07-WLAN分册
01-WLAN命令
本章节下载 01-WLAN命令  (481.88 KB)
01-WLAN命令
  录
1 WLAN命令
1.1 802.11 MAC配置命令
1.1.1 a-mpdu enable
1.1.2 a-msdu enable
1.1.3 beacon ssid-hide
1.1.4 beacon-interval
1.1.5 channel
1.1.6 channel band-width
1.1.7 client dot11n-only
1.1.8 client max-count(服务模板视图)
1.1.9 display wlan client
1.1.10 display wlan service-template
1.1.11 display wlan statistics
1.1.12 dtim
1.1.13 fragment-threshold
1.1.14 long-retry threshold
1.1.15 max-power
1.1.16 max-rx-duration
1.1.17 preamble
1.1.18 radio type
1.1.19 reset wlan client
1.1.20 reset wlan statistics
1.1.21 rts-threshold
1.1.22 service-template (WLAN射频接口视图)
1.1.23 service-template (服务模板视图)
1.1.24 short-gi enable
1.1.25 short-retry threshold
1.1.26 shutdown
1.1.27 ssid
1.1.28 wlan broadcast-probe reply
1.1.29 wlan client idle-timeout
1.1.30 wlan client keep-alive
1.1.31 wlan country-code
1.1.32 wlan service-template
1.1.33 wlan uplink-interface
2 WLAN Mesh配置命令
2.1 WLAN Mesh配置命令
2.1.1 bind wlan-mesh
2.1.2 display wlan mesh-link
2.1.3 display wlan mesh-profile
2.1.4 display wlan mp-policy
2.1.5 link-hold-rssi
2.1.6 link-saturation-rssi
2.1.7 link rate-mode
2.1.8 link-backhaul-rate
2.1.9 link-initiation enable
2.1.10 link-keep-alive
2.1.11 link-maximum-number
2.1.12 mesh-id
2.1.13 mesh-profile
2.1.14 mesh-profile enable
2.1.15 mesh peer-mac-address
2.1.16 mp-policy
2.1.17 probe-request-interval
2.1.18 wlan mesh-profile
2.1.19 wlan mp-policy
2.1.20 wlan uplink-interface mesh-link
3 WLAN安全配置命令
3.1 WLAN安全配置命令
3.1.1 authentication-method
3.1.2 cipher-suite
3.1.3 gtk-rekey client-offline
3.1.4 gtk-rekey enable
3.1.5 gtk-rekey method
3.1.6 ptk-lifetime
3.1.7 security-ie
3.1.8 tkip-cm-time
3.1.9 wep default-key
3.1.10 wep key-id
4 WLAN RRM 命令
4.1 WRRM配置命令
4.1.1 dot11a
4.1.2 dot11b
4.1.3 dot11g
4.1.4 dot11g protection
4.1.5 dot11n mandatory maximum-mcs
4.1.6 dot11n support maximum-mcs
4.1.7 autochannel-set avoid-dot11h
4.1.8 display wlan rrm
4.1.9 power-constraint
4.1.10 spectrum-management enable
4.1.11 wlan rrm
5 WLAN IDS配置命
5.1 WLAN-Rouge AP配置命令
5.1.1 attack-detection enable
5.1.2 display wlan ids history
5.1.3 display wlan ids statistics
5.1.4 wlan ids
5.1.5 reset wlan ids history
5.1.6 reset wlan ids statistics
5.2 WLAN-FrameFiltering配置命令
5.2.1 display wlan blacklist
5.2.2 display wlan whitelist
5.2.3 dynamic-blacklist enable
5.2.4 dynamic-blacklist lifetime
5.2.5 reset wlan dynamic-blacklist
5.2.6 static-blacklist mac-address
5.2.7 whitelist mac-address
6 WLAN QoS配置命令
6.1 WLAN QoS配置命令
6.1.1 display wlan wmm
6.1.2 reset wlan wmm
6.1.3 wmm cac policy
6.1.4 wmm edca radio
6.1.5 wmm edca client(ac-vo和ac-vi)
6.1.6 wmm edca client(ac-be 和ac-bk)
6.1.7 wmm enable
6.1.8 wmm svp map-ac
7 无线用户接入
7.1.1 l2fw wlan-client-isolation enable
l    手册中标有请以设备实际情况为准的地方,请参见“用户手册”中的“特性差异化列表”部分的描述。
l    设备支持的接口类型和编号与设备的实际情况相关,本手册涉及以太网接口的配置举例统一使用Eth口举例说明。实际使用中请根据具体设备的接口类型和编号进行配置。
1 WLAN命令
1.1  802.11 MAC配置命令
1.1.1  a-mpdu enable
a-mpdu enable
undo a-mpdu enable
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
a-mpdu enable命令用来使能指定接口的A-MPDU功能。undo a-mpdu enable命令用来关闭A-MPDU功能。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
缺省情况下,在802.11n模式下A-MPDU功能处于使能状态。
需要注意的是,该命令仅对802.11n模式的接口有效。在进行接口模式切换的时候,恢复该功能在该模式下的缺省情况。
射频接口正在使用时是无法关闭A-MPDU功能的,需要使用shutdown命令关闭射频接口之后,才可以关闭A-MPDU功能。
# 关闭当前射频接口的A-MPDU功能
<sysname> system-view
[sysname] interface WLAN-Radio 1/0/1
[sysname-WLAN-Radio1/0/1] undo a-mpdu enable
1.1.2  a-msdu enable
a-msdu enable
undo a-msdu enable
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
a-msdu enable命令用来使能指定接口的A-MSDU功能。undo a-msdu enable用来关闭A-MSDU功能。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
缺省情况下,802.11n模式下A-MSDU功能处于使能状态。
需要注意的是,该命令仅对802.11n模式的接口有效。在进行接口模式切换的时候,恢复该功能在该模式下的缺省情况。目前,设备只支持接收A-MSDU。
射频接口正在使用时是无法关闭A-MSDU功能的,需要使用shutdown命令关闭射频接口之后,才可以关闭A-MSDU功能。
# 关闭当前射频接口的A-MSDU功能
[sysname- WLAN-Radio1/0/1] undo a-msdu enable
beacon ssid-hide
undo beacon ssid-hide
服务模板视图
【缺省级别】
2:系统级
【描述】
beacon ssid-hide命令用来设置禁止在信标帧中通告SSIDundo beacon ssid-hide命令用来恢复缺省配置。
缺省情况下,信标帧通告SSID。
SSID隐藏后,AP发送的信标帧里面不包含SSID信息,接入客户端必须在无线网卡上手动配置该SSID标识才能接入AP。隐藏SSID对无线安全意义并不是很大。允许广播SSID可以使AP在关联阶段更容易发现客户端。
# 禁止信标帧通告SSID。
<Sysname> System-view
[Sysname] wlan service-template 1 clear
[Sysname-wlan-st-1] beacon ssid-hide
beacon-interval interval
undo beacon-interval
WLAN射频接口视图
【缺省级别】
2:系统级
interval:发送信标帧的时间间隔。取值范围为32~8191,单位TU(Time Unit,1024微秒)。
【描述】
beacon-interval命令用来设置发送信标帧的时间间隔。信标帧按规定的时间间隔周期性发送,以允许移动用户接入网络。undo beacon-interval命令用来恢复缺省的时间间隔。
缺省情况下,发送信标帧的时间间隔为100TU。
信标帧用于与其它接入点设备或其它网络控制设备进行联络,表明本设备的存在。
# 设置发送信标帧的时间间隔为1000TU。
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] beacon-interval 1000
1.1.5  channel
channel { channel-number | auto }
undo channel
WLAN射频接口视图
【缺省级别】
2:系统级
channel-number:射频的工作信道。信道可以基于国家代码和射频模式来进行选择。
auto:在系统初始化时,由设备根据实际环境自动选择最优信道。
【描述】
channel命令用来配置射频的工作信道。undo channel命令用来恢复为缺省配置。
缺省情况下,使能自动选择信道模式,即auto模式。
不同的射频支持不同的信道,同时信道可能因国家不同而有所不同。
# 设置射频的工作信道为6。
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] radio-type dot11b
[Sysname-WLAN-Radio1/0/2] channel 6
channel band-width { 20 | 40 }
undo channel band-width
WLAN射频接口视图
【缺省级别】
2:系统级
20:表示该802.11n端口的工作带宽是20MHz。
40:表示该802.11n端口的工作带宽是40MHz。
【描述】
channel band-width命令用来指定当前Radio接口的带宽模式。undo channel band-width命令用来恢复缺省情况。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
缺省情况下,11an类型的Radio接口的带宽工作在40MHz,11gn类型的Radio接口的带宽工作在20MHz。
需要注意的是
l              该命令仅对802.11n类型的接口有效。在进行接口模式切换的时候,恢复在该模式下的默认值。
l              在指定Radio接口的带宽为40MHz情况下,如果找到可以绑定的信道,那么使用40MHz带宽,如果找不到可以绑定的信道,那么实际使用20MHz带宽。
# 配置当前射频接口的工作方式为20MHz。
[sysname-WLAN-Radio1/0/1] radio-type dot11an
[sysname-WLAN-Radio1/0/1] channel band-width 20
client dot11n-only
undo client dot11n-only
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
client dot11n-only命令用来使能仅允许802.11n用户接入功能。undo client dot11n-only用来恢复缺省情况。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
缺省情况下,802.11an类型的接口可以允许802.11a用户接入;802.11gn类型的接口可以允许802.11g的用户接入。
关于混合接入:802.11n支持2.4GHz和5GHz两个频段,考虑到11n设备对11a/b/g工作站的兼容性,目前的802.11n设备支持802.11a/b/g工作站的混合接入。也就是在802.11n模式时可以同时提供802.11a或者802.11g(11b用户工作方式与11g相同)的接入。
需要注意的是:当用户使能client dot11n-only命令后,非802.11n的客户端将不能接入到AP,如果用户想要兼容802.11a/b/g的客户端,同时还要接入802.11n的客户端,则必须关闭client dot11n-only命令。
# 在当前射频接口上使能只允许802.11n用户接入。
[sysname-WLAN-Radio1/0/1] client dot11n-only
client max-count max-number
undo client max-count
服务模板视图
【缺省级别】
2:系统级
max-number:BSS中关联客户端的最大个数。取值范围1~64。
【描述】
client max-count命令用来指定BSS中关联客户端的最大个数。undo client max-count命令用来恢复缺省情况。
如果BSS中的关联客户端达到最大个数,除非某些关联客户端因为某种原因解关联了,否则没有客户端能够再加入BSS。
缺省情况下,BSS中可关联客户端最多为64。
# 指定BSS中关联客户端的数量最多为10。
[Sysname-wlan-st-1] client max-count 10
display wlan client { interface wlan-radio [ wlan-radio-number ] | mac-address mac-address | service-template service-template-number } [ verbose ]
【缺省级别】
1:监控级
wlan-radio radio-number:显示连接到指定射频接口的客户端信息。
mac-address mac-address:客户端的MAC地址。
service-template service-template-number:显示基于指定服务模板的客户端信息。服务模板取值范围为1~1024。
verbose:显示用户的详细信息。该参数在输入了radio-number、mac-address、service-template-numberdisplay wlan client命令之后才会出现。
【描述】
display wlan client命令用来查看指定客户端或者所有客户端的信息。
# 显示所有用户的信息。
<Sysname> display wlan client
 Total Number of Clients           : 2
 Total Number of Clients Connected : 2
                               Client Information
MAC Address        BSSID             AID    State       PS Mode      QoS Mode
