H3C S12500系列路由交换机 Probe命令参考-R7328-6W730
01-Probe命令
本章节下载: 01-Probe命令  (1.19 MB)
01-Probe命令
1 Probe命令
1.1 D
1.1.1 debug hardware internal mpls  {error | event}
1.1.2 debugging hardware internal drv_l2 fdb au-message
1.1.3 debugging lipc
1.1.4 debugging system internal adj4
1.1.5 debugging system internal arp event
1.1.6 debugging system internal arp features
1.1.7 debugging system internal arp notify
1.1.8 debugging system internal arp sync
1.1.9 debugging system internal fib prefix
1.1.10 debugging system internal fib vn
1.1.11 debugging system internal httpd
1.1.12 debugging system internal igmp-snooping fsm tracing
1.1.13 debugging system internal ip vpn-instance
1.1.14 debugging system internal ipv6 fib prefix
1.1.15 debugging system internal mld-snooping fsm tracing
1.1.16 debugging system internal nd
1.1.17 debugging system internal stg
1.1.18 debugging system internal stp
1.1.19 debugging system internal vlan
1.1.20 display fan auto-control-mode
1.1.21 display hardware  internal tunnel
1.1.22 display hardware internal devd
1.1.23 display hardware internal device
1.1.24 display hardware internal diag board-check
1.1.25 display hardware internal diag buffer-usage
1.1.26 display hardware internal diag forward-path check
1.1.27 display hardware internal driver boot information
1.1.28 display hardware internal driver dstm control stackport
1.1.29 display hardware internal driver dstm hello-packet exceptioninfo
1.1.30 display hardware internal driver dstm hello-packet summary
1.1.31 display hardware internal driver dstm selfmemberinfo
1.1.32 display hardware internal driver dstm stackport
1.1.33 display hardware internal driver dstm topodata
1.1.34 display hardware internal driver dstm topoinfo
1.1.35 display hardware internal driver dstm { diaginfo | exceptioninfo }
1.1.36 display hardware internal driver eth-controller info
1.1.37 display hardware internal driver eth-controller mib
1.1.38 display hardware internal driver eth-controller queue
1.1.39 display hardware internal driver led-alarm-source
1.1.40 display hardware internal driver register lsw
1.1.41 display hardware internal driver reserved_memory
1.1.42 display hardware internal driver [ oam ] register etsec
1.1.43 display hardware internal driver [oam] etsec mib
1.1.44 display hardware internal driver { phy-g | phy-xg } register
1.1.45 display hardware internal drv_l2 fdb hash-info
1.1.46 display hardware internal drv_l2 fdb hw-table
1.1.47 display hardware internal drv_l2 four-irf forward-path
1.1.48 display hardware internal drv_l2 mstp
1.1.49 display hardware internal drv_l2 port global-info
1.1.50 display hardware internal drv_l2 port mac-ctrl-reg
1.1.51 display hardware internal drv_l2 port mib-counters-reg
1.1.52 display hardware internal drv_l2 port port-status-reg
1.1.53 display hardware internal drv_l2 port vlan-qos-config
1.1.54 display hardware internal drv_l2 port { port-peak-rate | port-state-info | port-traffic-state }
1.1.55 display hardware internal drv_l2 trunk
1.1.56 display hardware internal drv_l2 trunk designated-port-entry
1.1.57 display hardware internal drv_l2 vlan vlan-hw-table
1.1.58 display hardware internal drv_l2 vlan vlan-port-tagged
1.1.59 display hardware internal ekdm slot
1.1.60 display hardware internal ekdm-sync
1.1.61 display hardware internal fa flow-control enable slot chip
1.1.62 display hardware internal fa flow-control status slot chip
1.1.63 display hardware internal fa fport-cell-statistic slot chip
1.1.64 display hardware internal fa fport-rx-cell-drop slot chip
1.1.65 display hardware internal fa fport-tx-cell-drop slot chip
1.1.66 display hardware internal fa fport-tx-fifo-status slot chip
1.1.67 display hardware internal fa voq drop slot chip unit
1.1.68 display hardware internal fa voq statistic slot  chip unit
1.1.69 display hardware internal fabric connectivity-table
1.1.70 display hardware internal fabric d-function
1.1.71 display hardware internal fabric fap flow-queue-table
1.1.72 display hardware internal fabric fap portqos
1.1.73 display hardware internal fabric fap queue-flow-table
1.1.74 display hardware internal fabric fap queue-flow-table tgtslot
1.1.75 display hardware internal fabric fap queue-size
1.1.76 display hardware internal fabric fap queue-size non-empty
1.1.77 display hardware internal fabric link-status
1.1.78 display hardware internal fabric mc-route
1.1.79 display hardware internal fabric mc-route counter
1.1.80 display hardware internal fabric mc-route mode
1.1.81 display hardware internal fabric mc-route phylist
1.1.82 display hardware internal fabric prbs-mode
1.1.83 display hardware internal fabric register dump
1.1.84 display hardware internal fabric unicast-table
1.1.85 display hardware internal fcoe dit
1.1.86 display hardware internal fcoe interface Vfc
1.1.87 display hardware internal fcoe key-info
1.1.88 display hardware internal fcoe op route
1.1.89 display hardware internal fcoe route
1.1.90 display hardware internal forward counter
1.1.91 display hardware internal forward err-info
1.1.92 display hardware internal fwd egress-resource slot chip txq-port
1.1.93 display hardware internal fwd ingress-buffer slot chip physical-port
1.1.94 display hardware internal fwd pfc key-info slot chip port
1.1.95 display hardware internal ha masterboard-standbyboard
1.1.96 display hardware internal ha switch-info
1.1.97 display hardware internal ibc control-path-check state
1.1.98 display hardware internal ibc lanswitch egresscntr | ingresscntr
1.1.99 display hardware internal ibc lanswitch mactable
1.1.100 display hardware internal ibc lanswitch portmap
1.1.101 display hardware internal ibc lanswitch portmib
1.1.102 display hardware internal ibc lanswitch vlan
1.1.103 display hardware internal ibc rxpkt
1.1.104 display hardware internal ibc rxque
1.1.105 display hardware internal ibc txpkt
1.1.106 display hardware internal ipuc adj index
1.1.107 display hardware internal ipuc cnt
1.1.108 display hardware internal ipuc fib
1.1.109 display hardware internal ipuc fib number
1.1.110 display hardware internal ipuc op
1.1.111 display hardware internal ipuc op adj
1.1.112 display hardware internal l2mc dit
1.1.113 display hardware internal l2mc mac-table { igsp | mldsp | static }
1.1.114 display hardware internal l2mc { igsp | mldsp | static }
1.1.115 display hardware internal l3mc counter
1.1.116 display hardware internal l3mc dit
1.1.117 display hardware internal l3mc ditcnt
1.1.118 display hardware internal l3mc lbp
1.1.119 display hardware internal l3mc localvpninfo vpnid
1.1.120 display hardware internal l3mc lpm bipim ipv4
1.1.121 display hardware internal l3mc lpm ipv4/ipv6
1.1.122 display hardware internal l3mc mroute ipv4/ipv6
1.1.123 display hardware internal l3mc nexthop
1.1.124 display hardware internal l3mc tcam
1.1.125 display hardware internal l3mc tunnel
1.1.126 display hardware internal l3mc vidx
1.1.127 display hardware internal l3mc vrfinfo vrid
1.1.128 display hardware internal mirror
1.1.129 display hardware internal mpls  dit
1.1.130 display hardware internal mpls  frr dit
1.1.131 display hardware internal mpls  nhlfe
1.1.132 display hardware internal mpls  nhlfecnt
1.1.133 display hardware internal mpls  tablesize
1.1.134 display hardware internal mpls  tticnt
1.1.135 display hardware internal mpls  tunnel
1.1.136 display hardware internal mpls  vpws
1.1.137 display hardware internal mpls  vpws actti
1.1.138 display hardware internal mpls debugging
1.1.139 display hardware internal mpls evi- hashpcl
1.1.140 display hardware internal mpls evi- tunnel
1.1.141 display hardware internal mpls evi- vlan
1.1.142 display hardware internal mpls evi-info  globalvar
1.1.143 display hardware internal mpls evi-instance
1.1.144 display hardware internal mpls evi-link
1.1.145 display hardware internal mpls evi-operation
1.1.146 display hardware internal mpls infilter
1.1.147 display hardware internal mpls labelinfo inlabel
1.1.148 display hardware internal mpls mpls variable
1.1.149 display hardware internal mpls spb bmacinfo
1.1.150 display hardware internal mpls spb bvlan
1.1.151 display hardware internal mpls spb fabricvidx
1.1.152 display hardware internal mpls spb lbpinfo
1.1.153 display hardware internal mpls spb operation
1.1.154 display hardware internal mpls spb pwinfo
1.1.155 display hardware internal mpls spb tunnelinfo
1.1.156 display hardware internal mpls spb variable
1.1.157 display hardware internal mpls spb vidx
1.1.158 display hardware internal nh
1.1.159 display hardware internal nst  packet-statistic
1.1.160 display hardware internal packet-drop
1.1.161 display hardware internal pcl pce-entry slot
1.1.162 display hardware internal qos buffer-count
1.1.163 display hardware internal register
1.1.164 display hardware internal register dump
1.1.165 display hardware internal rxtx device-status
1.1.166 display hardware internal rxtx dma
1.1.167 display hardware internal rxtx interrupt
1.1.168 display hardware internal rxtx packet
1.1.169 display hardware internal rxtx rxpkt
1.1.170 display hardware internal rxtx txpkt
1.1.171 display hardware internal sflow interface
1.1.172 display hardware internal temperature-limit
1.1.173 display hardware internal transceiver register interface
1.1.174 display hardware internel driver phy-xg register dump
1.1.175 display psr status
1.1.176 display system internal acl
1.1.177 display system internal adj4 entry
1.1.178 display system internal adj4 statistics
1.1.179 display system internal adjacent-table
1.1.180 display system internal arp
1.1.181 display system internal arp ifcb
1.1.182 display system internal arp ip-address
1.1.183 display system internal arp machash
1.1.184 display system internal arp probe
1.1.185 display system internal arp reload
1.1.186 display system internal arp source-suppression cache
1.1.187 display system internal arp statistics
1.1.188 display system internal arp vlan
1.1.189 display system internal bgp graceful-restart statistics
1.1.190 display system internal bgp instance statistics
1.1.191 display system internal bgp interface
1.1.192 display system internal bgp l2vpn auto-discovery advertise
1.1.193 display system internal bgp l2vpn auto-discovery verbose
1.1.194 display system internal bgp l2vpn signaling advertise
1.1.195 display system internal bgp l2vpn signaling verbose
1.1.196 display system internal bgp nib
1.1.197 display system internal bgp nib log
1.1.198 display system internal bgp peer statistics
1.1.199 display system internal bgp protocol statistics
1.1.200 display system internal bgp routing-table advertise-info
1.1.201 display system internal bgp routing-table verbose
1.1.202 display system internal control-plane management statistics
1.1.203 display system internal dbm
1.1.204 display system internal ethernet character
1.1.205 display system internal ethernet controlblock
1.1.206 display system internal evi flooding
1.1.207 display system internal evi selective-flooding
1.1.208 display system internal evi statistics
1.1.209 display system internal evi vlan-mapping
1.1.210 display system internal evi vlan-status
1.1.211 display system internal evi-link data
1.1.212 display system internal eviisis status
1.1.213 display system internal fib prefix
1.1.214 display system internal fib prefix entry-status
1.1.215 display system internal fib prefix ip
1.1.216 display system internal fib running-status
1.1.217 display system internal fib statistics
1.1.218 display system internal fib vn
1.1.219 display system internal fib vn entry-status
1.1.220 display system internal fib vn reference
1.1.221 display system internal ha service
1.1.222 display system internal ha service-group
1.1.223 display system internal ha statistics
1.1.224 display system internal httpd service
1.1.225 display system internal ifmgr brief
1.1.226 display system internal ifmgr down
1.1.227 display system internal ifmgr entry
1.1.228 display system internal ifmgr event
1.1.229 display system internal ifmgr hotplug
1.1.230 display system internal ifmgr index
1.1.231 display system internal ifmgr list
1.1.232 display system internal ifmgr mdc
1.1.233 display system internal ifmgr name
1.1.234 display system internal ifmgr type
1.1.235 display system internal ip address
1.1.236 display system internal ip source binding
1.1.237 display system internal ip vpn-binding
1.1.238 display system internal ip vpn-instance
1.1.239 display system internal ip vpn-instance inactive
1.1.240 display system internal ip vpn-instance statistics
1.1.241 display system internal ipv6 address
1.1.242 display system internal ipv6 fib prefix
1.1.243 display system internal ipv6 fib prefix entry-status
1.1.244 display system internal ipv6 fib prefix ipv6
1.1.245 display system internal ipv6 l2-multicast ip forwarding verbose
1.1.246 display system internal ipv6 l2-multicast ip verbose
1.1.247 display system internal ipv6 l2-multicast ipc statistics
1.1.248 display system internal ipv6 l2-multicast mac forwarding verbose
1.1.249 display system internal ipv6 l2-multicast mac verbose
1.1.250 display system internal ipv6 mrib interface statistics
1.1.251 display system internal ipv6 mrib mbr
1.1.252 display system internal ipv6 multicast forwarding vlan reference
1.1.253 display system internal ipv6 multicast forwarding-table dummy
1.1.254 display system internal ipv6 multicast forwarding-table verbose
1.1.255 display system internal ipv6 multicast-vlan forwarding-table verbose
1.1.256 display system internal ipv6 pathmtu
1.1.257 display system internal ipv6 pbr fib
1.1.258 display system internal ipv6 pbr kernel policy
1.1.259 display system internal ipv6 pbr policy
1.1.260 display system internal ipv6 pim interface
1.1.261 display system internal ipv6 pim rp
1.1.262 display system internal ipv6 pim thread
1.1.263 display system internal ipv6 rawip
1.1.264 display system internal ipv6 rib event attribute
1.1.265 display system internal ipv6 rib event policy
1.1.266 display system internal ipv6 rib event prefix
1.1.267 display system internal ipv6 rib event protocol
1.1.268 display system internal ipv6 rib event statistics
1.1.269 display system internal ipv6 rib log
1.1.270 display system internal ipv6 rib memory
1.1.271 display system internal ipv6 rib nib log
1.1.272 display system internal ipv6 rib prefix
1.1.273 display system internal ipv6 rib summary
1.1.274 display system internal ipv6 route-direct interface
1.1.275 display system internal ipv6 route-direct log
1.1.276 display system internal ipv6 route-static nib log
1.1.277 display system internal ipv6 source binding
1.1.278 display system internal ipv6 tcp
1.1.279 display system internal ipv6 udp
1.1.280 display system internal isis import-route
1.1.281 display system internal isis import-route ipv6
1.1.282 display system internal isis interface
1.1.283 display system internal isis interface ipv6
1.1.284 display system internal isis nib
1.1.285 display system internal isis nib ipv6
1.1.286 display system internal isis nib log
1.1.287 display system internal isis prefix
1.1.288 display system internal isis prefix ipv6
1.1.289 display system internal isis status
1.1.290 display system internal kernel memory dump
1.1.291 display system internal kernel memory pool
1.1.292 display system internal l2-multicast ip forwarding verbose
1.1.293 display system internal l2-multicast ip verbose
1.1.294 display system internal l2-multicast ipc statistics
1.1.295 display system internal l2-multicast mac forwarding verbose
1.1.296 display system internal l2-multicast mac verbose
1.1.297 display system internal l2vpn l2vfib record
1.1.298 display system internal l2vpn l2vfib statistics
1.1.299 display system internal link-aggregation global
1.1.300 display system internal link-aggregation interface
1.1.301 display system internal lipc lcmp statistics
1.1.302 display system internal lipc lgmp group
1.1.303 display system internal lipc lgmp group-list
1.1.304 display system internal lipc lgmp physical-group
1.1.305 display system internal lipc lgmp physical-group-list
1.1.306 display system internal lipc lgmp statistics
1.1.307 display system internal lipc lip statistics
1.1.308 display system internal lipc loop statistics
1.1.309 display system internal lipc mtcp group
1.1.310 display system internal lipc mtcp performance
1.1.311 display system internal lipc mtcp statistics
1.1.312 display system internal lipc pcb statistics
1.1.313 display system internal lipc physical
1.1.314 display system internal lipc publish global-cb
1.1.315 display system internal lipc publish statistics
1.1.316 display system internal lipc stcp event
1.1.317 display system internal lipc stcp global-server
1.1.318 display system internal lipc stcp links
1.1.319 display system internal lipc stcp performance
1.1.320 display system internal lipc stcp statistics
1.1.321 display system internal lipc stcp status
1.1.322 display system internal lipc stream
1.1.323 display system internal lipc sudp pcb-info
1.1.324 display system internal lipc sudp statistics
1.1.325 display system internal lipc sudp { global-port | local-port }
1.1.326 display system internal lipc topology history
1.1.327 display system internal lipc topology link
1.1.328 display system internal lipc topology node
1.1.329 display system internal lipc topology process-time
1.1.330 display system internal lipc topology statistics
1.1.331 display system internal lipc topology status
1.1.332 display system internal mac-address configuration
1.1.333 display system internal mac-address statistics
1.1.334 display system internal mbuf relay statistics
1.1.335 display system internal mbuf statistics
1.1.336 display system internal mpls lfib ilm
1.1.337 display system internal mpls lfib nhlfe
1.1.338 display system internal mpls lfib nhlfe reflist
1.1.339 display system internal mpls lfib record
1.1.340 display system internal mpls lfib statistics
1.1.341 display system internal mpls lsp-pending
1.1.342 display system internal mpls statistics
1.1.343 display system internal mrib interface statistics
1.1.344 display system internal mrib mbr
1.1.345 display system internal multicast capability
1.1.346 display system internal multicast forwarding vlan reference
1.1.347 display system internal multicast forwarding-table dummy
1.1.348 display system internal multicast forwarding-table verbose
1.1.349 display system internal multicast record
1.1.350 display system internal multicast-vlan forwarding-table verbose
1.1.351 display system internal mvrp interface
1.1.352 display system internal mvrp map-count
1.1.353 display system internal nd dad
1.1.354 display system internal nd entry
1.1.355 display system internal nd ifcb
1.1.356 display system internal nd machash
1.1.357 display system internal nd probe
1.1.358 display system internal nd reload
1.1.359 display system internal nd static
1.1.360 display system internal nd statistics
1.1.361 display system internal ospf event-log
1.1.362 display system internal ospf interface
1.1.363 display system internal ospf lsdb
1.1.364 display system internal ospf nib
1.1.365 display system internal ospf prefix
1.1.366 display system internal ospf status
1.1.367 display system internal ospfv3 event-log
1.1.368 display system internal ospfv3 interface
1.1.369 display system internal ospfv3 lsdb
1.1.370 display system internal ospfv3 nib
1.1.371 display system internal ospfv3 prefix
1.1.372 display system internal ospfv3 status
1.1.373 display system internal pbr fib
1.1.374 display system internal pbr kernel policy
1.1.375 display system internal pbr policy
1.1.376 display system internal pim interface
1.1.377 display system internal pim rp
1.1.378 display system internal pim thread
1.1.379 display system internal rawip
1.1.380 display system internal rib event attribute
1.1.381 display system internal rib event policy
1.1.382 display system internal rib event prefix
1.1.383 display system internal rib event protocol
1.1.384 display system internal rib event statistics
1.1.385 display system internal rib log
1.1.386 display system internal rib memory
1.1.387 display system internal rib nib log
1.1.388 display system internal rib prefix
1.1.389 display system internal rib summary
1.1.390 display system internal rip interface
1.1.391 display system internal rip nib
1.1.392 display system internal rip nib log
1.1.393 display system internal rip status
1.1.394 display system internal ripng interface
1.1.395 display system internal ripng nib
1.1.396 display system internal ripng nib log
1.1.397 display system internal ripng status
1.1.398 display system internal route-direct interface
1.1.399 display system internal route-direct log
1.1.400 display system internal route-static nib log
1.1.401 display system internal sflow statistics
1.1.402 display system internal startup cache
1.1.403 display system internal stp bridge-info
1.1.404 display system internal stp port-info
1.1.405 display system internal tcp
1.1.406 display system internal tunnel data
1.1.407 display system internal udp
1.1.408 display system internal vlan
1.1.409 display system internal zone acl
1.2 F
1.2.1 follow
1.3 I
1.3.1 irf link-status auto-recovery enable
1.3.2 irf link-status detect enable
1.4 L
1.4.1 l2vpn l2vfib record size
1.4.2 lipc dump-port
1.4.3 lipc performance
1.4.4 lipc ping
1.4.5 lipc timeout
1.4.6 list
1.5 M
1.5.1 memory boundary-check enable
1.5.2 memory boundary-check scan
1.5.3 mpls lfib record size
1.5.4 multicast record
1.6 P
1.6.1 probe
1.7 R
1.7.1 reset hardware internal mpls evi-operation
1.7.2 reset ipv6 route-static nib log
1.7.3 reset system internal adj4 statistics
1.7.4 reset system internal arp statistics
1.7.5 reset system internal ipv6 multicast forwarding-table dummy
1.7.6 reset system internal mac-address statistics
1.7.7 reset system internal mbuf relay statistics
1.7.8 reset system internal mpls lfib record
1.7.9 reset system internal multicast forwarding-table dummy
1.7.10 reset system internal multicast record
1.7.11 reset system internal nd statistics
1.7.12 reset system internal sflow statistics
1.8 S
1.8.1 set  hardware internal driver { phy-g | phy-xg } register
1.8.2 set hardware internal diag monitor-control
1.8.3 set hardware internal fa fport-rx-cell-cfg slot chip fport
1.8.4 set hardware internal fa fport-tx-cell-cfg slot chip fport
1.8.5 set hardware internal fa voq statistic-cfg slot chip unit set
1.8.6 set hardware internal fan low-speed-thresh speed
1.8.7 set hardware internal fcoe op route
1.8.8 set hardware internal ibc lanswitch egresscntr | ingresscntr bind
1.8.9 set hardware internal ipuc cnt
1.8.10 set hardware internal ipuc dropcnt
1.8.11 set hardware internal ipuc op
1.8.12 set hardware internal l3mc counter
1.8.13 set hardware internal l3mc ditcnt
1.8.14 set hardware internal mpls  dit_load_balance
1.8.15 set hardware internal mpls  nhlfecntbind
1.8.16 set hardware internal mpls  nhlfecntunbind
1.8.17 set hardware internal mpls  tticntbind
1.8.18 set hardware internal mpls  tticntunbind
1.9 T
1.9.1 test diag-offline
1.10 V
1.10.1 view
2 Probe不支持命令列表
2.1 快速转发Probe配置命令
2.1.1 display system internal ip fast-forwarding cache verbose
2.1.2 display system internal ip fast-forwarding service-sequece
2.2 IPv6快速转发Probe配置命令
2.2.1 display system internal ipv6 fast-forwarding cache verbose
2.2.2 display system internal ipv6 fast-forwarding service-information
2.2.3 display system internal ipv6 fast-forwarding statistics
2.2.4 reset system internal ipv6 fast-forwarding statistics
2.3 IPv6邻接表Probe配置命令
2.3.1 display system internal ipv6 adjacent-table
2.3.2 display system internal adj6 statistics
2.3.3 reset system internal adj6 statistics
2.3.4 display system internal adj6 entry
2.3.5 debugging system internal adj6
1 Probe命令
本手册中的命令,仅供专业技术人员进行问题定位和调试所用,不建议用户使用。
1.1  D
debug hardware internal mpls {error | event}命令用来打开MPLS相应模块的debug开关。
debug hardware internal mpls basic-entry slot slot-number
debug hardware internal mpls basic-error slot slot-number
debug hardware internal mpls basic-event slot slot-number
debug hardware internal mpls bfd-error slot slot-number
debug hardware internal mpls bfd-event slot slot-number
debug hardware internal mpls diag-error slot slot-number
debug hardware internal mpls diag-event slot slot-number
debug hardware internal mpls evi-error slot slot-number
debug hardware internal mpls evi-event slot slot-number
debug hardware internal mpls l3vpn-error slot slot-number
debug hardware internal mpls l3vpn -event slot slot-number
debug hardware internal mpls vll-error slot slot-number
debug hardware internal mpls vll-event slot slot-number
debug hardware internal mpls vpls-error slot slot-number
debug hardware internal mpls vpls-event slot slot-number
debug hardware internal mpls spb-error slot slot-number
debug hardware internal mpls spb-event slot slot-number
Probe视图
debugging hardware internal drv_l2 fdb au-message命令用来显示到达Bridge处理流程的AU消息以及到达的时间。
debugging hardware internal drv_l2 fdb au-message { interface { interface-type interface-number | interface-name } | slot slot-number [ chip chip-number ] } [ mac mac-addr ] [ vlan vlan-id ] [ message-type type ]  [ max-count count-num ]
Probe视图
interface-type interface-number:指定接口类型和编号。
interface-name:指定接口名称,可以为聚合接口。
