03-MPLS TE命令
本章节下载: 03-MPLS TE命令 (457.04 KB)
1.1.4 display isis traffic-eng advertisements
1.1.5 display isis traffic-eng link
1.1.6 display isis traffic-eng network
1.1.7 display isis traffic-eng statistics
1.1.10 display mpls rsvp-te established
1.1.11 display mpls rsvp-te peer
1.1.12 display mpls rsvp-te psb-content
1.1.13 display mpls rsvp-te request
1.1.14 display mpls rsvp-te reservation
1.1.15 display mpls rsvp-te rsb-content
1.1.16 display mpls rsvp-te sender
1.1.17 display mpls rsvp-te statistics
1.1.18 display mpls static-cr-lsp
1.1.19 display mpls te cspf tedb
1.1.20 display mpls te link-administration admission-control
1.1.22 display mpls te tunnel path
1.1.23 display mpls te tunnel statistics
1.1.24 display mpls te tunnel-interface
1.1.26 display ospf traffic-adjustment
1.1.28 enable traffic-adjustment
1.1.29 enable traffic-adjustment advertise
1.1.34 mpls rsvp-te authentication
1.1.35 mpls rsvp-te bfd enable
1.1.36 mpls rsvp-te blockade-multiplier
1.1.37 mpls rsvp-te graceful-restart
1.1.39 mpls rsvp-te hello-lost
1.1.40 mpls rsvp-te keep-multiplier
1.1.41 mpls rsvp-te reliability
1.1.42 mpls rsvp-te resvconfirm
1.1.44 mpls rsvp-te timer graceful-restart recovery
1.1.45 mpls rsvp-te timer graceful-restart restart
1.1.46 mpls rsvp-te timer hello
1.1.47 mpls rsvp-te timer refresh
1.1.48 mpls rsvp-te timer retransmission
1.1.50 mpls te affinity property
1.1.52 mpls te backup bandwidth
1.1.56 mpls te cspf timer failed-link
1.1.57 mpls te failure-action teardown
1.1.59 mpls te fast-reroute bypass-tunnel
1.1.63 mpls te link administrative group
1.1.67 mpls te path metric-type
1.1.68 mpls te periodic-tracert
1.1.71 mpls te reoptimization (Tunnel Interface view)
1.1.72 mpls te reoptimization (User view)
1.1.76 mpls te signal-protocol
1.1.77 mpls te timer fast-reroute
1.1.85 reset mpls rsvp-te statistics
l 有关VPN的详细介绍请参见“MPLS L2VPN配置”和“MPLS L3VPN配置”;
l 本章中支持的接口类型为隧道接口(Tunnel)、VLAN接口(Vlan-interface)和三层以太网接口。三层以太网接口是指工作模式被配置成三层模式的以太网端口,有关以太网端口工作模式切换的操作,请参见“二层技术-以太网交换配置指导”中的“以太网端口配置”部分。
add hop ip-address1 [ include [ loose | strict ] | exclude ] { after | before } ip-address2
显式路径视图
【缺省级别】
2:系统级
ip-address1:要插入的节点的IP地址或Router ID,点分十进制形式。
include:在显式路径中包含插入的IP地址。
loose:松散下一跳,即,下一跳与本节点可以不是直接相连。
strict:严格下一跳,即,下一跳与本节点必须直接相连。
exclude:在显式路径的指定IP地址前或后插入新的IP地址,并且在计算路径时不包括此地址。
after:在指定节点之后插入新的IP地址。
before:在指定节点之前插入新的IP地址。
ip-address2:插入点前或后的IP地址,点分十进制形式。
【描述】
add hop命令用来向显式路径中插入一个节点。
缺省情况下,显式路径包含指定的节点(include),加入的节点是严格下一跳。
# 在3.3.10.5后面插入3.3.29.3,不包括此IP地址。
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] add hop 3.3.29.3 exclude after 3.3.10.5
delete hop ip-address
显式路径视图
【缺省级别】
2:系统级
ip-address:显式路径的指定节点的IP地址。
【描述】
delete hop命令用来在显式路径中删除指定的一个节点。
# 在MPLS TE显式路径中删除下一跳IP地址10.0.0.1。
[Sysname-explicit-path-path1] delete hop 10.0.0.1
display explicit-path [ pathname ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
pathname:指定路径名,为1~31个字符的字符串。
|:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。
begin:从包含指定正则表达式的行开始显示。
exclude:只显示不包含指定正则表达式的行。
include:只显示包含指定正则表达式的行。
【描述】
display explicit-path命令用来显示显式路径信息。
如果不指定路径名,将显示所有显式路径信息。
# 显示所有显式路径信息。
<Sysname> display explicit-path
Path Name : ErHop-Path1 Path Status : Enabled
1 1.1.1.10 Strict Include
2 2.1.1.10 Strict Include
3 1.1.1.20 Strict Include
4 2.1.1.20 Strict Include
5 2.1.1.30 Strict Include
6 1.1.1.30 Strict Include
7 9.4.4.4 Strict Include
Path Name : ErHop-Path2 Path Status : Enabled
3 1.1.1.40 Strict Include
4 2.1.1.40 Strict Include
5 1.1.1.50 Strict Include
6 2.1.1.40 Strict Include
7 2.1.1.30 Strict Include
8 1.1.1.30 Strict Include
9 9.4.4.4 Strict Include
表1-1 display explicit-path命令显示信息描述表
Path Name |
显式路径名称 |
Path Status |
显式路径状态 |
display isis traffic-eng advertisements [ [ level-1 | level-1-2 | level-2 ] | [ lsp-id lsp-id | local ] ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
level-1:Level-1路由器的TE信息。
level-1-2:Level-1-2路由器的TE信息。
level-2:Level-2路由器的TE信息。
lsp-id lsp-id:显示指定LSP(Link State PDU,链路状态报文) ID发布的TE信息。有关IS-IS的LSP的详细介绍请参见“三层技术-IP路由配置指导”中的“IS-IS配置”。
local:显示本地发布的TE信息。
process-id:指定IS-IS进程号,取值范围为1~65535。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示指定VPN实例的名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的信息。
【描述】
display isis traffic-eng advertisements命令用来显示IS-IS TE最近一次发布的TE信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE信息。
# 显示IS-IS TE最近一次发布的TE信息。
<Sysname> display isis traffic-eng advertisements
TE information for ISIS(1)
Level-1 Link State Database
LSPID LSP Seq Num LSP Checksum LSP Holdtime ATT/P/OL
0000.0000.0001.00-00* 0x00000001 0x3f57 534 0/0/0
NLPID : IPV4
AREA ADDR : 00.0005
INTF ADDR : 10.1.1.1
INTF ADDR : 1.1.1.9
INTF ADDR : 30.1.1.1
Level-2 Link State Database
0000.0000.0001.00-00* 0x0000001c 0xf1ec 687 0/0/0
NLPID : IPV4
AREA ADDR : 00.0005
INTF ADDR : 1.1.1.9
Router ID : 1.1.1.9
+NBR : 0000.0000.0002.02 COST: 10
Admin Group: 0x00000000
Interface IP Address: 10.1.1.1
+NBR : 0000.0000.0004.00 COST: 10
Interface IP Address: 30.1.1.1
Peer IP Address : 30.1.1.2
TE Cost : 10
表1-2 display isis traffic-eng advertisements命令显示信息描述表
LSPID |
LSP ID |
LSP Seq Num |
LSP序列号 |
LSP Checksum |
LSP校验和 |
LSP Holdtime |
LSP保持时长 |
ATT/P/OL |
Attach bit(ATT):连接位 Partition bit(P):分区位 Overload bit(OL):过载位 |
NLPID |
网络协议类型 |
AREA ADDR |
IS-IS域地址 |
INTF ADDR |
接口地址 |
Router ID |
路由ID |
+NBR |
邻居 |
COST |
开销 |
Admin Group |
链路管理组属性 |
Interface IP Address |
接口IP地址 |
TE Cost |
TE开销 |
Peer IP Address |
对端邻居的IP地址 |
display isis traffic-eng link [ [ level-1 | level-1-2 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
verbose:显示详细信息。
vpn-instance vpn-instance-name:显示指定VPN的信息。vpn-instance-name表示VPN实例名称,为1~31个字符的字符串,区分大小写。如果不指定本参数,则显示公网的信息。
【描述】
display isis traffic-eng link命令用来显示IS-IS TE的链路信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的链路信息。
# 显示IS-IS TE的链路信息。
<Sysname> display isis traffic-eng link
Level-2 Link Information
0000.0000.0001.00-->0000.0000.0001.01 Type: MULACC LinkID: 10.1.1.1
0000.0000.0002.00-->0000.0000.0003.00 Type: P2P LinkID: 3.3.3.9
0000.0000.0002.00-->0000.0000.0001.01 Type: MULACC LinkID: 10.1.1.1
0000.0000.0003.00-->0000.0000.0002.00 Type: P2P LinkID: 2.2.2.9
0000.0000.0003.00-->0000.0000.0004.01 Type: MULACC LinkID: 30.1.1.2
0000.0000.0004.00-->0000.0000.0004.01 Type: MULACC LinkID: 30.1.1.2
Total Number of TE Links in Level-2 Area: 6, Num Active: 6
表1-3 display isis traffic-eng link命令显示信息描述表
Type |
链路类型 |
LinkID |
链路ID |
Total Number of TE Links in Level-2 Area |
Level-2区域中的TE链路数 |
Num Active |
处于激活状态的数目 |
display isis traffic-eng network [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display isis traffic-eng network命令用来显示IS-IS TE的网络信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的网络信息。
# 显示IS-IS TE的网络信息。
<Sysname> display isis traffic-eng network
Level-1 Network Information
DIS Router ID : 89.1.1.1 DIS's Ip Address : 86.1.1.1
Status In CSPF : ACTIVE Attached Router Count : 2
List of Attached Routers
RouterId : 89.1.1.1 Nbr : 1111.1111.1111.00
Link State : 1
RouterId : 89.2.2.2 Nbr : 1111.1111.1113.00
Link State : 1
Total Number of TE Networks in Level-1 Area: 1, Num Active: 1
Level-2 Network Information
Link State : 1
Link State : 1
Total Number of TE Networks in Level-2 Area: 1, Num Active: 1
表1-4 display isis traffic-eng network命令显示信息描述表
Level-1 Network Information |
Level-1网络信息 |
DIS Router ID |
DR路由器ID |
DIS's Ip Address |
DR路由器IP地址 |
Status In CSPF |
CSPF状态 |
Attached Router Count |
相连路由器的数目 |
List of Attached Routers |
相连路由器列表 |
RouterId |
路由器ID |
Nbr |
邻居 |
Link State |
链路状态 |
Total Number of TE Networks in Level-1 Area |
处于Level-1的TE网络数目 |
Num Active |
处于激活状态的数目 |
Level-2 Network Information |
Level-2网络信息 |
Total Number of TE Networks in Level-2 Area |
处于Level-2的TE网络数目 |
display isis traffic-eng statistics [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display isis traffic-eng statistics命令用来显示IS-IS TE的统计信息。
如果不指定中间系统IS的级别,将显示Level-1-2的TE的统计信息。
# 显示IS-IS TE的统计信息。
<Sysname> display isis traffic-eng statistics
TE Statistics Information
IS-IS System Type : Level-1-2
IS-IS Cost Style Status : Wide
IS-IS Level-1 Traffic Engineering Status : Disabled
