50-附录
本章节下载: 50-附录 (121.31 KB)
本命令索引包括手册中所出现的全部命令,按字母序排列,左边为命令行,右边为该命令所在的功能模块和页码。
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
abr-summary |
16-路由协议命令 |
4-1 |
access-limit |
19-AAA命令 |
1-1 |
accounting |
19-AAA命令 |
1-2 |
accounting domain |
24-DHCP命令 |
1-1 |
accounting optional |
19-AAA命令 |
1-3 |
19-AAA命令 |
1-24 |
accounting-on enable |
19-AAA命令 |
1-25 |
acl |
02-登录交换机命令 |
2-1 |
acl |
25-ACL命令 |
1-1 |
active region-configuration |
15-MSTP命令 |
1-1 |
add-member |
30-Cluster命令 |
1-12 |
address-check |
24-DHCP命令 |
2-1 |
administrator-address |
30-Cluster命令 |
1-12 |
adv-factor |
41-HWPing命令 |
1-1 |
am enable |
45-访问管理命令 |
1-1 |
am ip-pool |
45-访问管理命令 |
1-1 |
am trap enable |
45-访问管理命令 |
1-2 |
am user-bind |
11-端口安全-端口绑定命令 |
2-1 |
apply cost |
16-路由协议命令 |
5-1 |
apply poe-profile |
31-PoE-PoE Profile命令 |
2-1 |
apply qos-profile |
26-QoS-QoS Profile命令 |
2-1 |
apply tag |
16-路由协议命令 |
5-1 |
area |
16-路由协议命令 |
4-2 |
arp anti-attack valid-check enable |
23-ARP命令 |
2-1 |
arp check enable |
23-ARP命令 |
1-1 |
arp detection enable |
23-ARP命令 |
2-1 |
arp detection trust |
23-ARP命令 |
2-2 |
arp filter binding |
23-ARP命令 |
2-3 |
arp filter source |
23-ARP命令 |
2-2 |
arp mac-forced-forwarding |
23-ARP命令 |
5-1 |
arp mac-forced-forwarding network-port |
23-ARP命令 |
5-1 |
arp mac-forced-forwarding server |
23-ARP命令 |
5-2 |
arp mac-forced-forwarding user-port |
23-ARP命令 |
5-3 |
arp max-learning-num |
23-ARP命令 |
2-4 |
arp protective-down recover enable |
23-ARP命令 |
2-4 |
arp protective-down recover interval |
23-ARP命令 |
2-5 |
arp proxy enable |
23-ARP命令 |
3-1 |
arp rate-limit |
23-ARP命令 |
2-5 |
arp rate-limit enable |
23-ARP命令 |
2-6 |
arp restricted-forwarding enable |
23-ARP命令 |
2-7 |
arp send-gratuitous enable vrrp |
23-ARP命令 |
1-1 |
arp static |
23-ARP命令 |
1-2 |
arp timer aging |
23-ARP命令 |
1-3 |
asbr-summary |
16-路由协议命令 |
4-2 |
ascii |
37-FTP-SFTP-TFTP命令 |
1-7 |
attribute |
19-AAA命令 |
1-1 |
attribute |
47-PKI命令 |
1-1 |
attribute-ignore |
19-AAA命令 |
1-26 |
authentication |
19-AAA命令 |
1-4 |
authentication super |
19-AAA命令 |
1-5 |
authentication-mode |
02-登录交换机命令 |
1-1 |
16-路由协议命令 |
4-3 |
authorization |
19-AAA命令 |
1-6 |
authorization vlan |
19-AAA命令 |
1-7 |
auto-build |
30-Cluster命令 |
1-13 |
auto-execute command |
02-登录交换机命令 |
1-3 |
backup current-configuration |
36-文件系统管理命令 |
1-20 |
bims-server |
24-DHCP命令 |
1-2 |
binary |
1-7 |
black-list |
30-Cluster命令 |
1-39 |
boot attribute-switch |
36-文件系统管理命令 |
1-15 |
boot boot-loader |
36-文件系统管理命令 |
1-16 |
boot boot-loader |
39-系统维护与调试命令 |
3-1 |
boot boot-loader backup-attribute |
36-文件系统管理命令 |
1-17 |
boot bootrom |
39-系统维护与调试命令 |
3-1 |
boot web-package |
36-文件系统管理命令 |
1-18 |
bootfile-name |
24-DHCP命令 |
1-2 |
bpdu-drop any |
15-MSTP命令 |
1-1 |
bpdu-tunnel |
40-VLAN-VPN命令 |
3-1 |
bpdu-tunnel tunnel-dmac |
40-VLAN-VPN命令 |
3-2 |
broadcast-suppression |
08-端口基本配置命令 |
1-1 |
bsr-policy |
17-组播协议命令 |
3-1 |
build |
30-Cluster命令 |
1-15 |
burst-mode enable |
1-1 |
bye |
1-7 |
bye |
1-24 |
ca identifier |
47-PKI命令 |
1-2 |
cache-sa-enable |
17-组播协议命令 |
4-1 |
calling-station-id mode |
19-AAA命令 |
1-27 |
c-bsr |
17-组播协议命令 |
3-2 |
cd |
36-文件系统管理命令 |
1-1 |
cd |
1-8 |
cd |
1-25 |
cdup |
1-8 |
cdup |
1-25 |
certificate request entity |
47-PKI命令 |
1-2 |
certificate request from |
47-PKI命令 |
1-3 |
certificate request mode |
47-PKI命令 |
1-3 |
certificate request polling |
47-PKI命令 |
1-4 |
certificate request url |
47-PKI命令 |
1-5 |
change self-unit |
29-IRF Fabric命令 |
1-1 |
change unit-id |
29-IRF Fabric命令 |
1-2 |
check region-configuration |
15-MSTP命令 |
1-2 |
checkzero |
16-路由协议命令 |
3-1 |
ciphersuite |
48-SSL命令 |
1-1 |
client-verify enable |
48-SSL命令 |
1-1 |
clock datetime |
39-系统维护与调试命令 |
1-1 |
clock summer-time |
39-系统维护与调试命令 |
1-1 |
clock timezone |
39-系统维护与调试命令 |
1-2 |
close |
1-9 |
close-mode wait |
48-SSL命令 |
1-2 |
cluster |
30-Cluster命令 |
1-16 |
cluster enable |
30-Cluster命令 |
1-17 |
cluster switch-to |
30-Cluster命令 |
1-17 |
cluster-local-user |
30-Cluster命令 |
1-18 |
cluster-mac |
30-Cluster命令 |
1-19 |
cluster-mac syn-interval |
30-Cluster命令 |
1-20 |
cluster-snmp-agent community |
30-Cluster命令 |
1-21 |
cluster-snmp-agent group v3 |
30-Cluster命令 |
1-21 |
cluster-snmp-agent mib-view included |
30-Cluster命令 |
1-22 |
cluster-snmp-agent usm-user v3 |
30-Cluster命令 |
1-23 |
command-alias enable |
01-CLI命令 |
1-1 |
command-alias mapping |
01-CLI命令 |
1-1 |
command-privilege level |
01-CLI命令 |
1-2 |
common-name |
47-PKI命令 |
1-5 |
copy |
36-文件系统管理命令 |
1-2 |
copy configuration |
08-端口基本配置命令 |
1-2 |
copyright-info enable |
02-登录交换机命令 |
1-3 |
count |
41-HWPing命令 |
1-1 |
country |
47-PKI命令 |
1-6 |
crl check |
47-PKI命令 |
1-6 |
crl update-period |
47-PKI命令 |
1-7 |
crl url |
47-PKI命令 |
1-7 |
c-rp |
17-组播协议命令 |
3-2 |
crp-policy |
17-组播协议命令 |
3-3 |
cut connection |
19-AAA命令 |
1-7 |
databits |
02-登录交换机命令 |
1-4 |
datafill |
41-HWPing命令 |
1-2 |
data-flow-format |
19-AAA命令 |
1-28 |
data-flow-format |
19-AAA命令 |
1-52 |
datasize |
41-HWPing命令 |
1-3 |
debugging |
39-系统维护与调试命令 |
1-6 |
default |
16-路由协议命令 |
4-4 |
default cost |
16-路由协议命令 |
3-1 |
default-cost |
16-路由协议命令 |
4-5 |
default-route-advertise |
16-路由协议命令 |
4-6 |
delete |
36-文件系统管理命令 |
1-2 |
delete |
1-9 |
delete |
1-26 |
delete static-routes all |
16-路由协议命令 |
2-1 |
delete-member |
30-Cluster命令 |
1-24 |
description |
04-VLAN命令 |
1-1 |
description |
08-端口基本配置命令 |
1-4 |
description |
25-ACL命令 |
1-2 |
description |
41-HWPing命令 |
1-4 |
destination-ip |
41-HWPing命令 |
1-5 |
destination-port |
41-HWPing命令 |
1-5 |
detect-group |
14-自动侦测命令 |
1-1 |
detect-list |
14-自动侦测命令 |
1-1 |
dhcp enable |
24-DHCP命令 |
1-3 |
dhcp protective-down recover enable |
24-DHCP命令 |
4-1 |
dhcp protective-down recover interval |
24-DHCP命令 |
4-1 |
dhcp rate-limit |
24-DHCP命令 |
4-2 |
dhcp rate-limit enable |
24-DHCP命令 |
4-3 |
dhcp relay hand |
24-DHCP命令 |
2-1 |
dhcp relay inform replace enable |
24-DHCP命令 |
2-2 |
dhcp relay information enable |
24-DHCP命令 |
2-3 |
dhcp relay information strategy |
24-DHCP命令 |
2-3 |
dhcp select global |
24-DHCP命令 |
1-4 |
dhcp select interface |
24-DHCP命令 |
1-5 |
dhcp server bims-server |
24-DHCP命令 |
1-6 |
dhcp server bootfile-name |
24-DHCP命令 |
1-7 |
dhcp server detect |
24-DHCP命令 |
1-8 |
dhcp server dns-list |
24-DHCP命令 |
1-8 |
dhcp server domain-name |
24-DHCP命令 |
1-9 |
dhcp server expired |
24-DHCP命令 |
1-10 |
dhcp server forbidden-ip |
24-DHCP命令 |
1-11 |
dhcp server ip-pool |
24-DHCP命令 |
1-12 |
dhcp server nbns-list |
24-DHCP命令 |
1-13 |
dhcp server netbios-type |
24-DHCP命令 |
1-14 |
dhcp server option |
24-DHCP命令 |
1-15 |
dhcp server ping |
24-DHCP命令 |
1-16 |
dhcp server relay information enable |
24-DHCP命令 |
1-16 |
dhcp server static-bind |
