S5850-CMW710-R8345P05
Release time:2025-12-08
HomeSupportSwitchesS5850 SeriesS5850 SeriesSoftware DownloadS5850 Series
H3C S5850-CMW710-R8345P05 Release Notes
H3C_彩色.emf
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 1
ISSU upgrade type matrix· 3
Upgrade advice· 3
Upgrade restrictions and guidelines· 3
Hardware feature updates· 3
R8345P05· 3
R8305P15~R8106P22· 4
R8106P21· 4
Software feature and command updates· 4
MIB updates· 4
Operation changes· 4
Operation changes in R8345P05~R8106P22· 4
Operation changes in R8106P21· 4
Restrictions and cautions· 4
Restrictions· 5
Cautions· 5
Licensing· 5
About licensing· 5
Registering and installing licenses· 5
Obtaining license server software and documentation· 5
Open problems and workarounds· 6
List of resolved problems· 6
Resolved problems in R8345P05· 错误!未定义书签。
Resolved problems in R8305P15· 6
Resolved problems in R8106P39· 7
Resolved problems in R8106P22· 8
Resolved problems in R8106P21· 8
Troubleshooting resources· 9
Related documentation· 9
Technical support 9
Appendix A Feature list 10
Hardware features· 10
Software features· 10
Appendix B Fixed security vulnerabilities· 13
Fixed security vulnerabilities in R8106P21· 13
Appendix C Upgrading software· 14
System software file types· 14
System startup process· 14
Upgrade methods· 15
Upgrading from the CLI 16
Preparing for the upgrade· 16
Downloading software images to the master switch· 17
Upgrading from the Boot menu· 21
Prerequisites· 21
Accessing the Boot menu· 22
Accessing the basic Boot menu· 23
Accessing the extended Boot menu· 24
Upgrading Comware images from the Boot menu· 25
Upgrading Boot ROM from the Boot menu· 33
Managing files from the Boot menu· 40
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version S5850-CMW710-R8345P05. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use the documents listed in "Troubleshooting resources ."
Version information
Version number
H3C Comware Software, Version 7.1.070, Rrlease 8345P05
To identify the version number (see Note), execute the display version command in any view.
Version history
IMPORTANT
IMPORTANT:
The software feature changes listed in the version history table for each version are not complete. To obtain complete information about all software feature changes in each version, see the Software Feature Changes document for this release notes.
Table 1 Version history
Version number
Last version
Release date
Release type
Remarks
R8345P05
R8106P22
2025-11-15
Release
None
R8305P15
R8106P39
2024-01-30
Release
None
R8106P39
R8106P22
2023-10-27-
Release
None
R8106P22
R8106P21
2022-12-21
Release
None
R8106P21
First release
2022-10-26
Release
None
CAUTION
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Table 2 Hardware and software compatibility matrix
Item
Specifications
Product family
H3C S5850 series
Hardware platform
S5850-54QS
Memory
2G
Flash
1024M
Boot ROM version
Version 105or higher (Note: Execute the display version command in any view to view the version information. Please see Note)
Host software
S5850-CMW710-R8345P05.ipe (See the MD5 file.)
iMC Version
iMC ACLM  7.3 (E0705P12)
iMC BIMS      7.3 (E0506H01)
iMC DM        7.3 (E0705P12)
iMC EAD       7.3 (E0611P10)
iMC EIA (TAM)  7.3 (E0611P13)
iMC EIA (UAM)  7.3 (E0611P13)
iMC iCC        7.3 (E0705P12)
iMC IPM        7.3(E0609)
iMC NTA        7.3 (E0707L06)
iMC PLAT 7.3 (E0705P12)
iMC QoSM   7.3 (E0505P01)
iMC SHM    7.3 (E0707L06)
iMC VLAN  7.3 (E0705P12)
iNode Version
iNode PC   7.3 (E0585)
Remarks
N/A
<Sysname> display version
H3C Comware Software, Version 7.1.070, Release 8106P39       ------- Note
Copyright (c) 2004-2021 New H3C Technologies Co., Ltd. All rights reserved.
H3C S5850-54QS uptime is 0 weeks, 0 days, 0 hours, 1 minute
Last reboot reason : Cold reboot
Boot image: flash:/s5850-cmw710-boot-r8106P39.bin
Boot image version: 7.1.070, Release 8106P39
  Compiled Jul 12 2021 11:00:00
System image: flash:/s5850-cmw710-system-r8106P39.bin
System image version: 7.1.070, Release 8106P39
Feature image(s) list:
  flash:/s5850-cmw710-freeradius-r8106P39.bin, version: 7.1.070, Release 8106P39
Slot 5:
Uptime is 0 weeks,0 days,0 hours,1 minute
BOARD TYPE:         S5850-54QS
DRAM:               2048M bytes
FLASH:              1024M bytes
PCB 1 Version:      VER.A
Bootrom Version:    105              ------ Note
CPLD 1 Version:     004
Power CPLD Version: None
PowChip Version:    None
Release Version:    H3C S5850-54QS-8106P39
Patch Version:      None
Reboot Cause:       ColdReboot
[SubSlot 0]48*GE + 4*SFP + 2*QSFP
ISSU provides compatible upgrade and incompatible upgrade, depending on the compatibility between software versions. Table 3 provides the approved ISSU upgrade types only between the current version and the history versions within the past 18 months. This matrix does not include history versions that are 18 months earlier than the current version, for which, no ISSU upgrade verification was performed.
For more information about ISSU, see the fundamentals configuration guide for the device.
Table 3 ISSU version compatibility matrix
Current version
History version
Compatibility
S5850-CMW710-R8305P15
Incompatible
Upgrade advice
As a best practice, upgrade to this version as long as possible.
Before performing a software upgrade, it is important to refer to the Software Feature Changes document for any feature changes in the new version. Also check the most recent version of the related documents (see "Related documentation") available on the H3C website for more information about feature configuration and commands.
R8345P05
As from this release, the switch series supports the third-party transceiver modules after the corresponding third-party license is installed.
The MAC address is displayed during the BootROM startup stage of the device.
R8305P15~R8106P22
None
R8106P21
First release.
For more information about the software feature and command update history, see H3C S5850-CMW710-R8345P05 Release Notes (Software Feature Changes).
MIB updates
Table 4 MIB updates
Item
MIB file
Module
S5850-CMW710-R8345P05~S5850-CMW710-R8106P22
New
None
None
None
Modified
None
None
None
S5850-CMW710-R8106P21
New
First release
First release
First release
Modified
First release
First release
First release
Operation changes
None
First release.
