H3C WAC系列无线控制器产品 Probe命令参考(R5218P01)-6W102
01-正文
本章节下载 01-正文  (787.48 KB)
01-正文
  录
Probe命令
C
cloud-management local-port
D
debug
debug from-device clear
debug from-device display
debug level
debug module
debugging lipc
debugging lipc mtcp
debugging lipc stcp
debugging system internal arp event
debugging system internal arp features
debugging system internal arp notify
debugging system internal arp sync
debugging system internal ike detail
debugging system internal ikev2 detail
debugging system internal ipsec packet detail
debugging system internal ipv6 fib prefix
debugging system internal nd
debugging system internal nd sub-features
debugging system internal stg
debugging system internal stp
debugging system internal vlan
debugging system internal wlan ap queue message-process-count
debugging system internal wlan ap queue message-type-count
debugging system internal wlan ap queue message-type-trace
debugging system internal wlan forward packet
debugging transceiver
debugging wlan ap app
debugging wlan radio
debugging wlan rfid-tracking
diag app display filename
diag boot-info display
diag dev-table display
diag drvflag display
diag environment display
diag fan display speed
diag hasa display
diag if display
diag led display
diag lipc display
diag log display
diag mbuf-relay display
diag mbus display
diag mem-assign display
diag module display content
diag pcie display
diag poe
diag port display  statistics
diag port-list display
diag port-table display
diag stm display
diag stm statistic display
diag temperature display status
diag tmpr-alarm display threshold
display debug-info
display fastforward session table
display hardware internal transceiver register interface
display system internal acl
display system internal arp
display system internal arp ifcb
display system internal arp ip-address
display system internal arp machash
display system internal arp probe
display system internal arp rbhash
display system internal arp reload
display system internal arp rule
display system internal arp source-suppression cache
display system internal arp statistics
display system internal arp vlan
display system internal aspf statistics
display system internal attack-defense scan stat-nodes ip
display system internal attack-defense scan stat-nodes ipv6
display system internal cloud-management state
display system internal dbm
display system internal dot11 characteristics
display system internal dot11 verbose
display system internal ethernet character
display system internal ethernet controlblock
display system internal ifmgr down
display system internal ifmgr entry
display system internal ifmgr event
display system internal ifmgr index
display system internal ifmgr list
display system internal ifmgr name
display system internal ifmgr type
display system internal ike phase2-sa count
display system internal ike phase2-sa verbose
display system internal ike received-message count
display system internal ike sent-message count
display system internal ikev2 child-sa count
display system internal ip address
display system internal ipsec block-flow
display system internal ipsec received-message
display system internal ipsec sent-message
display system internal ipsec sp
display system internal ipv6 address
display system internal ipv6 fib prefix
display system internal ipv6 fib prefix entry-status
display system internal ipv6 fib prefix ipv6
display system internal ipv6 l2-multicast ip forwarding verbose
display system internal ipv6 l2-multicast ip verbose
display system internal ipv6 l2-multicast ipc statistics
display system internal ipv6 l2-multicast mac forwarding verbose
display system internal ipv6 l2-multicast mac verbose
display system internal ipv6 multicast forwarding vlan reference
display system internal ipv6 multicast forwarding-table dummy
display system internal ipv6 pathmtu
display system internal ipv6 rawip
display system internal ipv6 rib event attribute
display system internal ipv6 rib event policy
display system internal ipv6 rib event prefix
display system internal ipv6 rib event protocol
display system internal ipv6 rib event statistics
display system internal ipv6 rib instance
display system internal ipv6 rib log
display system internal ipv6 rib memory
display system internal ipv6 rib nib log
display system internal ipv6 rib prefix
display system internal ipv6 rib summary
display system internal ipv6 route-direct interface
display system internal ipv6 route-direct log
display system internal ipv6 route-static nib log
display system internal ipv6 tcp
display system internal ipv6 tcp port-info
display system internal ipv6 tcp-proxy verbose
display system internal ipv6 udp
display system internal ipv6 udp port-info
display system internal kernel memory dump
display system internal kernel memory pool
display system internal l2-multicast ip forwarding verbose
display system internal l2-multicast ip verbose
display system internal l2-multicast ipc statistics
display system internal l2-multicast mac forwarding verbose
display system internal l2-multicast mac verbose
display system internal link-aggregation interface
display system internal lipc dump
display system internal lipc dump configuration
display system internal lipc history
display system internal lipc lcmp statistics
display system internal lipc lgmp group
display system internal lipc lgmp group-list
display system internal lipc lgmp physical-group
display system internal lipc lgmp physical-group-list
display system internal lipc lgmp statistics
display system internal lipc lip statistics
display system internal lipc loop statistics
display system internal lipc mtcp group
display system internal lipc mtcp group all
display system internal lipc mtcp performance
display system internal lipc mtcp statistics
display system internal lipc pcb mbuf statistics
display system internal lipc pcb statistics
display system internal lipc physical
display system internal lipc publish global-cb
display system internal lipc publish statistics
display system internal lipc stcp event
display system internal lipc stcp global-server
display system internal lipc stcp links
display system internal lipc stcp performance
display system internal lipc stcp port
display system internal lipc stcp statistics
display system internal lipc stcp status
display system internal lipc stream
display system internal lipc sudp pcb-info
display system internal lipc sudp statistics
display system internal lipc sudp { global-port | local-port }
display system internal lipc topology history
display system internal lipc topology link
display system internal lipc topology node
display system internal lipc topology process-time
display system internal lipc topology statistics
display system internal lipc topology status
display system internal lps
display system internal mac-address configuration
display system internal mac-address learned
display system internal mac-address protocol
display system internal mac-address statistics
display system internal mac-forwarding cache ip verbose
display system internal mac-forwarding cache ipv6 verbose
display system internal mac-forwarding controlblock
display system internal mbuf relay statistics
display system internal multicast capability
display system internal multicast forwarding vlan reference
display system internal multicast forwarding-table dummy
display system internal multicast record
display system internal nat
display system internal nat aging-queue
display system internal nat statistics
display system internal nd dad
display system internal nd entry
display system internal nd ifcb
display system internal nd machash
display system internal nd probe
display system internal nd rbhash
display system internal nd reload
display system internal nd rule
display system internal nd static
display system internal nd statistics
display system internal portal process
display system internal ppp statistics
display system internal process state
display system internal rawip
display system internal rib event attribute
display system internal rib event policy
display system internal rib event protocol
display system internal rib event statistics
display system internal rib instance
display system internal rib log
display system internal rib memory
display system internal rib nib log
display system internal rib prefix
display system internal rib summary
display system internal rip database standby
display system internal rip graceful-restart event-log
display system internal rip interface
display system internal rip interface standby
display system internal rip neighbor standby
display system internal rip nib
display system internal rip nib log
display system internal rip route standby
display system internal rip status
display system internal ripng database standby
display system internal ripng graceful-restart event-log
display system internal ripng interface
display system internal ripng interface standby
display system internal ripng neighbor standby
display system internal ripng nib
display system internal ripng nib log
display system internal ripng route standby
display system internal ripng status
display system internal route-direct interface
display system internal route-direct log
display system internal route-static nib log
display system internal session
display system internal session aging-queue
display system internal session alg-exception
display system internal session relation-table ipv4
display system internal session relation-table ipv6
display system internal session statistics
display system internal session table ipv4
display system internal session table ipv6
display system internal startup cache
display system internal stp bridge-info
display system internal stp port-info
display system internal tcp
display system internal tcp port-info
display system internal tcp-proxy statistics
display system internal tcp-proxy verbose
display system internal udp
display system internal udp port-info
display system internal userlog mbuf dump
display system internal userlog statistic
display system internal userlog test
display system internal vlan
display system internal wips statistics
display system internal wlan ac capability
display system internal wlan adapter-asyncinfo
display system internal wlan ap capwap accb
display system internal wlan ap capwap queue-statistics
display system internal wlan ap capwap send-statistics
display system internal wlan ap message
display system internal wlan ap name
display system internal wlan ap name map-configuration
display system internal wlan ap radio drv-info
display system internal wlan ap reboot-history
display system internal wlan ap reboot-reason
display system internal wlan ap-group-configuration
display system internal wlan ap-libinfo
display system internal wlan ap-model-configuration
display system internal wlan apdb
display system internal wlan band-navigation
display system internal wlan client ip
display system internal wlan command-cache
display system internal wlan history bandwidth
display system internal wlan history radiostate
display system internal wlan history wlanid
display system internal wlan history-error
display system internal wlan kernel-ap
display system internal wlan link-info
display system internal wlan load-balance neighbor-list ap
display system internal wlan load-balance neighbor-list client
display system internal wlan load-balance neighbor-list statistics
display system internal wlan load-status
display system internal wlan logbuffer ha
display system internal wlan logbuffer memory
display system internal wlan response-timeout event
display system internal wlan statistics
display system internal wlan statistics radio-backup
display system internal wlan { aplb | kernel-aplb }
display transceiver information
display transceiver moduleinfo
display transceiver register
F
follow
fpl-diag
L
lipc connection detect
lipc dump
lipc dump buffer
lipc dump enable
lipc dump offset
lipc performance
lipc ping
lipc timeout
list
M
memory boundary-check enable
memory boundary-check scan
monitor lipc
multicast record limit
P
probe
R
reset system internal arp statistics
reset system internal aspf statistics
reset system internal ipv6 rib log
reset system internal ipv6 rib nib log
reset system internal ipv6 rib summary
reset system internal ipv6 route-direct log
