02-用户接入命令
本章节下载 (259.35 KB)
1.1.1 debugging ppp { all | cbcp | ccp | scp }
1.1.2 debugging ppp { chap | compression | pap | vjcomp packet }
1.1.3 debugging ppp { core | ip | ipcp | lcp | lqc | mp }
1.1.10 ppp ipcp remote-address forced
1.2.1 debugging ppp compression iphc rtp
1.2.2 debugging ppp compression iphc tcp
1.2.3 display ppp compression iphc rtp
1.2.4 display ppp compression iphc tcp
1.2.5 display ppp compression stac-lzs
1.2.8 ppp compression iphc rtp-connections
1.2.9 ppp compression iphc tcp-connections
1.2.10 ppp compression stac-lzs
1.2.11 reset ppp compression iphc
1.2.12 reset ppp compression stac-lzs
2.1.1 display pppoe-server session
2.1.2 pppoe-server bind virtual-template
2.1.3 pppoe-server log-information off
2.1.4 pppoe-server max-sessions local-mac
2.1.5 pppoe-server max-sessions remote-mac
2.1.6 pppoe-server max-sessions total
3.1.7 display pppoe-client session
4.1.2 display vlan max-packet-process
4.1.3 display vlan statistics vid
4.1.5 reset vlan statistics vid
debugging ppp { all | cbcp packet | ccp { all | event | error | packet | state } | scp packet } [ interface interface-type interface-number ]
undo debugging ppp { all | cbcp packet | ccp { all | event | error | packet | state } | scp packet } [ interface interface-type interface-number ]
cbcp packet:打开cbcp报文的调试开关。
scp packet:打开scp报文的调试开关。
ccp:打开关于ccp的调试开关。
all:打开所有的调试开关。
event:打开事件信息的调试开关。
error:打开错误信息的调试开关。
packet:打开报文信息的调试开关。
state:打开状态信息的调试开关。
interface interface-type interface-number:接口类型及接口编号。
【描述】
debugging ppp { all | cbcp | ccp | scp }命令用来打开ppp相关的cbcp、ccp、scp或所有的调试开关。undo debugging ppp { all | cbcp | ccp | scp }命令用来恢复ppp相关的cbcp、ccp、scp或所有的调试开关的缺省设置。
缺省情况下,ppp的所有调试开关都是关闭的。
# 打开cbcp报文的调试开关。
<H3C> debugging ppp cbcp packet
debugging ppp { chap { all | event | error | packet | state } | compression iphc { rtp | tcp } | pap { all | event | error | packet | state } | vjcomp packet } [ interface interface-type interface-number ]
undo debugging ppp { chap { all | event | error | packet | state }| compression iphc { rtp | tcp } | pap { all | event | error | packet | state } | vjcomp packet } [ interface interface-type interface-number ]
chap:打开PPP的CHAP认证调试开关。
compression iphc rtp:打开IP报文头压缩中IP/UDP/RTP头压缩的调试开关。
compression iphc tcp:打开IP报文头压缩中IP/TCP头压缩的调试开关。
pap:打开PPP的PAP认证调试开关。
vjcomp packet:打开PPP的vjcomp报文调试开关。
all:打开所有的调试开关。
event:打开事件信息的调试开关。
error:打开错误信息的调试开关。
packet:打开报文信息的调试开关。
state:打开状态信息的调试开关。
【描述】
debugging ppp { chap| compression | pap | vjcomp packet }命令用来打开PPP相关的CHAP、compression、PAP或vjcomp的调试开关。undo debugging ppp { chap| compression | pap | vjcomp packet }命令用来恢复PPP相关的CHAP、compression、PAP或vjcomp的调试开关的缺省设置。
缺省情况下,PPP的所有调试开关都是关闭的。
# 打开PPP的CHAP认证调试开关。
<H3C> debugging ppp chap
debugging ppp { core event | ip packet | ipcp { all | event | error | packet | state } | lcp { all | event | error | packet | state } | lqc packet | mp { all | event | error | packet } } [ interface interface-type interface-number ]
undo debugging ppp { core event | ip packet| ipcp { all | event | error | packet | state } | lcp { all | event | error | packet | state } | lqc packet | mp { all | event | error | packet } } [ interface interface-type interface-number ]