IS-IS Level-2 Traffic Engineering Status : Enabled
IS-IS Router ID : 1.1.1.9
表1-5 display isis traffic-eng statistics命令显示信息描述表
IS-IS System Type |
系统类型 |
IS-IS Cost Style Status |
路由器的开销类型 |
IS-IS Level-1 Traffic Engineering Status |
Level-1路由器的TE状态 |
IS-IS Level-2 Traffic Engineering Status |
Level-2路由器的TE状态 |
IS-IS Router ID |
IS-IS路由器的Router ID |
display mpls lsp bfd [ te tunnel tunnel-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel tunnel-number:显示指定MPLS TE隧道的BFD检测信息。tunnel-number为隧道接口的编号。
【描述】
display mpls lsp bfd te命令用来显示BFD对MPLS TE隧道的检测信息。
# 显示BFD对接口Tunnel0对应的MPLS TE隧道的检测信息。
<Sysname> display mpls lsp bfd te Tunnel 0
MPLS BFD Session(s) Information
FEC : Tunnel0 Type : TE Tunnel
Local Discr : 3 Remote Discr : 3
Tunnel ID : 0xd2009 NextHop : ----
Session State : Up Source IP : 1.1.1.1
Session Role : Active
Total Session Num: 1
表1-6 display mpls lsp bfd te命令显示信息描述表
FEC |
FEC信息 |
Type |
BFD检测的隧道类型,取值包括LSP和TE Tunnel |
Local Discr |
本地BFD会话的鉴别值 |
Remote Discr |
远端BFD会话的鉴别值 |
Tunnel ID |
隧道ID |
NextHop |
下一跳地址 |
Session State |
BFD会话状态,取值包括: l Init:BFD会话处于初始化状态 l Up:BFD会话处于up状态 l Down:BFD会话处于down状态 |
Source IP |
主动端(Ingress LSR)BFD会话的源IP地址 |
Session Role |
BFD会话角色,取值包括 l Active:BFD会话的主动端 l Passive:BFD会话的被动端 |
display mpls rsvp-te [ interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] ]
【缺省级别】
1:监控级
Interface:显示接口的RSVP-TE配置信息。
interface-type interface-number:显示指定接口的RSVP-TE配置信息。interface-type interface-number为接口类型及接口编号。
|:使用正则表达式对显示进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。
begin:显示特定行及其以后的所有行,该特定行必须包含指定正则表达式。
exclude:显示不包含指定正则表达式的所有行。
include:显示只包含指定正则表达式的所有行。
【描述】
display mpls rsvp-te命令用来显示RSVP-TE的配置信息。
l 如果不使用关键字interface,将显示全局的RSVP-TE配置信息。
l 如果不指定接口名,将显示所有使能了RSVP-TE的接口的RSVP-TE配置信息。
# 显示全局的RSVP-TE配置信息。
<Sysname> display mpls rsvp-te
LSR ID: 4.4.4.4
Resv Confirmation Request: DISABLE
RSVP Hello Extension: ENABLE
Hello interval: 3 sec Max Hello misses: 3
Path and Resv message refresh interval: 30 sec
Path and Resv message refresh retries count: 3
Blockade Multiplier: 4
Graceful Restart: ENABLE
Restart Time: 200 sec Recovery Time: 150 sec
表1-7 display mpls rsvp-te命令显示信息描述表
LSR ID |
标签交换路由器ID,格式为X.X.X.X |
Resv Confirmation Request |
预留确认特性 |
RSVP Hello Extension |
是否使能Hello特性 |
Hello Interval |
Hello定时器时长,单位为秒 |
Max Hello misses |
最多可遗漏的Hello报文 |
Path and Resv message refresh interval |
路径和预留刷新消息的刷新定时器时间,单位为秒 |
Path and Resv message refresh retries count |
路由和预留消息重发的次数 |
Blockade Multiplier |
PSB和RSB的超时倍数 |
Graceful Restart |
是否使能Graceful Restart功能 |
Restart Time |
GR的重启定时器间隔,单位为秒 |
Recovery Time |
GR的恢复定时器间隔,单位为秒 |
# 显示指定接口的RSVP-TE配置信息。
<Sysname> display mpls rsvp-te interface vlan-interface 3
Interface Vlan-interface3
Interface state: UP BFD feature: ENABLE
Total-BW: 80 Used-BW: 20
Hello configured: NO Num of Neighbors: 1
SRefresh feature: ENABLE SRefresh Interval: 30sec
Authentication: DISABLE Reliability configured: NO
Retransmit Interval: 500msec Increment Value: 1
表1-8 display mpls rsvp-te interface命令显示信息描述表
已使能RSVP-TE的接口名称 |
Interface state |
物理接口状态 |
BFD feature |
是否使能BFD |
Total-BW |
总带宽(单位:kbit/s) |
Used-BW |
所用带宽(单位:kbit/s) |
Hello configured |
是否配置了Hello特性 |
Num of Neighbors |
经该接口连接的邻居个数 |
Srefresh feature |
摘要刷新配置 |
Srefresh interval |
摘要刷新定时器时长(单位:秒) |
Authentication |
是否使能验证 |
Reliability |
是否存在可靠性特性 |
Retransmit interval |
重传定时器时长(单位:微秒) |
Increment value |
重传增量调整重传定时器的时间间隔。如果在重传初始时间间隔内(假设为Rf秒),没有收到应答消息ACK,则经过(1+重传增量)×Rf秒后,将重传此消息 |
display mpls rsvp-te established [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface interface-type interface-number:指定接口类型及接口号。如果不指定本参数,则显示所有接口的RSVP-TE隧道信息。
regular-expression:表示正则表达式,为1~80个字符的字符串,区分大小写。
【描述】
display mpls rsvp-te established命令用来显示RSVP-TE隧道信息。
# 显示指定接口的RSVP-TE隧道信息。
<Sysname> display mpls rsvp-te established interface vlan-interface 3
Token Bucket Rate: 0.00 Peak Data Rate: 0.00
Tunnel Dest: 2.2.2.2 Ingress LSR ID: 3.3.3.3
Local LSP ID: 4 Session Tunnel ID: 4
Next Hop Addr: 80.4.1.1
Upstream Label: 1024 Downstream Label: 3
表1-9 display mpls rsvp-te established命令的显示信息描述表
使能RSVP-TE的接口 |
Token Bucket rate |
流量参数,令牌桶速率 |
Peak Data Rate |
流量参数,峰值速率 |
Tunnel Dest |
隧道地址,格式为X.X.X.X |
Ingress LSR ID |
入口标签交换路由ID,格式为X.X.X.X |
Local LSP ID |
本地LSP ID |
Session Tunnel ID |
隧道ID |
Next Hop Addr |
下一跳地址,格式为X.X.X.X |
Upstream label |
上游标签 |
Downstream Label |
下游标签 |
display mpls rsvp-te peer [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te peer命令用来显示RSVP-TE邻居信息。
如果不指定接口,将显示所有接口的RSVP-TE邻居信息。
# 显示所有接口的RSVP-TE邻居信息。
<Sysname> display mpls rsvp-te peer
Neighbor Addr: 80.4.1.1
SrcInstance: 841 NbrSrcInstance: 928
PSB Count: 0 RSB Count: 1
Hello Type Sent: ACK Neighbor Hello Extension: ENABLE
SRefresh Enable: NO Reliability Enable: YES
Graceful Restart State: Ready
Interface Vlan-interface4
Neighbor Addr: 80.2.1.1
SrcInstance: 832 NbrSrcInstance: 920
PSB Count: 1 RSB Count: 0
Hello Type Sent: REQ Neighbor Hello Extension: ENABLE
Graceful Restart State: Not Ready
Restart Time: --- Recovery Time: ---
表1-10 display mpls rsvp-te peer 命令的显示信息描述表
使能RSVP-TE的接口 |
Neighbor Addr |
邻居地址,格式为 X.X.X.X. |
SrcInstance |
源Message ID的Instance |
NbrSrcInstance |
对端Message ID的Instance |
PSB Count |
路径状态块数量 |
RSB Count |
预留状态块数量 |
Hello Type Sent |
向对端发送Hello类型,取值为REQ/ACK/NONE |
Neighbor Hello Extension |
邻居是否使能Hello特性,只有接口使能了hello扩展时才会显示此项 |
SRefresh Enable |
是否使能摘要刷新,取值为YES/NO |
Reliability Enable |
对等体是否使能可靠性,取值为YES/NO |
Graceful Restart State |
邻居的GR状态,取值为Not Ready、Ready、Restart或Recovery,设备不支持时显示为--- |
Restart Time |
GR的重启定时器间隔,单位为秒 |
Recovery Time |
GR的恢复定时器间隔,单位为秒 |
display mpls rsvp-te psb-content ingress-lsr-id lspid tunnel-id egress-lsr-id [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
ingress-lsr-id:入口LSR ID。
lspid:本地LSP ID,取值范围为1~65535。
tunnel-id:隧道ID,取值范围为0~65535。
egress-lsr-id:出口LSR ID。
【描述】
display mpls rsvp-te psb-content命令用来显示RSVP-TE PSB(Path State Block)信息。
# 显示RSVP-TE PSB信息。
<Sysname> display mpls rsvp-te psb-content 19.19.19.19 1 0 29.29.29.29
The PSB Content:
Tunnel Dest: 29.29.29.29 Session Tunnel ID: 0
Tunnel ExtID: 19.19.19.19
Ingress LSR ID: 19.19.19.19 Local LSP ID: 1
Previous Hop : 101.101.101.1 Next Hop : -----
Incoming / Outgoing Interface: Vlan-interface3 / -----
InLabel : 3 OutLabel : NULL
Send Message ID : 1 Recv Message ID : 0
Session Attribute-
SetupPrio: 7 HoldPrio: 7
SessionFlag: SE Style desired
ERO Information-
L-Type ERO-IPAddr ERO-PrefixLen
ERHOP_STRICT 101.101.101.2 32
RRO Information-
RRO-CType: IPV4 RRO-IPAddress: 101.101.101.1 RRO-IPPrefixLen: 32
SenderTspec Information-
Token bucket rate: 0.00
Token bucket size: 0.00
Peak data rate: 0.00
Minimum policed unit: 0
Maximum packet size: 4294967295
Path Message arrive on Vlan-interface3 from PHOP 101.101.101.1
Resource Reservation OK
Graceful Restart State: Stale
表1-11 display mpls rsvp-te psb-content命令显示信息描述表
Tunnel Dest |
隧道目的地址,格式为 X.X.X.X |
Session Tunnel ID |
会话隧道ID |
Tunnel ExtID |
隧道的扩展ID,格式为X.X.X.X |
Ingress LSR ID |
入口标签交换路由器ID,格式为X.X.X.X |
Local LSP ID |
本地LSP ID |
Next Hop |
下一跳地址,格式为 X.X.X.X |
Previous Hop |
前一跳地址,格式为X.X.X.X |
In Label |
入标签 |
Out Label |
出标签 |
Send message ID |
发送的MessageID的instance |
Resv Message ID |
接收的MessageID的instance |
Setup Prio |
会话建立优先级 |
HoldPrio |
会话保持优先级 |
Session Flag |
会话类型(需要的本地保护、标签、SE风格) |
RRO Information |
记录路由信息 |
RRO-C Type |
记录路由的类型 |
RRO-IP Address |
记录路由的IP地址 (X.X.X.X) |
RRO-IPPrefixLen |
记录路由前缀的长度 |
ERO Information |
显式路由信息 |
L-Type |
显式路由类型(Strict / Loose) |
ERO-IPAddress |
显式路由地址 |
ERO-Prefix Len |
显式路由前缀值 |
Sender Tspec Information |
包括发送方业务规格信息 |
Token Bucket rate |
流量参数,令牌桶速率(单位:kbit/s) |
Token Bucket size |
流量参数,令牌桶大小 |
Peak Data Rate |
流量参数:峰值数据速率(单位:kbit/s) |
Maximum packet size |
流量参数,最大报文长度 |
Minimum policed unit |
流量参数,最小监管单元 |
Path message |
从接口发送到下一跳X.X.X.X的路径消息 |
Resource |
只有配置了资源预留标记时才会有此项显示 |
GR状态,取值为Stale或Normal,设备不支持时显示为--- |
display mpls rsvp-te request [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te request命令用来显示RSVP-TE请求消息信息。
如果不指定接口名,将显示所有接口的请求消息信息。
# 显示所有接口的请求消息信息。
<Sysname> display mpls rsvp-te request
Interface Vlan-interface3:
NextHopAddr: 80.4.1.1
SessionFlag: SE Style desired.
