05-三层技术-IP路由命令参考
02-静态路由命令
本章节下载: 02-静态路由命令  (146.92 KB)
02-静态路由命令
1 静态路由配置命令
本文所指的路由器代表运行了路由协议的三层设备。
1.1  静态路由配置命令
1.1.1  delete static-routes all
delete [ vpn-instance vpn-instance-name ] static-routes all
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:删除指定VPN的所有静态路由。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示删除公网的所有静态路由。
【描述】
delete static-routes all命令用来删除所有静态路由。
使用本命令删除静态路由时,系统会提示确认,确认后才会删除所配置的所有静态路由。
相关配置可参考命令ip route-static,“三层技术-IP路由命令参考/IP路由基础”中的display ip routing-table。
# 删除所有静态路由。
[Sysname] delete static-routes all
This will erase all ipv4 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]:Y
1.1.2  ip route-static
ip route-static dest-address { mask | mask-length } { next-hop-address [ bfd control-packet [ bfd-source ip-address ] | track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ bfd { control-packet [ bfd-source ip-address ] | echo-packet } ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address | track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ permanent ] [ description description-text ]
undo ip route-static dest-address { mask | mask-length } [ next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } { next-hop-address [ public ] [ bfd control-packet [ bfd-source ip-address ] | track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ bfd { control-packet [ bfd-source ip-address ] | echo-packet } ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ip-address |  track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ permanent ] [ description description-text ]
undo ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } [ next-hop-address [ public ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
【缺省级别】
2:系统级
vpn-instance s-vpn-instance-name&<1-6>:指定源VPN。s-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。&<1-6>表示前面的参数最多可以输入6次。每个VPN都有自己的路由表,配置的静态路由将被加入指定VPN的路由表。
dest-address:静态路由的目的IP地址,点分十进制格式。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
next-hop-address:指定路由的下一跳的IP地址,点分十进制格式。
interface-type interface-number:指定静态路由的出接口类型和编号。对于接口类型为非P2P接口(包括NBMA类型接口或广播类型接口,如以太网接口、VLAN接口等),必须指定下一跳地址。
vpn-instance d-vpn-instance-name:指定目的VPN。d-vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果指定目的VPN,静态路由将根据配置的next-hop-address在目的VPN中查找出接口。
next-hop-address public:此参数表示指定的next-hop-address是公网地址,不是源VPN实例地址。
preference preference-value:指定静态路由的优先级,取值范围为1~255,缺省值为60。
tag tag-value:静态路由Tag值,用于标识该条静态路由,以便在路由策略中根据Tag对路由进行灵活的控制。tag-value的取值范围为1~4294967295,缺省值为0。关于路由策略的详细信息,请参见“三层技术-IP路由命令参考/IP路由基础”中的“路由策略”。
permanent:指定为永久静态路由。即使在出接口down时,配置的永久静态路由仍然保持active状态。
description description-text:静态路由描述信息。description-text为1~60个字符的字符串,除“?”外,可以包含空格等特殊字符。
bfd:使能BFD(Bidirectional Forwarding Detection,双向转发检测)功能,对静态路由下一跳的可达性进行快速检测,当下一跳不可达时可以快速切换到备份路由。
control-packet:通过BFD控制报文方式实现BFD功能。
bfd-source ip-address:BFD源IP地址。建议配置为Loopback接口IP地址。
echo-packet:通过BFD echo报文方式实现BFD功能。
track track-entry-number:将静态路由与Track项相关联,track-entry-number为Track项的序号,取值范围为1~1024。
【描述】
ip route-static命令用来配置单播静态路由。undo ip route-static命令用来删除单播静态路由配置。
配置单播静态路由时应注意以下几点:
(1)     如果目的IP地址和掩码都为0.0.0.0(或掩码为0),则配置的路由为缺省路由。当检查路由表失败的时候,将使用缺省路由进行报文转发。