24-DHCP命令 |
1-17 |
dhcp server tftp-server domain-name |
24-DHCP命令 |
1-18 |
dhcp server tftp-server ip-address |
24-DHCP命令 |
1-19 |
dhcp server voice-config |
24-DHCP命令 |
1-20 |
dhcp-security static |
24-DHCP命令 |
2-4 |
dhcp-security tracker |
24-DHCP命令 |
2-5 |
dhcp-server |
24-DHCP命令 |
2-5 |
dhcp-server detect |
24-DHCP命令 |
2-6 |
dhcp-server ip |
24-DHCP命令 |
2-7 |
dhcp-snooping |
24-DHCP命令 |
3-1 |
dhcp-snooping information enable |
24-DHCP命令 |
3-1 |
dhcp-snooping information format |
24-DHCP命令 |
3-2 |
dhcp-snooping information packet-format |
24-DHCP命令 |
3-3 |
dhcp-snooping information remote-id |
24-DHCP命令 |
3-3 |
dhcp-snooping information strategy |
24-DHCP命令 |
3-4 |
dhcp-snooping information vlan circuit-id |
24-DHCP命令 |
3-5 |
dhcp-snooping information vlan remote-id |
24-DHCP命令 |
3-5 |
dhcp-snooping trust |
24-DHCP命令 |
3-6 |
dir |
36-文件系统管理命令 |
1-4 |
dir |
1-10 |
dir |
1-26 |
disconnect |
1-11 |
display acl |
25-ACL命令 |
1-3 |
display am |
45-访问管理命令 |
1-3 |
display am user-bind |
11-端口安全-端口绑定命令 |
2-2 |
display arp |
23-ARP命令 |
1-3 |
display arp | |
23-ARP命令 |
1-4 |
display arp count |
23-ARP命令 |
1-5 |
display arp detection statistics interface |
23-ARP命令 |
2-7 |
display arp mac-forced-forwarding interface |
23-ARP命令 |
5-3 |
display arp mac-forced-forwarding vlan |
23-ARP命令 |
5-4 |
display arp proxy |
23-ARP命令 |
3-1 |
display arp timer aging |
23-ARP命令 |
1-6 |
display boot-loader |
36-文件系统管理命令 |
1-18 |
39-系统维护与调试命令 |
3-2 |
display bootp client |
24-DHCP命令 |
5-3 |
display bpdu-tunnel |
40-VLAN-VPN命令 |
3-3 |
display brief interface |
08-端口基本配置命令 |
1-4 |
display channel |
38-信息中心命令 |
1-1 |
display clock |
39-系统维护与调试命令 |
1-4 |
display cluster |
30-Cluster命令 |
1-25 |
display cluster base-members |
30-Cluster命令 |
1-40 |
display cluster base-topology |
30-Cluster命令 |
1-41 |
display cluster black-list |
30-Cluster命令 |
1-42 |
display cluster candidates |
30-Cluster命令 |
1-26 |
display cluster current-topology |
30-Cluster命令 |
1-43 |
display cluster members |
30-Cluster命令 |
1-28 |
display command-alias |
01-CLI命令 |
1-5 |
display connection |
19-AAA命令 |
1-8 |
display cpu |
39-系统维护与调试命令 |
3-2 |
display current-configuration |
03-配置文件管理命令 |
1-1 |
display current-configuration vlan |
03-配置文件管理命令 |
1-5 |
display debugging |
39-系统维护与调试命令 |
1-4 |
display detect-group |
14-自动侦测命令 |
1-2 |
display device |
39-系统维护与调试命令 |
3-3 |
display dhcp client |
24-DHCP命令 |
5-1 |
display dhcp server conflict |
24-DHCP命令 |
1-21 |
display dhcp server expired |
24-DHCP命令 |
1-21 |
display dhcp server free-ip |
24-DHCP命令 |
1-22 |
display dhcp server ip-in-use |
24-DHCP命令 |
1-23 |
display dhcp server statistics |
24-DHCP命令 |
1-24 |
display dhcp server tree |
24-DHCP命令 |
1-25 |
display dhcp-security |
24-DHCP命令 |
2-7 |
display dhcp-server |
24-DHCP命令 |
2-8 |
display dhcp-server interface |
24-DHCP命令 |
2-10 |
display dhcp-snooping |
24-DHCP命令 |
3-7 |
display dhcp-snooping trust |
24-DHCP命令 |
3-8 |
display diagnostic-information |
39-系统维护与调试命令 |
1-6 |
display dldp |
12-DLDP命令 |
1-1 |
display dns domain |
43-域名解析命令 |
1-1 |
display dns dynamic-host |
43-域名解析命令 |
1-1 |
display dns ipv6 dynamic-host |
42-IPv6管理命令 |
1-1 |
display dns server |
43-域名解析命令 |
1-2 |
display domain |
19-AAA命令 |
1-10 |
display dot1x |
18-802.1x及System-Guard命令 |
1-1 |
display drv qacl_resource |
25-ACL命令 |
1-4 |
display fan |
39-系统维护与调试命令 |
3-4 |
display fib |
05-IP地址-IP性能命令 |
2-1 |
display fib | |
05-IP地址-IP性能命令 |
2-3 |
display fib acl |
05-IP地址-IP性能命令 |
2-3 |
display fib ip-address |
05-IP地址-IP性能命令 |
2-2 |
display fib ip-prefix |
05-IP地址-IP性能命令 |
2-4 |
display fib statistics |
05-IP地址-IP性能命令 |
2-5 |
display ftm |
29-IRF Fabric命令 |
1-3 |
display ftp source-ip |
1-11 |
display ftp-server |
1-1 |
display ftp-server source-ip |
1-2 |
display ftp-user |
1-2 |
display garp statistics |
07-GVRP命令 |
1-1 |
display garp timer |
07-GVRP命令 |
1-2 |
display gvrp statistics |
07-GVRP命令 |
1-5 |
display gvrp status |
07-GVRP命令 |
1-6 |
display habp |
3-1 |
display habp table |
3-1 |
display habp traffic |
3-2 |
display history-command |
01-CLI命令 |
1-5 |
display hwping |
41-HWPing命令 |
1-6 |
display hwping statistics |
41-HWPing命令 |
1-11 |
display hwtacacs |
19-AAA命令 |
1-53 |
display icmp statistics |
05-IP地址-IP性能命令 |
2-5 |
display igmp group |
17-组播协议命令 |
2-1 |
display igmp interface |
17-组播协议命令 |
2-2 |
display igmp-snooping configuration |
17-组播协议命令 |
5-1 |
display igmp-snooping group |
17-组播协议命令 |
5-2 |
display igmp-snooping statistics |
17-组播协议命令 |
5-3 |
display info-center |
38-信息中心命令 |
1-1 |
display interface |
08-端口基本配置命令 |
1-6 |
display interface Vlan-interface |
04-VLAN命令 |
1-1 |
display ip host |
43-域名解析命令 |
1-3 |
display ip https |
49-HTTPS命令 |
1-1 |
display ip interface |
05-IP地址-IP性能命令 |
1-1 |
display ip interface brief |
05-IP地址-IP性能命令 |
1-2 |
display ip ip-prefix |
16-路由协议命令 |
5-2 |
display ip routing-table |
16-路由协议命令 |
1-1 |
display ip routing-table acl |
16-路由协议命令 |
1-3 |
display ip routing-table ip-address |
16-路由协议命令 |
1-4 |
display ip routing-table ip-address1 ip-address2 |
16-路由协议命令 |
1-6 |
display ip routing-table ip-prefix |
16-路由协议命令 |
1-6 |
display ip routing-table protocol |
16-路由协议命令 |
1-7 |
display ip routing-table radix |
16-路由协议命令 |
1-8 |
display ip routing-table statistics |
16-路由协议命令 |
1-9 |
display ip routing-table verbose |
16-路由协议命令 |
1-10 |
display ip socket |
05-IP地址-IP性能命令 |
2-7 |
display ip source static binding |
24-DHCP命令 |
3-8 |
display ip statistics |
05-IP地址-IP性能命令 |
2-8 |
display ipv6 fib |
42-IPv6管理命令 |
1-2 |
display ipv6 host |
42-IPv6管理命令 |
1-3 |
display ipv6 interface |
42-IPv6管理命令 |
1-4 |
display ipv6 neighbors |
42-IPv6管理命令 |
1-6 |
display ipv6 neighbors count |
42-IPv6管理命令 |
1-7 |
display ipv6 route-table |
42-IPv6管理命令 |
1-8 |
display ipv6 socket |
42-IPv6管理命令 |
1-9 |
display ipv6 statistics |
42-IPv6管理命令 |
1-11 |
display irf-fabric |
29-IRF Fabric命令 |
1-6 |
display isolate port |
10-端口隔离命令 |
1-1 |
display job |
39-系统维护与调试命令 |
22 |
display lacp system-id |
09-端口汇聚命令 |
1-4 |
display link-aggregation interface |
09-端口汇聚命令 |
1-1 |
display link-aggregation summary |
09-端口汇聚命令 |
1-2 |
display link-aggregation verbose |
09-端口汇聚命令 |
1-3 |
display link-delay |
08-端口基本配置命令 |
1-9 |
display lldp local-information |
46-LLDP命令 |
1-1 |
display lldp neighbor-information |
46-LLDP命令 |
1-5 |
display lldp statistics |
46-LLDP命令 |
1-8 |
display lldp status |
46-LLDP命令 |
1-10 |
display lldp tlv-config |
46-LLDP命令 |
1-11 |
display local-server statistics |
19-AAA命令 |
1-29 |
display local-user |
19-AAA命令 |
1-11 |
display logbuffer |
38-信息中心命令 |
1-3 |
display logbuffer summary |
38-信息中心命令 |
1-4 |
display loopback-detection |