core event:打开PPP核心状态事件信息的调试开关。
ip packet:打开PPP的ip报文的调试开关。
ipcp:打开PPP的IP控制协议的调试开关。
lcp:打开PPP的网络控制协议的调试开关。
lqc packet:打开PPP链路质量控制协议的调试开关。
mp:打开PPP多链路协议的调试开关。
all:打开所有的调试开关。
event:打开事件信息的调试开关。
error:打开错误信息的调试开关。
packet:打开报文信息的调试开关。
state:打开状态信息的调试开关。
【描述】
debugging ppp { core | ip | ipcp | lcp | lqc | mp }命令用来打开PPP相关的core、ip、ipcp、lcp、lqc或mp的调试开关。undo debugging ppp { core | ip | ipcp | lcp | lqc | mp }命令用来恢复PPP相关的core、ip、ipcp、lcp、lqc或mp的调试开关的缺省设置。
# 打开PPP核心状态事件信息的调试开关。
<H3C> debugging ppp core event
link-protocol ppp
无
【描述】
link-protocol ppp命令用来配置接口封装的链路层协议为PPP。
缺省情况下,除以太网接口外,其它接口链路层协议均封装为PPP。
PPP协议是在点到点链路上承载网络层数据包的一种链路层协议。PPP定义了一整套的协议,包括链路控制协议(LCP)、网络层控制协议(NCP)和验证协议(PAP和CHAP)等等。PPP由于能够提供用户验证、易于扩充和支持同/异步而获得了较广泛的应用。
相关配置可参考命令display interface。
# 设置接口Dialer1封装的链路层协议为PPP。
[H3C-Dialer1] link-protocol ppp
ppp authentication-mode { chap | pap } [ [ call-in ] domain isp-name ]
undo ppp authentication-mode
chap和pap二者必选其一,也只能选一种。
call-in:表示只在远端用户呼入时才验证对方。
domain:表示用户认证采用的域名。
【描述】
ppp authentication-mode命令用来设置本端PPP协议对对端路由器的验证方式,undo ppp authentication-mode命令用来取消配置的验证方式,即不进行验证。
当配置ppp authentication-mode { pap | chap } 后不加domain时,默认使用的domain是系统缺省的域system,认证方式是本地验证,地址分配使用的是system域中的地址池(通过display domain命令可以查看该域的配置)。如果在该命令加了domain,则必须在对应的domain中配置地址池。
如果用户名中带有domain,则以用户名中的domain为准(若该domain名不存在,则认证被拒绝),否则应使用为PPP认证配置的domain名。
如果用户名中不带domain,而为PPP认证配置的domain名又不存在,则认证被拒绝。
缺省情况下,不验证。
PPP有两种验证方式:
l PAP为两次握手验证,口令为明文。
l CHAP为三次握手验证,口令为密文。
另外可以采用已经定义的AAA验证方法表进行验证。
无论是CHAP或PAP,只是一种验证过程,最终能否通过验证,还需要AAA来作决定,AAA可以利用本地验证数据库验证或由AAA服务器进行验证。
相关配置可参考命令local-user,ppp chap user,ppp pap local-user,ppp pap password,ppp chap password。
# 在接口H3C-Virtual-Template1上,采用PAP方法验证对端路由器。
[H3C-Virtual-Template1] ppp authentication-mode pap
ppp chap password { simple | cipher } password
undo ppp chap password
password:为发送的口令。
simple和cipher:表示不加密显示和加密显示口令。
【描述】
ppp chap password命令用来配置进行CHAP验证时采用的缺省CHAP口令,undo ppp chap password命令用来取消配置的口令。
配置CHAP验证时,要将本端的password配置为对端相应user的password。
相关配置可参考命令ppp authentication-mode chap,local-user。
# 设置本地路由器以CHAP方式被验证时,用户口令为h3c且为明文显示。
[H3C-Virtual-Template1] ppp chap password simple h3c
ppp chap user username
undo ppp chap user
username:CHAP验证用户名,为长度为1~80的字符串,该名称是发送到对端设备进行CHAP验证的用户名。
【描述】
ppp chap user命令用来配置采用CHAP认证时的用户名称,undo ppp chap user命令用来删除已有的配置。
缺省情况下,CHAP认证的用户名为“H3C”。
配置CHAP验证时,要将各自的username配置为对端的local-user,而且对应的password要一致。
相关配置可参考命令ppp authentication-mode,local-user。
# 配置接口Dialer1进行CHAP验证时,本地用户名为Root。
[H3C-Dialer1] ppp chap user Root
ppp ipcp dns primary-dns-address [ secondary-dns-address ]
undo ppp ipcp dns primary-dns-address [ secondary-dns-address ]
primary-dns-address:主DNS服务器地址。
secondary-dns-address:从DNS服务器地址。
【描述】
ppp ipcp dns命令用来使能路由器为对端分配DNS服务器地址,undo ppp ipcp dns命令用来禁止路由器为对端分配DNS服务器地址。
缺省情况下,路由器不为对端分配DNS服务器地址。
当其他设备与路由器通过PPP协议相连时(通常为PC机拨号连接路由器),通过协商,路由器可以为对端设备分配DNS服务器地址(但需要等待对端请求,不会主动给对端分配DNS服务器地址)。这样,对端设备就可以通过域名直接访问网络。
如果用户通过PC机连接路由器,用户可以在PC机上使用命令winipcfg或ipconfig /all来查看路由器为其提供的DNS服务器地址。
H3C路由器可以为对端设备提供主DNS服务器和从DNS服务器两个服务器地址。
相关配置可参考命令ppp authentication-mode pap,ppp ipcp dns admit-any。
# 设置本地路由器的主DNS服务器地址为100.1.1.1,从DNS服务器地址为100.1.1.2。
[H3C-Dialer1] ppp ipcp dns 100.1.1.1 100.1.1.2
undo ppp ipcp dns admit-any
