H3C SecPath F1000-AI-55_F1000-AI-35_F1000-AI-25 Series
Release time:2025-05-26
HomeSupportSecurityH3C SecPath F1000-AI FirewallSoftware DownloadF1000-AI-55 F1000-AI-35 F1000-AI-25 Series
H3C SECPATHF1000_AI_55-CMW710- R9660P54
Release Notes
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 2
ISSU upgrade type matrix· 4
Upgrade restrictions and guidelines· 5
Hardware feature updates· 5
R8860P12 hardware feature updates· 5
Software feature and command updates· 6
MIB updates· 6
Operation changes· 7
Restrictions and cautions· 8
Restrictions· 8
Cautions· 8
License management 9
About licenses· 9
License registration and installation· 9
Open problems and workarounds· 9
List of resolved problems· 9
Resolved problems in R9660P54· 9
Resolved problems in R9660P53· 10
Resolved problems in R9660P51· 11
Resolved problems in R8860P50· 11
Resolved problems in R8860P46· 12
Resolved problems in R8860P43· 12
Resolved problems in R8860P41· 12
Resolved problems in R8860P40· 12
Resolved problems in R8860P27· 12
Resolved problems in R8860P24· 13
Resolved problems in R8860P22· 13
Resolved problems in R8860P18· 15
Resolved problems in F8860P17· 15
Resolved problems in R8860P1212· 16
Resolved problems in R8860P1211· 17
Resolved problems in R8860P1210· 17
Resolved problems in R8860P12· 17
Resolved problems in R8860P11· 17
Resolved problems in E8860P09· 17
Resolved problems in E8860P08· 17
Resolved problems in A8860P0302· 17
Resolved problems in A8860P01· 17
Related documentation· 18
Technical support 18
Appendix A Feature list 1
Hardware features· 1
Software features· 1
Appendix B List of severe vulnerabilities· 5
Severe vulnerabilities in R8860P50 and earlier versions· 5
Appendix C Upgrading software· 6
Software images· 7
Software images types· 7
Software release forms· 7
Configuration files· 7
Upgrade methods· 7
Preparing for the upgrade· 8
Upgrading system software· 9
Upgrading system software from the CLI 9
Upgrading system software from the Web interface· 16
Upgrading system software from BootWare menus· 17
Upgrading the BootWare· 21
Upgrading the BootWare from the CLI 21
Upgrading BootWare from BootWare menus· 22
Handling software upgrade failures· 25
Appendix D Using BootWare menus· 26
Overview· 26
BootWare menus· 26
BootWare shortcut keys· 26
Using the BASIC-BOOTWARE menu· 27
Accessing the BASIC-BOOTWARE menu· 27
Modifying serial port parameters· 28
Upgrading the extended BootWare segment 28
Upgrading the entire BootWare· 28
Running the primary extended BootWare segment 29
Running the backup extended BootWare segment 29
Accessing the BASIC ASSISTANT menu· 30
Testing the memory· 30
Using the EXTENDED-BOOTWARE menu· 30
Accessing the EXTENDED-BOOTWARE menu· 30
Controlling the password recovery capability· 32
Running Comware images· 33
Accessing the Serial submenu· 33
Accessing the Ethernet submenu· 34
Managing files· 36
Restoring the factory-default configuration· 47
Skipping the configuration file· 48
Accessing the BootWare Operation submenu· 48
Skipping console login authentication· 48
Managing storage media· 49
Accessing the EXTEND ASSISTANT submenu· 49
Formatting the file system·· 50
List of tables
Table 1 Version history................................................................................................................................................................ 1
Table 2 Hardware and software compatibility matrix............................................................................................................ 2
Table 3 ISSU version compatibility matrix.............................................................................................................................. 4
Table 5 Device hardware version changes............................................................................................................................... 6
Table 6 MIB updates.................................................................................................................................................................... 6
Table 7 Hardware specifications................................................................................................................................................ 1
Table 8 Firewall software features............................................................................................................................................. 1
Table 9 Default login information........................................................................................................................................... 16
Table 12 BootWare menus........................................................................................................................................................ 26
Table 13 BootWare shortcut keys............................................................................................................................................ 26
Table 15 BASIC ASSISTANT menu options........................................................................................................................ 30
Table 17 Serial submenu options............................................................................................................................................. 34
Table 20 File Control submenu options................................................................................................................................. 36
Table 21 BootWare Operation submenu options.................................................................................................................. 48
Table 22 DEVICE CONTROL menu options....................................................................................................................... 49
Table 23 EXTEND ASSISTANT submenu options............................................................................................................. 49
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version R9660P54 Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with H3C SECPATHF1000_AI_55-CMW710-R9660P54 Release Notes (Software Feature Changes) and the documents listed in "Related documentation."
