09-ACL和QoS命令参考
02-QoS命令
本章节下载 02-QoS命令  (404.71 KB)
docurl=/cn/Service/Document_Software/Document_Center/Switches/Catalog/S7500E/S7500E/Command/Command_Manual/H3C_S7500E_CR-R7536P02-6W100/09/201704/983849_30005_0.htm
02-QoS命令
  录
1 QoS策略
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 nest top-most
1.2.6 redirect
1.2.7 remark customer-vlan-id
1.2.8 remark dot1p
1.2.9 remark drop-precedence
1.2.10 remark dscp
1.2.11 remark ip-precedence
1.2.12 remark local-precedence
1.2.13 remark qos-local-id
1.2.14 remark service-vlan-id
1.2.15 traffic behavior
1.3 定义和应用QoS策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 display qos policy
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy global
1.3.7 display qos policy interface
1.3.8 display qos vlan-policy
1.3.9 qos apply policy (interface view, control plane view)
1.3.10 qos apply policy global
1.3.11 qos policy
1.3.12 qos vlan-policy
1.3.13 reset qos policy control-plane
1.3.14 reset qos policy global
1.3.15 reset qos vlan-policy
2 优先级映射
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 import
2.1.3 map export
2.1.4 qos map-table
2.2 端口优先级信任模式配置命令
2.2.1 display qos trust interface
2.2.2 qos trust
2.3 端口优先级配置命令
2.3.1 qos priority
3 流量整形和限速
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts (interface view)
3.2 限速配置命令
3.2.1 display qos lr interface
3.2.2 qos lr
4 拥塞管理
4.1 拥塞管理公共配置命令
4.1.1 display qos queue interface
4.2 严格优先级队列配置命令
4.2.1 display qos queue sp interface
4.2.2 qos sp
4.3 加权轮询队列配置命令
4.3.1 display qos queue wrr interface
4.3.2 qos wrr
4.3.3 qos wrr { byte-count | weight }
4.3.4 qos wrr group sp
4.4 加权公平队列配置命令
4.4.1 display qos queue wfq interface
4.4.2 qos bandwidth queue
4.4.3 qos wfq
4.4.4 qos wfq { byte-count | weight }
4.4.5 qos wfq group sp
4.5 队列调度策略配置命令
4.5.1 bandwidth queue
4.5.2 display qos qmprofile configuration
4.5.3 display qos qmprofile interface
4.5.4 qos apply qmprofile
4.5.5 qos qmprofile
4.5.6 queue (queue scheduling profile view)
5 拥塞避免
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred queue table
5.1.5 queue
5.1.6 queue ecn
5.1.7 queue weighting-constant
6 聚合CAR
6.1 聚合CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car (system view)
6.1.4 reset qos car name
7 端口队列统计
7.1 端口队列统计配置命令
7.1.1 display qos queue-statistics interface outbound
1 QoS策略
1.1  定义类的命令
display traffic classifier命令用来显示类的配置信息。
(独立运行模式)
display traffic classifier user-defined  [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义类。
classifier-name:类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示所有类的配置信息。
slot slot-number:显示指定单板的流分类的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主用主控板的类的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上流分类的信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,将显示全局主用主控板上类的配置信息。(IRF模式)
# 显示用户定义类的配置信息。
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
表1-1 display traffic classifier命令显示信息描述表
用户自定义类的信息
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
1.1.2  if-match
if-match命令用来定义匹配数据包的规则。
undo if-match命令用来删除配置的匹配数据包的规则。
if-match match-criteria
undo if-match match-criteria
未定义匹配数据包的规则。
类视图
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999,用户自定义ACL序号的取值范围是5000~5999
acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
any
定义匹配所有数据包的规则
control-plane protocol protocol-name&<1-8>
定义匹配控制平面或者管理口控制平面协议的规则,protocol-name&<1-8>为系统预定义匹配协议报文类型名称的列表,具体如表1-3所示,&<1-8>表示前面的参数最多可以输入8次
control-plane protocol-group protocol-group-name
定义匹配控制平面或者管理口控制平面协议组的规则,protocol-group-name取值为critical、important、management、monitor、normal、redirect
customer-dot1p dot1p-value
定义匹配内层VLAN Tag 802.1p优先级的规则,802.1p优先级的取值范围为0~7
customer-vlan-id vlan-id-list
定义匹配内层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
destination-mac mac-address
定义匹配目的MAC地址的规则,仅对以太网接口生效
dscp dscp-value
定义匹配DSCP的规则,DSCP的取值范围为0~63;也可以输入关键字,具体如表1-5所示
forwarding-layer route
定义匹配三层转发的报文
ip-precedence ip-precedence-value
定义匹配IP优先级的规则,IP优先级的取值范围为0~7
定义匹配协议的规则,protocol-name取值为ip、ipv6
qos-local-id local-id-value
定义匹配QoS本地ID值的规则,local-id-value为QoS本地ID,取值范围为1~4095,目前仅支持取值为1~3999
service-dot1p dot1p-value&<1-8>
定义匹配外层VLAN Tag 802.1p优先级的规则,802.1p优先级的取值范围为0~7
service-vlan-id vlan-id-list
定义匹配外层VLAN Tag VLAN ID的规则,vlan-id-list:VLAN列表,表示方式为vlan-id-list = { vlan-id | vlan-id1 to vlan-id2 }&<1-10>vlan-idvlan-id1vlan-id2取值范围为1~4094,且vlan-id1的值必须小于vlan-id2的值;&<1-10>表示前面的参数最多可以重复输入10次
若只携带单层VLAN Tag,可以用外层VLAN Tag的VLAN ID规则来匹配
source-mac mac-address
定义匹配源MAC地址的规则,仅对以太网接口生效
vlan-tag { double | none | single }
定义匹配报文携带的VLAN Tag层次的规则:
·     double:匹配携带双层VLAN Tag的报文
·     none:匹配不携带VLAN Tag的报文
·     single:匹配携带单层VLAN Tag的报文
表1-3 系统预定义匹配协议报文类型名称的列表
报文类型
arp
ARP协议
arp-snooping
ARP Snooping协议
bfd
BFD协议
bgp
BGP协议
bgp4+
IPv6 BGP
dhcp
DHCP协议
dhcp-snooping
DHCP Snooping协议
dhcpv6
IPv6 DHCP协议
dldp
DLDP协议
dot1x
802.1p 协议
icmp
ICMP协议
icmpv6
IPv6 ICMP协议
igmp
IGMP协议
ip-option
带选项字段的IPv4报文
ipv6-option
带选项字段的IPv6报文
isis
IS-IS协议
lacp
LACP协议
lldp
LLDP协议
mvrp
MVRP协议(包含GVRP协议)
ospf-multicast
OSPF组播
ospf-unicast
OSPF单播
ospf3-multicast
OSPFv3组播
ospf3-unicast
OSPFv3单播
pvst
PVST协议
ssh
SSH协议
stp
STP协议
telnet
TELNET协议
vrrp
VRRP协议
vrrp6
IPv6 VRRP协议
一个类下可配置多条匹配命令,各个配置之间互相不覆盖。
在定义匹配规则(控制平面和VLAN ID)时,请注意:
一条命令可以配置多个规则,如果指定了多个相同的规则,系统默认为一个;一条命令中多个不同的规则是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配的规则时,必须与该规则中定义的完全相同才会删除,顺序可以不同。
在定义匹配ACL的规则时,请注意:
·     如果类中引用的ACL不存在,则不能在硬件中下发。
if-match中引用的ACL规则的动作为deny时,则忽略ACL规则的动作,以流行为中定义的动作为准,报文匹配只使用ACL中的分类域。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的802.1p优先级为3。
# 定义类class1的匹配规则为:匹配外层VLAN Tag的802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1的报文。
[Sysname-classifier-class1] if-match dscp 1
# 定义类class1的匹配规则为:匹配IP优先级值为1的报文。
[Sysname-classifier-class1] if-match ip-precedence 1