When you use this version of software, make sure you fully understand the restrictions and cautions described in this section.
Restrictions
On an IRF fabric, a local precedence marking action takes effect on only the current member device.
Cautions
None.
Licensing
About licensing
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, purchase licenses from H3C and install the licenses. For more information about the license-based features and licenses available for them, see H3C Switches License Matrixes.
To register and transfer licenses, access H3C license services at http://www.h3c.com/en/License.
For information about registering licenses, installing activation files, and transferring licenses, see H3C Switches and Routers Licensing Guide.
Some switches support the license for the unified wired and wireless access controller feature. You can purchase licenses to add the number of APs to be managed. For more information, see H3C Comware 7 or 9 Wireless Products Licensing Guide.
To perform remote licensing, first download and install the H3C license server software.
·         To obtain the H3C license server software package, click
·         To obtain H3C license server documentation, click
202510270002
·         Symptom: Port security does not notify an interface in the VLAN module to remove a VLAN. When a new user comes online, adding the interface VLAN fails, causing the user to fail to come online.
·         Condition: This symptom occurs if the following operations are performed:
¡  Configure both 802.1X and MAC authentication and an authorized VLAN on a port.
¡  Users repeatedly go online and come offline.
¡  Restart the port security process.
·         Workaround: None.
202508271528
·         Symptom: After ARP packets reach the standby MPU, they cannot be forwarded through the AC interface.
·         Condition: This symptom occurs if you execute the forwarding vxlan-packet inner-protocol command on an IRF device in an EVPN VXLAN network, and the device receives ARP packets.
202510151848
·         Symptom: Failed to read and configure the MPLS node through NETCONF.
·         Condition: This symptom occurs if you read and configure the MPLS node through NETCONF.
202510201562
·         Symptom: The device experiences lag when the display epa monitor command is executed and continuously outputs LIPC timeout messages.
·         Condition: This symptom might occur if you execute the display epa monitor command during a device stress test because repeated TM and TC connection establishment can cause the EPAD process to reach the FD upper limit.
202510271535
·         Symptom: During the startup of the TM, the smartmc process exits abnormally. After rebooting, the device automatically adds a new DHCP server IP pool named smartmc.
·         Condition: This symptom might occur if the environment contains a large number of protocol-enabled entries and the TC and TM devices restart sequentially.
202510141512
·         Symptom: The FEC configuration on an interface is cleared.
·         Condition: This symptom occurs if you switch the interface between Layer 2 mode and Layer 3 mode after configuring FEC on the interface.
202510151500
·         Symptom: Executing the reset packet-drop interface command does not clear the dropped packet statistics for an interface.
·         Condition: This symptom occurs if you execute the reset packet-drop interface command during congestion and packet loss on an interface.
202509241535
·         Symptom: IPv6 VXLAN tunnel isolation does not take effect on peer-link traffic, causing the remote device to receive duplicate broadcast traffic.
·         Condition: This symptom occurs in an EVPN M-LAG IPv6 network if you configure IPv6 VXLAN tunnel isolation and the single-homing AC on an M-LAG device forwards Layer 2 broadcast traffic.
202411010654
·         Symptom: Transparent transmission with the PTP 8021 protocol cannot be implemented between the two devices.
·         Condition: This symptom occurs if PTP is not configured on the intermediate device.
202510201370
·         Symptom: The device experiences a restart loop.
·         Condition: This symptom occasionally occurs if the network management interface frequently sends data packets.
202510310607
·         Symptom: The device reports PTP packet loss.
·         Condition: This symptom occurs when a large number of protocol packets are exchanged.
202510210819
·         Symptom: After the S5850-54QS device is enabled with DLDP, if an interface receives broadcast traffic, it is unexpectedly shut down by DLDP after a period of time, which affects normal services.
·         Condition: This symptom occurs if the device receives broadcast traffic after DLDP is enabled on it.
202509251564
·         Symptom: A DHCP client cannot obtain an IP address from the DHCP server or generate a default route.
·         Condition: This symptom might occur on a Layer 3 aggregate subinterface if it acts as a DHCP client to obtain an IP address from the DHCP server.
202510141171
·         Symptom: You fail to configure the upper MAC address learning limit in a VLAN, and the system returns a message of Not enough resources to complete the operation.
·         Condition: This symptom might occur if the device does not have sufficient resources when you execute the mac-address max-mac-count command in VLAN view.
202509051817
·         Symptom: In an IRF fabric, a member device deletes a MAC address entry from a chip unexpectedly, and the device does not automatically restore that entry.
·         Condition: This symptom might occur after MAC authentication is enabled in an IRF fabric.
202312040839
·         Symptom: Configuration failed.
·         Condition: This symptom occurs when the web-auth max-user command is configured on an aggregate interface or a physical interface of the master device.
202312040857
·         Symptom: The portsecd process is abnormal.
·         Condition: This symptom occurs if MAC authentication users and 802.1X users repeatedly log on and off.
202312040847
·         Symptom: The maximum values of the authorization CAR in the authentication domain cannot be deployed.
·         Condition: This symptom might occur if the CIR value exceeds 4194303 in the authorization CAR attributes of the authentication domain.
202312040853
·         Symptom: The number of BFD MAD sessions increases.
a.   Configure another type (non-BFD MAD) of BFD sessions on the IRF fabric.
b.   Configure BFD MAD and apply for a greater ID than the BFD session above.
c.   Restart the BFD process on the active MPU, and then perform active/standby MPU switchover.
d.   Execute the display bfd session command to view BFD session information.
202312040861
·         Symptom: In the output from the display bfd session verbose command, the BFD session authentication mode is incorrect.
·         Condition: This symptom occurs if perform the following operations:
a.   Configure the same source address, destination address, output interface, and VPN settings for the static and dynamic BFD sessions.
b.   Configure different authentication modes in static BFD view and interface view.
c.   Delete the static BFD session.
202312210764
·         Symptom: The serial port periodically prints threshold-crossing logs for port broadcast rate changes as follows:
¡  %Dec 21 11:26:18:860 2023 6550_1 IFMON/4/IFMON_INPUT_BC_RAPID_CHANGE: The incoming broadcast traffic of Twenty-FiveGigE1/0/35 suddenly exceeds the threshold. Threshold=20000, current value=1266394.