reset system internal ipv6 route-static nib log
reset system internal lipc dump buffer
reset system internal mac-address statistics
reset system internal mbuf relay statistics
reset system internal multicast forwarding-table dummy
reset system internal multicast record
reset system internal nat statistics
reset system internal nd statistics
reset system internal ppp statistics
reset system internal rib log
reset system internal rib nib log
reset system internal rib summary
reset system internal rip graceful-restart event-log
reset system internal ripng graceful-restart event-log
reset system internal route-direct log
reset system internal route-static nib log
reset system internal session alg statistics
reset system internal session statistics
reset system internal tcp-proxy statistics
reset system internal wlan history bandwidth
reset system internal wlan history radiostate
reset system internal wlan history-error
reset system internal wlan load-balance neighbor-list statistics
reset system internal wlan response-timeout event
rrm calibrate-power step
S
T
V
view
W
wlan ap queue message-type-count interval
wlan ap-execute exec-console enable
wlan image-load model
wlan image-load simultaneous
wlan system internal ap access-limit
wlan system internal ap adjust reboot
wlan system internal offline-restrain
wlan system internal reboot-restrain
Probe命令
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
C
cloud-management local-port命令用来配置建立云平台连接时使用的TCP端口号。
undo cloud-management local-port命令用来恢复缺省情况。
cloud-management local-port port-number
设备建立云平台连接时使用的TCP端口号为443。
Probe视图
port-number:建立云平台连接时使用的TCP端口号,取值范围为1~65535。
本命令用于与测试服务器互通、调试使用。
设备不会保存更改后的端口号,重启之后,端口号将恢复为缺省情况。
D
debug
debug命令用来打开debug开关,配置调试信息的输出设置。
debug {on | off | switch-save | out-to-ic | out-to-console }
Probe视图
on:表示debug打开开关。
off: 表示debug关闭开关。
switch-save: 表示保存debug开关。
out-to-ic: 表示调试信息在信息中心输出。
out-to-console: 表示调试信息在串口输出。
debug from-device clear命令用来清除debug异常调试信息。
Probe视图
debug from-device display命令用来显示设备异常信息开关。
debug from-device display { all | error }
Probe视图
all显示设备所有异常信息。
error显示设备异常错误信息。
debug level
debug level命令用来配置驱动debug调试信息级别开关。
debug level { all | debug | error | info | print-fileline | print-modulename } { on | off }
Probe视图
all:打开或关闭所有level调试信息开关。
debug:打开或关闭debug level调试信息开关。
error:打开或关闭 level error调试信息开关。
info:打开或关闭 level info调试信息开关。
print-fileline:打开或关闭输出文件行数调试信息开关。
print-modulename:打开或关闭输出模块名调试信息开关。
on:表示开启指定的debug信息开关。
off:表示关闭指定的debug信息开关。
debug module
debug module命令用来打开或关闭器件调试信息。
debug module { adp | all-module | btrm | cf | cfm | conf | cpld | cpu | dev | devm | dim | drv-mod1 | drv-mod2 | drv-mod3 | ec | eeprom | fan | fe | flash| fshe | fwd | ge | ht | i2c | ibc | init | intf | led | lic | lipc | lpu | lpum | mbuf-relay | mbus | mcore | mm | mon | np | nvram | oem | optic | other | pci | per | plat | port | relinfo | rtc | sae | stm | tcam | tmpr | u2f | uart | usb | xge } {on | off }
Probe视图
debugging lipc
debugging lipc命令用来打开LIPC的debug开关。
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
undo debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo | stream } [ lip lip ]
Probe视图
detail:用来打开LIPC的报文详细内容的调试信息开关。
dump port:表示端口号,取值范围为0~65535。
lgmp:用来打开LIPC的LGMP模块的调试信息开关。
mbuf:用来打开LIPC的MBUF模块的调试信息开关。
mtcp:用来打开LIPC的MTCP模块调试信息开关。
pub:用来打开LIPC的PUB模块的调试信息开关。
stcp:用来打开LIPC的STCP模块的调试信息开关。
stream:用来打开LIPC的STREAM模块的调试信息开关。
topo:用来打开LIPC的TOPO模块的调试信息开关。
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
debugging lipc mtcp
debugging lipc mtcp命令用来打开LIPC组播传输控制协议的调试信息开关。
undo debugging lipc mtcp命令用来关闭LIPC组播传输控制协议的调试信息开关。
debugging lipc mtcp [ group group-id ] [ lip lip ]
undo debugging lipc mtcp [ group group-id ] [ lip lip ]
LIPC组播传输控制协议调试信息开关处于关闭状态。
Probe视图
group group-id:要调试的组播端口号,取值范围为0~65535。不指定该参数时,表示所有组播组。
debugging lipc stcp
debugging lipc stcp命令用来打开LIPC单播的调试信息开关。
undo debugging lipc stcp命令用来关闭LIPC单播的调试信息开关。
debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
undo debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
LIPC单播调试信息开关处于关闭状态。
Probe视图
port port1 [ port port2 ]:port1和port2分别为连接的本地和对端端口号,取值范围为0~65535,缺省值为0。
debugging system internal arp event命令用来打开ARP事件调试信息开关。
undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
ARP事件调试信息开关处于关闭状态。
Probe视图
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。
undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP子特性的调试信息开关处于关闭状态。
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp notify命令用来打开ARP的外部通知调试信息开关。
undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
ARP的外部通知调试信息开关处于关闭状态。
Probe视图
debugging system internal arp sync命令用来打开ARP表项的同步调试开关。
undo debugging system internal arp sync命令用来关闭ARP表项的同步调试开关。
ARP表项的同步调试信息开关处于关闭状态。
Probe视图
debugging system internal ike detail { event | packet [ remote-address { ipv4-address | ipv6 ipv6-address } [ local-address { ipv4-address | ipv6 ipv6-address } | remote-port port-number ] * ] }
undo debugging system internal ike detail { event | packet }
Probe视图
event:表示事件调试信息开关。
packet:表示报文调试信息开关。
remote-address:根据对端地址过滤调试信息。
local-address:根据本端地址过滤调试信息。
ipv4-address:表示IPv4地址。
ipv6 ipv6-address:表示IPv6地址。
remote-port remote-port:根据对端端口过滤调试信息。port-number表示对端端口号,取值范围为0~65535。
【描述】
debugging system internal ike detail命令用来打开IKE详细调试开关。undo debugging system internal ike detail命令用来关闭IKE详细调试开关。
缺省情况下,IKE详细调试开关处于关闭状态。
debugging system internal ikev2 detail命令用来打开IKEv2的详细调试开关。
debugging system internal ikev2 detail [ { event | packet | remote-address } { { ipv4-address | ipv6 ipv6-address } [ remote-port port-number | local-address { ipv4-address | ipv6 ipv6-address } ]* ]
undo debugging system interval ikev2 detail [ packet | event ]
Probe视图
event:表示事件调试信息开关。
packet:表示报文调试信息开关。
【描述】
debugging system internal ikev2 detail命令用来打开IKEv2详细调试开关。undo debugging system internal ikev2 detail命令用来关闭IKEv2详细调试开关。
缺省情况下,IKEv2详细调试开关处于关闭状态。
debugging system internal ipsec packet detail命令用来打开IPsec转发过程的调试信息开关。
undo debugging system internal ipsec packet detail命令用来关闭IPsec转发过程的调试信息开关。
debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi ]
undo debugging system internal ipsec packet detail [ acl [ ipv6 ] acl-number | { ipv6-policy | policy } policy-name [ policy-sequence-number ] | profile profile-name | remote { ipv4-address | ipv6 ipv6-address } | spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number ]
Probe视图
acl [ ipv6 ] acl-number:显示符合指定高级ACL的调试信息。ipv6表示IPv6类型的高级ACL,若不支持,则表示IPv4类型的高级ACL。acl-number是高级ACL的变化,取值范围为3000~3999。
{ ipv6-policy | policy } policy-name [ policy-sequence-number ]:显示指定IPv4或IPv6 IPsec安全策略的调试信息。
·     ipv6-policy:IPv6 IPsec安全策略。
·     policy:IPv4 IPsec安全策略。
·     policy-name:IPsec安全策略的名称,为1~63个字符的字符串,不区分大小写。
·     policy-sequence-number:IPsec安全策略的顺序号,取值范围为1~65535,若不指定此参数,则表示显示指定名称IPsec安全策略中所有IPsec安全策略表项的调试信息。
profile profile-name:显示指定IPsec安全框架的调试信息。profile-name是IPsec安全框架的名称,为1~63个字符的字符串,不区分大小写。
remote { ipv4-address | ipv6 ipv6-address }:显示符合指定IPsec隧道对端IPv4/IPv6地址的过滤信息。
·     ipv4-address:IPsec隧道的对端IPv4地址。
·     ipv6 ipv6-address:IPsec隧道的对端IPv6地址。
spi { ipv4-address | ipv6 ipv6-address } { ah | esp } spi-number:显示符合SA的三元组信息(对端IP地址、安全协议、安全参数索引)的过滤信息。
·     ipv4-address:对端的IPv4地址。
·     ipv6 ipv6-address:对端的IPv6地址。
·     ah:AH协议。
·     esp:ESP协议。
spi-number:安全参数索引,取值范围为256~4294967295。
命令用于在Probe视图下查看IPsec转发过程中报文详细信息,包括加密前报文信息、加密后报文详细信息、解密前报文详细信息、解密后报文详细信息。
debugging system internal ipv6 fib prefix命令用来打开IPv6 FIB调试信息开关。
undo debugging system internal ipv6 fib prefix命令用来关闭IPv6 FIB调试信息开关。
debugging system internal ipv6 fib prefix { all | message | hardware }
undo debugging system internal ipv6 fib prefix { all | message | hardware }
IPv6 FIB调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开前缀消息调试开关,打印路由下发和板间同步的IPv6 FIB前缀消息。
hardware:打开下驱动信息调试开关,打印下发驱动信息以及驱动返回的消息。
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
Probe视图
notify表示邻居发现的通知调试开关。
sync 表示邻居发现的同步调试开关。
【描述】
debugging system internal nd命令用来打开邻居发现的调试信息开关。undo debugging system internal nd命令用来关闭邻居发现的外部通知调试信息开关。
缺省情况下,邻居发现的调试信息开关处于关闭状态。
debugging system internal nd sub-features { all | event | packet }
undo debugging system internal nd sub-features
Probe视图
all:表示ND子特性的所有调试信息开关。
event:表示ND子特性的事件调试信息开关。
packet:表示ND子特性的报文调试信息开关。
【描述】
debugging system internal nd sub-features命令用来打开ND子特性的调试开关。undo debugging system internal nd sub-features命令用来关闭ND子特性的调试开关。
缺省情况下,ND子特性的调试开关处于关闭状态。
debugging system internal stg命令用来开启STG调试信息开关。
undo debugging system internal stg命令用来关闭STG调试信息开关。
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
STG调试信息开关处于关闭状态。
Probe视图
all:表示STG所有调试信息开关。
bind:表示STG与VLAN绑定调试信息开关。
error:表示STG错误调试信息开关。
map:表示STG与STI映射事件调试信息开关。
state:表示STG状态设置调试信息开关。
tc:表示TC事件调试信息开关。
debugging system internal stp命令用来开启生成树进程间通信调试开关。
undo debugging system internal stp命令用来关闭生成树进程间通信调试开关。
debugging system internal stp ipc
undo debugging system internal stp ipc
生成树进程间通信调试开关处于关闭状态。
Probe视图
ipc:表示生成树进程间通信调试信息开关。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
Probe视图
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
debugging system internal wlan ap queue message-process-count命令用来打开AP管理进程队列消息处理统计调试信息开关。
undo debugging system internal wlan ap queue message-process-count命令用来关闭AP管理进程队列消息处理统计调试信息开关。
AP管理进程队列消息处理统计调试信息开关处于关闭状态。
Probe视图
按不同线程间隔6秒打印一次,每次打印60组数据,每组按100毫秒的时间间隔统计。统计的内容是每个线程消息队列中新增的消息数量和未处理的消息数量。
debugging system internal wlan ap queue message-type-count命令用来打开AP管理进程队列消息类型统计调试信息开关。
undo debugging system internal wlan ap queue message-type-count命令用来关闭AP管理进程队列消息类型统计调试信息开关。
AP管理进程队列消息类型统计调试信息开关处于关闭状态。
Probe视图
打开AP管理进程队列消息统计调试信息开关后,系统将定时统计APMGR模块不同线程队列中缓存的消息类型的数量,每个线程队列中根据消息类型的多少,按照从大到小的顺序打印前10类信息的统计信息。
debugging system internal wlan ap queue message-type-trace命令用来打开AP管理进程队列指定消息类型读写情况的调试信息开关。
undo debugging system internal wlan ap queue message-type-trace命令用来关闭AP管理进程队列指定消息类型读写情况的调试信息开关。
debugging system internal wlan ap queue message-type-trace msg-type
AP管理进程队列指定消息类型读写情况的调试信息开关处于关闭状态。
Probe视图
msg-type:指定AP管理进程队列消息类型(十六进制数)。该类型最多配置8个,超过8个则从第1个开始进行覆盖。
本功能用于查看线程队列中对指定类型消息的追踪信息。
debugging system internal wlan forward packet用来打开WLAN转发WLAN转发报文调试开关,并设置过滤调试信息的规则。
undo debugging system internal wlan forward packet命令用来关闭WLAN转发报文调试开关,并删除所有设置的过滤调试信息的规则。
debugging system internal wlan forward packet content content-hex [ offset bytes ]
WLAN转发报文的调试开关处于关闭状态。
Probe视图
packet:WLAN转发报文调试信息开关。
content content-hex:指定用来过滤WLAN转发报文调试信息的过滤信息。content-hex表示过滤信息,可以输入多条,信息之间使用符号“&”相隔,表示过滤信息之间是“与”的关系,当过滤信息依次全部匹配成功时,才会打印WLAN转发报文的调试信息。其中每条过滤信息表示报文十六进制内容,形式为H:H:H,H代表用十六进制表示的报文中一个字节的内容,H之间使用“:”相隔,H的个数范围1~256。
offset bytes:表示从指定的偏移位置开始匹配调试信息,bytes表示偏移量,取值范围0~127,单位为字节,缺省值为0字节。当使用“&”指定多条规则时,不可指定offset
debugging transceiver命令用来调试光模块的相关功能。
debugging transceiver { mibcache | moduleinfo | read_write_retry } { disable | enable } interface [ interface-type interface-number ]
设备各款型对于本节所描述的命令支持情况有所不同,详细差异信息如下:
型号
WAC380-30
不支持
WAC380-60
不支持
WAC380-90
支持
WAC380-120
支持
光模块的调试开关处于关闭状态。
Probe视图
moduleinfo:该参数用来控制光模块信息的访问方式。打开调试开关后,上层模块在需要使用光模块的信息时,必须直接从光模块中获取。关闭调试开关后,设备第一次识别光模块时,会在软件内部保存光模块的信息,以便上层模块可直接从软件中获取光模块的信息。
mibcache:该参数用来控制光模块信息的访问方式。打开调试开关后,上层模块需要使用MIB节点的值时,必须通过硬件中的数据立即构建光模块MIB节点的值。关闭调试开关后,系统后台会定期从硬件获取数据来构建光模块MIB节点的值,并将该值保存在内存中供上层模块使用。
read_write_retry:该参数用来控制读写错误的光模块信息时采取的措施。打开调试开关后,即便系统读写的光模块基本信息存在校验和错误,软件也不会重新读写。关闭调试开关后,当系统读写的光模块基本信息存在校验和错误时,软件会重新读写。
disable:关闭调试开关。
enable:打开调试开关。
interface [ interface-type interface-number ]:表示接口类型和接口编号。不指定该参数时,表示所有接口。需要注意的,配置该参数后,会开启/关闭接口所在单板的光模块的相关功能。
debugging wlan ap app命令用来开启APP调试信息开关。
undo debugging wlan ap app命令用来关闭APP调试信息开关。
debugging wlan ap app { app-id | all }
undo debugging wlan ap app { app-id | all }
APP调试信息开关处于关闭状态。
Probe视图
app-id:APP的ID,取值范围为0~274。
all:所有APP。
debugging wlan radio命令用来配置Radio调试信息开关。
undo debugging wlan radio命令用来关闭Radio调试信息开关。
debugging wlan radio { all | error | event } { all | bandwidth | channel | channellist | power | preamble | radiobkp | radiostate | rate | scanconfig | statis | type | wlanid }
undo debugging wlan radio { all | error | event } { all | bandwidth | channel | channellist | power | preamble | radiobkp | radiostate | rate | scanconfig | statis | type | wlanid }
Radio调试信息开关处于关闭状态。
Probe视图
all:表示Radio所有类型调试信息开关。
error:表示Radio的错误类型调试信息开关。
event:表示Radio的事件类型调试信息开关。
all:表示Radio所有场景调试信息开关。
channel:表示Radio工作信道信息场景的调试信息开关。
type:表示Radio工作类型场景的调试信息开关。
radiostate:表示Radio工作状态场景的调试信息开关。
power:表示Radio发射功率场景的调试信息开关。
rate:表示Radio协商速率场景的调试信息开关。
wlanid:表示Radio wlan id场景的调试信息开关。
bandwidth:表示Radio带宽场景的调试信息开关。
channellist:表示Radio信道列表场景的调试信息开关。