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配内层VLAN Tag的VLAN ID值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
# 定义类class1的匹配规则为:匹配外层VLAN Tag的VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类class1匹配qos-local-id 3。
[Sysname-classifier-class1] if-match qos-local-id 3
# 在流分类class1中配置匹配上送控制平面或管理口控制平面的ARP协议报文。
[Sysname-classifier-class1] if-match control-plane protocol arp
# 在流分类class1中配置匹配上送控制平面或管理口控制平面的normal协议组报文。
[Sysname-classifier-class1] if-match control-plane protocol-group normal
# 在流分类class1中配置匹配组播类型的报文。
[Sysname-classifier-class1] if-match traffic-type multicast
traffic classifier命令用来创建一个类,并进入类视图。如果指定的类已经存在,则直接进入类视图。
undo traffic classifier命令用来删除一个类。
不存在类。
operator:指定各规则之间的逻辑运算符。缺省情况为and
# 定义一个名为class1的类。
·     display traffic classifier
1.2  定义流行为的命令
1.2.1  accounting
accounting命令用来配置流量统计动作。
undo accounting命令用来恢复缺省情况。
accounting [ byte | packet ]
undo accounting
未配置流量统计动作。
流行为视图
byte:表示报文基于字节进行统计。
packet:表示报文基于包进行统计。
若配置流量统计动作但不指定bytepacket参数,则设备会基于包进行流量统计。
# 为流行为配置流量统计动作,基于字节进行统计。
[Sysname-behavior-database] accounting byte
1.2.2  car
car命令用来配置流量监管动作。
undo car命令用来恢复缺省情况。
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
未配置流量监管动作。
流行为视图
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
cbs committee-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,缺省取值为与62.5 × committed-information-rate的乘积最接近且不小于该乘积值的512的整数倍,但是最大值不能超过256000000。
·     如果指定cbs参数,取值范围512~256000000且必须为512的整数倍。
ebs excess-burst-size:超出突发尺寸,单位为byte。取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。不配置峰值速率表示所配置的是单速桶流量监管,否则表示双速桶流量监管。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
hierarchy-car-name:分层CAR的名称。
mode:分层CAR和CAR动作的合作模式。有andor两种模式,默认为and模式。
·     and:在该模式下,对于多条数据流应用同一个分层CAR,必须每条流满足各自的CAR配置,同时各流量之和又满足分层CAR的配置,流量才能正常通过。
·     or:在该模式下,对于多条数据流应用同一个分层CAR,只要每条流满足各自的CAR配置或者各流量之和满足分层CAR配置,流量即可正常通过。
在同一个流行为中多次执行本命令,最后一次执行的命令生效。
如果未配置峰值速率,则表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 为流行为配置流量监管。报文正常流速为200kbps,承诺突发尺寸为51200bytes,速率大于200kbps时,报文DSCP值改为0并发送。
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
display traffic behavior命令用来显示流行为的配置信息。
(独立运行模式)
display traffic behavior user-defined  [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有流行为的配置信息。
slot slot-number:显示指定单板的流行为的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的流行为的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上流行为的信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示全局主用主控板上流行为的配置信息。(IRF模式)
# 显示用户定义行为的配置信息。
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 200 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark dot1p 1
    Behavior: 3 (ID 102)
      -none-
表1-4 display traffic behavior命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
Marking
标记相关信息
Remark dscp
重新标记报文的DSCP优先级值
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,单位为byte
EBS
超出突发尺寸,单位为byte
Green action
对绿色报文的动作
Red action
对红色报文的动作
Yellow action
对黄色报文的动作
Filter enable
流量过滤动作
Remark dot1p
重新标记报文的802.1p优先级值
none
表示没有配置其他流行为
1.2.4  filter
filter命令用来配置流量过滤动作。
undo filter命令用来恢复缺省情况。
filter { deny | permit }
undo filter
未配置流量过滤动作。
流行为视图
deny:丢弃数据包。
permit:允许数据包通过。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  nest top-most
nest top-most命令用来添加报文的外层VLAN Tag。
undo nest top-most命令用来恢复缺省情况。
nest top-most vlan vlan-id
undo nest top-most
未添加报文外层VLAN Tag。
流行为视图
vlan vlan-id:添加的VLAN ID,取值范围为1~4094。
引用了添加VLAN Tag动作的QoS策略只能应用到接口的入方向上。
# 在流行为b1上配置如下动作:添加VLAN ID为123的外层VLAN Tag。
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
1.2.6  redirect
redirect命令用来为流行为配置流量重定向动作。
undo redirect命令用来恢复缺省情况。
redirect { cpu | interface interface-type interface-number [ track-oap ] | next-hop { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } }
undo redirect { cpu | interface interface-type interface-number | next-hop }
未配置流量重定向动作。
流行为视图
cpu:重定向到CPU。
interface:重定向到指定的接口。
track-oap:重定向到接口的行为需要关心OAP client的状态。
next-hop:重定向到指定的下一跳。
ipv4-add1:优选的下一跳IPv4地址。如果重定向到优选的IPv4地址失败,则会重定向到备选IPv4地址。
ipv4-add2:备选的下一跳IPv4地址。
ipv6-add1:优选的下一跳IPv6地址。如果重定向到优选的IPv6地址失败,则会重定向到备选IPv6地址。
ipv6-add2:备选的下一跳IPv6地址。
track track-entry-number:指定下一跳关联的Track项,优选和备选的地址可以分别指定不同的Track项。track-entry-number取值范围为1~1024。通过指定Track项,可实现与监测特性(如NQA、BFD)的联动,详情请参见“可靠性配置指导”中的“Track”。
配置track-oap后,只有存在OAP Client且指定接口为内部业务接口或连接独立业务部件接口,才会执行重定向动作,否则,设备不执行该重定向动作。有关内部业务接口和连接独立业务部件接口的详细介绍,请参见“OAA配置指导”中的“OAP单板配置”或“OAP配置”。
基于接口应用QoS策略时,本系列设备只支持在二层以太网接口下配置流量重定向动作。
在配置重定向到下一跳的动作时,指定的下一跳地址必须路由可达,如果同时配置了优选和备选地址,则至少需要有一个地址路由可达,否则将导致重定向失败。在配置生效后,重定向功能会定期查询路由表,检查下一跳地址是否有效;如果配置了Track项,则通过Track检测结果来判断下一跳地址是否有效。如果检测到优选和备选地址均失效,则重定向到下一跳的动作将不再生效。在IRF环境中,当IRF成员设备之间通过多个IRF物理端口互联时,不支持跨成员设备配置重定向到接口。即流量的入接口和重定向接口需要是同一成员设备上的接口。有关IRF的相关介绍请参见“虚拟化技术配置指导”中的“IRF”。
# 为流行为配置流量重定向动作,重定向到接口Ten-GigabitEthernet1/0/1。
[Sysname-behavior-database] redirect interface ten-gigabitethernet 1/0/1
·     classifier behavior
·     qos policy
·     traffic behavior
remark customer-vlan-id命令用来重标记报文的CVLAN。
undo remark customer-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的动作。
流行为视图
vlan-id:表示重标记报文内层VLAN(CVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的CVLAN为VLAN 111。
[Sysname-behavior-b1] remark customer-vlan-id 111
1.2.8  remark dot1p
remark dot1p命令用来配置重新标记报文的802.1p优先级或内外层标签802.1p优先级复制动作。
undo remark dot1p命令用来恢复缺省情况。
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
未配置重新标记报文802.1p优先级以及内外层标签802.1p优先级复制动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dot1p-value:802.1p优先级,取值范围为0~7。
customer-dot1p-trust:将内层VLAN tag的802.1p优先级复制为外层VLAN tag的802.1p优先级。
命令remark dot1p dot1p-valueremark dot1p customer-dot1p-trust是覆盖关系。
对于只携带一层VLAN tag的报文,配置的remark dot1p customer-dot1p-trust不会生效。
在同一个流行为中,如果多次对同一种颜色的报文重新标记802.1p优先级,则最后一次执行的命令生效。
