H3C SPM系列智能PoE管理器 Probe命令参考(R5208P03)-6W100
01-正文
本章节下载 01-正文  (509.38 KB)
01-正文
  录
1 Probe命令
1.1 D
1.1.1 debug
1.1.2 debug from-device clear
1.1.3 debug from-device display
1.1.4 debug level
1.1.5 debug module
1.1.6 debugging lipc
1.1.7 debugging lipc mtcp
1.1.8 debugging lipc stcp
1.1.9 debugging system internal arp event
1.1.10 debugging system internal arp features
1.1.11 debugging system internal arp notify
1.1.12 debugging system internal arp sync
1.1.13 debugging system internal ipv6 fib prefix
1.1.14 debugging system internal nd
1.1.15 debugging system internal nd sub-features
1.1.16 debugging system internal stg
1.1.17 debugging system internal stp
1.1.18 debugging system internal vlan
1.1.19 diag app display filename
1.1.20 diag boot-info display
1.1.21 diag dev-table display
1.1.22 diag drvflag display
1.1.23 diag environment display
1.1.24 diag fan display speed
1.1.25 diag hasa display
1.1.26 diag if display
1.1.27 diag led display
1.1.28 diag lipc display
1.1.29 diag log display
1.1.30 diag mbuf-relay display
1.1.31 diag mbus display
1.1.32 diag mem-assign display
1.1.33 diag module display content
1.1.34 diag module display content
1.1.35 diag pcie display
1.1.36 diag poe
1.1.37 diag port display  statistics
1.1.38 diag port-list display
1.1.39 diag port-table display
1.1.40 diag stm display
1.1.41 diag stm statistic display
1.1.42 diag temperature display status
1.1.43 diag tmpr-alarm display threshold
1.1.44 display debug-info
1.1.45 display hardware internal transceiver register interface
1.1.46 display system internal arp
1.1.47 display system internal arp ifcb
1.1.48 display system internal arp ip-address
1.1.49 display system internal arp machash
1.1.50 display system internal arp probe
1.1.51 display system internal arp rbhash
1.1.52 display system internal arp reload
1.1.53 display system internal arp rule
1.1.54 display system internal arp source-suppression cache
1.1.55 display system internal arp statistics
1.1.56 display system internal arp vlan
1.1.57 display system internal customlog host
1.1.58 display system internal customlog mbuf dump
1.1.59 display system internal customlog mbuf usage
1.1.60 display system internal customlog test
1.1.61 display system internal dbm
1.1.62 display system internal ethernet character
1.1.63 display system internal ethernet controlblock
1.1.64 display system internal ifmgr down
1.1.65 display system internal ifmgr entry
1.1.66 display system internal ifmgr event
1.1.67 display system internal ifmgr hotplug
1.1.68 display system internal ifmgr index
1.1.69 display system internal ifmgr list
1.1.70 display system internal ifmgr name
1.1.71 display system internal ifmgr type
1.1.72 display system internal ip address
1.1.73 display system internal ipv6 address
1.1.74 display system internal ipv6 fib prefix
1.1.75 display system internal ipv6 fib prefix entry-status
1.1.76 display system internal ipv6 fib prefix ipv6
1.1.77 display system internal ipv6 pathmtu
1.1.78 display system internal ipv6 rawip
1.1.79 display system internal ipv6 rib event attribute
1.1.80 display system internal ipv6 rib event policy
1.1.81 display system internal ipv6 rib event prefix
1.1.82 display system internal ipv6 rib event protocol
1.1.83 display system internal ipv6 rib event statistics
1.1.84 display system internal ipv6 rib instance
1.1.85 display system internal ipv6 rib log
1.1.86 display system internal ipv6 rib memory
1.1.87 display system internal ipv6 rib nib log
1.1.88 display system internal ipv6 rib prefix
1.1.89 display system internal ipv6 rib summary
1.1.90 display system internal ipv6 route-direct interface
1.1.91 display system internal ipv6 route-direct log
1.1.92 display system internal ipv6 route-static nib log
1.1.93 display system internal ipv6 tcp
1.1.94 display system internal ipv6 tcp port-info
1.1.95 display system internal ipv6 udp
1.1.96 display system internal ipv6 udp port-info
1.1.97 display system internal kernel memory dump
1.1.98 display system internal kernel memory pool
1.1.99 display system internal link-aggregation global
1.1.100 display system internal link-aggregation interface
1.1.101 display system internal lipc dump
1.1.102 display system internal lipc dump configuration
1.1.103 display system internal lipc history
1.1.104 display system internal lipc lcmp statistics
1.1.105 display system internal lipc lgmp group
1.1.106 display system internal lipc lgmp group-list
1.1.107 display system internal lipc lgmp physical-group
1.1.108 display system internal lipc lgmp physical-group-list
1.1.109 display system internal lipc lgmp statistics
1.1.110 display system internal lipc lip statistics
1.1.111 display system internal lipc loop statistics
1.1.112 display system internal lipc mtcp group
1.1.113 display system internal lipc mtcp group all
1.1.114 display system internal lipc mtcp performance
1.1.115 display system internal lipc mtcp statistics
1.1.116 display system internal lipc pcb mbuf statistics
1.1.117 display system internal lipc pcb statistics
1.1.118 display system internal lipc physical
1.1.119 display system internal lipc publish global-cb
1.1.120 display system internal lipc publish statistics
1.1.121 display system internal lipc stcp event
1.1.122 display system internal lipc stcp global-server
1.1.123 display system internal lipc stcp links
1.1.124 display system internal lipc stcp performance
1.1.125 display system internal lipc stcp port
1.1.126 display system internal lipc stcp statistics
1.1.127 display system internal lipc stcp status
1.1.128 display system internal lipc stream
1.1.129 display system internal lipc sudp pcb-info
1.1.130 display system internal lipc sudp statistics
1.1.131 display system internal lipc sudp { global-port | local-port }
1.1.132 display system internal lipc topology history
1.1.133 display system internal lipc topology link
1.1.134 display system internal lipc topology node
1.1.135 display system internal lipc topology process-time
1.1.136 display system internal lipc topology statistics
1.1.137 display system internal lipc topology status
1.1.138 display system internal mac-address configuration
1.1.139 display system internal mac-address learned
1.1.140 display system internal mac-address protocol
1.1.141 display system internal mac-address statistics
1.1.142 display system internal mac-forwarding cache ip verbose
1.1.143 display system internal mac-forwarding cache ipv6 verbose
