02-H3C网络技术缩略语表
本章节下载 (283.89 KB)
# A B C D E F G H I K L M N O P Q R S T U V W X Z
缩略语 |
英语解释 |
中文解释 |
10GE |
Ten-GigabitEthernet |
万兆以太网 |
1DM |
One-way Delay Measurement |
单向时延测量 |
6PE |
IPv6 Provider Edge |
IPv6供应商边缘 |
A Return |
AAA |
Authentication, Authorization and Accounting |
认证、授权和计费 |
AAL |
ATM适配层 |
AAL5 |
ATM Adaptation Layer 5 |
ATM适配层5 |
ABR |
Area Border Router |
区域边界路由器 |
AC |
Access Category |
接入类 |
AC |
Attachment Circuit |
接入电路 |
AC |
Access Controller |
接入控制器 |
AC |
Access Circuit |
接入电路 |
AC Name |
Access Concentrator Name |
接入集中器名称 |
ACA |
Acquire Change Authorization |
获取修改授权 |
ACCM |
Async-Control-Character-Map |
异步控制字符映射表 |
ACFC |
Address-and-Control-Field-Compression |
地址控制字段压缩 |
ACFP |
Application Control Forwarding Protocol |
应用控制转发协议 |
Ack |
Acknowledgment |
确认 |
ACL |
Access Control List |
访问控制列表 |
ACR |
Adaptive Clock Recovery |
自适应时钟恢复 |
ACS |
AS Control Server |
AS控制服务器 |
ACS |
Auto-Configuration Server |
自动配置服务器 |
ACSEI |
ACFP Client and Server Exchange Information |
ACFP客户端和服务器端信息交互协议 |
Active-Stateful PCC |
Active-Stateful Path Computation Client |
主动有状态PCC |
Active-Stateful PCE |
Active-Stateful Path Computation Element |
主动有状态PCE |
AD |
Active Directory |
活动目录 |
ADM |
ATM Direct Mapping |
ATM直接映射 |
ADP |
Add Diagnostic Parameter |
增加诊断信息 |
ADPCM |
Adaptive Differential Pulse Code Modulation |
自适应差分脉冲编码调制 |
ADSL |
Asymmetric Digital Subscriber Line |
不对称数字用户线 |
ADVPN |
Auto Discovery Virtual Private Network |
自动发现虚拟专用网络 |
AER |
AS Edge Router |
AS边界路由器 |
AES |
Advanced Encryption Standard |
高级加密标准 |
AF |
Assured Forwarding |
确保转发 |
AFI |
Authority and Format Identifier |
授权和格式标识符 |
AFI |
Address Family Identifier |
地址族标识符 |
AFT |
Address Family Translation |
地址族转换 |
AFTR |
Address Family Transition Router |
地址族转换路由器 |
AH |
Authentication Header |
认证头 |
AIFSN |
Arbitration Inter Frame Spacing Number |
仲裁帧间隙数 |
AIS |
Alarm Indication Signal |
告警指示信号 |
AIW |
APPN Implementers Workshop |
APPN实现工作组 |
AKM |
Authentication and Key Management |
身份认证与密钥管理 |
ALG |
Application Level Gateway |
应用层网关 |
AM |
Analog Modem |
模拟调制解调器 |
AMB |
Active Main Board |
主用主控板 |
AMI |
Alternate Mark Inversion |
交替传号反转 |
A-MPDU |
Aggregate MAC Protocol Data Unit |
聚合MAC协议数据单元 |
A-MSDU |
Aggregate MAC Service Data Unit |
聚合MAC服务数据单元 |
ANCP |
Access Node Control Protocol |
接入节点控制协议 |
ANI |
Adaptive Noise Immunity |
自动抗干扰 |
ANSI |
American National Standards Institute |
美国国家标准协会 |
AP |
Agreement Protocol |
一致协议 |
AP |
Access Point |
接入点 |
APD |
Avalanche Photo Diode |
雪崩光电二极管 |
APDB |
Access Point Information Database |
接入点信息数据库 |
APoT |
AP of things |
无线物联网 |
APP |
Application Protocol |
应用协议 |
APPN |
Advanced Peer-to-Peer Networking |
高级对等网络 |
APR |
Application Recognition |
应用层协议识别 |
ARP |
Address Resolution Protocol |
地址解析协议 |
ARQ |
Automatic Repeat Request |
自动重发请求 |
AS |
Autonomous System |
自治系统 |
ASBR |
Autonomous System Boundary Router |
自治系统边界路由器 |
ASM |
Any-Source Multicast |
任意信源组播 |
ASPF |
Application Specific Packet Filter |
基于应用层状态的包过滤 |
ASPF |
Advanced Stateful Packet Filter |
高级状态包过滤 |
AT |
AppleTalk |
Apple计算机网络协议 |
ATD |
Attribute Discovery |
属性发现 |
ATM |
Asynchronous Transfer Mode |
异步传输模式 |
AU |
Administration Unit |
管理单元 |
AUG |
Administration Unit Group |
管理单元组 |
AU-PTR |
Administration Unit Pointer |
管理单元指针 |
AVF |
Appointed VLAN-x Forwarder |
指定VLAN转发者 |
AVF |
Active Virtual Forwarder |
动态虚拟转发器 |
AVP |
Attribute Value Pair |
属性值对 |
B Return |
B4 |
Basic Bridging BroadBand |
基本桥接宽带 |
B8ZS |
Bipolar 8-zero substitution |
双极性8zero替换码 |
BA |
Block Acknowledgment |
块确认 |
BAS |
Broadband Access Server |
宽带接入服务器 |
BB_Credit |
Buffer-to-Buffer Credit |
报文缓冲区大小 |
BC |
Bandwidth Constraint |
带宽约束 |
BC |
Boundary Clock |
边界时钟 |
BCB |
Backbone Core Bridge |
骨干网核心网桥 |
BDI |
Backward Defect Indication |
反向缺陷通告 |
BDR |
Backup Designated Router |
备份指定路由器 |
BE |
Best Effort |
尽力转发 |
BEB |
Backbone Edge Bridge |
骨干网边缘网桥 |
BECN |
Backward Explicit Congestion Notification |
后向显式拥塞通知 |
BF |
Build Fabric |
建立Fabric |
BFD |
Bidirectional Forwarding Detection |
双向转发检测 |
BGP |
Border Gateway Protocol |
边界网关协议 |
BIDIR-PIM |
Bidirectional Protocol Independent Multicast |
双向协议无关组播 |
BIMS |
Branch Intelligent Management System |
分支网点智能管理系统 |
BIP |
Bit-Interleaved Parity |
比特交叉奇偶校验 |
BIP |
Broadcast Integrity Protocol |
广播完整性协议 |
BITS |
Building Integrated Timing Supply System |
通信楼综合定时供给系统 |
BLE |
Bluetooth Low Energy |
蓝牙低功耗 |
B-MAC |
Backbone MAC |
骨干网MAC |
BMC |
Best Master Clock |
最佳主时钟 |
BMP |
BGP Monitoring Protocol |
BGP监控协议 |
BOOTP |
Bootstrap Protocol |
自举协议 |
BPDU |
Bridge Protocol Data Unit |
网桥协议数据单元 |
BQ |
Bandwidth Queuing |
带宽队列 |
BRAS |
Broadband Remote Access Server |
宽带远程接入服务器 |
BRI |
Basic Rate Interface |
基本速率接口 |
BRPC |
Backward-Recursive PCE-Based Computation |
反向递归路径计算 |
BSB |
Blockade State Block |
阻塞状态块 |
BSM |
Bootstrap Message |
自举报文 |
BSMF |
Bootstrap Message Fragment |
自举报文分片 |
BSR |
Bootstrap Router |
自举路由器 |
BSS |
Basic Service Set |
基本服务集 |
BSV |
BRI S/T Voice |
ISDN BRI S/T接口语音模块 |
BT |
BitTorrent |
比特洪流 |
B-VLAN |
Backbone VLAN |
骨干网VLAN |
C Return |
CA |
Connectivity Association |
安全连通集 |
CA |
Certificate Authority |
证书颁发机构 |
CAC |
Connect Admission Control |
连接准入控制 |
CAMS |
Comprehensive Access Management Server |
综合访问管理服务器 |
CAPWAP |
Controlling and Provisioning of Wireless Access Point |
无线接入点控制与供应 |
CAR |
Committed Access Rate |
承诺访问速率 |
CB |
Customer Bridge |
客户桥 |
CB |
Controlling Bridge |
控制设备 |
CBQ |
Class Based Queuing |
基于类的队列 |
CBR |
Constant Bit Rate |
确定比特率 |
CBS |
Committed Burst Size |
承诺突发尺寸 |
C-BSR |
Candidate-BSR |
候选BSR |
CBT |
Core-Based Tree |
有核树 |
CBTS |
Class-of-service Based Tunnel Selection |
基于服务类型的隧道选择 |
CBWFQ |
Class Based Weighted Fair Queuing |
基于类的加权公平队列 |
CC |
Control Channel |
控制通道 |
CC |
Call Control |
呼叫控制 |
CC |
Continuity Check |
连续性检测 |
CC |
Common Criteria |
公共准则 |
CCA |
Clear Channel Assessment |
空闲信道评估 |
CCC |
Circuit Cross Connect |
电路交叉连接 |
CCF |
Congestion Controlled Flow |
拥塞控制流 |
CCM |
Continuity Check Message |
连续性检测报文 |
C-DCC |
Circular DCC |
轮询DCC |
CDCP |
S-Channel Discovery and Configuration Protocol |
S通道发现和配置协议 |
CDP |
Cisco Discovery Protocol |
思科发现协议 |
CDR |
Call Detail Record |
呼叫详细记录 |
CDV |
Cell Delay Variation |
信元时延抖动 |
CE |
Customer Edge |
用户网络边缘 |
CED |
Called Station Identifier |
被叫终端标识 |
CEDCNG |
被叫终端标识 |
CEE |
Converged Enhanced Ethernet |
汇聚增强型以太网 |
CEM |
Circuit Emulation |
电路仿真 |
CEM Class |
Circuit Emulation Class |
电路仿真类 |
CESoPSN |
Circuit Emulation Services over PSN |
分组交换网络上传输电路仿真服务 |
CFD |
Connectivity Fault Detection |