# 重新标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
# 配置内外层标签优先级复制功能。
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence命令用来重新标记报文的丢弃优先级。
undo remark drop-precedence命令用来恢复缺省情况。
remark drop-precedence drop-precedence-value
未配置重新标记报文的动作。
流行为视图
drop-precedence-value:丢弃优先级,取值范围为0~2。
应用该动作的流行为只能应用在入方向。
# 重新标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.10  remark dscp
remark dscp命令用来重新标记报文的DSCP值。
undo remark dscp命令用来取消标记报文的DSCP值。
undo remark [ green | red | yellow ] dscp
未配置重新标记报文DSCP值的动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-5所示。
表1-5 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
default
000000
0
ef
101110
46
# 重新标记报文的DSCP值为6。
remark ip-precedence命令用来重新标记报文的IP优先级。
undo remark ip-precedence命令用来取消标记报文的IP优先级。
remark ip-precedence ip-precedence-value
未配置重新标记报文IP优先级的动作。
流行为视图
ip-precedence-value:IP优先级,取值范围为0~7。
# 重新标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark local-precedence命令用来重新标记报文的本地优先级。
undo remark local-precedence命令用来取消标记报文的本地优先级。
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
未配置重新标记报文本地优先级的动作。
流行为视图
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
local-precedence-value:本地优先级,取值范围为0~7。
# 重新标记报文的本地优先级值为2。
remark qos-local-id命令用来重新标记报文的QoS本地ID值。
undo remark qos-local-id命令用来恢复缺省情况。
remark qos-local-id local-id-value
未配置重新标记报文的QoS本地ID值的动作。
流行为视图
local-id-value:QoS本地ID值,取值范围为1~4095,目前仅支持取值为1~3999。
一般情况下,在QoS策略的入方向对报文的QoS本地ID值进行标记,在QoS策略的出方向根据标记的QoS本地ID值对报文进行分类以及指定相应的流行为,两者要结合使用。
# 重新标记报文的QoS本地ID值为2。
[Sysname-behavior-database] remark qos-local-id 2
remark service-vlan-id命令用来重标记报文的SVLAN。
undo remark service-vlan-id命令用来恢复缺省情况。
未配置重新标记报文的SVLAN的动作。
流行为视图
vlan-id:表示重标记报文外层VLAN(SVLAN)的编号,取值范围为1~4094。
# 在流行为b1上配置重标记报文的SVLAN为VLAN 222。
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior命令用来创建一个流行为,并进入流行为视图。如果指定的流行为已经存在,则直接进入流行为视图。
undo traffic behavior命令用来删除一个流行为。
不存在流行为。
behavior-name:流行为名,为1~31个字符的字符串,区分大小写。
# 定义一个名为behavior1的流行为。
[Sysname-behavior-behavior1]
·     display traffic behavior
1.3  定义和应用QoS策略的命令
classifier behavior命令用来为类指定流行为。
undo classifier命令用来取消为类指定的流行为。
classifier classifier-name behavior behavior-name [  insert-before before-classifier-name ]
没有为类指定流行为。
QoS策略视图
insert-before before-classifier-name:表示将配置的类插入到QoS策略中已存在的指定类之前。before-classifier-name表示QoS策略中已存在的类名,为1~31个字符的字符串,区分大小写。不指定该参数时,表示新配置的类与流行为配对将添加到QoS策略最后。
QoS策略下每个类只能与一个流行为关联。
如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
# 在QoS策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
# 在QoS策略user1中为类database指定流行为test,并将该类插入到策略中已存在的类class-a前。
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
·     qos policy
1.3.2  control-plane
control-plane命令用来进入控制平面视图。
(独立运行模式)
control-plane chassis chassis-number slot slot-number
slot slot-number:指定单板。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。(IRF模式)
# 进入指定slot上的控制平面视图。(独立运行模式)
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy命令用来显示QoS策略的配置信息。
(独立运行模式)
display qos policy user-defined  [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined:用户定义QoS策略。
policy-name:QoS策略名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有用户定义策略的配置信息。
classifier classifier-name:QoS策略中的类名,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示策略中所有类相关的配置信息。
slot slot-number:显示指定单板的QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的QoS策略的配置信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的QoS策略的信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示全局主用主控板的QoS策略的信息。(IRF模式)
# 显示用户定义QoS策略的配置信息。
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 512 (Bytes)
        Green action  : pass
   Classifier: 2 (ID 101)
     Behavior: 2
      Marking:
        Remark dot1p 4
     Behavior: 3
      -none-
表1-6 display qos policy命令显示信息描述表
用户自定义QoS策略的信息
Policy
QoS策略名
其它显示信息解释请参见表1-1表1-4
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:显示指定单板的控制平面应用QoS策略的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的控制平面应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。(IRF模式)
# 显示应用到指定slot上的控制平面的QoS策略信息。(独立运行模式)
<Sysname> display qos policy control-plane slot 2
Control plane slot 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Yellow packets: 0 (Packets) 0 (Bytes)
        Red packets   : 0 (Packets) 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-7 display qos policy control-plane命令显示信息描述表
Direction
对进入控制平面(Inbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-6
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
(独立运行模式)
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
任意视图‌
slot slot-number:显示指定单板的系统预定义的控制平面策略信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示所有在位单板的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的系统预定义的控制平面策略信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示所有成员设备上在位单板以及所有PEX设备的系统预定义的控制平面应用QoS策略的信息。(IRF模式)
# 显示指定slot上的系统预定义的控制平面应用QoS策略的信息。(独立运行模式)
<Sysname> display qos policy control-plane pre-defined slot 1
Pre-defined policy information slot 1
  Protocol          Priority   Bandwidth          Group
  IS-IS             29         512 (kbps)         critical
  VRRP              36         512 (kbps)         important
  OSPF Multicast    30         1024 (kbps)        critical
  OSPF Unicast      30         1024 (kbps)        critical
  PIM Multicast     24         128 (kbps)         critical
  PIM Unicast       24         128 (kbps)         critical
  IGMP              18         512 (kbps)         important
  PIMv6 Multicast   24         64 (kbps)          critical
  PIMv6 Unicast     24         64 (kbps)          critical
  OSPFv3 Unicast    30         1024 (kbps)        critical
  OSPFv3 Multicast  30         1024 (kbps)        critical
  VRRPv6            36         512 (kbps)         important
  ARP               12         768 (kbps)         normal
  DHCP Snooping     18         256 (kbps)         redirect