无
【描述】
ppp ipcp dns admit-any命令用来配置路由器可以被动地接收对端分配的DNS地址,即路由器不发送DNS请求,也能接收对端分配的DNS地址。undo ppp ipcp dns admit-any命令用来禁止路由器被动地接收对端分配的DNS地址。
缺省情况下,路由器不会被动地接收对端分配的DNS地址。
当路由器通过PPP协议与其他设备相连时(通常为路由器拨号连接运营商的接入服务器),通过协商,路由器可以被动地接收对端分配的DNS地址,这样路由器就可以使用对端设备分配的DNS服务器来解析域名。
相关配置可参考命令ppp authentication-mode pap,ppp ipcp dns。
# 设置本地路由器可以被动地接收对端分配的DNS地址。
[H3C-Dialer1] ppp ipcp dns admit-any
undo ppp ipcp remote-address forced
无
【描述】
ppp ipcp remote-address forced命令用来使路由器为对端分配IP地址时具有强制性,不允许对端使用自行配置的固定IP地址;undo ppp ipcp remote-address forced命令用来取消这种强制性,允许对端使用自行配置的固定IP地址。
缺省情况下,PPP IPCP的IP地址协商情况为本端不具有地址分配的强制,即路由器本端允许对端自行配置地址。当对端明确请求本端分配地址时,本端给对端分配地址;若对端已自行配置IP地址时,本端不再强行给对端分配地址。在不允许对端自行指定IP地址的情况下,路由器本端接口下一定要配置ppp ipcp remote-address forced命令。
相关配置可参考命令remote address。
# 封装PPP的拨号接口Dialer1为对端分配的IP地址为10.0.0.1,此时,对端可以接收这个分配的地址,也可以自行配置IP地址或无地址。
[H3C-Dialer1] remote address 10.0.0.1
# 封装PPP的拨号接口Dialer1为对端分配的IP地址为10.0.0.1,此时,对端必须接收这个地址,不允许对端自行配置IP地址或无地址。
[H3C-Dialer1] ppp ipcp remote-address forced
ppp ipcp dns request
undo ppp ipcp dns request
无
【描述】
ppp ipcp dns request命令用来配置路由器主动向对端请求DNS地址。undo ppp ipcp dns request命令用来禁止路由器主动向对端请求DNS地址。
缺省情况下,禁止路由器主动向对端请求对端的DNS地址。
当路由器通过PPP协议与其他设备相连时(通常为路由器拨号连接运营商的接入服务器),通过协商,路由器可以主动向对端请求DNS地址,这样路由器就可以使用对端设备分配的DNS服务器来解析域名。
& 说明:
如果协商到有效的DNS地址,将在接口显示信息中打印出来。
# 配置Dialer0接口主动请求DNS地址。
[H3C-Dialer0] ppp ipcp dns request
ppp lqc forbidden-percentage [ resumptive-percentage ]
undo ppp lqc
forbidden-percentage:禁用链路质量百分比,取值范围为0~100。
resumptive-percentage:恢复链路质量百分比,取值范围为0~100。
ppp lqc命令用来使能PPP链路质量监测功能,undo ppp lqc命令用来禁用PPP链路质量监测功能。
缺省情况下,不启用PPP链路质量监测功能。
参数resumptive-percentage的缺省值等于forbidden-percentage之值。
PPP链路质量监测可以实时对PPP链路(包括绑定在MP中的PPP链路)的质量进行监测。当链路的质量低于禁用链路质量百分比时,链路会被禁用;当链路质量恢复到恢复链路质量百分比时,链路会被自动重新启用。为了保证链路不会在禁用和恢复之间反复振荡,PPP链路质量监测在重新启用链路时会有一定的时间延迟。
配置时参数resumptive-percentage的值必须大于等于参数forbidden-percentage的值。
当在PPP链路两端同时启用链路质量监测时,两端路由器的参数必须相等。一般来说,不建议在链路两端同时使用链路质量监测功能。
不建议在拨号线路上使用PPP链路质量监测。当在拨号线路上启用链路质量监测功能后,由于拨号线路的特点,一旦链路被禁用DCC模块就会把拨号线路挂断,因此链路质量监测就不能正常的运行。只有当有数据需要传输时,DCC模块把拨号线路重新呼起,链路质量监测才能恢复正常。
相关配置可参考命令timer hold。
# 在接口Dialer1上启用PPP链路质量监测功能,禁用链路质量百分比为90%,恢复链路质量百分比为95%。
[H3C-Dialer1] ppp lqc 90 95
ppp pap local-user username password { simple | cipher } password
undo ppp pap local-user
username:为发送的用户名,为长度为1~80的字符串;
password:为发送的口令;
simple:表示不加密显示口令;
cipher:表示加密显示口令。
【描述】
ppp pap local-user命令用来配置本地路由器被对端路由器采用PAP方式验证时发送的用户名和口令,undo ppp pap local-user命令用来取消配置的发送的用户名和口令。
缺省情况下,被对端以PAP方式验证时,本地路由器发送的用户名和口令均为空。
当本地路由器被对端以PAP方式验证时,本地路由器发送的用户名username和口令password应与对端路由器的user和password一致。
相关配置可参考命令ppp authentication-mode pap,local-user。
# 设置本地路由器被对端以PAP方式验证时发送的用户名为H3C,口令为H3C。
[H3C-Dialer1] ppp pap local-user H3C password simple H3C
ppp timer negotiate seconds
undo ppp timer negotiate
seconds:为协商超时时间,单位为秒。在PPP协商过程中,如果在这个时间间隔内没有收到对端的应答报文,则PPP将会重发前一次发送的报文。该时间取值范围为1秒到10秒。
【描述】
ppp timer negotiate命令用来设置PPP协商超时时间,undo ppp timer negotiate命令用来恢复PPP协商超时时间的缺省值。
缺省情况下,PPP协商超时时间为3秒。
相关配置可参考命令link-protocol ppp。
# 设置PPP协商超时时间为5秒。
[H3C-Dialer1] ppp timer negotiate 5
timer hold seconds
undo timer hold
seconds:接口发送keepalive报文的时间周期,单位为秒,取值范围为0~32767,缺省值为10秒。
【描述】
timer hold命令用来设置接口发送keepalive报文的周期,undo timer hold命令用来恢复发送keepalive报文的时间周期的缺省值。