Token bucket rate: 0.00 Token bucket size: 1000.00
Out Interface: Vlan-interface4
表1-12 display mpls rsvp-te request 命令的显示信息描述表
使能了RSVP-TE的接口 |
Tunnel Dest |
隧道目的地址,格式为X.X.X.X |
Ingress LSR ID |
Local LSP ID |
本地LSP ID |
Session Tunnel ID |
会话隧道ID |
Next Hop Address |
下一跳地址,格式为 X.X.X.X |
SessionFlag |
风格 |
Token Bucket rate |
流量参数,令牌桶速率 |
Token Bucket Size |
流量参数,令牌桶大小 |
Out Interface |
消息出接口 |
display mpls rsvp-te reservation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te reservation命令用来显示RSVP-TE资源预留消息。
如果不指定接口名,将显示所有接口的资源预留信息。
# 显示指定接口的RSVP-TE预留消息。
<Sysname> display mpls rsvp-te reservation interface vlan-interface 3
Tunnel Dest: 29.29.29.29 Ingress LSR ID: 19.19.19.19
LSP ID: 1 Tunnel ID: 1
Upstream Label: -----
Token bucket rate: 0.00 Token bucket size: 0.00
# 显示所有接口的RSVP-TE预留消息。
Interface: Outgoing-Interface at the Egress
Tunnel Dest: 19.19.19.19 Ingress LSR ID: 29.29.29.29
Upstream Label: 3
表1-13 display mpls rsvp-te reservation命令的显示信息描述表
使能了RSVP-TE的接口 |
Tunnel Dest |
Ingress LSR ID |
LSP ID |
LSP ID |
Tunnel ID |
隧道ID |
Upstream Label |
上游标签 |
Token Bucket rate |
流量参数,令牌桶速率 |
Token Bucket Size |
流量参数,令牌桶大小 |
display mpls rsvp-te rsb-content ingress-lsr-id Ispid tunnel-id egress-lsr-id nexthop-address [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
nexthop-address:下一跳地址。
【描述】
display mpls rsvp-te rsb-content命令用来显示RSVP-TE RSB(Reserve State Block)信息。
# 显示RSVP-TE RSB信息。
<Sysname> display mpls rsvp-te rsb-content 19.19.19.19 1 0 29.29.29.29 101.101.101.2
The RSB Content:
Next Hop: 101.101.101.2 Resevation Style: SE Style
Reservation Incoming Interface: Vlan-interface3
Reservation Interface: Vlan-interface3
Message ID : 2
Filter Spec Information-
The filter number: 1
Ingress LSR ID: 19.19.19.19 Local LSP ID: 1 OutLabel: 3
RRO Information-
RRO-Flag is
RRO-CType: IPV4 RRO-IPAddress: 101.101.101.2 RRO-IPPrefixLen: 32
FlowSpec Information-
Token bucket rate: 2500.00
Maximum packet size: 0
Bandwidth guarantees: 0.00
Delay guarantees: 0
Qos Service is Controlled
Resv Message arrive on Vlan-interface3 from NHOP 101.101.101.2
表1-14 display mpls rsvp-te rsb content命令显示信息描述表
Tunnel Dest |
隧道地址,格式为 X.X.X.X |
Session Tunnel ID |
会话隧道ID |
Tunnel Ext ID |
隧道扩展(入口LSR ID),格式为 X.X.X.X |
Next Hop |
下一跳地址,格式为 X.X.X.X |
Reservation Style |
预留风格,取值为SE/FF |
Reservation Interface |
预留资源的接口名称 |
Reserve Incoming Interface |
预留消息入接口 |
Message ID |
减少刷新的消息的ID |
Filter Spec Information |
过滤规格信息 |
Filter Num |
过滤器总数 |
Ingress LSR ID |
LSP ID |
LSP ID |
Out Label |
出标签 |
RRO Information |
记录路由信息 |
RRO-C Type |
记录路由的类型 |
RRO-IP Address |
RRO-IPPrefixLen |
记录路由前缀的长度 |
Flow Spec information |
包括流规格业务信息 |
Token Bucket rate |
流量参数,令牌桶速率 (单位:kbit/s) |
Token Bucket size |
流量参数,令牌桶大小 |
Peak Data Rate |
流量参数,峰值数据速率(单位:kbit/s) |
流量参数,最大报文长度 |
流量参数,最少监管单位 |
Bandwidth guarantees |
预留规格参数,带宽保证 |
Delay guarantees |
预留规格参数,延迟保证 |
QOS service |
QoS保证/控制 |
Resv Message |
从下一跳地址(X.X.X.X)到Serial0的预留消息 |
display mpls rsvp-te sender [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls rsvp-te sender命令用来显示RSVP-TE发送方消息信息。
# 显示指定接口的RSVP-TE发送方消息信息。
<Sysname> display mpls rsvp-te sender interface vlan-interface 3
Interface Vlan-interface3;
LSP ID: 1 Session Tunnel ID: 1
Session Name: Tunnel0
Previous Hop Address: 101.101.101.1
Token bucket rate: 0.0 Token bucket size: 0.00
# 显示所有接口的RSVP-TE发送方消息信息。
LSP ID: 1 Session Tunnel ID: 0
Previous Hop Address: 101.101.101.2
Interface: Incoming-Interface at the Ingress
Session Name: Tunnel1
Previous Hop Address: 19.19.19.19
表1-15 display mpls rsvp-te sender命令的显示信息描述表
使能RSVP-TE的接口 |
Tunnel Dest |
隧道地址,格式为X.X.X.X |
Ingress LSR ID |
LSP ID |
LSP ID |
Tunnel ID |
会话隧道ID |
Session Name: |
会话的名称 |
Previous Hop Address |
前一跳地址,格式为X.X.X.X |
Token Bucket rate |
流量参数,令牌桶速率 |
Token Bucket Size |
流量参数,令牌桶大小 |
display mpls rsvp-te statistics { global | interface [ interface-type interface-number ] } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
global:全局RSVP-TE。
interface:所有接口。
【描述】
display mpls rsvp-te statistics命令用来显示RSVP-TE的统计信息。
l 如果选择参数global,则查看全局RSVP-TE的统计信息;
l 如果选择参数interface,则查看所有接口RSVP-TE的统计信息;
l 如果选择参数interface interface-type interface-number,则查看指定接口RSVP-TE的统计信息。
# 显示全局RSVP-TE的统计信息。
<Sysname> display mpls rsvp-te statistics global
LSR ID: 1.1.1.1
PSB Count: 1 RSB Count: 1
RFSB Count: 0 TCSB Count: 1
LSP Count: 1
Total Statistics Information:
PSB CleanupTimeOutCounter: 0 RSB CleanupTimeOutCounter: 0
SendPacketCounter: 55 RecPacketCounter: 54
SendPathCounter: 5 RecPathCounter: 0
SendResvCounter: 0 RecResvCounter: 4
SendResvConfCounter: 0 RecResvConfCounter: 0
SendHelloCounter: 2 RecHelloCounter: 48
SendAckCounter: 48 RecAckCounter: 2
SendPathErrCounter: 0 RecPathErrCounter: 0
SendResvErrCounter: 0 RecResvErrCounter: 0
SendPathTearCounter: 0 RecPathTearCounter: 0
SendResvTearCounter: 0 RecResvTearCounter: 0
SendSrefreshCounter: 0 RecSrefreshCounter: 0
SendAckMsgCounter: 0 RecAckMsgCounter: 0
SendErrMsgCounter: 0 RecErrMsgCounter: 0
RecReqFaultCounter: 0
# 显示指定接口Vlan-interface3的RSVP-TE的统计信息。
<Sysname> display mpls rsvp-te statistics interface vlan-interface 3
Vlan-interface3:
SendPacketCounter: 69 RecPacketCounter: 68
SendPathCounter: 6 RecPathCounter: 0
SendResvCounter: 0 RecResvCounter: 5
SendHelloCounter: 2 RecHelloCounter: 61
SendAckCounter: 61 RecAckCounter: 2
表1-16 display mpls rsvp-te statistics命令显示信息描述表
LSR ID |
LSR的ID |
PSB Count |
PSB的数量 |
RSB Count |
RSB的数量 |
RFSB Count |
RFSB的数量 |
TCSB Count |
TCSB的数量 |
LSP Count |
LSP的数量 |
PSB CleanupTimeOutCounter |
PSB超时次数 |
RSB CleanupTimeOutCounter |
RSB超时次数 |
SendPacketCounter |
发送的报文数量 |
RecPacketCounter |
接收的报文数量 |
SendPathCounter |
发送的Path消息数量 |
RecPathCounter |
接收的Path消息数量 |
SendResvCounter |
发送的Resv消息数量 |
RecResvCounter |
接收的Resv消息数量 |
SendResvConfCounter |
发送的ResvConf消息数量 |
RecResvConfCounter |
接收的ResvConf消息数量 |
SendHelloCounter |
发送的Hello消息数量 |
RecHelloCounter |
接收的Hello消息数量 |
SendAckCounter |
发送的Ack消息数量 |
RecAckCounter |
接收的Ack消息数量 |
SendPathErrCounter |
发送的PathErr消息数量 |
RecPathErrCounter |
接收的PathErr消息数量 |
SendResvErrCounter |
发送的ResvErr消息数量 |
RecResvErrCounter |
接收的ResvErr消息数量 |
SendPathTearCounter |
发送的PathTear消息数量 |
RecPathTearCounter |
接收的PathTear消息数量 |
SendResvTearCounter |
发送的ResvTear消息数量 |
RecResvTearCounter |
接收的ResvTear消息数量 |
SendSrefreshCounter |
发送的Srefresh消息数量 |
RecSrefreshCounter |
接收的Srefresh消息数量 |
SendAckMsgCounter |
发送的AckMsg消息数量 |
RecAckMsgCounter |
接收的AckMsg消息数量 |
SendErrMsgCounter |
发送错误的消息数量 |
RecErrMsgCounter |
接收错误的消息数量 |
RecReqFaultCounter |
请求失败的次数 |
display mpls static-cr-lsp [ lsp-name lsp-name ] [ { include | exclude } ip-address prefix-length ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
lsp-name lsp-name:标签转发路径的名称,为1~15个字符的字符串。
include:只显示指定FEC的CR-LSP信息。
exclude:显示除指定FEC外的所有CR-LSP信息。
ip-address:FEC的IP地址。
prefix-length:地址前缀的长度,取值范围为0~32。
verbose:显示详细信息。
| { begin | exclude | include } regular-expression:使用正则表达式对显示信息进行过滤。有关正则表达式的详细介绍,请参见“基础配置指导”中的“CLI配置”。其中:
l begin:从包含指定正则表达式的行开始显示。
l exclude:只显示不包含指定正则表达式的行。
l include:只显示包含指定正则表达式的行。
l regular-expression:表示正则表达式,为1~256个字符的字符串,区分大小写。
【描述】
display mpls static-cr-lsp命令用来显示静态CR-LSP信息。
# 显示静态CR-LSP的简要信息。
<Sysname> display mpls static-cr-lsp
total statics-cr-lsp : 1
Name FEC I/O Label I/O If State
Tunnel0 3.3.3.9/32 NULL/100 -/Vlan1 Down
表1-17 display mpls static-cr-lsp命令显示信息描述表
Name |
静态CR-LSP的名称 |
FEC |
FEC(等价转发类) |
I/O Label |
入/出标签值 |
I/O If |
入/出接口 |
State |
静态CR-LSP当前的状态 |
# 显示静态CR-LSP的详细信息。
<Sysname> display mpls static-cr-lsp verbose
No : 1
LSP-Name : Tunnel0
LSR-Type : Ingress
FEC : 3.3.3.3/32
In-Label : NULL
Out-Label : 20
In-Interface : -
Out-Interface : Vlan-interface2
NextHop : 2.1.1.2
Lsp Status : Up
表1-18 display mpls static-cr-lsp verbose命令显示信息描述表
No |
序号 |
LSP-Name |
静态CR-LSP名称 |
LSR-Type |
静态CR-LSP类型 |
FEC |
FEC(转发等价类) |
In-Label |
入标签值 |
Out-Label |
出标签值 |
In-Interface |
入接口名称 |
Out-Interface |
出接口名称 |
NextHop |
下一跳地址 |
Lsp Status |
LSP状态 |
display mpls te cspf tedb { all | area area-id | interface ip-address | network-lsa | node [ mpls-lsr-id ] } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
area area-id:区域ID。对于OSPF,取值范围为0~4294967295;对于IS-IS,取值为1或2。
interface ip-address:接口IP地址。
network-lsa:所有的Network-LSA信息。