slot-number:取值为当前在位的接口板ID号。
chip-number:指定显示表项的芯片号,取值为指定接口板存在的芯片ID号。
mac-addr:指定显示表项的MAC地址。
vlan-id:表项的VLAN ID,取值1~4095。
type:AU消息类型,取值AA(3)或者NA(0)。
count-num:指定显示表项的最大个数,取值1~4294967295。
debugging lipc命令用来打开LIPC的debug开关。
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
undo debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo | stream } [ lip lip ]
detail:用来打开LIPC的报文详细内容的调试信息开关。
dump port:表示端口号,取值范围为0~65535。
lgmp:用来打开LIPC的LGMP模块的调试信息开关。
mbuf:用来打开LIPC的MBUF模块的调试信息开关。
mtcp:用来打开LIPC的MTCP模块调试信息开关。
pub:用来打开LIPC的PUB模块的调试信息开关。
stcp:用来打开LIPC的STCP模块的调试信息开关。
stream:用来打开LIPC的STREAM模块的调试信息开关。
topo:用来打开LIPC的TOPO模块的调试信息开关。
lip lip:可选参数,表示远端节点号,取值范围为0~32767。
debugging system internal adj4命令用来打开IPv4邻接表调试开关。
undo debugging system internal adj4命令用来关闭IPv4邻接表调试开关。
debugging system internal adj4 { hardware | bind | notify | entry }
undo debugging system internal adj4 { hardware | bind | notify | entry }
IPv4邻接表调试开关处于关闭状态。
probe视图
hardware:打开IPv4邻接表临接表下驱动调试功能。
bind:打开VN/NHLFE表项绑定IPv4邻接表临接表调试功能。
notify:打开IPv4邻接表临接表项变化时,反刷VN和NHLFE表项调试功能。
entry:打开IPv4邻接表临接表项更新时调试功能。
debugging system internal arp event命令用来打开ARP事件调试信息开关。
undo debugging system internal arp event命令用来关闭ARP事件调试信息开关。
ARP事件调试信息开关处于关闭状态。
Probe视图
debugging system internal arp features命令用来打开ARP子特性的调试信息开关。
undo debugging system internal arp features命令用来关闭ARP子特性的调试信息开关。
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP子特性的调试信息开关处于关闭状态。
Probe视图
notify:表示ARP子特性的外部通知调试开关。
packet:表示ARP子特性报文调试开关。
debugging system internal arp notify命令用来打开ARP的外部通知调试信息开关。
undo debugging system internal arp notify命令用来关闭ARP的外部通知调试信息开关。
ARP的外部通知调试信息开关处于关闭状态。
Probe视图
debugging system internal arp sync命令用来打开ARP表项的同步调试开关。
undo debugging system internal arp sync命令用来关闭ARP表项的同步调试开关。
ARP表项的同步调试信息开关处于关闭状态。
Probe视图
debugging system internal fib 命令用来打开FIB调试信息开关。
undo debugging system internal fib命令用来关闭FIB调试信息开关。
独立运行模式:
debugging system internal fib prefix { all | message | hardware } slot slot-number
undo debugging system internal fib prefix { all | message | hardware } slot slot-number
IRF模式:
debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number
undo debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number
FIB 调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开message调试开关,打印路由下发和板间同步的IPv4 FIB前缀消息。
hardware:打开hardware调试开关,打印下发驱动信息以及驱动返回的消息。
slot slot-number:单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging system internal fib vn 命令用来打开VN调试信息开关。
undo debugging system internal fib vn命令用来关闭VN调试信息开关。
独立运行模式:
debugging system internal fib vn { all | message | hardware | bind | notify }  slot slot-number
undo debugging system internal fib vn { all | message | hardware | bind | notify }  slot slot-number
IRF模式:
debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number
undo debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number
VN 调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开message调试开关, 显示路由等下发和板间同步的vn消息。
hardware:打开hardware调试开关,显示下发驱动的信息以及驱动返回的信息。
bind:打开bind调试开关,显示前缀绑定vn,vn绑定adj/nhlfe的相关信息。
notify:打开notify调试开关,显示adj/nhlfe反向通知vn,以及vn反向通知前缀的信息。
debugging system internal httpd命令用来打开HTTPD的调试信息开关。
undo debugging system internal httpd命令用来关闭HTTPD的调试信息开关。
debugging system internal httpd { all | event | process | error }
undo debugging system internal httpd { all | event | process | error }
Probe视图
all:打开HTTPD模块全部调试信息开关。
event:打开HTTPD模块的事件调试信息开关。
process:打开HTTPD模块的处理调试信息开关。
error:打开HTTPD模块的错误调试信息开关。
debugging system internal igmp-snooping fsm tracing命令用来打开IGMP Snooping状态机的Trace日志调试信息开关。
undo debugging system internal igmp-snooping fsm tracing命令用来关闭IGMP Snooping状态机的Trace日志调试信息开关。
独立运行模式:
debugging system internal igmp-snooping fsm tracing [ vlan vlan-id [ group-address source-address ] ] [ slot slot-number ]
IRF模式:
debugging system internal igmp-snooping fsm tracing [ vlan vlan-id [ group-address source-address ] ] [ chassis chassis-number slot slot-number ]
IGMP Snooping状态机的Trace日志调试信息开关处于关闭状态。
Probe视图
vlan vlan-id:输出指定VLAN内的信息,vlan-id表示VLAN的编号,取值范围为1~4094。如果未指定本参数,将输出所有VLAN内的信息。
group-address:输出指定组播组的信息。如果未指定本参数,将输出所有组播组的信息。
source-address:输出指定组播源的信息。如果未指定本参数,将输出所有组播源的信息。
slot slot-number:输出指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将输出所有单板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:输出指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将输出IRF中所有单板上的信息。(IRF模式)
debugging system internal ip vpn-instance命令用来打开VPN实例调试信息开关。
undo debugging system internal ip vpn-instance命令用来关闭VPN实例调试信息开关。
独立运行模式:
debugging system internal ip vpn-instance slot slot-number
undo debugging system internal ip vpn-instance slot slot-number
IRF模式:
debugging system internal ip vpn-instance chassis chassis-number slot slot-number
undo debugging system internal ip vpn-instance chassis chassis-number slot slot-number
VPN实例的调试信息开关处于关闭状态。
Probe视图
slot slot-number:表示指定单板上的VPN实例调试信息开关。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的VPN实例调试信息开关。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging system internal ipv6 fib prefix命令用来打开IPv6 FIB调试信息开关。
undo debugging system internal ipv6 fib prefix命令用来关闭IPv6 FIB调试信息开关。
独立运行模式:
debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
undo debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
IRF模式:
debugging system internal ipv6 fib prefix { all | message | hardware } chassis chassis-number slot slot-number
undo debugging system internal ipv6 fib prefix { all | message | hardware } chassis chassis-number slot slot-number
IPv6 FIB调试信息开关处于关闭状态。
Probe视图
all:打开所有调试开关。
message:打开前缀消息调试开关,打印路由下发和板间同步的IPv6 FIB前缀消息。
hardware:打开下驱动信息调试开关,打印下发驱动信息以及驱动返回的消息。
slot slot-number:打开指定单板的IPv6 FIB调试信息开关,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:打开指定成员设备上指定单板的IPv6 FIB调试信息开关,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
debugging system internal mld-snooping fsm tracing命令用来打开MLD Snooping状态机的Trace日志调试信息开关。
undo debugging system internal mld-snooping fsm tracing命令用来关闭MLD Snooping状态机的Trace日志调试信息开关。
独立运行模式:
debugging system internal mld-snooping fsm tracing [ vlan vlan-id [ ipv6-group-address ipv6-source-address ] ] [ slot slot-number ]
IRF模式:
debugging system internal mld-snooping fsm tracing [ vlan vlan-id [ ipv6-group-address ipv6-source-address ] ] [ chassis chassis-number slot slot-number ]
MLD Snooping状态机的Trace日志调试信息开关处于关闭状态。
Probe视图
group ipv6-group-address:输出指定IPv6组播组的信息。如果未指定本参数,将输出所有IPv6组播组的信息。
source ipv6-source-address:输出指定IPv6组播源的信息。如果未指定本参数,将输出所有IPv6组播源的信息。
debugging system internal nd命令用来打开邻居发现的调试信息开关。
undo debugging system internal nd命令用来关闭邻居发现的外部通知调试信息开关。
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
邻居发现的调试信息开关处于关闭状态。
Probe视图
notify:表示邻居发现的通知调试开关。
sync: 表示邻居发现的同步调试开关。
debugging system internal stg命令用来打开STG调试信息开关。
undo debugging system internal stg命令用来关闭STG调试信息开关。
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
STG调试信息开关处于关闭状态。
debugging system internal stp命令用来打开生成树进程间通信调试开关。
undo debugging system internal stp命令用来关闭生成树进程间通信调试开关。
debugging system internal stp ipc
undo debugging system internal stp ipc
生成树进程间通信调试开关处于关闭状态。
Probe视图
ipc:表示生成树进程间通信调试信息开关。
debugging system internal vlan命令用来打开VLAN的调试开关。
undo debugging system internal vlan命令用来关闭VLAN的调试开关。
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
VLAN的调试开关处于关闭状态。
all:表示VLAN的所有调试信息开关。
error:表示VLAN的错误调试信息开关。
event:表示VLAN的事件调试信息开关。
execution:表示VLAN的执行调试信息开关。
hardware:表示VLAN的硬件调试信息开关。
display fan auto-control-mode命令用来显示当前的风扇自动控制模式。
独立运行模式:
IRF模式:
display fan auto-control-mode chassis chassis-number
Probe视图
chassis chassis-number:显示指定成员设备的信息,chassis-number表示设备在IRF中的成员编号。(IRF模式)
display hardware internal tunnel命令用来显示隧道软、硬件表项信息。可以根据产品的软件索引或者平台的隧道ID进行查看。
独立运行模式:
display hardware internal tunnel {index indexid | interface Tunnel tunnelId} [hardware] slot slot-number
IRF模式:
display hardware internal tunnel {index indexid | interface Tunnel tunnelId} [hardware] chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
index:显示指定隧道索引的表项信息。
indexid:软件索引的编号,取值范围从0~8191(与系统工作模式有关)。
interface:显示制定隧道接口的表项。
Tunnel:隧道关键字。
tunnelId:全局隧道ID,和平台的ID一致。
hardware:是否显示硬件信息。
 display hardware internal devd命令用来查看板状态变化事件,以及全局事件。
display hardware internal devd global-event slot-number cpu-number
display hardware internal devd board-event slot-number cpu-number
Probe视图
global-event :全局事件。
board-event:板状态变化事件。
Slot-number:板槽位号。
cpu-number:CPU号,取值范围为0~1。
display hardware internal device命令用来显示设备的详细信息。
Probe视图
无
display hardware internal diag board-check命令用来在Probe视图可以输入,显示单板状态快速检测功能的使能状态的命令。
display hardware internal diag board-check slot slot-number  [ oam ]
Probe视图
      slot slot-number:主控板槽位号。
    oam:辅助CPU。
display hardware internal diag buffer-usage 命令用来查询buffer的使用情况,最多可以统计一天内的数据。
display hardware internal diag buffer-usage slot slot-id chip chip-num
Probe视图
Slot-id:业务板槽号。
Chip-num:芯片号。
 display hardware internal diag forward-path check命令用来在Probe视图可以输入,在业务检测使能的前提下,可以查看某单板与其他单板就业务检测报文是否正常。
       display hardware internal diag forward-path check slot-number chip-number
Probe视图
      Slot-number:本框槽位号。
    Chip-number:本框对应的PP芯片号。
           正常情况下,不打印信息,如果业务检测不通或丢包则打印日志信息,如下形式的信息:
display hardware internal driver boot information命令用来查看指定单板的启动记录,默认情况下为主控板记录。
display hardware internal driver boot information { previous [ standby ] | current } [ slot slot-number [ cpu cpu-number ] ] [ clear ]
Probe视图
previous:前次的信息。
standby:本地备用板的信息。
current:本次的信息。
slot slot-number:槽位号。
cpu cpu-number:cpu编号,0:主cpu,1:oam辅助cpu。
clear:清除记录。
display hardware internal driver dstm control stackport命令用来查询指定槽位DSTM保存的控制口数据。
display hardware internal driver dstm control stackport slot slot-number cpu cpu-number
Probe视图
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm hello-packet命令用来查询指定主控板上的hello报文统计异常信息,hello计数异常时记录该时刻的统计信息。
display hardware internal driver dstm hello-packet exceptioninfo [ clear ] slot Mr-slot-number
Probe视图
clear:清除记录的异常统计信息。
slot Mr-slot-number:主控板槽位号。
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm hello-packet summary命令用来查询指定主控板上的hello报文统计信息。
display hardware internal driver dstm hello-packet summary slot Mr-slot-number
Probe视图
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm selfmemberinfo命令用来查询dstm模块的成员信息。
display hardware internal driver dstm selfmemberinfo slot slot-number cpu cpu-number
Probe视图
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm stackport命令用来查询指定槽位DSTM保存的IRF物理端口数据。
display hardware internal driver dstm stackport port-number slot slot-number cpu cpu-number [clear]
Probe视图
stackport port-number:IRF端口号,取值范围<1-2>。
clear:清除数据操作。
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm topodata命令用来查询指定槽位DSTM保存的topo数据,可以获得转发路径、整个设备的连接关系、拓扑类型等信息。
display hardware internal driver dstm topodata slot slot-number cpu cpu-number
Probe视图
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm topoinfo命令用来查询指定槽位DSTM保存的拓扑信息,可以获取IRF环境中相邻成员设备的主控板的槽位号及CPU MAC等信息。
display hardware internal driver dstm topoinfo slot slot-number cpu cpu-number
Probe视图
注意:该命令行只能在IRF模式下执行。
display hardware internal driver dstm命令用来查看DSTM模块记录的诊断信息和异常信息。
display hardware internal driver dstm { diaginfo | exceptioninfo } slot slot-number cpu cpu-number [ clear | { after | before } date time [ reverse ] ]
Probe视图
diaginfo:诊断信息。
exceptioninfo:异常信息。
clear:清除记录。
after:在某个时间点之后的记录。
before:在某个时间点之前的记录。
date:日期。
time:时间。
reverse:按照时间由近到远的顺序反向读取记录。
display hardware internal driver eth-controller info slot命令用来查询DTSEC端口的收发数据,MAC信息,硬件错误信息。
display hardware internal driver eth-controller info slot slot-number port port-number
Probe视图
port port-number:端口号。
display hardware internal driver eth-controller mib slot命令用来查询DTSEC端口的mib计数,统计收发报文个数。
display hardware internal driver eth-controller mib slot slot-number port port-number
Probe视图
display hardware internal driver eth-controller queue 命令用来查询DTSEC端口各个队列的情况。
display hardware internal driver eth-controller queue slot slot-number [ { queue queue-number | port port-number } ]
Probe视图
queue queue-number:队列号。
display hardware internal driver led-alarm-source命令用来查看指示灯告警原因。
display hardware internal driver led-alarm-source [ slot slot-number ]
Probe视图
display hardware internal driver register lsw命令用来查看lsw芯片信息。
display hardware internal driver register lsw [ slot slot-number [ chip chip-number [ { port port-number }  | reg-addr ] ] ]
Probe视图
chip chip-number:芯片号。
reg-addr:寄存器地址。
display hardware internal driver reserved_memory命令用来查看保留内存的信息。
display hardware internal driver reserved_memory [ slot slot-number [ cpu cpu-number ] ] [ clear ]
Probe视图
clear:清除记录。
display hardware internal driver [ oam ] register etsec命令用来显示etsec端口的寄存器信息。
display hardware internal driver [ oam ] register etsec slot slot-number port port-number
Probe视图
Oam:oam cpu。
display hardware internal driver [oam] etsec mib slot命令用来查询ETSEC端口的mib计数,统计收发报文个数。
display hardware internal driver [oam] etsec mib slot slot-number port port-number
Probe视图
oam:oam cpu。
port port-number:制定需要查询的端口号。
主控板上 :0表示调试网口,
          1表示与对端CPU相连的端口,
          2表示连接LSW的端口。
接口板:暂时使用0作为连接LSW端口,3暂时不用。
           OAM :0表示连接对板的OAM CPU,
               3表示连接LSW的端口 。
·     不支持查询网板的ETSEC BD状态。
·     关于OAM CPU,只能查询当前主用主控板OAM CPU的相关信息,不能查询备用主控板OAM CPU的相关信息。
·     若想查询备用主控板OAM信息,可以在备用主控板输入命令获取相关信息。
display hardware internal driver { phy-g | phy-xg } register命令用来显示读取指定端口的PHY寄存器数据
display hardware internal driver phy-g register interface { interface-type interface-number | interface-name } { internal | external } address address
display hardware internel driver phy-xg register interface { interface-type interface-number | interface-name } sublayer sub-number address address
Probe视图
internal:查询内部PHY信息。
external:查询外部PHY信息。
interface-name:指定接口名称。
address:PHY的寄存器地址。
sub-number:PHY寄存器子层,取值0~1F (十六进制)。
display hardware internal drv_l2 fdb hash-info命令用来显示到指定芯片的Hash查找表内容。
display hardware internal drv_l2 fdb hash-info { mac mac-addr vlan vlan-id | hash-value value }  slot slot-number chip chip-number
display hardware internal drv_l2 fdb hash-info vpls-type mac mac-addr vpn-id vpn-id slot slot-number chip chip-number
Probe视图
mac-addr:MAC地址取值。
vlan-num:表项的VLAN ID。
value:指定MAC表项一级Hash值。
vpn-id:指定VPN ID。
display hardware internal drv_l2 fdb hw-table命令用来显示硬件FDB表的内容,可按照参数组合进行过滤显示
display hardware internal drv_l2 fdb hw-table [ mac-type [ mac mac-addr ] [ vlan vlan-id ] [ static static-status ] [ userdefined define-num ] [ age age-flag ] [ sa-cmd sa-cmd ] [ da-cmd da-cmd ] [ da-route route-flag ] [ sp sp-flag ] [ dev dev-num phy-port phy-port-num ] [ dev dev-num ] [ trunk-id trunk-num ] | vpls-type [ mac mac-addr ] [ static static-status ] [ age age-flag ] [ pw-id pw-num ] [ inlif-id inlif-id ] [ dit-pointer pointer-num ] [ dev dev-num ] [ trunk-id trunk-num ] | slot slot-number chip chip-number [ [ beginning-address address ] [ max-num max-num ] | [ count ] ]
Probe视图
 以下取值为0,1的,一般可认为0表示否或者未置位,1表示是或者置位。
mac-type:表项类型为Bridge MAC表项。
vpls-type:表项类型为VPLS MAC表项。
mac-addr:MAC地址。
vlan-id:表项的VLAN ID,取值为0~4095。
static-status:表项的静态标志位,取值为0,1。
define-num:表项的用户自定义字段,取值为0~15。
age-flag:表项的老化标志位,取值为0,1。
sa-cmd:表项源匹配的转发决定字段,取值为0~4。
da-cmd:表项目的匹配的转发决定字段,取值为0~4。
route-flag:目的匹配是否上三层引擎决定字段,取值为0,1。
sp-flag:标识表项是否为SP表项,取值为0,1。
dev-num:表项的设备号,取值为0~127。
phy-port-num:表项的物理端口号,取值为0~63。
trunk-num:表项的聚合组号,取值1~255。
pw-num:PW-ID,entry-type为vpls时有效,取值为0~127。
inlif-id:表项的InLif ID,取值为0~16383。
pointer-num:VPLS表项的DIT Pointer,取值为0~65535。
slot-number:指定显示表项的槽位号,取值为当前在位的接口板ID号。
address:指定显示表项的起始地址,取值FDB表的起始地址~FDB表的末尾地址。
max-num:指定显示表项的最大个数,取值1~500。
count:只显示表项计数。
display hardware internal drv_l2 four-irf forward-path命令用来显示四框IRF各种组网中框与框之间转发路径,显示信息见描述表。
display hardware internal drv_l2 four-irf forward-path slot slot-number
Probe视图
slot-number:取值为当前在位的接口板或主控板。
display hardware internal drv_l2 mstp命令用来显示STP实例硬件表项状态或者STP/DLDP/LACP/ETHOAM的软件表项状态。
display hardware internal drv_l2 mstp slot slot-number { instance instance-Id software  | chip chip-number instance instance-Id hardware }
Probe视图
software:指定显示软件表项。
hardware:指定显示硬件表项。
slot-number:取值为当前在位的接口板Id号。
instance-Id:指定实例号,软件表项取值0~255,硬件表项取值0~4095。
display hardware internal drv_l2 port global-info命令用来显示指定端口相关全局变量。
display hardware internal drv_l2 port global-info interface interface-name
Probe视图
display hardware internal drv_l2 port mac-ctrl-reg命令用来显示端口的MAC控制寄存器内容
display hardware internal drv_l2 port mac-ctrl-reg interface { interface-type interface-number | interface-name }
Probe视图
display hardware internal drv_l2 port mib-counters-reg命令用来显示指定端口的MIB统计控制寄存器内容。
display hardware internal drv_l2 port mib-counters-reg interface { interface-type interface-number | interface-name }
Probe视图
display hardware internal drv_l2 port port-status-reg命令用来显示端口的状态寄存器内容。
display hardware internal drv_l2 port port-status-reg interface { interface-type interface-number | interface-name }
Probe视图
【参数】。
display hardware internal drv_l2 port vlan-qos-confi命令用来显示Port VLAN and QoS Configuration Table寄存器信息
display hardware internal drv_l2 port vlan-qos-config interface { interface-type interface-number | interface-name }
Probe视图
display hardware internal drv_l2 port { port-peak-rate | port-state-info | port-traffic-state }命令用来显示指定端口或所有端口状态/流量/历史峰值变化记录
display hardware internal drv_l2 port { port-peak-rate | port-state-info | port-traffic-state } { interface interface-name | slot slot-number }
Probe视图
display hardware internal drv_l2 trunk命令用来显示链路聚合单播表和Non-Trunk表
display hardware internal drv_l2 trunk trunk-id slot slot-number chip chip-number
Probe视图
trunk-id:聚合组ID,范围:1~255。
display hardware internal drv_l2 trunk designated-port-entry命令用来显示链路聚合多播表
display hardware internal drv_l2 trunk designated-port-entry index slot slot-number chip chip-number
Probe视图
index:链路聚合多播表的索引,取值为0~15。
display hardware internal drv_l2 vlan vlan-hw-table命令用来显示指定槽位和芯片的VLAN硬件表项信息。
display hardware internal drv_l2 vlan vlan-hw-table { start-vlan start-vlan-id [ max-count count-num ] | vlan vlan-id } slot slot-number chip chip-number
Probe视图
start-vlan-id:指定显示的第一个VLAN,取值0~4095。
count-num:显示VLAN的最大个数,取值1~10。
vlan-id:指定显示的VLAN ID,取值0~4095。
display hardware internal drv_l2 vlan vlan-port-tagged命令用来显示VLAN-TAG端口相关信息。
display hardware internal drv_l2 vlan vlan-port-tagged vlan-id slot slot-number
Probe视图
vlan-id: VLAN 取值<1 - 4094>。
display hardware internal ekdm命令用来显示指定单板上保存的单板核心数据。
display hardware internal ekdm slot slot-number cpu cpu-number
Probe视图
slot slot-number:单板的槽位号。
cpu cpu-number:cpu号。
display hardware internal ekdm-sync命令用来显示指定主控板主CPU上或辅助CPU上保存的各单板间核心数据同步的状态,当不指定主控板槽位号时,显示的是主用板上的信息。
display hardware internal ekdm-sync [ mr-slot cpu-number ]
Probe视图
mr-slot:主控板槽位号。
cpu-number: CPU号,取值范围:0~1。
display hardware internal fa flow-control enable slot chip命令用来显示FA端口的流控使能状态。
display hardware internal fa flow-control enable slot slot-number chip chip-num
Probe视图
slot-number:目的接口板槽位,具体视机框而定
chip-num:PP芯片在单板上局部编号(0~3)
display hardware internal fa flow-control status slot chip命令用来显示FA端口收到的流控状态。
display hardware internal fa flow-control status slot slot-number chip chip-num
Probe视图
display hardware internal fa fport-cell-statistic slot chip命令用来实现FA端口Cell收发统计信息的显示功能。
display hardware internal fa fport-cell-statistic slot slot-number chip chip-num
Probe视图
配置命令,参见1.1.7和 1.1.8。
display hardware internal fa fport-rx-cell-drop slot chip命令用来显示端口Cell接收丢弃计数。
display hardware internal fa fport-rx-cell-drop slot slot-number chip chip-num
Probe视图
display hardware internal fa fport-tx-cell-drop slot chip命令用来显示端口Cell发送丢弃计数。
display hardware internal fa fport-tx-cell-drop slot slot-num chip chip-num
Probe视图
display hardware internal fa fport-tx-fifo-status slot chip命令用来显示端口FIFO状态。
display hardware internal fa fport-tx-fifo-status slot slot-number chip chip-num
Probe视图
本命令读取Fport  Fifo状态寄存器100次,只记录发生过XOFF的Fifo及次数。如果没有发生过XOFF,打印"No xoff occurs!"。
display hardware internal fa voq drop slot chip unit命令用来显示VOQ丢弃计数的功能。
display hardware internal fa voq drop slot slot-num chip chip-num unit unit-num
Probe视图
unit-num:VOQ Unit(0~1)
display hardware internal fa voq statistic slot  chip unit命令用来显示VOQ计数的功能。
display hardware internal fa voq statistic slot slot-number chip chip-num  unit unit-num
Probe视图
slot-number:目的接口板槽位,具体视机框而定。
chip-num:PP芯片在单板上局部编号(0~3)。
unit-num:VOQ Unit(0~1)。
display hardware internal fabric connectivity-table命令用来查看连通性信息。
display hardware internal fabric connectivity-table slot slotid chip chipnum
Probe视图
slotid:单板的槽位号,范围为当前在位接口板槽位号;
chipnum:单板的在位芯片号,范围0-3。
当单板插拔或链路变化时,会改变链路的连接状态,为了直接了解链路物理连接信息,增加本功能用于实现连通性信息的查询。
display hardware internal fabric d-function命令用来实现直接调用dune接口来实现其具体接口功能
display hardware internal fabric d-function d-function-id slot slot-number chip chipnum [ help ] [ param1 [ param2 [ param3 [ param4 [ param5 ] ] ] ] ]
Probe视图
d-function-id:dune的接口在命令行中指定的序号。
slot-number:目的接口板槽位。
chipnum:FAP或FE芯片在单板上局部编号(0~3)。
param1:参数一。
param2:参数二。
param3:参数三。
param4:参数四。
param5:参数五。
display hardware internal fabric fap flow-queue-table命令用来实现输出FQL表项详细信息,包括流类型,流ID号,源队列号和源FAP设备号。
display hardware internal fabric fap flow-queue-table slot slotid  chip chipnum  [ flownum [ querylen ] ]
Probe视图
chipnum:单板的在位芯片号,范围0-3;
flownum:查询的流ID号,范围0-(12K-1),默认值为0;
querylen:查询长度,范围1-16,默认值为8。
查询表 Flow to FIP and Queue Mapping and Flow Slow Enable Mode (FFQ)。
单播是根据队列和调度流的映射来实现的,因此本功能提供了调度流到队列之间的映射关系,通过本功能可以查看之间的映射是否正确。
display hardware internal fabric fap portqos命令用来查看FAP芯片内所配置的端口级联层次关系。
display hardware internal fabric fap portqos slot slotnum chip chipnum port portnum [ wrrgroup [ INTEGER<0-3> ] ] [ tc [ INTEGER<0-7> ] ] [ credit-rate ]
Probe视图
slotid:单板的槽位号,范围为当前在位接口板槽位号。
portnum: 分配带宽得端口号,与出端口对应。
creditrate: 查看对应flow的credit分配速率。
display hardware internal fabric fap queue-flow-table命令用来显示输出QFL表项详细信息,包括队列类型,所映射的流,目的FAP设备号和端口,队列长度等。
display hardware internal fabric fap queue-flow-table slot slotid chip chipnum
[ queuenum [ querylen ] ]
Probe视图
queuenum:查询的队列ID号,范围0-(12K-1),默认值为0;
querylen:查询长度,范围1-8,默认值为8。
display hardware internal fabric fap queue-flow-table tgtslot命令用来根据对端的槽位号芯片号和端口号查询QFL表项详细信息,包括队列类型,所映射的流,目的FAP设备号和端口,队列长度等。
slot tgt-slotid chip tgt-chipnum port tgt-portnum
Probe视图
tgt-slotid:目的槽位号
tgt-chipnum:目的芯片号
tgt-portnum:目的端口号(Phy端口号)。
可以根据下面的命令得到phy端口号:
display hardware internal intf port-info { interface { interface-type interface-number | interface-name } | slot slotid }
比如:
(1)      display hardware internal intf port-info slot 5
(2)     display hardware internal intf port-info interface GigabitEthernet 5/0/1
display hardware internal fabric fap queue-size命令用来查看指定队列的大小,不输入查询长度。也可查看以某条队列开始的几条队列大小,最大的查询长度是100。
display hardware internal fabric fap queue-size slot slotid  chip chipnum queuenum [querylen]
Probe视图
chipnum:单板的在位芯片号;
queuenum:查询的队列ID号,范围0-(12K-1);
querylen:查询长度,范围1-100。
display hardware internal fabric fap queue-size non-empty命令用来查找最近100条非空队列以及队列的大小。
display hardware internal fabric fap queue-size slot slotid chip chipnum non-empty [ start-queueunum ] [verbose]
Probe视图
start-queueunum: 查询的起始队列ID号,范围0-(12K-1)。
verbose:打印每个队列的运行时关键信息
默认从第0号队列查询,如果输入队列号,则从指定队列开始查找。
display hardware internal fabric link-status命令用来查询SERDES链路上下电及一些参数。
display hardware internal fabric link-status slot slotid chip chipnum [link linknum  ]
Probe视图
chipnum:单板的在位芯片号;
linknum:配置SERDES的Link号。
display hardware internal fabric mc-route命令用来查询fabric vidx管理数据,vidx软件表项。
display hardware internal fabric mc-route { physical | virtual | vlan } slot mr-slotnum offset offset
display hardware internal fabric mc-route physical slot sfc-slotnum offset offset
display hardware internal fabric mc-route slot sfc-slotnum chip chip-num offset  offset
physical :下发硬件的VIDX组播软件表,支持主控板和网板上查询
vlan:VLAN组播表,仅支持主控板上查询
virtual:虚拟fabric vidx组播表,仅支持主控板上查询
mr-slotnum :主控板槽号
sfc-slotnum:网板槽号
offset:指定vidx号。
不指定physical/ virtual / vlan参数时,仅支持网板槽号,查询的是网板寄存器中的表项。
查询网板上的硬件和软件表项时,对于不在位的接口板,对fap-devportmap的转换,默认是按照4芯片单板来转换。
display hardware internal fabric mc-route counter命令用来显示有关交换网组播操作的计数。
display hardware internal fabric mc-route counter slot slot-number
Probe视图
slot-number:主控板槽号。
display hardware internal fabric mc-route mode 命令用来查询lbi模式。
Probe视图
mode:查询lbi模式
display hardware internal fabric mc-route phylist 命令用来针对一个具体的list显示其每个游标下挂的phyvidxnode情况。
display hardware internal fabric mc-route phylist slot slot-number block block-num list list-num
Probe视图
slot-number:主控板槽号
block-num:block号,每个block只能被一个MDC使用
list-num:block下挂contrl list号,此值表征端口数
display hardware internal fabric prbs-mode 命令用来查询prbs模式,可以具体到某个链路。
display hardware internal fabric prbs-mode slot slotid chip chipnum [lane lanenum]
Probe视图
slotid:业务板槽号
chipnum:芯片号
lanenum:链路号
display hardware internal fabric register dump命令用来显示用于在主控板的控制台上输出查询的FAP内部寄存器值。
display hardware internal fabric register slot slotid chip chipnum dump
Probe视图
chipnum:单板的在位芯片号。
display hardware internal fabric unicast-table命令用来查看单播信息。
display hardware internal fabric unicast-table slot slotid chip chipnum
Probe视图
chipnum:单板的在位芯片号。
单播路由表由硬件自动生成。FAP与FE通过交互可达信元,各自形成自己的单播路由表。整个过程不需要软件干预。考虑到问题的定位以及可维护性,增加单播表查询功能。
display hardware internal fcoe dit命令用来显示FC路由与dit资源相关的内部信息。
独立运行模式:
display hardware internal fcoe dit dit-id slot slot-number
IRF模式:
display hardware internal fcoe dit dit-id chassis chassis-number slot slot-number
Probe视图
dit dit-id:显示指定dit id相关的FC路由相关信息。
slot slot-number:显示指定单板上dit相关的FC路由内部信息。slot-number表示单板所在的槽位号。 (独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上dit相关的FC路由内部信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。 (IRF模式)
display hardware internal fcoe interface Vfc命令用来显示和Vfc相关的内部信息。
