14-EVI命令参考
01-EVI命令
本章节下载 01-EVI命令  (339.39 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S7500E/S7500E/Command/Command_Manual/H3C_S7500E_CR-R7536P02-6W100/14/201704/983917_30005_0.htm
01-EVI命令
  录
1 EVI
1.1 EVI配置命令
1.1.1 display evi arp-suppression
1.1.2 display evi isis brief
1.1.3 display evi isis graceful-restart status
1.1.4 display evi isis local-mac
1.1.5 display evi isis lsdb
1.1.6 display evi isis peer
1.1.7 display evi isis remote-mac
1.1.8 display evi isis tunnel
1.1.9 display evi link
1.1.10 display evi mac-address
1.1.11 display evi neighbor-discovery client member
1.1.12 display evi neighbor-discovery client statistics
1.1.13 display evi neighbor-discovery client summary
1.1.14 display evi neighbor-discovery server member
1.1.15 display evi neighbor-discovery server statistics
1.1.16 display evi neighbor-discovery server summary
1.1.17 display interface evi-link
1.1.18 evi arp-suppression enable
1.1.19 evi enable
1.1.20 evi extend-vlan
1.1.21 evi flooding enable
1.1.22 evi isis ded-priority
1.1.23 evi isis timer csnp
1.1.24 evi isis timer hello
1.1.25 evi isis timer holding-multiplier
1.1.26 evi isis timer lsp
1.1.27 evi isis track
1.1.28 evi neighbor-discovery authentication
1.1.29 evi neighbor-discovery client enable
1.1.30 evi neighbor-discovery client register-interval
1.1.31 evi neighbor-discovery server enable
1.1.32 evi network-id
1.1.33 evi selective-flooding mac-address
1.1.34 evi site-id
1.1.35 evi-isis
1.1.36 filter-policy
1.1.37 graceful-restart
1.1.38 graceful-restart interval
1.1.39 gre key vlan-id
1.1.40 keepalive
1.1.41 log-peer-change enable
1.1.42 reset evi arp-suppression
1.1.43 reset evi isis all
1.1.44 reset evi neighbor-discovery client statistics
1.1.45 reset evi neighbor-discovery server statistics
1.1.46 snmp context-name
1.1.47 snmp-agent trap enable evi-isis
1.1.48 timer lsp-max-age
1.1.49 timer lsp-refresh
1.1.50 virtual-system
1 EVI
提示
EVI需要安装Licence才能使用。有关Licence的详细介绍,请参见“基础配置指导”中的“License管理”。
1.1  EVI配置命令
display evi arp-suppression命令用来显示EVI ARP泛洪抑制表项。
(独立运行模式)
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
interface tunnel interface-number:显示指定EVI隧道接口下的EVI ARP泛洪抑制表项。
vlan vlan-id:显示指定VLAN的EVI ARP泛洪抑制表项。vlan-id表示VLAN编号,取值范围为1~4094。如果不指定本参数,将显示所有VLAN的EVI ARP泛洪抑制表项。
slot slot-number:显示指定单板的EVI ARP泛洪抑制表项。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的EVI ARP泛洪抑制表项。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的EVI ARP泛洪抑制表项。chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果不指定本参数,将显示全局主用主控板上的EVI ARP泛洪抑制表项。(IRF模式)
count:显示EVI ARP泛洪抑制表项的数目。
# 显示EVI隧道接口Tunnel101下的EVI ARP泛洪抑制表项。
<Sysname> display evi arp-suppression interface tunnel 101
IP Address      MAC Address    VLAN ID  Interface                Aging Status
1.1.1.2         000f-e201-0101 1        EVI-link1                14    Valid
1.1.1.3         000f-e201-0202 1        EVI-link1                18    Invalid
1.1.1.4         000f-e201-0203 1        EVI-link1                10    Collision
# 显示EVI隧道接口Tunnel101下的EVI ARP泛洪抑制表项的数目。
<Sysname> display evi arp-suppression interface tunnel 101 count
Total entries: 3
表1-1 display evi arp-suppression命令显示信息描述表
IP Address
EVI ARP泛洪抑制表项的IP地址
MAC Address
EVI ARP泛洪抑制表项的MAC地址
VLAN ID
EVI ARP泛洪抑制表项所属的激活VLAN
EVI ARP泛洪抑制表项对应的入接口,也就是学习到EVI ARP泛洪抑制表项的接口
Aging
EVI ARP泛洪抑制表项的老化时间,单位为分钟。超出老化时间,EVI ARP泛洪抑制表项会被自动删除
Status
EVI ARP泛洪抑制表项的表项状态:
·     Valid:有效。表项建立的初始状态为有效,有效时可以根据该表项进行代答
·     Invalid:无效。表项自最后一次更新后15分钟内没有收到ARP更新报文,变为无效状态,此时不能根据该表项代答。无效状态能保持10分钟,10分钟内无更新报文,则删除该表项
·     Collision:冲突。如果收到ARP报文时发现相同IP地址的泛洪抑制表项已经存在,但是MAC地址发生变化,则认为发生攻击,此时泛洪抑制表项处于冲突状态,不能根据该表项代答,并在Collision状态持续1分钟后删除此表项
Total entries
EVI ARP泛洪抑制表项的数目
·     evi arp-suppression enable
·     reset evi arp-suppression
display evi isis brief命令用来显示EVI IS-IS进程的摘要信息。
display evi isis brief [ process-id ]
process-id:显示指定EVI IS-IS进程的摘要信息。process-id表示EVI IS-IS进程号,取值范围为0~65535。如果不指定本参数,将显示所有EVI IS-IS进程的摘要信息。
# 显示EVI IS-IS进程的摘要信息。
<Sysname> display evi isis brief
Site ID: 10
Isolation Count: 0
Process ID: 0
Network-entity: 00.0011.2200.0001.00
LSP-length receive: 16384
LSP-length originate: 1400
Timers:
  LSP-max-age: 1200s
  LSP-refresh: 900s
表1-2 display evi isis brief显示信息描述表
Site ID
本地站点ID
Isolation Count
本设备被多少其他站点所隔离:
·     若该数目不为0,则表示本地站点ID仍与其他站点ID有冲突且本设备被隔离,则本设备不对外发布Hello报文
·     若该数目为0,则表示本设备未被隔离,此时对外发布Hello报文
Process ID
进程实例号
Network-entity
网络实体名称
LSP-length receive
可以接收LSP的最大长度
生成的LSP的最大长度
Timers
LSP-max-age:LSP的最大生存时间
LSP-refresh:LSP的刷新周期
display evi isis graceful-restart status命令用来显示EVI IS-IS协议的GR状态。
display evi isis graceful-restart status [ process-id ]
process-id:显示指定EVI IS-IS进程的GR状态。process-id表示EVI IS-IS进程号,取值范围为0~65535。如果不指定本参数,将显示所有EVI IS-IS进程的GR状态。
# 显示EVI IS-IS协议的GR状态。
<Sysname> display evi isis graceful-restart status
Process ID: 0
Restart status: RESTARTING
Restart phase: LSDB synchronization
Restart interval: 300s
T3 remaining time: 65531s
Total number of interfaces: 1
Number of waiting LSPs: 0
T2 remaining time: 56s
  Interface: EVI-Link0
    T1 remaining time: 2
    RA received: N
    CSNP received: N
    T1 expired number: 3
表1-3 display evi isis graceful-restart status显示信息描述表
Process ID
进程实例号
Restart status
重启状态:
·     COMPLETE:重启完成
·     STARTING:重启开始
·     RESTARTING:重启中
·     UNKNOWN:未知状态
Restart phase
重启阶段:
·     Initialization:初始阶段
·     LSDB synchronization:LSDB同步阶段
·     MAC receiving:接收本地MAC地址上报的阶段
·     LSP stable:LSP生成的阶段
·     LSP generation:LSP刷新和泛洪的阶段
·     Finish:GR完成的阶段
·     Unknown:未知阶段
Restart interval
重启间隔
T3 remaining time
定时器T3的剩余时间,单位为秒,T3定时器用来控制路由器的重启时间间隔
进程实例下的所有接口数
等待的LSP报文数
T2 remaining time
定时器T2的剩余时间,单位为秒,T2定时器用来控制LSDB同步时间
接口名称
T1 remaining time
定时器T1的剩余时间,T1定时器用来控制发送带有RR标志位的Restart TLV的次数
RA received
RA接收标记位
CSNP received
CSNP接收标记位
T1 expired number
定时器T1的超时次数
display evi isis local-mac命令用来显示EVI IS-IS的本地MAC地址信息。
display evi isis local-mac { dynamic | static } [ interface tunnel interface-number [ vlan vlan-id ] [ filtered | passed ] [ count ] ]
display evi isis local-mac nonadvertised [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
dynamic:显示本地动态MAC地址信息。
nonadvertised:显示本地非发布MAC地址信息。非发布MAC地址包括:选择性泛洪MAC地址、黑洞MAC地址、多端口单播MAC地址、组播MAC地址。
static:显示本地静态MAC地址信息。
interface tunnel interface-number:显示指定EVI隧道接口下的本地MAC地址信息。如果不指定本参数,将显示所有EVI隧道接口下的EVI IS-IS的本地MAC地址信息。
vlan vlan-id:显示指定VLAN的本地MAC地址信息。vlan-id表示VLAN编号,取值范围为1~4094。如果不指定本参数,将显示所有VLAN的本地MAC地址信息。
filtered:只显示本地存在,但是被路由策略过滤掉、不能发布的本地MAC地址信息。
passed:只显示没有被路由策略过滤掉、允许发布的本地MAC地址信息。
count:显示本地MAC地址的数目。
# 显示所有EVI隧道接口下的EVI IS-IS的本地动态MAC地址信息。
<Sysname> display evi isis local-mac dynamic
Process ID: 0
Tunnel interface: Tunnel1
  VLAN ID: 100
    MAC address: 00aa-00bb-00cc
    MAC address: 00aa-00cc-00bb (Filtered)