# 设置接口GigabitEthernet1/0的keepalive报文发送周期为20秒。
[H3C-GigabitEthernet1/0] timer hold 20
debugging ppp compression iphc rtp { all | context_state | error | full_header | general_info }
undo debugging ppp compression iphc rtp { all | context_state | error | full_header | general_info }
all:表示打开IPHC RTP的所有调试开关。
context_state:表示打开IPHC RTP context_state报文调试开关。
error:表示打开IPHC RTP错误信息调试开关。
full_header:表示打开IPHC RTP full_header报文调试开关。
general_info:表示打开IPHC RTP总体信息调试开关。
【描述】
debugging ppp compression iphc rtp命令用来显示IP报文头压缩中IP/UDP/RTP头压缩的调试信息。undo debugging ppp compression iphc rtp命令用来关闭IP报文头压缩中IP/UDP/RTP头压缩的调试开关。
# 打开IP报文头压缩中IP/UDP/RTP头压缩的错误调试开关。
<H3C> debugging ppp compression iphc rtp error
debugging ppp compression iphc tcp { all | context_state | error | full_header | general_info }
undo debugging ppp compression iphc tcp { all | context_state | error | full_header | general_info }
all:表示打开IPHC TCP的所有调试开关。
context_state:表示打开IPHC TCP context_state报文调试开关。
error:表示打开IPHC TCP错误信息调试开关。
full_header:表示打开IPHC TCP full_header报文调试开关。
general_info:表示打开IPHC TCP总体信息调试开关。
【描述】
debugging ppp compression iphc tcp命令用于显示IP报文头压缩中IP/TCP头压缩的调试信息。undo debugging ppp compression iphc tcp用来关闭IP报文头压缩中IP/TCP头压缩的调试开关。
# 打开IP报文头压缩中IP/TCP头压缩的错误信息调试开关。
<H3C> debugging ppp compression iphc tcp error
display ppp compression iphc rtp [ interface-type interface-number ]
interface-type:接口类型。
interface-number:接口编号。
【描述】
display ppp compression iphc rtp命令用来显示RTP头压缩的统计信息。
# 显示RTP头压缩的统计信息。
[H3C] display ppp compression iphc rtp
display ppp compression iphc tcp [ interface-type interface-number ]
【描述】
display ppp compression iphc tcp命令用来显示TCP头压缩的统计信息。
# 显示TCP头压缩的统计信息。
[H3C] display ppp compression iphc tcp
display ppp compression stac-lzs [ interface-type interface-number ]
【描述】
display ppp compression stac-lzs命令用来显示stac-lzs压缩的统计信息。
# 显示stac-lzs压缩的统计信息。
[H3C] display ppp compression stac-lzs
Staz-lzs compression
Interface: Dialer1
Received:
Compress/Error/Discard/Total: 302/0/0/302 (Packets)
Sent:
Compress/Error/Total: 302/0/302 (Packets)
ip tcp vjcompress
undo ip tcp vjcompress
无
【描述】
ip tcp vjcompress命令用来允许PPP接口进行VJ TCP头压缩,undo ip tcp vjcompress命令用来禁止PPP接口进行VJ TCP头压缩。
如果允许PPP接口进行VJ TCP头压缩,线路对端的接口也应同时允许VJ TCP头压缩。该命令只用在集中式环境下。
缺省情况下,PPP接口禁止使用VJ TCP头压缩。
# 在PPP接口上允许VJ TCP头压缩。
[H3C-Dialer0] ip tcp vjcompress
ppp compression iphc [ nonstandard ]
undo ppp compression iphc
nonstandard:非标准兼容的封装格式。
【描述】
ppp compression iphc命令用来启动某接口上的IP头压缩,这里主要指TCP头压缩与RTP头压缩,undo ppp compression iphc命令用来关闭TCP头压缩与RTP头压缩功能。
缺省情况下,不启动接口上的TCP头压缩与RTP头压缩功能。
用户必须在链路的两端同时配置压缩命令才能生效。
在配置完成后,只有对接口进行shutdown与undo shutdown操作后,配置才能生效。如果是应用在MP上,要对所有MP捆绑的接口执行shutdown与undo shutdown操作。
相关配置可参考命令ppp compression iphc rtp-connection,ppp compression iphc tcp-connections。
# 启动拨号接口Dialer1上的IP头压缩。
[H3C-Dialer1] ppp compression iphc
ppp compression iphc rtp-connections number
undo ppp compression iphc rtp-connections
number:指该接口上IPHC功能的RTP头压缩的最大连接数,取值范围3~1000,缺省值为16。
【描述】
ppp compression iphc rtp-connections命令用来指定某一个接口上允许存在RTP头压缩连接的总数,undo ppp compression iphc rtp-connections命令可以取消配置,恢复缺省值。
RTP是面向连接的协议,一条链路上所能承载的RTP连接的数目是比较多的,但压缩算法压缩时需对每个连接维护一定的信息,从而占用一定的内存,因此可以用ppp compression iphc rtp-connections命令来配置RTP压缩的最大连接数。例如连接数限定为3时,第4条RTP连接上的报文就不会被压缩了。