¡  %Dec 21 11:26:28:983 2023 6550_1 IFMON/4/IFMON_INPUT_BC_RAPID_RECOVER: The incoming broadcast traffic of Twenty-FiveGigE1/0/35 suddenly drops below the lower threshold. Threshold=20000, current value=632717.
·         Condition: This symptom occurs if you keep injecting broadcast packets slowly to the port.
202312040849
·         Symptom: The display system internal mac-address protocol voice-vlan command output displays residual MAC address entries.
·         Condition: This symptom occurs if the undo voice-vlan mac-address command is executed when voice VLAN traffic exists.
202312040840
·         Symptom: The prompt message is incorrect.
·         Condition: This symptom occurs if you attempt to delete the mirroring group reflector port configuration that does not exist on an interface.
202305230329
·         Symptom: The device restarts abnormally.
·         Condition: This symptom might occur if you execute the display diagnostic-information command to obtain diagnostic information about power supply fans.
202210251301
·         Symptom: The controller fails to issue the ignore-first-as command to the device.
·         Condition: This symptom occurs if the controller issues the ignore-first-as command to the device.
202212280249
·         Symptom: On an EVPN M-LAG system, the display system internal overlay mac-address command displays residual entries.
·         Condition: This symptom might occur if the following conditions exist:
¡  The mac-address forwarding-conversational-learning command is executed.
¡  The M-LAG system receives unknown unicast.
¡  The undo mac-address forwarding-conversational-learning command is executed.
¡  The display system internal overlay mac-address command is executed.
202308300979
·         Symptom: No trap alarm information is received for hh3cPowerRemoved and hh3cPowerInserted nodes.
·         Condition: This symptom occurs if the power supplies of the device are in place and the power cords are unplugged.
202310102003
·         Symptom: The Mode field shows that the power supply type is AC.
·         Condition: This symptom occurs if the device has a 150W DC power supply plugged and starts up normally, and you execute the display power command.
202310100962
·         Symptom: The Current(A) field in the display power command output displays two hyphens (--).
a.    All the power supplies of the device are in place and the device is powered on.
b.    No cable or transceiver module is plugged into any port.
c.    When the device load is low, execute the display power command.
202310080966
·         Symptom: The ARP, ND, and vlaninterface resources are displayed abnormally.
·         Condition: This symptom occurs if the display resource-monitor command is executed on the device.
202304181097
·         Symptom: During the ISSU upgrade and downgrade process, the version number after the upgrade is incorrectly displayed as the version number before the upgrade in the log messages.
·         Condition: This symptom occurs if ISSU upgrade or downgrade is performed.
202304110673
·         Symptom: The value for the Send operation times field is incorrect in the output from the display nqa result command.
·         Condition: This symptom occurs if you shut down the interface and then execute the display nqa result command after the UDP-tracert operation succeeds.
202211281396
·         Symptom: The snmp-agent trap enable ifmonitor or undo snmp-agent trap enable ifmonitor command does not take effect.
·         Condition: This symptom occurs when you execute the snmp-agent trap enable ifmonitor or undo snmp-agent trap enable ifmonitor command.
202211101950
·         Symptom: Core files are generated.
·         Condition: This symptom occurs if you disconnect the connection while executing scripts in TCL view.
First release.
To obtain troubleshooting resources for the product:
1.       Access Technical Documents at http://www.h3c.com/en/Technical_Documents.
2.       Select the device category and model.
3.       Select the Maintain or Maintenance menu.
·         H3C S6526XE-HI[EI] Switch Series Installation Guides
·         H3C S6526XE-HI[EI] Switch Series Hardware Information and Specifications
·         H3C S6526XE-HI[EI] Switch Series Configuration Guides
·         H3C S6526XE-HI[EI] Switch Series Command References
·         H3C Fixed Port Campus Switches Installation Quick Start
Technical support
To obtain technical assistance, contact H3C by using one of the following methods:
·         Email:
[email protected] (countries and regions except Hong Kong, China)
[email protected] (Hong Kong, China)
·         Technical support hotline number. To obtain your local technical support hotline number, go to the H3C Service Hotlines website: https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
To access documentation, go to the H3C website at http://www.h3c.com/en/.
Hardware features
Please refer to H3C S6526XE-HI[EI] Switch Series Installation Guides.
Software features
Table 5 Software features
Feature
S6526XE
Link aggregation
·        Aggregation of 10-GE ports
·        Aggregation of 100-GE ports
·        Static link aggregation
·        Dynamic link aggregation
·        Inter-device aggregation
·        Port aggregation group
Flow control
·        IEEE 802.3x flow control
Jumbo Frame
·        Supports maximum frame size of 9216
MAC address table
·        Blackhole MAC addresses
·        MAC address learning limit on a port
VLAN
·        Port-based VLANs
·        QinQ, selective QinQ, VLAN mapping
·        Voice VLANs
·        Protocol-based VLANs
·        MAC-based VLANs
·        IP subnet VLANs
VxLAN
·        VxLAN based IPv4
ARP
·        Static ARP entries
·        Gratuitous ARP
·        ARP attack detection based on DHCP snooping entries, 802.1X entries, and static IPSG bindings
·        ARP rate limit
ND
·        Static entries
VLAN virtual interface
·        Layer 3 VLAN virtual interface
·        Secondary IP
DHCP
·        DHCP client
·        DHCP snooping
·        DHCP relay
·        DHCP server
·        DHCP Option82
DHCPv6
·        DHCPv6 client
·        DHCPv6 snooping
·        DHCPv6 relay
·        DHCPv6 server
DNS
·        Static DNS
·        Dynamic DNS
·        IPv4 and IPv6 DNS
unicast route
·        IPv4 and IPv6 static routes
·        RIP/RIPng
·        OSPF/OSPFv3
·        BGP/IPv6 BGP
·        ISIS/ISISv6
·        Routing policies
·        Policy-based routing
·        IPv6 policy-based routing
Broadcast/multicast/unicast storm control
·        Storm control based on port rate percentage
·        PPS-based storm control
·        Bps-based storm control
MSTP
·        STP/RSTP/MSTP protocol
·        64 Spanning Tree instances
·        STP Root Guard
·        BPDU Guard
SmartLink
·        SmartLink
RRPP
·        RRPP
QoS/ACL
·        Remarking of 802.1p and DSCP priorities
·        Packet filtering at L2 (Layer 2) through L4 (Layer 4)
·        Eight output queues for each port
·        SP/WRR/SP+WRR queue scheduling algorithms
·        Port-based rate limiting
·        Flow-based redirection
·        Time range
Mirroring
·        Local port mirroring
·        Layer 2 remote port mirroring
·        Layer 3 remote port mirroring
·        Flow mirroring
Security
·        Hierarchical management and password protection of users
·        AAA authentication
·        RADIUS authentication
·        HWTACACS
·        LDAP
·        SSH 2.0
·        Port isolation
·        802.1X
·        Port security
·        User Profile
·        MAC-address-based authentication
·        IP Source Guard
·        HTTPS
·        Public key management
·        PKI
·        IPSec/IKE/IKEv2
·        EAD
802.1X
·        Port-based and MAC address-based authentication
·        Guest VLAN
·        Trunk port authentication
·        Dynamic 802.1X-based ACL/VLAN assignment
Loading and upgrading
·        Loading and upgrading through XModem protocol
·        Loading and upgrading through FTP
·        Loading and upgrading through the trivial file transfer protocol (TFTP)
Management
·        Configuration at the command line interface
·        Remote configuration through Telnet
·        Configuration through Console port
·        Simple network management protocol (SNMP)
·        Remote Monitoring(RMON)
·        IMC NMS
·        System log
·        Hierarchical alarms
·        IRF
·        NTP
·        Power supply alarm function
·        Fan and temperature alarms
Maintenance
·        Debugging information output
·        Ping and Tracert
·        Remote maintenance through Telnet
·        NQA
·        DLDP
·        Virtual Cable Test
This chapter describes types of software used on the switch and how to upgrade software while the switch is operating normally or when the switch cannot correctly start up.
