · Дріт має бути затверджений в UL і сертифікований у CSA. · Мінімальні вимоги до гнучкого дроту: · AWG: №18; · тип: SPT-2; · кількість провідників: 2; · номінально допустимий струм: від 2.5 A. · Рознім: штекер із заземленням і конфігурацією NEMA 1-15(15A, 125V). |
United Kingdom 英国 영국 Royaume-Uni Regno Unito Reino Unido Reino Unido Біріккен Корольдік Великобритания Великобританія |
· The supply plug must comply with BS1363 (3-pin, 13A) and be fitted with a 5A fuse that complies with BS1362 · The mains cord must <HAR> or <BASEC> marked and be of type H03VVH2F2X0.75 (minimum). · 電源プラグは、BS1363 (3 ピン、13A) に準拠し、BS1362 に準拠した 5A のヒューズを装着したものである必要があります。 · 電源コードは <HAR> または <BASEC> のマークが付いたもので、タイプH03VVH2F2X0.75 (最小) である必要があります。 · 전원 플러그가 BS1363(3핀, 13A)에 적합한 규격이고, BS1362 규격을 따르는 5A 퓨즈와 함께 사용되어야 합니다. · 주 코드가H03VVH2F2X0.75 형식(최소)이고 <HAR> 또는 <BASEC> 표시가 있어야 합니다. · La prise d'alimentation doit être de type BS1363 (3 broches, 13 A) et équipée d'un fusible de 5A conforme à la norme BS1362. · Le câble secteur doit porter la mention <HAR> ou <BASEC> et être de type H03VVH2F2X0.75 (minimum). · La spina di alimentazione di corrente deve essere conforme allo standard BS1363 (3 poli, 13 A) ed essere dotata di un fusibile a 5 A conforme a BS1362. · Il cavo di alimentazione deve essere contrassegnato con <HAR> o <BASEC> ed essere di tipo H03VVH2F2X0.75 (minimo). · El enchufe de la fuente debe cumplir con BS1363 (3 clavijas, 13A) y contar con un fusible de 5A que cumpla con BS1362. · El cable de la alimentación debe tener la marca <HAR> o <BASEC> y ser del tipo H03VVH2F2X0.75 (mínimo). · O plugue da fonte deve estar em conformidade com BS1363 (3 pinos, 13 A) e ser equipado com um fusível de 5 A que esteja em conformidade com BS1362. · O cabo de alimentação deve ter a marca <HAR> ou <BASEC> e ser do tipo H03VVH2F2X0.75 (mínimo). · Желі штепселі BS1363/BS1362 стандартының талаптарына сәйкес болуы тиіс. · Желі сымы <HAR> немесе <BASEC> жазбасымен таңбаланған және H03VVH2F2X0.75 (ең аз) типті болуы тиіс. · Разъем питания должен соответствовать требованиям BS1363/BS1362 · Сетевой кабель должен иметь отметку <HAR> или <BASEC>, а также тип H03VVH2F2X0.75 (минимум) · Рознім живлення має відповідати вимогам BS1363/BS1362. · Дріт живлення має містити маркування <HAR> або <BASEC> і відповідати типу H03VVH2F2X0.75 (мінімум). |
Europe Europa ヨーロッパ 유럽 Europe Europa Europa Europa Еуропа Европа Європа Avrupa |
· The supply plug must comply with CEE 7/16 (“SCHUKO”) · The mains cord must <HAR> or <BASEC> marked and be of type H03VVH2F2X0.75 (minimum) · Der Stromversorgungsstecker muss CEE 7/16 (“SCHUKO”) entsprechen. · Das Netzkabel muss mit <HAR> oder <BASEC> gekennzeichnet werden und sein Typ muss von H03VVH2F2X0.75 (Minimum) sein. · 電源プラグは CEE 7/16 (「SCHUKO」) に準拠している必要があります · 電源コードは <HAR> または <BASEC> マークが付いたものでタイプ H03VVH2F2X0.75 (最小) である必要があります · 전원 플러그가 CEE 7/16(“SCHUKO”)에 적합한 규격이며 · 주 코드는 H03VVH2F2X0.75 형식(최소)이고 <HAR> 또는 <BASEC> 표시가 있어야 합니다 · La prise d'alimentation doit être de type CEE 7/16 (« SCHUKO ») · Le câble secteur doit porter la mention <HAR> ou <BASEC> et être de type H03VVH2F2X0.75 (minimum) · La spina di alimentazione deve essere conforme allo standard CEE 7/16 (“SCHUKO”) · Il cavo di alimentazione deve essere contrassegnato con <HAR> o <BASEC> ed essere di tipo H03VVH2F2X0.75 (minimo) · El enchufe de la fuente debe cumplir con CEE 7/16 (“SCHUKO”) · El cable de la alimentación debe tener la marca <HAR> o <BASEC> y ser del tipo H03VVH2F2X0.75 (mínimo) · O plugue da fonte deve estar em conformidade com CEE 7/16 (“SCHUKO”) · O cabo de alimentação deve ter a marca <HAR> ou <BASEC> e ser do tipo H03VVH2F2X0.75 (mínimo) · Желі штепселі CEE 7/16 (“SCHUKO”) стандартына сәйкес болуы тиіс. · Желі сымы <HAR> немесе <BASEC> жазбасымен таңбаланған және H03VVH2F2X0.75 (ең аз) типті болуы тиіс. · Разъем питания должен соответствовать требованиям CEE 7/16 («SCHUKO») · Сетевой кабель должен иметь отметку <HAR> или <BASEC>, а также тип H03VVH2F2X0.75 (минимум) · Рознім живлення має відповідати вимогам CEE 7/16 ("SCHUKO"). · Дріт живлення має містити маркування <HAR> або <BASEC> і відповідати типу H03VVH2F2X0.75 (мінімум). · Güç kaynağı fişinin CEE 7/16 (“SCHUKO”) ile uyumlu olması gerekmektedir · Ana güç kablosu <HAR> veya <BASEC> işaretli ve H03VVH2F2X0.75 tipi (en az) olmalıdır |
Denmark デンマーク 덴마크 Danemark Danimarca Dinamarca Dinamarca Дания Дания Данія |