连通错误检测 |
CFI |
Canonical Format Indicator |
标准格式指示位 |
CFM |
Connectivity Fault Management |
连通错误管理 |
CHAP |
Challenge Handshake Authentication Protocol |
质询握手认证协议 |
CID |
Calling Identity Delivery |
主叫信息识别及显示 |
CIDR |
Classless Inter-Domain Routing |
无类域间路由 |
CIR |
Committed Information Rate |
承诺信息速率 |
CIR ALLOW |
Committed Information Rate ALLOW |
允许的承诺信息速率 |
CIST |
Common and Internal Spanning Tree |
公共和内部生成树 |
CLC |
Channel Link Control |
通道链路控制 |
CLI |
Calling Line Identification |
主叫线路标识 |
CLI |
Command Line Interface |
命令行接口 |
CLNP |
Connection-Less Network Protocol |
无连接网络协议 |
CLP |
Cell Loss Priority |
信元丢失优先级 |
CMC |
Call Management Center |
呼叫管理中心 |
CNAME |
Canonical Name |
规范名称 |
CND |
Congestion Notification Domain |
拥塞通知域 |
CNG |
Comfortable Noise Generation |
舒适噪音 |
CNG |
Calling Tone |
主叫单音 |
CNGCED |
Calling Tone |
主叫单音 |
CNM |
Congestion Notification Message |
拥塞通告消息 |
CNPV |
Congestion Notification Priority value |
拥塞通知优先级的值 |
CO |
Central Office |
中心局 |
COPS |
Common Open Policy Service |
公共开放策略服务 |
CoS |
Class of Service |
服务类型 |
CP |
Congestion Point |
拥塞点 |
CPE |
Customer Premises Equipment |
用户侧设备 |
CPOS |
Channelized POS |
通道化的POS |
CPS |
Certification Practice Statement |
证书惯例声明 |
CPTone |
Call Progress Tone |
呼叫进程音 |
CQ |
Custom Queuing |
定制队列 |
CR |
Constraint-based Routing |
基于约束的路由 |
CRC |
Cyclic Redundancy Code |
循环冗余校验码 |
CRC |
Cyclic Redundancy Check |
循环冗余校验 |
CRC4 |
Cyclic Redundancy Check 4 |
4阶循环冗余校验 |
CRL |
Certificate Revocation List |
证书吊销列表 |
CRLDP |
Constraint-based Routed Label Distribution Protocol |
基于约束路由的LDP |
CRLSP |
Constraint-based Routed Label Switched Paths |
基于约束路由的LSP |
C-RP |
Candidate-RP |
候选RP |
CS |
Class Selector |
兼容IP优先级 |
CSMA/CD |
Carrier Sense Multiple Access/Collision Detect |
带冲突检测的载波侦听多路访问 |
CSNP |
Complete Sequence Number PDU |
全时序报文 |
CSP |
Port Extender Control and Status Protocol |
端口扩展设备控制和状态协议 |
CSPF |
Constraint-based Shortest Path First |
基于约束的最短路径优先 |
CST |
Common Spanning Tree |
公共生成树 |
CSV |
Comma Separated Value |
逗号分隔值 |
CT |
Class Type |
服务类型 |
CTR |
Counter mode |
计数器模式 |
CTS |
Clear to Send |
清除发送请求 |
CUG |
Closed User Group |
封闭用户群 |
CV |
Connectivity Verification |
连通性验证 |
CWMP |
CPE WAN Management Protocol |
CPE广域网管理协议 |
D Return |
DAC |
Digital to Analog Converter |
数模转换器 |
DAD |
Duplicate Address Detection |
重复地址检测 |
DAE |
Dynamic Authorization Extensions |
动态授权扩展 |
DAR |
Deeper Application Recognition |
深度应用识别 |
Data-MDT |
Data-Multicast Distribution Tree |
数据组播分发树 |
DBA |
Dynamic Bandwidth Allocation |
动态带宽分配 |
DCBX |
Data Center Bridging Exchange Protocol |
数据中心桥能力交换协议 |
DCC |
Dial Control Center |
拨号控制中心 |
DCD |
Data Carrier Detection |
数据载波检测 |
DCE |
Data Center Ethernet |
数据中心以太网 |
DCE |
Data Circuit-terminating Equipment |
数据电路终接设备 |
DCF |
Distributed Coordination Function |
分布式协调功能 |
DCN |
Data Communication Network |
数据通信网 |
DCR |
Differential Clock Recovery |
差分时钟恢复 |
DD |
Database Description |
数据库描述 |
DDN |
Digital Data Network |
数字数据网 |
DDNS |
Dynamic Domain Name System |
动态域名系统 |
DDoS |
Distributed Denial of Service |
分布式拒绝服务 |
DDR |
Dial-on-Demand Routing |
按需拨号路由 |
DDT |
Delegated Database Tree |
数据库权限分发树 |
DE |
Discard Eligibility |
合格丢弃 |
DED |
Designated Edge Device |
指定边缘设备 |
Default-MDT |
Default-Multicast Distribution Tree |
默认组播分发树 |
DER |
Distinguished Encoding Rules |
特异编码规则 |
DF |
Designated Forwarder |
指定转发者 |
DGAF |
Downstream Group-Addressed Forwarding |
下行组地址报文转发 |
DH |
Diffie-Hellman |
交换及密钥分发 |
DHCP |
Dynamic Host Configuration Protocol |
动态主机配置协议 |
DHCPv6 |
Dynamic Host Configuration Protocol for IPv6 |
支持IPv6的动态主机配置协议 |
DID |
Device ID |
设备ID |
DID |
Direct Inward Dialing |
直接内部呼叫 |
DiffServ |
Differentiated Service |
区分服务 |
DIS |
Designated IS |
指定中间系统 |
DLCI |
Data Link Connection Identifier |
数据链路连接标识符 |
DLDP |
Device Link Detection Protocol |
设备链路检测协议 |
DLSw |
Data Link Switching |
数据链路交换 |
DM |
Diagnostic and Monitoring |
诊断和监控 |
DM |
Delay Measurement |
延时测量 |
DMC |
Device Management Controller |
设备管理控制台 |
DMM |
Delay Measurement Message |
时延测量报文 |
DMR |
Delay Measurement Reply |
时延测量应答 |
DMZ |
Demilitarized Zone |
非军事区 |
DN |
Distinguished Name |
识别名 |
DN |
Directory Number |
号码目录 |
DNAT |
Destination Network Address Translation |
目的网络地址转换 |
DND |
Do-not Disturb |
免打扰 |
DNS |
域名系统 |
DNU |
Do Not Use for synchronization |
不应用作同步 |
DoD |
Downstream On Demand |
下游按需方式 |
DoS |
Denial of Service |
拒绝服务 |
DP |
Drop Profile |
丢弃策略 |
DPD |
Dead Peer Detection |
对等体存活检测 |
DPI |
Deep Packet Inspection |
深度报文检测 |
DR |
Designated Router |
指定路由器 |
DRB |
Designated Routing Bridge |
指定路由桥 |
DRCP |
Distributed Relay Control Protocol |
分布式聚合控制协议 |
DRCPDU |
Distributed Relay Control Protocol Data Unit |
分布式聚合控制协议数据单元 |
DRE |
Data Redundancy Elimination |
数据冗余消除 |
DRNI |
Distributed Resilient Network Interconnect |
分布式弹性网络互连 |
DRS |
DPI Report Statistics |
深度报文检测信息统计 |
DS |
Differentiated Services |
差分服务 |
DSA |
Digital Signature Algorithm |
数字签名算法 |
DSCP |
Differentiated Services Code Point |
区分服务编码点 |
DSL |
数字用户线路 |
DS-Lite |
Dual Stack Lite |
轻量级双协议栈 |
DSU |
Data Service Unit |
数据服务单元 |
DTD |
Document Type Definition |
文件类型定义 |
DTE |
Data Terminal Equipment |
数据终端设备 |
DTIM |
Delivery Traffic Indication Message |
数据待传指示信息 |
DTLS |
Datagram Transport Layer Security |
数据包传输层安全性协议 |
DTMF |
Dual Tone Multi-Frequency |
双音多频 |
DU |
Downstream Unsolicited |
下游自主方式 |
DUID |
DHCP Unique Identifier |
DHCP唯一标识符 |
DUID-LL |
DUID Based on Link-layer Address |
基于链路层地址的DUID |
D-V |
Distance Vector |
距离向量 |
DVMRP |
Distance Vector Multicast Routing Protocol |
距离矢量组播路由协议 |
DVPN |
Dynamic Virtual Private Network |
动态虚拟专用网络 |
DWDM |
Dense Wavelength Division Multiplexing |
密级波分复用 |
E Return |
E2ETC |
End-to-End Transparent Clock |
端到端透明时钟 |
EAA |
Embedded Automation Architecture |
嵌入式自动化架构 |
EACL |
Enhanced ACL |
增强型ACL |
EAD |
Endpoint Admission Defense |
端点准入防御 |
EAIS |
Ethernet Alarm Indication Signal |
以太网告警指示信号 |
EAN |
Ethernet Access Node |
以太网接入节点 |
EAP |
Extensible Authentication Protocol |
可扩展认证协议 |
EAPOL |
Extensible Authentication Protocol over LAN |
局域网上的可扩展认证协议 |
EAPOL KCK |
EAPOL-Key Confirmation Key |
EAPOL确认密钥 |
EAPOL KEK |
EAPOL-Key Encryption Key |
EAPOL加密密钥 |
EAP-TLS |
Extensible Authentication Protocol -Transport Layer Security |
可扩展认证协议-传输层安全 |
EBS |
Excess Burst Size |
超出突发尺寸 |
ECDSA |
Elliptic Curve Digital Signature Algorithm |
椭圆曲线数字签名算法 |
ECID |
E-channel Identifier |
E通道标识 |
ECM |
Encapsulated Control Message |
封装控制信息 |
ECM |
Error Correction Mode |
误码纠错模式 |
ECN |
显式拥塞通知 |
ECP |