    MAC address: 00cc-00aa-00bb
  VLAN ID: 50
    MAC address: 00bb-00aa-00cc
    MAC address: 00bb-00cc-00aa
# 显示EVI隧道接口Tunnel1下允许发布的EVI IS-IS的本地动态MAC地址信息。
<Sysname> display evi isis local-mac dynamic interface tunnel 1 passed
Process ID: 0
  VLAN ID: 100
  VLAN ID: 50
# 显示所有EVI隧道接口下的EVI IS-IS的本地非发布MAC地址信息。
<Sysname> display evi isis local-mac nonadvertised
MAC Flags: F-Flooding, B-Blackhole, P-Multiport, M-Multicast
Process ID: 3
  Tunnel interface: Tunnel3
  VLAN ID: 111
    MAC address: 0005-0005-0005
          Flags: F
# 显示所有EVI隧道接口下的EVI IS-IS的本地静态MAC地址信息。
<Sysname> display evi isis local-mac static
Process ID: 0
  VLAN ID: 100
  VLAN ID: 50
# 显示EVI隧道接口Tunnel1下被路由策略过滤不允许发布的EVI IS-IS的本地静态MAC地址信息。
<Sysname> display evi isis local-mac static interface tunnel 1 filtered
Process ID: 0
  VLAN ID: 100
  VLAN ID: 50
# 显示EVI隧道接口Tunnel1下的本地动态MAC地址的数目。
<Sysname> display evi isis local-mac dynamic interface tunnel 1 count
5 MAC addresses found.
# 显示EVI隧道接口Tunnel1下允许发布的本地动态MAC地址的数目。
<Sysname> display evi isis local-mac dynamic interface tunnel 1 passed count
4 MAC addresses found.
# 显示EVI隧道接口Tunnel1下被路由策略过滤不允许发布的本地静态MAC地址的数目。
<Sysname> display evi isis local-mac static interface tunnel 1 filtered count
1 MAC addresses found.
表1-4 display evi isis local-mac显示信息描述表
Process ID
进程实例号
Tunnel interface
进程实例对应的Tunnel接口
VLAN ID
隧道接口上的扩展VLAN
MAC address
MAC地址
(Filtered)
被路由策略过滤掉、不能发布的MAC地址
Flags
EVI IS-IS本地非发布MAC地址标记:
·     F-Flooding:泛洪MAC地址(即通过evi selective-flooding mac-address命令配置的选择性泛洪的MAC地址)
·     B-Blackhole:黑洞MAC地址
·     P-Multiport:多端口单播MAC地址
·     M-Multicast:组播MAC地址
本地MAC地址的数目,本例中本地MAC地址的数目为5
display evi isis lsdb命令用来显示EVI IS-IS的链路状态数据库。
display evi isis lsdb [ local | lsp-id lspid | verbose ] * [ process-id ]
local:显示当前设备产生的LSP的信息。
lsp-id lspid:LSP标识,形式为SYSID.Pseudonode ID-fragment num,其中,SYSID是产生该LSP的结点或伪结点的SystemID,fragment num是该LSP的分片号。
verbose:显示链路状态数据库中的LSP的详细信息。如果不指定本参数,将显示链路状态数据库中的LSP的摘要信息。
process-id:显示指定EVI IS-IS进程的链路状态信息。process-id表示EVI IS-IS进程号,取值范围为0~65535。如果不指定本参数,将显示所有EVI IS-IS进程的链路状态信息。
# 显示链路状态数据库的摘要信息。
<Sysname> display evi isis lsdb
               Link state database information for EVI-ISIS(0)
LSP ID                 Seq num     Checksum  Holdtime  Length    Overload
0011.2200.0001.00-00*  0x000000f3  0xd95e    45        47        0
0011.2200.0101.00-00   0x00000017  0xbb6f    1139      85        0
0011.2200.0101.02-00   0x00000002  0x7973    805       54        0
Flags: *-Self LSP, +-Self LSP(Extended)
# 显示链路状态数据库的详细信息。
<Sysname> display evi isis lsdb verbose
                Link state database information for EVI-ISIS(1)
LSP ID: 3822.d69e.ee00.00-00*
Sequence number: 0x00000001
Checksum: 0xe0b5
Holdtime: 820s
Length: 47
Overload: 0
Source: 3822.d69e.ee00.00
Neighbour
    ID: 3ce5.a600.7600.02, Cost: 16777214
LSP ID: 3ce5.a600.7600.00-00
Sequence number: 0x00000007
Checksum: 0xc98a
Holdtime: 1163s
Length: 72
Overload: 0
Source: 3ce5.a600.7600.00
Neighbour
MAC addresses:
  VLAN ID: 1   Confidence: 1
    3822-d69e-ef68
    d485-64aa-7f23
    3408-0499-b44c
LSP ID: 3ce5.a600.7600.02-00
Checksum: 0xe16d
Holdtime: 819s
Length: 54
Overload: 0
Source: 3ce5.a600.7600.02
Neighbour
    ID: 3822.d69e.ee00.00, Cost: 0
    ID: 3ce5.a600.7600.00, Cost: 0
表1-5 display evi isis lsdb命令显示信息描述表
EVI IS-IS进程0的链路状态数据库信息
LSP ID
链路状态报文ID:
·     带*号表示是本地生成的、原始系统LSP
·     带+号表示是本地生成的、虚拟系统LSP(LSP扩展分片)
Sequence number
LSP序列号
Checksum
LSP校验和
Holdtime
LSP生存时间,随着时间推移递减,单位为秒
Length
LSP长度
Overload
LSP中Overload bit的置位情况。1表示置位,0表示没有置位
Source
LSP生成路由器的System ID
Neighbour
LSP生成路由器邻居
ID
邻居的System ID
Cost
开销值
MAC addresses
LSP生成路由器的MAC地址信息
VLAN ID
LSP生成路由器的MAC地址所在的VLAN ID
Confidence
可信度
·     0表示可信
·     1表示不可信
display evi isis peer命令用来显示EVI IS-IS的邻居信息。
display evi isis peer [ process-id ]
process-id:显示指定的EVI IS-IS进程下的邻居信息。process-id表示EVI IS-IS进程号,取值范围为0~65535。如果不指定本参数,将显示所有EVI IS-IS进程的邻居信息。
# 显示EVI IS-IS进程0的邻居信息。(此例为无冲突的站点内邻居)
<Sysname> display evi isis peer 0
Process ID: 0
System ID: 0011.2200.0101
Link interface: Tunnel1
Circuit ID: 0011.2200.0301.01
State: Up
Site ID: 1
Hold time: 29s
Neighbour DED priority: 64
Uptime: 00:10:56
Process ID: 0
Link interface: EVI-Link0
Circuit ID: ---
State: Init
Site ID: 1
Hold time: 29s
Uptime: 00:00:58
# 显示EVI IS-IS进程0的邻居信息(此例为有冲突的站点间邻居)。
Process ID: 0
System ID: 0011.2200.0301
Circuit ID: ---
State: Init
Site ID: 1 (Conflict)
Hold time: 27s
Neighbor DED priority: 64
Uptime: 00:00:00
表1-6 display evi isis peer命令显示信息描述表
Process ID
进程实例号
System ID
邻居的系统ID
Link interface
·     Tunnel:与对端相连的本地Tunnel接口
·     EVI-link:与对端相连的本地EVI-Link接口
Circuit ID
链路ID
邻居状态:
·     Init:邻居初始化
·     Up:邻接关系建立
·     Down:邻接关系断开
Site ID
邻居的站点ID。括号中的Conflict表示邻居的站点ID与本地站点ID有冲突,具体有以下两种情况:
·     站点间邻居的站点ID与本地站点ID一致
·     站点内邻居的站点ID与本地站点ID不一致
Hold time
存活时间,随着时间推移递减,如果在存活时间内还没有收到邻居发送的Hello报文,则认为邻居已经失效,如果收到了Hello报文,则存活时间将重置为初始值
Neighbour DED Priority
邻居接口DED优先级
Uptime
邻居关系保持的时间,格式为HH:MM:SS(小时:分钟:秒)
display evi isis remote-mac命令用来显示EVI IS-IS的远端MAC地址信息。
display evi isis remote-mac [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
interface tunnel interface-number:显示指定EVI隧道接口下的远端MAC地址信息。如果不指定本参数,将显示所有EVI隧道接口下的EVI IS-IS的远端MAC地址信息。
vlan vlan-id:显示指定VLAN的远端MAC地址信息。vlan-id表示VLAN编号,取值范围为1~4094。如果不指定本参数,将显示所有VLAN的远端MAC地址信息。
count:显示远端MAC地址的数目。
# 显示所有EVI隧道接口下的EVI IS-IS的远端MAC地址信息。
<Sysname> display evi isis remote-mac
Process ID: 0
  VLAN ID: 3
    MAC address: 0033-0011-0022
          Flags:  0x2
  VLAN ID: 2
    MAC address: 0022-0033-0011
    MAC address: 0033-0022-0011
          Flags:  0x2
# 显示EVI隧道接口Tunnel1下的远端MAC地址的数目。
<Sysname> display evi isis remote-mac interface tunnel 1 count
3 mac address(es) found.