· The supply plug must comply with CEE 7/16 · 電源プラグは CEE 7/16 に準拠している必要があります。 · 전원 플러그가 CEE 7/16에 적합한 규격이어야 합니다. · La prise d'alimentation doit être conforme à la norme CEE 7/16. · La spina di alimentazione deve essere conforme allo standard CEE 7/16. · El enchufe del suministro debe cumplir con CEE 7/16. · O plugue da fonte deve estar em conformidade com CEE 7/16. · Желі штепселі CEE 7/16 стандартының талаптарына сәйкес болуы тиіс. · Разъем питания должен соответствовать требованиям CEE 7/16. · Рознім живлення має відповідати вимогам CEE 7/16. |
Switzerland die Schweiz スイス 스위스 Suisse Svizzera Suiza Suíça Швейцария Швейцария Швейцарія |
· The supply plug must comply with SEV/ASE 1011 · Der Netzstecker muss SEV/ASE 1011 entsprechen. · 電源プラグは SEV/ASE 1011 に準拠している必要があります。 · 전원 플러그가 SEV/ASE 1011에 적합한 규격이어야 합니다. · La prise d'alimentation doit être conforme à la norme SEV/ASE 1011. · La spina di alimentazione deve essere conforme allo standard SEV/ASE 1011. · El enchufe del suministro debe cumplir con SEV/ASE 1011. · O plugue da fonte deve estar em conformidade com SEV/ASE 1011. · Желі штепселі SEV/ASE 1011 стандартының талаптарына сәйкес болуы тиіс. · Разъем питания должен соответствовать требованиям SEV/ASE 1011 · Рознім живлення має відповідати вимогам SEV/ASE 1011. |
Argentina アルゼンチン
아르헨티나
Argentine Argentina Argentina Argentina |
· El conjunto de cables debe estar certificado por UL, IRAM, TÜV (u otra organización de certificación autorizada), para cables de dos conductors. · El enchufe de conexión debe ser de tipo sin toma de tierra con una configuración IRAM-2063 (10 A, 250 V). · The power cord set must be certified by UL, IRAM, TÜV(or other authorized certification body), for two conductors cables. · The attachment plug must be a non-grounding type with an IRAM-2063 (10 A, 250 V) configuration · 電源ケーブル セットは、2 導体ケーブルに対する UL、IRAM、TÜV (または認定認証機関) による認証を受ける必要があります · 差し込みプラグは、非接地型で IRAM-2063 (10 A、250 V) 構成である必要があります · 전원 코드 세트는 2개 도체 케이블에 대해 UL, IRAM, TÜV(또는 다른 인증 단체)의 인증을 받아야 합니다 · 부착 플러그는 IRAM-2063(10A, 250V) 구성을 포함하는 비접지 유형이어야 합니다 · Les cordons d'alimentation doivent être certifiés par les organismes UL, IRAM ou TÜV (ou tout autre organisme de certification autorisé), pour les câbles à deux conducteurs · L'utilisation d'une fiche de branchement de type sans mise à la terre avec une configuration IRAM-2063 (10 A, 250 V) est requise · Il gruppo cavo di alimentazione deve essere certificato da UL, IRAM, TÜV (o un altro ente di certificazione autorizzato), per cavi con due conduttori · La spina dell’accessorio deve essere di tipo senza messa a terra con configurazione IRAM-2063 (10 A, 250 V) · El juego de cables de alimentación debe estar certificado por UL, IRAM, TÜV (u otro ente de certificación autorizado), para cables de dos conductores · El enchufe de conexión debe ser del tipo sin conexión a tierra con una configuración IRAM-2063 (10A, 250V) · O cabo de alimentação deve ter certificação UL, IRAM, TÜV (ou outro órgão de certificação autorizado) para cabos com dois condutores · O plugue de conexão deve ser do tipo sem aterramento com configuração IRAM-2063 (10 A, 250 V) |
中国 |
· 电源线组件必须通过CCC认证。 · 使用符合GB1002,额定值为250V/10A的单相两级插头 · 电源线最小线径为0.75mm2 |
The appliance coupler (the connector to the unit and not the connector to the wall plug) must have a configuration for mating with an EN 60320 / IEC 320 C8 appliance inlet.
Die Gerätesteckvorrichtung (der Anschluss an die Anlage, nicht an den Wandstecker) muss mit einer Konfiguration nach EN 60320 / IEC 320 C8 versehen.
機器用カプラ (壁面プラグへではなくユニットへ接続するほうの部品) は、EN 60320 / IEC 320 C8の機器用差込口と噛み合う構造である必要があります
기기 연결 장치(벽면 플러그 커넥터가 아닌 장치 커넥터)가 EN 60320/IEC 320 C8기기 전원 소켓에 연결되도록 구성되어야 합니다.
Le système de couplage (le connecteur utilisé pour l'unité et non le connecteur de la prise murale) doit être compatible avec les prises femelle de type EN 60320 / IEC 320 C8.
L’attacco per apparecchiature elettriche (il connettore all’unità e non il connettore alla spina a muro) deve avere una configurazione atta all’accoppiamento con una presa per apparecchiature elettriche EN 60320 / IEC 320 C8.
El acoplador del artefacto (el conector que va a la unidad y no el que va a la toma de la pared) debe tener una configuración para una entrada de artefacto EN 60320 / IEC 320 C8.
O acoplador de dispositivo (o conector que vai até a unidade, não o que vai até a tomada) deve ter uma configuração para corresponder à entrada de dispositivo EN 60320 / IEC 320 C8.
Құрылғының қосқышы (қабырға розеткасына емес, құрылғыға қосатын қосқыш) EN 60320 / IEC 320 C8 құрылғы ашасына қосылуы тиіс.
Конфигурация приборного соединителя (разъем для устройства и не для розетки) должна соответствовать вилке EN 60320/IEC 320 C8.
Штекер пристрою (той, що підключається до пристрою, а не до електричної розетки) має підходити до гнізда EN 60320/IEC 320 C8 на пристрої.
