11-Track命令
本章节下载: 11-Track命令 (147.13 KB)
display track命令用来显示Track项信息。
display track { track-entry-number | all [ negative | positive ] } [ brief ]
track-entry-number:显示指定Track项的信息。track-entry-number为Track项的序号,取值范围为1~1024。
all:显示所有Track项的信息。
negative:显示Negative状态的Track项的信息。
positive:显示Positive状态的Track项的信息。
brief:显示Track项的简要信息。
# 显示所有Track项的信息。
<Sysname> display track all
Track ID: 1
State: Positive
Duration: 0 days 0 hours 0 minutes 7 seconds
Notification delay: Positive 20, Negative 30 (in seconds)
Tracked object:
NQA entry: admin test
Reaction: 10
Remote IP/URL: --
Local IP: --
Interface: --
Track ID: 2
State: NotReady
Tracked object:
BFD session mode: Echo
Outgoing interface: Vlan-interface2
VPN instance name: --
Remote IP: 192.168.40.1
Local IP: 192.168.40.2
Track ID: 3
State: Negative
Tracked object:
Interface: Vlan-interface3
Protocol: IPv4
Track ID: 4
State: Negative
Tracked object:
CFD service instance: MEP 2 in Ethernet service instance 1
Track ID: 5
State: Positive
Tracked object:
IP route: 0.0.0.0/0 reachability
Protocol: Static
Nexthop interface : Vlan-Interface4
Track ID: 6
State: Positive
Tracked object:
LLDP interface: Vlan-interface4
# 显示所有Negative状态的Track项的简要信息。
<Sysname> display track all negative brief
ID Status Type Remote IP/URL Local IP Interface
1 Negative Interface -- -- Vlan2
10 Negative Interface -- -- Vlan3
表1-1 display track命令输出信息描述
Track ID |
Track项序号 |
State |
Track项的状态,取值包括: · Positive:表示状态正常 · NotReady:表示无效值 · Negative:表示状态异常 |
Duration |
Track项处于当前状态的持续时间 |
Notification delay: Positive 20, Negative 30 (in seconds) |
通知延迟: · Track项状态变为Positive后,延迟20秒通知应用模块 · Track项状态变为Negative后,延迟30秒通知应用模块 |
Tracked object |
Track项关联的对象 |
NQA entry |
Track项关联的NQA测试组 |
Reaction |
Track项关联的联动项 |
BFD session mode |
BFD会话的模式,当前只支持Echo模式 |
Outgoing interface |
出接口 |
VPN instance name |
VPN实例的名称。如果属于公网,则显示为“--” |
Remote IP/URL |
远端IP地址或URL路径,不存在时则显示“--” |
Local IP |
本地IP地址,不存在时则显示“--” |
Track项关联的接口,不存在时则显示“--” |
Protocol |
监视接口的链路状态或网络层协议状态,取值包括: · None:监视接口的链路状态 · IPv4:监视三层接口的IPv4协议状态 · IPv6:监视三层接口的IPv6协议状态 |
CFD service instance |
CFD服务实例的编号 |
MEP ID |
CFD MEP的编号 |
IP route |
Track项关联的路由 |
VPN instance name |
Track项关联路由的VPN实例名称,如果关联的是公网路由,则显示为“--” |
Protocol |
关联路由的协议类型,如果路由不存在,则显示为“N/A” |
Nexthop interface |
关联路由的下一跳,如果路由不存在,则显示为“N/A” |
LLDP interface |
监视LLDP邻居状态的接口 |
Type |
Track项关联项类型,取值包括: · BFD:Track项关联BFD · CFD:Track项关联CFD · Interface:Track项关联接口 · LLDP:Track项关联LLDP · NQA:Track项关联NQA测试组 · Route:Track项关联路由 |
· track bfd
· track cfd
· track interface
· track interface physical
· track interface protocol
· track ip route reachability
· track lldp neighbor
· track nqa
track bfd命令用来创建和BFD会话关联的Track项。
undo track命令用来删除指定的Track项。
track track-entry-number bfd echo interface interface-type interface-number remote ip remote-ip-address local ip local-ip-address [ delay { negative negative-time | positive positive-time } * ]