node:节点信息。
mpls-lsr-id:MPLS LSR ID。
【描述】
display mpls te cspf tedb命令用来显示满足指定条件的基于CSPF的TEDB信息。
# 显示Network-LSA的TEDB信息。
<Sysname> display mpls te cspf tedb network-lsa
Maximum Network LSA Supported: 2048
Current Total Network LSA Number: 2
Id DR MPLS LSR-Id DR-Address IGP Process-Id Area Neighbor
1 104.4.4.4 45.1.1.4 OSPF 1 0 105.5.5.5
104.4.4.4
2 104.4.4.4 45.1.1.4 ISIS 1 Level-2 104.4.4.4
105.5.5.5
表1-19 display mpls te cspf tedb命令显示信息描述表
ID |
序号 |
DR MPLS LSR-Id |
指定路由器(Designated Router)的MPLS LSR ID |
DR-Address |
指定路由器(Designated Router)的接口地址 |
IGP |
内部网关协议(OSPF/IS-IS) |
Process-Id |
IGP进程ID |
Area |
路由器属于的区域 |
Neighbor |
邻居路由器ID |
# 显示所有TEDB信息。
<Sysname> display mpls te cspf tedb all
Maximum Node Supported: 128 Maximum Link Supported: 2048
Current Total Node Number: 4 Current Total Link Number: 4
Id MPLS LSR-Id IGP Process-Id Area Link-Count
1 104.4.4.4 OSPF 1 0 1
2 105.5.5.5 OSPF 1 0 1
3 104.4.4.4 ISIS 1 Level-2 1
4 105.5.5.5 ISIS 1 Level-2 1
表1-20 display mpls te cspf tedb all命令显示信息描述表
ID |
序号 |
MPLS LSR-Id |
MPLS LSR ID |
IGP |
Process-Id |
IGP进程ID |
Area |
路由器属于的区域 |
Link-count |
路由器上连接的指定IGP类型和进程号的链路总数 |
# 显示指定区域的TEDB信息。
<Sysname> display mpls te cspf tedb area 1
Router Node Information for Area 1:
1 2.2.2.2 OSPF 100 1 1
2 3.3.3.3 OSPF 100 1 1
3 2.2.2.2 ISIS 100 Level-1 1
4 3.3.3.3 ISIS 100 Level-1 1
Network LSA Information for Area 1:
1 3.3.3.3 20.1.1.2 OSPF 100 1 2.2.2.2
3.3.3.3
2 3.3.3.3 20.1.1.2 ISIS 100 Level-1 3.3.3.3
2.2.2.2
表1-21 display mpls te cspf tedb area命令显示信息描述表
Id |
序号 |
MPLS LSR-Id |
MPLS LSR ID,点分十进制形式 |
IGP |
内部网关协议(OSPF或IS-IS) |
Process-Id |
IGP的进程号 |
Area |
路由器所属的区域 |
Link-Count |
DR MPLS LSR-Id |
指定路由器DR的MPLS LSR ID |
DR-Address |
指定路由器DR的接口地址 |
Neighbor |
邻居的MPLS LSR ID |
# Prestandard模式下显示本地路由的TEDB信息。
<Sysname> display mpls te cspf tedb node
MPLS LSR-Id: 1.1.1.1
IGP Type: OSPF Process Id: 100
MPLS-TE Link Count: 1
Link[1] :
Interface IP Address: 2.0.0.33, 2.0.0.35, 2.0.0.36,
Neighbor IP Address: 2.0.0.2, 2.0.0.42, 2.0.0.43,
2.0.0.44, 2.0.0.45, 2.0.0.46,
2.0.0.47, 2.0.0.32,
Neighbor MPLS LSR-Id : 1.1.1.2
IGP Area: 1
Link Type: point-to-point Link Status: Inactive
IGP Metric: 100 TE Metric: 100 Color: 0xff
IGP Type: ISIS Process Id: 100
MPLS-TE Link Count: 2
Link[1] :
2.0.0.47, 2.0.0.32, 2.0.0.33
Neighbor MPLS LSR-Id: 1.1.1.2
IGP Area: Level-0
Link Type: point-to-point Link Status: Active
IGP Metric: 10 TE Metric: 10 Color: 0x11
表1-22 display mpls te cspf tedb node命令显示信息描述表
MPLS LSR-Id |
路由器的名称 |
IGP Type |
IGP类型 |
Process Id |
IGP进程号 |
MPLS-TE Link Count |
MPLS TE链路数目 |
Link[1] |
第一条链路的信息 |
接口地址 |
DR Address |
指定路由器DR地址 |
IGP Area |
IGP区域 |
Link Type |
链路类型 |
Link Status |
链路状态 |
IGP Metric |
IGP度量 |
TE Metric |
TE度量 |
Color |
链路管理属性 |
display mpls te link-administration admission-control [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
interface interface-type interface-number:指定接口类型和接口编号。
【描述】
display mpls te link-administration admission-control命令用来显示所有链路接纳的CR-LSP信息。
如果不指定接口,将显示所有接口的所有链路接纳的CR-LSP信息。
# 显示所有链路接纳的CR-LSP信息。
<Sysname> display mpls te link-administration admission-control
LspID In/Out IF S/H Prio CT BW(kbps)
1.1.1.9:1024 ---/Vlan3 7/7 0 0
1.1.1.9:2048 ---/Vlan4 7/7 0 0
表1-23 display mpls te link-administration admission-control命令显示信息描述表
LspID |
链路接纳的LSP的ID |
In/Out IF |
入/出接口名称 |
S/H Prio |
建立/保持优先级 |
CT |
服务类型 |
BW(kbps) |
带宽 |
display mpls te tunnel [ destination dest-addr ] [ lsp-id lsr-id lsp-id ] [ lsr-role { all | egress | ingress | remote | transit } ] [ name name ] [ { incoming-interface | outgoing-interface | interface } interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
destination dest-addr:只显示目的地址为指定IP地址的隧道。
lsp-id lsr-id lsp-id:lsr-id为Ingress节点的LSR-ID,点分十进制格式,lsp-id为LSP标识号,取值范围为1~65535。
lsr-role:显示具有指定角色的隧道(所有、入口、中间、出口或远端)。
all:显示所有隧道。
egress:显示出口位于该路由器的隧道。
ingress:显示入口位于该路由器的隧道。
remote:显示出口或中间节点位于该路由器的隧道。
transit:显示中间节点位于该路由器的隧道。
name name:显示具有指定名称的隧道,name,隧道名称,为1~63个字符的字符串。如果指定,该隧道名称从接口描述中获得。否则它就是接口名称。隧道名称应当包含在信令消息中,这样所有的跳都可以获得。
incoming-interface:显示使用指定入接口的所有隧道。
outgoing-interface:显示使用指定出接口的所有隧道。
interface:显示使用指定接口作为出接口或入接口的所有隧道。
verbose:显示详细信息。
【描述】
display mpls te tunnel命令用来显示MPLS TE隧道信息。
# 显示MPLS TE隧道信息。(根据隧道使用的信令协议不同,显示信息不同。)
<Sysname> display mpls te tunnel
LSP-Id Destination In/Out-If Name
1.1.1.9:1024 3.3.3.9 -/Vlan3 Tunnel1
1.1.1.9:2048 3.3.3.9 -/Vlan4 Tunnel2
表1-24 display mpls te tunnel命令显示信息描述表
LSP-ID |
隧道的LSP ID |
Destination |
目的路由器的ID |
In/Out-IF |
入接口/出接口 |
Name |
隧道入口配置的隧道名称 |
# 显示MPLS TE隧道的详细信息。
<Sysname> display mpls te tunnel verbose
No : 1
LSP-Id : 1.1.1.9:1024
Tunnel-Name : Tunnel0
Destination : 3.3.3.9
In-Interface : -
Out-Interface : Vlan3
Ingress LSR-Id : 1.1.1.9
Egress LSR-Id : 3.3.3.9
Setup-Priority : 7
Hold-Priority : 7
Sign-Protocol : RSVP TE
Resv Style : SE
IncludeAnyAff : 0x0
ExcludeAllAff : 0x0
IncludeAllAff : 0x0
Created Time : 2004/10/18 16:05:17
表1-25 display mpls te tunnel verbose命令显示信息描述表
No |
序号 |
LSP-Id |
隧道的LSP ID |
Tunnel-Name |
隧道入口配置的隧道名称 |
Destination |
目的路由器的ID |
In-Interface |
入接口 |
Out-Interface |
出接口 |
Ingress LSR-Id |
入口标签交换路由器的ID |
Egress LSR-Id |
出口标签交换路由器的ID |
Setup-Priority |
建立优先级 |
Hold-Priority |
保持优先级 |
Sign-Protocol |
信令协议 |
Resv Style |
预留风格 |
IncludeAnyAff |
需要包含的任一链路属性 |
ExcludeAllAff |
排除的链路属性 |
IncludeAllAff |
需要包含的全部链路属性 |
Created Time |
建立时间 |
display mpls te tunnel path [ lsp-id lsr-id lsp-id | tunnel-name tunnel-name ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel-name tunnel-name:隧道名称,为1~63个字符的字符串。
【描述】
display mpls te tunnel path命令用来显示本地节点的MPLS TE隧道的路径属性信息。
如果不指定隧道名称,将显示所有隧道的路径属性信息。
# 显示所有隧道路径属性信息。
<Sysname> display mpls te tunnel path
Tunnel Interface Name : Tunnel0
Lsp ID : 1.1.1.9:10
Hop information:
Hop 0: 192.1.1.1;
Hop 1: 12.1.1.2;
Hop 2: 10.202.2.2.
表1-26 display mpls te tunnel path命令显示信息描述表
Tunnel Interface Name |
隧道接口名称 |
Lsp ID |
LSP ID |
Hop 0 |
第0跳 |
Hop 1 |
第1跳 |
Hop 2 |
第2跳 |
display mpls te tunnel statistics [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
【描述】
display mpls te tunnel statistics命令用来显示MPLS TE隧道统计信息。
# 显示MPLS TE隧道统计信息。
<Sysname> display mpls te tunnel statistics
Ingress: 0 Tunnels, 0 Tunnels Up, 0 CRLSPs Up
0 Modified, 0 In-Progress, 0 Failed
Transit: 0 Up
Egress : 0 Up
表1-27 display mpls te tunnel statistics命令显示信息描述表
Ingress |
以本设备为隧道入口 |
Transit: |
以本设备为隧道中间结点 |
Egress |
以本设备为隧道出口 |
Modified |
以本设备为入口,处于Modified状态的CR-LSP数目 |
In-Progress |
以本设备为入口,处于In-Progress状态的CR-LSP数目 |
Failed |
以本设备为入口,处于Failed状态的CR-LSP数目 |
display mpls te tunnel-interface [ tunnel number ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel number:显示指定Tunnel接口的信息。
【描述】
display mpls te tunnel-interface命令用来显示本地节点的MPLS TE隧道接口信息。
# 显示本地节点的MPLS TE隧道接口信息。
<Sysname> display mpls te tunnel-interface
Tunnel Name : Tunnel0
Tunnel Desc : Tunnel Interface
Tunnel State Desc : CR-LSP is Up
Tunnel Attributes :
LSP ID : 1.1.1.9:1
Session ID : 10
Admin State : UP Oper State : UP
Ingress LSR ID : 1.1.1.9 Egress LSR ID: 2.2.2.9
Signaling Prot : CR LDP Resv Style : -
Setup Priority : 7 Hold Priority: 7
Affinity Prop/Mask : 0/0
Explicit Path Name : -
Tie-Breaking Policy : None
Metric Type : None
Record Route : Disabled Record Label : Disabled
FRR Flag : Disabled BackUpBW Flag: Not Supported
BackUpBW Type : - BackUpBW : -
Route Pinning : Disabled
Retry Limit : 10 Retry Interval: 10
Reopt : Disabled Reopt Freq : -
Back Up Type : None
Back Up LSPID : -
Auto BW : Disabled Auto BW Freq : -
Min BW : - Max BW : -
Current Collected BW: -
Interfaces Protected: -
VPN Bind Type : NONE
VPN Bind Value : -
Car Policy : Disabled
Tunnel Group : Secondary
Primary Tunnel : 120
Backup Tunnel : -
Group Status : -
Oam Status : -
表1-28 display mpls te tunnel-interface命令显示信息描述表
Tunnel Name |
隧道的名称 |
Tunnel Desc |
隧道的描述信息 |
Tunnel State Desc |
隧道的状态信息 |
LSP ID |
LSP ID |
Session ID |
会话ID |
Admin State |
管理状态 |
Oper State |
运行状态 |
Ingress LSR ID |
入口标签交换路由器ID |
Egress LSR ID |
目的标签交换路由器ID |
Signaling Prot |
隧道信令协议 |
Resv Style |
预留方式 |
Class Type |
服务类型 |
Setup Priority |
建立优先级 |
Hold Priority |
保持优先级 |
Affinity Prop/Mask |
亲和属性/掩码 |
Explicit Path Name |
显式路径名称 |
Tie-Breaking Policy |
路由选择策略 |
Metric Type |
度量类型 |
Record Route |
记录路由 |
Record Label |
记录标签 |
FRR Flag |