radiobkp:表示Radio数据备份场景的调试信息开关。
scanconfig:表示Radio扫描配置场景的调试信息开关。
statis:表示Radio统计信息上报场景的调试信息开关。
preamble:表示Radio前导码场景的调试信息开关。
Radio调试信息开关处于关闭状态。
Probe视图
debugging wlan rfid-tracking命令用来开启WLAN定位调试信息开关。
undo debugging wlan rfid-tracking命令用来关闭WLAN定位调试信息开关。
debugging wlan rfid-tracking { all | error | event | packet }
undo debugging wlan rfid-tracking { all | error | event | packet }
WLAN定位调试信息开关处于关闭状态。
Probe视图
all:表示WLAN定位所有调试信息开关。
error:表示WLAN定位的错误调试信息开关。
event:表示WLAN定位的事件调试信息开关。
packet:表示WLAN定位的报文调试信息开关。
diag app display filename命令用来查看应用程序打包的文件信息。
diag app display filename string
Probe视图
string:带有路径的文件名,为1~128个字符的字符串,不区分大小写。
diag boot-info display命令用来显示设备启动信息。
Probe视图
diag dev-table display命令用来显示设备管理信息。
Probe视图
diag drvflag display命令用来显示各个存储模块的存储区信息。
diag drvflag { apmode | art | bf | bm | capwap | debug | dm | fanmi | lic | log | mac | mi | mon | netcfg | powmi | rel | stm | target | tr } display
Probe视图
【参数】】
apmode:显示AP工作模式信息。
art:显示射频信息。
bf:显示驱动Bootware Flag段标志区信息。
bm:显示主、备启动文件和主、备配置文件信息。
capwap:显示capwap隧道统计信息。
debug:显示目前系统中存储debug信息数量和存储debug起始位置信息。
dm:显示驱动dm段标志区信息,包括flash擦除次数,启动次数,重启类型,调试开关标志。
fanmi:显示风扇制造标志区信息,具体支持情况和设备型号有关。
lic:显示驱动license标志区信息,具体支持情况和设备型号有关。
log:显示驱动存储日志起始位置,日志存储的最大数量等信息。
mac:显示驱动MAC标志区信息。
mi:显示驱动电子标签字段信息。
mon:显示驱动监控信息类型,日志存放起始位置等信息。
netcfg:显示bootware的网络参数。
powmi:显示电源制造信息,具体支持情况和设备型号有关。
rel:显示可靠性,进风口,出风口, cpu,温感等信息。
stm:显示驱动stm标志区信息。
target:显示射频驱动监控信息类型,日志存放起始位置等信息。
tr:显示存储器件测试结果。
diag environment display命令用来显示设备当前各个温感数据。
Probe视图
diag fan display speed命令用来显示风扇速度。
Probe视图
diag hasa display
diag hasa display命令用来显示hasa标志位信息。
diag hasa display
Probe视图
diag if display
diag if display命令用来显示系统接口规格。
diag if display
Probe视图
diag led display
diag led display命令用于显示设备LED指示灯灯状态。
diag led display
Probe视图
diag lipc display
diag lipc display命令用来显示产品IPC信息。FEL层IPC报文用户注册的EINTF信息、多播组信息、IPC收发报文信息。
diag lipc display
Probe视图
diag log display
diag log display命令用来显示设备的日志信息。
diag log display { all | last }
Probe视图
all:显示所有的日志信息。
last:显示最新的日志信息。
diag mbuf-relay display命令用来显示产品mbuf-relay信息。mbuf-relay用户注册的EINTF信息,Mbuf-Relay报文收方向信息,Mbuf-Relay报文发送方向信息。
Probe视图
diag mbus display
diag mbus display命令用来显示mbus的调试信息,显示用户注册的EINTF信息,mbus报文信息。
diag mbus display
Probe视图
diag mem-assign display命令用来显示存储器件的空间分配情况。
Probe视图
diag module display content命令用来显示各个器件模块指定地址存储信息。
diag module slot/subslot { btrm | cf | cpld | cpu | dimm | eeprom | fan | nandflash | norflash | | nvram | pci | power | rtc | tmpr | usb } chip-no display content offset-value len-value
Probe视图
slot/subslot:指定槽位号或者子槽位号。
chip-no:指定芯片编号。
offset-value:指定起始地址。
len-value:指定偏移长度值。
btrm:显示bootrom的信息。
cf:显示cf卡的信息。
cpld:显示cpld的信息。
cpu:显示cpu的信息。
dimm:显示内存的信息。
eeprom:显示eeprom的信息。
fan:显示风扇的信息。
nandflash:显示nandflash的信息。
norflash:显示norflash的信息。
nvram:显示nvram的信息。
pci:显示pci的信息。
power:显示电源的信息。
rtc:显示硬件时钟的信息。
tmpr:显示温感的信息。
usb:显示usb的信息。
diag module display content命令用来显示mac或phy模块各个端口信息。
diag module slot/subslot { mac | phy } { aux | console | ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | ten-gigabitethernet | wlan-radio } chip-no display content offset-value len-value
Probe视图
设备接口类型的支持情况请以设备实际情况为准。
mac:显示mac模块各个端口信息。
phy:显示phy模块各个端口信息。
auxaux接口,本参数的支持情况与设备型号有关。
consoleconsole接口,本参数的支持情况与设备型号有关。
ethernet:以太网接口,本参数的支持情况与设备型号有关。
gigabitethernet:GE接口,本参数的支持情况与设备型号有关。
i-gigabitethernet:内部GE接口,本参数的支持情况与设备型号有关。
inasync:内部异步接口,本参数的支持情况与设备型号有关。
inner-ethernet:内部以太网接口,本参数的支持情况与设备型号有关。
m-ethernet:百兆管理以太网接口,本参数的支持情况与设备型号有关。
m-gigabitethernet:千兆管理以太网接口,本参数的支持情况与设备型号有关。
ten-gigabitethernet:10GE(万兆以太网接口),本参数的支持情况与设备型号有关。
wlan-radio:无线射频接口,本参数的支持情况与设备型号有关。
chip-no:指定芯片编号。
len-value:指定偏移长度值。
diag pcie display
diag pcie display命令用于显示PCIE状态。
diag pcie slot/subslot display chip-no bus-id device-id function-id offset width
Probe视图
chip-no:指定芯片号。
bus-id:指定总线号。
device-id:指定设备ID。
function-id:指定功能ID。
offset:指定偏移量。
width:指定长度。
diag poe
diag poe命令用于设置超瘦本体PoE功能状态,以及获取端口PoE工作状态。
diag poe slot/subslot { port-no | all } { disable | enable | status }
Probe视图
slot/subslot:指定槽位号或子槽位号。
port-no:指定端口号。
all:配置所有端口的PoE功能。
disable:关闭端口PoE功能。
enable:开启端口PoE功能。
status:显示端口PoE功能的状态,关闭或开启。
diag port display statistics命令用来显示各端口统计信息。
diag port { aux | console | Ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | wlan-radio } display statistics
Probe视图
all:显示所有端口的统计信息。
aux:显示aux接口的统计信息,本参数的支持情况与设备型号有关。
console:显示console接口的统计信息。
ethernet:显示以太网接口的统计信息,本参数的支持情况与设备型号有关。
gigabitethernet:显示GE接口的统计信息,本参数的支持情况与设备型号有关。
i-gigabitethernet:显示内部GE接口的统计信息,本参数的支持情况与设备型号有关。
inasync:显示内部异步接口的统计信息,本参数的支持情况与设备型号有关。
inner-ethernet:显示内部以太网接口的统计信息,本参数的支持情况与设备型号有关。
m-ethernet:显示以以太管理接口的统计信息,本参数的支持情况与设备型号有关。
m-gigabitethernet:显示管理以太网接口的统计信息,本参数的支持情况与设备型号有关。
ten-gigabitethernet:显示10GE接口的统计信息,本参数的支持情况与设备型号有关。
wlan-radio:显示无线射频接口的统计信息,本参数的支持情况与设备型号有关。
smartrate-ethernet:显示smartrate-ethernet以太网接口的统计信息,本参数的支持情况与设备型号有关。
fortygige:显示fortygige接口的统计信息,本参数的支持情况与设备型号有关。
diag port-list display命令用来显示所有端口列表。
Probe视图
diag port-table display命令用来显示上报平台端口列表。
Probe视图
diag stm display
diag stm display命令用来显示堆叠调试信息,包括是否支持堆叠、支持盒式堆叠还是分布式堆叠,获取堆叠的能力等信息。
diag stm display
Probe视图
diag stm statistic display命令用来显示堆叠收发统计信息。
Probe视图
diag temperature display status命令用来显示温感信息。
Probe视图
diag tmpr-alarm display threshold命令用来显示进风口最低温度和最高温度。
Probe视图
display debug-info
display debug-info命令用来打印debug设置信息。
display debug-info
Probe视图
display fastforward session table命令用来显示未经过安全业务处理的会话表项。
display fastforward session table { ipv4 | ipv6 } [ source-ip source-ip ] [ destination-ip destination-ip ] [ verbose ]
Probe视图
ipv4:显示IPv4会话表项。
ipv6:显示IPv6会话表项。
source-ip source-ip:显示指定源IP地址的会话表项。其中,source-ip表示发起方到响应方会话的源IP地址。
destination-ip destination-ip:显示指定目的IP地址的会话表项。其中,destination-ip表示发起方到响应方会话的目的IP地址。
verbose:显示详细的会话表项。不指定该参数表示显示会话表项的概要信息。
如果除ipv4ipv6外不指定任何参数,则显示所有未经过安全业务处理的IPv4或IPv6会话表项。
display hardware internal transceiver register interface命令用来显示可插拔光模块上指定寄存器区域的内容,用十六进制数表示。
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
型号
WAC380-30
不支持
WAC380-60
不支持
WAC380-90
支持
WAC380-120
支持
Probe视图
interface interface-type interface-number:显示接口上插入的可插拔光模块上的寄存器信息。interface-type interface-number表示接口类型和接口编号。
device device-index:表示指定接口上光模块内部寄存器的索引号,用十六进制数表示,取值范围为0~FF。
address start-address:起始地址,即需要显示的寄存器区域的起始点的偏移地址。用十六进制数表示,取值范围为0~FFFF。
length region-length:寄存器区域的长度,即需要显示的寄存器区域的字节数。用十进制数表示,取值范围为1~256。
display system internal acl命令用来显示ACL的配置和运行情况。
display system internal acl [ ipv6 | mac ] { acl-number | name acl-name }
Probe视图
ipv6:指定ACL类型为IPv6 ACL。
mac:指定ACL类型为二层ACL。
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:表示基本ACL。
·     3000~3999:表示高级ACL。
·     4000~4999:表示二层ACL。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。
display system internal arp命令用来显示指定设备学习到的ARP表项信息或表项个数。
display system internal arp { all | static | dynamic } [ count ]
Probe视图
all: 命令用来显示所有ARP表项信息或表项个数。
static: 用来显示静态ARP表项信息或表项个数。
dynamic: 用来显示动态ARP表项信息或表项个数。
count:用来显示ARP表项个数。
display system internal arp ifcb命令用来查看指定设备上二层或三层接口ARP控制块信息。
display system internal arp ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
display system internal arp ip-address命令用来显示指定设备的指定IP的ARP表项信息。
Probe视图
ip-address: 用来显示指定IP的ARP表项信息。
display system internal arp machash命令用来显示指定设备上machash表项信息。
display system internal arp machash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id: 显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的ID。
ip ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址。
display system internal arp probe命令用来显示指定设备上ARP探测链表项。
Probe视图
display system internal arp rbhash命令用来显示指定设备上rbhash表项信息。
display system internal arp rbhash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id: 显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ip ip-address:显示指定IP上rbhash表项信息。
display system internal arp reload命令用来显示指定设备上ARP重刷链表项。
Probe视图
display system internal arp rule命令用来显示ARP规则信息。
display system internal arp rule { all | interface interface-type interface-number [ ip-address ] }
Probe视图
all:显示所有ARP规则信息。
interface interface-type interface-number:显示指定接口的ARP规则信息,interface-type interface-number表示接口类型和接口编号。
ip-address:显示指定IP地址的ARP规则信息。
display system internal arp source-suppression cache命令用来显示指定成员设备的源抑制表项。
Probe视图
display system internal arp statistics命令用来显示指定成员设备的ARP统计信息。
Probe视图
display system internal arp vlan命令用来显示指定VLAN的ARP表项信息或表项个数。
display system internal arp vlan vlan-id [ count ]
Probe视图
vlan vlan-id: 用来显示指定VLAN的ARP表项信息或表项个数。
display system internal aspf statistics命令用来查看ASPF、报文过滤的丢包统计信息。
display system internal aspf statistics interface { ipv4 | ipv6 }
Probe视图
interface:查看接口上的ASPF丢包统计信息。
ipv4:查看IPv4报文的丢包统计信息。
ipv6:查看IPv6报文的丢包统计信息。
display system internal attack-defense scan stat-nodes ip命令用来显示扫描攻击防范的IPv4统计节点信息。
display system internal attack-defense scan stat-nodes ip [ { source | destination } [ ipv4-address ] ] [ interface interface-type interface-number | local ] [ count ]
Probe视图
source:显示基于源IP地址进行统计的扫描攻击统计节点。
destination:显示基于目的IP地址进行统计的扫描攻击统计节点。
ipv4-address:表示指定的源IPv4地址或目的IPv4地址,不能为广播地址、127.0.0.0/8网段地址、D类地址或E类地址。
interface interface-type interface-number:显示指定接口的扫描攻击统计节点,interface-type interface-number表示接口类型和接口编号。
local:显示本机上进行检测的扫描攻击统计节点。
count:显示符合指定条件的统计节点的个数。
display system internal attack-defense scan stat-nodes ipv6命令用来显示扫描攻击防范的IPv6统计节点信息。
display system internal attack-defense scan stat-nodes ipv6 [ { source | destination } [ ipv6-address ] ] [ interface interface-type interface-number | local ] [ count ]
Probe视图
source:显示基于源IPv6地址进行统计的扫描攻击统计节点。
destination:显示基于目的IPv6地址进行统计的扫描攻击统计节点。
ipv6-address:表示指定的源IPv6地址或目的IPv6地址。
display system internal cloud-management state命令用来显示模块的云平台连接状态。
display system internal cloud-management state [ module module-name ]
Probe视图
module module-name:显示指定模块的云平台连接状态。module-name表示模块名,为1~31个字符的字符串,区分大小写。不指定本参数时,显示所有模块的云平台连接状态。
display system internal dbm命令用来显示数据库信息。
display system internal dbm { all | name dbname [ key keyname ] }
Probe视图
all:表示所有数据库。
name dbname:指定数据库名。
key keyname:指定key的名称,在数据库中以key名称标识一项数据。
display system internal dot11 characteristics命令用来显示802.11侦听特征的统计信息和详细信息。
display system internal dot11 characteristics bss bssid
Probe视图
bss bssid:显示BSS实体的特征统计信息和详细信息,包括BSS接收报文方向和发送报文方向。
display system internal dot11 verbose命令用来显示802.11协议socket的详细信息。
Probe视图
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
display system internal ethernet character { global | interface interface-type interface-number }
Probe视图
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:表示接口类型和接口编号。
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如STP,LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
display system internal ethernet controlblock interface { interface-type interface-number }
Probe视图
display system internal ifmgr down命令用来显示已注册的down类型。
Probe视图
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para | help }
Probe视图
para:指定显示时的参数。表示接口名或接口索引,格式为:1*接口索引,2*接口名。
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para | help }
Probe视图
para:指定显示时的参数。para为事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,格式为:event*type
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para | help }
Probe视图
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口树信息。
display system internal ifmgr list [ para | help ]
Probe视图
para:指定显示时的参数。para为接口类型对应的数值,该数值可通过help参数获取。
接口树用于管理设备上存在的接口。树上的节点对应接口,子节点对应接口下创建的子接口,每个节点的信息包括接口的名称和索引。
不指定parahelp参数时,显示所有类型接口的接口树信息。
display system internal ifmgr name命令用来显示接口名字解析树信息。该树用于解析接口名字,以及命令行上输入接口名字时的帮助检查。
display system internal ifmgr name { para | help }
Probe视图
para:指定显示时的参数,为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para | help }
Probe视图
para:指定显示时的参数。para为接口类型,为1~127个字符的字符串。
display system internal ike phase2-sa count命令用来显示IKE第二阶段SA的个数。
display system internal ike phase2-sa count [ phase1-connection-id connection-id ]
Probe视图
phase1-connection-id connection-id:指定IKE第一阶段的连接标识,可以根据此表示显示第二阶段SA的个数,取值范围为1~2000000000。
通过display ike sa可以查看IKE第一阶段的连接标识。
display system internal ike phase2-sa verbose命令用来显示IKE第二阶段SA的详细信息。
Probe视图
display system internal ike received-message count命令用来显示IKE接收消息的个数。
display system internal ike received-message count [ verbose ipsec-doi ]
Probe视图
verbose:显示IKE收到消息个数的详细信息。
ipsec-doi:显示接收IPsec-DOI消息个数的详细信息。
display system internal ike sent-message count命令用来显示IKE发送消息的个数。
display system internal ike sent-message count [ verbose ipsec-doi ]
Probe视图
verbose:显示IKE发送消息个数的详细信息。
ipsec-doi:显示发送给IPsec-DOI消息个数的详细信息。
display system internal ikev2 child-sa count命令用来显示Child SA的个数。
display system internal ikev2 child-sa count [ tunnel-id tunnel-id ]