Version information
Version number
H3C Comware software, Version 7.1.064, Release 8860P51
Note: You can see the version number with the display version command in any view.
Version history
Version number
Last version
Release date
Release type
Remarks
R9660P54
R9660P53
2025-05-20
Release version
This version has solved the problems, provide derived  annual version and technical support.
R9660P53
R9660P51
2025-03-24
Release version
This version has solved the problems, provide annual version ,product and technical support.
R9660P51
R9660P50
2024-11-30
Release version
R8860P50
R8860P46
2024-9-22
Release version
This version has solved the problems, provide derived annual version ,product and technical support.
R8860P46
R8860P43
2024-5-21
Release version
Fixed bugs and released for production use and the use of Technical Support.
R8860P43
R8860P41
2024-2-26
Release version
R8860P41
R8860P40
2023-11-17
Release version
R8860P40
R8860P27
2023-10-30
Release version
R8860P27
R8860P24
2022-08-29
Release version
R8860P24
R8860P22
2022-05-30
Release version
Fixed bugs and released for Technical Support.
R8860P22
R8860P18
2022-03-31
Release version
R8860P18
F8860P17
2021-11-26
Release version
F8860P17
R8860P1212
2021-10-30
Feature version
Fixed bugs and released for the use of Technical Support.
R8860P1212
R8860P1211
2021-08-28
Release version
R8860P1211
R8860P1210
2021-07-28
Release version
R8860P1210
R8860P12
2021-06-25
Release version
R8860P12
R8860P11
2021-05-28
Release version
R8860P11
E8860P09
2021-04-30
Release version
TR6.
Released for the use of Technical Support and production.
E8860P09
E8860P08
2021-03-05
ESS version
TR5.
E8860P08
A8860P0302
2021-02-09
ESS version
TR4A trial release.
A8860P0302
A8860P01
2020-09-17
Alpha version
This version has solved problems and is a trial release for production.
A8860P01
First release
2020-07-16
Alpha version
This version is released for TR4A and production.
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Item
Specifications
Hardware platform
F1000-AI-25
F1000-AI-35
F1000-AI-55
Memory
4 GB
4 GB
8 GB
EMMC flash (stores the IPE file)
4 GB
BootWare version
1.04 (Note: Execute the display version command in any view to view the version information.)
Host software and MD5 checksum
SECPATHF1000_AI_55-CMW710-R8860P50.ipe:
c9e2fe8e89d8a37f7fc1a566cb70fed2
f1028fw-cmw710-boot-R9660P54.bin
c4974fdfc75e27a9e6a32a67bcc37efc
f1028fw-cmw710-system-R9660P54.bin
b70df3958399e39ae4005c5a16dfc4ab
iMC version
iMC-DM  PLAT 7.3 (E0705P12)
iMC UBA 7.3 (E0707L06)
iMC-EIA(TAM)  iMC EIA 7.3 (E0611P13)
iMC-EIA(UAM)  iMC EIA 7.3 (E0611P13)
iMC-iCC  PLAT 7.3 (E0705P12)
iMC-IVM  iMC IVM 7.3 (E0506)
iMC-PLAT  iMC PLAT 7.3 (E0705P12)
iMC-SHM  iMC SHM 7.3 (E0707L06)
iMC-ACLM PLAT 7.3 (E0705P12)
iMC-VLAN iMC PLAT 7.3 (E0705P12)
iNode PC 7.3(C0635)
1.      The time on the iMC server must be consistent with the time on the device.
2.      As a best practice, do not use the wildcard subnet address type when you configure address groups on the device management page of security services on iMC.