08-端口基本配置命令 |
1-10 |
display mac-address |
13-MAC地址转发表管理命令 |
1-1 |
display mac-address aging-time |
13-MAC地址转发表管理命令 |
1-1 |
display mac-address multicast static |
17-组播协议命令 |
1-1 |
display mac-address security |
11-端口安全-端口绑定命令 |
1-1 |
display mac-authentication |
21-MAC地址认证命令 |
1-1 |
display memory |
16-路由协议命令 |
6-1 |
display memory |
39-系统维护与调试命令 |
3-4 |
display memory limit |
16-路由协议命令 |
6-2 |
display mirror |
28-镜像命令 |
1-1 |
display mirroring-group |
28-镜像命令 |
1-2 |
display monitor-link group |
44-Smart Link-Monitor Link命令 |
2-1 |
display mpm forwarding-table |
17-组播协议命令 |
1-2 |
display mpm group |
17-组播协议命令 |
1-3 |
display msdp brief |
17-组播协议命令 |
4-1 |
display msdp peer-status |
17-组播协议命令 |
4-2 |
display msdp sa-cache |
17-组播协议命令 |
4-4 |
display msdp sa-count |
17-组播协议命令 |
4-5 |
display multicast forwarding-table |
17-组播协议命令 |
1-4 |
display multicast routing-table |
17-组播协议命令 |
1-5 |
display multicast-source-deny |
17-组播协议命令 |
1-7 |
display ndp |
30-Cluster命令 |
1-1 |
display ntdp |
30-Cluster命令 |
1-5 |
display ntdp device-list |
30-Cluster命令 |
1-6 |
display ntdp single-device mac-address |
30-Cluster命令 |
1-42 |
display ntp-service sessions |
34-NTP命令 |
1-1 |
display ntp-service status |
34-NTP命令 |
1-2 |
display ntp-service trace |
34-NTP命令 |
1-3 |
display ospf abr-asbr |
16-路由协议命令 |
4-7 |
display ospf asbr-summary |
16-路由协议命令 |
4-8 |
display ospf brief |
16-路由协议命令 |
4-9 |
display ospf cumulative |
16-路由协议命令 |
4-11 |
display ospf error |
16-路由协议命令 |
4-13 |
display ospf interface |
16-路由协议命令 |
4-15 |
display ospf lsdb |
16-路由协议命令 |
4-17 |
display ospf nexthop |
16-路由协议命令 |
4-19 |
display ospf peer |
16-路由协议命令 |
4-20 |
display ospf request-queue |
16-路由协议命令 |
4-22 |
display ospf retrans-queue |
16-路由协议命令 |
4-23 |
display ospf routing |
16-路由协议命令 |
4-24 |
display ospf vlink |
16-路由协议命令 |
4-25 |
display packet-drop |
08-端口基本配置命令 |
1-10 |
display packet-filter |
25-ACL命令 |
1-5 |
display patch-information |
39-系统维护与调试命令 |
3-6 |
display pim bsr-info |
17-组播协议命令 |
3-4 |
display pim interface |
17-组播协议命令 |
3-5 |
display pim neighbor |
17-组播协议命令 |
3-6 |
display pim routing-table |
17-组播协议命令 |
3-6 |
display pim rp-info |
17-组播协议命令 |
3-8 |
display pki certificate |
47-PKI命令 |
1-8 |
display pki certificate access-control-policy |
47-PKI命令 |
1-9 |
display pki certificate attribute-group |
47-PKI命令 |
1-10 |
display pki crl domain |
47-PKI命令 |
1-11 |
display poe interface |
1-1 |
display poe interface power |
1-3 |
display poe powersupply |
1-4 |
display poe temperature-protection |
1-5 |
display poe-profile |
2-2 |
display port |
04-VLAN命令 |
1-8 |
display port vlan-vpn |
40-VLAN-VPN命令 |
1-1 |
display port-mac |
13-MAC地址转发表管理命令 |
1-3 |
display port-security |
11-端口安全-端口绑定命令 |
1-2 |
display power |
39-系统维护与调试命令 |
3-7 |
display protocol-priority |
1-2 |
display protocol-vlan interface |
04-VLAN命令 |
1-13 |
display protocol-vlan vlan |
04-VLAN命令 |
1-14 |
display public-key local |
35-SSH命令 |
1-1 |
display public-key peer |
35-SSH命令 |
1-2 |
display qos cos-local-precedence-map |
1-2 |
display qos-interface all |
1-3 |
display qos-interface line-rate |
1-5 |
display qos-interface mirrored-to |
1-6 |
display qos-interface traffic-limit |
1-7 |
display qos-interface traffic-priority |
1-7 |
display qos-interface traffic-redirect |
1-8 |
display qos-interface traffic-remark-vlanid |
1-8 |
display qos-interface traffic-statistic |
1-9 |
display qos-profile |
2-2 |
display queue-scheduler |
1-10 |
display radius scheme |
19-AAA命令 |
1-29 |
display radius statistics |
19-AAA命令 |
1-31 |
display resilient-arp |
23-ARP命令 |
4-1 |
display rip |
16-路由协议命令 |
3-2 |
display rip interface |
16-路由协议命令 |
3-3 |
display rip routing |
16-路由协议命令 |
3-4 |
display rmon alarm |
33-SNMP-RMON命令 |
2-1 |
display rmon event |
33-SNMP-RMON命令 |
2-2 |
display rmon eventlog |
33-SNMP-RMON命令 |
2-3 |
display rmon history |
33-SNMP-RMON命令 |
2-4 |
display rmon prialarm |
33-SNMP-RMON命令 |
2-5 |
display rmon statistics |
33-SNMP-RMON命令 |
2-6 |
display route-policy |
16-路由协议命令 |
5-3 |
display router id |
16-路由协议命令 |
4-7 |
display rsa local-key-pair public |
35-SSH命令 |
1-4 |
display rsa peer-public-key |
35-SSH命令 |
1-5 |
display saved-configuration |
03-配置文件管理命令 |
1-6 |
display schedule reboot |
39-系统维护与调试命令 |
3-7 |
display sftp source-ip |
1-27 |
display smart-link flush |
1-1 |
display smart-link group |
1-2 |
display snmp-agent |
33-SNMP-RMON命令 |
1-1 |
display snmp-agent community |
33-SNMP-RMON命令 |
1-1 |
display snmp-agent group |
33-SNMP-RMON命令 |
1-2 |
display snmp-agent mib-view |
33-SNMP-RMON命令 |
1-3 |
display snmp-agent statistics |
33-SNMP-RMON命令 |
1-5 |
display snmp-agent sys-info |
33-SNMP-RMON命令 |
1-6 |
display snmp-agent trap-list |
33-SNMP-RMON命令 |
1-7 |
display snmp-agent usm-user |
33-SNMP-RMON命令 |
1-8 |
display ssh server |
35-SSH命令 |
1-6 |
display ssh server-info |
35-SSH命令 |
1-7 |
display ssh user-information |
35-SSH命令 |
1-8 |
display ssh2 source-ip |
35-SSH命令 |
1-9 |
display ssh-server source-ip |
35-SSH命令 |
1-9 |
display ssl client-policy |
48-SSL命令 |
1-3 |
display ssl server-policy |
48-SSL命令 |
1-3 |
display startup |
03-配置文件管理命令 |
1-9 |
display stop-accounting-buffer |
19-AAA命令 |
1-33 |
19-AAA命令 |
1-54 |
display storm-constrain |
08-端口基本配置命令 |
1-11 |
display stp |
15-MSTP命令 |
1-3 |
display stp abnormalport |
15-MSTP命令 |
1-7 |
display stp portdown |
15-MSTP命令 |
1-7 |
display stp region-configuration |
15-MSTP命令 |
1-8 |
display stp root |
15-MSTP命令 |
1-9 |
display system-guard ip state |
4-1 |
display system-guard ip-record |
4-2 |
display system-guard l3err state |
4-2 |
display system-guard tcn state |
4-3 |
display tcp ipv6 statistics |
42-IPv6管理命令 |
1-13 |
display tcp ipv6 status |
42-IPv6管理命令 |
1-15 |
display tcp statistics |
05-IP地址-IP性能命令 |
2-9 |
display tcp status |
05-IP地址-IP性能命令 |
2-12 |
display telnet source-ip |
02-登录交换机命令 |
1-5 |
display telnet-server source-ip |
02-登录交换机命令 |
1-5 |
display tftp source-ip |
2-1 |
display this |
03-配置文件管理命令 |
1-10 |
display time-range |
25-ACL命令 |
1-6 |
display transceiver alarm interface |
39-系统维护与调试命令 |
3-8 |
display transceiver diagnosis interface |
39-系统维护与调试命令 |
3-10 |
display transceiver interface |
39-系统维护与调试命令 |
3-11 |
display transceiver manuinfo interface |
39-系统维护与调试命令 |
3-12 |
display trapbuffer |
38-信息中心命令 |
1-5 |
display udp ipv6 statistics |
42-IPv6管理命令 |
1-16 |
display udp statistics |
05-IP地址-IP性能命令 |
2-12 |
display udp-helper server |
32-UDP Helper命令 |
1-1 |
display unit |
08-端口基本配置命令 |
1-12 |
display user-interface |
02-登录交换机命令 |
1-6 |
display users |
02-登录交换机命令 |
1-8 |
display version |
39-系统维护与调试命令 |
1-5 |
display vlan |