表1-7 display evi isis remote-mac显示信息描述表
Process ID
进程实例号
Tunnel interface
进程实例对应的Tunnel接口
VLAN ID
进程实例下的VLAN
MAC address
MAC地址
EVI链路索引
Flags
EVI IS-IS远端MAC地址标记:
·     0x1:该MAC地址与EVI IS-IS本地动态MAC地址冲突
·     0x2:该MAC地址已经下发到远端MAC地址表
·     0x4:该MAC地址与EVI IS-IS本地的静态或泛洪MAC地址冲突
远端MAC地址的数目,本例中远端MAC地址的数目为3
display evi isis tunnel命令用来显示Tunnel接口的EVI IS-IS信息。
display evi isis tunnel [ tunnel-number ]
tunnel-number:显示指定Tunnel接口的EVI IS-IS信息。如果不指定本参数,将显示所有Tunnel接口上的EVI IS-IS信息。
# 显示Tunnel接口101上的EVI IS-IS信息。
<Sysname> display evi isis tunnel 101
Tunnel101
MTU: 1400
DED: Yes
DED priority: 80
Hello timer: 10s
Hello multiplier: 3
CSNP timer: 10s
LSP timer: 100ms
LSP transmit-throttle count: 5
AEF: Yes
EVI-Link0    DED: Yes
LAV:
  1,50,100
表1-8 display evi isis tunnel显示信息描述表
Tunnel
EVI隧道接口编号
MTU
链路MTU值
DED
是否被选举为DED:Yes表示是;No表示否
DED priority
DED优先级
Hello timer
Hello报文发送时间间隔
Hello multiplier
Hello报文失效数目
CSNP timer
CSNP报文发送时间间隔
LSP timer
LSP的最小发送时间间隔
LSP的最大传输数量
AEF
本设备是否可以作为扩展VLAN的授权转发设备:
·     如果双归属站点内某设备核心侧故障,则该属性显示为No,表示本设备不能作为任何VLAN的授权转发设备
·     如果某设备核心侧正常,则该属性显示为Yes,表示本设备可以作为扩展VLAN的授权转发设备
EVI-link
EVI虚拟链接
LAV
Tunnel接口下的激活VLAN
display evi link命令用来显示EVI隧道创建的EVI Link的信息。
display evi link interface tunnel interface-number
interface tunnel interface-number:显示指定EVI隧道接口下的EVI Link的信息。
# 显示EVI隧道接口Tunnel1创建的EVI Link的信息。
<Sysname> display evi link interface tunnel 1
Interface     Status Source          Destination
EVI-Link0     UP     1.1.1.1         1.1.2.1
EVI-Link1     UP     1.1.1.1         1.1.3.1
表1-9 display evi link命令显示信息描述表
EVI-Link接口名称
Status
EVI-Link接口的链路状态:
·     UP:表示链路状态为已连接
·     DOWN:表示链路状态为断开
Source
EVI-Link的EVI隧道本端地址
Destination
EVI-Link的EVI隧道对端地址
display evi mac-address命令用来显示远端MAC地址信息。
(独立运行模式)
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ slot slot-number ]
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ chassis chassis-number slot slot-number ]
mac-address mac-address:显示指定MAC地址的远端MAC地址信息。如果不指定本参数,将显示所有MAC地址的远端MAC地址信息。
slot slot-number:显示指定单板的远端MAC地址信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的远端MAC地址信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的远端MAC地址信息。chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果不指定本参数,将显示全局主用主控板上的远端MAC地址信息。(IRF模式)
count:显示远端MAC地址信息的数目。
# 显示EVI隧道接口Tunnel101下的远端MAC地址信息。
<Sysname> display evi mac-address interface tunnel 101
MAC Address      VLAN ID   Port
000f-e202-0101   2         EVI-link1, EVI-link2
# 显示EVI隧道接口Tunnel101下的远端MAC地址信息的数目。
<Sysname> display evi mac-address interface tunnel 101 count
Total entries: 2
表1-10 display evi mac-address命令显示信息描述表
MAC Address
远端MAC地址
VLAN ID
远端MAC地址所属VLAN
Port
到达远端MAC地址的EVI-Link的出端口(N/A表示出端口无效,已被删除)
Total entries
远端MAC地址信息的数目
display evi neighbor-discovery client member命令用来在ENDC上显示ENDC学到的邻居信息。
display evi neighbor-discovery client member [ interface tunnel interface-number | [ local local-ip | remote client-ip | server server-ip ] [ vpn-instance vpn-instance-name ] ]
interface tunnel interface-number:显示通过指定EVI隧道接口学到的邻居信息。
local local-ip:显示通过指定IPv4地址对应的EVI隧道接口学到的邻居信息。local-ip表示本地ENDC的IPv4地址。
remote client-ip:显示设备学到的指定邻居ENDC的信息。client-ip表示邻居ENDC的IPv4地址。
server server-ip:显示通过指定ENDS学到的邻居信息。server-ip表示ENDS的IPv4地址。
vpn-instance vpn-instance-name:显示ENDC学到的指定VPN实例的邻居信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示ENDC学到的所有邻居信息。
通过本命令可以查看ENDC学到的邻居信息,包括邻居的IP地址、桥MAC地址、创建时间、老化时间、邻居之间的EVI Link状态等信息。
如果不指定任何参数,将显示设备上本地ENDC学到的所有邻居信息。
# 显示设备上ENDC学到的所有IPv4邻居信息。
<Sysname> display evi neighbor-discovery client member
Interface: Tunnel1    Network ID: 1    Vpn-instance: vpn1
Local Address: 20.0.0.2
Server Address: 20.0.1.1
Neighbor        System ID         Created Time           Expire    Status
20.0.2.1        000F-0000-0A3E    2015/01/01 12:12:12    13        Up
20.0.3.1        000F-0000-0A3F    2015/01/01 12:12:12    12        Up
Server Address: 20.0.1.2
20.0.2.1        000F-0000-0A3E    2015/01/01 12:12:12    25        Up
20.0.3.1        000F-0000-0A3F    2015/01/01 12:12:12    19        Up
Interface: Tunnel2    Network ID: 2    Vpn-instance: [No Vrf]
Local Address: 21.0.0.1
Server Address: 21.0.1.2
21.0.2.1        000F-0000-0A3E    2015/01/01 12:12:12    25        Up
21.0.3.1        000F-0000-0A3F    2015/01/01 12:12:12    19        Down
Interface: Tunnel3    Network ID: 3    Vpn-instance: [No Vrf]
Local Address: 21.0.0.2
Server Address: NA
21.0.2.1        NA                2015/01/01 12:12:12    25        Up
21.0.3.1        NA                2015/01/01 12:12:12    19        Up
# 显示ENDC学到的指定EVI隧道接口的邻居信息。
<Sysname> display evi neighbor-discovery client member interface tunnel 2
Local Address: 10.1.1.1
Server Address: 10.1.1.1
10.1.1.2        000f-e20e-0817    2014/08/14 09:59:44    62        Up
# 显示指定ENDS指定VPN实例学到的邻居信息。
<Sysname> display evi neighbor-discovery client member server 10.1.1.1 Vpn-instance vpn1
10.1.1.2        000f-e20e-0817    2014/08/14 09:58:59    73        Up
表1-11 display evi neighbor-discovery client member命令显示信息描述表
启动ENDC功能的接口名称
Network ID
配置的Network ID
Vpn-instance
EVI隧道关联的VPN实例
Local Address
EVI隧道的源端地址
Server Address
ENDS的IP地址,NA表示ENDS未知
Neighbor
通过ENDS学到的邻居IP
System ID
邻居的桥MAC地址,NA表示桥MAC地址未知
Created Time
邻居创建的时间
Expire
邻居的老化时间,单位为秒
Status
与邻居之间EVI Link的状态:
·     Up:表示可以通过EVI Link进行传输
·     Down:表示不可以通过EVI Link进行传输
·     NA:表示尚未创建EVI Link
display evi neighbor-discovery client statistics命令用来显示使能ENDC功能的接口收到和发送ENDP报文的统计信息。
display evi neighbor-discovery client statistics interface tunnel interface-number
interface tunnel interface-number:显示指定EVI隧道接口收到和发送ENDP报文的统计信息。
# 显示IPv4 EVI隧道接口Tunnel1收到和发送ENDP报文的统计信息。
<Sysname> display evi neighbor-discovery client statistics interface tunnel 1
Server Address: 10.0.0.1    Vpn-instance: vpn1
Received packets:
  Reply:        170              Error:      1
Sent packets:
  Register:     170              Purge:      0
Server Address: 10.0.0.2    Vpn-instance: vpn1
Received packets:
  Reply:        99               Error:      1
Sent packets:
  Register:     100              Purge:      0
表1-12 display evi neighbor-discovery client statistics命令显示信息描述表
Server Address
ENDC对应的ENDS的IP地址
Vpn-instance
EVI隧道关联的VPN实例
Received packets
ENDC收到的报文统计信息:
·     Reply:表示注册应答报文
·     Error:表示错误指示报文
Sent packets
ENDC发送的报文统计信息:
·     Register:表示注册报文
·     Purge:表示注销报文
display evi neighbor-discovery client summary命令用来显示ENDC的配置信息以及ENDC与ENDS的连接状态。
# 显示IPv4 ENDC的运行信息。
<Sysname> display evi neighbor-discovery client summary
                         Status: I-Init  E-Establish  P-Probe
Interface    Local Address   Server Address  Network ID  Reg  Auth      Status Vpn-instance
Tunnel1      20.0.0.2        20.0.0.1        1           15   enabled   E      Vpn1
Tunnel1      20.0.0.2        20.0.0.3        1           15   enabled   P      [No Vrf]
Tunnel2      21.0.0.2        21.0.0.1        2           15   disabled  P      [No Vrf]
表1-13 display evi neighbor-discovery client summary命令显示信息描述表
启动ENDC功能的接口名称
Local Address
本地EVI隧道接口的源端地址,NA表示未配置
Server Address
配置的远端ENDS的地址
Network ID
配置的Network ID,NA表示未配置
Reg
注册时间间隔
Auth
是否使能认证功能:
·     enabled:表示已使能
·     disabled:表示未使能
Status
ENDC与ENDS的连接状态:
·     I:表示初始状态
·     E:表示已建立连接
·     P:表示未建立连接正在探测
Vpn-instance
EVI隧道关联的VPN实例
·     evi neighbor-discovery authentication
·     evi neighbor-discovery client enable
·     evi neighbor-discovery client register-interval
display evi neighbor-discovery server member命令用来在ENDS上显示ENDS学到的成员信息。
display evi neighbor-discovery server member [ interface tunnel interface-number | [ local local-ip | remote client-ip ] [ vpn-instance vpn-instance-name ] ]
interface tunnel interface-number:显示通过指定EVI隧道接口学到的成员信息。
local local-ip:显示通过指定ENDS学到的成员信息。local-ip表示本地ENDS的IPv4地址。
remote client-ip:显示ENDS学到的指定IPv4地址的成员信息。client-ip表示ENDC的IPv4地址。
vpn-instance vpn-instance-name: 显示ENDS学到的指定VPN实例的成员信息。 vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示ENDS学到的所有成员信息。
通过本命令可以查看ENDS学到的成员信息,包括成员的IPv4地址、桥MAC地址、创建时间、老化时间等信息。
如果不指定任何参数,将显示设备上ENDS学到的所有成员信息。
# 显示设备上ENDS学到的所有IPv4成员信息。
<Sysname> display evi neighbor-discovery server member
IP Address: 11.0.0.1
Client Address  System ID         Expire    Created Time
11.0.0.3        000F-0001-0001    25        2015/01/01 00:00:43
11.0.0.4        000F-0001-0002    15        2015/01/01 01:00:46
11.0.0.5        000F-0001-0003    20        2015/01/01 01:02:13
IP Address: 11.0.1.2
11.0.1.3        000F-0001-0011    19        2015/01/01 00:19:31
11.0.1.4        000F-0001-0012    30        2015/01/01 02:00:43
11.0.1.5        000F-0001-0013    20        2015/01/01 01:02:13
IP Address: 12.0.0.1
12.0.0.2        000F-0002-0001    30        2015/01/01 03:20:43
12.0.0.3        000F-0002-0002    37        2015/01/01 03:27:46
# 显示ENDS学到的指定EVI隧道接口的成员信息。
<Sysname> display evi neighbor-discovery server member interface tunnel 1
IP Address: 10.1.1.1
10.1.1.1        000f-e20e-0811    66        2014/08/13 18:44:13
10.1.1.2        000f-e20e-0817    69        2014/08/14 09:58:47
# 显示ENDS学到的指定IPv4地址指定VPN实例的成员信息。
<Sysname> display evi neighbor-discovery server member remote 10.1.1.1 Vpn-instance vpn1
10.1.1.1        000f-e20e-0811    61        2014/08/13 18:44:13
表1-14 display evi neighbor-discovery server member命令显示信息描述表
启动ENDS功能的接口名称
Network ID
配置的Network ID
Vpn-instance
EVI隧道关联的VPN实例
IP Address
ENDS的IP地址
Client Address
学到的成员的IP地址
System ID
学到的成员的桥MAC地址
Expire
成员的剩余老化时间
Created Time
成员的创建时间
display evi neighbor-discovery server statistics命令用来显示使能ENDS功能的接口收到和发送ENDP报文的统计信息。
display evi neighbor-discovery server statistics interface tunnel interface-number
<Sysname> display evi neighbor-discovery server statistics interface tunnel 1
Received packets:
  Register:     170              Purge:      13
Sent packets:
  Reply:        170              Error:      1
表1-15 display evi neighbor-discovery server statistics命令显示信息描述表
Received packets
ENDS收到的报文统计信息:
·     Register:表示注册报文
·     Purge:表示注销报文
Sent packets
ENDS发送的报文统计信息:
·     Reply:表示注册应答报文
·     Error:表示错误指示报文
display evi neighbor-discovery server summary命令用来显示ENDS的运行信息。
通过本命令可以查看ENDS的运行信息,包括ENDS的配置信息、通过该ENDS学习到的ENDC个数。
# 显示IPv4 ENDS的运行信息。
<Sysname> display evi neighbor-discovery server summary
Interface      Local Address   Network ID    Auth        Members   Vpn-instance
Tunnel1        20.0.0.1        1             enabled     10        vpn1
Tunnel2        21.0.0.1        2             disabled    20        [No Vrf]
Tunnel3        22.0.0.1        NA            disabled    0         [No Vrf]
