IPS Signature V7-IPS-1.0.354
Release time:2025-06-14
HomeSupportSecuritySignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-IPS-1.0.354.dat 16.01 MB
Version number
V7-IPS-1.0.354
MD5 number
a6e388bc3c834dea89fa2cd251a0859b
Update time
2025-06-12
Update attack list
Key new rules:
55359  CVE-2025-27817_Apache_Kafka_Client_File_Read_And_SSRF_Vulnerability[2]
---- Category: Vulnerability
---- Description: Apache Kafka Client is a Kafka client developed by the Apache Foundation in the United States.
---- The Apache Kafka Client has a security vulnerability due to insufficient configuration data validation, which
---- may result in arbitrary file reads and server request forgery.
55318  Qiyuesuo_Arbitrary_File_Write_Vulnerability[2]
---- Description: Contract Lock is an electronic signature and seal control platform that provides electronic documents
---- with the same legal effect as paper documents. There is an arbitrary file write vulnerability in some versions of the
---- contract lock. By default, contract locks allow front-end signature verification, allowing unauthenticated attackers
---- to exploit this vulnerability to write arbitrary files, which could ultimately trigger remote code execution by writing
---- timed tasks or other means.
55302  CVE-2025-32433_Erlang_OTP_SSHServer_Remote_Code_Execution_Vulnerability[2]
---- Description: Erlang/OTP is a collection of libraries for the Erlang programming language. In versions prior to OTP-27.3.3,
---- OTP-26.2.5.11, and OTP-25.3.2.20, a vulnerability may exist in the SSH server that allows an attacker to perform unauthenticated
---- remote code execution (RCE). An attacker could exploit a vulnerability in the SSH protocol message handling to gain unauthorized
---- access to an affected system and execute arbitrary commands without valid credentials.
Note
[1] Indicates that this change is incorporated into all security products
[2] Indicates that this change is only incorporated into the full series of F5000, T5000, T9000, M9000, F1030 and above F series products
[3] The device memory is greater than 2GB. After loading the IPS rules library file of this version, 24999 predefined rules can be generated in "Intrusion Prevention System"
[4] The device memory is less than or equal to 2GB. After loading the IPS rules library file of this version, 3286 predefined rules can be generated in "Intrusion Prevention System"