1.1.144 display system internal mac-forwarding controlblock
1.1.145 display system internal mbuf relay statistics
1.1.146 display system internal nd dad
1.1.147 display system internal nd entry
1.1.148 display system internal nd ifcb
1.1.149 display system internal nd machash
1.1.150 display system internal nd probe
1.1.151 display system internal nd rbhash
1.1.152 display system internal nd reload
1.1.153 display system internal nd rule
1.1.154 display system internal nd static
1.1.155 display system internal nd statistics
1.1.156 display system internal process state
1.1.157 display system internal rawip
1.1.158 display system internal rib event attribute
1.1.159 display system internal rib event policy
1.1.160 display system internal rib event protocol
1.1.161 display system internal rib event statistics
1.1.162 display system internal rib instance
1.1.163 display system internal rib log
1.1.164 display system internal rib memory
1.1.165 display system internal rib nib
1.1.166 display system internal rib nib log
1.1.167 display system internal rib prefix
1.1.168 display system internal rib summary
1.1.169 display system internal route-direct interface
1.1.170 display system internal route-direct log
1.1.171 display system internal route-static nib log
1.1.172 display system internal startup cache
1.1.173 display system internal stp bridge-info
1.1.174 display system internal stp port-info
1.1.175 display system internal tcp
1.1.176 display system internal tcp port-info
1.1.177 display system internal udp
1.1.178 display system internal udp port-info
1.1.179 display system internal vlan
1.2 F
1.2.1 follow
1.2.2 fpl-diag
1.3 L
1.3.1 lipc connection detect
1.3.2 lipc dump
1.3.3 lipc dump buffer
1.3.4 lipc dump enable
1.3.5 lipc dump offset
1.3.6 lipc performance
1.3.7 lipc ping
1.3.8 lipc timeout
1.3.9 list
1.4 M
1.4.1 memory boundary-check enable
1.4.2 memory boundary-check scan
1.4.3 monitor lipc
1.5 P
1.5.1 probe
1.6 R
1.6.1 reset system internal arp statistics
1.6.2 reset system internal ipv6 rib log
1.6.3 reset system internal ipv6 rib nib log
1.6.4 reset system internal ipv6 rib summary
1.6.5 reset system internal ipv6 route-direct log
1.6.6 reset system internal ipv6 route-static nib log
1.6.7 reset system internal lipc dump buffer
1.6.8 reset system internal mac-address statistics
1.6.9 reset system internal mbuf relay statistics
1.6.10 reset system internal nd statistics
1.6.11 reset system internal rib log
1.6.12 reset system internal rib nib log
1.6.13 reset system internal rib summary
1.6.14 reset system internal route-direct log
1.6.15 reset system internal route-static nib log
1.7 V
1.7.1 view
1 Probe命令
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
1.1  D
1.1.1  debug
debug命令用来打开debug开关,配置调试信息的输出设置。
debug {on | off | switch-save | out-to-ic | out-to-console }
Probe视图
on:表示debug打开开关。
off: 表示debug关闭开关。
switch-save: 表示保存debug开关。
out-to-ic: 表示调试信息在信息中心输出。
out-to-console: 表示调试信息在串口输出。
debug from-device clear命令用来清除debug异常调试信息。
Probe视图
debug from-device display命令用来显示设备异常信息开关。
debug from-device display { all | error }
Probe视图
all显示设备所有异常信息。
error显示设备异常错误信息。
1.1.4  debug level
debug level命令用来配置驱动debug调试信息级别开关。
debug level { all | debug | error | info | print-fileline | print-modulename } { on | off }
Probe视图
all:打开或关闭所有level调试信息开关。
debug:打开或关闭debug level调试信息开关。
error:打开或关闭 level error调试信息开关。
info:打开或关闭 level info调试信息开关。
print-fileline:打开或关闭输出文件行数调试信息开关。
print-modulename:打开或关闭输出模块名调试信息开关。
on:表示开启指定的debug信息开关。
off:表示关闭指定的debug信息开关。
1.1.5  debug module
debug module命令用来打开或关闭器件调试信息。
debug module { adp | all-module | btrm | cf | cfm | conf | cpld | cpu | dev | devm | dim | drv-mod1 | drv-mod2 | drv-mod3 | ec | eeprom | fan | fe | flash| fshe | fwd | ge | ht | i2c | ibc | init | intf | led | lic | lipc | lpu | lpum | mbuf-relay | mbus | mcore | mm | mon | np | nvram | oem | optic | other | pci | per | plat | port | relinfo | rtc | sae | stm | tcam | tmpr | u2f | uart | usb | xge } {on | off }
Probe视图
debugging lipc命令用来打开LIPC的debug开关。
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
undo debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo | stream } [ lip lip ]
Probe视图
detail:用来打开LIPC的报文详细内容的调试信息开关。
dump port:表示端口号,取值范围为0~65535。
lgmp:用来打开LIPC的LGMP模块的调试信息开关。
mbuf:用来打开LIPC的MBUF模块的调试信息开关。
mtcp:用来打开LIPC的MTCP模块调试信息开关。
pub:用来打开LIPC的PUB模块的调试信息开关。
stcp:用来打开LIPC的STCP模块的调试信息开关。
stream:用来打开LIPC的STREAM模块的调试信息开关。
topo:用来打开LIPC的TOPO模块的调试信息开关。
lip lip:表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
debugging lipc mtcp命令用来打开LIPC组播传输控制协议的调试信息开关。
undo debugging lipc mtcp命令用来关闭LIPC组播传输控制协议的调试信息开关。
debugging lipc mtcp [ group group-id ] [ lip lip ]
undo debugging lipc mtcp [ group group-id ] [ lip lip ]
LIPC组播传输控制协议调试信息开关处于关闭状态。
Probe视图
group group-id:要调试的组播端口号,取值范围为0~65535。不指定该参数时,表示所有组播组。
debugging lipc stcp命令用来打开LIPC单播的调试信息开关。
undo debugging lipc stcp命令用来关闭LIPC单播的调试信息开关。
debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
undo debugging lipc stcp [ port port1 [ port port2 ] ] [ lip lip ]
LIPC单播调试信息开关处于关闭状态。
Probe视图
port port1 [ port port2 ]:port1和port2分别为连接的本地和对端端口号,取值范围为0~65535,缺省值为0。
debugging system internal arp event命令用来打开ARP事件调试信息开关。
undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
ARP事件调试信息开关处于关闭状态。
Probe视图
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。
undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP子特性的调试信息开关处于关闭状态。
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp notify命令用来打开ARP的外部通知调试信息开关。
undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
ARP的外部通知调试信息开关处于关闭状态。
Probe视图
debugging system internal arp sync命令用来打开ARP表项的同步调试开关。
undo debugging system internal arp sync命令用来关闭ARP表项的同步调试开关。
ARP表项的同步调试信息开关处于关闭状态。
Probe视图
debugging system internal ipv6 fib prefix命令用来打开IPv6 FIB调试信息开关。
undo debugging system internal ipv6 fib prefix命令用来关闭IPv6 FIB调试信息开关。
debugging system internal ipv6 fib prefix { all | message | hardware }
undo debugging system internal ipv6 fib prefix { all | message | hardware }
IPv6 FIB调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开前缀消息调试开关,打印路由下发和板间同步的IPv6 FIB前缀消息。
hardware:打开下驱动信息调试开关,打印下发驱动信息以及驱动返回的消息。
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
Probe视图
notify表示邻居发现的通知调试开关。
sync 表示邻居发现的同步调试开关。
【描述】
debugging system internal nd命令用来打开邻居发现的调试信息开关。undo debugging system internal nd命令用来关闭邻居发现的外部通知调试信息开关。
缺省情况下,邻居发现的调试信息开关处于关闭状态。
debugging system internal nd sub-features { all | event | packet }
undo debugging system internal nd sub-features
Probe视图
all:表示ND子特性的所有调试信息开关。