表1-16 display evi neighbor-discovery server summary命令显示信息描述表
启动ENDS功能的接口名称
Local Address
接口的源端地址,NA表示未配置
Network ID
接口下配置的Network ID,NA表示未配置
Auth
是否使能认证功能:
·     enabled:表示已使能
·     disabled:表示未使能
Members
通过该ENDS学习到的ENDC个数
Vpn-instance
EVI隧道关联的VPN实例
·     evi neighbor-discovery server enable
display interface evi-link命令用来显示EVI-Link接口的相关信息。
display interface [ evi-link [ interface-number ] ] [ brief [ description | down ] ]
evi-link [ interface-number ]:显示指定EVI-Link接口的信息。interface-number表示EVI-Link接口编号,取值为已创建的EVI-Link接口的编号。如果只指定evi-link参数将显示所有已创建的EVI-Link接口的相关信息。如果不指定evi-link参数,将显示设备支持的所有接口的相关信息。
brief:显示接口的概要信息。如果不指定该参数,则显示接口的详细信息。
本命令可以显示EVI-Link接口的相关信息,包括缺省VLAN ID、链路类型、EVI隧道源端地址、EVI隧道目的端地址、Network ID等。
# 显示接口EVI-Link0的详细信息。
<Sysname> display interface evi-link 0
EVI-Link0
Current state: UP
Description: EVI-Link0 Interface
PVID: 1
Port link-type: Trunk
 VLAN Passing:   None
 VLAN permitted: None
 Trunk port encapsulation:  IEEE 802.1q
This EVI-Link belongs to Tunnel1
Source 1.1.1.1, Destination 1.1.2.1
Network ID 1
表1-17 display interface evi-link命令显示信息描述表
Current state
接口的物理状态,可能的取值及含义如下:
·     DOWN:该接口的物理状态为关闭
·     UP:该接口的物理状态为开启
接口的描述信息
PVID
EVI-Link接口的缺省VLAN
Port link-type: trunk
EVI-Link接口的链路类型为Trunk
VLAN Passing
Trunk口实际可以通过的VLAN(该VLAN已经创建,并且接口允许其通过),对于EVI-Link接口来说,始终显示None
VLAN permitted
Trunk口允许通过的VLAN(该VLAN不一定存在,可能没有创建),对于EVI-Link接口来说,始终显示None
Trunk口上封装的协议类型
EVI-Link接口所属的EVI隧道实例
Source
EVI-Link接口的EVI隧道本端地址
Destination
EVI-Link接口的EVI隧道对端地址
Network ID
EVI-Link接口所属的Network ID
最近300秒钟的平均输入速率:bytes/sec表示平均每秒输入的字节数,bits/sec表示平均每秒输入的比特数,packets/sec表示平均每秒输入的包数
最近300秒钟的平均输出速率:bytes/sec表示平均每秒输出的字节数,bits/sec表示平均每秒输出的比特数,packets/sec表示平均每秒输出的包数
总计输入的报文数,总计输入的字节,总计丢弃的输入报文数
总计输出的报文数,总计输出的字节,总计丢弃的输出报文数
# 显示接口EVI-Link0的概要信息。
<Sysname> display interface evi-link 0 brief
Speed: (a) - auto
EVI0                 UP   --      --     T    1
# 显示当前物理状态为down的EVI-Link接口的信息以及down的原因。
<Sysname> display interface evi-link brief down
Interface            Link   Cause
EVI0                 DOWN   Not connected
表1-18 display interface evi-link brief命令显示信息描述表
Brief information on interface(s) under bridge mode
二层接口的概要信息
接口的Link属性值:
·     如果接口的Link属性值为“ADM”,则表示该接口被管理员通过shutdown命令关闭,需要在该接口下执行undo shutdown命令才能恢复接口本身的物理状态
·     如果接口的Link属性值为“Stby”,则表示该接口是一个处于Standby状态的备份接口,使用display interface-backup state命令可以查看该备份接口对应的主接口
Speed: (a) - auto
如果接口的Speed属性值为“(a)”,则表示该接口的速率是通过自动协商获取的
如果接口的Speed属性值为“auto”,则表示该接口的速率是通过自动协商获取的,但协商还未开始
如果接口的Duplex属性值为“(a)”或者“A”,则表示该接口的Duplex属性是通过自动协商获取的;取值为“H”则表示为半双工;取值为“F”则表示为全双工
当显示为“A”时表示该接口的Duplex属性是通过自动协商获取的,但协商还未开始
接口的链路类型:
·     A:表示Access链路类型
·     T:表示Trunk链路类型
·     H:表示Hybrid链路类型
接口名称缩写
Link
接口物理连接状态,取值可能为:
·     UP:表示接口物理上是连通的
·     DOWN:表示接口物理上不通
·     ADM:表示接口被管理员通过shutdown命令关闭,需要执行undo shutdown命令才能恢复接口本身的物理状态
·     Stby:表示该接口是一个处于Standby状态的备份接口
Speed
接口的速率,单位为bps
Duplex
接口的双工模式,取值为:
·     A:表示双工模式由自动协商结果决定
·     F:表示全双工
·     F(a):表示自由协商的结果为全双工
·     H:表示半双工
·     H(a):表示自由协商的结果为半双工
接口的链路类型:
·     A:表示Access链路类型
·     H:表示Hybrid链路类型
·     T:表示Trunk链路类型
PVID
接口的缺省VLAN ID
用户通过description命令给接口配置的描述信息。使用display interface brief命令,不指定description参数时,该字段最多显示27个字符;指定description参数时,可显示配置的全部描述信息
Cause
接口物理连接状态为down的原因,取值为:
·     Administratively:表示本链路被手工关闭了(配置了shutdown命令),需要执行undo shutdown命令才能恢复真实的物理状态
·     Not connected:表示没有物理连接(可能没有插网线或者网线故障)
evi arp-suppression enable命令用来开启EVI ARP泛洪抑制功能。
undo evi arp-suppression enable命令用来关闭EVI ARP泛洪抑制功能。
EVI ARP泛洪抑制功能处于关闭状态。
Tunnel接口视图
EVI ARP泛洪抑制功能可以大大减少ARP泛洪的次数。
边缘设备通过侦听EVI隧道终结的流量建立EVI ARP泛洪抑制表项,当侦听到本站点内主机请求其它站点主机的ARP请求时,优先根据EVI ARP泛洪抑制表项进行代答,没有表项的则将ARP请求泛洪到公网。
# 在EVI隧道接口Tunnel101下开启EVI ARP泛洪抑制功能。
[Sysname] interface tunnel 101 mode evi
[Sysname-tunnel 101] evi arp-suppression enable
·     display evi arp-suppression
·     mac-address timer(二层技术-以太网交换命令参考/MAC地址表)
1.1.19  evi enable
evi enable命令用来开启接口的EVI功能。
undo evi enable命令用来关闭接口的EVI功能。
evi enable
undo evi enable
接口的EVI功能处于关闭状态。
二层以太网接口视图
三层以太网接口视图
用户需要在EVI公网侧接口上开启EVI功能。
# 开启接口Ten-GigabitEthernet1/0/1的EVI功能。
[Sysname-Ten-GigabitEthernet1/0/1] evi enable
evi extend-vlan命令用来配置扩展VLAN。
undo evi extend-vlan命令用来取消指定的扩展VLAN。
evi extend-vlan vlan-list
undo evi extend-vlan vlan-list
未配置扩展VLAN。
Tunnel接口视图
vlan-list:VLAN列表,指定了扩展VLAN的范围。表示方式为vlan-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>vlan-id取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以输入10次。
# 配置扩展VLAN为1~10、15和100~200。
[Sysname-tunnel101] evi extend-vlan 1 to 10 15 100 to 200
evi flooding enable命令用来开启EVI泛洪功能。
undo evi flooding enable命令用来关闭EVI泛洪功能。
evi flooding enable
EVI泛洪功能处于关闭状态。边缘设备对于未知地址的帧(包括未知单播帧和未知组播帧)只在VLAN内的站点内部接口上进行泛洪,不会泛洪到其它站点。
Tunnel接口视图
开启EVI泛洪功能后,边缘设备会将所有目的地址未知的帧泛洪到其他站点。
evi flooding enable命令和evi selective-flooding mac-address命令的区别如下:
·     evi flooding enable命令是将所有的未知单播帧和未知组播帧都向其它站点泛洪。
·     evi selective-flooding mac-address命令是针对某业务的MAC地址放开限制,仅将配置的MAC地址在指定的VLAN范围内向其它站点泛洪。
上述两个命令的使用场景不同,建议用户不要同时配置。如果用户同时配置了这两条命令,系统实际执行的是evi flooding enable命令,无法实现evi selective-flooding mac-address命令的控制效果。
# 在EVI隧道接口Tunnel101下开启EVI泛洪功能。
[Sysname-tunnel 101] evi flooding enable
evi isis ded-priority命令用来在EVI隧道接口上配置DED优先级。
undo evi isis ded-priority命令用来恢复缺省情况。
evi isis ded-priority priority
DED优先级为64。
Tunnel接口视图
priority:DED优先级,取值范围为0~127。