04-VLAN命令 |
1-3 |
display vlan |
06-Voice VLAN命令 |
1-3 |
display voice vlan error-info |
06-Voice VLAN命令 |
1-1 |
display voice vlan oui |
06-Voice VLAN命令 |
1-1 |
display voice vlan status |
06-Voice VLAN命令 |
1-2 |
display vrrp |
22-VRRP命令 |
1-1 |
display vrrp statistics |
22-VRRP命令 |
1-3 |
display web package |
36-文件系统管理命令 |
1-19 |
display web users |
02-登录交换机命令 |
1-8 |
display web-authentication configuration |
20-Web认证命令 |
1-1 |
display web-authentication connection |
20-Web认证命令 |
1-2 |
display webcache |
27-Web Cache重定向命令 |
1-1 |
dldp |
12-DLDP命令 |
1-2 |
dldp authentication-mode |
12-DLDP命令 |
1-3 |
dldp delaydown-timer |
12-DLDP命令 |
1-7 |
dldp interval |
12-DLDP命令 |
1-4 |
dldp reset |
12-DLDP命令 |
1-5 |
dldp unidirectional-shutdown |
12-DLDP命令 |
1-5 |
dldp work-mode |
12-DLDP命令 |
1-6 |
dns domain |
43-域名解析命令 |
1-4 |
dns resolve |
43-域名解析命令 |
1-4 |
dns resolve-target |
41-HWPing命令 |
1-14 |
dns server |
43-域名解析命令 |
1-5 |
dns server ipv6 |
42-IPv6管理命令 |
1-17 |
dns-list |
24-DHCP命令 |
1-27 |
dns-server |
41-HWPing命令 |
1-13 |
domain |
19-AAA命令 |
1-12 |
domain delimiter |
19-AAA命令 |
1-13 |
domain-name |
24-DHCP命令 |
1-27 |
dot1x |
1-4 |
dot1x authentication-method |
1-5 |
dot1x dhcp-launch |
1-6 |
dot1x free-ip |
2-1 |
dot1x guest-vlan |
1-6 |
dot1x handshake |
1-7 |
dot1x handshake secure |
1-8 |
dot1x max-user |
1-9 |
dot1x port-control |
1-9 |
dot1x port-method |
1-10 |
dot1x quiet-period |
1-11 |
dot1x re-authenticate |
1-13 |
dot1x retry |
1-12 |
dot1x retry-version-max |
1-12 |
dot1x supp-proxy-check |
1-14 |
dot1x timer |
1-15 |
dot1x timer acl-timeout |
2-1 |
dot1x timer reauth-period |
1-17 |
dot1x url |
2-2 |
dot1x version-check |
1-17 |
duplex |
08-端口基本配置命令 |
1-14 |
enable log updown |
08-端口基本配置命令 |
1-14 |
enable snmp trap updown |
33-SNMP-RMON命令 |
1-9 |
execute |
36-文件系统管理命令 |
1-6 |
exit |
1-27 |
expired |
24-DHCP命令 |
1-28 |
fabric member-auto-update software enable |
29-IRF Fabric命令 |
1-7 |
fabric save-unit-id |
29-IRF Fabric命令 |
1-8 |
fabric-port enable |
29-IRF Fabric命令 |
1-10 |
file prompt |
36-文件系统管理命令 |
1-6 |
filename |
41-HWPing命令 |
1-15 |
filesize |
41-HWPing命令 |
1-15 |
filter-policy export |
16-路由协议命令 |
3-5 |
16-路由协议命令 |
4-26 |
filter-policy import |
16-路由协议命令 |
3-6 |
16-路由协议命令 |
4-27 |
fixdisk |
36-文件系统管理命令 |
1-7 |
flow-control |
08-端口基本配置命令 |
1-15 |
flow-control no-pauseframe-sending |
08-端口基本配置命令 |
1-16 |
flow-interval |
08-端口基本配置命令 |
1-16 |
flush enable control-vlan |
1-2 |
format |
36-文件系统管理命令 |
1-8 |
fqdn |
47-PKI命令 |
1-12 |
free user-interface |
02-登录交换机命令 |
1-9 |
free web-users |
02-登录交换机命令 |
2-1 |
frequency |
41-HWPing命令 |
1-16 |
ftm fabric-vlan |
29-IRF Fabric命令 |
1-11 |
ftp |
1-12 |
ftp { cluster | remote-server } source-interface |
1-13 |
ftp { cluster | remote-server } source-ip |
1-13 |
ftp cluster |
30-Cluster命令 |
1-30 |
ftp disconnect |
1-3 |
ftp server enable |
1-4 |
ftp source-interface |
1-14 |
ftp source-ip |
1-14 |
ftp timeout |
1-4 |
ftp-operation |
41-HWPing命令 |
1-17 |
ftp-server |
30-Cluster命令 |
1-30 |
ftp-server source-interface |
1-5 |
1-6 |
garp timer |
07-GVRP命令 |
1-3 |
garp timer leaveall |
07-GVRP命令 |
1-4 |
gateway-list |
24-DHCP命令 |
1-28 |
get |
1-15 |
get |
1-28 |
giant-frame statistics enable |
08-端口基本配置命令 |
1-17 |
gratuitous-arp period-resending enable |
23-ARP命令 |
1-6 |
gratuitous-arp-learning enable |
23-ARP命令 |
1-7 |
gvrp |
07-GVRP命令 |
1-6 |
gvrp registration |
07-GVRP命令 |
1-7 |
habp enable |
3-3 |
habp server vlan |
3-3 |
habp timer |
3-4 |
handshake timeout |
48-SSL命令 |
1-4 |
header |
02-登录交换机命令 |
1-10 |
help |
1-28 |
history keep-time |
41-HWPing命令 |
1-17 |
history-command max-size |
02-登录交换机命令 |
1-11 |
history-record enable |
41-HWPing命令 |
1-18 |
history-records |
41-HWPing命令 |
1-18 |
holdtime |
30-Cluster命令 |
1-31 |
host-route |
16-路由协议命令 |
3-7 |
http-operation |
41-HWPing命令 |
1-19 |
http-string |
41-HWPing命令 |
1-20 |
hwping |
41-HWPing命令 |
1-20 |
hwping-agent clear |
41-HWPing命令 |
1-21 |
hwping-agent enable |
41-HWPing命令 |
1-21 |
hwping-agent max-requests |
41-HWPing命令 |
1-22 |
hwping-server enable |
41-HWPing命令 |
1-35 |
hwping-server tcpconnect |
41-HWPing命令 |
1-35 |
hwping-server udpecho |
41-HWPing命令 |
1-36 |
hwtacacs nas-ip |
19-AAA命令 |
1-55 |
hwtacacs scheme |
19-AAA命令 |
1-55 |
icmp redirect send |
05-IP地址-IP性能命令 |
2-13 |
icmp unreach send |
05-IP地址-IP性能命令 |
2-14 |
idle-cut |
19-AAA命令 |
1-14 |
idle-timeout |
02-登录交换机命令 |
1-12 |
if-match { acl | ip-prefix } |
16-路由协议命令 |
5-4 |
if-match cost |
16-路由协议命令 |
5-4 |
if-match interface |
16-路由协议命令 |
5-5 |
if-match ip next-hop |
16-路由协议命令 |
5-5 |
if-match tag |
16-路由协议命令 |
5-6 |
igmp enable |
17-组播协议命令 |
2-3 |
igmp group-limit |
17-组播协议命令 |
2-4 |
igmp group-policy |
17-组播协议命令 |
2-4 |
igmp group-policy vlan |
17-组播协议命令 |
2-5 |
igmp host-join |
17-组播协议命令 |
5-16 |
igmp host-join port |
17-组播协议命令 |
2-6 |
17-组播协议命令 |
5-15 |
igmp host-join vlan |
17-组播协议命令 |
2-7 |
igmp lastmember-queryinterval |
17-组播协议命令 |
2-7 |
igmp max-response-time |
17-组播协议命令 |
2-8 |
igmp proxy |
17-组播协议命令 |
2-9 |
igmp robust-count |
17-组播协议命令 |
2-9 |
igmp timer other-querier-present |
17-组播协议命令 |
2-10 |
igmp timer query |
17-组播协议命令 |
2-11 |
igmp transparent enable |
40-VLAN-VPN命令 |
1-2 |
igmp version |
17-组播协议命令 |
2-11 |
igmp-snooping |
17-组播协议命令 |
5-4 |
igmp-snooping fast-leave |
17-组播协议命令 |
5-5 |
igmp-snooping general-query source-ip |
17-组播协议命令 |
5-6 |
igmp-snooping group-limit |
17-组播协议命令 |
5-7 |
igmp-snooping group-policy |
17-组播协议命令 |
5-8 |
igmp-snooping host-aging-time |
17-组播协议命令 |
5-9 |
igmp-snooping max-response-time |
17-组播协议命令 |
5-10 |
igmp-snooping nonflooding-enable |
17-组播协议命令 |
5-10 |
igmp-snooping querier |
17-组播协议命令 |
5-11 |
igmp-snooping query-interval |
17-组播协议命令 |
5-12 |
igmp-snooping query-pkt-deny |
17-组播协议命令 |
5-12 |
igmp-snooping router-aging-time |
17-组播协议命令 |
5-13 |
igmp-snooping special-query source-ip |
17-组播协议命令 |
5-17 |
igmp-snooping version |
17-组播协议命令 |
5-14 |
igmp-snooping vlan-mapping |
17-组播协议命令 |
5-14 |
import-route |
16-路由协议命令 |
3-7 |
import-route |
16-路由协议命令 |
4-28 |
import-source |
17-组播协议命令 |
4-6 |
info-center channel name |
38-信息中心命令 |
1-6 |
info-center console channel |
38-信息中心命令 |
1-6 |
info-center enable |
38-信息中心命令 |
1-7 |
info-center logbuffer |
38-信息中心命令 |
1-7 |
info-center loghost |
38-信息中心命令 |
1-8 |
info-center loghost source |
38-信息中心命令 |
1-9 |
info-center monitor channel |
38-信息中心命令 |
1-10 |
info-center snmp channel |
38-信息中心命令 |
1-10 |
info-center source |
38-信息中心命令 |
1-11 |
info-center switch-on |
38-信息中心命令 |
1-13 |
info-center synchronous |
38-信息中心命令 |
1-13 |
info-center timestamp |
38-信息中心命令 |
1-14 |
info-center timestamp loghost |
38-信息中心命令 |