独立运行模式:
display hardware internal fcoe interface Vfc interface-number vlan-id slot slot-number
IRF模式:
disdisplay hardware internal fcoe interface Vfc interface-number vlan-id chassis chassis-number slot slot-number
Probe视图
interface Vfc interface-number:显示指定Vfc接口相关的内部信息。
vlan-id: 指定要显示的vlan。
slot slot-number:显示指定单板上Vfc接口相关的内部信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板Vfc接口相关的内部信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display hardware internal fcoe key-info命令用来显示FCoE交换机的内部关键信息。
独立运行模式:
display hardware internal fcoe key-info [vsan vsan-id] slot slot-number
IRF模式:
display hardware internal fcoe key-info [vsan vsan-id] chassis chassis-number slot slot-number
Probe视图
vsan vsan-id:显示指定vsan的FCoE交换机的内部关键信息。
slot slot-number:显示指定单板上FCoE的内部关键信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板FCoE交换机的内部关键信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display hardware internal fcoe op route命令用来显示FC路由操作记录的内部信息。
独立运行模式:
display hardware internal fcoe op route [clear] [error] slot slot-number
IRF模式:
display hardware internal fcoe op route [clear] [error] chassis chassis-number slot slot-number
Probe视图
clear:删除之前的记录信息。
error:显示没有下发成功的记录信息。
slot slot-number:显示指定单板上路由操作记录的内部信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上路由操作记录的内部信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display hardware internal fcoe route命令用来显示FC路由的内部信息。
独立运行模式:
display hardware internal fcoe route route-id slot slot-number
IRF模式:
display hardware internal fcoe route route-id chassis chassis-number slot slot-number
Probe视图
route route-id:FC路由内部编号,显示指定route-id的FC路由的内部信息。
slot slot-number:显示指定单板上FC路由的内部信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板FC路由的内部信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
display hardware internal forward counter命令用来输出关键的转发路径计数,包括PP、XBAR、FAP、DX(级联芯片,GV48和XP32单板上有)和FE上的计数信息。
独立运行模式:
display hardware internal forward counter [ slot slot-number ] [ drop | hgl | clear ]
display hardware internal forward counter { pp | fap | fe | dx } [ slot slot-number [ chip chip-num ] ] [ drop | hgl | clear ]
IRF模式:
display hardware internal forward counter [ chassis chassis-num slot slot-number ] [ drop |
 hgl | clear ]
display hardware internal forward counter { pp | fap | fe | dx } [ chassis chassis-num slot slot-number ] [ chip chip-num ] [ drop | hgl | clear ]
Probe视图
chassis-num:框号,1~2,独立运行模式不需要输入;
slot-number:目的槽位,具体视机框而定;
chip-num:转发芯片在局部编号(XBAR:0~1,PP:0~3,FAP:0~3,DX:4~7,FE:0~1);
pp:PP芯片,在接口板上;
fap:FAP芯片,在S12500接口板上;
fe:交换网芯片,在S12500网板上;
dx:级联芯片,在级联接口板上;
drop:只输出丢弃或错误计数,不输入drop,则输出所有计数;
hgl:与HGL错误相关的计数;
clear:清除所有计数,不输出计数。
根据具体需求,区分HGL相关的计数信息和丢包有关的计数信息;如果只需要将这些寄存器清零,可以键入关键字clear即可。
display hardware internal forward err-info命令用来输出系统中发生的关键中断,包括PP、XBAR、FAP、DX(级联芯片,GV48和XP32单板上有)和FE上的中断信息。
独立运行模式:
display hardware internal forward err-info [ slot slot-number ] [severity | hgl | clear ]
display hardware internal forward err-info { pp | fap | fe | dx } [ slot slot-number [ chip chip-num ] ] [severity | hgl | clear ]
 IRF模式:
display hardware internal forward err-info [ chassis chassis-num slot slot-number ] [severity | hgl | clear ]
display hardware internal forward err-info { pp | fap | fe | dx } [ chassis chassis-num slot slot-number ] [ chip chip-num ] [severity | hgl | clear ]
Probe视图
pp:PP芯片,在接口板上;
dx:级联芯片,在级联接口板上;
severity:只输出发生的丢弃或错误中断,不输入severity,输出所有发生过的中断;
hgl:与HGL错误相关的中断;
clear:清除所有中断,不输出。
display hardware internal fwd egress-resource slot chip txq-port命令用来显示txq端口buffer计数的功能。
display hardware internal fwd egress-resource slot slot-number chip chip-num txq-port txq-port-num
Probe视图
chip-num:PP芯片在单板上局部编号,具体视单板类型而定
txq-port-num:txq端口号(0~69)
display hardware internal fwd ingress-buffer slot chip physical-port命令用来显示物理端口上行buffer计数的功能。
display hardware internal fwd ingress-buffer slot slot-number chip chip-num physical-port physical-port-num
Probe视图
chip-num:PP芯片在单板上局部编号,具体视单板类型而定。
physical-port-num:物理端口号(0~63)。
display hardware internal fwd pfc key-info slot chip port命令用来查看PFC关键信息,包括虚拟端口映射的Bank&PFC port、配置的Profile、PFC接收对应的TxQ port、每个优先级的Count信息和门限配置。
display hardware internal fwd pfc key-info slot slot-number chip chip-num port port-num
Probe视图
slot-number:槽位号。
chip-num:芯片号。
port-num:虚拟端口号。
display hardware internal ha masterboard-standbyboard命令用来显示主备倒换信息。
display hardware internal ha masterboard-standbyboard slot slot-number [ cpu cpu-number ]
Probe视图
cpu cpu-number:CPU芯片号,范围0~1。
display hardware internal ha switch-info命令用来显示主备倒换中断记录信息。
display hardware internal ha switch-info slot slot-number cpu cpu-number [ clear ]
Probe视图
clear:清除计数。
display hardware internal ibc control-path-check state命令用于查询控制通道检测状态。显示内容包括板在位状态、是否使能检测、是否正在检测和检测失败的计数。
display hardware internal ibc control-path-check state slot slot-number
Probe视图
display hardware internal ibc lanswitch egresscntr | ingresscntr命令用来显示指定槽号指定LSW芯片上Bridge Couter 计数信息。
display hardware internal ibc lanswitch slot  slot-number lsw lsw-number { egresscntr | ingresscntr }
Probe视图
ingresscntr:绑定入方向Bridge Couter。
egresscntr:绑定出方向Bridge Counter。
slot-number:槽位号。
lsw-number:LSW芯片号。范围0~1。
display hardware internal ibc lanswitch mactable命令用来显示指定LSW芯片上的MAC转发表项。
display hardware internal ibc lanswitch slot slot-number lsw lsw-number mactable
Probe视图
slot-number:槽位号。
Slot-number:目的槽号。
display hardware internal ibc lanswitch portmap命令用来显示指定槽号指定LSW 上端口的连接表查询,可以查看到LSW 芯片上所有端口连接对端的信息情况,包括对端的槽号、LSW芯片号、对端物理端口号、对端CPU ID和对端PP ID。根据该表信息即可确定板间通讯报文的传输途径。
display hardware internal ibc lanswitch slot  slot-number lsw lsw-number portmap
Probe视图
slot-number:槽位号。
lsw-number:LSW芯片号。
display hardware internal ibc lanswitch portmib命令用来显示指定槽号指定LSW芯片上指定端口的转发信息,包括端口PVID信息、端口link连接状态、端口入方向和出方向报文信息统计。该计数信息是反映前一次敲此命令和本一次敲此命令时间间隔内,报文信息统计。
display hardware internal ibc lanswitch slot  slot-number lsw lsw-number portmib phyport-number
Probe视图
slot-number:槽位号。
lsw-number:LSW芯片号。
phyport-number:物理端口号
display hardware internal ibc lanswitch vlan命令用来显示指定槽号指定LSW芯片上Vlan 表信息。
display hardware internal ibc lanswitch slot slot-number lsw lsw-number vlan vlanId
Probe视图
slot-number:槽位号。
vlanId:查询的Vlan ID
display hardware internal ibc rxpkt命令用来打印指定槽号指定LSW芯片接收到的指定报文特定的报文内容。
display hardware internal ibc rxpkt slot slot-number cpu cpu-number [ number number | length length | frametype type | srcmac mac | vlan vlanID |  queid queid  | [ match matchPosition matchLength matchData | missmatch missmatchPosition matchLength matchData ] ]
Probe视图
slot-number:槽位号。
number:打印报文个数,范围1~1000。
length:打印报文长度,范围64~600。
type:指定报文类型。
mac:指定报文的源MAC,H-H-H形式。
vlanID:指定VlanID,范围0~4095。
queid: 指定收包队列ID,范围0~7 。
matchPosition :指定从报文哪个位置开始匹配。
matchLength :指定需要匹配多少个字段(1~8)。
matchData :指定需要匹配的内容(2~16)。
missmatchPosition :指定从报文哪个位置开始过滤。
missmatchLength :指定需要过滤多少个字段(1~8)。
missmatchData :指定需要过滤的内容(2~16)。
display hardware internal ibc rxque命令用来显示或清除指定槽号指定CPU 上的板间通讯报文接收队列的信息。
display hardware internal ibc rxque slot slot-number cpu cpu-number [clear]
Probe视图
Clear:将队列信息清空。
display hardware internal ibc txpkt命令用来打印指定槽号指定LSW芯片发送的指定报文特定的报文内容。
display hardware internal ibc txpkt slot  slot-number cpu cpu-number  [number number | length length | frametype type | dstmac mac | vlan vlanID | [ match matchPosition matchLength matchData  | missmatch missmatchPosition matchLength matchData ] ]
Probe视图
slot-number:槽位号。
type:指定报文类型。
mac:指定报文的目的MAC,H-H-H形式。
display hardware internal ipuc adj index命令用来显示指定槽位接口板指定ARP/ND硬件表项的信息。
独立运行模式:
display hardware internal ipuc adj index index slot slot-number
IRF模式:
display hardware internal ipuc adj index index chassis chassis-number slot slot-number
Probe视图
index index: ARP/ND硬件索引
display hardware internal ipuc  cnt命令用来查看路由引擎计数器信息。路由所有Next-hop默认绑定计数器0。
独立运行模式:
display hardware internal ipuc  cnt index slot slot-number
IRF模式:
display hardware internal ipuc  cnt index chassis chassis-number slot slot-number
Probe视图
 cnt:显示IP单播引擎计数器。
index:显示特定计数器计数,数值0-3。
display hardware internal ipuc fib命令用来查看CPSS层面的精确匹配和最长匹配查找的NH信息。不输入掩码使用最长匹配查找。没有找到显示“The prefix not found.”。
独立运行模式:
display hardware internal ipuc fib { [ vrid  ] ipv4-addr | ipv6-addr } [ mask-length ] slot slot-number
IRF模式:
display hardware internal ipuc fib { [ vrid  ] ipv4-addr | ipv6-addr } [ mask-length ] chassis chassis-number slot slot-number
Probe视图
 vrid:VRF-ID ,范围1~1023(与系统工作模式有关)
ipv4-addr:显示ipv4地址。
ipv6-addr:显示ipv6地址。
mask-length:掩码长度。Ipv4 <0-32>, ipv6 <0-128>.
display hardware internal ipuc fib number命令用来查看指定VRF的单播表项统计计数。不携带vrid显示所有vrf的fib总信息。
独立运行模式:
display hardware internal ipuc fib number [ vrid ] slot slot-number
IRF模式:
display hardware internal ipuc fib number [ vrid ] chassis chassis-number slot slot-number
Probe视图
fib:显示单播表项的统计。
vrid:VRF ID,范围1~1023(与系统工作模式有关)
display hardware internal ipuc op命令用来查看slot所在全部mdc的路由表项操作记录信息,默认记录200条。循环记录,最新的记录最先显示。
独立运行模式:
display hardware internal ipuc op { ipv4 | ipv6 | vn }  [ error ] [ clear ] slot slot-number
IRF模式:
display hardware internal ipuc op { ipv4 | ipv6 | vn }  [ error ] [ clear ] chassis chassis-number  slot slot-number
Probe视图
op:显示操作记录。
ipv4:显示ipv4路由转发表项的操作记录。
ipv6:显示ipv6路由转发表项的操作记录。
vn:显示vn路由转发表项的操作记录。
error:显示所有非成功的操作记录。
clear:清除操作记录。
display hardware internal ipuc op adj命令用来显示主控板或指定槽位接口板上的arp/nd操作记录。
独立运行模式:
display hardware internal ipuc op adj [ error ] [ clear ] slot slot-number
IRF模式:
display hardware internal ipuc op adj [ error ] [ clear ] chassis chassis-number slot slot-number
Probe视图
error:只显示错误操作记录。
clear:清除操作记录。
display hardware internal l2mc dit命令用来查看EVILINK-DIT映射表;根据EVILINK的索引值,查询EVILINK下关联的所有组播表项的DIT值
独立运行模式:
display hardware internal l2mc dit evi-ifindex ifindex slot slot-number
IRF模式:
display hardware internal l2mc dit evi-ifindex ifindex chassis chassis-number slot slot-number
Probe视图
ifindex :EVI LINK接口索引。
slot slot-number:显示指定接口板上的信息,slot-number表示接口板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定接口板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示接口板所在的槽位号。(IRF模式)
display hardware internal l2mc mac-table { igsp | mldsp | static } 命令用来查询符合条件的驱动二层组播MAC shadow表内容,该命令只在接口板提供。
独立运行模式:
display hardware internal l2mc mac-table { igsp | mldsp | static } [ mac-address ] vlan vlan-id slot slot-number chip chip-number
IRF模式:
display hardware internal l2mc mac-table { igsp | mldsp | static } [ mac-address ] vlan vlan-id chassis chassis-number slot slot-number chip chip-number
Probe视图
igsp:查询的是MAC-ipv4 shadow表。
mldsp:查询的是MAC-ipv6 shadow表。
static:查询的是多播多端口MAC。
mac-address:要查询的MAC地址。
vlan-id:要查询的VLAN号。
chip chip-number:指定显示信息所在的芯片号。
display hardware internal l2mc { igsp | mldsp | static } 命令用来查询符合条件的驱动二层组播MAC shadow表内容,该命令只在主控板提供。
独立运行模式:
display hardware internal l2mc { igsp | mldsp | static } [ mac-address ] vlan vlan-id slot slot-number
IRF模式:
display hardware internal l2mc { igsp | mldsp | static } [ mac-address ] vlan vlan-id chassis chassis-number slot slot-number
Probe视图
mac-address:要查询地址。
vlan-id:要查询的VLAN号。
slot slot-number:显示指定主控板上的信息,slot-number表示主控板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定主控板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示主控板所在的槽位号。(IRF模式)
1.1.115  display hardware internal l3mc counter
display hardware internal l3mc counter命令用来显示接口板指定计数器的统计信息,对于多PP单板,显示每一个PP上该计数器的统计信息。
独立运行模式:
display hardware internal l3mc counter cnt-id slot slot-number  [ clear ]
IRF模式:
display hardware internal l3mc counter cnt-id chassis chassis-number slot slot-number  [ clear ]
Probe视图
counter cnt-id:计数器ID,范围是2,3。
clear:清除历史计数。
可以用单播的命令display hardware internal ipuc cnt cnt-number chassis chassis-number slot slot-number显示计数器0。
1.1.116  display hardware internal l3mc dit
display hardware internal l3mc dit命令用来显示接口板某特定DIT以及以该DIT为头结点的DIT链的信息,当遇到IsLast标识为yes时,中止显示;当DIT链中的DIT节点超过64条时中止显示,并提示“More DITs need to display.”,多于64条DIT节点的DIT链可以通过查询显示信息中的Next DIT值来显示。
独立运行模式:
display hardware internal l3mc dit dit-id [ verbose ] slot slot-number chip chip-number
IRF模式:
display hardware internal l3mc dit dit-id [ verbose ] chassis chassis-number slot slot-number chip chip-number
Probe视图
chip chip-number :芯片编号,0表示范围为0~3;
dit dit-id :具体的dit号;
verbose:显示该表项详细信息,如果没有,则只显示dit-id和下一跳dit-id,不显示具体的信息。
查询的DIT必须是组播使用的DIT,否则显示的信息不正确。
1.1.117  display hardware internal l3mc ditcnt
display hardware internal l3mc ditcnt命令用来显示指定计数器上经过DIT硬件表项转发的组播报文计数。
独立运行模式:
display hardware internal l3mc ditcnt cnt-id slot slot-number
IRF模式:
display hardware internal l3mc ditcnt cnt-id chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。单板包括主控板和接口板。(独立运行模式)
ditcnt cnt-id:计数器ID,范围为0,1;
1.1.118  display hardware internal l3mc lbp
display hardware internal l3mc lbp命令用来显示主控板或者接口板聚合环回口软件表项信息。
独立运行模式:
display hardware internal l3mc lbp slot slot-number
IRF模式:
display hardware internal l3mc lbp chassis chassis-number slot slot-number
Probe视图
1.1.119  display hardware internal l3mc localvpninfo vpnid
display hardware internal l3mc localvpninfo vpnid命令用来根据驱动VPN号查询对应的平台VRF索引及驱动VPN号的使用情况。
独立运行模式:
display hardware internal l3mc localvpninfo vpnid vpnid slot slot-number
IRF模式:
display hardware internal l3mc localvpninfo vpnid vpnid chassis chassis-number slot slot-number
Probe视图
vpnid vpnid:驱动VPN,vpnid表示VPN号,取值范围为0~1023。
slot slot-number:显示指定接口板对应的平台VRF索引及驱动VPN号的使用情况,slot-number表示接口板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定接口板对应的平台VRF索引及驱动VPN号的使用情况,chassis-number表示设备在IRF中的成员编号,slot-number表示接口板所在的槽位号。(IRF模式)
1.1.120  display hardware internal l3mc lpm bipim ipv4
display hardware internal l3mc lpm bipim ipv4命令用来显示三层组播前缀表。
独立运行模式:
display hardware internal l3mc lpm bipim ipv4 vpn-id source-address group-address slot slot-number chip chip-id
IRF模式:
display hardware internal l3mc lpm bipim ipv4 vpn-id source-address group-address chassis chassis-number slot slot-number chip chip-id
Probe视图
vpn-id:局部VPN号,取值范围为0~1023。
source-address:组播源的IP地址。
group-address:组播组的IP地址。
slot slot-number:显示指定接口板的三层组播前缀表,slot-number表示接口板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定接口板的三层组播前缀表,chassis-number表示设备在IRF中的成员编号,slot-number表示接口板所在的槽位号。(IRF模式)
chip chip-id:显示指定芯片的三层组播前缀表,chip-id表示芯片号。
1.1.121  display hardware internal l3mc lpm ipv4/ipv6
display hardware internal l3mc lpm ipv4/ipv6命令用来显示接口板硬件表项的信息。对于ipv4,只显示(V,S,G),对于ipv6,只显示(S,G)。
独立运行模式:
display hardware internal l3mc lpm ipv4 [vpn-id ] sip gip slot slot-number chip chip-number
display hardware internal l3mc lpm ipv6 sip gip slot slot-number chip chip-number
IRF模式:
display hardware internal l3mc lpm ipv4 [vpn-id ] sip gip chassis chassis-number slot slot-number chip chip-number
display hardware internal l3mc lpm ipv6 sip gip chassis chassis-number slot slot-number chip chip-number
Probe视图
vpn-id :具体的VPN号,0表示公网;
sip :源IP地址;
gip :组IP地址;
1.1.122  display hardware internal l3mc mroute ipv4/ipv6
display hardware internal l3mc mroute ipv4/ ipv6命令用来显示指定接口板CPSS软件表项以及对应的Nexthop具体信息。
独立运行模式:
display hardware internal l3mc mroute ipv4 vpn-id sip gip [ verbose ] slot slot-number
display hardware internal l3mc mroute ipv6 vpn-id sip gip [ verbose ] slot slot-number
IRF模式:
display hardware internal l3mc mroute ipv4 vpn-id sip gip [ verbose ] chassis chassis-number slot slot-number
display hardware internal l3mc mroute ipv6 vpn-id sip gip [ verbose ] chassis chassis-number slot slot-number
Probe视图
vpn-id:具体的VPN号,0表示公网。
sip:源IP地址。
gip:组IP地址。
verbose :当指定verbose时,显示详细信息;不然,只显示(VPN,SIP,GIP)和Nexthop信息。
需要注意的是,当输入SIP=0.0.0.0时,表示显示(*,G)表项,当输入(0.0.0.0,0.0.0.0)时,表示显示默认路由表项。
1.1.123  display hardware internal l3mc nexthop
display hardware internal l3mc nexthop命令用来显示某个组播NexthopId以及下挂的DIT链的信息,最多显示的DIT链结点为8个,对于组播VLAN plus等需要显示更多DIT的情况,要显示多于8个的DIT请使用相应的DIT链显示命令display hardware internal l3mc dit。
独立运行模式:
display hardware internal l3mc nexthop nexthop-id [ verbose ] slot slot-number chip chip-number
IRF模式:
display hardware internal l3mc nexthop nexthop-id [ verbose ] chassis chassis-number slot slot-number chip chip-number
Probe视图
chip chip-number :芯片号,范围是0~3;
nexthop nexthop-id :具体的nexthop-id值;
verbose :是否显示DIT的详细信息。
只能查询三层组播使用的nexthop-id,包括组播默认路由使用的nexthop-id,其他值则输出“The nexthop is not used.”。
1.1.124  display hardware internal l3mc tcam
display hardware internal l3mc tcam命令用来显示接口板上IPv6组播使用的TCAM硬件表项信息。
独立运行模式:
display hardware internal l3mc tcam tcam-id slot slot-number
IRF模式:
display hardware internal l3mc tcam tcam-id chassis chassis-number slot slot-number
Probe视图
tcam tcam-id :具体的TCAM软件资源号。
输入的必须是使用的Tcam-id才显示信息;不同工作模式下,Tcam-id的取值范围不一样。
1.1.125  display hardware internal l3mc tunnel
display hardware internal l3mc tunnel 命令用来显示组播VPN隧道硬件表项。
独立运行模式:
display hardware internal l3mc tunnel tunnel-id slot slot-number chip chip-number
IRF模式:
display hardware internal l3mc tunnel tunnel-id chassis chassis-number slot slot-number chip chip-number
Probe视图
tunnel tunnel-id:组播VPN的MTunnel ID。
1.1.126  display hardware internal l3mc vidx
display hardware internal l3mc vidx命令用来显示接口板上VIDX号在本板各芯片的软硬件信息。
独立运行模式:
display hardware internal l3mc vidx vidx-id slot slot-number
IRF模式:
display hardware internal l3mc vidx vidx-id chassis chassis-number slot slot-number
Probe视图
vidx vidx-id :具体的VIDX号,取值范围为2049~4089。
注意:查询的VIDX必须是使用的组播使用的局部VIDX号,否则显示的信息不正确。
1.1.127  display hardware internal l3mc vrfinfo vrid
display hardware internal l3mc vrfinfo vrid命令用来根据平台VRF索引查询对应的驱动VPN号及使用情况。
独立运行模式:
display hardware internal l3mc vrfinfo vrid vrf-id slot slot-number
IRF模式:
display hardware internal l3mc vrfinfo vrid vrf-id chassis chassis-number slot slot-number
Probe视图
vrid vrf-id:平台VRF索引,vrf-id表示索引号,取值范围为0~1023。
slot slot-number:显示指定接口板对应的驱动VPN号及使用情况,slot-number表示接口板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定接口板对应的驱动VPN号及使用情况,chassis-number表示设备在IRF中的成员编号,slot-number表示接口板所在的槽位号。(IRF模式)
1.1.128  display hardware internal mirror
display hardware internal mirror命令用来显示软、硬件中出入方向镜像配置。
display hardware internal mirror { ingress | egress } slot slot-number  chip chip-number  [ hardware ]
display hardware internal mirror { ingress | egress } slot slot-number  chip mdc_chip
Probe视图
ingress:ingress方向。
egress:egress方向。
slot-number:槽位号。在位接口板有效。
chip-number:本地芯片号。范围0~7,mdc_chip表示虚芯片。
1.1.129  display hardware internal mpls  dit
display hardware internal mpls dit命令用来查询DIT表项信息。
display hardware internal mpls dit mpls dit-index slot slot-number
display hardware internal mpls dit vpls dit-index slot slot-number
Probe视图
dit dit-index:DIT索引。
MPLS使用的DIT类型只有两种:MPLS、VPLS。目前仅有VPLS类型DIT在使用。DIT表项指向端口的出方向信息。
1.1.130  display hardware internal mpls  frr dit
display hardware internal mpls frr dit命令用来查询表项信息。FRR DIT实现快速切换。
display hardware internal mpls frr dit dit-index slot slot-number
Probe视图
dit dit-index:下一跳标签转发表项。
1.1.131  display hardware internal mpls  nhlfe
display hardware internal mpls nhlfe命令用来查询NHLFE表项信息。
display hardware internal mpls nhlfe nhlfe-value slot slot-number
Probe视图
nhlfe nhlfe-value:下一跳标签转发表项
查询下一跳标签转发表项的信息,该表项中包含以下信息,
1.1.132  display hardware internal mpls  nhlfecnt
display hardware internal mpls nhlfcnt 命令用来查询绑定了NHLFE的指定计数器内容,首先该命令前先进行NHLFE的绑定操作。
display hardware internal mpls nhlfecnt slot slot-number chip chip-number count-id
Probe视图
count-id:指定的计数器。
1.1.133  display hardware internal mpls  tablesize
display hardware internal mpls tablesize命令用来查询表项信息。
Probe视图
1.1.134  display hardware internal mpls  tticnt
display hardware internal mpls tticnt命令用来查询绑定的TTI计数。
display hardware internal mpls tticnt mpls slot slot-number tti-index
display hardware internal mpls tticnt ipv4 slot slot-number tti-index
display hardware internal mpls tticnt Ethernet { Bridge-Aggregation | GigabitEthernet | InLoopBack  | LoopBack | M-Ethernet | NULL | Register-Tunnel |  EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
display hardware internal mpls tticnt minm  { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
Probe视图
mpls:MPLS类型TTI。
Ethernet:以太类型TTI。
ipv4:IPV4类型TTI。
minm  :MINM类型TTI。
tti-index :TTI索引。
1.1.135  display hardware internal mpls  tunnel
display hardware internal mpls tunnel命令用来查询隧道表项信息。
display hardware internal mpls tunnel tunnel-id slot slot-number
Probe视图
tunnel tunnel-id:隧道索引。
1.1.136  display hardware internal mpls  vpws
display hardware internal mpls vpws命令用来显示VLL软件表项信息。
display hardware internal mpls vpws slot slot-number  inlabel label-value
Probe视图
slot slot-number:slot-number为单板所在的槽位号。
inlabel label-value:VLL业务指定的入标签,标签提示范围根据系统工作模式获取。
该命令行可以提供查询VLL使用的多数软件表项信息。包括AC和PW使用的TTI、DIT、OutLif等。
1.1.137  display hardware internal mpls  vpws actti
display hardware internal mpls vpws actti命令用来查询AC TTI索引。
display hardware internal mpls vpws actti slot slot-number  inlabel label-value
Probe视图
该命令行可以提供查询AC TTI索引,该TTI匹配PORT+VLAN的规则,动作为PUSH一层私网标签,指定PW DIT索引,重定向到PW出接口。
1.1.138  display hardware internal mpls debugging
display hardware internal mpls debugging命令用来查询单板上MPLS业务DEBUG开关状态。
display hardware internal mpls debuging slot slot-number
Probe视图
1.1.139  display hardware internal mpls evi- hashpcl
display hardware internal mpls evi-hashpcl命令用来显示EVI MAC HASH冲突的PCL规则。
display hardware internal mpls evi-hashpclslot slot-number
Probe视图
1.1.140  display hardware internal mpls evi- tunnel
display hardware internal mpls evi- tunnel命令用来显示平台Tunnel相关信息。
display hardware internal mpls evi- tunnel slot slot-number tunnel  interface-number
Probe视图
interface tunnel interface-number:平台Tunnel索引。
1.1.141  display hardware internal mpls evi- vlan
display hardware internal mpls evi-vlan命令用来显示扩展VLAN的内容。
display hardware internal mpls evi-vlan slot slot-number vlan  vlan-id-list
Probe视图
Vlan vlan-id-list:指定了扩展VLAN的范围
1.1.142  display hardware internal mpls evi-info  globalvar
display hardware internal mpls evi-info globalvar命令用来显示EVI使用的全局变量信息。
display hardware internal mpls evi-info globalvar slot slot-number
Probe视图
1.1.143  display hardware internal mpls evi-instance
display hardware internal mpls evi-instance命令用来显示EVI实例的软件表项。
display hardware internal mpls evi-instance slot slot-number tunnel  interface-number
Probe视图
slot slot-number:显示指定单板上EVI 实例软件表项。slot-number为单板所在的槽位号。
tunnel interface-number:显示指定EVI隧道接口下的EVI-Link接口信息。
1.1.144  display hardware internal mpls evi-link
display hardware internal mpls evi-link命令用来显示指定EVI隧道创建的EVI-LINK接口产品软件表项信息。
独立运行模式:
display hardware internal mpls evi-link slot slot-number tunnel  interface-number evi-link interface-number
IRF模式:
display hardware internal mpls evi-link chassis chassis-number slot slot-number tunnel  interface-number evi-link interface-number
Probe视图
slot slot-number:显示指定单板上的LINK软件表项。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的LINK软件表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
evi-link interface-number:显示指定EVI-Link接口的信息。interface-number表示EVI-Link接口编号,取值为已创建的EVI-Link接口的编号
通过本命令可以查看到报文转发过程中使用到的资源信息,包括DIT、隧道、TTI、出接口等。
1.1.145  display hardware internal mpls evi-operation
display hardware internal mpls evi-operation命令用来显示EVI平台下发记录。
display hardware internal mpls evi-operation slot slot-number
Probe视图
1.1.146  display hardware internal mpls infilter
display hardware internal mpls infilter命令用来查询端口上是否使能过滤功能。
display hardware internal mpls infilter slot slot-number
Probe视图
1.1.147  display hardware internal mpls labelinfo inlabel
display hardware internal mpls mpls labelinfo inlabel命令用来查询MPLS标签的内容。
display hardware internal mpls labelinfo inlabel label-value slot slot-number
display hardware internal mpls labelinfo hardware inlabel label-value slot slot-number
Probe视图
inlabel label-value:根据工作模式自己获取标签范围。
该命令行可以查询到该标签对应驱动硬件相关的信息,包括如果是PHP的话终结该标签的TTI,如果是SWAP的话,SWAP的标签值。同时包括出接口信息,TTI更新标记等。
1.1.148  display hardware internal mpls mpls variable
display hardware internal mpls mpls variable命令用来显示MPLS使用到的全局变量的信息。
display hardware internal mpls mpls variable slot slot-number
Probe视图
该调试命令可以查看MPLS各模块在初始化的时候下发的默认TTI、TTL复制的设置、标签分发模式、路由口状态、标签范围、保留标签的范围等。
1.1.149  display hardware internal mpls spb bmacinfo
display hardware internal mpls spb bmacinfo命令用来显示spb bmac软件表项信息。
display hardware internal mpls spb bmacinfo vlan vlanid mac-address H-H-H slot slot-number
Probe视图
vlan vlanid :显示指定BVLAN下的BMAC的软件表项。
mac-address H-H-H:显示指定BMAC软件表项。
slot slot-number:显示指定单板上的BMAC软件表项。slot-number为单板所在的槽位号。
该命令行可以提供查询指定了BVLAN的某一条BMAC软件表项。
1.1.150  display hardware internal mpls spb bvlan
display hardware internal mpls spb bvlan命令用来显示bvlan信息。
display hardware internal mpls spb bvlan vlanid slot slot-number
Probe视图
vlan vlanid :查询指定VLAN是否为BVLAN。
slot slot-number:显示指定单板上BVLAN的信息。slot-number为单板所在的槽位号。
该命令行可以提供查询某一个VLAN是否为BVLAN。
1.1.151  display hardware internal mpls spb fabricvidx
display hardware internal mpls spb fabircvidx命令用来显示用来显示预留的fabric vidx对应的组播组需要组播到哪些芯片哪些端口。
display hardware internal mpls spb fabircvidx slot slot-number chip chip-number mrboard mr-slot-number
Probe视图
slot slot-number:显示指定单板的fabricvidx软件表项信息。
chip chip-number:显示指定单板上指定芯片的fabricvidx软件表项信息。
mrboard slot-number:显示指定主控板上保存的fabricvidx软件表项信息, slot-number为主控板所在槽位号。
该命令行可以提供查询预留的fabircvidx软件表项信息,包含有对应的组播组需要组播到哪些芯片的哪些端口。
1.1.152  display hardware internal mpls spb lbpinfo
display hardware internal mpls spb lbpinfo命令用来显示环回口软件表项信息。
display hardware internal mpls spb lbpinfo slot slot-number frame frameid
Probe视图
slot slot-number:显示指定单板的lbpinfo软件表项信息。
frame frameid:选择指定单板所在的框号。
该命令行可以提供查询主控板上保存的指定芯片的lbpinfo软件表项信息。包括使能了SPB、EVI、ROUTE的端口及个数等。
1.1.153  display hardware internal mpls spb operation
display hardware internal mpls spb operation命令用来显示环回口软件表项信息。
display hardware internal mpls spb operation slot slot-number optype optype