快速重路由标记 |
BackUpBW Flag |
备份带宽标志 |
BackUpBW Type |
备份带宽类型 |
BackUpBW |
备份带宽 |
Route Pinning |
路由固定 |
Retry Limit |
最少重建次数 |
Retry Interval |
重建间隔 |
Reopt |
重优化 |
Reopt Freq |
重优化频率 |
Back Up Type |
备份路径类型 |
Back Up LSPID |
备份LSP ID |
Auto BW |
自动带宽调整 |
Auto BW Freq |
自动带宽调整频率 |
Min BW |
自动带宽调整的最小带宽 |
Max BW |
自动带宽调整的最大带宽 |
Current Collected BW |
当前收集带宽 |
Interfaces Protected |
快速重路由保护接口 |
VPN Bind Type |
绑定类型,指明是VPN或ACL |
VPN Bind Value |
具体绑定的值,VPN实例名称或ACL号 |
Car Policy |
CAR(Committed Access Rate,承诺访问速率)策略 |
Tunnel Group |
该隧道在保护组中是主隧道还是备份隧道 |
Primary Tunnel |
主隧道的Tunnel ID,如果是主隧道,则不填写 |
Backup Tunnel |
备份隧道Tunnel ID,如果是备隧道,则不填写 |
Group Status |
保护组状态,如果未配保护组,则不填写 |
display ospf [ process-id ] mpls-te [ area area-id ] [ self-originated ] [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
process-id:OSPF进程号,取值范围为1~65535。
area area-id:OSPF区域号,可以是整数形式,也可以是IPv4地址形式。当是整数形式时,取值范围为0~4294967295。
self-originated:显示自产生(Self Originated)的TE LSA信息。
【描述】
display ospf mpls-te命令用来显示LSDB(链路状态数据库)中包含的所有TE LSA信息。
# 显示LSDB中包含的所有TE LSA信息。
<Sysname> display ospf mpls-te
OSPF Process 100 with Router ID 10.0.0.1
Area ID:
Traffic Engineering LSA’s of the database
LSA []
LSA Type : Opq-Area
Opaque Type : 1
Opaque ID :
Advertising Router ID : xxx.xxx.xxx.xxx
LSA Age :
Length :
LSA Options :
LS Seq Number :
CheckSum :
Link Type :Point to Point / Point to Multi Point /MultiAccess
Link ID :
Local Interface Address : xxx.xxx.xxx.xxx
Remote Interface Address : xxx.xxx.xxx.xxx
TE Metric :
Admin Group :
表1-29 display ospf mpls-te命令显示信息描述表
Area ID |
使能了TE的OSPF区域的区域号 |
LSA Type |
LSA类型,为“Opq-Area”(在Opaque LSA头中携带) |
Opaque Type |
对于TE,这项值为1(在Opaque LSA头中携带) |
Opaque ID |
Opaque ID(在Opaque LSA头中携带) |
Advertising Router ID |
生成这条LSA的路由器ID |
LSA age |
LSA的年龄(在Opaque LSA头中携带) |
Length |
Opaque LSA的长度(在Opaque LSA头中携带) |
LSA Options |
LSA选项(在Opaque LSA头中携带) |
LS Seq Number |
LSA的顺序号(在Opaque LSA头中携带) |
Checksum |
LSA的校验和(在Opaque LSA头中携带) |
Link Type |
链路类型,可能是点到点(Point to Point)、点到多点(Point to Multi Point)、广播(MultiAccess) |
Link ID |
链路ID |
Local Interface Address |
本地的主IP地址 |
Remote Interface Address |
远端接口地址 |
TE Metric |
TE度量 |
Admin Group |
管理组 |
display ospf [ process-id ] traffic-adjustment [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
process-id:OSPF的进程号,取值范围为1~65535。
【描述】
display ospf traffic-adjustment命令用来显示与流量调节(IGP shortcut及转发邻接)相关的、OSPF进程的隧道信息。
# 显示所有OSPF进程与流量调节相关的隧道信息。
<Sysname> display ospf traffic-adjustment
OSPF Process 100 with Router ID 100.0.0.1
Traffic adjustment
Interface: 100.0.0.1 (Tunnel0)
Type: Forwarding Adjacency State: Up
Neighbor ID: 100.0.0.2 Cost: 100
Configuration:
Neighbor Ip Address: 100.0.0.2
Cost : -10
Cost Type : Relative
Hold time : 10s
表1-30 display ospf traffic-adjustment命令显示信息描述表
隧道类型接口的接口地址和接口名 |
Type |
该隧道是否用于IGP Shortcut或Forwarding Adjacency |
Neighbor ID |
隧道对端邻居的Router ID |
Cost |
开销 |
State |
状态,取值为up/down |
Neighbor Ip Address |
邻居的IP地址 |
Cost Type |
开销类型 |
Hold time |
保持时间 |
display tunnel-info { tunnel-id | all | statistics } [ | { begin | exclude | include } regular-expression ]
【缺省级别】
1:监控级
tunnel-id:指定隧道ID号,取值范围为1~FFFFFFFE。
all:所有隧道。
statistics:隧道的统计信息。
【描述】
display tunnel-info命令用来显示隧道信息。
# 显示所有隧道信息。
<Sysname> display tunnel-info all
Tunnel ID Type Destination
0x1100002 lsp 2.2.2.2
表1-31 display tunnel-info all命令显示信息描述表
Tunnel ID |
隧道ID |
Type |
隧道类型 |
Destination |
隧道目的地址 |
# 显示隧道的统计信息。
<Sysname> display tunnel-info statistics
Tunnel Allocation Method : GLOBAL
Avail Tunnel ID Value : 102400
Total Tunnel ID Allocated : 0
LSP : 0
GRE : 0
CRLSP : 0
LOCAL IFNET : 0
MPLS LOCAL IFNET : 0
表1-32 display tunnel-info statistics命令显示信息描述表
Tunnel Allocation Method |
隧道分配方式 |
Avail Tunnel ID Value |
有效隧道ID值 |
Total Tunnel ID Allocated |
所有已经分配隧道ID的数量 |
LSP |
隧道类型为LSP隧道的数量 |
GRE |
隧道类型为GRE隧道的数量 |
CRLSP |
隧道类型为CRLSP隧道的数量 |
LOCAL IFNET |
MPLS L2VPN中CE侧接口的数量 |
MPLS LOCAL IFNET |
MPLS L2VPN中CCC远程方式出接口的数量 |
undo enable traffic-adjustment
OSPF视图
【缺省级别】
2:系统级
无
【描述】
enable traffic-adjustment命令用来使能IGP Shortcut特性。undo enable traffic-adjustment命令用来禁止IGP Shortcut特性。
缺省情况下,未使能IGP Shortcut特性。
配置后,在进行SPF计算和泛洪(flooding)时,所有静态LSP隧道也被包括在内。
# IGP协议为OSPF时使能IGP Shortcut特性。
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment
undo enable traffic-adjustment advertise
OSPF视图
【缺省级别】
2:系统级
无
【描述】
enable traffic-adjustment advertise命令用来使能转发邻接特性。undo enable traffic-adjustment advertise命令用来禁止转发邻接特性。
缺省情况下,未使能转发邻接特性。
# IGP协议为OSPF时使能转发邻接特性。
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment advertise
explicit-path pathname [ disable | enable ]
undo explicit-path pathname
【缺省级别】
2:系统级
pathname:隧道的显式路径名称,为1~31个字符的字符串。
disable:禁止显式路径。
enable:使能显式路径。
【描述】
explicit-path命令用来创建隧道的显式路径,并进入显式路径视图。undo explicit-path命令用来删除配置的路径。
# 创建一条名为path1的显式路径,并进入显式路径视图。
list hop [ ip-address ]
显式路径视图
【缺省级别】
2:系统级
【描述】
list hop命令用来显示显式路径的节点信息。
# 显示MPLS TE显式路径的节点信息。
[Sysname-explicit-path-path1] list hop
Path Name : path1 Path Status : Enabled
1 1.1.1.9 Strict Include
2 2.2.2.9 Strict Exclude
modify hop ip-address1 ip-address2 [ include [ loose | strict ] | exclude ]
显式路径视图
【缺省级别】
2:系统级
ip-address1 ip-address2:将显式路径中的IP地址ip-address1修改为ip-address2。可以指定链路的IP地址或节点的Router ID。
include:在显式路径中包含IP地址。
exclude:不在后续的路径计算中包括此地址。
【描述】
modify hop命令用来修改显式路径中的节点IP地址。
缺省情况下,显式路径包含指定的节点(include),修改的节点是严格下一跳(strict)。
# 将MPLS TE显式路径中的IP地址10.0.0.125修改为10.0.0.200,同时将10.0.0.200的属性设为exclude。
[Sysname-explicit-path-path1] modify hop 10.0.0.125 10.0.0.200 exclude
mpls rsvp-te
undo mpls rsvp-te
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te命令用来使能RSVP-TE能力。undo mpls rsvp-te命令用来取消RSVP-TE能力。
缺省情况下,未使能RSVP-TE能力。
l 在配置其他RSVP-TE功能之前,应先使能RSVP-TE。
l 在MPLS视图下使能本节点的RSVP-TE能力之前,需要先在系统视图下使能本节点的MPLS能力,并在MPLS视图下使能本节点的MPLS TE能力。
l 在接口视图下使能接口的RSVP-TE能力之前,需要先在接口视图下使能接口的MPLS能力和MPLS TE能力。
l 当在MPLS视图下取消RSVP-TE能力时,将会同时取消所有接口上配置的RSVP-TE能力。
# 使能RSVP-TE特性。
[Sysname] mpls
[Sysname-mpls] mpls te
[Sysname-mpls] mpls rsvp-te
# 在接口Vlan-interface1上使能RSVP-TE特性。
[Sysname-Vlan-interface1] mpls
[Sysname-Vlan-interface1] mpls te
[Sysname-Vlan-interface1] mpls rsvp-te
mpls rsvp-te authentication { cipher | plain } auth-key
undo mpls rsvp-te authentication
【缺省级别】
2:系统级
cipher:表示密文密钥。
plain:表示明文密钥。
auth-key:验证密钥,区分大小写。如果采用明文(plain)形式,为8~16个字符的字符串;如果采用密文(cipher)形式,既可以是8~16个字符的明文,也可以是24个字符的密文。
【描述】
mpls rsvp-te authentication命令用来使能验证功能。undo mpls rsvp-te authentication命令用来禁止验证功能。
RSVP-TE传送由验证密钥和加密哈希算法生成的消息验证摘要。所有从此接口发送的报文将使用此密钥来计算消息摘要,从此接口接收的报文也将使用此密钥来验证。
RSVP验证功能和快速重路由功能不能同时配置。
# 在接口Vlan-interface1上启动验证功能。
[Sysname-Vlan-interface1] mpls rsvp-te authentication plain beijing123
undo mpls rsvp-te bfd enable
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te bfd enable命令用来在已使能RSVP-TE的接口下使能BFD提供的链路检测功能。undo mpls rsvp-te bfd enable命令用来关闭已使能RSVP的接口下BFD提供的链路检测功能恢复缺省情况。
缺省情况下,已使能RSVP-TE的接口下未使能BFD提供的链路检测功能。
需要注意的是,在接口视图下使能BFD提供的链路检测功能,要先在接口视图下使能RSVP-TE。
# 在接口Vlan-intface100上使能MPLS RSVP-TE的BFD链路检测功能。
[Sysname-Vlan-interface100] mpls rsvp-te bfd enable
mpls rsvp-te blockade-multiplier number
undo mpls rsvp-te blockade-multiplier
MPLS视图
【缺省级别】
2:系统级
number:阻塞状态倍数,取值范围为3~255。
【描述】
mpls rsvp-te blockade-multiplier命令用来配置阻塞状态超时倍数。undo mpls rsvp-te blockade-multiplier用来恢复缺省配置。
缺省情况下,阻塞状态超时倍数为4。
ResvErr消息在一个节点创建阻塞状态以解决“killer reservation”问题,这样就可以转发或创建更小的请求。
阻塞状态超时时间Blockade_Expired_Time=Kb×refresh-time。执行该命令前应先使能RSVP-TE特性。
相关配置可参考命令mpls rsvp-te timer refresh。
# 设定阻塞状态时间倍数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te blockade-multiplier 5
undo mpls rsvp-te graceful-restart
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te graceful-restart命令用来使能MPLS RSVP-TE协议的GR能力。undo mpls rsvp-te graceful-restart命令用来关闭MPLS RSVP-TE协议的GR能力。
缺省情况下,MPLS RSVP-TE协议的GR能力处于关闭状态。
需要注意的是,在使能RSVP-TE协议的GR能力前,需要先使能RSVP-TE协议Hello扩展能力。
# 使能MPLS RSVP-TE协议的GR能力。
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello
[Sysname-mpls] mpls rsvp-te graceful-restart
mpls rsvp-te hello
undo mpls rsvp-te hello
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te hello命令用来使能RSVP的Hello扩展。undo mpls rsvp-te hello命令用来禁止RSVP的Hello扩展。
缺省情况下,未使能RSVP的Hello扩展。
Hello机制用于检测邻居的存在。
在接口视图下使能RSVP的Hello扩展,要先在接口视图下使能RSVP-TE,并在MPLS视图下使能RSVP的Hello扩展。
# 使能RSVP的Hello扩展。
[Sysname] mpls
# 在接口Vlan-interface1上使能RSVP的Hello扩展。
[Sysname-Vlan-interface1] mpls rsvp-te hello