Software required for starting up the switch includes:
·         Boot ROM image—A .bin file that comprises a basic section and an extended section. The basic section is the minimum code that bootstraps the system. The extended section enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the switch cannot correctly start up.
·         Software images—Includes boot images and system images.
¡  Boot image—A .bin file that contains the operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡  System image—A .bin file that contains the minimum modules required for device operation and some basic features, including device management, interface management, configuration management, and routing management.
The software images that have been loaded are called “current software images.” The software images specified to load at next startup are called “startup software images.”
These images might be released separately or as a whole in one .ipe package file. If an .ipe file is used, the system automatically decompresses the file, loads the .bin boot and system images in the file and sets them as startup software images. Typically, the Boot ROM and software images for this switch series are released in an .ipe file named main.ipe.
Boot ROM images are not released along with the boot images and system images. To get a version of Boot ROM image, contact the H3C technical support.
Upon power-on, the Boot ROM image runs to initialize hardware and then the software images run to start up the entire system, as shown in Figure 1.
Figure 1 System startup process
Upgrade methods
You can upgrade system software by using one of the following methods:
Upgrading method
Software types
Remarks
·        Boot ROM image
·        Software images
·        You must reboot the switch to complete the upgrade.
·        This method can interrupt ongoing network services.
·        Boot ROM image
·        Software images
Use this method when the switch cannot correctly start up.
CAUTION CAUTION:
Upgrading an IRF fabric from the CLI instead of the Boot menu.
The Boot menu method increases the service downtime, because it requires that you upgrade the member switches one by one.
The output in this document is for illustration only and might vary with software releases. This document uses boot.bin and system.bin to represent boot and system image names. The actual software image name format is chassis-model_Comware-version_image-type_release, for example, S6526XE-CMW710-BOOT-Rxxxx.bin and S6526XE-CMW710-SYSTEM-Rxxxx.bin.
This section uses a two-member IRF fabric as an example to describe how to upgrade software from the CLI. If you have more than two subordinate switches, repeat the steps for the subordinate switch to upgrade their software. If you are upgrading a standalone switch, ignore the steps for upgrading the subordinate switch. For more information about setting up and configuring an IRF fabric, see the installation guide and Virtual Technologies configuration guide for the H3C S6526XE switch series.
Before you upgrade software, complete the following tasks:
1.       Log in to the IRF fabric through Telnet or the console port. (Details not shown.)
2.       Identify the number of IRF members, each member switch's role, and IRF member ID.
<Sysname> display irf
MemberID   Role   Priority  CPU-Mac         Description
 *+1      Master  5         0023-8927-afdc  ---
   2      Standby 1         0023-8927-af43  ---
 The Bridge MAC of the IRF is: 0023-8927-afdb
 Auto upgrade                : no
 Mac persistent              : 6 min
 Domain ID                   : 0
3.       Verify that each IRF member switch has sufficient storage space for the upgrade images.
IMPORTANT
IMPORTANT:
Each IRF member switch must have free storage space that is at least two times the size of the upgrade image file.
# Identify the free flash space of the master switch.
<Sysname> dir
Directory of flash:
     0      -rw-       41424  Aug 23 2013 02:23:44     startup.mdb
     1      -rw-        3792  Aug 23 2013 02:23:44     startup.cfg
     2      -rw-    53555200  Aug 23 2013 09:53:48     system.bin
     3      drw-           -  Aug 23 2013 00:00:07     seclog
     4      drw-           -  Aug 23 2013 00:00:07     diagfile
     5      drw-           -  Aug 23 2013 00:00:07     logfile
     6      -rw-     9959424  Aug 23 2013 09:53:48     boot.bin
     7      -rw-     9012224  Aug 23 2013 09:53:48     backup.bin
524288 KB total (453416 KB free)
# Identify the free flash space of each subordinate switch, for example, switch 2.
<Sysname> dir slot2#flash:/
Directory of slot2#flash:/
     0      -rw-       41424  Jan 01 2011 02:23:44     startup.mdb
     1      -rw-        3792  Jan 01 2011 02:23:44     startup.cfg
     2      -rw-    93871104  Aug 23 2013 16:00:08     system.bin
     3      drw-           -  Jan 01 2011 00:00:07     seclog
     4      drw-           -  Jan 01 2011 00:00:07     diagfile
     5      drw-           -  Jan 02 2011 00:00:07     logfile
     6      -rw-     13611008  Aug 23 2013 15:59:00     boot.bin
     7      -rw-     9012224  Nov 25 2011 09:53:48     backup.bin
4.       Compare the free flash space of each member switch with the size of the software file to load. If the space is sufficient, start the upgrade process. If not, go to the next step.
5.       Delete unused files in the flash memory to free space:
CAUTION
CAUTION:
·     To avoid data loss, do not delete the current configuration file. For information about the current configuration file, use the display startup command.
·     The delete /unreserved file-url command deletes a file permanently and the action cannot be undone.