Edge Control Protocol |
边缘控制协议 |
ECT |
Equal Cost Tree |
等价树 |
ECWmax |
Exponent form of CWmax |
最大竞争窗口指数形式 |
ECWmin |
Exponent form of CWmin |
最小竞争窗口指数形式 |
ED |
Edge Device |
边缘设备 |
EDCA |
Enhanced Distributed Channel Access |
增强的分布式信道访问 |
EEE |
Energy Efficient Ethernet |
高效节能以太网 |
EF |
Expedited Forwarding |
加速转发 |
EFM |
Ethernet First Mile |
第一英里以太网 |
EGP |
Exterior Gateway Protocol |
外部网关协议 |
EID |
Endpoint Identifier |
节点标识符 |
EIRP |
Effective Isotropic Radiated Power |
有效全向辐射功率 |
EM |
Event Monitor |
事件监控 |
EMO |
Endpoint Mobile Office |
终端移动办公 |
EMR |
Ensure Minimum Rate |
保障最低速率 |
ENDC |
EVI Neighbor Discovery Client |
EVI邻居发现客户端 |
ENDC |
Enhanced Neighbor Discovery Client |
增强的邻居发现客户端 |
End-Of-RIB |
End of Routing-Information-Base |
路由信息库结束 |
ENDP |
EVI Neighbor Discovery Protocol |
EVI邻居发现协议 |
ENDP |
Enhanced Neighbor Discovery Protocol |
增强的邻居发现协议 |
ENDS |
Enhanced Neighbor Discovery Server |
增强的邻居发现服务器 |
ENDS |
EVI Neighbor Discovery Server |
EVI邻居发现服务器 |
ENUM |
Telephone Number Mapping |
电话号码映射 |
EOAM |
Ethernet Operation, Administration and Maintenance |
以太网操作、管理和维护 |
EoPW |
Ethernet over Pseudo Wire |
虚电路上承载以太网 |
EPC |
External Path Computation |
外部路径计算 |
EPON |
Ethernet Passive Optical Network |
以太网无源光网络 |
ER |
Edge Relay |
边缘中继 |
ERPS |
Ethernet Ring Protection Switching |
以太环网保护倒换 |
ERT |
Export Route-target |
引出路由标识 |
ES |
End System |
终端系统 |
ES |
Ethernet Segment |
以太网段 |
ESF |
Extended Super Frame |
扩展超帧 |
ESI |
Ethernet Segment Identifier |
以太网段标识符 |
ESMC |
Ethernet Synchronous Message Channel |
以太网同步消息通道 |
ESN |
Extended Sequence Number |
扩展序列号 |
ESP |
Encapsulating Security Payload |
封装安全载荷 |
ESS |
Extended Service Set |
拓展服务集 |
ESS |
Exchange Switch Support |
交换机能力协商 |
ETR |
Egress Tunnel Router |
出方向隧道路由器 |
ETS |
Enhanced Transmission Selection |
增强传输选择 |
ETSI |
European Telecommunications Standards Institute |
欧洲电信标准协会 |
EUI |
Extended Unique Identifier |
扩展唯一标识符 |
EUI-64 |
64-bit Extended Unique Identifier |
64位扩展唯一标识符 |
EVB |
Edge Virtual Bridging |
边缘虚拟桥接 |
Event MIB |
Event Management Information Base |
事件管理信息库 |
EVFP |
Exchange Virtual Fabrics Parameter |
虚拟Fabric参数交换 |
EVI |
Ethernet Virtual Interconnect |
以太网虚拟化互联 |
EVPN |
Ethernet Virtual Private Network |
以太网虚拟专用网络 |
F Return |
FA |
Foreign-AC |
外地代理AC |
FA |
Foreign Agent |
外地代理 |
FAC |
Feature Access Code |
业务特征码 |
FAS |
Frame Alignment Signal |
帧同步标记 |
FC |
Fibre Channel |
光纤通道 |
FC |
Forwarding Class |
转发类 |
FCF |
FCoE Forwarder |
FCoE转发器 |
FCM |
Fast Connect Modem |
快速连接调制解调器 |
FCoE |
Fibre Channel over Ethernet |
基于以太网的光纤通道 |
FCPS |
FC Port Security |
FC端口安全 |
FCS |
Fabric Configuration Server |
Fabric配置服务 |
FCS |
Frame Check Sequence |
帧校验序列 |
FDB |
Forwarding Database |
转发数据库 |
FDMI |
Fabric Device Management Interface |
Fabric设备管理接口 |
FE |
Fast Ethernet |
快速以太网 |
FEAC |
Far End Alarm and Control signal |
远端告警与控制信号 |
FEC |
Forwarding Equivalence Class |
转发等价类 |
FEC |
Forward Error Correction |
前向错误纠错 |
FECN |
Forward Explicit Congestion Notification |
前向显式拥塞通知 |
FEP |
Front End Processor |
前端处理器 |
FF |
Fixed-Filter |
固定过滤器 |
FFD |
Fast Failure Detection |
快速缺陷检测 |
FFT |
Fast Fourier Transform |
快速傅立叶变换 |
FG |
Forwarding Group |
转发组 |
FHR |
First Hop Router |
第一跳路由器 |
FIB |
Forwarding Information Base |
转发信息库 |
FIFO |
First In First Out |
先入先出 |
FIFO |
First In First Out Queuing |
先进先出队列 |
FIP |
FCoE Initialization Protocol |
FCoE初始化协议 |
FIP Snooping |
FCoE Initialization Protocol Snooping |
FCoE初始化探测协议 |
FIPS |
Federal Information Processing Standards |
联邦信息处理标准 |
Flowpsec |
Flow Specification |
流规格 |
FNG |
Fault Notification Generator |
错误提示生成器 |
FP |
Forwarding Profile |
转发策略 |
FPMA |
Fabric Provided MAC Address |
Fabric提供的MAC地址 |
FQ |
Fair Queuing |
公平队列 |
FQDN |
Fully Qualified Domain Name |
完全合格域名 |
FR |
Frame Relay |
帧中继 |
FRR |
Fast Reroute |
快速重路由 |
FRTP |
Frame Relay Traffic Policing |
帧中继流量监管 |
FRTS |
Frame Relay Traffic Shaping |
帧中继流量整形 |
FRU |
Field Replaceable Unit |
现场可替换部件 |
FS |
Forced Switch |
强制倒换 |
FSK |
Frequency Shift Keying |
频移键控 |
FSPF |
Fabric Shortest Path First |
光纤最短路径优先 |
FT |
Fault Tolerance |
容错 |
FT |
Fast BSS Transition |
快速BSS切换 |
FTN |
FEC to NHLFE map |
FEC到NHLFE表项的映射 |
FTP |
File Transfer Protocol |
文件传输协议 |
FXO |
Foreign Exchange Office |
外部交换局 |
FXS |
Foreign Exchange Station |
外部交换站 |
G Return |
GAL |
G-ACh Label |
通用共路通道标签 |
GARP |
Generic Attribute Registration Protocol |
通用属性注册协议 |
GAS |
Generic Advertisement Service |
通用通告服务 |
GDOI |
Group Domain of Interpretation |
组解释域 |
GE |
Gigabit Ethernet |
千兆以太网 |
GI |
Guard Interval |
保护间隔 |
GK |
GateKeeper |
网守 |
GM |
Group Member |
组成员 |
GM |
Grandmaster Clock |
最优时钟 |
GMK |
Group Master Key |
组播主密钥 |
GNE |
Gateway Network Element |
网关网元 |
GNS |
Get Nearest Server |
请求最近的服务器 |
GOLD |
Generic OnLine Diagnostics |
通用在线诊断 |
GPS |
Global Positioning System |
全球定位系统 |
GR |
Graceful Restart |
平滑重启 |
GRE |
Generic Routing Encapsulation |
通用路由封装 |
Group Domain VPN |
Group Domain Virtual Private Network |
组域虚拟专用网络 |
GSMPv3 |
General Switch Management Protocol Version 3 |
通用交换管理协议版本3 |
GTC |
Generic Token Card |
通用令牌卡 |
GTK |
Group Temporal Key |
群组临时密钥 |
GTP |
GPRS Tunneling Protocol |
GPRS隧道协议 |
GTP-U |
GPRS Tunneling Protocol User |
GTP用户面 |
GTS |
Generic Traffic Shaping |
通用流量整形 |
GTSM |
Generalized TTL Security Mechanism |
通用TTL安全保护机制 |
GVRP |
GARP VLAN Registration Protocol |
GARP VLAN注册协议 |
GW |
Gateway |
网关 |
H Return |
HA |
Home-AC |
家乡代理AC |
HA |
Home Agent |
本地代理 |
HABP |
HW Bypass Protocol |
HW旁路认证协议 |
HBA |
Host Bus Adapter |
主机总线适配器 |
HDB3 |
High-density bipolar 3 |
3阶高密度双极性码 |
HDLC |
High-level Data Link Control |
高级数据链路控制 |
HDSL |
High-speed Digital Subscriber Line |
高速数字用户线路 |
HESSID |
Homogenous Extended Service Set IDentifier |
扩展服务标识 |
HGMP |
HW Group Management Protocol |
HW组管理协议 |
HGMPv2 |
HW Group Management Protocol version 2 |
HW组管理协议版本2 |
HMAC |
Hash-based Message Authentication Code |
基于散列的消息鉴别码 |
HoPE |
Hierarchy of PE |
分层PE |
HoVPN |
Hierarchy of VPN |
分层VPN |
HQoS |
Hierarchical Quality of Service |
分层QoS |
HTTP |
Hypertext Transfer Protocol |
超文本传输协议 |
HTTPS |
Hypertext Transfer Protocol Secure |
超文本传输协议的安全版本 |
H-VPLS |
Hierarchical VPLS |
分层VPLS |
HWTACACS |
HW Terminal Access Controller Access Control System |
HW终端访问控制器控制系统协议 |
I Return |
IA |
Identity Association |
标识联盟 |
IACTP |
Inter Access Controller Tunneling Protocol |
接入控制器间隧道协议 |
IAD |
Integrated Access Device |
综合接入设备 |
IANA |
Internet Assigned Numbers Authority |
互联网编号分配委员会 |
IBGP |
Internal Border Gateway Protocol |
内部边界网关协议 |
ICANN |
Internet Corporation for Assigned Names and Numbers |