DED分为站点内DED和站点间DED。
站点内DED的选举方式:站点内的各边缘设备通过交互EVI IS-IS Hello报文来选举站点内DED。由站点内DED来分配各边缘设备的激活VLAN。
站点间DED的选举方式:每个EVI Link两端的边缘设备通过交互EVI IS-IS Hello报文选举出一个站点间DED。站点间的边缘设备通过站点间DED周期性发布CSNP报文来进行LSDB同步。
DED优先级数值越高,被选中的可能性就越大;如果两台边缘设备的DED优先级相同,则MAC地址较大的边缘设备会被选中。
# 配置EVI隧道接口Tunnel101的DED优先级为2。
[Sysname-tunnel101] evi isis ded-priority 2
·     display evi isis tunnel
evi isis timer csnp命令用来配置DED发送CSNP报文的时间间隔。
undo evi isis timer csnp命令用来恢复缺省情况。
evi isis timer csnp seconds
DED发送CSNP报文的时间间隔为10秒。
Tunnel接口视图
seconds:DED发送CSNP报文的时间间隔,取值范围为1~600,单位为秒。
站点间DED使用CSNP报文来进行LSDB同步,只有在被选举为DED的设备上进行该项配置才有效。
# 配置DED发送CSNP报文的时间间隔为15秒。
[Sysname-tunnel101] evi isis timer csnp 15
evi isis timer hello命令用来配置EVI IS-IS Hello报文的发送时间间隔。
undo evi isis timer hello命令用来恢复缺省情况。
evi isis timer hello seconds
EVI IS-IS Hello报文的发送时间间隔为10秒。
Tunnel接口视图
seconds:配置EVI IS-IS Hello报文的发送时间间隔,取值范围为3~255,单位为秒。
EVI IS-IS Hello报文的发送时间间隔越短,网络收敛越快,但也需要占用更多的系统资源;因此,需要根据实际情况指定EVI IS-IS Hello报文的发送时间间隔。
DED发送EVI IS-IS Hello报文的时间间隔是evi isis timer hello命令设置的时间间隔的1/3。
# 配置EVI IS-IS Hello报文的发送时间间隔为6秒。
[Sysname-tunnel101] evi isis timer hello 6
evi isis timer holding-multiplier命令用来配置EVI IS-IS Hello报文失效数目。
undo evi isis timer holding-multiplier命令用来恢复缺省情况。
evi isis timer holding-multiplier value
EVI IS-IS Hello报文失效数目为3。
Tunnel接口视图
value:配置邻居的EVI IS-IS Hello报文失效数目,取值范围为3~1000。
当前边缘设备可以将邻接关系保持时间通过EVI IS-IS Hello报文通知邻居边缘设备,如果邻居边缘设备在邻接关系保持时间内没有收到来自当前边缘设备的EVI IS-IS Hello报文,将宣告邻接关系失效。
邻接关系保持时间的计算方法为:
·     没有使能GR能力时,为EVI IS-IS Hello报文失效数目与EVI IS-IS Hello报文发送时间间隔的乘积。
·     使能GR能力时,取以下二者间的较大值:EVI IS-IS Hello报文失效数目与EVI IS-IS Hello报文发送时间间隔的乘积(如果是DED,该乘积还要除以3)、GR重启间隔时间。
EVI IS-IS Hello报文失效数目,即宣告邻接关系失效前EVI IS-IS没有收到的邻居EVI IS-IS Hello报文的数目。通过设置EVI IS-IS Hello报文失效数目和EVI IS-IS Hello报文的发送时间间隔,可以调整邻接关系保持时间,即邻居边缘设备要花多长时间能够监测到链路已经失效并重新进行路由计算。
邻接关系保持时间最大不能超过65535秒,超过65535秒时,算作65535秒。
# 配置EVI IS-IS Hello报文失效数目为6。
[Sysname-tunnel101] evi isis timer holding-multiplier 6
·     evi isis timer hello
evi isis timer lsp命令用来配置EVI IS-IS在接口上发送LSP的最小时间间隔以及一次最多可以发送的LSP数目。
undo evi isis timer lsp命令用来恢复缺省情况。
evi isis timer lsp time [ count count ]
发送LSP的最小时间间隔为100毫秒,一次最多可以发送的LSP数目为5。
Tunnel接口视图
time:发送LSP的最小时间间隔,取值范围为100~1000,为100的整数倍,单位为毫秒。
count count:一次最多可以发送的LSP数目,取值范围为1~1000,缺省值为5。
当LSDB的内容发生变化时,EVI IS-IS将把发生变化的LSP扩散出去,用户可以对LSP的最小发送时间间隔进行调节。
# 配置发送LSP的最小时间间隔为500毫秒。
[Sysname-tunnel101] evi isis timer lsp 500
·     display evi isis brief
evi isis track命令用来配置EVI IS-IS关联的Track项。
undo evi isis track命令用来删除EVI IS-IS关联的Track项。
evi isis track track-entry-number
undo evi isis track
EVI IS-IS不与任何Track项联动。
Tunnel接口视图
track-entry-number:指定Track项的序号,取值范围为1~1024。
一个Tunnel接口下的EVI IS-IS实例最多关联一个Track项,当配置多次时,最后配置的Track项生效。关于Track的详细介绍请参见“可靠性配置指导”中的“Track”。
EVI IS-IS通过Track与BFD联动来检测本地站点通过核心网到达远端站点之间的链路的工作状态。
Track模块通知EVI IS-IS的监测结果有三种:
·     Positive:本地站点通过核心网到达远端站点之间的链路可达时,状态为Positive,表示核心网侧未发生故障。
·     Negative:本地站点通过核心网到达远端站点之间的链路不可达时,状态为Negative,表示核心网侧发生故障。
·     NotReady:Track模块尚未准备就绪,无法检测本地站点通过核心网到达远端站点之间的链路时,状态为NotReady,此时核心网侧是否发生故障由慢Hello机制决定。
# 配置EVI隧道接口Tunnel101上运行的EVI IS-IS关联Track项1。
[Sysname-tunnel101] evi isis track 1
evi neighbor-discovery authentication命令用来使能ENDP认证功能。
undo evi neighbor-discovery authentication命令用来关闭ENDP认证功能。
evi neighbor-discovery authentication { cipher | simple } string
ENDP认证功能处于关闭状态。
Tunnel接口视图
cipher:以密文方式设置密钥。
simple:以明文方式设置密钥,该密钥将以密文形式存储。
string:密钥字符串,区分大小写。明文密钥为1~24个字符的字符串,密文密钥为1~65个字符的字符串。
为了安全起见,可以配置ENDP认证功能来防止恶意的节点注册到EVI网络。
在一个安全的网络中,可以不配置ENDP认证功能。
同一个EVI网络实例中所有的ENDS与ENDC必须配置相同的认证密钥。
# 使能ENDP认证功能,并以方式设置指定明文认证密钥为web-evi。
<Sysname> system
[Sysname] interface tunnel 1 mode evi
[Sysname-Tunnel1] evi neighbor-discovery authentication simple web-evi
·     display evi neighbor-discovery client summary
·     display evi neighbor-discovery server summary
evi neighbor-discovery client enable命令用来使能接口的ENDC功能,同时指定对应的ENDS地址。
undo evi neighbor-discovery client enable命令用来删除指定的ENDS地址或关闭接口的ENDC功能。
evi neighbor-discovery client enable server-ip
undo evi neighbor-discovery client enable server-ip
ENDC功能处于关闭状态。
Tunnel接口视图
server-ip:ENDC要连接的ENDS的IP地址。
为了防止ENDS异常导致ENDC不能加入EVI网络,用户可以为每个ENDC指定两个ENDS,这两个ENDS同时有效。
同一个EVI网络实例中,建议所有的ENDC上配置相同的ENDS。
# 使能IPv4 ENDC功能,该ENDC对应的ENDS地址为11.0.0.1。
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery client enable 11.0.0.1
evi neighbor-discovery client register-interval命令用来在EVI隧道接口上配置ENDC向ENDS注册的时间间隔。
undo evi neighbor-discovery client register-interval命令用来恢复缺省情况。
evi neighbor-discovery client register-interval interval
ENDC向ENDS注册的时间间隔为15秒。
Tunnel接口视图
interval:注册时间间隔,取值范围为5~120,单位为秒。
ENDP协议中用到了3个定时器:探测定时器、注册定时器、老化定时器。
(1)     探测定时器
ENDC请求加入EVI网络时会启用探测定时器,该定时器以5秒的时间间隔定时向ENDS发送注册报文,收到ENDS应答报文后会停止探测定时器。
(2)     注册定时器
ENDC加入EVI网络后,为了通告自己工作正常,会定时向ENDS发送注册报文,该定时器的默认时间间隔为15秒,用户可以通过配置evi neighbor-discovery client register-interval命令来调整该时间间隔。
如果ENDC连续发送5个注册报文,都未能收到ENDS的应答报文,则认为网络故障,此时需要清除之前学到的邻居信息,同时重新启用探测定时器。
(3)     老化定时器
ENDC向ENDS发送的注册报文中携带注册时间间隔,ENDS会记录该时间间隔。
ENDC加入EVI网络后,如果ENDS在5倍的注册时间内未收到ENDC的注册报文则认为ENDC出现故障,此时需要把ENDC从EVI网络中删除。
# 配置ENDC向ENDS注册的时间间隔为30秒。
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery client register-interval 30
evi neighbor-discovery server enable命令用来使能EVI隧道接口的ENDS功能。