event:表示ND子特性的事件调试信息开关。
packet:表示ND子特性的报文调试信息开关。
【描述】
debugging system internal nd sub-features命令用来打开ND子特性的调试开关。undo debugging system internal nd sub-features命令用来关闭ND子特性的调试开关。
缺省情况下,ND子特性的调试开关处于关闭状态。
debugging system internal stg命令用来开启STG调试信息开关。
undo debugging system internal stg命令用来关闭STG调试信息开关。
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
STG调试信息开关处于关闭状态。
Probe视图
all:表示STG所有调试信息开关。
bind:表示STG与VLAN绑定调试信息开关。
error:表示STG错误调试信息开关。
map:表示STG与STI映射事件调试信息开关。
state:表示STG状态设置调试信息开关。
tc:表示TC事件调试信息开关。
debugging system internal stp命令用来开启生成树进程间通信调试开关。
undo debugging system internal stp命令用来关闭生成树进程间通信调试开关。
debugging system internal stp ipc
undo debugging system internal stp ipc
生成树进程间通信调试开关处于关闭状态。
Probe视图
ipc:表示生成树进程间通信调试信息开关。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
Probe视图
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
diag app display filename命令用来查看应用程序打包的文件信息。
diag app display filename string
Probe视图
string:带有路径的文件名,为1~128个字符的字符串,不区分大小写。
diag boot-info display命令用来显示设备启动信息。
Probe视图
diag dev-table display命令用来显示设备管理信息。
Probe视图
diag drvflag display命令用来显示各个存储模块的存储区信息。
diag drvflag { apmode | art | bf | bm | capwap | debug | dm | fanmi | lic | log | mac | mi | mon | netcfg | powmi | rel | stm | target | tr } display
Probe视图
【参数】】
apmode:显示AP工作模式信息。
art:显示射频信息。
bf:显示驱动Bootware Flag段标志区信息。
bm:显示主、备启动文件和主、备配置文件信息。
capwap:显示capwap隧道统计信息。
debug:显示目前系统中存储debug信息数量和存储debug起始位置信息。
dm:显示驱动dm段标志区信息,包括flash擦除次数,启动次数,重启类型,调试开关标志。
fanmi:显示风扇制造标志区信息,具体支持情况和设备型号有关。
lic:显示驱动license标志区信息,具体支持情况和设备型号有关。
log:显示驱动存储日志起始位置,日志存储的最大数量等信息。
mac:显示驱动MAC标志区信息。
mi:显示驱动电子标签字段信息。
mon:显示驱动监控信息类型,日志存放起始位置等信息。
netcfg:显示bootware的网络参数。
powmi:显示电源制造信息,具体支持情况和设备型号有关。
rel:显示可靠性,进风口,出风口, cpu,温感等信息。
stm:显示驱动stm标志区信息。
target:显示射频驱动监控信息类型,日志存放起始位置等信息。
tr:显示存储器件测试结果。
diag environment display命令用来显示设备当前各个温感数据。
Probe视图
diag fan display speed命令用来显示风扇速度。
Probe视图
diag hasa display命令用来显示hasa标志位信息。
diag hasa display
Probe视图
diag if display命令用来显示系统接口规格。
diag if display
Probe视图
diag led display命令用于显示设备LED指示灯灯状态。
diag led display
Probe视图
diag lipc display命令用来显示产品IPC信息。FEL层IPC报文用户注册的EINTF信息、多播组信息、IPC收发报文信息。
diag lipc display
Probe视图
diag log display命令用来显示设备的日志信息。
diag log display { all | last }
Probe视图
all:显示所有的日志信息。
last:显示最新的日志信息。
diag mbuf-relay display命令用来显示产品mbuf-relay信息。mbuf-relay用户注册的EINTF信息,Mbuf-Relay报文收方向信息,Mbuf-Relay报文发送方向信息。
Probe视图
diag mbus display命令用来显示mbus的调试信息,显示用户注册的EINTF信息,mbus报文信息。
diag mbus display
Probe视图
diag mem-assign display命令用来显示存储器件的空间分配情况。
Probe视图
diag module display content命令用来显示各个器件模块指定地址存储信息。
diag module slot/subslot { btrm | cf | cpld | cpu | dimm | eeprom | fan | nandflash | norflash | | nvram | pci | power | rtc | tmpr | usb } chip-no display content offset-value len-value
Probe视图
slot/subslot:指定槽位号或者子槽位号。
chip-no:指定芯片编号。
offset-value:指定起始地址。
len-value:指定偏移长度值。
btrm:显示bootrom的信息。
cf:显示cf卡的信息。
cpld:显示cpld的信息。
cpu:显示cpu的信息。
dimm:显示内存的信息。
eeprom:显示eeprom的信息。
fan:显示风扇的信息。
nandflash:显示nandflash的信息。
norflash:显示norflash的信息。
nvram:显示nvram的信息。
pci:显示pci的信息。
power:显示电源的信息。
rtc:显示硬件时钟的信息。
tmpr:显示温感的信息。
usb:显示usb的信息。
diag module display content命令用来显示mac或phy模块各个端口信息。
diag module slot/subslot { mac | phy } { aux | console | ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | ten-gigabitethernet | wlan-radio } chip-no display content offset-value len-value
Probe视图
设备接口类型的支持情况请以设备实际情况为准。
mac:显示mac模块各个端口信息。
phy:显示phy模块各个端口信息。
auxaux接口,本参数的支持情况与设备型号有关。
consoleconsole接口,本参数的支持情况与设备型号有关。
ethernet:以太网接口,本参数的支持情况与设备型号有关。
gigabitethernet:GE接口,本参数的支持情况与设备型号有关。
i-gigabitethernet:内部GE接口,本参数的支持情况与设备型号有关。
inasync:内部异步接口,本参数的支持情况与设备型号有关。
inner-ethernet:内部以太网接口,本参数的支持情况与设备型号有关。
m-ethernet:百兆管理以太网接口,本参数的支持情况与设备型号有关。
m-gigabitethernet:千兆管理以太网接口,本参数的支持情况与设备型号有关。
ten-gigabitethernet:10GE(万兆以太网接口),本参数的支持情况与设备型号有关。
wlan-radio:无线射频接口,本参数的支持情况与设备型号有关。
chip-no:指定芯片编号。
len-value:指定偏移长度值。
diag pcie display命令用于显示PCIE状态。
diag pcie slot/subslot display chip-no bus-id device-id function-id offset width
Probe视图
chip-no:指定芯片号。
bus-id:指定总线号。
device-id:指定设备ID。
function-id:指定功能ID。
offset:指定偏移量。
width:指定长度。
1.1.36  diag poe
diag poe命令用于设置超瘦本体PoE功能状态,以及获取端口PoE工作状态。
diag poe slot/subslot { port-no | all } { disable | enable | status }
Probe视图
slot/subslot:指定槽位号或子槽位号。
port-no:指定端口号。
all:配置所有端口的PoE功能。
disable:关闭端口PoE功能。
enable:开启端口PoE功能。
status:显示端口PoE功能的状态,关闭或开启。
diag port display statistics命令用来显示各端口统计信息。
diag port { aux | console | Ethernet | gigabitethernet | i-gigabitethernet | inasync | inner-ethernet | m-ethernet | m-gigabitethernet | wlan-radio } display statistics
Probe视图
all:显示所有端口的统计信息。
aux:显示aux接口的统计信息,本参数的支持情况与设备型号有关。
console:显示console接口的统计信息。
ethernet:显示以太网接口的统计信息,本参数的支持情况与设备型号有关。
gigabitethernet:显示GE接口的统计信息,本参数的支持情况与设备型号有关。
i-gigabitethernet:显示内部GE接口的统计信息,本参数的支持情况与设备型号有关。
inasync:显示内部异步接口的统计信息,本参数的支持情况与设备型号有关。
inner-ethernet:显示内部以太网接口的统计信息,本参数的支持情况与设备型号有关。
m-ethernet:显示以以太管理接口的统计信息,本参数的支持情况与设备型号有关。
m-gigabitethernet:显示管理以太网接口的统计信息,本参数的支持情况与设备型号有关。
ten-gigabitethernet:显示10GE接口的统计信息,本参数的支持情况与设备型号有关。
wlan-radio:显示无线射频接口的统计信息,本参数的支持情况与设备型号有关。
smartrate-ethernet:显示smartrate-ethernet以太网接口的统计信息,本参数的支持情况与设备型号有关。
fortygige:显示fortygige接口的统计信息,本参数的支持情况与设备型号有关。
diag port-list display命令用来显示所有端口列表。
Probe视图
diag port-table display命令用来显示上报平台端口列表。
Probe视图
diag stm display命令用来显示堆叠调试信息,包括是否支持堆叠、支持盒式堆叠还是分布式堆叠,获取堆叠的能力等信息。
diag stm display
Probe视图
diag stm statistic display命令用来显示堆叠收发统计信息。
Probe视图
diag temperature display status命令用来显示温感信息。
Probe视图
diag tmpr-alarm display threshold命令用来显示进风口最低温度和最高温度。
Probe视图
display debug-info命令用来打印debug设置信息。
display debug-info
Probe视图
display hardware internal transceiver register interface命令用来显示可插拔光模块上指定寄存器区域的内容,用十六进制数表示。
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
Probe视图
interface interface-type interface-number:显示接口上插入的可插拔光模块上的寄存器信息。interface-type interface-number表示接口类型和接口编号。
device device-index:表示指定接口上光模块内部寄存器的索引号,用十六进制数表示,取值范围为0~FF。
address start-address:起始地址,即需要显示的寄存器区域的起始点的偏移地址。用十六进制数表示,取值范围为0~FFFF。
length region-length:寄存器区域的长度,即需要显示的寄存器区域的字节数。用十进制数表示,取值范围为1~256。
display system internal arp命令用来显示指定设备学习到的ARP表项信息或表项个数。
display system internal arp { all | static | dynamic } [ count ]
Probe视图
all: 命令用来显示所有ARP表项信息或表项个数。
static: 用来显示静态ARP表项信息或表项个数。
dynamic: 用来显示动态ARP表项信息或表项个数。
count:用来显示ARP表项个数。
display system internal arp ifcb命令用来查看指定设备上二层或三层接口ARP控制块信息。
display system internal arp ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
display system internal arp ip-address命令用来显示指定设备的指定IP的ARP表项信息。
Probe视图
ip-address: 用来显示指定IP的ARP表项信息。
