APP_R3.1.558_G_EN
Release time:2026-03-26
HomeSupportSecurityH3C SecPath ACG1000H3C SecPath ACG1000Software DownloadACG1000 Series
Download
Title Size Downloads
APP_R3.1.558_G_EN.zip 12.37 MB
Version
APP-R3.1.558-G
MD5 Value
611C990455B4505BA77768E44873E9AF
Update Time
2026-03-23
Applicable Versions
Compatible with ACG1000 R6614 and later host versions
Notes:
1) The signature library is in .ubc format and can be directly uploaded for use;
2) Product updates may take some time. During the update process, users should not perform operations involving other functions of the product. Since background services will be modified during the update, this precaution helps avoid data inconsistencies caused by the upgrade.