 0011-95c3-9241    000f-e200-0500    1      Running     Active      WMM
 0013-4695-16dd    000f-e200-0500    2      Running     Active      None
表1-1 display wlan client命令显示信息描述表
MAC address
客户端的MAC地址
BSSID
BSS的MAC地址
AID
客户端的关联ID
客户端的状态,例如:Running
PS Mode
客户端的节电模式:active或者sleep
QoS Mode
AP是否支持WMM标志。并且只有当AP和客户端同时支持WMM时,才能显示WMM标志。
# 显示所有用户的详细信息。
<Sysname> display wlan client verbose
 Total Number of Clients           : 1
 Total Number of Clients Connected : 1
                              Client Information
 MAC Address                       : 0014-6c91-9a14
 AID                               : 251
 Radio Interface                   : WLAN-Radio1/0/2
 SSID                              : nsw-nsw
 BSSID                             : 000f-e2cc-2022
Port                              : WLAN-BSS1
 VLAN                              : 1
 State                             : Running
 Power Save Mode                   : Sleep
Wireless Mode                     : 11g
 QoS Mode                          : WMM
 Listen Interval (Beacon Interval) : 10
 RSSI                              : 25
 SNR                               : 0
 Rx/Tx Rate                        : 48/54
 Client Type                       : RSN
 Authentication Method             : Open System
 AKM Method                        : Dot1X
 4-Way Handshake State             : PTKINITDONE
 Group Key State                   : IDLE
 Encryption Cipher                 : CCMP
 Roam Status                       : Normal
 Up Time (hh:mm:ss)                : 00:05:15
表1-2 display wlan client verbose命令显示信息描述表
MAC address
客户端的MAC地址
AID
客户端的关联ID
Radio Interface
WLAN射频接口
SSID
AP的SSID
BSSID
BSS的MAC地址
Port
与客户端关联的WLAN-BSS接口
VLAN
VLAN接口号
客户端的状态,例如:运行
Power Save Mode
客户端的节电模式:激活或者睡眠
Wireless Mode
无线模式:802.11a,802.11b,802.11g,802.11gn,802.11an
QoS Mode
AP是否支持WMM标志
Listen Interval
客户端清醒后监听信标帧间间隔,单位为Beacon interval(信标发送时间间隔)
RSSI
接收信号强度指示,该指标值表明了AP检测到Client的信号强度
SNR
信噪比
Rx/Tx Rate
上一个帧的接收和传输速率。对于分离式AP结构,由于接收/传输速率信息是按照一定的时间间隔周期性的从AP传送到AC,因此会有延时
Client Type
客户端类型,例如:RSN、WPA或Pre-RSN
认证方法,例如:开放系统或共享密钥
AKM Method
AKM套件,如Dot1X,PSK
4次握手状态中的一种:
IDLE:初始化状态
PTKSTART:4次握手初始化完毕
PTKNEGOTIATING:发送了有效消息3
PTKINITDONE:4次握手成功
Group Key State
组密钥状态,包括以下几种:
IDLE:初始化状态
REKEYNEGOTIATE:无线控制器向用户发送初始化消息
REKEYESTABLISHE:密钥更新成功
Encryption Cipher
加密密码:明文或者密文加密的类型
Roam Status
漫游状态:正常或者快速漫游。fat AP总是显示为正常
Up Time
客户端和AP关联的时间
display wlan service-template [ service-template-number ]
【缺省级别】
1:监控级
service-template-number:服务模板号,取值范围为1~1024。
【描述】
display wlan service-template命令用来查看指定的服务模板的信息。
如果未指定服务模板号,则显示所有服务模板的信息。
# 显示服务模板1的配置信息。
<Sysname> display wlan service-template 1
                           Service Template Parameters
 Service Template Number      : 1
 SSID                         : nsw-nsw
 Service Template Type        : Crypto
 Security IE                  : RSN WPA
 SSID-hide                    : Disabled
Cipher Suite                 : TKIP CCMP
 WEP Key Index  1             : WEP40
 WEP Key Mode                 : ASCII
 WEP Key                      : 12345
 TKIP Countermeasure Time(s)  : 60
 PTK Life Time(s)             : 180
 GTK Rekey                    : Enable
 GTK Rekey Method             : Packet-based
 GTK Rekey Packets            : 5000
 Service Template Status      : Enable
 Maximum clients per BSS      : 35
表1-3 display wlan service-template命令各字段的含义描述
当前服务模板号
SSID
ESS的服务集识别码
服务模板类型:cryto或、clearwapi
Security IE
安全IE:WPA或RSN
使用的认证类型:开放系统认证或者共享密钥认证
SSID-hide
Disabled:启用SSID通告
Enabled:禁用SSID通告
Cipher Suite
加密套件:CCMP、TKIP、WEP40、WEP104或WEP128
WEP Key Index
加密或解密帧的密钥索引
WEP Key Mode
WEP密钥模式
WEP Key
WEP密钥
TKIP反制策略中,MIC失败的计时器,以秒为单位
PTK Life Time(s)
PTK生存时间,以秒为单位
GTK Rekey
GTK密钥更新配置
GTK Rekey Method
已配置的GTK密钥更新方法:基于包或基于时间
GTK Rekey Packets
GTK密钥更新包数
服务模板状态:启用或禁用
一个BSS中能够连接的最大客户端数
display wlan statistics client { all | mac-address mac-address }
【缺省级别】
1:监控级
client:显示指定客户端的统计信息。
all:显示所有客户端的统计信息。
【描述】
display wlan statistics命令用来查看指定客户端的统计信息。
# 显示所有客户端统计信息。
<Sysname> display wlan statistics client all
                                Client Statistics
 AP Name                           : ap1
 Radio Id                          : 1
 SSID                              : 123
 BSSID                             : 000f-e2ff-7700
 MAC Address                       : 0014-6c8a-43ff
 RSSI                              : 31
 Transmitted Frames:
 Back Ground (Frames/Bytes)        : 0/0
 Best Effort (Frames/Bytes)        : 9/1230
 Video (Frames/Bytes)              : 0/0
 Voice (Frames/Bytes)              : 2/76
 Received Frames:
 Best Effort (Frames/Bytes)        : 18/2437
 Voice (Frames/Bytes)              : 7/468
 Discarded Frames:
 Best Effort (Frames/Bytes)        : 0/0
 Voice (Frames/Bytes)              : 5/389
表1-4 display wlan statistics命令各字段的含义描述
AP Name
接入点名称
Radio Id
射频ID号
SSID
AP的SSID
BSSID
AP的MAC地址
MAC Address
客户端的MAC地址
RSSI
接收信号强度指示,该指标值表明了AP检测到的Client的信号强度
Transmitted Frames
发送的帧的总数
Back Ground
以帧或字节为单位对背景流优先级队列进行统计
Best Effort
以帧或字节为单位尽力而为流优先级队列
Video
以帧或字节为单位视频流优先级队列
Voice
以帧或字节为单位语音流优先级队列
Received Frames
收到的帧的数目
Discarded Frames
丢弃的帧的数目
Back Ground、Best Effort、Video及Voice优先级的统计仅针对QoS客户端。对于非QoS客户端的收发流量,统一统计为Best Effort类型,包括SVP报文,可能与实际物理发送队列不一致。上述优先级统计只能针对dot11e或者WMM报文携带的用户优先级进行区分,否则会造成接收方向无法统计。
1.1.12  dtim
dtim counter
undo dtim
WLAN射频接口视图
【缺省级别】
2:系统级
counter:DTIM帧间的信标数,取值范围为1~31。例如,配置counter值为1,则每个信标帧中都会携带DTIM信息。
【描述】
dtim命令用来在AP发送缓存的多播帧或广播帧之前,为其设置信标帧的计数器。undo dtim 命令用来恢复DTIM时间间隔为缺省值。
缺省情况下,DTIM时间间隔为1。
当DTIM计数达到0时,AP才会发送缓存中的多播帧或广播帧。
# 配置DTIM计数器为10。
[Sysname-WLAN-Radio1/0/1] dtim 10
fragment-threshold size
undo fragment-threshold
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
fragment-threshold命令用来指定帧的分片门限值。undo fragment-threshold命令用来恢复分片门限值为缺省值。
缺省情况下,帧的分片门限值为2346字节,即小于2346字节的帧在传输时不分片。当数据包的实际大小超过指定的分片门限值时,该数据包被分片传输。
# 配置帧的分片门限值为2048字节。
[Sysname-WLAN-Radio1/0/1] fragment-threshold 2048
long-retry threshold count
undo long-retry threshold
WLAN射频接口视图
【缺省级别】
2:系统级
count:帧长超过RTS门限值的帧的最大发送次数,取值范围为1~15。
【描述】
long-retry threshold命令用来设置帧长超过RTS门限值的帧的最大发送次数。undo long-retry threshold命令用来恢复缺省情况。
缺省情况下,帧长超过RTS门限值的帧的最大发送次数为4。
# 配置帧长超过RTS门限值的帧的最大发送次数为10。
[Sysname-WLAN-Radio1/0/1] long-retry threshold 10
1.1.15  max-power
max-power radio-power
undo max-power
WLAN射频接口视图
【缺省级别】
2:系统级
radio-power:射频功率的最大值,其取值范围由国家码和射频模式决定。
【描述】
max-power命令用来配置射频的最大传输功率。undo max-power命令用来恢复缺省情况。
缺省情况下,射频的最大功率由国家码、射频模式、信道和设备类型共同决定。
相关命令请参考wlan country-coderadio type
# 配置射频最大功率为5。
[Sysname-WLAN-Radio1/0/1] radio-type dot11a
[Sysname-WLAN-Radio1/0/1] max-power 5
max-rx-duration interval
undo max-rx-duration
WLAN射频接口视图
【缺省级别】
2:系统级
interval:AP接收到的帧可以在缓存区保存的最大时间,取值范围为500~250000,单位为毫秒。
【描述】
max-rx-duration命令用来配置AP接收的帧可以在缓存中保存的最大时间。undo max-rx-duration命令用来恢复缺省情况。
缺省情况下,AP接收的帧可以在缓存中保存的最大时间为2000毫秒。
# 配置AP接收的帧可以在缓存中保存的最大时间为5000毫秒。
[Sysname-WLAN-Radio1/0/1] max-rx-duration 5000
1.1.17  preamble
preamble { long | short }
WLAN射频接口视图
【缺省级别】
2:系统级
long指定只传输有long前导码的帧。
short:指定只传输有shortlong前导码的帧。
【描述】
preamble命令用来配置AP支持的前导码类型。undo preamble命令用来恢复AP支持的前导码类型为缺省值。
前导码是位于数据包起始处的一组bit位,接收者可以据此同步并准备接收实际的数据。前导码有两种:longshort
只有802.11b/g支持此项配置。
# 配置AP支持long前导码。
[Sysname-WLAN-Radio1/0/2] preamble long
1.1.18  radio type
radio-type { dot11a | dot11an | dot11b | dot11g | dot11gn }
WLAN射频接口视图
【缺省级别】
2:系统级
dot 11a表示无线接口工作在5GHZ的802.11a模式。
dot11an表示无线接口工作在5GHZ的802.11an模式。
dot 11b表示无线接口工作在2.4GHZ的802.11b模式。