·     The delete file-url command moves a file to the recycle bin and the file still occupies storage space. To free the storage space, first execute the undelete command to restore the file, and then execute the delete /unreserved file-url command.
# Delete unused files from the flash memory of the master switch.
<Sysname> delete /unreserved flash:/backup.bin
The file cannot be restored. Delete flash:/backup.bin?[Y/N]:y
Deleting the file permanently will take a long time. Please wait...
Deleting file flash:/backup.bin...Done.
# Delete unused files from the flash memory of the subordinate switch.
<Sysname> delete /unreserved slot2#flash:/backup.bin
The file cannot be restored. Delete slot2#flash:/backup.bin?[Y/N]:y
Deleting file slot2#flash:/backup.bin...Done.
Before you start upgrading software images packages, make sure you have downloaded the upgrading software files to the root directory in flash memory. This section describes downloading an .ipe software file as an example.
The following are ways to download, upload, or copy files to the master switch:
·         FTP download from a server
·         FTP upload from a client
·         TFTP download from a server
If FTP or TFTP is used, the IRF fabric and the PC working as the FTP/TFTP server or FTP client can reach each other.
Prepare the FTP server or TFTP server program yourself for the PC. The switch series does not come with these software programs.
You can use the switch as an FTP client to download files from an FTP server.
To download a file from an FTP server, for example, the server at 10.10.110.1:
6.       Run an FTP server program on the server, configure an FTP username and password, specify the working directory and copy the file, for example, newest.ipe, to the directory.
7.       Execute the ftp command in user view on the IRF fabric to access the FTP server.
<Sysname> ftp 10.10.110.1
Trying 10.10.110.1...
Press CTRL+C to abort
Connected to 10.10.110.1(10.10.110.1).
220 FTP service ready.
User (10.10.110.1:(none)):username
331 Password required for username.
Password:
230 User logged in.
8.       Enable the binary transfer mode.
ftp> binary
  200 Type set to I.
9.       Execute the get command in FTP client view to download the file from the FTP server.
ftp> get newest.ipe
  227 Entering Passive Mode (10,10,110,1,17,97).
  125 BINARY mode data connection already open, transfer starting for /newest.ipe
  226 Transfer complete.
  32133120 bytes received in 35 seconds (896. 0 kbyte/s)
ftp> bye
221 Server closing.
You can use the IRF fabric as an FTP server and upload files from a client to the IRF fabric.
To FTP upload a file from a client:
On the IRF fabric:
10.     Enable FTP server.
[Sysname] ftp server enable
11.     Configure a local FTP user account:
# Create the user account.
[Sysname] local-user abc
# Set its password and specify the FTP service.
[Sysname-luser-manage-abc] password simple pwd
[Sysname-luser-manage-abc] service-type ftp
# Assign the network-admin user role to the user account for uploading file to the working directory of the server.
[Sysname-luser-manage-abc] authorization-attribute user-role network-admin
[Sysname-luser-manage-abc] quit
[Sysname] quit
On the PC:
12.     Log in to the IRF fabric (the FTP server) in FTP mode.
c:\> ftp 1.1.1.1
Connected to 1.1.1.1.
User(1.1.1.1:(none)):abc
331 Password required for abc.
Password:
230 User logged in.
13.     Enable the binary file transfer mode.
ftp> binary
200 TYPE is now 8-bit binary.
14.     Upload the file (for example, newest.ipe) to the root directory of the flash memory on the master switch.
ftp> put newest.ipe
200 PORT command successful
150 Connecting to port 10002
226 File successfully transferred
ftp: 32133120 bytes sent in 64.58 secs (497.60 Kbytes/sec).
To download a file from a TFTP server, for example, the server at 10.10.110.1:
15.     Run a TFTP server program on the server, specify the working directory, and copy the file, for example, newest.ipe, to the directory.
16.     On the IRF fabric, execute the tftp command in user view to download the file to the root directory of the flash memory on the master switch.
<Sysname> tftp 10.10.110.1 get newest.ipe
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 30.6M    0 30.6M    0     0   143k      0 --:--:--  0:03:38 --:--:--  142k
Upgrading the software images
To upgrade the software images:
17.     Specify the upgrade image file (newest.ipe in this example) used at the next startup for the master switch, and assign the M attribute to the boot and system images in the file.
<Sysname> boot-loader file flash:/newest.ipe slot 1 main
Verifying image file..........Done.
Images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to target slot.
Decompressing file boot.bin to flash:/boot.bin....................Done.
Decompressing file system.bin to flash:/system.bin................Done.
The images that have passed all examinations will be used as the main startup so
ftware images at the next reboot on slot 1.
18.     Specify the upgrade image file as the main startup image file for each subordinate switch. This example uses IRF member 2. (The subordinate switches will automatically copy the file to the root directory of their flash memories.)
<Sysname> boot-loader file flash:/newest.ipe slot 2 main
Images in IPE:
  boot.bin
  system.bin
ftware images at the next reboot on slot 2.
19.     Enable the software auto-update function.
[Sysname] irf auto-update enable
[Sysname] quit
This function checks the software versions of member switches for inconsistency with the master switch. If a subordinate switch is using a different software version than the master, the function propagates the current software images of the master to the subordinate as main startup images. The function prevents software version inconsistency from causing the IRF setup failure.
20.     Save the current configuration in any view to prevent data loss.
<Sysname> save
Validating file. Please wait.................
Slot 2:
Save next configuration file successfully.
21.     Reboot the IRF fabric to complete the upgrade.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
 Now rebooting, please wait...
The system automatically loads the .bin boot and system images in the .ipe file and sets them as the startup software images.
22.     Execute the display version command in any view to verify that the current main software images have been updated (details not shown).
The system automatically checks the compatibility of the Boot ROM image and the boot and system images during the reboot. If you are prompted that the Boot ROM image in the upgrade image file is different than the current Boot ROM image, upgrade both the basic and extended sections of the Boot ROM image for compatibility. If you choose to not upgrade the Boot ROM image, the system will ask for an upgrade at the next reboot performed by powering on the switch or rebooting from the CLI (promptly or as scheduled). If you fail to make any choice in the required time, the system upgrades the entire Boot ROM image.
In this approach, you must access the Boot menu of each member switch to upgrade their software one by one. If you are upgrading software images for an IRF fabric, using the CLI is a better choice.
TIP
TIP:
Upgrading through the Ethernet port is faster than through the console port.
Make sure the prerequisites are met before you start upgrading software from the Boot menu.
