01-Probe命令
本章节下载: 01-Probe命令 (1.52 MB)
1.1.10 bcm diag/cosq/print_flow_and_up/dest_id=1623/print_status=1
1.1.11 bcm diag/cosq/print_flow_and_up/dest_id=17082/is_flow=1/print_status=1
1.1.12 bcm diag/count/packet/nz
1.2.1 clear mainboard switchinfo
1.3.1 debug devm close-reboot-msg
1.3.2 debug devm lowipc-test node
1.3.7 debug fcoe show fips agg
1.3.8 debug fcoe show fips userport
1.3.9 debug fcoe show nexthop vfc hard
1.3.10 debug fcoe show nexthop vfc soft
1.3.11 debug fcoe show nexthop vfc soft
1.3.12 debug fcoe show nexthop vfc soft
1.3.13 debug fcoe show nexthop vfc soft
1.3.14 debug fcoe show npvmap soft
1.3.15 debug fcoe show npvmap soft
1.3.16 debug fcoe show npvmap vfc hard
1.3.17 debug fcoe show npvmap vfc soft
1.3.19 debug fcoe show route hard
1.3.20 debug fcoe show route soft
1.3.21 debug fcoe show route soft
1.3.22 debug fcoe show statistic
1.3.23 debug fcoe show vsan map-info
1.3.24 debug fcoe show vsan map-info mapped
1.3.25 debug fcoe show vsan map-info unmapped
1.3.29 debug ipc-status cpu-info clear
1.3.30 debug ipc-status cpu-info show
1.3.31 debug ipc-status mac-info show
1.3.32 debug ipc-status port-info reset
1.3.33 debug ipc-status port-info show
1.3.39 debug ipmc show mtunnel
1.3.43 debug ipv4-drv show arp
1.3.44 debug ipv4-drv show config
1.3.45 debug ipv4-drv show nexthop
1.3.46 debug ipv4-drv show nexthop all
1.3.47 debug ipv4-drv show nexthop index
1.3.48 debug ipv4-drv show route
1.3.49 debug ipv4-drv show statistics
1.3.51 debug ipv6-drv show route
1.3.52 debug ipv6-drv show statistics
1.3.55 debug l2 evb/show/vlan=
1.3.57 debug l2 mac/config/static/
1.3.58 debug l2 mac/config/static/clear
1.3.59 debug l2 mac/config/static/count
1.3.60 debug l2 mac/config/static/err
1.3.61 debug l2 mac/config/static/vid=/mac=
1.3.63 debug l2 mac/extendinfo
1.3.64 debug l2 mac/find/vid=/mac=
1.3.65 debug l2 mac/findvsi/vsi=/mac=
1.3.66 debug l2 mac/find_in_cache/vid=/mac=
1.3.67 debug l2 mac/find_in_shadow/vid=/mac=
1.3.68 debug l2 mac/hashconflict/show
1.3.69 debug l2 mac/mac-cache/show
1.3.70 debug l2 mac/macnotify/unit=/port=
1.3.72 debug l2 mac/max/unit=/port=
1.3.73 debug l2 mac/move_rec/show
1.3.76 debug l2 mac/vlan/learnlimit/vlan=
1.3.77 debug l2 mac/vlan/unknowsrcact/vlan=
1.3.78 debug l2 qinq/chipinfo/unit=
1.3.80 debug l2 qinq/portinfo/
1.3.86 debug l2 vlan/info/vid=
1.3.88 debug l2mc show mcarp-rbtree
1.3.89 debug l2mc show mcmac-rbtree
1.3.90 debug l2mc show node-list
1.3.91 debug l3intf-drv logshow
1.3.92 debug l3intf-drv logshow all
1.3.93 debug l3intf-drv logshow statistics
1.3.94 debug l3intf-drv mystationshow infobystationid
1.3.95 debug l3intf-drv mystationshow infobyvlan
1.3.96 debug l3intf-drv show infobyindex
1.3.97 debug l3intf-drv show infobyvlan
1.3.98 debug l3intf-drv show statistics
1.3.99 debug l3intf-drv show variable
1.3.100 debug l3intf-drv show virtualmac
1.3.102 debug mdc show datachginfo
1.3.103 debug mdc show drvevent
1.3.104 debug mdc show locationslotinfo
1.3.105 debug mdc show platevent
1.3.106 debug mdc show setisolateinfo
1.3.107 debug mdc show slot2mdcinfo
1.3.108 debug mdc show tgid2mdcinfo
1.3.109 debug mpls-drv display dscp-exp
1.3.110 debug mpls-drv display egress
1.3.111 debug mpls-drv display ftn
1.3.112 debug mpls-drv display global
1.3.113 debug mpls-drv display ilm
1.3.114 debug mpls-drv display intf-status
1.3.115 debug mpls-drv display l2vpn vpls
1.3.116 debug mpls-drv display l2vpn vpws
1.3.117 debug mpls-drv display l3vpn
1.3.118 debug mpls-drv display rbtree ac
1.3.119 debug mpls-drv display rbtree egr
1.3.120 debug mpls-drv display rbtree port
1.3.121 debug mpls-drv display rbtree pw
1.3.122 debug mpls-drv display rbtree station
1.3.123 debug mpls-drv display rbtree statistics
1.3.124 debug mpls-drv display rbtree tnl
1.3.125 debug mpls-drv display rbtree vn
1.3.126 debug mpls-drv display rbtree vnegr
1.3.127 debug mpls-drv display statistics
1.3.128 debug netstream show entry
1.3.129 debug netstream show global
1.3.130 debug netstream show port
1.3.131 debug netstream show { ipv4_agg | ipv6_agg }
1.3.135 debug port flow-record
1.3.136 debug port global-info
1.3.146 debug port optical-eeprom
1.3.147 debug port optical-module
1.3.148 debug port optical-recover
1.3.151 debug port trunk-global
1.3.152 debug port trunk-state
1.3.154 debug port wc40_reg_read
1.3.155 debug port wc40_reg_write
1.3.156 debug ptp showvariables
1.3.157 debug qacl packet action
1.3.158 debug qacl packet control
1.3.159 debug qacl packet pattern
1.3.160 debug qacl show acl-prioinfo
1.3.161 debug qacl show acl-resc
1.3.162 debug qacl show acltype-info
1.3.163 debug qacl show copp-sysidx
1.3.164 debug qacl show globalcar
1.3.165 debug qacl show packet pattern
1.3.166 debug qacl show proctime
1.3.167 debug qacl show seminfo
1.3.168 debug qacl show verbose
1.3.170 debug rport-drv show infobyifindex
1.3.171 debug rport-drv show l3port
1.3.172 debug rport-drv show statistics
1.3.173 debug rxtx coscar show
1.3.177 debug rxtx rxacl acltype
1.3.178 debug rxtx rxacl counter
1.3.179 debug rxtx rxacl info all
1.3.180 debug rxtx rxacl info recordlist
1.3.181 debug rxtx rxacl info singleport
1.3.185 debug rxtx softcar attack_rcd
1.3.186 debug rxtx softcar show
1.3.187 debug stack clear-record
1.3.188 debug stack show fwdpathinfo
1.3.189 debug stack show globalvariable
1.3.190 debug stack show ipc-info
1.3.191 debug stack show loglevel
1.3.192 debug stack show memberinfo
1.3.193 debug stack show portinfo
1.3.194 debug stack show record
1.3.195 debug stack show taskinfo
1.3.196 debug stack show topoinfo
1.3.197 debug sysm bridgemac read
1.3.198 debug sysm cpld-reg read
1.3.200 debug sysm display temperature-all
1.3.203 debug sysm get-fan-para
1.3.209 debug sysm set-fan-para
1.3.217 debug tm portspeed set
1.3.219 debug tm variable show
1.3.223 debug trill show default-vlan singleport
1.3.224 debug trill show default-vlan soft
1.3.225 debug trill show ipmc all
1.3.226 debug trill show ipmc index
1.3.227 debug trill show mc-entry all-entry
1.3.228 debug trill show mc-entry byipmcindex
1.3.229 debug trill show mc-entry local-entry
1.3.230 debug trill show mc-entry macvlanrb-entry
1.3.231 debug trill show mc-entry rb-entry
1.3.232 debug trill show mc-entry vlanrbingress-entry
1.3.233 debug trill show mc-entry vlanrbtransit-entry
1.3.235 debug trill show port all
1.3.236 debug trill show port portnum
1.3.237 debug trill show route
1.3.238 debug trill show route rb
1.3.239 debug trill show rpf-entry
1.3.240 debug trill show statistic
1.3.241 debug tunnel-drv show infobyindex
1.3.242 debug tunnel-drv show state
1.3.243 debug tunnel-drv show variable
1.3.244 debug { ipc-rx | ipc-tx } printpkt
1.3.245 debug { ipc-rx | ipc-tx } statistic detail
1.3.246 debug { ipc-rx | ipc-tx } statistic protocol
1.3.247 debug { ipc-rx | ipc-tx } statistic reset
1.3.250 debugging l2vpn l2vfib
1.3.253 debugging search symbol
1.3.256 debugging system internal arp event
1.3.257 debugging system internal arp features
1.3.258 debugging system internal arp notify
1.3.259 debugging system internal arp sync
1.3.260 debugging system internal fc fib
1.3.261 debugging system internal fib prefix
1.3.262 debugging system internal fib vn
1.3.263 debugging system internal igmp-snooping fsm tracing
1.3.264 debugging system internal ip vpn-instance
1.3.265 debugging system internal ipv6 fib prefix
1.3.266 debugging system internal mld-snooping fsm tracing
1.3.267 debugging system internal nd
1.3.268 debugging system internal trill adjacent-table
1.3.269 debugging system internal trill fib
1.3.270 debugging system internal trill management
1.3.271 debugging system internal trill mfib
1.3.272 debugging system internal trill vn
1.3.274 display deadloop section
1.3.277 display devm fabricporttype
1.3.279 display devm innerport
1.3.280 display devm isrrecord
1.3.282 display devm notify-record
1.3.283 display devm recordekdmtime
1.3.284 display devm recordipcportstatus
1.3.285 display devm switchport
1.3.287 display diag-msg start-msg
1.3.288 display hardware internal transceiver register interface
1.3.289 display hgmonitor action
1.3.290 display hgmonitor faultport
1.3.291 display hgmonitor info
1.3.292 display hgmonitor judge
1.3.293 display hgmonitor start
1.3.294 display hgmonitor variable
1.3.295 display inner-channel info
1.3.296 display inner-channel variable
1.3.297 display mainboard switchinfo
1.3.301 display rxtx broadcast
1.3.310 display rxtx matchrule
1.3.311 display rxtx multicast
1.3.319 display rxtx source_mac
1.3.320 display rxtx switchflag
1.3.324 display switch-fabric event
1.3.325 display switch-fabric variable
1.3.326 display system internal acl
1.3.327 display system internal arp
1.3.328 display system internal arp ifcb
1.3.329 display system internal arp ip-address
1.3.330 display system internal arp machash
1.3.331 display system internal arp probe
1.3.332 display system internal arp reload
1.3.333 display system internal arp source-suppression cache
1.3.334 display system internal arp statistics
1.3.335 display system internal arp vlan
1.3.336 display system internal bgp graceful-restart statistics
1.3.337 display system internal bgp instance statistics
1.3.338 display system internal bgp interface
1.3.339 display system internal bgp l2vpn auto-discovery advertise
1.3.340 display system internal bgp l2vpn auto-discovery verbose
1.3.341 display system internal bgp l2vpn signaling advertise
1.3.342 display system internal bgp l2vpn signaling verbose
1.3.343 display system internal bgp nib
1.3.344 display system internal bgp nib log
1.3.345 display system internal bgp peer statistics
1.3.346 display system internal bgp protocol statistics
1.3.347 display system internal bgp routing-table advertise-info
1.3.348 display system internal bgp routing-table verbose
1.3.349 display system internal cfd hardware
1.3.350 display system internal cfd mep
1.3.351 display system internal dbm
1.3.352 display system internal ethernet character
1.3.353 display system internal ethernet controlblock
1.3.354 display system internal evb global-info
1.3.355 display system internal evb kernel
1.3.356 display system internal fc fib
1.3.357 display system internal fib prefix
1.3.358 display system internal fib prefix entry-status
1.3.359 display system internal fib prefix ip
1.3.360 display system internal fib running-status
1.3.361 display system internal fib statistics
1.3.362 display system internal fib vn
1.3.363 display system internal fib vn entry-status
1.3.364 display system internal fib vn reference
1.3.365 display system internal ha service
1.3.366 display system internal ha service-group
1.3.367 display system internal ha statistics
1.3.368 display system internal ifmgr brief
1.3.369 display system internal ifmgr down
1.3.370 display system internal ifmgr entry
1.3.371 display system internal ifmgr event
1.3.372 display system internal ifmgr hotplug
1.3.373 display system internal ifmgr index
1.3.374 display system internal ifmgr list
1.3.375 display system internal ifmgr mdc
1.3.376 display system internal ifmgr name
1.3.377 display system internal ifmgr type
1.3.378 display system internal ip address
1.3.379 display system internal ip source binding
1.3.380 display system internal ip vpn-binding
1.3.381 display system internal ip vpn-instance
1.3.382 display system internal ip vpn-instance inactive
1.3.383 display system internal ip vpn-instance statistics
1.3.384 display system internal ipv6 address
1.3.385 display system internal ipv6 fib prefix
1.3.386 display system internal ipv6 fib prefix entry-status
1.3.387 display system internal ipv6 fib prefix ipv6
1.3.388 display system internal ipv6 l2-multicast ip forwarding verbose
1.3.389 display system internal ipv6 l2-multicast ip verbose
1.3.390 display system internal ipv6 l2-multicast ipc statistics
1.3.391 display system internal ipv6 l2-multicast mac forwarding verbose
1.3.392 display system internal ipv6 l2-multicast mac verbose
1.3.393 display system internal ipv6 mrib interface statistics
1.3.394 display system internal ipv6 mrib mbr
1.3.395 display system internal ipv6 multicast forwarding vlan reference
1.3.396 display system internal ipv6 multicast forwarding-table dummy
1.3.397 display system internal ipv6 multicast forwarding-table verbose
1.3.398 display system internal ipv6 multicast-vlan forwarding-table verbose
1.3.399 display system internal ipv6 pathmtu
1.3.400 display system internal ipv6 pbr fib
1.3.401 display system internal ipv6 pbr kernel policy
1.3.402 display system internal ipv6 pbr policy
1.3.403 display system internal ipv6 pim interface
1.3.404 display system internal ipv6 pim rp
1.3.405 display system internal ipv6 pim thread
1.3.406 display system internal ipv6 rawip
1.3.407 display system internal ipv6 rib event attribute
1.3.408 display system internal ipv6 rib event policy
1.3.409 display system internal ipv6 rib event prefix
1.3.410 display system internal ipv6 rib event protocol
1.3.411 display system internal ipv6 rib event statistics
1.3.412 display system internal ipv6 rib log
1.3.413 display system internal ipv6 rib memory
1.3.414 display system internal ipv6 rib nib log
1.3.415 display system internal ipv6 rib prefix
1.3.416 display system internal ipv6 rib summary
1.3.417 display system internal ipv6 route-direct interface
1.3.418 display system internal ipv6 route-direct interface
1.3.419 display system internal ipv6 route-direct log
1.3.420 display system internal ipv6 route-direct log
1.3.421 display system internal ipv6 route-static nib log
1.3.422 display system internal ipv6 source binding
1.3.423 display system internal ipv6 tcp
1.3.424 display system internal ipv6 udp
1.3.425 display system internal isis import-route
1.3.426 display system internal isis import-route ipv6
1.3.427 display system internal isis interface
1.3.428 display system internal isis interface ipv6
1.3.429 display system internal isis nib
1.3.430 display system internal isis nib ipv6
1.3.431 display system internal isis nib log
1.3.432 display system internal isis prefix
1.3.433 display system internal isis prefix ipv6
1.3.434 display system internal isis status
1.3.435 display system internal isis status
1.3.436 display system internal kernel memory dump
1.3.437 display system internal kernel memory pool
1.3.438 display system internal l2-multicast ip forwarding verbose
1.3.439 display system internal l2-multicast ip verbose
1.3.440 display system internal l2-multicast ipc statistics
1.3.441 display system internal l2-multicast mac forwarding verbose
1.3.442 display system internal l2-multicast mac verbose
1.3.443 display system internal l2vpn l2vfib record
1.3.444 display system internal l2vpn l2vfib statistics
1.3.445 display system internal link-aggregation global
1.3.446 display system internal link-aggregation interface
1.3.447 display system internal lipc lcmp statistics
1.3.448 display system internal lipc lgmp group
1.3.449 display system internal lipc lgmp group-list
1.3.450 display system internal lipc lgmp physical-group
1.3.451 display system internal lipc lgmp physical-group-list
1.3.452 display system internal lipc lgmp statistics
1.3.453 display system internal lipc lip statistics
1.3.454 display system internal lipc loop statistics
1.3.455 display system internal lipc mtcp group
1.3.456 display system internal lipc mtcp performance
1.3.457 display system internal lipc mtcp statistics
1.3.458 display system internal lipc pcb statistics
1.3.459 display system internal lipc physical
1.3.460 display system internal lipc publish global-cb
1.3.461 display system internal lipc publish statistics
1.3.462 display system internal lipc stcp event
1.3.463 display system internal lipc stcp global-server
1.3.464 display system internal lipc stcp links
1.3.465 display system internal lipc stcp performance
1.3.466 display system internal lipc stcp statistics
1.3.467 display system internal lipc stcp status
1.3.468 display system internal lipc stream
1.3.469 display system internal lipc sudp pcb-info
1.3.470 display system internal lipc sudp statistics
1.3.471 display system internal lipc sudp { global-port | local-port }
1.3.472 display system internal lipc topology history
1.3.473 display system internal lipc topology link
1.3.474 display system internal lipc topology node
1.3.475 display system internal lipc topology process-time
1.3.476 display system internal lipc topology statistics
1.3.477 display system internal lipc topology status
1.3.478 display system internal mac-address configuration
1.3.479 display system internal mac-address statistics
1.3.480 display system internal mbuf relay statistics
1.3.481 display system internal mbuf statistics
1.3.482 display system internal mpls lfib ilm
1.3.483 display system internal mpls lfib nhlfe
1.3.484 display system internal mpls lfib nhlfe reflist
1.3.485 display system internal mpls lfib record
1.3.486 display system internal mpls lfib statistics
1.3.487 display system internal mpls lsp-pending
1.3.488 display system internal mpls statistics
1.3.489 display system internal mrib interface statistics
1.3.490 display system internal mrib mbr
1.3.491 display system internal multicast capability
1.3.492 display system internal multicast forwarding vlan reference
1.3.493 display system internal multicast forwarding-table dummy
1.3.494 display system internal multicast forwarding-table verbose
1.3.495 display system internal multicast record
1.3.496 display system internal multicast-vlan forwarding-table verbose
1.3.497 display system internal nd dad
1.3.498 display system internal nd entry
1.3.499 display system internal nd ifcb
1.3.500 display system internal nd machash
1.3.501 display system internal nd probe
1.3.502 display system internal nd reload
1.3.503 display system internal nd static
1.3.504 display system internal nd statistics
1.3.505 display system internal ospf event-log
1.3.506 display system internal ospf interface
1.3.507 display system internal ospf lsdb
1.3.508 display system internal ospf nib
1.3.509 display system internal ospf prefix
1.3.510 display system internal ospf status
1.3.511 display system internal ospfv3 event-log
1.3.512 display system internal ospfv3 interface
1.3.513 display system internal ospfv3 lsdb
1.3.514 display system internal ospfv3 nib
1.3.515 display system internal ospfv3 prefix
1.3.516 display system internal ospfv3 status
1.3.517 display system internal pbr fib
1.3.518 display system internal pbr kernel policy
1.3.519 display system internal pbr policy
1.3.520 display system internal pim interface
1.3.521 display system internal pim rp
1.3.522 display system internal pim thread
1.3.523 display system internal ptp irf-port
1.3.524 display system internal ptp irf-statistics
1.3.525 display system internal rawip
1.3.526 display system internal rib event attribute
1.3.527 display system internal rib event policy
1.3.528 display system internal rib event prefix
1.3.529 display system internal rib event protocol
1.3.530 display system internal rib event statistics
1.3.531 display system internal rib log
1.3.532 display system internal rib memory
1.3.533 display system internal rib nib log
1.3.534 display system internal rib prefix
1.3.535 display system internal rib summary
1.3.536 display system internal rip interface
1.3.537 display system internal rip nib
1.3.538 display system internal rip nib log
1.3.539 display system internal rip status
1.3.540 display system internal ripng interface
1.3.541 display system internal ripng nib
1.3.542 display system internal ripng nib log
1.3.543 display system internal ripng status
1.3.544 display system internal route-direct interface
1.3.545 display system internal route-direct log
1.3.546 display system internal route-direct log
1.3.547 display system internal route-static nib log
1.3.548 display system internal service-loopback interface-list
1.3.549 display system internal service-loopback running
1.3.550 display system internal sflow statistics
1.3.551 display system internal startup cache
1.3.552 display system internal stp bridge-info
1.3.553 display system internal stp port-info
1.3.554 display system internal tcp
1.3.555 display system internal trill adjacent-table
1.3.556 display system internal trill fib
1.3.557 display system internal trill management
1.3.558 display system internal trill mfib
1.3.559 display system internal trill status
1.3.560 display system internal trill vn
1.3.561 display system internal tunnel data
1.3.562 display system internal udp
1.3.563 display system internal vlan
1.3.564 display transceiver diagnosis interface
1.3.565 display transceiver information interface
1.5.1 inner-channel port-isolate
1.6.1 l2vpn l2vfib record size
1.6.9 local logbuffer display qacl
1.6.10 local logbuffer display stack
1.7.1 memory boundary-check enable
1.7.2 memory boundary-check scan
1.9.1 reset ipv6 multicast forwarding-table dummy
1.9.5 reset ipv6 route-direct log
1.9.6 reset ipv6 route-direct log
1.9.7 reset ipv6 route-static nib log
1.9.8 reset l2vpn l2vfib record
1.9.10 reset multicast forwarding-table dummy
1.9.18 reset route-static nib log
1.9.19 reset system internal arp statistics
1.9.20 reset system internal fib statistics
1.9.21 reset system internal mac-address statistics
1.9.22 reset system internal mbuf relay statistics
1.9.23 reset system internal nd statistics
1.9.24 reset system internal sflow statistics
1.9.25 reset system internal trill adjacent-table statistics
1.9.26 reset system internal trill fib statistics
1.9.27 reset system internal trill management statistics
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
bcm命令用来显示BCM指定单板上芯片的信息。
独立运行模式:
bcm slot slot-number chip chip-number bcm-cli
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number bcm-cli
Probe视图
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。(IRF模式)
chip-number:芯片编号。
bcm-cli:BCM芯片的命令行。取值不允许含有空格或者“?”,使用“/”或者“\”分隔多个命令,使用“!”获取帮助。
bcm clear/c命令用来清除芯片报文计数。
独立运行模式:
bcm slot slot-number chip chip-number clear/c
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number clear/c
Probe视图
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
chip chip-number:表示芯片编号。
bcm cos/show命令用来显示硬件802.1p优先级到cos优先级的映射关系。
独立运行模式:
bcm slot slot-number chip chip-number cos/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number cos/show
Probe视图
chip-number:表示芯片编号。
bcm d/chg/egr_ip_tunnel显示隧道封装表项。
独立运行模式:
bcm slot slot-number chip chip-number d/chg/egr_ip_tunnel
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number d/chg/egr_ip_tunnel
Probe视图
bcm d/dscp_table命令用来显示硬件DSCP优先级到DSCP优先级、802.1p优先级、CNG优先级的映射关系。
独立运行模式:
bcm slot slot-number chip chip-number d/dscp_table
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number d/dscp_table
Probe视图
chip-number:表示芯片编号。
bcm d/fp_counter_table命令用来显示counter硬件表项。
独立运行模式:
bcm slot slot-number chip chip-number d/fp_counter_table
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number d/fp_counter_table
Probe视图
chip-number:表示芯片编号。
bcm d/fp_meter_table命令用来显示meter硬件表项。
独立运行模式:
bcm slot slot-number chip chip-number d/fp_meter_table
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number d/fp_meter_table
Probe视图
chip-number:表示芯片编号。
bcm d/fp_tcam命令用来显示FP硬件表项。
独立运行模式:
bcm slot slot-number chip chip-number d/fp_tcam
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number d/fp_tcam
Probe视图
chip-number:表示芯片编号。
bcm d/l3_tunnel显示隧道解封装表项。
独立运行模式:
bcm slot slot-number chip chip-number d/l3_tunnel
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number d/l3_tunnel
Probe视图
bcm diag/cosq/print_flow_and_up/dest_id=1623/print_status=1用来根据system_port显示flow id等状态信息。
【命令行】
独立运行模式:
bcm slot slot-number chip chip-number diag/cosq/print_flow_and_up/dest_id=1623/print_status=1
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number diag/cosq/print_flow_and_up/dest_id=1623/print_status=1
Probe视图
bcm diag/cosq/print_flow_and_up/dest_id=17082/is_flow=1/print_status=1用来根据flow id显示SCH、EGQ、HR 、credit rate等信息。
【命令行】
独立运行模式:
bcm slot slot-number chip chip-number diag/cosq/print_flow_and_up/dest_id=17082/is_flow=1/print_status=1
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number diag/cosq/print_flow_and_up/dest_id=17082/is_flow=1/print_status=1
Probe视图
bcm diag/count/packet/nz用来流量管理芯片报文计数。
【命令行】
独立运行模式:
bcm slot slot-number chip chip-number diag/count/packet/nz
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number diag/count/packet/nz
Probe视图
bcm fp/show/entry/命令用来显示指定的表项信息。
独立运行模式:
bcm slot slot-number chip chip-number fp/show/entry/ [ entry-id ]
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number fp/show/entry/ [ entry-id ]
Probe视图
chip-number:表示芯片编号。
entry-id:表项索引号。
bcm l3/defip/show显示IPv4路由表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/defip/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/defip/show
Probe视图
bcm l3/egress/show显示Egress表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/egress/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/egress/show
Probe视图
bcm l3/intf/show显示INTF表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/intf/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/intf/show
Probe视图
bcm l3/ip6host/show显示ND表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/ip6host/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/ip6host/show
Probe视图
bcm l3/ip6route/show显示IPv6路由表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/ip6route/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/ip6route/show
Probe视图
bcm l3/l3table/show显示arp表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/l3table/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/l3table/show
Probe视图
bcm l3/multipath/show显示等价路由Egress表项。
独立运行模式:
bcm slot slot-number chip chip-number l3/multipath/show
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number l3/multipath/show
Probe视图
【功能】
bcm show/c命令用来查看芯片报文计数。
独立运行模式:
bcm slot slot-number chip chip-number show/c
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number show/c
Probe视图
bcm show/c/fabric用来流量管理芯片上行口报文计数。
【命令行】
独立运行模式:
bcm slot slot-number chip chip-number show/c/fabric
IRF模式:
bcm chassis chassis-number slot slot-number chip chip-number show/c/fabric
Probe视图
clear mainboard switchinfo清除主控板重启原因信息的记录
独立运行模式:
IRF模式:
clear mainboard switchinfo [ chassis chassis-number ]
Probe视图
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。若未指定本参数,将清除所有成员设备的主控板重启原因信息的记录。
debug devm close-reboot-msg关闭向控制台输出握手通知信息。
Probe视图
debug devm lowipc-test node node-id测试驱动的IPC通道。
Probe视图
node node-id:测试驱动的IPC通道。node-id表示节点号。
debug devm reboot-msg开启向控制台输出握手提示信息。
Probe视图
debug devm switch切换HG开关。
独立运行模式:
debug devm switch slot slot-number switch-number switch-status
IRF模式:
debug devm switch chassis chassis-number slot slot-number switch-number switch-status
Probe视图
switch-number:表示开关号,取值为0或1。
switch-status:表示开关状态,取值为0或1。0表示使用HG0;1表示使用HG1。
debug fcoe show fips命令用来查看所有FIP Snooping规则。
独立运行模式:
debug fcoe show fips slot slot-number offset offset-number
IRF模式:
debug fcoe show fips chassis chassis-number slot slot-number offset offset-number
Probe视图
offset offset-number:显示指定起始行数的FIP Snooping规则的信息。offset-number表示显示信息的偏移值,如果offset-number值为0,则显示第一行开始的30条信息;如果offset-number值为5,则显示第六行开始的30条信息。
debug fcoe show fips命令用来查看某个VLAN的所有FIP Snooping规则。
独立运行模式:
debug fcoe show fips vlan-id slot slot-number offset offset-number
IRF模式:
debug fcoe show fips vlan-id chassis chassis-number slot slot-number offset offset-number
Probe视图
vlan-id:VLAN的编号。
debug fcoe show fips agg 命令用来查看某个聚合接口的FIP Snooping规则
独立运行模式:
debug fcoe show fips vlan-id agg agg-id slot slot-number offset offset-number
IRF模式:
debug fcoe show fips vlan-id agg agg-id chassis chassis-number slot slot-number offset offset-number
Probe视图
vlan-id:VLAN的编号。
agg agg-id:显示指定聚合接口的FIP Snooping规则的信息,agg-id表示该聚合接口的编号。
debug fcoe show fips userport命令用来查看某个 VLAN的某个具体接口下的FIP Snooping规则。
独立运行模式:
debug fcoe show fips vlan-id userport subslot-number userport-number slot slot-number offset offset-number
IRF模式:
debug fcoe show fips vlan-id userport subslot-number userport-number chassis chassis-number slot slot-number offset offset-number
Probe视图
vlan-id:VLAN的编号。
subslot-number:表示接口所在子槽位号。
userport-number:面板接口的编号。
debug fcoe show nexthop vfc hard命令用来显示某个VFC接口的硬件表项。
独立运行模式:
debug fcoe show nexthop vfc vlan-id vfc-id dfc-id hard slot slot-number
IRF模式:
debug fcoe show nexthop vfc vlan-id vfc-id dfc-id hard chassis chassis-number slot slot-number
Probe视图
vlan-id:VFC接口所在的VLAN的编号。
vfc-id:VFC接口的编号。
dfc-id:对于E模式的VFC接口,该参数需要配置为0;对于F模式的VFC接口,该参数需要配置为0或者是该VFC接口的FC地址。
debug fcoe show nexthop vfc soft命令用来显示某个VFC接口的软件表项。
独立运行模式:
debug fcoe show nexthop vfc vlan-id vfc-id dfc-id soft slot slot-number
IRF模式:
debug fcoe show nexthop vfc vlan-id vfc-id dfc-id soft chassis chassis-number slot slot-number
Probe视图
vfc-id:VFC接口的编号。
debug fcoe show nexthop vfc soft命令用来显示某个VLAN的所有VFC接口下一跳的软件表项。
独立运行模式:
debug fcoe show nexthop vfc vlan-id soft slot slot-number offset-number
IRF模式:
debug fcoe show nexthop vfc vlan-id soft chassis chassis-number slot slot-number offset-number
Probe视图
vlan-id:VLAN的编号。
offset-number:表示显示信息的偏移值,如果offset-number值为0,则显示第一行开始的30条信息;如果offset-number值为5,则显示第六行开始的30条信息。
debug fcoe show nexthop vfc soft命令用来显示某个VFC接口下一跳的软件表项。
独立运行模式:
debug fcoe show nexthop vfc vlan-id vfc-id soft slot slot-number offset-number
IRF模式:
debug fcoe show nexthop vfc vlan-id vfc-id soft chassis chassis-number slot slot-number offset-number
Probe视图
vfc-id:VFC接口的编号。
debug fcoe show nexthop vfc soft命令用来显示所有VFC接口下一跳的软件表项。
独立运行模式:
debug fcoe show nexthop vfc soft slot slot-number offset-number
IRF模式:
debug fcoe show nexthop vfc soft chassis chassis-number slot slot-number offset-number
Probe视图
debug fcoe show npvmap soft命令用来显示显示所有VSAN的NPV的软件表项。
独立运行模式:
debug fcoe show npvmap soft slot slot-number offset-number
IRF模式:
debug fcoe show npvmap soft chassis chassis-number slot slot-number offset-number
Probe视图
debug fcoe show npvmap soft命令用来显示某个VSAN的所有NPV的软件表项
独立运行模式:
debug fcoe show npvmap vsan-id soft slot slot-number offset-number
IRF模式:
debug fcoe show npvmap vsan-id soft chassis chassis-number slot slot-number offset-number
Probe视图
vsan-id:VSAN的编号。
debug fcoe show npvmap vfc hard命令用来显示某个VSAN的某个VFC接口的NPV的硬件表项。
独立运行模式:
debug fcoe show npvmap vsan-id vfc vfc-id sfc-id sfc-id-masklen hard slot slot-number
IRF模式:
debug fcoe show npvmap vsan-id vfc vfc-id sfc-id sfc-id-masklen hard chassis chassis-number slot slot-number
Probe视图
vsan-id:VSAN的编号。
vfc vfc-id:显示指定VFC接口的NPV的硬件表项,vfc-id表示该VFC接口的编号。
sfc-id:源FC地址。
sfc-id-masklen:源FC地址的掩码长度。
debug fcoe show npvmap vfc soft命令用来显示某个VSAN的某个VFC接口的NPV的软件表项。
独立运行模式:
debug fcoe show npvmap vsan-id vfc vfc-id sfc-id sfc-id-masklen soft slot slot-number
IRF模式:
debug fcoe show npvmap vsan-id vfc vfc-id sfc-id sfc-id-masklen soft chassis chassis-number slot slot-number
Probe视图
vsan-id:VSAN的编号。
vfc vfc-id:显示指定VFC接口的NPV的软件表项,vfc-id表示该VFC接口的编号。
sfc-id:源FC地址。
debug fcoe show reload命令用来显示需要重刷的VSAN。
独立运行模式:
debug fcoe show reload slot slot-number
IRF模式:
debug fcoe show reload chassis chassis-number slot slot-number
Probe视图
debug fcoe show route hard命令用来显示某个路由的硬件表项。
独立运行模式:
debug fcoe show route vsan-id dfc-id dfc-id-masklen hard slot slot-number
IRF模式:
debug fcoe show route vsan-id dfc-id dfc-id-masklen hard chassis chassis-number slot slot-number
Probe视图
vsan-id:路由所在的VSAN的编号。
dfc-id:目的FC地址。
dfc-id-masklen:目的FC地址的掩码长度。
debug fcoe show route soft命令用来显示某个路由的软件表项。
独立运行模式:
debug fcoe show route vsan-id dfc-id dfc-id-masklen soft slot slot-number
IRF模式:
debug fcoe show route vsan-id dfc-id dfc-id-masklen soft chassis chassis-number slot slot-number
Probe视图
dfc-id:目的FC地址。
debug fcoe show route soft命令用来显示路由的软件表项。
独立运行模式:
debug fcoe show route [ vsan-id ] soft slot slot-number offset-number
IRF模式:
debug fcoe show route [ vsan-id ] soft chassis chassis-number slot slot-number offset-number
Probe视图
vsan-id:VSAN的编号。
debug fcoe show statistic命令用来显示FCoE的规格以及各项计数。
独立运行模式:
debug fcoe show statistic slot slot-number
IRF模式:
debug fcoe show statistic chassis chassis-number slot slot-number
Probe视图
debug fcoe show vsan map-info命令用来显示某个VSAN的映射关系。
独立运行模式:
debug fcoe show vsan map-info vsan-id slot slot-number
IRF模式:
debug fcoe show vsan map-info vsan-id chassis chassis-number slot slot-number
Probe视图
vsan-id:VSAN的编号。
debug fcoe show vsan map-info mapped命令用来显示所有已映射VSAN的映射关系。
独立运行模式:
debug fcoe show vsan map-info mapped slot slot-number
IRF模式:
debug fcoe show vsan map-info mapped chassis chassis-number slot slot-number
Probe视图
debug fcoe show vsan map-info unmapped命令用来显示所有没映射VSAN。
独立运行模式:
debug fcoe show vsan map-info unmapped slot slot-number
IRF模式:
debug fcoe show vsan map-info unmapped chassis chassis-number slot slot-number
Probe视图
debug fcoe show zone命令用来显示某个VSAN的某个Zone规则的信息。
独立运行模式:
debug fcoe show zone vsan-id sfc-id sfc-id-masklen dfc-id dfc-id-masklen slot slot-number
IRF模式:
debug fcoe show zone vsan-id sfc-id sfc-id-masklen dfc-id dfc-id-masklen chassis chassis-number slot slot-number
Probe视图
vsan-id:VSAN的编号。
sfc-id:源FC地址。
dfc-id:目的FC地址。
debug fcoe show zone命令用来显示某个VSAN的所有Zone规则的信息。
独立运行模式:
debug fcoe show zone vsan-id slot slot-number offset offset-number
IRF模式:
debug fcoe show zone vsan-id chassis chassis-number slot slot-number offset offset-number
Probe视图
vsan-id:VSAN的编号。
slot slot-mumber:表示单板所在的槽位号。(独立运行模式)
offset offset-number:显示指定起始行数的Zone规则的信息。offset-number表示显示信息的偏移值,如果offset-number值为0,则显示第一行开始的30条信息;如果offset-number值为5,则显示第六行开始的30条信息。
debug fcoe show zone命令用来显示所有VSAN的Zone的规则。
独立运行模式:
debug fcoe show zone slot slot-number offset offset-number
IRF模式:
debug fcoe show zone chassis chassis-number slot slot-number offset offset-number
Probe视图
offset offset-number:显示指定起始行数的Zone的规则的信息。offset-number表示显示信息的偏移值,如果offset-number值为0,则显示第一行开始的30条信息;如果offset-number值为5,则显示第六行开始的30条信息。
debug ipc-status cpu-info clear命令对IPC指定CPU收发报文计数统计清零。
独立运行模式:
debug ipc-status cpu-info clear slot slot-number [ cpu-number ]
IRF模式:
debug ipc-status cpu-info clear chassis chassis-number slot slot-number [ cpu-number ]
Probe视图
cpu-number:CPU端口编号。
debug ipc-status cpu-info show命令显示IPC指定CPU对应端口报文统计。
独立运行模式:
debug ipc-status cpu-info show slot slot-number [ cpu-number ]
IRF模式:
debug ipc-status cpu-info show chassis chassis-number slot slot-number [ cpu-number ]
Probe视图
cpu-number:CPU端口编号。
debug ipc-status mac-info show命令用来显示IPC指定端口的静态MAC的信息。
独立运行模式:
debug ipc-status mac-info show [ slot slot-number ]
IRF模式:
debug ipc-status mac-info show [ chassis chassis-number slot slot-number ]
Probe视图
debug ipc-status port-info reset命令对IPC指定端口收发报文计数统计清零。
独立运行模式:
debug ipc-status port-info reset slot slot-number [ port-number ]
IRF模式:
debug ipc-status port-info reset chassis chassis-number slot slot-number [ port-number ]
Probe视图
port-number:端口编号。
debug ipc-status port-info show命令用来显示IPC指定端口收发报文计数统计。
独立运行模式:
debug ipc-status port-info show slot slot-number [ port-number ]
IRF模式:
debug ipc-status port-info show chassis chassis-number slot slot-number [ port-number ]
Probe视图
port-number:端口编号。
debug ipmc show agg命令用来显示组播聚合相关信息。
独立运行模式:
debug ipmc show agg slot slot-number [ entry-id ] [ continue ]
IRF模式:
debug ipmc show agg chassis chassis-number slot slot-number [ entry-id ] [ continue ]
Probe视图
slot slot-number:表示单板所在的槽位号。(独立运行模式)。
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)。
entry-id:l3mc表的索引编号。
continue:一次打印没有显示完,接着上次的结果显示。
debug ipmc show entry命令用来显示l3mc表项信息。
独立运行模式:
debug ipmc show entry { entry-id | all } [ detail ] [ slot slot-number ] [ continue ]
IRF模式:
debug ipmc show entry { entry-id | all } [ detail ] [ chassis chassis-number slot slot-number ] [ continue ]
Probe视图
all:表示打印所有l3mc表项。
detail:表示要打印出接口列表等详细信息。
debug ipmc show global命令用来显示IPMC模块规格相关信息。
独立运行模式:
debug ipmc show global [ slot slot-number ]
IRF模式:
debug ipmc show global [chassis chassis-number slot slot-number ]
Probe视图
debug ipmc show group命令用来查找组播表项。
独立运行模式:
debug ipmc show group { { ipv4 | ipv6 } slot slot-number chip-number group-address source-address vlan-id vrf-id [ hardware ] | { ipv4_bipim | ipv6_bipim } slot slot-number group-address vrf-id }
IRF模式:
debug ipmc show group { { ipv4 | ipv6 } chassis chassis-number slot slot-number chip-number group-address source-address vlan-id vrf-id [ hardware ] | { ipv4_bipim | ipv6_bipim } chassis chassis-number slot slot-number group-address vrf-id }
Probe视图
ipv4:查找ipv4组播组。
ipv4_bipim:查找类型为双向pim的ipv4组播组。
ipv6:查找ipv6组播组
ipv6_bipim:查找类型为双向pim的ipv6组播组。
hardware:表示直接通过查询硬件获取l3mc表项信息。
chip-number:指定芯片编号。
group-address:组播组地址。
source-address:组播组源地址。
vlan-id:指定组播组入接口所在vlan编号。
vrf-id:指定组播组入接口所在vrf id编号。
debug ipmc show mti命令用来显示组播mti接口相关信息。
独立运行模式:
debug ipmc show mti [ slot slot-number ]
IRF模式:
debug ipmc show mti [ chassis chassis-number slot slot-number ]
Probe视图
debug ipmc show mtunnel命令用来显示组播VPN相关调试信息。
独立运行模式:
debug ipmc show mtunnel { data-group | default-group } [ slot slot-number ]
IRF模式:
debug ipmc show mtunnel { data-group | default-group } [ chassis chassis-number slot slot-number ]
Probe视图
default-group:共享组信息。
data-group:切换组信息。
debug ipmc show pvlan命令用来显示组播pvlan相关调试信息
独立运行模式:
debug ipmc show pvlan slot slot-number vlan-id
IRF模式:
debug ipmc show pvlan chassis chassis-number slot slot-number vlan-id
Probe视图
vlan-id:指定pvlan编号
debug ipmc show rp命令用来显示组播双向PIM RP相关调试信息
独立运行模式:
debug ipmc show rp { ipv4 | ipv6 } slot slot-number group-address vrf-id
IRF模式:
debug ipmc show rp { ipv4 | ipv6 } chassis chassis-number slot slot-number group-address vrf-id
Probe视图
ipv4:ipv4类型的双向pim rp信息。
ipv6:ipv6类型的双向pim rp信息。
group-address:指定双向pim的组播组地址。
vrf-id:指定双向pim的vrf编号。
debug ipmc show vlan命令用来显示vlan对应的组播协议使能情况。
独立运行模式:
debug ipmc show vlan { vlan-id | all } [ slot slot-number ] [ continue ]
IRF模式:
debug ipmc show vlan { vlan-id | all } [ chassis chassis-number slot slot-number ] [ continue ]
Probe视图
vlan-id:指定VLAN编号。
all:查看所有vlan对应的组播协议使能情况。
debug ipv4-drv show arp显示arp的信息。
独立运行模式:
debug ipv4-drv show arp vrf-value ip-address slot slot-number
IRF模式:
debug ipv4-drv show arp vrf-value ip-address chassis chassis-number slot slot-number
Probe视图
vrf-value:VRF值。
ip-address:IP地址,为点分十进制格式。
debug ipv4-drv show config显示当前IPv4配置信息,包含IPv4最大arp个数、IPv4最大路由个数、IPv4等价路由条数、IPv6最大ND个数、IPv6最大路由个数、本板下一跳个数以及分配给vlan、子vlan、多播、MPLS和隧道各模块三层接口大小。
独立运行模式:
debug ipv4-drv show config slot slot-number
IRF模式:
debug ipv4-drv show config chassis chassis-number slot slot-number
Probe视图
debug ipv4-drv show nexthop显示下一跳表项索引对应信息。
独立运行模式:
debug ipv4-drv show nexthop index-number slot slot-number
IRF模式:
debug ipv4-drv show nexthop index-number chassis chassis-number slot slot-number
Probe视图
index-number:下一跳索引。
debug ipv4-drv show nexthop all显示全部下一跳表项信息。
独立运行模式:
debug ipv4-drv show nexthop all slot slot-number
IRF模式:
debug ipv4-drv show nexthop all chassis chassis-number slot slot-number
Probe视图
debug ipv4-drv show nexthop index显示下一跳表项指定范围索引对应信息。
独立运行模式:
debug ipv4-drv show nexthop index index_start index_end slot slot-number
IRF模式:
debug ipv4-drv show nexthop index index_start index_end chassis chassis-number slot slot-number
Probe视图
index_start:起始索引。
index_end:结束索引。
debug ipv4-drv show route显示IPv4路由的信息。
独立运行模式:
debug ipv4-drv show route vrf-value ip-address [ mask ] slot slot-number
IRF模式:
debug ipv4-drv show route vrf-value ip-address [ mask ] chassis chassis-number slot slot-number
Probe视图
vrf-value:VRF值。
mask:子网掩码长度。
debug ipv4-drv show statistics显示IPv4统计信息。
独立运行模式:
debug ipv4-drv show statistics slot slot-number
IRF模式:
debug ipv4-drv show statistics chassis chassis-number slot slot-number
Probe视图
debug ipv6-drv show nd显示ND信息。
独立运行模式:
debug ipv6-drv show nd vrf-value ipv6-address slot slot-number
IRF模式:
debug ipv6-drv show nd vrf-value ipv6-address chassis chassis-number slot slot-number
Probe视图
vrf-value:VRF值。
ipv6-address:IPv6地址。
debug ipv6-drv show route显示IPv6路由信息。
独立运行模式:
debug ipv6-drv show route vrf-value ipv6-address mask slot slot-number
IRF模式:
debug ipv6-drv show route vrf-value ipv6-address mask chassis chassis-number slot slot-number
Probe视图
vrf-value:VRF值。
mask:前缀长度。
debug ipv6-drv show statistics显示IPv6统计信息,包含路由个数、ND个数、等价路由个数、平台ND下发次数和驱动成功次数、平台路由下发次数和驱动成功次数。
独立运行模式:
debug ipv6-drv show statistics slot slot-number
IRF模式:
debug ipv6-drv show statistics chassis chassis-number slot slot-number
Probe视图
debug l2命令用来显示L2驱动模块指定模块的记录,可以指定VLAN、MAC、STP、QinQ和Portsec模块。
独立运行模式:
debug l2 slot slot-number chip chip-number string
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number string
Probe视图
chassis chassis-number slot slot-number:表示单板所在成员设备编号和槽位号。(IRF模式)
string:使用debug l2 slot slot-number chip chip-number ?或debug l2 chassis chassis-number slot slot-number chip chip-number ?查看string可取的值。
debug l2 evb/show/sch=命令查看指定S通道对应的配置信息。
独立运行模式:
debug l2 slot slot-number chip chip-number evb/show/sch=sch-number
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number evb/show/sch=sch-number
Probe视图
sch-number:S通道索引号。
debug l2 evb/show/vlan=命令用来查看CVLAN对应的VP和广播、组播组信息。
独立运行模式:
debug l2 slot slot-number chip chip-number evb/show/vlan=vlan-id
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number evb/show/vlan=vlan-id
Probe视图
vlan-id:表示VLAN编号。
debug l2 mac/avl命令用来显示MAC软件树的信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/avl
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/avl
Probe视图
debug l2 mac/config/static/命令用来显示从start_index开始的10条静态MAC地址表项。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/config/static/start-index
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/config/static/start-index
Probe视图
start-index:起始值索引号。
debug l2 mac/config/static/clear命令清除静态MAC下发记录。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/config/static/clear
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/config/static/clear
Probe视图
debug l2 mac/config/static/count命令用来显示静态MAC下发计数。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/config/static/count
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/config/static/count
Probe视图
debug l2 mac/config/static/err命令用来显示静态MAC下发失败记录。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/config/static/err
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/config/static/err
Probe视图
debug l2 mac/config/static/vid=/mac=命令用来查找指定静态MAC下发记录。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/config/static/vid=vlan-id/mac=mac-address
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/config/static/vid=vlan-id/mac=mac-address
Probe视图
vlan-id:表示VLAN编号。
mac-address:mac-address的格式为hh:hh:hh:hh:hh:hh。
debug l2 mac/del/show命令用来显示MAC地址删除记录信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/del/show
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/del/show
Probe视图
debug l2 mac/extendinfo命令用来显示整机和本板的扩展模式。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/extendinfo
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/extendinfo
Probe视图
debug l2 mac/find/vid=/mac=命令用来在硬件中查找MAC地址是否存在。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/find/vid=vlan-id/mac=mac-address
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/find/vid=vlan-id /mac=mac-address
Probe视图
vlan-id:表示VLAN编号。
debug l2 mac/findvsi/vsi=/mac=命令用来在硬件中查找指定VSI中指定MAC地址是否存在。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/findvsi/vsi=vsi-number/mac=mac-address
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/findvsi/vsi=vsi-number/mac=mac-address
Probe视图
vsi-number:表示VSI编号。
debug l2 mac/find_in_cache/vid=/mac=命令用来显示指定MAC的MAC cache表项的信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/find_in_cache/vid=vlan-id/mac=mac-address
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/find_in_cache/vid=vlan-id/mac=mac-address
Probe视图
vlan-id:表示VLAN编号。
debug l2 mac/find_in_shadow/vid=/mac=命令用来在软件中查找指定VLAN中指定MAC地址是否存在。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/find_in_shadow/vid=vlan-id/mac=mac-address
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/find_in_shadow/vid=vlan-id/mac=mac-address
Probe视图
vlan-id:表示VLAN编号。
debug l2 mac/hashconflict/show命令用来显示MAC表项软件记录hash冲突信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/hashconflict/show
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/hashconflict/show
Probe视图
debug l2 mac/mac-cache/show命令用来显示MAC cache表项的信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/mac-cache/show
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/mac-cache/show
Probe视图
debug l2 mac/macnotify/unit=/port=命令用来显示MAC地址通知功能下发的端口信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/macnotify/unit=chip-number/port=port-number
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/macnotify/unit=chip-number/port=port-number
Probe视图
port-number:表示端口编号。
debug l2 mac/max/tid=命令用来显示聚合端口MAC个数限制信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/max/tid=tid-number
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/max/tid=tid-number
Probe视图
tid-number:表示聚合接口编号。
debug l2 mac/max/unit=/port=命令用来显示非聚合端口MAC个数限制信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/max/unit=chip-number/port=port-number
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/max/unit=chip-number/port=port-number
Probe视图
port-number:表示端口编号。
debug l2 mac/move_rec/show命令用来显示MAC地址端口迁移以及外扩模式下搬移fifo的信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/move_rec/show
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/move_rec/show
Probe视图
debug l2 mac/savl命令用来显示静态MAC软件树上的信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/savl
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/savl
Probe视图
debug l2 mac/vavl命令用来显示软件树上的VSI MAC地址信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/vavl
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/vavl
Probe视图
debug l2 mac/vlan/learnlimit/vlan=命令用来显示基于VLAN的MAC地址学习个数限制的信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/vlan/learnlimit/vlan=vlan-id
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/vlan/learnlimit/vlan=vlan-id
Probe视图
vlan-id:表示VLAN编号。
debug l2 mac/vlan/unknowsrcact/vlan=命令用来显示基于VLAN的未知源动作信息。
独立运行模式:
debug l2 slot slot-number chip chip-number mac/vlan/unknowsrcact/vlan=vlan-id
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number mac/vlan/unknowsrcact/vlan=vlan-id
Probe视图
vlan-id:表示VLAN编号。
debug l2 qinq/chipinfo/unit=命令用来查看芯片VT表已用表项个数和总表项个数。
独立运行模式:
debug l2 slot slot-number chip chip-number qinq/chipinfo/unit=chip-number
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number qinq/chipinfo/unit=chip-number
Probe视图
debug l2 qinq/eninfo命令用来查看已使能QinQ的端口列表,其中slot-number必须是主控板的槽位号。
独立运行模式:
debug l2 slot slot-number chip chip-number qinq/eninfo
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number qinq/eninfo
Probe视图
debug l2 qinq/portinfo/命令用来查看端口上配置的QinQ使能状态、TPID以及内外层VLAN的映射关系。
独立运行模式:
debug l2 slot slot-number chip chip-number qinq/portinfo/port-number
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number qinq/portinfo/port-number
Probe视图
port-number:表示端口编号。
debug l2 qinq/xlate命令用来查看vlan_xlate表项下发信息。
独立运行模式:
debug l2 slot slot-number chip chip-number qinq/xlate
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number qinq/xlate
Probe视图
debug l2 stg/bind/命令用来查看stg和VLAN的绑定关系。
独立运行模式:
debug l2 slot slot-number chip chip-number stg/bind/stg-id
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number stg/bind/stg-id
Probe视图
stg-id:stg表项编码。
debug l2 stg/info/命令用来查看所有端口在相关stg表项上的状态。
独立运行模式:
debug l2 slot slot-number chip chip-number stg/info/stg-id
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number stg/info/stg-id
Probe视图
stg-id:stg表项编号。
debug l2 stp/detail用来查看端口的STP/Trunk/DLDP/LDP状态信息。
独立运行模式:
debug l2 slot slot-number chip chip-number stp/detail
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number stp/detail
Probe视图
debug l2 stp/info命令用来查看端口的STP协议使能情况。
独立运行模式:
debug l2 slot slot-number chip chip-number stp/info
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number stp/info
Probe视图
debug l2 vlan/info/vid=命令用来显示硬件端口是否属于指定VLAN。
独立运行模式:
debug l2 slot slot-number chip chip-number vlan/info/vid=vlan-id
IRF模式:
debug l2 chassis chassis-number slot slot-number chip chip-number vlan/info/vid=vlan-id
Probe视图
vlan-id:表示VLAN编号。
debug l2mc show entry命令用来显示组播l2mc表相关信息,目前有trill、CFD等功能模块使用到组播l2mc表项
独立运行模式:
debug l2mc show entry { entry-number | all } [ detail ] [ slot slot-number ] [ continue ]
IRF模式:
debug l2mc show entry { entry-number | all } [ detail ] [ chassis chassis-number slot slot-number ] [ continue ]
Probe视图
entry-number:指定l2mc表索引编号。
all:表示显示所有的l2mc表项信息。
detail:表示要打印出l2mc表的详细信息。
debug l2mc show mcarp-rbtree命令用来显示l2mc表中保存的组播arp信息
独立运行模式:
debug l2mc show mcarp-rbtree [ slot slot-number ] [ continue ]
IRF模式:
debug l2mc show mcarp-rbtree [ chassis chassis-number slot slot-number ] [ continue ]
Probe视图
debug l2mc show mcmac-rbtree命令用来显示l2mc表中保存的组播mac信息
独立运行模式:
debug l2mc show mcmac-rbtree [ slot slot-number ] [ continue ]
IRF模式:
debug l2mc show mcmac-rbtree [ chassis chassis-number slot slot-number ] [ continue ]
Probe视图
debug l2mc show node-list命令用来显示保存组播ip和mac对应关系信息
独立运行模式:
debug l2mc show node-list [ slot slot-number ] [ continue ]
IRF模式:
debug l2mc show node-list [ chassis chassis-number slot slot-number ] [ continue ]
Probe视图
continue: 一次打印没有显示完,接着上次的结果显示。
debug l3intf-drv logshow根据模块显示L3 log信息。
独立运行模式:
debug l3intf-drv logshow module-number slot slot-number
IRF模式:
debug l3intf-drv logshow module-number chassis chassis-number slot slot-number
Probe视图
module-number:模块编号。
debug l3intf-drv logshow all显示所有L3 log信息。
独立运行模式:
debug l3intf-drv logshow all slot slot-number
IRF模式:
debug l3intf-drv logshow all chassis chassis-number slot slot-number
Probe视图
debug l3intf-drv logshow statistics显示L3 log统计信息。
独立运行模式:
debug l3intf-drv logshow statistics slot slot-number
IRF模式:
debug l3intf-drv logshow statistics chassis chassis-number slot slot-number
Probe视图
debug l3intf-drv mystationshow infobystationid根据mystation索引显示对应索引的mystation信息。
独立运行模式:
debug l3intf-drv mystationshow infobystationid station-id slot slot-number
IRF模式:
debug l3intf-drv mystationshow infobystationid station-id chassis chassis-number slot slot-number
Probe视图
station-id:stationid的索引。
debug l3intf-drv mystationshow infobyvlan根据vlan id显示对应vlan的mystation信息。
独立运行模式:
debug l3intf-drv mystationshow infobyvlan vlan-id slot slot-number
IRF模式:
debug l3intf-drv mystationshow infobyvlan vlan-id chassis chassis-number slot slot-number
Probe视图
vlan-id:VLAN ID。
debug l3intf-drv show infobyindex根据三层接口索引显示三层接口信息。
独立运行模式:
debug l3intf-drv show infobyindex index-number slot slot-number
IRF模式:
debug l3intf-drv show infobyindex index-number chassis chassis-number slot slot-number
Probe视图
index-number:接口索引。
debug l3intf-drv show infobyvlan根据vlanid显示对应vlan三层接口硬件信息。
独立运行模式:
debug l3intf-drv show infobyvlan vlan-id slot slot-number
IRF模式:
debug l3intf-drv show infobyvlan vlan-id chassis chassis-number slot slot-number
Probe视图
vlan-id:表示指定VLAN的编号,取值范围为1~4094。
debug l3intf-drv show statistics显示已创建三层接口统计信息。
独立运行模式:
debug l3intf-drv show statistics slot slot-number
IRF模式:
debug l3intf-drv show statistics chassis chassis-number slot slot-number
Probe视图
debug l3intf-drv show variable显示三层接口变量信息,包含Vrrp虚MAC信息全局变量地址、三层接口信息全局变量地址、VLAN与三层接口对应关系信息全局变量地址、子网广播标志、IPv6使能标志、ARP透传信息。
独立运行模式:
debug l3intf-drv show variable slot slot-number
IRF模式:
debug l3intf-drv show variable chassis chassis-number slot slot-number
Probe视图
debug l3intf-drv show virtualmac显示VRRP虚MAC信息。
独立运行模式:
debug l3intf-drv show virtualmac index-number slot slot-number
IRF模式:
debug l3intf-drv show virtualmac index-number chassis chassis-number slot slot-number
Probe视图
index-number:索引值。
debug mac命令用来打开MAC模块指定子模块Debug指令开关。
undo debug mac命令用来关闭MAC模块指定子模块Debug指令开关。
独立运行模式:
debug mac string slot slot-number
undo debug mac string slot slot-number
IRF模式:
debug mac string chassis chassis-number slot slot-number
undo debug mac string chassis chassis-number slot slot-number
Probe视图
string:使用debug mac ?查看string可取的具体子模块值。
debug mdc show datachginfo显示MDC stop数据变化信息。
【命令行】
独立运行模式:
debug mdc show datachginfo slot slot-number
IRF模式:
debug mdc show datachginfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的MDC stop数据变化信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板的MDC stop数据变化信息。(IRF模式)
【说明】
显示执行MDC stop的时候,驱动各模块处理数据删除时的信息,此信息用于记录驱动目前正在处理数据的模块。如果10秒钟没有数据变化,则认为数据删除成功,否则,继续等待,直到数据删除完毕为止。
debug mdc show drvevent显示指定单板记录的驱动事件,即各模块注册的事件,包括单板插入和插入完成、单板拔出和拔出完成、MDC 启动、MDC 停止等事件。
【命令行】
独立运行模式:
debug mdc show drvevent slot slot-number
IRF模式:
debug mdc show drvevent chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板记录驱动事件。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板记录驱动事件。(IRF模式)
debug mdc show locationslotinfo显示指定单板被划分到的MDC。
【命令行】
独立运行模式:
debug mdc show locationslotinfo slot slot-number
IRF模式:
debug mdc show locationslotinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板被划分到的MDC。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板被划分到的MDC。(IRF模式)
【说明】
记录单板被划分到的MDC。主控板和网板可以供多个MDC共用,但只能属于缺省MDC,不能被划分到其他非缺省MDC;业务板属于通过location命令将该单板划分到的MDC。
debug mdc show platevent显示指定单板上下发的事件。
【命令行】
独立运行模式:
debug mdc show platevent slot slot-number
IRF模式:
debug mdc show platevent chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上下发的事件。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板上下发的事件。(IRF模式)
【说明】
此命令用于记录指定单板上下发的事件,包括MDC事件和slot事件。
debug mdc show setisolateinfo显示记录端口隔离事件。
【命令行】
独立运行模式:
debug mdc show setisolateinfo slot slot-number
IRF模式:
debug mdc show setisolateinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板记录的端口隔离事件。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板记录的端口隔离事件。(IRF模式)
【说明】
此命令用于记录指定单板通知端口模块设置端口隔离以及是否下发过禁止MDC学习等信息。
debug mdc show slot2mdcinfo显示指定单板所属MDC。
【命令行】
独立运行模式:
debug mdc show slot2mdcinfo slot slot-number
IRF模式:
debug mdc show slot2mdcinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板所属MDC。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板所属MDC。(IRF模式)
【说明】
显示指定单板所属MDC。主控板以及网板,所属MDC为缺省MDC;业务板显示通过location命令将该业务板的使用权限分配给的非缺省MDC的信息。
debug mdc show tgid2mdcinfo显示指定单板TGID与MDC对应关系。
【命令行】
独立运行模式:
debug mdc show tgid2mdcinfo slot slot-number
IRF模式:
debug mdc show tgid2mdcinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板TGID与MDC对应关系。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上的指定单板TGID与MDC对应关系。(IRF模式)
【说明】
显示指定单板上的聚合组与所属MDC的对应关系。
debug mpls-drv display dscp-exp命令用来显示DSCP和PRI、EXP的优先级映射关系,以及关联底层表项的索引信息。
独立运行模式:
debug mpls-drv display dscp-exp slot slot-number
IRF模式:
debug mpls-drv display dscp-exp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上DSCP和PRI、EXP的优先级映射关系,以及关联底层表项的索引信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上DSCP和PRI、EXP的优先级映射关系,以及关联底层表项的索引信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display egress命令用来显示指定Egress ID底层对应的硬件查询信息。
独立运行模式:
debug mpls-drv display egress egress-index slot slot-number
IRF模式:
debug mpls-drv display egress egress-index chassis chassis-number slot slot-number
Probe视图
egress-index:硬件转发资源索引,取值范围为100000~199999。
slot slot-number:显示指定单板上指定Egress ID底层对应的硬件查询信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上指定Egress ID底层对应的硬件查询信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display ftn命令用来显示指定ftn路由底层对应的硬件查询信息。
独立运行模式:
debug mpls-drv display ftn vrf-id ipv4-address mask-length slot slot-number
IRF模式:
debug mpls-drv display ftn vrf-id ipv4-address mask-length chassis chassis-number slot slot-number
Probe视图
vrf-id:VPN实例索引,取值范围为0~2048。
ipv4-address:IPv4地址。
mask-length:IPv4地址掩码长度,取值范围为0~32。
slot slot-number:显示指定单板上指定ftn路由底层对应的硬件查询信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上指定ftn路由底层对应的硬件查询信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display global命令用来显示MPLS软件信息和规格表项等。
独立运行模式:
debug mpls-drv display global slot slot-number
IRF模式:
debug mpls-drv display global chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的MPLS软件信息和规格表项等。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上的MPLS软件信息和规格表项等。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display ilm命令用来显示ilm硬件节点信息。
独立运行模式:
debug mpls-drv display ilm label-number slot slot-number
IRF模式:
debug mpls-drv display ilm label-number chassis chassis-number slot slot-number
Probe视图
label-number:标签值,取值范围为0~1048575。
slot slot-number:显示指定单板上的ilm硬件节点信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上的ilm硬件节点信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display intf-status命令用来显示与指定VLAN对应的底层的软件绑定信息。
独立运行模式:
debug mpls-drv display intf-status vlan vlan-id slot slot-number
IRF模式:
debug mpls-drv display intf-status vlan vlan-id chassis chassis-number slot slot-number
Probe视图
vlan-id:VLAN编号,取值范围为0~4095。
slot slot-number:显示指定单板上与指定VLAN对应的底层的软件绑定信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上与指定VLAN对应的底层的软件绑定信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display l2vpn vpls命令用来显示底层记录的指定VSI的VPLS软件记录信息。
独立运行模式:
debug mpls-drv display l2vpn vpls vsi-id slot slot-number
IRF模式:
debug mpls-drv display l2vpn vpls vsi-id chassis chassis-number slot slot-number
Probe视图
vsi-id:VSI索引,取值范围为0~4096。
slot slot-number:显示指定单板上指定VSI的VPLS软件记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上指定VSI的VPLS软件记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display l2vpn vpws命令用来显示底层记录的指定VSI的VPWS软件记录信息。
独立运行模式:
debug mpls-drv display l2vpn vpws vsi-id slot slot-number
IRF模式:
debug mpls-drv display l2vpn vpws vsi-id chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上指定VSI的VPWS软件记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上指定VSI的VPWS软件记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display l3vpn命令用来显示底层记录的MPLS L3VPN的软件记录信息。
独立运行模式:
debug mpls-drv display l3vpn { vlan vlan-id | { index | from } index-number | bykey key-value key-type | all } slot slot-number
IRF模式:
debug mpls-drv display l3vpn { vlan vlan-id | { index | from } index-number | bykey key-value key-type | all } chassis chassis-number slot slot-number
Probe视图
vlan vlan-id:显示与指定VLAN绑定的MPLS L3VPN的软件记录信息。vlan-id为VLAN编号,取值范围为0~4095。
index:显示指定VPN实例的MPLS L3VPN的软件记录信息。
index-number:VPN实例索引,取值范围为0~2048。
bykey:查找并显示与指定索引对应的MPLS L3VPN软件记录信息。
key-value:软件索引,取值范围为0~2147483648。
key-type:查找算法使用的关键字类型,取值为1或2。
all:显示所有MPLS L3VPN的软件记录信息。
slot slot-number:显示指定单板上MPLS L3VPN的软件记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上MPLS L3VPN的软件记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(分布式设备-IRF模式)
debug mpls-drv display rbtree ac命令用来显示底层AC树的详细软件记录信息。
独立运行模式:
debug mpls-drv display rbtree ac { { precisely-match | from } vlan-id | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree ac { { precisely-match | from } vlan-id | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示底层AC树指定节点的详细软件记录信息。
all:显示底层AC树所有节点的详细软件记录信息。由于此类信息较多,建议不要使用此参数。
slot slot-number:显示指定单板上底层AC树的详细软件记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上底层AC树的详细软件记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree egr命令用来显示驱动记录的Egress软件树节点信息。
独立运行模式:
debug mpls-drv display rbtree egr { { precisely-match | from } tunnel-id spectype label-number | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree egr { { precisely-match | from } tunnel-id spectype label-number | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示驱动记录的指定节点的Egress软件树节点信息。
tunnel-id:隧道索引,取值范围为0~4294967295。
spectype:隧道类型,取值范围为0~2147483648。
all:显示驱动记录的所有Egress软件树节点信息。由于此类信息较多,建议不要使用此参数。
slot slot-number:显示指定单板上驱动记录的Egress软件树节点信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上驱动记录的Egress软件树节点信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree port命令用来显示驱动记录的port软件树节点信息。
独立运行模式:
debug mpls-drv display rbtree port { { precisely-match | from } tunnel-id | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree port { { precisely-match | from } tunnel-id | all } tunnel-id spectype label-number | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示驱动记录的指定节点的port软件树节点信息。
tunnel-id:隧道索引号,取值范围为0~4294967295。
all:显示驱动记录的所有port软件树节点信息。
slot slot-number:显示指定单板上驱动记录的port软件树节点信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上驱动记录的port软件树节点信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree pw命令用来显示底层PW树的详细软件记录信息。
独立运行模式:
debug mpls-drv display rbtree pw { { precisely-match | from } label-number | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree pw { { precisely-match | from } label-number | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示底层PW树指定节点的详细软件记录信息。
all:显示底层PW树所有节点的详细软件记录信息。
slot slot-number:显示指定单板上底层PW树的详细软件记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上底层PW树的详细软件记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree station命令用来显示底层station树的详细软件记录信息。
独立运行模式:
debug mpls-drv display rbtree station { { precisely-match | from } vlan-id | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree station { { precisely-match | from } vlan-id | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示底层station树指定节点的详细软件记录信息。
all:显示底层station树所有节点的详细软件记录信息。
slot slot-number:显示指定单板上底层station树的详细软件记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上底层station树的详细软件记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree statistics命令用来显示驱动记录的软件树节点计数器信息。
独立运行模式:
debug mpls-drv display rbtree statistics slot slot-number
IRF模式:
debug mpls-drv display rbtree statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上驱动记录的软件树节点计数器信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上驱动记录的软件树节点计数器信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree tnl命令用来显示驱动记录的tunnel软件树节点信息。
独立运行模式:
debug mpls-drv display rbtree tnl { { precisely-match | from } tunnel-id spectype | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree tnl { { precisely-match | from } tunnel-id spectype | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示驱动记录的指定节点的tunnel软件树节点信息。
all:显示驱动记录的所有tunnel软件树节点信息。
slot slot-number:显示指定单板上驱动记录的tunnel软件树节点信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上驱动记录的tunnel软件树节点信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree vn命令用来显示驱动记录的vn软件树节点信息。
独立运行模式:
debug mpls-drv display rbtree vn { { precisely-match | from } vn-id spectype | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree vn { { precisely-match | from } vn-id spectype | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示驱动记录的指定节点的vn软件树节点信息。
vn-id:虚拟下一跳索引,取值范围为0~4294967295。
spectype:虚拟下一跳类型,取值范围为0~2147483648。
all:显示驱动记录的所有vn软件树节点信息。
slot slot-number:显示指定成员设备上驱动记录的vn软件树节点信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上驱动记录的vn软件树节点信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display rbtree vnegr命令用来显示驱动记录的vnegr软件树节点信息。
独立运行模式:
debug mpls-drv display rbtree vnegr { precisely-match vn-id spectype | all } slot slot-number
IRF模式:
debug mpls-drv display rbtree vnegr { precisely-match vn-id spectype | all } chassis chassis-number slot slot-number
Probe视图
precisely-match:显示驱动记录的指定节点的vnegr软件树节点信息。
all:显示驱动记录的所有vnegr软件树节点信息。
slot slot-number:显示指定单板上驱动记录的vnegr软件树节点信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上驱动记录的vnegr软件树节点信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug mpls-drv display statistics命令用来显示由MPLS创建的VPN计数器信息,以及发生过错误的VPN计数器信息。
独立运行模式:
debug mpls-drv display statistics slot slot-number
IRF模式:
debug mpls-drv display statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的VPN计数器信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板上的VPN计数器信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug netstream show entry命令用来显示指定单板中指定芯片对应端口的表项的详细信息,该命令可以在报文不用上送CPU的情况下简单查看报文信息。
独立运行模式:
debug netstream show entry port port-number chip chip-number direction slot slot-number
IRF模式:
debug netstream show entry port port-number chip chip-number direction chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板中指定芯片对应端口的表项的详细信息,slot-number表示设备在IRF中的成员编号。(独立运行模式)
direction:表示报文输入和输出方向,取值为0(输入方向)或1(输出方向)。
chip-number:表示芯片编号。
port-number:端口编号。
debug netstream show global命令用来显示指定单板的软件或硬件信息。
独立运行模式:
debug netstream show global { soft | hard } slot slot-number
IRF模式:
debug netstream show global { soft | hard } chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的软件信息,slot-number表示单板所在的槽位号。(独立运行模式)
hard:显示指定单板的硬件信息。
soft:表示显示指定单板的软件信息。
debug netstream show port命令用来显示指定单板中指定芯片对应端口的硬件或者软件信息。
独立运行模式:
debug netstream show port port-number chip chip-number { hard | soft } direction slot slot-number
IRF模式:
debug netstream show port port-number chip chip-number { hard | soft } direction chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板中指定芯片对应端口的硬件或者软件信息,slot-number表示设备在IRF中的成员编号。(独立运行模式)
hard:显示指定单板中指定芯片对应端口的硬件信息。
soft:显示指定单板中指定芯片对应端口的软件信息。
chip-number:表示芯片编号。
port port-number:端口编号。
debug netstream show { ipv4_agg | ipv6_agg }命令用来显示指定单板的聚合下发信息。
独立运行模式:
debug netstream show { ipv4_agg | ipv6_agg } slot slot-number
IRF模式:
debug netstream show { ipv4_agg | ipv6_agg } chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的聚合下发信息,slot-number表示设备在IRF中的成员编号。(独立运行模式)
ipv4_agg:表示显示IPv4报文的聚合下发信息。
ipv6_agg:表示显示IPv6报文的聚合下发信息。
debug port egress命令用来显示egress状态。
独立运行模式:
debug port egress slot slot-number read-length
IRF模式:
debug port egress chassis chassis-number slot slot-number read-length
Probe视图
read-length:表示读取数据长度。
debug port event-list命令用来显示其他模块注册到PORT模块回调函数地址列表。
独立运行模式:
debug port event-list slot slot-number
IRF模式:
debug port event-list chassis chassis-number slot slot-number
Probe视图
debug port flow-info命令用来显示端口当前流量统计。
独立运行模式:
debug port flow-info slot slot-number
IRF模式:
debug port flow-info chassis chassis-number slot slot-number
Probe视图
debug port flow-record命令用来显示流量历史记录统计。
独立运行模式:
debug port flow-record slot slot-number subslot-number port-number subport-number
IRF模式:
debug port flow-record chassis chassis-number slot slot-number subslot-number port-number subport-number
Probe视图
subslot-number:表示端口所在子槽位号。
port-number:表示端口编号。
subport-number:表示子端口号。
debug port global-info命令用来显示全局Ifindex信息。
独立运行模式:
debug port global-info slot slot-number dest-slot
IRF模式:
debug port global-info chassis chassis-number slot slot-number dest-slot
Probe视图
dest-slot:表示目的端口所在的槽位号。
debug port halfduplex命令用来显示双工模式为半双工的端口信息。
独立运行模式:
debug port halfduplex slot slot-number
IRF模式:
debug port halfduplex chassis chassis-number slot slot-number
Probe视图
debug port hg-monitor命令用来显示HG口状态变化记录。
独立运行模式:
debug port hg-monitor slot slot-number
IRF模式:
debug port hg-monitor chassis chassis-number slot slot-number
Probe视图
debug port info命令用来显示端口关键变量值。
独立运行模式:
debug port info slot slot-number subslot-number port-number subport-number
IRF模式:
debug port info chassis chassis-number slot slot-number subslot-number port-number subport-number
Probe视图
port-number:表示端口编号。
debug port isolate命令用来显示端口隔离相关信息。
独立运行模式:
debug port isolate slot slot-number
IRF模式:
debug port isolate chassis chassis-number slot slot-number
Probe视图
debug port license命令用来显示License相关变量信息。
独立运行模式:
debug port license slot slot-number
IRF模式:
debug port license chassis chassis-number slot slot-number
Probe视图
debug port link-diag命令用来显示端口的UP/DOWN状态变化信息记录。
独立运行模式:
debug port link-diag slot slot-number subslot-number port-number subport-number
IRF模式:
debug port link-diag chassis chassis-number slot slot-number subslot-number port-number subport-number
Probe视图
port-number:表示端口编号。
debug port linkstatus命令用来显示驱动上报的端口UP/DOWN状态变化信息记录。
独立运行模式:
debug port linkstatus slot slot-number subslot-number port-number subport-number
IRF模式:
debug port linkstatus chassis chassis-number slot slot-number subslot-number port-number subport-number
Probe视图
port-number:表示端口编号。
debug port mapping命令用来显示端口的物理端口号,芯片编号,接口索引等信息的对应关系。
独立运行模式:
debug port mapping slot slot-number
IRF模式:
debug port mapping chassis chassis-number slot slot-number
Probe视图
debug port oam命令用来显示端口的OAM状态信息。
独立运行模式:
debug port oam slot slot-number
IRF模式:
debug port oam chassis chassis-number slot slot-number
Probe视图
debug port optical-eeprom命令用来显示相应端口光模块在电可擦可编程只读存储器EEPROM(Electrically Erasable Programmable Read-Only Memory)中的内容。
独立运行模式:
debug port optical-eeprom slot slot-number subslot-number port-number device-address start-address read-length
IRF模式:
debug port optical-eeprom chassis chassis-number slot slot-number subslot-number port-number device-address start-address read-length
Probe视图
port-number:表示端口编号。
device-address:表示设备地址。
start-address:表示从该偏移地址开始显示。
debug port optical-module命令用来显示光模块相关信息(包括光模块是否在位、rx_los、tx_fault、tx_disable等信息)。
独立运行模式:
debug port optical-module slot slot-number
IRF模式:
debug port optical-module chassis chassis-number slot slot-number
Probe视图
debug port optical-recover命令用来修复光模块相关参数。
独立运行模式
debug port optical-recover slot slot-number subslot-number port-number start_address length value
IRF模式
debug port optical-recover chassis chassis-number slot slot-number subslot-number port-number start_address length value
Probe视图
port-number:表示端口编号。
start_address:修复光模块的起始地址,取值范围为1~127(十进制)。
length:从起始地址起要修复的长度,取值范围为1~32(十进制)。
value:修复取值,取值范围为1~64(十六进制)。
debug port phy_dump命令用来显示PHY寄存器值。
独立运行模式:
debug port phy_dump slot slot-number chip chip-number port-number { ext_phy | int_phy }
IRF模式:
debug port phy_dump chassis chassis-number slot slot-number chip chip-number port-number { ext_phy | int_phy }
Probe视图
port-number:表示端口编号。
ext_phy:指定寄存器为外部PHY寄存器。
int_phy:指定寄存器为内部PHY寄存器。
debug port sflow命令用来显示sFlow关键变量值。
独立运行模式:
debug port sflow slot slot-number subslot-number port-number subport-number
IRF模式:
debug port sflow chassis chassis-number slot slot-number subslot-number port-number subport-number
Probe视图
port-number:表示端口编号。
debug port trunk-global命令用来显示聚合信息。
独立运行模式:
debug port trunk-global slot slot-number agg-id
IRF模式:
debug port trunk-global chassis chassis-number slot slot-number agg-id
Probe视图
agg-id:表示聚合接口的编号,可通过bcm slot slot-number chip chip-number trunk/show(独立运行模式)或者bcm chassis chassis-number slot slot-number chip chip-number trunk/show(IRF模式)命令查看已创建的聚合接口。
debug port trunk-state命令用来显示各端口与聚合相关的状态。
独立运行模式:
debug port trunk-state slot slot-number
IRF模式:
debug port trunk-state chassis chassis-number slot slot-number
Probe视图
debug port trunkegress命令用来显示trunkegress状态。
独立运行模式:
debug port trunkegress slot slot-number read-length
IRF模式:
debug port trunkegress chassis chassis-number slot slot-number read-length
Probe视图
debug port wc40_reg_read该命令用来显示WC40寄存器值。
独立运行模式:
debug port wc40_reg_read slot slot-number chip chip-number port-number wc40_register_aer wc40_register_block wc40_register_offset-address
IRF模式:
debug port wc40_reg_read chassis chassis-number slot slot-number chip chip-number port-number wc40_register_aer wc40_register_block wc40_register_offset-address
Probe视图
port-number:表示端口编号。
wc40_register_aer:表示WC40寄存器AER,取值范围为0~FFFFFFFF(十六进制)。
wc40_register_block:表示WC40寄存器BLOCK,取值范围为0~FFFFFFFF(十六进制)。
wc40_register_offset-address:表示从该偏移地址开始显示,取值范围为0~FFFFFFFF(十六进制)。
debug port wc40_reg_write该命令用来修改WC40寄存器值。
独立运行模式
debug port wc40_reg_write slot slot-number chip chip-number port-number wc40_register_aer wc40_register_block wc40_register_offset-address wc40_register_value
IRF模式
debug port wc40_reg_write chassis chassis-number slot slot-number chip chip-number port-number wc40_register_aer wc40_register_block wc40_register_offset-address wc40_register_value
Probe视图
port-number:表示端口编号。
wc40_register_offset-address:表示从该偏移地址开始修改,取值范围为0~FFFFFFFF(十六进制)。
wc40_register_value:表示修改该寄存器的值,取值范围为0-FFFFFFFF(十六进制)。
debug ptp showvariables命令显示PTP板间和板内芯片间时间同步相关参数的设置信息。
独立运行模式:
debug ptp showvariables [ slot slot-number ]
IRF模式:
debug ptp showvariables [ chassis chassis-number slot slot-number ]
Probe视图
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。(IRF模式)
debug qacl packet action命令用来设置规则动作。
独立运行模式:
debug qacl packet action action-type slot slot-number chip chip-number
IRF模式:
debug qacl packet action action-type chassis chassis-number slot slot-number chip chip-number
Probe视图
action_type:动作类型,可选参数如表1-1所示。
chip-number:表示芯片编号。
表1-1 action_type可选参数
mirror dstmod module-id dstport port-number |
镜像至指定模块的指定端口,module-id取值范围为0~255,port-number取值范围为0~127 |
redirect dstmod module-id dstport port-number |
重定向至指定模块的指定端口,module-id取值范围为0~255,port-number取值范围为0~127 |
statistics |
为将报文信息计入统计数据 |
debug qacl packet control命令用来将规则应用到内部端口上。
独立运行模式:
debug qacl packet control slot slot-number chip chip-number port-number direction
IRF模式:
debug qacl packet control chassis chassis-number slot slot-number chip chip-number port-number direction
Probe视图
chip-number:表示芯片编号。
port-number:端口编号,取值范围为0~63。
direction:应用方向,in或out。
debug qacl packet pattern命令用来设置匹配内容,与packet action、packet control命令一起配合,在指定的内部端口上下发匹配规则与动作,用于问题调试。
独立运行模式:
debug qacl packet pattern pattern-type slot slot-number chip chip-number
IRF模式:
debug qacl packet pattern pattern-type chassis chassis-number slot slot-number chip chip-number
Probe视图
pattern-type:匹配特征,可选参数如表1-2所示。
all |
匹配所有报文 |
dip ip-address [ ip-address-mask ] |
匹配报文的目的IP地址及子网掩码 |
dmac mac-address [ mac-address-mask ] |
匹配报文的目的MAC地址 |
dport port-number |
匹配报文的目的服务端口号,port-number取值范围为0~65536 |
dstmod module-id |
匹配发送该报文的模块编号,module-id取值范围为0~255 |
匹配发送该报文的目的端口,port-number取值范围为0~127 |
etype protocol-type protocol-type-mask |
匹配报文的链路层协议类型 |
ippro-type protocol-type |
匹配报文的IP协议类型 |
iptype ip-type |
匹配报文的IP版本,目前支持版本4和6 |
outer-vlan vlan-id vlan-mask |
匹配报文的外层VLAN编号 |
sip ip-address [ ip-address-mask ] |
匹配报文的源IP地址及子网掩码 |
smac mac-address [ mac-address-mask ] |
匹配报文的源MAC地址 |
sport port-number |
匹配报文的源服务端口号,port-number取值范围为0~65536 |
src-equal-dstport |
匹配接收端口也是转发端口的报文 |
udf base-l2 data1 mask1 offset1 [ data2 mask2 offset2 ] |
匹配用户自定义规则,用户可以指定数据帧中任意位置的取值作为匹配规则 |
debug qacl show acl-prioinfo命令用来显示ACL优先级信息
独立运行模式:
debug qacl show acl-prioinfo slot slot-number
IRF模式:
debug qacl show acl-prioinfo chassis chassis-number slot slot-number
Probe视图
debug qacl show acl-resc命令用来显示指定芯片的ACL资源。
独立运行模式:
debug qacl show acl-resc slot slot-number chip chip-number [ stage stage-id ]
IRF模式:
debug qacl show acl-resc chassis chassis-number slot slot-number chip chip-number [ stage stage-id ]
Probe视图
chip-number:表示芯片编号。
stage stage-id:Stage编号,取值范围为0~3。取值为不同数值时的含义分别为:
· 0-VFP
· 1-EFP
· 2-IFP
· 3-External TCAM
debug qacl show acltype-info命令用来显示ACL类型。
独立运行模式:
debug qacl show acltype-info slot slot-number
IRF模式:
debug qacl show acltype-info chassis chassis-number slot slot-number
Probe视图
debug qacl show copp-sysidx命令用来显示应用到控制平面的QoS策略(Copp)的配置参数。
独立运行模式:
debug qacl show copp-sysidx slot slot-number
IRF模式:
debug qacl show copp-sysidx chassis chassis-number slot slot-number
Probe视图
debug qacl show globalcar命令用来显示指定芯片上下发的全局CAR信息,每次最多显示50条。
独立运行模式:
debug qacl show globalcar slot slot-number chip chip-number start-number
IRF模式:
debug qacl show globalcar chassis chassis-number slot slot-number chip chip-number start-number
Probe视图
chip-number:表示芯片编号。
start-number:显示的起始位置,取值范围为0~4294967295。
debug qacl show packet pattern命令用来显示指定槽位与芯片上设定的匹配项和已下发的条数。
独立运行模式:
debug qacl show packet pattern slot slot-number chip chip-number [ port-number direction ]
IRF模式:
debug qacl show packet pattern chassis chassis-numbe slot slot-number chip chip-number [ port-number direction ]
Probe视图
chip-number:表示芯片编号。
port-number :端口编号,取值范围为0~63。
debug qacl show proctime命令用来显示重要处理流程的运行时间。
独立运行模式:
debug qacl show proctime slot slot-number
IRF模式:
debug qacl show proctime chassis chassis-number slot slot-number
Probe视图
debug qacl show seminfo命令用来显示ACL模块信号量的操作轨迹。
独立运行模式:
debug qacl show seminfo slot slot-number
IRF模式:
debug qacl show seminfo chassis chassis-number slot slot-number
Probe视图
debug qacl show verbose命令用来按照指定条件显示底层ACL详细信息。
独立运行模式:
debug qacl show slot slot-number chip chip-number verbose start-number [ [ acl-type acltype-number [ port-number | pattern-type ]* ] | denied | matched | [ stage stage-id slice slice-id ] | [ sysidx sysidx-id ] ]
IRF模式:
debug qacl show chassis chassis-number slot slot-number chip chip-number verbose start-number [ [ acl-type acltype-number [ port-number | pattern-type ]* ] | denied | matched | [ stage stage-id slice slice-id ] | [ sysidx sysidx-id ] ]
Probe视图
chip-number:表示芯片编号。
start-number:显示的起始位置,取值范围为0~4294967295,缺省值为0,即从0开始,显示连续的20条内容。
acl-type acltype-number:ACL类型编号,取值范围为0~200。
pattern-type:匹配特征,表示要显示指定条件的底层ACL详细信息,取值范围如表1-3所示,匹配特征可以选择一种,也可以同时选择多种。
denied:包含有丢弃动作的规则。
matched:包含统计动作且有匹配的规则。
· 0-VFP
· 1-EFP
· 2-IFP
· 3-External TCAM
slice slice-id:Slice编号,取值范围为0~15。
sysidx sysidx-id:系统规则编号,取值范围为0~200。
dip ip-address |
匹配报文的目的IP地址 |
dmac mac-address |
匹配报文的目的MAC地址 |
dport port-number |
etype protocol-type |
匹配报文的链路层协议类型 |
fc_did fc_did |
匹配FC报文的目的FC ID |
fc_didmask fc_didmask |
匹配FC报文的目的FC ID掩码 |
fc_sid fc_sid |
匹配FC报文的源FC ID |
fc_sidmask fc_sidmask |
匹配FC报文的源FC ID掩码 |
匹配报文的IP协议类型 |
iptype ip-type |
outer-vlan vlan-id |
匹配报文的外层VLAN编号 |
sip ip-address |
匹配报文的源IP地址 |
smac mac-address |
匹配报文的源MAC地址 |
sport port-number |
debug qacl vlanrange命令用来计算VLAN分段结果。
独立运行模式:
debug qacl vlanrange start-vlan-id end-vlan-id slot slot-number
IRF模式:
debug qacl vlanrange start-vlan-id end-vlan-id chassis chassis-number slot slot-number
Probe视图
start-vlan-id:起始VLAN编号,取值范围为1~4095。
end-vlan-id:结束VLAN编号,取值范围为1~4095。
debug rport-drv show infobyifindex显示指定索引的三层口信息。
独立运行模式:
debug rport-drv show infobyifindex index-number slot slot-number
IRF模式:
debug rport-drv show infobyifindex index-number chassis chassis-number slot slot-number
Probe视图
index-number:索引编号。
debug rport-drv show l3port显示从指定三层口索引开始的所有三层口信息。
独立运行模式:
debug rport-drv show l3port ifindex-start slot slot-number
IRF模式:
debug rport-drv show l3port ifindex-start chassis chassis-number slot slot-number
Probe视图
ifindex-start:三层接口索引。
debug rport-drv show statistics显示三层口切换基本统计信息。
独立运行模式:
debug rport-drv show statistics slot slot-number
IRF模式:
debug rport-drv show statistics chassis chassis-number slot slot-number
Probe视图
debug rxtx coscar show命令用来查看各个cos队列的收包情况。
undo debug rxtx coscar show命令用来关闭各个cos队列的收包情况。
独立运行模式:
debug rxtx coscar show slot slot-number [start-entry-number [ show-entry-number ] ]
undo debug rxtx coscar show slot slot-number
IRF模式:
debug rxtx coscar show chassis chassis-number slot slot-number [start-entry-number [ show-entry-numner ] ]
undo debug rxtx coscar show chassis chassis-number slot slot-number
Probe视图
start-entry-number:表示开始表项索引。
show-entry-numner:表示表项的条数。
debug rxtx event命令用来查看平台调用驱动接口发包的统计信息。
undo debug rxtx event命令用来关闭平台调用驱动接口发包的统计信息。
独立运行模式:
debug rxtx event [ slot slot-number ]
undo debug rxtx event [ slot slot-number ]
IRF模式:
debug rxtx event [ chassis chassis-number slot slot-number ]
undo debug rxtx event [ chassis chassis-number slot slot-number ]
Probe视图
debug rxtx irf show命令用来查看堆叠收发包相关的统计信息。
undo debug rxtx irf show命令用来关闭堆叠收发包相关的统计信息。
独立运行模式:
debug rxtx irf show slot slot-number
undo debug rxtx irf show slot slot-number
IRF模式:
debug rxtx irf show chassis chassis-number slot slot-number
undo debug rxtx irf show chassis chassis-number slot slot-number
Probe视图
debug rxtx pkt命令用来显示报文信息。
undo debug rxtx pkt命令用来关闭显示报文信息。
独立运行模式:
debug rxtx [ -c packet-number [ -s packet-length ] ] pkt [ slot slot-number ]
undo debug rxtx [ -c packet-number [ -s packet-length ] ] pkt [ slot slot-number ]
IRF模式:
debug rxtx [ -c packet-number [ -s packet-length ] ] pkt [ chassis chassis-number slot slot-number ]
undo debug rxtx [ -c packet-number [ -s packet-length ] ] pkt [ chassis chassis-number slot slot-number ]
Probe视图
-c packet-number:显示指定报文个数,packet-number表示要打印的报文个数。
-s packet-length:显示指定长度的报文,packet-length表示要打印报文的长度。(若实际报文长度小于设定值,则打印实际长度的报文)
debug rxtx rxacl acltype命令用来显示指定协议规则的acl类型。
独立运行模式:
debug rxtx rxacl acltype protocol slot slot-number
IRF模式:
debug rxtx rxacl acltype protocol chassis chassis-number slot slot-number
Probe视图
protocol:表示协议类型。
debug rxtx rxacl counter命令用来显示匹配指定协议规则的报文统计。
独立运行模式:
debug rxtx rxacl counter protocol slot slot-number
IRF模式:
debug rxtx rxacl counter protocol chassis chassis-number slot slot-number
Probe视图
protocol:表示协议类型。
debug rxtx rxacl info all命令用来显示已使能的协议规则信息,包括上CPU方式、使能的端口统计、是否受到攻击等。
独立运行模式:
debug rxtx rxacl info all slot slot-number
IRF模式:
debug rxtx rxacl info all chassis chassis-number slot slot-number
Probe视图
debug rxtx rxacl info recordlist命令用来显示dot1ag和rrpp协议规则信息。
独立运行模式:
debug rxtx rxacl info recordlist start-number [dot1ag | rrpp] slot slot-number
IRF模式:
debug rxtx rxacl info recordlist start-number [dot1ag | rrpp] chassis chassis-number slot slot-number
Probe视图
start-number:表示起始序号。
debug rxtx rxacl info single port命令用来基于端口的显示指定协议规则信息。
独立运行模式:
debug rxtx rxacl info singleport protocol slot slot-number
IRF模式:
debug rxtx rxacl info singleport protocol chassis chassis-number slot slot-number
Probe视图
protocol:表示协议类型。
debug rxtx sdk_info命令用来显示单板芯片上CPU报文的相关数据。
独立运行模式:
debug rxtx sdk_info slot slot-number chip chip-number
IRF模式:
debug rxtx sdk_info slot-number chassis chassis-number slot slot-number chip chip-number
Probe视图
slot slot-number chip chip-number:slot-number表示单板所在的槽位号。chip-number表示芯片编号。(独立运行模式)
chassis chassis-number slot slot-number chip chip-number:表示指定成员设备上指定单板的指定芯片编号。(IRF模式)
debug rxtx show命令用来查看芯片端口报文收发记录。
undo debug rxtx show 命令用来清除芯片端口报文收发记录。
独立运行模式:
debug rxtx show slot slot slot-number chip chip-number [ verbose ]
undo debug rxtx show slot slot-number chip chip-number [ verbose ]
IRF模式:
debug rxtx show chassis chassis-number slot slot-number chip chip-number [ verbose ]
undo debug rxtx show chassis chassis-number slot slot-number chip chip-number [ verbose ]
Probe视图
verbose:表示查看详细报文计数信息。
debug rxtx softcar按协议报文类型进行使能、去使能、hash模式、端口收包速率操作。
独立运行模式:
debug rxtx softcar softcar-type-index { disable [ slot slot-number ] | dynamic_buffer disable [ slot slot-number ] | dynamic_buffer enable [ slot slot-number ] | enable [ slot slot-number ] | hashmode hashmode-index [ slot slot-number ] | portdetail [ slot slot-number ] | pps pps-value [ slot slot-number ] }
IRF模式:
debug rxtx softcar softcar-type-index { disable [ chassis chassis-number slot slot-number ] | dynamic_buffer disable [ chassis chassis-number slot slot-number ] | dynamic_buffer enable [ chassis chassis-number slot slot-number ] | enable [ chassis chassis-number slot slot-number ] | hashmode hashmode-index [ chassis chassis-number slot slot-number ] | portdetail [ chassis chassis-number slot slot-number ] | pps pps-value [ chassis chassis-number slot slot-number ] }
Probe视图
softcar-type-index:表示协议报文类型索引。
disable:将指定协议报文类型去使能。
dynamic_buffer disable:将指定协议报文类型的动态缓冲区关闭。
dynamic_buffer enable:使能指定协议报文类型动态缓冲区。
enable:使能指定协议报文类型。
hashmode.hashmode-index:设置协议报文类型的hash模式。(只支持arp报文)
portdetail:显示端口的收包情况。
pps pps-value:设置指定协议报文类型的pps值,pps-value表示pps值。
debug rxtx softcar attack_rcd命令用来查看单板的防攻击记录。
undo debug rxtx softcar attack_rcd命令用来清除单板的防攻击记录。
独立运行模式:
debug rxtx softcar attack_rcd [ slot slot-number ]
undo debug rxtx softcar attack_rcd [ slot slot-number ]
IRF模式:
debug rxtx softcar attack_rcd [ chassis chassis-number slot slot-number ]
undo debug rxtx softcar attack_rcd [ chassis chassis-number slot slot-number ]
Probe视图
debug rxtx softcar show命令用来查看单板的报文限速信息记录。
undo debug rxtx softcar show命令用来清除单板的报文限速信息记录。
独立运行模式:
debug rxtx softcar show { slot slot-number [ start-entry [ entry-count ] ] }
undo debug rxtx softcar show slot slot-number
IRF模式:
debug rxtx softcar show { chassis chassis-number slot slot-number [ start-entry [ entry-count ] ] }
undo debug rxtx softcar show chassis chassis-number slot slot-number
Probe视图
start-entry:表示显示单板上起始表项,默认显示一条信息。
entry-count:表示显示单板上指定起始表项和信息条数。
debug stack clear-record用来清除IRF模块记录在NVRAM或HIGHMEM上的信息。
独立运行模式:
debug stack clear-record slot slot-number
IRF模式:
debug stack clear-record chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板上的IRF记录信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备指定单板上的IRF记录信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show fwdpathinfo用来查看IRF的转发路径信息。
独立运行模式:
debug stack show fwdpathinfo slot slot-number
IRF模式:
debug stack show fwdpathinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的IRF转发路径信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IRF转发路径信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show globalvariable用来查看IRF相关全局变量地址信息。
独立运行模式:
debug stack show globalvariable slot slot-number
IRF模式:
debug stack show globalvariable chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的IRF全局变量地址信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的IRF全局变量地址信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show ipc-info用来查看跨框广播和单播IPC消息的个数,每180秒清空一次,重新计数。
独立运行模式:
debug stack show ipc-info slot slot-number
IRF模式:
debug stack show ipc-info chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上接收的跨框广播和单播IPC消息个数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备的指定单板上接收的跨框广播和单播IPC消息个数,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show loglevel用来查看IRF日志等级信息。
独立运行模式:
debug stack show loglevel slot slot-number
IRF模式:
debug stack show loglevel chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的IRF日志等级信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的IRF日志等级信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show memberinfo用来查看IRF成员信息。
独立运行模式:
debug stack show memberinfo slot slot-number
IRF模式:
debug stack show memberinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的IRF成员信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IRF成员信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show portinfo用来查看IRF物理端口信息。
独立运行模式:
debug stack show portinfo slot slot-number
IRF模式:
debug stack show portinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的IRF物理端口信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IRF物理端口信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show record用来查看IRF模块的记录信息,每次显示30条记录。这些信息采用循环方式记录在NVRAM或HIGHMEM中,设备重启不会丢失。
独立运行模式:
debug stack show record start-number slot slot-number
IRF模式:
debug stack show record chassis chassis-number slot slot-number
Probe视图
start-number:信息的起始记录,取值范围0~1000。
slot slot-number:显示指定单板的IRF记录信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IRF记录信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show taskinfo用来查看IRF报文收发异常时的任务堆栈信息。
独立运行模式:
debug stack show taskinfo slot slot-number
IRF模式:
debug stack show taskinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的IRF报文异常堆栈信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的IRF报文异常堆栈信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug stack show topoinfo用来查看IRF拓扑信息。
独立运行模式:
debug stack show topoinfo slot slot-number
IRF模式:
debug stack show topinfo chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的IRF拓扑信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IRF拓扑信息,chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
debug sysm bridgemac read命令用于读取mac(缺省情况下,读取机框的mac)。
独立运行模式下:
IRF模式下:
debug sysm bridgemac read chassis chassis-number
Probe视图
chassis chassis-number:成员设备的编号。(IRF模式)
debug sysm cpld-reg read读取cpld寄存器。
独立运行模式:
debug sysm cpld-reg read offset-address read-length slot slot-number
IRF模式:
debug sysm cpld-reg read offset-address read-length chassis chassis-number slot slot-number
Probe视图
offset-address:表示CPLD寄存器的偏移地址,取值范围为0x0~0xFFFF。
read-length:表示读取数据长度,取值范围为1~40。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number: chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug sysm cpldupdate用于升级单板的逻辑。
独立运行模式:
debug sysm cpldupdate filename slot slot-number
IRF模式:
debug sysm cpldupdate filename chassis chassis-number slot slot-number
Probe视图
filename:文件名称,具体指升级单板CPLD所用的文件。
slot slot-number:表示升级指定单板的逻辑。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示升级指定成员设备上单板的逻辑。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug sysm display temperature-all命令用来查看单板的温度信息。
独立运行模式:
debug sysm display temperature-all [ slot slot-number ]
IRF模式:
debug sysm display temperature-all chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的温度信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的温度信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debug sysm eeprom命令用于读eeprom内容。
独立运行模式:
debug sysm eeprom offset-address length slot slot-number [ selection channel-number device-address]
IRF模式:
debug sysm eeprom offset-address length chassis chassis-number slot slot-number [ selection channel-number device-address]
Probe视图
offset-address:表示eeprom偏移地址,取值范围为0~1FFFF(十六进制)。
length:表示读取eeprom信息的长度,取值范围为1~32。
slot slot-number:slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
channel-number:表示i2c通道号,取值范围为0~16。
device-address:表示i2c器件地址,取值范围为0~FF(十六进制)。
debug sysm fan 用于查看风扇的运行速度,设置风扇运行的速度模式,读取风扇的运行状态。
独立运行模式:
debug sysm fan frame-id { get-speed [ fan-sub-id ] | fan-section-id { value | auto | high | low | middle | state }
IRF模式:
debug sysm fan chassis chassis-number frame-id { get-speed [ fan-sub-id ] | fan-section-id { value | auto | high | low | middle | state }
Probe视图
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。(IRF模式)
frame-id:表示风扇框编号。
fan-sub-id:表示子风扇编号。
fan-section-id:表示风扇区编号。
value:表示风扇速率,取值范围为0x0~0xFF。
auto:设置风扇速度为自动模式。
high:设置风扇速度为高速模式。
low:设置风扇速度为低速模式。
middle:设置风扇速度为中速模式。
state:读取风扇状态。
debug sysm get-fan-para读取风扇调速参数。
独立运行模式:
IRF模式:
debug sysm get-fan-para chassis chassis-number
Probe视图
debug sysm nmi_reset命令用来使指定槽位产生NMI中断并自动重启。
独立运行模式:
debug sysm nmi_reset slot slot-number
IRF模式:
debug sysm nmi_reset chassis chassis-number slot slot-number
Probe视图
仅R1005P04及以上版本支持本命令。
debug sysm power-down给指定槽位的接口板下电。
独立运行模式:
debug sysm power-down slot slot-number
IRF模式:
debug sysm power-down chassis chassis-number slot slot-number
Probe视图
debug sysm power-info读取电源的型号信息。
独立运行模式:
debug sysm power-info power-id
IRF模式
debug sysm power-info chassis chassis-number power-id
Probe视图
power-id:表示电源编号。
debug sysm power-reg查看电源的寄存器。
独立运行模式:
debug sysm power-reg power-id [ power-register ]
IRF模式:
debug sysm power-reg chassis chassis-number power-id [ power-register ]
Probe视图
power-id:表示电源编号。
power-register:表示电源寄存器号。
debug sysm power-up用于给特定槽位接口板上电。
独立运行模式:
debug sysm power-up slot slot-number
IRF模式:
debug sysm power-up chassis chassis-number slot slot-number
Probe视图
debug sysm set-fan-para设置风扇调速参数。
独立运行模式:
debug sysm set-fan-para para1 para2
IRF模式:
debug sysm set-fan-para para1 para2 chassis chassis-number
Probe视图
para1:Tadj值,取值范围为-30~30。
para2:Tclowadj值,取值范围为0~30。
debug sysm variable读取sysm模块常用的全局变量。
独立运行模式:
debug sysm variable { cpld | interrupt | netm | power-fan | temperature } slot slot-number
IRF模式:
debug sysm variable { cpld | interrupt | netm | power-fan | temperature } chassis chassis-number slot slot-number
Probe视图
cpld:CPLD相关的全局变量。
interrupt:中断全局变量。
netm:管理网口全局变量。
power-fan:电源,风扇全局变量。
temperature:温度全局变量。
debug tm cosque { show | clear }显示或清除Cosque统计信息。
【命令行】
独立运行模式:
debug tm cosque { show | clear } slot slot-number chip chip-number port-id cos-id
IRF模式:
debug tm cosque { show | clear } chassis chassis-number slot slot-number chip chip-number port-id cos-id
Probe视图
show:显示Cosque统计信息。
clear:清除Cosque统计信息。
chip chip-number:表示芯片编号。
port-id:表示端口编号。
cos-id:优先级cos值,取值范围为0~7。
debug tm counters用来显示或清除指定ARAD芯片的计数信息。
【命令行】
独立运行模式:
debug tm counters { show | clear } slot slot-number chip chip-number
IRF模式:
debug tm counters { show | clear } chassis chassis-number slot slot-number chip chip-number
Probe视图
show:显示ARAD芯片的计数信息。
clear:清除ARAD芯片的计数信息。
debug tm discard show显示单板的丢包信息。
【命令行】
独立运行模式:
debug tm discard show slot slot-number [ chip chip-number ]
IRF模式:
debug tm discard show chassis chassis-number slot-number [ chip chip-number ]
Probe视图
debug tm fap show用来显示保存的ARAD端口信息。
【命令行】
独立运行模式:
debug tm fap show slot slot-number slot dst-slot-number
debug tm fap show slot slot-number fapidx fap-id
IRF模式:
debug tm fap show chassis chassis-number slot slot-number slot dst-slot-number
debug tm fap show chassis chassis-number slot slot-number fapidx fap-id
Probe视图
dst-slot-number:表示目标单板所在的槽位号。
fapidx fap-id:fap号,取值范围为0~384。
debug tm link show用来显示业务板和网板间的连接信息。
【命令行】
独立运行模式:
debug tm link show slot slot-number [ chip chip-number ]
IRF模式:
debug tm link show chassis chassis-number slot slot-number [ chip chip-number ]
Probe视图
debug tm mapping show用来显示单板上的端口信息。
【命令行】
独立运行模式:
debug tm mapping show slot slot-number
IRF模式:
debug tm mapping show chassis chassis-number slot slot-number
Probe视图
debug tm portspeed set用来设置端口加速比。
【命令行】
独立运行模式:
debug tm portspeed set speed-percent slot slot-number
IRF模式:
debug tm portspeed set speed-percent chassis chassis-number slot slot-number
Probe视图
speed-percent:表示端口的加速比。
debug tm sch show用来显示端口的调度模式。
【命令行】
独立运行模式:
debug tm sch show slot slot-number port-id
IRF模式:
debug tm sch show chassis chassis-number slot slot-number port-id
Probe视图
port-id:表示端口编号。
debug tm variable show用来显示机框全局变量。
【命令行】
独立运行模式:
debug tm variable show slot slot-number
IRF模式:
debug tm variable show chassis chassis-number slot slot-number
Probe视图
debug tm voq用来显示或清除VOQ队列的统计信息。
【命令行】
独立运行模式:
debug tm voq { show | clear } voq-id slot slot-number [ chip chip-number ]
IRF模式:
debug tm voq { show | clear } voq-id chassis chassis-number slot slot-number [ chip chip-number ]
Probe视图
show:显示VOQ队列统计信息。
clear:清除VOQ队列统计信息。
voq-id:表示VOQ队列编号。
debug tm vsq用来显示或清除VSQ队列的统计信息。
【命令行】
独立运行模式:
debug tm vsq { show | clear } slot slot-number chip chip-number vsq-id
IRF模式:
debug tm vsq { show | clear } chassis chassis-number slot slot-number chip chip-number vsq-id
Probe视图
show:显示VSQ队列的统计信息。
clear:清除VSQ队列的统计信息。
vsq-id:表示VSQ队列编号。
debug trill show avf命令用来显示指定端口的AVF信息,AVF信息包括AVF Vlan和非AVF Vlan
独立运行模式:
debug trill show avf slot slot-number subslot-number portnum port-number [ subport-number ]
debug trill show avf slot slot-number lag lag-number
IRF模式:
debug trill show avf chassis chassis-number slot slot-number subslot-number portnum port-number [ subport-number ]
debug trill show avf chassis chassis-number slot slot-number lag lag-number
Probe视图
chassis chassis-number slot slot-number:表示单板所在成员设备编号和槽位号。(IRF模式)
subslot-number:表示端口所在的子槽位号。
portnum port-number:表示端口编号。
lag lag-number:表示聚合口编号。
debug trill show default-vlan singleport命令用来显示TRILL指定端口的Default VLAN表项。
独立运行模式:
debug trill show default-vlan singleport { slot slot-number subslot-number portnum port-number [ subport-number ] | lag lag id } slot slot-number
IRF模式:
debug trill show default-vlan singleport { chassis chassis-number slot slot-number subslot-number portnum port-number [ subport-number ] | lag lag id } chassis chassis-number slot slot-number
Probe视图
portnum port-number:表示端口编号,数字< 0-63 >。
debug trill show default-vlan soft命令用来遍历显示TRILL Default VLAN表项。
独立运行模式:
debug trill show default-vlan soft slot slot-number [ offset-number ]
IRF模式:
debug trill show default-vlan soft chassis chassis-number slot slot-number [ offset-number ]
Probe视图
slot slot-number:显示指定单板的TRILL Default VLAN表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备指定单板的TRILL Default VLAN表项信息。(IRF模式)
offset-number:表示显示信息的偏移值。表项数目较多的情况下,无法一次全部显示,此时可以通过指定偏移值进行显示。如果offset-number值为0,则显示第一行开始的30条信息;如果offset-number值为5,则显示第六行开始的30条信息。
debug trill show ipmc all命令用来显示TRILL IPMC表项信息。
独立运行模式:
debug trill show ipmc all [ brief ] slot slot-number
debug trill show ipmc all slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show ipmc all [ brief ] chassis chassis-number slot slot-number
debug trill show ipmc all chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
brief:显示TRILL IPMC表项概要信息。
mdc mdc-id:MDC的编号。指定MDC编号时显示指定MDC的信息。不指定MDC编号时,如果slot-number指定的单板是主控板或备用主控板,则显示所有MDC的信息,如果slot-number指定的单板是业务板,则显示该业务板所属MDC的信息。
debug trill show ipmc index命令用来显示指定TRILL IPMC表项信息。
独立运行模式:
debug trill show ipmc index index-number slot slot-number
IRF模式:
debug trill show ipmc index index-number chassis chassis-number slot slot-number
Probe视图
index index-number:IPMC索引号。
debug trill show mc-entry all-entry命令用来显示TRILL组播表项信息。
独立运行模式:
debug trill show mc-entry all-entry slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show mc-entry all-entry chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
debug trill show mc-entry byipmcindex命令用来显示指定ipmc索引对应的软件表项。
独立运行模式:
debug trill show mc-entry byipmcindex ipmc-index slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show mc-entry byipmcindex ipmc-index chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
ipmc-index:表示ipmc索引。
debug trill show mc-entry local-entry命令用来显示TRILL组播Local表项。
独立运行模式:
debug trill show mc-entry local-entry [ vlan vlan-id ] slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show mc-entry local-entry [ vlan vlan-id ] chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
vlan vlan-id:显示指定VLAN的信息。
debug trill show mc-entry macvlanrb-entry命令用来显示指定RB+VLAN+MAC的TRILL组播表项。
独立运行模式:
debug trill show mc-entry macvlanrb-entry [ rb nickname ] [ vlan vlan-id ] [ mac mac-address ] slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show mc-entry macvlanrb-entry [ rb nickname ] [ vlan vlan-id ] [ mac mac-address ] chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
rb nickname:显示指定RB的信息。nickname表示RB的Nickname。
mac mac-address:MAC地址,H-H-H。
debug trill show mc-entry rb-entry命令用来显示指定RB的TRILL组播表项。
独立运行模式:
debug trill show mc-entry rb-entry [ rb nickname ] slot slot-number [ mdc mdc-id ]
IRF模式:
debug trill show mc-entry rb-entry [ rb nickname ] chassis chassis-number slot slot-number [ mdc mdc-id ]
Probe视图
debug trill show mc-entry vlanrbingress-entry命令用来显示指定RB+VLAN(ingress)的TRILL组播表项。
独立运行模式:
debug trill show mc-entry vlanrbingress-entry [ rb nickname ] [ vlan vlan-id ] slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show mc-entry vlanrbingress-entry [ rb nickname ] [ vlan vlan-id ] chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
debug trill show mc-entry vlanrbtransit-entry命令用来显示指定RB+VLAN(transit)的TRILL组播表项。
独立运行模式:
debug trill show mc-entry vlanrbtransit-entry [ rb nickname ] [ vlan vlan-id ] slot slot-number [ mdc mdc-id ]
IRF模式:
debug trill show mc-entry vlanrbtransit-entry [ rb nickname ] [ vlan vlan-id ] chassis chassis-number slot slot-number [ mdc mdc-id ]
Probe视图
debug trill show port命令用来显示单端口或聚合接口的TRILL类型。
独立运行模式:
debug trill show port slot slot-number subslot-number portnum port-number [ subport-number ]
debug trill show port slot slot-number lag lag-number
debug trill show port all slot slot-number
IRF模式:
debug trill show port chassis chassis-number slot slot-number subslot-number portnum port-number [ subport-number ]
debug trill show port chassis chassis-number slot slot-number lag lag-number
debug trill show port all chassis chassis-number slot slot-number
Probe视图
all:显示所有端口TRILL类型。
debug trill show port all命令用来显示所有TRILL端口的信息。
独立运行模式:
IRF模式:
Probe视图
debug trill show port portnum命令用来显示单端口的TRILL类型。
独立运行模式:
debug trill show port slot slot-number { subslot-number portnum port-number [ subport-number ] | lag lag-number }
IRF模式:
debug trill show port chassis chassis-number slot slot-number { subslot-number portnum port-number [ subport-number ] | lag lag-number }
Probe视图
debug trill show route 命令用来显示所有TRILL单播路由信息。
独立运行模式:
debug trill show route slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show route chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
debug trill show route rb命令用来显示指定RB的TRILL单播路由信息。
独立运行模式:
debug trill show route rb nickname slot slot-number [ mdc mdc-id ]
IRF模式:
debug trill show route rb nickname chassis chassis-number slot slot-number [ mdc mdc-id ]
Probe视图
debug trill show rpf-entry命令用来显示TRILL RPF表项。
独立运行模式:
debug trill show rpf-entry [ rb nickname ] [ ingress ingress-rb-nickname ] slot slot-number [ mdc mdc-id ] [ offset-number ]
IRF模式:
debug trill show rpf-entry [ rb nickname ] [ ingress ingress-rb-nickname ] chassis chassis-number slot slot-number [ mdc mdc-id ] [ offset-number ]
Probe视图
ingress ingress-rb-nickname:Ingress RB的Nickname。
debug trill show statistic命令用来显示指定单板上的TRILL统计信息。
独立运行模式:
debug trill show statistic slot slot-number [ mdc mdc-id ]
IRF模式:
debug trill show statistic chassis chassis-number slot slot-number [ mdc mdc-id ]
Probe视图
debug tunnel-drv show infobyindex根据隧道索引显示隧道节点信息。
独立运行模式:
debug tunnel-drv show infobyindex index-number slot slot-number
IRF模式:
debug tunnel-drv show infobyindex index-number chassis chassis-number slot slot-number
Probe视图
index-number:隧道索引。
debug tunnel-drv show state根据隧道状态和隧道索引显示隧道节点信息。
独立运行模式:
debug tunnel-drv show state state-number index-number slot slot-number
IRF模式:
debug tunnel-drv show state state-number index-number chassis chassis-number slot slot-number
Probe视图
state-number:隧道状态项。
index-number:隧道索引值。
debug tunnel-drv show variable显示隧道内部变量信息,包含隧道大小、已创建隧道个数、隧道MTU值、是否下发环回口上隧道ACL重定向规则、隧道节点信息数组地址以及环回聚合类型。
独立运行模式:
debug tunnel-drv show variable slot slot-number
IRF模式:
debug tunnel-drv show variable chassis chassis-number slot slot-number
Probe视图
debug { ipc-rx | ipc-tx } printpkt命令用来显示IPC接收或发送报文的信息。
独立运行模式:
debug { ipc-rx | ipc-tx } printpkt slot slot-number { disable | dmac | enable | protocol protocol-number | settings | showall | showlength length | shownumber number | towhere [ direction ] }
IRF模式:
debug { ipc-rx | ipc-tx } printpkt chassis chassis-number slot slot-number { disable | dmac | enable | protocol protocol-number | settings | showall | showlength length | shownumber number | towhere [ direction ] }
Probe视图
ipc-rx:显示接收报文的相关信息。
ipc-tx:显示发送报文的相关信息。
disable:关闭IPC发送或接收报文调试命令。
enable:开启IPC发送或接收报文调试命令。
dmac:过滤不含IPC目的MAC的报文。
smac:过滤不含IPC源MAC的报文。
protocol protocol:过滤不含IPC协议类型的报文,protocol表示协议类型的编号,取值范围为0~xFFFFFFFF。
settings:显示已配置过的调试参数。
showall:显示所有发送报文。
showlength length:配置发送报文显示长度,取值范围为32~256。
shownumber number:配置发送报文显示个数,取值范围为1~65535。
towhere direction:配置将发送报文打印到AUX0或tShell,取值范围为1~2。其中1表示tShell,2表示AUX0。
debug { ipc-rx | ipc-tx } statistic detail命令用来显示IPC接收或发送报文统计。
独立运行模式:
debug { ipc-rx | ipc-tx } statistic slot slot-number detail
IRF模式:
debug { ipc-rx | ipc-tx } statistic chassis chassis-number slot slot-number detail
Probe视图
debug { ipc-rx | ipc-tx } statistic protocol命令用来显示IPC按协议接收或发送报文统计。
独立运行模式:
debug { ipc-rx | ipc-tx } statistic slot slot-number protocol
IRF模式:
debug { ipc-rx | ipc-tx } statistic chassis chassis-number slot slot-number protocol
Probe视图
debug { ipc-rx | ipc-tx } statistic reset命令用来对IPC接收或发送的报文统计清零。
独立运行模式:
debug { ipc-rx | ipc-tx } statistic slot slot-number reset
IRF模式:
debug { ipc-rx | ipc-tx } statistic chassis chassis-number slot slot-number reset
Probe视图
debugging cfd命令用来打开CFD调试信息开关。
undo debugging cfd命令用来关闭CFD调试信息开关。
debugging cfd { error | hardware }
undo debugging cfd { error | hardware }
CFD调试信息开关处于关闭状态。
Probe视图
error:表示CFD错误调试信息开关。
hardware:表示CFD硬件调试信息开关。
debugging driver命令用来打开相应模块调试信息。
undo debugging driver命令用来关闭模块调试信息。
独立运行模式:
debugging driver [ module | all ] [ { level } [ above | below ] ] [ slot slot-number ]
undo debugging driver [ module | all ] [ { level } [ above | below ] ] [ slot slot-number ]
IRF模式:
debugging driver [ module | all ] [ { level } [ above | below ] ] [ chassis chassis-number slot slot-number ]
undo debugging driver [ module | all ] [ { level } [ above | below ] ] [ chassis chassis-number slot slot-number ]
Probe视图
module:表示驱动模块名称。
all:表示打开或关闭所有驱动模块的开关。
level:表示驱动模块调试信息级别。
above:表示指定级别以上的驱动模块的开关。
below:表示指定级别以下的驱动模块的开关。
debugging l2vpn l2vfib命令用来打开L2VPN L2VFIB模块的调试信息开关。
undo debugging l2vpn l2vfib命令用来关闭L2VPN L2VFIB模块的调试信息开关。
debugging l2vpn l2vfib { ac | all | config | lpw | sync } slot slot-number
undo debugging l2vpn l2vfib { ac | all | config | lpw | sync } slot slot-number
IRF模式:
debugging l2vpn l2vfib { ac | all | config | lpw | sync } chassis chassis-number slot slot-number
undo debugging l2vpn l2vfib { ac | all | config | lpw | sync } chassis chassis-number slot slot-number
L2VPN L2VFIB模块的调试信息开关处于关闭状态。
Probe视图
ac:表示L2VPN L2VFIB AC相关调试信息开关。
all:表示L2VPN L2VFIB所有调试信息开关。
config:表示L2VPN L2VFIB配置消息调试信息开关。
lpw:表示L2VPN L2VFIB LPW相关调试信息开关。
sync:表示L2VPN L2VFIB同步相关调试信息开关。
slot slot-number:表示指定单板的L2VPN L2VFIB调试信息开关。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的L2VPN L2VFIB调试信息开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging lipc命令用来打开LIPC的debug开关。
debugging lipc { mtcp | stcp | lgmp | topo | detail | pub | mbuf | dump port | stream } [ lip lip ]
undo debugging lipc { mtcp | stcp | lgmp | topo | detail | pub | mbuf | all | dump port | stream } [ lip lip ]
mtcp:用来打开LIPC的MTCP模块调试信息开关。
stcp:用来打开LIPC的STCP模块的调试信息开关。
lgmp:用来打开LIPC的LGMP模块的调试信息开关。
topo:用来打开LIPC的TOPO模块的调试信息开关。
pub:用来打开LIPC的PUB模块的调试信息开关。
mbuf:用来打开LIPC的MBUF模块的调试信息开关。
stream:用来打开LIPC的STREAM模块的调试信息开关。
dump port:表示端口号,取值范围为0~65535。
lip lip:可选参数,表示远端节点号,取值范围为0~32767。
debugging mpls lfib命令用来打开MPLS LFIB模块的调试信息开关。
undo debugging mpls lfib命令用来关闭MPLS LFIB模块的调试信息开关。
debugging mpls lfib { all | config | ilm | message | nhlfe | sync } slot slot-number
undo debugging mpls lfib { all | config | ilm | message | nhlfe | sync } slot slot-number
IRF模式:
debugging mpls lfib { all | config | ilm | message | nhlfe | sync } chassis chassis-number slot slot-number
undo debugging mpls lfib { all | config | ilm | message | nhlfe | sync } chassis chassis-number slot slot-number
MPLS LFIB模块的调试信息开关处于关闭状态。
Probe视图
all:表示MPLS LFIB所有调试信息开关。
config:表示MPLS LFIB配置消息调试信息开关。
ilm:表示MPLS LFIB ILM相关调试信息开关。
message:表示MPLS LFIB消息相关调试信息开关。
nhlfe:表示MPLS LFIB NHLFE相关调试信息开关。
sync:表示MPLS LFIB同步相关调试信息开关。
slot slot-number:表示指定单板的MPLS LFIB调试信息开关。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的MPLS LFIB调试信息开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging search symbol命令用来显示指定函数的地址。
独立运行模式:
debugging search symbol string slot slot-number
IRF模式:
debugging search symbol string chassis chassis-number slot slot-number
Probe视图
string:函数名称。
slot slot-mumber:显示指定单板上指定函数的地址,slot-number表示单板所在的槽位号。(独立运行模式)
debugging stg命令用来打开STG调试信息开关。
undo debugging stg命令用来关闭STG调试信息开关。
debugging stg { all | bind | error | map | state | tc }
undo debugging stg { all | bind | error | map | state | tc }
Probe视图
all:表示STG所有调试信息开关。
bind:表示STG与VLAN绑定调试信息开关。
error:表示STG错误调试信息开关。
map:表示STG与STI映射事件调试信息开关。
state:表示STG状态设置调试信息开关。
tc:表示tc事件调试信息开关。
debugging stp ipc命令用来打开生成树进程间通信调试开关。
undo debugging stp ipc命令用来关闭生成树进程间通信调试开关。
Probe视图
ipc:表示生成树进程间通信调试信息开关。
debugging system internal arp event
undo debugging system internal arp event
Probe视图