dot 11g表示无线接口工作在2.4GHZ的802.11g模式。
dot11gn:表示无线接口工作在2.4GHZ的802.11gn模式。
【描述】
radio-type命令用来配置射频使用的射频类型。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
射频类型的缺省值取决于产品的型号。根据不同类型的AP,WLAN支持自定义缺省的射频类型。
# 配置射频接口的射频类型为802.11g。
[Sysname-WLAN-Radio1/0/2] radio-type dot11g
reset wlan client { all | mac-address mac-address }
【缺省级别】
2:系统级
all:断开所有的客户端连接。
mac-address:将要被断开连接的客户端的MAC地址。
【描述】
reset wlan client命令用来断开所有或指定的客户端连接。
执行这条命令后,AP将向客户端发送解除认证帧,同时停止对客户端提供WLAN接入服务。
# 断开MAC地址为0102-0304-0506的客户端连接。
<Sysname> reset wlan client mac-address 0102-0304-0506
reset wlan statistics client { all | mac-address mac-address }
【缺省级别】
2:系统级
all:重置所有客户端的统计信息。
【描述】
reset wlan statistics命令用来清除指定客户端或全部客户端的统计信息。
# 清除所有客户端射频的统计信息。
<Sysname> reset wlan statistics client all
rts-threshold size
undo rts-threshold
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
rts-threshold命令用来设置启用RTS机制所要求的帧的长度门限值。undo rts-threshold命令用来恢复缺省情况。
缺省情况下,启用RTS机制所要求的帧长度门限值为2346字节。
当帧的实际长度大于设定的门限值时,则系统启用RTS机制。
RTSRequest To Send,要求发送)用于在无线局域网中避免数据发送冲突。RTS包的发送频率需要合理设置,设置RTS门限时需要进行权衡:如果将RTS门限值设得较小,则会增加RTS包的发送频率,消耗更多的带宽。但与此同时,由于RTS包发送得越频繁,系统从中断或冲突中恢复得也就越快。
# 设置启用RTS机制所要求的帧的最大长度为2046字节。
[Sysname-WLAN-Radio1/0/1] rts-threshold 2046
service-template service-template-number interface wlan-bss wlan-bss-number
undo service-template service-template-number
WLAN射频接口视图
【缺省级别】
2:系统级
service-template-number:设置服务模板号。取值范围为1~1024。
wlan-bss-number:设置WLAN BSS接口号。取值范围为0~31。
【描述】
service-template命令用来将服务模板映射到当前的WLAN射频接口上指定的WLAN BSS接口或者WLAN以太网接口。undo service-template命令用来解除映射。
缺省情况下,没有任何映射。
# 将服务模板1与WLAN-Radio1/0/1上的WLAN BSS 1进行关联。
[Sysname-WLAN-Radio1/0/1] service-template 1 interface WLAN-BSS 1
service-template { disable | enable }
服务模板视图
【缺省级别】
2:系统级
disable:禁用服务模板。
enable:使能服务模板。
【描述】
service-template enable命令用来使能服务模板。service-template disable命令用来禁用服务模板。
缺省情况下,禁用服务模板。
# 使能服务模板1。
[Sysname-wlan-st-1] ssid ssid-1
[Sysname-wlan-st-1] authentication-method open-system
[Sysname-wlan-st-1] service-template enable
short-gi enable
undo short-gi enable
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
short-gi enable用来使能short GI功能。undo short-gi enable关闭short GI功能。
缺省情况下,Short GI功能处于使能状态。
需要注意的是,该命令仅在支持802.11n的接口上存在。在进行接口模式切换的时候,恢复该模式下的对该功能的缺省情况。
无线信号在空间传输会因多径等因素在接收侧形成时延,如果后面的数据块发送的过快,会和前一个数据块的形成干扰,而GI就是用来规避这个干扰的。在使用Short GI的情况下,可提高约10%的速率。
Short GI与带宽无关,支持20MHz、40MHz带宽。
# 禁止Short GI特性。
[sysname] interface WLAN-Radio1/0/2
[sysname-WLAN-Radio1/0/2] undo short-gi enable
short-retry threshold count
undo short-retry threshold
WLAN射频接口视图
【缺省级别】
2:系统级
count:设置AP在未收到确认的情况下,帧长不大于RTS门限值的单播帧的最大发送次数,取值范围为1~15。
【描述】
short-retry threshold命令用来设置帧长不大于RTS门限值的单播帧的最大发送次数。undo short-retry threshold命令用来恢复为缺省情况。
缺省情况下,帧长不大于RTS门限值的单播帧的最大发送次数为7。
# 设置帧长不大于RTS门限值的单播帧的最大发送次数为10。
[Sysname-WLAN-Radio1/0/1] short-retry threshold 10
1.1.26  shutdown
shutdown
WLAN射频接口视图/WLAN-BSS接口视图
【缺省级别】
2:系统级
【描述】
shutdown命令用来关闭当前正在使用的射频。undo shutdown命令用来使能射频。
缺省情况下,射频处于使能状态。
# 关闭射频。
[Sysname-WLAN-Radio1/0/1] shutdown
1.1.27  ssid
ssid ssid-name
undo ssid
服务模板视图
【缺省级别】
2:系统级
ssid-name:设置SSID的名称。SSID是服务模板的标识。1~32个字符的字符串,包含字母、数字及下划线“_”,区分大小写,可包含其他特殊字符(除“?”),注意字符串的开始和结束位置不可以用空格。
【描述】
ssid命令用来设置当前服务模板的SSID。undo ssid命令用来删除当前服务模板的SSID。
缺省情况下,没有设置SSID。
SSID的名称应该尽量具有唯一性。从安全方面考虑不应该体现公司名称,也不推荐使用长随机数序列做为SSID,因为长随机数序列只是增加了Beacon报文长度和使用难度,对无线安全没有改进。
# 设置服务模板1的SSID为firstfloor。
[Sysname-wlan-st-1] ssid firstfloor
undo wlan broadcast-probe reply
【缺省级别】
2:系统级
【描述】
wlan broadcast-probe reply命令用来设置AP响应广播的探查请求(Probe报文)。
客户端发送探查请求帧去定位附近的AP。这个探查请求帧包括了SSID和客户端支持的速率等客户端信息。AP收到客户端发送的探查请求帧后,会针对此请求发送一个探测响应。这个探测响应包括了网络SSID和AP支持的速率等信息,其中,AP支持的速率与信标帧中指示的发送速率相同。
广播探查请求是SSID为NULL的探查请求类型。
undo wlan broadcast-probe reply命令用来设置AP不响应广播的探查请求。
缺省情况下,设备接收广播Probe报文。
# 使能AP响应广播探查请求。
[Sysname] wlan broadcast-probe reply
wlan client idle-timeout interval
undo wlan client idle-timeout
【缺省级别】
2:系统级
interval:指定AP和客户端(节电状态或清醒状态)之间连接允许的最大空闲时间,取值范围为60~86400,单位为秒。
【描述】
wlan client idle-timeout命令用来配置AP和客户端之间的连接允许的最大空闲的时间。undo wlan client idle-timeout命令用来恢复缺省情况。
缺省情况下,空闲时间为3600秒。
如果客户端空闲的时间超过了指定时间,即AP在指定的时间内没有收到从客户端发来的数据,那么客户端将从网络中被删除。
# 设置客户端空闲时间为600秒。
[Sysname] wlan client idle-timeout 600
wlan client keep-alive interval
undo wlan client keep-alive
【缺省级别】
2:系统级
interval:保活请求的时间间隔,取值范围为3~1800,单位为秒。
【描述】
wlan client keep-alive命令用来设置保活时间间隔。undo wlan client keep-alive命令用来关闭保活功能。
缺省情况下,关闭客户端的保活功能。
保活机制通常用来检测客户端是否从系统中被隔离出来,并断开客户端同AP的连接,导致客户端被隔离的原因有电源故障、系统崩溃。
# 设置客户端的保活时间间隔为60秒。
[Sysname] wlan client keep-alive 60
wlan country-code code
undo wlan country-code
【缺省级别】
2:系统级
code:设置国家代码。详细内容请参见表1-5
表1-5 国家代码信息
国家
代码
国家
代码
澳大利亚
AU
列支敦士登
LI
阿根廷
AR
立陶宛
LT
奥地利
AT
卢森堡
LU
比利时
BE
马来西亚
MY
保加利亚
BG
马耳他
MT
巴西
BR
墨西哥
MX
加拿大
CA
摩洛哥
MA
智利
CL
荷兰
NL
中国
CN
新西兰
NZ
克罗地亚
HR
挪威
NO
塞浦路斯
CY
秘鲁
PE
捷克斯洛伐克
CZ
菲律宾
PH
丹麦
DK
波兰
PL
爱沙尼亚
EE
葡萄牙
PT
芬兰
FI
罗马尼亚
RO
法国
FR
俄罗斯
RU
德国
DE
沙特阿拉伯
SA
希腊
GR
新加坡
SG
中国香港
HK
斯洛伐克
SK
匈牙利
HU
斯洛文尼亚
SI
冰岛
IS
南非
ZA
印度
IN
西班牙
ES
印度尼西亚
ID
瑞典
SE
爱尔兰
IE
瑞士
CH
以色列
IL
中国台湾省
TW
意大利
IT
泰国
TH
日本
JP
土耳其
TR
韩国
KR
英国
GB
拉脱维亚
LV
美国
US
【描述】
wlan country-code命令用来设置国家代码。undo wlan country-code命令用来恢复国家代码为缺省值。
缺省情况下,国家代码为CN。
l    国家代码决定了射频信号的属性,如能量级别、信道总数等。在配置AP之前,必须正确的设置国家和地区码。
l    当改变国家码时,若AP上存在该地区所禁止的射频卡类型,相应wlan-radio接口下的服务模板、最大功率、信道等配置信息会自动取消。
# 设置国家代码为IN。
[Sysname] wlan country-code IN
wlan service-template service-template-number { clear | crypto | wapi }
undo wlan service-template service-template-number
【缺省级别】
2:系统级
service-template-number:设置服务模板号。取值范围是1~1024。
clear:设置当前服务模板为明文方式,即与AP关联后使用明文方式发送数据。
crypto:设置当前服务模板为密文方式,即与AP关联后使用密文方式发送数据。
wapi:设置当前服务模板类型为WAPI方式,即与AP关联后使用WAPI方式发送数据。
【描述】
wlan service-template命令用来创建服务模板或进入服务模板视图。如果输入的服务模板已经存在,则直接进入该视图。undo wlan service-template命令用来删除一个服务模板并清除相关的配置。如果指定的服务模板映射到射频,则在解除映射之前不能删除此服务模板。
缺省情况下,没有配置任何服务模板。
如果一个服务模板为clear类型,则不能将其转换为其他类型。如果需要将一个clear类型的服务模板转换为其他类型,必须首先删除该clear类型的模板,然后再创建一个需要的服务模板,反之亦然。
# 创建一个新的服务模板,服务模板号为1。
[Sysname] wlan service-template 1 crypto
wlan uplink-interface interface-type interface-number
undo wlan uplink-interface interface-type interface-number
【缺省级别】
2:系统级
interface-type interface-number:指定接口类型为上行接口。
【描述】
wlan uplink-interface命令用来指定接口类型为上行接口。undo wlan uplink-interface用来取消已有配置。
缺省情况下,没有配置上行接口。
l              如果所有配置的上行接口都处于down状态,设备将不能提供WLAN服务。WLAN服务正常运行要求至少有一个上行接口处于up状态。
l              只有以太网口光口/电口可以配置为上行接口。
l              可以同时配置多个上行接口。
# 配置以太网接口Ethernet 1/0/1为上行接口。
[Sysname] wlan uplink-interface Ethernet 1/0/1
2 WLAN Mesh配置命令
2.1  WLAN Mesh配置命令
bind wlan-mesh interface-index
undo bind wlan-mesh
Mesh-Profile视图
【缺省级别】
2:系统级
interface-index:指定的WLAN Mesh接口索引,取值范围为0~1023。
【描述】
bind wlan-mesh命令用来将指定的Mesh接口和Mesh绑定。undo bind wlan-mesh命令用来取消已配置的绑定关系。
缺省情况下,Mesh接口和Mesh Profile没有绑定关系。
一个Mesh接口只能绑定一个Mesh Profile。
# 将Mesh接口1绑定到Mesh Profile 1下。
[Sysname] wlan mesh-profile 1
[Sysname-wlan-mshp-1] bind wlan-mesh 1
display wlan mesh-link { mesh-profile mesh-profile-number | radio radio-number | peer-mac-address mac-address | all }
【缺省级别】
2: 系统级
mesh-profile mesh-profile-number:指定一个Mesh Profile,取值范围为1~32。
radio radio-number:指定一个radio。Radio号的范围为1到该设备支持的最大radio数。
peer-mac-address mac-address:指定邻居MP的MAC地址。
all:指定所有创建的链路。
【描述】
display wlan mesh-link命令用来显示Mesh链路信息。
此命令在MP上使用。
# 显示所有Mesh链路的信息。
<Sysname> display wlan mesh-link all
                              Peer Link Information
Nbr-Mac        BSSID          Interface         Link-state Uptime(hh:mm:ss)
000f-e274-3840 000f-e276-3240 WLAN-MESHLINK621  Active     0:5:16
