07-ACL和QoS命令参考
02-QoS命令
本章节下载: 02-QoS命令  (459.94 KB)
02-QoS命令
1 QoS策略配置命令
1.1 定义类的命令
1.1.1 display traffic classifier
1.1.2 if-match
1.1.3 traffic classifier
1.2 定义流行为的命令
1.2.1 accounting
1.2.2 car
1.2.3 display traffic behavior
1.2.4 filter
1.2.5 redirect
1.2.6 remark dot1p
1.2.7 remark drop-precedence
1.2.8 remark dscp
1.2.9 remark ip-precedence
1.2.10 remark local-precedence
1.2.11 remark qos-local-id
1.2.12 traffic behavior
1.3 定义策略和应用策略的命令
1.3.1 classifier behavior
1.3.2 control-plane
1.3.3 display qos policy
1.3.4 display qos policy control-plane
1.3.5 display qos policy control-plane pre-defined
1.3.6 display qos policy global
1.3.7 display qos policy interface
1.3.8 display qos vlan-policy
1.3.9 qos apply policy (interface view, port group view, control plane view)
1.3.10 qos apply policy (user-profile view)
1.3.11 qos apply policy global
1.3.12 qos policy
1.3.13 qos vlan-policy
1.3.14 reset qos policy control-plane
1.3.15 reset qos policy global
1.3.16 reset qos vlan-policy
2 优先级映射配置命令
2.1 优先级映射表配置命令
2.1.1 display qos map-table
2.1.2 import
2.1.3 qos map-table
2.2 端口优先级配置命令
2.2.1 qos priority
2.3 端口优先级信任模式配置命令
2.3.1 display qos trust interface
2.3.2 qos trust
3 流量整形/端口限速命令
3.1 流量整形配置命令
3.1.1 display qos gts interface
3.1.2 qos gts
3.1.3 display qos lr interface
3.1.4 qos lr
4 拥塞管理配置命令
4.1 严格优先级队列配置命令
4.1.1 display qos sp
4.1.2 qos sp
4.2 加权轮询队列配置命令
4.2.1 display qos wrr interface
4.2.2 qos wrr
4.2.3 qos wrr byte-count
4.2.4 qos wrr group sp
4.2.5 qos wrr weight
4.3 加权公平队列配置命令
4.3.1 display qos wfq interface
4.3.2 qos bandwidth queue
4.3.3 qos wfq
4.3.4 qos wfq byte-count
4.3.5 qos wfq group sp
4.3.6 qos wfq weight
4.4 端口队列统计显示命令
4.4.1 display qos queue-statistics
5 拥塞避免配置命令
5.1 WRED配置命令
5.1.1 display qos wred interface
5.1.2 display qos wred table
5.1.3 qos wred apply
5.1.4 qos wred queue table
5.1.5 queue
5.1.6 queue weighting-constant
6 全局CAR配置命令
6.1 全局CAR配置命令
6.1.1 car name
6.1.2 display qos car name
6.1.3 qos car aggregative
6.1.4 qos car hierarchy
6.1.5 reset qos car name
7 数据缓冲区配置命令
7.1 自动配置数据缓冲区的命令
7.1.1 burst-mode enable
7.2 手工配置数据缓冲区的命令
7.2.1 buffer apply
7.2.2 buffer egress queue guaranteed
7.2.3 buffer egress queue shared
7.2.4 buffer egress shared
7.2.5 buffer egress total-shared
1 QoS策略配置命令
QoS策略功能中的“端口”包括二层以太网端口和三层以太网端口。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
1.1  定义类的命令
display traffic classifier user-defined [ tcl-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义类。
tcl-name:类名,为1~31个字符的字符串。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display traffic classifier命令用来显示配置的类信息。
如果未指定类名,本命令将显示所有用户定义类的信息。
# 显示配置的用户自定义的类信息。
User Defined Classifier Information:
 Classifier: USER1
  Operator: AND
  Rule(s) : If-match ip-precedence 5
 Classifier: database
  Operator: AND
  Rule(s) : If-match acl 3131
表1-1 display traffic classifier user-defined命令显示信息描述表
用户自定义类的信息
Classifier
类的名字及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule
分类规则
1.1.2  if-match
if-match match-criteria
undo if-match match-criteria
类视图
【缺省级别】
2:系统级
表1-2 类的匹配规则取值
取值
acl [ ipv6 ] { acl-number | name acl-name }
定义匹配ACL的规则
acl-number是ACL的序号,IPv4 ACL序号的取值范围是2000~3999,IPv6 ACL序号的取值范围是2000~3999,二层ACL序号的取值范围是4000~4999
acl-name是ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头,为避免混淆,ACL的名称不可以使用英文单词all
any
定义匹配所有数据包的规则
dscp dscp-list
定义匹配DSCP的规则,dscp-list为DSCP取值的列表,最多可以输入8个DSCP取值,DSCP取值范围为0~63或表1-4中的关键字
destination-mac mac-address
定义匹配目的MAC地址的规则
customer-dot1p 8021p-list
定义匹配用户网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
service-dot1p 8021p-list
定义匹配运营商网络802.1p优先级的规则,8021p-list为802.1p优先级值的列表,最多可以输入8个802.1p优先级值,802.1p优先级取值范围为0~7
ip-precedence ip-precedence-list
定义匹配IP优先级的规则,ip-precedence-list为ip-precedence的列表,最多可以输入8个ip-precedence,ip-precedence取值范围为0~7
protocol protocol-name
定义匹配协议的规则,protocol-name取值为ip或ipv6
qos-local-id local-id-value
定义匹配qos-local-id的规则,local-id-value为QoS本地ID,取值范围为1~4095
在本系列交换机上,能够支持的local-id-value值为1~3999
source-mac mac-address
定义匹配源MAC地址的规则
customer-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配用户网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4094
service-vlan-id { vlan-id-list | vlan-id1 to vlan-id2 }
定义匹配运营商网络VLAN ID的规则,vlan-id-list为VLAN ID的列表,最多可以输入8个VLAN ID,vlan-id1 to vlan-id2表示一个VLAN ID的范围,vlan-id1的值必须小于vlan-id2的值,VLAN ID取值范围为1~4094
system-index index-value-list
定义规则来匹配预定义的上送控制平面报文类型,index-value-list为系统预定义匹配字段索引号(system-index)的列表,最多可以输入8个system-index值,system-index值的取值范围为1~128
如果指定类的逻辑关系为and,使用if-match命令定义匹配规则时,有如下注意事项:
·     匹配规则含有acl或acl ipv6时,如果在类中配置了多条这样的匹配规则,在应用策略时,匹配acl或acl ipv6的规则之间的逻辑关系实际为or。
·     匹配规则含有customer-vlan-id或service-vlan-id时,如果在类中配置了多条这样的匹配规则,在应用策略时,匹配customer-vlan-id或service-vlan-id的规则之间的逻辑关系实际为or。
当流分类中各规则之间的逻辑关系为and时,对于以下匹配条件,用户虽然可以通过重复执行if-match命令来配置多条匹配不同取值的规则,或在一条规则中使用list形式输入多个匹配值,但在应用使用该类的QoS策略时,系统将提示应用失败:
·     customer-dot1p 8021p-list
·     destination-mac mac-address(不支持list形式)
·     dscp dscp-list
·     ip-precedence ip-precedence-list
·     service-dot1p 8021p-list
·     source-mac mac-address(不支持list形式)
·     system-index index-value-list
如果用户需要创建匹配以上某一字段多个取值的规则,需要在创建流分类时指定各规则之间的逻辑关系为or,然后再通过多次执行if-match命令的方式来配置匹配多个值的规则。
【描述】
if-match命令用来定义匹配指定匹配规则的所有报文的规则。undo if-match命令用来删除匹配指定匹配规则的所有报文的规则。
在定义各个规则的时候,注意事项如下:
(1)     定义匹配ACL的规则
·     如果类中引用的ACL不存在,则不能在硬件中下发。
·     对同一个类,允许通过ACL名称和序号的方式分别引用一次同一个ACL。
(2)     定义匹配目的MAC地址和源MAC地址规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。
(3)     定义匹配DSCP的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,dscp值将自动按照从小到大的顺序排序。
·     删除某条匹配DSCP的规则时,指定的所有DSCP值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(4)     定义匹配用户网络或运营商网络的802.1p优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,8021p值将自动按照从小到大的顺序排序。
·     删除某条匹配802.1p优先级的规则时,指定的所有802.1p优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(5)     定义匹配IP优先级的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,IP优先级的值将自动按照从小到大的顺序排序。
·     删除某条匹配IP优先级的规则时,指定的所有IP优先级值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(6)     定义匹配用户网络和运营商网络VLAN ID的规则
·     一个类下可配置多条这样的命令,各个配置之间互相不覆盖。每条命令在配置后,vlan-id值将自动按照从小到大的顺序排序。
·     一条命令可以配置多个VLAN ID值,如果指定了多个相同的VLAN ID值,系统默认为一个;多个不同的VLAN ID值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配VLAN ID的规则时,指定的所有VLAN ID值必须与该规则中定义的完全相同才会删除,顺序可不一样。
(7)     定义匹配预定义的上送控制平面报文类型的规则
·     一条命令可以配置多个system-index值,如果指定了多个相同的system-index值,系统默认为一个;多个不同的system-index值是或的关系,即只要有一个值匹配,就算匹配这条规则。
·     删除某条匹配system-index的规则时,指定的所有system-index值必须与该规则中定义的完全相同才会删除,顺序可不一样。
·     系统预定义的报文类型信息可以通过display qos policy control-plane pre-defined命令查看。
相关配置可参考命令traffic classifier。