互联网域名和地址分配公司 |
ICMP |
Internet Control Message Protocol |
互联网控制消息协议 |
ICMPv6 |
Internet Control Message Protocol for IPv6 |
IPv6互联网控制消息协议 |
ICP |
IMA Control Protocol |
IMA控制协议 |
ICPIF |
Calculated Planning Impairment Factor |
计算计划损伤元素 |
ICRQ |
Incoming Call Request |
入呼叫请求 |
IDN |
Integrated Digital Network |
综合数字网 |
IDS |
Intrusion Detection System |
入侵检测系统 |
IE |
Information Element |
信息元素 |
IE |
Interconnect Element |
互联设备 |
IEEE |
Institute of Electrical and Electronics Engineers |
电气和电子工程师学会 |
IETF |
Internet Engineering Task Force |
互联网工程任务组 |
IGMP |
Internet Group Management Protocol |
互联网组管理协议 |
IGMP Snooping |
Internet Group Management Protocol Snooping |
互联网组管理协议窥探 |
IGP |
Interior Gateway Protocol |
内部网关协议 |
IGTK |
Integrity Group Temporal Key |
完整性组临时密钥 |
IIH |
Intermediate System-to-Intermediate System Hello |
中间系统到中间系统Hello |
IKE |
Internet Key Exchange |
互联网密钥交换 |
IKEv2 |
Internet Key Exchange Version 2 |
互联网密钥交换协议第2版 |
ILM |
Incoming Label Map |
入标签映射 |
ILS |
Internet Locator Service |
互联网定位服务 |
IM |
Instant Messaging |
即时消息服务 |
IMA |
Inverse Multiplexing for ATM |
ATM反向复用 |
IMAP |
Internet Mail Access Protocol |
Internet邮件访问协议 |
iMC |
Intelligent Management Center |
智能管理中心 |
IMSI |
International Mobile Subscriber Identification Number |
国际移动用户标识 |
InARP |
Inverse Address Resolution Protocol |
逆向地址解析协议 |
IND |
Inverse Neighbor Discovery |
逆向邻居发现 |
IntServ |
Integrated Service |
综合业务模型 |
IPC |
Inter-process Communication |
进程间通信 |
IPE |
Image Package Envelope |
复合软件包套件 |
IPHC |
IP Header Compression |
IP报文头压缩 |
IPL |
Intra-Portal Link |
内部控制链路 |
IPN |
IGTK Packet Number |
IGTK报文序列号 |
IPng |
IP Next Generation |
下一代互联网协议 |
IPoA |
IP over ATM |
在ATM上承载IP协议 |
IPoEoA |
IP over Ethernet over ATM |
在ATM上承载IPoE协议 |
IPP |
Intra-Portal Port |
内部控制链路端口 |
IPS |
Intrusion Prevention System |
入侵防御系统 |
IPsec |
IP Security |
IP安全 |
IPTA |
IP Terminal Access |
IP终端接入 |
IPv6 |
Internet Protocol version 6 |
互联网协议版本6 |
IPv6 MBGP |
IPv6 Multicast BGP |
IPv6 组播BGP |
IPv6 ND |
IPv6 Neighbor Discovery |
IPv6邻居发现 |
IPv6 PIM |
IPv6 Protocol Independent Multicast |
IPv6协议无关组播 |
IPv6 PIM Snooping |
IPv6 Protocol Independent Multicast Snooping |
IPv6协议无关组播窥探 |
IPX |
Internetwork Packet Exchange |
网际报文交换 |
IRB |
Integrated Bridging and Routing |
集成的桥接和路由 |
IRB |
Integrated Routing Bridging and Bridging Routing |
集成的路由桥接和桥接路由 |
IRDP |
ICMP Router Discovery Protocol |
ICMP路由器发现协议 |
IRF |
Intelligent Resilient Framework |
智能弹性架构 |
IS |
Intermediate System |
中间系统 |
ISAKMP |
Internet Security Association and Key Management Protocol |
互联网安全联盟和密钥管理协议 |
ISATAP |
Intra-Site Automatic Tunnel Addressing Protocol |
站点内自动隧道寻址协议 |
ISDN |
Integrated Services Digital Network |
综合业务数字网 |
I-SID |
Backbone Service Instance Identifier |
骨干网服务实例编号 |
IS-IS |
Intermediate System-to-Intermediate System |
中间系统到中间系统 |
ISO |
International Organization for Standardization |
国际标准化组织 |
ISP |
Internet Service Provider |
互联网服务提供商 |
ISPF |
Incremental Shortest Path First |
增量最短路径优先 |
ISSU |
In-Service Software Upgrade |
不中断业务升级 |
IST |
内部生成树 |
ITA |
Intelligent Target Accounting |
智能靶向计费 |
ITR |
Ingress Tunnel Router |
入方向隧道路由器 |
ITSP |
Internet Telephone Service Provider |
互联网电话运营商 |
ITU |
International Telecommunication Union |
国际电信联盟 |
ITU-T |
International Telecommunication Union Telecommunication |
国际电信联盟-电信标准部 |
IV |
Initialization Vector |
初始化向量 |
IVR |
Interactive Voice Response |
交互式语音应答 |
K Return |
KAT |
Known-Answer Test |
已知结果测试 |
KCK |
确认密钥 |
KEK |
加密密钥 |
KEK |
Key Encrytion Key |
加密密钥 |
KS |
Key Server |
密钥服务器 |
L Return |
L2F |
Layer 2 Forwarding |
二层转发 |
L2PT |
Layer 2 Protocol Tunneling |
二层协议隧道 |
L2TP |
Layer 2 Tunneling Protocol |
二层隧道协议 |
L2VPN |
Layer 2 Virtual Private Network |
二层虚拟专用网络 |
L3VNI |
Layer 3 VNI |
三层VXLAN ID |
L3VPN |
Layer 3 Virtual Private Network |
三层虚拟专用网 |
LAC |
L2TP Access Concentrator |
L2TP访问集中器 |
LACP |
Link Aggregation Control Protocol |
链路聚合控制协议 |
LACPDU |
Link Aggregation Control Protocol Data Unit |
链路聚合控制协议数据单元 |
LAN |
Local Area Network |
局域网 |
LB |
Label Base |
初始标签 |
LB |
Loopback |
环回 |
LB |
Load Balance |
负载均衡 |
LBM |
Loopback Message |
环回报文 |
LBR |
Loopback Reply |
环回应答 |
LC |
Logic Channel |
逻辑信道 |
LCFO |
Loop Current Feed Open |
脉冲挂机信号 |
LCI |
Logic Channel Identifier |
逻辑信道号 |
LCP |
Link Control Protocol |
链路控制协议 |
LDAP |
Lightweight Directory Access Protocol |
轻量级目录访问协议 |
LDN |
Local Dialing Number |
本地拨号号码 |
LDP |
标签分发协议 |
LDP ID |
LDP Identifier |
LDP标识符 |
LDPC |
Low-Density Parity Check |
低密度奇偶校验 |
LER |
Label Edge Router |
标签边缘路由器 |
LFI |
Link Fragmentation and Interleaving |
链路分片与交叉 |
LFIB |
Label Forwarding Information Base |
标签转发信息库 |
LGS |
Loop-start & Ground-start Signaling |
环路启动与地启动信令 |
LI |
Leap Indicator |
闰秒指示 |
LLC |
Logical Link Control |
逻辑链路控制 |
LLDP |
Link Layer Discovery Protocol |
链路层发现协议 |
LLDPDU |
Link Layer Discovery Protocol Data Unit |
链路层发现协议数据单元 |
LLDP-MED |
Link Layer Discovery Protocol Media Endpoint Discovery |
链路层发现协议媒体终端发现 |
LLID |
Logical Link ID |
逻辑链路标志 |
LLQ |
Low Latency Queuing |
低时延队列 |
LM |
Loss Measurement |
丢包测量 |
LMI |
Local Management Interface |
本地管理接口 |
LMM |
Loss Measurement Message |
丢包测量报文 |
LMR |
Loss Measurement Reply |
丢包测量应答 |
LNS |
L2TP Network Server |
L2TP网络服务器 |
LO |
Label-block Offset |
标签块偏移 |
LOCV |
Loss of Connectivity Verification defect |
连通性检测缺陷 |
LOS |
Loss of Signal |
信号丢失 |
LPU |
Line Processing Unit |
线路处理单元 |
LPU Port |
Line Processing Unit Port |
线路处理单元端口 |
LQR |
Link Quality Reports |
链路质量报告 |
LR |
Line Rate |
物理接口总速率限制 |
LR |
Label Range |
标签范围 |
LS |
Link State |
链路状态 |
LSA |
Link State Advertisement |
链路状态通告 |
LSA |
Link State Acknowledgment |
链路状态确认 |
LSAck |
链路状态确认 |
LSDB |
Link State DataBase |
链路状态数据库 |
LSDB |
Link State Database |
链路状态数据库 |
LSP |
Link State PDU |
链路状态协议数据单元 |
LSP |
Label Switched Path |
标签交换路径 |
LSPDU |
Link State Protocol Data Unit |
链路状态协议数据单元 |
LSR |
Label Switching Router |
标签交换路由器 |
LSR |
Link State Record |
链路状态记录 |
LSR |
Link State Request |
链路状态请求 |
LSU |
Link State Update |
链路状态更新 |
LT |
Linktrace |
链路跟踪 |
LTM |
Linktrace Message |
链路跟踪报文 |
LTR |
Linktrace Reply |
链路跟踪应答 |
LTS |
L2TP Tunnel Switch |
L2TP隧道交换 |
LVF |
Listening Virtual Forwarder |
监听虚拟转发器 |
LZ |
Lempel-Ziv compression |
LZ压缩 |
M Return |
M flag |
Managed Address Configuration Flag |
被管理地址配置标志位 |
MA |
Mobility Agent |
漫游代理 |
MA |
Maintenance Association |
维护集 |
MAC |
Media Access Control |
媒体访问控制 |
MAC |
消息验证码 |
MACsec |
Media Access Control Security |
MAC安全 |
MAD |
Multi-Active Detection |
多Active检测 |
MAM |
