整本手册(chm)
本章节下载 (7.82 MB)
A B C D E F G H I J K L M N O P Q R S T U V W X Y
archive configuration interval
archive configuration location
arp resolving-route probe-count
arp resolving-route probe-interval
attack-defense tcp fragment enable
authorization-attribute(ISP domain view)
authorization-attribute(Local user view/user group view)
bfd multi-hop authentication-mode
bfd multi-hop destination-port
bfd multi-hop detect-multiplier
bfd multi-hop min-receive-interval
bfd multi-hop min-transmit-interval
cfd ais-track link-status global
cfd ais-track link-status level
cfd ais-track link-status period
cfd ais-track link-status vlan
controller echo-request interval
cwmp cpe inform interval enable
data-flow-format (HWTACACS scheme view)
data-flow-format (RADIUS scheme view)
description (any NQA test type view)
dhcp relay check mac-address aging-time
dhcp relay client-information record
dhcp relay client-information refresh
dhcp relay client-information refresh enable
dhcp relay information circuit-id
dhcp relay information remote-id
dhcp relay information strategy
dhcp server bootp reply-rfc-1048
dhcp server relay information enable
dhcp snooping binding database filename
dhcp snooping binding database update interval
dhcp snooping binding database update now
dhcp snooping check mac-address
dhcp snooping check request-message
dhcp snooping information circuit-id
dhcp snooping information enable
dhcp snooping information remote-id
dhcp snooping information strategy
dhcp snooping max-learning-num
display | { begin | exclude | include }
display arp detection statistics
display arp source-suppression
display cfd ais-track link-status
display cfd dm one-way history
display cfd linktrace-reply auto-detection
display cpu-usage configuration
display crypto-engine statistics
display current-configuration diff
display device manuinfo power(仅S5560-28F-SI支持)
display dhcp relay check mac-address
display dhcp relay client-information
display dhcp relay information
display dhcp relay server-address
display dhcp server statistics
display dhcp snooping binding database
display dhcp snooping information
display dhcp snooping packet statistics
display diagnostic-information
display diagnostic-logfile summary
display igmp-snooping router-port
display igmp-snooping static-group
display igmp-snooping static-router-port
display igmp-snooping statistics
display interface vlan-interface
display ip policy-based-route interface
display ip policy-based-route local
display ip policy-based-route setup
display ip routing-table ip-address
display ip routing-table prefix-list
display ip routing-table protocol
display ip routing-table statistics
display ipsec { ipv6-policy | policy }
display ipsec { ipv6-policy-template | policy-template }
display ip-subnet-vlan interface
display ipv6 dhcp client statistics
display ipv6 dhcp relay server-address
display ipv6 dhcp relay statistics
display ipv6 dhcp server conflict
display ipv6 dhcp server expired
display ipv6 dhcp server ip-in-use
display ipv6 dhcp server pd-in-use
display ipv6 dhcp server statistics
display ipv6 dhcp snooping binding
display ipv6 dhcp snooping binding database
display ipv6 dhcp snooping packet statistics
display ipv6 dhcp snooping trust
display ipv6 l2-multicast ip forwarding
display ipv6 l2-multicast mac forwarding
display ipv6 multicast-vlan forwarding-table
display ipv6 multicast-vlan group
display ipv6 nd detection statistics
display ipv6 nd snooping count
display ipv6 pim-snooping neighbor
display ipv6 pim-snooping router-port
display ipv6 pim-snooping routing-table
display ipv6 pim-snooping statistics
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
display ipv6 route-static routing-table
display ipv6 routing-table acl
display ipv6 routing-table ipv6-address
display ipv6 routing-table prefix-list
display ipv6 routing-table protocol
display ipv6 routing-table statistics
display irf-port load-sharing mode
display kernel deadloop configuration
display kernel starvation configuration
display l2-multicast ip forwarding
display l2-multicast mac forwarding
display link-aggregation load-sharing mode
display link-aggregation member-port
display link-aggregation summary
display link-aggregation verbose
display lldp local-information
display lldp neighbor-information
display mac-address aging-time
display mac-address mac-learning
display mac-address statistics
display mac-authentication connection
display mac-forced-forwarding interface
display mac-forced-forwarding vlan
display mld-snooping router-port
display mld-snooping static-group
display mld-snooping static-router-port
display mld-snooping statistics
display multicast-vlan forwarding-table
display ntp-service ipv6 sessions
display packet-filter statistics
display packet-filter statistics sum
display password-control blacklist
display pim-snooping router-port
display pim-snooping routing-table
display pim-snooping statistics
display pki certificate access-control-policy
display pki certificate attribute-group
display pki certificate domain
display pki certificate request-status