3.      Enable action parameters before you configure them on the device management page of security services on iMC.
The EIA component is not supported.
H3C SecCenter CSAP-S version
E1143P05
SMP version
E1111P05
H3C SecCloud OMP version
E1301P01
U-Center
Not supported
AD-NET
E0709
U-Center AOM
E0706P01
AD-Campus
Not supported
AD-DC
Not supported
AD-WAN
Not supported
Cloudnet
OASIS V100R001
Sample: To display the host software and BootWare version of the device, perform the following:
<H3C>dis version
H3C Comware Software, Version 7.1.064, Release 9660P54
Copyright (c) 2004-2025 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F1000 uptime is 0 weeks, 0 days, 0 hours, 50 minutes
Last reboot reason: User reboot
Boot image: flash:/f1028fw-cmw710-boot-R9660P54.bin
Boot image version: 7.1.064, Release 9660P54
    Compiled May 07 2025 14:00:00
System image: flash:/f1028fw-cmw710-system-R9660P54.bin
System image version: 7.1.064, Release 9660P54
SLOT 1
CPU Type         : Multi-core CPU
DDR4 SDRAM Memory        : 3807 MB
Flash                    : 3728 MB
Board PCB Version        : Ver.A
CPLD_A Version           : 2.0
CPLD_B Version           : 1.0
Release Version          : H3C SecPath F1000-9660P54
Basic BootWare Version   : 1.09
Extend BootWare Version  : 1.09
BuckleBoard Version      : Ver.A
BaseBoard Version        : Ver.B
BackBoard Version        : Ver.A
HDD BackBoard Version    : Ver.A
Boot Type                : Warm
[SUBCARD 0] Fixed Subcard(Hardware)Ver.A, (Driver)1.0, (Cpld)2.0
ISSU provides two upgrade types: compatible upgrade and incompatible upgrade. Table 3 provides the approved ISSU upgrade types only between the current version and the history versions within the past 18 months. This matrix does not include history versions that are 18 months earlier than the current version, for which, no ISSU upgrade verification is performed.
For more information about ISSU, see the fundamentals configuration guide for the device.
Current version
History version
ISSU upgrade method
SECPATHF1000_AI_55-CMW710-R8860P46
compatible
SECPATHF1000_AI_55-CMW710-R8860P43
compatible
SECPATHF1000_AI_55-CMW710-R8860P41
compatible
SECPATHF1000_AI_55-CMW710-R8860P40
compatible
SECPATHF1000_AI_55-CMW710-R8860P27
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P24
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P22
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P18
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P1212
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P1211
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P1210
Incompatible
Incompatible
SECPATHF1000_AI_55-CMW710-R8860P11
Incompatible
SECPATHF1000_AI_55-CMW710-E8860P09
Incompatible
SECPATHF1000_AI_55-CMW710-E8860P08
Incompatible
SECPATHF1000_AI_55-CMW710-A8860P0302
Incompatible
SECPATHF1000_AI_55-CMW710-A8860P01
Incompatible
·            To ensure hardware compatibility, do not downgrade the factory software version.
·            The BootWare image is included in the IPE image package. When the device starts up, it compares the current BootWare image with that in the IPE image package. If the current BootWare version is earlier than that in the IPE image package, the system automatically upgrades the BootWare to the version in the IPE image package.
·            When you manually upgrade the AV/URL signature library, follow these restrictions and guidelines: For the signature libraries for anti-virus and URL filtering, the official website provides two sizes for different device storage spaces. The letter H in the name indicates a large signature library. For example, V7-AV-H-1.0.68.dat is a large signature library and V7-AV-1.0.68.dat is a small one. When you perform a manual upgrade, examine your device storage capacity to determine which signature library should be downloaded. The large signature libraries are supported when the memory is larger than 8 GB, and the capacity of the storage medium (flash memory, SD card, or CF card) is larger than 1 GB. Otherwise, only the small signature libraries are supported.