000f-e274-3841 000f-e276-3240 WLAN-MESHLINK622  Active     1 Day,0:1:16
000f-e274-3842 000f-e276-3240 WLAN-MESHLINK623  Active     2 Days,0:0:16
表2-1 display wlan mesh-link命令显示信息描述表
Nbr-Mac
在此mesh链路上邻居的MAC地址
BSSID
在此mesh链路上邻居的MAC地址
mesh接口
Link-state
链路状态
Uptime(hh:mm:ss)
链路UP时间
display wlan mesh-profile { mesh-profile-number | all }
【缺省级别】
2:系统级
mesh-profile-number:Mesh策略号,取值范围为1~32。
all:所有Mesh策略。
【描述】
display wlan mesh-profile命令用来显示Mesh Profile信息。
# 显示Mesh Profile 1的信息。
<Sysname> display wlan mesh-profile 1
                                 Mesh Profile Parameters
 Mesh Profile Number                     : 1
 Mesh ID                                 : sys_mesh
 Binding Interface                       : WLAN-MESH1
 MKD Service                             : Enable
 Link Keep Alive Interval (s)            : 2 (Default)
 Link Backhaul Rate (Mbps)               : 18 (Default)
 Mesh Profile Status                     : Enable
表2-2 display wlan mesh-profile 命令显示信息描述表
Mesh Profile Number
Mesh策略号
Mesh ID
Mesh策略的Mesh ID
Binding Interface
绑定的Mesh接口
MKD Service
MKD服务是否使能
保活报文发送间隔
Link Backhaul Rate
链路回程速率
Mesh Profile Status
Mesh策略是否使能
display wlan mp-policy { mp-policy-name | all }
【缺省级别】
2: 系统级
mp-policy-name:MP策略名,为1~15个字符的字符串。字符可以包含字母,数字,下划线,但是不能有空格。
all:所有的MP策略。
【描述】
display wlan mp-policy命令用来显示MP策略信息。
# 显示所有MP策略的信息。
<Sysname> display wlan mp-policy all
                      Mesh Policy Parameters
 MP Policy Name              : default_mp_plcy
 Mesh Link Initiation        : Enable
 Authenticator Role          : Enable
 Max Links                   : 2 (Default)
 Probe Request Interval (ms) : 1000 (Default)
 Link Hold RSSI              : 15 (Default)
 Link saturation RSSI        : 150 (Default)
Link rate-mode              : fixed (Default)
 MP Policy Name              : new
 Max Links                   : 5
表2-3 display wlan mp-policy 命令显示信息描述表
MP Policy Name
MP策略名
Mesh链路发起是否使能
Authenticator Role
认证者角色是否使能
Max Links
策略允许的最大链路数
探查请求的发送间隔
Link Hold RSSI
链路保持RSSI
链路饱和RSSI
Link rate-mode
选择计算COST值的方式
link-hold-rssi value
undo link-hold-rssi
MP策略视图
【缺省级别】
2:系统级
value:链路保持RSSI,即维持Mesh链路的最小信号强度,取值范围为5~100,单位为dBm。
【描述】
link-hold-rssi命令用来配置维持Mesh链路的最小信号强度。undo link-hold-rssi命令用来恢复缺省情况。
缺省情况下,维持Mesh链路的最小信号强度值为15。
# 配置MP策略sys_mp的设置链路维持的最小信号强度为10dBm。
[Sysname] wlan mp-policy sys_mp
[Sysname-wlan-mp-policy-sys_mp] link-hold-rssi 10
link-saturation-rssi value
undo link-saturation-rssi
MP策略视图
【缺省级别】
2:系统级
value:Mesh链路饱和RSSI,取值范围为30~150,单位为dBm。
【描述】
link-saturation-rssi命令用来配置链路饱和RSSI。undo link-saturation-rssi命令用来恢复缺省情况。当活跃链路上的RSSI超过链路饱和RSSI时,会进行链路切换。
缺省情况下,链路饱和RSSI为100。
# 配置MP策略sys_mp的链路饱和RSSI为44。
[Sysname-wlan-mp-policy-sys_mp] link-saturation-rssi 44
link rate-mode { fixed | real-time }
undo link rate-mode
MP策略视图
【缺省级别】
2:系统级
fixed:Mesh链路接口的速率为固定值,其值为当前射频接口速率集的最大值。
real-time:Mesh链路接口的速率为根据链路质量(RSSI)实时变化的值,其值随radio接口的信号强度(RSSI)而变化。
【描述】
link rate-mode命令是用来配置选择计算COST值的方式。undo link rate-mode命令用来恢复缺省情况。
缺省情况下,使用fixed方式计算COST值。
# 配置根据链路质量(RSSI)实时变化的值来计算COST值。
[Sysname-wlan-mp-policy-sys_mp] link rate-mode real-time
link-backhaul-rate rate-value
undo link-backhaul-rate
Mesh-Profile视图
【缺省级别】
2:系统级
rate-value:链路回程速率,单位为Mbps。有效的速率包括1,2,5.5,6,9,11,12,18,24,36,48和54。
【描述】
link-backhaul-rate命令用来配置链路回程速率。undo link-backhaul-rate命令用来恢复缺省情况。
缺省情况下,链路回程速率为18Mbps。
# 设置Mesh Profile 1的链路回程速率为6Mbps。
[Sysname-wlan-mshp-1] link-backhaul-rate 6
undo link-initiation enable
MP策略视图
【缺省级别】
2:系统级
【描述】
link-initiation enable命令用来使能MP的链路发起功能。undo link-initiation enable命令用来关闭MP的链路发起功能。
缺省情况下,MP的链路发起功能是开启的。
此命令用于地铁WLAN Mesh的部署中。列车MP使能此项功能后,可以发起Mesh链路建立。而轨道MP间则不能建立Mesh链路。
# 关闭MP策略sys_mp的链路发起功能。
[Sysname-wlan-mp-policy-sys_mp] undo link-initiation enable
link-keep-alive keep-alive-interval
undo link-keep-alive
Mesh-Profile视图
【缺省级别】
2:系统级
keep-alive-interval:保活报文发送间隔,取值范围为1~1800秒。
【描述】
link-keep-alive命令用来配置Mesh链路上发送保活报文的时间间隔。undo link-keep-alive命令用来恢复缺省情况。
缺省情况下,保活报文发送间隔为2秒。
# 配置Mesh链路上发送保活报文的时间间隔为60秒。
[Sysname-wlan-mshp-1] link-keep-alive 60
link-maximum-number max-link-number
undo link-maximum-number
MP策略视图
【缺省级别】
2:系统级
max-link-number:最大Mesh链路数,取值范围为1~8。
【描述】
link-maximum-number命令用来配置策略允许MP建立的最大Mesh链路数。undo link-maximum-number命令用来恢复缺省情况。
缺省情况下,最大Mesh链路数为2。
# 设置MP策略sys_mp允许建立的最大链路数为5。
[Sysname-wlan-mp-policy-sys_mp] link-maximum-number 5
2.1.12  mesh-id
mesh-id mesh-id-name
undo mesh-id
Mesh-Profile视图
【缺省级别】
2:系统级
mesh-id-name:Mesh ID,为1~32个字符的字符串,区分大小写,其中不能包含问号“?”。
【描述】
mesh-id命令用配置当前Mesh Profile的Mesh ID。undo mesh-id命令用来删除配置的Mesh ID。
缺省情况下,没有为Mesh Profile配置Mesh ID。
一个Mesh ID只能属于一个Mesh策略。
# 为Mesh Profile 1设置的Mesh ID为sys_mesh
[Sysname-wlan-mshp-1] mesh-id sys_mesh
2.1.13  mesh-profile
undo mesh-profile mesh-profile-number
WLAN射频接口视图
【缺省级别】
2:系统级
mesh-profile-number:Mesh Profile号,取值范围为1~32。
【描述】
mesh-profile命令用来为当前射频接口绑定一个Mesh Profile。undo mesh-profile 命令用来取消绑定。
缺省情况下,当前射频接口没有绑定任何Mesh Profile。
注意:
l              一个射频接口只能绑定一个Mesh Profile。
l              如果业务策略已经和射频接口绑定,则不能为该射频接口绑定Mesh Profile,反之亦然。
# 将Mesh Profile 1与WLAN-Radio 1/0/1绑定。
[Sysname] interface WLAN-Radio 1/0/1
[Sysname-WLAN-Radio1/0/1] mesh-profile 1
mesh-profile enable
undo mesh-profile enable
Mesh-Profile视图
【缺省级别】
2:系统级
【描述】
mesh-profile enable命令用来使能当前Mesh Profile。undo mesh-profile enable 命令用来去使能当前Mesh Profile。
缺省情况下,Mesh Profile处于关闭状态。
注意:
l              在使能Mesh Profile前,必须绑定Mesh接口并配置Mesh ID。
l              如果一个Mesh Profile已经和一个射频接口绑定,则该策略不能被删除。
相关命令:bind wlan-meshmesh-idmesh-profile
# 使能Mesh策略1。
[Sysname-wlan-mshp-1] mesh-profile enable
mesh peer-mac-address mac-address
undo mesh peer-mac-address { mac-address | all }
WLAN射频接口视图
【缺省级别】
2:系统级
mac-address:Mesh邻居MAC地址。
all:删除所有Mesh邻居MAC地址。
【描述】
mesh peer-mac-address命令用来预先指定与其相连的邻居。用户可以配置一个或多个Mesh邻居MAC地址。本端设备会根据配置的MAC地址寻找相应的邻居来建立Mesh链路。undo mesh peer-mac-address用来取消已有配置。
缺省情况下,没有配置Mesh邻居MAC地址,即允许连接所有邻居。
# 配置与当前设备相连的邻居MAC地址。
[Sysname] interface WLAN-Radio 1/0/2
[Sysname-WLAN-Radio1/0/2] mesh peer-mac-address 01aa-0eaa-aa00
2.1.16  mp-policy
mp-policy my-policy-name
undo mp-policy
WLAN射频接口视图
【缺省级别】
2:系统级
my-policy-name:MP策略名,包含1~15个字符的字符串。字符可以包括字母,数字和下划线。
【描述】
mp-policy 命令用来将指定的MP策略与当前的radio绑定。undo mp-policy 命令用来恢复缺省情况。
缺省情况下,缺省的MP策略“default_mp_plcy” 与 radio绑定。
注意:
l              一个射频接口只能与一个MP策略绑定。
l              如果要取消绑定的MP策略,必须首先去使能射频接口。取消绑定后,缺省的MP策略会自动与射频接口绑定。
l              用户不能手动绑定缺省的MP策略。
# 将MP策略sys_mp和WLAN-Radio 1/0/2绑定。
[Sysname-WLAN-Radio1/0/2] mp-policy sys_mp
probe-request-interval interval-value
undo probe-request-interval
MP策略视图
【缺省级别】
2:系统级
Interval-value:探查请求的发送间隔,单位为毫秒,取值范围为100~8191。
【描述】
probe-request-interval命令用来配置探查请求的发送间隔。undo probe-request-interval命令用来恢复缺省情况。
缺省情况下,探查请求的发送间隔是1000毫秒。
# 为策略sys_mp配置探查请求的发送间隔为500毫秒。
[Sysname-wlan-mp-policy-sys_mp] probe-request-interval 500
wlan mesh-profile mesh-profile-number
undo wlan mesh-profile mesh-profile-number
【缺省级别】
2:系统级
【描述】
wlan mesh-profile命令用来创建一个Mesh Porfile,并进入Mesh Profile策略视图。undo wlan mesh-profile命令用来删除指定的Mesh Porfile。
如果想要修改Mesh Porfile里的参数,必须保证该策略没有被使能。
相关配置可参考命令bind wlan-meshmesh-idlink-keep-alivemesh-profile enablelink-backhaul-rate
# 创建Mesh Porfile 1并进入该视图。
wlan mp-policy mp-policy-name
undo wlan mp-policy mp-policy-name
【缺省级别】
2:系统级
mp-policy-name:MP策略名,包含1~15个字符的字符串。字符可以包括字母,数字和下划线。
【描述】
wlan mp-policy 命令用来创建一个MP策略,并进入MP策略视图。 undo wlan mp-policy 命令用来删除指定的MP策略。
缺省情况下,缺省MP策略“default_mp_plcy”与射频接口绑定。