display hardware internal mpls spb operation slot slot-number clear
Probe视图
slot slot-number:显示指定单板的SPB操作记录软件表项信息。
optype optype:选择SPB操作类型。
该命令行可以提供查询各个单板上保存的SPB操作记录信息和清除操作。
1.1.154  display hardware internal mpls spb pwinfo
display hardware internal mpls spb pwinfo命令用来显示SPB PWINFO产品软件表项信息。
display hardware internal mpls spb pwinfo vsiindex vsiindex linkid pwid slot slot-number
Probe视图
vsiindex vsiindex:显示指定vsi的SPB PWINFO产品软件表项信息。
linkid pwid:显示指定vsi的指定pw的产品软件表项信息。
slot slot-number:显示指定单板的SPB PWINFO产品软件表项信息。
该命令行可以提供查询各个单板上保存的指定PW的软件表项信息。包括TTI、BrdcastDit、UnicastDit、PW出端口等PWINFO。
1.1.155  display hardware internal mpls spb tunnelinfo
display hardware internal mpls spb tunnelinfo命令用来显示SPB哈希节点软件表项信息。
display hardware internal mpls spb tunnelinfo i-sid isid  vlan vlanid mac-address H-H-H slot slot-number
Probe视图
i-sid isid:显示指定实例号的SPB哈希节点软件表项信息。
vlan vlanid:显示指定BVLAN的SPB哈希节点软件表项信息。
mac-address H-H-H:显示指定骨干网BMAC的SPB哈希节点软件表项信息。
slot slot-number:显示指定单板的SPB哈希节点软件表项信息。
该命令行可以提供查询隧道哈希节点软件表项信息,ISID最高位、BVLAN、BMAC为节点的key。
1.1.156  display hardware internal mpls spb variable
display hardware internal mpls spb variable命令用来显示SPB全局变量的产品软件表项信息。
display hardware internal mpls spb variable slot slot-number
Probe视图
slot slot-number:显示指定单板上的产品全局变量信息。
该命令行可以提供查询各个单板上保存的对应MDC的全局变量信息。
1.1.157  display hardware internal mpls spb vidx
display hardware internal mpls spb vidx命令用来查询接口板上VIDX的信息。
display hardware internal mpls spb vidx vidxid slot slot-number
Probe视图
vidx vidxid:显示指定vidx的产品软件表项信息。
slot slot-number:显示指定单板上的vidx产品软件表项信息。
该命令行可以提供查询各个单板上保存的BMAC申请的vidx的软件表项信息,可以显示该接口板上属于该组播组的成员端口。
1.1.158  display hardware internal nh
display hardware internal  nh命令用来查看指定VRF ID的Next-hop硬件表项信息。
独立运行模式:
display hardware internal ipuc nh nh-id  [ number show-number  [ urpf ] ] slot slot-number chip ppid
display hardware internal ipuc nh { x.x.x.x | x:x::x:x } mask-length slot slot-number chip ppid
display hardware internal ipuc nh vrid vrid { x.x.x.x | x:x::x:x } mask-length slot slot-number chip ppid
slot-number
IRF模式:
display hardware internal ipuc nh nh-id  [ number show-number  [ urpf ] ]  chassis chassis-number slot slot-number chip ppid
display hardware internal ipuc nh { x.x.x.x | x:x::x:x } mask-length chassis chassis-number  slot slot-number chip ppid
display hardware internal ipuc nh vrid vrid { x.x.x.x | x:x::x:x } mask-length chassis chassis-number  slot slot-number chip ppid
Probe视图
nh:显示next-hop表项。
nh-id:指定Next-hop索引。
number show-number:指定显示NH的表项数<1-32>。
urpf:是否携带ecmp urpf route entry。
chip ppid:本板物理芯片号,取值范围<0-7>(与单板类型有关)。
x.x.x.x:点分十进制表示的IPv4地址。
x:x::x:x:IPv6地址。
mask-length:掩码长度。Ipv4 <0-32>, ipv6 <0-128>。
vrid vrid:显示指定VPN的私网路由,范围1~1023(与系统工作模式有关)。
若输入的是ip地址,则是查看硬件表项,硬件表项从PP硬件中获取,如果指定urpf关键字,最后一个表项以ecmp urpf route entry方式显示。
1.1.159  display hardware internal nst  packet-statistic
display hardware internal nst packet-statistic命令用于显示指定接口板槽位的按照CPU Code统计的报文计数。携带清除标记,则显示统计信息后把当前计数清空;不携带清除标记,显示统计信息后不清空当前计数。
独立运行模式:
display hardware internal nst packet-statistic slot slot-number  [ clear ]
IRF模式:
display hardware internal nst packet-statistic chassis chassis-number slot slot-number  [ clear ]
Probe视图
 clear:清除标记,标识查询后是否清除原有报文统计计数信息。
1.1.160  display hardware internal packet-drop
display hardware internal packet-drop命令用来显示接口板转发芯片的丢包信息
独立运行模式:
display hardware internal packet-drop slot slot-number [ verbose ]
IRF模式:
display hardware internal packet-drop chassis chassis-number slot slot-number [ verbose ]
Probe视图
verbose: 带verbose关键字时,显示所有信息;不带verbose关键字时,只显示非零计数。
1.1.161  display hardware internal pcl pce-entry slot
display hardware internal pcl pce-entry slot命令用来显示指定规则的内容以及对应的动作。
display hardware internal pcl pce-entry slot  slot-number  chip chip-number  portgroup  portgroup-number  pce { pclid pceid pcltype | drvindex  drvindex-number } [ hardware ]
display hardware internal pcl pce-entry slot slot-number chip mdc_chip portgroup portgroup-number pce { pclid pceid pcltype | drvindex drvindex-number }
display hardware internal pcl pce-entry slot slot-number  chip chip-number portgroup portgroup-number  tti { pclid pceid pcltype  |  drvindex drvindex-number } [ hardware ]
display hardware internal pcl pce-entry slot slot-number chip mdc_chip portgroup portgroup-number  tti { pclid pceid pcltype  |  drvindex drvindex-number }
Probe视图
Pce: 根据PCEID来查询PCL表项。
tti:根据PCEID来查询TTI表项。
slot-number: 槽位号,在位接口板有效。
chip-number: 芯片号,范围0~7,mdc_chip(虚芯片)。
portgroup-number:芯片上的CoreId号,范围0~1。
Pclid:要查询的PCL索引,范围0~4294967295。
Pceid: 要查询的PCE在PCL中的相对索引,范围:0~65535。
pceType: 要查询的PCE/TTI的PCL类型,范围0~56。
Drvindex: PCE对应软件全局索引,范围:标准单板0~(104K-1);增强单板0~(392K-1)。
Hardware:显示硬件中表项,不带此命令字则显示软件中表项,mdc_chip表示虚芯片不支持此字段。
1.1.162  display hardware internal qos buffer-count
display hardware internal qos buffer-count命令用来显示硬件中Ingress/Egress已使用的Buffer数值。
display hardware internal qos buffer-count { ingress | egress } slot slot-number chip chip-number
Probe视图
ingress:ingress方向。
egress:egress方向。
chip-number:本地芯片号。范围:0~3表示PP芯片号,4~7表示二层芯片号。
1.1.163  display hardware internal register
display hardware internal register 命令用来查询接口板芯片寄存器。
display hardware internal register slot slot-number chip chip-num [ portgroup portgroup-num ] address [ length ]
Probe视图
slot-number:接口板槽号。
chip-num:芯片号。
portgroup-num:芯片的portgroup。
address:寄存器地址。
length:显示长度。
1.1.164  display hardware internal register dump
display hardware internal register dump 命令用来显示接口板芯片寄存器dump结果。
display hardware internal register dump slot slot-number chip chip-num
Probe视图
slot-number:接口板槽号。
chip-num:芯片号。
1.1.165  display hardware internal rxtx device-status
display hardware internal rxtx device-status命令用来显示用户指定的板cpu查询到的pp芯片状态,以及选择发送的芯片报文个数。
display hardware internal rxtx device-status slot  slot-number cpu cpu-number [ clear ]
Probe视图
cpu cpu-number:CPU编号,<0~1>。
clear:计数清空。
1.1.166  display hardware internal rxtx dma
display hardware internal rxtx dma命令用来显示PP上送的报文DMA队列的丢包计数和队列的计数。
display hardware internal rxtx dma statistic slot slot-number
Probe视图
slot-number:PP板槽位号,具体视机框而定。
Packet drop显示的是0---7号队列中DMA丢包的计数,若是队列有丢包,则这里会显示。(一般在大量报文上送时可能出现)。
Packet received 显示的是PP上送DMA队列的报文个数(逐个芯片显示)。
1.1.167  display hardware internal rxtx interrupt
display hardware internal rxtx interrupt命令用来显示中断处理模块的统计项。
display hardware internal rxtx interrupt statistic slot slot-number [clear]
Probe视图
slot slot-number:槽位号,具体视机框而定。
clear:显示计数器的内容之后清除计数器。
1.1.168  display hardware internal rxtx packet
display hardware internal rxtx packet命令用来显示报文收发模块的统计项。
display hardware internal rxtx packet statistic slot slot-number cpu cpu-number [ clear ]
Probe视图
clear: 计数是否读清。
1.1.169  display hardware internal rxtx rxpkt
display hardware internal rxtx rxpkt命令用来将来自PP芯片上送的符合用户指定的特征的报文内容打印出来。
display hardware internal rxtx rxpkt slot slotnum [ cpucode  cpu-code ] [ queue queueid ] [ number num ] [ length len ]  [ vlan vlanid ] [ port portid ] [dev dev-num ]
Probe视图
slot slotnum:需要打印发送报文的槽位号,只支持主控板和PP板CPU。
cpucode  cpu-code:需要打印的特定报文的cpu-code。
queue queueid:报文上送的队列号。
number num:需要打印的来自平台的报文的数目,<1~10000>。
vlan vlanid:需要打印的特定报文的vlanid。
port portid:端口编号。
dev dev-num:需要打印的特定报文的设备号。
length len:需要打印的来自平台的报文的报文长度,<1~1536>。
1.1.170  display hardware internal rxtx txpkt
display hardware internal rxtx txpkt命令用来将来自平台的符合用户指定的特征的报文内容打印出来。
display hardware internal rxtx txpkt [dit-tx dit-transmit | ingress-tx ingress-transmit | port-tx port-transmit | vidx-tx vidx-transmit | vlan-tx vlan-transmit | slot slotnum ] [ number num ] [ length len ]  [ vlan vlanid ]
Probe视图
dit-tx dit-transmit:dit发送方式。
ingress-tx ingress-transmit:ingress发送方式。
port-tx port-transmit:端口发送方式。
vidx-tx vidx-transmit:vidx发送方式。
vlan-tx vlan-transmit:vlan发送方式。
length len:需要打印的来自平台的报文的报文长度,默认是48字节,<1~1536>。
number num:需要打印的来自平台的报文的数目,默认是20个,<1~10000>。
1.1.171  display hardware internal sflow interface
display hardware internal sflow interface命令用来显示硬件sFlow配置的采样率和端口统计的报文。
display hardware internal sflow interface { interface-type interface-number | interface-name }
Probe视图
interface-type interface-number:指定接口类型和编号。
1.1.172  display hardware internal temperature-limit
display hardware internal temperature-limit命令用来显示所有接口板上的单板过温下电门限。
Probe视图
无
1.1.173  display hardware internal transceiver register interface
display hardware internal transceiver register interface命令用来显示可插拔光模块上指定寄存器区域的内容,用十六进制数表示。
display hardware internal transceiver register interface interface-type interface-number device device-index address start-address length region-length
Probe视图
interface interface-type interface-number:显示接口上插入的可插拔光模块上的寄存器信息。interface-type interface-number表示接口类型和接口编号。
device device-index:表示指定接口上光模块内部寄存器的索引号,用十六进制数表示,取值范围为0~FF。
address start-address:起始地址,即需要显示的寄存器区域的起始点的偏移地址。用十六进制数表示,取值范围为0~FFFF。
length region-length:寄存器区域的长度,即需要显示的寄存器区域的字节数。用十进制数表示,取值范围为1~256。
1.1.174  display hardware internel driver phy-xg register dump
display hardware internel driver phy-xg register dump命令用来显示指定槽位的PHY寄存器
display hardware internel driver phy-xg register dump slot slot-number
Probe视图
slot-number:指定槽位号
1.1.175  display psr status
display psr status命令用来显示设备上电源模块的状态信息。
display psr slot-number psr-id status
Probe视图
slot-number:主控板的全局槽位号。
psr-id:电源模块ID。S12504的取值范围为1~6;S12508的取值范围为1~8;S12518的取值范围为1~16。
电源模块的状态信息包括:
·     电源模块的运行时间。
·     电源模块内部子模块的版本号。
·     电源模块的电压、电流。
·     电源模块的温度。
·     电源模块的运行状态。
·     电源模块的告警状态。
1.1.176  display system internal acl
display system internal acl命令用来显示ACL的配置和运行情况。
分布式设备:
display system internal acl [ ipv6 ] { acl-number | name acl-name } { slot slot-number }
分布式IRF设备:
display system internal acl [ ipv6 ] { acl-number | name acl-name } { chassis chassis-number slot slot-number }
Probe视图
acl-number:显示指定编号的ACL的配置和运行情况。acl-number表示ACL的编号,取值范围及其代表的ACL类型如下:
·     2000~2999:若未指定ipv6关键字,表示IPv4基本ACL;否则表示IPv6基本ACL。
·     3000~3999:若未指定ipv6关键字,表示IPv4高级ACL;否则表示IPv6高级ACL。
·     4000~4999:表示二层ACL(指定ipv6关键字后不会显示本项)。
·     5000~5999:表示用户自定义ACL(指定ipv6关键字后不会显示本项)。
name acl-name:显示指定名称的ACL的配置和运行情况。acl-name表示ACL的名称,为1~63个字符的字符串,不区分大小写,必须以英文字母a~z或A~Z开头。对于基本ACL或高级ACL,若未指定ipv6关键字,表示IPv4基本ACL或IPv4高级ACL的名称,否则表示IPv6基本ACL或IPv6高级ACL的名称。
slot slot-number:显示指定单板上ACL的配置和运行情况,slot-number表示单板所在的槽位号。若未指定本参数,将显示主控板上ACL的配置和运行情况。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上ACL的配置和运行情况,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。若未指定本参数,将显示IRF设备中所有主控板上ACL的配置和运行情况。(IRF模式)
1.1.177  display system internal adj4 entry
display system internal adj4 entry 命令用来显示指定IPv4邻接表项的详细信息。
独立运行模式:
display system internal adj4 entry ip-address interface interface-type interface-number slot slot-number
IRF模式:
display system internal adj4 entry ip-address interface interface-type interface-number chassis chassis-number slot slot-number
probe视图
ip-address:IPv4邻接表项中的IP地址。
interface interface-type interface-number:IPv4邻接表项所对应的三层接口类型和接口号。
slot slot-number:显示指定单板的IPv4邻接表项的信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4邻接表项的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.178  display system internal adj4 statistics
display system internal adj4 statistics命令用来显示IPv4邻接表项的统计信息。
独立运行模式:
display system internal adj4 statistics slot slot-number
IRF模式:
display system internal adj4 statistics chassis chassis-number slot slot-number
probe视图
slot slot-number:显示指定单板的IPv4邻接表项的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4邻接表项的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.179  display system internal adjacent-table
display system internal adjacent-table命令用来显示IPv4邻接表的信息。
独立运行模式:
display system internal adjacent-table slot slot-number [ count | verbose ]
IRF模式:
display system internal adjacent-table chassis chassis-number slot slot-number [ count | verbose ]
Probe视图
slot slot-number:显示指定单板的IPv4邻接表信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4邻接表信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
count:显示IPv4邻接表项的数目。
verbose:显示IPv4邻接表项的详细信息。
1.1.180  display system internal arp
display system internal arp命令用来显示对应设备或单板上学习到的ARP表项信息或表项个数。
独立运行模式:
display system internal arp { all | static | dynamic | multiport } slot slot-number [ count ]
IRF模式:
display system internal arp { all | static | dynamic | multiport } chassis chassis-number slot slot-number [ count ]
Probe视图
all: 命令用来显示所有ARP表项信息或表项个数。
static: 用来显示静态ARP表项信息或表项个数。
dynamic: 用来显示动态ARP表项信息或表项个数。
multiport: 用来显示多端口ARP表项信息或表项个数。
slot slot-number:显示指定单板的ARP表项信息或表项个数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP表项信息或表项个数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
count:用来显示ARP表项个数。
1.1.181  display system internal arp ifcb
display system internal arp ifcb命令用来查看指定板上二层或三层接口ARP控制块信息
独立运行模式:
display system internal arp ifcb interface interface-type interface-number slot slot-number
IRF模式:
display system internal arp ifcb interface interface-type interface-number chassis chassis-number slot slot-number
Probe视图
interface interface-type interface-number :显示指定二层或三层接口上的ARP控制块信息,interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板的ARP控制块信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP控制块信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.182  display system internal arp ip-address
display system internal arp ip-address命令用来显示指定板上指定IP的ARP表项信息。
独立运行模式:
display system internal arp ip-address slot slot-number
IRF模式:
display system internal arp ip-address chassis chassis-number slot slot-number
Probe视图
ip-address: 用来显示指定IP的ARP表项信息。
slot slot-number:显示指定单板指定IP的ARP表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板指定IP的ARP表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.183  display system internal arp machash
display system internal arp machash命令用来显示指定板上machash表项信息。
独立运行模式:
display system internal arp machash vlan vlan-id ip ip-address slot slot-number
IRF模式:
display system internal arp machash vlan vlan-id ip ip-address chassis chassis-number slot slot-number
Probe视图
vlan vlan-id: 显示指定VLAN上machash表项信息。vlan-id表示指定VLAN的id。
ip-address:显示指定IP上machash表项信息。ip-address表示指定IP的IP地址
slot slot-number:显示指定单板的machash表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的machash表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.184  display system internal arp probe
display system internal arp probe命令用来显示指定单板上的ARP探测链表项。
独立运行模式:
display system internal arp probe slot slot-number
IRF模式:
display system internal arp probe chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ARP探测链表项,slot-number表示单板所在的槽位号。(独立
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP探测链表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.185  display system internal arp reload
display system internal arp reload命令用来显示指定单板上的ARP重刷链表项。
独立运行模式:
display system internal arp reload slot slot-number
IRF模式:
display system internal arp reload chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ARP重刷链表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP重刷链表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.186  display system internal arp source-suppression cache
display system internal arp source-suppression cache命令用来显示指定板源抑制表项。
独立运行模式:
display system internal arp source-suppression cache slot slot-number
IRF模式:
display system internal arp source-suppression cache chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的源抑制表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的源抑制表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.187  display system internal arp statistics
display system internal arp statistics命令用来显示指定板ARP统计信息。
独立运行模式:
display system internal arp statistics slot slot-number
IRF模式:
display system internal arp statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ARP统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ARP统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.188  display system internal arp vlan
display system internal arp vlan命令用来显示指定VLAN的ARP表项信息或表项个数。
独立运行模式:
display system internal arp vlan vlan-id slot slot-number [ count ]
IRF模式:
display system internal arp vlan vlan-id chassis chassis-number slot slot-number [ count ]
Probe视图
vlan vlan-id: 用来显示指定VLAN的ARP表项信息或表项个数。
slot slot-number:显示指定单板指定VLAN的ARP表项信息或表项个数,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板指定VLAN的ARP表项信息或表项个数,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
count:用来显示ARP表项个数。
1.1.189  display system internal bgp graceful-restart statistics
display system internal bgp graceful-restart statistics命令用来显示BGP GR统计信息。
Probe视图
1.1.190  display system internal bgp instance statistics
display system internal bgp instance statistics命令用来显示BGP实例统计信息。
display system internal bgp instance { ipv4 | ipv6 | vpnv4 } [ vpn-instance vpn-instance-name ] [ rib | send ] statistics
display system internal bgp instance { l2vpn | vpnv6 } [ rib | send ] statistics
Probe视图
ipv4:显示IPv4地址族的BGP实例统计信息。
ipv6:显示IPv6地址族的BGP实例统计信息。
vpnv4:显示VPNv4地址族的BGP实例统计信息。
l2vpn:显示L2VPN地址族的BGP实例统计信息。
vpnv6:显示VPNv6地址族的BGP实例统计信息。
vpn-instance vpn-instance-name:显示指定VPN的BGP实例统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网BGP实例的统计信息。
rib:显示BGP实例路由模块的统计信息。
send:显示BGP实例发送模块的统计信息。
执行本命令时,如果没有指定rib和send参数,则显示BGP协议的实例统计信息。
1.1.191  display system internal bgp interface
display system internal bgp interface命令用来显示BGP接口信息。
display system internal bgp interface ipv4 [ vpn-instance vpn-instance-name] [ interface-type interface-number | ipv4-address { mask | mask-length } ]
display system internal bgp interface ipv6 [ vpn-instance vpn-instance-name] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
ipv4:显示IPv4地址族的BGP接口信息。
ipv6:显示IPv6地址族的BGP接口信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP接口信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP接口信息。
interface-type interface-number:显示指定BGP接口的信息。interface-type interface-number为接口类型和接口编号。
ipv4-address { mask | mask-length }:显示IPv4地址为指定值的BGP接口的信息。ipv4-address为接口的IPv4地址;mask为接口IPv4地址的网络掩码;mask-length为接口IPv4地址的网络掩码长度,取值范围为0~32。
ipv6-address prefix-length:显示IPv6地址为指定值的BGP接口的信息。ipv6-address为接口的IPv6地址;prefix-length为接口IPv6地址的前缀长度,取值范围为0~128。
执行本命令时,如果没有指定interface-type interface-number和ipv4-address { mask | mask-length }、ipv6-address prefix-length参数,则显示所有BGP接口的信息。
1.1.192  display system internal bgp l2vpn auto-discovery advertise
display system internal bgp l2vpn auto-discovery advertise命令用来显示通过BGP协议自动发现的VPLS PE的通告信息。
display system internal bgp l2vpn auto-discovery route-distinguisher route-distinguisher pe-address ip-address advertise
Probe视图
route-distinguisher route-distinguisher:显示指定路由标识符的信息。route-distinguisher为路由标识符,为3~21个字符的字符串。路由标识符有三种格式:
·     32位自治系统号:16位用户自定义数字,其中的自治系统号最小值为65536。例如:65536:1。
pe-address ip-address:显示通过BGP协议自动发现的指定VPLS PE的信息。ip-address为自动发现的PE的IP地址。
1.1.193  display system internal bgp l2vpn auto-discovery verbose
display system internal bgp l2vpn auto-discovery verbose命令用来显示通过BGP协议自动发现的VPLS PE的详细信息。
display system internal bgp l2vpn auto-discovery route-distinguisher route-distinguisher pe-address ip-address verbose
Probe视图
pe-address ip-address:显示通过BGP协议自动发现的指定VPLS PE的详细信息。ip-address为自动发现的PE的IP地址。
1.1.194  display system internal bgp l2vpn signaling advertise
display system internal bgp l2vpn signaling advertise命令用来显示BGP L2VPN标签块的通告信息。
display system internal bgp l2vpn signaling route-distinguisher route-distinguisher site-id site-id label-offset label-offset advertise
Probe视图
site-id site-id:显示为指定站点分配的BGP L2VPN标签块的通告信息。site-id为站点编号,取值范围为0~65535。
label-offset label-offset:显示标签块偏移量为指定值的BGP L2VPN标签块的通告信息。label-offset为标签块偏移量,取值范围为0~65535。
1.1.195  display system internal bgp l2vpn signaling verbose
display system internal bgp l2vpn signaling verbose命令用来显示BGP L2VPN标签块的详细信息。
display system internal bgp l2vpn signaling route-distinguisher route-distinguisher site-id site-id label-offset label-offset verbose
Probe视图
site-id site-id:显示为指定站点分配的BGP L2VPN标签块的详细信息。site-id为站点编号,取值范围为0~65535。
label-offset label-offset:显示标签块偏移量为指定值的BGP L2VPN标签块的详细信息。label-offset为标签块偏移量,取值范围为0~65535。
1.1.196  display system internal bgp nib
display system internal bgp nib命令用来显示BGP路由下一跳信息。
display system internal bgp nib { ipv4 | ipv6 } [ nib-id ] [ verbose ]
Probe视图
ipv4:显示IPv4地址族的BGP路由下一跳信息。
ipv6:显示IPv6地址族的BGP路由下一跳信息。
nib-id:下一跳ID,取值范围为1~FFFFFFFF。如果不指定本参数,则显示所有下一跳信息。
verbose:显示下一跳的详细信息。如果不指定本参数,则显示下一跳的简要信息。
1.1.197  display system internal bgp nib log
display system internal bgp nib log命令用来显示BGP路由下一跳的日志信息。
Probe视图
1.1.198  display system internal bgp peer statistics
display system internal bgp peer statistics命令用来显示BGP对等体的统计信息。
display system internal bgp peer { ipv4 | vpnv4 } [ vpn-instance vpn-instance-name ] ipv4-address [ rib | send | session ] statistics
display system internal bgp peer ipv6 { ipv4-address | [ vpn-instance vpn-instance-name ] ipv6-address } [ rib | send | session ] statistics
display system internal bgp peer vpnv6 ipv4-address [ rib | send | session ] statistics
display system internal bgp peer l2vpn ipv4-address [ rib | send | session ] statistics
Probe视图
ipv4:显示IPv4地址族的BGP对等体统计信息。
ipv6:显示IPv6地址族的BGP对等体统计信息。
vpnv4:显示VPNv4地址族的BGP对等体统计信息。
vpnv6:显示VPNv6地址族的BGP对等体统计信息。
l2vpn:显示L2VPN地址族的BGP对等体统计信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP对等体统计信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP对等体统计信息。
ipv4-address:显示指定对等体的信息。ipv4-address为对等体的IPv4地址。
ipv6-address:显示指定对等体的信息。ipv6-address为对等体的IPv6地址。
rib:显示BGP路由模块相关信息。
send:显示BGP发送模块相关信息。
session:显示BGP会话模块相关信息。
指定本命令时,如果不指定rib、send和session参数,则显示BGP协议的对等体统计信息。
1.1.199  display system internal bgp protocol statistics
display system internal bgp protocol statistics命令用来显示BGP协议的统计信息。
display system internal bgp protocol [ calc | rib | send | session ] statistics
Probe视图
calc:显示BGP路由优选模块的统计信息。
rib:显示BGP路由模块的统计信息。
send:显示BGP发送模块的统计信息。
session:显示BGP会话模块的统计信息。
执行本命令时,如果没有指定任何参数,则显示BGP协议的统计信息。
1.1.200  display system internal bgp routing-table advertise-info
display system internal bgp routing-table advertise-info命令用来显示BGP路由的通告信息。
display system internal bgp routing-table ipv4 [ vpn-instance vpn-instance-name ] network-address { mask | mask-length } advertise-info
display system internal bgp routing-table ipv6 [ vpn-instance vpn-instance-name ] network-address prefix-length advertise-info
display system internal bgp routing-table vpnv4 network-address { mask | mask-length } advertise-info
display system internal bgp routing-table vpnv6 network-address prefix-length advertise-info
Probe视图
ipv4:显示IPv4地址族的BGP路由通告信息。
ipv6:显示IPv6地址族的BGP路由通告信息。
vpnv4:显示VPNv4地址族的BGP路由通告信息。
vpnv6:显示VPNv6地址族的BGP路由通告信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由通告信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP路由通告信息。
network-address:目的网络的地址。
mask:目的网络的掩码,点分十进制格式。
mask-length:目的网络的掩码长度,取值范围为0~32。
prefix-length:目的网络的前缀长度,取值范围为0~128。
1.1.201  display system internal bgp routing-table verbose
display system internal bgp routing-table verbose命令用来显示BGP路由的详细信息。
display system internal bgp routing-table ipv4 [ vpn-instance vpn-instance-name ] network-address { mask | mask-length } verbose
display system internal bgp routing-table ipv6 [ vpn-instance vpn-instance-name ] network-address prefix-length verbose
display system internal bgp routing-table vpnv4 network-address { mask | mask-length } verbose
display system internal bgp routing-table vpnv6 network-address prefix-length verbose
Probe视图
ipv4:显示IPv4地址族的BGP路由详细信息。
ipv6:显示IPv6地址族的BGP路由详细信息。
vpnv4:显示VPNv4地址族的BGP路由详细信息。
vpnv6:显示VPNv6地址族的BGP路由详细信息。
vpn-instance vpn-instance-name:显示指定VPN实例的BGP路由详细信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的BGP路由详细信息。
1.1.202  display system internal control-plane management statistics
display system internal control-plane management statistics命令用来显示管理口控制平面报文的统计信息。
Probe视图
1.1.203  display system internal dbm
display system internal dbm命令用来显示数据库信息。
独立运行模式:
display system internal dbm { all | name dbname [ key kename ] } { slot slot-number }
IRF模式:
display system internal dbm { all | name dbname [ key kename ] } { chassis chassis-number  slot slot-number  }
Probe视图
chassis-number:表示设备在IRF中的成员编号。(IRF模式)
slot-number:表示单板所在的槽位号。(独立运行模式)
name dbname:指定数据库名。
key kename:指定key的名称,在数据库中以key名称标识一项数据。
1.1.204  display system internal ethernet character
display system internal ethernet character命令用来显示以太网模块侦听的特征统计信息和详细信息。
独立运行模式:
display system internal ethernet character { global | interface { interface-type interface-number } } slot slot-number
IRF模式:
display system internal ethernet character { global | interface { interface-type interface-number } } chassis chassis-number slot slot-number
Probe视图
global:显示全局的以太特征。全局特征表示对设备上所有报文进行匹配。
interface interface-type interface-number:显示指定接口上的以太特征。接口特征表示对设备上该接口收发的报文进行匹配。
slot slot-number:显示指定单板的以太网统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的以太网统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
以太网模块主要实现链路层报文接收去封装和发送加封装等处理。上层应用模块(如STP,LLDP等)需要侦听处理协议报文,指定侦听的范围(如指定接口上的报文或者设备上所有报文),侦听的协议报文具有指定的特征(如特殊的以太协议类型、特定的MAC等),并将这些特征下发给以太网模块,以太网模块在指定阶段(如收包MAC阶段/收包LLC阶段/发包三层口阶段等)会根据注册的特征库对报文进行匹配。匹配上了这些特征就交给这个阶段处理,不匹配就交给下一个阶段处理。
1.1.205  display system internal ethernet controlblock
display system internal ethernet controlblock命令用来显示接口的控制块信息,它记录了链路层参数的值。
独立运行模式:
display system internal ethernet controlblock interface { interface-type interface-number } slot slot-number
IRF模式:
display system internal ethernet controlblock interface { interface-type interface-number } chassis chassis-number slot slot-number
Probe视图
interface interface-type interface-number:显示指定接口的链路控制信息。interface-type interface-number表示接口类型和接口编号。
1.1.206  display system internal evi flooding
display system internal evi flooding命令用来显示EVI泛洪功能信息。