1-15 |
info-center timestamp utc |
38-信息中心命令 |
1-16 |
info-center trapbuffer |
38-信息中心命令 |
1-17 |
instance |
15-MSTP命令 |
1-10 |
interface |
08-端口基本配置命令 |
1-18 |
04-VLAN命令 |
1-4 |
ip (Pki Entity view) |
47-PKI命令 |
1-13 |
ip address |
05-IP地址-IP性能命令 |
1-3 |
ip address bootp-alloc |
24-DHCP命令 |
5-3 |
ip address dhcp-alloc |
24-DHCP命令 |
5-2 |
ip check dot1x enable |
24-DHCP命令 |
3-9 |
ip check source ip-address |
24-DHCP命令 |
3-9 |
ip forward-broadcast |
05-IP地址-IP性能命令 |
2-14 |
ip host |
43-域名解析命令 |
1-5 |
ip http acl |
02-登录交换机命令 |
2-2 |
ip http shutdown |
02-登录交换机命令 |
1-12 |
ip https acl |
49-HTTPS命令 |
1-1 |
ip https certificate access-control-policy |
49-HTTPS命令 |
1-2 |
ip https enable |
49-HTTPS命令 |
1-3 |
ip https ssl-server-policy |
49-HTTPS命令 |
1-3 |
ip ip-prefix |
16-路由协议命令 |
5-7 |
ip route-static |
16-路由协议命令 |
2-1 |
ip route-static detect-group |
14-自动侦测命令 |
1-3 |
24-DHCP命令 |
3-10 |
ip source static import dot1x |
23-ARP命令 |
2-8 |
ip-pool |
30-Cluster命令 |
1-32 |
ipv6 address |
42-IPv6管理命令 |
1-18 |
ipv6 address auto link-local |
42-IPv6管理命令 |
1-18 |
ipv6 address eui-64 |
42-IPv6管理命令 |
1-19 |
ipv6 address link-local |
42-IPv6管理命令 |
1-20 |
ipv6 host |
42-IPv6管理命令 |
1-21 |
ipv6 icmp-error |
42-IPv6管理命令 |
1-22 |
ipv6 nd dad attempts |
42-IPv6管理命令 |
1-22 |
ipv6 nd hop-limit |
42-IPv6管理命令 |
1-23 |
ipv6 nd ns retrans-timer |
42-IPv6管理命令 |
1-23 |
ipv6 nd nud reachable-time |
42-IPv6管理命令 |
1-24 |
ipv6 neighbor |
42-IPv6管理命令 |
1-24 |
ipv6 neighbors max-learning-num |
42-IPv6管理命令 |
1-25 |
ipv6 route-static |
42-IPv6管理命令 |
1-26 |
irf-fabric authentication-mode |
29-IRF Fabric命令 |
1-11 |
jitter-interval |
41-HWPing命令 |
1-22 |
jitter-packetnum |
41-HWPing命令 |
1-23 |
job |
39-系统维护与调试命令 |
22 |
jumboframe enable |
08-端口基本配置命令 |
1-18 |
key |
19-AAA命令 |
1-34 |
key |
19-AAA命令 |
1-56 |
lacp enable |
09-端口汇聚命令 |
1-4 |
lacp port-priority |
09-端口汇聚命令 |
1-5 |
lacp system-priority |
09-端口汇聚命令 |
1-6 |
lcd |
1-15 |
ldap-server |
47-PKI命令 |
1-13 |
level |
19-AAA命令 |
1-15 |
line-rate |
1-10 |
link-aggregation group |
1-3 |
2-1 |
link-aggregation group description |
09-端口汇聚命令 |
1-6 |
link-aggregation group mode |
09-端口汇聚命令 |
1-7 |
link-delay |
08-端口基本配置命令 |
1-19 |
lldp admin-status |
46-LLDP命令 |
1-13 |
lldp check-change-interval |
46-LLDP命令 |
1-14 |
lldp compliance admin-status cdp |
46-LLDP命令 |
1-14 |
lldp compliance cdp |
46-LLDP命令 |
1-15 |
lldp enable |
46-LLDP命令 |
1-16 |
lldp encapsulation snap |
46-LLDP命令 |
1-16 |
lldp fast-count |
46-LLDP命令 |
1-17 |
lldp hold-multiplier |
46-LLDP命令 |
1-17 |
lldp management-address-tlv |
46-LLDP命令 |
1-18 |
lldp notification remote-change enable |
46-LLDP命令 |
1-18 |
lldp timer notification-interval |
46-LLDP命令 |
1-19 |
lldp timer reinit-delay |
46-LLDP命令 |
1-19 |
lldp timer tx-delay |
46-LLDP命令 |
1-20 |
lldp timer tx-interval |
46-LLDP命令 |
1-20 |
lldp tlv-enable |
46-LLDP命令 |
1-21 |
locality |
47-PKI命令 |
1-14 |
local-proxy-arp enable |
23-ARP命令 |
3-2 |
local-server |
19-AAA命令 |
1-35 |
local-server nas-ip |
19-AAA命令 |
1-35 |
local-user |
19-AAA命令 |
1-15 |
local-user password-display-mode |
19-AAA命令 |
1-16 |
lock |
02-登录交换机命令 |
1-13 |
logging-host |
30-Cluster命令 |
1-32 |
log-peer-change |
16-路由协议命令 |
4-29 |
loopback |
08-端口基本配置命令 |
1-20 |
loopback-detection control enable |
08-端口基本配置命令 |
1-20 |
loopback-detection enable |
08-端口基本配置命令 |
1-21 |
loopback-detection interface-list enable |
08-端口基本配置命令 |
1-22 |
loopback-detection interval-time |
08-端口基本配置命令 |
1-23 |
loopback-detection per-vlan enable |
08-端口基本配置命令 |
1-24 |
loopback-detection shutdown enable |
08-端口基本配置命令 |
1-24 |
ls |
1-16 |
ls |
1-29 |
mac-address |
13-MAC地址转发表管理命令 |
1-3 |
mac-address aging destination-hit enable |
13-MAC地址转发表管理命令 |
1-5 |
mac-address max-mac-count |
13-MAC地址转发表管理命令 |
1-5 |
mac-address multicast interface |
17-组播协议命令 |
1-7 |
mac-address multicast vlan |
17-组播协议命令 |
1-8 |
11-端口安全-端口绑定命令 |
1-5 |
mac-address timer |
13-MAC地址转发表管理命令 |
1-6 |
mac-address-mapping |
40-VLAN-VPN命令 |
2-1 |
21-MAC地址认证命令 |
1-3 |
mac-authentication authmode usernameasmacaddress |
21-MAC地址认证命令 |
1-4 |
mac-authentication authmode usernamefixed |
21-MAC地址认证命令 |
1-5 |
mac-authentication authpassword |
21-MAC地址认证命令 |
1-5 |
mac-authentication authusername |
21-MAC地址认证命令 |
1-6 |
mac-authentication domain |
21-MAC地址认证命令 |
1-6 |
mac-authentication guest-vlan |
21-MAC地址认证命令 |
1-8 |
mac-authentication interface |
21-MAC地址认证命令 |
1-3 |
mac-authentication max-auth-num |
21-MAC地址认证命令 |
1-9 |
mac-authentication timer |
21-MAC地址认证命令 |
1-7 |
mac-authentication timer guest-vlan-reauth |
21-MAC地址认证命令 |
1-10 |
management-vlan |
30-Cluster命令 |
1-33 |
mdi |
08-端口基本配置命令 |
1-25 |
memory |
16-路由协议命令 |
6-3 |
memory auto-establish disable |
16-路由协议命令 |
6-3 |
memory auto-establish enable |
16-路由协议命令 |
6-4 |
messenger |
19-AAA命令 |
1-17 |
mirrored-to |
1-11 |
mirroring-group |
28-镜像命令 |
1-3 |
mirroring-group mirroring-port |
28-镜像命令 |
1-4 |
mirroring-group monitor-port |
28-镜像命令 |
1-5 |
mirroring-group reflector-port |
28-镜像命令 |
1-6 |
mirroring-group remote-probe vlan |
28-镜像命令 |
1-6 |
mirroring-port |
28-镜像命令 |
1-7 |
mkdir |
36-文件系统管理命令 |
1-8 |
mkdir |
1-17 |
mkdir |
1-30 |
2-2 |
monitor-port |
28-镜像命令 |
1-8 |
more |
36-文件系统管理命令 |
1-9 |
move |
36-文件系统管理命令 |
1-10 |
msdp |
17-组播协议命令 |
4-7 |
msdp-tracert |
17-组播协议命令 |
4-7 |
mtracert |
17-组播协议命令 |
1-9 |
multicast route-limit |
17-组播协议命令 |
1-10 |
multicast routing-enable |
17-组播协议命令 |
1-11 |
multicast static-group interface |
17-组播协议命令 |
5-17 |
multicast static-group vlan |
17-组播协议命令 |
5-18 |
multicast static-router-port |
17-组播协议命令 |
5-19 |
multicast static-router-port vlan |
17-组播协议命令 |
5-20 |
multicast storing-enable |
17-组播协议命令 |
1-11 |
multicast storing-packet |
17-组播协议命令 |
1-12 |
17-组播协议命令 |
1-12 |
multicast-suppression |
08-端口基本配置命令 |
1-26 |
multi-path-number |
16-路由协议命令 |
4-30 |
name |
04-VLAN命令 |
1-5 |
name |
19-AAA命令 |
1-18 |
nas-ip |
19-AAA命令 |
1-36 |
nas-ip |
19-AAA命令 |
1-56 |
nbns-list |
24-DHCP命令 |
1-29 |
ndp enable |
30-Cluster命令 |
1-2 |
ndp timer aging |
30-Cluster命令 |
1-3 |
ndp timer hello |
30-Cluster命令 |
1-4 |
netbios-type |
24-DHCP命令 |
1-30 |
network |
16-路由协议命令 |
3-8 |
network |
16-路由协议命令 |
4-30 |
network |
24-DHCP命令 |
1-30 |
nm-interface Vlan-interface |
30-Cluster命令 |
1-35 |
nslookup type |
43-域名解析命令 |
1-6 |
nssa |
16-路由协议命令 |
4-31 |
ntdp enable |
30-Cluster命令 |
1-8 |
ntdp explore |
30-Cluster命令 |
1-8 |
ntdp hop |
30-Cluster命令 |
1-9 |
ntdp timer |
30-Cluster命令 |
1-9 |
ntdp timer hop-delay |
30-Cluster命令 |
1-10 |
ntdp timer port-delay |
30-Cluster命令 |
1-11 |
ntp-service access |
34-NTP命令 |
1-4 |
ntp-service authentication enable |
34-NTP命令 |
1-5 |
ntp-service authentication-keyid |