display system internal arp machash命令用来显示指定设备上machash表项信息。
display system internal arp machash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id: 显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的ID。
ip ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址。
display system internal arp probe命令用来显示指定设备上ARP探测链表项。
Probe视图
display system internal arp rbhash命令用来显示指定设备上rbhash表项信息。
display system internal arp rbhash vlan vlan-id ip ip-address
Probe视图
vlan vlan-id: 显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ip ip-address:显示指定IP上rbhash表项信息。
display system internal arp reload命令用来显示指定设备上ARP重刷链表项。
Probe视图
display system internal arp rule命令用来显示ARP规则信息。
display system internal arp rule { all | interface interface-type interface-number [ ip-address ] }
Probe视图
all:显示所有ARP规则信息。
interface interface-type interface-number:显示指定接口的ARP规则信息,interface-type interface-number表示接口类型和接口编号。
ip-address:显示指定IP地址的ARP规则信息。
display system internal arp source-suppression cache命令用来显示指定成员设备的源抑制表项。
Probe视图
display system internal arp statistics命令用来显示指定成员设备的ARP统计信息。
Probe视图
display system internal arp vlan命令用来显示指定VLAN的ARP表项信息或表项个数。
display system internal arp vlan vlan-id [ count ]
Probe视图
vlan vlan-id: 用来显示指定VLAN的ARP表项信息或表项个数。
display system internal customlog host命令用来显示指定日志主机当前运行状态下的内核数据信息。
display system internal customlog host index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW }
Probe视图
index:表示指定日志主机的索引号。index取值范围为0~3。
cmccPortA指定中国移动公司的端口创建日志类型,并显示日志对应的内核数据信息。
cmccPortF指定中国移动公司的端口资源不足日志类型,并显示日志对应的内核数据信息。
cmccPortW指定中国移动公司的端口删除日志类型,并显示日志对应的内核数据信息。
cmccSessionA指定中国移动公司的session创建日志类型,并显示日志对应的内核数据信息。
cmccSessionW指定中国移动公司的session删除日志类型,并显示日志对应的内核数据信息。
portA指定中国联通公司的端口创建日志类型,并显示日志对应的内核数据信息。
portW指定中国联通公司的端口删除日志类型,并显示日志对应的内核数据信息。
sessionA指定中国联通公司的session创建日志类型,并显示日志对应的内核数据信息。
sessionW指定中国联通公司的session删除日志类型,并显示日志对应的内核数据信息。
sessionbasedA指定中国电信公司的session创建日志类型,并显示日志对应的内核数据信息。
sessionbasedW 指定中国电信公司的session删除日志类型,并显示日志对应的内核数据信息。
userbasedA指定中国电信公司的端口创建日志,并显示日志对应的内核数据信息。
userbasedF指定中国电信公司的端口资源不足日志类型,并显示日志对应的内核数据信息。
userbasedW指定中国电信公司的端口删除日志,并显示日志对应的内核数据信息。
display system internal customlog mbuf dump命令用来显示指定个数的CUSTOMLOG报文的详细信息。
display system internal customlog mbuf dump count number
Probe视图
number:指定需要显示的日志个数。number取值范围为1~100。
display system internal customlog mbuf usage命令用来显示指定日志主机上每个CPU内MBUF池的使用情况信息。
display system internal customlog mbuf usage index { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW }
Probe视图
index:指定需要查看数据的日志主机索引号。index取值范围为0~3。
cmccPortA指定中国移动公司的端口创建日志类型,并显示日志对应的MBUF池使用情况信息。
cmccPortF指定中国移动公司的端口资源不足日志类型,并显示日志对应的MBUF池使用情况信息。
cmccPortW指定中国移动公司的端口删除日志类型,并显示日志对应的MBUF池使用情况信息。
cmccSessionA指定中国移动公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
cmccSessionW指定中国移动公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
portA指定中国联通公司的端口创建日志类型,并显示日志对应的MBUF池使用情况信息。
portW指定中国联通公司的端口删除日志类型,并显示日志对应的MBUF池使用情况信息。
sessionA指定中国联通公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
sessionW指定中国联通公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
sessionbasedA指定中国电信公司的session创建日志类型,并显示日志对应的MBUF池使用情况信息。
sessionbasedW 指定中国电信公司的session删除日志类型,并显示日志对应的MBUF池使用情况信息。
userbasedA指定中国电信公司的端口创建日志,并显示日志对应的MBUF池使用情况信息。
userbasedF指定中国电信公司的端口资源不足日志类型,并显示日志对应的MBUF池使用情况信息。
userbasedW指定中国电信公司的端口删除日志,并显示日志对应的MBUF池使用情况信息。
display system internal customlog test命令用来发送指定数目CUSTOMLOG测试的报文,并显示日志发送结果信息。
display system internal customlog test count number { cmccPortA | cmccPortF | cmccPortW | cmccSessionA | cmccSessionW | portA | portW | sessionA | sessionW | sessionbasedA | sessionbasedW | userbasedA | userbasedF | userbasedW }
Probe视图
number:指定需要参与测试的CUSTOMLOG数目。number取值范围为1~100。
cmccPortA指定中国移动公司的端口创建日志类型,并显示日志对应的测试日志发送结果信息。
cmccPortF指定中国移动公司的端口资源不足日志类型,并显示日志对应的测试日志发送结果信息。
cmccPortW指定中国移动公司的端口删除日志类型,并显示日志对应的测试日志发送结果信息。
cmccSessionA指定中国移动公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
cmccSessionW指定中国移动公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
portA指定中国联通公司的端口创建日志类型,并显示日志对应的测试日志发送结果信息。
portW指定中国联通公司的端口删除日志类型,并显示日志对应的测试日志发送结果信息。
sessionA指定中国联通公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
sessionW指定中国联通公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
sessionbasedA指定中国电信公司的session创建日志类型,并显示日志对应的测试日志发送结果信息。
sessionbasedW 指定中国电信公司的session删除日志类型,并显示日志对应的测试日志发送结果信息。
userbasedA指定中国电信公司的端口创建日志,并显示日志对应的测试日志发送结果信息。
userbasedF指定中国电信公司的端口资源不足日志类型,并显示日志对应的测试日志发送结果信息。
userbasedW指定中国电信公司的端口删除日志,并显示日志对应的测试日志发送结果信息。
display system internal dbm命令用来显示数据库信息。
display system internal dbm { all | name dbname [ key keyname ] }
Probe视图
all:表示所有数据库。
name dbname:指定数据库名。
key keyname:指定key的名称,在数据库中以key名称标识一项数据。
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
display system internal ethernet character { global | interface interface-type interface-number }
Probe视图
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:表示接口类型和接口编号。
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如STP,LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
display system internal ethernet controlblock interface interface-type interface-number
Probe视图
display system internal ifmgr down命令用来显示已注册的down类型。
Probe视图
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para | help }
Probe视图
para:指定显示时的参数。表示接口名或接口索引,格式为:1*接口索引,2*接口名。
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para | help }
Probe视图
para:指定显示时的参数。para为事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,格式为:event*type
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
display system internal ifmgr hotplug [ para | help ]
Probe视图
para:指定显示时的参数。para为槽位号或者槽位号和子槽位号(格式为slot-number*subslot-number),用于显示该板或子卡的热插拔信息。不指定该参数以及help参数时,显示所有板的热插拔信息;
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para | help }
Probe视图
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口树信息。
display system internal ifmgr list [ para | help ]
Probe视图
para:指定显示时的参数。para为接口类型对应的数值,该数值可通过help参数获取。
接口树用于管理设备上存在的接口。树上的节点对应接口,子节点对应接口下创建的子接口,每个节点的信息包括接口的名称和索引。
不指定parahelp参数时,显示所有类型接口的接口树信息。
display system internal ifmgr name命令用来显示接口名字解析树信息。该树用于解析接口名字,以及命令行上输入接口名字时的帮助检查。
display system internal ifmgr name { para | help }
Probe视图
para:指定显示时的参数,为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para | help }
Probe视图
para:指定显示时的参数。para为接口类型,为1~127个字符的字符串。
display system internal ip address命令用来显示地址详细信息
display system internal ip address [ ip-address | interface interface-type interface-number ]
Probe视图
ip-address:显示指定IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
display system internal ipv6 address命令用来显示IPv6地址详细信息