Probe视图
tunnel-id tunnel-id:指定IKEv2 SA的Tunnel ID,用来显示Child SA的个数,取值范围为1~2000000000。
通过display ikev2 sa可以查看Tunnel ID。
display system internal ip address命令用来显示地址详细信息
display system internal ip address [ ip-address | interface interface-type interface-number ]
Probe视图
ip-address:显示指定IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
display system internal ipsec block-flow命令用来显示IPsec阻流表信息。
Probe视图
阻流表是为了阻止相同流量重复触发IPsec协商,以节省系统资源。阻流表默认协商成功或者失败后就会删除。
display system internal ipsec received-message count命令用来显示IPsec接收自IKE的消息个数。
display ipsec system internal ipsec received-message count
Probe视图
display system internal ipsec sent-message count命令用来显示IPsec发送给IKE的消息个数。
display ipsec system internal ipsec sent-message count
Probe视图
display system internal ipsec sp命令用来显示IPsec的SP信息。
display system internal ipsec sp { brief | sp-id sp-id }
Probe视图
brief:表示显示IPsec SP的摘要信息。
sp-id sp-id:表示显示指定IPsec SP的详细信息。sp-id是IPsec SP的ID号,取值范围为0~4294967295。
SP是IPsec Security Policy生成的动态数据,有可能每个板都会有SP信息,查看时需要区分板号。
display system internal ipv6 address命令用来显示IPv6地址详细信息
display system internal ipv6 address [ interface interface-type interface-number [ gateway | multicast | prefix | unicast ] ] [ ipv6-address ]
Probe视图
interface interface-type interface-number:显示指定接口的IPv6地址,interface-type interface-number表示接口类型和接口编号。
gateway:显示指定接口的网关地址信息。
multicast:显示指定接口的组播地址信息。
prefix:显示指定接口的ipv6前缀信息。
unicast:显示指定接口的单播地址信息。
ipv6-address:显示指定的IPv6地址。
display system internal ipv6 fib prefix命令用来显示IPv6 FIB前缀基本信息。
Probe视图
display system internal ipv6 fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv6 FIB表项信息信息。
display system internal ipv6 fib prefix entry-status status
Probe视图
entry-status status:用于匹配IPv6 FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv6 FIB表项,“F”表示下刷驱动失败的IPv6 FIB表项。
display system internal ipv6 fib prefix ipv6命令用来显示IPv6 FIB前缀详细信息。
display system internal ipv6 fib prefix ipv6 [ prefix-length ]
Probe视图
ipv6:显示目的地址为指定IPv6地址的IPv6 FIB前缀详细信息。
prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
display system internal ipv6 l2-multicast ip forwarding verbose命令用来显示IPv6二层组播的IP转发表详细信息。
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ]
Probe视图
group ipv6-group-address:显示指定IPv6组播组的信息。如果未指定本参数,将显示所有IPv6组播组的信息。
source ipv6-source-address:显示指定IPv6组播源的信息。如果未指定本参数,将显示所有IPv6组播源的信息。
vlan vlan-id:显示指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
display system internal ipv6 l2-multicast ip verbose命令用来显示IPv6二层组播的IP组播组详细信息。
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ]
Probe视图
display system internal ipv6 l2-multicast ipc statistics命令用来显示IPv6二层组播板间消息的统计信息。
Probe视图
display system internal ipv6 l2-multicast mac forwarding verbose命令用来显示IPv6二层组播的MAC转发表详细信息。
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
mac-address:显示指定MAC组播组的信息。如果未指定本参数,将显示所有MAC组播组的信息。
display system internal ipv6 l2-multicast mac verbose命令用来显示IPv6二层组播的MAC组播组详细信息。
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
display system internal ipv6 multicast forwarding vlan reference命令用来显示VLAN出接口与IPv6二层组播表项之间的映射关系。
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ]
Probe视图
display system internal ipv6 multicast forwarding-table dummy命令用来显示IPv6组播临时转发表的信息。
display system internal ipv6 multicast forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | statistics ] *
Probe视图
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
prefix-length:指定IPv6组播源或IPv6组播组地址的前缀长度。对于IPv6组播源地址,其取值范围为0~128,缺省值为128;对于IPv6组播组地址,其取值范围为8~128,缺省值为128。
statistics:显示统计信息。
display system internal ipv6 pathmtu命令用来显示IPv6的PMTU信息,信息全局同步。
display system internal ipv6 pathmtu { ipv6-address | { all | dynamic | static } [ count ] }
Probe视图
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有公网的PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
count:显示PMTU表项数目。
display system internal ipv6 rawip命令用来显示设备上所有IPv6 RawIP连接的摘要信息。
Probe视图
display system internal ipv6 rib event attribute 命令用来显示IPv6 RIB的路由属性事件信息。
Probe视图
display system internal ipv6 rib event policy命令用来显示IPv6 RIB的路由策略事件信息。
Probe视图
display system internal ipv6 rib event prefix命令用来显示IPv6 RIB的路由前缀事件信息。
Probe视图
display system internal ipv6 rib event protocol命令用来显示IPv6 RIB的协议事件信息。
Probe视图
display system internal ipv6 rib event statistics用来显示IPv6 RIB的统计事件信息。
Probe视图
display system internal ipv6 rib instance命令用来显示IPv6 RIB的协议进程信息。
Probe视图
display system internal ipv6 rib log命令用来显示IPv6 RIB的日志信息。
display system internal ipv6 rib log [ reverse ]
display system internal ipv6 rib event log
Probe视图
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志信息。
display system internal ipv6 rib nib log [ reverse ]
Probe视图
nib:显示IPv6 NIB子模块的运行状态。
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
display system internal ipv6 rib prefix ipv6-address prefix-length
Probe视图
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
Probe视图
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
display system internal ipv6 route-direct interface [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
ipv6-address:IPv6地址。
display system internal ipv6 route-direct log命令用来显示IPv6直连路由日志信息。
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:IPv6直连路由NIB子模块相关日志。
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
display system internal ipv6 tcp命令用来显示设备上所有IPv6 TCP连接的摘要信息。
Probe视图
display system internal ipv6 tcp port-info命令用来显示IPv6 TCP模块非保留端口的使用信息。
Probe视图
display system internal ipv6 tcp-proxy verbose命令用来显示IPv6 TCP代理连接的详细信息。
Probe视图
display system internal ipv6 udp命令用来显示设备上所有IPv6 UDP连接的摘要信息。
Probe视图
display system internal ipv6 udp port-info命令用来显示IPv6 UDP模块非保留端口的使用信息。
Probe视图
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
display system internal kernel memory dump address address-hex length memory-length
Probe视图
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
display system internal kernel memory pool [ name name-string ]
display system internal kernel memory pool tag [ tag-value ]
display system internal kernel memory pool name name-string tag tag-value
Probe视图
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
不指定nametag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
display system internal l2-multicast ip forwarding verbose命令用来显示二层组播的IP转发表详细信息。
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ]
Probe视图
group group-address:显示指定组播组的信息。如果未指定本参数,将显示所有组播组的信息。
source source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
display system internal l2-multicast ip verbose命令用来显示二层组播的IP组播组详细信息。
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ]
Probe视图
display system internal l2-multicast ipc statistics命令用来显示二层组播板间消息的统计信息。
Probe视图
display system internal l2-multicast mac forwarding verbose命令用来显示二层组播的MAC转发表详细信息。
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
display system internal l2-multicast mac verbose命令用来显示二层组播的MAC组播组详细信息。
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ]
Probe视图
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
display system internal link-aggregation interface bridge-aggregation interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
interface-type interface-number:聚合成员口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
ipv4:IPv4报文统计值。
ipv6:IPv6报文统计值。
·     如果未指定kernelstatistics参数,则显示LAGG主线程中接口的基本数据。
·     如果未指定ipv4ipv6参数,则显示所有报文统计值。
·     部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
display system internal lipc dump命令用来显示LIPC抓包记录。
display system internal lipc dump [ lip lip ]
Probe视图
display system internal lipc dump configuration命令用来显示配置的LIPC抓包规则。
display system internal lipc dump configuration [ lip lip ]
Probe视图
display system internal lipc history命令用来以图表方式显示LIPC各协议的历史流量信息。
display system internal lipc history [ mtcp | publish | stcp ] { recv | send } { by-min | by-sec } [ lip lip ]
Probe视图
mtcp显示组播传输控制协议的历史流量信息。不指定mtcppublishstcp参数时,表示显示三种协议报文流量总和的历史信息。
publish显示可靠发布协议的历史流量信息。不指定mtcppublishstcp参数时,表示显示三种协议报文流量总和的历史信息。
stcp显示单播传输控制协议的历史流量信息。不指定mtcppublishstcp参数时,表示显示三种协议报文流量总和的历史信息。
recv:显示当前协议的历史接收流量。
send:显示当前协议的历史发送流量。
by-min:以分钟为单位显示最近30分钟内的历史流量。
by-sec:以秒为单位显示最近30秒内的历史流量。
display system internal lipc lcmp statistics命令用来显示LIPC LCMP全局统计信息,包括收发包计数和错误计数。
display system internal lipc lcmp statistics [ lip lip ]
显示本地节点LCMP全局统计信息。
Probe视图
lip lip表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
display system internal lipc lgmp group命令用来显示一个指定组播组信息,包含成员信息和组播组相关的统计信息。
display system internal lipc lgmp group groupID [ lip lip ]
显示本地节点指定组播组信息。
Probe视图
groupID:表示组播组号,取值范围为0~4294967295。
display system internal lipc lgmp group-list命令用来查看系统中所有已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
display system internal lipc lgmp group-list [ lip lip ]
显示本地节点已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
Probe视图
display system internal lipc lgmp physical-group命令用来显示指定的硬件组播组信息。
display system internal lipc lgmp physical-group phyID [ lip lip ]
显示本地节点指定的硬件组播组信息。
Probe视图
physical-group phyID:表示硬件组播组ID,取值范围为0~4294967295。
display system internal lipc lgmp physical-group-list命令用来显示所有的硬件组播组信息,以便了解硬件组播组的使用情况。
display system internal lipc lgmp physical-group-list [ lip lip ]
显示本节点显示所有的硬件组播组信息。
Probe视图
display system internal lipc lgmp statistics命令用来显示LIPC LGMP模块的统计信息。
display system internal lipc lgmp statistics [ lip lip ]
显示本地节点LIPC LGMP模块的统计信息。
Probe视图
display system internal lipc lip statistics命令用来显示LIPC LIP全局统计信息。包括LIP报文的收发计数和出错计数。
display system internal lipc lip statistics [ lip lip ]
显示本地节点LIP全局统计信息。
Probe视图
display system internal lipc loop statistics命令用来显示本地环回的统计信息。
display system internal lipc loop statistics [ lip lip ]
显示本地节点环回的统计信息。
Probe视图
display system internal lipc mtcp group命令用来显示LIPC显示某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
显示本地节点某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
Probe视图
portID:组播组的端口号,一个端口号标识一个组播组,取值范围为0~4294967295。
history:显示该组播组状态机的历史变迁轨迹。
member:显示该组播组的成员信息。
statistics:显示该组播组的统计信息。
display system internal lipc mtcp group all命令用来显示所有包含本节点的组播组的统计信息。
display system internal lipc mtcp group all [ lip lip ]
Probe视图
display system internal lipc mtcp performance命令显示LIPC组播性能信息。
display system internal lipc mtcp performance [ lip lip ]
显示本地节点LIPC组播性能信息。
Probe视图
必须打开相应得性能统计开关后,该命令才能输出性能信息。
·     lipc performance
display system internal lipc mtcp statistics命令用来显示LIPC组播的全局统计信息。
display system internal lipc mtcp statistics [ lip lip ]
显示本地节点LIPC组播的全局统计信息。
Probe视图
display system internal lipc pcb mbuf statistics命令用来显示LIPC各个PCB下的MBUF使用情况。
display system internal lipc pcb mbuf statistics [ lip lip ]
Probe视图
lip lip:表示节点号,取值范围为0~32767。不指定该参数时,表示本节点。
display system internal lipc pcb statistics命令用来显示LIPC PCB模块全局统计信息。
display system internal lipc pcb statistics [ lip lip ]
显示本地节点PCB模块全局统计信息。
Probe视图
display system internal lipc physical命令用来显示驱动适配层的全局统计信息。用于统计LIPC与驱动交互的各种信息,包括收发包计数,驱动错误计数和驱动上报事件计数。
display system internal lipc physical [ lip lip ]
显示本地节点驱动适配层的全局统计信息。
Probe视图
display system internal lipc publish global-cb命令用来显示LIPC PUBLISH模块全局控制块信息。
display system internal lipc publish global-cb [ lip lip ]
显示本地节点PUBLISH模块全局控制块信息。
Probe视图
一般用于诊断Pub模块在某个节点上是否乱序。
display system internal lipc publish statistics命令用来显示LIPC  PUBLISH模块统计信息。
display system internal lipc publish statistics [ lip lip ]
显示本地节点PUBLISH模块的统计信息。
Probe视图
display system internal lipc stcp event命令用来显示LIPC单播事件的信息。
display system internal lipc stcp event { sync | trans } [ lip lip ]
显示本地节点LIPC单播的事件信息。
Probe视图
sync:显示LIPC单播控制报文事件信息。
trans:显示LIPC单播数据报文事件信息。
该命令主要记录本节点和其他节点的连接/DACK/销毁/时序交互信息。当设备上连接很多时,该命令记录的条目很容易满(512条),此时会将最老的记录清除掉。因此,发现问题时,应当尽早执行该命令,获取事件信息,便于定位分析。
display system internal lipc stcp global-server命令显示LIPC单播的全局知名端口信息。
display system internal lipc stcp global-server [ lip lip ]
显示本地节点LIPC单播的全局知名端口同步信息。
Probe视图
display system internal lipc stcp links命令用来显示单播的连接信息。包括收发包信息、状态信息、缓存信息等。
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
显示本节点LIPC单播的连接信息。
Probe视图
all:表示显示本节点所有的单播连接信息。
detail port:表示指定端口号的具体信息,取值范围为0~65535。
global gport:表示全局知名端口号,取值范围为100~8100。
listening:表示显示本节点处于侦听状态的连接。
local lport:表示本地端口号,取值范围为10100~65535。
singledetail lport rport:表示指定本地端口号和目的端口号的具体信息,取值范围为0~65535。
display system internal lipc stcp performance命令用来显示单播的性能信息。
display system internal lipc stcp performance [ lip lip ]
显示本地节点LIPC单播的性能信息。
Probe视图
必须使用lipc performance命令打开相应的性能统计开关后,该命令才能输出性能信息。
·     lipc performance
display system internal lipc stcp port命令用来显示单播支持的知名端口的指定操作的统计信息。
display system internal lipc stcp port { close | connect | get-port | half-close| recv-get-port | resend | send } [ lip lip ]