(2)     对不同的优先级配置,可采用不同的路由管理策略。例如,为同一目的地配置多条路由,如果指定相同的优先级,则实现路由负载分担;如果指定不同的优先级,则实现路由备份。
(3)     配置静态路由时,可根据实际需要指定出接口或下一跳地址,下一跳地址不能为本地接口IP地址,否则路由不会生效。对于支持从网络地址到链路层地址的解析的接口或点到点的接口,可指定出接口或下一跳地址。指定出接口时需要注意:
·     对于Null0接口,配置了出接口就不再配置下一跳地址。
·     在配置静态路由时,如果指定广播接口(如以太网接口、VLAN接口等)为出接口,则必须同时指定其对应的下一跳地址。
·     通过控制报文方式实现BFD功能时,对端必须创建BFD会话,否则BFD功能将无法正常运行;通过Echo报文方式实现BFD功能时,对端不需要创建BFD会话,BFD功能也可以正常运行。
·     BFD控制报文方式支持直连下一跳和非直连下一跳。当配置出接口和下一跳时,BFD建立直连会话;当配置非直连下一跳和指定BFD源IP地址时,BFD建立非直连会话。
相关配置可参考命令ip route-static default-preference,“三层技术-IP路由命令参考/IP路由基础”中的display ip routing-table。
·     在配置静态路由时,如果先指定下一跳地址,然后将该地址配置为本地接口(如以太网接口、VLAN接口等)的IP地址,静态路由不会生效。
·     路由振荡时,使能BFD检测功能可能会加剧振荡,需谨慎使用。关于BFD的详细介绍,请参考“可靠性配置指导”中的“BFD”。
·     如果Track模块通过NQA探测私网静态路由中下一跳的可达性,静态路由下一跳的VPN实例号与NQA测试组配置的实例号必须相同,才能进行正常的探测。
·     需要注意在静态路由进行迭代时,Track项监测的应该是静态路由真正的下一跳,而不是配置的下一跳。否则,可能导致错误地将有效路由判断为无效路由。
·     参数permanent不能和bfd、track一起进行配置。
# 配置静态路由,其目的地址为1.1.1.1/24,指定下一跳为2.2.2.2,Tag值为45,描述信息为“for internet & intranet”。
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet & intranet
# 为名为vpn1的VPN实例配置一条静态路由,其目的地址为1.1.1.1/16,下一跳地址为此VPN实例的地址1.1.1.2。
[Sysname] ip route-static vpn-instance vpn1 1.1.1.1 16 vpn-instance vpn1 1.1.1.2
# 配置静态路由,其目的地址为1.1.1.1/24,出接口为Vlan-interface11,指定下一跳为2.2.2.2,并使能BFD功能,通过BFD echo报文方式实现BFD功能。
[Sysname] ip route-static 1.1.1.1 24 Vlan-interface 11 2.2.2.2 bfd echo-packet
1.1.3  ip route-static default-preference
ip route-static default-preference default-preference-value
undo ip route-static default-preference
【缺省级别】
2:系统级
default-preference-value:静态路由缺省优先级的值,取值范围为1~255。
【描述】
ip route-static default-preference命令用来配置静态路由的缺省优先级。undo ip route-static default-preference命令用来恢复该缺省优先级为缺省值。
缺省情况下,静态路由的缺省优先级为60。
·     如果在配置静态路由时没有指定优先级,就会使用缺省优先级。
·     重新设置缺省优先级后,新设置的缺省优先级仅对新增的静态路由有效。
# 配置静态路由的缺省优先级为120。
[Sysname] ip route-static default-preference 120
1.1.4  ip route-static fast-reroute
ip route-static [ vpn-instance vpn-instance-name ] fast-reroute route-policy route-policy-name
undo ip route-static [ vpn-instance vpn-instance-name ] fast-reroute
【缺省级别】
2:系统级
vpn-instance vpn-instance-name:为指定VPN的所有静态路由配置快速重路由功能。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示为公网的所有静态路由配置快速重路由功能。
route-policy route-policy-name:为通过策略的静态路由指定备份下一跳信息。route-policy-name为路由策略名,为1~63个字符的字符串,区分大小写。
【描述】
ip route-static fast-reroute命令用来配置静态路由支持快速重路由功能。undo ip route-static fast-reroute命令用来恢复缺省情况。
缺省情况下,没有配置静态路由支持快速重路由功能。
如果不指定vpn-instance参数,则只配置公网所有匹配策略的静态路由支持快速重路由功能。
·     要为静态路由配置快速重路由功能,除了使能静态路由快速重路由功能,还需要配置路由策略,通过apply fast-reroute backup-interface命令在路由策略中指定备份下一跳;关于apply fast-reroute backup-interface命令以及路由策略的相关配置,请参考“三层技术-IP路由配置指导”中的“路由策略”。
·     只有在配置静态路由时指定出接口和下一跳地址,静态路由快速重路由功能才能生效。
·     静态路由快速重路由功能不能与静态路由BFD功能同时使用。
# 配置对通过策略frr的静态路由指定备份下一跳信息。
[Sysname] ip ip-prefix abc index 10 permit 100.1.1.0 24
[Sysname] route-policy frr permit node 10
[Sysname-route-policy] if-match ip-prefix abc
[Sysname-route-policy]    apply fast-reroute backup-interface vlan-interface 1 backup-nexthop 193.1.1.8
[Sysname-route-policy] quit
[Sysname] ip route-static fast-reroute route-policy frr