  DHCP              18         768 (kbps)         normal
  802.1x            12         128 (kbps)         important
  STP               36         256 (kbps)         critical
  LACP              36         64 (kbps)          critical
  MVRP              18         256 (kbps)         critical
  BGP               24         256 (kbps)         critical
  ICMP              9          512 (kbps)         monitor
  IPOPTION          18         384 (kbps)         normal
  BGPv6             24         256 (kbps)         critical
  IPOPTIONv6        18         64 (kbps)          normal
  LLDP              24         64 (kbps)          important
  DLDP              24         64 (kbps)          critical
  TELNET            8          512 (kbps)         management
  SSH               8          512 (kbps)         management
  HTTP              12         64 (kbps)          management
  HTTPS             12         64 (kbps)          management
  TACACS            12         64 (kbps)          management
  RADIUS            12         64 (kbps)          management
  ARP Snooping      18         256 (kbps)         redirect
  ICMPv6            8          512 (kbps)         monitor
  PVST              35         2560 (kbps)        critical
  DHCPv6            18         256 (kbps)         normal
  BFD               31         12800 (kbps)       critical
表1-8 display qos policy control-plane pre-defined命令显示信息描述表
Pre-defined control plane policy
预定义控制平面策略内容
Protocol
系统预定义协议报文类型
其他协议
Priority
优先级
Bandwidth
带宽
Group
协议所属的协议组
其它显示信息解释请参见表1-3
display qos policy global命令用来显示基于全局应用QoS策略的信息。
(独立运行模式)
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound:显示对全局接收到的报文应用QoS策略的信息。
outbound:显示对全局发送的报文应用QoS策略的信息。
slot slot-number:显示指定单板的基于全局应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于全局应用QoS策略的信息,不显示各单板的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的基于全局应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于全局应用QoS策略的信息,不显示各单板及PEX设备的信息。(IRF模式)
如果未指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-9 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos policy interface命令用来显示接口上QoS策略的配置信息和运行情况。
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口上QoS策略的配置信息和运行情况。
inbound:显示对接口接收到的报文应用QoS策略的信息。
outbound:显示对接口发送的报文应用QoS策略的信息。
如果未指定显示方向,则同时显示出入两个方向接口上应用QoS策略的配置信息和运行情况。
# 显示对接口Ten-GigabitEthernet1/0/1接收到的报文应用QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface ten-gigabitethernet 1/0/1 inbound
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Matched : 0 (Packets) 0 (Bytes)
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
# 显示所有接口上QoS策略的接口的配置信息和运行情况。
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/2
        CIR 112 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
Interface: Ten-GigabitEthernet1/0/3
  Direction: Inbound
  Policy: b
   Classifier: b
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: b
        Green action  : pass
        Green packets : 0(Packets)
  Direction: Inbound
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet1/0/4
        Green action  : pass
表1-10 display qos policy interface命令显示信息描述表
Direction
Policy应用在接口的方向
Matched
符合分类规则的数据包数目
5-minute statistics
最近5分钟的流速统计信息
Forwarded
符合分类规则的成功转发报文在统计周期内的平均速率
Dropped
符合分类规则的丢弃报文在统计周期内的平均速率
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的信息。
(独立运行模式)
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串,区分大小写。
vlan vlan-id:显示指定VLAN上应用QoS策略的信息。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:显示对VLAN接收到的报文应用的QoS策略信息。
outbound:显示对VLAN发送的报文应用的QoS策略信息。
slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板上基于VLAN应用QoS策略的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上基于VLAN应用QoS策略的信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示全局主用主控板上基于VLAN应用QoS策略的信息。(IRF模式)
如果未指定显示方向,则同时显示出入两个方向基于VLAN应用QoS策略的信息。
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Green packets : 0(Packets) 0(Bytes)
        Yellow packets: 0(Packets) 0(Bytes)
        Red packets   : 0(Packets) 0(Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
      Accounting enable:
        0 (Packets)
      Marking:
        Remark dscp 3
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
表1-11 display qos vlan-policy命令显示信息描述表
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
其它显示信息解释请参见表1-1表1-4
qos apply policy命令用来在以太网服务实例、接口或控制平面上应用QoS策略。
undo qos apply policy命令用来取消以太网服务实例、接口或控制平面上应用的QoS策略。
undo qos apply policy policy-name { inbound | outbound }
未应用QoS策略。
控制平面视图
policy-name:策略名,为1~31个字符的字符串,区分大小写。
inbound:对接口或控制平面接收到的报文应用QoS策略。
outbound:对接口发送的报文应用QoS策略。
三层聚合接口/子接口不支持应用QoS策略;三层聚合接口存在子接口时,该聚合接口的成员端口也不支持应用QoS策略。
# 将策略USER1应用到接口Ten-GigabitEthernet1/0/1的出方向上。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply policy USER1 outbound
# 对进入3号槽控制平面的报文应用策略aaa。
[Sysname-cp-slot3] qos apply policy aaa inbound
qos apply policy global命令用来全局应用QoS策略。
undo qos apply policy global命令用来取消全局应用的QoS策略。
undo qos apply policy policy-name global { inbound | outbound }
未在全局应用QoS策略。
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
全局应用的QoS策略对全部流量生效。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.11  qos policy
qos policy命令用来创建一个策略,并进入策略视图。如果指定的策略已经存在,则直接进入策略视图。
undo qos policy命令用来删除一个策略。
qos policy policy-name
undo qos policy policy-name
不存在策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
# 定义一个名为user1的策略。
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy命令用来在VLAN上应用QoS策略。
undo qos vlan-policy命令用来取消VLAN上应用的QoS策略。
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
未在VLAN上应用QoS策略。
policy-name:策略名称,为1~31个字符的字符串,区分大小写。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
# 在VLAN 200、300、400、500的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
(独立运行模式)
reset qos policy control-plane chassis chassis-number slot slot-number