mpls rsvp-te hello-lost times
undo mpls rsvp-te hello-lost
MPLS视图
【缺省级别】
2:系统级
times:最多可以接受的Hello报文丢失次数,取值范围为3~10。
【描述】
mpls rsvp-te hello-lost命令用来配置允许的连续未收到Hello报文的次数。undo mpls rsvp-te hello-lost命令用来恢复缺省值。
缺省情况下,最多允许连续收不到3个Hello报文。
采用Hello机制时,如果节点连续多次未接收到对端发来的Hello应答消息,则判定链路出现故障。
执行该命令之前,应先使能RSVP-TE特性,并在MPLS视图下使能RSVP的Hello扩展功能。
相关配置可参考命令mpls rsvp-te timer hello。
# 设定节点连续未收到Hello应答的次数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello-lost 5
mpls rsvp-te keep-multiplier number
undo mpls rsvp-te keep-multiplier
MPLS视图
【缺省级别】
2:系统级
number:超时倍数,取值范围为3~255。
【描述】
mpls rsvp-te keep-multiplier命令用来配置PSB和RSB的超时倍数。undo mpls rsvp-te keep-multiplier命令用来恢复缺省配置。
缺省情况下,PSB和RSB的超时倍数为3。
超时时间Expired_Time=(keep-multiplier+0.5)×1.5×refresh-time。执行该命令前,应先使能RSVP-TE特性。
# 配置保持时间倍数为5。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te keep-multiplier 5
undo mpls rsvp-te reliability
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te reliability命令用来使能可靠性功能。undo mpls rsvp-te reliability命令用来禁止可靠性功能。
# 在接口Vlan-interface1上启动可靠性机制。
[Sysname-Vlan-interface1] mpls rsvp-te reliability
undo mpls rsvp-te resvconfirm
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te resvconfirm命令用来使能节点的预留确认机制。undo mpls rsvp-te resvconfirm命令用来禁止预留确认机制。
缺省情况下,节点上不使能预留确认机制。
预留确认是指对预留请求的确认。
# 在本节点使能预留确认机制。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te resvconfirm
mpls rsvp-te srefresh
undo mpls rsvp-te srefresh
【缺省级别】
2:系统级
无
【描述】
mpls rsvp-te srefresh 命令用来使能Srefresh(Summary Refresh,摘要刷新)功能。undo mpls rsvp-te srefresh命令用来禁止摘要刷新功能。
缺省情况下,未使能摘要刷新功能。
使能Srefresh功能将在当前接口禁用传统的时间驱动刷新。Srefresh消息用于刷新路径Path和预留Resv的状态。
# 在接口Vlan-interface1上启动Srefresh特性。
[Sysname-Vlan-interface1] mpls rsvp-te srefresh
mpls rsvp-te timer graceful-restart recovery recovery-time
undo mpls rsvp-te timer graceful-restart recovery
MPLS视图
【缺省级别】
2:系统级
recovery-time:RSVP-TE GR恢复定时器的值,取值范围为60~300,单位为秒。
【描述】
mpls rsvp-te timer graceful-restart recovery命令用来配置RSVP-TE GR的恢复定时器。undo mpls rsvp-te timer graceful-restart recovery命令用来恢复缺省情况。
缺省情况下,RSVP-TE GR恢复定时器的值为300秒。
执行该命令之前,必须先使能RSVP-TE协议的GR能力。
# 配置RSVP-TE GR恢复定时器的值为100秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart recovery 100
mpls rsvp-te timer graceful-restart restart restart-time
undo mpls rsvp-te timer graceful-restart restart
MPLS视图
【缺省级别】
2:系统级
restart-time:RSVP-TE GR重启定时器的值,取值范围为60~300,单位为秒。
【描述】
mpls rsvp-te timer graceful-restart restart命令用来配置RSVP-TE GR的重启定时器。undo mpls rsvp-te timer graceful-restart restart命令用来恢复缺省情况。
缺省情况下,RSVP-TE GR重启定时器的值为120秒。
# 配置RSVP-TE GR重启定时器的值为200秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart restart 200
mpls rsvp-te timer hello timevalue
undo mpls rsvp-te timer hello
MPLS视图
【缺省级别】
2:系统级
timevalue:Hello定时器时长,取值范围为1~60,单位为秒。
【描述】
mpls rsvp-te timer hello命令用来配置Hello消息的发送时间间隔。undo mpls rsvp-te timer hello 命令用来恢复缺省配置。
缺省情况下,Hello消息发送时间间隔为3秒。
执行此命令前,应先在MPLS视图下启动Hello机制。
相关配置可参考命令mpls rsvp-te hello和mpls rsvp-te hello-lost。
# 配置Hello消息的发送时间间隔为5秒。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer hello 5
mpls rsvp-te timer refresh timevalue
undo mpls rsvp-te timer refresh
MPLS视图
【缺省级别】
2:系统级
timevalue:刷新定时器时长,取值范围10~65535,单位为秒。
【描述】
mpls rsvp-te timer refresh命令用来配置节点的路径/预留消息的刷新时间。undo mpls rsvp-te timer refresh命令用来恢复缺省配置。
缺省情况下,节点的路径/预留消息的刷新时间为30秒。
相关配置可参考命令mpls rsvp-te keep-multiplier。
# 配置每60秒发送一次路径/预留刷新消息。
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer refresh 60
mpls rsvp-te timer retransmission { increment-value [ increment-value ] | retransmit-value [ retrans-timer-value ] } *
undo mpls rsvp-te timer retransmission
【缺省级别】
2:系统级
increment-value increment-value:重传增量,取值范围为1~10,缺省值为1。
retransmit-value retrans-timer-value:重传定时器间隔,取值范围为500~3000,单位为毫秒,缺省值为500毫秒。
【描述】
mpls rsvp-te timer retransmission命令用来使能重传功能。undo mpls rsvp-te timer retransmission命令用来关闭重传功能。
缺省情况下,未使能重传功能。
# 在接口Vlan-interface1上启动重传功能,重传增量为2,重传定时器间隔为1000。
[Sysname-Vlan-interface1] mpls rsvp-te timer retransmission increment-value 2 retransmit-value 1000
mpls te
undo mpls te
MPLS视图/接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te用来使能MPLS TE能力。undo mpls te用来禁止MPLS TE能力。
l 在MPLS视图下执行mpls te命令,将使能本节点的MPLS TE能力;undo mpls te删除所有CR-LSP,禁止MPLS TE能力。
l 在接口视图下执行mpls te命令,将使能接口的MPLS TE能力;undo mpls te删除接口上所有CR-LSP,禁止接口的MPLS TE能力。
缺省情况下,未使能MPLS TE能力。
必须先全局使能本节点的MPLS TE能力,才能在接口下使能MPLS TE的能力。
# 使能本节点的MPLS TE能力。
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls
# 使能接口Vlan-interface1的MPLS TE能力。
mpls te affinity property properties [ mask mask-value ]
undo mpls te affinity property
Tunnel接口视图
【缺省级别】
2:系统级
properties:承载隧道的链路的属性值,32位整数,取值范围为0x0~0xFFFFFFFF,每一位代表一种属性,属性值是1或0,缺省值为0x0。
mask-value:需要检查的链路属性位,32位整数,取值范围为0x0~0xFFFFFFFF,每一位代表一种属性,属性值是1或0,缺省值为0x00000000。
【描述】
mpls te affinity property命令用来配置隧道的亲和(Affinity)属性,也就是隧道使用的链路属性。undo mpls te affinity property命令用来恢复缺省情况。
缺省情况下,隧道的亲和属性为0x00000000,掩码为0x00000000。
亲和属性的掩码决定了设备需要检查哪些链路属性。
相关配置可参考命令mpls te link administrative group。
# 配置隧道的亲和属性。
[Sysname] interface tunnel 0
[Sysname-Tunnel0] mpls te affinity property 101 mask 303
mpls te backup { hot-standby | ordinary }
undo mpls te backup
Tunnel接口视图
【缺省级别】
2:系统级
hot-standby:热备份。
ordinary:普通备份。
【描述】
mpls te backup命令用来配置当前隧道使用的备份模式。undo mpls te backup命令用来恢复缺省配置。
缺省情况下,隧道不进行备份。
l 对隧道使能了备份功能后,记录路由标志将被自动配置为“record reroute”,而不论用户是否配置了命令mpls te record-route。
l 隧道备份功能与以下命令互斥:mpls te reoptimization和mpls te resv-style ff。
# 使能当前隧道使用热备份。
[Sysname-Tunnel0] mpls te backup hot-standby
mpls te backup bandwidth { bandwidth | { ct0 | ct1 | ct2 | ct3 } { bandwidth | un-limited } }
undo mpls te backup bandwidth
Tunnel接口视图
【缺省级别】
2:系统级
bandwidth:Bypass隧道所能保护的带宽总量,取值范围为1~32000000,单位为kbit/s。
ct0:只有CT 0的LSP可以使用Bypass隧道。
ct1:只有CT 1的LSP可以使用Bypass隧道。
ct2:只有CT 2的LSP可以使用Bypass隧道。
ct3:只有CT 3的LSP可以使用Bypass隧道。
un-limited:不对所能保护的带宽总量进行限制。
【描述】
mpls te backup bandwidth命令用来配置Bypass Tunnel可保护的带宽和LSP类型。undo mpls te backup bandwidth命令用来取消配置。
缺省情况下,Bypass Tunnel不对带宽进行保护。
l 如果不指定CT 0、CT 1、CT 2和C T3,则所有LSP都可以使用Bypass隧道。
l 通过本命令配置的保护带宽数目,仅用于计算并确立带宽保护关系,在Bypass隧道上不会预留相应的带宽。
l 配置的保护带宽数目要小于Bypass隧道实际的带宽。否则,FRR切换后,会导致被保护隧道所承载的流量丢失,并造成被保护隧道down。
# 隧道Tunnel0只用来保护属于CT 0的LSP,并且不对所保护带宽总量进行限制。隧道Tunnel1只用来保护属于CT 1的LSP,保护的带宽总量是1000kbit/s。
[Sysname-Tunnel0] mpls te backup bandwidth ct0 un-limited
[Sysname-Tunnel0] quit
[Sysname] interface tunnel 1
[Sysname-Tunnel1] mpls te backup bandwidth ct1 1000
mpls te bfd enable [ discriminator local local-id remote remote-id ]
undo mpls te bfd enable
Tunnel接口视图
【缺省级别】
2:系统级
discriminator:指定BFD会话鉴别值。
local local-id:指定BFD会话的本地鉴别值,取值范围为1~32。
remote remote-id:指定BFD会话的远端鉴别值,取值范围为1~4294967295。
【描述】
mpls te bfd enable命令用来使能TE隧道接口的MPLS TE隧道BFD检测功能。undo mpls te bfd enable命令用来关闭TE隧道接口的MPLS TE隧道BFD检测功能。
缺省情况下,未使能TE隧道接口所在MPLS TE隧道的BFD检测功能。
l 执行本命令前,必须先通过mpls lspv命令使能LSP检测功能。mpls lspv命令的详细介绍,请参见“MPLS基本配置命令”。
l BFD会话参数为TE隧道接口下配置的BFD参数,BFD会话的源地址为MPLS LSR-ID。因此,配置BFD检测MPLS TE隧道功能前,需要确保对端设备上存在MPLS LSR-ID对应的路由,还可以根据需要在隧道接口下配置BFD会话参数。BFD参数配置的详细介绍,请参见“可靠性配置指导”中的“BFD配置”。
# 使用BFD检测隧道接口Tunnel1下的MPLS TE隧道。
[Sysname-Tunnel1] mpls te bfd enable
mpls te commit
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te commit命令用来提交隧道当前配置。
在执行mpls te commit命令之前,对MPLS TE隧道的配置不会生效。
# 配置一条MPLS TE隧道,并提交隧道当前配置。
[Sysname-Tunnel0] tunnel-protocol mpls te
[Sysname-Tunnel0] destination 2.2.2.9
[Sysname-Tunnel0] mpls te commit
mpls te cspf
undo mpls te cspf
MPLS视图
【缺省级别】
2:系统级
无
【描述】
mpls te cspf命令用来使能本节点的CSPF功能。undo mpls te cspf命令用来禁止本节点的CSPF功能。
缺省情况下,未使能本节点的CSPF功能。
使能CSPF前,应先在MPLS视图下使能MPLS TE。
CSPF提供了一种在MPLS域中选择路径的方法。必须先使能CSPF,才能配置其他CSPF相关功能。
# 使能CSPF。
[Sysname] mpls
[Sysname-mpls] mpls te cspf
mpls te cspf timer failed-link timer-interval
undo mpls te cspf timer failed-link
MPLS视图
【缺省级别】
2:系统级
timer-interval:失效链路时间间隔,取值范围为0~300,单位为秒,缺省值为10秒。
【描述】
mpls te cspf timer failed-link命令用来配置失效链路定时器值。undo mpls te cspf timer failed-link命令用来恢复缺省配置。
相关配置可参考命令mpls te cspf。
# 配置失效链路定时器的时长为50秒。
[Sysname] mpls
[Sysname-mpls] mpls te cspf timer failed-link 50
undo mpls te failure-action teardown
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te failure-action teardown命令用来使能RSVP-TE隧道故障后的拆除重建功能。undo mpls te failure-action teardown命令用来关闭RSVP-TE隧道故障后的拆除重建功能。
缺省情况下,未使能RSVP-TE隧道故障后的拆除重建功能。