·            After an ISSU, clear the browser cache for the Web interface to correctly display the configuration information of modified features.
·            You can check the Upgrade Way field in the output from the display version comp-matrix command for recommended ISSU methods.
Table 4 ISSU compatibility list
Version description
Version identifier
Version number
ISSU compatibility
Baseline version
V0
R8860P43
compatible
Last software version
Vn-1
R8860P43
compatible
Last Release version
Vk
R8860P43
compatible
As from R8860P12, the memory for F1000-AI-25 is upgraded from 3 GB to 4 GB and that for F1000-AI-55 is upgraded from 4 GB to 8GB. The device hardware version is also upgraded accordingly.
Model
Device hardware version before upgrade
Device hardware version after upgrade
F1000-AI-25
A0
B0 and higher
F1000-AI-55
A0
B0 and higher
This version has no feature changes. For information about the software feature and command update history, see H3C SECPATHF1000_AI_55-CMW710-R8860P50 Release Notes (Software Feature Changes).
MIB updates
Table 6 MIB updates
Item
MIB file
Module
R8860P50
New
None
None
None
Modified
None
None
None
R8860P46
New
None
None
None
Modified
None
None
None
R8860P43
New
New
New
New
Modified
Modified
Modified
Modified
R8860P41
New
New
New
New
Modified
Modified
Modified
Modified
R8860P40
New
New
New
New
Modified
Modified
Modified
Modified
R8860P27
New
New
New
New
Modified
Modified
Modified
Modified
R8860P24
New
None
None
None
Modified
None
None
None
R8860P22
New
None
None
None
Modified
None
None
None
R8860P18
New
None
None
None
Modified
None
None
None
F8860P17
New
None
None
None
Modified
None
None
None
R8860P1212
New
None
None
None
Modified
None
None
None
R8860P1211
New
None
None
None
Modified
None
None
None
R8860P1210
New
None
None
None
Modified
None
None
None
R8860P11
New
None
None
None
Modified
None
None
None
E8860P09
New
None
None
None
Modified
None
None
None
E8860P08
New
None
None
None
Modified
None
None
None
A8860P0302
New
None
None
None
Modified
None
None
None
A8860P01
New
None
None
None
Modified
None
None
None
Operation changes
None.
Before performing an upgrade, see H3C SECPATHF1000_AI_55-CMW710-R8860P50 Release Notes (Software Feature Changes) and related documentation to see the software feature changes and evaluate the influence on the service.
To avoid abnormality and configuration failure, follow these restrictions:
Restrictions
·            If you need to form an RBM or IRF, make sure that the hardware version, software version, interface type, and speed of the 2 devices are consistent.
·            After configuring the IRF stack, the device's performance will decrease, so it is recommended to configure RBM.
·            To ensure stable traffic bandwidth, it is recommended to use the GE1/0/24 port for stacking configuration.
·            Interface cards do not support stacking configuration and hot swapping, as it may cause damage to the entire device.
·            Optical interface cards only support forced mode and do not support auto-negotiation mode.
·            10G optical ports do not support 1G optical modules.
·            When the device is using dual power supplies, avoid repeatedly plugging and unplugging the power supply. If it is necessary to plug and unplug the power supply, make sure the power supply is inserted correctly to avoid CPU abnormalities.
·            If the device has 2 USB ports, when one USB port is connected and configured for external bypass, the other USB port cannot be used as a USB interface to read a USB flash drive.
·            The device does not support VSYS features.
·            The expansion slots (slots 1 and 2) are both low-speed slots, providing 1*GE bandwidth. There are many fixed ports on the front panel of the device, so it is recommended to use the panel ports for configuration first. If the number of interfaces is still not sufficient, then consider configuring the expansion interface card.