配置将在对接口进行shutdown与undo shutdown操作后生效。如果是对MP进行配置,则shutdown与undo shutdown操作必须在所有MP上实施。
# 配置接口Dialer1上RTP头压缩连接的总数为10。
[H3C-Dialer1] ppp compression iphc rtp-connections 10
ppp compression iphc tcp-connections number
undo ppp compression iphc tcp-connections
number:该接口上IPHC功能的TCP头压缩的最大连接数,取值范围3~256,缺省值为16。
【描述】
ppp compression iphc tcp-connections命令用来配置TCP头压缩的最大连接数,undo ppp compression iphc tcp-connections命令用来恢复TCP头压缩的最大连接数的缺省值。
TCP是面向连接的协议,一条链路上所能承载的TCP连接的数目是比较多的,但压缩算法压缩时需对每个连接维护一定的信息,从而占用一定的内存,因此可以用ppp compression iphc tcp-connections命令来配置TCP压缩的最大连接数。例如连接数限定为3时,第4条TCP连接上的报文就不会被压缩了。
# 配置接口Dialer1上TCP头压缩连接的总数为10。
[H3C-Dialer1] ppp compression iphc-connections 10
undo ppp compression stac-lzs
无
【描述】
ppp compression stac-lzs命令用来设置PPP协议启用Stac压缩算法,undo ppp compression stac-lzs命令用来禁止在相应接口使用Stac压缩算法。
缺省情况下,禁止使用Stac压缩算法。
在接口配置stac-lzs压缩,能通过无损的数据压缩减小数据帧的尺寸,但是使用这项配置将增加路由器的负担,所以推荐您在路由器负担过重的时候,禁止该功能。同时只有当链路两端都配置了stac-lzs选项的时候,该PPP链路才支持stac-lzs压缩。
# 设置本端路由器支持stac-lzs压缩。
[H3C-Dialer1] ppp compression stac-lzs
reset ppp compression iphc [ interface-type interface-number ]
【描述】
reset ppp compression iphc命令用来删除那些已经无效的IP/UDP/RTP IP头压缩或解压上下文存储表,并清除IP/UDP/RTP头压缩的统计信息。
如果不指定参数,将清空所有接口的RTP头压缩存储表项。
# 清除IP/UDP/RTP头压缩的统计信息。
<H3C> reset ppp compression iphc
reset ppp compression stac-lzs [ interface-type interface-number ]
【描述】
reset ppp compression stac-lzs命令用来清除Stac-lzs压缩的统计信息。
如果不指定参数,将清空所有接口的Stac-lzs压缩统计信息。
# 清除Stac-lzs压缩的统计信息。
<H3C> reset ppp compression stac-lzs
display pppoe-server session { all | packet }
all:显示各PPPoE session的所有信息。
packet:显示各PPPoE session的报文统计信息。
【描述】
display pppoe-server session命令用来显示PPPoE session的状态和统计数据。
相关配置可参考命令link-protocol ppp,pppoe-server bind。
# 查看所有PPPoE的会话信息。
<H3C> display pppoe-server session all
There is 1 session in total:
SID Intf State OIntf RemMAC LocMAC
2 Virtual-Template1:0 UP Ethernet0/0/0 0050.ba22.7369 00e0.fc08.f4de
表2-1 display pppoe-server session all命令输出信息描述
项目 |
SID |
Session Identifier |
Intf |
对应的虚拟模板接口 |
State |
会话的状态 |
OIntf |
对应的以太网口 |
RemMAC |
Remote MAC,对端MAC地址 |
LocMAC |
Local MAC,本端MAC地址 |
# 查看PPPoE会话统计信息。
<H3C> display pppoe-server session packet
SID RemMAC LocMAC InP InO InD OutP OutO OutD
1 0050ba1a02ce 0001af02a40f 42 2980 0 16 343 0
表2-2 display pppoe-server session packet命令输出信息描述
项目 |
InP |
In Packets,接收报文数 |
InO |
In Octets,接收字节数 |
InD |
In Discards,入方向丢弃的报文数 |
OutP |
Out Packets,发送报文数 |
OutO |
Out Octets,发送字节数 |
OutD |
Out Discard,出方向丢弃的报文数 |
pppoe-server bind virtual-template number
undo pppoe-server bind
number:接入PPPoE的virtual-template数值,取值范围0~1023。
【描述】
pppoe-server bind virtual-template命令用来在以太网接口指定的虚拟模板上使能PPPoE,undo pppoe-server bind virtual-template命令用来在相应接口禁止PPPoE协议。
缺省情况下,禁止PPPoE协议。
# 在以太网口GigabitEthernet1/0的虚拟模板1上使能PPPoE。
[H3C-GigabitEthernet1/0] pppoe-server bind virtual-template 1
undo pppoe-server log-information off
无
【描述】
pppoe-server log-information off命令用来关闭PPPoE Server产生的PPP日志信息的显示开关。undo pppoe-server log-information off 命令用来打开PPPoE Server产生的PPP日志信息的显示开关。
缺省情况下,系统显示PPPoE Server产生的PPP日志信息。
# 关闭PPPoE Server产生的PPP日志信息的显示开关。
[H3C] pppoe-server log-information off
pppoe-server max-sessions local-mac number