Aygıt kuplörünün (duvardaki prize değil, birime bağlanan konektör) EN 60320 / IEC 320 C8 aygıt girişiyle eşleşecek bir yapılandırmaya sahip olması gerekmektedir.
Caution: For DC power supplied equipment, please use 0.75 mm2 or 18AWG minimum power supply cord. Achtung: Für mit Gleichstrom betriebene Ausrüstung benutzen Sie bitte eine Zuleitung mit einem Mindestquerschnitt von 0.75 mm2 oder mindestens 18 AWG. 注意: DC电源设备,请使用至少 0.75 mm2 或18 AWG的电缆。 注意:DC で装置に給電する場合、最低でも 0.75 mm2 または18AWG の電源コードを使用してください。 주의: DC 전원을 사용하는 장치의 경우 최소 0.75 mm2 또는 18AWG 전원 코드를 사용하십시오. Mise en garde: avec un matériel alimenté en CC, utilisez un cordon d'alimentation de 0.75 mm2 ou de calibre 18AWG au minimum. Avvertenza: per le apparecchiature alimentate con corrente c.c., utilizzare un cavo di alimentazione di almeno 0.75 mm2 o 18AWG. Precaución: Para el equipo con alimentación de CC, use un cable de suministro eléctrico de al menos 0.75 mm2 o 18 AWG. Cuidado: Para equipamento com fonte de alimentação CC, use um cabo de alimentação de 0.75 mm2 ou 18 AWG, no mínimo. Ескерту: Тұрақты ток берілетін жабдық үшін диаметрі 0.75 мм2 немесе 18AWG ең аз қуат беру сымын пайдаланыңыз. Внимание! Для оборудования, работающего от постоянного тока, используйте кабель питания с площадью сечения не менее 0.75 мм2 или 18AWG. Попередження. У пристроях із живленням від постійного струму слід використовувати дріт живлення із площею перерізу щонайменше 0.75 мм2 або 18AWG. Dikkat: DC güç kaynağıyla çalışan ekipman için lütfen en az 0.75 mm2 veya 18AWG güç kaynağı kablosu kullanın. |
Caution: Fiber optic ports – optical safety Achtung: Glasfaseranschlüsse – optische Sicherheit 注意:光纤接口 - 光口安全 注意:光ファイバーのポート – 光学上の安全 주의: 광 섬유 포트 – 광학적 안전 Mise en garde: ports en fibre optique – sécurité optique Avvertenza: porte fibre ottiche – sicurezza ottica Precaución: Puertos de fibra óptica – seguridad óptica Cuidado: Portas de fibra ótica – segurança ótica Ескерту: Оптикалық талшық кабель порттары – оптикалық қауіпсіздік Внимание! Оптоволоконные порты — оптическая безопасность Попередження. Волоконно-оптичні порти – оптична безпека Dikkat: Fiber optik bağlantı noktaları – optik güvenlik |
Never look at the transmit laser while the power is on. Never look directly at the fiber ports and the fiber cable ends when they are powered on. Schauen Sie niemals in den Laserstrahl, wenn die Einheit eingeschaltet ist. Schauen Sie niemals direkt in die Glasfaseranschlüsse und die Enden des Glasfaserkabels, wenn diese eingeschaltet sind. 当设备工作时,请不要直视光接口和光纤接头。 電源がオンの間は、絶対に送出されているレーザーを見ないようにしてください。電源がオンのときは、絶対にファイバー ポートとファイバー ケーブルの端を直接見ないようにしてください。 전원이 켜지는 동안 레이저를 쳐다보지 마십시오. 또한 섬유 포트 및 섬유 케이블에 전원이 공급되는 동안 포트 및 케이블 단부를 똑바로 쳐다보지 마십시오. Ne regardez jamais directement le laser lorsque le système est sous tension. Ne regardez jamais directement les ports et les extrémités de câble en fibre lorsqu'ils sont en service. Quando l’alimentazione è accesa, non fissare mai direttamente nel laser di trasmissione. Quando l’alimentazione è accesa, non fissare mai direttamente nelle porte laser e nei terminali dei cavi delle fibre. Nunca mire el láser de transmisión cuando esté encendido. Nunca mire directamente los puertos de fibra ni los extremos de los cables de fibra cuando estén encendidos. Nunca olhe para o laser de transmissão com a alimentação ligada. Nunca olhe diretamente nas portas de fibra e nas extremidades dos cabos de fibra, quando estiverem ligados. Қуат қосулы кезде шығарылатын лазер сәулелерінің шоғырына қарамаңыз. Оптикалық талшық кабель порттары және талшық кабель ұштары қуатқа қосылған кезде оларға тікелей қарамаңыз. Никогда не смотрите на включенный лазер передачи. Никогда не смотрите непосредственно в оптоволоконные порты и на концы оптоволоконного кабеля включенного устройства. Ніколи не дивіться на лазер передачі, коли ввімкнено живлення. Ніколи не дивіться на волоконні порти та кінці волоконних кабелів, коли ввімкнено живлення. Güç açıkken asla aktarıcı lazere bakmayın. Güç açıkken asla fiber bağlantı noktalarına ve fiber kablo uçlarına doğrudan bakmayın. |
Caution: Use of controls or adjustments of the performance or procedures other than those specified herein may result in hazardous laser emissions. Achtung: Werden Steuerelemente, Leistungseinstellungen oder Prozeduren anders als hier angegeben verwendet, kann gefährliche Laserstrahlung auftreten. 注意:不遵守本手册规定而任意改动光模块的功能或性能可能导致激光辐射的危险。 注意:パフォーマンスの制御や調整を行ったり、本書で指定されていない手順を使用すると、危険なレーザーの発光が起きる可能性があります。 주의: 본 설명서에 지정되지 않은 방식으로 성능을 제어하거나 절차를 조정하면 레이저에 노출될 위험이 있습니다. Mise en garde: l'utilisation de contrôles ou de réglages des performances ou de procédures autres que ceux indiqués ici risque d'entraîner l'émission de rayons dangereux. Avvertenza: l’uso di controlli o regolazioni delle prestazioni o procedure diversi da quelli specificati in questo documento può causare emissioni laser pericolose. Precaución: El uso de controles o ajustes del rendimiento o procedimientos diferentes a los especificados aquí puede causar emisiones de láser peligrosas. Cuidado: O uso dos controles ou ajustes de desempenho ou procedimentos que não os especificados aqui podem resultar em emissões laser perigosas. Ескерту: Осы құжатта белгіленгеннен басқа басқару құралдарын пайдалану, жұмысты немесе процедураларды реттеу қауіпті лазер сәулеленуіне әкелуі мүмкін. Внимание! Использование элементов управления или настройки производительности либо процедур, кроме описанных здесь, могут привести к опасному лазерному излучению. Попередження. Внесення змін у робочі характеристики обладнання, а також використання засобів керування процедурами, відмінних від описаних у цьому посібнику, може призвести до появи небезпечного лазерного випромінювання. Dikkat: Burada belirtilenlerden farklı şekilde kontrollerin kullanımı, performans ayarlamaları ve diğer işlemler, tehlikeli lazer emisyonlarına neden olabilir. |
· Conducting articles, such as a watch, hand chain, bracelet or ring should be removed during the installation.