display system internal ipv6 address [ interface interface-type interface-number [ gateway | multicast | prefix | unicast ] ] [ ipv6-address ]
Probe视图
interface interface-type interface-number:显示指定接口的IPv6地址,interface-type interface-number表示接口类型和接口编号。
gateway:显示指定接口的网关地址信息。
multicast:显示指定接口的组播地址信息。
prefix:显示指定接口的ipv6前缀信息。
unicast:显示指定接口的单播地址信息。
ipv6-address:显示指定的IPv6地址。
display system internal ipv6 fib prefix命令用来显示IPv6 FIB前缀基本信息。
Probe视图
display system internal ipv6 fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv6 FIB表项信息信息。
display system internal ipv6 fib prefix entry-status status
Probe视图
entry-status status:用于匹配IPv6 FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv6 FIB表项,“F”表示下刷驱动失败的IPv6 FIB表项。
display system internal ipv6 fib prefix ipv6命令用来显示IPv6 FIB前缀详细信息。
display system internal ipv6 fib prefix ipv6 [ prefix-length ]
Probe视图
ipv6:显示目的地址为指定IPv6地址的IPv6 FIB前缀详细信息。
prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
display system internal ipv6 pathmtu命令用来显示IPv6的PMTU信息,信息全局同步。
display system internal ipv6 pathmtu { ipv6-address | { all | dynamic | static } [ count ] }
Probe视图
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有公网的PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
count:显示PMTU表项数目。
display system internal ipv6 rawip命令用来显示设备上所有IPv6 RawIP连接的摘要信息。
Probe视图
display system internal ipv6 rib event attribute 命令用来显示IPv6 RIB的路由属性事件信息。
Probe视图
display system internal ipv6 rib event policy命令用来显示IPv6 RIB的路由策略事件信息。
Probe视图
display system internal ipv6 rib event prefix命令用来显示IPv6 RIB的路由前缀事件信息。
Probe视图
display system internal ipv6 rib event protocol命令用来显示IPv6 RIB的协议事件信息。
Probe视图
display system internal ipv6 rib event statistics用来显示IPv6 RIB的统计事件信息。
Probe视图
display system internal ipv6 rib instance命令用来显示IPv6 RIB的协议进程信息。
Probe视图
display system internal ipv6 rib log命令用来显示IPv6 RIB的日志信息。
display system internal ipv6 rib log [ reverse ] [ standby slot slot-number ]
display system internal ipv6 rib event log [ standby slot slot-number ]
Probe视图
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
standby slot slot-number:显示备份的指定成员设备的RIB的日志信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB的日志信息。
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志信息。
display system internal ipv6 rib nib log [ reverse ] [ standby slot slot-number ]
Probe视图
nib:显示IPv6 NIB子模块的运行状态。
standby slot slot-number:显示备份的指定成员设备的NIB子模块的运行状态日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示NIB子模块的运行状态日志。
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
display system internal ipv6 rib prefix ipv6-address prefix-length [ standby slot slot-number ]
Probe视图
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
standby slot slot-number:显示备份的指定成员设备的IPv6路由表前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv6路由表前缀信息。
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
display system internal ipv6 rib summary [ standby slot slot-number ]
Probe视图
standby slot slot-number:显示备份的指定成员设备的RIB统计信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示RIB统计信息。
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
display system internal ipv6 route-direct interface [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
ipv6-address:IPv6地址。
display system internal ipv6 route-direct log命令用来显示IPv6直连路由日志信息。
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:IPv6直连路由NIB子模块相关日志。
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
display system internal ipv6 tcp命令用来显示设备上所有IPv6 TCP连接的摘要信息。
Probe视图
display system internal ipv6 tcp port-info命令用来显示IPv6 TCP模块非保留端口的使用信息。
Probe视图
display system internal ipv6 udp命令用来显示设备上所有IPv6 UDP连接的摘要信息。
Probe视图
display system internal ipv6 udp port-info命令用来显示IPv6 UDP模块非保留端口的使用信息。
Probe视图
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
display system internal kernel memory dump address address-hex length memory-length
Probe视图
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
display system internal kernel memory pool [ name name-string ]
display system internal kernel memory pool tag [ tag-value ]
display system internal kernel memory pool name name-string tag tag-value
Probe视图
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
不指定nametag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
display system internal link-aggregation global命令用来显示聚合模块的系统内部全局信息。
Probe视图
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
display system internal link-aggregation interface bridge-aggregation interface-number [ kernel | statistics [ ipv4 | ipv6 ] ]
display system internal link-aggregation interface interface-type interface-number [ kernel | lacp | lacppdu | statistics [ ipv4 | ipv6 ] ]
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
interface-type interface-number:聚合成员口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
ipv4:IPv4报文统计值。
ipv6:IPv6报文统计值。
lacp:动态聚合数据。
lacppdu:LACP报文统计值。
·     如果未指定kernellacplacppdustatistics参数,则显示LAGG主线程中接口的基本数据。
·     如果未指定ipv4、ipv6参数,则显示所有报文统计值。
·     部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
display system internal lipc dump命令用来显示LIPC抓包记录。
display system internal lipc dump [ lip lip ]
Probe视图
display system internal lipc dump configuration命令用来显示配置的LIPC抓包规则。
display system internal lipc dump configuration [ lip lip ]
Probe视图
display system internal lipc history命令用来以图表方式显示LIPC各协议的历史流量信息。
display system internal lipc history [ mtcp | publish | stcp ] { recv | send } { by-min | by-sec } [ lip lip ]
Probe视图
mtcp显示组播传输控制协议的历史流量信息。不指定mtcppublishstcp参数时,表示显示三种协议报文流量总和的历史信息。
publish显示可靠发布协议的历史流量信息。不指定mtcppublishstcp参数时,表示显示三种协议报文流量总和的历史信息。
stcp显示单播传输控制协议的历史流量信息。不指定mtcppublishstcp参数时,表示显示三种协议报文流量总和的历史信息。
recv:显示当前协议的历史接收流量。
send:显示当前协议的历史发送流量。
by-min:以分钟为单位显示最近30分钟内的历史流量。
by-sec:以秒为单位显示最近30秒内的历史流量。
display system internal lipc lcmp statistics命令用来显示LIPC LCMP全局统计信息,包括收发包计数和错误计数。
display system internal lipc lcmp statistics [ lip lip ]
显示本地节点LCMP全局统计信息。
Probe视图
lip lip表示远端节点号,取值范围为0~65535。不指定该参数时,表示全局主用主控板所在节点。
display system internal lipc lgmp group命令用来显示一个指定组播组信息,包含成员信息和组播组相关的统计信息。
display system internal lipc lgmp group groupID [ lip lip ]
显示本地节点指定组播组信息。
Probe视图
groupID:表示组播组号,取值范围为0~4294967295。
display system internal lipc lgmp group-list命令用来查看系统中所有已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
display system internal lipc lgmp group-list [ lip lip ]
显示本地节点已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
Probe视图
display system internal lipc lgmp physical-group命令用来显示指定的硬件组播组信息。
display system internal lipc lgmp physical-group phyID [ lip lip ]