Maximum Allocation Model |
最大分配模型 |
MAN |
Metropolitan Area Network |
城域网 |
MAP |
Mesh Access Point |
Mesh接入点 |
MBGP |
Multicast BGP |
组播BGP |
MBS |
Maximum Burst Size |
最大突发长度 |
MC |
Mobility Controller |
漫游控制器 |
MCC |
Mobile Country Code |
移动国家编码 |
MCE |
Multi-VPN-Instance Customer Edge |
多VPN实例用户网络边界设备 |
MCS |
Modulation and Coding Scheme |
调制与编码策略 |
MCU |
Multipoint Control Unit |
多点控制单元 |
MD |
Maintenance Domain |
维护域 |
MD |
Multicast Domain |
组播域 |
MDC |
Multitenant Device Context |
多租户设备环境 |
MDI |
Medium Dependent Interface |
介质相关接口 |
MDL |
Maintenance Data Link |
维护数据链路 |
mDNS |
Multicast DNS |
组播域名 |
MDT |
组播分发树 |
ME |
Maintenance Entity |
维护实体 |
MED |
Multi-Exit Discriminator |
多出口区分 |
MEG |
Maintenance Entity Group |
维护实体组 |
MEP |
MEG End Point |
MEG端点 |
MEP |
Maintenance association End Point |
维护端点 |
MFAS |
Multiframe FAS |
复帧同步标记 |
MFC |
Multi-Frequency Compelled |
多频互控 |
MFF |
MAC-Forced Forwarding |
MAC强制转发 |
MFR |
Multilink Frame Relay |
多链路帧中继 |
MGCP |
Media Gateway Control Protocol |
媒体网关控制协议 |
mGRE |
Multipoint Generic Routing Encapsulation |
多点通用路由封装 |
MIB |
管理信息库 |
MIC |
Message Integrity Check |
信息完整性校验 |
MIMO |
Multiple Input, Multiple Output |
多输入多输出 |
MIP |
Mobile IP |
移动IP |
MIP |
Maintenance association Intermediate Point |
维护中间点 |
MKA |
MACsec Key Agreement |
MACsec密钥协商 |
MKD |
Mesh Key Distributor |
Mesh密钥分发器 |
MKI |
Master Key Identifier |
主密钥标识符 |
MLD |
Multicast Listener Discovery Protocol |
组播侦听者发现协议 |
MLD Snooping |
Multicast Listener Discovery Snooping |
组播侦听者发现协议窥探 |
MLSP |
Mobile Link Switch Protocol |
移动链路切换协议 |
MME |
Management MIC IE |
管理MIC IE |
MNC |
Mobile Network Code |
移动网络编码 |
MoH |
Music on Hold |
音乐保持 |
MOS |
Mean Opinion Scores |
平均意见得分 |
MOTD |
Message of The Day |
每日提示 |
MP |
Merge Point |
汇聚点 |
MP |
Maintenance Point |
维护点 |
MP_REACH_NLRI |
Multiprotocol Reachable NLRI |
多协议可达NLRI |
MP_UNREACH_NLRI |
Multiprotocol Unreachable NLRI |
多协议不可达NLRI |
MP-BGP |
Multiprotocol Border Gateway Protocol |
多协议边界网关协议 |
MPCP |
Multipoint Control Protocol |
多点控制协议 |
MPDU |
MAC层协议数据单元 |
MPDU |
MAC协议数据单元 |
MPE |
Middle-Level PE |
中间层PE |
MPLS |
Multiprotocol Label Switching |
多协议标签交换 |
MPLS SR |
Segment Routing with MPLS |
MPLS段路由 |
MPLS TE |
Multiprotocol Label Switching Traffic Engineering |
多协议标记交换流量工程 |
MPLS VPN |
MPLS Virtual Private Network |
MPLS虚拟专用网络 |
MPLS-TP |
MPLS Transport Profile |
MPLS传送技术架构 |
MPP |
Mesh Portal Point |
Mesh Portal节点 |
MQC |
Model QoS Command |
QoS模块命令 |
MR |
Map Resolver |
映射解答者 |
MR |
Merge Request |
合并请求 |
MRIB |
Multicast Routing Information Base |
组播路由信息库 |
MRP |
Multiple Registration Protocol |
多属性注册协议 |
MRPDU |
MRP Protocol Data Unit |
MRP协议数据单元 |
MRRA |
Merge Request Resource Allocation |
合并请求资源分配 |
MRU |
Maximum-Receive-Unit |
最大接收单元 |
MS |
Manual Switch |
手工倒换 |
MS |
Map Server |
映射服务器 |
MSCHAP |
Microsoft Challenge Handshake Authentication Protocol |
微软CHAP协议 |
MSDP |
Multicast Source Discovery Protocol |
组播源发现协议 |
MSDU |
MAC服务数据单元 |
MSDU |
媒介访问服务数据单元 |
MSK |
Multicast Session Key |
组播会话密钥 |
MSOH |
Multiplex Section Overhead |
复用段开销 |
MSS |
Maximum Segment Size |
最大报文段长度 |
MSTI |
Multiple Spanning Tree Instance |
多生成树实例 |
MSTP |
Multiple Spanning Tree Protocol |
多生成树协议 |
MT |
Multicast Tunnel |
组播隧道 |
MTI |
Multicast Tunnel Interface |
组播隧道接口 |
MTR |
Multi-Topology Routing |
多拓扑路由 |
MTU |
Maximum Transmission Unit |
最大传输单元 |
MTU-s |
Multi-Tenant Unit switch |
汇聚交换机 |
MU |
Mobile Unit |
移动设备 |
MVRP |
Multiple VLAN Registration Protocol |
多VLAN注册协议 |
MWI |
Message Waiting Indication |
消息等待指示 |
MX |
Mail Exchanger |
邮件交换 |
N Return |
NA |
Neighbor Advertisement |
邻居通告消息 |
NAI |
Network Access Identifier |
网络接入标识符 |
NAPT |
Network Address Port Translation |
网络地址端口转换 |
NAPT-PT |
Network Address Port Translation-Protocol Translation |
附带协议转换的网络地址端口转换 |
NAS |
Network Access Server |
网络接入服务器 |
NAS-ID |
Network Access Server Identifier |
网络接入服务器标识 |
NAS-Port-ID |
Network Access Server Port Identifier |
网络接入服务器端口标识 |
NAS-VLAN-ID |
Network Access Server VLAN Identifier |
网络接入服务器VLAN标识 |
NAT |
网络地址转换 |
NAT-PT |
Network Address Translation-Protocol Translation |
附带协议转换的网络地址转换 |
NBAR |
Network Based Application Recognition |
基于内容特征的应用层协议识别 |
NBMA |
Non-Broadcast Multi-Access |
非广播多路访问 |
NCP |
Network Control Protocol |
网络控制协议 |
ND |
邻居发现 |
NDA |
NetStream Data Analyzer |
网络流数据分析者 |
NDE |
NetStream Data Exporter |
网络流数据输出者 |
NDP |
邻居发现协议 |
NDPP |
Network Device Protection Profile |
网络设备保护特性 |
NE |
Network Element |
网元 |
NEMO |
Network Mobility |
网络移动 |
NET |
Network Entity Title |
网络实体名称 |
NetBIOS |
Network Basic Input/Output System |
网络基本输入输出单元 |
NETCONF |
Network Configuration Protocol |
网络配置协议 |
NFAS |
non–FAS |
非帧同步标记 |
NFV |
Network Function Virtualisation |
网络功能虚拟化 |
NHLFE |
Next Hop Label Forwarding Entry |
下一跳标签转发项 |
NHRP |
Next Hop Resolution Protocol |
下一跳地址解析协议 |
NI |
National ISDN |
国家ISDN |
NIB |
Nexthop Information Base |
下一跳信息库 |
NII |
Network International Identifier |
网络互联标识符 |
NIST |
National Institute of Standards and Technology |
美国国家标准与技术研究院 |
NIT |
Not Initial Terminal |
非初始化终端 |
NLB |
Network Load Balancing |
网络负载均衡 |
NLBS |
Network Load Balancing Service |
网络负载均衡服务 |
NLPID |
Network Layer Protocol Identifier |
网络层协议标识符 |
NLRI |
Network Layer Reachability Information |
网络层可达性信息 |
NM |
Network Management |
网络管理 |
NMFAS |
Non-Multiframe FAS |
非复帧同步标记 |
NMS |
Network Management Server |
网络管理服务器 |
NMS |
Network Management Station |
网管工作站 |
NMS |
Network Management System |
网络管理系统 |
NNI |
Network-to-Network Interface |
网间接口 |
NO-PAT |
Not Port Address Translation |
非端口地址转换 |
NPDU |
Network Protocol Data Unit |
网络协议数据单元 |
NPE |
Network Provider Edge |
网络核心侧PE |
NPV |
N_Port Virtualization |
N端口虚拟化 |
NQA |
Network Quality Analyzer |
网络质量分析 |
NR |
No Request |
链路恢复 |
nrt-VBR |
non-real-time Variable Bit Rate |
非实时可变比特率 |
NS |
Name Server |
权威名称服务器 |
NS |
Neighbor Solicitation |
邻居请求消息 |
NSAP |
Network Service Access Point |
网络服务接入点 |
NSC |
NetStream Collector |
网络流数据收集者 |
NSF |
Non-Standard Facilities |
非标准能力 |
NSR |
Nonstop Routing |
不间断路由 |
NSS |
Number of Spatial Streams |
空间流数 |
NTDP |
Neighbor Topology Discover Protocol |
邻居拓扑发现协议 |
NTE |
Named Telephone Event |
命名的电话事件 |
NTP |
Network Time Protocol |
网络时间协议 |
NTT |
Nippon Telegraph and Telephone Corpration |
日本电报电话公司 |
NVC |
Network Virtualization Controller |
网络虚拟化控制器 |
NVE |
Network Virtualization Edge |
网络虚拟化边缘设备 |
NVGRE |
Network Virtualization using Generic Routing Encapsulation |
使用通用路由封装的网络虚拟化 |
O Return |
O Flag |
Other Stateful Configuration Flag |
其他配置标志位 |
OAA |
Open Application Architecture |