# 定义类class1的匹配规则为:匹配用户网络802.1p优先级为3。
# 定义类class1的匹配规则为:匹配运营商网络802.1p优先级为5。
[Sysname-classifier-class1] if-match service-dot1p 5
# 定义类匹配ACL3101。
# 定义类匹配ACL flow。
# 定义类匹配IPv6 ACL3101。
# 定义类匹配IPv6 ACL flow。
# 定义匹配所有数据包的规则。
# 定义类class1的匹配规则为:匹配DSCP值为1或6或9的报文。
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1
[Sysname-classifier-class1] if-match dscp 6
[Sysname-classifier-class1] if-match dscp 9
# 定义类class1的匹配规则为:匹配IP优先级值为1或6的报文。
[Sysname-classifier-class1] if-match ip-precedence 1
[Sysname-classifier-class1] if-match ip-precedence 6
# 定义类匹配IP协议的报文。
# 定义类class1的匹配规则为:匹配用户网络VLAN ID值为1或6或9的报文。
# 定义类class1的匹配规则为:匹配运营商网络VLAN ID值为2或7或10的报文。
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# 定义类匹配qos-local-id 3。
[Sysname-classifier-class1] if-match qos-local-id 3
# 在流分类class1中配置匹配系统预定义的字段索引号为1的报文类型。
[Sysname-classifier-class1] if-match system-index 1
traffic classifier tcl-name [ operator { and | or } ]
undo traffic classifier tcl-name
【缺省级别】
2:系统级
operator:指定各规则之间的逻辑运算符。
【描述】
traffic classifier命令用来定义一个类并进入类视图。undo traffic classifier命令用来删除一个类。
缺省情况下为operator and。
相关配置可参考命令qos policy、qos apply policy和classifier behavior。
# 定义一个名为class1的类。
1.2  定义流行为的命令
1.2.1  accounting
accounting { byte | packet }
undo accounting
流行为视图
【缺省级别】
2:系统级
byte:表示报文基于字节为单位进行统计。
packet:表示报文基于包为单位进行统计。
【描述】
accounting命令用来为流行为配置流量统计动作。undo accounting命令用来取消流量统计动作配置。
相关统计信息可以通过命令display qos policy interface和display qos vlan-policy查看。
相关配置可参考命令qos policy、traffic behavior和classifier behavior。
# 为流行为配置流量统计动作,并指定统计单位为byte。
[Sysname-behavior-database] accounting byte
1.2.2  car
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peak-information-rate ] [ green action ] [ yellow action ] [ red action ] [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
流行为视图
【缺省级别】
2:系统级
cir committed-information-rate:承诺信息速率。流量的平均速率,单位为kbps。取值范围为8~10000000且必须为8的整数倍。
cbs committed-burst-size:承诺突发尺寸,单位为Byte。
·     如果不指定cbs参数,缺省取值为62.5 × committed-information-rate,但是最大值不能超过256000000。
·     如果指定cbs参数,取值范围512~256000000。
ebs excess-burst-size:超出突发尺寸,缺省值为512,单位为Byte。取值范围为0~256000000。
pir peak information rate:峰值速率,单位为kbps。取值范围为8~10000000且必须为8的整数倍。
green action:数据包的流量符合承诺速率时对数据包采取的动作,缺省动作为pass。
yellow action:数据包的流量不符合承诺速率但是符合峰值速率时对数据包采取的动作,缺省动作为pass。
red action:数据包的流量既不符合承诺速率也不符合峰值速率时对数据包采取的动作,缺省动作为discard。
action:对数据包采取的动作,有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
·     remark-dot1p-pass new-cos:设置新的802.1P报文的优先级值,并允许数据包通过,取值范围为0~7。
·     remark-dscp-pass new-dscp:设置报文新的DSCP值,并允许数据包通过,取值范围为0~63或表1-4中的关键字。
·     remark-lp-pass new-local-precedence:设置新的本地优先级,并允许数据包通过,取值范围为0~7。
hierarchy-car-name:分层CAR的名称。
mode:分层CAR和CAR动作的合作模式。有and和or两种模式,默认为and模式。
·     and:在该模式下,对于多条数据流应用同一个分层CAR,必须每条流满足各自的CAR配置,同时各流量之和又满足分层CAR的配置,流量才能正常通过。
·     or:在该模式下,对于多条数据流应用同一个分层CAR,只要每条流满足各自的CAR配置或者各流量之和满足分层CAR配置,流量即可正常通过。
【描述】
car命令用来为流行为配置流量监管动作。undo car命令用来取消流量监管动作配置。
端口上应用的策略中使用car时,可以应用到端口报文的接收或者发送方向。
如果多次使用该命令在同一个流行为上配置,最后一次配置生效。
# 为流行为配置流量监管。报文正常流速为128kbps,承诺突发尺寸为50000bytes,速率大于128kbps时,报文DSCP优先级改为0并发送。
[Sysname-behavior-database] car cir 128 cbs 50000 ebs 0 green pass red remark-dscp-pass 0
# 为流行为配置流量监管。报文正常流速为128kbps,承诺突发尺寸为50000bytes,速率大于128kbps时,报文DSCP优先级改为0,之后再进行第二次分层CAR动作,并使用or模式。
[Sysname-behavior-database] car cir 128 cbs 50000 ebs 0 green pass red remark-dscp-pass 0 hierarchy-car hcar mode or
display traffic behavior user-defined [ behavior-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义行为。
behavior-name:行为名,为1~31个字符的字符串。如果未指定行为名,则显示所有用户定义行为的信息。
【描述】
display traffic behavior命令用来显示配置的流行为信息。
# 显示配置的用户自定义的流行为信息。
User Defined Behavior Information:
    Behavior: 2
      Accounting enable: byte
      Committed Access Rate:
        CIR 12800 (kbps), CBS 40960 (byte), EBS 4000 (byte)
        Green Action: pass
        Red Action: discard
        Yellow Action: pass
      Redirect enable:
        Redirect type: cpu
        Redirect destination: cpu
      Marking:
        Remark dot1p COS 1
      Marking:
        Remark DSCP af12
表1-3 display traffic behavior user-defined命令显示信息描述表
用户自定义流行为的信息
Behavior
行为的名字及其内容,内容可以有多种类型
Marking
重标记的相关信息
Remark
重标记的类型。可支持的类型有DSCP、IP precedence、dot1p COS、qos local ID、local precedence、drop precedence、Customer VLAN ID、Service VLAN ID等类型,相关类型描述请参考1.2  定义流行为的命令
Accounting enable
流量统计相关信息。统计单位可以配置字节(byte)和报文个数(packet)两种方式
流量限速的相关信息
Green Action
对绿色报文的处理
Red Action
对红色报文的处理
Yellow Action
对黄色报文的处理
Redirect enable
流量重定向相关信息
Redirect type
重定向类型,目前支持CPU、interface、next-hop三种
重定向的目的。对应不同的重定向类型,可以显示为cpu、端口名称、或者下一跳的IP地址
1.2.4  filter
filter { deny | permit }
undo filter
流行为视图
【缺省级别】
2:系统级
deny:丢弃数据包。
permit:允许数据包通过。
【描述】
filter命令用来为流行为配置流量过滤动作。undo filter命令用来取消过滤动作配置。
# 为流行为配置丢弃数据包的过滤动作。
1.2.5  redirect
redirect { cpu | interface interface-type interface-number | next-hop { ipv4-add1 [ ipv4-add2 ] | ipv6-add1 [ interface-type interface-number ] [ ipv6-add2 [ interface-type interface-number ] ] } [ fail-action { discard | forward } ] }
undo redirect { cpu | interface interface-type interface-number | next-hop }
流行为视图
【缺省级别】
2:系统级
cpu:重定向到CPU。
interface:重定向到指定的接口。
next-hop:重定向到指定的下一跳。
ipv4-add:下一跳IPv4地址。ipv4-add2是ipv4-add1的备份下一跳地址,如果重定向到ipv4-add1失败,则会选择重定向到ipv4-add2。
ipv6-add:下一跳IPv6地址。IPv6地址为链路本地地址时,下一跳IPv6地址需要配置接口;IPv6地址为非链路本地地址时,下一跳IPv6地址不需要配置接口。ipv6-add2是ipv6-add1的备份下一跳地址,如果重定向到ipv6-add1失败,则会选择重定向到ipv6-add2。
fail-action { discard | forward }:当下一跳的地址不存在时,对报文采取的处理动作。discard表示丢弃此报文。forward表示转发此报文。
【描述】
redirect命令用来为流行为配置流量重定向动作。undo redirect命令用来取消流量重定向动作配置。
·     在配置重定向动作时,同一个流行为中重定向类型只能为重定向到CPU、重定向到端口、重定向到下一跳中的一种。
·     如果不配置重定向下一跳失败的处理动作,默认的处理动作是转发。
# 为流行为配置流量重定向动作,重定向到GigabitEthernet1/0/1。
[Sysname-behavior-database] redirect interface gigabitethernet1/0/1
1.2.6  remark dot1p
remark { [ green | red | yellow ] dot1p 8021p | dot1p customer-dot1p-trust }
undo remark [ green | red | yellow ] dot1p
流行为视图
【缺省级别】
2:系统级
green:重标记绿色报文的802.1p优先级。
red:重标记红色报文的802.1p优先级。
yellow:重标记黄色报文的802.1p优先级。
8021p:标记的802.1p优先级,取值范围为0~7。
customer-dot1p-trust:QoS策略应用到端口后,将内层VLAN Tag的802.1p优先级复制为外层VLAN Tag的802.1p优先级。如果报文只携带一层Tag,则配置不生效。
【描述】
remark dot1p命令用来配置标记报文的802.1p优先级或内外层标签优先级复制功能。undo remark dot1p命令用来取消配置。
需要注意的是,命令remark dot1p 8021p和remark dot1p customer-dot1p-trust是覆盖关系。
# 配置标记报文的802.1p优先级值为2。
[Sysname-behavior-database] remark dot1p 2
# 重标记绿色报文的802.1p优先级为2。
[Sysname-behavior-database] remark green dot1p 2
# 配置内外层标签优先级复制功能。
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
remark drop-precedence drop-precedence-value
undo remark drop-precedence
流行为视图
【缺省级别】
2:系统级
drop-precedence-value:标记的丢弃优先级,取值范围为0~2。
【描述】
remark drop-precedence命令用来配置标记报文的丢弃优先级。undo remark drop-precedence命令用来取消标记报文的丢弃优先级。