l              一个MP策略名必须具备唯一性。
l              MP策略名不能是“a”,“al”,“all”,或“default_mp_plcy”,否则MP策略不能被创建。
l              缺省MP策略default_mp_plcy不能被删除或修改。
l              不能删除一个已经绑定射频接口的MP策略。
l              如果MP策略已经与射频接口绑定,且该射频接口已经被使能,则此MP策略的参数不能被修改。
相关配置可参考命令link-initiation enablelink-maximum-number, probe-request-interval
# 创建MP策略sys_mp,并进入MP策略视图。
wlan uplink-interface mesh-link interface-type interface-number
undo wlan uplink-interface mesh-link interface-type interface-number
【缺省级别】
2:系统级
【描述】
wlan uplink-interface mesh-link用来将射频接口配置为上行接口。undo wlan uplink-interface mesh-link用来取消已有配置。
缺省情况下,没有配置上行接口。
如果没有配置上行接口,设备默认会提供无线服务。
# 将指定的射频接口设置为上行接口。
[Sysname] wlan uplink-interface mesh-link wlan-radio 1/0/1
3 WLAN安全配置命令
3.1  WLAN安全配置命令
authentication-method { open-system | shared-key }
undo authentication-method { open-system | shared-key }
服务模板视图
【缺省级别】
2:系统级
open-system:使能开放式认证。
shared-key:使能共享密钥认证。
【描述】
authentication-method命令用来选择802.11规定的认证方式。undo authentication-method命令用来禁用所选择的认证方式。
缺省情况下,使用open-system认证方式。
使用该命令设置认证方式时,当前服务模板为crypto类型的,且加密方式为WEP方式时,认证方式可以同时是open-systemshared-key类型的。
l    当前模板类型为clear时,只能使能open-system类型的认证;
l    当前模板类型为crypto时,则可以使能open-systemshared-key类型的认证;
l    当前模板类型为wapi时,不支持认证功能。
# 使能开放式认证。
# 使能共享密钥认证。
[Sysname-wlan-st-1] authentication-method shared-key
3.1.2  cipher-suite
cipher-suite { ccmp | tkip | wep40 | wep104 | wep128}*
undo cipher-suite { ccmp | tkip | wep40 | wep104 | wep128}*
服务模板视图(crypto类型)
【缺省级别】
2:系统级
ccmp:使能CCMP加密套件,CCMP是一种基于AES加密算法的加密机制。
tkip:使能TKIP加密套件,TKIP是一种基于RC4算法和动态密钥管理的加密机制。
wep40:使能WEP40加密套件,WEP是一种基于RC4算法和共享密钥管理的加密机制。
wep104:使能WEP104加密套件。
wep128:使能WEP128加密套件。
【描述】
cipher-suite命令用来配置在帧加密时使用的加密套件。undo cipher-suite命令用来停用选择的加密套件。
缺省情况下,没有选择任何加密套件。
目前支持的加密套件有CCMP、TKIP、WEP40、WEP104、WEP128。
# 使能TKIP加密套件。
[Sysname-wlan-st-1] cipher-suite tkip
gtk-rekey client-offline enable
undo gtk-rekey client-offline
服务模板视图(crypto类型)
【缺省级别】
2:系统级
【描述】
gtk-rekey client-offline enable命令用来启动当客户端离线时更新GTK(Group Temporal Key,群组临时密钥)的功能。undo gtk-rekey client-offline命令用来关闭客户端离线更新GTK的功能。
缺省情况下,关闭客户端离线更新GTK的功能。
只有执行了gtk-rekey enable命令,此功能才生效。
# 启用当客户端离线时更新GTK的功能。
[Sysname-wlan-st-1] gtk-rekey client-offline enable
gtk-rekey enable
undo gtk-rekey enable
服务模板视图(crypto类型)
【缺省级别】
2:系统级
【描述】
gtk-rekey enable命令用来设置允许GTK更新。undo gtk-rekey enable命令用来禁止GTK更新。
缺省情况下,使能GTK更新功能。
# 禁止GTK更新。
[Sysname-wlan-st-1] undo gtk-rekey enable
gtk-rekey method { packet-based [ packet ] | time-based [ time ] }
undo gtk-rekey method
服务模板视图(crypto类型)
【缺省级别】
2:系统级
packet-based:设置GTK密钥更新采用基于数据包的方法。
packet:指定传输的数据包(包括组播和广播)的数目,在传送指定数目的数据包(包括组播和广播)后更新GTK,取值范围为5000~4294967295。
time-based:设置GTK密钥更新采用基于时间的方法。
time:指定GTK密钥更新的周期。取值范围为180~604800,单位为秒。
【描述】
gtk-rekey method命令用来设置GTK进行密钥的更新方法。undo gtk-rekey method命令用来恢复缺省情况。
缺省情况下,GTK密钥更新采用基于时间的方法,缺省的时间间隔是86400秒。
l              如果配置了基于时间的GTK密钥更新,则在指定时间间隔后进行GTK更新密钥,时间间隔的取值范围为180~604800秒,缺省为86400秒。
l              如果配置了基于数据包的GTK密钥更新,则在传输了指定数目的数据包后进行GTK密钥更新,数据包数目的取值范围为5000~4294967295;缺省情况下,在传输了10000000个报文后进行密钥更新。
使用该命令配置GTK密钥更新方法时,新配置的方法会覆盖前一次的配置。例如,如果先配置了基于数据包的方法,然后又配置了基于时间的方法,则最后生效的是基于时间的方法。
# 设置采用基于数据包的方法进行GTK密钥更新,且在传输了60000个数据包后进行密钥更新。
[Sysname-wlan-st-1] gtk-rekey method packet-based 60000
3.1.6  ptk-lifetime
ptk-lifetime time
undo ptk-lifetime
服务模板视图(crypto类型)
【缺省级别】
2:系统级
time:指定生存时间,取值范围为180~604800,单位为秒。。
【描述】
ptk-lifetime命令用来设置PTK(Pairwise Transient Key,成对临时密钥)的生存时间。undo ptk-lifetime命令用来恢复PTK的生存时间为缺省值。
缺省情况下,PTK的生存时间是43200秒。
# 设置PTK的生存时间为86400秒。
[Sysname-wlan-st-1] ptk-lifetime 86400
3.1.7  security-ie
security-ie { rsn | wpa }
undo security-ie { rsn | wpa }
服务模板视图(crypto类型)
【缺省级别】
2:系统级
rsn:设置在AP发送信标和探查响应帧时携带RSN IE。RSN IE(RSN Information Element,RSN信息元素)通告了AP的RSN(Robust Security Network,健壮安全网络)能力。
wpa:设置在AP发送信标和探查响应帧时携带WPA IE(WPA Information Element,WPA信息元素)。WPA IE通告了AP的WPA(Wi-Fi Protected Access,Wi-Fi保护访问)能力。
【描述】
security-ie命令用来设置信标和探查响应帧携带WPA IE或RSN IE,或者同时携带二者。undo security-ie命令用来设置信标和探查响应帧不携带WPA IE或RSN IE。
缺省情况下,信标和探查响应帧不携带WPA IE或RSN IE。
# 配置信标和探查帧携带WPA IE信息。
[Sysname-wlan-st-1] security-ie wpa
3.1.8  tkip-cm-time
tkip-cm-time time
undo tkip-cm-time
服务模板视图(crypto类型)
【缺省级别】
2:系统级
time:设置反制策略实施时间。当在设置的时间间隔内发生两个MIC(Message Integrity Check,信息完整性校验)错误时,系统将实施反制策略。单位为秒。取值范围为0~3600。
【描述】
tkip-cm-time命令用来设置TKIP(Temporal Key Integrity Protocol,临时密钥完整性协议)反制策略实施的时间。undo tkip-cm-time命令用来恢复TKIP反制策略实施的时间为缺省值。
缺省情况下,TKIP反制策略实施的时间为0秒,即不启动反制策略。
启动反制策略后,如果在一定的时间内发生了两次MIC错误,则TKIP关联将被解除,并且在TKIP反制策略实施的时间后,客户端才能重新建立关联。
# 设置TKIP反制策略的时间间隔为90秒。
[Sysname-wlan-st-1] tkip-cm-time 90
wep default-key key-index { wep40 | wep104 | wep128} { pass-phrase | raw-key } key
undo wep default-key key-index
服务模板视图(crypto类型)
【缺省级别】
2:系统级
key-index:密钥索引值如下:
l              1:配置第一个WEP缺省密钥。
l              2:配置第二个WEP缺省密钥。
l              3:配置第三个WEP缺省密钥。
l              4:配置第四个WEP缺省密钥。
wep40:设置WEP40密钥选项。
wep104:设置WEP104密钥选项。
wep128:设置WEP128密钥选项。
pass-phrase:配置pass-phrase选项。使用包含数字和字母的字符串作为密钥。如果使用WEP40,则可以配置5个字符的密钥作为pass-phrase。如果使用WEP104,则可以配置13个字符的密钥作为pass-phrase。如果使用WEP128,则可以配置16个字符的密钥作为pass-phrase。pass-phrase的长度是固定的。
raw-key:配置raw-key选项。raw-key为16进制的形式。对于WEP40为10位16进制数,对于WEP104为26位16进制数。对于WEP128为32位16进制数。raw-key的长度是固定的。
key:设置密钥。不同组合密钥的长度如下:
l              对于wep40 pass-phrase,密钥的是5个字符的字符串。
l              对于wep104 pass-phrase,密钥是13个字符的字符串。
l              对于wep128 pass-phrase,密钥是16个字符的字符串。
l              对于wep40 raw-key,密钥是10个16进制数。
l              对于wep104 raw-key,密钥是26个16进制数。
l              对于wep104 raw-key,密钥是32个16进制数。
【描述】
wep default-key命令用来配置WEP缺省密钥。undo wep default-key命令用来删除已配置的WEP缺省密钥。
缺省情况下,没有配置WEP缺省密钥。
当配置了安全IE并使能了服务模板,WEP缺省密钥1不允许配置。
# 配置WEP缺省密钥1(wep40)为“hello”。
[Sysname -wlan-st-1] wep default-key 1 wep40 pass-phrase hello
# 配置WEP缺省密钥为c25d3fe4483e867d1df96eaacd。
[Sysname-wlan-st-1] wep default-key 1 wep104 raw-key c25d3fe4483e867d1df96eaacd
3.1.10  wep key-id
wep key-id { 1 | 2 | 3 | 4 }
undo wep key-id
服务模板视图(crypto类型)
【缺省级别】
2:系统级
key-index:密钥索引号的取值范围为1~4,详细如下:
l              1:选择密钥索引为1。
l              2:选择密钥索引为2。
l              3:选择密钥索引为3。
l              4:选择密钥索引为4。
【描述】
wep key-id命令用来配置密钥索引号。undo wep key-id命令用来恢复缺省情况。
缺省情况下,密钥索引号为1。
在WEP中有四个静态的密钥。其密钥索引分别是1、2、3和4。指定的密钥索引所对应的密钥将被用来进行帧的加密和解密。
# 配置密钥索引号为2。
[Sysname-wlan-st-1] wep key-id 2
4 WLAN RRM 命令
4.1  WRRM配置命令
4.1.1  dot11a
dot11a { disabled-rate | mandatory-rate | supported-rate } rate-value
undo dot11a { disabled-rate | mandatory-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
mandatory-rate:强制速率。
supported-rate:支持速率。
rate-value:可设置的射频速率如下:
l              6 Mbps
l              9 Mbps
l              12 Mbps
l              18 Mbps
l              24 Mbps
l              36 Mbps
l              48 Mbps
l              54 Mbps
【描述】
dot11a命令用来设置“802.11a”模式下的射频速率。undo dot11a用来恢复缺省情况。
缺省情况下,
l              强制速率:6,12,24;
l              支持速率:9,18,36,48,54;
l              禁用速率:无。
# 设置802.11a模式的射频速率(禁用速率:12,24;支持速率:6)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11a disabled-rate 12 24
[Sysname-wlan-rrm] dot11a supported-rate 6
4.1.2  dot11b
dot11b { disabled-rate | mandatory-rate | supported-rate } rate-value
undo dot11b { disabled-rate | mandatory-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
l              1 Mbps
l              2 Mbps
l              5.5 Mbps
l              11 Mbps
【描述】
dot11b命令用来设置“802.11b”模式下的射频速率。undo dot11b用来恢复缺省情况。
缺省情况下,
l              强制速率:1,2;
l              支持速率:5.5,11;