独立运行模式:
display system internal evi flooding interface interface-type interface-number slot slot-number
IRF模式:
display system internal evi flooding interface interface-type interface-number chassis chassis-number slot slot-number
Probe视图
interface interface-type interface-number:显示指定接口的EVI泛洪功能信息。
slot slot-number:显示指定单板的EVI泛洪功能信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的EVI泛洪功能信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.207  display system internal evi selective-flooding
display system internal evi selective-flooding命令用来显示EVI保存的指定EVI隧道接口下指定泛洪MAC在指定VLAN的下发驱动信息。
独立运行模式:
display system internal evi selective-flooding interface tunnel interface-number mac-address mac-address vlan vlan-id slot slot-number
IRF模式:
display system internal evi selective-flooding interface tunnel interface-number mac-address mac-address vlan vlan-id chassis chassis-number slot slot-number
Probe视图
【支持的缺省用户角色】
interface tunnel interface-number:指定EVI隧道接口。
mac-address mac-address:指定泛洪MAC。
vlan vlan-id:指定VLAN。vlan-id表示VLAN编号,取值范围为1~4094。
slot slot-number:显示指定单板的EVI保存的指定EVI隧道接口下指定泛洪MAC在指定VLAN的下发驱动信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的EVI保存的指定EVI隧道接口下指定泛洪MAC在指定VLAN的下发驱动信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.208  display system internal evi statistics
display system internal evi statistics命令用来显示EVI的统计信息。
独立运行模式:
display system internal evi statistics slot slot-number
IRF模式:
display system internal evi statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的EVI统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的EVI统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.209  display system internal evi vlan-mapping
display system internal evi vlan-mapping命令用来显示EVI的VLAN映射信息。
独立运行模式:
display system internal evi vlan-mapping vlan vlan-id interface interface-type interface-number slot slot-number
IRF模式:
display system internal evi vlan-mapping vlan vlan-id interface interface-type interface-number chassis chassis-number slot slot-number
Probe视图
vlan vlan-id:显示指定本地VLAN的VLAN映射信息。vlan-id表示VLAN编号,取值范围为1~4094。
interface interface-type interface-number:显示指定接口的VLAN映射信息。
slot slot-number:显示指定单板的VLAN映射信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的VLAN映射信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.210  display system internal evi vlan-status
display system internal evi vlan-status命令用来显示EVI保存的指定EVI隧道接口下的VLAN下发驱动信息。
独立运行模式:
display system internal evi vlan-status interface tunnel interface-number vlan vlan-id slot slot-number
IRF模式:
display system internal evi vlan-status interface tunnel interface-number vlan vlan-id chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的EVI保存的VLAN下发驱动信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的EVI保存的VLAN下发驱动信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.211  display system internal evi-link data
display system internal evi-link data命令用来显示EVI-Link接口内核数据信息。
独立运行模式:
display system internal evi-link data interface evi-link number [ slot slot-number ]
IRF模式:
display system internal evi-link data interface evi-link number [ chassis chassis-number slot slot-number ]
Probe视图
interface evi-link number:显示指定EVI-Link接口的内核数据信息。number表示EVI-Link接口编号,取值为已创建的EVI-Link接口编号。
slot slot-number:显示指定单板的EVI-Link接口内核数据信息。slot-number表示单板所在的槽位号。如果不指定本参数,则显示主用主控板的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的EVI-Link接口内核数据信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则显示全局主用主控板的信息。(IRF模式)
1.1.212  display system internal eviisis status
display system internal eviisis status命令用来显示EVI IS-IS进程的状态信息。
Probe视图
1.1.213  display system internal fib prefix
display system internal fib prefix命令用来显示IPv4 FIB前缀基本信息。
独立运行模式:
display system internal fib prefix [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
display system internal fib prefix [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4 FIB前缀基本信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB前缀基本信息。
slot slot-number:显示指定单板上的IPv4 FIB前缀基本信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB前缀基本信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.214  display system internal fib prefix entry-status
display system internal fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv4 FIB表项信息。
独立运行模式:
display system internal fib prefix [ vpn-instance vpn-instance-name ] entry-status status slot slot-number
IRF模式:
display system internal fib prefix [ vpn-instance vpn-instance-name] entry-status status chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的下驱动失败或者待老化的IPv4 FIB表项信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB表项信息。
entry-status status:用于匹配FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv4 FIB表项信息,“F”表示下刷驱动失败的IPv4 FIB表项信息。
slot slot-number:显示指定单板上的下驱动失败或者待老化的IPv4 FIB表项信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的下驱动失败或者待老化的IPv4 FIB表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.215  display system internal fib prefix ip
display system internal fib prefix ip命令用来显示IPv4 FIB前缀详细信息。
独立运行模式:
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip [ mask | mask-length ]  slot slot-number
IRF模式:
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip [ mask | mask-length ]  chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv4 FIB前缀详细信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv4 FIB前缀详细信息。
ip:显示指定IP地址的IPv4 FIB前缀详细信息。
mask:IP地址掩码。
mask-length:IP地址掩码长度,即掩码中连续“1”的个数。
slot slot-number:显示指定单板上的IPv4 FIB前缀详细信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB前缀详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.216  display system internal fib running-status
display system internal fib running-status命令用来显示IPv4 FIB、IPv6 FIB、VN全局信息。
独立运行模式:
display system internal fib running-status slot slot-number
IRF模式:
display system internal fib  running-status chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的IPv4 FIB、IPv6 FIB、VN全局信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB、IPv6 FIB、VN全局信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.217  display system internal fib statistics
display system internal fib statistics命令用来显示IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。
独立运行模式:
display system internal fib statistics slot slot-number
IRF模式:
display system internal fib  statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv4 FIB、IPv6 FIB、VN表项操作的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.218  display system internal fib vn
display system internal fib vn命令用来显示VN表项信息。
独立运行模式:
display system internal fib vn [ next-hop next-hop ] slot slot-number
display system internal fib vn { id id | index index } slot slot-number
IRF模式:
display system internal fib vn [ next-hop next-hop ] chassis chassis-number slot slot-number
display system internal fib vn { id id |  index index } chassis chassis-number slot slot-number
Probe视图
id id:按指定VN ID显示VN表项详细信息。
index index:按指定VN索引显示VN表项详细信息。
next-hop next-hop:显示指定下一跳的VN表项基本信息,可以输入IPv4、IPv6地址。
slot slot-number:显示指定单板上的VN表项信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的VN表项信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.219  display system internal fib vn entry-status
display system internal fib vn entry-status命令用来显示指定状态的VN表项基本信息。
独立运行模式:
display system internal fib vn entry-status status slot slot-number
IRF模式:
display system internal fib vn entry-status status chassis chassis-number slot slot-number
Probe视图
entry-status status:按指定状态显示VN信息。取值范围为<A,F,R>,“A”表示待老化表项,“F”表示下驱动失败表项,“R”表示由于被关联而未删除的表项。
slot slot-number:显示指定单板上的指定状态的VN表项基本信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的指定状态的VN表项基本信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.220  display system internal fib vn reference
display system internal fib vn reference命令用来显示前缀关联VN的信息。
独立运行模式:
display system internal fib vn { id id | index index } reference slot slot-number
IRF模式:
display system internal fib vn {id id | index index } reference chassis chassis-number slot slot-number
Probe视图
id id:按指定VN ID显示VN信息。
index index:按指定VN指针显示VN信息。
reference:显示关联该VN的前缀信息。
slot slot-number:显示指定单板的前缀关联VN的信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的前缀关联VN的信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.221  display system internal ha service
display system internal ha service命令用来显示某个业务进程的HA统计信息,包括业务注册的基本信息、各控制消息接收处理统计、各数据的发送统计和接收统计等。
display system internal ha service socket
Probe视图
socket:所要查询的业务进程的socket,可通过display system internal ha service-group sg-name查询。
1.1.222  display system internal ha service-group
display system internal ha service-group命令用来显示当前到HA模块注册的所有SG信息,包括SG的名称、SG的状态、SU的个数等信息。
display system internal ha service-group [ name [ instance ] ]
Probe视图
instance:SG实例的名称(如果有实例)。
1.1.223  display system internal ha statistics
display system internal ha statistics命令用来显示HA各子模块的统计信息。
display system internal ha statistics { submodule { fsm | service } | summary }
Probe视图
submodule:HA子模块的信息。
fsm:FSM子模块的信息。
service:service子模块的信息。
summary:全局统计信息。
1.1.224  display system internal httpd service
display system internal httpd service命令用来显示HTTPD服务相关信息。
Probe视图
通过本命令可以查看HTTPD服务信息,包括打开的服务端口,注册的URL,内部LIPC端口号等。
1.1.225  display system internal ifmgr brief
display system internal ifmgr brief命令用来显示接口基本信息同步的简要信息。
独立运行模式:
display system internal ifmgr brief { para slot slot-number | help }
IRF模式:
display system internal ifmgr brief { para chassis chassis-number slot slot-number | help }
Probe视图
para:指定显示时的参数,为具体的接口索引值。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
help:显示命令参数的帮助信息,用于指导用户输入合法参数。
1.1.226  display system internal ifmgr down
display system internal ifmgr down命令用来显示已注册的down类型。
独立运行模式:
display system internal ifmgr down [ slot slot-number ]
IRF模式:
display system internal ifmgr down [ chassis chassis-number slot slot-number ]
Probe视图
slot slot-number:表示单板所在的槽位号。不指定该参数时,则表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。(IRF模式)
1.1.227  display system internal ifmgr entry
display system internal ifmgr entry命令用来显示指定接口的数据结构信息。
独立运行模式:
display system internal ifmgr entry { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr entry { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。表示接口名或接口索引,具体格式为:1*接口索引,2*接口名。
1.1.228  display system internal ifmgr event
display system internal ifmgr event命令用来显示接口事件的注册信息,包括哪些模块注册了该事件,以及模块在哪些接口上注册了该事件。
独立运行模式:
display system internal ifmgr event { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr event { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。para为具体事件或接口类型,如果同时指定事件和接口类型,事件和接口中间需用“*”连接,具体格式为:event*type。
1.1.229  display system internal ifmgr hotplug
display system internal ifmgr hotplug命令用来显示板或子卡的热插拔信息。
独立运行模式:
display system internal ifmgr hotplug [ para [ slot slot-number ] | help ]
IRF模式:
display system internal ifmgr hotplug [ para [ chassis chassis-number slot slot-number ] | help ]
Probe视图
para:指定显示时的参数。当不指定参数时显示所有板的热插拔信息;当指定参数时,可直接指定槽位号,用于显示该板的热插拔信息。
slot slot-number:表示单板所在的槽位号。不指定该参数时,则表示主用主控板。用于显示slot-number单板上记录的热插拔信息。(独立运行模式)
chassis chassis-number slot slot-number:chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的全局主用主控板。用于显示slot-number单板上记录的热插拔信息。(IRF模式)
1.1.230  display system internal ifmgr index
display system internal ifmgr index命令用来显示接口索引节点的相关信息。
独立运行模式:
display system internal ifmgr index { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr index { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。为接口索引值的十进制形式。
1.1.231  display system internal ifmgr list
display system internal ifmgr list命令用来显示接口的名称和索引。
独立运行模式:
display system internal ifmgr list [ para [ slot slot-number ] | help ]
IRF模式:
display system internal ifmgr list [ para [ chassis chassis-number slot slot-number ] | help ]
Probe视图
para:指定显示时的参数。不指定时显示所有类型接口的信息;当指定时para为具体接口类型。
1.1.232  display system internal ifmgr mdc
display system internal ifmgr mdc命令用来显示MDC接口分配相关信息。
独立运行模式:
display system internal ifmgr mdc { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr mdc { para [ chassis chassis-number slot slot-number ] | help }
Probe视图
para:指定显示时的参数。合法参数形式有如下四种:1*接口所在分组的编号、2*接口名、3*MDC的编号、4*槽位号。
1.1.233  display system internal ifmgr name
display system internal ifmgr name命令用来显示接口名字解析树信息。
独立运行模式:
display system internal ifmgr name { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr name { para [ chassis chassis-number  slot slot-number ] | help }
Probe视图
para:指定显示时的参数。为接口全名或简名,不指定该参数,表示显示所有接口的名字解析树信息。
1.1.234  display system internal ifmgr type
display system internal ifmgr type命令用来按类型显示接口的信息。
独立运行模式:
display system internal ifmgr type { para [ slot slot-number ] | help }
IRF模式:
display system internal ifmgr type { para [ chassis chassis-number  slot slot-number ] | help }
Probe视图
para:表示接口类型,为1~127个字符的字符串。
1.1.235  display system internal ip address
display system internal ip address命令用来显示地址详细信息
独立运行模式:
display system internal ip address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ip-address ] slot slot-number
IRF模式:
display system internal ip address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ip-address ] chassis chassis-number slot slot-number
Probe视图
ip-address ip-address:显示指定IP地址。
vpn-instance vpn-instance-name: 显示指定VPN的IP地址。
interface interface-type interface-number:显示指定接口的IP地址,interface-type interface-number表示接口类型和接口编号。
slot slot-number:显示指定单板上的IP地址,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IP地址,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     ip address
1.1.236  display system internal ip source binding
display system internal ip source binding命令用来显示详细的IPv4绑定表项信息。
独立运行模式:
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dot1x | dhcp-relay | dhcp-server | dhcp-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] slot slot-number
IRF模式:
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dot1x | dhcp-relay | dhcp-server | dhcp-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
Probe视图
static:显示配置的静态绑定表项。
vpn-instance vpn-instance-name:显示指定VPN的动态绑定表项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示显示公网的动态绑定表项。
dhcp-relay:显示DHCP中继模块生成的动态绑定表项。
dhcp-server:显示DHCP服务器模块生成的动态绑定表项。
dhcp-snooping:显示DHCP Snooping模块生成的动态绑定表项。
dot1x:显示802.1X模块生成的动态绑定表项。
ip-address ip-address:显示指定IPv4地址的绑定表项,ip-address表示绑定的IPv4地址。
mac-address mac-address:显示指定MAC地址的绑定表项,mac-address表示绑定的MAC地址,格式为H-H-H。
vlan vlan-id:显示指定VLAN的绑定表项,vlan-id表示绑定的VLAN ID,取值范围为1~4094。
interface interface-type interface-number:显示指定接口的绑定表项,interface-type interface-number表示绑定的接口类型和接口编号。
slot slot-number:显示存储在指定单板上的绑定表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示存储在指定成员设备上指定单板的绑定表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     ip source binding
1.1.237  display system internal ip vpn-binding
display system internal ip vpn-binding命令用来显示内核的VPN实例绑定信息。
独立运行模式:
display system internal ip vpn-binding slot slot-number
IRF模式:
display system internal ip vpn-binding chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的内核VPN实例绑定信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例绑定信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.238  display system internal ip vpn-instance
display system internal ip vpn-instance命令用来显示内核的VPN实例信息。
独立运行模式:
display system internal ip vpn-instance [ instance-name vpn-instance-name ] slot slot-number
IRF模式:
display system internal ip vpn-instance [ instance-name vpn-instance-name ] chassis chassis-number slot slot-number
Probe视图
instance-name vpn-instance-name:显示指定VPN实例的内核信息。vpn-instance-name表示VPN实例的名称,为1~31个字符的字符串,区分大小写。
slot slot-number:显示指定单板上的内核VPN实例信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.239  display system internal ip vpn-instance inactive
display system internal ip vpn-instance inactive命令用来显示正在删除中的VPN实例的信息。
Probe视图
1.1.240  display system internal ip vpn-instance statistics
display system internal ip vpn-instance statistics命令用来显示内核VPN实例的统计信息。
独立运行模式:
display system internal ip vpn-instance statistics slot slot-number
IRF模式:
display system internal ip vpn-instance statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的内核VPN实例统计信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的内核VPN实例统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.241  display system internal ipv6 address
display system internal ipv6 address命令用来显示IPv6地址详细信息
独立运行模式:
display system internal ipv6 address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ipv6-address ] slot slot-number
IRF模式:
display system internal ipv6 address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ipv6-address ] chassis chassis-number slot slot-number
Probe视图
ipv6-address:显示的指定IPv6地址的详细信息。
vpn-instance vpn-instance-name:显示指定VPN的IPv6地址。
interface interface-type interface-number:显示指定接口的IPv6地址,interface-type interface-number表示接口类型和接口编号。
slot slot-number:显示指定单板上的IPv6地址,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6地址,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
如果不指定任何参数,则显示公网所有的IPv6地址。
1.1.242  display system internal ipv6 fib prefix
display system internal ipv6 fib prefix命令用来显示IPv6 FIB前缀基本信息。
独立运行模式:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
display system internal ipv6 fib prefix [vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB前缀基本信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB前缀基本信息。
slot slot-number:显示指定单板的IPv6 FIB前缀基本信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6 FIB前缀基本信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.243  display system internal ipv6 fib prefix entry-status
display system internal ipv6 fib prefix entry-status命令用来显示下驱动失败或者待老化的IPv6 FIB表项信息。
独立运行模式:
display system internal ipv6 fib prefix entry-status status [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
display system internal ipv6 fib prefix entry-status status [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB表项信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB表项信息。
entry-status status:用于匹配IPv6 FIB表项;取值范围为<A,F>,“A”表示需要被老化的IPv6 FIB表项,“F”表示下刷驱动失败的IPv6 FIB表项。
slot slot-number:显示指定单板的下驱动失败或者待老化的IPv6 FIB表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的下驱动失败或者待老化的IPv6 FIB表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.244  display system internal ipv6 fib prefix ipv6
display system internal ipv6 fib prefix ipv6命令用来显示IPv6 FIB前缀详细信息。
独立运行模式:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] ipv6 [ prefix-length ] slot slot-number
IRF模式:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] ipv6 [ prefix-length ] chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6 FIB前缀详细信息。vpn-instance-name为VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定VPN实例,则显示公网的IPv6 FIB前缀详细信息。
ipv6:显示目的地址为指定IPv6地址的IPv6 FIB前缀详细信息。
prefix-length:指定IPv6地址的前缀长度,取值范围为0~128。
slot slot-number:显示指定单板的IPv6 FIB前缀详细信息,slot-number表示单板所在的槽位号。(独立运行模式)
1.1.245  display system internal ipv6 l2-multicast ip forwarding verbose
display system internal ipv6 l2-multicast ip forwarding verbose命令用来显示IPv6二层组播的IP组播组详细信息。
独立运行模式:
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
group ipv6-group-address:显示指定IPv6组播组的信息。如果未指定本参数,将显示所有IPv6组播组的信息。
source ipv6-source-address:显示指定IPv6组播源的信息。如果未指定本参数,将显示所有IPv6组播源的信息。
vlan vlan-id:显示指定VLAN内的信息。vlan-id为VLAN的编号,取值范围为1~4094。如果未指定本参数,将显示所有VLAN内的信息。
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的信息。(IRF模式)
1.1.246  display system internal ipv6 l2-multicast ip verbose
display system internal ipv6 l2-multicast ip verbose命令用来显示IPv6二层组播的IP组播组详细信息。
独立运行模式:
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.247  display system internal ipv6 l2-multicast ipc statistics
display system internal ipv6 l2-multicast ipc statistics命令用来显示IPv6二层组播板间消息的统计信息。
独立运行模式:
display system internal ipv6 l2-multicast ipc statistics [ slot slot-number ]
IRF模式:
display system internal ipv6 l2-multicast ipc statistics [ chassis chassis-number slot slot-number ]
Probe视图
1.1.248  display system internal ipv6 l2-multicast mac forwarding verbose
display system internal ipv6 l2-multicast mac forwarding verbose命令用来显示IPv6二层组播的MAC转发表详细信息。
独立运行模式:
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
mac-address:显示指定MAC组播组的信息。如果未指定本参数,将显示所有MAC组播组的信息。
1.1.249  display system internal ipv6 l2-multicast mac verbose
display system internal ipv6 l2-multicast mac verbose命令用来显示IPv6二层组播的MAC组播组详细信息。
独立运行模式:
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.250  display system internal ipv6 mrib interface statistics
display system internal ipv6 mrib interface statistics命令用来显示IPv6 MRIB所维护接口的统计信息,这些接口包括配置了IPv6 PIM、MLD等IPv6组播协议的接口以及注册接口、InLoopBack0接口、Null0接口等内部接口。
display system internal ipv6 mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例上IPv6 MRIB所维护接口的统计信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例上IPv6 MRIB所维护接口的统计信息。
1.1.251  display system internal ipv6 mrib mbr
display system internal ipv6 mrib mbr interface命令用来显示IPv6 MRIB进程中MBR(Multicast Border Router,组播边界路由器)模块维护的组加入信息。
display system internal ipv6 mrib [ vpn-instance vpn-instance-name ] mbr interface interface-type interface-number [ source ipv6-source-address group ipv6-group-address ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的信息。
interface interface-type interface-number:显示指定接口上的信息。
source ipv6-source-address:显示指定组播源的IPv6 MBR表项信息。如果未指定本参数,将不显示IPv6 MBR表项信息。
group ipv6-group-address:显示指定组播组的IPv6 MBR表项信息,ipv6-group-address的取值范围为FFxy::/16(但不包括下列地址:FFx0::/16、FFx1::/16、FFx2::/16和FF0y::),其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将不显示IPv6 MBR表项信息。
1.1.252  display system internal ipv6 multicast forwarding vlan reference
display system internal ipv6 multicast forwarding vlan reference命令用来显示VLAN出接口与IPv6二层组播表项之间的映射关系。
独立运行模式:
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.253  display system internal ipv6 multicast forwarding-table dummy
display system internal ipv6 multicast forwarding-table dummy命令用来显示IPv6组播临时转发表的信息。
独立运行模式:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | statistics | slot slot-number ] *
IRF模式:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | statistics ] *
Probe视图
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息
prefix-length:指定IPv6组播源或IPv6组播组地址的前缀长度。对于IPv6组播源地址,其取值范围为0~128,缺省值为128;对于IPv6组播组地址,其取值范围为8~128,缺省值为128。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的信息。(IRF模式)
statistics:显示统计信息。
1.1.254  display system internal ipv6 multicast forwarding-table verbose
display system internal ipv6 multicast forwarding-table verbose命令用来显示IPv6组播转发表的详细信息。
独立运行模式:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number ] *
IRF模式:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的IPv6组播转发项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的IPv6组播转发项。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的IPv6组播转发项。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的IPv6组播转发项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的IPv6组播转发项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的IPv6组播转发表项。(IRF模式)
incoming-interface:显示指定入接口的IPv6组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的IPv6组播转发项。
outgoing-interface:显示指定出接口的IPv6组播转发项。
exclude:显示出接口列表中不包含指定接口的IPv6组播转发项。
include:显示出接口列表中包含指定接口的IPv6组播转发项。
match:显示出接口列表中包含且仅包含指定接口的IPv6组播转发项。
slot slot-number:显示指定单板上的IPv6组播转发项,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的IPv6组播转发表项。(独立运行模式)
1.1.255  display system internal ipv6 multicast-vlan forwarding-table verbose
display system internal ipv6 multicast-vlan forwarding-table verbose命令用来显示IPv6组播VLAN转发表的详细信息。
独立运行模式:
display system internal ipv6 multicast-vlan forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
IRF模式:
display system internal ipv6 multicast-vlan forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | subvlan vlan-id | vlan vlan-id ] *
Probe视图
ipv6-group-address:显示指定IPv6组播组的信息,取值范围为FFxy::/16,其中x和y均代表0~F的任意一个十六进制数。如果未指定本参数,将显示所有IPv6组播组的信息。
subvlan vlan-id:显示指定子VLAN的信息。如果未指定本参数,将显示所有子VLAN的信息。
1.1.256  display system internal ipv6 pathmtu
display system internal ipv6 pathmtu命令用来显示IPv6的PMTU信息,信息全局同步。
独立运行模式:
display system internal ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] } slot slot-number
IRF模式:
display system internal ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] } chassis chassis-number slot slot-number
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的IPv6 PMTU信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的IPv6 PMTU信息。
ipv6-address:显示到达指定IPv6地址的PMTU信息。
all:显示所有公网的PMTU信息。
dynamic:显示所有动态PMTU信息。
static:显示所有静态PMTU信息。
count:显示PMTU表项数目。
slot slot-number:显示指定单板上的所有PMTU表项。slot-number表示单板的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上的所有PMTU表项。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号。(IRF模式)
如果未指定任何可选参数,将显示设备上所有的PathMTU信息。
1.1.257  display system internal ipv6 pbr fib
display system internal ipv6 pbr fib命令用来显示用户态下IPv6下一跳的配置信息。
独立运行模式:
display system internal ipv6 pbr fib [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
display system internal ipv6 pbr fib [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
不显示用户态下IPv6下一跳的配置信息。
Probe视图
vpn-instance vpn-instance-name:显示用户态下指定私网内IPv6下一跳的配置信息,不指定该参数为公网内下一跳。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定单板指定私网内IPv6下一跳的配置信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的指定私网内IPv6下一跳的配置信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.258  display system internal ipv6 pbr kernel policy
display system internal ipv6 pbr kernel policy用于显示内核态下指定单板上的IPv6策略路由信息。
独立运行模式:
display system internal ipv6 pbr kernel policy [ policy-name [ setup ] ] slot slot-number
IRF模式:
display system internal ipv6 pbr kernel policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