# 配置标记报文的丢弃优先级值为2。
[Sysname-behavior-database] remark drop-precedence 2
1.2.8  remark dscp
undo remark [ green | red | yellow ] dscp
流行为视图
【缺省级别】
2:系统级
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
dscp-value:DSCP值,取值范围为0~63,也可以是关键字,如表1-4所示。
表1-4 DSCP关键字与值的对应表
关键字
DSCP值(二进制)
DSCP值(十进制)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
【描述】
remark dscp命令用来为类配置标记报文的DSCP值。undo remark dscp命令用来取消标记报文的DSCP值。
# 配置标记报文的DSCP值为6。
remark  ip-precedence ip-precedence-value
undo remark ip-precedence
流行为视图
【缺省级别】
2:系统级
ip-precedence-value:标记的IP优先级,取值范围为0~7。
【描述】
remark ip-precedence命令用来配置标记报文的IP优先级。undo remark ip-precedence命令用来取消标记报文的IP优先级。
# 配置标记报文的IP优先级值为6。
[Sysname-behavior-database] remark ip-precedence 6
remark [ green | red | yellow ] local-precedence local-precedence
undo remark [ green | red | yellow ] local-precedence
流行为视图
【缺省级别】
2:系统级
green:对绿色报文进行重标记。
red:对红色报文进行重标记。
yellow:对黄色报文进行重标记。
local-precedence:标记的本地优先级,取值范围为0~7。
【描述】
remark local-precedence命令用来配置标记报文的本地优先级。undo remark local-precedence命令用来取消标记报文的本地优先级。
需要注意的是,remark local-precedence动作与remark dot1p动作同时配置时,两者重标记的本地优先级和802.1p优先级的取值必须相同,否则策略将不能成功应用。
# 配置标记报文的本地优先级值为2。
remark qos-local-id local-id-value
undo remark qos-local-id
流行为视图
【缺省级别】
2:系统级
local-id-value:标记的QoS本地ID值,取值范围为1~4095。在本系列交换机上,能够支持的local-id-value值为1~3999。
【描述】
remark qos-local-id命令用来配置标记报文的qos-local-id值。undo remark qos-local-id命令用来取消标记报文的qos-local-id值。
# 配置标记报文的qos-local-id值为2。
[Sysname-behavior-database] remark qos-local-id 2
【缺省级别】
2:系统级
behavior-name:流行为名,为1~31个字符的字符串。
【描述】
traffic behavior命令用来定义一个流行为并进入流行为视图。undo traffic behavior命令用来删除一个流行为。
# 定义一个名为behavior1的流行为。
[Sysname-behavior-behavior1]
1.3  定义策略和应用策略的命令
classifier tcl-name behavior behavior-name [ mode dot1q-tag-manipulation ]
undo classifier tcl-name
策略视图
【缺省级别】
2:系统级
mode dot1q-tag-manipulation:设置该类和流行为对应关系用于VLAN映射功能。有关VLAN映射功能的介绍,请参见“二层技术-以太网交换配置指导”中的“VLAN映射”。
【描述】
classifier behavior命令用来在策略中为类指定采用的流行为。undo classifier命令用来取消指定类在策略中的使用。
·     策略下每个类只能与一个动作关联。
·     如果配置本命令时指定的类和流行为不存在,系统将创建一个空的类和空的流行为。
当用户在策略下配置了多组类和流行为的对应关系时,如果某个流行为中配置了nest、remark customer-vlan-id或remark service-vlan-id动作,建议用户不要在此流行为中配置其他动作,以保证应用策略后实际的运行结果与用户的配置意图一致。
相关配置可参考命令qos policy。
# 在策略user1中为类database指定采用流行为test。
[Sysname] qos policy user1
1.3.2  control-plane
【缺省级别】
2:系统级
slot slot-number:在IRF中,使用slot参数进入指定成员设备的控制平面视图。slot-number的取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
control-plane命令用来进入控制平面视图。
# 进入2号成员设备的控制平面视图。
[Sysname] control-plane 2
[Sysname-cp-slot2]
display qos policy user-defined [ policy-name [ classifier tcl-name ] ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
user-defined:用户定义策略。
policy-name:策略名,为1~31个字符的字符串。如果未指定,则显示所有用户定义策略的配置信息。
tcl-name:策略中的类名。
【描述】
display qos policy命令用来显示用户定义策略的配置信息。
# 显示用户定义策略的配置信息。
User Defined QoS Policy Information:
Policy: test
 Classifier: 1
   Behavior: be
    -none-
 Classifier: USER1
   Behavior: USER1
      CIR 256 (kbps), CBS 15000 (byte), EBS 0 (byte)
      Green Action: pass
      Red  Action: discard
    Marking:
      Remark IP Precedence 3
      Remark dot1p COS 2
表1-5 display qos policy命令显示信息描述表
Policy
策略名
Classifier
类名,一个策略中可以存在多个类,每个类有对应的行为,每个类的匹配规则又可以有多条,参见traffic classifier命令
Behavior
策略中一个类对应的行为,每个行为可以有多条规则,参见traffic behavior命令
display qos policy control-plane slot slot-number [ inbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定成员设备的控制平面上应用QoS策略的信息。slot-number的取值范围取决于当前IRF中的成员数量和编号情况。
inbound:显示对进入控制平面的报文应用的QoS策略信息。
【描述】
display qos policy control-plane命令用来显示控制平面应用QoS策略的信息。
# 显示3号成员设备的控制平面入方向的QoS策略信息。
<Sysname> display qos policy control-plane slot 3 inbound
Control-plane slot 3
  Direction: Inbound
  Policy: 1
    Classifier: 2
      Operator: AND
      Rule(s) : If-match system-index 10
      Behavior: 2
          CIR 128 (kbps), CBS 8000 (byte), EBS 0 (byte)
          Red Action: discard
          Green : 12928(Bytes)
          Red   : 43904(Bytes)
        Filter Enable: deny
表1-6 display qos policy control-plane命令显示信息描述表
Control-plane
控制平面
Direction
对进控制平面(Inbound)/出控制平面(Outbound)的报文应用QoS策略,目前仅支持入方向
Policy
策略名称及其内容
Classifier
类的名称及其内容,内容可以有多种类型
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
流行为的名称及其内容,内容可以有多种类型
流量限速的相关信息
CIR
承诺信息速率,单位为kbps
CBS
承诺突发尺寸,也就是容纳突发流量的令牌桶深度,单位为byte
EBS
超出突发尺寸,在双令牌桶算法中超出突发流量超过承诺突发流量的部分,单位为byte
Red Action
对红色报文的动作
Green
绿色报文的流量统计
Red
红色报文的流量统计
Filter Enable
包过滤的相关信息(deny表示丢弃数据包;permit表示允许数据包通过)
none
表示没有配置其他流行为
display qos policy control-plane pre-defined [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
slot slot-number:显示指定成员设备的系统预定义的控制平面策略信息。slot-number的取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display qos policy control-plane pre-defined命令用来显示系统预定义的控制平面应用QoS策略的信息。
需要注意的是:如果不指定成员设备,则显示所有成员设备的系统预定义的控制平面应用QoS策略的信息。
# 显示5号成员设备上系统预定义的控制平面QoS策略的信息。
<Sysname> display qos policy control-plane pre-defined slot 5
 Pre-defined Control-plane Policy Slot 5
  Index |   PacketType              |  Priority  |  BandWidth(Kbps)
  1          ISIS                         31          512
  4          VRRP                         38          384
  7          IPV4_MC_RIP                  32          256
  8          IPV4_BC_RIP                  32          256
  9          MCAST_NTP                    14          64
  10         BCAST_NTP                    14          64
  11         IPV4_MC_OSPF_5               33          256
  12         IPV4_MC_OSPF_6               33          256
  13         IPV4_UC_OSPF                 33          256
  14         IPV4_MC_PIM                  18          128
  15         IPV4_UC_PIM                  18          128
  16         IPV4_IGMP                    19          256
  17         LDP                          22          256
  18         IPV6_MC_PIM                  17          128
  19         IPV6_UC_PIM                  17          128
  20         IPV6_MLD                     19          64
  21         IPV6_RIPNG                   21          256
  22         IPV6_UC_OSPFV3               26          256
  23         IPV6_MC_OSPFV3_5             26          256
  24         IPV6_MC_OSPFV3_6             26          256
  25         IPV6_LDP                     22          64
  26         IPV6_VRRP                    28          384
  27         RRPP                         44          64
  28         IPV4_AUTORP                  19          64
  29         ARP                          2           256
  30         ARP_REPLY                    3           256
  31         DHCP_CLIENT                  16          256