slot slot-number:清除指定单板的基于控制平面应用QoS策略的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:清除指定单板的基于控制平面应用QoS策略的统计信息,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。(IRF模式)
# 清除应用到指定slot上的控制平面的QoS策略统计信息。(独立运行模式)
<Sysname> reset qos policy control-plane slot 3
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
inbound:清除全局接收到的报文应用QoS策略的统计信息。
outbound:清除全局发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向全局应用的QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
vlan vlan-id:指定VLAN。vlan-id为指定VLAN的ID号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除对VLAN发送的报文应用QoS策略的统计信息。
如果不指定方向,则同时清除出入两个方向VLAN应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射
2.1  优先级映射表配置命令
display qos map-table命令用来显示优先级映射表配置情况。
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dscp-dp | dscp-dscp | exp-dot1p ]
表2-1 优先级映射表
优先级映射
dot1p-dp
802.1p优先级到丢弃优先级映射表
dot1p-exp
802.1p优先级到EXP映射表
dot1p-lp
802.1p优先级到本地优先级映射表
dscp-dp
DSCP到丢弃优先级映射表
dscp-dscp
DSCP到DSCP映射表
exp-dot1p
EXP到802.1p优先级映射表
exp-dscp
EXP到DSCP映射表
如果未指定表的类型,将显示所有映射表的配置情况。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
表2-2 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名称
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.2  import
import命令用来配置指定优先级映射表的映射关系。
undo import命令用来删除配置的优先级映射表的映射关系,恢复其为缺省的映射关系。
优先级映射表的映射关系请参见配置指导中的附录 B。
优先级映射表视图
import-value-list:输入值列表。
export-value:输出值。
all:删除配置地该映射表的所有映射关系,恢复其为缺省的映射关系。
# 配置802.1p优先级到本地优先级映射表的映射关系,与802.1p优先级4、5相对应的本地优先级为1。
[Sysname] qos map-table dot1p-lp
[Sysname-maptbl-dot1p-lp] import 4 5 export 1
·     display qos map-table
2.1.3  map export
map export命令用来将映射关系配置到指定MPLS标签的EXP域。
undo map export命令用来恢复缺省情况。
map export mpls-exp
undo map export
如果入方向的报文为不带MPLS标签的私网报文,则映射关系同时被配置到出方向添加得第一层和第二层MPLS标签的EXP域;如果入方向的报文为带两层MPLS标签的公网报文,则映射关系只被配置到出方向第一层MPLS标签的EXP域。
优先级映射表视图
mpls-exp:表示映射关系仅配置到第一层MPLS标签的EXP域。
该命令仅对输出值为EXP的优先级映射表生效。
如果入方向的报文为不带MPLS标签的私网报文,则本命令配置后映射关系只被配置到第一层MPLS标签的EXP域,同时第二层MPLS标签的EXP域会被设置为0;如果入方向的报文为带两层MPLS标签的公网报文,则本命令配置后则映射关系不会被配置到MPLS标签的EXP域。
# 配置802.1p优先级到EXP优先级映射表的映射关系,与802.1p优先级4、5相对应的EXP优先级为1,并且仅将映射关系配置到第一层MPLS标签的EXP域。
[Sysname] qos map-table dot1p-exp
[Sysname-maptbl-dot1p-exp] import 4 5 export 1
[Sysname-maptbl-dot1p-exp] map export mpls-exp
2.1.4  qos map-table
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dscp-dp | dscp-dscpexp-dot1p }
其它参数请参见表2-1
# 进入802.1p优先级到本地优先级映射表视图。
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp]
·     import
2.2  端口优先级信任模式配置命令
display qos trust interface命令用来显示端口优先级信任模式信息和端口优先级的信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的端口优先级信任模式信息。
# 显示端口优先级信任模式信息。
<Sysname> display qos trust interface ten-gigabitethernet 1/0/1
 Port priority trust information
  Port priority:4
  Port priority trust type: dscp
表2-3 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
端口优先级信任信息
Port priority
端口优先级
端口优先级信任类型,取值为:
·     dot1p:802.1p优先级
·     dscp:DSCP优先级
2.2.2  qos trust
qos trust命令用来配置端口优先级信任模式。
undo qos trust命令用来恢复缺省情况。
qos trust { dot1p | dscp }
undo qos trust
设备信任报文的802.1p优先级。
VXLAN网络的公网侧端口和AC侧端口都不支持配置优先级信任模式为DSCP。关于VXLAN的配置,请参见“VXLAN配置指导”中的“VXLAN”。
# 在接口Ten-GigabitEthernet1/0/1上配置优先级信任模式为信任报文自带的802.1p优先级。
[Sysname-Ten-GigabitEthernet1/0/1] qos trust dot1p
2.3  端口优先级配置命令
2.3.1  qos priority
qos priority命令用来配置端口的端口优先级。
undo qos priority命令用来恢复端口优先级为缺省值。
qos priority priority-value
undo qos priority
端口优先级的缺省值为0。
priority-value:端口优先级值,取值范围为0~7。
# 配置接口Ten-GigabitEthernet1/0/1的端口优先级为2。
[Sysname-Ten-GigabitEthernet1/0/1] qos priority 2
·     display qos trust interface
3 流量整形和限速
3.1  流量整形配置命令
display qos gts interface命令用来显示接口的流量整形配置情况和统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的流量整形配置情况和统计信息。
# 显示所有接口的流量整形配置情况和统计信息。
 Rule: If-match queue 1
  CIR 1000 (kbps), CBS 62976 (Bytes)
 Rule: If-match queue 4
  CIR 400 (kbps), CBS 25088 (Bytes)
表3-1 display qos gts命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成
Rule
匹配规则
CIR
承诺信息速率,当采用绝对值形式输入时,单位为kbps;当采用百分比形式时,单位为%
CBS
承诺突发尺寸,当采用绝对值形式输入时,单位为byte;当采用百分比形式时,单位为ms,实际的CBS值是cbs-time 乘以实际的承诺信息速率(cir值乘以接口带宽)
qos gts命令用来在接口上配置流量整形。
undo qos gts命令用来取消接口上流量整形的配置。
undo qos gts queue queue-id
接口上未配置流量整形。
queue queue-id对队列上的数据包进行流量整形。queue-id为匹配的队列号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000。用户配置的数值必须是8的倍数。‌
cbs committed-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5*committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍,最大不能超过16000000。
·     如果指定cbs参数,取值范围为512~16000000,committed-burst-size必须为512的整数倍。
不配置峰值速率表示所配置的是单速率流量整形,否则表示双速率流量整形。
# 在接口Ten-GigabitEthernet1/0/1上对队列1中的报文进行流量整形。正常流速为6400kbps,突发流量为51200bytes。
[Sysname-Ten-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
3.2  限速配置命令
display qos lr interface命令用来显示接口上的限速配置情况和统计信息。
display qos lr  interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的限速配置情况和运行统计信息。
# 显示所有接口的接口限速配置情况和统计信息。
 Direction: Inbound
  CIR 2000 (kbps), CBS 20000 (Bytes)
表3-2 display qos lr命令显示信息描述表
Direction
方向,可以是Inbound、Outbound
CIR
CBS
3.2.2  qos lr
qos lr命令用来配置限速。
undo qos lr命令用来取消配置的限速。
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
未配置限速。
outbound:对发送的数据流进行限速。
cbs committed-burst-size:承诺突发尺寸,单位为bytes。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5ms*committed-information-rate,且必须为512的整数倍,如果乘积不是512的整数倍,就取比乘积大的最近的512的整数倍,最大不能超过128000000。
·     如果指定cbs参数,取值范围为512~128000000,committed-burst-size必须为512的整数倍。
# 对接口Ten-GigabitEthernet1/0/1上出方向的报文进行限速。正常流速为256kbps,突发流量为51200bytes,以后速率小于等于256kbps时正常发送,速率大于256kbps时,将进行限速。
[Sysname-Ten-GigabitEthernet1/0/1] qos lr outbound cir 256 cbs 51200
4 拥塞管理
4.1  拥塞管理公共配置命令
display qos queue interface命令用来显示接口上队列配置情况和统计信息。
display qos queue interface [ interface-type interface-number ]
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的接口队列配置情况和运行统计信息。