Cautions
·            The browser supports Chrome 40 and above, Firefox 19 and above, Internet Explorer 10 and above.
·            Please ensure that the encoding format of CLI is GB18030, otherwise the web page display will appear garbled.
·            Web and command line cannot be used simultaneously for the same feature module configuration.
·            Interface NAT and global NAT are not mutually exclusive. Global NAT only supports new openings, does not support replacing interface NAT, and does not support mixing with interface NAT. SSL VPN web access method to access pages such as WeChat, Alipay, and hao123, some content has not been rewritten, resulting in login or page display failure.
·            E8860P1212 now supports RBM, but does not support Context; R8860P18 now supports RBM+Context.
·            Starting from R8860P33, the mail server address on the report subscription page supports IP address or hostname.
·            RBM running backup cannot handle sslvpn dial-up traffic.
·            The MAC address of the main interface and sub-interface need to be consistent.
·            After resolving the vulnerability issue caused by insufficient password algorithm strength, the original version carrying the INODE client (default using TLS1.0 negotiation) cannot successfully log in to the SSLVPN gateway, and a new INode (after E0582) needs to be used. License management.
·            Zombie network analysis can only read data in the trust-untrust domain.
·            Global NAT object groups do not support nesting.
License management
About licenses
To use license-based features, you must purchase licenses from H3C and install the licenses.
For more information about license-based features and supported licenses, see H3C SecPath F1000 & F5000 Firewall Series License Matrixes.
H3C License Management Platform provides product licensing services for H3C customers. You can access this system to obtain an activation file or transfer licenses.
H3C License Management Platform is accessible at http://www.h3c.com/en/License/.
For more information about license registration, activation file installation, and license transfer, see H3C Security Products Licensing Configuration Demonstration Video (Comware 7), H3C Security Products Licensing Configuration Demonstration  (Comware 7), H3C Security Products Licensing Configuration Examples  (Comware 7), and H3C Security Products Licensing Guide  (Comware 7).
H3C provides license-related FAQ. For more information, see H3C Security Products Licensing FAQ  (Comware 7).
None.
202504211467
·            Symptom: After a long time, the ntop process exits abnormally, generating a core file for ntop mail.
·            Condition: The device has a drive and a large number of URL filtering logs, exporting a summary report related to the URLs.
202504290498
·            Symptom: The first authentication cannot proceed to the redirect.
·            Condition: When the user first accesses the webpage, it triggers a transparent state; the kernel reports the source MAC of the packet as the outgoing interface MAC of the intermediate Layer 3 switch. The process creates a temporary transparent entry in the kernel, but in the cross-Layer 3 transparent scenario, this entry's MAC is all zeros. Subsequent packets do not match this entry due to the inconsistent MAC, leading to repeated submissions. The user mode receives packets and finds that the temporary transparent entry already exists, causing the packet to be discarded.
202504081403
·            Symptom: After a period of time, the system hangs and restarts.
·            Condition: Using the processor's direct exit, sending large packets (70-160004 bytes).
202504020033
·            Symptom: The device does not support web HTTP slow attack defense functionality, making it unable to mitigate detected HTTP slow attacks.
·            Condition: The device is performing vulnerability scanning.
202504160694
·            Symptom: Device traffic is not passing.
·            Condition: Due to abnormal buffer occupation.
202502120603
·            Symptom:The local device's 100M full duplex configuration is ineffective, resulting in packet loss.
·            Condition: Loaded version R9660P51 or below, the local device's interface is configured for forced 100M full duplex, and the opposite transmission equipment is also set to forced 100M full duplex.
202411251582
·            Symptom:Two abnormal reboots occurred in a short period, with the device indicating the reboot reason as User reboot. Upon checking the audit log, there are no historical commands, nor was a reboot operation found to have been executed.
·            Condition: Loaded version R9660P51 or below.
202502080879
·            Symptom:The text description in the report indicates attack data; however, the actual trend chart does not show any attacks.
·            Condition: Review the attack data in the report.
202502190089
·            Symptom:Abnormal quick log filtering; the log server received session logs for SNMP/DNS.
