03-MAC地址认证命令
本章节下载 (114.23 KB)
1.1.1 display mac-authentication
1.1.3 mac-authentication domain
1.1.4 mac-authentication timer
1.1.5 mac-authentication user-name-format
1.1.6 reset mac-authentication statistics
display mac-authentication [ interface interface-list ]
【缺省级别】
2:系统级
interface interface-list:以太网端口列表,表示多个以太网端口,表示方式为interface-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-10>。其中,interface-type为端口类型,interface-number为端口号。&<1-10>表示前面的参数最多可以输入10次。起始端口类型必须和终止端口类型一致,并且终止端口号必须大于起始端口号。
【描述】
display mac-authentication命令用来显示全局或指定端口的MAC地址认证信息。
# 显示全局的MAC地址认证信息。
MAC address authentication is enabled.
User name format is MAC address, like xxxxxxxxxxxx
Fixed username:mac
Fixed password:not configured
Offline detect period is 300s
Quiet period is 60s.
Server response timeout value is 100s
the max allowed user number is 2048 per slot
Current user number amounts to 0
Current domain: not configured, use default domain
Silent Mac User info:
MAC Addr From Port Port Index
GigabitEthernet2/0/1 is link-up
Authenticate success: 0, failed: 0
Current online user number is 0
MAC Addr Authenticate state AuthIndex
……(略)
表1-1 display mac-authentication命令显示信息描述表
域名 |
MAC address authentication is enabled |
MAC地址认证特性已经开启 |
User name format is MAC address, like xxxxxxxxxxxx |
MAC地址形式的用户名,用户名格式为不带连字符的MAC地址,形如xxxxxxxxxxxx 若配置MAC地址形式的用户名格式带连字符,则显示“like xx-xx-xx-xx-xx-xx” |
Fixed username: |
固定用户名 |
Fixed password: |
固定用户名的密码 |
Offline detect period |
下线检测定时器的时间间隔 |
Quiet period |
静默定时器的时间间隔 |
Server response timeout value |
服务器连接超时定时器的值 |
The max allowed user number |
设备每板最大支持的MAC地址认证用户数 |
Current user number amounts |
当前用户数 |
Current domain: not configured, use default domain |
当前认证域没有配置,使用缺省域 |
Silent Mac User info |
静默用户信息 |
GigabitEthernet2/0/1 is link-up |
端口GigabitEthernet2/0/1链路处于UP状态 |
端口GigabitEthernet2/0/1MAC地址认证特性已开启 |
Authenticate success: 0, failed: 0 |
端口上MAC地址认证的统计信息,包括认证通过和认证失败的数目 |
Current online user number |
端口当前的接入用户数 |
MAC Addr |
MAC地址 |
Authenticate state |
端口接入用户的状态,共有四种: l CONNECTING:正在连接 l SUCCESS:认证通过 l FAILURE:认证失败 l LOGOFF:已下线 |
AuthIndex |
认证体索引号 |
在系统视图下:
undo mac-authentication [ interface interface-list ]
在以太网端口视图下:
mac-authentication
系统视图/以太网端口视图
【缺省级别】
2:系统级
【描述】
mac-authentication命令用来开启指定端口上或全局的MAC地址认证特性。undo mac-authentication命令用来关闭指定端口上或全局的MAC地址认证特性。
缺省情况下,所有端口及全局的MAC地址认证特性都处于关闭状态。
l 在系统视图下使用该命令时,如果不输入可选项interface interface-list,则表示开启全局的MAC地址认证特性;如果指定了interface interface-list,则表示开启指定端口的MAC地址认证特性。在以太网端口视图下使用该命令时,不能指定参数interface-list,只能开启当前端口的MAC地址认证特性。
l MAC地址认证特性启动前后,都可以使用命令来配置全局或端口的MAC地址认证特性参数。如果在开启全局MAC地址认证特性前,没有配置全局或端口的MAC地址认证特性参数,则这些参数在运行时均为缺省值。
l 各端口的MAC地址认证状态在全局MAC地址认证没有开启之前可以配置,但不起作用;在全局MAC地址认证启动后,各端口的MAC地址认证配置会立即生效。
# 开启全局的MAC地址认证特性。
[Sysname] mac-authentication
Mac-auth is enabled globally.
# 开启以太网端口GigabitEthernet2/0/1上的MAC地址认证特性。
[Sysname] mac-authentication interface GigabitEthernet 2/0/1
Mac-auth is enabled on port GigabitEthernet2/0/1.
