02-静态路由命令
本章节下载: 02-静态路由命令 (141.48 KB)
本章所指的路由器代表了一般意义下的路由器,以及运行了路由协议的三层交换机。
delete [ vpn-instance vpn-instance-name ] static-routes all
【缺省级别】
2:系统级
vpn-instance-name:指定VPN实例的名称,为1~31个字符的字符串,区分大小写。
【描述】
delete static-routes all命令用来删除所有静态路由。
使用本命令删除静态路由时,系统会提示确认,确认后才会删除所配置的所有静态路由。
相关配置可参考命令ip route-static,“IP路由分册/IP路由基础命令”中的display ip routing-table。
# 删除所有静态路由。
[Sysname] delete static-routes all
This will erase all ipv4 static routes and their configurations, you must reconf
igure all static routes
Are you sure?[Y/N]:Y
ip route-static dest-address { mask | mask-length } { next-hop-address [ track track-entry-number ] | interface-type interface-number next-hop-address [ bfd { control-packet | echo-packet } ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static dest-address { mask | mask-length } [ next-hop-address | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } { next-hop-address [ track track-entry-number ] [ public ] | interface-type interface-number next-hop-address [ bfd { control-packet | echo-packet } ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ preference preference-value ] [ tag tag-value ] [ description description-text ]
undo ip route-static vpn-instance s-vpn-instance-name&<1-6> dest-address { mask | mask-length } [ next-hop-address [ public ] | interface-type interface-number [ next-hop-address ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference-value ]
【缺省级别】
2:系统级
vpn-instance s-vpn-instance-name&<1-6>:指定源VPN实例的名称,取值范围为1~31个字符,区分大小写。&<1-6>表示前面的参数最多可以输入6次。每个VPN实例都有自己的路由表,配置的静态路由将被加入指定VPN实例的路由表。
dest-address:静态路由的目的IP地址,点分十进制格式。
mask:IP地址的掩码,点分十进制格式。
mask-length:掩码长度,取值范围为0~32。
next-hop-address:指定路由的下一跳的IP地址,点分十进制格式。
interface-type interface-number:指定静态路由的出接口类型和接口号。对于接口类型为非P2P接口(包括NBMA类型接口或广播类型接口,如VLAN接口等),必须指定下一跳地址。
vpn-instance d-vpn-instance-name:目的VPN实例的名称,区分大小写。如果指定目的VPN实例的名称,静态路由将根据配置的next-hop-address在目的VPN实例中查找出接口。
next-hop-address public:此参数表示指定的next-hop-address是公网地址,不是源VPN实例地址。
preference preference-value :指定静态路由的优先级,取值范围为1~255,缺省值为60。
tag tag-value:静态路由Tag值,用于标识该条静态路由,以便在路由策略中根据Tag对路由进行灵活的控制。关于路由策略的详细信息,请参见“IP路由分册”中的“路由策略配置”。
可在路由策略中根据Tag值对路由进行灵活的控制,取值范围为1~4294967295,缺省值为0。
description description-text:设置的静态路由描述信息,取值范围为1~60个字符。除“?”外,可以包含空格等特殊字符。
bfd:使能BFD(Bidirectional Forwarding Detection,双向转发检测)功能,对静态路由下一跳的可达性进行快速检测,当下一跳不可达时可以快速切换到备份路由。