显示本地节点指定的硬件组播组信息。
Probe视图
physical-group phyID:表示硬件组播组ID,取值范围为0~4294967295。
display system internal lipc lgmp physical-group-list命令用来显示所有的硬件组播组信息,以便了解硬件组播组的使用情况。
display system internal lipc lgmp physical-group-list [ lip lip ]
显示本节点显示所有的硬件组播组信息。
Probe视图
display system internal lipc lgmp statistics命令用来显示LIPC LGMP模块的统计信息。
display system internal lipc lgmp statistics [ lip lip ]
显示本地节点LIPC LGMP模块的统计信息。
Probe视图
display system internal lipc lip statistics命令用来显示LIPC LIP全局统计信息。包括LIP报文的收发计数和出错计数。
display system internal lipc lip statistics [ lip lip ]
显示本地节点LIP全局统计信息。
Probe视图
display system internal lipc loop statistics命令用来显示本地环回的统计信息。
display system internal lipc loop statistics [ lip lip ]
显示本地节点环回的统计信息。
Probe视图
display system internal lipc mtcp group命令用来显示LIPC显示某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
显示本地节点某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
Probe视图
portID:组播组的端口号,一个端口号标识一个组播组,取值范围为0~4294967295。
history:显示该组播组状态机的历史变迁轨迹。
member:显示该组播组的成员信息。
statistics:显示该组播组的统计信息。
display system internal lipc mtcp group all命令用来显示所有包含本节点的组播组的统计信息。
display system internal lipc mtcp group all [ lip lip ]
Probe视图
display system internal lipc mtcp performance命令显示LIPC组播性能信息。
display system internal lipc mtcp performance [ lip lip ]
显示本地节点LIPC组播性能信息。
Probe视图
必须打开相应得性能统计开关后,该命令才能输出性能信息。
·     lipc performance
display system internal lipc mtcp statistics命令用来显示LIPC组播的全局统计信息。
display system internal lipc mtcp statistics [ lip lip ]
显示本地节点LIPC组播的全局统计信息。
Probe视图
display system internal lipc pcb mbuf statistics命令用来显示LIPC各个PCB下的MBUF使用情况。
display system internal lipc pcb mbuf statistics [ lip lip ]
Probe视图
lip lip:表示节点号,取值范围为0~32767。不指定该参数时,表示本节点。
display system internal lipc pcb statistics命令用来显示LIPC PCB模块全局统计信息。
display system internal lipc pcb statistics [ lip lip ]
显示本地节点PCB模块全局统计信息。
Probe视图
display system internal lipc physical命令用来显示驱动适配层的全局统计信息。用于统计LIPC与驱动交互的各种信息,包括收发包计数,驱动错误计数和驱动上报事件计数。
display system internal lipc physical [ lip lip ]
显示本地节点驱动适配层的全局统计信息。
Probe视图
display system internal lipc publish global-cb命令用来显示LIPC PUBLISH模块全局控制块信息。
display system internal lipc publish global-cb [ lip lip ]
显示本地节点PUBLISH模块全局控制块信息。
Probe视图
一般用于诊断Pub模块在某个节点上是否乱序。
display system internal lipc publish statistics命令用来显示LIPC PUBLISH模块统计信息。
display system internal lipc publish statistics [ lip lip ]
显示本地节点PUBLISH模块的统计信息。
Probe视图
display system internal lipc stcp event命令用来显示LIPC单播事件的信息。
display system internal lipc stcp event { sync | trans } [ lip lip ]
显示本地节点LIPC单播的事件信息。
Probe视图
sync:显示LIPC单播控制报文事件信息。
trans:显示LIPC单播数据报文事件信息。
该命令主要记录本节点和其他节点的连接/DACK/销毁/时序交互信息。当设备上连接很多时,该命令记录的条目很容易满(512条),此时会将最老的记录清除掉。因此,发现问题时,应当尽早执行该命令,获取事件信息,便于定位分析。
display system internal lipc stcp global-server命令显示LIPC单播的全局知名端口信息。
display system internal lipc stcp global-server [ lip lip ]
显示本地节点LIPC单播的全局知名端口同步信息。
Probe视图
display system internal lipc stcp links命令用来显示单播的连接信息。包括收发包信息、状态信息、缓存信息等。
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
显示本节点LIPC单播的连接信息。
Probe视图
all:表示显示本节点所有的单播连接信息。
detail port:表示指定端口号的具体信息,取值范围为0~65535。
global gport:表示全局知名端口号,取值范围为100~8100。
listening:表示显示本节点处于侦听状态的连接。
local lport:表示本地端口号,取值范围为10100~65535。
singledetail lport rport:表示指定本地端口号和目的端口号的具体信息,取值范围为0~65535。
display system internal lipc stcp performance命令用来显示单播的性能信息。
display system internal lipc stcp performance [ lip lip ]
显示本地节点LIPC单播的性能信息。
Probe视图
必须使用lipc performance命令打开相应的性能统计开关后,该命令才能输出性能信息。
·     lipc performance
display system internal lipc stcp port命令用来显示单播支持的知名端口的指定操作的统计信息。
display system internal lipc stcp port { close | connect | get-port | half-close| recv-get-port | resend | send } [ lip lip ]
Probe视图
close:显示当前节点各端口的连接关闭次数。
connect:显示当前节点各端口的连接请求次数。
get-port:显示当前节点各全局知名端口的目的节点请求次数。
half-close:显示各端口的连接半关闭次数。
recv-get-port:显示当前节点收到的全局知名端口目的节点请求次数。
resend:显示各端口的重传次数。
send:显示各端口的发送次数。
display system internal lipc stcp statistics命令用来显示LIPC单播的全局统计信息,用于分析单播的全局工作情况。
display system internal lipc stcp statistics [ lip lip ]
显示本节点LIPC单播的统计信息。
Probe视图
display system internal lipc stcp status命令用来显示单播的传输状态。主要记录单播对象的传输序号、ACK序号、发送标志、接收状态。该命令通常用于分析单播的数据可靠传输问题。
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe视图
recv:显示接收端的单播传输状态。
send:显示发送端的单播传输状态。
display system internal lipc stream命令用来查看流模式单播的记录信息。
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
显示本地节点LIPC单播流模式信息。
Probe视图
ack:表示查看指定端口号的收到ACK的记录。
reass:表示查看指定端口号的接收重组队列信息。
send:表示查看指定端口号的发送报文分片记录。
port portID:表示端口号,为0~65535的整数。
display system internal lipc sudp pcb-info命令用来查看SUDP模块的PCB详细信息。
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
显示本地节点SUDP模块的PCB详细信息。
Probe视图
all-port:显示所有PCB信息。
global-port:显示全局知名端口的PCB信息。
local-port:显示本地知名端口的PCB信息。
specific-port portID:表示指定端口号,取值范围为0~65535。
display system internal lipc sudp statistics命令用来显示LIPC SUDP模块的全局统计信息。
display system internal lipc sudp statistics [ lip lip ]
显示本地节点SUDP模块的全局统计信息。
Probe视图
display system internal lipc sudp命令用来查看所有SUDP全局知名端口号或本地端口号的信息。
display system internal lipc sudp { global-port | local-port } [ lip lip ]
显示本地节点SUDP全局知名端口号或本地端口号的信息。
Probe视图
global-port:表示查看所有SUDP全局知名端口号的信息。
local-port:表示查看所有SUDP本地端口号的信息。
display system internal lipc topology history命令用来查看拓扑链接信息的历史变迁记录。
display system internal lipc topology history [ lip lip ]
显示本地节点拓扑链接信息的历史变迁记录。
Probe视图
display system internal lipc topology link命令用来显示LIPC的拓扑链接信息。
display system internal lipc topology link [ lip lip ]
显示本地节点LIPC 的拓扑链接信息。
Probe视图
display system internal lipc topology node命令用来查看拓扑节点相关的统计信息。
display system internal lipc topology node nodeID [ lip lip ]
显示本地节点上和其他拓扑节点相关的统计信息。
Probe视图
nodeID:表示节点号,取值范围为0~32767。
记录了该节点上事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology process-time命令用来查看发生拓扑事件时,通知各个模块耗时。
display system internal lipc topology process-time [ lip lip ]
显示本地节点发生拓扑事件时,通知各个模块耗时。
Probe视图
display system internal lipc topology statistics命令用来查看拓扑相关的全局统计。记录了该全局事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology statistics [ lip lip ]
显示本地节点拓扑相关的全局统计。
Probe视图
display system internal lipc topology status命令用来显示节点的拓扑状态信息。
display system internal lipc topology status [ lip lip ]
显示本地节点拓扑状态信息。
Probe视图
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
display system internal mac-address configuration { blackhole | static } [ count ]
Probe视图
blackhole:显示黑洞MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
display system internal mac-address learned命令用来显示动态MAC地址表项。
display system internal mac-address learned [ mac-address [ vlan vlan-id ] | [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] ]