Probe视图
close:显示当前节点各端口的连接关闭次数。
connect:显示当前节点各端口的连接请求次数。
get-port:显示当前节点各全局知名端口的目的节点请求次数。
half-close:显示各端口的连接半关闭次数。
recv-get-port:显示当前节点收到的全局知名端口目的节点请求次数。
resend:显示各端口的重传次数。
send:显示各端口的发送次数。
display system internal lipc stcp statistics命令用来显示LIPC单播的全局统计信息,用于分析单播的全局工作情况。
display system internal lipc stcp statistics [ lip lip ]
显示本节点LIPC单播的统计信息。
Probe视图
display system internal lipc stcp status命令用来显示单播的传输状态。主要记录单播对象的传输序号、ACK序号、发送标志、接收状态。该命令通常用于分析单播的数据可靠传输问题。
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe视图
recv:显示接收端的单播传输状态。
send:显示发送端的单播传输状态。
display system internal lipc stream命令用来查看流模式单播的记录信息。
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
显示本地节点LIPC单播流模式信息。
Probe视图
ack:表示查看指定端口号的收到ACK的记录。
reass:表示查看指定端口号的接收重组队列信息。
send:表示查看指定端口号的发送报文分片记录。
port portID:表示端口号,为0~65535的整数。
display system internal lipc sudp pcb-info命令用来查看SUDP模块的PCB详细信息。
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
显示本地节点SUDP模块的PCB详细信息。
Probe视图
all-port:显示所有PCB信息。
global-port:显示全局知名端口的PCB信息。
local-port:显示本地知名端口的PCB信息。
specific-port portID:表示指定端口号,取值范围为0~65535。
display system internal lipc sudp statistics命令用来显示LIPC SUDP模块的全局统计信息。
display system internal lipc sudp statistics [ lip lip ]
显示本地节点SUDP模块的全局统计信息。
Probe视图
display system internal lipc sudp命令用来查看所有SUDP全局知名端口号或本地端口号的信息。
display system internal lipc sudp { global-port | local-port } [ lip lip ]
显示本地节点SUDP全局知名端口号或本地端口号的信息。
Probe视图
global-port:表示查看所有SUDP全局知名端口号的信息。
local-port:表示查看所有SUDP本地端口号的信息。
display system internal lipc topology history命令用来查看拓扑链接信息的历史变迁记录。
display system internal lipc topology history [ lip lip ]
显示本地节点拓扑链接信息的历史变迁记录。
Probe视图
display system internal lipc topology link命令用来显示LIPC 的拓扑链接信息。
display system internal lipc topology link [ lip lip ]
显示本地节点LIPC 的拓扑链接信息。
Probe视图
display system internal lipc topology node命令用来查看拓扑节点相关的统计信息。
display system internal lipc topology node nodeID [ lip lip ]
显示本地节点上和其他拓扑节点相关的统计信息。
Probe视图
nodeID:表示节点号,取值范围为0~32767。
记录了该节点上事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology process-time命令用来查看发生拓扑事件时,通知各个模块耗时。
display system internal lipc topology process-time [ lip lip ]
显示本地节点发生拓扑事件时,通知各个模块耗时。
Probe视图
display system internal lipc topology statistics命令用来查看拓扑相关的全局统计。记录了该全局事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology statistics [ lip lip ]
显示本地节点拓扑相关的全局统计。
Probe视图
display system internal lipc topology status命令用来显示节点的拓扑状态信息。
display system internal lipc topology status [ lip lip ]
显示本地节点拓扑状态信息。
Probe视图
display system internal lps命令用来显示LPS(Linux Packet Socket)信息。
Probe视图
lps:显示LPS信息。
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
display system internal mac-address configuration { blackhole | static } [ count ]
Probe视图
blackhole:显示黑洞MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
display system internal mac-address learned命令用来显示动态MAC地址表项。
display system internal mac-address learned [ mac-address [ vlan vlan-id ] | [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
Probe视图
mac-address:显示指定MAC地址的动态MAC地址表项,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示指定VLAN的动态MAC地址表项。vlan-id的取值范围为1~4094。
interface interface-type interface-number:显示指定接口的动态MAC地址表项。interface-type interface-number为接口类型和接口编号。
count:显示动态MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)动态MAC地址表项的数量,而不显示动态MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的动态MAC地址表项的具体内容。
display system internal mac-address protocol命令用来显示指定协议或特性生成的MAC地址或VLAN接口的MAC地址。
display system internal mac-address protocol [ auth | client | dot1x | security | vlan-interface ] [ count ]
Probe视图
auth:显示MAC地址认证特性的MAC地址表项。
client:显示在线用户的MAC地址表项。目前,仅显示无线在线用户的MAC地址表项。
dot1x:显示802.1X特性的MAC地址表项。
security:显示端口安全特性中学习到的MAC地址表项。
vlan-interface:显示VLAN接口的MAC地址表项。
count:显示MAC地址表项的数量。如果指定了本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果未指定本参数,则显示符合条件的MAC地址表项的具体内容。
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
Probe视图
display system internal mac-forwarding cache ip verbose命令用来显示IP快转表项的详细内容。
display system internal mac-forwarding cache ip [ ip-address ] verbose
probe视图
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
display system internal mac-forwarding cache ipv6 verbose命令用来显示IPv6快转表项的详细内容。
display system internal mac-forwarding cache ipv6 [ ipv6-address ] verbose
probe视图
ipv6-address:显示指定IPv6地址的IPv6快速转发表信息。如果不指定ipv6-address,将显示所有IPv6地址的IPv6快速转发表信息。
display system internal mac-forwarding controlblock命令用来显示二层转发的接口控制信息。
display system internal mac-forwarding controlblock interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的二层转发控制信息。其中,interface-type interface-number为指定接口类型和接口编号。
display system internal mbuf relay statistics命令用来显示MBUF中继模块的统计信息。
display system internal mbuf relay statistics [ vcpu vcpu-number ] [ rcv receiver-id ]
Probe视图
vcpu vcpu-number:MBUF中继使用的VCPU的编号。不指定该参数时,表示当前成员设备上的所有VCPU。
rcv received-id:MBUF中继接收者的编号,取值范围为0~127。不指定该参数时,表示当前VCPU上的所有接收者。
display system internal multicast capability命令用来显示组播能力的信息。
Probe视图
display system internal multicast forwarding vlan reference命令用来显示VLAN出接口与二层组播表项之间的映射关系。
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ]
Probe视图
display system internal multicast forwarding-table dummy命令用来显示组播临时转发表的信息。
display system internal multicast forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] ] *
Probe视图
group-address:显示指定组播组的信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
display system internal multicast record命令用来显示组播表项的操作记录。
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-data-group | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } }
Probe视图
statistics:显示组播表项操作记录的统计信息。
all:显示组播表项的所有操作记录。
fail:显示组播表项的失败操作记录。
group-address:组播组地址,显示指定组播组的记录。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的记录。
source-address:组播源地址,显示包含指定组播源的记录。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的记录。
item item-list:记录列表,表示一条或多条记录。表示方式为item-list = start-item [ to end-item ]。其中,start-itemend-item的取值范围均为1~500000。
filter:显示指定模式下的组播表项操作记录。
exclude:显示排除满足指定条件的组播表项操作记录。
include:显示包含满足指定条件的组播表项操作记录。
add-l2-ip:表示添加二层IP表项的操作记录。
add-l2-ip-port:表示添加二层IP表项端口的操作记录。
add-l2-ip-slot:表示添加二层IP表项板信息的操作记录。
add-l2-mac:表示添加二层MAC表项的操作记录。
add-l2-mac-port:表示添加二层MAC表项端口的操作记录。
add-l2-mac-slot:表示添加二层MAC表项板信息的操作记录。
add-l3-ipm:表示添加三层组播表项的操作记录。
add-l3-oif:表示添加三层表项出接口的操作记录。
add-l3-port:表示添加三层表项出端口的操作记录。
add-l3-slot:表示添加三层表项分布式转发的出接口板信息的操作记录。
del-l2-ip:表示删除二层IP表项的操作记录。
del-l2-ip-port:表示删除二层IP表项端口的操作记录。
del-l2-ip-slot:表示删除二层IP表项板信息的操作记录。
del-l2-mac:表示删除二层MAC表项的操作记录。
del-l2-mac-port:表示删除二层MAC表项端口的操作记录。
del-l2-mac-slot:表示删除二层MAC表项板信息的操作记录。
del-l3-ipm:表示删除三层组播表项的操作记录。
del-l3-oif:表示删除三层表项出接口的操作记录。
del-l3-port:表示删除三层表项出端口的操作记录。
del-l3-slot:表示删除三层表项分布式转发的出接口板信息的操作记录。
set-l3-data-group:表示设置三层表项对应的Data-Group地址。
set-l3-iif:表示设置三层表项入接口的操作记录。
ipmc-type-all:表示全部类型。
verbose:显示详细信息。如果记录的出接口和出端口显示不全时,需要指定本参数。
display system internal nat
display system internal nat命令用来显示内核的NAT配置信息。
Probe视图
display system internal nat aging-queue
display system internal nat aging-queue命令用来显示NAT模块老化队列的统计信息。
display system internal nat aging-queue { nopat | portblock } [ verbose ]
Probe视图
nopat:显示NO-PAT表项老化队列的统计信息。
portblock:显示端口块表项所需要的配置信息不存在时,已备份的端口块表项暂存老化队列的统计信息。
verbose:显示NAT老化队列的详细统计信息。若不指定该参数,则只显示NAT老化队列上NAT表项的个数统计信息。
display system internal nat statistics
display system internal nat statistics命令用来显示NAT报文统计信息。
Probe视图
当配置有NAT业务的组网环境中,出现网络丢包时,可以通过该命令查看NAT报文统计信息,确定丢包是否与NAT业务有关。
display system internal nd dad
display system internal nd dad命令用来显示DAD链信息。
Probe视图
display system internal nd entry
display system internal nd entry命令用来显示各板上的ND表项信息。
Probe视图
display system internal nd ifcb
display system internal nd ifcb命令用来显示接口的ND控制块信息。
display system internal nd ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的ND控制块信息。interface-type interface-number为接口类型和接口编号。
display system internal nd machash
display system internal nd machash命令用来显示各板上的machash表项。
display system internal nd machash vlan vlan-id ipv6-address
Probe视图
vlan vlan-id:显示指定VLAN的信息。vlan-id表示指定VLAN的编号。
IPv6-address:指定IPv6地址。
display system internal nd probe
display system internal nd probe命令用来显示探测链信息。
Probe视图
display system internal nd rbhash
display system internal nd rbhash命令用来显示指定板上rbhash表项信息。
display system internal nd rbhash vlan vlan-id ipv6-address
Probe视图
vlan vlan-id:显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ipv6-address:显示指定IPv6地址上rbhash表项信息。
display system internal nd reload
display system internal nd reload命令用来显示重刷链信息。
Probe视图
display system internal nd rule
display system internal nd rule命令用来显示ND规则信息。
display system internal nd rule { all | interface interface-type interface-number [ ipv6-address ] }
Probe视图
all:显示所有ND规则信息。
interface interface-type interface-number:显示指定接口的ND规则信息,interface-type interface-number表示接口类型和接口编号。
ipv6-address:显示的指定IPv6地址的ND规则信息。
display system internal nd static
display system internal nd static命令用来显示ND静态配置。
display system internal nd static ipv6-address interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
display system internal nd statistics
display system internal nd statistics命令用来显示各板上的ND统计信息。
Probe视图
display system internal portal process
display system internal portal process命令用来显示Portal进程的相关信息。
Probe视图
display system internal ppp statistics
display system internal ppp statistics命令用来显示PPP的统计信息。
display system internal ppp statistics { aggregation | all | interface-even }
Probe视图
aggregation:显示PPP的聚合处理统计信息。
all:显示PPP的所有统计信息。
interface-event:显示PPP的接口处理统计信息。
在主用设备和备用设备上都可以查询PPP的统计信息。
display system internal process state
display system internal process state命令用来显示服务的运行状态。
Probe视图
display system internal rawip
display system internal rawip命令用来显示设备上所有RawIP连接的摘要信息。
Probe视图
display system internal rib event attribute
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
display system internal rib event policy
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
display system internal rib event protocol
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
Probe视图
display system internal rib event statistics
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
Probe视图
display system internal rib instance
display system internal rib instance命令用来显示RIB的协议进程信息。
Probe视图
display system internal rib log
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ]
display system internal rib event log
Probe视图
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
display system internal rib memory
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
display system internal rib nib log
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ]
Probe视图
nib:显示NIB子模块的运行状态。
display system internal rib prefix
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length
Probe视图
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
display system internal rib summary
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
Probe视图
display system internal rip database standby
display system internal rip database standby命令用来显示备份的RIP数据库的激活路由。
display system internal rip process-id database standby [ ip-address { mask-length | mask } ]
Probe视图
process-id:RIP进程号,取值范围为1~65535。
ip-address:目的IP地址,点分十进制格式。
mask-length/mask:IP地址掩码,点分十进制格式或以整数形式表示的长度,当用整数时,取值范围为0~32。
standby:显示备份的指定成员设备的RIP数据库的激活路由。
display system internal rip graceful-restart event-log
display system internal rip graceful-restart event-log命令用来显示RIP GR日志信息。
Probe视图
display system internal rip interface
display system internal rip interface命令用来显示RIP的接口信息。
display system internal rip interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
display system internal rip interface standby
display system internal rip interface standby命令用来显示备份的RIP接口信息。
display system internal rip process-id interface standby [ interface-type interface-number ]
Probe视图
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIP的所有接口信息。
standby:显示备份的指定成员设备的RIP接口信息。
display system internal rip neighbor standby
display system internal rip neighbor standby命令用来显示备份的RIP邻居信息。
display system internal rip process-id neighbor standby [ interface-type interface-number ]
Probe视图
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIP的所有邻居信息。
standby:显示备份的指定成员设备的RIP邻居信息。
display system internal rip nib
display system internal rip nib命令用来显示RIP路由下一跳信息。
display system internal rip nib [ nib-id ] [ verbose ]
Probe视图
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果不指定,显示所有下一跳信息。
verbose:显示下一跳详细信息。
display system internal rip nib log
display system internal rip nib log命令用来显示RIP路由下一跳日志信息。