undo track track-entry-number
不存在Track项。
track-entry-number:Track项的序号,取值范围为1~1024。
interface interface-type interface-number:BFD会话报文的出接口。interface-type interface-number为接口类型和接口编号。
remote ip remote-ip-address:BFD会话探测的远端IP地址。
local ip local-ip-address:BFD会话探测的本地IP地址。
delay:指定Track项状态发生变化时,延迟通知应用模块。如果未指定该参数,则Track项状态变化后立即通知应用模块。
negative negative-time:指定Track项状态变为Negative时,延迟通知应用模块的时间。negative-time为延迟时间,取值范围为1~300,单位为秒。
positive positive-time:指定Track项状态变为Positive时,延迟通知应用模块的时间。positive-time为延迟时间,取值范围为1~300,单位为秒。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track bfd命令。
可以通过重复执行track bfd delay命令修改延迟通知应用模块的时间。多次执行track bfd delay命令,最后一次执行的命令生效。
配置Track与BFD联动时,VRRP备份组的虚拟IP地址不能作为BFD会话探测的本地地址和远端地址。
# 创建与BFD会话关联的Track项1。BFD会话使用Echo报文进行探测,出接口为VLAN接口2,远端IP地址为1.1.1.1,本地IP地址为1.1.1.2。
[Sysname] track 1 bfd echo interface vlan-interface 2 remote ip 1.1.1.1 local ip 1.1.1.2
· display track
track cfd命令用来创建和CFD连续性检测功能关联的Track项。
track track-entry-number cfd cc service-instance instance-id mep mep-id [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
service-instance instance-id:表示服务实例的编号,instance-id的取值范围为1~32767。
mep mep-id:表示MEP的编号,mep-id的取值范围为1~8191。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track cfd命令。
可以通过重复执行track cfd delay命令修改延迟通知应用模块的时间。多次执行track cfd delay命令,最后一次执行的命令生效。
# 创建与CFD连续性检测功能关联的Track项1。指定CFD服务实例2,MEP编号为3。
[Sysname] track 1 cfd cc service-instance 2 mep 3
· cfd mep(可靠性命令参考/CFD)
· cfd service-instance(可靠性命令参考/CFD)
· display track
track interface命令用来创建与接口链路状态关联的Track项。
track track-entry-number interface interface-type interface-number [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
interface-type interface-number:监视的接口类型和接口编号。
创建与接口链路状态关联的Track项后,接口的链路状态为up时,Track项的状态为Positive;接口的链路状态为down时,Track项的状态为Negative。通过display ip interface brief命令可以查看接口的链路状态。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track interface命令。
可以通过重复执行track interface delay命令修改延迟通知应用模块的时间。多次执行track interface delay命令,最后一次执行的命令生效。
# 创建与VLAN接口10的链路状态关联的Track项1。
[Sysname] track 1 interface vlan-interface 10
· display ip interface brief(三层技术-IP业务命令参考/IP地址)
· display track
track interface physical命令用来创建与接口物理状态关联的Track项。
track track-entry-number interface interface-type interface-number physical [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track interface physical命令。
可以通过重复执行track interface physical delay命令修改延迟通知应用模块的时间。多次执行track interface physical delay命令,最后一次执行的命令生效。
# 创建与VLAN接口2的物理状态关联的Track项1。
[Sysname] track 1 interface vlan-interface 2 physical
track interface protocol命令用来创建与接口网络层协议状态关联的Track项。
track track-entry-number interface interface-type interface-number protocol { ipv4 | ipv6 } [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