control-packet:通过BFD控制报文方式实现BFD功能。
echo-packet:通过BFD echo报文方式实现BFD功能。
track track-entry-number:将静态路由与Track项相关联,track-entry-number为Track项的序号,取值范围为1~1024。
【描述】
ip route-static命令用来配置单播静态路由。undo ip route-static命令用来删除单播静态路由配置。
配置单播静态路由时应注意以下几点:
(1) 如果目的IP地址和掩码都为0.0.0.0,配置的路由为缺省路由。如果检查路由表失败,将使用缺省路由进行报文转发。
(2) 对不同的优先级配置,可采用不同的路由管理策略。例如,为同一目的地配置多条路由,如果指定相同的优先级,则实现路由负载分担;如果指定不同的优先级,则实现路由备份。
(3) 配置静态路由时,可根据实际需要指定出接口或下一跳地址,下一跳地址不能为本地接口IP地址,否则路由不会生效。对于支持从网络地址到链路层地址的解析的接口或点到点的接口,可指定出接口或下一跳地址。指定出接口时需要注意:
l 对于Null0接口,配置了出接口就不再配置下一跳地址。
l 对于点到点接口,即使不知道对端地址,也可以在路由器配置时指定出接口。这样,即使对端地址发生了改变也无须改变该路由器的配置。如封装PPP协议的接口,通过PPP协商获取对端的IP地址,这时可以不指定下一跳地址,只需指定出接口即可。
l 对于NBMA、P2MP等接口,它们支持点到多点网络,这时除了配置IP路由外,还需在链路层建立二次路由,即IP地址到链路层地址的映射。通常情况下,建议在配置出接口时,同时配置下一跳IP地址。
l 在配置静态路由时,建议不要直接指定广播类型接口作出接口(如VLAN接口)。因为广播类型的接口,会导致出现多个下一跳,无法唯一确定下一跳。在某些特殊应用中,如果必须指定广播接口(如VLAN接口),则必须同时指定其对应的下一跳地址。
l 通过控制报文方式实现BFD功能时,对端必须创建BFD会话,否则BFD功能将无法正常运行;通过Echo报文方式实现BFD功能时,对端不需要创建BFD会话,BFD功能也可以正常运行。
相关配置可参考命令ip route-static default-preference,“IP路由分册/IP路由基础命令”中的display ip routing-table。
l 在配置静态路由时,如果先指定下一跳地址,然后将该地址配置为本地接口(如VLAN接口)的IP地址,静态路由不会生效。
l 路由振荡时,使能BFD检测功能可能会加剧振荡,需谨慎使用。关于BFD的详细介绍,请参考“可靠性分册”中的“BFD配置”。
l 配置静态路由支持Track监测功能,该条静态路由可以是已经创建的,也可以是未创建的。对于已经创建的静态路由,只是将静态路由与Track项关联,并根据Track项的状态来判断静态路由的有效性;对于未创建的静态路由,首先要生成该静态路由,然后将其与Track项关联。
l 如果Track模块通过NQA探测私网静态路由中下一跳的可达性,静态路由下一跳的VPN实例号与NQA测试组配置的实例号必须相同,才能进行正常的探测。
l 需要注意在静态路由进行迭代时,Track项监测的应该是静态路由真正的下一跳,而不是配置的下一跳。否则,可能导致错误地将有效路由判断为无效路由。
# 配置静态路由,其目的地址为1.1.1.1/24,指定下一跳为2.2.2.2,Tag值为45,描述信息为“for internet & intranet”。
[Sysname] ip route-static 1.1.1.1 24 2.2.2.2 tag 45 description for internet & intranet
# 为名为vpn1的VPN实例配置一条静态路由,其目的地址为1.1.1.1/16,下一跳地址为此VPN实例的地址1.1.1.2。
[Sysname] ip route-static vpn-instance vpn1 1.1.1.1 16 vpn-instance vpn1 1.1.1.2
# 配置静态路由,其目的地址为1.1.1.1/24,出接口为Vlan-interface1,指定下一跳为2.2.2.2,并使能BFD功能,通过BFD echo报文方式实现BFD功能。
[Sysname] ip route-static 1.1.1.1 24 Vlan-interface 1 2.2.2.2 bfd echo-packet
ip route-static default-preference default-preference-value
undo ip route-static default-preference
【缺省级别】
2:系统级
default-preference-value:静态路由缺省优先级的值,取值范围为1~255。
【描述】
ip route-static default-preference命令用来配置静态路由的缺省优先级。undo ip route-static default-preference命令用来恢复该缺省优先级为缺省值。
缺省情况下,静态路由的缺省优先级为60。
l 如果在配置静态路由时没有指定优先级,就会使用缺省优先级。
l 重新设置缺省优先级后,新设置的缺省优先级仅对新增的静态路由有效。
# 配置静态路由的缺省优先级为120。
[Sysname] ip route-static default-preference 120