Probe视图
display system internal rip route standby
display system internal rip route standby命令用来显示备份的RIP路由信息。
display system internal rip process-id route standby [ ip-address { mask-length | mask } [ verbose ] | peer ip-address | statistics ]
Probe视图
verbose:显示当前RIP路由表中指定目的地址和掩码的所有路由信息。如果未指定本参数,则只显示指定目的地址和掩码的最优RIP路由。
peer ip-address:显示从指定邻居学到的所有路由信息。
statistics:显示路由的统计信息。路由的统计信息包括路由总数目,各个邻居的路由数目。
standby slot:显示备份的指定成员设备的RIP路由信息。
display system internal rip status
display system internal rip status命令用来显示RIP协议全局状态信息。
Probe视图
display system internal ripng database standby
display system internal ripng database standby命令用来显示备份的RIPng数据库的激活路由。
display system internal ripng process-id database standby [ ipv6-address prefix-length ]
Probe视图
process-id:RIPng进程号,取值范围为1~65535。
ipv6-address prefix-length:显示指定IPv6地址的激活路由信息。ipv6-address表示IPv6地址;prefix-length表示IPv6地址前缀长度,取值范围为0~128。
standby:显示备份的指定成员设备的RIPng数据库的激活路由。
display system internal ripng graceful-restart event-log
display system internal ripng graceful-restart event-log命令用来显示RIPng GR日志信息。
Probe视图
standby:显示指定成员设备的RIPng GR日志信息。
display system internal ripng interface
display system internal ripng interface命令用来显示RIPng的接口信息。
display system internal ripng interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
display system internal ripng interface standby
display system internal ripng interface standby命令用来显示备份的RIPng接口信息。
display system internal ripng process-id interface standby [ interface-type interface-number ]
Probe视图
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIPng指定进程的所有接口信息。
standby:显示备份的指定成员设备的RIPng接口信息,slot-number表示单板所在的槽位号。
display system internal ripng neighbor standby
display system internal ripng neighbor standby命令用来显示备份的RIPng邻居信息。
display system internal ripng process-id neighbor standby [ interface-type interface-number ]
Probe视图
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示RIPng的所有接口信息。
standby:显示备份的指定成员设备的RIPng邻居信息。
display system internal ripng nib
display system internal ripng nib命令用来显示RIPng路由下一跳信息。
display system internal ripng nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示下一跳详细信息。
display system internal ripng nib log
display system internal ripng nib log命令用来显示RIPng路由下一跳日志信息。
Probe视图
display system internal ripng route standby
display system internal ripng route standby命令用来显示备份的RIPng路由信息。
display system internal ripng process-id route standby [ ipv6-address prefix-length [ verbose ] | peer ipv6-address | statistics ]
Probe视图
standby:显示备份的指定成员设备的RIPng路由信息。
display system internal ripng status
display system internal ripng status命令用来显示RIPng协议全局状态信息。
Probe视图
display system internal route-direct interface
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
display system internal route-direct interface [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
display system internal route-direct log
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
display system internal route-static nib log
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
display system internal session
display system internal session命令用来显示会话的配置信息。
display system internal session [ verbose | interface [ interface-type interface-number ] ]
Probe视图
verbose:显示会话配置的详细信息。不指定该参数时,显示会话配置的概要信息。
interface interface-type interface-number:表示使用指定接口的会话配置信息。interface-type interface-number表示接口类型和接口编号。
display system internal session aging-queue
display system internal session aging-queue命令用来显示会话管理模块老化队列的统计信息。
display system internal session aging-queue [ { ipv4 | ipv6 } hot-backup-relation | relation ] [ core core-number ] [ verbose ]
Probe视图
ipv4:显示IPv4热备份关联表项老化队列的统计信息。
ipv6:显示IPv6热备份关联表项老化队列的统计信息。
hotback-relation:显示热备份关联表项老化队列的统计信息。
relation:显示关联表项老化队列的统计信息。
core core-number:显示指定内核上的会话老化队列统计信息,core-number表示多核CPU的内核编号。
verbose:显示会话模块老化队列的详细统计信息。若不指定该参数,则只显示会话管理模块老化队列上关联表项的个数统计信息。
如果不指定任何参数,则显示会话表项老化队列的统计信息。
display system internal session alg-exception
display system internal session alg-exception命令用来显示ALG异常统计信息。
display system internal session alg-exception [ acl acl-number ] [ application { ftp | gtp | h225 | h245 | ils | mgcp | nbdgm | nbns | nbss | pptp | ras | rsh | rtsp | sccp | sip | sqlnet | tftp | xdmcp } ]
Probe视图
acl acl-number:显示匹配指定ACL的ALG异常统计信息,取值范围为2000~3999。
ftp:表示FTP的ALG异常统计信息。
gtp:表示GTP的ALG异常统计信息。
h225:表示H.225的ALG异常统计信息。
h245:表示H.245的ALG异常统计信息。
ils:表示ILS的ALG异常统计信息。
mgcp:表示MGCP的ALG异常统计信息。
nbns:表示NBNS的ALG异常统计信息。
nbss:表示NBSS的ALG异常统计信息。
ngdgm:表示NGDGM的ALG异常统计信息。
pptp:表示PPTP的ALG异常统计信息。
rsh:表示RSH的ALG异常统计信息。
ras:表示RAS的ALG异常统计信息。
rtsp:表示RTSP的ALG异常统计信息。
sccp:表示SCCP的ALG异常统计信息。
sip:表示SIP的ALG异常统计信息。
sqlnet:表示SQLNET的ALG异常统计信息。
tftp:表示TFTP的ALG异常统计信息。
xdmcp:表示XDMCP的ALG异常统计信息。
display system internal session relation-table ipv4
display system internal session relation-table ipv4命令用来显示IPv4关联表详细信息。
display system internal session relation-table ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
source-ip source-ip:显示指定源IPv4地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的关联表表项。destination-ip表示发起方到响应方关联表的目的IPv4地址。
display system internal session relation-table ipv6
display system internal session relation-table ipv6命令用来显示IPv6关联表详细详细信息。
display system internal session relation-table ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ]
Probe视图
source-ip source-ip:显示指定源IPv6地址的关联表表项。source-ip表示发起方到响应方关联表的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的关联表表项。 destination-ip表示发起方到响应方关联表的目的IPv6地址。
display system internal session statistics
display system internal session statistics命令用来显示会话的异常报文统计信息。
display system internal session statistics { ipv4 | ipv6 }
Probe视图
ipv4:显示Pv4会话的异常报文统计信息。
ipv6:显示IPv6会话的异常报文统计信息。
display system internal session table ipv4
display system internal session table ipv4命令用来显示IPv4单播会话表项详细信息。
display system internal session table ipv4 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe视图
source-ip source-ip:显示指定源IP地址的单播会话表项。source-ip表示发起方到响应方会话的源IPv4地址。
destination-ip destination-ip:显示指定目的IPv4地址的单播会话表项详细信息。destination-ip表示发起方到响应方会话的目的IPv4地址。
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv4单播会话表项详细信息。其中,IPv4传输层协议类型可包括:DCCP、ICMP、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv4单播会话表项详细信息。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv4单播会话表项详细信息。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
display system internal session table ipv6
display system internal session table ipv6命令用来显示IPv6单播会话表项详细信息。
display system internal session table ipv6 [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ]
Probe视图
source-ip source-ip:显示指定源IPv6地址的单播会话表项。 source-ip表示发起方到响应方会话的源IPv6地址。
destination-ip destination-ip:显示指定目的IPv6地址的单播会话表项。destination-ip表示发起方到响应方会话的目的IPv6地址。
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }:显示指定协议类型的IPv6单播会话表项。其中,IPv6传输层协议类型可包括:DCCP、ICMPV6、RawIP、SCTP、TCP、UDP和UDP-Lite。
source-port source-port:显示指定源端口号的IPv6单播会话表项。其中,source-port表示发起方到响应方会话的源端口号,取值为0~65535。
destination-port destination-port:显示指定目的端口号的IPv6单播会话表项。其中,destination-port表示发起方到响应方会话的目的端口号,取值为0~65535。
display system internal startup cache
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
·     字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
·     二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
display system internal stp bridge-info
display system internal stp bridge-info命令用来显示生成树指定实例桥配置信息及运行状态。
display system internal stp bridge-info instance instance-id
Probe视图
instance instance-id:显示指定实例的生成树桥配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
display system internal stp port-info
display system internal stp port-info命令用来显示生成树指定实例端口配置信息及运行状态。
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe视图
instance instance-id:显示指定实例的生成树端口配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
interface interface-type interface-number:显示指定端口上的生成树端口信息和运行状态,interface-type interface-number表示端口类型和端口编号。
display system internal tcp
display system internal tcp命令用来显示设备上所有TCP连接的摘要信息。
Probe视图
display system internal tcp port-info
display system internal tcp port-info命令用来显示TCP模块非保留端口的使用信息。
Probe视图
display system internal tcp-proxy statistics
display system internal tcp-proxy statistics命令用来显示TCP代理的统计信息。
display system internal tcp-proxy statistics { all | api | error | fsm | packet }
Probe视图
all:显示所有统计信息。
api:显示API统计信息。
error:显示错误统计信息。
fsm:显示状态机统计信息。
packet:显示报文统计信息。
本命令可以显示IPv4 TCP和IPv6 TCP代理的统计信息。
Probe视图
all:显示所有统计信息。
api:显示API统计信息。
error:显示错误统计信息。
fsm:显示状态机统计信息。
packet:显示报文统计信息。
display system internal tcp-proxy verbose
display system internal tcp-proxy verbose命令用来显示TCP代理连接的详细信息。
Probe视图
display system internal udp
display system internal udp命令用来显示设备上所有UDP连接的摘要信息。
Probe视图
display system internal udp port-info
display system internal udp port-info命令用来显示UDP模块非保留端口的使用信息。
Probe视图
display system internal userlog mbuf dump
display system internal userlog mbuf dump命令用来显示指定个数的USERLOG UDP报文内容。
display system internal userlog mbuf dump count number
Probe视图
count number:指定显示报文的个数。number为需要显示内容的日志个数,取值范围为1~100。
display system internal userlog statistic
display system internal userlog statistic命令用来显示USERLOG模块的运行统计信息。
Probe视图
display system internal userlog test
display system internal userlog test命令用来发送指定个数的FLOW测试日志,并显示日志发送结果信息。
display system internal userlog test count number
Probe视图
count number:指定发送测试日志个数。number为发送测试日志的个数,取值范围为1~3000。
display system internal vlan
display system internal vlan命令用来查看VLAN模块相关的内部信息。
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary }
Probe视图
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
display system internal wips statistics
display system internal wips statistics命令用来显示WIPS模块的统计信息。
Probe视图
display system internal wlan ac capability
display system internal wlan ac capability命令用来显示AC能力信息。
Probe视图
display system internal wlan adapter-asyncinfo
display system internal wlan adapter-asyncinfo命令用来显示适配层异步信息。
display system internal wlan adapter-asyncinfo { all | thread thread-number }
Probe视图
all:显示所有线程的适配层异步信息。
thread thread-number:显示指定线程上的适配层异步信息。
display system internal wlan ap capwap accb
本命令的支持情况与设备的型号有关,请以设备的实际情况为准。
display system internal wlan ap name ap-name capwap accb命令用来在Local AC上显示ACCB信息。
Probe视图
ap-name:指定Local AC的名称,目前只能配置为fitap。
display system internal wlan ap capwap queue-statistics
display system internal wlan ap name ap-name capwap queue-statistics命令用来显示指定AP的CAPWAP报文重传队列统计信息。
Probe视图
ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
display system internal wlan ap capwap send-statistics
display system internal wlan ap name ap-name capwap send-statistics命令用来查看指定AP的CAPWAP发送报文统计信息。
display system internal wlan ap name ap-name capwap send-statistics [ time time ]
Probe视图
ap-name:指定AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
time time:查看包含指定时间在内的10分钟内AP的CAPWAP发送报文统计信息,time的格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。例如,当time配置为10:20~10:30内的任意时间时,则显示10:20~10:30时间范围内AP的CAPWAP发送报文统计信息。当不配置time参数时,则显示距离当前时间最近的时间块内AP的CAPWAP发送报文统计信息。例如,在10:27分配置该命令,则显示10:20~10:27时间范围内AP的CAPWAP发送报文统计信息。
设备会记录24小时之内的CAPWAP发送报文统计信息。
display system internal wlan ap message
display system internal wlan ap message命令用来显示APMGR发送和接收消息的统计信息。
display system internal wlan ap message statistics
Probe视图
display system internal wlan ap name ap-name apcb命令用来显示APCB的信息。
display system internal wlan ap name ap-name capwap context命令用来显示CAPWAP的信息。
display system internal wlan ap name ap-name radio raido-id命令用来打印显示的Radio接口信息。
displya system internal wlan ap all radio命令用来显示所有AP的Radio接口信息。
display system internal wlan ap { all radio | name ap-name { apcb | capwap context | radio radio-id } }
Probe视图
all radio:显示所有AP的Radio接口信息。
name ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
apcb:显示APCB的信息。
capwap context:显示CAPWAP上下文的对话信息。
radio radio-id:显示指定的radio-id的Radio信息。
display system internal wlan ap name map-configuration
display system interval wlan ap name ap-name map-configuration命令用来显示指定AP的map-configuration的运行信息。
Probe视图
display system internal wlan ap radio drv-info
display system internal wlan ap ap-name radio drv-info命令用来显示指定AP下所有射频的驱动信息。
Probe视图
display system internal wlan ap reboot-history
display system internal wlan ap reboot-history命令用来显示AP的重启历史信息。
display system internal wlan ap all reboot-history
Probe视图
AP关联到AC后,会向AC上报BSS个数和BSSID,AC把AP上报的数据和本地统计的数据进行比较:
·     对于传统的AC+Fit AP架构,如果数据匹配,则不做处理;如果不匹配,则统计不匹配次数并重新比较,当不匹配次数达到6次时,通知AP重启。
·     对于分层AC架构,先由Local AC对AP上报的数据进行比较,如果数据匹配,则将数据上报给Central AC,由Central AC对数据进行比较;如果数据不匹配,则统计不匹配次数并重新比较,直到数据匹配后再将数据上报给Central AC。当Local AC和Central AC上不匹配次数总和达到6次时,通知AP重启。