undo pppoe-server max-sessions local-mac
number:一个本端MAC地址上能创建的最大session数目。
【描述】
pppoe-server max-sessions local-mac命令用来配置一个本端MAC地址上能创建的最大PPPoE session数目,undo pppoe-server max-sessions local-mac命令用来恢复本参数为缺省值。
相关配置可参考命令pppoe-server max-sessions remote-mac,pppoe-server max-sessions total。
# 设置一个本端MAC地址上能创建的最大PPPoE session数目为50。
[H3C] pppoe-server max-sessions local-mac 50
pppoe-server max-sessions remote-mac number
undo pppoe-server max-sessions remote-mac
number:一个对端MAC地址上能创建的最大PPPoE session数目。
【描述】
pppoe-server max-sessions remote-mac命令用来配置一个对端MAC地址上能创建的最大PPPoE session数目,undo pppoe-server max-sessions remote-mac命令用来恢复本参数为缺省值。
相关配置可参考命令pppoe-server max-sessions local-mac,pppoe-server max-sessions total。
# 设置一个对端MAC地址上能创建的最大PPPoE session数目为50。
[H3C] pppoe-server max-sessions remote-mac 50
pppoe-server max-sessions total number
undo pppoe-server max-sessions total
number:设置本系统能创建的最大PPPoE session数目。
【描述】
pppoe-server max-sessions total命令用来配置本系统能创建的最大PPPoE session数目,undo pppoe-server max-sessions total命令用来将本系统创建的最大PPPoE session数目恢复为缺省值。
相关配置可参考命令pppoe-server max-sessions remote-mac,pppoe-server max-sessions local-mac。
# 设置系统能创建的最大PPPoE session数目为300。
[H3C] pppoe-server max-sessions total 300
reset pppoe-server { all | virtual-template number | interface interface-type interface-num }
all:清除PPPoE全部会话。
virtual-template number:虚拟模板接口编号。
interface interface-type interface-num:接口类型和接口编号。
【描述】
reset pppoe-server命令用来在Server端清除PPPoE会话。
# 清除虚拟模板接口1上的会话。
<H3C> reset pppoe-server virtual-template1
debugging pppoe-client { all | data | error | event | packet | verbose } [ interface type number ]
all:打开所有PPPoE Client调试开关。
data:打开PPPoE Session阶段数据报文调试开关。
error:打开PPPoE Client的错误信息调试开关。
event:打开PPPoE Client事件调试开关。
packet:打开PPPoE Discovery 阶段协商报文调试开关。
verbose:显示PPPoE数据的详细内容。
interface type number:接口类型及编号,用于打开指定接口的调试信息开关。如果不指定接口,则打开所有接口的调试信息开关。
debugging pppoe-client命令用来打开PPPoE Client的调试信息开关。
# 打开所有PPPoE Client调试开关。
<H3C> debugging pppoe-client all
dialer enable-circular
undo dialer enable-circular
Dialer接口视图
无
【描述】
dialer enable-circular命令用来使能轮询DCC(Circular DCC)配置,undo dialer enable-circular命令用来禁用轮询DCC。
在ISDN接口上缺省为使能轮询DCC,在其它接口上缺省为禁止轮询DCC。
用户在使用轮询DCC方法前,必须首先使用此命令使能轮询DCC功能。
# 在Dialer1上使能轮询DCC。
[H3C-Dialer1] dialer enable-circular
dialer bundle number
undo dialer bundle
Dialer接口视图
number:Dialer pool序号,取值范围为1~255。
【描述】
dialer bundle命令用来设置一个Dialer接口使用的拨号池,undo dialer bundle命令用来将dialer bundle与Dialer接口脱离。
缺省没有使能共享DCC,也没有指定dialer bundle。
此命令仅用于Dialer接口,并且一个Dialer接口只能对应一个dialer bundle。
# 在Dialer1上配置接口使用Dialer bundle 3。
[H3C-Dialer1] dialer bundle 3
dialer-group group-number
undo dialer-group
Dialer接口视图
group-number:接口属于的拨号访问组的序号,这个拨号访问组由dialer-rule命令设定,取值范围为1~255。
【描述】
dialer-group命令用来对通过DCC接口发送的报文进行访问控制,将接口置于一个拨号访问组(dialer access group)中,undo dialer-group命令用来将接口从此dialer access group中删除。
缺省情况下,未将接口加入到拨号访问组中。
此命令将接口置于一个拨号访问组中,通过dialer-rule命令将dialer access group与acl命令对应起来。一个DCC接口只能属于一个dialer group,若配置第二次,则覆盖第一次的配置。
& 说明:
接口的缺省配置中,dialer-group是未配置的。用户必须配置此命令,否则DCC将无法发送报文。
相关配置可参考命令dialer-rule。
# 将接口dialer1置入dialer-group 1。
[H3C] dialer-rule 1 acl 3101
[H3C] interface dialer1
[H3C-dialer1] dialer-group 1
dialer-rule dialer-number { protocol-name { permit | deny } | acl acl-number }