l              禁用速率:无
# 设置802.11b模式的射频速率(禁用速率:1,2;支持速率:11)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11b disabled-rate 1 2
[Sysname-wlan-rrm] dot11b supported-rate 11
4.1.3  dot11g
dot11g { disabled-rate | mandatory-rate | supported-rate } rate-value
undo dot11g { disabled-rate | mandatory-rate | supported-rate }
RRM视图
【缺省级别】
2:系统级
disabled-rate:禁用速率。
l              1 Mbps
l              2 Mbps
l              5.5 Mbps
l              6 Mbps
l              9 Mbps
l              11 Mbps
l              12 Mbps
l              18 Mbps
l              24 Mbps
l              36 Mbps
l              48 Mbps
l              54 Mbps
【描述】
dot11g命令用来设置“802.11g”模式下的射频速率。undo dot11g用来恢复缺省情况。
缺省情况下,
l              强制速率:1,2,5.5,11;
l              支持速率:6,9,12,18,24,36,48,54;
l              禁用速率:无
# 设置802.11g模式的射频速率(禁用速率:2,36;支持速率:54)。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g disabled-rate 2 36
[Sysname-wlan-rrm] dot11g supported-rate 54
dot11g protection enable
undo dot11g protection enable
RRM视图
【缺省级别】
2:系统级
【描述】
dot11g protection enable用来使能dot11g保护功能。undo dot11g protection enable关闭此功能。
缺省情况下,dot11g保护功能处于关闭状态。
# 使能dot11g保护功能。
[Sysname] wlan rrm
[Sysname-wlan-rrm] dot11g protection enable
dot11n mandatory maximum-mcs index
undo dot11n mandatory maximum-mcs
RRM视图
【缺省级别】
2:系统级
index:指定802.11n的基本MCS集的最大MCS索引。取值范围0到最大MCS索引,其中MCS最大索引目前为76。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
【描述】
dot11n mandatory maximum-mcs命令用来配置802.11n的基本MCS集的最大MCS索引号。undo dot11n mandatory maximum-mcs取消已有配置。
缺省情况下,没有配置任何基本MCS集。
l              如果用户配置了基本MCS,使能了client dot11n-only命令,则非802.11n客户端不能与AP建立连接。
l              如果用户在指定radio接口下配置使能了client dot11n-only命令,则必须配置基本MCS。
# 配置dot11n的基本MCS集最大索引号为15。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n mandatory maximum-mcs 15
dot11n support maximum-mcs index
undo dot11n support maximum-mcs
RRM视图
【缺省级别】
2:系统级
index:指定的802.11n的支持MCS集的最大MCS索引。取值范围0到最大MCS索引,其中MCS最大索引目前为76。
【描述】
dot11n support maximum-mcs命令用来配置802.11n的支持MCS集的最大MCS索引号。undo dot11n support maximum-mcs恢复缺省情况。该命令的支持情况与设备实际情况相关,使用时请以设备实际情况为准。
缺省情况下,支持MCS集的索引号为76。
l              如果用户在指定radio接口下配置使能了client dot11n-only命令,则在用户没有配置基本MCS的情况下,不能使能该radio接口。
# 配置dot11n的支持MCS集最大索引号为25。
[sysname] wlan rrm
[sysname-wlan-rrm] dot11n support maximum-mcs 25
undo autochannel-set
RRM 视图
【缺省级别】
2:系统级
【描述】
autochannel-set avoid-dot11h用来配置扫描非dot11h信道。配置此功能后,设备在初始信道选择时,只扫描属于配置国家代码的非dot11h信道,此时如果也配置了自动信道选择功能,将在被扫描的信道中选择一个使用。undo autochannel-set命令用来恢复缺省情况。
缺省情况下,选择信道没有限制,即扫描所有信道。
# 设置信道为非11h模式。
[Sysname] wlan rrm
[Sysname-wlan-rrm] autochannel-set avoid-dot11h
display wlan rrm
【缺省级别】
1:监控级
【描述】
display wlan rrm命令用来显示基本RRM配置参数。如果不存在RRM配置,将显示配置参数的缺省值。
命令输出包括单独的射频带完成的配置。显示输出如下所示。
# 显示RRM配置。
<Sysname> display wlan rrm
                                 RRM Configuration
 11a Configured Rates (Mbps)
   Mandatory                   : 6, 12, 24
   Supported                   : 9, 18, 36, 48, 54
   Disabled                    : -NA-
 11b Configured Rates (Mbps)
   Mandatory                   : 1, 2
   Supported                   : 5.5, 11
   Disabled                    : -NA-
 11g Configured Rates (Mbps)
   Mandatory                   : 1, 2, 5.5, 11
   Supported                   : 6, 9, 12, 18, 24, 36, 48, 54
   Disabled                    : -NA-
   11g Protection              : Enabled
 11h Configuration
   Spectrum Management         : Disabled
   Power Constraint (dBm)      : 0
   Channel Set                 : Non-dot11h
表4-1 display wlan rrm命令显示信息描述表
802.11a模式下的射频速率,802.11b/g具有的相同字段表示相同的意思,这里省略
Mandatory
强制速率,AP必须支持其中一种速率
Supported
支持速率,AP或客户端支持的扩展速率
Disabled
禁用速率,禁止AP传输的速率
11g Protection
使能dot11g保护功能
11h Configuration
802.11h的配置情况
Spectrum Management
802.11a频段的频谱管理功能,由命令spectrum-management enable配置
802.11a射频的功率限制值,由命令power-constraint配置
Channel Set
Non-dot11h:信道组设置为非dot11h信道。配置此功能后,设备在初始信道选择时,只扫描属于配置国家代码的非dot11h信道
all:不限制选择的信道
power-constraint power-constraint
undo power-constraint
RRM 视图
【缺省级别】
2:系统级
power-constraint:用于指定WLAN系统下的用于BSS的功率限制,取值范围为0~MAX-POWER–1(MAX-POWER为802.11a射频下缺省的最大MAX-POWER,MAX-POWER的取值根据不同的国家码而有所不同),单位为dBm。
【描述】
power-constraint命令用于配置所有的802.11a射频的功率限制。在频谱管理使能的情况下,信标帧中将通告所配置功率限制。
缺省情况下,功率限制为0dBm。
相关命令请参考spectrum-management enable
# 配置射频的功率限制。
[Sysname] wlan rrm
[Sysname-wlan-rrm] power-constraint 5
undo spectrum-management enable
RRM视图
【缺省级别】
2:系统级
【描述】
spectrum-management enable命令用于使能802.11a频段的频谱管理。undo spectrum-management enable命令用来恢复缺省情况。当WLAN系统的频谱管理功能使能后,WLAN系统会通告AP的功率能力和功率限制,该BSS下的所有设备都应根据所在地区的规定遵守AP通告的功率限制。
缺省情况下,频谱管理处于关闭状态。
# 使能频谱管理。
[Sysname] wlan rrm
[Sysname-wlan-rrm] spectrum-management enable
4.1.11  wlan rrm
wlan rrm
【缺省级别】
2:系统级
【描述】
wlan rrm命令用来进入RRM(射频资源管理)视图。
在该视图下,用户可以管理WLAN射频资源。
# 进入RRM视图。
[Sysname] wlan rrm
[Sysname-wlan-rrm]
5 WLAN IDS配置命令
attack-detection enable { all | flood | weak-iv | spoof }
undo attack-detection enable
WLAN IDS视图
【缺省级别】
2:系统级
all:使能所有攻击检测功能。
flood:使能泛洪攻击检测功能。
spoof:使能spoof攻击检测功能。
weak-iv:使能weak-iv攻击检测功能。
【描述】
attack-detection enable命令用来使能攻击检测功能。undo attack-detection enable命令用来恢复缺省情况。
缺省情况下,攻击检测功能处于关闭状态。
# 使能spoof攻击检测功能。
[Sysname] wlan ids
[Sysname-wlan-ids] attack-detection enable spoof
【缺省级别】
2:系统级
【描述】
display wlan ids history命令用来显示WLAN系统的攻击检测历史信息,最多支持512路输入。
# 显示历史攻击信息。
<Sysname> display wlan ids history
 Total Number of Entries: 5
  Flags:
   act = Action Frame             asr = Association Request
   aur = Authentication Request   daf = Deauthentication Frame
   dar = Disassociation Request   ndf = Null Data Frame
   pbr = Probe Request            rar = Reassociation Request
   saf = Spoofed Disassociation Frame
   sdf = Spoofed Deauthentication Frame
   wiv = Weak IV Detected
   AT - Attack Type, Ch - Channel Number, AR - Average RSSI
                              WIDS History Table
 MAC Address      AT    Ch    AR    Detected Time          AP
 0027-E699-CA71   asr   8     44    2007-06-12/19:47:54    ap12
 0015-E9A4-D7F4   wiv   8     45    2007-06-12/19:45:28    ap48
 0027-E699-CA71   asr   8     20    2007-06-12/19:18:17    ap12
 003d-B5A6-539F   pbr   8     43    2007-06-12/19:10:48    ap56
 0015-E9A4-D7F4   wiv   8     50    2007-06-12/19:01:28    ap48
表5-1 display wlan ids history命令显示信息描述表
MAC-Address
在欺骗攻击模式下,该阈值提供用于欺骗攻击的BSSID;在其它攻击模式下,该阈值用于提供发起攻击的设备的MAC地址
AT
攻击类型首字母缩写
Ch
攻击检测频道
AR
攻击帧的平均RSSI
Detected time
攻击检测时间
AP
检测到攻击的AP名称
【缺省级别】
2:系统级
【描述】
display wlan ids statistics命令用来显示检测到的攻击数。
#显示wlan ids的统计信息。
<Sysname> display wlan ids statistics
 Current attack tracking since: 2007-06-21/12:46:33
 Type                                            Current       Total
 Probe Request Frame Flood Attack                2             7
 Authentication Request Frame Flood Attack       0             0
 Deauthentication Frame Flood Attack             0             0
 Association Request Frame Flood Attack          1             1
 Disassociation Request Frame Flood Attack       4             8
 Reassociation Request Frame Flood Attack        0             0
 Action Frame Flood Attack                       0             0
 Null Data Frame Flood Attack                    0             0
 Weak IVs Detected                               12            21
 Spoofed Deauthentication Frame Attack           0             0
 Spoofed Disassociation Frame Attack             0             2
表5-2 display wlan ids statistics命令显示信息描述表.