display portal packet statistics
display port-security mac-address block
display port-security mac-address security
display process memory heap address
display process memory heap size
display protocol-vlan interface
display public-key local public
display qos policy control-plane
display qos policy control-plane pre-defined
display qos queue wfq interface
display qos queue wrr interface
display qos queue-statistics interface outbound
display route-static routing-table
display security-logfile summary
display snmp-agent local-engineid
display stp region-configuration
display voice-vlan mac-address
dot1p-priority (IGMP-Snooping view)
dot1p-priority (MLD-Snooping view)
dot1x re-authenticate server-unreachable keep-online
entry-limit (IGMP-Snooping view)
entry-limit (MLD-Snooping view)
fast-leave (IGMP-Snooping view)
fast-leave (MLD-Snooping view)
gratuitous-arp-learning enable
group-policy (IGMP-Snooping view)
group-policy (MLD-Snooping view)
host-aging-time (IGMP-Snooping view)
host-aging-time (MLD-Snooping view)
igmp-snooping general-query source-ip
igmp-snooping last-member-query-interval
igmp-snooping max-response-time
igmp-snooping overflow-replace
igmp-snooping report source-ip
igmp-snooping router-aging-time
igmp-snooping router-port-deny
igmp-snooping special-query source-ip
ike invalid-spi-recovery enable
ike signature-identity from-certificate
info-center diagnostic-logfile directory
info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
info-center diagnostic-logfile quota
info-center logfile overwrite-protection
info-center logfile size-quota
info-center logging suppress duplicates
info-center security-logfile alarm-threshold
info-center security-logfile directory
info-center security-logfile enable
info-center security-logfile frequency
info-center security-logfile size-quota
info-center trace-logfile quota
ip https certificate access-control-policy
ip route-static default-preference
ip source binding(interface view)
ip source binding(system view)
ipsec { ipv6-policy | policy } isakmp template
ipsec { ipv6-policy | policy } local-address
ipsec { ipv6-policy-template | policy-template } policy-template
ipv6 dhcp client stateless enable
ipv6 dhcp server forbidden-address
ipv6 dhcp server forbidden-prefix
ipv6 dhcp snooping binding database filename
ipv6 dhcp snooping binding database update interval
ipv6 dhcp snooping binding database update now
ipv6 dhcp snooping binding record
ipv6 dhcp snooping check request-message
ipv6 dhcp snooping max-learning-num
ipv6 dhcp snooping option interface-id enable
ipv6 dhcp snooping option interface-id string
ipv6 dhcp snooping option remote-id enable
ipv6 dhcp snooping option remote-id string
ipv6 multicast-vlan entry-limit
ipv6 nd ra hop-limit unspecified
ipv6 nd snooping enable global
ipv6 nd snooping enable link-local
ipv6 nd snooping max-learning-num
ipv6 neighbors max-learning-num
ipv6 pim-snooping graceful-restart join-aging-time
ipv6 pim-snooping graceful-restart neighbor-aging-time
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (System view)
ipv6 route-static default-preference
ipv6 source binding(interface view)
ipv6 source binding(system view)
irf-port global load-sharing mode
last-listener-query-interval (MLD-Snooping view)
last-member-query-interval (IGMP-Snooping view)
link-aggregation global load-sharing mode
link-aggregation lacp traffic-redirect-notification enable
link-aggregation load-sharing mode local-first
link-aggregation port-priority
link-aggregation selected-port maximum
link-aggregation selected-port minimum
lldp compliance admin-status cdp
lldp management-address-format string
lldp notification med-topology-change enable
lldp notification remote-change enable
lldp timer notification-interval
loopback-detection global action
loopback-detection global enable
loopback-detection interval-time
mac-address information enable (interface view)
mac-address information enable (system view)
mac-address information interval
mac-address information queue-length
mac-address mac-learning enable
mac-address mac-move fast-update
mac-address mac-roaming enable
mac-address max-mac-count enable-forwarding
mac-address notification mac-move
mac-address notification mac-move suppression
mac-address notification mac-move suppression interval
mac-address notification mac-move suppression threshold
mac-address static source-check enable
mac-authentication critical vlan
mac-authentication re-authenticate server-unreachable keep-online
mac-authentication timer auth-delay
mac-authentication user-name-format
mac-forced-forwarding gateway probe
mac-forced-forwarding network-port
match local address (IKE keychain view)
match local address (IKE profile view)
max-response-time (IGMP-Snooping view)
max-response-time (MLD-Snooping view)
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-egress
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
mirroring-group reflector-port
mirroring-group remote-probe vlan
mld-snooping general-query source-ip
mld-snooping last-listener-query-interval