不显示内核态下的IPv6策略路由信息。
Probe视图
policy policy-name:显示内核态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示内核态指定策略的接口应用信息。
slot slot-number:显示内核态下指定单板上的内核态下IPv6策略路由信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示内核态下指定成员设备上指定单板的IPv6策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.259  display system internal ipv6 pbr policy
display system internal ipv6 pbr policy用于显示用户态下的IPv6策略路由信息。
独立运行模式:
display system internal ipv6 pbr policy [ policy-nam [ setup ] ] slot slot-number
IRF模式:
display system internal ipv6 pbr policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
不显示用户态下的IPv6策略路由信息。
Probe视图
policy policy-name:显示用户态下指定IPv6策略路由信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
setup:显示用户态下指定策略的接口应用信息。
slot slot-number:显示用户态下指定单板上的IPv6策略路由信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的IPv6策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.260  display system internal ipv6 pim interface
display system internal ipv6 pim interface命令用来显示IPv6 PIM进程中路由管理LIB所维护的接口信息。
display system internal ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number [ address | gateway | prefix] ] | ipv6-address prefix-length ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
interface-type interface-number:显示指定接口的信息。如果未指定本参数,将显示所有接口的信息。
address:指定IPv6地址。
gateway:指定IPv6网关。
prefix:指定IPv6前缀。
ipv6-address:显示指定IPv6地址的信息。如果未指定本参数,将显示所有IPv6地址的信息。::为保留地址,用户不感知。
prefix-length:表示前缀长度,取值范围为0~128。
1.1.261  display system internal ipv6 pim rp
display system internal ipv6 pim rp命令用来显示IPv6 PIM的RP统计信息。
display system internal ipv6 pim [ vpn-instance vpn-instance-name ] rp
Probe视图
1.1.262  display system internal ipv6 pim thread
display system internal ipv6 pim thread命令用来显示IPv6 PIM线程的统计信息。
display system internal ipv6 pim thread { event | main | route }
Probe视图
event:显示IPv6 PIM事件线程的统计信息。
main:显示IPv6 PIM主线程的统计信息。
route:显示IPv6 PIM路由线程的统计信息。
1.1.263  display system internal ipv6 rawip
display system internal ipv6 rawip命令用来显示指定单板上所有IPv6 RawIP连接的摘要信息。
独立运行模式:
display system internal ipv6 rawip slot slot-number
IRF模式:
display system internal ipv6 rawip chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 RawIP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 RawIP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号。(RF模式)
1.1.264  display system internal ipv6 rib event attribute
display system internal ipv6 rib event attribute 命令用来显示IPv6 RIB的路由属性事件信息。
Probe视图
1.1.265  display system internal ipv6 rib event policy
display system internal ipv6 rib event policy命令用来显示IPv6 RIB的路由策略事件信息。
Probe视图
1.1.266  display system internal ipv6 rib event prefix
display system internal ipv6 rib event prefix命令用来显示IPv6 RIB的路由前缀事件信息。
Probe视图
1.1.267  display system internal ipv6 rib event protocol
display system internal ipv6 rib event protocol命令用来显示IPv6 RIB的协议事件信息。
display system internal ipv6 rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
1.1.268  display system internal ipv6 rib event statistics
display system internal ipv6 rib event statistics用来显示IPv6 RIB的统计事件信息。
display system internal ipv6 rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
1.1.269  display system internal ipv6 rib log
display system internal ipv6 rib log命令用来显示IPv6 RIB的日志信息。
display system internal ipv6 rib log [ reverse ]
display system internal ipv6 rib event log
Probe视图
rib:显示IPv6 RIB的日志信息。
event:显示IPv6 RIB路由变化通知的日志信息。
reverse:按时间新旧显示日志信息。
1.1.270  display system internal ipv6 rib memory
display system internal ipv6 rib memory命令用来显示IPv6 RIB的内存信息。
Probe视图
1.1.271  display system internal ipv6 rib nib log
display system internal ipv6 rib nib log命令用来显示系统内部IPv6 NIB子模块运行状态的日志信息。
display system internal ipv6 rib nib log [ reverse ]
Probe视图
nib:显示IPv6 NIB子模块的运行状态。
1.1.272  display system internal ipv6 rib prefix
display system internal ipv6 rib prefix命令用来显示IPv6路由表前缀信息。
display system internal ipv6 rib prefix ipv6-address prefix-length [ vpn-instance vpn-instance-name ]
Probe视图
ipv6-address:指定IPv6目的地址。
prefix-length:前缀长度,取值范围为0~128。
1.1.273  display system internal ipv6 rib summary
display system internal ipv6 rib summary命令用来显示IPv6 RIB的统计信息。
Probe视图
无
1.1.274  display system internal ipv6 route-direct interface
display system internal ipv6 route-direct interface命令用来显示IPv6地址接口的信息。
display system internal ipv6 route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
ipv6-address:IPv6地址。
1.1.275  display system internal ipv6 route-direct log
display system internal ipv6 route-direct log命令用来显示IPv6直连路由日志信息。
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:IPv6直连路由NIB子模块相关日志。
1.1.276  display system internal ipv6 route-static nib log
display system internal ipv6 route-static nib log命令用来显示IPv6静态路由NIB子模块日志信息。
display system internal ipv6 route-static nib log [ reverse ]
Probe视图
1.1.277  display system internal ipv6 source binding
display system internal ipv6 source binding命令用来显示详细的IPv6绑定表项信息。
独立运行模式:
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] slot slot-number
IRF模式:
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
Probe视图
static:显示配置的静态绑定表项。
dhcpv6-snooping:显示DHCPv6 Snooping模块生成的动态绑定表项。
ip-address ipv6-address:显示指定IPv6地址的绑定表项,ipv6-address表示绑定的IPv6地址。
1.1.278  display system internal ipv6 tcp
display system internal ipv6 tcp命令用来指定单板上所有IPv6 TCP连接的摘要信息。
独立运行模式:
display system internal ipv6 tcp slot slot-number
IRF模式:
display system internal ipv6 tcp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 TCP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 TCP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号。(IRF模式)
1.1.279  display system internal ipv6 udp
display system internal ipv6 udp命令用来显示指定单板上所有IPv6 UDP连接的摘要信息。
独立运行模式:
display system internal ipv6 udp slot slot-number
IRF模式:
display system internal ipv6 udp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有IPv6 UDP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有IPv6 UDP连接的摘要信息。chassis-number表示设备在IRF中的成员编号, slot-number表示单板所在的槽位号。(IRF模式)
1.1.280  display system internal isis import-route
display system internal isis import-route命令用来显示IS-IS的IPv4引入路由表。
独立运行模式:
display system internal isis import-route [ ipv4 ] [ process-id ] [ standby slot slot-number ]
IRF模式:
display system internal isis import-route [ ipv4 ] [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe视图
ipv4:显示IS-IS的IPv4引入路由表。如果不指定该参数,显示IPv4引入路由表。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程引入路由表。 如果未指定IS-IS进程号,将显示所有IS-IS进程引入路由表。
standby slot slot-number:显示备份的指定单板的IS-IS引入路由表信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IS-IS的引入路由表。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IS-IS引入路由表,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IS-IS的引入路由表。(IRF模式)
1.1.281  display system internal isis import-route ipv6
display system internal isis import-route ipv6命令用来显示IS-IS的IPv6引入路由表。
独立运行模式:
display system internal isis import-route ipv6 [ process-id ] [ standby  slot slot-number ]
IRF模式:
display system internal isis import-route ipv6 [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe视图
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程引入路由表。如果未指定IS-IS进程号,将显示所有IS-IS进程引入路由表。
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IS-IS引入路由表信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IS-IS的引入路由表信息。(IRF模式)
1.1.282  display system internal isis interface
display system internal isis interface命令用来显示接口的IPv4信息。
display system internal isis interface [ ipv4 ] [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
ipv4:显示接口的IPv4信息。如果未指定该参数,显示接口的IPv4信息。
ip-address:接口IP地址,点分十进制,显示指定IP地址和掩码/掩码长度接口的信息。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
1.1.283  display system internal isis interface ipv6
display system internal isis interface ipv6命令用来显示接口的IPv6信息。
display system internal isis interface ipv6 [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
1.1.284  display system internal isis nib
display system internal isis nib命令用来显示IS-IS的IPv4路由下一跳信息。
display system internal isis nib [ ipv4 ] [ nib-id ] [ verbose ]
Probe视图
ipv4:显示IS-IS的IPv4下一跳信息。如果不指定该参数,显示IPv4下一跳信息。
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果不指定,显示所有下一跳信息。
verbose:显示下一跳详细信息。
1.1.285  display system internal isis nib ipv6
display system internal isis nib ipv6命令用来显示IS-IS的IPv6路由下一跳信息。
display system internal isis nib ipv6 [ nib-id ] [ verbose ]
Probe视图
nib-id:下一跳ID,取值范围1~FFFFFFFF。如果未指定本参数,则显示所有下一跳信息。
verbose:显示下一跳详细信息。如果未指定本参数,则显示概要信息。
1.1.286  display system internal isis nib log
display system internal isis nib log命令用来显示IS-IS路由下一跳日志信息。
Probe视图
1.1.287  display system internal isis prefix
display system internal isis prefix命令用来显示IS-IS的IPv4前缀信息。
独立运行模式:
display system internal isis prefix [ ipv4 ] [ [ level-1 | leve-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby slot slot-number ]
IRF模式:
display system internal isis prefix [ ipv4 ] [ [ level-1 | leve-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe视图
ipv4:显示IS-IS的IPv4前缀信息。如果不指定该参数,显示IPv4前缀信息。
level-1:显示IS-IS的Level-1前缀信息。如果未指定级别,将同时显示Level-1和Level-2的前缀信息。
level-2:显示IS-IS的Level-2前缀信息。如果未指定级别,将同时显示Level-1和Level-2的前缀信息。
prefix mask-length:显示指定前缀和掩码长度的前缀信息。
process-id:IS-IS进程号,取值范围为1~65535,显示指定IS-IS进程的前缀信息。如果未指定IS-IS进程号,将显示所有IS-IS进程的前缀信息。
standby slot slot-number:显示备份的指定单板的IPv4前缀信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv4前缀信息。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IS-IS IPv4前缀信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IPv4前缀信息。(IRF模式)
1.1.288  display system internal isis prefix ipv6
display system internal isis prefix ipv6命令用来显示IS-IS的IPv6前缀信息。
独立运行模式:
display system internal isis prefix ipv6 [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby  slot slot-number ]
IRF模式:
display system internal isis prefix ipv6 [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe视图
standby slot slot-number:显示备份的指定单板的IS-IS前缀信息,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主进程的IS-IS前缀信息。(独立运行模式)
standby chassis chassis-number slot slot-number:显示备份的指定成员设备上指定单板的IS-IS 前缀信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主进程的IS-IS前缀信息。(IRF模式)
1.1.289  display system internal isis status
display system internal isis status命令用来显示IS-IS的协议全局状态信息。
Probe视图
1.1.290  display system internal kernel memory dump
display system internal kernel memory dump命令用来查看指定内核内存地址的内容。
独立运行模式:
display system internal kernel memory dump address address-hex length memory-length [ slot slot-number ]
IRF模式:
display system internal kernel memory dump address address-hex length memory-length [ chassis chassis-number slot slot-number ]
Probe视图
address address-hex:表示内存起始地址。
length memory-length:表示要查看的内存大小,取值范围为1~1024,单位为字节。
slot slot-number:表示单板所在的槽位号,不指定表示主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板,不指定表示全局主用主控板。(IRF模式)
1.1.291  display system internal kernel memory pool
display system internal kernel memory pool命令用来显示内核态正在使用的内存池的统计信息。
独立运行模式:
display system internal kernel memory pool [ name name-string ] [ slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ slot slot-number ]
IRF模式:
display system internal kernel memory pool [ name name-string ] [ chassis chassis-number slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ chassis chassis-number slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ chassis chassis-number slot slot-number ]
Probe视图
name name-string:表示内存池的名字。
tag tag-value:指定内存池使用者的标识。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
不指定name和tag参数时,显示系统内存池使用情况的概要信息。
仅指定name name-string时,显示指定内存池使用情况的概要信息;
仅指定tag时,显示所有内存池使用情况的概要信息,以tag为关键字进行显示;
仅指定tag tag-value时,显示指定tag使用的内存池概要信息;
指定name name-string tag tag-value时,显示指定tag和内存池中内存对象的使用信息。
1.1.292  display system internal l2-multicast ip forwarding verbose
display system internal l2-multicast ip forwarding verbose命令用来显示二层组播的IP转发表详细信息。
独立运行模式:
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
group group-address:显示指定组播组的信息。如果未指定本参数,将显示所有组播组的信息。
source source-address:显示指定组播源的信息。如果未指定本参数,将显示所有组播源的信息。
1.1.293  display system internal l2-multicast ip verbose
display system internal l2-multicast ip verbose命令用来显示二层组播的IP组播组详细信息。
独立运行模式:
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.294  display system internal l2-multicast ipc statistics
display system internal l2-multicast ipc statistics命令用来显示二层组播板间消息的统计信息。
独立运行模式:
display system internal l2-multicast ipc statistics [ slot slot-number ]
IRF模式:
display system internal l2-multicast ipc statistics [ chassis chassis-number slot slot-number ]
Probe视图
1.1.295  display system internal l2-multicast mac forwarding verbose
display system internal l2-multicast mac forwarding verbose命令用来显示二层组播的MAC转发表详细信息。
独立运行模式:
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.296  display system internal l2-multicast mac verbose
display system internal l2-multicast mac verbose命令用来显示二层组播的MAC组播组详细信息。
独立运行模式:
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.297  display system internal l2vpn l2vfib record
display system internal l2vpn l2vfib record命令用来显示L2VPN L2VFIB模块记录的信息,包括L2VFIB模块收到的信息、L2VFIB通知驱动的信息、驱动返回的信息等。
独立运行模式:
display system internal l2vpn l2vfib record [ start start-number ] slot slot-number
IRF模式:
display system internal l2vpn l2vfib record [ start start-number ] chassis chassis-number slot slot-number
Probe视图
start start-number:从指定位置开始显示记录信息,取值范围为0~10000。
slot slot-number:显示指定单板上的记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     reset system internal l2vpn l2vfib record
1.1.298  display system internal l2vpn l2vfib statistics
display system internal l2vpn l2vfib statistics命令用来显示L2VPN L2VFIB模块的统计信息。
独立运行模式:
display system internal l2vpn l2vfib statistics slot slot-number
IRF模式:
display system internal l2vpn l2vfib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的L2VPN L2VFIB模块统计信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的L2VPN L2VFIB模块统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.299  display system internal link-aggregation global
display system internal link-aggregation global命令用来显示聚合模块的系统内部全局信息。
独立运行模式:
display system internal link-aggregation slot slot-number global
IRF模式:
display system internal link-aggregation chassis chassis-number slot slot-number global
Probe视图
chassis chassis-number slot slot-number:表示设备及单板的位置。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号列表。(IRF模式)
1.1.300  display system internal link-aggregation interface
display system internal link-aggregation interface命令用来显示聚合模块的系统内部接口信息。
独立运行模式:
display system internal link-aggregation slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics ]
display system internal link-aggregation slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics ]
IRF模式:
display system internal link-aggregation chassis chassis-number slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics ]
display system internal link-aggregation chassis chassis-number slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics ]
Probe视图
bridge-aggregation:显示二层聚合接口所对应聚合组的系统内部信息。
route-aggregation:显示三层聚合接口所对应聚合组的系统内部信息。
interface-number:取值范围为已经创建的聚合接口编号。
interface-type interface-number:聚合成员口。其中,interface-type为接口类型,interface-number为接口编号。
kernel:内核数据。
statistics:数据统计值。
lacp:动态聚合数据。
lacppdu:LACP报文统计值。
·     如果未指定kernel、lacp、lacppdu和statistics参数,则显示LAGG主线程中接口的基本数据。
·     部分显示数据重复,实际上是保存在不同的线程中,定位问题时可互相佐证,利于问题的分析。
1.1.301  display system internal lipc lcmp statistics
display system internal lipc lcmp statistics命令用来显示LIPC LCMP全局统计信息,包括收发包计数和错误计数。
display system internal lipc lcmp statistics [ lip lip ]
显示本地节点LCMP全局统计信息。
Probe视图
lip lip :可选参数,表示远端节点号,取值范围为0~32767。
1.1.302  display system internal lipc lgmp group
display system internal lipc lgmp group命令用来显示一个指定组播组信息,包含成员信息和组播组相关的统计信息。
display system internal lipc lgmp group groupID [ lip lip ]
显示本地节点指定组播组信息。
Probe视图
groupID:表示组播组号,取值范围为0-4294967295。
lip lip:可选参数,表示远端节点号,取值范围为0~32767。
1.1.303  display system internal lipc lgmp group-list
display system internal lipc lgmp group-list命令用来查看系统中所有已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
display system internal lipc lgmp group-list [ lip lip ]
显示本地节点已经创建的组播组数目、组播端口号,以及组播组的HASH分布情况。
Probe视图
1.1.304  display system internal lipc lgmp physical-group
display system internal lipc lgmp physical-group命令用来显示指定的硬件组播组信息。
display system internal lipc lgmp physical-group phyID [ lip lip ]
显示本地节点指定的硬件组播组信息。
Probe视图
physical-group phyID:表示硬件组播组ID,取值范围为0-4294967295。
1.1.305  display system internal lipc lgmp physical-group-list
display system internal lipc lgmp physical-group-list命令用来显示所有的硬件组播组信息,以便了解硬件组播组的使用情况。
display system internal lipc lgmp physical-group-list [ lip lip ]
显示本节点显示所有的硬件组播组信息。
Probe视图
1.1.306  display system internal lipc lgmp statistics
display system internal lipc lgmp statistics命令用来显示LIPC LGMP模块的统计信息。
display system internal lipc lgmp statistics [ lip lip ]
显示本地节点LIPC LGMP模块的统计信息。
Probe视图
1.1.307  display system internal lipc lip statistics
display system internal lipc lip statistics命令用来显示LIPC LIP全局统计信息。包括LIP报文的收发计数和出错计数。
display system internal lipc lip statistics [ lip lip ]
显示本地节点LIP全局统计信息。
Probe视图
1.1.308  display system internal lipc loop statistics
display system internal lipc loop statistics命令用来显示本地环回的统计信息。
display system internal lipc loop statistics [ lip lip ]
显示本地节点环回的统计信息。
Probe视图
1.1.309  display system internal lipc mtcp group
display system internal lipc mtcp group命令用来显示LIPC显示某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
显示本地节点某个组播组的成员信息或统计信息或状态机的历史变迁轨迹。
Probe视图
portID:组播成员号,取值范围为0-4294967295。
history:显示该组播组状态机的历史变迁轨迹。
member:显示该组播组的成员信息。
statistics:显示该组播组的统计信息。
1.1.310  display system internal lipc mtcp performance
display system internal lipc mtcp performance命令显示LIPC组播性能信息。
display system internal lipc mtcp performance [ lip lip ]
显示本地节点LIPC组播性能信息。
Probe视图
必须打开相应得性能统计开关后(参见lipc performance命令),该命令才能输出性能信息。
1.1.311  display system internal lipc mtcp statistics
display system internal lipc mtcp statistics命令用来显示LIPC组播的全局统计信息。
display system internal lipc mtcp statistics [ lip lip ]
显示本地节点LIPC组播的全局统计信息。
Probe视图
1.1.312  display system internal lipc pcb statistics
display system internal lipc pcb statistics命令用来显示LIPC PCB模块全局统计信息。
display system internal lipc pcb statistics [ lip lip ]
显示本地节点PCB模块全局统计信息。
Probe视图
1.1.313  display system internal lipc physical
display system internal lipc physical命令用来显示驱动适配层的全局统计信息。用于统计LIPC与驱动交互的各种信息,包括收发包计数,驱动错误计数和驱动上报事件计数。
display system internal lipc physical [ lip lip ]
显示本地节点驱动适配层的全局统计信息。
Probe视图
1.1.314  display system internal lipc publish global-cb
display system internal lipc publish global-cb命令用来显示LIPC PUBLISH模块全局控制块信息。
display system internal lipc publish global-cb [ lip lip ]
显示本地节点PUBLISH模块全局控制块信息。
Probe视图
一般用于诊断Pub模块在某个节点上是否乱序。
1.1.315  display system internal lipc publish statistics
display system internal lipc publish statistics命令用来显示LIPC  PUBLISH模块统计信息。
display system internal lipc publish statistics [ lip lip ]
显示本地节点PUBLISH模块的统计信息。
Probe视图
1.1.316  display system internal lipc stcp event
display system internal lipc stcp event命令用来显示LIPC单播事件的信息。
display system internal lipc stcp event { sync | trans } [ lip lip ]
显示本地节点LIPC单播的事件信息。
Probe视图
sync:显示LIPC单播控制报文事件信息。
trans:显示LIPC单播数据报文事件信息。
该命令主要记录本节点和其他节点的连接/DACK/销毁/时序交互信息。当设备上连接很多时,该命令记录的条目很容易满(512条),此时会将最老的记录清除掉。因此,发现问题时,应当尽早执行该命令,获取事件信息,便于定位分析。
1.1.317  display system internal lipc stcp global-server
display system internal lipc stcp global-server命令显示LIPC单播的全局知名端口信息。
display system internal lipc stcp global-server [ lip lip ]
显示本地节点LIPC单播的全局知名端口同步信息。
Probe视图
1.1.318  display system internal lipc stcp links
display system internal lipc stcp links命令用来显示单播的连接信息。包括收发包信息、状态信息、缓存信息等。
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
显示本节点LIPC单播的连接信息。
Probe视图
all:表示显示本节点所有的单播连接信息。
detail port:表示指定端口号的具体信息,取值范围为0-65535。
global gport:表示全局知名端口号,取值范围为100-8100。
listening:表示显示本节点处于侦听状态的连接。
local lport:表示本地端口号,取值范围为10100-65535。
singledetail lport rport:表示指定本地端口号和目的端口号的具体信息,取值范围为0-65535。
1.1.319  display system internal lipc stcp performance
display system internal lipc stcp performance命令用来显示单播的性能信息。
display system internal lipc stcp performance [ lip lip ]
显示本地节点LIPC单播的性能信息。
Probe视图
必须使用lipc performance命令打开相应的性能统计开关后,该命令才能输出性能信息。
·     lipc performance
1.1.320  display system internal lipc stcp statistics
display system internal lipc stcp statistics命令用来显示LIPC单播的全局统计信息,用于分析单播的全局工作情况。
display system internal lipc stcp statistics [ lip lip ]
显示本节点LIPC单播的统计信息。
Probe视图
1.1.321  display system internal lipc stcp status
display system internal lipc stcp status命令用来显示单播的传输状态。主要记录单播对象的传输序号、ACK序号、发送标志、接收状态。该命令通常用于分析单播的数据可靠传输问题。
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe视图
recv:显示发送端的单播传输状态。
send:显示接收端的单播传输状态。
1.1.322  display system internal lipc stream
display system internal lipc stream命令用来查看流模式单播的记录信息。
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
显示本地节点LIPC单播流模式信息。
Probe视图
ack:表示查看指定端口号的收到ACK的记录。
reass:表示查看指定端口号的接收重组队列信息。
send:表示查看指定端口号的发送报文分片记录。
port portID:表示端口号,为0-65535的整数。
1.1.323  display system internal lipc sudp pcb-info
display system internal lipc sudp pcb-info命令用来查看SUDP模块的PCB详细信息。
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
显示本地节点SUDP模块的PCB详细信息。
Probe视图
all-port:显示所有PCB信息。
global-port:显示全局知名端口的PCB信息。
local-port:显示本地知名端口的PCB信息。
specific-port portID:表示指定端口号,取值范围为0-65535。
1.1.324  display system internal lipc sudp statistics
display system internal lipc sudp statistics命令用来显示LIPC SUDP模块的全局统计信息。
display system internal lipc sudp statistics [ lip lip ]
显示本地节点SUDP模块的全局统计信息。
Probe视图
1.1.325  display system internal lipc sudp { global-port | local-port }
display system internal lipc sudp命令用来查看所有SUDP全局知名端口号或本地端口号的信息。
display system internal lipc sudp { global-port | local-port } [ lip lip ]
显示本地节点SUDP全局知名端口号或本地端口号的信息。
Probe视图
1.1.326  display system internal lipc topology history
display system internal lipc topology history命令用来查看拓扑链接信息的历史变迁记录。
display system internal lipc topology history [ lip lip ]
显示本地节点拓扑链接信息的历史变迁记录。
Probe视图
1.1.327  display system internal lipc topology link
display system internal lipc topology link命令用来显示LIPC 的拓扑链接信息。
display system internal lipc topology link [ lip lip ]
显示本地节点LIPC 的拓扑链接信息。
Probe视图
1.1.328  display system internal lipc topology node
display system internal lipc topology node命令用来查看拓扑节点相关的统计信息。
display system internal lipc topology node nodeID [ lip lip ]
显示本地节点上和其他拓扑节点相关的统计信息。
Probe视图
nodeID:表示节点号,取值范围为0~32767。
记录了该节点上事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
1.1.329  display system internal lipc topology process-time
display system internal lipc topology process-time命令用来查看发生拓扑事件时,通知各个模块耗时。
display system internal lipc topology process-time [ lip lip ]
显示本地节点发生拓扑事件时,通知各个模块耗时。
Probe视图
1.1.330  display system internal lipc topology statistics
display system internal lipc topology statistics命令用来查看拓扑相关的全局统计。记录了该全局事件发生的次数,并记录了最近六次发生该事件的时间(精确到0.1毫秒)。
display system internal lipc topology statistics [ lip lip ]
显示本地节点拓扑相关的全局统计。
Probe视图
1.1.331  display system internal lipc topology status
display system internal lipc topology status命令用来显示节点的拓扑状态信息。
display system internal lipc topology status [ lip lip ]
显示本地节点拓扑状态信息。
Probe视图
1.1.332  display system internal mac-address configuration
display system internal mac-address configuration命令用来显示MAC地址表的配置信息。
独立运行模式:
display system internal mac-address configuration { blackhole | multiport | multicast | static } [ count ] slot slot-number
IRF模式:
display system internal mac-address configuration { blackhole | multiport | multicast | static } [ count ] chassis chassis-number slot slot-number
Probe视图
blackhole:显示黑洞MAC地址表项。
multiport:显示多端口单播MAC地址表项。
multicast:显示组播MAC地址表项。
static:显示静态MAC地址表项。
count:显示MAC地址表项的数量。如果配置本参数,将仅显示符合条件的(由count前面的参数决定)MAC地址表项的数量,而不显示MAC地址表项的具体内容。如果不指定本参数,则显示符合条件的MAC地址表的具体内容。
slot slot-number:显示指定单板的MAC地址信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC地址信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.333  display system internal mac-address statistics
display system internal mac-address statistics命令用来显示MAC地址表的统计信息。
独立运行模式:
display system internal mac-address statistics slot slot-number
IRF模式:
display system internal mac-address statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的MAC地址表统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MAC地址表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.334  display system internal mbuf relay statistics
display system internal mbuf relay statistics命令用来显示MBUF中继模块的统计信息。
独立运行模式:
display system internal mbuf relay statistics slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
IRF模式:
display system internal mbuf relay statistics chassis chassis-number slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
Probe视图
slot slot-number:显示指定单板的MBUF中继模块的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MBUF中继模块的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-id:MBUF中继使用的CPU编号。不指定该参数时,表示当前单板上的所有CPU。
rcv received-id:MBUF中继接收者的编号。不指定该参数时,表示当前CPU上的所有接收者。
1.1.335  display system internal mbuf statistics
display system internal mbuf命令用来显示MBUF的统计信息。
独立运行模式:
display system internal mbuf statistics slot slot-number
IRF模式:
display system internal mbuf statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的MBUF统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MBUF统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.336  display system internal mpls lfib ilm
display system internal mpls lfib ilm命令用来显示MPLS ILM表项的详细信息。
独立运行模式:
display system internal mpls lfib ilm label slot slot-number
IRF模式:
display system internal mpls lfib ilm label chassis chassis-number slot slot-number
Probe视图
label:显示指定入标签的ILM表项详细信息,取值范围为16~1048575。
slot slot-number:显示指定单板上的ILM表项详细信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的ILM表项详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.337  display system internal mpls lfib nhlfe
display system internal mpls lfib nhlfe命令用来显示MPLS NHLFE表项详细信息。
独立运行模式:
display system internal mpls lfib nhlfe nid slot slot-number
IRF模式:
display system internal mpls lfib nhlfe nid chassis chassis-number slot slot-number
Probe视图
nid:显示指定NHLFE表项的详细信息。nid为NHLFE表项索引,取值范围为0~4294967294。
slot slot-number:显示指定单板上的NHLFE表项详细信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的NHLFE表项详细信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.338  display system internal mpls lfib nhlfe reflist
display system internal mpls lfib nhlfe reflist命令用来显示MPLS NHLFE反向关联信息。
独立运行模式:
display system internal mpls lfib nhlfe nid reflist slot slot-number
IRF模式:
display system internal mpls lfib nhlfe nid reflist chassis chassis-number slot slot-number
Probe视图
nid:显示指定NHLFE表项的反向关联信息。nid为NHLFE表项索引,取值范围为0~4294967294。
slot slot-number:显示指定单板上的NHLFE表项的反向关联信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的NHLFE表项的反向关联信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.339  display system internal mpls lfib record
display system internal mpls lfib record命令用来显示MPLS LFIB模块记录的信息,包括LFIB模块收到的信息、LFIB通知驱动的信息、驱动返回的信息等。
独立运行模式:
display system internal mpls lfib record [ start start-number ] slot slot-number
IRF模式:
display system internal mpls lfib record [ start start-number ] chassis chassis-number slot slot-number
Probe视图
start start-number:从指定位置开始显示记录信息,取值范围为0~4096。
·     reset system internal mpls lfib record
1.1.340  display system internal mpls lfib statistics
display system internal mpls lfib statistics命令用来显示MPLS LFIB的统计信息。
独立运行模式:
display system internal mpls lfib statistics slot slot-number
IRF模式:
display system internal mpls lfib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的MPLS LFIB统计信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的MPLS LFIB统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.341  display system internal mpls lsp-pending
display system internal mpls lsp-pending命令用来显示LDP、BGP、RSVP协议GR过程中,尚未下发到转发平面的LSP信息。
Probe视图
1.1.342  display system internal mpls statistics
display system internal mpls statistics命令用来显示MPLS的内部状态统计信息。
Probe视图
1.1.343  display system internal mrib interface statistics
display system internal mrib interface statistics命令用来显示MRIB所维护接口的统计信息,这些接口包括配置了PIM、IGMP等组播协议的接口以及注册接口、InLoopBack0接口、Null0接口等内部接口。
display system internal mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例上MRIB所维护接口的统计信息,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例上MRIB所维护接口的统计信息。
1.1.344  display system internal mrib mbr
display system internal mrib mbr命令用来显示MRIB进程中MBR模块维护的组加入信息。
display system internal mrib [ vpn-instance vpn-instance-name ] mbr interface interface-type interface-number [ source source-address group group-address ]
Probe视图
source source-address:显示指定组播源的MBR表项信息。如果未指定本参数,将不显示MBR表项信息。
group group-address:显示指定组播组的MBR表项信息,group-address的取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将不显示MBR表项信息。
1.1.345  display system internal multicast capability
display system internal multicast capability命令用来显示组播能力的信息。
独立运行模式:
display system internal multicast capability [ slot slot-number ]
IRF模式:
display system internal multicast capability [ chassis chassis-number slot slot-number ]
Probe视图
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。如果未指定本参数,则显示主控板上的信息。(独立运行模式)
1.1.346  display system internal multicast forwarding vlan reference
display system internal multicast forwarding vlan reference命令用来显示VLAN出接口与二层组播表项之间的映射关系。
独立运行模式:
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
IRF模式:
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe视图
1.1.347  display system internal multicast forwarding-table dummy
display system internal multicast forwarding-table dummy命令用来显示组播临时转发表的信息。
独立运行模式:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | statistics | slot slot-number ] *
IRF模式:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | chassis chassis-number slot slot-number | statistics ] *
Probe视图
group-address:显示指定组播组的信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的信息。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
statistics:显示统计信息。
1.1.348  display system internal multicast forwarding-table verbose
display system internal multicast forwarding-table verbose命令用来显示组播转发表的详细信息。
独立运行模式:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number ] *
IRF模式:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | chassis chassis-number slot slot-number | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例的组播转发项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网实例的组播转发项。
group-address:组播组地址,显示指定组播组的组播转发项,取值范围为224.0.0.0~239.255.255.255。
source-address:组播源地址,显示包含指定组播源的组播转发项。
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的组播转发项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将显示IRF中所有主控板上的组播转发表项。(IRF模式)
incoming-interface:显示指定入接口的组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的组播转发项。
outgoing-interface:显示指定出接口的组播转发项。
exclude:显示出接口列表中不包含指定接口的组播转发项。
include:显示出接口列表中包含指定接口的组播转发项。
match:显示出接口列表中包含且仅包含指定接口的组播转发项。
slot slot-number:显示指定单板上的组播转发项,slot-number表示单板所在的槽位号。如果未指定本参数,将显示主控板上的组播转发表项。(独立运行模式)
1.1.349  display system internal multicast record
display system internal multicast record命令用来显示组播表项的操作记录。
独立运行模式:
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ slot slot-number ]
IRF模式:
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ chassis chassis-number slot slot-number ]
Probe视图
statistics:显示组播表项操作记录的统计信息。
all:显示组播表项的所有操作记录。
fail:显示组播表项的失败操作记录。
group-address:组播组地址,显示指定组播组的记录。
ipv6-group-address:IPv6组播组地址,显示指定IPv6组播组的记录。
source-address:组播源地址,显示包含指定组播源的记录。
ipv6-source-address:IPv6组播源地址,显示包含指定IPv6组播源的记录。
item item-list:记录列表,表示一条或多条记录。表示方式为item-list = start-item [ to end-item ]。其中,start-item和end-item的取值范围均为1~500000。
filter:显示指定模式下的组播表项操作记录。
exclude:显示排除满足指定条件的组播表项操作记录。
include:显示包含满足指定条件的组播表项操作记录。
add-l2-ip:表示添加二层IP表项的操作记录。
add-l2-ip-port:表示添加二层IP表项端口的操作记录。
add-l2-ip-slot:表示添加二层IP表项板信息的操作记录。
add-l2-mac:表示添加二层MAC表项的操作记录。
add-l2-mac-port:表示添加二层MAC表项端口的操作记录。
add-l2-mac-slot:表示添加二层MAC表项板信息的操作记录。
add-l3-ipm:表示添加三层组播表项的操作记录。
add-l3-oif:表示添加三层表项出接口的操作记录。
add-l3-port:表示添加三层表项出端口的操作记录。
add-l3-slot:表示添加三层表项分布式转发的出接口板信息的操作记录。
del-l2-ip:表示删除二层IP表项的操作记录。
del-l2-ip-port:表示删除二层IP表项端口的操作记录。
del-l2-ip-slot:表示删除二层IP表项板信息的操作记录。
del-l2-mac:表示删除二层MAC表项的操作记录。
del-l2-mac-port:表示删除二层MAC表项端口的操作记录。
del-l2-mac-slot:表示删除二层MAC表项板信息的操作记录。
del-l3-ipm:表示删除三层组播表项的操作记录。
del-l3-oif:表示删除三层表项出接口的操作记录。
del-l3-port:表示删除三层表项出端口的操作记录。
del-l3-slot:表示删除三层表项分布式转发的出接口板信息的操作记录。
set-l3-iif:表示设置三层表项入接口的操作记录。
ipmc-type-all:表示全部类型。
verbose:显示详细信息。如果记录的出接口和出端口显示不全时,需要指定本参数。
1.1.350  display system internal multicast-vlan forwarding-table verbose
display system internal multicast-vlan forwarding-table verbose命令用来显示组播VLAN转发表的详细信息。
独立运行模式:
display system internal multicast-vlan forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
IRF模式:
display system internal multicast-vlan forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | chassis chassis-number slot slot-number | subvlan vlan-id | vlan vlan-id ] *
Probe视图
mask { mask-length | mask }:指定组播组的掩码长度或掩码。mask-length的取值范围为4~32,缺省值为32;mask的缺省值为255.255.255.255。
mask { mask-length | mask }:指定组播源的掩码长度或掩码。mask-length的取值范围为0~32,缺省值为32;mask的缺省值为255.255.255.255。
1.1.351  display system internal mvrp interface
display system internal mvrp interface命令用来显示端口在指定VLAN下的MVRP运行信息。
display system internal mvrp interface interface-type interface-number vlan vlan-id
Probe视图
interface interface-type interface-number:显示指定端口的MVRP运行信息,interface-type interface-number表示端口类型和端口编号。
vlan vlan-id:显示端口在指定VLAN内的MVRP运行信息。其中,vlan-id为指定VLAN的编号,取值范围为1~4094。
1.1.352  display system internal mvrp map-count
display system internal mvrp map-count命令用来显示指定VLAN的传播计数信息。
display system internal mvrp map-count vlan vlan-id
Probe视图
vlan vlan-id:显示指定VLAN的传播计数信息。其中,vlan-id为指定VLAN的编号,取值范围为1~4094。
该命令显示设备通过MVRP在指定VLAN注册的允许传播的接口个数,表明当前有多少STP状态为Forwarding的接口注册了该VLAN。
1.1.353  display system internal nd dad
display system internal nd dad命令用来显示指定单板的DAD链信息。
独立运行模式:
display system internal nd dad slot slot-number
IRF模式:
display system internal nd dad chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的DAD链信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的DAD链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.354  display system internal nd entry
display system internal nd entry命令用来显示各板上的ND表项信息。
独立运行模式:
display system internal nd entry slot slot-number
IRF模式:
display system internal nd entry chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ND表项信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ND表项信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.355  display system internal nd ifcb
display system internal nd ifcb命令用来显示指定单板的接口ND控制块信息。
独立运行模式:
display system internal nd ifcb interface interface-type interface-number slot slot-number
IRF模式:
display system internal nd ifcb interface interface-type interface-number chassis chassis-number slot slot-number
Probe视图
interface interface-type interface-number:显示指定接口的ND控制块信息。interface-type interface-number为接口类型和接口编号。
slot slot-number:显示指定单板的ND控制块信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ND控制块信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.356  display system internal nd machash
display system internal nd machash命令用来显示指定单板上的machash表项。
独立运行模式:
display system internal  nd machash vlan vlan-id ipv6-address slot slot-number
IRF模式:
display system internal  nd machash vlan vlan-id ipv6-address chassis chassis-number slot slot-number
Probe视图
vlan vlan-id: 显示指定VLAN的信息。vlan-id表示指定VLAN的编号。
IPv6-address:指定IPv6地址。
slot slot-number:显示指定单板的machash表项,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的machash表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.357  display system internal nd probe
display system internal nd probe命令用来显示指定单板的探测链信息。
独立运行模式:
display system internal nd probe slot slot-number
IRF模式:
display system internal nd probe chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的探测链信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的探测链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.358  display system internal nd reload
display system internal nd reload命令用来显示重刷链信息。
独立运行模式:
display system internal nd reload slot slot-number
IRF模式:
display system internal nd reload chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的重刷链信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的重刷链信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.359  display system internal nd static
display system internal nd static命令用来显示ND静态配置。
display system internal nd static ipv6-address interface interface-type interface-number
Probe视图
interface interface-type interface-number:显示指定接口的信息。interface-type interface-number为接口类型和接口编号。
1.1.360  display system internal nd statistics
display system internal nd statistics命令用来显示指定单板上的ND统计信息。
独立运行模式:
display system internal nd statistics slot slot-number
IRF模式:
display system internal nd statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板的ND统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上指定单板的ND统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.361  display system internal ospf event-log
display system internal ospf event-log命令用来显示OSPF的日志信息。
display system internal ospf event-log { gr | ha | interface | nib | notify | upgrade }
Probe视图
gr:显示GR日志。
ha:显示HA事件处理日志信息。
interface:显示接口事件日志。
nib:显示NIB日志。
notify:显示接口通知日志。
upgrade:显示升级平滑日志信息。
1.1.362  display system internal ospf interface
display system internal ospf interface命令用来显示接口相关信息。
display system internal ospf interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN实例下接口相关信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则显示公网的信息。
interface-type interface-number:接口类型和编号。如果未指定本参数,将显示所有接口的信息。
mask:网络掩码,点分十进制格式。
mask-length:网络掩码长度,取值范围为0~32。
1.1.363  display system internal ospf lsdb
display system internal ospf lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospf [ process-id ] lsdb { asbr | ase | nssa | summary }
Probe视图
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的LSA map信息。
asbr:显示数据库中Type-4 LSA(ASBR Summary LSA)的map信息。
ase:显示数据库中Type-5 LSA(AS External LSA)的map信息。
nssa:显示数据库中Type-7 LSA(NSSA External LSA)的map信息。
summary:显示数据库中Type-3 LSA(Network Summary LSA)的map信息。
1.1.364  display system internal ospf nib
display system internal ospf nib命令用来显示NIB分配的下一跳信息。
display system internal ospf nib [ nib-id ] [ verbose ]
Probe视图
nib-id:路由下一跳信息的ID值,取值范围1~FFFFFFFF。
verbose:显示NIB详细信息。
1.1.365  display system internal ospf prefix
display system internal ospf prefix命令用来显示OSPF中前缀对应的LSA信息。
display system internal ospf [ process-id ] prefix [ ip-address { mask | mask-length } ]
Probe视图
process-id:OSPF进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPF进程的前缀信息。
ip-address:路由的目的IP地址。如果未指定本参数,将显示所有前缀的信息。
mask:网络掩码,点分十进制格式。
1.1.366  display system internal ospf status
display system internal ospf status命令用来显示OSPF协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
1.1.367  display system internal ospfv3 event-log
display system internal ospfv3 event-log命令用来显示OSPFv3的各种日志信息。
display system internal ospfv3 event-log { gr | nib | rib }
Probe视图
gr:显示GR状态机变迁记录。
nib:显示路由管理上报给OSPFv3的NIB信息。
rib:显示路由管理上报给OSPFv3的RIB信息。
1.1.368  display system internal ospfv3 interface
display system internal ospfv3 interface命令用来显示OSPFv3的接口相关信息。
display system internal ospfv3 interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
vpn-instance vpn-instance-name:指定OSPFv3进程所属的VPN。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示OSPFv3位于公网中。
ipv6-address:IPv6地址前缀。
prefix-length:IPv6地址前缀长度,取值范围为0~128。
1.1.369  display system internal ospfv3 lsdb
display system internal ospfv3 lsdb命令用来显示LSA产生的来源及详细信息。
display system internal ospfv3 [ process-id ] lsdb { inter-prefix | inter-router | intra-prefix { reference type-1 | reference type-2 } | router }
Probe视图
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程下的map信息。
inter-prefix:显示Inter-area-prefix LSA的map信息。
inter-router:显示Inter-area-router LSA的map信息。
intra-prefix:显示Intra-area-prefix LSA的map信息。
reference type-1:显示引用Router-LSA的Intra-area-prefix LSA map信息。
reference type-2:显示引用Network-LSA的Intra-area-prefix LSA map信息。
router:显示Router-LSA的map信息。
1.1.370  display system internal ospfv3 nib
display system internal ospfv3 nib命令用来显示OSPFv3的下一跳NIB信息。
display system internal ospfv3 nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示NIB详细信息。
1.1.371  display system internal ospfv3 prefix
display system internal ospfv3 prefix命令用来显示OSPFv3的前缀对应的LSA信息。
display system internal ospfv3 [ process-id ] prefix { inter | intra } [ ipv6-address prefix-length ]
Probe视图
process-id:OSPFv3进程号,取值范围为1~65535。如果未指定本参数,将显示所有OSPFv3进程的前缀对应的LSA信息。
inter:显示InterAs前缀对应的LSA信息。
intra:显示IntraAs前缀对应的LSA信息。
ipv6-address prefix-length:显示指定IPv6地址的OSPFv3前缀对应的LSA信息。ipv6-address表示IPv6地址前缀;prefix-length表示IPv6地址前缀长度,取值范围为0~128。如果未指定本参数,将显示所有的前缀对应的LSA信息。
1.1.372  display system internal ospfv3 status
display system internal ospfv3 status命令用来显示OSPFv3协议状态信息,包括内存门限状态,及各模块相关信息。
Probe视图
1.1.373  display system internal pbr fib
display system internal pbr fib命令用来显示用户态下下一跳的配置信息。
独立运行模式:
display system internal pbr fib [ vpn-instance vpn-instance-name ] slot slot-number
IRF模式:
display system internal pbr fib [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
不显示用户态下下一跳的配置信息。
Probe视图
vpn-instance vpn-instance-name:显示用户态下指定私网内下一跳的配置信息,不指定该参数为公网内下一跳。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。指定的VPN实例必须已经存在。
slot slot-number:显示用户态下指定单板指定私网内下一跳的配置信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的指定私网内下一跳的配置信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.374  display system internal pbr kernel policy
display system internal pbr kernel policy用于显示内核态下的策略路由信息。
独立运行模式:
display system internal pbr kernel policy [ policy-name [ setup ] ] slot slot-number
IRF模式:
display system internal pbr kernel policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
不显示内核态下的策略路由信息。
Probe视图
policy policy-name:显示内核态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
slot slot-number:显示内核态下指定单板上的策略路由信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示内核态下指定成员设备上指定单板的策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.375  display system internal pbr policy
display system internal pbr policy用于显示用户态下的策略路由信息。
独立运行模式:
display system internal pbr policy [ policy-name [ setup ] ] slot slot-number
IRF模式:
display system internal pbr policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
不显示用户态下的策略路由信息。
Probe视图
policy policy-name:显示用户态下指定策略路由的信息。policy-name为策略名,为1~19个字符的字符串,区分大小写。
slot slot-number:显示用户态下指定单板上的策略路由信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示用户态下指定成员设备上指定单板的策略路由信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.376  display system internal pim interface
display system internal pim interface命令用来显示PIM进程中路由管理LIB所维护的接口信息。
display system internal pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number | ip-address { mask-length | mask } ]
Probe视图
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将显示公网的信息。
ip-address:显示指定IP地址的信息。如果未指定本参数,将显示所有IP地址的信息。0.0.0.0为保留地址,用户不感知。
mask-length:表示掩码长度,取值范围为0~32。
mask:表示掩码。
1.1.377  display system internal pim rp
display system internal pim rp命令用来显示PIM的RP统计信息。
display system internal pim [ vpn-instance vpn-instance-name ] rp
Probe视图
1.1.378  display system internal pim thread
display system internal pim thread命令用来显示PIM线程的统计信息。
display system internal pim thread { event | main | route }
Probe视图
event:显示PIM事件线程的统计信息。
main:显示PIM主线程的统计信息。
route:显示PIM路由线程的统计信息。
1.1.379  display system internal rawip
display system internal rawip命令用来显示指定单板上所有RawIP连接的摘要信息。
独立运行模式:
display system internal rawip slot slot-number
IRF模式:
display system internal rawip chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有RawIP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有RawIP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.380  display system internal rib event attribute
display system internal rib event attribute命令用来显示IPv4 RIB的路由属性事件信息。
Probe视图
1.1.381  display system internal rib event policy
display system internal rib event policy命令用来显示IPv4 RIB的路由策略事件信息。
Probe视图
1.1.382  display system internal rib event prefix
display system internal rib notificaion prefix命令用来显示IPv4 RIB的路由前缀事件信息。
Probe视图
1.1.383  display system internal rib event protocol
display system internal rib event protocol命令用来显示IPv4 RIB的协议事件信息。
display system internal rib event protocol [ vpn-instance vpn-instance-name ]
Probe视图
1.1.384  display system internal rib event statistics
display system internal rib event statistics用来显示IPv4 RIB的统计事件信息。
display system internal rib event statistics [ vpn-instance vpn-instance-name ]
Probe视图
1.1.385  display system internal rib log
display system internal rib log命令用来显示RIB的日志信息。
display system internal rib log [ reverse ]
display system internal rib event log
Probe视图
rib:显示RIB的日志信息。
event:显示RIB路由变化通知的日志信息。
1.1.386  display system internal rib memory
display system internal rib memory命令用来显示RIB的内存信息。
Probe视图
1.1.387  display system internal rib nib log
display system internal rib nib log命令用来显示系统内部NIB子模块运行状态的日志记录。
display system internal rib nib log [ reverse ]
Probe视图
nib:显示NIB子模块的运行状态。
1.1.388  display system internal rib prefix
display system internal rib prefix命令用来显示IPv4路由表前缀信息。
display system internal rib prefix ip-address mask-length [ vpn-instance vpn-instance-name ]
Probe视图
ip-address:指定IPv4目的地址。
mask-length:IP地址掩码,取值范围为0~32。
1.1.389  display system internal rib summary
display system internal rib summary命令用来显示IPv4 RIB的统计信息。
Probe视图
无
1.1.390  display system internal rip interface
display system internal rip interface命令用来显示接口信息。
display system internal rip interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
1.1.391  display system internal rip nib
display system internal rip nib命令用来显示RIP路由下一跳信息。
display system internal rip nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示下一跳详细信息。
1.1.392  display system internal rip nib log
display system internal rip nib log命令用来显示RIP路由下一跳日志信息。
Probe视图
1.1.393  display system internal rip status
display system internal rip status命令用来显示RIP协议全局状态信息。
Probe视图
1.1.394  display system internal ripng interface
display system internal ripng interface命令用来接口信息。
display system internal ripng interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe视图
1.1.395  display system internal ripng nib
display  system internal ripng nib命令用来RIPng路由下一跳信息。
display system internal ripng nib [ nib-id ] [ verbose ]
Probe视图
verbose:显示下一跳详细信息。
1.1.396  display system internal ripng nib log
display  system internal ripng nib log命令用来RIPng路由下一跳日志信息。
Probe视图
1.1.397  display system internal ripng status
display system internal ripng status命令用来显示RIPng协议全局状态信息。
Probe视图
1.1.398  display system internal route-direct interface
display system internal route-direct interface命令用来显示IPv4地址接口的信息。
display system internal route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe视图
1.1.399  display system internal route-direct log
display system internal route-direct log命令用来显示直连路由日志信息。
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe视图
event:接口事件相关日志。
notify:接口事件通知相关日志。
nib:直连路由NIB子模块相关日志。
1.1.400  display system internal route-static nib log
display system internal route-static nib log命令用来显示静态路由NIB子模块日志信息。
display system internal route-static nib log [ reverse ]
Probe视图
1.1.401  display system internal sflow statistics
display system internal sflow statistics命令用来显示sFlow的统计信息。
独立运行模式:
display system internal sflow statistics [ slot slot-number ]
IRF模式:
display system internal sflow statistics [ chassis chassis-number slot slot-number ]
probe视图
slot slot-number:查看指定单板上的sFlow的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:查看指定成员设备上指定单板的sFlow的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.402  display system internal startup cache
display system internal startup cache命令用来显示设备本次启动时使用的二进制配置文件的路径,如flash:/startup.mdb。
Probe视图
用户执行save命令保存配置时,系统会自动生成一个字符串类型的配置文件和一个二进制类型的配置文件。
·     字符串类型的配置文件是一个文本文件,文件名后缀为“.cfg”,可以通过more命令查看该文件的内容。
·     二进制类型的配置文件是字符串类型的配置文件的二进制格式,文件名后缀为“.mdb”。在设备启动和运行时,系统软件能够解析该类配置文件,而用户却不能读取和编辑文件内容。
两个文件保存的配置相同,但格式不同。设备启动的时候,会优先使用二进制类型的配置文件,以便提高加载配置的速度。如果没有找到合适的二进制类型的配置文件,才使用字符串类型的配置文件。
当设备本次启动使用的是二进制类型的配置文件时,使用该命令会显示该二进制文件的路径;当设备本次启动使用的是字符串类型的配置文件时,使用该命令将显示None。
1.1.403  display system internal stp bridge-info
display system internal stp bridge-info命令用来显示生成树指定实例桥配置信息及运行状态。
独立运行模式:
display system internal stp bridge-info instance instance-id slot slot-number
IRF模式:
display system internal stp bridge-info instance instance-id chassis chassis-number slot slot-number
Probe视图
instance instance-id:显示指定实例的生成树桥配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
slot slot-number:显示指定单板的生成树桥配置信息和运行状态,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的生成树桥配置信息和运行状态,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.404  display system internal stp port-info
display system internal stp port-info命令用来显示生成树指定实例端口配置信息及运行状态。
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe视图
instance instance-id:显示指定实例的生成树端口配置信息和运行状态,instance-id为MSTI的编号,取值范围为0~4094,0表示CIST。
interface interface-type interface-number:显示指定端口上的生成树端口信息和运行状态,interface-type interface-number表示端口类型和端口编号。
1.1.405  display system internal tcp
display system internal tcp命令用来显示指定单板上所有TCP连接的摘要信息。
独立运行模式:
display system internal tcp slot slot-number
IRF模式:
display system internal tcp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有TCP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有TCP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.406  display system internal tunnel data
display system internal tunnel data命令用来显示Tunnel接口内核数据信息。
独立运行模式:
display system internal tunnel data interface tunnel number [ slot slot-number ]
IRF模式:
display system internal tunnel data interface tunnel number [ chassis chassis-number slot slot-number ]
Probe视图
interface tunnel number:显示指定Tunnel接口的内核数据信息。number表示Tunnel接口编号,取值为已创建的Tunnel接口的编号。
slot slot-number:显示指定单板的Tunnel接口内核数据信息。slot-number表示单板所在的槽位号。如果不指定本参数,则显示主用主控板的信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的Tunnel接口内核数据信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则显示全局主用主控板的信息。(IRF模式)
1.1.407  display system internal udp
display system internal udp命令用来显示指定单板上所有UDP连接的摘要信息。
独立运行模式:
display system internal udp slot slot-number
IRF模式:
display system internal udp chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示从指定单板上获取的所有UDP连接的摘要信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示从指定成员设备的指定单板上获取的所有UDP连接的摘要信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.408  display system internal vlan
display system internal vlan命令用来查看VLAN模块相关的内部信息。
独立运行模式:
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } slot slot-number
IRF模式:
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } chassis chassis-number slot slot-number
Probe视图
instance vlan-id:显示指定VLAN的VLAN模块信息。vlan-id为指定VLAN的编号,取值范围为1~4094。
interface interface-type interface-number:显示指定端口的VLAN模块信息。interface-type interface-number为端口类型和端口编号。