  32         DHCP_SERVER                  16          256
  33         DHCP_RELAY_CLIENT            16          256
  34         DHCP_RELAY_SERVER            16          256
  35         DOT1X                        8           128
  36         STP                          44          256
  37         LACP                         37          64
  38         GVRP                         22          256
  39         HGMP                         10          128
  40         BGP                          25          256
  41         ICMP                         5           640
  44         IPV6_BGP                     25          256
  45         IPV6_ND_PASS                 4           128
  46         IPV6_ND_DEST                 4           128
  47         IPV6_PING                    5           128
  50         IPV6_DHCP                    15          64
  53         LLDP                         23          128
  54         DLDP                         27          64
  55         LSP_PING                     22          64
  61         TELNET/SSH                   47          512
  62         HTTP/HTTPS                   6           128
  63         SNMP                         9           512
  64         SMARTLINK                    41          64
  67         ARP_DAI                      2           256
  71         IPV4_UC_DHCP                 16          256
  72         IPV4_UCOSPF_TTL              33          256
  73         IPV4_UC_PIM_TTL              18          64
  74         BGP_TTL                      25          256
  76         IPV6_ICMP                    5           640
  77         IPV6_TELNET/SSH              47          512
  80         HGMP_BC                      11          64
  82         PVST                         30          1536
  88         HGMP_BRIDGEMAC               34          256
  90         IPV6_DHCPUC_CLIENT           15          256
  91         IPV6_DHCPUC_RELAY            15          256
  92         IPV6_DHCPR_SERVER            15          256
  94         BFD_ARP_REPLY                35          256
  98         BFD_ECHO                     35          512
  99         BFD_CTRL                     35          512
  100        BFD_MULTIHOP                 35          512
  102        IPV6_ND_DAI                  4           256
  103        IPV6_DHCP_CLIENT             15          256
  104        IPV6_DHCP_SERVER             15          256
  105        ICMP_RDM                     31          256
  106        IPV6_CPUDST_CAR              13          640
表1-7 display qos policy control-plane pre-defined命令显示信息描述表
预定义控制平面策略内容
Index
系统预定义匹配字段索引号
PacketType
匹配字段内容
Priority
优先级
BandWidth
带宽
display qos policy global [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
inbound:显示设备所有接口入方向应用的QoS策略信息。
outbound:显示设备所有接口出方向应用的QoS策略信息。
slot slot-number:显示指定成员设备的基于全局应用QoS策略的信息。slot-number的取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display qos policy global命令用来显示基于全局应用QoS策略的信息。
·     如果不指定显示方向,则同时显示出入两个方向基于全局应用QoS策略的信息。
·     如果不指定成员设备,则显示整个IRF系统全局应用QoS策略的信息。
# 显示基于全局应用QoS策略的信息。
<Sysname> display qos policy global
Direction: Inbound
  Policy: 1
   Classifier: 2
     Operator: AND
     Rule(s) : If-match acl 2000
     Behavior: 2
       Accounting Enable
         20864 (Bytes)
         CIR 128 (kbps), CBS 8000 (Bytes), EBS 0 (Bytes)
         Red Action: discard
         Red   : 43904(Bytes)
Direction: Outbound
  Policy: 2
   Classifier: 2 (Failed)
     Operator: AND
     Rule(s) : If-match customer-dot1p 3
     Behavior: 1
      Marking:
        Remark local precedence 2
表1-8 display qos policy global命令显示信息描述表
Direction
对接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Policy
策略名称及其内容
Classifier
类的名称及其内容;如果在类的名称后面显示“(Failed)”,表示该流分类以及与其关联的流行为所组成的关联组没有在全局正常应用;
在IRF中:
·     如果在没有使用slot参数的情况下显示“(Failed)”,表示该关联组没有在IRF全局正常应用
·     如果在使用了slot参数的情况下显示“(Failed)”,表示该关联组没有在指定成员设备的全局正常应用
一个QoS策略中可以存在多个关联组,某个关联组的下发失败并不影响其它关联组的正常应用
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定的接口类型和接口编号。
inbound:显示对接口接收到的报文应用的QoS策略信息。
outbound:显示对接口发送的报文应用的QoS策略信息。
【描述】
display qos policy interface命令用来显示指定接口或所有接口上QoS策略的配置信息和运行情况。
# 显示GigabitEthernet1/0/1端口上QoS策略的配置信息和运行情况。
<Sysname> display qos policy interface gigabitethernet 1/0/1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Behavior: 1
      Accounting Enable:
      Mirror enable:
        Mirror type: interface
        Mirror destination: GigabitEthernet1/0/2
      Redirect enable:
        Redirect type: cpu
      Marking:
        Remark Customer VLAN ID 100
      Marking:
        Remark dot1p COS 2
      Marking:
        Remark IP precedence 3
      Marking:
        Remark qos local ID 3
表1-9 display qos policy interface命令显示信息描述表
接口名,由接口类型和接口编号结合在一起组成。
Direction
Policy应用在接口的方向
Policy
应用到接口上的策略的名字
Classifier
策略里分类规则以及对应的配置信息
Operator
同一个类中多条分类规则的逻辑关系
Rule(s)
类的分类规则
Behavior
策略里行为的名字及配置信息,参见behavior的相关命令
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ slot slot-number ] [ inbound | outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
name policy-name:显示指定策略名称的基于VLAN应用QoS策略的信息。policy-name表示策略名称,为1~31个字符的字符串。
vlan vlan-id:显示指定VLAN上应用的基于VLAN应用QoS策略的信息。vlan-id表示应用策略的VLAN ID。
inbound:显示对VLAN接收到的报文应用的QoS策略信息。
outbound:显示对VLAN发送的报文应用的QoS策略信息。
slot slot-number:显示指定成员设备上基于VLAN应用QoS策略的信息。slot-number的取值范围取决于当前IRF中的成员数量和编号情况。
【描述】
display qos vlan-policy命令用来显示基于VLAN应用QoS策略的信息。
·     如果不指定显示方向,则同时显示出入两个方向基于VLAN应用QoS策略的信息。
·     如果不指定成员设备,则显示整个IRF系统基于VLAN应用QoS策略的信息。
# 显示IRF中6号成员设备上基于VLAN应用的名为test的QoS策略信息。
<Sysname> display qos vlan-policy name test slot 6
  Policy test
    Vlan 200:inbound
    Vlan 300:outbound
表1-10 display qos vlan-policy命令显示信息描述表
Policy
QoS策略名称
Vlan
应用QoS策略的VLAN ID
inbound
对VLAN接收到的报文应用QoS策略
outbound
对VLAN发送的报文应用QoS策略
# 显示VLAN 2的QoS策略信息。
<Sysname> display qos vlan-policy vlan 2
Vlan 2
Direction: Inbound
  Policy: 1
   Classifier: 2
     Operator: AND
     Behavior: 2
       Accounting Enable
         163 (Packets)
         Red Action: discard
         Red   : 43904(Bytes)
Direction: Outbound
  Policy: 2
   Classifier: 3 (Failed)
     Operator: AND
     Behavior: 3
      Marking:
表1-11 display qos vlan-policy命令显示信息描述表
Vlan
应用QoS策略的VLAN ID
Direction
对VLAN接收到(Inbound)/发送(Outbound)的报文应用QoS策略
Classifier
在IRF中:
·     如果在没有使用slot参数的情况下显示“(Failed)”,表示该关联组没有在IRF上正常应用
·     如果在使用了slot参数的情况下显示“(Failed)”,表示该关联组没有在指定成员设备上正常应用
Operator
分类规则之间的逻辑关系
Rule(s)
分类规则
Behavior
undo qos apply policy [ policy-name ] { inbound | outbound }
二层以太网端口视图/三层以太网端口视图/端口组视图/控制平面视图
【缺省级别】
2:系统级
inbound:入方向。
outbound:出方向。在控制平面视图下不支持该参数。