或者
[Sysname] interface GigabitEthernet 2/0/1
[Sysname-GigabitEthernet2/0/1] mac-authentication
mac-authentication domain isp-name
undo mac-authentication domain
【缺省级别】
2:系统级
isp-name:ISP域名,为1~24个字符的字符串,不区分大小写,且不能包括“/”、“:”、“*”、“?”、“<”、“>”以及“@”等特殊字符。
【描述】
mac-authentication domain命令用来配置MAC地址认证用户所使用的ISP域。undo mac-authentication domain命令用来恢复缺省情况。
缺省情况下,MAC地址认证用户使用缺省ISP域。关于缺省ISP域的介绍请参见“安全分册/AAA命令”中的命令domain default enable。
# 配置MAC地址认证使用的域为domain1。
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
undo mac-authentication timer { offline-detect | quiet | server-timeout }
【缺省级别】
2:系统级
offline-detect offline-detect-value:表示下线检测定时器。其中,offline-detect-value表示下线检测定时器的值,取值范围60~65535,单位为秒。
quiet quiet-value:表示静默定时器。其中quiet-value表示静默定时器的值,取值范围1~3600,单位为秒。
server-timeout server-timeout-value:表示服务器超时定时器。其中,server-timeout-value表示服务器超时定时器的值,取值范围为100~300,单位为秒。
【描述】
mac-authentication timer命令用来配置MAC地址认证的各项定时器参数。undo mac-authentication timer命令用来将指定的定时器恢复为缺省情况。
缺省情况下,下线定时器的值为300秒,静默定时器的值为60秒,服务器的超时定时器的值为100秒。
MAC地址认证过程受以下定时器的控制:
l 下线检测定时器(offline-detect):用来设置用户空闲超时的时间间隔。如果在两个时间间隔之内,没有来自用户的流量通过,设备将切断用户的连接,同时通知RADIUS服务器,停止对该用户的计费。
l 静默定时器(quiet):用来设置用户认证失败以后,设备需要等待的时间间隔。在静默期间,设备不处理该用户的认证功能,静默之后设备再重新对用户发起认证。
l 服务器超时定时器(server-timeout):用来设置设备同RADIUS服务器的连接超时时间。在用户的认证过程中,如果服务器超时定时器超时,设备将在相应的端口上禁止此用户访问网络。
相关配置可参考命令display mac-authentication。
# 设置服务器超时定时器时长为150秒。
mac-authentication user-name-format { fixed [ account name ] [ password { cipher | simple } password ] | mac-address [ with-hyphen | without-hyphen ] }
undo mac-authentication user-name-format
【缺省级别】
2:系统级
fixed:表示采用固定用户名格式。
account name:指定用户名。其中name为用户名,为1~55个字符的字符串,不区分大小写,缺省为mac。
password { cipher | simple } password:指定固定用户名的密码。其中,cipher表示密文显示密码,simple表示明文显示密码,password表示用户密码。无缺省值。
l 密文显示的情况下,可输入1~63个字符的明文字符串密码,也可输入长度为24或88个字符的密文字符串密码;
l 明文显示的情况下,只能输入1~63个字符的明文字符串。
mac-address:表示使用用户的源MAC地址为用户名。
with-hyphen:带连字符“-”的MAC地址格式,例如xx-xx-xx-xx-xx-xx,其中的字母必须小写。
without-hyphen:不带连字符“-”的MAC地址格式,例如xxxxxxxxxxxx,其中的字母必须小写。
【描述】
mac-authentication user-name-format命令用来配置MAC地址认证的用户名和密码。undo mac-authentication user-name-format命令用来恢复缺省情况。
缺省情况下,使用用户的源MAC地址做用户名和密码,不带连字符。
l 若指定用户的源MAC地址为用户名,则用户密码也为用户的源MAC地址。
l 在cipher方式下,长度小于等于16的明文密码会被加密为长度是24的密文,长度大于16且小于等于63的明文密码会被加密为长度是88的密文。当用户输入长度为24的密码时,如果密码能够被系统解密,则按密文密码处理;若不能被解密,则按明文密码处理。
# 配置MAC认证的用户名为abc,密码是明文显示的xyz。
reset mac-authentication statistics [ interface interface-list ]
【缺省级别】
2:系统级
【描述】
reset mac-authentication statistics命令用来清除MAC认证的统计信息。
l 如果不指定端口类型和端口号,则清除设备上的全局及所有端口的MAC认证统计信息;
l 如果指定端口类型和端口号,则清除指定端口上的MAC认证统计信息。
# 清除以太网端口GigabitEthernet2/0/1上的MAC认证统计信息。
<Sysname> reset mac-authentication statistics interface GigabitEthernet 2/0/1