开放应用架构 |
OAMPDU |
OAM Protocol Data Unit |
OAM协议数据单元 |
OAP |
Open Application Platform |
开放应用平台 |
OC |
Ordinary Clock |
普通时钟 |
OC |
Optical Carrier |
光载波 |
ODF |
Optical Distribution Frame |
光配线架 |
ODN |
Optical Distribution Network |
光分配网络 |
OEM |
Original Equipment Manufacturer |
原始设备制造商 |
OFDM |
Orthogonal Frequency Division Multiplexing |
正交频分复用 |
OI |
Organization Identifier |
机构标识 |
OID |
Object Identifier |
对象标识符 |
OLT |
Optical Line Terminal |
光线路终端 |
ONU |
Optical Network Unit |
光网络单元 |
OOB |
Out-of-Band |
带外 |
ORF |
Outbound Route Filtering |
输出路由过滤 |
OSI |
Open System Interconnection |
开放系统互联 |
OSPF |
Open Shortest Path First |
开放最短路径优先 |
OSU |
Online Sign Up |
在线注册 |
OUI |
Organizationally Unique Identifier |
全球统一标识符 |
OVSDB |
Open vSwitch Database |
开源虚拟交换机数据库 |
P Return |
P2MP |
Point-to-MultiPoint |
点到多点 |
P2P |
PW to PW |
PW到PW |
P2P |
Peer-to-Peer |
对等 |
P2P |
Point-to-Point |
点到点 |
P2PTC |
Peer-to-Peer Transparent Clock |
对等透明时钟 |
PA |
Provider Allocated |
分发提供者 |
PADT |
PPPoE Active Discovery Terminate |
PPPoE活动发现终止 |
PAGP |
Port Aggregation Protocol |
端口聚合协议 |
PAM |
Pulse Amplitude Modulation |
脉冲调制 |
PAM |
Port to Application Map |
应用协议端口映射 |
PAP |
Password Authentication Protocol |
密码认证协议 |
Passive-Stateful PCC |
Passive-Stateful Path Computation Client |
被动有状态PCC |
Passive-Stateful PCE |
Passive-Stateful Path Computation Element |
被动有状态PCE |
PAT |
端口地址转换 |
PBAR |
Port Based Application Recognition |
基于端口的应用层协议识别 |
PBB |
Provider Backbone Bridge |
运营商骨干网桥 |
PBBN |
Provider Backbone Bridge Network |
运营商骨干桥接网 |
PBN |
Provider Bridge Network |
运营商桥接网 |
PBR |
Policy-based Routing |
基于策略的路由 |
PBX |
Private Branch Exchange |
程控交换机 |
PCB |
Protocol Control Block |
协议控制块 |
PCC |
路径计算客户端 |
PCE |
路径计算单元 |
PCEP |
Path Computation Element Communication Protocol |
路径计算单元通信协议 |
PCM |
脉冲编码调制 |
PCR |
Peak Cell Rate |
峰值信元速率 |
PD |
Powered Device |
受电设备 |
PD |
Prefix Delegation |
前缀授权 |
PDH |
Plesiochronous Digital Hierarchy |
准同步数字体系 |
PDP |
Policy Decision Point |
策略决策者 |
PDU |
协议数据单元 |
PE |
Provider Edge |
服务提供商网络边缘 |
PE-agg |
PE Aggregation |
聚合PE |
PEAP |
Protected Extensible Authentication Protocol |
受保护的扩展认证协议 |
PEAP-GTC |
Protected Extensible Authentication Protocol-Microsoft Generic Token Card |
受保护的扩展认证协议-通用令牌卡 |
PEAP-MSCHAPv2 |
Protected Extensible Authentication Protocol-Microsoft Challenge Handshake Authentication Protocol v2 |
受保护的扩展认证协议-Microsoft质询握手身份验证协议版本2 |
PEM |
Privacy Enhanced Mail |
增强保密邮件 |
PEM |
Power Entry Module |
电源输入模块 |
PEP |
Policy Enforcement Point |
策略执行者 |
PFC |
Power Free Connector |
无源连接设备 |
PFC |
Priority-based Flow Control |
基于优先级的流量控制 |
PFC |
Protocol-Field-Compression |
协议字段压缩 |
PFS |
Perfect Forward Secrecy |
完善的前向安全性 |
PHB |
Per-hop Behavior |
单中继段行为 |
PHP |
Penultimate Hop Popping |
倒数第二跳弹出 |
PI |
Progress Indicator |
进展指示语 |
PI |
Power Interface |
电源接口 |
PI |
Provider Independent |
独立提供者 |
PIC |
Prefix Independent Convergence |
前缀无关收敛 |
PIM |
协议无关组播 |
PIM Snooping |
协议无关组播窥探 |
PIM-DM |
Protocol Independent Multicast-Dense Mode |
协议无关组播—密集模式 |
PIM-SM |
Protocol Independent Multicast-Sparse Mode |
协议无关组播—稀疏模式 |
PIM-SSM |
Protocol Independent Multicast Source-Specific Multicast |
协议无关组播-指定源组播 |
PIN |
Personal Identification Number |
个人识别号码 |
PIR |
Peak Information Rate |
峰值信息速率 |
PKCS |
Public Key Cryptography Standards |
公共密钥加密标准 |
PKI |
Public Key Infrastructure |
公钥基础设施 |
PLCP |
Physical Layer Convergence Procedure |
物理层汇聚协议 |
PLMN |
Public Land Mobile Network |
公共地带移动网络 |
PLR |
Point of Local Repair |
本地修复节点 |
PMK |
Pairwise Master Key |
成对主密钥 |
PMTU |
Path MTU |
路径MTU |
PoE |
Power over Ethernet |
以太网供电 |
POH |
Path Overhead |
通道开销字节 |
POP3 |
Post Office Protocol - Version 3 |
邮局协议的第3个版本 |
POS |
Passive Optical Splitter |
无源光纤分支器 |
POS |
Point of Sale |
销售点 |
PPP |
Point-to-Point Protocol |
点对点协议 |
PPPoA |
PPP over ATM |
在ATM上承载PPP协议 |
PPPoE |
Point-to-Point Protocol over Ethernet |
在以太网上承载PPP协议 |
PPPoEoA |
PPPoE over ATM |
在ATM上承载PPPoE协议 |
PPTP |
Point-to-Point Tunneling Protocol |
点到点隧道协议 |
PQ |
Priority Queuing |
优先队列 |
PRBS |
Pseudo Random Bit Sequence |
不带CRC-32校验码的伪随机序列 |
PRC |
Primary Reference Clock |
基准参考时钟 |
PRI |
Primary Rate Interface |
基群速率接口 |
PRL |
Preferred Roaming List |
优先漫游列表 |
PS |
保护倒换 |
PSB |
Path State Block |
路径状态块 |
PSC |
Protection State Coordination |
保护状态协调 |
PSE |
Power Sourcing Equipment |
供电设备 |
PSK |
Pre-Shared Key |
预共享密钥 |
PSN |
Packet Switched Network |
分组交换网 |
PSNP |
Partial Sequence Number PDU |
部分时序报文 |
PSST |
Principal Switch Selection Timer |
主交换机选举定时器 |
PSTN |
Public Switched Telephone Network |
公共电话交换网 |
PTK |
Pairwise Transient Key |
成对临时密钥 |
PTP |
Precision Time Protocol |
精确时间协议 |
PTR |
Pointer Record |
指针记录 |
PTY |
Pseudo-Terminals |
伪终端 |
PUK |
PIN Unlocking Key |
PIN码解锁码 |
PVC |
Permanent Virtual Circuit |
永久虚电路 |
PVC PQ |
PVC Priority Queuing |
虚电路优先级队列 |
PVID |
Port VLAN ID |
端口VLAN ID |
PVP |
Permanent Virtual Path |
永久虚路径 |
PVST |
Per-VLAN Spanning Tree |
每VLAN生成树 |
PW |
Pseudowire |
伪线 |
PW-ACH |
PW Associated Channel Header |
PW随路通道首部 |
PWCT |
Pairwise Conditional Test |
密钥对有效性测试 |
PWE3 |
Pseudo Wire Emulation Edge-to-Edge |
边缘到边缘的伪线仿真 |
PXE |
Preboot eXecution Environment |
预启动执行环境 |
Q Return |
QCN |
Quantized Congestion Notification |
量化拥塞通知 |
QL |
Quality Level |
质量等级 |
QoS |
服务质量 |
QPPB |
QoS Policy Propagation Through the Border Gateway Protocol |
通过BGP传播QoS策略 |
R Return |
RA |
Router Advertisement |
路由器通告 |
RA |
Router Alert |
路由器告警 |
RA |
Registration Authority |
证书注册机构 |
RADIUS |
Remote Authentication Dial-In User Service |
远程认证拨号用户服务 |
RAI |
Remote Alarm Indication |
远端告警指示 |
RALM |
RADIUS Authenticated Login Using MAC-address |
基于MAC地址的RADIUS认证 |
R-APS |
Ring Automatic Protection Switching |
环网自动保护倒换 |
RAS |
Registration, Admission, and Status |
注册、接入和状态 |
RB |
Routing Bridge |
路由桥 |
RBAC |
Role Based Access Control |
基于角色的访问控制 |
RCA |
Release Change Authorization |
释放修改授权 |
RCF |
Reconfigure Fabric |
重配置Fabric |
RCPI |
Received Channel Power Indicator |
接收信道功率参数 |
RD |
Routing Domain |
路由域 |
RD |
Route Distinguisher |
路由标识符 |
RDI |
Remote Defect Indication |
远程故障指示 |
RDI |
远端失效指示 |
RDM |
Russian Dolls Model |
俄罗斯套娃模型 |
RDP |
Read Diagnostic Parameters |
诊断参数读取请求 |
RED |
Random Early Detection |
随机早期检测 |
REG |
Registration Center |
联盟注册中心 |
RFID |
Radio Frequency Identification |
射频识别 |
RIB |
路由信息库 |
RIP |
Routing Information Protocol |
路由信息协议 |
RIP-2 |
Routing Information Protocol version 2 |
路由信息协议版本2 |
RIPng |
RIP next generation |
下一代RIP协议 |
RLOC |
Routing Locator |
路由标识符 |
RLSN |