policy policy-name:策略名,为1~31个字符的字符串。
【描述】
qos apply policy命令用来应用关联的策略。undo qos apply policy命令用来删除关联的策略。
# 将策略USER1应用到端口GigabitEthernet1/0/1的入方向上。
[Sysname-GigabitEthernet1/0/1] qos apply policy USER1 inbound
# 对进入IRF中3号成员设备控制平面的报文应用策略aaa。
[Sysname] control-plane slot 3
[Sysname-cp-slot3] qos apply policy aaa inbound
user-profile视图
【缺省级别】
2:系统级
inbound:入方向,对设备接收的上线用户流量(即上线用户发送的流量)应用策略。
outbound:出方向,对设备发送的上线用户流量(即上线用户接收的流量)应用策略。
【描述】
qos apply policy命令用来为User Profile应用关联的策略。undo qos apply policy命令用来删除关联的策略。
·     如果User Profile处于激活状态,既不能修改策略的内容(包括流分类引用的ACL规则),也不能删除已经应用到此User Profile的策略。
·     关联的策略只有在User Profile处于激活状态、且用户成功上线后才能生效。
·     user-profile视图下应用的策略中的流行为只支持remark、car、filter三种动作。
·     user-profile视图下应用的策略不能为空策略。
# 对设备接收的上线用户user的流量应用策略test(该策略已经建立)。
[Sysname] user-profile user
[Sysname-user-profile-user] qos apply policy test inbound
undo qos apply policy [ policy-name ] global { inbound | outbound }
【缺省级别】
2:系统级
inbound:对设备所有端口接收到的流量应用QoS策略。
outbound:对设备所有端口发送的流量应用QoS策略。
【描述】
qos apply policy global命令用来全局应用QoS策略,全局应用的QoS策略对全部流量生效。undo qos apply policy global命令用来取消全局应用的QoS策略。
# 将名为user1的策略应用到全局的入方向上。
[Sysname] qos apply policy user1 global inbound
1.3.12  qos policy
qos policy policy-name
undo qos policy policy-name
【缺省级别】
2:系统级
【描述】
qos policy命令用来定义一个策略并进入策略视图。undo qos policy命令用来删除一个策略。
如果该策略已经被应用,则不允许删除该策略,需要先在应用的位置上取消对该策略的应用,然后再使用undo qos policy命令删除该策略。
相关配置可参考命令classifier behavior、qos apply policy、qos apply policy global和qos vlan-policy。
# 定义一个名为user1的策略。
undo qos vlan-policy [ policy-name ] vlan vlan-id-list { inbound | outbound }
【缺省级别】
2:系统级
policy-name:策略名称,为1~31个字符的字符串。
vlan-id-list:VLAN ID列表,形式可以是vlan-id to vlan-id,其中,vlan-id为指定VLAN的ID号,取值范围为1~4094。可以输入多个不连续的VLAN ID,中间以空格隔开。设备最多允许用户同时指定8个VLAN ID。
inbound:对VLAN接收到的报文应用QoS策略。
outbound:对VLAN发送的报文应用QoS策略。
【描述】
qos vlan-policy命令用来在指定VLAN上应用QoS策略。undo qos vlan-policy命令用来取消指定VLAN上应用的QoS策略。
# 在VLAN 200、300、400、500的入方向上应用VLAN策略test。
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane slot slot-number [ inbound ]
【缺省级别】
1:监控级
slot slot-number:清除指定成员设备的控制平面应用QoS策略的统计信息。slot-number的取值范围取决于当前IRF中的成员数量和编号情况。
inbound:清除进入控制平面的方向的基于控制平面应用QoS策略的统计信息。
【描述】
reset qos policy control-plane命令用来清除控制平面应用QoS策略的统计信息。
# 清除应用到编号为3的成员设备控制平面上入方向的QoS策略统计信息。
<Sysname> reset qos policy control-plane slot 3 inbound
【缺省级别】
1:监控级
inbound:清除全局在入方向应用的QoS策略的统计信息。
outbound:清除全局在出方向应用的QoS策略的统计信息。
【描述】
reset qos policy global命令用来清除全局应用的QoS策略的统计信息。
如果不指定方向,则同时清除全局在入方向和出方向应用的QoS策略的统计信息。
# 清除全局入方向应用的QoS策略的统计信息。
<Sysname> reset qos policy global inbound
【缺省级别】
1:监控级
vlan-id:VLAN的ID号,取值范围为1~4094。
inbound:清除VLAN接收到的报文应用QoS策略的统计信息。
outbound:清除对VLAN发送的报文应用QoS策略的统计信息。
【描述】
reset qos vlan-policy命令用来清除VLAN应用的QoS策略的统计信息。
如果不指定方向,则同时清除在VLAN入方向和出方向应用的QoS策略的统计信息。
# 清除VLAN 2应用的QoS策略的统计信息。
<Sysname> reset qos vlan-policy vlan 2
2 优先级映射配置命令
优先级映射功能中的“接口”包括二层以太网端口和三层以太网端口。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
2.1  优先级映射表配置命令
display qos map-table [ dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
dot1p-dp:802.1p优先级到丢弃优先级映射表。
dot1p-lp:802.1p优先级到本地优先级映射表。
dscp-dot1p:DSCP到802.1p优先级映射表。
dscp-dp:DSCP到丢弃优先级映射表。
dscp-dscp:DSCP到DSCP映射表。
【描述】
display qos map-table命令用来显示指定优先级映射表配置情况。
如不指定表的类型,本命令将显示所有映射表的配置情况。
相关配置可参考命令qos map-table。
# 显示802.1p优先级到本地优先级映射表的配置信息。
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
# 显示802.1p优先级到丢弃优先级映射表的配置信息。
<Sysname> display qos map-table dot1p-dp
MAP-TABLE NAME: dot1p-dp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    0
   1    :    0
   2    :    0
   3    :    0
   4    :    0
   5    :    0
   6    :    0
   7    :    0
表2-1 display qos map-table命令显示信息描述表
MAP-TABLE NAME
映射表的名字
TYPE
映射表的类型
IMPORT
映射表的输入值
EXPORT
映射表的输出值
2.1.2  import
优先级映射表视图
【缺省级别】
2:系统级
import-value-list:映射输入参数列表。
export-value:映射输出参数。
all:删除该映射表所有参数。
【描述】
import命令用来配置指定优先级映射表参数,定义一条或一组映射规则。undo import命令用来删除指定映射索引所对应的映射项,被删除的映射条目恢复为系统缺省值。
相关配置可参考命令display qos map-table。
# 配置802.1p优先级到丢弃优先级映射表参数,与802.1p优先级4、5相对应的丢弃优先级为1。
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
2.1.3  qos map-table
qos map-table { dot1p-dp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp }
【缺省级别】
2:系统级
【描述】
# 进入802.1p优先级到丢弃优先级映射表视图。
2.2  端口优先级配置命令
2.2.1  qos priority
qos priority priority-value
undo qos priority
接口视图/端口组视图
【缺省级别】
2:系统级
priority-value:端口优先级值,取值范围为0~7。
【描述】
qos priority命令用来配置当前端口的端口优先级。undo qos priority命令用来恢复端口优先级为缺省值。
缺省情况下,端口的优先级为0。
端口优先级可以通过命令display qos trust interface来查看。
对于不带有802.1Q标签头的报文,交换机将使用端口的优先级作为该端口接收的报文的802.1p优先级,然后根据该优先级查找802.1p优先级到本地优先级/丢弃优先级映射表,为报文标记本地优先级/丢弃优先级。
# 配置端口GigabitEthernet 1/0/1的优先级为2。
[Sysname-GigabitEthernet1/0/1] qos priority 2
2.3  端口优先级信任模式配置命令
display qos trust interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos trust interface命令用来显示当前配置的端口优先级信任模式信息和端口优先级的信息。
如果不指定接口,本命令将显示所有接口的端口优先级信任模式信息。
# 显示端口GigabitEthernet 1/0/1的优先级信任模式配置信息。
<Sysname> display qos trust interface GigabitEthernet 1/0/1
 Port priority information
  Port priority :0
  Port priority trust type : dscp
表2-2 display qos trust interface命令显示信息描述表
接口名,由接口类型和接口编号构成
Port priority trust information
端口优先级信任信息
Port priority
端口优先级
优先级信任模式:
·     dscp表示信任报文的DSCP优先级
·     dot1p表示信任报文的802.1p优先级
·     untrust表示不信任报文携带的优先级
2.3.2  qos trust
qos trust { dot1p | dscp }
undo qos trust
接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos trust命令用来配置端口优先级信任模式。undo qos trust命令用来恢复端口优先级信任模式为缺省值。
缺省情况下,设备不信任报文携带的优先级。
在端口视图下执行该命令,则该配置只在当前端口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
# 在端口GigabitEthernet 1/0/1上配置优先级信任模式为信任报文的DSCP优先级。
[Sysname-GigabitEthernet1/0/1] qos trust dscp
3 流量整形/端口限速命令
流量整形/端口限速功能中的“接口”包括二层以太网端口和三层以太网端口。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
3.1  流量整形配置命令
display qos gts interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos gts interface命令用来显示某个端口或所有端口的GTS配置情况。
如不指定端口,本命令将显示所有端口的GTS配置情况和运行统计信息。
# 显示所有端口的流量整形配置信息。
Rule(s): If-match queue 2
 CIR 640 (kbps), CBS 40960 (byte)
表3-1 display qos gts命令显示信息描述表
端口名,由端口类型和端口编号结合在一起组成
Rule(s)
匹配规则。
CIR
承诺信息速率,单位为kbps
CBS
3.1.2  qos gts
qos gts queue queue-number cir committed-information-rate [ cbs committed-burst-size ]
undo qos gts queue queue-number
接口视图/端口组视图
【缺省级别】
2:系统级
queue queue-number:对指定队列的数据包进行流量整形,queue-number为队列编号,取值范围为0~7。
cir committed-information-rate:承诺信息速率,单位为kbps。committed-information-rate在不同端口上的取值分别为:
·     千兆端口的取值范围为8~1000000且必须是8的倍数。
·     万兆端口的取值范围为8~10000000且必须是8的倍数。
cbs committed-burst-size:承诺突发尺寸,单位为byte。
·     如果不指定cbs参数,committed-burst-size缺省取值为62.5ms*committed-information-rate,且必须为4096的整数倍,如果乘积不是4096的整数倍,就取比乘积大的最近的4096的整数倍,但最大不会超过16777216。