· Es ist nicht erlaubt während dieser Arbeiten leitende Gegenstände wie Uhren, Armbänder, Armreifen und Ringe am Körper zu tragen.
· 在操作中不能穿戴导电性的物品,如:手表,手琏,手镯和项链等。
· 通電性の物、たとえば時計、ハンド チェーン、ブレスレット、指輪などは、設置作業中は外しておく必要があります。
· 설치하는 동안에는 시계, 팔찌, 반지 등의 전도성 액세서리를 착용하지 않아야 합니다.
· Il veillera à retirer tout objet de type montre, chaîne, bracelet ou bague préalablement à l'installation.
· Durante l’installazione, rimuovere eventuali articoli conduttori di elettricità, come orologi, catene, bracciali o anelli.
· Durante la instalación, el personal debería quitarse los artículos de conducción, como relojes, cadenas, pulseras o anillos.
· Objetos condutores, como relógios, correntes, braceletes ou anéis devem ser removidos durante a instalação.
· Құрылғыны орнату кезінде сағат, қолға киетін бау, білезік немесе сақина сияқты токты өткізетін заттарды шешу қажет.
· Перед установкой необходимо снять токопроводящие предметы, такие как часы, наручные цепочки, браслеты или кольца.
· Під час установлення необхідно зняти всі предмети, що проводять струм (годинник, браслети, персні тощо).
· Kurulum sırasında saat, künye, bilezik veya yüzük gibi iletken nesneler çıkarılmalıdır.
· Do not use this product near water.
· Verwenden Sie dieses Produkt nicht in der Nähe von Wasser.
· 请勿在靠近水的地方使用此产品。
· 本製品は、水に濡れやすい場所では使用しないでください。
· 물과 가까운 곳에서 이 제품을 사용하지 마십시오.
· N'utilisez pas ce produit à proximité de l'eau.
· Non utilizzare questo prodotto vicino all'acqua.
· No utilice este producto cerca del agua.
· Não use este produto perto da água.
· е өнімді қолданбаңыз.
· Не используйте данное устройство рядом с водой.
· Не користуйтеся пристроєм біля води.
· Ürünü suya yakın yerde kullanmayın.
Table 2 Regulatory compliance standards
Discipline |
Standards |
EMC |
FCC Part 15 Subpart B CLASS A ICES-003 CLASS A VCCI CLASS A CISPR 32 CLASS A EN 55032 CLASS A AS/NZS CISPR32 CLASS A CISPR 24 EN 55024 EN 61000-3-2 EN 61000-3-3 ETSI EN 300 386EN 301 489-1 EN 301 489-17 EN 301 489-52 GB/T 9254 |
Safety |
UL 60950-1 CAN/CSA C22.2 No 60950-1 IEC 60950-1 EN 60950-1 AS/NZS 60950-1 FDA 21 CFR Subchapter J GB 4943.1 |
FCC Bulletin OET-65C FCC part15 subpart C/E FCC part22 FCC part24 RSS-210 RSS-GEN RSS-132 RSS-133 EN 300 328 EN 301 893 EN 301 511 EN 301 908-1 EN 301 908-2 EN 50385 EN 62311 |
Table 3 Equipment may be operated in the following country:
AT |
BE |
CY |
CZ |
DK |
EE |
FI |
FR |
DE |
GR |
HU |
IE |
IT |
LV |
LT |
LU |
MT |
NL |
PL |
PT |
SK |
SI |
ES |
SE |
GB |
IS |
LI |
NO |
CH |
BG |
RO |
TR |
HR |
1. Select the country in which this product is installed to ensure product operation is in compliance with local regulations. For information on how to select the country, refer to the “H3C A-Series Access Controllers WLAN Command Reference”.
2. Intended use: IEEE 802.11 a/b/g/n/acradio LAN device.
3. These products must maintain a minimum distance of 20cm from body to antenna.Under these conditions These products will meet the Basic Restriction limits of 1999/519/EC(Council Recommendation of 12 July 1999 on the limitation of exposure of the general public to electromagnetic fields(0Hz-300GHz)).