# 显示所有接口下的队列信息。
<Sysname> display qos queue interface
 Output queue: Strict Priority queuing
Interface: Ten-GigabitEthernet1/0/2
Interface: Ten-GigabitEthernet1/0/4
Interface: Ten-GigabitEthernet1/0/5
Interface: Ten-GigabitEthernet1/0/6
表4-1 display qos queue interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列的相关信息
Queue ID
队列号
Group
分组号,说明队列属于哪一个分组,缺省情况下,队列所属的分组号为1
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算,N/A表示该队列采用SP调度算法
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算
4.2  严格优先级队列配置命令
display qos queue sp interface命令用来显示接口的SP(Strict Priority,严格优先级)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的SP队列配置情况。
# 显示Ten-GigabitEthernet1/0/1的严格优先级队列配置情况。
<Sysname> display qos queue sp interface ten-gigabitethernet 1/0/1
表4-2 display qos queue sp interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
4.2.2  qos sp
qos sp命令用来在接口上配置严格优先队列。
undo qos sp命令用来恢复缺省情况。
qos sp
undo qos sp
端口采用SP调度算法。
# 在接口Ten-GigabitEthernet1/0/1上应用SP模式的队列调度。
[Sysname-Ten-GigabitEthernet1/0/1] qos sp
·     display qos queue sp interface
4.3  加权轮询队列配置命令
display qos queue wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WRR队列配置情况。
# 显示接口Ten-GigabitEthernet1/0/1的WRR队列配置情况。
<Sysname> display qos queue wrr interface ten-gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Queue    name      Group           Weight
 0               be              1               1
 1               af1             1               1
 2               af2             1               1
 3               af3             1               1
 4               af4             1               1
 5               ef              1               1
 6               cs6             1               1
 7               cs7             sp              N/A
表4-3 display qos queue wrr interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
Weight
Byte count
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的字节数进行计算,N/A表示该队列采用SP调度算法
4.3.2  qos wrr
qos wrr命令用来在接口上开启WRR队列。
undo qos wrr命令用来恢复缺省情况。
undo qos wrr { byte-count | weight }
接口使用SP队列调度算法。
byte-count:表示按照每次轮询可发送的字节数进行计算。
weight:表示按照每次轮询可发送的报文个数进行计算。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行WRR配置。
# 在接口Ten-GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的报文个数进行计算。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr weight
# 在接口Ten-GigabitEthernet1/0/1上开启WRR队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr byte-count
·     display qos queue wrr interface
qos wrr { byte-count | weight }命令用来配置WRR队列或修改WRR队列的参数。
undo qos wrr命令用来取消WRR队列调度参数的配置。
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
在使用WRR队列时,所有队列都处于WRR调度组1中,调度权重从队列0到7分别为1、2、3、4、5、6、7、8。
queue-id:队列序号。取值范围为0~7。
表4-4 queue-id数字和关键字对应表
queue-id数字
queue-id关键字
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
group { 1 | 2 }:表示该队列属于哪个WRR优先组,缺省为group 1。其中group 1表示该队列属于WRR优先组1,group 2表示该队列属于WRR优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。仅LSQ1QGS4SC0和LSQM2TGS16SF0接口板支持配置WRR调度组2。
schedule-value:配置队列的调度权重,取值范围为1~15。
必须先使用qos wrr命令在接口上开启WRR队列,然后才能进行本配置。
# 在接口Ten-GigabitEthernet1/0/1上应用WRR队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
·     qos wrr
qos wrr group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wrr group sp命令用来取消将队列加入SP组。
qos wrr queue-id group sp
当使用WRR队列时,所有队列都处于WRR调度组1中。
本命令需要在端口队列为WRR调度模式下使用。
SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WRR优先组。
# 在接口Ten-GigabitEthernet1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-Ten-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
4.4  加权公平队列配置命令
display qos queue wfq interface命令用来显示接口的WFQ配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的WFQ配置情况。
# 显示接口Ten-GigabitEthernet1/0/1的加权公平队列配置情况。
<Sysname> display qos queue wfq interface ten-gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID        Queue name      Group           Byte count      Min Bandwidth
 0               be              1               1               64
 1               af1             1               1               64
 2               af2             1               1               64
 3               af3             1               1               64
 4               af4             1               1               64
 5               ef              1               1               64
 6               cs6             1               1               64
 7               cs7             1               1               64
表4-5 display qos queue wfq interface命令显示信息描述表
接口名,由接口类型和接口编号组成
Output queue
当前出队列类型
Queue ID
队列号
Queue name
队列名称
Group
Byte-count
Weight
各个队列的调度权重,当前WRR队列调度权重的计算方式为按照每次轮询可发送的报文个数进行计算, N/A表示该队列采用SP调度算法
Min-Bandwidth
队列的最小保证带宽值
qos bandwidth queue命令用来配置端口队列的最小带宽保证。
undo qos bandwidth queue命令用来恢复缺省情况。
undo qos bandwidth queue queue-id
在使用WFQ队列时,每个队列的最小带宽保证为64kbps。
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。千兆端口的取值范围为8~1000000,万兆端口的取值范围为8~10000000,40GE端口的取值范围为8~40000000,100GE端口的取值范围为8~100000000,单位为kbps。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行本配置。
# 在接口Ten-GigabitEthernet1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq weight
[Sysname-Ten-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
·     qos wfq
4.4.3  qos wfq
qos wfq命令用来在接口上开启WFQ队列。
undo qos wfq命令用来恢复缺省情况。
undo qos wfq { byte-count | weight }
接口使用SP队列调度算法。
必须先使用qos wfq命令在接口上开启WFQ队列,然后才能进行WFQ配置。
# 在接口Ten-GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的报文个数进行计算。
# 在接口Ten-GigabitEthernet1/0/1上开启WFQ队列,并按照每次轮询可发送的字节数进行计算。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq byte-count
·     display qos queue wfq interface
qos wfq { byte-count | weight }命令用来配置WFQ队列或修改WFQ队列的参数。
undo qos wfq命令用来取消WFQ队列调度参数的配置。
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
在使用WFQ队列时,所有队列都处于WFQ调度组1中,各队列的调度权重均为1。