·     如果指定cbs参数,committed-burst-size的取值范围为4096~16777216,且必须为4096的整数倍。
【描述】
qos gts命令用来为某个队列的流设置整形参数,并开始整形。undo qos gts命令用来取消对某一队列流的整形设置。
缺省情况下,端口上没有配置整形参数。
# 配置端口GigabitEthernet 1/0/1上队列2发送报文的速率为640 kbps。
[Sysname-GigabitEthernet1/0/1] qos gts queue 2 cir 640
·     端口限速配置命令
display qos lr interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos lr interface命令用来显示某个或者全部端口的端口限速配置情况。
如不指定端口,本命令将显示所有端口的端口限速配置情况。
# 显示所有端口的端口限速配置情况。
Direction: Outbound
 CIR 64000 (kbps),  CBS 4000000 (byte)
表3-2 display qos lr命令显示信息描述表
Direction
指明端口限速的方向
CIR
承诺信息速率,单位为kbps
CBS
3.1.4  qos lr
undo qos lr { inbound | outbound }
接口视图/端口组视图
【缺省级别】
2:系统级
inbound:对端口接收的数据流进行限速。
outbound:对端口发送的数据流进行限速。
cir committed-information-rate:承诺信息速率,单位为kbps:committed-information-rate在不同端口上的取值分别为:
·     如果不指定cbs参数,缺省取值为62.5ms*committed-information-rate,且必须为4000的整数倍,如果乘积不是4000的整数倍,就取比乘积大的最近的4000的整数倍,但是最大值不能超过16000000。
·     如果指定cbs参数,取值范围4000~16000000且必须是4000的倍数。
【描述】
qos lr命令用来限制端口的接收或者发送数据的速率。undo qos lr命令用来取消限制。
# 限制端口GigabitEthernet 1/0/1发送报文的速率为640kbps。
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 640
4 拥塞管理配置命令
拥塞管理功能中的“接口”包括二层以太网端口和三层以太网端口。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
4.1  严格优先级队列配置命令
display qos sp interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定的端口类型和端口编号。
【描述】
display qos sp interface命令用来显示端口的SP(Strict Priority,严格优先级)队列配置情况。
如不指定端口,本命令将显示所有端口的SP队列配置情况。
相关配置可参考命令qos sp。
# 显示端口GigabitEthernet 1/0/1的SP队列配置信息。
<Sysname> display qos sp interface GigabitEthernet 1/0/1
 Output queue: Strict-priority queue
表4-1 display qos sp interface命令显示信息描述表
Output queue
当前出队列类型
采用SP队列进行队列调度
4.1.2  qos sp
qos sp
undo qos sp
接口视图/端口组视图
【缺省级别】
2:系统级
无
【描述】
qos sp命令用来在端口上配置严格优先队列。undo qos sp命令用来恢复端口上缺省的队列算法。
缺省情况下,所有端口采用WRR调度算法。
相关配置可参考命令display qos sp interface。
# 在端口GigabitEthernet 1/0/1上配置使用SP调度算法。
[Sysname-GigabitEthernet1/0/1] qos sp
4.2  加权轮询队列配置命令
display qos wrr interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wrr interface命令用来显示接口的WRR(Weighted Round Robin,加权轮询)队列配置情况。
如不指定端口,本命令将显示所有端口的WRR队列配置情况。
相关配置可参考命令qos wrr。
# 显示端口GigabitEthernet 1/0/1的WRR队列配置信息。
<Sysname> display qos wrr interface GigabitEthernet 1/0/1
 Output queue: Weighted round robin queue
Queue ID    Group    Weight
   0         1        1
   1         sp       N/A
   2         1        3
   3         1        4
   4         1        5
   5         1        6
   6         1        7
   7         1        8
表4-2 display qos wrr interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Group
队列所属调度组,1表示队列处于WRR调度组,sp表示队列处于SP调度组
Weight
调度时各个队列的权重,N/A表示该队列采用SP调度算法
4.2.2  qos wrr
qos wrr [ byte-count | weight ]
undo qos wrr
接口视图/端口组视图
【缺省级别】
2:系统级
byte-count:表示以字节数为调度单位,即按照每次轮询发送的字节数来体现调度权重。如果不指定调度权重,则缺省使用字节数作为调度权重。
weight:表示以报文个数为调度单位,即按照每次轮询发送的报文个数来体现调度权重。
【描述】
qos wrr命令用来配置端口使用WRR队列算法进行调度,并指定调度单位。undo qos wrr命令用来将端口的队列调度权重恢复为缺省值。
缺省情况下,端口使用WRR队列进行调度。
# 在GigabitEthernet1/0/1上使能WRR队列。
[Sysname-GigabitEthernet1/0/1] qos wrr
qos wrr queue-id group 1 byte-count schedule-value
undo qos wrr queue-id group 1 byte-count
接口视图/端口组视图
【缺省级别】
2:系统级
queue-id:队列序号,取值范围为0~7。
1:表示该队列属于group 1,即WRR队列组。
byte-count schedule-value:配置队列的调度权重,schedule-value的取值范围为1~15。
【描述】
qos wrr byte-count命令用来配置WRR队列的调度权重(在使用字节数为调度单位时)。undo qos wrr byte-count命令用来将WRR队列参数恢复为缺省情况(在使用字节数为调度单位时)。
缺省情况下,在使用字节数为调度单位时,0~7队列的调度权重分别为1、2、3、4、5、9、13、15。
需要注意的是,在使用本命令配置WRR队列调度权重前,请确认当前端口的WRR队列调度是以字节数作为调度单位,以保证调度权重的配置能够正常生效。
在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
相关配置可参考命令display qos wrr interface和qos wrr。
# 在GigabitEthernet1/0/1上应用WRR队列,使用字节数为调度单位,并配置队列0的调度权重为10。
[Sysname-GigabitEthernet1/0/1] qos wrr byte-count
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
qos wrr queue-id group sp
undo qos wrr queue-id group sp
接口视图/端口组视图
【缺省级别】
2:系统级
sp:严格优先级调度算法。
【描述】
qos wrr group sp命令用来配置端口使用SP+WRR队列算法时加入SP调度组的队列。undo qos wrr group sp命令用来取消配置。
本系列以太网交换机的端口支持8个输出队列,用户可以根据需要配置端口上的部分队列使用SP调度算法,部分队列使用WRR调度算法。通过将端口上的队列分别加入SP调度组和WRR调度组(即group 1),实现SP+WRR的调度功能。在队列调度时,系统会优先保证SP调度组内的队列调度,当SP调度组内的队列中没有报文发送时,才会调度WRR调度组内的队列。SP调度组内各个队列执行严格优先级调度方式,WRR调度组内各个队列执行加权轮询调度方式。
此命令需要在端口队列为WRR调度模式下使用。SP组与普通WRR优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权轮循调度算法。
# 在GigabitEthernet1/0/1端口上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
qos wrr queue-id group 1 weight schedule-value
undo qos wrr queue-id group 1 weight
接口视图/端口组视图
【缺省级别】
2:系统级
group 1:表示该队列属于WRR调度组。
weight schedule-value:配置队列的调度权重,取值范围为1~15。
【描述】
qos wrr weight命令用来配置WRR队列的调度权重(在使用报文个数为调度单位时)。undo qos wrr weight命令用来将WRR队列参数恢复为缺省情况(在使用报文个数为调度单位时)。
缺省情况下,在使用报文个数为调度单位时,0~7队列的调度权重分别为1、2、3、4、5、9、13、15。
需要注意的是,在使用本命令配置WRR队列调度权重前,请确认当前端口的WRR队列调度是以报文个数作为调度单位,以保证调度权重的配置能够正常生效。
# 在GigabitEthernet1/0/1上应用使用报文个数为调度单位的WRR队列,并配置队列0的调度权重为10。
[Sysname-GigabitEthernet1/0/1] qos wrr weight
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 weight 10
4.3  加权公平队列配置命令
本系列交换机中S5500-28SC-HI-D和S5500-52SC-HI-D不支持本节介绍的命令。
display qos wfq interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wfq interface命令用来显示端口的WFQ配置情况。
如不指定端口,本命令将显示所有端口的WFQ配置情况。
相关配置可参考命令qos wfq。
# 显示端口GigabitEthernet1/0/1的加权公平队列配置情况。
<Sysname> display qos wfq interface gigabitethernet 1/0/1
 Output queue: Hardware weighted fair queue
Queue ID        Group           Byte-count      Min-Bandwidth
0                1               1               64
1                1               1               64
2                1               1               64
3                1               1               64
4                1               1               64
5                1               1               64
6                1               1               64
7                1               1               64
表4-3 display qos wfq interface命令显示信息描述表
Output queue
当前出队列类型
Queue ID
队列号
Group
队列所属调度组,1表示队列处于WFQ调度组,sp表示队列处于SP调度组
Byte-count
表示队列调度权重为字节数,如果开启WFQ队列时选择的调度权重为报文个数,这里将显示Weight,SP调度组的队列此处显示为NA
Min-Bandwidth
队列的最小保证带宽值
undo qos bandwidth queue queue-id [ min bandwidth-value ]
接口视图/端口组视图
【缺省级别】
2:系统级
queue-id:端口队列序号,取值范围为0~7。
min bandwidth-value:最小保证带宽值,单位为kbps。bandwidth-value的取值范围在不同端口上分别为:
·     千兆端口的取值范围为64~1000000。
·     万兆端口的取值范围为64~10000000。
【描述】
qos bandwidth queue命令用来配置端口队列的最小带宽保证。undo qos bandwidth queue命令用来取消端口队列的最小带宽保证配置。
缺省情况下,队列的最小保证带宽为64kbps。
·     在接口视图下执行该命令,则该配置只在当前接口生效;在端口组视图下执行该命令,则该配置将在端口组中的所有端口生效。
·     在端口或端口组上开启WFQ(Weighted Fair Queuing,加权公平队列)调度算法的情况下,才需要配置最小带宽保证。
# 在GigabitEthernet 1/0/1上配置队列0的最小保证带宽值为100kbps。
[Sysname-GigabitEthernet1/0/1] qos wfq
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
4.3.3  qos wfq
qos wfq [ byte-count | weight ]
undo qos wfq
