05-三层技术-IP路由命令参考
07-IPv6静态路由命令
本章节下载 07-IPv6静态路由命令  (99.21 KB)
07-IPv6静态路由命令
1 IPv6静态路由
1.1  IPv6 静态路由配置命令
1.1.1  delete ipv6 static-routes all
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:删除指定VPN的所有IPv6静态路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定该参数,则删除公网实例下的所有IPv6静态路由。
【描述】
delete ipv6 static-routes all命令用来删除所有IPv6静态路由。
使用本命令删除IPv6静态路由时,系统会提示确认,确认后才会删除所配置的所有静态路由。
使用undo ipv6 route-static命令可以删除一条IPv6静态路由,而使用delete ipv6 static-routes all命令可以删除包括缺省路由在内的所有IPv6静态路由。
相关配置可参考命令ipv6 route-static,“三层技术-IP路由命令参考/IP路由基础”中的display ipv6 routing-table
# 删除所有IPv6静态路由。
[Sysname] delete ipv6 static-routes all
This will erase all ipv6 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]y
1.1.2  ipv6 route-static
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address } [ preference preference-value ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ipv6 route-static vpn-instance s-vpn-instance-name&<1-6> ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address } [ preference preference-value ]
undo ipv6 route-static vpn-instance s-vpn-instance-name&<1-6> ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
【缺省级别】
2:系统级
ipv6-address prefix-length:IPv6地址及前缀长度。
interface-type interface-number:路由出接口的类型和编号。对于广播类型接口(如以太网接口、VLAN接口等),必须指定下一跳地址。
next-hop-address:下一跳IPv6地址。
vpn-instance d-vpn-instance-name:指定目的VPNd-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN,IPv6静态路由将根据配置的下一跳IPv6地址在目的VPN中查找出接口。
preference preference-value:路由的优先级,取值范围为1~255,缺省值为60。
vpn-instance s-vpn-instance-name&<1-6>:指定源VPN。s-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。&<1-6>表示前面的参数最多可以输入6次。每个VPN都有自己的路由表,配置的IPv6静态路由将被加入指定VPN的路由表。
public:指定静态路由下一跳处于公网实例。
【描述】
ipv6 route-static命令用来配置IPv6静态路由。undo ipv6 route-static命令用来删除已配置的IPv6静态路由。
缺省情况下,没有配置IPv6静态路由。
如果配置的IPv6静态路由指定目的地址为::/0(前缀长度为0),则表示配置了一条IPv6缺省路由。如果报文的目的地址无法匹配路由表中的任何一项,设备将选择IPv6缺省路由来转发IPv6报文。
在配置静态路由时,如果出接口类型为广播(如以太网接口、VLAN接口等),必须指定下一跳地址。如果指定了出接口还要指定下一跳地址。
相关配置可参考命令delete ipv6 static-routes all,“三层技术-IP路由命令参考/IP路由基础”中的display ipv6 routing-table
# 配置IPv6静态路由,该路由的目的地址为1:1:2::/64,下一跳地址为1:1:3::1。
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