34-NTP命令 |
1-6 |
ntp-service broadcast-client |
34-NTP命令 |
1-6 |
ntp-service broadcast-server |
34-NTP命令 |
1-7 |
ntp-service in-interface disable |
34-NTP命令 |
1-7 |
ntp-service max-dynamic-sessions |
34-NTP命令 |
1-8 |
ntp-service multicast-client |
34-NTP命令 |
1-8 |
ntp-service multicast-server |
34-NTP命令 |
1-9 |
ntp-service reliable authentication-keyid |
34-NTP命令 |
1-10 |
ntp-service source-interface |
34-NTP命令 |
1-10 |
ntp-service unicast-peer |
34-NTP命令 |
1-11 |
ntp-service unicast-server |
34-NTP命令 |
1-12 |
open |
1-17 |
option |
14-自动侦测命令 |
1-4 |
option |
24-DHCP命令 |
1-31 |
organization |
47-PKI命令 |
1-14 |
organization-unit |
47-PKI命令 |
1-15 |
originating-rp |
17-组播协议命令 |
4-9 |
ospf |
16-路由协议命令 |
4-32 |
ospf authentication-mode |
16-路由协议命令 |
4-33 |
ospf cost |
16-路由协议命令 |
4-34 |
ospf dr-priority |
16-路由协议命令 |
4-34 |
ospf mib-binding |
16-路由协议命令 |
4-35 |
ospf mtu-enable |
16-路由协议命令 |
4-36 |
ospf network-type |
16-路由协议命令 |
4-36 |
ospf timer dead |
16-路由协议命令 |
4-37 |
ospf timer hello |
16-路由协议命令 |
4-38 |
ospf timer poll |
16-路由协议命令 |
4-39 |
ospf timer retransmit |
16-路由协议命令 |
4-39 |
ospf trans-delay |
16-路由协议命令 |
4-40 |
packet-filter |
25-ACL命令 |
1-7 |
packet-filter |
2-3 |
packet-filter vlan |
25-ACL命令 |
1-9 |
parity |
02-登录交换机命令 |
1-14 |
passive |
1-18 |
password |
19-AAA命令 |
1-18 |
password |
41-HWPing命令 |
1-24 |
patch activate |
39-系统维护与调试命令 |
3-13 |
patch delete |
39-系统维护与调试命令 |
3-13 |
patch load |
39-系统维护与调试命令 |
3-14 |
patch run |
39-系统维护与调试命令 |
3-15 |
peer |
16-路由协议命令 |
3-9 |
peer |
16-路由协议命令 |
4-40 |
peer connect-interface |
17-组播协议命令 |
4-9 |
peer description |
17-组播协议命令 |
4-10 |
peer mesh-group |
17-组播协议命令 |
4-11 |
peer minimum-ttl |
17-组播协议命令 |
4-11 |
peer request-sa-enable |
17-组播协议命令 |
4-12 |
peer sa-cache-maximum |
17-组播协议命令 |
4-12 |
peer sa-policy |
17-组播协议命令 |
4-13 |
peer sa-request-policy |
17-组播协议命令 |
4-14 |
peer-public-key end |
35-SSH命令 |
1-10 |
pim |
17-组播协议命令 |
3-9 |
pim bsr-boundary |
17-组播协议命令 |
3-9 |
pim dm |
17-组播协议命令 |
3-10 |
pim neighbor-limit |
17-组播协议命令 |
3-11 |
pim neighbor-policy |
17-组播协议命令 |
3-11 |
pim sm |
17-组播协议命令 |
3-12 |
pim timer hello |
17-组播协议命令 |
3-13 |
ping |
39-系统维护与调试命令 |
2-1 |
ping ipv6 |
42-IPv6管理命令 |
2-1 |
47-PKI命令 |
1-15 |
47-PKI命令 |
1-16 |
pki delete-certificate |
47-PKI命令 |
1-16 |
pki domain |
47-PKI命令 |
1-17 |
pki entity |
47-PKI命令 |
1-17 |
pki import-certificate |
47-PKI命令 |
1-18 |
pki request-certificate domain |
47-PKI命令 |
1-18 |
pki retrieval-certificate |
47-PKI命令 |
1-19 |
pki retrieval-crl domain |
47-PKI命令 |
1-19 |
pki validate-certificate |
47-PKI命令 |
1-20 |
pki-domain |
48-SSL命令 |
1-5 |
poe enable |
1-5 |
poe legacy enable |
1-6 |
poe max-power |
1-6 |
poe mode |
1-7 |
poe power-management |
1-7 |
poe priority |
1-8 |
1-9 |
poe update |
1-9 |
poe-profile |
2-2 |
port |
04-VLAN命令 |
1-8 |
port |
1-4 |
port |
2-3 |
port access vlan |
04-VLAN命令 |
1-9 |
port auto-power-down |
39-系统维护与调试命令 |
3-15 |
port hybrid protocol-vlan vlan |
04-VLAN命令 |
1-15 |
port hybrid pvid vlan |
04-VLAN命令 |
1-9 |
port hybrid vlan |
04-VLAN命令 |
1-10 |
port isolate |
10-端口隔离命令 |
1-1 |
port link-aggregation group |
09-端口汇聚命令 |
1-7 |
port link-type |
04-VLAN命令 |
1-11 |
port link-type irf-fabric |
29-IRF Fabric命令 |
1-12 |
port monitor-link group |
2-4 |
port smart-link group |
1-4 |
port trunk permit vlan |
04-VLAN命令 |
1-12 |
port trunk pvid vlan |
04-VLAN命令 |
1-13 |
port-mac |
13-MAC地址转发表管理命令 |
1-7 |
port-security authorization ignore |
11-端口安全-端口绑定命令 |
1-6 |
port-security enable |
11-端口安全-端口绑定命令 |
1-7 |
port-security guest-vlan |
11-端口安全-端口绑定命令 |
1-8 |
port-security intrusion-mode |
11-端口安全-端口绑定命令 |
1-9 |
port-security max-mac-count |
11-端口安全-端口绑定命令 |
1-11 |
port-security ntk-mode |
11-端口安全-端口绑定命令 |
1-12 |
port-security oui |
11-端口安全-端口绑定命令 |
1-13 |
port-security port-mode |
11-端口安全-端口绑定命令 |
1-13 |
port-security timer autolearn |
11-端口安全-端口绑定命令 |
1-16 |
port-security timer disableport |
11-端口安全-端口绑定命令 |
1-17 |
port-security timer guest-vlan-reauth |
11-端口安全-端口绑定命令 |
1-17 |
port-security trap |
11-端口安全-端口绑定命令 |
1-18 |
prefer-cipher |
48-SSL命令 |
1-6 |
preference |
16-路由协议命令 |
3-9 |
preference |
16-路由协议命令 |
4-41 |
primary accounting |
19-AAA命令 |
1-37 |
19-AAA命令 |
1-57 |
primary authentication |
19-AAA命令 |
1-38 |
19-AAA命令 |
1-58 |
primary authorization |
19-AAA命令 |
1-58 |
priority |
1-13 |
priority trust |
1-14 |
probe-failtimes |
41-HWPing命令 |
1-24 |
protocol inbound |
02-登录交换机命令 |
1-15 |
protocol inbound |
35-SSH命令 |
1-10 |
protocol-priority protocol-type |
1-14 |
protocol-vlan |
04-VLAN命令 |
1-16 |
prune delay |
17-组播协议命令 |
3-13 |
public-key local create |
35-SSH命令 |
1-11 |
public-key local destroy |
35-SSH命令 |
1-13 |
public-key local export dsa |
35-SSH命令 |
1-15 |
public-key local export rsa |
35-SSH命令 |
1-14 |
public-key peer |
35-SSH命令 |
1-17 |
public-key peer import sshkey |
35-SSH命令 |
1-17 |
public-key-code begin |
35-SSH命令 |
1-18 |
public-key-code end |
35-SSH命令 |
1-19 |
put |
1-19 |
put |
1-30 |
pwd |
36-文件系统管理命令 |
1-10 |
pwd |
1-19 |
pwd |
1-31 |
1-16 |
qos-profile |
2-4 |
qos-profile port-based |
2-4 |
queue-scheduler |
1-17 |
quit |
01-CLI命令 |
1-6 |
quit |
1-20 |
quit |
1-31 |
radius client |
19-AAA命令 |
1-38 |
radius nas-ip |
19-AAA命令 |
1-39 |
radius scheme |
19-AAA命令 |
1-40 |
radius trap |
19-AAA命令 |
1-41 |
radius-scheme |
19-AAA命令 |
1-19 |
raw-vlan-id inbound |
40-VLAN-VPN命令 |
2-2 |
reboot |
39-系统维护与调试命令 |
3-16 |
reboot member |
30-Cluster命令 |
1-35 |
region-name |
15-MSTP命令 |
1-10 |
register-policy |
17-组播协议命令 |
3-14 |
remotehelp |
1-20 |
remote-probe vlan enable |
28-镜像命令 |
1-9 |
remove |
1-31 |
rename |
36-文件系统管理命令 |
1-11 |
rename |
1-21 |
rename |
1-32 |
reset |
16-路由协议命令 |
3-10 |
reset arp |
23-ARP命令 |
1-8 |
reset counters interface |
08-端口基本配置命令 |
1-26 |
reset dhcp server conflict |
24-DHCP命令 |
1-32 |
reset dhcp server ip-in-use |
24-DHCP命令 |
1-32 |
reset dhcp server statistics |
24-DHCP命令 |
1-33 |
reset dhcp-server |
24-DHCP命令 |
2-10 |
reset dhcp-snooping |
24-DHCP命令 |
3-11 |
reset dns dynamic-host |
43-域名解析命令 |
1-7 |
reset dns ipv6 dynamic-host |
42-IPv6管理命令 |
1-26 |
reset dot1x statistics |
1-18 |
reset ftm statistics |
29-IRF Fabric命令 |
1-12 |
reset garp statistics |
07-GVRP命令 |
1-5 |
reset hwtacacs statistics |
19-AAA命令 |
1-59 |
reset igmp group |
17-组播协议命令 |
2-12 |
reset igmp-snooping statistics |
17-组播协议命令 |
5-20 |
reset ip routing-table statistics protocol |
16-路由协议命令 |
1-11 |
reset ip statistics |
05-IP地址-IP性能命令 |
2-15 |
reset ipv6 neighbors |
42-IPv6管理命令 |
1-27 |
reset ipv6 statistics |
42-IPv6管理命令 |
1-27 |
reset lacp statistics |
09-端口汇聚命令 |
1-8 |
reset logbuffer |
38-信息中心命令 |
1-18 |
reset mac-authentication |