使能RSVP-TE隧道故障后的拆除重建功能后,如果在BFD检测MPLS TE隧道或周期性LSP Tracert检测到RSVP-TE隧道故障后的一段时间内,RSVP没有重新创建该RSVP-TE隧道,则拆除该隧道并进行重建。
# 在隧道接口Tunnel0上使能RSVP-TE隧道故障后的拆除重建功能。
[Sysname-Tunnel0] mpls te failure-action teardown
undo mpls te fast-reroute
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te fast-reroute命令用来使能快速重路由功能。undo mpls te fast-reroute命令用来禁止快速重路由功能。
缺省情况下,未使能快速重路由功能。
对Tunnel接口使能快速重路由功能后,记录路由标志将自动配置“record reroute with label”,而不论用户是否配置了命令mpls te record-route label。如果用户需要配置mpls te record-route或undo mpls te record-route,必须先禁用快速重路由功能。
l 快速重路由功能与以下命令互斥:mpls te resv-style ff。
l 快速重路由功能和RSVP验证功能不能同时使用。
l 如果用户在配置了快速重路由功能后又配置了RSVP-TE GR功能,快速重路由功能将失效。
# 当一条链路失效时,使能MPLS TE隧道使用一条已经存在的备份隧道。
[Sysname-Tunnel0] mpls te fast-reroute
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
【缺省级别】
2:系统级
tunnel tunnel-number:指定旁路隧道的编号。
【描述】
mpls te fast-reroute bypass-tunnel命令用来为被保护的接口指定一条或多条旁路隧道。undo mpls te fast-reroute bypass-tunnel命令用来删除配置的旁路隧道。
如果需要为被保护的接口指定多条旁路隧道,可以多次使用mpls te fast-reroute bypass-tunnel命令。最多可以为被保护的接口指定3条旁路隧道。
为接口指定旁路隧道,需要满足以下条件:
l 旁路隧道必须是up状态的;
l 被保护的接口不是路由的下一跳的出接口。
被指定为Bypass隧道后,该隧道不能做为VPN等业务的隧道使用。
# 使用隧道接口Tunnel0作为旁路隧道。
[Sysname-Vlan-interface1] mpls te fast-reroute bypass-tunnel tunnel 0
mpls te igp advertise [ hold-time value ]
undo mpls te igp advertise
Tunnel接口视图
【缺省级别】
2:系统级
hold-time value:TE隧道状态转为down后到通知网络之前等待的时间,取值范围为0~4294967295,单位为毫秒,缺省值为0毫秒。
【描述】
mpls te igp advertise命令用来将MPLS TE隧道作为链路发布到IGP网络。undo mpls te igp advertise命令用来取消配置。
缺省情况下,MPLS TE隧道不被作为链路发布到IGP网络。
mpls te igp advertise命令与mpls te igp shortcut命令互斥。
# 配置保持时间为10000毫秒。
[Sysname-Tunnel0] mpls te igp advertise hold-time 10000
mpls te igp metric { absolute value | relative value }
undo mpls te igp metric
Tunnel接口视图
【缺省级别】
2:系统级
absolute value:绝对度量模式。value,正整数,取值范围为1~65535。
relative value:相对度量模式。value,表示相对于隧道IGP度量的差异,可以是正整数、负整数或0,取值范围为-10~10,缺省值为0。
【描述】
mpls te igp metric命令用来配置MPLS TE隧道的度量值。undo mpls te igp metric命令用来恢复缺省配置。
缺省情况下,TE隧道的度量等于其IGP度量。
# 配置IGP增强的SPF计算使用MPLS TE隧道相对值-1。
[Sysname-Tunnel0] mpls te igp metric relative -1
mpls te igp shortcut [ isis | ospf ]
undo mpls te igp shortcut
Tunnel接口视图
【缺省级别】
2:系统级
isis:IS-IS协议。
ospf:OSPF协议。
【描述】
mpls te igp shortcut命令用来配置IGP在进行增强的SPF计算时,使用处于up状态的MPLS TE隧道。undo mpls te igp shortcut命令用来取消这一功能。
如果不指定IGP类型,则ospf和isis都支持
缺省情况下,IGP在进行增强的SPF计算时不使用MPLS TE隧道。
mpls te igp shortcut命令与mpls te igp advertise命令互斥。
# 配置如果Tunnel0处于up状态,则OSPF和IS-IS在进行增强的SPF计算时都要使用此隧道。
[Sysname-Tunnel0] mpls te igp shortcut
mpls te link administrative group value
undo mpls te link administrative group
【缺省级别】
2:系统级
value:链路属性,在选路时将与隧道的affinity位进行比较。可用范围为0x00000000到0xFFFFFFFF,表示32个属性,每个属性占一位,属性值为0或1。
【描述】
mpls te link administrative group命令用来配置链路管理组属性值。undo mpls te link administrative group命令用来恢复缺省配置。
缺省情况下,链路管理组属性的值为0x00000000。
接口属性被全局范围内扩散,从而可以用作隧道源端的路径选择标准。
相关配置可参考命令mpls te affinity property。
# 在接口Vlan-interface1上配置用户相关属性标志为0x00000101。
[Sysname-Vlan-interface1] mpls te link administrative group 101
mpls te loop-detection
undo mpls te loop-detection
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te loop-detection命令用来配置隧道建立时进行环路检测。undo mpls te loop-detection命令用来取消环路检测功能。
缺省情况下,不进行环路检测。
# 配置建立TE隧道时进行环路检测。
[Sysname-Tunnel0] mpls te loop-detection
mpls te metric value
undo mpls te metric
【缺省级别】
2:系统级
value:链路的TE度量值,取值范围是0~4294967295。
【描述】
mpls te metric命令用来配置链路的TE度量。undo mpls te metric命令用来取消配置。
缺省情况下,链路使用其IGP度量作为TE的度量。
相关配置可参考命令mpls te path metric-type。
# 在接口Vlan-interface1上配置链路的TE度量为20。
[Sysname-Vlan-interface1] mpls te metric 20
mpls te path { dynamic | explicit-path pathname } preference value
undo mpls te path { dynamic | explicit-path pathname }
Tunnel接口视图
【缺省级别】
2:系统级
dynamic:使用动态自动计算的路径。
explicit-path pathname:使用已经存在的显示路径。其中,pathname为MPLS-TE显式路径名称,为1~31个字符的字符串,不区分大小写。
preference value:指定路径的优先级。其中,value取值范围为1~10,数值越小,优先级越高。
【描述】
mpls te path命令用来配置隧道应用的路径及路径的优先级。undo mpls te path命令用来删除配置。
缺省情况下,隧道应用动态自动计算的路径。
l 一条MPLS TE隧道下最多可以配置10条路径。
l 不同路径的优先级不能相同。
l 优先级高的路径,将优先用于CSPF计算。
# 配置Tunnel0可以使用显式路径path1和动态自动计算的路径,优先级分别为1和2。
[Sysname-Tunnel0] mpls te path explicit-path path1 preference 1
[Sysname-Tunnel0] mpls te path dynamic preference 2
mpls te path metric-type { igp | te }
undo mpls te path metric-type
MPLS视图/Tunnel接口视图
【缺省级别】
2:系统级
igp:使用IGP度量。
te:使用TE度量。
【描述】
在MPLS视图下,mpls te path metric-type命令用来配置未配置度量类型的隧道选路时使用的链路度量类型。
在Tunnel接口视图下,mpls te path metric-type命令用来配置为当前隧道选路时使用的链路度量类型。
undo mpls te path metric-type命令只用在Tunnel接口视图下,用于恢复缺省情况。
对于MPLS视图,缺省情况下,选路时使用链路的TE度量。
对于Tunnel接口视图,缺省情况下,没有指定选路时使用的链路度量类型。
隧道优先使用本隧道接口视图下配置的链路度量类型,如果隧道接口视图下没有配置,则使用MPLS视图下的配置。
相关配置可参考命令mpls te metric。
# 对所有未指定度量类型的TE隧道,配置其在进行路径计算时使用IGP度量。
[Sysname] mpls
[Sysname-mpls] mpls te path metric-type igp
# 配置为Tunnel0隧道选路时使用IGP度量。
[Sysname-Tunnel0] mpls te path metric-type igp
mpls te periodic-tracert [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -t time-out | -u retry-attempt ] *
undo mpls te periodic-tracert
Tunnel接口视图
【缺省级别】
2:系统级
-a source-ip:指定MPLS Echo Request报文的源地址,缺省使用MPLS LSR-ID作为MPLS Echo Request报文的源地址。
-exp exp-value:指定标签的Exp值。exp-value取值范围为0~7,缺省值为0。
-h ttl-value:指定MPLS Echo Request报文携带的TTL值。ttl-value取值范围为1~255,缺省值为30。
-m wait-time:指定LSP Tracert功能的检测周期。wait-time取值范围为15~120,单位为分钟,缺省值为60分钟。
-t time-out:指定发送出MPLS Echo Request报文后等待响应的超时时间。time-out取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
-u retry-attempt:指定MPLS Echo Request报文超时重试的次数。retry-attempt取值范围为1~9,单位为次数,缺省值为3次。
【描述】
mpls te periodic-tracert命令用来使能MPLS TE隧道的周期性LSP Tracert功能。undo mpls te periodic-tracert命令用来关闭MPLS TE隧道的周期性LSP Tracert功能。
缺省情况下,未使能MPLS TE隧道的周期性LSP Tracert功能。
MPLS TE隧道的周期性LSP Tracert功能,即周期性地对MPLS TE隧道进行Tracert检测,该功能用来对MPLS TE隧道的错误进行定位,对转发平面和控制平面一致性进行检测,并通过日志记录检测结果。管理员可以通过查看日志信息,了解MPLS TE隧道是否出现故障。
如果同时配置了BFD检测MPLS TE隧道功能和MPLS TE隧道的周期性LSP Tracert功能,则MPLS TE隧道的周期性LSP Tracert检测到转发平面故障或转发平面与控制平面不一致时,会触发删除原有BFD会话,并基于控制平面重新建立BFD会话。
需要注意的是,执行本命令前,必须先通过mpls lspv命令使能LSP检测功能。
# 在隧道接口Tunnel0上使能MPLS TE隧道的周期性LSP Tracert功能。
[Sysname-Tunnel0] mpls te periodic-tracert
mpls te priority setup-priority [ hold-priority ]
undo mpls te priority
Tunnel接口视图
【缺省级别】
2:系统级
setup-priority:建立优先级,取值范围为0~7。
hold-priority:保持优先级,取值范围为0~7,缺省情况下与建立优先级相同。
【描述】
mpls te priority命令用来配置MPLS TE隧道的建立优先级和保持优先级。undo mpls te priority命令用来恢复缺省配置。
缺省情况下,建立优先级和保持优先级的值都为7。
建立优先级不能高于相应的保持优先级,即,其在数值上应大于或等于保持优先级的值。
# 配置建立优先级和保持优先级都为1。
[Sysname-Tunnel0] mpls te priority 1
mpls te record-route [ label ]
Tunnel接口视图
【缺省级别】
2:系统级
label:使能路由记录特性时包含对标签的记录。
【描述】
mpls te record-route命令用来配置隧道支持路由记录或标签记录。undo mpls te record-route命令用来取消该配置。
缺省情况下,不进行路由记录和标签记录。
# 配置MPLS TE隧道支持路由记录。
[Sysname-Tunnel0] mpls te record-route
mpls te reoptimization [ frequency seconds ]
undo mpls te reoptimization
Tunnel接口视图
【缺省级别】
2:系统级
frequency seconds:指定重优化频率,取值范围为1~604800,单位为秒,缺省值为3600秒,即1小时。
【描述】
mpls te reoptimization命令用来使能隧道重优化功能。undo mpls te reoptimization命令用来禁止此功能。
缺省情况下,未使能重优化功能。
隧道重优化功能与以下命令互斥:mpls te route-pining,mpls te backup和mpls te resv-style ff。
# 使能重优化功能,并配置每隔43200秒(12小时)重新计算路由。
[Sysname-Tunnel0] mpls te reoptimization frequency 43200
【缺省级别】
2:系统级
无
【描述】
mpls te reoptimization命令用来立即对所有使能了重优化功能的TE隧道进行重优化。
# 立即对所有使能了重优化功能的TE隧道进行重优化。
<Sysname> mpls te reoptimization
mpls te resv-style { ff | se }
undo mpls te resv-style
Tunnel接口视图
【缺省级别】
2:系统级
ff:使用FF(Fixed-Filter)样式的资源预留。
se:使用SE(Shared-Explicit)样式的资源预留。
【描述】
mpls te resv-style命令用来配置隧道的资源预留风格。undo mpls te resv-style命令用来恢复缺省情况。
缺省情况下,资源预留样式为se。
只有RSVP-TE协议才存在FF和SE两种资源预留样式。
# 使用FF资源预留样式建立CR-LSP隧道。
[Sysname-Tunnel0] mpls te resv-style ff
mpls te retry times
undo mpls te retry
Tunnel接口视图
【缺省级别】
2:系统级
times:重建次数,取值范围为1~4294967295。
【描述】
mpls te retry命令用来配置隧道重建的次数。undo mpls te retry命令用来恢复缺省配置。
缺省情况下,隧道重建的次数为10。
相关配置可参考命令mpls te timer retry。
# 配置隧道重建次数为20次。
[Sysname-Tunnel0] mpls te retry 20
mpls te route-pinning
undo mpls te route-pinning
Tunnel接口视图
【缺省级别】
2:系统级
无
【描述】
mpls te route-pinning命令用来使能路由固定(route pinning)功能。undo mpls te route-pinning命令用来禁止路由固定功能。
缺省情况下,未使能路由固定功能。
mpls te route-pining命令与mpls te reoptimization命令互斥。
# 使能路由固定功能。
[Sysname-Tunnel0] mpls te route-pinning
mpls te signal-protocol { crldp | rsvp-te | static }
Tunnel接口视图
【缺省级别】
2:系统级
crldp:使用CR-LDP作为信令协议,目前本交换机暂不支持CR-LDP协议。
rsvp-te:使用RSVP-TE作为信令协议。
static:使用静态信令协议。
【描述】
mpls te signal-protocol命令用来配置MPLS TE建立隧道使用的信令协议。