mld-snooping max-response-time
mld-snooping router-aging-time
mld-snooping special-query source-ip
monitor kernel deadloop enable
monitor kernel deadloop exclude-thread
monitor kernel starvation enable
monitor kernel starvation exclude-thread
monitor kernel starvation time
ntp-service authentication enable
ntp-service authentication-keyid
ntp-service ipv6 inbound disable
ntp-service ipv6 multicast-client
ntp-service ipv6 multicast-server
ntp-service ipv6 unicast-server
ntp-service max-dynamic-sessions
ntp-service reliable authentication-keyid
oam errored-frame-period threshold
oam errored-frame-period window
oam errored-frame-seconds threshold
oam errored-frame-seconds window
oam errored-symbol-period threshold
oam errored-symbol-period window
oam global errored-frame threshold
oam global errored-frame window
oam global errored-frame-period threshold
oam global errored-frame-period window
oam global errored-frame-seconds threshold
oam global errored-frame-seconds window
oam global errored-symbol-period threshold
oam global errored-symbol-period window
oam remote-loopback reject-request
operation (FTP test type view)
operation (HTTP test type view)
overflow-replace (IGMP-Snooping view)
overflow-replace (MLD-Snooping view)
password-control { aging | composition | history | length } enable
password-control alert-before-expire
password-control expired-user-login
password-control login idle-time
password-control login-attempt
password-control super composition
password-control update-interval
pki-domain (SSL client policy view)
pki-domain (SSL server policy view)
port (IPv6 multicast-VLAN view)
port private-vlan trunk promiscuous
port private-vlan trunk secondary
portal free-all except destination
portal ipv6 free-all except destination
port-security authorization ignore
port-security authorization-fail offline
port-security mac-address aging-type inactivity
port-security mac-address dynamic
port-security timer autolearn aging
port-security timer disableport
primary accounting (HWTACACS scheme view)
primary accounting (RADIUS scheme view)
primary authentication (HWTACACS scheme view)
primary authentication (RADIUS scheme view)
private-vlan(VLAN interface view)
qinq ethernet-type customer-tag
qinq ethernet-type service-tag
qos apply policy (interface view, control plane view)
qos apply policy (user-profile view)
qos wfq { byte-count | weight }
qos wrr { byte-count | weight }
reaction checked-element { jitter-ds | jitter-sd }
reaction checked-element { owd-ds | owd-sd }
reaction checked-element icpif
reaction checked-element packet-loss
reaction checked-element probe-duration
reaction checked-element probe-fail (for trap)
reaction checked-element probe-fail (for trigger)
report-aggregation (IGMP-Snooping view)
report-aggregation (MLD-Snooping view)
reset arp detection statistics
reset counters interface loopback
reset crypto-engine statistics
reset dhcp relay client-information
reset dhcp snooping packet statistics
reset igmp-snooping router-port
reset igmp-snooping statistics
reset ip policy-based-route statistics
reset ip routing-table statistics protocol
reset ipv6 dhcp client statistics
reset ipv6 dhcp relay statistics
reset ipv6 dhcp server conflict
reset ipv6 dhcp server expired
reset ipv6 dhcp server ip-in-use
reset ipv6 dhcp server pd-in-use
reset ipv6 dhcp server statistics
reset ipv6 dhcp snooping binding
reset ipv6 dhcp snooping packet statistics
reset ipv6 multicast-vlan group
reset ipv6 nd detection statistics
reset ipv6 pim-snooping statistics
reset ipv6 policy-based-route statistics
reset ipv6 routing-table statistics protocol
reset mac-authentication critical-vlan
reset mac-authentication guest-vlan
reset mac-authentication statistics
reset mld-snooping router-port
reset openflow instance controller statistics
reset packet-filter statistics
reset password-control blacklist
reset password-control history-record
reset portal packet statistics
reset qos policy control-plane
router-aging-time (IGMP-Snooping view)
router-aging-time (MLD-Snooping view)
rule (Ethernet frame header ACL view)
secondary accounting (HWTACACS scheme view)
secondary accounting (RADIUS scheme view)
secondary authentication (HWTACACS scheme view)
secondary authentication (RADIUS scheme view)
server-detect (portal server view)
server-detect (portal web-server view)
snmp-agent { inform | trap } source
snmp-agent trap enable mac-address
snmp-agent trap if-mib link extended
snmp-agent usm-user { v1 | v2c }
sntp reliable authentication-keyid
source-deny (IGMP-Snooping view)
source-deny (MLD-Snooping view)
ssh server authentication-retries
ssh server authentication-timeout
ssh server compatible-ssh1x enable
stp global config-digest-snooping
subvlan (IPv6 multicast-VLAN view)
timer quiet (HWTACACS scheme view)
timer quiet (RADIUS scheme view)
timer realtime-accounting (HWTACACS scheme view)
timer realtime-accounting (RADIUS scheme view)
timer response-timeout (HWTACACS scheme view)
timer response-timeout (RADIUS scheme view)
user-name-format (HWTACACS scheme view)