21-MAC地址认证命令 |
1-8 |
reset msdp peer |
17-组播协议命令 |
4-14 |
reset msdp sa-cache |
17-组播协议命令 |
4-15 |
reset msdp statistics |
17-组播协议命令 |
4-15 |
reset multicast forwarding-table |
17-组播协议命令 |
1-13 |
reset multicast routing-table |
17-组播协议命令 |
1-14 |
reset ndp statistics |
30-Cluster命令 |
1-4 |
reset ospf |
16-路由协议命令 |
4-42 |
reset ospf statistics |
16-路由协议命令 |
4-42 |
reset packet-drop interface |
08-端口基本配置命令 |
1-27 |
reset pim neighbor |
17-组播协议命令 |
3-15 |
reset pim routing-table |
17-组播协议命令 |
3-15 |
reset radius statistics |
19-AAA命令 |
1-41 |
reset recycle-bin |
36-文件系统管理命令 |
1-11 |
reset saved-configuration |
03-配置文件管理命令 |
1-11 |
reset smart-link packets counter |
1-5 |
reset stop-accounting-buffer |
19-AAA命令 |
1-42 |
19-AAA命令 |
1-60 |
reset stp |
15-MSTP命令 |
1-11 |
reset tcp ipv6 statistics |
42-IPv6管理命令 |
1-28 |
reset tcp statistics |
05-IP地址-IP性能命令 |
2-15 |
reset traffic-statistic |
1-20 |
reset trapbuffer |
38-信息中心命令 |
1-18 |
reset udp ipv6 statistics |
42-IPv6管理命令 |
1-28 |
reset udp statistics |
05-IP地址-IP性能命令 |
2-16 |
reset udp-helper packet |
32-UDP Helper命令 |
1-1 |
reset vrrp statistics |
22-VRRP命令 |
1-4 |
resilient-arp enable |
23-ARP命令 |
4-2 |
resilient-arp interface vlan-interface |
23-ARP命令 |
4-2 |
restore startup-configuration |
36-文件系统管理命令 |
1-21 |
retry |
14-自动侦测命令 |
1-5 |
retry |
19-AAA命令 |
1-42 |
retry realtime-accounting |
19-AAA命令 |
1-43 |
retry stop-accounting |
19-AAA命令 |
1-44 |
19-AAA命令 |
1-60 |
return |
01-CLI命令 |
1-6 |
revision-level |
15-MSTP命令 |
1-12 |
rip |
16-路由协议命令 |
3-10 |
rip authentication-mode |
16-路由协议命令 |
3-11 |
rip input |
16-路由协议命令 |
3-12 |
rip metricin |
16-路由协议命令 |
3-13 |
rip metricout |
16-路由协议命令 |
3-13 |
rip output |
16-路由协议命令 |
3-14 |
rip split-horizon |
16-路由协议命令 |
3-14 |
rip version |
16-路由协议命令 |
3-15 |
rip work |
16-路由协议命令 |
3-16 |
rmdir |
36-文件系统管理命令 |
1-13 |
rmdir |
1-21 |
rmdir |
1-32 |
rmon alarm |
33-SNMP-RMON命令 |
2-8 |
rmon event |
33-SNMP-RMON命令 |
2-9 |
rmon history |
33-SNMP-RMON命令 |
2-10 |
rmon prialarm |
33-SNMP-RMON命令 |
2-11 |
rmon statistics |
33-SNMP-RMON命令 |
2-12 |
root-certificate fingerprint |
47-PKI命令 |
1-20 |
route-policy |
16-路由协议命令 |
5-8 |
router id |
16-路由协议命令 |
4-43 |
rsa local-key-pair create |
35-SSH命令 |
1-20 |
rsa local-key-pair destroy |
35-SSH命令 |
1-22 |
35-SSH命令 |
1-22 |
rsa peer-public-key import sshkey |
35-SSH命令 |
1-23 |
rule (Pki Cert Acp view) |
47-PKI命令 |
1-21 |
rule comment |
25-ACL命令 |
1-25 |
rule(IPv6 ACL) |
25-ACL命令 |
1-22 |
rule(二层ACL) |
25-ACL命令 |
1-17 |
rule(高级ACL) |
25-ACL命令 |
1-11 |
rule(基本ACL) |
25-ACL命令 |
1-10 |
rule(用户自定义ACL) |
25-ACL命令 |
1-19 |
save |
03-配置文件管理命令 |
1-12 |
schedule reboot at |
39-系统维护与调试命令 |
3-16 |
schedule reboot delay |
39-系统维护与调试命令 |
3-17 |
schedule reboot regularity |
39-系统维护与调试命令 |
3-18 |
scheme |
19-AAA命令 |
1-20 |
screen-length |
02-登录交换机命令 |
1-15 |
secondary accounting |
19-AAA命令 |
1-45 |
19-AAA命令 |
1-61 |
secondary authentication |
19-AAA命令 |
1-45 |
19-AAA命令 |
1-61 |
secondary authorization |
19-AAA命令 |
1-62 |
security-policy-server |
19-AAA命令 |
2-1 |
self-service-url |
19-AAA命令 |
1-21 |
send |
02-登录交换机命令 |
1-16 |
sendpacket passroute |
41-HWPing命令 |
1-25 |
send-trap |
41-HWPing命令 |
1-25 |
server-type |
19-AAA命令 |
1-46 |
service-type |
02-登录交换机命令 |
1-17 |
service-type |
19-AAA命令 |
1-22 |
service-type multicast |
17-组播协议命令 |
5-21 |
session |
48-SSL命令 |
1-6 |
set authentication password |
02-登录交换机命令 |
1-18 |
set unit name |
29-IRF Fabric命令 |
1-13 |
sftp |
1-33 |
sftp server enable |
1-23 |
sftp source-interface |
1-34 |
sftp source-ip |
1-35 |
sftp timeout |
1-23 |
shell |
02-登录交换机命令 |
1-19 |
shutdown |
04-VLAN命令 |
1-6 |
shutdown |
08-端口基本配置命令 |
1-28 |
shutdown |
17-组播协议命令 |
4-16 |
silent-interface |
16-路由协议命令 |
4-44 |
smart-link flush enable control-vlan |
1-6 |
smart-link group |
1-7 |
smart-link group |
2-5 |
snmp-agent |
33-SNMP-RMON命令 |
1-10 |
snmp-agent calculate-password |
33-SNMP-RMON命令 |
1-10 |
02-登录交换机命令 |
2-2 |
33-SNMP-RMON命令 |
1-11 |
snmp-agent group |
02-登录交换机命令 |
2-3 |
snmp-agent group |
33-SNMP-RMON命令 |
1-12 |
snmp-agent local-engineid |
33-SNMP-RMON命令 |
1-14 |
snmp-agent log |
33-SNMP-RMON命令 |
1-14 |
33-SNMP-RMON命令 |
1-15 |
snmp-agent packet max-size |
33-SNMP-RMON命令 |
1-16 |
33-SNMP-RMON命令 |
1-17 |
snmp-agent target-host |
33-SNMP-RMON命令 |
1-18 |
snmp-agent trap enable |
33-SNMP-RMON命令 |
1-19 |
snmp-agent trap enable ospf |
16-路由协议命令 |
4-44 |
snmp-agent trap ifmib |
33-SNMP-RMON命令 |
1-20 |
snmp-agent trap life |
33-SNMP-RMON命令 |
1-21 |
snmp-agent trap queue-size |
33-SNMP-RMON命令 |
1-21 |
snmp-agent trap source |
33-SNMP-RMON命令 |
1-22 |
02-登录交换机命令 |
2-4 |
snmp-agent usm-user { v1 | v2c } |
33-SNMP-RMON命令 |
1-23 |
33-SNMP-RMON命令 |
1-24 |
snmp-host |
30-Cluster命令 |
1-36 |
source-interface |
41-HWPing命令 |
1-26 |
source-ip |
41-HWPing命令 |
1-27 |
source-lifetime |
17-组播协议命令 |
3-17 |
source-policy |
17-组播协议命令 |
3-17 |
source-port |
41-HWPing命令 |
1-28 |
speed |
02-登录交换机命令 |
1-19 |
speed |
08-端口基本配置命令 |
1-29 |
speed auto |
08-端口基本配置命令 |
1-29 |
spf-schedule-interval |
16-路由协议命令 |
4-45 |
spt-switch-threshold |
17-组播协议命令 |
3-16 |
ssh authentication-type default |
35-SSH命令 |
1-24 |
ssh client assign |
35-SSH命令 |
1-25 |
ssh client first-time enable |
35-SSH命令 |
1-26 |
ssh server authentication-retries |
35-SSH命令 |
1-27 |
ssh server compatible-ssh1x enable |
35-SSH命令 |
1-27 |
ssh server rekey-interval |
35-SSH命令 |
1-28 |
ssh server timeout |
35-SSH命令 |
1-28 |
ssh user |
35-SSH命令 |
1-29 |
ssh user assign |
35-SSH命令 |
1-30 |
ssh user authentication-type |
35-SSH命令 |
1-31 |
ssh user service-type |
35-SSH命令 |
1-32 |
ssh2 |
35-SSH命令 |
1-33 |
ssh2 source-interface |
35-SSH命令 |
1-34 |
ssh2 source-ip |
35-SSH命令 |
1-35 |
ssh-server source-interface |
35-SSH命令 |
1-36 |
35-SSH命令 |
1-36 |
ssl client-policy |
48-SSL命令 |
1-7 |
ssl server-policy |
48-SSL命令 |
1-8 |
standby detect-group |
14-自动侦测命令 |
1-5 |
startup bootrom-access enable |
36-文件系统管理命令 |
1-19 |
startup saved-configuration |
03-配置文件管理命令 |
1-13 |
state |
19-AAA命令 |
1-22 |
state |
19-AAA命令 |
1-47 |
state |
47-PKI命令 |
1-22 |
static-bind client-identifier |
24-DHCP命令 |
1-33 |
static-bind ip-address |
24-DHCP命令 |
1-34 |
static-bind mac-address |
24-DHCP命令 |
1-35 |
static-rp |
17-组播协议命令 |
3-18 |
static-rpf-peer |
17-组播协议命令 |
4-16 |
statistics |
41-HWPing命令 |
1-28 |
statistics keep-time |
41-HWPing命令 |
1-29 |
stop-accounting-buffer enable |
19-AAA命令 |
1-48 |
stopbits |
02-登录交换机命令 |
1-20 |
storm-constrain |
08-端口基本配置命令 |
1-30 |
storm-constrain control |
08-端口基本配置命令 |
1-31 |
storm-constrain enable |
08-端口基本配置命令 |
1-32 |
storm-constrain interval |
08-端口基本配置命令 |
1-32 |
stp |
15-MSTP命令 |
1-12 |
stp bpdu-protection |