group { 1 | 2 }:表示该队列属于哪个WFQ优先组,缺省为group 1。其中group 1表示该队列属于WFQ优先组1,group 2表示该队列属于WFQ优先组2。各组之间执行优先级调度,由组1至组2优先级依次降低。仅LSQ1QGS4SC0和LSQM2TGS16SF0接口板支持配置WFQ调度组2。
schedule-value:配置队列的调度权重,取值范围为1~16。
# 在接口Ten-GigabitEthernet1/0/1上应用WFQ队列,并按照每次轮询可发送的字节数进行计算,配置队列0的调度权重为10,分组为1。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
·     qos bandwidth queue
·     qos wfq
qos wfq group sp命令用来配置队列加入SP组,采用严格优先级调度算法。
undo qos wfq group sp命令用来取消将队列加入SP组。
qos wfq queue-id group sp
当使用WFQ队列时,所有队列都处于WFQ调度组1中。
本命令需要在端口队列为WFQ调度模式下使用。
SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。调度时先调度SP组,然后调度其他WFQ优先组。
# 在接口Ten-GigabitEthernet1/0/1上应用WFQ队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-Ten-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
4.5  队列调度策略配置命令
bandwidth queue命令用来配置队列调度策略下队列的最小带宽保证。
undo bandwidth queue命令用来恢复缺省情况。
undo bandwidth queue queue-id
在队列调度策略中配置某个队列为WFQ队列后,该队列的最小带宽保证为64kbps。
队列调度策略视图
min bandwidth-value:最小保证带宽值,单位为kbps。端口流量拥塞时能够保证的最小队列带宽。取值范围为8~100000000。
必须先在队列调度策略中将某个队列配置为WFQ队列,才能为该队列配置最小带宽保证。
# 在队列调度策略myprofile中,配置队列0使用WFQ队列算法,使用报文个数作为调度权重,权重值为1,分组为1,并为该队列配置最小保证带宽值为100kbps。
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
display qos qmprofile configuration命令用来显示队列调度策略的配置情况。
(独立运行模式)
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name:队列调度策略名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示所有队列调度策略的配置情况。
slot slot-number:显示指定单板的队列调度策略的配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的队列调度策略的配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的队列调度策略的配置情况,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示全局主用主控板的队列调度策略的配置情况。(IRF模式)
# 显示队列调度策略myprofile的配置情况。
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
 Queue ID  Type  Group   Schedule   Schedule  Min         Max
                         unit       value     bandwidth   bandwidth
 be        SP    N/A     N/A        N/A       0           N/A
 af1       WFQ   1       weight     1         200         N/A
 af2       WFQ   1       weight     1         0           N/A
 af3       WFQ   1       weight     2         0           N/A
 af4       WFQ   1       weight     2         0           N/A
 ef        WFQ   1       weight     3         0           N/A
 cs6       WFQ   1       weight     4         0           N/A
 cs7       WFQ   1       weight     3         0           N/A
表4-6 display qos qmprofile configuration命令显示信息描述表
队列调度策略名称
Queue ID
队列号
队列调度类型,包括SP(严格优先级)、WRR(加权轮询调度)、WFQ(加权公平队列)
Group
优先组,N/A表示无效
Schedule unit
队列调度单位,包括weight和byte-count,N/A表示无效
Schedule vlaue
·     队列调度单位为weight时,表示报文个数
·     队列调度单位为byte-count时,表示字节个数
·     N/A表示无效
Min Bandwidth
最小保证带宽,N/A表示无效
Max bandwidth
最大带宽值,N/A表示无效
display qos qmprofile interface命令用来显示接口的队列调度策略的配置情况。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列调度策略的配置情况。
# 显示指定接口的队列调度策略的配置情况。
<Sysname> display qos qmprofile interface ten-gigabitethernet 1/0/1
Direction: Outbound
表4-7 display qos qmprofile interface命令显示信息描述表
接口名称
Direction
应用方向
队列调度策略名称
qos apply qmprofile命令用来在接口上应用队列调度策略。
undo qos apply qmprofile命令用来恢复缺省情况。
接口上未应用队列调度策略。
inbound:表示在接口的入方向上应用队列调度策略。如果未指定该参数,则表示在接口的出方向应用队列调度策略。
每个接口在同一方向上只能应用一个队列调度策略。
# 在接口Ten-GigabitEthernet1/0/1上应用队列调度策略myprofile。
[Sysname-Ten-GigabitEthernet1/0/1] qos apply qmprofile myprofile
·     display qos qmprofile interface
4.5.5  qos qmprofile
qos qmprofile命令用来创建用户自定义的队列调度策略,并进入相应的队列调度策略视图。如果指定的队列调度策略已经存在,则直接进入该队列调度策略视图。
undo qos qmprofile命令用来删除用户自定义的队列调度策略。
qos qmprofile profile-name
undo qos qmprofile profile-name
不存在用户自定义的队列调度策略。
如果需要删除已经应用到接口的队列调度策略,必须先在应用的位置上取消对该队列调度策略的应用,然后再删除该队列调度策略。
# 创建队列调度策略myprofile,并进入队列调度策略视图。
·     queue
queue命令用来配置队列调度参数。
undo queue命令用来取消队列调度参数的配置。
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
缺省情况下,队列调度策略的内容是所有队列均采用SP方式调度。
队列调度策略视图
sp:配置队列为严格优先级调度。
wfq:配置队列为加权公平调度。
wrr:配置队列为加权轮询调度。
group group-id:优先组号。group-id取值范围为1~2。仅LSQ1QGS4SC0和LSQM2TGS16SF0接口板支持group-id取值为2。对于WFQ队列,如果不选则此参数,则表示将队列加入组1。
schedule-value:配置队列的调度权重。对于WFQ优先组取值范围为1~16,对于WRR优先组取值范围为1~15。
# 创建自定义的队列调度策略myprofile,并配置队列0为严格优先级调度。
[Sysname-qmprofile-myprofile] queue 0 sp
# 创建自定义的队列调度策略myprofile,并配置队列1为加权轮询调度,权重为10,分组为1。
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
·     qos qmprofile
5 拥塞避免
5.1  WRED配置命令
display qos wred interface命令用来显示WRED配置情况和统计信息。
interface-type interface-number:指定的接口类型和接口编号。如果未指定本参数,将显示所有接口的WRED配置情况和统计信息。
# 显示所有接口的WRED配置情况和统计信息。
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: q1
表5-1 display qos wred interface命令显示信息描述表
接口名,由接口类型和接口编号组成
当前WRED的配置情况
当前应用的WRED表的名称
display qos wred table命令用来显示WRED表的配置情况。
(独立运行模式)
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则显示所有WRED表配置情况。
slot slot-number:显示指定单板的WRED表配置情况。slot-number表示单板所在的槽位号。如果未指定本参数,则显示主用主控板的WRED表配置情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的WRED表配置情况,chassis-number表示设备在IRF中的成员编号或者PEX对应的虚拟框号,slot-number表示单板或PEX所在的槽位号。如果未指定本参数,则显示全局主用主控板的WRED表配置情况。(IRF模式)
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     100   1000  10     100   1000  10     9         N
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     100   1000  10     100   1000  10     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     100   1000  10     100   1000  10     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
表5-2 display qos wred table命令显示信息描述表
Table name
WRED表名
Table type
WRED表类型
QID
队列ID
gmin
绿色报文的队列下限
gmax
绿色报文的队列上限
gprob
绿色报文的丢弃概率
ymin
黄色报文的队列下限
ymax
黄色报文的队列上限
yprob
黄色报文的丢弃概率
rmin
红色报文的队列下限
rmax
红色报文的队列上限
rprob
红色报文的丢弃概率
exponent
计算平均队列长度指数
ECN
是否对该队列开启了拥塞通知功能,Y表示开启,N表示未开启
qos wred apply命令用来在接口上应用WRED表。
undo qos wred apply命令用来恢复缺省情况。
qos wred apply [ table-name ]
undo qos wred apply
接口没有应用WRED表,即接口采用尾丢弃。
table-name:WRED表的名称,为1~32个字符的字符串,区分大小写。如果未指定本参数,则在接口上应用缺省WRED表。