Probe视图
mac-address:显示指定MAC地址的动态MAC地址表项,mac-address的格式为H-H-H。在配置时,用户可以省去MAC地址中每段开头的“0”,例如输入“f-e2-1”即表示输入的MAC地址为“000f-00e2-0001”。
vlan vlan-id:显示指定VLAN的动态MAC地址表项。vlan-id的取值范围为1~4094。
interface interface-type interface-number:显示指定接口的动态MAC地址表项。interface-type interface-number为接口类型和接口编号。
count:显示动态MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)动态MAC地址表项的数量,而不显示动态MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的动态MAC地址表项的具体内容。
display system internal mac-address protocol命令用来显示指定协议或特性生成的MAC地址或VLAN接口的MAC地址。
display system internal mac-address protocol [ client | security | vlan-interface ] [ count ]
Probe视图
client:显示在线用户的MAC地址表项。目前,仅显示无线在线用户的MAC地址表项。
security:显示端口安全特性中学习到的MAC地址表项。
vlan-interface:显示VLAN接口的MAC地址表项。
count:显示MAC地址表项的数量。如果指定了本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果未指定本参数,则显示符合条件的MAC地址表项的具体内容。
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
Probe视图
display system internal mac-forwarding cache ip verbose命令用来显示IP快转表项的详细内容。
display system internal mac-forwarding cache ip [ ip-address ] verbose
probe视图
ip-address:显示指定IP地址的快速转发表信息。如果不指定ip-address,将显示所有快速转发表信息。
display system internal mac-forwarding cache ipv6 verbose命令用来显示IPv6快转表项的详细内容。
display system internal mac-forwarding cache ipv6 [ ipv6-address ] verbose
probe视图
ipv6-address:显示指定IPv6地址的IPv6快速转发表信息。如果不指定ipv6-address,将显示所有IPv6地址的IPv6快速转发表信息。
display system internal mac-forwarding controlblock命令用来显示二层转发的接口控制信息。
display system internal mac-forwarding controlblock interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的二层转发控制信息。其中,interface-type interface-number为指定接口类型和接口编号。
display system internal mbuf relay statistics命令用来显示MBUF中继模块的统计信息。
display system internal mbuf relay statistics [ vcpu vcpu-number ] [ rcv receiver-id ]
Probe视图
vcpu vcpu-number:MBUF中继使用的VCPU的编号,取值为0。不指定该参数时,表示当前成员设备上的所有VCPU。
rcv received-id:MBUF中继接收者的编号,取值范围为0~127。不指定该参数时,表示当前VCPU上的所有接收者。
display system internal nd dad命令用来显示DAD链信息。
Probe视图
display system internal nd entry命令用来显示各板上的ND表项信息。
Probe视图
display system internal nd ifcb命令用来显示接口的ND控制块信息。
display system internal nd ifcb interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的ND控制块信息。interface-type interface-number为接口类型和接口编号。
display system internal nd machash命令用来显示各板上的machash表项。
display system internal nd machash vlan vlan-id ipv6-address
Probe视图
vlan vlan-id:显示指定VLAN的信息。vlan-id表示指定VLAN的编号。
IPv6-address:指定IPv6地址。
display system internal nd probe命令用来显示探测链信息。
Probe视图
display system internal nd rbhash命令用来显示指定板上rbhash表项信息。
display system internal nd rbhash vlan vlan-id ipv6-address
Probe视图
vlan vlan-id:显示指定VLAN上rbhash表项信息。vlan-id表示指定VLAN的编号。
ipv6-address:显示指定IPv6地址上rbhash表项信息。
display system internal nd reload命令用来显示重刷链信息。
Probe视图
display system internal nd rule命令用来显示ND规则信息。
display system internal nd rule { all | interface interface-type interface-number [ ipv6-address ] }
Probe视图
all:显示所有ND规则信息。
interface interface-type interface-number:显示指定接口的ND规则信息,interface-type interface-number表示接口类型和接口编号。
ipv6-address:显示的指定IPv6地址的ND规则信息。
display system internal nd static命令用来显示ND静态配置。
display system internal nd static ipv6-address interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
display system internal nd statistics命令用来显示各板上的ND统计信息。
Probe视图
display system internal process state命令用来显示服务的运行状态。
Probe视图
display system internal rawip命令用来显示设备上所有RawIP连接的摘要信息。
Probe视图
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
Probe视图
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
Probe视图
display system internal rib instance命令用来显示RIB的协议进程信息。
Probe视图
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ] [ standby slot slot-number ]
display system internal rib event log [ standby slot slot-number ]
Probe视图
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
display system internal rib nib命令用来显示RIB的下一跳信息。
display system internal rib nib [ self-originated ] [ nib-id ] [ verbose ] standby slot slot-number
display system internal rib nib protocol protocol-name [ verbose ] standby slot slot-number
Probe视图
self-originated:路由管理自己生成的下一跳信息。
nib-id:路由下一跳信息的ID值,取值范围1~FFFFFFFF。
verbose:显示详细信息。如果未指定本参数,则显示概要信息。
protocol protocol-name:显示指定路由协议生成的下一跳信息,包括bgpdirectisisospfripstatic
standby slot slot-number:显示备份的指定成员设备的RIB下一跳信息,slot-number表示设备在IRF中的成员编号。
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ] [ standby slot slot-number ]
Probe视图
nib:显示NIB子模块的运行状态。
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length [ standby slot slot-number ]
Probe视图
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
standby slot slot-number:显示备份的指定成员设备的IPv4路由表前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IPv4路由表前缀信息。
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
display system internal rib summary [ standby slot slot-number ]
Probe视图
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
display system internal route-direct interface [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
·     字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
·     二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
display system internal stp bridge-info命令用来显示生成树指定实例桥配置信息及运行状态。
display system internal stp bridge-info instance instance-id
Probe视图
instance instance-id:显示指定实例的生成树桥配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
display system internal stp port-info命令用来显示生成树指定实例端口配置信息及运行状态。
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe视图
instance instance-id:显示指定实例的生成树端口配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
interface interface-type interface-number:显示指定端口上的生成树端口信息和运行状态,interface-type interface-number表示端口类型和端口编号。
display system internal tcp命令用来显示设备上所有TCP连接的摘要信息。
Probe视图
display system internal tcp port-info命令用来显示TCP模块非保留端口的使用信息。
Probe视图
display system internal udp命令用来显示设备上所有UDP连接的摘要信息。
Probe视图
display system internal udp port-info命令用来显示UDP模块非保留端口的使用信息。
Probe视图
display system internal vlan命令用来查看VLAN模块相关的内部信息。
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } slot slot-number
Probe视图
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
slot slot-number:查看指定成员设备的VLAN模块信息。其中,slot-number表示设备在IRF中的成员编号。
1.2  F
1.2.1  follow
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ]
Probe视图
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
1.2.2  fpl-diag
fpl-diag命令用来执行指定调试命令。
fpl-diag { cmd-string | slot slot-number cmd-string }
Probe视图
slot slot-number: 表示指定槽位号的调试信息。
cmd-string: 调试命令信息,此命令只适用于产品调式使用,可能引起系统崩溃,设备不可用等情况。此命令只能由H3C的技术支持人员使用。
1.3  L
lipc connection detect命令用来检测本节点和所有相连节点的连通性。