slot slot-number:查看指定单板上的VLAN模块信息。其中,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:查看指定成员设备上指定单板的VLAN模块信息。其中,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.1.409  display system internal zone acl
display system internal zone acl命令用来显示已经下发的FC Zone ACL相关信息。
独立运行模式:
display system internal zone acl vsan vsan-id [ slot slot-number ]
IRF模式:
display system internal zone acl vsan vsan-id [ chassis chassis-number slot slot-number ]
Probe视图
vsan vsan-id:显示指定VSAN内已经下发的FC Zone ACL信息。vsan-id的取值范围为1~3839。
slot slot-number:显示指定单板上已经下发的FC Zone ACL信息。slot-number表示单板所在的槽位号。如果不指定本参数,将显示主用主控板上已经下发的FC Zone ACL信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板上已经下发的FC Zone ACL信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,将显示全局主用主控板上已经下发的FC Zone ACL信息。(IRF模式)
1.2  F
1.2.1  follow
follow命令用来通过跟踪栈信息来调试指定的进程或者线程。
独立运行模式:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ slot slot-number ]
IRF模式:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ chassis chassis-number slot slot-number ]
Probe视图
job job-id:任务ID,用于唯一标识一个进程,该ID不会随着进程的重启而改变,取值范围为1~2147483647。
process pid:进程ID,该ID可能会随着进程的重启而改变,取值范围为1~2147483647。
thread thread-id:线程ID,用于指定进程内某一指定线程,取值范围为1~2147483647。
delay seconds:指定每次跟踪操作的间隔时间,取值范围为0~255秒,缺省为5秒。
iteration count:指定跟踪调试的次数的次数,取值范围为1~255次,缺省为5次。
对于用户态进程,follow命令会分别显示当前进程的内核态堆栈和用户态堆栈信息,并以user stack/kernel stack提示符加以区分;对于内核态进程,则只显示内核态堆栈信息。
不指定thread参数时,默认显示指定进程内所有线程。
1.3  I
1.3.1  irf link-status auto-recovery enable
irf link-status auto-recovery enable命令用来使能IRF链路故障恢复功能。
undo irf link-status auto-recovery enable命令用来关闭IRF链路故障恢复功能。
IRF链路故障恢复功能处于使能状态。
Probe视图
使能IRF链路故障恢复功能后,系统能自动对检测到的IRF链路故障尝试修复,增强系统的稳定性。
该命令仅供调试IRF链路故障恢复功能运行是否正常。如果调试结束,请输入使能命令,确保设备的IRF链路故障恢复功能处于使能状态。
·     只有先使能IRF链路状态检测功能,本命令才生效。
·     本命令只在IRF模式下支持。配置undo irf link-status auto-recovery enable命令并保存配置后,切换到独立运行模式,该配置将失效。即便之后再切换回IRF模式,仍需重新配置。
1.3.2  irf link-status detect enable
irf link-status detect enable命令用来使能IRF链路状态检测功能。
undo irf link-status detect enable命令用来关闭IRF链路状态检测功能。
IRF链路状态检测功能处于使能状态。
Probe视图
使能IRF链路的状态检测功能后,当存在多于一条IRF物理连接时,系统会检测每条IRF物理连接是否连通,确保系统能及时发现故障链路。
该命令仅供调试IRF链路的状态检测功能运行是否正常。如果调试结束,请输入使能命令,确保设备的IRF链路状态检测功能处于使能状态。
需要注意的是,本命令只在IRF模式下支持。配置undo irf link-status detect enable命令并保存配置后,切换到独立运行模式,该配置将失效。即便之后再切换回IRF模式,仍需重新配置。
1.4  L
1.4.1  l2vpn l2vfib record size
l2vpn l2vfib record size命令用来设置L2VPN L2VFIB模块记录信息的最大数目。
独立运行模式:
l2vpn l2vfib record size size slot slot-number
IRF模式:
l2vpn l2vfib record size size chassis chassis-number slot slot-number
L2VPN L2VFIB模块记录信息的最大数目为4096条。
Probe视图
slot slot-number:指定单板上的记录信息的最大数目。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板的记录信息的最大数目。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.4.2  lipc dump-port
lipc dump-port命令打开指定单播端口的dump开关。
lipc dump-port port &<1-5> [ lip lip ]
undo lipc dump-port [ lip lip ]
单播端口的dump开关是关闭的。
Probe视图
port &<1-5>:表示单播端口号,取值范围为0-65535。&<1-5>表示前面的参数最多可以输入5次。
打开指定单播端口的dump开关后,系统会在/proc/lipc/dumpinfo文件中记录该端口的所有报文收发信息。
1.4.3  lipc performance
lipc performance命令用来配置单播或者组播的性能统计功能,用于评测LIPC的传输性能。
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
性能统计开关是关闭的。
Probe视图
mtcp:MTCP子模块的信息。
stcp:STCP子模块的信息。
clear:清除单播或者组播的性能统计信息。
off:关闭单播或者组播的性能统计开关。
on:打开单播或者组播的性能统计开关。
1.4.4  lipc ping
lipc ping命令ping其它节点并等待回应,用于检查与目的节点LIPC通信链路是否正常。
lipc ping lip [ length len times num ]
发送长度为100字节的请求报文,发送10次。
Probe视图
LIP :表示节点号,取值范围为0~32767。
length len: 可选参数,表示报文长度,取值范围为0~32767。
times num:可选参数,表示发送次数,取值范围为0~32767。
系统中有效的节点号可以使用display system internal lipc topology link 命令获取,用户需自己保证节点号的有效性。
1.4.5  lipc timeout
lipc timeout命令用来设置LIPC拓扑链路的超时时间。
lipc timeout time [ lip lip ]
拓扑链路的超时时间为60秒。
Probe视图
timeout time:表示超时时间,取值范围为3-65535。
如果本节点的TOPOLOGY模块在超时时间内没有收到UP节点的心跳报文,则会断开与该节点的所有单播、组播连接。
通常,只有在使用KDB或者KGDB调试内核时,才需要修改该数值,以避免其他节点认为正处于内核调试状态的节点链路Down。
1.4.6  list
list命令用来查看系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息,且文件路径中不能包含文件链接。
独立运行模式:
list file-path [ slot slot-number ]
IRF模式:
list file-path [ chassis chassis-number slot slot-number ]
Probe视图
file-path:要查看的文件或目录的路径,区分大小写。
slot slot-number:查看指定单板系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:查看指定设备上单板系统目录(/proc/、/sys/、/var/)下的文件和子目录的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(IRF模式)
1.5  M
1.5.1  memory boundary-check enable
memory boundary-check enable命令用来开启内存越界检查功能。
undo memory boundary-check enable命令用来恢复缺省情况。
独立运行模式:
memory boundary-check enable job job-id [ slot slot-number ]
undo memory boundary-check enable job job-id [ slot slot-number ]
IRF模式:
memory boundary-check enable job job-id [ chassis chassis-number slot slot-number ]
undo memory boundary-check enable job job-id [ chassis chassis-number slot slot-number ]
内存越界检查功能处于关闭状态。
Probe视图
开启指定进程的内存越界检查功能后,该进程每次释放内存前都会进行内存越界检查,以便确保申请和释放操作的正确性。如果发生内存越界,将内存越界信息记录到内存文件中(所有进程的越界信息都会记录到一个文件中)。
·     memory boundary-check scan
1.5.2  memory boundary-check scan
memory boundary-check scan命令用来触发一次内存越界检查,并显示检查的结果。若有内存被写越界,则打印出该出错处地址往前偏移16字节,一共128字节的内存内容。
独立运行模式:
memory boundary-check scan job job-id [ slot slot-number ]
IRF模式:
memory boundary-check scan job job-id [ chassis chassis-number slot slot-number ]
Probe视图
使用前必须使能内存越界检测功能,否则使用该命令检查,无效果。
执行该命令后,系统会从出错处地址往前偏移16字节,一共显示128字节的内存内容;当系统中存在多处内存越界时,只记录并显示地址最小的一条检查结果。
·     memory boundary-check enable
1.5.3  mpls lfib record size
mpls lfib record size命令用来设置MPLS LFIB模块记录信息的最大数目。
独立运行模式:
mpls lfib record size size slot slot-number
IRF模式:
mpls lfib record size size chassis chassis-number slot slot-number
MPLS LFIB模块记录信息的最大数目为4096条。
Probe视图
1.5.4  multicast record
multicast record命令用来配置组播表项操作记录的最大数目。
undo multicast record命令用来恢复缺省情况。
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
组播表项操作记录的最大数目为0,即不记录组播表项的操作信息。
Probe视图
fail:表示组播表项的失败操作记录。
limit-value:表示操作记录的最大数目,取值范围为0~500000。
1.6  P
1.6.1  probe
probe命令用来从系统视图进入Probe视图。
probe
在Probe视图下,用户可以通过命令查看系统的状态和信息,以便对系统故障进行诊断。
1.7  R
1.7.1  reset hardware internal mpls evi-operation
reset hardware internal mpls evi-operation命令用来清空EVI平台下发记录。
reset hardware internal mpls evi-operation slot slot-number
Probe视图
slot slot-number:单板所在的槽位号。
清空EVI所有的下发记录,包括隧道实例创建、扩展VLAN添加、激活VLAN添加、LINK创建、更新所有操作信息。
1.7.2  reset ipv6 route-static nib log
reset ipv6 route-static nib log命令用来清除IPv6静态路由NIB子模块日志。
Probe视图
1.7.3  reset system internal adj4 statistics
reset system internal adj4 statistics命令用来清除指定单板的IPv4邻接表项的统计信息。
独立运行模式:
reset system internal adj4 statistics slot slot-number
IRF模式:
reset system internal adj4 statistics chassis chassis-number slot slot-number
probe视图
slot slot-number:清除指定单板的IPv4邻接表项的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的IPv4邻接表项的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.7.4  reset system internal arp statistics
reset system internal arp statistics命令用来清除指定板上的ARP统计信息。
独立运行模式:
reset system internal arp statistics slot slot-number
IRF模式:
reset system internal arp statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清空指定单板的ARP统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清空指定成员设备上指定单板的ARP统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
reset system internal fib statistics
reset system internal fib statistics命令用来清除FIB统计信息。
独立运行模式:
reset system internal fib statistics slot slot-number
IRF模式:
reset system internal fib statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板的FIB统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的FIB统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.7.5  reset system internal ipv6 multicast forwarding-table dummy
reset system internal ipv6 multicast forwarding-table dummy命令用来清除IPv6组播临时转发表中的表项。
独立运行模式:
reset system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] } * | all } [ slot slot-number ]
IRF模式:
reset system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] } * | all } [ chassis chassis-number slot slot-number ]
Probe视图
vpn-instance vpn-instance-name:清除指定VPN实例的表项,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,将清除公网实例的表项。
ipv6-group-address:清除指定IPv6组播组的表项,取值范围为FFxy::/16,其中x和y均表示0~F的任意一个十六进制数。如果未指定本参数,将清除所有IPv6组播组的表项。
ipv6-source-address:清除指定IPv6组播源的表项。如果未指定本参数,将清除所有IPv6组播源的表项。
prefix-length:指定IPv6组播组或IPv6组播源地址的前缀长度。对于IPv6组播组地址,其取值范围为8~128,缺省值为128;对于IPv6组播源地址,其取值范围为0~128,缺省值为128。
all:清除所有表项。
slot slot-number:清除指定单板上的表项,slot-number表示单板所在的槽位号。如果未指定本参数,将清除主控板上的表项。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的表项,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果未指定本参数,将清除IRF中所有主控板上的表项。(IRF模式)
1.7.6  reset system internal mac-address statistics
reset system internal mac-address statistics命令用来清除MAC地址表的统计信息
独立运行模式:
reset system internal mac-address statistics slot slot-number
IRF模式:
reset system internal mac-address statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板的MAC地址表统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的MAC地址表统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.7.7  reset system internal mbuf relay statistics
reset system internal mbuf relay statistics命令用来清除MBUF中继模块的统计信息。
独立运行模式:
reset system internal mbuf relay statistics slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
IRF模式:
reset system internal mbuf relay statistics chassis chassis-number slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
Probe视图
slot slot-number:清除指定单板的MBUF中继模块的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的MBUF中继模块的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-id:MBUF中继使用的CPU编号。不指定该参数时,表示当前单板上的所有接CPU。
1.7.8  reset system internal mpls lfib record
reset system internal mpls lfib record命令用来清除MPLS LFIB模块记录的信息。
独立运行模式:
reset system internal mpls lfib record slot slot-number
IRF模式:
reset system internal mpls lfib record chassis chassis-number slot slot-number
Probe视图
slot slot-number:清除指定单板上的记录信息。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的记录信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
·     display system internal mpls lfib record
1.7.9  reset system internal multicast forwarding-table dummy
reset system internal multicast forwarding-table dummy命令用来清除组播临时转发表中的表项。
独立运行模式:
reset system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] } * | all } [ slot slot-number ]
IRF模式:
reset system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] } * | all } [ chassis chassis-number slot slot-number ]
Probe视图
source-address:清除指定组播源的表项。如果未指定本参数,将清除所有组播源的表项。
group-address:清除指定组播组的表项,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将清除所有组播组的表项。
mask-length:指定组播源或组播组地址的掩码长度。对于组播源地址,其取值范围为0~32,缺省值为32;对于组播组地址,其取值范围为4~32,缺省值为32。
mask:指定组播源或组播组地址的掩码,缺省值为255.255.255.255。
all:清除所有表项。
1.7.10  reset system internal multicast record
reset system internal multicast record命令用来清除组播表项的操作记录。
Probe视图
1.7.11  reset system internal nd statistics
reset system internal nd statistics命令用来清除各板上的ND统计信息。
独立运行模式:
reset system internal nd statistics slot slot-number
IRF模式:
reset system internal nd statistics chassis chassis-number slot slot-number
Probe视图
slot slot-number:清空指定单板的ND统计信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清空指定成员设备上指定单板的ND统计信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.7.12  reset system internal sflow statistics
reset system internal sflow statistics命令用来清除sFlow的统计信息。
独立运行模式:
reset system internal sflow statistics [ slot slot-number ]
IRF模式:
reset system internal sflow statistics [ chassis chassis-number slot slot-number ]
probe视图
slot slot-number:清除指定单板上的sFlow的统计信息。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:清除指定成员设备上指定单板的sFlow的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.8  S
1.8.1  set  hardware internal driver { phy-g | phy-xg } register
set  hardware internal driver { phy-g | phy-xg } register命令用来设置指定端口的PHY寄存器
set hardware internal driver phy-g register interface { interface-type interface-number | interface-name } { internal | external } address address data
set hardware internel driver phy-xg register interface { interface-type interface-number | interface-name } sublayer sub-number address address data
Probe视图
internal:查询内部PHY信息。
external:查询外部PHY信息。
interface-type interface-number:指定接口类型和编号。
interface-name:指定接口名称。
address:寄存器地址。
sub-number:PHY寄存器子层,取值0~1F (十六进制)。
data:数据。
使用该条命令可能会导致业务异常,请勿随意设置参数。
1.8.2  set hardware internal diag monitor-control
set hardware internal diag monitor-control命令用来在Probe视图可以输入,set命令表示打开或关闭某1块单板或所有单板的诊断定时检测项,undo命令表示恢复set命令之前的状态,各单板共有哪些定时检测项可以通过Probe视图下命令行display hardware internal diag content slot slotid [ oam ]来查看。
              [ undo ] set hardware internal diag monitor-control { on | off } [ slot slotid [ oam ] ]
Probe视图
undo:取消打开/关闭所有诊断定时检测项,恢复打开/关闭所有定时检测项之前的状态。
on:打开所有诊断定时检测项。
 off:关闭所有诊断定时检测项。
slot slotid [ oam ]:指定槽位号,cpu。
1.8.3  set hardware internal fa fport-rx-cell-cfg slot chip fport
set hardware internal fa fport-rx-cell-cfg slot chip fport命令用来配置端口统计的接收的Cell的类型。
set hardware internal fa fport-rx-cell-cfg slot slot-number chip chip-num fport port-num [ bc-cell ] [ diagnostic-cell ] [ mc-cell ] [ uc-cell ]
Probe视图
slot-number:目的接口板槽位,具体视机框而定
chip-num:PP芯片在单板上局部编号(0~3)
port-num:FA的端口号(0~5)
bc-cell:需要统计广播Cell
diagnostic -cell:需要统计诊断Cell
mc-cell:需要统计多播Cell
uc-cell:需要统计单播Cell
默认情况统计方式是根据寄存器的默认设置,后续所有设置统计方式命令的都是同理。不带任何Cell的情况下,统计所有类型。
1.8.4  set hardware internal fa fport-tx-cell-cfg slot chip fport
set hardware internal fa fport-tx-cell-cfg slot chip fport命令用来配置端口统计的发送的Cell的类型。不带任何Cell的情况下,统计所有类型。
set hardware internal fa fport-tx-cell-cfg slot slot-number chip chip-num fport port-num [bc-cell ] [ diagnostic-cell ] [ mc-cell ] [ uc-cell ]
Probe视图
bc-cell:需要统计广播Cell
mc-cell:需要统计多播Cell
uc-cell:需要统计单播Cell
1.8.5  set hardware internal fa voq statistic-cfg slot chip unit set
set hardware internal fa voq statistic-cfg slot chip unit set命令用来设置VOQ计数统计的方式。不带任何参数的情况下,则统计所有的描述符。
display hardware internal fa voq statistic-cfg slot chip命令用来显示VOQ计数的统计方式。
set hardware internal fa voq statistic-cfg slot slot-number chip chip-num unit unit-num set set-num [ descriptor ] [ { descriptor-dp | fabric-dp } DP-num ] [ { descriptor-tc | fabric-tc } TC-num ] [ tgt-fport fport-num ] [ tgt-device dev-num ]
display hardware internal fa voq statistic-cfg slot slot-number chip chip-num
Probe视图
unit-num:VOQ Unit(0~1)
set-num:计数器号(0~3),具有4套独立的计数器
descriptor-dp:Ingress分配的DP,(0~2)
fabric-dp:FA映射过的DP,(0~2)
DP-num:DP,(0~2)
Descriptor-tc:Ingress分配的TC,(0~7)
fabric-tc:FA映射过的TC,(0~3)
TC-num:根据前面的设置,Descriptor时,为(0~7);Fabric时,为(0~3);
tgt-fport:统计指定的Cell的目的端口号(FA的端口),此处的Fport是指源设备中的Fport
fport-num:FA的端口号,(0~5)
tgt-device:统计指定的目的设备
dev-num:目的设备号(0~63)
1.8.6  set hardware internal fan low-speed-thresh speed
set hardware internal fan low-speed-thresh命令用来设置风扇转速告警门限。
独立运行模式:
set hardware internal fan [ fan-tray-id ] low-speed-thresh speed
undo set hardware internal fan [ fan-tray-id ] low-speed-thresh
IRF模式:
set hardware internal fan chassis chaiss-number [ fan-tray-id ]  low-speed-thresh speed
undo set hardware internal fan chassis chaiss-number [ fan-tray-id ] low-speed-thresh
Probe视图
fantray-id:表示风扇框id,从上到下id顺序为1-2
speed:转速最低门限。S12518转速取值范围为1450~6000 rpm,S12508转速取值范围为750~3200 rpm, S12504转速取值范围为750~6000 rpm
undo set hardware internal fan low-speed-thresh命令用来恢复缺省情况。
缺省情况下,S12518缺省转速最低门限为1450rpm,S12508缺省转速最低门限为750rpm,S12504缺省转速最低门限为750rpm。
1.8.7  set hardware internal fcoe op route
set hardware internal fcoe op route命令用来设置FC路由的内部信息记录的条数。
独立运行模式:
set hardware internal fcoe op route record-num slot slot-number
IRF模式:
set hardware internal fcoe op route record-num chassis chassis-number slot slot-number
Probe视图
route record-num:待设置指定FC路由的内部信息记录条数。
slot slot-number:设置指定单板上FC路由的内部信息记录条数。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:设置指定成员设备上指定单板FC路由的内部信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
1.8.8  set hardware internal ibc lanswitch egresscntr | ingresscntr bind
set hardware internal ibc lanswitch egresscntr | ingresscntr bind命令用来将指定槽号指定LSW芯片上指定端口或Vlan的计数信息绑定到某个Bridge Couter 组。
set hardware internal ibc lanswitch slot  slot-number lsw lsw-number { egresscntr | ingresscntr } set set-number bind { vlan vlanID | port phyport-number }
Probe视图
ingresscntr:绑定入方向Bridge Couter。
egresscntr:绑定出方向Bridge Counter。
slot-number:槽位号。
lsw-number:LSW芯片号。范围0~1。
VlanID:Vlan 编号,范围0~4095。
phyport-number:物理端口号,范围0~23。
set-number:Bridge Counter 组编号,范围0~1。
1.8.9  set hardware internal ipuc cnt
set  hardware internal ipuc cnt命令用来绑定特定Nexthop Id转发计数。路由所有Next-hop默认绑定计数器0。
独立运行模式:
set hardware internal ipuc cnt index nh nexthop-id slot slot-number
IRF模式:
set hardware internal ipuc cnt index nh nexthop-id chassis chassis-number slot slot-number
Probe视图
slot slot-number:显示指定单板上的信息,slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板上的信息,chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
 cnt index  :指定引擎计数器,计数器编号<0-3>。
nh nexthop-id:绑定特定Nexthop。
1.8.10  set hardware internal ipuc dropcnt
set hardware internal ipuc dropcnt命令用来绑定特定丢弃计数器计数模式。默认丢弃计数器工作在0模式,即记录路由引擎所有丢弃报文计数。
独立运行模式:
set hardware internal ipuc dropcnt { 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 }  slot slot-number
IRF模式:
set hardware internal ipuc dropcnt { 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 } chassis chassis-number slot slot-number
Probe视图
 dropcnt mode:设置丢弃计数器的计数类型。
1.8.11  set hardware internal ipuc op
set hardware internal ipuc op命令用来设置IPv4或IPv6路由转发表操作记录的条数,默认200条。
独立运行模式:
set hardware internal ipuc op { ipv4 | ipv6 } number slot slot-number
IRF模式:
set hardware internal ipuc op { ipv4 | ipv6 } number chassis chassis-number slot slot-number
Probe视图
 op { ipv4 | ipv6 }:设置IPv4或IPv6路由转发表的操作记录。
nubmer:操作记录的个数<0-20000>,默认200条。设置为0,不做操作记录。
此命令也可用于单播操作记录的清除,因为设置了此命令单播操作记录会重新申请内存。
配置命令对指定板板生效,但不处理BuildRun和板插拔。单板重新启动,恢复默认值。
使用此命令根据操作记录个数的增加会增加内存的使用量。
1.8.12  set hardware internal l3mc counter
set hardware internal l3mc counter命令用来将某个计数器绑定到指定的Nexthop,该绑定操作将在目的接口板的所有PP上执行。
独立运行模式:
set hardware internal l3mc counter cnt-id nexthop nexthop-id slot slot-number
undo set hardware internal l3mc counter cnt-id slot slot-number
IRF模式:
set hardware internal l3mc counter cnt-id nexthop nexthop-id chassis chassis-number slot slot-number
undo set hardware internal l3mc counter cnt-id chassis chassis-number slot slot-number
Probe视图
slot slot-number:指定接口板上,slot-number表示接口板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备指定接口板,chassis-number表示设备在IRF中的成员编号,slot-number表示接口板所在的槽位号。(IRF模式)
counter cnt-id:计数器ID,取值范围为2~3。表示与指定的Nexthop对应的表项进行绑定。
nexthop nexthop-id :绑定的NexthopId,该NexthopId必须是三层组播使用的NexthopId。
仅限于绑定组播所使用的Nexthop;
当解绑定时,将组播Nexthop绑定到计数0;
当执行undo set命令的时候,此命令操作的必须是已经绑定的计数器。
1.8.13  set hardware internal l3mc ditcnt
set hardware internal l3mc ditcnt命令用来将某个计数器绑定到指定接口板的接口上。
独立运行模式:
set hardware internal l3mc ditcnt cnt-id [ vlan vlan-id ] [ trunk trunk-id ] slot slot-number
undo set hardware internal l3mc ditcnt cnt-id slot slot-number
IRF模式:
set hardware internal l3mc ditcnt cnt-id [ vlan vlan-id ] [ trunk trunk-id ] chassis chassis-number slot slot-number
undo set hardware internal l3mc ditcnt cnt-id  chassis chassis-number slot slot-number
Probe视图
ditcnt cnt-id:计数器ID,取值范围为0~1。
vlan vlan-id:接口所属的VLAN,取值范围为1~4094。
trunk trunk-id:接口为聚合接口。trunk-id表示芯片中的聚合组ID,取值范围为1~255。
slot slot-number:指定接口板,slot-number表示接口板所在的槽位号。(独立运行模式)
1.8.14  set hardware internal mpls  dit_load_balance
set hardware internal mpls dit_load_balance命令用来设置dit均衡定时器。
set hardware internal mpls dit_load_balance slot slot-number  time time-space
Probe视图
time time-spacer:定时器时间间隔。
1.8.15  set hardware internal mpls  nhlfecntbind
set hardware internal mpls nhlfcntbind命令用来根据入标签绑定NHLFE计数。
set hardware internal mpls nhlfecntbind slot slot-number chip chip-number inlabel label-value count-id
Probe视图
chip chip-number:芯片号
label label-value:入标签
count-id:指定的计数器
1.8.16  set hardware internal mpls  nhlfecntunbind
set hardware internal mpls nhlfcntunbind命令用来根据入标签解绑定NHLFE计数。
set hardware internal mpls nhlfecntunbind slot slot-number chip chip-number inlabel label-value count-id
Probe视图
count-id:指定的计数器
1.8.17  set hardware internal mpls  tticntbind
set hardware internal mpls tticntbind命令用来绑定TTI计数。
set hardware internal mpls tticntbind mpls slot slot-number tti-index
set hardware internal mpls tticntbind ipv4 slot slot-number tti-index
set hardware internal mpls tticntbind Ethernet { Bridge-Aggregation | GigabitEthernet | InLoopBack  | LoopBack | M-Ethernet | NULL | Register-Tunnel |  EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
set hardware internal mpls tticntbind minm { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
Probe视图
mpls:MPLS类型TTI
Ethernet:以太类型TTI
ipv4:IPV4类型TTI
minm  :MINM类型TTI
tti-index :TTI索引
1.8.18  set hardware internal mpls  tticntunbind
set hardware internal mpls tticntunbind命令用来解绑定TTI计数。
set hardware internal mpls tticntunbind mpls slot slot-number tti-index
set hardware internal mpls tticntunbind ipv4 slot slot-number tti-index
set hardware internal mpls tticntunbind ethernet { Bridge-Aggregation | GigabitEthernet | InLoopBack  | LoopBack | M-Ethernet | NULL | Register-Tunnel |  EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
set hardware internal mpls tticntunbind minm { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
Probe视图
mpls:MPLS类型TTI
Ethernet:以太类型TTI
ipv4:IPV4类型TTI
minm  :MINM类型TTI
tti-index :TTI索引
1.9  T
1.9.1  test diag-offline
独立运行模式:
test diag-offline slot slot-number
IRF模式:
test diag-offline chassis chassis-number slot slot-number
Probe视图
slot slot-number:单板的槽位号。
chassis chassis-number slot slot-number:对指定成员设备上指定单板进行诊断操作。chassis-number表示设备在IRF中的成员编号,slot-number表示单板的槽位号,可使用display device命令查看。
test diag-offline命令用来对被隔离的单板进行诊断操作。
执行test diag-offline命令后,系统将自动对指定单板执行一系列自检、故障诊断操作,并记录诊断结果。诊断结果除直接显示之外,还将以日志信息的形式保存在设备flash的根目录下,文件名以“diag_框号槽位号_年月日_时分秒”规则命名。
相关配置可参考命令board-offline。
·     执行test diag-offline命令后,终端上显示的诊断信息末尾处会提示用户诊断结果的保存路径,例如:/mnt/flash:/ diag_c3slot7_20130426_103159.txt。
·     诊断结果请交由专业工程师分析。
1.10  V
1.10.1  view
view命令用来查看系统目录(/proc/、/sys/、/var/)下的文件的内容。
独立运行模式:
view file-path [ slot slot-number ]
IRF模式:
view file-path [ chassis chassis-number slot slot-number ]
Probe视图
file-path:要查看文件的路径,区分大小写。
slot slot-number:查看指定单板系统目录(/proc/、/sys/、/var/)下的文件的内容。slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:查看指定设备上单板系统目录(/proc/、/sys/、/var/)下的文件的内容。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示主用主控板。(IRF模式)
执行该命令显示的文件路径中不能包含文件链接。文件链接类似于文件的快捷方式,文件链接指向另一个文件或目录。通过文件链接可以访问到其所指向的文件或目录。
2 Probe不支持命令列表
本章中列出的命令,在设备上可见但配置时不生效,请您不要使用这些命令。
2.1  快速转发Probe配置命令
2.1.1  display system internal ip fast-forwarding cache verbose
命令用来显示IPv4快转表项的详细内容。
独立运行模式:
display system internal ip fast-forwarding cache [ ip-address ] [ slot slot-number ] verbose
IRF模式:
display system internal ip fast-forwarding cache [ ip-address ] [ chassis chassis-number slot slot-number ] verbose
probe视图
2.1.2  display system internal ip fast-forwarding service-sequece
display system internal ip fast-forwarding service-sequece命令用来显示业务模块向快转模块的注册信息。
probe视图
2.2  IPv6快速转发Probe配置命令
2.2.1  display system internal ipv6 fast-forwarding cache verbose
display system internal ipv6 fast-forwarding cache [ ipv6-address ] verbose命令用来显示分布式各板IPv6快转表项的详细内容。
独立运行模式:
display system internal ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ] verbose
IRF模式:
display system internal ipv6 fast-forwarding cache [ ipv6-address ] [ chassis chassis-number slot slot-number ] verbose
probe视图
2.2.2  display system internal ipv6 fast-forwarding service-information
display system internal ipv6 fast-forwarding service-information 命令用来显示业务模块向快转模块的IPv6注册信息。
probe视图
2.2.3  display system internal ipv6 fast-forwarding statistics
display system internal ipv6 fast-forwarding statistics 命令用来显示 IPv6 快转的报文统计信息。
独立运行模式:
display system internal ipv6 fast-forwarding statistics [ slot slot-number ]
IRF模式:
display system internal ipv6 fast-forwarding statistics [ chassis chassis-number slot slot-number ]
probe视图
2.2.4  reset system internal ipv6 fast-forwarding statistics
reset system internal ipv6 fast-forwarding statistics 命令用来清除IPv6快转的报文统计信息。
独立运行模式:
reset system internal ipv6 fast-forwarding statistics [ slot slot-number ]
IRF模式:
reset system internal ipv6 fast-forwarding statistics [ chassis chassis-number slot slot-number ]
probe视图
2.3  IPv6邻接表Probe配置命令
2.3.1  display system internal ipv6 adjacent-table
display system internal ipv6 adjacent-table命令用来显示IPv6邻接表的信息。
独立运行模式:
display system internal ipv6 adjacent-table slot slot-number [ count | verbose ]
IRF模式:
display system internal ipv6 adjacent-table chassis chassis-number slot slot-number [ count | verbose ]
probe视图
2.3.2  display system internal adj6 statistics
display system internal adj6 statistics 命令用来显示IPv6邻接表项的统计信息。
独立运行模式:
display system internal adj6 statistics slot slot-number
IRF模式:
display system internal adj6 statistics chassis chassis-number slot slot-number
probe视图
2.3.3  reset system internal adj6 statistics
reset system internal adj6 statistics命令用来清除IPv6邻接表项的统计信息
独立运行模式:
reset system internal adj6 statistics slot slot-number
IRF模式:
reset system internal adj6 statistics chassis chassis-number slot slot-number
probe视图
2.3.4  display system internal adj6 entry
display system internal adj6 entry 命令用来显示指定IPv6邻接表项的详细信息。
独立运行模式:
display system internal adj6 entry ipv6-address interface interface-type interface-number slot slot-number
IRF模式:
display system internal adj6 entry ipv6-address interface interface-type interface-number chassis chassis-number slot slot-number
probe视图
2.3.5  debugging system internal adj6
debugging system internal adj6 { hardware | bind | notify | entry }
undo debugging system internal adj6 { hardware | bind | notify | entry }
probe视图