Setting up the upgrade environment
1.       Use a console cable to connect the console terminal (for example, a PC) to the console port on the switch.
2.       Connect the Ethernet port on the switch to the file server.
The file server and the configuration terminal can be co-located.
3.       Run a terminal emulator program on the console terminal and set the following terminal settings:
¡  Bits per second—9,600
¡  Data bits—8
¡  Parity—None
¡  Stop bits—1
¡  Flow control—None
¡  Emulation—VT100
Preparing for the TFTP or FTP transfer
To use TFTP or FTP:
·         Run a TFTP or FTP server program on the file server or the console terminal.
·         Copy the upgrade file to the file server.
·         Correctly set the working directory on the TFTP or FTP server.
·         Make sure the file server and the switch can reach each other.
Verifying that sufficient storage space is available
IMPORTANT
IMPORTANT:
For the switch to start up correctly, do not delete the main startup software images when you free storage space before upgrading Boot ROM. On the Boot menu, the main startup software images are marked with an asterisk (*).
When you upgrade software, make sure each member switch has sufficient free storage space for the upgrade file, as shown in Table 6.
Table 6 Minimum free storage space requirements
Upgraded images
Comware images
Two times the size of the Comware upgrade package file.
Boot ROM
Same size as the Boot ROM upgrade image file.
If no sufficient space is available, delete unused files as described in “Managing files from the Boot menu.”
Scheduling the upgrade time
During the upgrade, the switch cannot provide any services. You must make sure the upgrade has a minimal impact on the network services.
Starting......
Press Ctrl+D to access BASIC BOOT MENU
Press Ctrl+T to start heavy memory test
*                   H3C S6526XE-48X4CC-EI BOOTROM, Version 101                 *
Copyright (c) 2004-2024 New H3C Technologies Co., Ltd.
Creation Date         : Jun 26 2024
Memory Type           : DDR4 SDRAM
Memory Size           : 4096MB
Memory Speed          : 1200MHz
flash Size            : 7456MB
CPLD 1 Version        : 002
CPLD 2 Version        : 002
PCB Version           : Ver.A
Mac Address           : 00ff00ff00ff
Press Ctrl+B to access EXTENDED BOOT MENU...1
Press one of the shortcut key combinations at prompt.
Table 7 Shortcut keys
Shortcut keys
Prompt message
Function
Remarks
Ctrl+B
Press Ctrl+B to enter Extended Boot menu...
Accesses the extended Boot menu.
Press the keys within 1 second (in fast startup mode) or 5 seconds (in full startup mode) after the message appears.
You can upgrade and manage system software and Boot ROM from this menu.
Ctrl+D
Accesses the basic Boot menu.
Press the keys within 1 seconds after the message appears.
You can upgrade Boot ROM or access the extended Boot ROM segment from this menu.
If the extended Boot ROM segment has corrupted, you can repair or upgrade it from the basic Boot menu.
Press Ctrl+D within 1 seconds after the "Press Ctrl+D to access BASIC BOOT MENU" prompt message appears. If you fail to do this within the time limit, the system starts to run the extended Boot ROM segment.
   BASIC BOOT MENU
1. Update full BootRom
2. Update extended BootRom
3. Update basic BootRom
4. Boot extended BootRom
0. Reboot
Ctrl+U: Access BASIC ASSISTANT MENU
Enter your choice(0-4):
Table 8 Basic Boot ROM menu options
Option
Update the entire Boot ROM, including the basic segment and the extended segment. To do so, you must use XMODEM and the console port. For more information, see Using XMODEM to upgrade Boot ROM through the console port.
Update the extended Boot ROM segment. To do so, you must use XMODEM and the console port. For more information, see Using XMODEM to upgrade Boot ROM through the console port.
Update the basic Boot ROM segment. To do so, you must use XMODEM and the console port. For more information, see Using XMODEM to upgrade Boot ROM through the console port.
Access the extended Boot ROM segment.
For more information, see Accessing the extended Boot menu.
0. Reboot
Reboot the switch.
Press Ctrl + U to access the BASIC ASSISTANT menu (see Table 9).
Table 9 BASIC ASSISTANT menu options
Option
1. RAM Test
Perform a RAM self-test.
0. Return to boot menu
Return to the basic Boot menu.
Press Ctrl+B within 1 second (in fast startup mode) or 5 seconds (in full startup mode) after the "Press Ctrl-B to enter Extended Boot menu..." prompt message appears. If you fail to do this, the system starts decompressing the system software.
Alternatively, you can enter 4 in the basic Boot menu to access the extended Boot menu.
The "Password recovery capability is enabled." or "Password recovery capability is disabled." message appears, followed by the extended Boot menu. Availability of some menu options depends on the state of password recovery capability (see Table 10). For more information about password recovery capability, see Fundamentals Configuration Guide in H3C S6526XE-HI[EI] Switch Series Configuration Guides.
   EXTENDED BOOT MENU
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+R: Download image to SDRAM and run
Enter your choice(0-8):
Table 10 Extended Boot ROM menu options
Option
Tasks
Download a software image file to the flash.
·        Specify the main and backup software image file for the next startup.
·        Specify the main and backup configuration files for the next startup. This task can be performed only if password recovery capability is enabled.
Display files on the flash.
Delete files to free storage space.
Delete the current next-startup configuration files and restore the factory-default configuration.
This option is available only if password recovery capability is disabled.
Access the Boot ROM upgrade menu.
Start the switch without loading any configuration file.
This is a one-time operation and takes effect only for the first system boot or reboot after you choose this option.
This option is available only if password recovery capability is enabled.
Set the startup mode to fast startup mode or full startup mode.
0. Reboot
Reboot the switch.
Format the current storage medium.
Skip the authentication for console login.
Download a system software image and start the switch with the image.
Access the EXTENDED ASSISTANT MENU.
For options in the menu, see Table 11.
Table 11 EXTENDED ASSISTANT menu options
Option
1. Display Memory
Display data in the memory.
2. Search Memory
Search the memory for a specific data segment.
Return to the extended Boot ROM menu.
You can use the following methods to upgrade Comware images:
·         Using TFTP to upgrade software images through the Ethernet port
·         Using FTP to upgrade software images through the Ethernet port
·         Using XMODEM to upgrade software through the console port
1.       Enter 1 in the Boot menu to access the file transfer protocol submenu.
1. Set TFTP protocol parameters
2. Set FTP protocol parameters
3. Set XMODEM protocol parameters
Enter your choice(0-3):
2.       Enter 1 to set the TFTP parameters.
Load File Name      :update.ipe
Server IP Address   :192.168.0.3
Local IP Address    :192.168.0.2
Subnet Mask         :255.255.255.0
Gateway IP Address  :0.0.0.0
Table 12 TFTP parameter description
Item
Load File Name
Name of the file to download (for example, update.ipe).