undo evi neighbor-discovery server enable命令用来关闭EVI隧道接口的ENDS功能。
ENDS功能处于关闭状态。
Tunnel接口视图
使能接口的ENDS功能时,会同时使能该接口的ENDC功能(该ENDC对应的ENDS地址为该接口的源地址)。用户也可以通过evi neighbor-discovery server enable命令修改该ENDC向ENDS注册的时间间隔。
# 使能IPv4 ENDS功能。
<Sysname> system
[Sysname-Tunnel1] evi neighbor-discovery server enable
evi network-id命令用来配置EVI隧道接口的Network ID。
undo evi network-id命令用来删除EVI隧道接口的Network ID。
evi network-id number
undo evi network-id
未配置EVI隧道接口的Network ID。
Tunnel接口视图
number:Network ID值,取值范围为1~16777215。
一个站点需要加入EVI网络时,必须指定加入的EVI网络实例的Network ID。
一个EVI隧道只能属于一个EVI网络实例,一个站点加入多个EVI网络实例时,需要创建多个EVI Tunnel接口,并使用该命令指定多个EVI Tunnel接口分别属于哪个EVI网络实例。
同一个EVI实例中,所有边缘设备的EVI隧道接口上指定的Network ID必须相同。
# 配置EVI隧道接口的Network ID为123。
[Sysname-Tunnel1] evi network-id 123
·     interface tunnel
evi selective-flooding mac-address命令用来配置选择性泛洪的MAC地址。
undo evi selective-flooding mac-address命令用来删除指定的选择性泛洪的MAC地址。
evi selective-flooding mac-address mac-address vlan vlan-id-list
undo evi selective-flooding mac-address mac-address vlan vlan-id-list
未配置选择性泛洪的MAC地址。边缘设备对于未知地址的帧(包括未知单播帧和未知组播帧)只在VLAN内的站点内部接口上进行泛洪,不会泛洪到其它站点。
Tunnel接口视图
mac-address:选择性泛洪的MAC地址。该MAC地址不能为全F。
vlan vlan-id-list:指定选择性泛洪MAC地址所属的VLAN范围,vlan-id-list = { vlan-id1 [ to vlan-id2 ] }&<1-10>vlan-id的取值范围为1~4094,vlan-id2的值要大于或等于vlan-id1的值,&<1-10>表示前面的参数最多可以输入10次。
不要将可以学习到的单播MAC地址设置为选择性泛洪的MAC地址,否则可能会导致报文在远端设备被丢弃。
缺省情况下,边缘设备对于未知地址的帧(包括未知单播帧和未知组播帧)只在VLAN内的站点内部接口上进行泛洪,不会泛洪到其它站点。如果用户希望某些MAC地址的帧可以泛洪到其它站点,可以通过本命令配置选择性泛洪的MAC地址,当报文的目的MAC地址匹配该MAC地址且报文中的VLAN是激活VLAN时,报文可以通过EVI隧道泛洪转发到其它站点。
选择性泛洪MAC地址所属的VLAN范围受到EVI Tunnel接口下激活VLAN的范围影响,最终生效的VLAN范围为激活VLAN和配置指定的VLAN之交集。
# 在EVI隧道接口Tunnel101下配置选择性泛洪的MAC地址。
[Sysname-tunnel 101] evi selective-flooding mac-address 000f-e201-0101 vlan 1 to 10
1.1.34  evi site-id
evi site-id命令用来指定一个设备所属的站点ID。
undo evi site-id命令用来恢复缺省情况。
evi site-id site-id
undo evi site-id
站点ID为0。
site-id:站点ID,取值范围为1~65535。
站点ID用来唯一标识边缘设备所处的站点。如果没有为边缘设备配置站点ID(采用缺省站点ID 0),则其他边缘设备认为该设备为站点间边缘设备。相同站点内的多台边缘设备必须配置相同的站点ID,不同站点间的边缘设备必须配置不同的站点ID或者均采用缺省站点ID。
为了避免站点ID冲突,请按照如下规则进行配置:
·     当两台设备均在本地站点时,必须为设备配置相同的站点ID,但不能使用缺省站点ID。
·     当两台设备分处在不同站点时,必须配置不同的站点ID,或者均采用缺省站点ID。
当站点ID冲突时,会将桥MAC地址较小的设备隔离,此处的隔离是针对EVI IS-IS协议来说的,被隔离的设备对于EVI IS-IS Hello报文将进行只收不发的处理,对于其它EVI IS-IS协议报文将不会进行交互。设备被隔离的情况可以通过display evi isis brief命令和display evi isis peer命令查看。
# 配置设备所属的站点ID为201。
[Sysname] evi site-id 201
·     display evi-isis brief
·     display evi isis peer
1.1.35  evi-isis
evi-isis命令用来创建EVI IS-IS进程,并进入EVI IS-IS视图。
undo evi-isis命令用来删除EVI IS-IS进程或者清除EVI IS-IS进程下的配置数据。
evi-isis process-id
undo evi-isis process-id
不存在EVI IS-IS进程。
process-id:EVI IS-IS的进程ID,取值范围为0~65535。
一个EVI实例对应一个EVI IS-IS进程。
创建EVI IS-IS进程有如下两种方法:
·     在EVI Tunnel接口下配置可以创建EVI IS-IS进程的配置项。此时会自动创建EVI IS-IS进程,其进程ID与EVI Tunnel接口号相同。
·     执行evi-isis命令。此时该EVI IS-IS进程与相同编号的EVI Tunnel接口相对应。
创建EVI IS-IS进程后,用户可以通过evi-isis命令进入EVI IS-IS视图,配置EVI IS-IS进程的协议参数。
用户需要配置扩展VLAN,对应的EVI IS-IS进程才能生效。
删除通过evi-isis命令创建的EVI IS-IS进程的时机如下:
·     如果EVI IS-IS进程对应的EVI Tunnel接口存在EVI IS-IS配置项,则执行undo evi-isis命令时不会删除进程,只会清除进程下的配置数据。
·     如果EVI IS-IS进程对应的EVI Tunnel接口下不存在EVI IS-IS配置项,则执行undo evi-isis命令时会删除进程,并清除进程下的配置数据。
对于自动创建的EVI IS-IS进程,删除EVI Tunnel接口下的EVI IS-IS配置项时会自动删除对应的EVI IS-IS进程。
# 进入EVI IS-IS视图。
[Sysname] evi-isis 101
[Sysname-evi-isis-101]
filter-policy命令用来配置EVI IS-IS进程绑定的路由策略。
undo filter-policy命令用来删除EVI IS-IS进程绑定的路由策略。
filter-policy policy-name
undo filter-policy
EVI IS-IS进程没有绑定路由策略。
EVI IS-IS视图
policy-name:路由策略名称,为1~63个字符的字符串,区分大小写。
绑定路由策略后,该EVI IS-IS进程只向其它站点通告路由策略允许的站点本地MAC地址信息。
EVI IS-IS进程绑定的路由策略的配置中仅有如下两类匹配条件生效:
·     MAC地址列表过滤的匹配条件
·     VLAN范围的匹配条件
关于路由策略的详细介绍请参见“三层技术-IP路由配置指导”中的“路由策略”。
# 配置EVI IS-IS进程绑定路由策略EVI-Filter。
[Sysname-evi-isis-101] filter-policy EVI-Filter
graceful-restart命令用来使能EVI IS-IS进程的GR能力。
undo graceful-restart命令用来关闭EVI IS-IS进程的GR能力。
graceful-restart
EVI IS-IS进程的GR能力处于关闭状态。
EVI IS-IS进程视图
为了保证EVI IS-IS重启或主备倒换时转发业务不中断,需要在EVI隧道两端的邻居上使能EVI IS-IS进程的GR能力。
# 使能EVI IS-IS进程101的GR能力。
[Sysname-evi-isis-101] graceful-restart
·     display evi isis graceful-restart status
graceful-restart interval命令用来配置EVI IS-IS协议的GR重启间隔时间。
EVI IS-IS协议的GR重启间隔时间为300秒。
EVI IS-IS视图
interval:指定EVI IS-IS协议的GR重启间隔时间(期望重启时间),取值范围为30~1800,单位为秒。
# 配置EVI IS-IS进程1的GR重启间隔时间为120秒。
[Sysname-evi-isis-1] graceful-restart interval 120
gre key vlan-id命令用来设置EVI类型Tunnel接口为发送的报文中添加根据VLAN ID生成的GRE Key。
undo gre key命令用来恢复缺省情况。
gre key vlan-id
undo gre key
EVI类型Tunnel接口发送的报文中不携带GRE Key。
Tunnel接口视图
通过设置EVI类型Tunnel接口发送报文时携带GRE Key后,发送方会在其发送的报文中携带GRE Key信息。接收方收到报文后将报文中的GRE Key与接收方本地配置的GRE Key进行比较,如果一致则对报文进行进一步处理;否则丢弃该报文。这样就可以防止设备接收非法报文。因此为保证通信正常,隧道两端必须设置相同的GRE Key,或者都不设置GRE Key。
部分产品发送报文时,报文中的GRE Key字段携带了VLAN ID。设备在与这些产品通信时需要配置本命令,使发出报文中的GRE Key字段也携带VLAN ID。
# 设置EVI类型Tunnel接口为发送的报文添加根据VLAN ID生成的GRE Key。
[Sysname-Tunnel2] gre key vlan-id
·     display interface tunnel
1.1.40  keepalive
keepalive命令用来配置EVI隧道探测对端状态的keepalive报文的发送周期和最大发送次数。
undo keepalive命令用来恢复缺省情况。
keepalive [ seconds [ times ] ]
undo keepalive
keepalive报文的发送周期为5秒,最大发送次数为2次。
Tunnel接口视图
seconds:keepalive报文发送周期,取值范围为1~32767,单位为秒。
times:keepalive报文的最大发送次数,取值范围为1~255。
设备会从基于EVI Tunnel建立的各个EVI-Link接口周期性发送keepalive报文。
如果超时时间(即配置的keepalive报文发送周期)内没有收到对端的回应,则本端重新发送keepalive报文。
如果达到最大发送次数后仍然没有收到对端的回应,则把本端EVI-Link接口的状态置为down。如果EVI-Link接口为down状态,当收到对端回复的keepalive确认报文或收到对端发送的keepalive报文时,EVI-Link接口的状态将转换为up,否则保持down状态。