·            Condition: Loaded version R9660P51 or below, the device is prohibited from sending SNMP/DNS session logs to the loghost.
202503061443
·            Symptom: Occasionally, the bootware fails to boot the IPE and gets stuck; switching to the formal release version does not resolve the issue. Only re-flashing the bootware restores functionality, requiring an upgrade of the bootware version.
·            Condition: During equipment testing while loading the equipment version.
202405280803
·            Symptom: The host configuration cannot be synchronized to the backup machine.
·            Condition: Network with domain name type under the address object group, configured for real-time backup.
202411150458
·            Symptom: Bidirectional traffic does not take the last hop from the same interface.
·            Condition: vFirewall equivalent multiple egresses enable IPv4 and IPv6 to take the last hop, and AFT traffic is generated.
202411050082
·            Symptom: After two devices restart, the standby device becomes the master, and some interface configurations and some security domain configurations of the original main frame device are lost.
·            Condition: When the standby device is added to the stack.
202409290905
·            Symptom: Automatically generate NAT commands.
·            Condition: After device restart.
202409061687
·            Symptom: Residual NAT addresses.
·            Condition: After configuring the interface address and VRRP, reconfigure it, and disable the global NAT policy.
202410170244
·            Symptom: Web page access is slow, small ping packets are normal, but large ping packets are dropped.
·            Condition: Customer terminal with source address pings the firewall address.
202407150938
·            Symptom: Power1 repeatedly oscillates, and the power indicator is normal.
·            Condition: Loading D060SP49 and earlier versions.
202406250189
·            Symptom: Both power sources oscillate repeatedly, and the plug and unplug power test still persists.
202311270997
·            Symptom: The function based on fuzzy domain names does not take effect, and it can be avoided by changing the fuzzy domain name to an exact domain name.
·            Condition: The old mark of the fuzzy domain name address in the address object group cannot be refreshed. This causes all addresses
None
202311162067
·            Symptom: The device reboots when it receives GTP packets with ICMP packets embedded.
·            Condition: This symptom occurs if the device receives GTP packets with ICMP packets embedded. ICMP packets do not go through the session establishment process. Instead, the current ICMP nested memory packet is used to match the session. When the session goes through the deletion and release process, there is no return value to release the empty cache.
None
None
202208081324
·            Symptom: A NAT server mapping received from the controller loses the VRRP configuration.
·            Condition: This symptom occurs if the same NAT server mapping already exists on the device.
202208050455
·            Symptom: NAT server mappings are deployed slowly.
·            Condition: This symptom occurs if 30000 NAT server mappings are configured.
202208050453
·            Symptom: Static NAT mappings are deployed slowly.
·            Condition: This symptom occurs if 30000 static NAT mappings are configured.
202208050452
·            Symptom: NAT server mappings are deployed slowly through NETCONF.
·            Condition: This symptom occurs if a large number of NAT server mappings are configured and deployed through NETCONF.
202207190036
·            Symptom: On the Dashboard page, an error message is displayed indicating that the used storage space reaches the limit.
·            Condition: This symptom occurs if the device is not installed with a hard disk and the size of ntop logs stored in the memory has reached the limit.
202203160861
·            Symptom: On a non-default context, a subinterface created based on a shared interface uses the all-zero MAC address. Packets cannot be forwarded on that subinterface.
·            Condition: This symptom occurs if the shared interface is a physical interface or an aggregate interface.
202203310385
·            Symptom: On the Web interface, the editing of an IPv6 security policy cannot succeed, and the Please wait dialog box exists all the time.
·            Condition: This symptom occurs after you edit an IPv6 security policy and click OK on the Edit Security Policy page.
202204200077
·            Symptom: In active mode, the FTP data channel fails to forward packets.
·            Condition: This symptom occurs if a one-to-one mapping for outbound static NAT is configured with the reversible keyword and an ACL specified.
202204191526
·            Symptom: FTP access fails.