Server IP Address
IP address of the TFTP server (for example, 192.168.0.3).
Local IP Address
IP address of the switch (for example, 192.168.0.2).
Subnet Mask
Subnet mask of the switch (for example, 255.255.255.0).
Gateway IP Address
IP address of the gateway (in this example, no gateway is required because the server and the switch are on the same subnet).
·     To use the default setting for a field, press Enter without entering any value.
·     If the switch and the server are on different subnets, you must specify a gateway address for the switch.
3.       Enter all required parameters, and enter Y to confirm the settings. The following prompt appears:
Are you sure to download file to flash? Yes or No (Y/N):Y
4.       Enter Y to start downloading the image file. To return to the Boot menu without downloading the upgrade file, enter N.
Loading.........................................................................
................................................................Done!
5.       Enter the M (main), B (backup), or N (none) attribute for the images. In this example, assign the main attribute to the images.
Please input the file attribute (Main/Backup/None) M
Image file boot.bin is self-decompressing...
Free space: 534980608 bytes
Writing flash...................................................................
...................................................................Done!
Image file system.bin is self-decompressing...
Free space: 525981696 bytes
.......................................................................Done!
·     The switch always attempts to boot with the main images first. If the attempt fails, for example, because the main images are not available, the switch tries to boot with the backup images. An image with the none attribute is only stored in flash memory for backup. To use it at reboot, you must change its attribute to main or backup.
·     If an image with the same attribute as the image you are loading is already in the flash memory, the attribute of the old image changes to none after the new image becomes valid.
6.       Enter 0 in the Boot menu to reboot the switch with the new software images.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8): 0
2.       Enter 2 to set the FTP parameters.
FTP User Name       :switch
FTP User Password   :***
Table 13 FTP parameter description
Item
Load File Name
Server IP Address
IP address of the FTP server (for example, 192.168.0.3).
Local IP Address
Subnet Mask
Gateway IP Address
FTP User Name
Username for accessing the FTP server, which must be the same as configured on the FTP server.
FTP User Password
Password for accessing the FTP server, which must be the same as configured on the FTP server.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8):0
·     The switch always attempts to boot with the main images first. If the attempt fails, for example, because the main images not available, the switch tries to boot with the backup images. An image with the none attribute is only stored in flash memory for backup. To use it at reboot, you must change its attribute to main or backup.
XMODEM download through the console port is slower than TFTP or FTP download through the Ethernet port. To save time, use the Ethernet port as long as possible.
2.       Enter 3 to set the XMODEM download baud rate.
Please select your download baudrate:
1.* 9600
2.  19200
3.  38400
4.  57600
5.  115200
Enter your choice(0-5):5
3.       Select an appropriate download rate, for example, enter 5 to select 115200 bps.
Download baudrate is 115200 bps
Please change the terminal's baudrate to 115200 bps and select XMODEM protocol
Press enter key when ready
4.       Set the serial port on the terminal to use the same baud rate and protocol as the console port. If you select 9600 bps as the download rate for the console port, skip this task.
a.       Select Call > Disconnect in the HyperTerminal window to disconnect the terminal from the switch.
Figure 2 Disconnecting the terminal from the switch
b.      Select File > Properties, and in the Properties dialog box, click Configure.
Figure 3 Properties dialog box
c.       Select 115200 from the Bits per second list and click OK.
Figure 4 Modifying the baud rate
d.      Select Call > Call to reestablish the connection.
Figure 5 Reestablishing the connection
5.       Press Enter. The following prompt appears:
6.       Enter Y to start downloading the file. (To return to the Boot menu, enter N.)
Now please start transfer file with XMODEM protocol
If you want to exit, Press <Ctrl+X>
Loading ...CCCCCCCCCCCCCCCCCCCCCCCCC
7.       Select Transfer > Send File in the HyperTerminal window.
Figure 6 Transfer menu
8.       In the dialog box that appears, click Browse to select the source file, and select Xmodem from the Protocol list.
Figure 7 File transmission dialog box
9.       Click Send. The following dialog box appears:
Figure 8 File transfer progress
10.     Enter the M (main), B (backup), or N (none) attribute for the images. In this example, assign the main attribute to the images.
Please input the file attribute (Main/Backup/None) m
The boot.bin image is self-decompressing...
# At the Load File name prompt, enter a name for the boot image to be saved to flash memory.
Load File name  : default_file boot-update.bin       (At the prompt,
Free space: 470519808 bytes
.............Done!
The system-update.bin image is self-decompressing...
# At the Load File name prompt, enter a name for the system image to be saved to flash memory.
Load File name  : default_file system-update.bin
Free space: 461522944 bytes
.............Done!
Your baudrate should be set to 9600 bps again!
·     The switch always attempts to boot with the main images first. If the attempt fails, for example, because the main images not available, the switch tries to boot with the backup images. An image with the none attribute is only stored in the flash memory for backup. To use it at reboot, you must change its attribute to main or backup.
·     If an image with the same attribute as the image you are loading is already in flash memory, the attribute of the old image changes to none after the new image becomes valid.
11.     If the baud rate of the HyperTerminal is not 9600 bps, restore it to 9600 bps as described in step a. If the baud rate is 9600 bps, skip this step.
The console port rate reverts to 9600 bps at a reboot. If you have changed the baud rate, you must perform this step so you can access the switch through the console port after a reboot.
   EXTENDED BOOT MENU
0. Reboot
12.     Enter 0 in the Boot menu to reboot the system with the new software images.
You can use the following methods to upgrade the Boot ROM image:
·         Using TFTP to upgrade Boot ROM through the Ethernet port
·         Using FTP to upgrade Boot ROM through the Ethernet port
·         Using XMODEM to upgrade Boot ROM through the console port
1.       Enter 6 in the Boot menu to access the Boot ROM update menu.
2.       Enter 1 in the Boot ROM update menu to upgrade the full Boot ROM.
The file transfer protocol submenu appears:
3.       Enter 1 to set the TFTP parameters.
Load File Name      :update.btm
Table 14 TFTP parameter description
Item
Load File Name
Name of the file to download (for example, update.btm).