current
current字段标识了当前攻击的跟踪时间,该字段提供了从当前攻击跟踪时间(在显示信息中“Current attack tracking since:”定义的时间)起的攻击检测数。当前攻击的跟踪时间在系统启动时开始计算,后续以小时为单位刷新。
total
total字段标识了系统从启动以来的所有检测到的攻击数
探查请求帧的泛洪攻击检测数
认证请求帧的泛洪攻击检测数
解除认证请求帧的泛洪攻击检测数
关联请求帧的泛洪攻击检测数
解除关联请求帧的泛洪攻击检测数
重关联请求帧的泛洪攻击检测数
执行帧的泛洪攻击检测数
空数据帧的泛洪攻击检测数
Weak IVs Detected
脆弱IV检测数
欺骗解除认证帧的攻击检测数
欺骗解除关联帧的攻击检测数
5.1.4  wlan ids
wlan ids
【缺省级别】
2:系统级
【描述】
wlan ids命令用来进入WLAN IDS视图。
# 进入WLAN IDS视图。
[Sysname] wlan ids
[Sysname-wlan-ids]
【缺省级别】
2:系统级
【描述】
reset wlan ids history命令用来重置WLAN系统攻击检测的历史信息。在执行了这条命令后所有关于攻击的历史信息将被清除,历史信息列表将被清空。
# 重置wlan ids历史信息。
<Sysname> reset wlan ids history
【缺省级别】
2:系统级
【描述】
reset wlan ids statistics命令用来重置WLAN系统攻击检测的统计信息。该命令将重置包括current和total字段的所有在WIDS统计列表内的攻击类型。
# 重置wlan ids统计信息。
<Sysname> reset wlan ids statistics
display wlan blacklist { static | dynamic }
【缺省级别】
2:系统级
static:只显示静态配置的黑名单列表。
dynamic:显示所有动态配置的黑名单列表。
【描述】
display wlan blacklist命令用来显示静态或动态配置的黑名单列表。
# 显示静态配置的黑名单列表
<Sysname> display wlan blacklist static
Total Number of Entries: 6
                               Static Blacklist
 MAC-Address
0014-6c8a-43ff
 0016-6F9D-61F3
 0019-5B79-F04A
表5-3 display wlan blacklist static命令显示信息描述表
MAC-Address
静态黑名单列表中的客户端MAC地址
# 显示动态配置的黑名单列表。
<Sysname> display wlan blacklist dynamic
Total Number of Entries: 3
                               Dynamic Blacklist
 MAC-Address    Lifetime(s) Last Updated Since(hh:mm:ss)     Reason
 000f-e2cc-0001 60          00:02:11                         Assoc-Flood
 000f-e2cc-0002 60          00:01:17                         Deauth-Flood
 000f-e2cc-0003 60          00:02:08                         Auth-Flood
表5-4 display wlan blacklist dynamic命令显示信息描述表
MAC-Address
动态黑名单列表中的客户端MAC地址
Lifetime(s)
动态黑名单列表中对应项的生存时间(单位:秒)
动态黑名单列表中对应的表项已经存在了多长时间
Reason
动态黑名单列表中对应项添加的原因
【缺省级别】
2:系统级
【描述】
display wlan whitelist命令用来显示白名单列表。
# 显示白名单列表信息。
<Sysname> display wlan whitelist
                               Whitelist
 MAC-Address
 0000-0000-000A
 0000-0000-0066
 0000-0000-00AA
 0000-0000-00EE
 0400-0000-0000
 0400-0000-00EE
表5-5 display wlan whitelist 命令显示信息描述表
MAC-Address
白名单列表中的客户端MAC地址
undo dynamic-blacklist enable
WLAN IDS视图
【缺省级别】
2:系统级
enable:使能动态黑名单功能。
【描述】
dynamic-blacklist enable命令用来使能动态黑名单功能,用来从已经建立联系的客户端中滤除不需要的客户端。undo dynamic-blacklist enable命令用来关闭动态黑名单功能。
缺省情况下,此功能处于关闭状态。
# 使能动态黑名单功能。
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist enable
dynamic-blacklist lifetime lifetime
undo dynamic-blacklist lifetime
WLAN IDS视图
【缺省级别】
2:系统级
lifetime:动态黑名单中的对应列表的生存时间,单位为秒,取值范围为60~3600。
【描述】
dynamic-blacklist lifetime命令用来设置动态黑名单中的对应列表的生存时间。undo dynamic-blacklist lifetime命令用来恢复缺省情况。
缺省情况下,生存时间为300秒。
如果在老化时间超时后,该设备没有再次被检测到,则从列表中清除该表项。
# 定义动态黑名单的生存时间为1200秒。
[Sysname] wlan ids
[Sysname-wlan-ids] dynamic-blacklist lifetime 1200
reset wlan dynamic-blacklist { mac-address mac-address | all }
【缺省级别】
2:系统级
mac-address:将要从动态黑名单中删除的客户端的MAC地址。
all:删除动态黑名单中的所有表项。
【描述】
reset wlan dynamic-blacklist mac-address命令用来清除动态黑名单中指定的MAC地址或者所有动态客户端。该表项最多可以输入128条。
# 从动态黑名单中清除MAC地址为aabb-cccc-dddd的客户端。
<Sysname> reset wlan dynamic-blacklist mac-address aabb-cccc-dddd
static-blacklist mac-address mac-address
undo static-blacklist { mac-address mac-address | all }
WLAN IDS视图
【缺省级别】
2:系统级
mac-address:将要从静态黑名单中添加或删除的客户端的MAC地址。
all:删除静态黑名单中的所有表项。
【描述】
static-blacklist mac-address命令用来添加指定的MAC地址到静态黑名单。undo static-blacklist mac-address命令用来删除静态黑名单中指定MAC地址的或者所有的客户端。表项最多可以输入64条。
# 添加MAC地址为aabb-cccc-dddd的客户端到静态黑名单。
[Sysname] wlan ids
[Sysname-wlan-ids] static-blacklist mac-address aabb-cccc-dddd
whitelist mac-address mac-address
undo whitelist { mac-address mac-address | all }
WLAN IDS视图
【缺省级别】
2:系统级
mac-address:将要从白名单中添加或删除的客户端的MAC地址。
all:删除白名单中的所有表项。
【描述】
whitelist mac-address命令用来添加指定的MAC地址到白名单。undo whitelist mac-address命令用来删除白名单中指定MAC地址的或者所有的客户端。也就是需要与AP相关联的客户端。该表项最多可以输入256条。
# 添加MAC地址为aabb-cccc-dddd的客户端到白名单
[Sysname] wlan ids
[Sysname-wlan-ids] whitelist mac-address aabb-cccc-dddd
6 WLAN QoS配置命令
6.1  WLAN QoS配置命令
display wlan wmm { radio [ interface wlan-radio wlan-radio-number ] | client { all | interface wlan-radio wlan-radio-number | mac-address mac-address } }
【缺省级别】
2:系统级
radio:显示射频的WMM(Wi-Fi Multimedia,Wi-Fi多媒体,是一种无线QoS协议)信息。
wlan-radio radio-number:显示连接到指定射频接口的客户端WMM信息。
client:显示客户端的WMM信息。
all:显示所有射频或客户端的WMM信息。
mac-address mac-address:显示指定MAC地址的客户端WMM信息。
【描述】
display wlan wmm radio命令用来显示所有射频或指定AP射频的WMM相关信息。
display wlan wmm client命令用来显示所有客户端,同指定AP关联的客户端,或指定MAC地址的客户端的WMM相关信息。
# 显示所有射频的WMM信息。
<Sysname> display wlan wmm radio
Radio interface : WLAN-Radio1/0/1
Client EDCA update count : 25587704
 QoS Mode                 : WMM        Radio chip QoS mode      : WMM
 Radio chip max AIFSN     : 255        Radio chip max ECWmin    : 10
 Radio chip max TXOPLimit : 32768      Radio chip max ECWmax    : 10
 CAC Information
  Client accepted                : 0
   Voice                         : 0
   Video                         : 0
  Total request mediumtime(us)   : 0
   Voice(us)                     : 0
   Video(us)                     : 0
  Calls rejected due to insufficient resource   : 0
  Calls rejected due to invalid parameters      : 0
  Calls rejected due to invalid mediumtime      : 0
  Calls rejected due to invalid delaybound      : 0
 QoS Mode                        : WMM
 Admission Control Policy        : Users
 Threshold users count           : 20
 CAC-Free's AC Request Policy    : Response Success
 CAC Unauthed Frame Policy       : Downgrade
 CAC Medium Time Limitation(us)  : 100000
 CAC AC-VO's Max Delay(us)       : 50000
 CAC AC-VI's Max Delay(us)       : 300000
 SVP packet mapped AC number     : Disabled
 Radio's WMM Parameters:
                          AC-BK    AC-BE    AC-VI    AC-VO
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       AckPolicy         Normal   Normal   Normal   Normal
 Client's WMM Parameters:
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
       CAC              Disable  Disable  Disable  Disable
Radio interface : WLAN-Radio1/0/2
 CAC Information
  Client accepted                : 0
   Voice                         : 0
   Video                         : 0
   Voice(us)                     : 0
   Video(us)                     : 0
 QoS Mode                        : WMM
       ECWmin                 4        4        3        2
       ECWmax                10        6        4        3
       AIFSN                  7        3        1        1
       TXOPLimit              0        0       94       47
       ECWmin                 4        4        3        2
       ECWmax                10       10        4        3
       AIFSN                  7        3        2        2
       TXOPLimit              0        0       94       47
表6-1 display wlan wmm radio命令各字段的含义描述
Radio interface
WLAN射频接口
客户端EDCA参数更新次数
QoS mode
QoS模式,WMM:启用QoS模式,None:不启用QoS模式
Radio chip Qos mode
Radio是否支持Qos模式
Radio支持的AIFSN值的最大值
Radio支持的ECWMIN值的最大值
Radio支持的TXOPLimit值的最大值
Radio支持的ECWMAX值的最大值
Client accepted
Radio下已准入的Client数量,包括Voice队列下和Video队列下准入的Client数量
所有队列申请的时间,包括Voice队列下和Video队列下申请的时间
因资源不足拒绝的请求数量
因参数无效拒绝的请求数量
因接入时间无效拒绝的请求数量
因延迟时间无效拒绝的请求数量
准入控制策略
Threshold
准入控制策略使用的门限值
对不支持CAC功能的AC采用的回应策略
对CAC未授权报文的处理策略
CAC策略允许的接入时间上限,单位为微秒
CAC策略允许的语音流延迟上限,单位为微秒
CAC策略允许的视频流延迟上限,单位为微秒
SVP报文映射到的AC的编号
ECWmin
ECWmin的值
ECWmax
ECWmax的值
AIFSN
AIFSN的值
TXOPLimit
TXOP limit的值
Ack Policy
AC所使用的ACK策略
CAC
表示此队列是否受CAC的限制,Disabled表示不受限制,Enabled表示受限制