接口视图/端口组视图
【缺省级别】
2:系统级
byte-count:表示按照每次轮询可发送的字节数作为调度权重。
weight:表示按照每次轮询可发送的报文个数作为调度权重。
【描述】
qos wfq命令用来在端口上使能WFQ队列,并指明当前WFQ队列调度权重的计算方式。undo qos wfq命令用来恢复端口上缺省的队列算法。
·     如果没有指定调度权重,则使用字节数作为调度权重。
# 在端口GigabitEthernet 1/0/1上开启WFQ调度算法,并使用报文个数作为调度权重。
[Sysname-GigabitEthernet1/0/1] qos wfq byte-count
qos wfq queue-id group 1 byte-count schedule-value
undo qos wfq queue-id group 1 byte-count
接口视图/端口组视图
【缺省级别】
2:系统级
group 1:表示该队列属于WFQ调度组。
byte-count schedule-value:配置队列的调度权重,取值范围为1~15。
【描述】
qos wfq byte-count命令用来配置WFQ队列的调度权重(在使用字节数为调度单位时)。undo qos wfq byte-count命令用来将WFQ队列参数恢复为缺省情况(在使用字节数为调度单位时)。
缺省情况下,在使用字节数为调度单位时,0~7队列的调度权重均为1。
需要注意的是,在使用本命令配置WFQ队列调度权重前,请确认当前端口的WFQ队列调度是以字节数作为调度单位,以保证调度权重的配置能够正常生效。
相关配置可参考命令display qos wfq interface和qos wfq。
# 在GigabitEthernet1/0/1上应用WFQ队列,使用字节数为调度单位,并配置队列0的调度权重为10。
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
qos wfq queue-id group sp
undo qos wfq queue-id group sp
接口视图/端口组视图
【缺省级别】
2:系统级
sp:严格优先级调度算法。
【描述】
qos wfq group sp命令用来配置端口使用SP+WFQ队列算法时加入SP调度组的队列。undo qos wfq group sp命令用来取消配置。
此命令需要在端口队列为WFQ调度模式下使用。SP组与普通WFQ优先组不同,加入SP组的端口队列采用严格优先级调度算法,不再采用加权公平调度算法。
# 在GigabitEthernet1/0/1上应用WRR队列,并配置队列0加入SP组进行严格优先级调度。
qos wfq queue-id group 1 weight schedule-value
undo qos wfq queue-id group 1 weight
接口视图/端口组视图
【缺省级别】
2:系统级
【描述】
qos wfq weight命令用来配置WFQ队列的调度权重(在使用报文个数为调度单位时)。undo qos wfq weight命令用来将WFQ队列参数恢复为缺省情况(在使用报文个数为调度单位时)。
缺省情况下,在使用报文个数为调度单位时,0~7队列的调度权重均为1。
# 在GigabitEthernet1/0/1上应用WFQ队列,使用报文个数为调度单位,并配置队列0的调度权重为10。
[Sysname-GigabitEthernet1/0/1] qos wfq weight
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 weight 10
4.4  端口队列统计显示命令
display qos queue-statistics interface [ interface-type interface-number ] [ outbound ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface-type interface-number:指定端口类型和端口编号。
outbound:显示出方向统计信息。
【描述】
display qos queue-statistics interface命令用来显示端口队列统计信息。
如果不指定端口,将显示所有端口的队列统计信息。
# 显示端口GigabitEthernet1/0/1的出方向队列统计信息。
<Sysname> display qos queue-statistics interface gigabitethernet 1/0/1
Direction: Outbound
Queue  Queued packets              Passed packets             Dropped packets
    0               0                           0                           0
    1               0                           0                           0
    2           2,689                  94,816,515                  94,851,667
    3               0                           0                           0
    4               0                           0                           0
    5               0                           0                           0
    6               0                           0                           0
    7               0                          26                           0
表4-4 display qos queue-statistics interface命令显示信息描述表
端口队列统计的端口
Direction
端口队列统计的方向
Queue
队列编号
Queued packets
本队列当前缓存的报文个数
Passed packets
通过本队列发送的报文个数
Dropped packets
在本队列中被丢弃的报文个数
5 拥塞避免配置命令
拥塞避免功能中的“接口”包括二层以太网端口和三层以太网端口。三层以太网端口是指被配置为三层模式的以太网端口,有关以太网端口模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”。
5.1  WRED配置命令
display qos wred interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display qos wred interface命令用来显示指定端口或所有端口的WRED配置情况。
如果不指定端口,本命令将显示所有端口的WRED配置情况。
# 显示端口GigabitEthernet 1/0/1的WRED配置信息。
<Sysname> display qos wred interface GigabitEthernet 1/0/1
 Current WRED configuration:
 Applied WRED table name: queue-table1
display qos wred table [ table-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
table-name:要显示的WRED表的名字。
【描述】
display qos wred table命令用来显示WRED表的配置情况。
如果不指定表名字,本命令将显示所有WRED表配置情况。
# 显示WRED表1的配置情况,表1是一个已经配置好的WRED参数表。
<Sysname> display qos wred table 1
Table Name: 1
Table Type: Queue based WRED
QID:  gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent
 0   100   1000    10   100   1000    10   100   1000    10      9
 1   100   1000    10   100   1000    10   100   1000    10      9
 2   100   1000    10   100   1000    10   100   1000    10      9
 3   100   1000    10   100   1000    10   100   1000    10      9
 4   100   1000    10   100   1000    10   100   1000    10      9
 5   100   1000    10   100   1000    10   100   1000    10      9
 6   100   1000    10   100   1000    10   100   1000    10      9
 7   100   1000    10   100   1000    10   100   1000    10      9
表5-1 display qos wred table命令显示信息描述表
Table name
WRED表的名称
Table type
WRED表的类型
QID
队列编号
gmin
绿色报文(丢弃优先级为0)的丢弃队列长度下限
gmax
绿色报文的丢弃队列长度上限
gprob
绿色报文的丢弃概率
ymin
黄色报文(丢弃优先级为1)的丢弃队列长度下限
ymax
黄色报文的丢弃队列长度上限
yprob
黄色报文的丢弃概率
rmin
红色报文(丢弃优先级为2)的丢弃队列长度下限
rmax
红色报文的丢弃队列长度上限
rprob
红色报文的丢弃概率
exponent
计算平均队列长度的指数
qos wred apply table-name
undo qos wred apply
接口视图/端口组视图
【缺省级别】
2:系统级
table-name:WRED表的名称,为1~32个字符的字符串。
【描述】
qos wred apply命令用来在端口或端口组上应用WRED表。undo qos wred apply用来取消WRED表在端口或端口组上的应用。
缺省情况下,端口或端口组上没有应用WRED表。
相关配置可参考命令display qos wred interface。
# 在端口上GigabitEthernet 1/0/1上应用WRED表queue-table1。
[Sysname-GigabitEthernet1/0/1] qos wred apply queue-table1
undo qos wred table table-name
【缺省级别】
2:系统级
【描述】
qos wred queue table命令用来创建WRED表,同时进入该WRED表视图。undo qos wred table命令用来删除WRED表。
缺省情况下,没有创建WRED表。
需要注意的是,用户不能删除已经应用的WRED表。
相关配置可参考命令qos wred apply和display qos wred interface。
# 创建WRED表queue-table1。
[Sysname-wred-table-queue-table1]
5.1.5  queue
queue queue-value [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-value | all }
WRED表视图
【缺省级别】
2:系统级
queue-value:队列编号,取值范围为0~7。
drop-level drop-level:丢弃级别,取值范围为0~2。如果没有指定,后续配置的参数对该队列所有丢弃级别的报文都生效。
low-limit low-limit:平均队列长度的丢弃下限,取值范围为0~8000,缺省为100。
high-limit high-limit:平均队列长度的丢弃上限,取值范围为0~8000且必须大于low-limit,缺省为1000。
discard-probability discard-prob:以百分数形式表示的丢弃概率,取值范围为0~100。当报文队列平均长度在上限和下限之间时,设备采用这个概率来丢弃报文。
【描述】
queue命令用来编辑WRED表的内容。undo queue命令用来恢复WRED表的内容为缺省值。
缺省情况下,基于队列的WRED全局表有一套可用的缺省参数,low-limit为100,high-limit为1000,discard-prob为10。
相关配置可参考命令qos wred queue table。
# 修改WRED表queue-table1的队列1的丢弃级别为1的数据包的丢弃参数,丢弃队列长度下限为120,丢弃队列长度上限为300,丢弃概率为百分之20。
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 120 high-limit 300 discard-probability 20
queue queue-value weighting-constant exponent
undo queue queue-value weighting-constant
WRED表视图
【缺省级别】
2:系统级
queue-value:队列编号,只适用于二层端口。
weighting-constant exponent:计算平均队列长度的指数,exponent的取值范围为1~15,缺省值为9。
【描述】
queue weighting-constant命令用来配置基于queue的WRED表的平均队列长度的指数,undo queue weighting-constant命令用来恢复基于queue的WRED表平均队列长度指数为缺省值。
相关配置可参考命令qos wred table。
# 配置基于queue的WRED表的平均队列长度的指数为12。
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
6 全局CAR配置命令
6.1  全局CAR配置命令
6.1.1  car name
car name car-name [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
流行为视图
【缺省级别】
2:系统级