Remote Link Status Notification |
远程链路状态通告 |
RMON |
Remote Network Monitoring |
远程网络监视 |
ROA |
Recognized operating Agency |
公认营运机构 |
Roam OI |
Roam Organization Identifier |
漫游联盟标识 |
RP |
Rendezvous Point |
汇集点 |
RP |
Reaction Point |
响应点 |
RP |
Reflective Relay |
反射式转发 |
RPA |
Register Port Attributes |
注册端口属性 |
RPA |
Rendezvous Point Address |
汇集点地址 |
RPC |
Remote Procedure Call |
远程调用 |
RPF |
Reverse Path Forwarding |
逆向路径转发 |
RPI |
Receive Power Indication |
接收功率指示 |
RPL |
Ring Protection Link |
环保护链路 |
RPL |
Rendezvous Point Link |
汇集点链路 |
RPR |
Resilient Packet Ring |
弹性分组环 |
RPRT |
Register Port |
注册端口 |
RPS |
Redundant Power System |
冗余电源系统 |
RP-Set |
Rendezvous Point Set |
RP集 |
RPT |
Rendezvous Point Tree |
共享树 |
RR |
Reflective Relay |
反射式转发 |
RR |
Router Renumber |
路由器重编号 |
RR |
Route Reflector |
路由反射器 |
RRI |
Reverse Route Injection |
反向路由注入 |
RRM |
Radio Resource Management |
射频资源管理 |
RRPP |
Rapid Ring Protection Protocol |
快速环网保护协议 |
RS |
Router Solicitation |
路由器请求 |
RSB |
Reservation State Block |
预留状态块 |
RSCN |
Registered State Change Notification |
注册状态变化通知 |
RS-DCC |
Resource-Shared DCC |
共享DCC |
RSH |
Remote Shell |
远程外壳 |
RSN |
Robust Security Network |
健壮安全网络 |
RSNA |
Robust Security Network Association |
健壮安全网络连接 |
RSNI |
Received Signal to Noise Indicator |
接收信噪比 |
RSOH |
Regenerator Section Overhead |
再生段开销 |
RSSI |
Received Signal Strength Indication |
接收信号强度指示 |
RSSI |
Received Signal Strength Indicator |
接收信号强度指示 |
RSTP |
Rapid Spanning Tree Protocol |
快速生成树协议 |
RSVP |
Resource Reservation Protocol |
资源预留协议 |
RT |
Route Target |
路由目标 |
RTC |
Remote Terminal Connection |
远程终端连接 |
RTCP |
Real-Time Transport Control Protocol |
实时传输控制协议 |
RTM |
Real-Time Event Manager |
实时事件管理 |
RTP |
Real-Time Transport Protocol |
实时传输协议 |
RTPQ |
Real-Time Transport Protocol Priority Queuing |
实时传输协议优先队列 |
RTS |
Request to Send |
发送请求 |
RTSP |
Real Time Streaming Protocol |
实时流协议 |
RTT |
Round-Trip Time |
往返时间 |
rt-VBR |
Real-time Variable Bit Rate |
实时可变比特率 |
RU |
Rack Unit |
机柜单位 |
S Return |
S/MIME |
Secure/Multipurpose Internet Mail Extensions |
安全/多用途Internet邮件扩充协议 |
SA |
Security Association |
安全联盟 |
SA |
Source Active |
信源有效 |
SA Query |
Security Association Query |
安全关联询问 |
SABM |
Set Asynchronous Balanced Mode |
置异步平衡模式 |
SACK |
Selective Acknowledgment |
选择性确认 |
SAE |
Simultaneous authentication of equals |
对等同时认证 |
SAFI |
Subsequent Address Family Identifier |
子地址族标识符 |
SAII |
Source Attachment Individual Identifier |
源转发实例本地标识符 |
SAM |
Security Accounting Management |
安全审计管理 |
SAN |
Storage Area Networks |
存储区域网络 |
SAP |
Service Advertising Protocol |
服务公告协议 |
SAToP |
Structure-Agnostic TDM over Packet |
分组网络上传输非结构化的TDM数据 |
SAVI |
Source Address Validation Improvement |
源地址有效性验证 |
SB |
Service Bridge |
服务桥 |
SBM |
Subnetwork Bandwidth Management |
子网带宽管理 |
SCCP |
Skinny Client Control Protocol |
瘦小客户端控制协议 |
SCEP |
Simple Certificate Enrollment Protocol |
简单证书注册协议 |
SCFF |
Single Choke Fairness Frame |
公平算法帧 |
SCR |
State Change Registration |
状态变化注册 |
SCR |
Sustainable Cell Rate |
可持续信元速率 |
SD |
Signal Degrade |
信号衰减 |
SDH |
Synchronous Digital Hierarchy |
同步数字系列 |
SDLC |
Synchronous Data Link Control |
同步数据链路控制 |
SDN |
Software Defined Network |
软件定义网络 |
SDP |
Session Description Protocol |
会话描述协议 |
SDSL |
Symmetric Digital Subscriber Line |
对称数字用户线路 |
SDU |
Service Data Unit |
协议数据单元 |
SE |
Shared-Explicit |
共享显式 |
SEC |
SDH Equipment Clock |
设备时钟 |
SF |
Signal Fail |
信号失败 |
SF |
Super Frame |
超帧 |
SFC |
Stage Fabric Configuration Update |
进行Fabric配置更新 |
sFlow |
Sampled Flow |
采样流 |
SFM |
Source-Filtered Multicast |
信源过滤组播 |
SFP |
Small Form-factor Pluggable |
小型封装可热插拔模块 |
SFTP |
Secure FTP |
安全的FTP |
Short GI |
Short Guard Interval |
短保护间隔 |
SID |
段标识 |
SIP |
Session Initiation Protocol |
会话初始协议 |
SIPS |
SIP Secure |
安全SIP |
SLA |
Service Level Agreement |
服务等级协定 |
SLAAC |
Stateless Address Autoconfiguration |
无状态地址自动配置 |
SLC |
Service Logic Control |
呼叫控制模块 |
SLIP |
Serial Line Internet Protocol |
串行线路因特网协议 |
SLM |
Single-ended Loss Measurement |
单向丢包检测 |
SMA |
State Machine based Anti-spoofing |
基于状态机的伪造源地址检查 |
SmartMC |
Smart Management Center |
智能管理中心 |
SMTP |
Simple Mail Transfer Protocol |
简单邮件传输协议 |
SN |
Serial Number |
序列号 |
SNA |
System Network Architecture |
系统网络结构体系 |
SNAP |
Subnet Access Protocol |
子网访问协议 |
SNAT |
Source Network Address Translation |
源网络地址转换 |
SNMP |
Simple Network Management Protocol |
简单网络管理协议 |
SNP |
时序报文 |
SNPA |
Subnetwork Point of Attachment |
子网连接点 |
SNR |
Signal-to-Noise Ratio |
信噪比 |
SNTP |
Simple NTP |
简单NTP |
SOA |
Start of Authority |
起始授权 |
SOAP |
Simple Object Access Protocol |
简单对象访问协议 |
SOH |
Section Overhead |
段开销 |
SONET |
Synchronous Optical Network |
同步光网络 |
SoO |
Site of Origin |
源站点 |
SP |
Scheduler Policy |
调度策略 |
SP |
Service Provider |
服务提供商 |
SP |
Strict Priority |
严格优先级 |
SPB |
Shortest Path Bridging |
最短路径桥 |
SPBM |
Shortest Path Bridging MAC Mode |
最短路径桥MAC模式 |
SPBN |
Shortest Path Bridging Network |
最短路径桥接网 |
SPCS |
Stored Program Control Switching System |
程控交换机 |
SPE |
Superstratum PE or Service Provider-end PE |
上层PE或运营商侧PE |
SPF |
最短路径优先 |
SPI |
Security Parameter Index |
安全参数索引 |
SPID |
Service Profile Identification |
业务轮廓标识 |
SPSource ID |
Shortest Path Source Identifier |
最短路径源标记 |
SPT |
Shortest Path Tree |
最短路径树 |
SQL |
Structured Query Language |
结构化查询语言 |
SR |
Segment Routing |
段路由 |
Srefresh |
Summary Refresh |
摘要刷新 |
SRLSP |
Segment Routing Label Switched Paths |
基于段路由的LSP |
SRST |
Survivable Remote Site Telephony |
本地存活 |
sr-TCM |
single rate TCM |
单速率三色标记 |
SRTP |
Secure Real-Time Transport Protocol |
安全RTP协议 |
SSA |
SIP Stack Adapt |
SIP适配模块 |
SSH |
Secure Shell |
安全外壳 |
SSID |
Service Set Identifier |
服务集标识符 |
SSL |
Secure Sockets Layer |
安全套接字层 |
SSM |
指定信源组播 |
SSM |
Synchronization Status Message |
同步状态信息 |
SSP |
Switch-to-Switch Protocol |
交换机到交换机协议 |
SSU-A |
primary level SSU |
转接局时钟 |
SSU-B |
second level SSU |
本地局时钟 |
ST |
Shared Tree |
共享树 |
Stateful PCE |
有状态PCE |
Stateless PCC |
Stateless Path Computation Client |
无状态PCC |
Stateless PCE |
Stateless Path Computation Element |
无状态PCE |
STBC |
Space-Time Block Coding |
空时块编码 |
STP |
生成树协议 |
STR |
Switch Trace Route |
FC交换机路由探测 |
SVC |
Switched Virtual Circuit |
交换虚电路 |
SVC |
Static Virtual Circuit |
静态虚拟电路 |
SVP |
SpectraLink Voice Priority |
SpectraLink语音优先级 |
T Return |
TA |
Terminal Adapter |
终端适配器 |
TACACS |
终端访问控制器控制系统 |
TACL |
Temporary Access Control List |
临时访问控制列表 |
TAI |
International Atomic Time |
国际原子时间 |
TAII |
Target Attachment Individual Identifier |