Probe视图
执行该命令后,本节点会向本节点所有相连节点连续发送5个ping报文,如果在200ms内收到目的节点的任何一个回复报文则认为该节点可达,否则不可达。
1.3.2  lipc dump
lipc dump命令用来配置LIPC各协议报文的抓包规则。
undo lipc dump命令用来清除抓包规则。
lipc dump lgmp [ port port ] [ recv | send ] [ lip lip ]
undo lipc dump [ lgmp [ port port ] [ recv | send ] ] [ lip lip ]
没有配置协议报文的抓包规则。
Probe视图
lgmp:配置组播管理协议报文的抓包规则。
port port:匹配协议端口号,不指定本参数时,表示匹配该协议所有端口。
recv:匹配该协议的接收报文。不指定recvsend参数时,表示匹配接收和发送报文。
send:匹配该协议的发送报文。不指定recvsend参数时,表示匹配接收和发送报文。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条协议报文的抓包规则。
所有下发的规则会被记录到系统,使用display system internal lipc dump configuration命令可以查看。
同一个报文被多个协议规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。
报文匹配成功后记录到抓包缓存区,使用display system internal lipc dump命令可以查看。
lipc dump buffer命令用来申请或释放指定节点的LIPC抓包缓存。
lipc dump buffer { alloc [ max-record num ] | free } [ lip lip ]
Probe视图
alloc:申请缓存。
free:释放缓存。
max-record num信息的最大记录缓存字节数,取值范围为1~10000,单位为KB,缺省值为10KB。
开启抓包功能后,系统会缺省申请10KB缓存来缓存捕获的报文。如果要捕获的报文较多,请先使用本命令提前申请内存,再开启抓包功能。
lipc dump enable命令用来开启本节点的LIPC抓包功能。
undo lipc dump enable命令用来关闭本节点的LIPC抓包功能。
lipc dump enable [ loop] [ lip lip ]
undo lipc dump enable [ lip lip ]
本节点的LIPC抓包功能处于关闭状态。
Probe视图
loop:表示开启循环记录模式,即缓存区满后会删除旧记录来保存新记录。不指定本参数时,表示非循环模式,缓存区满后不再继续记录。
lip lip:表示远端节点号,取值范围为0~65535,不指定该参数时,表示全局主用主控板所在节点。
开启本节点的LIPC抓包功能时,如未申请抓包缓存,系统会在开启抓包功能的同时申请10KB的抓包缓存。
关闭本节点的LIPC抓包功能时,不会清除抓包规则和抓包缓存区。
lipc dump offset命令用来配置报文内容抓包规则。
lipc dump offset offset length length value value [ recv | send ] [ lip lip ]
undo lipc dump [ offset offset length length value value [ recv | send ] ] [ lip lip ]
没有配置报文内容抓包规则。
Probe视图
offset:信息的偏移量,取值范围为0~65535。报文偏移起始位置为LIP报文头位置。
length length:信息的长度。取值为1、2、4、8,单位为字节。
value value:信息的内容的十六进制字符串形式(字符串不带“0x”)。length取值为1时,value的取值范围为0~0xFF;length取值为2时,value的取值范围为0~0xFFFF;length取值为4时,value的取值范围为0~0xFFFFFFFF;length取值为8时,value的取值范围为0~0xFFFFFFFFFFFFFFFF。
recv:匹配接收报文。不指定recvsend参数时,表示匹配接收和发送报文。
send:匹配发送报文。不指定recvsend参数时,表示匹配接收和发送报文。
下发内容匹配规则并开启抓包功能后,系统从驱动层收到的报文,从报文的第offset个字节开始取length长的内容,内容的值为value时,记录这个报文的前48字节内容到抓包缓存区。协议抓包规则和内容抓包规则抓取到的报文存放在同一个缓冲区,使用display system internal lipc dump命令可以查看捕获到的报文。
多次执行该命令,只要有字段取值不同,则作为不同的规则,系统最多支持配置5条不同的报文内容抓包规则。
清除报文内容抓包规则时,需要offsetlengthvalue三个字段完全匹配时才清除该规则,否则提示规则不存在。
同一个报文被多个内容匹配规则同时匹配成功,仅会有一条记录。协议规则和内容规则互相独立,如一个报文同时被协议规则和内容规则匹配成功,则会有两条不同的记录。报文匹配成功后记录到抓包缓存区,可使用display system internal lipc dump命令查看。
lipc performance命令用来配置单播或者组播的性能统计功能,用于评测LIPC的传输性能。
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
性能统计开关是关闭的。
Probe视图
mtcp:MTCP子模块的信息。
stcp:STCP子模块的信息。
clear:清除单播或者组播的性能统计信息。
off:关闭单播或者组播的性能统计开关。
on:打开单播或者组播的性能统计开关。
1.3.7  lipc ping
lipc ping命令用来检查本节点与目的节点LIPC通信链路的连通性和稳定性。
lipc ping lip lip [ length length ] [ times times ] [ summary ]
Probe视图
lip lip:指定目的端的LIP地址,取值范围0~65535。
length length:指定发送的LIPC回显请求报文的长度(不包括LIPC报文头),取值范围为0~32767,单位为字节,缺省值为100字节。
times times:指定LIPC回显请求报文的发送次数,取值范围为0~32767,缺省值为3。
summary:只显示统计信息。不指定该参数时,系统将显示包括统计信息在内的详细信息。
1.3.8  lipc timeout
lipc timeout命令用来设置LIPC拓扑链路的超时时间。
lipc timeout time [ lip lip ]
拓扑链路的超时时间为60秒。
Probe视图
timeout time:表示超时时间,取值范围为3-65535。
如果本节点的TOPOLOGY模块在超时时间内一直没有收到UP节点的心跳报文,则会断开与该节点的所有单播、组播连接。
通常,只有在使用KDB或者KGDB调试内核时,才需要修改该数值,以避免其他节点认为正处于内核调试状态的节点链路Down。
1.3.9  list
list命令用来查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
list file-path
Probe视图
file-path:要查看的文件或目录的路径,区分大小写。
1.4  M
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
memory boundary-check enable job job-id
undo memory boundary-check enable job job-id
内存越界检查功能处于关闭状态。
Probe视图
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
·     memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
memory boundary-check scan job job-id
Probe视图
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
·     memory boundary-check enable
1.4.3  monitor lipc
monitor lipc命令用来以交互模式显示各协议的实时统计信息。统计信息包括收发包信息、状态信息、缓存信息等。
monitor lipc { mtcp | stcp | sudp } { recv | send } [ lip lip ]
Probe视图
mtcp显示组播传输控制协议的实时统计信息。
stcp显示单播传输控制协议的实时统计信息。
sudp显示单播用户数据报的实时统计信息。
recv显示该协议接收报文的实时统计信息。
send显示该协议发送报文的实时统计信息。
信息的统计周期为5秒。统计结果以报文发送或接收量降序排列,最多同时显示10个数据,每隔5秒刷新一次。命令执行后前5秒内系统需统计信息,无统计信息输出。
用户可以通过输入q或Q来停止执行命令行,退回到命令行视图。
1.5  P
1.5.1  probe
probe命令用来从系统视图进入Probe视图。
probe
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
1.6  R
reset system internal arp statistics命令用来清除指定成员设备的上的ARP统计信息。
Probe视图
reset system internal ipv6 rib log命令用来清除IPv6 RIB相关的日志内容。
reset system internal ipv6 rib [ event ] log [ standby slot slot-number ]
Probe视图
event:IPv6 RIB路由变化相关的日志。
standby slot slot-number:清除备份的指定成员设备的RIB相关的日志内容,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除RIB相关的日志内容。
reset system internal ipv6 rib nib log命令用来清除IPv6 NIB子模块日志。
reset system internal ipv6 rib nib log [ standby slot slot-number ]
Probe视图
standby slot slot-number:清除备份的指定成员设备的NIB子模块日志,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除NIB子模块日志。
reset system internal ipv6 rib summary命令用来清除IPv6 RIB的统计摘要信息。
reset system internal ipv6 rib summary [ standby slot slot-number ]
Probe视图
standby slot slot-number:清除备份的指定成员设备RIB的统计摘要信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将清除RIB的统计摘要信息。
reset system internal ipv6 route-direct log命令用来清除直连路由日志。
reset system internal ipv6 route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:ipv6直连路由NIB子模块相关日志。
reset system internal ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
reset system internal lipc dump buffer命令用来清空本节点的LIPC抓包缓存。
reset system internal lipc dump buffer [ lip lip ]
Probe视图
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
Probe视图
reset system internal mbuf relay statistics命令用来清除MBUF中继模块的统计信息。
reset system internal mbuf relay statistics [ vcpu vcpu-number [ rcv receiver-id ] ]
Probe视图
reset system internal nd statistics命令用来清除各板上的ND统计信息。
Probe视图
reset system internal rib log命令用来清除RIB相关的日志内容。
reset system internal rib [ event ] log [ standby slot slot-number ]
Probe视图
event:RIB路由变化相关的日志。
reset system internal rib nib log命令用来清除NIB子模块日志。
reset system internal rib nib log [ standby slot slot-number ]
Probe视图
reset system internal rib summary命令用来清除IPv4 RIB的统计摘要信息。
reset system internal rib summary [ standby slot slot-number ]
Probe视图
reset system internal route-direct log命令用来清除直连路由日志。
reset system internal route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
reset system internal route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
1.7  V
1.7.1  view
view命令用来查看系统目录(/proc/、/sys/、/var/)下的文件的内容。
view file-path
Probe视图
file-path:要查看文件的路径,区分大小写。
执行该命令显示的文件路径中不能包含文件链接。文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