·            Condition: This symptom occurs if you configure three rules in a security policy as follows:
a.    Configure an FTP filtering criterion in the first rule.
b.    Configure any application as a filtering criterion in the second rule.
c.    Configure the drop action in the third rule.
202205050998
·            Symptom: On an IRF fabric, the dns snooping enable command does not take effect after the IRF fabric is rebooted.
·            Condition: This symptom occurs if you perform the following operations on an IRF fabric:
a.    Execute the dns snooping enable command.
b.    Save the configuration and reboot the IRF fabric.
202204150051
·            Symptom: A service interface on a subordinate device cannot be pinged successfully after it changes to Layer 3 mode.
a.    Use a VLAN interface for MAD.
b.    Configure the service interface on the subordinate device to operate in Layer 2 mode.
c.    Assign the service interface to the same VLAN as the VLAN interface used for MAD.
d.    Configure the service interface on the subordinate device to operate in Layer 3 mode.
202202250905
·            Symptom: Only four users come online.
·            Condition: This symptom occurs if the following operations are performed:
a.    Enable and disable MAC authentication repeatedly.
b.    Configure a RADIUS scheme with the maximum amount of configuration.
c.    Send traffic with unknown source MAC addresses of 4000 users.
202112161429
·            Symptom: Failed to send emails.
·            Condition: This symptom occurs if the mail server address is configured as a domain name.
202202210546
·            Symptom: The memory usage is high for the ntopd process.
a.    Insert a hard disk.
b.    Send many flows with different source and destination IP addresses.
c.    Enable traffic logging and session statistics collection.
202203091501
·            Symptom: The serial port of the device gets stuck. The device cannot be pinged. Traffic interruption occurs.
·            Condition: This symptom occurs if the kernel version of the device is 4.4 and IRF is configured on the device.
202201280915
·            Symptom: The CLI PlugIn license  Register Cmd Failed error message is displayed during an ISSU on an IRF active/standby fabric.
a.    Perform an ISSU from D060SP18 to D060SP20.
b.    Execute the issu run switchover command on the master device after the subordinate device is upgraded.
202112220320
·            Symptom: The RBM connection fails to be established.
·            Condition: This symptom occurs if you configure the dual-active mode for RBM and use an IPv6 address for the control channel.
202203181737
·            Symptom: The OpenSSL BN_mod_sqrt DoS vulnerability (CVE-2022-0778) exists on the device.
·            Condition: This symptom occurs when a system vulnerability scan is performed on the device.
202107281498
·            Symptom: A security policy containing an object group cannot work correctly after an IRF fabric is rebooted.
·            Condition: This symptom occurs if the object group contains domain names.
202112310557
·            Symptom: Core files are generated because the SSH process experiences exceptions.
202201040413
·            Symptom: Nessus found the FTP Privileged Port Bounce Scan high-risk vulnerability.
·            Condition: This symptom might occur if you use Nessus to scan the system for vulnerabilities when multiple protocols are enabled.
202110291292
·            Symptom: The device reboots when it processes an abnormal IPv4 packet.
·            Condition: This symptom might occur when the device processes abnormal IPv4 packets.
202111110695
·            Symptom: The SSL VPN service with the 0x81d0049 memory tag leaks memory during SSL VPN login.
·            Condition: This symptom occurs if you obtain verification codes repeatedly but do not log in.
202201181541
·            Symptom: IPsec traffic refreshes session interface information. Subsequent negotiation packets are dropped by ASPF.
a.    Set up a NAT traversal IPsec tunnel.
b.    Configure an interzone policy to permit the IPsec tunnel output interface in zone Untrust to zone local. Do not configure an interzone policy to permit traffic from any to zone Local on the headquarters.
c.    Use the addresses in the private networks connected by the tunnel to ping each other.
202201190694
·            Symptom: NTP clock synchronization fails. The reason is that Comware determines that a string that has more than 3 bytes and contains characters and digits is valid, but the OS determines that only the characters are valid and ignores the digits. To resolve the issue, restrictions on glibc time zone  specifications are added to Comware. Comware determines that a string that has more than 3 bytes and contains characters and digits is invalid.