RED declaration statements:
български [Bulgarian] |
С настоящото компанията New H3C Technologies Co., Ltd. потвърждава, че радиосъоръжението [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] отговаря на изискванията на Директива 2014/53/ЕС. Декларация за съответствие: http://www.h3c.com (Търсене по име на модел) |
Česky [Czech] |
Společnost New H3C Technologies Co., Ltd. tímto prohlašuje, že rádiové zařízení [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] je v souladu se směrnicí 2014/53/EU. Prohlášení o shodě: http://www.h3c.com (při vyhledávání zadejte název modelu) |
Dansk [Danish] |
New H3C Technologies Co., Ltd. erklærer hermed, at radioudstyret [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] overholder direktiv 2014/53/EU. Overensstemmelseserklæring: http://www.h3c.com (søg på modelnavn) |
Deutsch [German] |
Hiermit erklärt New H3C Technologies Co., Ltd., dass die Funkeinrichtung [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] die Richtlinie 2014/53/EU einhält. Konformitätserklärung: http://www.h3c.com (Suche nach Modellnamen) |
Eesti [Estonian] |
Käesolevaga kinnitab ettevõte New H3C Technologies Co., Ltd., et raadioseadmed [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] on kooskõlas direktiiviga 2014/53/EL. Vastavusdeklaratsioon: http://www.h3c.com (otsige mudeli nime järgi) |
English |
Hereby, New H3C Technologies Co., Ltd., declares that the radio equipment [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] is in compliance with the Directive 2014/53/EU. Declaration of Conformity: http://www.h3c.com (Search with Model Name) |
Español [Spanish] |
Por la presente, New H3C Technologies Co., Ltd., declara que el equipo de radio [H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE)] cumple con la Directiva 2014/53/EU. Declaración de conformidad: http://www.h3c.com (Búsqueda por nombre de modelo) |
Ελληνική [Greek] |
Δια του παρόντος, η New H3C Technologies Co., Ltd. δηλώνει ότι ο ραδιοεξοπλισμός H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) συμμορφώνεται με την Οδηγία 2014/53/ΕΕ. Δήλωση συμμόρφωσης: http://www.h3c.com (πραγματοποιήστε αναζήτηση χρησιμοποιώντας το όνομα μοντέλου) |
Français [French] |
Par le présent document, New H3C Technologies Co., Ltd. déclare que l’équipement radio H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) est conforme à la directive 2014/53/EU. Déclaration de conformité: http://www.h3c.com (rechercher avec le nom du modèle) |
Hrvatska [Croatian] |
Ovime tvrtka New H3C Technologies Co., Ltd. izjavljuje da je radijska oprema H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) usklađena s Direktivom 2014/53/EU. Izjava o usklađenosti: http://www.h3c.com (pretražite po broju modela) |
Íslenska [Icelandic] |
New H3C Technologies Co., Ltd. lýsir því hér með yfir að þráðlausi búnaðurinn H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) er í samræmi við tilskipun 2014/53/EU. Samræmisyfirlýsing: http://www.h3c.com (Leita eftir heiti tegundar) |
Italiano [Italian] |
Con la presente, New H3C Technologies Co., Ltd., dichiara che l’apparecchiatura radio H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE] è conforme con la direttiva Direttiva 2014/53/EU. Dichiarazione di conformità: http://www.h3c.com (cercare utilizzano il nome del modello) |
Latviski [Latvian] |
Ar šo uzņēmums New H3C Technologies Co., Ltd. paziņo, ka radioaprīkojums H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) atbilst direktīvas 2014/53/ES prasībām. Atbilstības deklarācija: http://www.h3c.com (meklēt pēc modeļa nosaukuma) |
Lietuvių [Lithuanian] |
Šiuo dokumentu „New H3C Technologies Co., Ltd.“ pareiškia, kad radijo įranga H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) atitinka direktyvą 2014/53/ES. Atitikties deklaracija: http://www.h3c.com (ieškoti pagal modelio pavadinimą) |
Malti [Maltese] |
Hawnhekk, New H3C Technologies Co., Ltd., tiddikjara li t-tagħmir tar-radju H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) hu konformi mad-Direttiva 2014/53/UE. Dikjarazzjoni ta' Konformità: http://www.h3c.com (Fittex bl-Isem tal-Mudell) |
Magyar [Hungarian] |
A New H3C Technologies Co., Ltd. ezúton kijelenti, hogy a H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) rádióberendezés megfelel a 2014/53/EU irányelvnek. Megfelelőségi nyilatkozat: http://www.h3c.com (keressen a modellnévvel). |
Nederlands [Dutch] |
Hierbij verklaart New H3C Technologies Co., Ltd. dat de radioapparatuur H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) voldoet aan Richtlijn 2014/53/EU. Conformiteitsverklaring: http://www.h3c.com (zoek op modelnaam) |
Norsk [Norwegian] |
New H3C Technologies Co., Ltd. erklærer herved at radioutstyret H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) er i samsvar med europaparlaments- og rådsdirektiv 2014/53/EU. Samsvarserklæring: http://www.h3c.com (søk etter modellnavn) |
Polski [Polish] |
Niniejszym firma New H3C Technologies Co., Ltd. oświadcza, że urządzenie radiowe H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE] jest zgodne z Dyrektywą 2014/53/UE. Deklaracja zgodności: http://www.h3c.com (wyszukiwanie poprzez nazwę modelu) |
Português [Portuguese] |
A New H3C Technologies Co., Ltd. declara pelo presente que o equipamento de rádio H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE] está em conformidade com a Diretiva 2014/53/UE. Declaração de Conformidade: http://www.h3c.com (Procurar pelo Nome do Modelo) |
Română [Romanian] |
Prin prezenta, New H3C Technologies Co., Ltd. declară că echipamentul radio H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) este în conformitate cu Directiva 2014/53/UE. Declaraţia de conformitate se găseşte la: http://www.h3c.com (căutaţi utilizând denumirea modelului) |
Slovensko [Slovenian] |
S tem družba New H3C Technologies Co., Ltd. izjavlja, da je radijska oprema H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) v skladu s smernico 2014/53/ES. Izjava o skladnosti: http://www.h3c.com (iščite po imenu modela) |
Slovensky [Slovak] |
Spoločnosť New H3C Technologies Co., Ltd. týmto vyhlasuje, že rádiové zariadenie H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE] je v súlade so smernicou 2014/53/EÚ. Vyhlásenie o zhode http://www.h3c.com (Vyhľadávajte pomocou názvu modelu) |
Suomi [Finnish] |
Yritys New H3C Technologies Co., Ltd. vakuuttaa täten, että radiolaite H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE) on yhdenmukainen direktiivin 2014/53/EU kanssa. Vaatimustenmukaisuusvakuutus: http://www.h3c.com (haku mallin nimen perusteella) |
Svenska [Swedish] |
Härmed försäkrar New H3C Technologies Co., Ltd. att radioutrustningen H3C LA3608E (WLAN & 4G-LTE)/H3C LA3608E-GM-DB/H3C LA3608E(WLAN & TD-LTE] efterlever direktivet 2014/53/EU. Försäkran om överensstämmelse: http://www.h3c.com (sök med modellnamn) |
The most up to date copy of the signed EU Declaration of Conformity can be downloaded from:
These products may be used indoors (or outdoors) in all countries of the European Community using the 2.4GHz band: Channel 1-13, except where noted below.