display system internal wlan ap reboot-reason
display system internal wlan ap reboot-reason命令用来显示AP的重启原因。
display system internal wlan ap { all | name ap-name } reboot-reason
Probe视图
all:显示所有AP的信息。
name ap-name:指定AP的名称,ap-name表示AP的名字,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
display system internal wlan ap-group-configuration
display system internal wlan ap-group-configuration命令用来显示指定AP组下的配置。
display system internal wlan ap-group-configuration group-name group-name
Probe视图
group-name group-name:显示指定AP组下的配置信息。group-name表示AP组的名称,为1~31个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
display system internal wlan ap-libinfo
display system internal wlan ap-libinfo命令用来显示lib端的AP信息或射频基础配置信息。
display system internal wlan ap-libinfo app-id app-id { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ]
Probe视图
app-id app-id:显示指定APP上的AP信息或射频基础配置信息,app-id表示APP的ID,取值范围与设备的当前配置有关,请以实际情况为准。
ap-id ap-id:显示指定AP的AP信息或射频基础配置信息,ap-id表示AP的ID,取值范围为1~65535。
ap-name ap-name:显示指定AP的AP信息或射频基础配置信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio-id radio-id:显示指定射频的基础配置信息,radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。如果不指定该参数,则显示lib端的AP信息。
某些情况下,APMGR与其他APP间的AP数据或射频基础配置数据同步失败,会出现局部不同步的AP数据或射频基础配置数据。这时请使用该命令查看指定APP上的AP数据或射频基础配置信息。
display system internal wlan ap-model-configuration
display system internal wlan ap-model-configuration命令用来显示AP组下指定型号AP的配置信息。
display system internal wlan ap-model-configuration group-name group-name model-name model-name [ radio radio-id ]
Probe视图
group-name group-name:显示指定AP组下某型号AP的配置信息。group-name表示AP组的名称,为1~31个字符的字符串,可以包含字母、数字、下划线、“[”、“]”、“/”及“-”,不区分大小写。
model-name model-name:显示指定型号AP的配置信息。model-name表示AP型号名。
radio radio-id:显示指定射频的配置信息。radio-id表示射频的ID号,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan apdb
display system internal wlan apdb命令用来显示APDB(Access Point Information Database,接入点信息数据库)中的AP型号信息。
display system internal wlan apdb ap-model name ap-model [ radio radio-id ]
Probe视图
ap-model:显示指定AP型号的信息。ap-model表示AP型号名。
radio radio-id:显示指定射频的信息。radio-id表示射频的ID号,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan band-navigation
display system internal wlan band-navigation命令用来显示AP扫描到的客户端的频谱导航信息。
display system internal wlan band-navigation ap ap-id [ client mac-address ]
Probe视图
ap-id:AP ID,取值范围为1~65535。
client mac-address:显示AP扫描到的指定客户端的频谱导航信息。mac-address为客户端MAC地址,格式为H-H-H。如果不指定该参数,将显示AP扫描到的所有客户端的频谱导航信息。
display system internal wlan client ip
display system internal wlan client ip [ mac-address mac-address ]命令用来显示客户端的IP地址信息。
Probe视图
mac-address mac-address:显示指定MAC地址的客户端IP地址信息。如果未指定本参数,则显示所有客户端的IP地址信息。
display system internal wlan command-cache
display system internal wlan command-cache命令用来查看缓存队列中的命令行消息。
Probe视图
display system internal wlan history bandwidth
display system internal wlan history bandwidth命令用来显示射频带宽配置的历史信息。
display system internal wlan history bandwidth ap { all | { name ap-name | id ap-id } radio radio-id }
Probe视图
name ap-name:显示指定AP的射频带宽配置的历史信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
id ap-id:显示指定AP的射频带宽配置的历史信息。ap-id表示AP的ID号,取值范围为1~65535。
radio radio-id:显示指定射频的射频带宽配置的历史信息。取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan history radiostate
display system internal wlan history radiostate命令用来显示Radio state场景处理消息的历史记录。
display system internal wlan history radiostate ap { id ap-id | name ap-name } radio radio-id
Probe视图
id ap-id:显示指定AP上Radio state场景处理消息的历史记录。ap-id表示AP的ID,取值范围为1~65535。
name ap-name:显示指定AP上Radio state场景处理消息的历史记录。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio radio-id:显示指定射频下Radio state场景处理消息的历史记录。radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan history radiostate命令用来显示射频状态配置的历史信息。
display system internal wlan history radiostate ap { all | { name ap-name | id ap-id } radio radio-id }
Probe视图
all:显示所有AP的射频状态配置的历史信息。
name ap-name:显示指定AP的射频状态配置的历史信息。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
id ap-id:显示指定AP的射频状态配置的历史信息。ap-id表示AP的ID号,取值范围为1~65535。
radio radio-id:显示指定射频的射频状态配置的历史信息。取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan history wlanid
display system internal wlan history wlanid命令用来显示WLAN ID申请、释放的历史记录。
display system internal wlan history wlanid { ap-name ap-name | ap-id ap-id } radio-id radio-id
Probe视图
ap-name ap-name:显示指定AP申请、释放WLAN ID的历史记录。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
ap-id ap-id:显示指定AP申请、释放WLAN ID的历史记录。ap-id表示AP ID,取值范围为1~65535。
radio-id radio-id:显示指定射频申请、释放WLAN ID的历史记录。radio-id表示射频ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan history-error
display system internal wlan history-error命令用来显示APMGR消息处理失败的历史记录。
display system internal wlan history-error { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ]
Probe视图
ap-id ap-id:显示指定AP的APMGR消息处理失败的历史记录。ap-id表示AP的ID,取值范围为1~65535。
ap-name ap-name:显示指定AP的APMGR消息处理失败的历史记录。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio-id radio-id:显示指定射频的APMGR消息处理失败的历史记录。radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。如果不指定本参数,则显示所有射频的APMGR消息处理失败的历史记录。
display system internal wlan kernel-ap
display system internal wlan kernel-ap命令用来显示AP内核信息。
display system internal wlan kernel-ap { name ap-name | all }
Probe视图
name ap-name:显示指定名称的AP内核信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
all:显示所有内核中的AP信息。
display system internal wlan link-info
display system internal wlan link-info用来显示连接信息。
Probe视图
display system internal wlan load-balance neighbor-list ap
display system internal wlan load-balance neighbor-list ap命令用来显示Radio的负载信息和扫描到的客户端列表。
display system internal wlan load-balance neighbor-list ap ap-id radio radio-id
Probe视图
radio-id:Radio ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
本命令仅在负载均衡类型为基于Radio的负载均衡时使用。
display system internal wlan load-balance neighbor-list client
display system internal wlan load-balance neighbor-list client命令用来显示扫描到指定客户端的Radio的信息。
display system internal wlan load-balance neighbor-list client mac-address
Probe视图
mac-address:客户端MAC地址,格式为H-H-H。
display system internal wlan load-balance neighbor-list statistics
display system internal wlan load-balance neighbor-list statistics命令用来显示WLAN负载均衡客户端统计信息。
Probe视图
本命令仅显示基于Radio的WLAN负载均衡客户端统计信息。
接收到同一客户端请求报文的射频互为邻居,称为邻居射频。统计邻居射频表项时(以创建表项为例),基于每客户端计算邻居射频数目,而后将所有客户端的邻居射频数目相加(接收到客户端请求报文的射频可能会重复统计)。
display system internal wlan load-status
display system internal wlan load-status命令用来显示AC的负载状态。
Probe视图
该命令可以查看成功注册到AC上的AP数量,以及该AC是否开启AP备份功能,是否处于活跃状态。
display system internal wlan logbuffer ha
display system internal wlan logbuffer ha命令用来显示HA期间打印的log信息。
Probe视图
display system internal wlan logbuffer memory
display system internal wlan logbuffer memory命令用来显示内存达到门限及恢复的log信息。
Probe视图
display system internal wlan response-timeout event
display system internal wlan response-timeout event命令用来显示应用进程响应时间超时的事件信息。
Probe视图
通过查看应用进程响应时间超时的事件可以查找应用进程响应缓慢的原因。系统定义的响应超时时间为1秒。
display system internal wlan statistics
display system internal wlan statistics命令用来显示AP的统计信息。
display system internal wlan statistics { ap-interface name ap-name | ap-radio name ap-name radio radio-id }
Probe视图
ap-interface:显示AP上的接口统计信息。
ap-radio:显示AP上的WLAN射频统计信息。
name ap-name:AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio radio-id:射频ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan statistics radio-backup
display system internal wlan statistics radio-backup命令用来显示AP射频的备份统计信息。
display system internal wlan statistics radio-backup name ap-name radio radio-id
Probe视图
name ap-name:指定AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio radio-id:指定射频ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
display system internal wlan { aplb | kernel-aplb }
display system internal wlan { aplb | kernel-aplb }命令用来显示AC上的AP负载均衡信息。
display system internal wlan { aplb | kernel-aplb } { { ip ipv4-address | ipv6 ipv6-address } port port-number | load-slot slot-number1 } [ slot slot-number2 ]
Probe视图
aplb:显示用户态的AP负载均衡信息。
kernel-aplb:显示内核态的AP负载均衡信息。
ip ipv4-address:显示AP负载均衡信息中指定AP的数据,ipv4-address表示AP建立CAPWAP隧道使用的IPv4地址。
ipv6 ipv6-address:显示AP负载均衡信息中指定AP的数据,ipv6-address表示AP建立CAPWAP隧道使用的IPv6地址。
port port-number:显示AP负载均衡信息中指定AP的数据,port-number表示AP建立CAPWAP隧道使用的端口号,取值范围为100~65535。
load-slot slot-number1:显示在指定AC上线的AP的负载均衡信息。
slot slot-number2:显示指定AC上保存的AP负载均衡信息。
display transceiver information
display transceiver information命令用来显示光模块的详细信息。
display transceiver information interface [ interface-type interface-number ]
设备各款型对于本节所描述的命令支持情况有所不同,详细差异信息如下:
型号
WAC380-30
不支持
WAC380-60
不支持
WAC380-90
支持
WAC380-120
支持
Probe视图
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的详细信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
display transceiver moduleinfo
display transceiver moduleinfo命令用来显示可插拔光模块软件内部的核心数据结构的信息。
display transceiver moduleinfo interface [ interface-type interface-number ]
型号
WAC380-30
不支持
WAC380-60
不支持
WAC380-90
支持
WAC380-120
支持
Probe视图
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块软件内部的核心数据结构的信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数时,表示所有接口。
display transceiver register
display transceiver register命令用来显示可插拔光模块的寄存器信息。
display transceiver register interface [ interface-type interface-number ]
型号
WAC380-30
不支持
WAC380-60
不支持
WAC380-90
支持
WAC380-120
支持
Probe视图
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的寄存器信息。interface-type interface-number表示接口类型和接口编号,不指定该参数时,表示所有接口。
F
follow
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ]
Probe视图
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
fpl-diag
fpl-diag命令用来执行指定调试命令。
fpl-diag { cmd-string | slot slot-number cmd-string }
Probe视图
slot slot-number: 表示指定槽位号的调试信息。
cmd-string: 调试命令信息,此命令只适用于产品调式使用,可能引起系统崩溃,设备不可用等情况。此命令只能由H3C的技术支持人员使用。
L
lipc connection detect
lipc connection detect命令用来检测本节点和所有相连节点的连通性。
Probe视图
执行该命令后,本节点会向本节点所有相连节点连续发送5个ping报文,如果在200ms内收到目的节点的任何一个回复报文则认为该节点可达,否则不可达。
lipc dump
lipc dump命令用来配置LIPC各协议报文的抓包规则。
undo lipc dump命令用来清除抓包规则。
lipc dump lgmp [ port port ] [ recv | send ] [ lip lip ]
undo lipc dump [ lgmp [ port port ] [ recv | send ] ] [ lip lip ]
lipc dump { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] [ lip lip ]
undo lipc dump [ { mtcp | stcp | sudp } [ port port ] [ ack | ctrl | data ] [ recv | send ] ] [ lip lip ]
lipc dump { publish | topology } [ recv | send ] [ lip lip ]
undo lipc dump [ { publish | topology } [ recv | send ] ] [ lip lip ]
没有配置协议报文的抓包规则。
Probe视图
lgmp:配置组播管理协议报文的抓包规则。
mtcp:配置组播传输控制协议报文的抓包规则。
stcp:配置单播传输控制协议报文的抓包规则。
sudp:配置单播用户数据报协议报文的抓包规则。
publish:配置可靠发布协议报文的抓包规则。
topology:配置拓扑协议报文的抓包规则。
port port:匹配协议端口号,不指定本参数时,表示匹配该协议所有端口。
ack:匹配该协议的确认报文。不指定ackctrldata参数时,表示匹配确认、控制和数据报文。
ctrl:匹配该协议的控制报文。不指定ackctrldata参数时,表示匹配确认、控制和数据报文。
data:匹配该协议的数据报文。不指定ackctrldata参数时,表示匹配确认、控制和数据报文。
recv:匹配该协议的接收报文。不指定recvsend参数时,表示匹配接收和发送报文。
send:匹配该协议的发送报文。不指定recvsend参数时,表示匹配接收和发送报文。
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条协议报文的抓包规则。
所有下发的规则会被记录到系统,使用display system internal lipc dump configuration命令可以查看。
同一个报文被多个协议规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。
报文匹配成功后记录到抓包缓存区,使用display system internal lipc dump命令可以查看。
lipc dump buffer
lipc dump buffer命令用来申请或释放指定节点的LIPC抓包缓存。
lipc dump buffer { alloc [ max-record num ] | free } [ lip lip ]
Probe视图
alloc:申请缓存。
free:释放缓存。
max-record num信息的最大记录缓存字节数,取值范围为1~10000,单位为KB,缺省值为10KB。
开启抓包功能后,系统会缺省申请10KB缓存来缓存捕获的报文。如果要捕获的报文较多,请先使用本命令提前申请内存,再开启抓包功能。
lipc dump enable
lipc dump enable命令用来开启本节点的LIPC抓包功能。
undo lipc dump enable命令用来关闭本节点的LIPC抓包功能。
lipc dump enable [ loop] [ lip lip ]
undo lipc dump enable [ lip lip ]
本节点的LIPC抓包功能处于关闭状态。
Probe视图
loop:表示开启循环记录模式,即缓存区满后会删除旧记录来保存新记录。不指定本参数时,表示非循环模式,缓存区满后不再继续记录。
lip lip:表示远端节点号,取值范围为0~65535,不指定该参数时,表示全局主用主控板所在节点。
开启本节点的LIPC抓包功能时,如未申请抓包缓存,系统会在开启抓包功能的同时申请10KB的抓包缓存。
关闭本节点的LIPC抓包功能时,不会清除抓包规则和抓包缓存区。
lipc dump offset
lipc dump offset命令用来配置报文内容抓包规则。
lipc dump offset offset length length value value [ recv | send ] [ lip lip ]
undo lipc dump [ offset offset length length value value [ recv | send ] ] [ lip lip ]
没有配置报文内容抓包规则。
Probe视图
offset:信息的偏移量,取值范围为0~65535。报文偏移起始位置为LIP报文头位置。
length length:信息的长度。取值为1、2、4、8,单位为字节。
value value:信息的内容的十六进制字符串形式(字符串不带“0x”)。length取值为1时,value的取值范围为0~0xFF;length取值为2时,value的取值范围为0~0xFFFF;length取值为4时,value的取值范围为0~0xFFFFFFFF;length取值为8时,value的取值范围为0~0xFFFFFFFFFFFFFFFF。
recv:匹配接收报文。不指定recvsend参数时,表示匹配接收和发送报文。
send:匹配发送报文。不指定recvsend参数时,表示匹配接收和发送报文。
下发内容匹配规则并开启抓包功能后,系统从驱动层收到的报文,从报文的第offset个字节开始取length长的内容,内容的值为value时,记录这个报文的前48字节内容到抓包缓存区。协议抓包规则和内容抓包规则抓取到的报文存放在同一个缓冲区,使用display system internal lipc dump命令可以查看捕获到的报文。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条不同的报文内容抓包规则。