debugging system internal arp event 命令用来打开ARP事件调试信息开关。undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
缺省情况下,ARP事件调试信息开关处于关闭状态。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
缺省情况下ARP子特性的调试信息开关处于关闭状态。
debugging system internal arp notify
undo debugging system internal arp notify
Probe视图
debugging system internal arp notify 命令用来打开ARP的外部通知调试信息开关。undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
缺省情况下,ARP的外部通知调试信息开关处于关闭状态。
debugging system internal arp sync
undo debugging system internal arp sync
Probe视图
debugging system internal arp sync 命令用来打开ARP表项的同步调试信息开关。undo debugging system internal arp sync命令用来关闭ARP表项的同步调试信息开关。
缺省情况下,ARP表项的同步调试信息开关处于关闭状态。
debugging system internal fc fib命令用来打开FC FIB的调试信息开关。
独立运行模式:
debugging system internal fc fib { all | hardware | msg | search } slot slot-number
undo debugging system internal fc fib { all | hardware | msg | search } slot slot-number
IRF模式:
debugging system internal fc fib { all | hardware | msg | search } chassis chassis-number slot slot-number
undo debugging system internal fc fib { all | hardware | msg | search } chassis chassis-number slot slot-number
Probe视图
all:打开FC FIB全部调试信息开关。
hardware:打开hardware调试开关,打印下发驱动信息以及驱动返回的消息。
msg:打开message调试开关,打印路由下发和板间同步的FC FIB消息。
search:打开search调试开关,打印报文转发时查找的FC FIB信息。
slot slot-number:打开指定单板上的FC FIB调试信息开关。slot-number表示单板所在的槽位号。如果不指定本参数,将打开主用主控板上的FC FIB调试信息开关。(独立运行模式)
chassis chassis-number slot slot-number:打开指定成员设备上指定单板上的FC FIB调试信息开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将打开全局主用主控板上的FC FIB调试信息开关。(IRF模式)
debugging system internal fib prefix { all | message | hardware } slot slot-number
undo debugging system internal fib prefix { all | message | hardware } slot slot-number
IRF模式:
debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number
undo debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number
Probe视图
all:打开所有调试开关。
message:打开message调试开关,打印路由下发和板间同步的IPv4 FIB前缀消息。
slot slot-number:单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging system internal fib 命令用来打开FIB调试信息开关。undo debugging system internal fib命令用来关闭FIB调试信息开关。
缺省情况下,FIB 调试信息开关处于关闭状态。
表1-4 debugging system internal fib prefix message命令输出信息描述表
Vrf索引 |
IP优先级 |
表1-5 debugging system internal fib prefix hardware命令输出信息描述表
Vrf索引 |
VN 指针 |
VN下驱动返回的信息 |
前缀下驱动信息[个数] |
BGP下一跳地址 |
Tunnel口驱动信息 |
ADJ信息 |
目的IP地址 |
ADJ动作类型 |
VRF索引 |
ADJ服务类型 |
ADJ表项属性 |
MAC地址 |
ADJ下驱动索引 |
NHLFE信息 |
NHLFE表项索引 |
debugging system internal fib vn { all | message | hardware | bind | notify } slot slot-number
undo debugging system internal fib vn { all | message | hardware | bind | notify } slot slot-number
IRF模式:
debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number
undo debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number
Probe视图
all:打开所有调试开关。
message:打开message调试开关,显示路由等下发和板间同步的vn消息。
hardware:打开hardware调试开关,显示下发驱动的信息以及驱动返回的信息。
bind:打开bind调试开关,显示前缀绑定vn,vn绑定adj/nhlfe的相关信息。
notify:打开notify调试开关,显示adj/nhlfe反向通知vn,以及vn反向通知前缀的信息。
debugging system internal fib vn 命令用来打开VN调试信息开关。undo debugging system internal fib vn命令用来关闭VN调试信息开关。
缺省情况下,VN 调试信息开关处于关闭状态。
表1-6 debugging system internal fib vn message命令输出信息描述表
刷新VN消息,RM4是一种NBR消息来源,还有其他类型,如RM6、L2VPN、LSM等。 |
NBR消息中下一跳个数 |
[索引]下一跳 |
本地Ip地址 |
出接口VRF索引 |
NHLFE索引 |
主控板带给接口板的VN驱动信息 |
表1-7 debugging system internal fib vn hardware命令输出信息描述表
旧VN驱动信息 |
VN驱动信息 |
VN属性 |
BGP下一跳地址 |
Tunnel口驱动信息 |
ADJ信息 |
目的IP地址 |
ADJ动作类型 |
VRF索引 |
ADJ服务类型 |
ADJ表项属性 |
MAC地址 |
ADJ下驱动索引 |
表1-8 debugging system internal fib vn bind命令输出信息描述表
Bind为一种操作类型,此处还可以为Unbind、Rebind |
VN 指针 |
Nexthop索引 |
VN表项时戳 |
前缀绑定VN操作信息 |
VN 指针 |
表1-9 debugging system internal fib vn notify命令输出信息描述表
ADJ4/ADJ6/NHLFE是一种notify类型,还有其他类型为BFD、VN |
ADJ4是一种变化类型,还有类型为ADJ6、NNLFE |
VN 指针 |
VN表项时戳 |
debugging system internal igmp-snooping fsm tracing命令用来打开IGMP Snooping状态机的Trace日志调试信息开关。
undo debugging system internal igmp-snooping fsm tracing命令用来关闭IGMP Snooping状态机的Trace日志调试信息开关。
IRF模式:
IGMP Snooping状态机的Trace日志调试信息开关处于关闭状态。
Probe视图
group-address:输出指定组播组的信息。如果未指定本参数,将输出所有组播组的信息。
source-address:输出指定组播源的信息。如果未指定本参数,将输出所有组播源的信息。
vlan vlan-id:输出指定VLAN内的信息,vlan-id表示VLAN的编号,取值范围为1~4094。如果未指定本参数,将输出所有VLAN内的信息。
slot slot-number:输出指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将输出所有单板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:输出指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将输出IRF中所有单板上的信息。(IRF模式)
debugging system internal ip vpn-instance命令用来打开VPN实例调试信息开关。
undo debugging system internal ip vpn-instance命令用来关闭VPN实例调试信息开关。
debugging system internal ip vpn-instance slot slot-number
undo debugging system internal ip vpn-instance slot slot-number
IRF模式:
debugging system internal ip vpn-instance chassis chassis-number slot slot-number
undo debugging system internal ip vpn-instance chassis chassis-number slot slot-number
VPN实例的调试信息开关处于关闭状态。
Probe视图
slot slot-number:表示指定单板上的VPN实例调试信息开关。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的VPN实例调试信息开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging system internal ipv6 fib prefix命令用来打开IPv6 FIB调试信息开关。
undo debugging system internal ipv6 fib prefix命令用来关闭IPv6 FIB调试信息开关。
debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
undo debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
IRF模式:
IPv6 FIB调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开前缀消息调试开关,打印路由下发和板间同步的IPv6 FIB前缀消息。
hardware:打开下驱动信息调试开关,打印下发驱动信息以及驱动返回的消息。
debugging system internal mld-snooping fsm tracing命令用来打开MLD Snooping状态机的Trace日志调试信息开关。
undo debugging system internal mld-snooping fsm tracing命令用来关闭MLD Snooping状态机的Trace日志调试信息开关。
IRF模式:
MLD Snooping状态机的Trace日志调试信息开关处于关闭状态。
Probe视图
ipv6-group-address:输出指定IPv6组播组的信息。如果未指定本参数,将输出所有IPv6组播组的信息。
ipv6-source-address:输出指定IPv6组播源的信息。如果未指定本参数,将输出所有IPv6组播源的信息。
debugging system internal nd命令用来打开邻居发现的调试信息开关。
undo debugging system internal nd命令用来关闭邻居发现的外部通知调试信息开关。
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
Probe视图
notify:表示邻居发现的通知调试开关。
sync: 表示邻居发现的同步调试开关。
debugging system internal trill adjacent-table命令用来打开TRILL邻接表调试信息开关。
undo debugging system internal trill adjacent-table命令用来关闭TRILL邻接表调试信息开关。
debugging system internal trill adjacent-table { all | hardware | message | notify }
undo debugging system internal trill adjacent-table { all | hardware | message | notify }
TRILL邻接表调试信息开关处于关闭状态。
Probe视图
all:表示TRILL邻接表的所有调试信息开关。
hardware:表示TRILL邻接表的硬件调试信息开关。
message:表示TRILL邻接表的消息调试信息开关。
notify:表示TRILL邻接表的通知调试信息开关。
debugging system internal trill fib命令用来打开TRILL单播转发表调试信息开关。
undo debugging system internal trill fib命令用来关闭TRILL单播转发表调试信息开关。
debugging system internal trill fib { all | bind | hardware | message }
undo debugging system internal trill fib { all | bind | hardware | message }
TRILL单播转发表调试信息开关处于关闭状态。
Probe视图
all:表示TRILL单播转发表的所有调试信息开关。
bind:表示TRILL单播转发表的绑定调试信息开关。
hardware:表示TRILL单播转发表的硬件调试信息开关。
message:表示TRILL单播转发表的消息调试信息开关。
debugging system internal trill management命令用来打开TRILL管理调试信息开关。
undo debugging system internal trill management命令用来关闭TRILL管理调试信息开关。
debugging system internal trill management { all | hardware | message }
undo debugging system internal trill management { all | hardware | message }
TRILL管理调试信息开关处于关闭状态。
Probe视图
all:表示TRILL管理的所有调试信息开关。
hardware:表示TRILL管理的硬件调试信息开关。
message:表示TRILL管理的消息调试信息开关。
debugging system internal trill mfib命令用来打开TRILL组播转发表调试信息开关。
undo debugging system internal trill mfib命令用来关闭TRILL组播转发表调试信息开关。
debugging system internal trill mfib { all | hardware | message }
undo debugging system internal trill mfib { all | hardware | message }
TRILL组播转发表调试信息开关处于关闭状态。
Probe视图
all:表示TRILL组播转发表的所有调试信息开关。
hardware:表示TRILL组播转发表的硬件调试信息开关。
message:表示TRILL组播转发表的消息调试信息开关。
debugging system internal trill vn命令用来打开TRILL VN(Virtual Nexthop,虚拟下一条)表项调试信息开关。
undo debugging system internal trill vn命令用来关闭TRILL VN调试信息开关。
debugging system internal trill vn { all | bind | hardware | message | notify }
undo debugging system internal trill vn { all | bind | hardware | message | notify }
TRILL VN表项调试信息开关处于关闭状态。
Probe视图
all:表示TRILL VN表项的所有调试信息开关。
bind:表示TRILL VN表项的绑定调试信息开关。
hardware:表示TRILL VN表项的硬件调试信息开关。
message:表示TRILL VN表项的消息调试信息开关。
notify:表示TRILL VN表项的通知调试信息开关。
debugging vlan { all | error | event | execution | hardware }
undo debugging vlan { all | error | event | execution | hardware }
Probe视图
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
debugging vlan命令用来打开VLAN的调试开关。undo debugging vlan命令用来关闭VLAN的调试开关。
缺省情况下,VLAN的调试开关处于关闭状态。
表1-1 debugging vlan event命令输出信息描述表
表1-2 debugging vlan error命令输出信息描述表
VLAN实例 |
表1-3 debugging vlan hardware命令输出信息描述表
VLAN实例 |
表1-4 debugging vlan execution命令输出信息描述表
VLAN处理消息类型 |
VLAN处理数据长度 |
VLAN实例 |
display deadloop section查看2秒没有任务切换的任务栈。
独立运行模式:
display deadloop section section-id slot slot-number
IRF模式:
display deadloop section section-id chassis chassis-number slot slot-number
Probe视图
section-id:表示信息的类别,取值为0或1;0,表示当前信息;1,表示上次重起前的信息。
slot slot-number:显示指定单板2秒没有任务切换的任务栈。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板2秒没有任务切换的任务栈。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display debugging命令用来显示调试开关状态。
display debugging [ module ]
Probe视图
module:模块名称。
display devm entity命令显示设备实体信息。
独立运行模式:
display devm entity entity-index slot slot-number
IRF模式:
display devm entity entity-index chassis chassis-number slot slot-number
Probe视图
entity-index:表示实体索引号。
display devm fabricporttype命令显示HG端口类型。
独立运行模式:
display devm fabricporttype slot slot-number
IRF模式:
display devm fabricporttype chassis chassis-number slot slot-number
Probe视图
display devm hgport命令显示交换机板间HG连接关系。
独立运行模式:
display devm hgport slot slot-number source-slot dest-slot
IRF模式:
display devm hgport chassis chassis-number slot slot-number source-slot dest-slot
Probe视图
source-slot:表示源单板所在的槽位号。
dest-slot:表示目的单板所在的槽位号。
display devm innerport显示单板内部端口互联关系。
独立运行模式:
display devm innerport slot slot-number
IRF模式:
display devm innerport chassis chassis-number slot slot-number
Probe视图
display devm isrrecord显示单板的插拔记录。
独立运行模式:
display devm isrrecord slot slot-number
IRF模式:
display devm isrrecord chassis chassis-number slot slot-number
Probe视图
display devm loadtime显示单板加载的可执行文件的信息。
Probe视图
display devm notify-record命令显示系统事件发生时,对驱动各个模块的通知时序。
独立运行模式:
display devm notify-record slot slot-number
IRF模式:
display devm notify-record chassis chassis-number slot slot-number
Probe视图
display devm recordekdmtime命令显示核心数据同步的记录信息。
独立运行模式:
display devm recordekdmtime slot slot-number
IRF模式:
display devm recordekdmtime chassis chassis-number slot slot-number
Probe视图
display devm recordipcportstatus监控IPC端口双工状态。
独立运行模式:
display devm recordipcportstatus slot slot-number
IRF模式:
display devm recordipcportstatus chassis chassis-number slot slot-number
Probe视图
display devm switchport命令显示指定单板的指定端口的属性。
独立运行模式:
display devm switchport slot slot-number dest-slot source-slot port-number
IRF模式:
display devm switchport chassis chassis-number slot slot-number dest-slot source-slot port-number
Probe视图
port-number:表示端口编号。
display devm variable命令用来显示EVB子线程的信息。
独立运行模式:
display devm variable slot slot-number
IRF模式:
display devm variable chassis chassis-number slot slot-number
Probe视图
display diag-msg start-msg查看单板启动信息。
独立运行模式:
display diag-msg start-msg slot slot-number message-type
IRF模式:
display diag-msg start-msg chassis chassis-number slot slot-number message-type
Probe视图
message-type:表示单板启动信息类型。
display hardware internal transceiver register interface命令用来显示可插拔光模块上指定寄存器区域的内容,用十六进制数表示。
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
Probe视图
interface interface-type interface-number:显示接口上插入的可插拔光模块上的寄存器信息。interface-type interface-number表示接口类型和接口编号。
device device-index:表示指定接口上光模块内部寄存器的索引号,用十六进制数表示,取值范围为0~FF。
address start-address:起始地址,即需要显示的寄存器区域的起始点的偏移地址。用十六进制数表示,取值范围为0~FFFF。
length region-length:寄存器区域的长度,即需要显示的寄存器区域的字节数。用十进制数表示,取值范围为1~256。
display hgmonitor action命令用来显示指定槽位的内部通道动作记录。
独立运行模式:
display hgmonitor action slot-number
IRF模式:
display hgmonitor action chassis chassis-number slot slot-number
Probe视图
display hgmonitor faultport命令用来显示指定槽位的故障端口记录
独立运行模式:
display hgmonitor faultport slot-number
IRF模式:
display hgmonitor faultport chassis chassis-number slot slot-number
Probe视图
display hgmonitor info命令用来显示指定槽位单板的指定芯片的内部通道检测记录。
独立运行模式:
display hgmonitor info slot-number chip-number [ port-number ]
IRF模式:
display hgmonitor info chassis chassis-number slot slot-number chip chip-number [port port-number ]
Probe视图
chip-number:表示芯片编号。(独立运行模式)
chassis chassis-number slot slot-number chip chip-number:表示指定成员设备上指定单板的指定芯片号。(IRF模式)
port-number:表示端口编号。(独立运行模式)
port port-number:表示端口编号。(IRF运行模式)
display hgmonitor judge命令用来显示指定槽位的内部通道检测记录。
独立运行模式:
display hgmonitor judge slot-number
IRF模式:
display hgmonitor judge chassis chassis-number slot slot-number
Probe视图
display hgmonitor start命令用来显示指定槽位的内部通道监控启动时间记录
独立运行模式:
display hgmonitor start slot-number
IRF模式:
display hgmonitor start chassis chassis-number slot slot-number
Probe视图
display hgmonitor variable命令用来显示指定槽位单板的内部通道检测相关全局变量。
独立运行模式:
display hgmonitor info variable slot-number chip-number
IRF模式:
display hgmonitor info variable chassis chassis-number slot slot-number chip chip-number
Probe视图
display inner-channel info slot命令用来显示指定槽位的内部通道监控记录。
独立运行模式:
display inner-channel info slot slot-number
IRF模式:
display inner-channel info chassis chassis-number slot slot-number
Probe视图
display inner-channel variable命令用来显示指定槽位内部通道监控相关全局变量。
独立运行模式:
display inner-channel variable slot slot-number
IRF模式:
display inner-channel variable chassis chassis-number slot slot-number
Probe视图
display mainboard switchinfo显示主控板的重启原因信息
独立运行模式:
IRF模式:
display mainboard switchinfo [ chassis chassis-number ]
Probe视图
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。若未指定本参数,将显示所有成员设备的显示主控板的重启原因信息。(IRF模式)
display power-info用于查看设备的功率信息。
独立运行模式:
display power-info
IRF模式:
display power-info chassis chassis-number
Probe视图
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。若未指定本参数,将显示所有成员设备的功率信息。(IRF模式)
display reboot查看重启的栈信息、最后一次重启时间以及中断信息。
独立运行模式:
display reboot { section section-id slot slot-number | last-time slot slot-number | interrupt section section-id slot slot-number }
IRF模式:
display reboot { section section-id chassis chassis-number slot slot-number | last-time chassis chassis-number slot slot-number | interrupt section section-id chassis chassis-number slot slot-number }
Probe视图
section section-id:表示信息的类别,取值为0或1;0,表示当前信息;1,表示上次重起前的信息。
slot slot-number:显示指定单板重启的栈信息、最后一次重启时间以及中断信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板重启的栈信息、最后一次重启时间以及中断信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display rxtx all命令设置显示所有报文。
独立运行模式:
display rxtx all [ slot slot-number ]
IRF模式:
display rxtx all [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx broadcast命令用来显示广播报文。
undo display rxtx broadcast命令用来关闭显示广播报文。
独立运行模式:
display rxtx broadcast [ slot slot-number ]
undo display rxtx broadcast [ slot slot-number ]
IRF模式:
display rxtx broadcast [ chassis chassis-number slot slot-number ]
undo display rxtx broadcast [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx chip命令用来显示指定芯片的报文。
undo display rxtx chip命令用来取消显示指定芯片的报文。
独立运行模式:
display rxtx chip chip-number [ slot slot-number ]
undo display rxtx chip [ slot slot-number ]
IRF模式:
display rxtx chip chip-number [ chassis chassis-number slot slot-number ]
undo display rxtx chip [ chassis chassis-number slot slot-number ]
Probe视图
chassis chassis-number slot slot-number:表示指定成员设备上的指定指定单板。(IRF模式)
display rxtx cos命令用来显示指定cos的报文。
undo display rxtx cos命令用来取消显示指定cos的报文。
独立运行模式:
display rxtx cos cos-number [ slot slot-number ]
undo display rxtx cos [ slot slot-number ]
IRF模式:
display rxtx cos cos-number [ chassis chassis-number slot slot-number ]
undo display rxtx cos [ chassis chassis-number slot slot-number ]
Probe视图
cos-number:表示cos队列编号。
display rxtx dest_mac命令用来显示指定目的mac的报文。
undo display dest_mac 命令用来取消显示指定目的mac的报文。
独立运行模式:
display rxtx dest_mac mac-address [ slot slot-number ]
undo display rxtx dest_mac [ slot slot-number ]
IRF模式:
display rxtx dest_mac mac-address [ chassis chassis-number slot slot-number ]
undo display rxtx dest_mac [ chassis chassis-number slot slot-number ]
Probe视图
mac-address:表示mac地址。
display rxtx dip命令用来显示指定目的IP的报文。
undo display rxtx dip命令用来取消显示指定目的IP的报文。
独立运行模式:
display rxtx dip ip-address [ slot slot-number ]
undo display rxtx dip [ slot slot-number ]
IRF模式:
display rxtx dip ip-address [ chassis chassis-number slot slot-number ]
undo display rxtx dip [ chassis chassis-number slot slot-number ]
Probe视图
ip-address:表示目的IPv4地址。
display rxtx dipv6命令用来显示指定目的IPv6地址的报文。
undo display rxtx dipv6 命令用来取消显示指定目的IPv6地址的报文。
独立运行模式:
display rxtx dipv6 ipv6-address [ slot slot-number ]
undo display rxtx dipv6 [ slot slot-number ]
IRF模式:
display rxtx dipv6 ipv6-address [ chassis chassis-number slot slot-number ]
undo display rxtx dipv6 [ chassis chassis-number slot slot-number ]
Probe视图
ipv6-address:表示IPv6地址。
display rxtx etype命令用来显示指定以太网类型的报文。
undo display rxtx etype命令用来取消显示指定以太网类型的报文。
独立运行模式:
display rxtx etype ethernet-type [ slot slot-number ]
undo display rxtx etype [ slot slot-number ]
IRF模式:
display rxtx etype ethernet-type [ chassis chassis-number slot slot-number ]
undo display rxtx etype [ chassis chassis-number slot slot-number ]
Probe视图
ethernet-type:表示以太网类型值。
display rxtx iptype 命令用来显示指定IP类型的报文。
undo display rxtx iptype 命令用来取消显示指定IP类型的报文。
独立运行模式:
display rxtx iptype ip-type [ slot slot-number ]
undo display rxtx iptype [ slot slot-number ]
IRF模式:
display rxtx iptype ip-type [ chassis chassis-number slot slot-number ]
[undo] display rxtx iptype [ chassis chassis-number slot slot-number ]
Probe视图
ip-type:表示IP类型值。
display rxtx length命令用来显示指定长度的报文。
undo display rxtx length命令取消显示指定长度的报文。
独立运行模式:
display rxtx length length-value [ slot slot-number ]
[undo] display rxtx length [ slot slot-number ]
IRF模式:
display rxtx length length-value [ chassis chassis-number slot slot-number ]
[undo] display rxtx length [ chassis chassis-number slot slot-number ]
Probe视图
length-value:表示报文长度。(报文长度不包括CRC字段)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。(IRF模式)
display rxtx matchrule命令用来显示指定ACL类型的IP报文。
undo display rxtx matchrule命令用来关闭显示指定ACL类型的IP报文。
独立运行模式:
display rxtx matchrule match-number [ slot slot-number ]
[undo] display rxtx matchrule [ slot slot-number ]
IRF模式:
display rxtx matchrule match-number [ chassis chassis-number slot slot-number ]
[undo] display rxtx matchrule [ chassis chassis-number slot slot-number ]
Probe视图
match-number:表示匹配类型值。
display rxtx multicast命令用来显示组播报文。
undo display rxtx multicast命令用来取消显示组播报文。
独立运行模式:
display rxtx multicast [ slot slot-number ]
undo display rxtx multicast [ slot slot-number ]
IRF模式:
display rxtx multicast [ chassis chassis-number slot slot-number ]
undo display rxtx multicast [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx port命令用来显示指定端口的报文。
undo display rxtx port命令用来取消显示指定端口的报文。
独立运行模式:
display rxtx port port-number [ slot slot-number ]
undo display rxtx port [ slot slot-number ]
IRF模式:
display rxtx port port-number [ chassis chassis-number slot slot-number ]
undo display rxtx port [ chassis chassis-number slot slot-number ]
Probe视图
port port-number:表示物理端口号。
display rxtx rcpu命令用来打开支持辅助cpu设备的主控板发送报文过滤条件的开关。
undo display rxtx rcpu命令用来关闭支持辅助cpu设备的主控板发送报文过滤条件的开关。
独立运行模式:
display rxtx rcpu [ slot slot-number ]
undo display rxtx rcpu [ slot slot-number ]
IRF模式:
display rxtx rcpu [ chassis chassis-number slot slot-number ]
undo display rxtx rcpu [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx reason命令用来显示指定上送方式的报文。
undo display rxtx reason命令用来取消显示指定上送方式的报文。
独立运行模式:
display rxtx reason reason-number [ slot slot-number ]
undo display rxtx reason [ slot slot-number ]
IRF模式:
display rxtx reason reason-number [ chassis chassis-number slot slot-number ]
undo display rxtx reason [ chassis chassis-number slot slot-number ]
Probe视图
reason-number:表示reason值。
display rxtx receive命令用来显示接收到的报文。
undo display rxtx receive命令用来取消显示接收到的报文。
独立运行模式:
display rxtx receive [ slot slot-number ]
undo display rxtx receive [ slot slot-number ]
IRF模式:
display rxtx receive [chassis chassis-number slot slot-number ]
undo display rxtx receive [chassis chassis-number slot slot-number ]
Probe视图
display rxtx send命令用来显示发送的报文。
undo display rxtx send命令用来取消显示发送的报文。
独立运行模式:
display rxtx send [ slot slot-number ]
undo display rxtx send [ slot slot-number ]
IRF模式:
display rxtx send [ chassis chassis-number slot slot-number ]
undo display rxtx send [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx sip命令用来显示指定源IP(IPV4)的报文。
undo display rxtx sip命令用来取消显示指定源IP(IPV4)的报文。
独立运行模式:
display rxtx sip ip-address [ slot slot-number ]
undo display rxtx sip [ slot slot-number ]
IRF模式:
display rxtx sip ip-address [ chassis chassis-number slot slot-number ]
undo display rxtx sip [ chassis chassis-number slot slot-number ]
Probe视图
ip-address:表示源IPv4地址。
display rxtx sipv6命令用来显示指定源IP(IPV6)的报文。
undo display rxtx sipv6命令用来取消显示指定源IP(IPV6)的报文。
独立运行模式:
display rxtx sipv6 ip-address [ slot slot-number ]
undo display rxtx sipv6 [ slot slot-number ]
IRF模式:
display rxtx sipv6 ip-address [ chassis chassis-number slot slot-number ]
undo display rxtx sipv6 [ chassis chassis-number slot slot-number ]
Probe视图
ip-address:表示IPv6地址。
display rxtx source_mac命令用来显示指定源mac地址的报文。
undo display rxtx source_mac命令用来取消显示指定源mac地址的报文。
独立运行模式:
display rxtx source_mac mac-address [ slot slot-number ]
undo display rxtx source_mac [ slot slot-number ]
IRF模式:
display rxtx source_mac mac-address [ chassis chassis-number slot slot-number ]
undo display rxtx source_mac [ chassis chassis-number slot slot-number ]
Probe视图
mac-address:表示源MAC地址。
display rxtx switchflag命令用来显示打印报文过滤条件各个参数的设置信息。
独立运行模式:
display rxtx switchflag [ slot slot-number ]
IRF模式:
display rxtx switchflag [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx unicast命令用来显示单播报文。
undo display rxtx unicast命令用来取消显示单播报文。
独立运行模式:
display rxtx unicast [ slot slot-number ]
undo display rxtx unicast [ slot slot-number ]
IRF模式:
display rxtx unicast [ chassis chassis-number slot slot-number ]
undo display rxtx unicast [ chassis chassis-number slot slot-number ]
Probe视图
display rxtx vlan命令用来显示指定vlan的报文。
undo display rxtx vlan命令用来取消显示指定vlan的报文。
独立运行模式:
display rxtx vlan vlan-id [ slot slot-number ]
undo display rxtx vlan [ slot slot-number ]
IRF模式:
display rxtx vlan vlan-id [ chassis chassis-number slot slot-number ]
undo display rxtx vlan [ chassis chassis-number slot slot-number ]
Probe视图
vlan-id:表示指定VLAN的编号,取值范围为1~4094。
display rxtx vp命令用来显示VP报文。
undo display rxtx vp命令用来取消显示VP报文。
独立运行模式:
display rxtx vp [ slot slot-number ]
undo display rxtx vp [ slot slot-number ]
IRF模式:
display rxtx vp [ chassis chassis-number slot slot-number ]
undo display rxtx vp [ chassis chassis-number slot slot-number ]
Probe视图
display switch-fabric event命令用来显示指定槽位的事件记录。
独立运行模式:
display switch-fabric event slot slot-number
IRF模式:
display switch-fabric event slot-number chassis chassis-number slot slot-number
Probe视图
display switch-fabric variable命令用来显示指定槽位的交换网模块内部全局变量。
独立运行模式:
display switch-fabric variable slot slot-number chip chip-number
IRF模式:
display switch-fabric variable chassis chassis-number slot slot-number chip chip-number
Probe视图
display system internal acl命令用来显示ACL的配置和运行情况。
display system internal acl [ ipv6 ] { acl-number | name acl-name } { slot slot-number }
IRF模式:
display system internal acl [ ipv6 ] { acl-number | name acl-name } { chassis chassis-number slot slot-number }
Probe视图
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下(不同型号的设备支持的取值范围不同,请以设备的实际情况为准):
· 2000~2999:若未指定ipv6关键字,表示IPv4基本ACL;否则表示IPv6基本ACL。
· 3000~3999:若未指定ipv6关键字,表示IPv4高级ACL;否则表示IPv6高级ACL。
· 4000~4999:表示二层ACL(指定ipv6关键字后不会显示本项)。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。对于基本ACL或高级ACL,若未指定ipv6关键字,表示IPv4基本ACL或IPv4高级ACL的名称,否则表示IPv6基本ACL或IPv6高级ACL的名称。
slot slot-number:显示指定单板上ACL的配置和运行情况,slot-number表示单板所在的槽位号。若未指定本参数,将显示主控板上ACL的配置和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上ACL的配置和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若未指定本参数,将显示IRF设备中所有主控板上ACL的配置和运行情况。(IRF模式)
display system internal arp命令用来显示对应单板上学习到的ARP表项信息或表项个数。
display system internal arp { all | static | dynamic | multiport } slot slot-number [ count ]
IRF模式:
Probe视图
all: 命令用来显示所有ARP表项信息或表项个数。
static: 用来显示静态ARP表项信息或表项个数。
dynamic: 用来显示动态ARP表项信息或表项个数。
multiport: 用来显示多端口ARP表项信息或表项个数。
slot slot-number:显示指定单板的ARP表项信息或表项个数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP表项信息或表项个数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
count:用来显示ARP表项个数。
display system internal arp ifcb命令用来查看指定板上二层或三层接口ARP控制块信息
display system internal arp ifcb interface interface-type interface-number slot slot-number
IRF模式:
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板的ARP控制块信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP控制块信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp ip-address命令用来显示指定板上指定IP的ARP表项信息。
display system internal arp ip-address slot slot-number
IRF模式:
display system internal arp ip-address chassis chassis-number slot slot-number
Probe视图
ip-address: 用来显示指定IP的ARP表项信息。
slot slot-number:显示指定单板指定IP的ARP表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板指定IP的ARP表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp machash命令用来显示指定板上machash表项信息。
display system internal arp machash vlan vlan-id ip ip-address slot slot-number
IRF模式:
Probe视图
vlan vlan-id: 显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的id。
ip ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址
slot slot-number:显示指定单板的machash表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的machash表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp probe命令用来显示指定板上ARP探测链表项。
display system internal arp probe slot slot-number
IRF模式:
display system internal arp probe chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ARP探测链表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP探测链表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp reload命令用来显示指定板上ARP重刷链表项。
display system internal arp reload slot slot-number
IRF模式:
display system internal arp reload chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ARP重刷链表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP重刷链表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp source-suppression cache命令用来显示指定板源抑制表项。
display system internal arp source-suppression cache slot slot-number
IRF模式:
display system internal arp source-suppression cache chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的源抑制表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的源抑制表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp statistics命令用来显示指定板ARP统计信息。