1. In Italy the end-user must apply for a license from the national spectrum authority to operate this device outdoors.
These products have been tested and found to comply with the limits for a Class A digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at his own expense.
These products comply with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
1. This device may not cause harmful interference.
2. This device must accept any interference received, including interference that may cause undesired operation.
If the customer modifies the equipment without the authorization of H3C, which directly or indirectly contribute to the equipment incompliance with FCC requirements for Class A digital devices, H3C is not liable for such interference problem and the expenses incurred there from shall be covered by the customers.
1. RF exposure Hazard Warning
This device generates and radiates radio-frequency energy. To ensure compliance with the requirements of FCC radio-frequency exposure, a minimum body to antenna distance of 20cm (8 inch) must be maintained when the device is installed and operated.
2. RF Frequency Requirements
This equipment complies with FCC RF radiation exposure limits set forth for an uncontrolled environment. This device and its antenna must not be co-located or operating in conjunction with any other antenna or transmitter.
This device is for indoor use only when it is operated at 5.15 to 5.25GHz frequency range.
High power radars are allocated as primary users of the 5.25 to 5.35GHz and 5.65 to 5.85GHz bands. These radar stations can cause interference with and /or damage this device.
Only use the supplied antenna. Unauthorized antennas, modifications or change to the antennas could violate FCC regulations and void the user’s authority to operate the equipment.
These products conform to the applicable requirements of 21 CFR Subchapter J.
This Class A digital apparatus complies with Canadian Standard ICES-003.
Cet appareil numérique de la Classe A est conforme à la norme NMB-003 du Canada.
These products comply with RSS-210 of Industry Canada.
Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of this device.
L ‘ utilisation de ce dispositif est autorisée seulement aux conditions suivantes: (1) il ne doit pas produire de brouillage et (2) l’ utilisateur du dispositif doit étre prêt à accepter tout brouillage radioélectrique reçu, même si ce brouillage est susceptible de compromettre le fonctionnement du dispositif.
The term "IC" before the equipment certification number only signifies that the Industry Canada technical specifications were met.
To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (EIRP) is not more than that required for successful communication. To prevent radio interference to the licensed service, this device is intended to be operated indoors and away from windows to provide maximum shielding. Equipment (or its transmit antenna) that is installed outdoors is subject to licensing.
Pour empecher que cet appareil cause du brouillage au service faisant l'objet d'une licence, il doit etre utilize a l'interieur et devrait etre place loin des fenetres afin de Fournier un ecram de blindage maximal. Si le matriel (ou son antenne d'emission) est installe a l'exterieur, il doit faire l'objet d'une licence.
This device must not be co-located or operated in conjunction with any other unauthorized antenna or transmitter.
Radiation Exposure Statement:
This equipment complies with IC RSS-102 with radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 20cm between the radiator & your body.
Déclaration d'exposition aux radiations:Cet équipement est conforme aux limites d'exposition aux rayonnements IC établies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé avec un minimum de 20 cm de distance entre la source de rayonnement et votre corps.
Table 4 Frequency band and channels in Canada and USA
Allowed Frequency Bands and Channel Numbers – 2.4GHz |
Allowed Frequency Bands and Channel Numbers – 5GHz |
Restriction |
11bg & 11n HT20: 2412~2462MHz (ch1-11) 11n HT40 2422~2452MHz (ch3-9) |
11a & 11n &11ac HT20&VHT20: 5180~5320 MHz, 5500~5700MHz(*), 5745~5825MHz Ch #s: 36,40,44,48,52,56,60,64,100,104,108,112,116 ,132,136,140, 149, 153, 157, 161,165 HT40& VHT40: 5190~5310MHz, 5510~5670 MHz(*), 5755~5795MHz Ch#s:38,46,54,62, 102,110, 134, 151, 159 VHT80: 5210~5290MHz, 5530MHz, 5775MHz Ch#s:42, 58, 106, 155 |
5GHz DFS required bands: 5250~5350MHz; 5470~5725MHz This device is Indoor use only in Canada when operating in below frequency bands: 5150~5250MHz |
Note: (*). No operation in band 5600-5650MHz in USA and Canada
These products comply with the requirements of VCCI Class A Information Technology Equipment (ITE).
Warning This is a Class A equipment. Operation of this equipment in a residential environment could cause radio interference. In such a case, the user may be required to take corrective actions. VCCI-A |
この装置は、クラスA機器です。この装置を住宅環境で使用すると電波妨害を引き起こすことがあります。この場合には使用者が適切な対策を講ずるよう要求されることがあります。VCCI-A
These products comply with the requirements of EN55032, AS/NZS CISPR 32, CISPR32 for Class A Information Technology Equipment (ITE).
Warning Operation of this equipment in a residential environment could cause radio interference. |
此为A级产品,在生活环境中,该产品可能会造成无线电干扰。在这种情况下,可能需要用户对其干扰采取切实可行的措施。
This device may cause radio interference during its operation. Therefore service in relation to human life security is not available.
이 기기는 업무용(A급) 전자파적합기기로서 판매자 또는 사용자는 이 점을 주의하시기 바라며, 가정 외의 지역에서 사용하는 것을 목적으로 합니다.
This wireless equipment may not be able to provide services related to personal safety due to radio interference.