# 在接口Ten-GigabitEthernet1/0/1上应用WRED表。
[Sysname-Ten-GigabitEthernet1/0/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred queue table
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。如果指定的WRED表已经存在,则直接进入WRED表视图。
undo qos wred queue table命令用来删除WRED表。
undo qos wred queue table table-name
设备上不存在WRED表。
table table-name:指定WRED表的名称,为1~32个字符的字符串,区分大小写。
设备不允许删除正在使用的WRED表。如果需要删除正在使用的表,请先在接口上取消应用的WRED表。
缺省WRED表可以通过display qos wred table命令显示,不允许修改和删除。
# 创建基于queue的WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.5  queue
queue命令用来配置基于队列的WRED表的内容。
undo queue命令用来恢复缺省情况。
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
WRED表在创建之后,low-limit的缺省取值为100,high-limit的缺省取值为1000,discard-prob的缺省取值为10。
WRED表视图
all:表示所有队列。
queue-id:队列编号。取值范围为0~7。
drop-level drop-level:丢弃级别,在进行报文丢弃时参考的参数,0对应绿色报文、1对应黄色报文、2对应红色报文。如果未指定本参数,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:队列平均长度的下限。,取值范围为0~16383。
high-limit high-limit:队列平均长度的上限。取值范围为0~16383且必须大于丢弃下限。
discard-probability discard-prob:丢弃概率,取值越大,计算出的丢弃概率越小。取值范围为0~100。当报文队列平均长度在上限和下限之间时,设备采用这个概率来丢弃报文。
当队列平均长度小于下限时,不丢弃报文。当队列平均长度在上限和下限之间时,设备随机丢弃报文,队列越长,丢弃概率越高。当队列平均长度超过上限时,丢弃所有到来的报文。
# 配置基于队列的WRED表queue-table1中队列1的丢弃参数:丢弃级别为1,队列平均长度的下限为10,队列平均长度的上限为20,丢弃概率为30%。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
5.1.6  queue ecn
queue ecn命令用来对指定队列开启拥塞通知功能。
undo queue ecn命令用来恢复缺省情况。
queue queue-id ecn
undo queue queue-id ecn
对任何队列都未开启拥塞通知功能。
WRED表视图
在报文的发送端和接收端都支持ECN功能时,设备可以通过对ECN域的识别和标记将拥塞状况告知终端,避免拥塞加剧。
拥塞通知功能仅对TCP连接中的已知单播生效。
# 在WRED表queue-table1中,对队列1开启拥塞通知功能。
[Sysname-wred-table-queue-table1] queue 1 ecn
queue weighting-constant命令用来配置计算平均队列长度的指数。
undo queue weighting-constant命令用来恢复缺省情况。
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
计算平均队列长度的指数为9。
WRED表视图
weighting-constant exponent:计算平均队列长度的指数。exponent的取值范围为1~15。
平均队列长度的指数越大,计算平均队列长度时对队列的实时变化越不敏感。计算队列平均长度的公式为:平均队列长度=(以前的平均队列长度×(1-1/2n))+(当前队列长度×(1/2n))。其中n表示指数。
# 在WRED表queue-table1中,配置计算平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
6 聚合CAR
6.1  聚合CAR配置命令
6.1.1  car name
car name命令用来配置全局CAR动作。
undo car用来恢复缺省情况。
car name car-name [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
未配置全局CAR动作。
流行为视图
car-name:聚合CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
hierarchy-car-name:分层CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。
mode:分层CAR和聚合CAR动作的合作模式。有andor两种模式,默认为and模式。
·     and:在该模式下,对于多条数据流应用同一个分层CAR,必须每条流满足各自的聚合CAR配置,同时各流量之和又满足分层CAR的配置,流量才能正常通过。
·     or:在该模式下,对于多条数据流应用同一个分层CAR,只要每条流满足各自的聚合CAR配置或者各流量之和满足分层CAR配置,流量即可正常通过。
# 配置流行为be1的聚合CAR动作为aggcar-1。
# 配置流行为be1的聚合CAR动作为aggcar-1,分层CAR动作为hcar,合作模式为or。
[Sysname-behavior-be1] car name aggcar-1 hierarchy-car hcar mode or
·     display qos car name
·     display traffic behavior user-defined
display qos car name命令用来显示全局CAR的配置和统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。显示指定全局CAR的配置和统计信息。如果未指定本参数,将显示所有全局CAR的配置和统计信息,包含聚合CAR和分层CAR。
# 显示全局CAR的配置和统计信息。(独立运行模式)
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
   Green action  : pass
  Slot 0:
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
  Slot 1:
  Slot 2:
   Apply failed
  Mode: hierarchy
   CIR 64 (kbps) CBS: 2048 (Bytes)
表6-1 display qos car name命令显示信息描述表
Name
聚合CAR的名称
Mode
聚合CAR的类型,取值为aggregative(聚合CAR)和hierarchy(分层CAR)
CIR  CBS  PIR  EBS
流量监管流量的参数配置
Green action
对绿色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Yellow action
对黄色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Red action
对红色报文的动作
·     discard:丢弃报文
·     pass:允许报文通过
Green packets
绿色报文的流量统计
Yellow packets
黄色报文的流量统计
Red packets
红色报文的流量统计
qos car命令用来配置聚合CAR或分层CAR。
undo qos car命令用来取消聚合CAR或分层CAR的配置。
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
未配置聚合CAR或分层CAR。
aggregative:该全局CAR为聚合模式。
hierarchy:该全局CAR为分层模式。
cir committed-information-rate:承诺信息速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍。
cbs committed-burst-size:承诺突发尺寸,即实际平均速率在承诺速率以内时的突发流量,单位为byte。
ebs excess-burst-size:过度突发尺寸,单位为byte。本参数仅全局CAR为聚合模式时支持。
配置pir参数后:
·     如果不指定ebs,则ebs缺省取值为与62.5 × peak-information-rate的乘积最接近且不小于512的整数倍,但是最大值不能超过256000000。
·     如果指定ebs,取值范围0~256000000且必须为512的整数倍。
未配置pir参数时,ebs的取值范围为0~256000000且必须为512的整数倍。
pir peak-information-rate:峰值速率,单位为kbps。取值范围为8~160000000且必须为8的整数倍,本参数仅全局CAR为聚合模式时支持。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass,本参数仅全局CAR为聚合模式时支持。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard,本参数仅全局CAR为聚合模式时支持。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass,本参数仅全局CAR为聚合模式时支持。
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63;用文字表示时,可以选取af11af12af13af21af22af23af31af32af33af41af42af43cs1cs2cs3cs4cs5cs6cs7defaultef
聚合CAR配置需要在接口上应用或在策略中引用后才能生效。
分层CAR配置需要在策略中引用后才能生效。
不配置峰值速率表示所配置的是单速率流量监管,否则表示双速率流量监管。
# 配置聚合CAR采取的CAR参数取值,cir取值为25600,cbs取值为512000,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
# 配置分层CAR采取的CAR参数取值,cir取值为120,cbs取值为51200。
[Sysname] qos car h-car hierarchy cir 120 cbs 51200
reset qos car name命令用来清除全局CAR的统计信息。
car-name:全局CAR的名称,首字符需要以字母开头,为1~31个字符的字符串,区分大小写。清除指定全局CAR的统计信息。如果未指定本参数,将清除所有全局CAR的统计信息,包含聚合CAR和分层CAR。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
7 端口队列统计
7.1  端口队列统计配置命令
display qos queue-statistics interface outbound命令用来显示端口队列出方向的统计信息。
interface-type interface-number:指定接口类型和接口编号。如果未指定本参数,将显示所有接口的队列出方向统计信息。
# 显示接口Ten-GigabitEthernet1/0/1的队列出方向统计信息。
<Sysname> display qos queue-statistics interface ten-gigabitethernet 1/0/1 outbound
 Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 0 packets, 0 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
表7-1 display qos queue-statistics interface outbound命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Forwarded
转发的数据包数目和字节数
Dropped
丢弃的数据包数目和字节数
Queue 0、Queue 1、Queue 2、Queue 3、Queue 4、Queue 5、Queue 6、Queue 7
某端口队列统计信息
当前队列长度
·     reset counters interface(接口管理命令参考/以太网接口)