15-MSTP命令 |
1-14 |
stp bridge-diameter |
15-MSTP命令 |
1-15 |
stp compliance |
15-MSTP命令 |
1-15 |
stp config-digest-snooping |
15-MSTP命令 |
1-16 |
stp cost |
15-MSTP命令 |
1-18 |
stp dot1d-trap |
15-MSTP命令 |
1-20 |
stp edged-port |
15-MSTP命令 |
1-20 |
stp loop-protection |
15-MSTP命令 |
1-22 |
stp max-hops |
15-MSTP命令 |
1-23 |
stp mcheck |
15-MSTP命令 |
1-24 |
stp mode |
15-MSTP命令 |
1-25 |
stp no-agreement-check |
15-MSTP命令 |
1-26 |
stp pathcost-standard |
15-MSTP命令 |
1-27 |
stp point-to-point |
15-MSTP命令 |
1-28 |
stp port priority |
15-MSTP命令 |
1-30 |
stp portlog |
15-MSTP命令 |
1-31 |
stp portlog all |
15-MSTP命令 |
1-31 |
stp priority |
15-MSTP命令 |
1-32 |
15-MSTP命令 |
1-32 |
stp root primary |
15-MSTP命令 |
1-33 |
stp root secondary |
15-MSTP命令 |
1-34 |
stp root-protection |
15-MSTP命令 |
1-35 |
stp tc-protection |
15-MSTP命令 |
1-36 |
stp tc-protection threshold |
15-MSTP命令 |
1-37 |
stp timer forward-delay |
15-MSTP命令 |
1-38 |
stp timer hello |
15-MSTP命令 |
1-38 |
stp timer max-age |
15-MSTP命令 |
1-39 |
stp timer-factor |
15-MSTP命令 |
1-40 |
stp transmit-limit |
15-MSTP命令 |
1-41 |
stub |
16-路由协议命令 |
4-46 |
summary |
16-路由协议命令 |
3-17 |
super |
02-登录交换机命令 |
3-1 |
super authentication-mode |
02-登录交换机命令 |
3-2 |
super password |
02-登录交换机命令 |
3-2 |
sysname |
29-IRF Fabric命令 |
1-14 |
sysname |
39-系统维护与调试命令 |
1-3 |
system-guard cpu-rcv-limit |
4-3 |
system-guard ip detect-maxnum |
4-4 |
system-guard ip detect-threshold |
4-4 |
system-guard ip enable |
4-5 |
system-guard l3err enable |
4-6 |
system-guard tcn enable |
4-7 |
system-guard tcn rate-threshold |
4-7 |
system-monitor enable |
39-系统维护与调试命令 |
3-19 |
system-view |
01-CLI命令 |
1-7 |
tcp ipv6 timer fin-timeout |
42-IPv6管理命令 |
1-29 |
tcp ipv6 timer syn-timeout |
42-IPv6管理命令 |
1-29 |
tcp ipv6 window |
42-IPv6管理命令 |
1-30 |
tcp timer fin-timeout |
05-IP地址-IP性能命令 |
2-16 |
tcp timer syn-timeout |
05-IP地址-IP性能命令 |
2-17 |
tcp window |
05-IP地址-IP性能命令 |
2-17 |
telnet |
02-登录交换机命令 |
1-21 |
telnet ipv6 |
02-登录交换机命令 |
1-21 |
telnet ipv6 |
42-IPv6管理命令 |
2-3 |
telnet source-interface |
02-登录交换机命令 |
1-22 |
telnet source-ip |
02-登录交换机命令 |
1-23 |
telnet-server source-interface |
02-登录交换机命令 |
1-23 |
02-登录交换机命令 |
1-24 |
terminal debugging |
38-信息中心命令 |
1-18 |
39-系统维护与调试命令 |
1-7 |
terminal logging |
38-信息中心命令 |
1-19 |
terminal monitor |
38-信息中心命令 |
1-19 |
terminal trapping |
38-信息中心命令 |
1-20 |
test-enable |
41-HWPing命令 |
1-31 |
test-failtimes |
41-HWPing命令 |
1-32 |
test-time begin |
41-HWPing命令 |
1-29 |
test-type |
41-HWPing命令 |
1-30 |
tftp { ascii | binary } |
2-1 |
tftp get |
30-Cluster命令 |
1-37 |
tftp get |
2-2 |
tftp ipv6 |
42-IPv6管理命令 |
2-3 |
tftp put |
30-Cluster命令 |
1-37 |
tftp put |
2-3 |
tftp source-interface |
2-5 |
tftp source-ip |
2-6 |
tftp tftp-server source-interface |
2-4 |
tftp tftp-server source-ip |
2-4 |
tftp-server |
30-Cluster命令 |
1-38 |
tftp-server acl |
2-6 |
24-DHCP命令 |
1-36 |
24-DHCP命令 |
1-36 |
time at |
39-系统维护与调试命令 |
23 |
time delay |
39-系统维护与调试命令 |
24 |
timeout |
41-HWPing命令 |
1-32 |
timer |
19-AAA命令 |
1-48 |
timer |
30-Cluster命令 |
1-39 |
timer loop |
14-自动侦测命令 |
1-6 |
timer quiet |
19-AAA命令 |
1-49 |
timer quiet |
19-AAA命令 |
1-63 |
timer realtime-accounting |
19-AAA命令 |
1-50 |
19-AAA命令 |
1-64 |
timer response-timeout |
19-AAA命令 |
1-51 |
19-AAA命令 |
1-64 |
timer retry |
17-组播协议命令 |
4-17 |
timer wait |
14-自动侦测命令 |
1-7 |
time-range |
25-ACL命令 |
1-25 |
timers |
16-路由协议命令 |
3-17 |
topology accept |
30-Cluster命令 |
1-45 |
topology restore-from |
30-Cluster命令 |
1-46 |
topology save-to |
30-Cluster命令 |
1-46 |
tos |
41-HWPing命令 |
1-33 |
tracemac |
30-Cluster命令 |
1-34 |
tracert |
39-系统维护与调试命令 |
2-2 |
tracert ipv6 |
42-IPv6管理命令 |
2-4 |
traffic-limit |
1-21 |
traffic-limit |
2-5 |
traffic-priority |
1-22 |
traffic-priority |
2-7 |
traffic-priority vlan |
1-24 |
traffic-redirect |
1-25 |
1-26 |
traffic-share-across-interface |
16-路由协议命令 |
3-18 |
traffic-statistic |
1-27 |
ttl |
41-HWPing命令 |
1-33 |
udp-helper enable |
32-UDP Helper命令 |
1-2 |
udp-helper port |
32-UDP Helper命令 |
1-2 |
udp-helper server |
32-UDP Helper命令 |
1-4 |
udp-helper ttl-keep enable |
32-UDP Helper命令 |
1-4 |
undelete |
36-文件系统管理命令 |
1-14 |
unicast-suppression |
08-端口基本配置命令 |
1-33 |
unknown-multicast drop enable |
17-组播协议命令 |
1-15 |
update fabric |
1-10 |
update fabric |
36-文件系统管理命令 |
1-14 |
update fabric |
39-系统维护与调试命令 |
3-20 |
user |
1-22 |
user privilege level |
02-登录交换机命令 |
1-25 |
user-interface |
02-登录交换机命令 |
1-24 |
username |
41-HWPing命令 |
1-34 |
user-name-format |
19-AAA命令 |
1-51 |
user-name-format |
19-AAA命令 |
1-65 |
verbose |
1-22 |
version |
48-SSL命令 |
1-8 |
view |
39-系统维护与调试命令 |
25 |
virtual-cable-test |
08-端口基本配置命令 |
1-33 |
vlan |
04-VLAN命令 |
1-6 |
vlan-assignment-mode |
19-AAA命令 |
1-23 |
vlan-mapping modulo |
15-MSTP命令 |
1-42 |
vlan-vpn enable |
40-VLAN-VPN命令 |
1-2 |
vlan-vpn inner-cos-trust |
40-VLAN-VPN命令 |
1-3 |
vlan-vpn priority |
40-VLAN-VPN命令 |
1-4 |
vlan-vpn tpid |
40-VLAN-VPN命令 |
1-5 |
vlan-vpn tunnel |
15-MSTP命令 |
1-42 |
vlan-vpn vid |
40-VLAN-VPN命令 |
2-2 |
vlink-peer |
16-路由协议命令 |
4-46 |
voice vlan |
06-Voice VLAN命令 |
1-4 |
voice vlan aging |
06-Voice VLAN命令 |
1-4 |
voice vlan enable |
06-Voice VLAN命令 |
1-5 |
voice vlan legacy |
06-Voice VLAN命令 |
1-6 |
voice vlan mac-address |
06-Voice VLAN命令 |
1-6 |
voice vlan mode |
06-Voice VLAN命令 |
1-7 |
voice vlan qos |
06-Voice VLAN命令 |
1-8 |
voice vlan qos trust |
06-Voice VLAN命令 |
1-9 |
voice vlan security enable |
06-Voice VLAN命令 |
1-9 |
voice-config |
24-DHCP命令 |
1-37 |
vrrp method |
22-VRRP命令 |
1-5 |
vrrp ping-enable |
22-VRRP命令 |
1-5 |
vrrp vlan-interface vrid track |
22-VRRP命令 |
1-6 |
vrrp vrid authentication-mode |
22-VRRP命令 |
1-7 |
vrrp vrid preempt-mode |
22-VRRP命令 |
1-8 |
vrrp vrid priority |
22-VRRP命令 |
1-9 |
vrrp vrid timer advertise |
22-VRRP命令 |
1-9 |
vrrp vrid track detect-group |
14-自动侦测命令 |
1-7 |
vrrp vrid track interface |
22-VRRP命令 |
1-10 |
vrrp vrid virtual-ip |
22-VRRP命令 |
1-11 |
web-authentication customize |
20-Web认证命令 |
1-3 |
web-authentication cut connection |
20-Web认证命令 |
1-4 |
web-authentication enable |
20-Web认证命令 |
1-5 |
web-authentication free-ip |
20-Web认证命令 |
1-6 |
web-authentication free-user |
20-Web认证命令 |
1-6 |
web-authentication max-connection |
20-Web认证命令 |
1-7 |
web-authentication protocol |
20-Web认证命令 |
1-8 |
web-authentication select method |
20-Web认证命令 |
1-8 |
web-authentication timer idle-cut |
20-Web认证命令 |
1-9 |
web-authentication timer max-online |
20-Web认证命令 |
1-10 |
web-authentication web-server |
20-Web认证命令 |
1-10 |
webcache address |
27-Web Cache重定向命令 |
1-2 |
webcache redirect-vlan |
27-Web Cache重定向命令 |
1-3 |
wred |
1-28 |
xmodem get |
39-系统维护与调试命令 |
3-20 |