# 显示所有客户端的WMM信息。
<Sysname> display wlan wmm client all
 MAC address     : 000f-e23c-0000       SSID                : abd
 QoS Mode        : None
 MAC address     : 000f-e23c-0001       SSID                : abc
 QoS Mode        : WMM
 APSD information :
  Max SP Length : all
  L: Legacy      T: Trigger      D: Delivery
  AC             AC-BK   AC-BE   AC-VI   AC-VO
  State          T|D     L       T|D     L
  Assoc State    T|D     L       T|D     T|D
 CAC  information :
  Uplink CAC packets   : 0           Downlink CAC packets   : 0
  Uplink CAC bytes     : 0           Downlink CAC bytes     : 0
  Downgrade packets    : 0           Discard packets        : 0
  Downgrade bytes      : 0           Discard bytes          : 0
  AC                   : AC-VO       User Priority               : 7
   TID                 : 1           Direction              : Bidirectional
   PSB                 : 0           Surplus Bandwidth Allowance : 1.0000
   Medium Time(ms)     : 39.108      Nominal MSDU Size(bytes)    : 1500
   Mean Data Rate(Kbps): 78.125      Minimum PHY Rate(Mbps)      : 2.000
   Create TS time      :  5s
   Update TS time      :  5s
   Uplink TS packets   : 0           Downlink TS packets         : 0
   Uplink TS bytes     : 0           Downlink TS bytes           : 0
表6-2 display wlan wmm client命令各字段的含义描述
MAC address
Client的MAC地址
SSID
SSID名
QoS Mode
Max SP length
最大服务时间长度
AC
接入类
AC队列的APSD属性 ,取值为T和D和L,T表示本AC有trigger-enabled属性,D表示本AC有delivery-enabled属性,T | D表示上面的两个属性都有,L表示本AC有Legacy属性
Assoc State
Client接入时指定的AC的APSD属性
Uplink CAC packets
上行CAC的报文数
Uplink CAC bytes
上行CAC的字节数
下行CAC的报文数
Downlink CAC bytes
下行CAC的字节数
Downgrade packets
降级处理的报文数
Downgrade bytes
降级处理的字节数
Discard packets
丢弃处理的报文数
Discard bytes
丢弃处理的字节数
Direction
流方向
User Priority
用户优先级
TID
流标识
PSB
省电模式标识
平均报文大小(单位为字节)
Mean Data Rate(kbps)
平均数据传输速率(单位为千比特每秒)
最小物理传输速率(单位为兆比特每秒)
允许富余带宽
Medium Time(ms)
接入时间(单位为毫秒)
Create TS time
创建业务流的时间
Update TS time
更新业务流的时间
Uplink TS packets
上行业务流的报文数
Uplink TS bytes
上行业务流的字节数
Downlink TS packets
下行业务流的报文数
Downlink TS bytes
下行业务流的字节数
reset wlan wmm { radio [ interface wlan-radio wlan-radio-number ] | client { all | interface wlan-radio wlan-radio-number | mac-address mac-address } }
【缺省级别】
2:系统级
radio:清除所有射频的WMM信息。
interface wlan-radio radio-number:在radio参数后的wlan-radio radio-number参数表示清除连接到指定射频接口的射频WMM信息。在client参数后的wlan-radio radio-number:清除连接到指定射频接口的客户端WMM信息。
client:清除客户端的WMM信息。
all:清除所有客户端的WMM信息。
mac-address mac-address:清除指定MAC地址的客户端WMM信息。
【描述】
reset wlan wmm radio命令用来清空所有射频或指定AP的射频的WMM相关的统计信息。
reset wlan wmm client命令用来清除所有客户端,同指定AP关联的客户端,或指定MAC地址的客户端的WMM相关统计信息。
对于wlan-radio命令在不同的关键字下的含义是不同的,如下:
l    reset wlan wmm radio interface wlan-radio命令用来清空连接到指定射频接口的射频WMM信息。
l    reset wlan wmm client interface wlan-radio命令用来清空连接到指定射频接口的客户端信息。
# 清空所有射频的WMM统计信息。
<Sysname> reset wlan wmm radio all
wmm cac policy { channelutilization [ channelutilization-value ] | users [ users-number ] }
undo wmm cac policy
WLAN射频接口视图
【缺省级别】
2:系统级
channelutilization:CAC使用基于信道利用率的准入策略。
channelutilization-value:允许接入的信道最大利用率,即单位时间内,允许接入AC-VO和AC-VI优先级的业务流占用信道的总共时间与单位时间内的有效时间的百分比,取值范围为0~100,缺省值为65,单位为百分比。有效时间为可用于实际收发数据的时间。
users:CAC使用基于用户数的准入策略。
users-number:允许接入的客户端的最大个数,取值范围为0~64,缺省值为20。如果一个客户端同时接入AC-VO和AC-VI优先级业务流,接入客户端的个数按1计算。
【描述】
wmm cac policy命令用来配置CAC功能启动后使用的接入控制策略。undo wmm cac policy命令用来恢复缺省情况。
缺省情况下,CAC策略是基于用户数的准入策略,用户数为20。
相关命令参考wmm edca client
# 配置CAC使用基于信道利用率的准入策略,允许信道最大利用率为70%。
[Sysname-WLAN-Radio1/0/1] wmm cac policy channelutilization 70
wmm edca radio { ac-vo | ac-vi | ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value | noack } *
undo wmm edca radio { ac-vo | ac-vi | ac-be | ac-bk } { aifsn | ecw | txoplimit | noack | all }
WLAN射频接口视图
【缺省级别】
2:系统级
ac-vo:AC-VO(语音流)优先级队列。
ac-vi:AC-VI(视频流)优先级队列。
ac-be:AC-BE(尽力而为流)优先级队列。
ac-bk:AC-BK(背景流)优先级队列。
all:指定AC的所有EDCA参数。
noack:指定AC使用的ACK策略是No ACK。协议规定ACK策略有Normal ACK和No ACK。
txoplimit-valueEDCA的TXOP Limit参数,以32微秒为单位,取值范围为0~65535,TXOP为0表示只允许传输一个MPDU,最大值为65535。且受射频芯片的支持范围限制。
ecwmin-valueEDCA的ECWmin参数,取值范围0~15。且受射频芯片的支持范围限制。
ecwmax-value:EDCA的ECWmax参数,取值范围0~15。且受射频芯片的支持范围限制。
aifsn-value:EDCA的AIFSN参数,取值范围1~15。且受射频芯片的支持范围限制。
【描述】
wmm edca radio用于配置AP指定优先级使用的EDCA参数和ACK策略。undo wmm edca radio用于恢复AP指定优先级使用的EDCA参数和ACK策略为缺省值。
缺省情况下,ACK策略为Normal ACK,EDCA参数值如表6-3所示。
表6-3 AP使用的EDCA参数的缺省值
AC
AIFSN
ECWmin
ECWmax
TXOP Limit
AC-BK
7
4
10
0
AC-BE
3
4
6
0
AC-VI
1
3
4
94
AC-VO
1
2
3
47
l    EDCA各个参数的含义请参考“WLAN配置”。
l    ECWmin的值不能大于ECWmax,两者需要同时启用配置,同时撤销配置。
l    AP应用802.11b射频卡时,建议将AC-BK、AC-BE、AC-VI、AC-VO的TXOP-Limit参数的值分别配置为0、0、188、102。
# 配置AP使用的AC-VO队列的AIFSN为2。
[Sysname-WLAN-Radio1/0/1] wmm edca radio ac-vo aifsn 2
wmm edca client { ac-vo | ac-vi } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value | txoplimit txoplimit-value | cac } *
undo wmm edca client { ac-vo | ac-vi } { aifsn | ecw | txoplimit | cac | all }
WLAN射频接口视图
【缺省级别】
2:系统级
all: 所有EDCA参数。
cac: 支持客户端使用连接准入控制。AC-VO和AC-VI支持CAC,缺省为关闭。AC-BE和AC-BK不支持CAC。
aifsn-value:EDCA的AIFSN参数,取值范围是2~15。
ecwmin-value:EDCA的ECWmin参数,取值范围0~15。
txoplimit-value:EDCA的TXOP Limit参数,以32微秒为单位,取值范围0~65535。TXOP为0表示只允许传输一个MPDU。
【描述】
wmm edca client用来配置在BSS域中,客户端指定优先级(AC-VO或AC-VI)使用的EDCA参数。undo wmm edca client用来恢复客户端指定优先级(AC-VO或AC-VI)使用的EDCA参数为缺省值。
缺省情况下,客户端优先级AC-VI和AC-VO的EDCA参数取值如表6-4所示。
表6-4 客户端EDCA参数的缺省值
AC
AIFSN
ECWmin
ECWmax
TXOP Limit
AC-VI
2
3
4
94
AC-VO
2
2
3
47
l    如果所有客户端应用802.11b射频卡,建议将AC-VI、AC-VO的TXOP-Limit参数的值分别配置为188、102。
l    如果网络中既有使用802.11b射频卡又有使用802.11g射频卡的客户端,则建议按TXOP-Limit参数值使用表6-4中缺省值。
l    如果某优先级队列的CAC功能被启动,则高于此优先级队列的CAC功能会同时被启用。例如,使用wmm edca client命令启动AC-VI优先级CAC功能,则AC-VO优先级也同时启动CAC功能,但是,启动AC-VO优先级的CAC功能,AC-VI优先级的CAC功能不会被启用。
# 配置AC-VO的aifsn 为3。
[Sysname-WLAN-Radio1/0/1] wmm edca client ac-vo aifsn 3
wmm edca client { ac-be | ac-bk } { aifsn aifsn-value | ecw ecwmin ecwmin-value ecwmax ecwmax-value  | txoplimit txoplimit-value } *
undo wmm edca client { ac-be | ac-bk } { aifsn | ecw | txoplimit | all }
WLAN射频接口视图
【缺省级别】
2:系统级
all: 所有EDCA参数。
txoplimit-value:EDCA的TXOP Limit参数,以32微秒为单位,取值范围为0~65535。TXOP Limit为0表示只允许传输一个MPDU。
【描述】
wmm edca client用来配置客户端指定优先级(AC-BE或AC-BK)使用的EDCA参数。undo wmm edca client用来恢复客户端指定优先级((AC-BE或AC-BK))使用的EDCA参数为缺省值。
缺省情况下,客户端优先级AC-BK和AC-BE的EDCA参数取值如表6-5所示。
表6-5 客户端EDCA参数的缺省值
AC
AIFSN
ECWmin
ECWmax
TXOP Limit
AC-BK
7
4
10
0
AC-BE
3
4
10
0
l    如果所有客户端应用802.11b射频卡,建议将AC-BK、AC-BE的TXOP-Limit参数的值分别配置为0、0。
l    如果网络中既有使用802.11b射频卡又有使用802.11g射频卡的客户端,则建议按TXOP-Limit参数值使用表6-5中缺省值。
# 配置AC-VO的aifsn 为3。
6.1.7  wmm enable
wmm enable
undo wmm enable
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
wmm enable命令用来开启WMM功能。undo wmm enable 命令用来关闭WMM功能。
缺省情况下,WMM功能处于开启状态。
协议要求802.11n的客户端必须支持WLAN QoS,所以当Radio工作在802.11an或802.11gn 式的情况下,WMM功能必须开启,否则可能会导致关联后的802.11n的客户端无法通信。
# 关闭WMM功能。
[Sysname-WLAN-Radio1/0/1] undo wmm enable
wmm svp map-ac { ac-vo | ac-vi | ac-be | ac-bk }
undo wmm svp map-ac
WLAN射频接口视图
【缺省级别】
2:系统级
【描述】
wmm svp map-ac命令用来配置SVP报文使用的AC优先级队列。undo svp map-ac这个命令要恢复为缺省情况。
缺省情况下,关闭SVP报文映射功能。
建议用户使用此命令时,在一般情况下映射到AC-VO队列。
# 配置SVP报文使用AC-VO队列。
[Sysname-WLAN-Radio1/0/1] wmm svp map-ac ac-vo
7 无线用户接入
undo l2fw wlan-client-isolation enable
【缺省级别】
2:系统级
【描述】
l2fw wlan-client-isolation enable命令用来启用无线用户二层隔离功能,使能用户隔离后无线用户之间不能互通。undo l2fw wlan-client-isolation enable命令用来关闭无线用户二层隔离。
缺省情况下,启用无线用户二层隔离功能。
# 关闭无线用户二层隔离功能。
[Sysname] undo l2fw wlan-client-isolation enable
% Info: wlan client isolation disabled.