1. 經型式認證合格之低功率射頻電機,非經許可,公司、商號或使用者均不得擅自變更頻率、加大功率或變更原設計之特性及功能。
2. 低功率射頻電機之使用不得影響飛航安全及干擾合法通信;經發現有干擾現象時,應立即停用,並改善至無干擾時方得繼續使用。所謂合法通信,係指依電信法規定作業之無線電信。低功率射頻電機須忍受合法通信或工業、科學及醫療用電波輻射性電機設備之干擾。
3. 無線資訊傳輸設備的製造廠商應確保頻率穩定性,如依製造廠商使用手冊上所述正常操作,發射的信號應維持於操作頻帶中。
These are Class A Information products. When used in a residential environment, it may cause radio frequency interference. Under such circumstances, the user may be requested to take appropriate countermeasures.
警告使用者:此為甲類資訊技術設備,於居住環境中使用時,可能會造成射頻擾動,在此種情況下,使用者會被要求採取某些適當的對策。
Türkiye Cumhuriyeti: AEEE Yönetmeliğine Uygundur
This product complies with the "India E-waste (Management and Handling) Rule 2016" and prohibits use of lead, mercury, hexavalent chromium, polybrominated biphenyls or polybrominated diphenyl ethers in concentrations exceeding 0.1 weight % and 0.01 weight % for cadmium, except for the exemptions set in Schedule 2 of the Rule.
限用物質含有情況標示
單元 |
限用物質及化學符號 |
鉛 (Pb) |
汞 (Hg) |
鎘 Cd) |
六價鉻(Cr+6) |
多溴聯苯 (PBB) |
多溴二苯醚 (PBDE) |
傳輸線和線材 |
〇 |
〇 |
〇 |
〇 |
〇 |
〇 |
外殼 |
〇 |
〇 |
〇 |
〇 |
〇 |
記憶體 |
〇 |
〇 |
〇 |
〇 |
〇 |
〇 |
其他機械組裝設備 |
〇 |
〇 |
〇 |
〇 |
〇 |
印刷電路零組件(PCAs) |
〇 |
〇 |
〇 |
〇 |
〇 |
斷路器(選配) |
〇 |
〇 |
〇 |
〇 |
〇 |
冷卻及加熱系統(選配) |
〇 |
〇 |
〇 |
〇 |
〇 |
〇 |
風扇(選配) |
〇 |
〇 |
〇 |
〇 |
〇 |
〇 |
存取裝置(HDD)(選配) |
〇 |
〇 |
〇 |
〇 |
〇 |
讀寫元件(CD/DVD/磁碟機)(選配) |
〇 |
〇 |
〇 |
〇 |
〇 |
變壓器/電源供應器(選配) |
〇 |
〇 |
〇 |
〇 |
〇 |
備考1. “〇”係指該項限用物質之百分比含量未超出百分比含量基準值。 備考2. “—”係指該項限用物質為排除項目。 |
選配單元使用於特定產品型號,詳細規格請參照產品說明書。
Perchlorate material - special handling may apply.
See http://www.dtsc.ca.gov/hazardouswaste/perchlorate/.
This product’s real-time clock battery or coin cell battery may contain perchlorate and may require special handling when recycled or disposed of in California.
معلومات الأمان
نظرة عامة
تحذير يجب تركيب هذه الوحدة وملحقاتها عن طريق فني مؤهل. ويجب عليك قراءة جميع إرشادات الأمان المرفقة بجهازك قبل تركيبه وتشغيله. |
ملاحظة قبل إجراء أي عملية تشغيل، يُرجى قراءة إرشادات واحتياطات التشغيل بعناية لتقليل احتمالية وقوع حوادث. لا تغطي بنود الملاحظات والتنبيهات والتحذيرات والمخاطر الواردة في الأدلة الأخرى جميع احتياطات الأمان التي تجب مراعاتها. فهي ليست مجرد مكملات لإرشادات الأمان للعمليات بكاملها. لذا، يتطلب من الفني المسؤول عن تركيب المنتجات وصيانتها فهم هذه الإرشادات الأساسية للتشغيل بأمان. وعند إجراء عمليات متنوعة، يُرجى اتباع قوانين الأمان المحلية. فاحتياطات الأمان الواردة في أدلة المنتج تكميلية وتخضع لقوانين الأمان المحلية. وعندما يتم تنفيذ عمليات متنوعة على المنتجات، يجب اتباع الاحتياطات وإرشادات الأمان الخاصة المرفقة بالمنتجات بكاملها. ويجب أن يحصل الفني المسؤول عن تركيب المنتجات وصيانتها على تدريب مثل المحترفين ليستخدم طرق التشغيل المناسبة وجميع احتياطات الأمان. ولا يجوز إلا للفني المؤهل والمعتمد فقط إجراء عمليات تركيب الجهاز وصيانته. |
تسميات رموز التحذير
يحتوي الجدول التالي على الرموز الواردة في هذا الدليل. فهي تُستخدم لتذكير قارئ احتياطات الأمان أثناء تركيب الجهاز وصيانته.