ipv4:监视接口的IPv4协议状态。接口的IPv4协议状态为up时,Track项的状态为Positive;接口的IPv4协议状态为down时,Track项的状态为Negative。通过display ip interface brief命令可以查看接口的IPv4协议状态。
ipv6:监视接口的IPv6协议状态。接口的IPv6协议状态为up时,Track项的状态为Positive;接口的IPv6协议状态为down时,Track项的状态为Negative。通过display ipv6 interface brief命令可以查看接口的IPv6协议状态。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track interface protocol命令。
可以通过重复执行track interface protocol delay命令修改延迟通知应用模块的时间。多次执行track interface protocol delay命令,最后一次执行的命令生效。
# 创建与VLAN接口2的IPv4协议状态关联的Track项1。
[Sysname] track 1 interface vlan-interface 2 protocol ipv4
· display ipv6 interface brief(三层技术-IP业务命令参考/IPv6基础)
· display track
track ip route reachability创建与路由管理关联的Track项,并指定Track项状态变化时通知应用模块的延迟时间。
track track-entry-number ip route [ vpn-instance vpn-instance-name ] ip-address { mask-length | mask } reachability [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
vpn-instance vpn-instance-name:在指定VPN实例中创建和路由条目关联的Track项。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示在公网中创建和路由关联的Track项。
ip-address:路由条目中的IP地址,点分十进制格式。
mask-length/mask:IP地址掩码长度/掩码,以整数形式表示掩码长度或以点分十进制格式表示掩码。当用整数形式时,取值范围为0~32。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track ip route reachability命令。
可以通过重复执行track ip route reachability delay命令修改延迟通知应用模块的时间。多次执行track ip route reachability delay命令,最后一次执行的命令生效。
当发生主备设备倒换或者RIB进程倒换后,如果路由协议进程平滑重启一直未结束,并且此时路由条目发生变化,路由管理不会立刻向Track模块通知路由变化信息,通过配置路由管理的不间断路由功能,可以解决上述问题。
# 创建与路由管理关联的Track项1,路由条目目的地址10.1.1.0,掩码长度为24。
[Sysname] track 1 ip route 10.1.1.0 24 reachability
· display ip route(三层技术-IP路由命令参考/IP路由基础)
· display track
track lldp neighbor 命令用来创建与接口的LLDP邻居状态关联的Track项。
track track-entry-number lldp neighbor interface interface-type interface-number [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
interface interface-type interface-number:监视LLDP邻居状态的接口,interface-type interface-number为接口类型和接口编号。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track lldp neighbor命令。
可以通过重复执行track lldp neighbor delay命令修改延迟通知应用模块的时间。多次执行track lldp neighbor delay命令,最后一次执行的命令生效。
# 创建与接口Ten-GigabitEthernet1/0/1的LLDP邻居状态关联的Track项。
[Sysname] track 1 lldp neighbor interface ten-gigabitethernet 1/0/1
· display track
track nqa命令用来创建与NQA测试组中指定联动项关联的Track项。
track track-entry-number nqa entry admin-name operation-tag reaction item-number [ delay { negative negative-time | positive positive-time } * ]
不存在Track项。
entry admin-name operation-tag:指定与Track项关联的NQA测试组。其中,admin-name为创建NQA测试组的管理员的名字,为1~32个字符的字符串,不区分大小写;operation-tag为NQA测试操作的标签,为1~32个字符的字符串,不区分大小写。
reaction item-number:指定与Track项关联的联动项。其中,item-number为联动项的序号,取值范围为1~10。
不能通过重复执行本命令修改Track项关联的内容。如需修改Track项关联的内容,请先通过undo track命令删除Track项,再执行track nqa命令。
可以通过重复执行track nqa delay命令修改延迟通知应用模块的时间。多次执行track nqa delay命令,最后一次执行的命令生效。
# 创建与NQA测试组(admin–test)中联动项3关联的Track项1。
[Sysname] track 1 nqa entry admin test reaction 3
· display track