display system internal arp statistics slot slot-number
IRF模式:
display system internal arp statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ARP统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal arp vlan命令用来显示指定VLAN的ARP表项信息或表项个数。
display system internal arp vlan vlan-id slot slot-number [ count ]
IRF模式:
display system internal arp vlan vlan-id chassis chassis-number slot slot-number [ count ]
Probe视图
vlan vlan-id: 用来显示指定VLAN的ARP表项信息或表项个数。
slot slot-number:显示指定单板指定VLAN的ARP表项信息或表项个数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板指定VLAN的ARP表项信息或表项个数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
count:用来显示ARP表项个数。
display system internal bgp graceful-restart statistics命令用来显示BGP GR统计信息。
Probe视图
display system internal bgp instance statistics命令用来显示BGP实例统计信息。
display system internal bgp instance { l2vpn | vpnv6 } [ rib | send ] statistics
Probe视图
ipv4:显示IPv4地址族的BGP实例统计信息。
ipv6:显示IPv6地址族的BGP实例统计信息。
vpnv4:显示VPNv4地址族的BGP实例统计信息。
l2vpn:显示L2VPN地址族的BGP实例统计信息。
vpnv6:显示VPNv6地址族的BGP实例统计信息。
vpn-instance vpn-instance-name:显示指定VPN的BGP实例统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP实例的统计信息。
rib:显示BGP实例路由模块的统计信息。
send:显示BGP实例发送模块的统计信息。
执行本命令时,如果没有指定rib和send参数,则显示BGP协议的实例统计信息。
display system internal bgp interface命令用来显示BGP接口信息。
Probe视图
ipv4:显示IPv4地址族的BGP接口信息。
ipv6:显示IPv6地址族的BGP接口信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP接口信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP接口信息。
interface-type interface-number:显示指定BGP接口的信息。interface-type interface-number为接口类型和接口编号。
ipv4-address { mask | mask-length }:显示IPv4地址为指定值的BGP接口的信息。ipv4-address为接口的IPv4地址;mask为接口IPv4地址的网络掩码;mask-length为接口IPv4地址的网络掩码长度,取值范围为0~32。
ipv6-address prefix-length:显示IPv6地址为指定值的BGP接口的信息。ipv6-address为接口的IPv6地址;prefix-length为接口IPv6地址的前缀长度,取值范围为0~128。
执行本命令时,如果没有指定interface-type interface-number和ipv4-address { mask | mask-length }、ipv6-address prefix-length参数,则显示所有BGP接口的信息。
display system internal bgp l2vpn auto-discovery advertise命令用来显示通过BGP协议自动发现的VPLS PE的通告信息。
Probe视图
route-distinguisher route-distinguisher:显示指定路由标识符的信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
· 16位自治系统号:32位用户自定义数,例如:101:3。
· 32位IP地址:16位用户自定义数,例如:192.168.122.15:1。
· 32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
pe-address ip-address:显示通过BGP协议自动发现的指定VPLS PE的信息。ip-address为自动发现的PE的IP地址。
display system internal bgp l2vpn auto-discovery verbose命令用来显示通过BGP协议自动发现的VPLS PE的详细信息。
Probe视图
pe-address ip-address:显示通过BGP协议自动发现的指定VPLS PE的详细信息。ip-address为自动发现的PE的IP地址。
display system internal bgp l2vpn signaling advertise命令用来显示BGP L2VPN标签块的通告信息。
Probe视图
site-id site-id:显示为指定站点分配的BGP L2VPN标签块的通告信息。site-id为站点编号,不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
label-offset label-offset:显示标签块偏移量为指定值的BGP L2VPN标签块的通告信息。label-offset为标签块偏移量,取值范围为0~65535。
display system internal bgp l2vpn signaling verbose命令用来显示BGP L2VPN标签块的详细信息。
Probe视图
site-id site-id:显示为指定站点分配的BGP L2VPN标签块的详细信息。site-id为站点编号,不同型号的设备支持的取值范围不同,请以设备的实际情况为准。
label-offset label-offset:显示标签块偏移量为指定值的BGP L2VPN标签块的详细信息。label-offset为标签块偏移量,取值范围为0~65535。
display system internal bgp nib命令用来显示BGP路由下一跳信息。
display system internal bgp nib { ipv4 | ipv6 } [ nib-id ] [ verbose ]
Probe视图
ipv4:显示IPv4地址族的BGP路由下一跳信息。
ipv6:显示IPv6地址族的BGP路由下一跳信息。
nib-id:下一跳ID,取值范围为1~FFFFFFFF。如果不指定本参数,则显示所有下一跳信息。
verbose:显示下一跳的详细信息。如果不指定本参数,则显示下一跳的简要信息。
display system internal bgp nib log命令用来显示BGP路由下一跳的日志信息。
Probe视图
display system internal bgp peer statistics命令用来显示BGP对等体的统计信息。
display system internal bgp peer vpnv6 ipv6-address [ rib | send | session ] statistics
display system internal bgp peer l2vpn ipv4-address [ rib | send | session ] statistics
Probe视图
ipv4:显示IPv4地址族的BGP对等体统计信息。
ipv6:显示IPv6地址族的BGP对等体统计信息。
vpnv4:显示VPNv4地址族的BGP对等体统计信息。
vpnv6:显示VPNv6地址族的BGP对等体统计信息。
l2vpn:显示L2VPN地址族的BGP对等体统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP对等体统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP对等体统计信息。
ipv4-address:显示指定对等体的信息。ipv4-address为对等体的IPv4地址。
ipv6-address:显示指定对等体的信息。ipv6-address为对等体的IPv6地址。
rib:显示BGP路由模块相关信息。
send:显示BGP发送模块相关信息。
session:显示BGP会话模块相关信息。
指定本命令时,如果不指定rib、send和session参数,则显示BGP协议的对等体统计信息。
display system internal bgp protocol statistics命令用来显示BGP协议的统计信息。
display system internal bgp protocol [ calc | rib | send | session ] statistics
Probe视图
calc:显示BGP路由优选模块的统计信息。
rib:显示BGP路由模块的统计信息。
send:显示BGP发送模块的统计信息。
session:显示BGP会话模块的统计信息。
执行本命令时,如果没有指定任何参数,则显示BGP协议的统计信息。
display system internal bgp routing-table advertise-info命令用来显示BGP路由的通告信息。
display system internal bgp routing-table vpnv6 network-address prefix-length advertise-info
Probe视图
ipv4:显示IPv4地址族的BGP路由通告信息。
ipv6:显示IPv6地址族的BGP路由通告信息。
vpnv4:显示VPNv4地址族的BGP路由通告信息。
vpnv6:显示VPNv6地址族的BGP路由通告信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由通告信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP路由通告信息。
network-address:目的网络的地址。
mask:目的网络的掩码,点分十进制格式。
mask-length:目的网络的掩码长度,取值范围为0~32。
prefix-length:目的网络的前缀长度,取值范围为0~128。
display system internal bgp routing-table verbose命令用来显示BGP路由的详细信息。
display system internal bgp routing-table vpnv4 network-address { mask | mask-length } verbose
display system internal bgp routing-table vpnv6 network-address prefix-length verbose
Probe视图
ipv4:显示IPv4地址族的BGP路由详细信息。
ipv6:显示IPv6地址族的BGP路由详细信息。
vpnv4:显示VPNv4地址族的BGP路由详细信息。
vpnv6:显示VPNv6地址族的BGP路由详细信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由详细信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP路由详细信息。
display system internal cfd hardware命令用来显示CFD硬件表项的信息。
独立运行模式:
display system internal cfd hardware slot slot-number level level-value [ vlan vlan-id ]
IRF模式:
display system internal cfd hardware chassis chassis-number slot slot-number level level-value [ vlan vlan-id ]
Probe视图
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
level level-value:显示指定MD级别的信息,level-value的取值范围为0~7。
vlan vlan-id:显示指定VLAN的信息,vlan-id的取值范围为1~4094。如果未指定本参数,将显示所有VLAN的信息。
display system internal cfd mep命令用来显示CFD的MEP节点信息。
独立运行模式:
display system internal cfd mep mep-id service-instance instance-id slot slot-number
IRF模式:
display system internal cfd mep mep-id service-instance instance-id chassis chassis-number slot slot-number
Probe视图
mep-id:显示指定MEP上的信息。其中,mep-id表示MEP的编号,取值范围为1~8191。
service-instance instance-id:显示指定服务实例中的信息。其中,instance-id表示服务实例的编号,取值范围为1~32767。
display system internal dbm命令用来显示数据库信息。
独立运行模式:
display system internal dbm { all | name dbname [ key kename ] } { slot slot-number }
IRF模式:
display system internal dbm { all | name dbname [ key kename ] } { chassis chassis-number slot slot-number }
Probe视图
chassis chassis-number slot slot-number:表示设备在IRF中的成员编号。(IRF模式)
name dbname:指定数据库名。
key kename:指定key的名称,在数据库中以key名称标识一项数据。
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
独立运行模式:
display system internal ethernet character { global | interface interface-type interface-number } slot slot-number
IRF模式:
display system internal ethernet character { global | interface interface-type interface-number } chassis chassis-number slot slot-number
Probe视图
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:显示指定接口上的以太特征。接口特征表示对设备上该接口收发的报文进行匹配。
slot slot-number:显示指定单板的以太网统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的以太网统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如STP,LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
独立运行模式:
display system internal ethernet controlblock interface interface-type interface-number slot slot-number
IRF模式:
display system internal ethernet controlblock interface interface-type interface-number chassis chassis-number slot slot-number
Probe视图
interface interface-type interface-number:显示指定接口的链路控制信息。interface-type interface-number表示接口类型和接口编号。
display system internal evb global-info命令用来显示EVB子线程的信息。
Probe视图
display system internal evb kernel命令用来显示EVB内核的数据信息。
独立运行模式:
display system internal evb kernel slot slot-number interface s-channel { interface-number:channel-id | interface-number:channel-id.vsi-local-id }
IRF模式:
display system internal evb kernel chassis chassis-number slot slot-number interface s-channel { interface-number:channel-id | interface-number:channel-id.vsi-local-id }
Probe视图
interface s-channel { interface-number:channel-id | interface-number:channel-id.vsi-local-id }:显示指定S通道接口或VSI接口上的信息。其中,interface-number为S通道所在端口的编号;channel-id为S通道的编号,取值范围为已创建S通道的编号;vsi-local-id为VSI本地编号,取值范围为已创建的VSI本地编号。
display system internal fc fib命令用来显示FC FIB相关信息。
display system internal fc fib [ fcid [ mask-length ] ] vsan vsan-id [ slot slot-number ]
IRF模式:
Probe视图
fcid:显示指定目的FC地址的FC FIB表项信息,取值范围为0x000000~0xFFFFFF(十六进制)。
mask-length:目的FC地址掩码长度,取值范围为0~24。
vsan vsan-id:显示指定VSAN内的FC FIB相关信息。vsan-id的取值范围为1~3839。
slot slot-number:显示指定单板上的FC FIB相关信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上的FC FIB相关信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的FC FIB相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上的FC FIB相关信息。(IRF模式)
display system internal fib prefix命令用来显示IPv4 FIB前缀基本信息。
display system internal fib prefix [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4 FIB前缀基本信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB前缀基本信息。
slot slot-number:显示指定单板上的IPv4 FIB前缀基本信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB前缀基本信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv4 FIB表项信息。
display system internal fib prefix [ vpn-instance vpn-instance-name ] entry-status status slot slot-number
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的下驱动失败或者待老化的IPv4 FIB表项信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB表项信息。
entry-status status:用于匹配FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv4 FIB表项信息,“F”表示下刷驱动失败的IPv4 FIB表项信息。
slot slot-number:显示指定单板上的下驱动失败或者待老化的IPv4 FIB表项信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的下驱动失败或者待老化的IPv4 FIB表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib prefix ip命令用来显示IPv4 FIB前缀详细信息。
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip [ mask | mask-length ] slot slot-number
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4 FIB前缀详细信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB前缀详细信息。
ip:显示指定IP地址的IPv4 FIB前缀详细信息。
mask:IP地址掩码。
mask-length:IP地址掩码长度,即掩码中连续“1”的个数。
slot slot-number:显示指定单板上的IPv4 FIB前缀详细信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB前缀详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib running-status命令用来显示IPv4 FIB、IPv6 FIB、VN全局信息。
display system internal fib running-status slot slot-number
IRF模式:
display system internal fib running-status chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的IPv4 FIB、IPv6 FIB、VN全局信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB、IPv6 FIB、VN全局信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib statistics命令用来显示IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。
display system internal fib statistics slot slot-number
IRF模式:
display system internal fib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib vn命令用来显示VN表项信息。
display system internal fib vn [ next-hop next-hop ] slot slot-number
display system internal fib vn { id id | index index } slot slot-number
IRF模式:
display system internal fib vn [ next-hop next-hop ] chassis chassis-number slot slot-number
display system internal fib vn { id id | index index } chassis chassis-number slot slot-number
Probe视图
id id:按指定VN ID显示VN表项详细信息。
index index:按指定VN索引显示VN表项详细信息。
next-hop next-hop:显示指定下一跳的VN表项基本信息,可以输入IPv4、IPv6地址。
slot slot-number:显示指定单板上的VN表项信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的VN表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib vn entry-status命令用来显示指定状态的VN表项基本信息。
display system internal fib vn entry-status status slot slot-number
IRF模式:
display system internal fib vn entry-status status chassis chassis-number slot slot-number
Probe视图
entry-status status:按指定状态显示VN信息。取值范围为<A,F,R>,“A”表示待老化表项,“F”表示下驱动失败表项,“R”表示由于被关联而未删除的表项。
slot slot-number:显示指定单板上的指定状态的VN表项基本信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定状态的VN表项基本信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal fib vn reference命令用来显示前缀关联VN的信息。
display system internal fib vn { id id | index index } reference slot slot-number
IRF模式:
Probe视图
id id:按指定VN ID显示VN信息。
index index:按指定VN指针显示VN信息。
reference:显示关联该VN的前缀信息。
slot slot-number:显示指定单板上的前缀关联VN的信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的前缀关联VN的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ha service命令用来显示某个业务进程的HA统计信息,包括业务注册的基本信息、各控制消息接收处理统计、各数据的发送统计和接收统计等。
display system internal ha service socket
Probe视图
socket:所要查询的业务进程的socket,可通过display system internal ha service-group sg-name查询。
display system internal ha service-group命令用来显示当前到HA模块注册的所有SG信息,包括SG的名称、SG的状态、SU的个数等信息。
display system internal ha service-group [ name [ instance ] ]
Probe视图
instance:SG实例的名称(如果有实例)。
display system internal ha statistics命令用来显示HA各子模块的统计信息。
display system internal ha statistics { submodule { fsm | service } | summary }
Probe视图
submodule:HA子模块的信息。
fsm:FSM子模块的信息。
service:service子模块的信息。
summary:全局统计信息。
display system internal ifmgr brief命令用来显示接口基本信息同步的信息。
display system internal ifmgr brief { para slot slot-number | help }
IRF模式:
display system internal ifmgr brief { para chassis chassis-number slot slot-number | help }
Probe视图
para:指定显示时的参数,为具体的接口索引值。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
display system internal ifmgr down命令用来显示已注册的down类型。
display system internal ifmgr down [ slot slot-number ]
IRF模式:
display system internal ifmgr down [ chassis chassis-number slot slot-number ]
Probe视图
slot slot-number:表示单板所在的槽位号。不指定该参数时,则表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。(IRF模式)
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
display system internal ifmgr entry { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr entry { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。表示接口名或接口索引,具体格式为:1*接口索引,2*接口名。
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
display system internal ifmgr event { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr event { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。para为具体事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,具体格式为:event*type。
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
display system internal ifmgr hotplug [ para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr hotplug [ para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。当不指定参数时显示所有板的热插拔信息;当指定参数时,可直接指定槽位号或者按照slot-number*subslot-number的格式指定槽位号和子槽位号,用于显示该板或子卡的热插拔信息。
slot slot-number:表示单板所在的槽位号。不指定该参数时,则表示主用主控板。用于显示slot-number单板上记录的热插拔信息。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。用于显示slot-number单板上记录的热插拔信息。(IRF模式)
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
display system internal ifmgr index { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr index { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。为接口索引值的十进制形式。
display system internal ifmgr list命令用来显示接口的名称和索引。
display system internal ifmgr list [ para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr list [ para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。不指定时显示所有类型接口的信息;当指定时para为具体接口类型。
display system internal ifmgr mdc命令用来显示MDC接口分配相关信息。
display system internal ifmgr mdc { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr mdc { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。合法参数形式有如下四种:1*接口所在分组的编号、2*接口名、3*MDC的编号、4*槽位号。
display system internal ifmgr name命令用来显示接口名字解析树信息。
display system internal ifmgr name { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr name { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。为接口全名或简名。
display system internal ifmgr type命令用来按类型显示接口的信息。
display system internal ifmgr type { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr type { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:表示接口类型,为1~127个字符的字符串。
display system internal ip address命令用来显示地址详细信息
IRF模式:
Probe视图
ip-address ip-address:显示指定IP地址。
vpn-instance vpn-instance-name: 显示指定VPN的IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
slot slot-number:显示指定单板上的IP地址,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IP地址,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ip source binding命令用来显示详细的IPv4绑定表项信息。
独立运行模式:
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server | dhcp-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] slot slot-number
IRF模式:
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcp-relay | dhcp-server | dhcp-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] chassis chassis-number slot slot-number
Probe视图
· static:显示配置的静态绑定表项。
· vpn-instance vpn-instance-name:显示指定VPN的动态绑定表项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示公网的动态绑定表项。
· dhcp-relay:显示DHCP中继模块生成的动态绑定表项。
· dhcp-server:显示DHCP服务器模块生成的动态绑定表项。
· dhcp-snooping:显示DHCP Snooping模块生成的动态绑定表项。
· ip-address ip-address:显示指定IPv4地址的绑定表项,ip-address表示绑定的IPv4地址。
· mac-address mac-address:显示指定MAC地址的绑定表项,mac-address表示绑定的MAC地址,格式为H-H-H。
· vlan vlan-id:显示指定VLAN的绑定表项,vlan-id表示绑定的VLAN ID,取值范围为1~4094。
· interface interface-type interface-number:显示指定接口的绑定表项,interface-type interface-number表示绑定的接口类型和接口编号。
· slot slot-number:显示存储在指定单板上的绑定表项,slot-number表示单板所在的槽位号。(独立运行模式)
· chassis chassis-number slot slot-number:显示存储在指定成员设备上指定单板的绑定表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
· 如果不指定任何参数,则显示公网所有接口的IPv4绑定表项。
· 如果不指定接口号和单板所在槽位号,则显示主控板存储的所有接口的IPv4绑定表项。(独立运行模式)
· 如果不指定接口号和成员设备编号,则显示当前成员设备的主控板存储的IPv4绑定表项。(IRF模式)
display system internal ip vpn-binding命令用来显示内核的VPN实例绑定信息。
display system internal ip vpn-binding slot slot-number
IRF模式:
display system internal ip vpn-binding chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的内核VPN实例绑定信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例绑定信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ip vpn-instance命令用来显示内核的VPN实例信息。
display system internal ip vpn-instance [ instance-name vpn-instance-name ] slot slot-number
IRF模式:
display system internal ip vpn-instance [ instance-name vpn-instance-name ] chassis chassis-number slot slot-number
Probe视图
instance-name vpn-instance-name:显示指定VPN实例的内核信息。vpn-instance-name表示VPN实例的名称,为1~31个字符的字符串,区分大小写。
slot slot-number:显示指定单板上的内核VPN实例信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ip vpn-instance inactive命令用来显示正在删除中的VPN实例的信息。
Probe视图
display system internal ip vpn-instance statistics命令用来显示内核VPN实例的统计信息。
display system internal ip vpn-instance statistics slot slot-number
IRF模式:
display system internal ip vpn-instance statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的内核VPN实例统计信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ipv6 address命令用来显示IPv6地址详细信息
IRF模式:
Probe视图
ipv6-address:显示的指定IPv6地址的详细信息。
vpn-instance vpn-instance-name: 显示指定VPN的IPv6地址。
interface interface-type interface-number:显示指定接口的IPv6地址,interface-type interface-number表示接口类型和接口编号。
slot slot-number:显示指定单板上的IPv6地址,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6地址,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ipv6 fib prefix命令用来显示IPv6 FIB前缀基本信息。
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB前缀基本信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB前缀基本信息。
display system internal ipv6 fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv6 FIB表项信息信息。
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB表项信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB表项信息。
entry-status status:用于匹配IPv6 FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv6 FIB表项,“F”表示下刷驱动失败的IPv6 FIB表项。
slot slot-number:slot-number表示单板所在的槽位号。(独立运行模式)
display system internal ipv6 fib prefix ipv6命令用来显示IPv6 FIB前缀详细信息。
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB前缀详细信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB前缀详细信息。
ipv6:显示目的地址为指定IPv6地址的IPv6 FIB前缀详细信息。
prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
display system internal ipv6 l2-multicast ip forwarding verbose命令用来显示IPv6二层组播的IP组播组详细信息。
IRF模式:
Probe视图
group ipv6-group-address:显示指定IPv6组播组的信息。如果未指定本参数,将显示所有IPv6组播组的信息。
source ipv6-source-address:显示指定IPv6组播源的信息。如果未指定本参数,将显示所有IPv6组播源的信息。
vlan vlan-id:显示指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的信息。(IRF模式)
display system internal ipv6 l2-multicast ip verbose命令用来显示IPv6二层组播的IP组播组详细信息。
IRF模式:
Probe视图
display system internal ipv6 l2-multicast ipc statistics命令用来显示IPv6二层组播板间消息的统计信息。
display system internal ipv6 l2-multicast ipc statistics [ slot slot-number ]
IRF模式:
display system internal ipv6 l2-multicast ipc statistics [ chassis chassis-number slot slot-number ]
Probe视图
display system internal ipv6 l2-multicast mac forwarding verbose命令用来显示IPv6二层组播的MAC转发表详细信息。
IRF模式:
Probe视图
mac-address:显示指定MAC组播组的信息。如果未指定本参数,将显示所有MAC组播组的信息。
display system internal ipv6 l2-multicast mac verbose命令用来显示IPv6二层组播的MAC组播组详细信息。
IRF模式:
Probe视图
display system internal ipv6 mrib interface statistics命令用来显示IPv6 MRIB所维护接口的统计信息,这些接口包括配置了IPv6 PIM、MLD等IPv6组播协议的接口以及注册接口、InLoopBack0接口、Null0接口等内部接口。
display system internal ipv6 mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例上IPv6 MRIB所维护接口的统计信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例上IPv6 MRIB所维护接口的统计信息。
display system internal ipv6 mrib mbr interface命令用来显示IPv6 MRIB进程中MBR(Multicast Border Router,组播边界路由器)模块维护的组加入信息。
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
interface interface-type interface-number:显示指定接口上的信息。
source ipv6-source-address:显示指定组播源的IPv6 MBR表项信息。如果未指定本参数,将不显示IPv6 MBR表项信息。
group ipv6-group-address:显示指定组播组的IPv6 MBR表项信息,ipv6-group-address的取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将不显示IPv6 MBR表项信息。
display system internal ipv6 multicast forwarding vlan reference命令用来显示VLAN出接口与IPv6二层组播表项之间的映射关系。
IRF模式:
Probe视图
display system internal ipv6 multicast forwarding-table dummy命令用来显示IPv6组播临时转发表的信息。
IRF模式:
Probe视图
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息
prefix-length:指定IPv6组播源或IPv6组播组地址的前缀长度。对于IPv6组播源地址,其取值范围为0~128,缺省值为128;对于IPv6组播组地址,其取值范围为8~128,缺省值为128。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的信息。(IRF模式)
statistics:显示统计信息。
display system internal ipv6 multicast forwarding-table verbose命令用来显示IPv6组播转发表的详细信息。
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6组播转发项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6组播转发项。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6组播转发项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的IPv6组播转发表项。(IRF模式)
incoming-interface:显示指定入接口的IPv6组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播转发项。
outgoing-interface:显示指定出接口的IPv6组播转发项。
exclude:显示出接口列表中不包含指定接口的IPv6组播转发项。
include:显示出接口列表中包含指定接口的IPv6组播转发项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播转发项。
slot slot-number:显示指定单板上的IPv6组播转发项,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的IPv6组播转发表项。(独立运行模式)
display system internal ipv6 multicast-vlan forwarding-table verbose命令用来显示IPv6组播VLAN转发表的详细信息。
IRF模式:
Probe视图
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
subvlan vlan-id:显示指定子VLAN的信息。如果未指定本参数,将显示所有子VLAN的信息。
display system internal ipv6 pathmtu 命令用来显示分布式各板IPv6的PMTU信息,信息全局同步
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的IPv6 PMTU信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的IPv6 PMTU信息。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有公网的PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
count:显示PMTU表项数目。
slot slot-number:显示指定单板上的所有PMTU表项。slot-number表示单板的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的所有PMTU表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。(IRF模式)
如果未指定任何可选参数,将显示设备上所有的PathMTU信息。
display system internal ipv6 pbr fib命令用来显示用户态下IPv6下一跳的配置信息。
独立运行模式:
display system internal ipv6 pbr fib [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
display system internal ipv6 pbr fib [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
不显示用户态下IPv6下一跳的配置信息。
Probe视图
vpn-instance vpn-instance-name:显示用户态下指定私网内IPv6下一跳的配置信息,不指定该参数为公网内下一跳。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定单板指定私网内IPv6下一跳的配置信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的指定私网内IPv6下一跳的配置信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ipv6 pbr kernel policy用于显示内核态下指定单板上的IPv6策略路由信息。
独立运行模式:
display system internal ipv6 pbr kernel policy [ policy-name [ setup ] ] slot slot-number
IRF模式:
display system internal ipv6 pbr kernel policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
不显示内核态下的IPv6策略路由信息。
Probe视图
policy policy-name:显示内核态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息
slot slot-number:显示内核态下指定单板上的内核态下IPv6策略路由信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示内核态下指定成员设备上指定单板的IPv6策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ipv6 pbr policy用于显示用户态下的IPv6策略路由信息。
独立运行模式:
display system internal ipv6 pbr policy [ policy-name [ setup ] ] slot slot-number
IRF模式:
display system internal ipv6 pbr policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
不显示用户态下的IPv6策略路由信息。
Probe视图
policy policy-name:显示用户态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息
slot slot-number:显示用户态下指定单板上的IPv6策略路由信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的IPv6策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ipv6 pim interface命令用来显示IPv6 PIM进程中路由管理LIB所维护的接口信息。
display system internal ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number [ address | gateway | prefix] ] | ipv6-address prefix-length ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
interface-type interface-number:显示指定接口的信息。如果未指定本参数,将显示所有接口的信息。
address:指定IPv6地址。
gateway:指定IPv6网关。
prefix:指定IPv6前缀。
ipv6-address:显示指定IPv6地址的信息。如果未指定本参数,将显示所有IPv6地址的信息。::为保留地址,用户不感知。
prefix-length:表示前缀长度,取值范围为0~128。
display system internal ipv6 pim rp命令用来显示IPv6 PIM的RP统计信息。
display system internal ipv6 pim [ vpn-instance vpn-instance-name ] rp
Probe视图
display system internal ipv6 pim thread命令用来显示IPv6 PIM线程的统计信息。
display system internal ipv6 pim thread { event | main | route }
Probe视图
event:显示IPv6 PIM事件线程的统计信息。
main:显示IPv6 PIM主线程的统计信息。
route:显示IPv6 PIM路由线程的统计信息。
display system internal ipv6 rawip命令用来显示设备上所有IPv6 RawIP连接的摘要信息。
display system internal ipv6 rawip slot slot-number
IRF模式:
display system internal ipv6 rawip chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 RawIP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 RawIP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号。(IRF模式)
display system internal ipv6 rib event attribute 命令用来显示IPv6路由协议关心路由属性变化的信息。
Probe视图
display system internal ipv6 rib event policy命令用来显示IPv6路由协议关注满足指定路由策略的路由变化信息。
Probe视图
display system internal ipv6 rib event prefix命令用来显示IPv6路由协议关注路由前缀的信息。
Probe视图
display system internal ipv6 rib event protocol命令用来显示IPv6按协议注册信息。