目的转发实例本地标识符 |
TC |
Transparent Clock |
透明时钟 |
TC |
Topology Checksum |
拓扑校验和 |
TC |
Traffic Class |
流量等级 |
TC |
Topology Change |
拓扑改变 |
TCA |
Topology Change Acknowledge |
拓扑改变确认 |
TCAM |
Ternary Content Addressable Memory |
三态内容寻址存储器 |
TCI |
Tag Control Information |
标签控制信息 |
Tcl |
Tool Command Language |
工具命令语言 |
TCN BPDU |
Topology Change Notification BPDU |
拓扑变化通知BPDU |
TCP |
Transmission Control Protocol |
传输控制协议 |
TDM |
Time Division Multiplexing |
时分复用 |
TDMA |
Time Division Multiple Access |
时分多址接入 |
TE |
流量工程 |
TEDB |
TE DataBase |
流量工程数据库 |
TEI |
Terminal Endpoint Identifier |
终端设备标识符 |
TEK |
Tranfic Encrytion Key |
加密流量的密钥 |
TFO |
Transport Flow Optimization |
传输层流优化 |
TFTP |
Trivial File Transfer Protocol |
简单文件传输协议 |
TIM |
Traffic Indication Map |
传输指示映射 |
TK |
Temporal Key |
临时密钥 |
TKIP |
Temporal Key Integrity Protocol |
临时密钥完整性协议 |
TLS |
传输层安全 |
TLS |
Transparent LAN Service |
透明局域网服务 |
TLV |
Type/Length/Value |
类型长度值 |
ToS |
Type of Service |
服务类型 |
TP |
Topology Protection |
拓扑保护 |
TP |
Traffic Policing |
流量监管 |
TPC |
Transmit Power Control |
传输功率控制 |
TPDU |
Transport Protocol Data Unit |
传输协议数据单元 |
TPID |
Tag Protocol Identifier |
标签协议标识符 |
TPMR |
Two-Port MAC Relay |
双端口MAC中继 |
TQ |
Time Quantum |
时间量子 |
TRILL |
TRansparent Interconnection of Lots of Links |
多链路透明互联 |
TRIP |
Triggered RIP |
触发路由信息协议 |
tr-TCM |
two-rate TCM |
双速率三色标记 |
TS |
Traffic Shaping |
流量整形 |
TSA |
Tunnel Switching Aggregator |
隧道交换聚合 |
TST |
Test |
比特错误测试 |
TTL |
Time to Live |
生存时间 |
TTLS |
Tunneled Transport Layer Security |
管道式传输层安全 |
TTLS-GTC |
Tunneled Transport Layer Security-Microsoft Generic Token Card |
管道式传输层安全-通用令牌卡 |
TTLS-MSCHAPv2 |
Tunneled Transport Layer Security-Microsoft Challenge Handshake Authentication Protocol v2 |
管道式传输层安全-Microsoft质询握手身份验证协议版本2 |
TTY |
True Type Terminal |
实体类型终端 |
TU |
Tributary Unit |
支路单元 |
TUG |
Tributary Unit Group |
支路单元组 |
TxBF |
Tx Beamforming |
固定发送波速成形 |
TXOP Limit |
Transmission Opportunity Limit |
传输机会限制 |
U Return |
UA |
User Agent |
用户代理 |
UA |
Unnumbered Acknowledge |
无编号确认 |
UAC |
User Agent Client |
用户代理客户端 |
U-APSD |
Unscheduled Automatic Power-Save Delivery |
非调度自动节能发送 |
UAS |
User Agent Server |
用户代理服务器 |
UBR |
Unspecified Bit Rate |
不确定比特率 |
UDLD |
Uni-directional Link Direction |
单向链路检测 |
UDP |
User Data Protocol |
用户数据报文协议 |
UFC |
Update Fabric Configuration |
更新Fabric配置 |
UIM |
User Identity Module |
用户识别模块 |
UNI |
User Network Interface |
用户网络接口 |
UNI |
User-to-Network Interface |
用户网络接口 |
UPE |
User facing-Provider Edge |
靠近用户侧的PE |
UPE |
Underlayer PE or User-end PE |
下层PE或用户侧PE |
URI |
Uniform Resource Identifier |
统一资源标识符 |
URL |
Uniform Resource Locator |
统一资源定位符 |
uRPF |
Unicast Reverse Path Forwarding |
单播反向路径转发 |
USK |
Unicast Session Key |
单播会话密钥 |
USM |
User-Based Security Model |
基于用户的安全模型 |
UTC |
Coordinated Universal Time |
国际协调时间 |
UTM |
Unified Threat Management |
统一威胁管理 |
V Return |
VA |
Virtual Access |
虚拟访问 |
VACM |
View-based Access Control Model |
基于视图的访问控制模型 |
VAD |
Voice Activity Detection |
静音检测 |
VAM |
VPN Address Management |
VPN地址管理 |
VBR-NRT |
Variable Bit Rate-Non Real Time |
非实时可变速率 |
VBR-RT |
Variable Bit Rate-Real Time |
实时可变速率 |
VC |
Virtual Circuit |
虚电路 |
VC |
Virtual Container |
虚容器 |
VCC |
Virtual Circuit Connection |
虚电路连接 |
VCCV |
Virtual Circuit Connectivity Verification |
虚电路连通性验证 |
VCF |
Vertical Converged Framework |
纵向融合架构 |
VCI |
Virtual Channel Identifier |
虚通道标识符 |
VCN |
Virtual Circuit Number |
虚电路号 |
VCPM |
Voice Co-processing Module |
语音协处理模块 |
VD |
Virtual Device |
虚拟设备 |
VDP |
VSI Discovery and Configuration Protocol |
VSI发现和配置协议 |
VDSL |
Very high-speed Digital Subscriber Line |
甚高速数字用户线路 |
VE |
Virtual Ethernet |
虚拟以太网 |
VE-Bridge |
Virtual Ethernet Bridge |
二层虚拟以太网 |
VF Owner |
Virtual Forwarder Owner |
虚拟转发器拥有者 |
VFW |
Virtual Firewall |
虚拟防火墙 |
VLAN |
Virtual Local Area Network |
虚拟局域网 |
VM |
Virtual Machine |
虚拟机 |
VMM |
Virtual Machine Management |
虚拟机管理系统 |
VN |
Version Number |
版本号 |
VNC |
Virtual Network Computing |
虚拟网络计算机 |
VNI |
VXLAN Network Identifier |
VXLAN网络标识符 |
VoD |
Video on Demand |
视频点播 |
VoIP |
Voice over IP |
在IP网络上传送语音 |
VP |
Virtual Path |
虚路径 |
VPC |
Virtual Private Cloud |
私有云 |
VPC |
Virtual Path Connection |
虚路径连接 |
VPDN |
Virtual Private Dial-up Network |
虚拟专用拨号网络 |
VPI |
Virtual Path Identifier |
虚路径标识符 |
VPLS |
Virtual Private LAN Service |
虚拟专用局域网服务 |
VPM |
Voice Processing Module |
语音处理模块 |
VPN |
虚拟专用网络 |
VR |
Virtual Router |
虚拟路由器 |
VRF |
Virtual Routing and Forwarding |
虚拟路由和转发 |
VRRP |
Virtual Router Redundancy Protocol |
虚拟路由器冗余协议 |
VSAN |
Virtual Storage Area Network |
虚拟存储区域网络 |
VSD |
Virtual Security Domain |
虚拟安全域 |
VSI |
Virtual Switch Instance |
虚拟交换实例 |
VSI |
Virtual Station Interface |
虚拟服务器接口 |
VSID |
Virtual Subnet Identifier |
虚拟子网标识符 |
VSIP |
Virtual Service IP |
虚服务IP |
VSRP |
Virtual Service Redundancy Protocol |
虚拟业务冗余协议 |
vSwitch |
Virtual Switch |
虚拟交换机 |
VT |
Virtual Template |
虚拟模板 |
VTEP |
VXLAN Tunnel End Point |
VXLAN隧道端点 |
VTP |
VLAN Trunking Protocol |
VLAN中继协议 |
VTY |
Virtual Type Terminal |
虚拟类型终端 |
VXLAN |
Virtual eXtensible LAN |
可扩展虚拟局域网络 |
VXLAN-DCI |
VXLAN Data Center Interconnection |
VXLAN数据中心互联 |
W Return |
WAAS |
Wide Area Application Services |
广域网应用服务 |
WAI |
WLAN Authentication Infrastructure |
无线局域网鉴别基础结构 |
WAN |
Wide Area Network |
广域网 |
WAP |
Wireless Application Protocol |
无线应用协议 |
WAPI |
WLAN Authentication and Privacy Infrastructure |
无线局域网鉴别与保密基础结构 |
WASS |
广域网应用服务 |
WDS |
Wireless Distribution System |
无线分布式系统 |
WEP |
Wired Equivalent Privacy |
有线等效加密 |
WFQ |
加权公平队列 |
WHA |
WLAN High Availability |
无线局域网高可靠性 |
WIDS |
Wireless Intrusion Detection System |
无线入侵检测系统 |
WiNet |
Wisdom Network |
智能网络 |
WINS |
Windows Internet Naming Service |
Windows Internet名称服务 |
WIPS |
Wireless Intrusion Prevention System |
无线入侵防御系统 |
WLAN |
Wireless Local Area Network |
无线局域网 |
WLAN RRM |
射频资源管理 |
WMM |
Wi-Fi Multimedia |
Wi-Fi多媒体 |
WPA |
Wi-Fi Protected Access |
Wi-Fi保护访问 |
WPAD |
Web Proxy Auto-Discovery |
Web代理服务器自动发现 |
WPI |
WLAN Privacy Infrastructure |
无线局域网保密基础结构 |
WRED |
Weighted Random Early Detection |
加权随机早期检测 |
WRR |
Weighted Round Robin |
加权轮询 |
WSA |
Wireless Spectrum Analysis |
无线频谱分析 |
WT |
Wireless Terminator |
无线终结者 |
WTU |
Wireless Terminator Unit |
无线终结者单元 |
WWN |
World Wide Name |
全球名字 |
X Return |
XFP |
10-Gigabit Small Form-factor Pluggable |
万兆以太网接口小封装可热插拔 |
XML |
Extensible Markup Language |
扩展标记语言 |
XSD |
XML Schema Document |
XML架构文档 |
XSD |
XML Schema Definition |
XML架构定义 |
Z Return |
ZBR |
Zone Border Router |
区域边界路由器 |