Server IP Address
Local IP Address
Subnet Mask
Gateway IP Address
4.       Enter all required parameters and press Enter to start downloading the file.
Loading.................................................Done!
5.       Enter Y at the prompt to upgrade the basic Boot ROM section.
Will you Update Basic BootRom? (Y/N):Y
Updating Basic BootRom...........Done.
6.       Enter Y at the prompt to upgrade the extended Boot ROM section.
Updating extended BootRom? (Y/N):Y
Updating extended BootRom.........Done.
7.       Enter 0 in the Boot ROM update menu to return to the Boot menu.
8.       Enter 0 in the Boot menu to reboot the switch with the new Boot ROM image.
3.       Enter 2 to set the FTP parameters.
FTP User Password  :123
Table 15 FTP parameter description
Item
Load File Name
Server IP Address
Local IP Address
Subnet Mask
Gateway IP Address
FTP User Name
FTP User Password
3.       Enter 3 to set the XMODEM download baud rate.
1.* 9600
2.  19200
3.  38400
4.  57600
5.  115200
4.       Select an appropriate download rate, for example, enter 5 to select 115200 bps.
5.       Set the serial port on the terminal to use the same baud rate and protocol as the console port. If you select 9600 bps as the download rate for the console port, skip this task.
Figure 9 Disconnecting the terminal from the switch
Figure 10 Properties dialog box
Figure 11 Modifying the baud rate
Figure 12 Reestablishing the connection
6.       Press Enter to start downloading the file.
Figure 13 Transfer menu
Figure 14 File transmission dialog box
Figure 15 File transfer progress
10.     Enter Y at the prompt to upgrade the basic Boot ROM section.
Loading ...CCCCCCCCCCCCCC  ...Done!
11.     Enter Y at the prompt to upgrade the extended Boot ROM section.
12.     If the baud rate of the HyperTerminal is not 9600 bps, restore it to 9600 bps at the prompt, as described in step a. If the baud rate is 9600 bps, skip this step.
Please change the terminal's baudrate to 9600 bps, press ENTER when ready.
13.     Press Enter to access the Boot ROM update menu.
14.     Enter 0 in the Boot ROM update menu to return to the Boot menu.
15.     Enter 0 in the Boot menu to reboot the switch with the new Boot ROM image.
From the Boot menu, you can display files in flash memory to check for obsolete files, incorrect files, or space insufficiency, delete files to release storage space, or change the attributes of software images.
Displaying all files
Enter 3 in the Boot menu to display all files in flash memory and identify the free space size.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8): 3
The following is a sample output:
Display all file(s) in flash:
File Number    File Size(bytes)     File Name
1              8177                 flash:/testbackup.cfg
2(*)           53555200             flash:/system.bin
3(*)           9959424              flash:/boot.bin
4              3678                 flash:/startup.cfg_backup
5              30033                flash:/default.mdb
6              42424                flash:/startup.mdb
7              18                   flash:/.pathfile
8              232311               flash:/logfile/logfile.log
9              5981                 flash:/startup.cfg_back
10(*)          6098                 flash:/startup.cfg
11             20                   flash:/.snmpboots
Free space: 464298848 bytes
The current image is boot.bin
(*)-with main attribute
(b)-with backup attribute
(*b)-with both main and backup attribute
Deleting files
If storage space is insufficient, delete obsolete files to free up storage space.
To delete files:
1.       Enter 4 in the Boot menu:
Deleting the file in flash:
2.       Enter the number of the file to delete. For example, enter 1 to select the file testbackup.cfg.
Please input the file number to change: 1
3.       Enter Y at the confirmation prompt.
The file you selected is testbackup.cfg,Delete it? (Y/N):Y
Deleting....................................Done!
Changing the attribute of software images
Software image attributes include main (M), backup (B), and none (N). System software and boot software can each have multiple none-attribute images but only one main image and one backup image on the switch. You can assign both the M and B attributes to one image. If the M or B attribute you are assigning has been assigned to another image, the assignment removes the attribute from that image. If the removed attribute is the sole attribute of the image, its attribute changes to N.
For example, the system image system.bin has the M attribute and the system image system-update.bin has the B attribute. After you assign the M attribute to system-update.bin, the attribute of system-update.bin changes to M+B and the attribute of system.bin changes to N.
To change the attribute of a system or boot image:
1.       Enter 2 in the Boot menu.
   EXTENDED BOOT MENU
0. Reboot
Enter your choice(0-8): 2
2.       1 or 2 at the prompt to set the attribute of a software image. (The following output is based on the option 2. To set the attribute of a configuration file, enter 3.)
1. Set image file
2. Set bin file
3. Set configuration file
Enter your choice(0-3): 2
1(*)              53555200              flash:/system.bin
2(*)              9959424               flash:/boot.bin
3                 13105152              flash:/boot-update.bin
4                 91273216              flash:/system-update.bin
Free space: 417177920 bytes
Note:Select .bin files. One but only one boot image and system image must be included.
3.       Enter the number of the file you are working with. For example, enter 3 to select the boot image boot-update.bin. and enter 4 to select the system image system-update.bin.
Enter file No.(Allows multiple selection):3
Enter another file No.(0-Finish choice):4
4.       Enter 0 to finish the selection.
Enter another file No.(0-Finish choice):0
You have selected:
5.       Enter M or B to change its attribute to main or backup. If you change its attribute to M, the attribute of boot.bin changes to none.
Please input the file attribute (Main/Backup) M
This operation may take several minutes. Please wait....
Next time, boot-update.bin will become default boot file!
Next time, system-update.bin will become default boot file!
Set the file attribute success!
Handling software upgrade failures
If a software upgrade fails, the system runs the old software version.
To handle a software upgrade failure:
1.       Verify that the software release is compatible with the switch model and the correct file is used.
2.       Verify that the software release and the Boot ROM release are compatible. For software and Boot ROM compatibility, see the hardware and software compatibility matrix in the correct release notes.
3.       Check the physical ports for a loose or incorrect connection.
4.       If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
5.       Check the file transfer settings:
¡  If XMODEM is used, you must set the same baud rate for the terminal as for the console port.
¡  If TFTP is used, you must enter the same server IP addresses, file name, and working directory as set on the TFTP server.
¡  If FTP is used, you must enter the same FTP server IP address, source file name, working directory, and FTP username and password as set on the FTP server.
6.       Check the FTP or TFTP server for any incorrect setting.
7.       Check that the storage device has sufficient space for the upgrade file.