display system internal ipv6 rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
display system internal ipv6 rib event statistics用来显示IPv6路由上报路由协议、下刷FIB的统计信息。
display system internal ipv6 rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
display system internal ipv6 rib log命令用来显示IPv6 RIB日志信息。
display system internal ipv6 rib log [ reverse ] [ standby slot slot-number ]
display system internal ipv6 rib event log [ standby slot slot-number ]
IRF模式:
display system internal ipv6 rib log [ reverse ] [ standby chassis chassis-number slot slot-number ]
display system internal ipv6 rib event log [ standby chassis chassis-number slot slot-number ]
Probe视图
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
standby slot slot-number:显示备份的指定单板RIB的日志信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB的日志信息。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上RIB的日志信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB的日志信息。(IRF模式)
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志记录。
display system internal ipv6 rib nib log [ reverse ] [ standby slot slot-number ]
IRF模式:
Probe视图
nib:显示IPv6 NIB子模块的运行状态。
standby slot slot-number:显示备份的指定单板NIB子模块的运行状态日志,slot-number表示单板所在的槽位号。如果未指定本参数,将显示NIB子模块的运行状态日志。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上NIB子模块的运行状态日志,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示NIB子模块的运行状态日志。(IRF模式)
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
IRF模式:
Probe视图
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
standby slot slot-number:显示备份的指定单板IPv6路由表前缀信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv6路由表前缀信息。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上IPv6路由表前缀信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv6路由表前缀信息。(IRF模式)
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
display system internal ipv6 rib summary [ standby slot slot-number ]
IRF模式:
display system internal ipv6 rib summary [ standby chassis chassis-number slot slot-number ]
Probe视图
standby slot slot-number:显示备份的指定单板的RIB统计信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB统计信息。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的RIB统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示RIB统计信息。(IRF模式)
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
Probe视图
ipv6-address:IPv6地址。
display system internal ipv6 route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
display system internal ipv6 route-direct log命令用来显示IPv6直连路由日志信息。
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:IPv6直连路由NIB子模块相关日志。
display system internal route-direct log命令用来显示IPv6直连路由日志信息。
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
display system internal ipv6 source binding命令用来显示详细的IPv6绑定表项信息。
独立运行模式:
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] slot slot-number
IRF模式:
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [ dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] chassis chassis-number slot slot-number
Probe视图
· dhcpv6-snooping:显示DHCPv6 Snooping模块生成的动态绑定表项。
· ip-address ipv6-address:显示指定IPv6地址的绑定表项,ipv6-address表示绑定的IPv6地址。
· 如果不指定任何参数,则显示公网所有接口的IPv6绑定表项。
· 如果不指定接口号和单板所在槽位号,则显示主控板存储的所有接口的IPv6绑定表项。(独立运行模式)
· 如果不指定接口号和成员设备编号,则显示当前成员设备的主控板存储的IPv6绑定表项。(IRF模式)
display system internal ipv6 tcp命令用来显示设备上所有IPv6 TCP连接的摘要信息。
display system internal ipv6 tcp slot slot-number
IRF模式:
display system internal ipv6 tcp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 TCP连接的摘要信息。slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 TCP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(IRF模式)
display system internal ipv6 udp命令用来显示设备上所有IPv6 UDP连接的摘要信息。
display system internal ipv6 udp slot slot-number
IRF模式:
display system internal ipv6 udp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 UDP连接的摘要信息。slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 UDP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(IRF模式)
display system internal isis import-route命令用来显示IS-IS的IPv4引入路由表。
display system internal isis import-route [ ipv4 ] [ process-id ] [ standby slot slot-number ]
Probe视图
ipv4:显示IS-IS的IPv4引入路由表。如果不指定该参数,显示IPv4引入路由表。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程引入路由表。 如果未指定IS-IS进程号,将显示所有IS-IS进程引入路由表。
standby slot slot-number:显示备份的指定成员设备IS-IS的IPv4引入路由表,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的IPv4引入路由表。
display system internal isis import-route ipv6命令用来显示IS-IS的IPv6引入路由表。
display system internal isis import-route ipv6 [ process-id ] [ standby slot slot-number ]
Probe视图
standby slot slot-number:显示备份的指定成员设备IS-IS的IPv6引入路由表,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的IPv6引入路由表。
display system internal isis interface命令用来显示接口的IPv4信息。
display system internal isis interface [ ipv4 ] [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
ipv4:显示接口的IPv4信息。如果未指定该参数,显示接口的IPv4信息。
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
display system internal isis interface ipv6命令用来显示接口的IPv6信息。
display system internal isis interface ipv6 [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
display system internal isis nib命令用来显示IS-IS的IPv4路由下一跳信息。
display system internal isis nib [ ipv4 ] [ nib-id ] [ verbose ]
Probe视图
ipv4:显示IS-IS的IPv4下一跳信息。如果不指定该参数,显示IPv4下一跳信息。
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果不指定,显示所有下一跳信息。
verbose:显示下一跳详细信息。
display system internal isis nib ipv6命令用来显示IS-IS的IPv6路由下一跳信息
display system internal isis nib ipv6 [ nib-id ] [ verbose ]
Probe视图
verbose:显示下一跳详细信息。
display system internal isis nib log命令用来显示IS-IS路由下一跳日志信息。
Probe视图
display system internal isis prefix命令用来显示IS-IS的IPv4前缀信息。
display system internal isis prefix [ ipv4 ] [ [ level-1 | level-2 ] | [ ip-address mask-length ] ] * [ process-id ] [ standby slot slot-number ]
Probe视图
ipv4:显示IS-IS的IPv4前缀信息。如果不指定该参数,显示IPv4前缀信息。
level-1:显示IS-IS的Level-1前缀信息。如果未指定级别,将同时显示Level-1和Level-2的前缀信息。
level-2:显示IS-IS的Level-2前缀信息。如果未指定级别,将同时显示Level-1和Level-2的前缀信息。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程的前缀信息。如果未指定IS-IS进程号,将显示所有IS-IS进程的前缀信息。
standby slot slot-number:显示备份的指定成员设备IS-IS的IPv4前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的IPv4前缀信息。
display system internal isis prefix ipv6命令用来显示IS-IS的IPv6前缀信息。
display system internal isis prefix ipv6 [ [ level-1 | level-2 ] | [ ipv6-address prefix-length ] ] * [ process-id ] [ standby slot slot-number ]
standby slot slot-number:显示备份的指定成员设备IS-IS的IPv6前缀信息,slot-number表示设备在IRF中的成员编号。如果未指定本参数,将显示IS-IS的IPv6前缀信息。
display system internal isis status命令用来显示IS-IS的协议全局状态信息。
Probe视图
Probe视图
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
独立运行模式:
display system internal kernel memory dump address address-hex length memory-length [ slot slot-number ]
IRF模式:
display system internal kernel memory dump address address-hex length memory-length [ chassis chassis-number slot slot-number ]
Probe视图
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
slot slot-number:表示单板所在的槽位号,不指定表示主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定表示全局主用主控板。(IRF模式)
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
独立运行模式:
display system internal kernel memory pool [ name name-string ] [ slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ slot slot-number ]
IRF模式:
display system internal kernel memory pool [ name name-string ] [ chassis chassis-number slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ chassis chassis-number slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ chassis chassis-number slot slot-number ]
Probe视图
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
不指定name和tag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
display system internal l2-multicast ip forwarding verbose命令用来显示二层组播的IP转发表详细信息。
IRF模式:
Probe视图
group group-address:显示指定组播组的信息。如果未指定本参数,将显示所有组播组的信息。
source source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
display system internal l2-multicast ip verbose命令用来显示二层组播的IP组播组详细信息。
IRF模式:
Probe视图
display system internal l2-multicast ipc statistics命令用来显示二层组播板间消息的统计信息。
display system internal l2-multicast ipc statistics [ slot slot-number ]
IRF模式:
display system internal l2-multicast ipc statistics [ chassis chassis-number slot slot-number ]
Probe视图
display system internal l2-multicast mac forwarding verbose命令用来显示二层组播的MAC转发表详细信息。
IRF模式:
Probe视图
display system internal l2-multicast mac verbose命令用来显示二层组播的MAC组播组详细信息。
IRF模式:
Probe视图
display system internal l2vpn l2vfib record命令用来显示L2VPN L2VFIB模块记录的信息,包括L2VFIB模块收到的信息、L2VFIB通知驱动的信息、驱动返回的信息等。
display system internal l2vpn l2vfib record [ start start-number ] slot slot-number
IRF模式:
display system internal l2vpn l2vfib record [ start start-number ] chassis chassis-number slot slot-number
Probe视图
start start-number:从指定位置开始显示记录信息,start-number的取值范围为0~10000。
slot slot-number:显示指定单板上的记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal l2vpn l2vfib statistics命令用来显示L2VPN L2VFIB模块的统计信息。
display system internal l2vpn l2vfib statistics slot slot-number
IRF模式:
display system internal l2vpn l2vfib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的L2VPN L2VFIB模块统计信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的L2VPN L2VFIB模块统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal link-aggregation global命令用来显示聚合模块的系统内部全局信息。
display system internal link-aggregation slot slot-number global
IRF模式:
display system internal link-aggregation chassis chassis-number slot slot-number global
Probe视图
chassis chassis-number slot slot-number:表示设备及单板的位置。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号列表。(IRF模式)
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
IRF模式:
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
interface-number:聚合接口的编号。必须是当前已经创建的聚合接口编号。
interface-type interface-number:指定聚合组的成员端口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
lacp:动态聚合数据。
lacppdu:LACP报文统计值。
· 如果未指定kernel、lacp、lacppdu和statistics参数,则显示LAGG主线程中接口的基本数据。
· 部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
display system internal lipc lcmp statistics命令用来显示LIPC LCMP全局统计信息,包括收发包计数和错误计数。
display system internal lipc lcmp statistics [ lip lip ]
Probe视图
lip lip :表示远端节点号,取值范围为0~32767。
display system internal lipc lgmp group命令用来显示一个指定组播组信息,包含成员信息和组播组相关的统计信息。
display system internal lipc lgmp group group [ lip lip ]
Probe视图
group group:表示组播组号,取值范围为0~4294967295。
lip lip:表示远端节点号,取值范围为0~32767。
display system internal lipc lgmp group-list命令用来查看系统中所有已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
display system internal lipc lgmp group-list [ lip lip ]
Probe视图
display system internal lipc lgmp physical-group命令用来显示指定的硬件组播组信息。
display system internal lipc lgmp physical-group phy [ lip lip ]
Probe视图
physical-group phy:表示硬件组播组ID,取值范围为0~4294967295。
display system internal lipc lgmp physical-group-list命令用来显示所有的硬件组播组信息,以便了解硬件组播组的使用情况。
display system internal lipc lgmp physical-group-list [ lip lip ]
Probe视图
display system internal lipc lgmp statistics命令用来显示LIPC LGMP模块的统计信息。
display system internal lipc lgmp statistics [ lip lip ]
Probe视图
display system internal lipc lip statistics命令用来显示LIPC LIP全局统计信息。包括LIP报文的收发计数和出错计数。
display system internal lipc lip statistics [ lip lip ]
Probe视图
display system internal lipc loop statistics命令用来显示本地环回的统计信息。
display system internal lipc loop statistics [ lip lip ]
Probe视图
display system internal lipc mtcp group命令用来显示LIPC某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
display system internal lipc mtcp group group { statistics | member | history } [ lip lip ]
Probe视图
statistics:显示本地节点某个组播组的统计信息。
member:显示本地节点某个组播组的成员信息。
history:显示本地节点某个组播组的历史变迁轨迹。
group group:组播成员号,取值范围为0~4294967295。
display system internal lipc mtcp performance命令显示LIPC组播性能信息。
display system internal lipc mtcp performance [ lip lip ]
显示本地节点LIPC组播性能信息。
Probe视图
必须打开相应得性能统计开关后,该命令才能输出性能信息。
· lipc performance
display system internal lipc mtcp statistics命令用来显示LIPC组播的全局统计信息。
display system internal lipc mtcp statistics [ lip lip ]
Probe视图
display system internal lipc pcb statistics命令用来显示LIPC PCB模块全局统计信息。
display system internal lipc pcb statistics [ lip lip ]
Probe视图
display system internal lipc physical命令用来显示驱动适配层的全局统计信息。
display system internal lipc physical [ lip lip ]
Probe视图
用于统计LIPC与驱动交互的各种信息,包括收发包计数,驱动错误计数和驱动上报事件计数。
display system internal lipc publish global-cb命令用来显示LIPC Publish模块全局控制块信息。
display system internal lipc publish global-cb [ lip lip ]
Probe视图
一般用于诊断Pub模块在某个节点上是否乱序。
display system internal lipc publish statistics命令用来显示LIPC PUBLISH模块统计信息。
display system internal lipc publish statistics [ lip lip ]
Probe视图
display system internal lipc stcp event命令用来显示LIPC单播事件的信息。
display system internal lipc stcp event { sync | trans } [ lip lip ]
Probe视图
sync:显示LIPC单播控制报文事件信息。
trans:显示LIPC单播数据报文事件信息。
该命令主要记录本节点和其他节点的连接/DACK/销毁/时序交互信息。当设备上连接很多时,该命令记录的条目很容易满(512条),此时会将最老的记录清除掉。因此,发现问题时,应当尽早执行该命令,获取事件信息,便于定位分析。
display system internal lipc stcp global-server命令显示LIPC单播的全局知名端口信息。
display system internal lipc stcp global-server [ lip lip ]
Probe视图
display system internal lipc stcp links命令用来显示单播的连接信息。包括收发包信息、状态信息、缓存信息等。
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip]
Probe视图
all:表示显示本节点所有的单播连接信息。
detail port:表示指定端口号的具体信息,取值范围为0~65535。
global gport:表示全局知名端口号,取值范围为100~8100。
listening:表示显示本节点处于侦听状态的连接。
local lport:表示本地端口号,取值范围为10100~65535。
singledetail lport rport:表示指定本地端口号和目的端口号的具体信息,取值范围为0~65535。
display system internal lipc stcp performance命令用来显示单播的性能信息。
display system internal lipc stcp performance [ lip lip ]
Probe视图
必须使用lipc performance命令打开相应的性能统计开关后,该命令才能输出性能信息。
· lipc performance
display system internal lipc stcp statistics命令用来显示LIPC单播的全局统计信息。
display system internal lipc stcp statistics [ lip lip ]
Probe视图
display system internal lipc stcp status命令用来显示单播的传输状态。
display system internal lipc stcp status { send | recv } [ lip lip ]
Probe视图
该命令主要记录单播对象的传输序号、ACK序号、发送标志、接收状态。通常用于分析单播数据的可靠传输。
display system internal lipc stream命令用来查看流模式单播的记录信息。
display system internal lipc stream { send | reass | ack } port port [ lip lip ]
Probe视图
send:表示查看指定端口号的发送报文分片记录。
reass:表示查看指定端口号的接收重组队列信息。
ack:表示查看指定端口号的收到ACK的记录。
port port:表示端口号,为0~65535的整数。
display system internal lipc sudp pcb-info命令用来查看SUDP模块的PCB详细信息。
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port port } [ lip lip ]
Probe视图
all-port:表示查看所有SUDP端口号的信息。
global-port:表示查看所有SUDP全局知名端口号的信息。
local-port:表示查看所有SUDP本地端口号的信息。
specific-port port:表示指定端口号,取值范围为0~65535。
display system internal lipc sudp statistics命令用来显示LIPC SUDP模块的全局统计信息。
display system internal lipc sudp statistics [ lip lip ]
Probe视图
display system internal lipc sudp命令用来查看所有SUDP全局知名端口号或本地端口号的信息。
display system internal lipc sudp { global-port | local-port } [ lip lip ]
Probe视图
display system internal lipc topology history命令用来查看LIPC拓扑链接信息的历史变迁记录。
display system internal lipc topology history [ lip lip ]
Probe视图
display system internal lipc topology link命令用来显示LIPC的拓扑链接信息。
display system internal lipc topology link [ lip lip ]
Probe视图
display system internal lipc topology node命令用来查看LIPC拓扑节点相关的统计信息。
display system internal lipc topology node node [ lip lip ]
Probe视图
node node:表示节点号,取值范围为0~32767。
记录了该节点上事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology process-time命令用来查看发生拓扑事件时,通知各个模块耗时。
display system internal lipc topology process-time [ lip lip ]
Probe视图
display system internal lipc topology statistics命令用来查看LIPC拓扑相关的全局统计。
display system internal lipc topology statistics [ lip lip ]
Probe视图
记录了该全局事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology status命令用来显示LIPC节点的拓扑状态信息。
display system internal lipc topology status [ lip lip ]
Probe视图
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
IRF模式:
Probe视图
blackhole:显示黑洞MAC地址表项。
multiport:显示多端口单播MAC地址表项。
multicast:显示组播MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
slot slot-number:显示指定单板的MAC地址信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC地址信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
display system internal mac-address statistics slot slot-number
IRF模式:
display system internal mac-address statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的MAC地址表统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC地址表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mbuf relay statistics命令用来显示MBUF中继模块的统计信息。
独立运行模式:
display system internal mbuf relay statistics slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
IRF模式:
display system internal mbuf relay statistics chassis chassis-number slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
Probe视图
slot slot-number:显示指定单板的MBUF中继模块的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MBUF中继模块的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-id:MBUF中继使用的CPU编号。不指定该参数时,表示当前单板上的所有接CPU。
rcv received-id:MBUF中继接收者的编号。不指定该参数时,表示当前CPU上的所有接收者。
display system internal mbuf命令用来显示MBUF的统计信息。
独立运行模式:
display system internal mbuf statistics slot slot-number
IRF模式:
display system internal mbuf statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的MBUF统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MBUF统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mpls lfib ilm命令用来显示MPLS ILM表项的详细信息。
display system internal mpls lfib ilm label slot slot-number
IRF模式:
display system internal mpls lfib ilm label chassis chassis-number slot slot-number
Probe视图
label:显示指定入标签的ILM表项详细信息,取值范围为16~1048575。
slot slot-number:显示指定单板上的ILM表项详细信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ILM表项详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mpls lfib nhlfe命令用来显示MPLS NHLFE表项详细信息。
display system internal mpls lfib nhlfe nid slot slot-number
IRF模式:
display system internal mpls lfib nhlfe nid chassis chassis-number slot slot-number
Probe视图
nid:显示指定NHLFE表项的详细信息。nid为NHLFE表项索引,取值范围为0~4294967294。
slot slot-number:显示指定单板上的NHLFE表项详细信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的NHLFE表项详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mpls lfib nhlfe reflist命令用来显示MPLS NHLFE反向关联信息。
display system internal mpls lfib nhlfe nid reflist slot slot-number
IRF模式:
display system internal mpls lfib nhlfe nid reflist chassis chassis-number slot slot-number
Probe视图
nid:显示指定NHLFE表项的反向关联信息。nid为NHLFE表项索引,取值范围为0~4294967294。
slot slot-number:显示指定单板上的NHLFE表项的反向关联信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的NHLFE表项的反向关联信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mpls lfib record命令用来显示MPLS LFIB模块记录的信息,包括LFIB模块收到的信息、LFIB通知驱动的信息、驱动返回的信息等。
display system internal mpls lfib record [ start start-number ] slot slot-number
IRF模式:
display system internal mpls lfib record [ start start-number ] chassis chassis-number slot slot-number
Probe视图
start start-number:从指定位置开始显示记录信息,取值范围为0~4096。
display system internal mpls lfib statistics命令用来显示MPLS LFIB的统计信息。
display system internal mpls lfib statistics slot slot-number
IRF模式:
display system internal mpls lfib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的MPLS LFIB统计信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MPLS LFIB统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal mpls lsp-pending命令用来显示协议层发生了变化、但系统内部没有处理完毕的LSP信息。
Probe视图
display system internal mpls statistics命令用来显示LSM的内部处理状态统计信息。
Probe视图
display system internal mrib interface statistics命令用来显示MRIB所维护接口的统计信息,这些接口包括配置了PIM、IGMP等组播协议的接口以及注册接口、InLoopBack0接口、Null0接口等内部接口。
display system internal mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例上MRIB所维护接口的统计信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例上MRIB所维护接口的统计信息。
display system internal mrib mbr命令用来显示MRIB进程中MBR模块维护的组加入信息。
Probe视图
source source-address:显示指定组播源的MBR表项信息。如果未指定本参数,将不显示MBR表项信息。
group group-address:显示指定组播组的MBR表项信息,group-address的取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将不显示MBR表项信息。
display system internal multicast capability命令用来显示组播能力的信息。
display system internal multicast capability [ slot slot-number ]
IRF模式:
display system internal multicast capability [ chassis chassis-number slot slot-number ]
Probe视图
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主控板上的信息。(独立运行模式)
display system internal multicast forwarding vlan reference命令用来显示VLAN出接口与二层组播表项之间的映射关系。
IRF模式:
Probe视图
display system internal multicast forwarding-table dummy命令用来显示组播临时转发表的信息。
IRF模式:
Probe视图
group-address:显示指定组播组的信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
statistics:显示统计信息。
display system internal multicast forwarding-table verbose命令用来显示组播转发表的详细信息。
IRF模式:
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的组播转发项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的组播转发项。
group-address:组播组地址,显示指定组播组的组播转发项,取值范围为224.0.0.0~239.255.255.255。
source-address:组播源地址,显示包含指定组播源的组播转发项。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的组播转发项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的组播转发表项。(IRF模式)
incoming-interface:显示指定入接口的组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的组播转发项。
outgoing-interface:显示指定出接口的组播转发项。
exclude:显示出接口列表中不包含指定接口的组播转发项。
include:显示出接口列表中包含指定接口的组播转发项。
match:显示出接口列表中包含且仅包含指定接口的组播转发项。
slot slot-number:显示指定单板上的组播转发项,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的组播转发表项。(独立运行模式)
display system internal multicast record命令用来显示组播表项的操作记录。
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ slot slot-number ]
IRF模式:
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ chassis chassis-number slot slot-number ]
Probe视图
statistics:显示组播表项操作记录的统计信息。
all:显示组播表项的所有操作记录。
fail:显示组播表项的失败操作记录。
group-address:组播组地址,显示指定组播组的记录。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的记录。
source-address:组播源地址,显示包含指定组播源的记录。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的记录。
item item-list:记录列表,表示一条或多条记录。表示方式为item-list = start-item [ to end-item ]。其中,start-item和end-item的取值范围均为1~500000。
filter:显示指定模式下的组播表项操作记录。
exclude:显示排除满足指定条件的组播表项操作记录。
include:显示包含满足指定条件的组播表项操作记录。
add-l2-ip:表示添加二层IP表项的操作记录。
add-l2-ip-port:表示添加二层IP表项端口的操作记录。
add-l2-ip-slot:表示添加二层IP表项板信息的操作记录。
add-l2-mac:表示添加二层MAC表项的操作记录。
add-l2-mac-port:表示添加二层MAC表项端口的操作记录。
add-l2-mac-slot:表示添加二层MAC表项板信息的操作记录。
add-l3-ipm:表示添加三层组播表项的操作记录。
add-l3-oif:表示添加三层表项出接口的操作记录。
add-l3-port:表示添加三层表项出端口的操作记录。
add-l3-slot:表示添加三层表项分布式转发的出接口板信息的操作记录。
del-l2-ip:表示删除二层IP表项的操作记录。
del-l2-ip-port:表示删除二层IP表项端口的操作记录。
del-l2-ip-slot:表示删除二层IP表项板信息的操作记录。
del-l2-mac:表示删除二层MAC表项的操作记录。
del-l2-mac-port:表示删除二层MAC表项端口的操作记录。
del-l2-mac-slot:表示删除二层MAC表项板信息的操作记录。
del-l3-ipm:表示删除三层组播表项的操作记录。
del-l3-oif:表示删除三层表项出接口的操作记录。
del-l3-port:表示删除三层表项出端口的操作记录。
del-l3-slot:表示删除三层表项分布式转发的出接口板信息的操作记录。
set-l3-iif:表示设置三层表项入接口的操作记录。
ipmc-type-all:表示全部类型。
verbose:显示详细信息。如果记录的出接口和出端口显示不全时,需要指定本参数。
display system internal multicast-vlan forwarding-table verbose命令用来显示组播VLAN转发表的详细信息。
IRF模式:
Probe视图
mask { mask-length | mask }:指定组播组的掩码长度或掩码。mask-length的取值范围为4~32,缺省值为32;mask的缺省值为255.255.255.255。
mask { mask-length | mask }:指定组播源的掩码长度或掩码。mask-length的取值范围为0~32,缺省值为32;mask的缺省值为255.255.255.255。
display system internal nd dad命令用来显示DAD链信息。
display system internal nd dad slot slot-number
IRF模式:
display system internal nd dad chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的DAD链信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的DAD链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal nd entry命令用来显示各板上的ND表项信息。
display system internal nd entry slot slot-number
IRF模式:
display system internal nd entry chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ND表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ND表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal nd ifcb命令用来显示接口的ND控制块信息。
display system internal nd ifcb interface interface-type interface-number slot slot-number
IRF模式:
Probe视图
interface interface-type interface-number:显示指定接口的ND控制块信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板的ND控制块信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ND控制块信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal nd machash命令用来显示各板上的machash表项。
display system internal nd machash vlan vlan-id ipv6-address slot slot-number
IRF模式:
display system internal nd machash vlan vlan-id ipv6-address chassis chassis-number slot slot-number
Probe视图
vlan vlan-id: 显示指定vlan的信息。vlan-id表示指定vlan的id。
IPv6-address:指定IPv6地址。
slot slot-number:显示指定单板的machash表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的machash表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal nd probe命令用来显示探测链信息。
display system internal nd probe slot slot-number
IRF模式:
display system internal nd probe chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的探测链信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的探测链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal nd reload命令用来显示重刷链信息。
display system internal nd reload slot slot-number
IRF模式:
display system internal nd reload chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的重刷链信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的重刷链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal nd static命令用来显示ND静态配置。
display system internal nd static ipv6-address interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
display system internal nd statistics命令用来显示各板上的ND统计信息。
display system internal nd statistics slot slot-number
IRF模式:
display system internal nd statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ND统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ND统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal ospf event-log命令用来显示OSPF的日志信息。
display system internal ospf event-log { gr | interface | nib | notify }
Probe视图
gr:显示GR日志。
interface:显示接口事件日志。
nib:显示NIB日志。
notify:显示接口通知日志。
display system internal ospf interface命令用来显示接口相关信息。
display system internal ospf interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例下接口相关信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的信息。
mask:网络掩码,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
display system internal ospf lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospf [ process-id ] lsdb { asbr | ase | nssa | summary }
Probe视图
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的LSA map信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的map信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的map信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的map信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的map信息。
display system internal ospf nib命令用来显示NIB分配的下一跳信息。
display system internal ospf nib [ nib-id ] [ verbose ]
Probe视图
nib-id:路由下一跳信息的ID值,取值范围1~FFFFFFFF。
verbose:显示NIB详细信息。
display system internal ospf prefix命令用来显示OSPF中前缀对应的LSA信息。
display system internal ospf [ process-id ] prefix [ ip-address { mask | mask-length } ]
Probe视图
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的前缀信息。
ip-address:路由的目的IP地址。如果未指定本参数,将显示所有前缀的信息。
mask:网络掩码,点分十进制格式。