缺省情况下,配置MPLS TE建立隧道使用RSVP-TE信令协议。
如果使用RSVP-TE作为MPLS TE隧道的信令协议,那么必须在隧道经过的路径上,使能接口的MPLS TE能力的同时使能接口的RSVP-TE能力。
# 配置MPLS TE建立隧道使用RSVP-TE信令协议。
[Sysname-Tunnel0] mpls te signal-protocol rsvp-te
mpls te timer fast-reroute [ seconds]
undo mpls te timer fast-reroute
MPLS视图
【缺省级别】
2:系统级
seconds:为决定一条LSP是否应使用新的、更好的备份隧道而进行的扫描的间隔,取值范围为0~604800,单位为秒,缺省值为300秒(5分钟)。配置为0表示禁止使用更好的LSP。
【描述】
mpls te timer fast-reroute命令用来配置当备份带宽可用时,路由器每隔多长时间决定一次是否需要将LSP转移到一条更好的备份隧道。undo mpls te timer fast-reroute命令用来恢复缺省情况。
缺省情况下,扫描间隔为300秒。
# 配置每隔2分钟(120秒),对LSP进行一次扫描,决定是否需要将它们切换到更好的备份隧道。
[Sysname] mpls
[Sysname-mpls] mpls te timer fast-reroute 120
mpls te timer retry second
undo mpls te timer retry
Tunnel接口视图
【缺省级别】
2:系统级
second:隧道重建的时间间隔,取值范围为1~4294967295,单位为秒。
【描述】
mpls te timer retry命令用来配置隧道重建的时间间隔。undo mpls te timer retry命令用来恢复缺省配置。
缺省情况下,隧道重建的时间间隔为2秒。
相关配置可参考命令mpls te retry。
# 配置每隔20秒重建隧道。
[Sysname-Tunnel0] mpls te timer retry 20
mpls te tunnel-id tunnel-id
Tunnel接口视图
【缺省级别】
2:系统级
tunnel-id:隧道ID,取值范围为1~1024。
【描述】
mpls te tunnel-id命令用来配置隧道ID。
在第一次提交隧道配置mpls te commit前必须完成,否则隧道将无法创建成功。
隧道ID在配置后不能修改,如果需要修隧道ID的值,需要删除Tunnel重新进行配置。
# 配置隧道的ID为100。
[Sysname-Tunnel0] mpls te tunnel-id 100
mpls te vpn-binding { acl acl-number | vpn-instance vpn-instance-name }
undo mpls te vpn-binding
Tunnel接口视图
【缺省级别】
2:系统级
acl acl-number:指定TE隧道只转发满足此ACL过滤条件的VPN的流量。acl-number表示ACL编号,取值范围为3000~3999。
vpn-instance vpn-instance-name:指定TE隧道只转发此VPN的流量。vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。
【描述】
mpls te vpn-binding命令用来配置TE隧道转发的流量类型。undo mpls te vpn-binding命令用来恢复缺省情况。
缺省情况下,TE隧道不限制可以转发的流量类型。
# 配置隧道接口只转发实例名为vpn1的VPN的流量。
[Sysname-Tunnel0] mpls te vpn-binding vpn-instance vpn1
# 配置隧道接口只转发满足ACL过滤条件的VPN的流量。
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule 0 permit ip vpn-instance vpn1
[Sysname-acl-adv-3001] quit
[Sysname-Tunnel0] mpls te vpn-binding acl 3001
mpls-te enable
undo mpls-te
OSPF区域视图
【缺省级别】
2:系统级
enable:使能MPLS TE特性。
【描述】
mpls-te命令用来在当前OSPF区域下使能MPLS TE能力。undo mpls-te命令用来取消当前OSPF区域的MPLS TE能力。
缺省情况下,OSPF区域不支持MPLS TE能力。
为了在区域上使能MPLS TE能力,相应的OSPF进程应具备Opaque LSA能力。
相关配置可参考命令opaque-capability。
# 在OSPF区域1使能TE。
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] mpls-te enable
next hop ip-address [ include [ loose | strict ] | exclude ]
显式路径视图
【缺省级别】
2:系统级
ip-address:显式路径中的下一跳IP地址,点分十进制格式。可以是链路的IP地址,也可以是节点的Router ID。对于严格(strict)方式,只能配置链路IP.对于松散(loose)方式,链路地址则认为指明链路对应的Router。
include:在显式路径中包含下一跳IP地址。
strict:严格下一跳,即,下一跳与本节点必须直接相连。
loose:松散下一跳,即,下一跳与本节点可以不是直接相连。
exclude:在后续的部分路径段中不包括IP地址。
【描述】
next hop命令用来在显式路径中指定下一跳IP地址。
缺省情况下,显式路径中指定的下一跳为严格(strict)下一跳。
相关配置可参考命令delete hop。
# 在MPLS TE显式路径中不包括IP地址10.0.0.125。
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] next hop 10.0.0.125 exclude
opaque-capability enable
undo opaque-capability
OSPF视图
【缺省级别】
2:系统级
enable:使能Opaque LSA能力。
【描述】
opaque-capability命令用来使能OSPF的Opaque LSA能力。undo opaque-capability命令用来禁止OSPF的Opaque LSA能力。
缺省情况下,未使能OSPF的Opaque LSA能力。
使能OSPF的Opaque LSA能力后,OSPF进程可以生成Opaque LSA,并能从邻居路由器接收Opaque LSA。
# 使能OSPF的Opaque LSA能力。
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * te interface-type interface-number
【缺省级别】
0:访问级
-a source-ip:指定发送的Echo Request报文的源地址。source-ip为源IP地址。
-c count:指定发送Echo Request报文的次数。count为Echo Request报文发送次数,取值范围为1~4294967295,缺省值为5。
-exp exp-value:指定Echo Request报文中的EXP值。exp-value为EXP值,取值范围为0~7,缺省值为0。
-h ttl-value:指定Echo Request报文中的TTL值。ttl-value为TTL值,取值范围为1~255,缺省值为255。
-m wait-time:指定连续发送Echo Request报文的时间间隔。wait-time为发送报文的时间间隔,取值范围为1~10000,单位为毫秒,缺省值为200毫秒。
-r reply-mode:指定接收者对Echo Request报文的应答模式。reply-mode为应答模式,取值范围为1和2,1表示不回应,2表示使用UDP报文回应,缺省值为2。
-s packet-size:指定Echo Request报文的净荷报文长度。packet-size为净荷报文长度,取值范围为65~8100,单位为字节,缺省值为100字节。
-t time-out:指定发送Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
-v:指定显示详细的应答信息。
te interface-type interface-number:指定隧道接口类型和接口编号。
【描述】
ping lsp te命令用来检测MPLS TE隧道的有效性和可达性。
# 检测隧道接口Tunnel1对应的MPLS TE隧道的有效性和可达性。
<Sysname> ping lsp te tunnel 1
LSP Ping FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 : 100 data bytes, press CTRL_C to break
Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
Reply from 100.1.2.1: bytes=100 Sequence=3 time = 62 ms
Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
--- FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 31/55/62 ms
reset mpls rsvp-te statistics { global | interface [ interface-type interface-number ]
【缺省级别】
1:监控级
global:全局RSVP-TE。
【描述】
reset mpls rsvp-te statistics命令用来清除RSVP-TE的统计信息。
l 如果选择参数global,则清除全局RSVP-TE的统计信息;
l 如果选择参数interface,则清除所有接口RSVP-TE的统计信息;
l 如果选择参数interface interface-type interface-number,则清除指定接口RSVP-TE的统计信息。
# 清除全局RSVP-TE的统计信息。
<Sysname> reset mpls rsvp-te statistics global
static-cr-lsp egress tunnel-name incoming-interface interface-type interface-number in-label in-label-value
undo static-cr-lsp egress tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道的名字,为1~15个字符的字符串,区分大小写。
incoming-interface interface-type interface-number:指定入接口的接口类型和接口编号。
in-label in-label-value:指定入标签,取值范围为0,3,16~1023。
【描述】
static-cr-lsp egress命令用来为Egress节点配置静态CR-LSP。undo static-cr-lsp egress命令用来删除配置的静态CR-LSP。
相关配置可参考命令mpls te tunnel-id。
# 在出口节点配置静态CR-LSP,名字为tunnel34,入接口是Vlan-interface3,入口标签是233。
[Sysname] static-cr-lsp egress tunnel34 incoming-interface vlan-interface 3 in-label 233
static-cr-lsp ingress tunnel-name destination dest-addr nexthop next-hop-addr out-label out-label-value
undo static-cr-lsp ingress tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道的名字,为1~15个字符的字符串,区分大小写。tunnel-name与interface tunnel命令创建的接口名称,包括大小写,必须保持一致,否则隧道将不能建立。例如建立的隧道接口为“Tunnel2”,此处的隧道名也必须为“Tunnel2”。
destination dest-addr:指定隧道的目的IP地址。
nexthop next-hop-addr:指定下一跳IP地址。
out-label out-label-value:指定出标签值,取值范围为0,3,16~1023。
【描述】
static-cr-lsp ingress命令用来为Ingress节点配置静态CR-LSP。undo static-cr-lsp ingress命令用来删除配置的静态CR-LSP。
本地公网IP地址不能被指定为下一跳。
# 在入口节点配置静态CR-LSP。名字为Tunnel3,目的IP地址为202.25.38.1,目的地址掩码长度为24,下一跳IP地址为202.55.25.33,出口标签为237,流量所属的服务类型为CT 0,所需要的带宽为20kbit/s。
[Sysname] static-cr-lsp ingress Tunnel3 destination 202.25.38.1 nexthop 202.55.25.33 out-label 237 bandwidth ct0 20
static-cr-lsp transit tunnel-name incoming-interface interface-type interface-number in-label in-label-value { nexthop next-hop-addr | outgoing-interface interface-type interface-number } out-label out-label-value
undo static-cr-lsp transit tunnel-name
【缺省级别】
2:系统级
tunnel-name:隧道的名字,为1~15个字符的字符串。
in-label in-label-value:指定入标签值,取值范围为16~1023。
【描述】
static-cr-lsp transit命令用来为Transit节点配置静态CR-LSP。undo static-cr-lsp transit命令用来删除配置的静态CR-LSP。
本地公网IP地址不能被指定为下一跳。
# 在转发节点配置静态CR-LSP,名字为tunnel34,入接口为Vlan-interface 3,入口标签为123,出接口为Vlan-interface 4,出口标签为253。
[Sysname] static-cr-lsp transit tunnel34 incoming-interface Vlan-interface 3 in-label 123 outgoing-interface Vlan-interface 4 out-label 253
tracert lsp [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode |-t time-out ] * te interface-type interface-number
【缺省级别】
0:访问级
-a source-ip:指定Echo Request报文的源地址。source-ip为源IP地址。
-h ttl-value:指定Echo Request报文中的TTL值。ttl-value为TTL值,取值范围为1~255,缺省值为30。
-t time-out:指定发送出Echo Request报文后等待响应的超时时间。time-out为超时时间,取值范围为0~65535,单位为毫秒,缺省值为2000毫秒。
【描述】
tracert lsp te命令用来对MPLS TE隧道的错误进行定位。
# 对隧道接口Tunnel1对应的MPLS TE隧道的错误进行定位。
<Sysname> tracert lsp te tunnel 1
LSP Trace Route FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 , press CTRL_C to break.
TTL Replier Time Type Downstream
0 Ingress 10.4.5.1/[1025]
1 10.4.5.1 1 Transit 100.3.4.1/[1024]
2 100.3.4.1 63 Transit 100.1.2.1/[3]
3 100.1.2.1 129 Egress
表1-33 tracert lsp te命令显示信息描述表
TTL |
跳数 |
Replier |
应答的LSR地址 |
Time |
接收到应答的时间,单位为毫秒 |
Type |
LSR的类型,取值包括: l Ingress:入节点 l Transit:中间节点 l Egress:出节点 |
Downstream |
下游LSR地址及出标签值 |
traffic-eng [ level-1 | level-1-2 | level-2 ]
undo traffic-eng [ level-1 | level-1-2 | level-2 ]
IS-IS视图
【缺省级别】
2:系统级
level-1:配置Level-1的IS-IS TE。
level-1-2:配置Level-1和Level-2的IS-IS TE。
level-2:配置Level-2的IS-IS TE。
如果命令中不指定Level,则对Level-1-2有效。
【描述】
traffic-eng命令用来使能IS-IS TE功能。undo traffic-eng命令用来恢复缺省配置。
如果不指定中间系统IS的级别,将对Level-1-2有效。
缺省情况下,未使能IS-IS TE功能。
为了在IS-IS进程使用TE特性,必须将IS-IS报文的cost类型配置为wide、compatible或wide-compatible,使用的命令是IS-IS视图下的cost-style,这条命令的详细介绍请参考“IP路由分册”中的“IS-IS命令”。
# 在IS-IS进程1的Level-2上使能TE功能。
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] traffic-eng level-2