car-name:聚合CAR的名称。
mode:分层CAR和聚合CAR动作的合作模式。有and和or两种模式,默认为and模式。
·     and:在该模式下,对于多条数据流应用同一个分层CAR,必须每条流满足各自的聚合CAR配置,同时各流量之和又满足分层CAR的配置,流量才能正常通过。
·     or:在该模式下,对于多条数据流应用同一个分层CAR,只要每条流满足各自的聚合CAR配置或者各流量之和满足分层CAR配置,流量即可正常通过。
【描述】
car name命令用来配置流行为的全局CAR动作。undo car用来删除流行为的全局CAR动作。
# 配置流行为be1的聚合CAR动作为aggcar-1。
# 配置流行为be1的聚合CAR动作为aggcar-1,分层CAR动作为hcar,合作模式为or。
[Sysname-behavior-be1] car name aggcar-1 hierarchy-car hcar mode or
display qos car name [ car-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
car-name:全局CAR的名称,包含聚合CAR和分层CAR。
【描述】
display qos car name命令用来显示全局CAR的配置和统计信息。
·     如果输入car-name参数,将显示指定全局CAR的配置和统计信息。
·     如果不输入car-name参数,将显示所有全局CAR的配置和统计信息。
# 显示全局CAR的配置信息。
<Sysname> display qos car name
  Mode: aggregative
  CIR: 256(kbps)  CBS: 1024(byte)  EBS: 0(byte)  PIR: 4096(kbps)
  Green Action: pass
  Yellow Action: pass
  Red Action: discard
  Green packet 37(Pkts)
  Red packet 1(Pkts)
  Mode: hierarchy
  CIR: 1024(kbps)  CBS: 8192(byte)
  Green packet 38(Pkts)
  Red packet 3(Pkts)
表6-1 display qos car name命令显示信息描述表
Name
流量监管的名称
Mode
流量监管的类型
·     aggregative:聚合CAR
·     hierarchy:分层CAR
CIR  CBS  EBS  PIR
流量监管流量的参数配置
Green Action
对绿色、黄色、红色报文采用的动作,可以为以下类型:
·     discard:丢弃数据包
·     pass:允许数据包通过
Yellow Action
Red Action
Green packet
绿色报文的流量统计
Red packet
红色报文的流量统计
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ pir peek-information-rate ] [ green action ] [ yellow action ] [ red action ]
undo qos car car-name
【缺省级别】
2:系统级
car-name:聚合CAR的名称,为1~31个字符的字符串。
cir committed-information-rate:承诺信息速率,单位为kbps,取值范围为8~10000000且必须是8的倍数。
ebs excess-burst-size:超出突发尺寸,单位为byte,取值范围为0~256000000,缺省值为512byte。
pir peak-information-rate:峰值信息速率,单位为kbps,取值范围为8~10000000且必须是8的倍数。
green action:对绿色报文采取的动作,缺省动作为pass。
yellow action:对红色报文采取的动作,缺省动作为pass。
red action:对红色报文采取的动作,缺省动作为discard。
action的取值有以下几种:
·     discard:丢弃数据包。
·     pass:允许数据包通过。
【描述】
qos car aggregative命令用来配置聚合CAR。undo qos car命令用来取消聚合CAR的配置。
聚合CAR配置需要在策略中引用后才能生效。
# 配置聚合CAR采取的CAR参数取值,cir取值为256,cbs取值为4096,对于红色报文采取丢弃的动作。
[Sysname] qos car aggcar-1 aggregative cir 256 cbs 4096 red discard
qos car car-name hierarchy cir committed-information-rate [ cbs committed-burst-size ]
【缺省级别】
2:系统级
car-name:分层CAR的名称,为1~31个字符的字符串。
hierarchy:标明该全局CAR为分层CAR类型。
cir committed-information-rate:承诺信息速率,取值为8~32000000且必须是8的整数倍,单位为kbps。
·     如果指定cbs参数,取值范围4096~256000000。
【描述】
qos car hierarchy命令用来配置分层CAR。undo qos car命令用来取消分层CAR的配置。
分层CAR配置需要在策略中引用后才能生效。
# 配置分层CAR采取的CAR参数取值,cir取值为256,cbs取值为8192。
[Sysname] qos car hcar hierarchy cir 256 cbs 8192
【缺省级别】
2:系统级
car-name:全局CAR的名称。
【描述】
reset qos car name命令用来清除全局CAR的统计信息。
·     如果输入car-name参数,将清除指定全局CAR的统计信息。
·     如果不输入car-name参数,将清除所有全局CAR的统计信息,包括聚合CAR、分层CAR和普通全局CAR。
# 清除全局CAR aggcar-1的统计信息。
<Sysname> reset qos car name aggcar-1
7 数据缓冲区配置命令
7.1  自动配置数据缓冲区的命令
burst-mode enable
undo burst-mode enable
【缺省级别】
2:系统级
无
【描述】
burst-mode enable命令用来开启Burst功能。undo burst-mode enable命令用来关闭Burst功能。
缺省情况下,Burst功能处于关闭状态。
用户可以通过开启Burst功能,使交换机自动分配cell资源和packet资源的共享区域比例、队列的最小保证资源比、队列和端口的最大共享资源占用比,来获得更好的报文缓存功能和流量转发性能。
burst-mode enable命令与手工配置数据缓冲区的所有命令均不能同时配置。
# 开启Burst功能。
[Sysname] burst-mode enable
7.2  手工配置数据缓冲区的命令
·     数据缓冲区的配置比较复杂,而且对设备的转发功能有重要的影响,建议用户不要轻易修改数据缓冲区的参数。在需要较大的缓存空间时,建议使用Burst功能来自动分配缓冲区。
·     本节中介绍的所有命令与burst-mode enable命令均不能同时配置。
7.2.1  buffer apply
buffer apply
undo buffer apply
【缺省级别】
2:系统级
无
【描述】
buffer apply命令用来应用用户对数据缓冲区所做的配置。undo buffer apply命令用来恢复数据缓冲区的配置为缺省情况。
缺省情况下,本系列交换机的数据缓冲区各项配置参数如表7-1所示。
表7-1 缺省缓冲区参数
资源类型
共享区域比例
队列的最小保证资源比
队列的最大共享资源占用比
端口的最大共享资源占用比
cell资源
64%
13%
33%
33%
packet资源
75%
13%
33%
33%
# 应用数据缓冲区的配置。
[Sysname] buffer apply
buffer egress [ slot slot-number ] { cell | packet } queue queue-id guaranteed ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } queue queue-id guaranteed
【缺省级别】
2:系统级
slot slot-number:成员设备编号。在IRF中配置该命令时,如果指定了slot-number,表示配置指定编号的成员设备的缓冲资源,如果没有指定slot-number,则表示配置IRF中所有成员设备的缓冲资源。
cell:配置队列在cell资源中的最小保证资源比。
packet:配置队列在packet资源中的最小保证资源比。
queue-id:需要配置的队列编号,取值范围为0~7。
ratio:队列的最小保证资源比,以百分数形式表示,取值范围为0~100。
【描述】
buffer egress queue guaranteed命令用来配置队列在cell资源或packet资源中的最小保证资源比。undo buffer egress queue guaranteed命令用来恢复队列最小保证资源比的缺省情况。
缺省情况下,所有队列在cell资源和packet资源的最小保证资源比均为12%。
·     由于端口的独享资源是由8个队列共同使用,因此当用户修改了某个队列的最小保证资源比之后,其它队列的最小保证资源比将随之自动变化,自动变化的原则为:除用户手工配置的最小保证资源比之外,剩余比例将平均分配给未进行手工配置的队列。例如,如果配置一个队列的最小保证资源比为30%,则剩余7个队列的最小保证资源比将自动变化为10%。
·     队列的最小保证资源比对全局生效,即配置后每个端口上的该队列均能以相同的比例占用当前端口的独享资源。
# 配置队列0在cell资源中的最小保证资源比为20%。
[Sysname] buffer egress cell queue 0 guaranteed ratio 20
# 在IRF中,配置指定成员设备(编号为2)的队列0在该设备cell资源中的最小保证资源比为15%。
[Sysname] buffer egress slot 2 cell queue 0 guaranteed ratio 15
buffer egress [ slot slot-number ] { cell | packet } queue queue-id shared ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } queue queue-id shared
【缺省级别】
2:系统级
cell:配置队列在cell资源中的最大共享资源占用比。
packet:配置队列在packet资源中的最大共享资源占用比。
ratio:队列的最大共享资源占用比,以百分数形式表示,取值范围为0~100。
【描述】
buffer egress queue shared命令用来配置队列在cell资源或packet资源中的最大共享资源占用比。undo buffer egress queue shared命令用来恢复队列最大共享资源占用比的缺省情况。
缺省情况下,所有队列在cell资源和packet资源的最大共享资源占用比均为33%。
队列的最大共享资源占用比对全局生效,即配置后每个端口上的该队列均能以相同的最大共享资源占用比来动态使用共享区域的资源。
# 配置队列0在cell资源中的最大共享资源占用比为10%。
[Sysname] buffer egress cell queue 0 shared ratio 10
# 在IRF中,配置指定成员设备(编号为2)的队列0在该设备cell资源中的最大共享资源占用比为5%。
[Sysname] buffer egress slot 2 cell queue 0 shared ratio 5
buffer egress [ slot slot-number ] { cell | packet } shared ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } shared
【缺省级别】
2:系统级
cell:配置端口在cell资源中的最大共享资源占用比。
packet:配置端口在packet资源中的最大共享资源占用比。
ratio:端口的最大共享资源占用比,以百分数形式表示,取值范围为0~100。
【描述】
buffer egress shared命令用来配置端口在cell资源或packet资源中的最大共享资源占用比。undo buffer egress shared命令用来恢复端口最大共享资源占用比的缺省情况。
缺省情况下,所有端口在cell资源和packet资源的最大共享资源占用比均为33%。
端口的最大共享资源占用比对所有端口生效,即配置后每个端口均能够以相同的最大共享资源占用比来动态使用共享区域资源。
# 配置当前设备上所有端口在cell资源中的最大共享资源占用比为30%。
[Sysname] buffer egress cell shared ratio 30
# 在IRF中,配置指定成员设备(编号为2)的所有端口在该设备cell资源中的最大共享资源占用比为40%。
[Sysname] buffer egress slot 2 cell shared ratio 40
buffer egress [ slot slot-number ] { cell | packet } total-shared ratio ratio
undo buffer egress [ slot slot-number ] { cell | packet } total-shared
【缺省级别】
2:系统级
cell:配置cell资源中的共享区域所占比例。
packet:配置packet资源中的共享区域所占比例。
ratio:共享区域所占的比例,以百分数形式表示,取值范围为0~100。
【描述】
buffer egress total-shared命令用来配置cell资源或packet资源中的共享区域所占的比例。undo buffer egress total-shared命令用来恢复cell资源或packet资源中共享区域所占比例的缺省值。
缺省情况下,本系列交换机的cell资源中共享区域所占比例为64%,packet资源中共享区域所占比例为75%。
# 配置当前设备cell资源中的共享区域所占比例为50%。
[Sysname] buffer egress cell total-shared ratio 50
# 在IRF中,配置指定成员设备(编号为2)的cell资源中共享区域所占比例为65%。
[Sysname] buffer egress slot 2 cell total-shared ratio 65