display system internal ospf status命令用来显示OSPF协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
display system internal ospfv3 event-log命令用来显示OSPFv3的各种日志信息。
display system internal ospfv3 event-log { gr | nib | rib }
Probe视图
gr:显示GR状态机变迁记录。
nib:显示路由管理上报给OSPFv3的NIB信息。
rib:显示路由管理上报给OSPFv3的RIB信息。
display system internal ospfv3 interface命令用来显示OSPFv3的接口相关信息。
display system internal ospfv3 interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
vpn-instance vpn-instance-name:指定OSPFv3进程所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPFv3位于公网中。本参数的支持情况与设备的型号有关,请以设备的实际情况为准。
ipv6-address:IPv6地址前缀。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
display system internal ospfv3 lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospfv3 [ process-id ] lsdb { inter-prefix | inter-router | intra-prefix { reference type-1 | reference type-2 } | router }
Probe视图
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下的map信息。
inter-prefix:显示Inter-area-prefix LSA的map信息。
inter-router:显示Inter-area-router LSA的map信息。
intra-prefix:显示Intra-area-prefix LSA的map信息。
reference type-1:显示引用Router-LSA的Intra-area-prefix LSA map信息。
reference type-2:显示引用Network-LSA的Intra-area-prefix LSA map信息。
router:显示Router-LSA的map信息。
display system internal ospfv3 nib命令用来显示OSPFv3的下一跳NIB信息。
display system internal ospfv3 nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示NIB详细信息。
display system internal ospfv3 prefix命令用来显示OSPFv3的前缀对应的LSA信息。
display system internal ospfv3 [ process-id ] prefix { inter | intra } [ ipv6-address prefix-length ]
Probe视图
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的前缀对应的LSA信息。
inter:显示InterAs前缀对应的LSA信息。
intra:显示IntraAs前缀对应的LSA信息。
ipv6-address prefix-length:显示指定IPv6地址的OSPFv3前缀对应的LSA信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有的前缀对应的LSA信息。
display system internal ospfv3 status命令用来显示OSPFv3协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
display system internal pbr fib命令用来显示用户态下下一跳的配置信息。
display system internal pbr fib [ vpn-instance vpn-instance-name ] slot slot-number
不显示用户态下下一跳的配置信息。
Probe视图
vpn-instance vpn-instance-name:显示用户态下指定私网内下一跳的配置信息,不指定该参数为公网内下一跳。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定成员设备的指定私网内下一跳的配置信息。slot-number表示设备在IRF中的成员编号。
display system internal pbr kernel policy用于显示内核态下的策略路由信息。
display system internal pbr kernel policy [ policy-name [ setup ] ] slot slot-number
不显示内核态下的策略路由信息。
Probe视图
policy policy-name:显示内核态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息。
slot slot-number:显示内核态下指定成员设备的策略路由信息。slot-number表示设备在IRF中的成员编号。
display system internal pbr policy用于显示用户态下的策略路由信息。
display system internal pbr policy [ policy-name [ setup ] ] slot slot-number
不显示用户态下的策略路由信息。
Probe视图
policy policy-name:显示用户态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息。
slot slot-number:显示用户态下指定成员设备的策略路由信息。slot-number表示设备在IRF中的成员编号。
display system internal pim interface命令用来显示PIM进程中路由管理LIB所维护的接口信息。
display system internal pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number | ip-address { mask-length | mask } ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网的信息。
ip-address:显示指定IP地址的信息。如果未指定本参数,将显示所有IP地址的信息。0.0.0.0为保留地址,用户不感知。
mask-length:表示掩码长度,取值范围为0~32。
mask:表示掩码。
display system internal pim rp命令用来显示PIM的RP统计信息。
display system internal pim [ vpn-instance vpn-instance-name ] rp
Probe视图
display system internal pim thread命令用来显示PIM线程的统计信息。
display system internal pim thread { event | main | route }
Probe视图
event:显示PIM事件线程的统计信息。
main:显示PIM主线程的统计信息。
route:显示PIM路由线程的统计信息。
display system internal ptp irf-port命令用来显示IRF物理端口的PTP运行信息。
Probe视图
如果ptp profile和ptp mode没有指定,则显示信息为空。
display system internal ptp irf-statistics命令用来显示IRF物理端口的PTP统计信息。
Probe视图
display system internal rawip命令用来显示设备上所有RawIP连接的摘要信息。
display system internal rawip slot slot-number
IRF模式:
display system internal rawip chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有RawIP连接的摘要信息。slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有RawIP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(IRF模式)
display system internal rib event attribute命令用来显示IPv4路由协议关心路由属性变化的信息。
Probe视图
display system internal rib event policy命令用来显示IPv4路由协议关注满足指定路由策略的路由变化信息。
Probe视图
display system internal rib notificaion prefix命令用来显示IPv4路由协议关注路由前缀的信息。
display system internal rib event prefix
Probe视图
display system internal rib event protocol命令用来显示IPv4路由协议间相互关注的信息。
display system internal rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
display system internal rib event statistics用来显示IPv4路由上报路由协议、下刷FIB的统计信息。
display system internal rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
display system internal rib log命令用来显示RIB日志信息。
IRF模式:
display system internal rib log [ reverse ] [ standby chassis chassis-number slot slot-number ]
display system internal rib event log [ standby chassis chassis-number slot slot-number ]
Probe视图
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ] [ standby slot slot-number ]
IRF模式:
display system internal rib nib log [ reverse ] [ standby chassis chassis-number slot slot-number ]
Probe视图
nib:显示NIB子模块的运行状态。
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
IRF模式:
Probe视图
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
standby slot slot-number:显示备份的指定单板IPv4路由表前缀信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv4路由表前缀信息。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上IPv4路由表前缀信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv4路由表前缀信息。(IRF模式)
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
display system internal rib summary [ standby slot slot-number ]
IRF模式:
display system internal rib summary [ standby chassis chassis-number slot slot-number ]
Probe视图
display system internal rip interface命令用来显示接口信息。
display system internal rip interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
display system internal rip nib命令用来显示RIP路由下一跳信息。
display system internal rip nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示下一跳详细信息。
display system internal rip nib log命令用来显示RIP路由下一跳日志信息。
Probe视图
display system internal rip status命令用来显示RIP协议全局状态信息。
Probe视图
display system internal ripng interface命令用来接口信息。
display system internal ripng interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
display system internal ripng nib命令用来RIPng路由下一跳信息。
display system internal ripng nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示下一跳详细信息。
display system internal ripng nib log命令用来RIPng路由下一跳日志信息。
Probe视图
display system internal ripng status命令用来显示RIPng协议全局状态信息。
Probe视图
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
Probe视图
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
display system internal service-loopback interface-list命令用来显示接口事件处理队列节点信息。
display system internal service-loopback interface-list slot slot-number
IRF模式:
display system internal service-loopback interface-list chassis chassis-number slot slot-number
Probe视图
slot slot-mumber:表示指定单板的接口事件队列信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示成员设备上指定单板的接口事件队列信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
该命令用于定位接口事件处理过程中出现的时序问题。
display system internal service-loopback running命令用来显示业务环回组的运行数据。
display system internal service-loopback running group group-number slot slot-number
IRF模式:
display system internal service-loopback running group group-number chassis chassis-number slot slot-number
Probe视图
group group-number:显示指定环回组的信息,取值范围为1~1024。
slot slot-mumber:显示指定单板的业务环回组信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示成员设备上指定单板的业务环回组信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
该命令可以用于了解当前系统指定业务环回组在各板的运行状态和驱动信息,方便定位与驱动配合的问题和分布式环境下各板信息不一致的问题。
display system internal sflow statistics命令用来显示sFlow的统计信息。
独立运行模式:
display system internal sflow statistics [ slot slot-number ]
IRF模式:
display system internal sflow statistics [ chassis chassis-number slot slot-number ]
probe视图
slot slot-number:查看指定单板上的sFlow的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:查看指定成员设备上指定单板的sFlow的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
· 字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
· 二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
display system internal stp bridge-info命令用来显示生成树指定实例桥配置信息及运行状态。
display system internal stp bridge-info instance instance-id slot slot-number
IRF模式:
display system internal stp bridge-info instance instance-id chassis chassis-number slot slot-number
Probe视图
instance instance-id:显示指定实例的生成树桥配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
slot slot-number:显示指定单板的生成树桥配置信息和运行状态,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的生成树桥配置信息和运行状态,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display system internal stp port-info命令用来显示生成树指定实例端口配置信息及运行状态。
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe视图
instance instance-id:显示指定实例的生成树端口配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
interface interface-type interface-number:显示指定端口上的生成树端口信息和运行状态,interface-type interface-number表示端口类型和端口编号。
display system internal tcp命令用来显示设备上所有TCP连接的摘要信息。
display system internal tcp slot slot-number
IRF模式:
display system internal tcp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有TCP连接的摘要信息。slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有TCP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(IRF模式)
display system internal trill adjacent-table命令用来显示TRILL邻接表的信息。
IRF模式:
Probe视图
count:显示表项计数。
next-hop nickname interface interface-type interface-number:显示指定下一跳RB指定端口上的详细信息。nickname表示下一跳RB的Nickname,为0x1~0xFFFE的十六进制数。interface-type interface-number为端口类型和端口编号。
reference:显示与VN表项的关联信息。
statistics:显示统计信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
如果未指定任何可选参数,将显示TRILL邻接表的所有表项。
display system internal trill fib命令用来显示TRILL单播转发表的信息。
IRF模式:
Probe视图
count:显示表项计数。
nickname nickname:显示指定RB的详细信息。nickname表示下一跳RB的Nickname,为0x1~0xFFFE的十六进制数。
running:显示运行信息。
statistics:显示统计信息。
如果未指定任何可选参数,将显示TRILL单播转发表的所有表项。
display system internal trill management命令用来显示TRILL管理的信息。
IRF模式:
Probe视图
interface interface-type interface-number:显示指定端口上的信息。interface-type interface-number为端口类型和端口编号。
statistics:显示统计信息。
如果未指定任何可选参数,将显示TRILL管理的全局信息。
display system internal trill mfib命令用来显示TRILL组播转发表的信息。
display system internal trill mfib statistics slot slot-number
IRF模式:
display system internal trill mfib statistics chassis chassis-number slot slot-number
Probe视图
statistics:显示统计信息。
ingress:显示入表项的信息。
vlan vlan-id:指定表项所属的VLAN,vlan-id的取值范围为1~4094。
local-entry:显示本地表项的信息。
remote-entry:显示远端表项的信息。
transit:显示转发表项的信息。
prune-entry:显示被剪枝表项的信息。
rpf-entry:显示RPF表项的信息。
mac mac-address:指定MAC地址,mac-address为MAC地址。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示所有单板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有单板上的信息。(IRF模式)
如果未指定任何可选参数,将显示TRILL组播转发表的所有表项。
display system internal trill status命令用来显示TRILL协议进程的状态信息。
Probe视图
display system internal trill vn命令用来显示TRILL VN表项的信息。
IRF模式:
Probe视图
count:显示表项计数。
vnid vn-id:显示指定VN表项的详细信息。vn-id表示VN表项的编号,为0x0~0xFFFFFFFF的十六进制数。
next-hop nickname:显示指定下一跳RB的信息。nickname表示下一跳RB的Nickname,为0x1~0xFFFE的十六进制数。
reference:显示关联信息。
display system internal tunnel data命令用来显示Tunnel接口内核数据信息。
display system internal tunnel data interface tunnel number [ slot slot-number ]
IRF模式:
Probe视图
interface tunnel number:显示指定Tunnel接口的内核数据信息。number表示Tunnel接口编号,取值为已创建的Tunnel接口的编号。
slot slot-number:显示指定单板的Tunnel接口内核数据信息。slot-number表示单板所在的槽位号。如果不指定本参数,则显示主用主控板的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的Tunnel接口内核数据信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则显示全局主用主控板的信息。(IRF模式)
display system internal udp命令用来显示设备上所有UDP连接的摘要信息。
display system internal udp slot slot-number
IRF模式:
display system internal udp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有UDP连接的摘要信息。slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有UDP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号,取值范围请以设备的实际情况为准。(IRF模式)
display system internal vlan命令用来查看VLAN模块相关的内部信息。
IRF模式:
Probe视图
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
port interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
summary:显示VLAN模块的摘要信息。
slot slot-number:查看指定单板上的VLAN模块信息。其中,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number:查看指定成员设备上的VLAN模块信息。其中,chassis-number表示设备在IRF中的成员编号。(IRF模式)
display transceiver diagnosis interface命令显示可插拔光模块的数字诊断参数的当前测量值以及告警门限。
interface-type interface-number:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值以及告警门限。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示显示所有接口下的该信息。
display transceiver information interface命令用来显示光模块的详细信息。
display transceiver information interface [ interface-type interface-number ]
Probe视图
interface-type interface-number:显示接口上插入的可插拔光模块的详细信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
fabric-disable命令用来隔离指定槽位网板不参与转发。
undo fabric-disable命令用来取消该配置。
独立运行模式:
fabric-disable slot slot-number
undo fabric-disable slot slot-number
IRF模式:
fabric-disable chassis chassis-number slot slot-number
undo fabric-disable chassis chassis-number slot slot-number
Probe视图
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。(IRF模式)
本命令在Release 1005P02和Release 1005P03版本支持。在Release 1005P04版本删除了本命令,对应功能由系统视图下 switch-fabric isolate 命令实现,具体情况请参见“基础配置指导”中的“设备管理配置”。
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
独立运行模式:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ slot slot-number ]
IRF模式:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ chassis chassis-number slot slot-number ]
Probe视图
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
inner-channel port-isolate命令用来隔离指定槽位网板的指定芯片的指定端口。
undo inner-channel port-isolate命令用来取消该配置。
独立运行模式:
inner-channel port-isolate slot-number chip-number port-number
undo inner-channel port-isolate slot-number chip-number port-number
IRF模式:
inner-channel port-isolate chassis chassis-number slot slot-number chip chip-number port-number
undo inner-channel port-isolate chassis chassis-number slot slot-number chip chip-number port-number
Probe视图
chip-number:表示芯片编号。(独立运行模式)
chassis chassis-number slot slot-number chip chip-number:表示指定成员设备上指定单板的指定芯片号。(IRF模式)
port-number:表示端口编号。(独立于行模式)
port port-number:表示端口编号。(IRF模式)
l2vpn l2vfib record size命令用来设置L2VPN L2VFIB模块记录信息的最大数目。
l2vpn l2vfib record size size slot slot-number
IRF模式:
l2vpn l2vfib record size size chassis chassis-number slot slot-number
L2VPN L2VFIB模块记录信息的最大数目为4096条。
Probe视图
slot slot-number:指定单板上的记录信息的最大数目。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板的记录信息的最大数目。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
lipc dump-port命令打开指定单播端口的dump开关。
lipc dump-port port &<1-5> [ lip lip ]
undo lipc dump-port [ lip lip ]
单播端口的dump开关是关闭的。
Probe视图
dump-port port &<1-5>:表示单播端口号,0~为0~65535。&<1-5>表示前面的参数最多可以输入5次。
lip lip:表示远端节点号,0~为0~32767。
打开指定单播端口的dump开关后,系统会在/proc/lipc/dumpinfo文件中记录该端口的所有报文收发信息。
lipc performance命令用来打开单播或者组播的性能统计开关,并测试LIPC的传输性能。
lipc performance { stcp | mtcp } { on | off | clear | { test { start [ parameter ] | stop } } } [ lip lip ]
性能统计开关是关闭的。
Probe视图
mtcp:表示LIPC的MTCP模块调试信息开关。
stcp:表示LIPC的STCP模块的调试信息开关。
on:表示打开调试信息开关。
off:表示关闭调试信息开关。
clear:表示清除单播或者组播的性能统计数据。
test:表示测试LIPC的传输性能。
start [ parameter ]:表示启动LIPC的传输性能测试,为1~64长度的字符串。
stop:表示停止LIPC的传输性能测试。
test { start [ parameter ] | stop } 参数必须在安装stresskit包后使用。
lipc ping命令ping其它节点并等待回应,用于检查与目的节点LIPC通信链路是否正常。
lipc ping lip [ length length times times ]
发送长度为100字节的请求报文,发送10次。
Probe视图
lip:表示节点号,取值范围为0~32767。
length length:表示报文长度,取值范围为0~32767。
times times:表示发送次数,取值范围为0~32767。
系统中有效的节点号可以使用display system internal lipc topology link 命令获取,用户需自己保证节点号的有效性。
lipc timeout命令用来设置LIPC拓扑链路的超时时间。
lipc timeout time [ lip lip ]
拓扑链路的超时时间为60秒。
Probe视图
timeout time:表示超时时间,取值范围为3-65535。
如果本节点的Topology模块在超时时间内没有收到UP节点的心跳报文,则会断开与该节点的所有单播、组播连接。
通常,只有在使用KDB或者KGDB调试内核时,才需要修改该数值,以避免其他节点认为正处于内核调试状态的节点链路Down。
list命令用来查看目录或文件信息。
独立运行模式:
list file-path [ slot slot-number ]
IRF模式:
list file-path [ chassis chassis-number slot slot-number ]
Probe视图
file-path:要查看的文件或目录的路径,区分大小写。
slot slot-number:查看指定单板的文件内容。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:查看指定设备上单板的文件内容。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
只能查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
local logbuffer clear命令用来清空指定单板上所有的调试信息。
独立运行模式:
local logbuffer slot slot-number clear
IRF模式:
local logbuffer chassis chassis-number slot slot-number clear
Probe视图
local logbuffer命令用来显示指定单板上相应模块的调试信息。
独立运行模式:
local logbuffer slot slot-number display [ module | all ]
IRF模式:
local logbuffer chassis chassis-number slot slot-number display [ module | all ]
Probe视图
module:模块名称。
all:显示所有模块调试信息。
local logbuffer display qacl命令用来显示ACL模块错误信息记录。
独立运行模式:
local logbuffer slot slot-number display [ start-number ] qacl
IRF模式:
local logbuffer chassis chassis-number slot slot-number display [ start-number ] qacl
Probe视图
start-number:显示的起始位置,取值范围为0~4294967295,缺省值为0,即从0开始显示连续的30条内容。
local logbuffer display stack用来查看IRF在本地日志缓冲区中记录的日志信息。
独立运行模式:
local logbuffer slot slot-number display stack
IRF模式:
local logbuffer chassis chassis-number slot slot-number display stack
Probe视图
slot slot-number:查看指定单板上日志缓冲区中的IRF日志信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:查看指定成员设备指定单板上日志缓冲区中的IRF日志信息。chassis-number表示成员设备编号,slot-number表示单板所在的槽位号。(IRF模式)
local logbuffer mode命令用来修改指定单板上的日志缓存模式。
独立运行模式:
local logbuffer slot slot-number mode mode-name
IRF模式:
local logbuffer chassis chassis-number slot slot-number mode mode-name
Probe视图
mode-name:模式名称。
local logbuffer size命令用来配置指定单板上调试信息最大记录条数。
独立运行模式:
local logbuffer slot slot-number size size
IRF模式:
local logbuffer chassis chassis-number slot slot-number size size
Probe视图
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
独立运行模式:
memory boundary-check enable job job-id [ slot slot-number ]
undo memory boundary-check enable job job-id [ slot slot-number ]
IRF模式:
memory boundary-check enable job job-id [ chassis chassis-number slot slot-number ]
undo memory boundary-check enable job job-id [ chassis chassis-number slot slot-number ]
内存越界检查功能处于关闭状态。
Probe视图
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
· memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
独立运行模式:
memory boundary-check scan job job-id [ slot slot-number ]
IRF模式:
memory boundary-check scan job job-id [ chassis chassis-number slot slot-number ]
Probe视图
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
· memory boundary-check enable
monitor inner-channel命令用来使能内部通道监控功能。
undo monitor inner-channel命令用来关闭内部通道监控功能。
monitor inner-channel [ isolate-port | upper-limit upper-limit ]
undo monitor inner-channel [ isolate-port ]
Probe视图
isolate-port:内部通道监控的动作是隔离故障端口。
upper-limit upper-limit:设置内部通道检测的超时间隔,upper-limit表示超时间隔,单位为100毫秒。
mpls lfib record size命令用来设置MPLS LFIB模块记录信息的最大数目。
mpls lfib record size size slot slot-number
IRF模式:
mpls lfib record size size chassis chassis-number slot slot-number
MPLS LFIB模块记录信息的最大数目为4096条。
Probe视图
multicast record命令用来配置组播表项操作记录的最大数目。
undo multicast record命令用来恢复缺省情况。
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
组播表项操作记录的最大数目为0,即不记录组播表项的操作信息。
Probe视图
fail:表示组播表项的失败操作记录。
limit-value:表示操作记录的最大数目,取值范围为0~500000。
probe命令用来从系统视图进入Probe视图。
probe
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
# 从系统视图进入Probe视图。
[Sysname] probe
[Sysname-probe]
reset ipv6 multicast forwarding-table dummy命令用来清除IPv6组播临时转发表中的表项。
IRF模式:
Probe视图
vpn-instance vpn-instance-name:清除指定VPN实例的表项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的表项。
ipv6-group-address:清除指定IPv6组播组的表项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将清除所有IPv6组播组的表项。
ipv6-source-address:清除指定IPv6组播源的表项。如果未指定本参数,将清除所有IPv6组播源的表项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
all:清除所有表项。
slot slot-number:清除指定单板上的表项,slot-number表示单板所在的槽位号。如果未指定本参数,将清除主控板上的表项。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除IRF中所有主控板上的表项。(IRF模式)
reset ipv6 rib log命令用来清除IPv6 RIB相关的日志内容。
reset ipv6 rib [ event ] log [ standby slot slot-number ]
IRF模式:
reset ipv6 rib [ event ] log [ standby chassis chassis-number slot slot-number ]
Probe视图
event:IPv6 RIB路由变化相关的日志。
standby slot slot-number:清除备份的指定单板RIB相关的日志内容,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB相关的日志内容。(独立运行模式)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备上RIB相关的日志内容,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB相关的日志内容。(IRF模式)
reset ipv6 rib nib log命令用来清除IPv6 NIB子模块日志。
reset ipv6 rib nib log [ standby slot slot-number ]
IRF模式:
reset ipv6 rib nib log [ standby chassis chassis-number slot slot-number ]
Probe视图
standby slot slot-number:清除备份的指定单板NIB子模块日志,slot-number表示单板所在的槽位号。如果未指定本参数,将清除NIB子模块日志。(独立运行模式)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备上NIB子模块日志,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除NIB子模块日志。(IRF模式)
reset ipv6 rib summary命令用来清除IPv6 RIB的统计摘要信息。
reset ipv6 rib summary [ standby slot slot-number ]
IRF模式:
reset ipv6 rib summary [ standby chassis chassis-number slot slot-number ]
Probe视图
standby slot slot-number:清除备份的指定单板RIB的统计摘要信息,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB的统计摘要信息。(独立运行模式)
standby chassis chassis-number slot slot-number:清除备份的指定成员设备上RIB的统计摘要信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除RIB的统计摘要信息。(IRF模式)
reset ipv6 route-direct log命令用来清除直连路由日志。
reset ipv6 route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:ipv6直连路由NIB子模块相关日志。
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
reset ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
reset l2vpn l2vfib record命令用来清除L2VPN L2VFIB模块记录的信息。
reset l2vpn l2vfib record slot slot-number
IRF模式:
reset l2vpn l2vfib record chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板上的记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
· display system internal l2vpn l2vfib record
reset mpls lfib record命令用来清除MPLS LFIB模块记录的信息。
reset mpls lfib record slot slot-number
IRF模式:
reset mpls lfib record chassis chassis-number slot slot-number
Probe视图
· display system internal mpls lfib record
reset multicast forwarding-table dummy命令用来清除组播临时转发表中的表项。
IRF模式:
Probe视图
source-address:清除指定组播源的表项。如果未指定本参数,将清除所有组播源的表项。
group-address:清除指定组播组的表项,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将清除所有组播组的表项。
mask-length:指定组播源或组播组地址的掩码长度。对于组播源地址,其取值范围为0~32,缺省值为32;对于组播组地址,其取值范围为4~32,缺省值为32。
mask:指定组播源或组播组地址的掩码,缺省值为255.255.255.255。
all:清除所有表项。
reset multicast record命令用来清除组播表项的操作记录。
Probe视图
reset ospf event-log命令用来清除NIB、接口事件和接口通知日志。
reset ospf event-log { interface | notify | nib }
Probe视图
interface:接口事件相关日志。
notify:接口通知相关日志。
nib:NIB的相关日志。
reset rib log命令用来清除RIB相关的日志内容。
reset rib [ event ] log [ standby slot slot-number ]
IRF模式:
reset rib [ event ] log [ standby chassis chassis-number slot slot-number ]
Probe视图
event:RIB路由变化相关的日志。
reset rib nib log命令用来清除NIB子模块日志。
reset rib nib log [ standby slot slot-number ]
IRF模式:
reset rib nib log [ standby chassis chassis-number slot slot-number ]
Probe视图
reset rib summary命令用来清除IPv4 RIB的统计摘要信息。
reset rib summary [ standby slot slot-number ]
IRF模式:
reset rib summary [ standby chassis chassis-number slot slot-number ]
Probe视图
reset route-direct log命令用来清除直连路由日志。
reset route-direct { event | notify | nib } log
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
reset route-static nib log命令用来清除静态路由NIB子模块日志。
Probe视图
reset system internal arp statistics命令用来清除指定板上的ARP统计信息。
reset system internal arp statistics slot slot-number
IRF模式:
reset system internal arp statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清空指定单板的ARP统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清空指定成员设备上指定单板的ARP统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal fib statistics命令用来清除FIB统计信息。
reset system internal fib statistics slot slot-number
IRF模式:
reset system internal fib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板的FIB统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的FIB统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
# 清除成员设备2上单板1的FIB统计信息。
[Sysname] probe
[Sysname-probe] reset system internal fib statistics chassis 2 slot 1
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
reset system internal mac-address statistics slot slot-number
IRF模式:
reset system internal mac-address statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板的MAC地址表统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的MAC地址表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal mbuf relay statistics命令用来清除MBUF中继模块的统计信息。
独立运行模式:
reset system internal mbuf relay statistics slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
IRF模式:
reset system internal mbuf relay statistics chassis chassis-number slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
Probe视图
slot slot-number:清除指定单板的MBUF中继模块的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的MBUF中继模块的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal nd statistics命令用来清除各板上的ND统计信息。
reset system internal nd statistics slot slot-number
IRF模式:
reset system internal nd statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清空指定单板的ND统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清空指定成员设备上指定单板的ND统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal sflow statistics命令用来清除sFlow的统计信息。
独立运行模式:
reset system internal sflow statistics [ slot slot-number ]
IRF模式:
reset system internal sflow statistics [ chassis chassis-number slot slot-number ]
probe视图
slot slot-number:清除指定单板上的sFlow的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的sFlow的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal trill adjacent-table statistics命令用来清除TRILL邻接表的统计信息。
reset system internal trill adjacent-table statistics slot slot-number
IRF模式:
reset system internal trill adjacent-table statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板上的统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal trill fib statistics命令用来清除TRILL单播转发表的统计信息。
reset system internal trill fib statistics slot slot-number
IRF模式:
reset system internal trill fib statistics chassis chassis-number slot slot-number
Probe视图
reset system internal trill management statistics命令用来清除TRILL管理的统计信息。
reset system internal trill management statistics slot slot-number
IRF模式:
reset system internal trill management statistics chassis chassis-number slot slot-number
Probe视图
reset system internal trill mfib statistics命令用来清除TRILL组播转发表的统计信息。
reset system internal trill mfib statistics slot slot-number
IRF模式:
reset system internal trill mfib statistics chassis chassis-number slot slot-number
Probe视图
view命令用来查看指定文件的内容。
独立运行模式:
view file-path [ slot slot-number ]
IRF模式:
view file-path [ chassis chassis-number slot slot-number ]
Probe视图
file-path:要查看文件的路径,区分大小写。
只能查看系统目录(/proc/、/sys/、/var/)下的文件的内容,且文件路径中不能包含文件链接。
文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