جدول 1 - رمز الأمان ووصفه
رموز الأمان |
الوصف |
رمز التنبيه العام: للتنبيه بشأن مخاوف أمان عامة. |
رمز حماية الأجهزة الحساسة إلكترونيًا: للتنبيه بشأن جهاز حساس إلكترونيًا. |
رمز الصدمة الكهربية: للتنبيه بشأن خطر جهد كهربي خطير. |
معلومات الأمان الهامة
تنبيه: يجب عليك قراءة جميع إرشادات التركيب الواردة في "دليل التركيب" المرفق بجهازك واتباع إرشادات الأمان قبل تركيب الجهاز أو تشغيله. |
تحذير: يجب تركيب هذه الوحدة وملحقاتها عن طريق فني مؤهل. |
تنبيه: لا تسد فتحات التهوية أثناء تشغيل الجهاز واجعلها تبعد مسافة 10 عن فتحات التهوية والحوائط أو الاشياء الأخرى التي قد تسد الفتحات. |
تحذير: يجب توصيل الطرف الأرضي المعزول الأرض بشكل دائم. |
تنبيه: يجب تعديل الموصل المؤرض/الأرضي المرفق بهذا المنتج بطريقة صحيحة عن طريق كهربائي مؤهل ليتناسب طوله مع القوانين المحلية. يجب أن يكون طول الموصل مناسبًا وتوصيله بمنفذ توصيل معتمد وملائم. لاحظ أنه بخصوص الأجهزة التي يتم تحميلها على الأرفف، يجب أن يكون الموصل متصلاً داخل نظام تأريض خزانة الأرفف. ويجب الحفاظ على الكبل المؤرض التكميلي داخل نظام الأرفف في جميع الأوقات. |
تحذير: عند تركيب الوحدة، قم بإجراء التوصيل الأرضي أولاً وافصله أخيرًا. لا تلغي الموصل الأرضي أو تشغل الجهاز دون وجود موصل أرضي مثبت جيدًا. وتحقق من عملية التركيب جيدًا. |
تحذير: بخصوص إدخال التيار المستمر بجهد آمن منخفض للغاية: يجب أن يتوافق التيار المستمر مع متطلبات SELV (الجهد الآمن المنخفض للغاية) وفقًا للمعيار IEC 60950-1. |
تنبيه: يقع ملصق الجهاز القابل للنقل على السطح الخارجي لقاعدته. |
تحذير: قبل توصيل كبل تيار متردد أو فضله من الوحدة، يجب إيقاف تشغيل مصدر التيار المتردد الذي يزود هذا الكبل. |
تحذير: لتقليل خطر نشوب حريق، لا تستخدم إلا سلك خط الاتصالات رقم 26 GWA أو الأكبر من ذلك فقط. |
تحذير: لا تشغل الجهاز ولا توصل الكبلات أثناء العواصف الرعدية. |
تحذير: لتجنب حدوث صدمة كهربية، لا توصل دوائر SELV (الجهد الآمن المنخفض للغاية) بدوائر TNV (جهد شبكة) الهاتف |
تنبيه: لضمان تثبيت الجهاز على الحائط بإحكام، يُرجى استخدام مسمار قلاووظ بقطر 0.6 مم على الأقل بحيث يبلغ قطر رأس المسمار 1 مم على الأقل. |
تحذير: عند تثبيت المنتج على الحائط، يجب عليك استخدام مثبت ملائم |
تحذير: عند تثبيت المنتج على الحائط، لا تثبته في وضع تكون فيه فتحات التهوية لأعلى أو لأسفل. |
تحذير: عند إجراء التوصيلات، احرص على عدم دفع المنتج أعلى الحائط أو بعيدًا عنه. |
تحذير: يجب توصيل الوحدة بشكل دائم بأرضي معزول قبل تشغيلها. يجب أن تكون المنطقة المستعرضة للموصل الأرضي المعزول 0.75مم2 أو 18AWGعلى الأقل. |
تحذير: قبل توصيل كبل الطاقة، يجب التأكد أولاً من توافق سلك الطاقة مع متطلبات التركيب الفعلية (راجع جدول سلك الطاقة) |
جدول تحذيرات أسلاك الطاقة: يجب أن تكون مجموعة سلك الطاقة معتمدة في الدولة التي يتم استخدامه فيها. |
الولايات المتحدة الأمريكية وكندا |
· يجب أن تكون مجموعة الطاقة معتمدة من UL و CSA · الحد الأدنى لمواصفات السلك المرن هي: · رقم 18 AWG · النوع SPT-2 · موصل ثنائي. · يجب أن تتمتع مجموعة الأسلاك بسعة تحميل تيار مقدّرة تبلغ 2.5 أمبير على الأقل. · يجب أن يكون القابس المستخدم من نوع مؤرض بتكوين NEMA من 1 إلى 15 (بشدة تيار 15 أمبير وجهد 125 فولت) |
المملكة المتحدة |
· يجب أن يكون قابس المورد متوافقًا مع المعيار BS1363 (مزوّد بـ 3 سنون وبشدة تيار 13 أمبير) وأن يتناسب مع منصهر بشدة تيار 5 أمبير يتوافق مع المعيار BS1362 · يجب أن يكون سلك التيار مميزًا بعلامة <HAR> أو <BASEC> وأن يكون من نوع H03VVH2F2X0.75 (بحد أدنى). |
أوروبا |
· يجب أن يكون قابس المورد متوافقًا مع المعيار CEE 7/16 ("SCHUKO") · يجب أن يكون سلك التيار مميزًا بعلامة <HAR> أو <BASEC> وأن يكون من نوع H03VVH2F2X0.75 (بحد أدنى) |
الدنمارك |
· يجب أن يكون قابس المورد متوافقًا مع المعيار CEE 7/16 |
سويسرا |
· يجب أن يكون قابس المورد متوافقًا مع المعيار SEV/ASE 1011 |
الأرجنتين |
· يجب أن تكون مجموعة سلك الطاقة معتمدة من UL و IRAM و TÜV (أو هيئة أخرى معتمدة) للكبلات المزوّدة بموصلات ثنائية. · يجب أن يكون القابس المستخدم من نوع غير مؤرض بتكوين IRAM-2063 (بشدة تيار 10 أمبير وجهد 250 فولت) |
يجب
أن تكون قارنة توصيل الجهاز (الموصل المتصل بالوحدة وليس مقبس الحائط) بتكوين يتزاوج مع مدخل الجهاز
تنبيه: بخصوص جهاز توريد طاقة التيار المستمر، يُرجى استخدام سلك مورد طاقة 0.75 مم2 أو 18AWG بحد أدنى. |
تنبيه: منافذ الألياف الضوئية – الأمان الضوئي |
لا تنظر إلى الليز المنبعث أثناء تشغيل الطاقة. ولا تنظر مباشرة إلى منافذ الألياف وأطراف كبل الألياف عندما يكون الجهاز قيد التشغيل |
تنبيه: قد يؤدي استخدام عناصر تحكم أو وحدات ضبط للأداء أو الإجراءات غير المحددة في هذا الدليل إلى انبعاثات ليزر خطيرة. |
احتياطات الأمان الكهربي
· يجب خلع الأشياء، مثل الساعة وسلسلة اليد والأساور والخواتم، أثناء التركيب.
· لا تستخدم هذا المنتج بالقرب من الماء.