undo dialer-rule dialer-number
dialer-number:拨号访问组(dialer access group)的序号,范围为1~255,与DCC接口配置中的dialer-group group-number相对应。
protocol-name:网络协议名,为IP等。
permit:表示允许相应协议的数据报文。
deny:表示禁止相应协议的数据报文。
acl acl-number:拨号访问组对应的acl序号。
【描述】
dialer-rule命令用来设定控制DCC呼叫发生的数据报文的条件,undo dialer-rule命令用来取消该设置。
缺省不设定控制DCC呼叫发生的数据报文的条件。
通过此命令设定一个拨号访问组对应的呼叫触发条件,通过dialer-group命令将Dialer接口置于一个拨号访问组中,从而完成对一个DCC接口的报文发送控制。
若一个dialer-group找不到对应的dialer-rule,DCC将报文作为Uninteresting报文。
相关配置可参考命令dialer-group。
# 设置dialer-rule。
[H3C] acl number 3101
[H3C-acl-adv-3101] rule permit ip source 0.0.0.0 255.255.255.255 destination 0.0.0.0 255.255.255.255
[H3C-acl-adv-3101] quit
dialer user username
undo dialer user
Dialer接口视图
username:对端用户名,为长度为1~80的字符串,用于PPP验证。
【描述】
dialer user命令用来设置对端用户名,以便接收呼叫时能验证请求,undo dialer user命令用来删除对端用户名。
缺省无对端用户名。
该命令仅在Dialer接口上有效。在一个Dialer口下最多可以配置255个Dialer user。当一个Dialer口下配置多个Dialer user时,可以实现用一个Dialer接口同时接入多个物理接口。
当Dialer接口封装PPP时,利用PPP验证得到的对端用户名决定接收呼叫时的Dialer接口,此时可以选择配置dialer number命令。
相关配置可参考命令ppp pap local-user,ppp chap user。
# 设置对端用户名为“GWB”。
[H3C-Dialer3] dialer user GWB
display pppoe-client session { summary | packet } [ dial-bundle-number number ]
summary:显示PPPoE会话的概要信息。
packet:显示PPPoE会话的数据收发统计信息。
dial-bundle-number number:显示指定PPPoE会话的统计信息。如果不指定PPPoE会话,则显示所有PPPoE会话的统计信息。
display pppoe-client session命令用来显示PPPoE会话的状态和统计信息。
# 显示PPPoE会话的概要信息。
[H3C] display pppoe-client session summary
There is 2 session in total:
ID Bundle Dialer Intf Client-MAC Server-MAC State
1 1 1 Eth0 00e0fc0254f3 00049a23b050 PPPUP
2 2 2 Eth0 00e0fc0254f3 00049a23b050 PPPUP
显示信息的详细说明请见下表。
表3-1 display pppoe-client session summary显示信息的含义
域 |
意义 |
ID |
Session ID,PPPoE会话的编号 |
Server-MAC |
服务器MAC地址 |
Client-MAC |
客户端MAC地址 |
Dialer |
PPPoE会话所对应的Dialer接口 |
Bundle |
PPPoE会话所属的Dialer Bundle |
Intf |
PPPoE会话所属的以太网接口 |
State |
PPPoE会话所处的状态 |
# 显示PPPoE会话的数据收发统计信息
[H3C] display pppoe-client session packet
PPPoE Client Session:
SID InP InO InD OutP OutO OutD
1 164 6126 0 83 1069 0
2 304 9886 0 156 2142 0
显示信息的详细说明请见下表。
表3-2 display pppoe-client session packet显示信息的含义
域 |
意义 |
SID |
InP |
In Packets,接收报文数 |
InO |
In Octets,接收字节数 |
InD |
In Discards,接收非法报文并抛弃的报文数 |
OutP |
Out Packets,发送报文数 |
OutO |
Out Octets,发送字节数 |
OutD |
Out Discards,发送非法报文并抛弃的报文数 |
interface dialer interface-number
undo interface dialer interface-number
interface-number:接口序号,取值范围为0~1023。
【描述】
interface dialer命令用来在轮询DCC配置中,创建一个Dialer Circular Group;在共享DCC配置中,定义一个Dialer接口。undo interface dialer命令用来取消已有的设置。
缺省情况下,未定义Dialer接口。
轮询DCC中,Dialer Circular Group 允许将一个Dialer接口的配置用于一组物理接口,这些物理接口继承Dialer接口的属性。这种方式在需要同时呼叫多个目的地址时是非常有效的,即在Dialer接口上配置多条dialer route命令,而每个物理接口中只需执行dialer circular-group命令。
共享DCC中,虽然任意一个Dialer接口也可以有多个物理接口为它提供服务,但任意一个物理接口可同时服务于多个Dialer接口,而这些物理接口上必须配置验证,通过拨入方的用户名寻找它本次呼叫所对应的Dialer接口;该方式下,物理接口与Dialer接口是动态绑定的,而且一个Dialer接口只能呼叫一个目的地址,由命令dialer number来指定。
轮询DCC和共享DCC的物理接口不具有单独的网络地址。它们都使用Dialer接口中对应的地址。
# 定义一个Dialer接口dialer1。
[H3C] interface dialer 1
pppoe-client dial-bundle-number number [ no-hostuniq ] [ idle-timeout seconds [ queue-length packets ] ]
undo pppoe-client dial-bundle-number number
以太网接口或者虚拟以太网接口视图
dial-bundle-number number:与PPPoE会话相对应的Dialer Bundle编号,取值范围为1~255。参数number可以用来唯一标识一个PPPoE会话,也可以把它作为PPPoE会话的编号。