# 配置keepalive报文的发送周期为20秒,最大发送次数为5次。
[Sysname-Tunnel1] keepalive 20 5
·     interface tunnel
log-peer-change enable命令用来打开邻接状态变化的输出开关。
undo log-peer-change enable命令用来关闭邻接状态变化的输出开关。
邻接状态变化的输出开关处于打开状态。
EVI IS-IS视图
当打开邻接状态变化的输出开关后,EVI IS-IS邻接状态变化时会生成日志信息发送到设备的信息中心,通过设置信息中心的参数,最终决定日志信息的输出规则(即是否允许输出以及输出方向)。有关信息中心参数的配置请参见“网络管理和监控配置指导”中的“信息中心”。
# 关闭邻接状态变化的输出开关。
[Sysname-evi-isis-1] undo log-peer-change enable
reset evi arp-suppression命令用来清除EVI ARP泛洪抑制表项。
reset evi arp-suppression interface tunnel interface-number [ vlan vlan-id ]
interface tunnel interface-number:清除指定EVI隧道接口下的EVI ARP泛洪抑制表项。
vlan vlan-id:清除指定VLAN的EVI ARP泛洪抑制表项。vlan-id表示VLAN编号,取值范围为1~4094。如果不指定本参数,将清除所有VLAN的EVI ARP泛洪抑制表项。
# 清除EVI隧道接口Tunnel101下的EVI ARP泛洪抑制表项。
<Sysname> reset evi arp-suppression interface tunnel 101
This will delete all entries under the specified interface. Continue? [Y/N]:y
reset evi isis all命令用来清除EVI IS-IS进程下所有的动态数据。
reset evi isis all [ process-id ]
process-id:EVI IS-IS进程号,取值范围为0~65535。如果不指定本参数,将清除所有EVI IS-IS进程下所有的动态数据。
# 清除EVI IS-IS进程1下所有的动态数据。
<Sysname> reset evi isis all 1
reset evi neighbor-discovery client statistics命令用来清除使能ENDC功能的接口收到和发送ENDP报文的统计信息。
reset evi neighbor-discovery client statistics interface tunnel interface-number
interface tunnel interface-number:清除指定EVI隧道接口收到和发送ENDP报文的统计信息。
# 清除EVI隧道接口Tunnel1收到和发送ENDP报文的统计信息。
<Sysname> reset evi neighbor-discovery client statistics interface tunnel 1
·     display evi neighbor-discovery client statistics
reset evi neighbor-discovery server statistics命令用来清除使能ENDS功能的接口收到和发送ENDP报文的统计信息。
reset evi neighbor-discovery server statistics interface tunnel interface-number
<Sysname> reset evi neighbor-discovery server statistics interface tunnel 1
·     display evi neighbor-discovery server statistics
snmp context-name命令用来配置管理EVI IS-IS协议的SNMP实体所使用的上下文名称。
未配置管理EVI IS-IS协议的SNMP实体所使用的上下文名称。
EVI IS-IS视图
context-name:管理EVI IS-IS协议的SNMP实体所使用的上下文名称,为1~32个字符的字符串,区分大小写。
与IS-IS相同部分的EVI IS-IS信息使用了IS-IS的标准MIB(Management Information Base,管理信息库)对NMS(Network Management System,网络管理系统)提供EVI IS-IS信息对象的管理,但标准IS-IS MIB中定义的MIB为单实例管理对象,无法同时对IS-IS和EVI IS-IS进行管理。因此,参考RFC 4750中对OSPF多实例的管理方法,需要为管理EVI IS-IS定义一个上下文名称,以区分来自NMS的SNMP请求是要对IS-IS还是EVI IS-IS进行管理。
所有使用标准IS-IS MIB的协议,如EVI、IS-IS等,都需要配置上下文名称以区分SNMP请求的管理对象。各协议(包括各协议中的每个进程)配置的上下文名称都不能相同。
由于上下文名称只是SNMPv3独有的概念,因此对于SNMPv1/v2c,为了区分不同的协议,必须创建团体名到SNMP上下文的映射。
# 配置管理EVI IS-IS进程100的SNMP实体所使用的上下文名称为eviisis100。
[Sysname] evi-isis 100
[Sysname-evi-isis-100] snmp context-name eviisis100
snmp-agent trap enable evi-isis命令用来开启EVI IS-IS的告警功能。
undo snmp-agent trap enable evi-isis命令用来关闭EVI IS-IS的告警功能。
snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
undo snmp-agent trap enable evi-isis [ adjacency-state-change | area-mismatch | buffsize-mismatch | id-length-mismatch | link-disconnect | lsp-parse-error | lsp-size-exceeded | max-seq-exceeded | maxarea-mismatch | new-ded | own-lsp-purge | protocol-support | rejected-adjacency | skip-sequence-number | topology-change | version-skew ] *
EVI IS-IS的所有告警功能均处于开启状态。
adjacency-state-change:表示EVI IS-IS邻接状态变化的告警信息。
area-mismatch:表示Hello报文区域地址不匹配的告警信息。
buffsize-mismatch:表示LSP长度与产生缓冲区大小不匹配的告警信息。
id-length-mismatch:表示EVI IS-IS报文中System ID长度不匹配的告警信息。
link-disconnect:表示ED的公网侧故障的告警信息。
lsp-parse-error:表示LSP解析错误的告警信息。
lsp-size-exceeded:表示超大LSP导致泛洪失败的告警信息。
max-seq-exceeded:表示LSP序列号超过最大序列号的告警信息。
maxarea-mismatch:表示Hello报文最大区域地址不匹配的告警信息。
new-ded:表示本设备成为新的DED的告警信息。
own-lsp-purge:表示尝试清除本地LSP的告警信息。
protocol-support:表示报文协议支持类型不匹配的告警信息。
rejected-adjacency:表示无法根据Hello报文建立邻接关系的告警信息。
skip-sequence-number:表示跳过已产生过的LSP序列号的告警信息。
topology-change:表示站点内ED拓扑变化的告警信息。但同一事件导致发送了new-ded,则不发送本告警信息。
version-skew:表示Hello报文版本号不匹配的告警信息。
开启EVI IS-IS模块的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。
如果未指定任何参数,将开启EVI IS-IS所有类型的告警功能。
生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 开启EVI IS-IS邻居状态变化的告警功能。
[Sysname] snmp-agent trap enable evi-isis adjacency-state-change
timer lsp-max-age命令用来配置当前边缘设备生成的LSP在LSDB里的最大生存时间。
undo timer lsp-max-age命令用来恢复缺省情况。
timer lsp-max-age seconds
当前边缘设备生成的LSP在LSDB里的最大生存时间为1200秒。
EVI IS-IS视图
seconds:LSP在LSDB里的最大生存时间,取值范围是3~65535,单位为秒。
每个LSP都有一个最大生存时间,随着时间的推移最大生存时间将逐渐减小,当LSP的最大生存时间为0时,EVI IS-IS将启动清除过期LSP的过程。用户可根据网络的实际情况调整LSP的最大生存时间。
# 配置生成的LSP的最大生存时间为25分钟,即1500秒。
[Sysname-evi-isis-101] timer lsp-max-age 1500
timer lsp-refresh命令用来配置LSP刷新周期。
undo timer lsp-refresh命令用来恢复缺省情况。
timer lsp-refresh seconds
LSP刷新周期为900秒。
EVI IS-IS视图
seconds:LSP刷新周期,取值范围为1~65534,单位为秒。
LSP刷新周期必须小于LSP在LSDB里的最大生存时间,以保证在LSP失效前进行刷新。
# 配置LSP刷新周期为1500秒。
[Sysname-evi-isis-101] timer lsp-refresh 1500
·     timer lsp-max-age
virtual-system命令用来为系统创建一个EVI IS-IS虚拟系统。
undo virtual-system命令用来删除一个系统中已经存在的EVI IS-IS虚拟系统。
virtual-system system-id
undo virtual-system system-id
不存在EVI IS-IS虚拟系统。
EVI IS-IS视图
system-id:虚拟系统的系统ID,用来标识虚拟系统,格式为XXXX.XXXX.XXXX,X表示十六进制数字。
创建虚拟系统时,用户要保证所配置的虚拟系统的系统ID在网络中是唯一的,否则会出现不可预知的错误。
当本地MAC地址数超过系统的LSP分片集所能携带的MAC地址数时,可以配置EVI IS-IS虚拟系统来扩展LSP的分片数量,以增加系统所能发布的MAC地址数量。
创建虚拟系统前,系统最多可以发送约55×210的MAC地址信息,每创建一个虚拟系统,最多可以多发送55×210的MAC地址信息。用户可以根据本地MAC地址表的规模,来决定创建的虚拟系统的个数。
# 创建一个系统ID为0001.0001.0001的虚拟系统。
[Sysname-evi-isis-101] virtual-system 0001.0001.0001