清除报文内容抓包规则时,需要offsetlengthvalue三个字段完全匹配时才清除该规则,否则提示规则不存在。
同一个报文被多个内容匹配规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。报文匹配成功后记录到抓包缓存区,可使用display system internal lipc dump命令查看。
lipc performance
lipc performance命令用来配置单播或者组播的性能统计功能,用于评测LIPC的传输性能。
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
性能统计开关是关闭的。
Probe视图
mtcp:MTCP子模块的信息。
stcp:STCP子模块的信息。
clear:清除单播或者组播的性能统计信息。
off:关闭单播或者组播的性能统计开关。
on:打开单播或者组播的性能统计开关。
lipc ping
lipc ping命令用来检查本节点与目的节点LIPC通信链路的连通性和稳定性。
lipc ping lip lip [ length length ] [ times times ] [ summary ]
Probe视图
lip lip:指定目的端的LIP地址,取值范围0~65535。
length length:指定发送的LIPC回显请求报文的长度(不包括LIPC报文头),取值范围为0~32767,单位为字节,缺省值为100字节。
times times:指定LIPC回显请求报文的发送次数,取值范围为0~32767,缺省值为3。
summary:只显示统计信息。不指定该参数时,系统将显示包括统计信息在内的详细信息。
lipc timeout
lipc timeout命令用来设置LIPC拓扑链路的超时时间。
lipc timeout time [ lip lip ]
拓扑链路的超时时间为60秒。
Probe视图
timeout time:表示超时时间,取值范围为3-65535。
如果本节点的TOPOLOGY模块在超时时间内一直没有收到UP节点的心跳报文,则会断开与该节点的所有单播、组播连接。
通常,只有在使用KDB或者KGDB调试内核时,才需要修改该数值,以避免其他节点认为正处于内核调试状态的节点链路Down。
list
list命令用来查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
list file-path
Probe视图
file-path:要查看的文件或目录的路径,区分大小写。
M
memory boundary-check enable
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
memory boundary-check enable job job-id
undo memory boundary-check enable job job-id
内存越界检查功能处于关闭状态。
Probe视图
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
·     memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
memory boundary-check scan job job-id
Probe视图
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
·     memory boundary-check enable
monitor lipc
monitor lipc命令用来以交互模式显示各协议的实时统计信息。统计信息包括收发包信息、状态信息、缓存信息等。
monitor lipc { mtcp | stcp | sudp } { recv | send } [ lip lip ]
Probe视图
mtcp显示组播传输控制协议的实时统计信息。
stcp显示单播传输控制协议的实时统计信息。
sudp显示单播用户数据报的实时统计信息。
recv显示该协议接收报文的实时统计信息。
send显示该协议发送报文的实时统计信息。
信息的统计周期为5秒。统计结果以报文发送或接收量降序排列,最多同时显示10个数据,每隔5秒刷新一次。命令执行后前5秒内系统需统计信息,无统计信息输出。
用户可以通过输入q或Q来停止执行命令行,退回到命令行视图。
multicast record limit
multicast record limit命令用来配置组播表项操作记录的最大数目。
undo multicast record limit命令用来恢复缺省情况。
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
组播表项操作记录的最大数目为0,即不记录组播表项的操作信息。
Probe视图
fail:表示组播表项的失败操作记录。
limit-value:表示操作记录的最大数目,取值范围为0~500000。
P
probe
probe命令用来从系统视图进入Probe视图。
probe
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
R
reset system internal arp statistics
reset system internal arp statistics命令用来清除指定成员设备的上的ARP统计信息。
Probe视图
reset system internal aspf statistics
reset system internal aspf statistics命令用来清除ASPF、报文过滤的丢包统计信息。
reset system internal aspf statistics interface { ipv4 | ipv6 }
Probe视图
interface:清除接口上的ASPF丢包统计信息。
ipv4:清除IPv4报文的丢包统计信息。
ipv6:清除IPv6报文的丢包统计信息。
reset system internal ipv6 rib log
reset system internal ipv6 rib log命令用来清除IPv6 RIB相关的日志内容。
reset system internal ipv6 rib [ event ] log
Probe视图
event:IPv6 RIB路由变化相关的日志。
reset system internal ipv6 rib nib log
reset system internal ipv6 rib nib log命令用来清除IPv6 NIB子模块日志。
Probe视图
reset system internal ipv6 rib summary
reset system internal ipv6 rib summary命令用来清除IPv6 RIB的统计摘要信息。
Probe视图
reset system internal ipv6 route-direct log
reset system internal ipv6 route-direct log命令用来清除直连路由日志。
reset system internal ipv6 route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:ipv6直连路由NIB子模块相关日志。
reset system internal ipv6 route-static nib log
reset system internal ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
reset system internal lipc dump buffer
reset system internal lipc dump buffer命令用来清空本节点的LIPC抓包缓存。
reset system internal lipc dump buffer [ lip lip ]
Probe视图
reset system internal mac-address statistics
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
Probe视图
reset system internal mbuf relay statistics
reset system internal mbuf relay statistics命令用来清除MBUF中继模块的统计信息。
reset system internal mbuf relay statistics [ vcpu vcpu-number [ rcv receiver-id ] ]
Probe视图
reset system internal multicast forwarding-table dummy
reset system internal multicast forwarding-table dummy命令用来清除组播临时转发表中的表项。
Probe视图
reset system internal multicast record
reset system internal multicast record命令用来清除组播表项的操作记录。
Probe视图
reset system internal nat statistics
reset system internal nat statistics命令用来清除NAT报文统计信息。
Probe视图
reset system internal nd statistics
reset system internal nd statistics命令用来清除各板上的ND统计信息。
Probe视图
reset system internal ppp statistics
reset system internal ppp statistics命令用来清除PPP的统计信息。
reset system internal ppp statistics { aggregation | all | interface-event }
Probe视图
aggregation:清除PPP的聚合处理统计信息。
all:清除PPP的所有统计信息。
interface-event:清除PPP的接口处理统计信息。
在主用设备和备用设备上都可以清除PPP的统计信息。
reset system internal rib log
reset system internal rib log命令用来清除RIB相关的日志内容。
reset system internal rib [ event ] log
Probe视图
event:RIB路由变化相关的日志。
reset system internal rib nib log
reset system internal rib nib log命令用来清除NIB子模块日志。
Probe视图
reset system internal rib summary
reset system internal rib summary命令用来清除IPv4 RIB的统计摘要信息。
Probe视图
reset system internal rip graceful-restart event-log
reset system internal rip graceful-restart event-log命令用来清除RIP GR日志信息。
reset system internal rip graceful-restart event-log slot slot-number
Probe视图
reset system internal ripng graceful-restart event-log
reset system internal ripng graceful-restart event-log命令用来清除RIPng GR日志信息。
Probe视图
standby slot slot-number:清除指定成员设备的RIPng GR日志信息。
reset system internal route-direct log
reset system internal route-direct log命令用来清除直连路由日志。
reset system internal route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
reset system internal route-static nib log
reset system internal route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
reset system internal session alg statistics
reset system internal session alg statistics命令用来清除ALG异常报文统计信息。
Probe视图
reset system internal session statistics
reset system internal session statistics命令用来清除会话异常报文统计信息。
reset system internal session statistics { ipv4 | ipv6 }
Probe视图
ipv4:清除IPv4会话的异常报文统计信息。
ipv6:清除IPv6会话的异常报文统计信息。
reset system internal tcp-proxy statistics
reset system internal tcp-proxy statistics命令用来清除TCP代理连接的统计信息。
Probe视图
本命令可以清除IPv4 TCP和IPv6 TCP代理的统计信息。
Probe视图
reset system internal wlan history bandwidth
reset system internal wlan history bandwidth命令用来清除射频带宽配置的历史信息。
reset system internal wlan history bandwidth ap { all | { name ap-name | id ap-id } radio radio-id }
Probe视图
name ap-name:清除指定AP的射频带宽配置的历史信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
id ap-id:清除指定AP的射频带宽配置的历史信息。ap-id表示AP的ID号,取值范围为1~65535。
radio radio-id:清除指定射频的射频带宽配置的历史信息。取值范围与AP设备的型号有关,请以设备的实际情况为准。
reset system internal wlan history radiostate
reset system internal wlan history raidostate命令用来清除射频状态配置的历史信息。
reset system internal wlan history raidostate ap { all | { name ap-name | id ap-id } radio radio-id }
Probe视图
all:清除所有AP的射频状态配置的历史信息。
name ap-name:清除指定AP的射频状态配置的历史信息,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
id ap-id:清除指定AP的射频状态配置的历史信息。ap-id表示AP的ID号,取值范围为1~65535。
radio radio-id:清除指定射频的射频状态配置的历史信息。取值范围与AP设备的型号有关,请以设备的实际情况为准。
reset system internal wlan history radiostate命令用来清除Radio state场景处理消息的历史信息。
reset system internal wlan history radiostate ap { id ap-id | name ap-name } radio radio-id
Probe视图
id ap-id:清除指定AP上Radio state场景处理消息的历史记录。ap-id表示AP的ID,取值范围为1~65535。
name ap-name:清除指定AP上Radio state场景处理消息的历史记录。ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio radio-id:清除指定射频下Radio state场景处理消息的历史记录。radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。
reset system internal wlan history-error
reset system internal wlan history-error命令用来清除APMGR消息处理失败的历史记录。
reset system internal wlan history-error { ap-id ap-id | ap-name ap-name } [ radio-id radio-id ]
Probe视图
ap-id ap-id:清除指定AP的APMGR消息处理失败的历史记录,ap-id表示AP的ID,取值范围为1~65535。
ap-name ap-name:清除指定AP的APMGR消息处理失败的历史记录,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”及“-”,不区分大小写。
radio-id radio-id:清除指定射频的APMGR消息处理失败的历史记录,radio-id表示射频的ID,取值范围与AP设备的型号有关,请以设备的实际情况为准。如果不指定该参数,则清除所有射频的APMGR消息处理失败的历史记录。
reset system internal wlan load-balance neighbor-list statistics
reset system internal wlan load-balance neighbor-list statistics命令用来清除WLAN负载均衡客户端统计信息。
Probe视图
本命令仅清除基于Radio的WLAN负载均衡客户端统计信息。
reset system internal wlan response-timeout event
reset system internal wlan response-timeout event命令用来重置应用进程响应时间超时的事件信息。
Probe视图
通过本命令可以清除已经不需要的应用进程事件信息,从而记录新增的应用进程事件信息。
rrm calibrate-power step
rrm calibrate-power step命令用来设置功率调整步长。
undo rrm calibrate-power step命令用来恢复缺省情况。
rrm calibrate-power step { down | up } value
undo rrm calibrate-power step { down | up }
增加功率或减小功率的调整步长为3。
Probe视图
down:减小功率的步长。
up:增加功率的步长。
value:功调调整步长,取值范围为1~8,单位为dBm。
S
system internal session alg statistics acl acl-number enable命令用来开启ALG异常报文统计功能。
undo system internal session alg statistics命令用来恢复缺省情况。
ALG异常报文统计功能处于关闭状态。
Probe视图
acl acl-number:指定ACL的编号,acl-number取值范围为2000~3999。
开启ALG异常报文统计功能后,设备对匹配指定IPv4/IPv6 ACL的ALG异常报文进行统计。关闭ALG统计开关后,清除统计信息。
T
tcp-proxy statistics命令用来开始或停止TCP代理统计计数。
tcp-proxy statistics { off | on }
不进行TCP代理统计计数。
Probe视图
off:表示停止TCP代理统计计数。
on:表示开始TCP代理统计计数。
本命令可以开始或停止IPv4 TCP和IPv6 TCP代理统计计数。
不进行IPv6 TCP代理统计计数。
Probe视图
off:表示停止IPv6 TCP代理统计计数。
on:表示开始IPv6 TCP代理统计计数。
V
view
view命令用来查看系统目录(/proc/、/sys/、/var/)下的文件的内容。
view file-path
Probe视图
file-path:要查看文件的路径,区分大小写。
执行该命令显示的文件路径中不能包含文件链接。文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
W
wlan ap queue message-type-count interval
wlan ap queue message-type-count interval命令用来配置AP管理进程队列消息类型统计信息的打印时间间隔。
undo wlan ap queue message-type-count interval命令用来恢复缺省情况。
wlan ap queue message-type-count interval interval
AP管理进程队列消息类型统计信息的打印时间间隔为10秒。
Probe视图
interval:指定命令控制台打印队列消息类型统计的打印间隔,取值范围为1~200,单位为秒。
wlan ap-execute exec-console enable
wlan ap-execute exec-console enable命令用来打开上线AP的执行控制台。
wlan ap-execute exec-console disable命令用来关闭上线AP的执行控制台。
wlan ap-execute ap-name exec-console { disable | enable }
当AP上线时,自动关闭执行控制台;AP下线时,自动开启执行控制台。
Probe视图
关闭AP的执行控制台后,用户将无法通过Console口和Telnet方式登录AP,已登录的用户不受影响。
wlan image-load model
wlan image-load model命令用来配置允许下发软件版本的AP型号。
undo wlan image-load model命令用来取消对指定AP型号下发软件版本的允许。
wlan image-load model { model }&<1-8>
undo wlan image-load model { model }&<1-8>
未配置对指定的AP型号下版本,即AC可对所有的AP型号下版本。
Probe视图
{ model }&<1-8>:指定AP型号,&<1-n>表示前面的参数最多可以输入n次。
开启版本升级功能,并配置对指定的AP型号下版本后,当指定型号的AP与AC建立CAPWAP隧道时,如果AP的软件版本与APDB中保存的软件版本不一致,则AP必须从AC上下载对应的软件版本文件进行升级后才能与AC建立CAPWAP隧道连接。对于其它型号的AP,即使软件版本与APDB中保存的软件版本不一致,AC也不允许对其下发版本。
wlan image-load model命令仅在版本升级功能处于开启的情况下才会生效。关于版本升级功能的介绍和配置请参见“WLAN配置指导”中的“AP管理”。
wlan image-load model命令仅对未上线的AP生效。
wlan image-load simultaneous
wlan image-load simultaneous命令用来配置AC上每个业务线程处理AP版本下载任务的并发数。
wlan image-load simultaneous count
AC上每个业务线程处理AP版本下载任务的并发数为8。
Probe视图
count:AC上每个业务线程处理AP版本下载任务的并发数,取值范围是1~64。
wlan system internal ap access-limit
wlan system internal ap access-limit命令用来配置AP并发上线数量。
undo wlan system internal ap access-limit命令用来恢复缺省情况。
wlan system internal ap access-limit count
AP并发上线数量为512。
Probe视图
count:指定AP最大并发上线数量,取值范围为1~4096。
wlan system internal ap adjust reboot
wlan system internal ap adjust reboot enable命令用来开启校准重启功能。
undo wlan system internal ap adjust reboot enable命令用来关闭校准重启功能。
校准重启功能处于开启状态。
Probe视图
AP上线后将向AC上报射频数据,AC用本地保存的射频数据与AP上报的数据进行匹配。如果开启校准重启功能,且射频数据连续10次没有完全匹配,将重启AP;关闭校准重启功能,不重启AP。
wlan system internal offline-restrain
wlan system internal offline-restrain命令用来开启抑制AP下线功能。
undo wlan system internal offline-restrain命令用来关闭抑制AP下线功能。
wlan system internal offline-restrain ap ap-name
undo wlan system internal offline-restrain ap ap-name
抑制AP下线功能处于关闭状态。
Probe视图
ap ap-name:指定AP的名称,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”、及“-”,不区分大小写。
为定位问题方便,使用抑制AP下线功能来控制AP在AC端和AP端的状态机是否保持为Run状态。
·     开启该功能之后,AP将一直保持在线状态。执行wlan system internal offline-restrain命令后,会提示用户是否一直重传报文,如果输入Y,AC将一直发送请求报文给AP;如果输入N,AC发送给AP的请求报文的数目为配置的重传次数。
·     关闭该功能之后,AP可以正常下线。
AC发送给AP的请求报文包括Image Data Request报文、Configuration Update Request报文、Reset Request报文、Data Transfer Request报文、IEEE 802.11 WLAN Configuration Request报文和Station Configuration Request报文。
wlan system internal reboot-restrain
wlan system internal reboot-restrain命令用来开启抑制AP长时间未上线时自动重启功能。
undo wlan system internal reboot-restrain命令用来关闭抑制AP长时间未上线时自动重启功能。
wlan system internal reboot-restrain ap ap-name
undo wlan system internal reboot-restrain ap ap-name
抑制AP长时间未上线时自动重启功能处于关闭状态。
Probe视图
ap ap-name:抑制指定AP长时间未上线时自动重启,ap-name表示AP的名称,为1~64个字符的字符串,可以包含字母、数字、下划线、“.”、“[”、“]”、“/”、及“-”,不区分大小写。
AP处于不在线状态10分钟后,就会自动重启。通过配置本命令,可以抑制AP进行自动重启。