no-hostuniq:在PPPoE Client发起的呼叫中不携带Host-Uniq字段。缺省没有配置no-hostuniq参数,即PPPoE会话缺省工作在永久在线方式。
idle-timeout seconds:允许PPPoE会话空闲的时间,单位为秒,取值范围为1~65535。如果不配置此参数,则PPPoE会话工作在永久在线方式;如果配置此参数,则PPPoE会话工作在报文触发方式。
queue-length packets:在PPPoE会话没有建立之前,系统可以缓存的报文个数,取值范围为1~100。此参数只有在配置了idle-timeout后才有效。packets的缺省值为10。
pppoe-client命令用来建立一个PPPoE会话,并且指定该会话所对应的Dialer Bundle;undo pppoe-client命令用来删除一个PPPoE会话。
缺省情况下,没有配置PPPoE会话。
在一个以太网接口上可以配置多个PPPoE会话,即一个以太网接口可以同时属于多个Dialer Bundle,但是一个Dialer Bundle中只能拥有一个以太网接口。PPPoE会话是和Dialer Bundle一一对应的。如果某一Dialer接口的Dialer Bundle已经有一个以太网接口被用于PPPoE,那么此Dialer Bundle中不能加入其他任何接口。同样,如果在Dialer Bundle中已经有除PPPoE以太网接口以外的接口,那么此Dialer Bundle也同样不能加入被用于PPPoE Client的以太网接口。
当PPPoE会话工作在永久在线方式时,物理线路UP后,路由器会立即发起PPPoE呼叫,建立PPPoE会话。除非用户使用命令undo pppoe-client命令删除PPPoE会话,否则此PPPoE连接会一直存在。当PPPoE会话工作在报文触发方式时,路由器只有在有数据需要传送时才会发起PPPoE呼叫,建立PPPoE会话。如果在seconds时间内PPPoE链路上没有数据传输,则路由器会自动中止PPPoE会话,直到有新的数据需要被传送,PPPoE会话才会被重新建立。
相关配置可参考命令reset pppoe-client。
# 在接口GigabitEthernet 1/0上创建一个PPPoE会话。
[H3C-GigabitEthernet1/0] pppoe-client dial-bundle-number 1
reset pppoe-client { all | dial-bundle-number number }
all:清除所有的PPPoE会话。
dial-bundle-number number:Dialer Bundle编号,取值范围为1~255。用于清除与指定Dialer Bundle相对应的PPPoE会话。
reset pppoe-client命令用来复位PPPoE会话,并在稍后重新发起连接。
当PPPoE会话工作在永久在线方式时,如果使用reset pppoe-client命令中止PPPoE会话,路由器会在16秒后自动重新建立PPPoE会话。当PPPoE会话工作在报文触发方式时,如果使用reset pppoe-client命令中止PPPoE会话,路由器会在有数据需要传送时,才重新建立PPPoE会话。
相关配置可参考命令pppoe-client。
# 清除所有的PPPoE会话,并在稍后重新发起PPPoE会话。
<H3C> reset pppoe-client all
display vlan interface interface-type interface-number
interface-type interface-number:参数用于指定接口。目前支持接口类型有以太网接口和千兆以太网接口,只支持子接口。
【描述】
display vlan interface命令用来显示某个接口的VLAN配置信息,只支持子接口。
# 显示GigabitEthernet2/0.1的VLAN配置信息。
<H3C> display vlan interface gigabitethernet 2/0.1
encapsulation dot1q vid 60
display vlan max-packet-process vid
vid:VLAN ID,用来标识一个VLAN。
【描述】
display vlan max-packet-process命令用来显示某个VLAN上配置的每秒的最大处理报文数目。
相关配置可参考命令max-packet-process。
# 显示VLAN 10上配置的最大处理报文数目。
<H3C> display vlan max-packet-process 10
Max Packet Process Count for Vid 10 is 300000
display vlan statistics vid vid
【描述】
display vlan statistics vid命令用来显示某个VLAN上的报文统计信息,如接收的报文数目,发送的报文数目。
相关配置可参考命令reset vlan statistics interface。
# 显示VLAN 10上的报文统计信息。
<H3C> display vlan statistics vid 10
Packets received: 53
Packets transmitted: 14
max-packet-process count vid
undo max-packet-process vid
count:最大处理报文数目。
【描述】
max-packet-process命令用来设置某个VLAN的每秒的最大处理报文数目,undo max-packet-process命令用来将某个VLAN的每秒的最大处理报文数目恢复为缺省配置。
缺省情况下,系统没有最大处理报文数目的限制。
设置了某个VLAN的每秒的最大处理报文数目后,当接收到的属于这个VLAN的报文达到这个限制后,就会丢弃以后接收到的属于这个VLAN的报文。通过这个命令可以进行流量控制。
相关配置可参考命令display vlan max-packet-process。
# 设置VLAN 10的每秒的最大处理报文数目为200000。
[H3C] max-packet-process 200000 10
reset vlan statistics vid vid
【描述】
reset vlan statistics vid命令用来清除VLAN统计信息。
相关配置可参考命令display vlan statistics vid。
# 清除VLAN ID为10的统计信息。
<H3C> reset vlan statistics vid 10
vlan-type dot1q vid vid
vid:VLAN ID,用来标识一个VLAN,取值范围为1~4094。
【描述】
vlan-type dot1q命令用来设置子接口上的封装类型。
缺省情况下,系统子接口上无封装,也没有与子接口关联的VLAN ID。
相关配置可参考命令display vlan interface。
# 设置GigabitEthernet2/0.1与VLAN ID 60相关联,封装格式为dot1q。
[H3C-GigabitEthernet2/0.1] vlan-type dot1q vid 60