·            Condition: This symptom occurs when NTP clock synchronization is configured on the device.
202201261656
·            Symptom: The IP address corresponding to the host name-based IPv4 address object is not deleted when the host name-to-IPv4 address mapping for DNS is aged out.
·            Condition: This symptom occurs when the host name-to-IPv4 address mapping for DNS is aged out.
202105060373
·            Symptom: In an IRF fabric, memory leaks occur on the subordinate device after the input interface of the forward flow is changed.
·            Condition: This symptom occurs if you have enabled last hop holding and last hop backup.
202108020312
·            Symptom: In an IRF fabric, a domain-name-based security policy does not take effect after the subordinate device is rebooted.
·            Condition: This symptom occurs if a large number of address object groups containing domain names exist.
202107220778
·            Symptom: Memory leaks occur.
·            Condition: This symptom occurs if you enable auto refresh and real-time traffic data collection for the Real-time user ranking and Real-time application ranking widgets from the Web interface.
202107151060
·            Symptom: Memory leaks occur for ntopd.
·            Condition: This symptom occurs if log aggregation is enabled from the Web interface and the device receives traffic.
202109020467
·            Symptom: The device reboots after you execute the session persistent acl 3000 aging-time 0 command and its undo form repeatedly.
·            Condition: This symptom occurs if you execute the session persistent acl 3000 aging-time 0 command and its undo form repeatedly.
202109220429
·            Symptom: A security policy cannot be moved after another security policy.
·            Condition: None.
202110080402
·            Symptom: Traffic rate statistics about IPsec tunnels are not supported.
·            Condition: None.
202109280720
·            Symptom: The memory is not released for the dpid process.
·            Condition: This symptom occurs if the dpid process uses the memory management library glibc instead of tcmalloc.
202108280160
·            Symptom: The device reboots.
·            Condition: This symptom occurs when the packet accessing the SSL VPN gateway carries the svnp_rewrite_code field.
202107090909
·            Symptom: The web https-authorization username command is lost after the binary configuration file recovers, and the Web interface cannot accessed.
·            Condition: This symptom occurs if a certificate is used to log in to the Web interface.
202107220895
202107151103
202101070348
·            Symptom: During reboot, the device still provides power for its connected PFC device. As a result, traffic forwarding fails.
·            Condition: This symptom occurs if the device cooperates with the PFC device.
202106160240
·            Symptom: In a Layer 2 dual-active IRF fabric, the device reboots during transparent transmission.
·            Condition: This symptom occurs if the session synchronization enable asymmetric command is executed.
None.
None.
None.
None.
None.
None.
None.
·            H3C SecPath F1000-AI-X5 Firewall Series Installation Quick Start
·            H3C SecPath F1000-AI-X5 Firewall Series Installation Guide
·            H3C SecPath F1000-AI-X0 Firewall Series Installation Guide
·            H3C SecPath Firewall Series Configuration Guides(V7)
·            H3C SecPath Firewall Series Command References(V7)
·            H3C Security Products Comware 7 System Log Messages Reference-6W600
·            H3C Firewall Products Comware 7 Web Configuration Guide
·            H3C SecPath PSR150-A1 & PSR150-D1 Power Modules User Manual
Technical support
[email protected]
Hardware features
Item
Specifications
Dimensions (W × D × H) excluding rubber feet and mounting brackets
440 × 435 × 44.2 mm (17.32 × 17.13 × 1.74 in)
Weight (net)
5.4 Kg
Ports
·          1 × console port
·          1 × management Ethernet port
·          16 × GE copper ports
·          4 × combo ports
·          6 × GE fiber ports
·          2 × 10GE fiber ports
·          2 × USB 2.0 ports
Expansion slots
2
Hard disk slots
1
Memory
F1000-AI-25 and F1000-AI-35: 4 GB
F1000-AI-55: 8 GB
Flash
4 GB EMMC flash
Power consumption
150 W
Operating temperature
·          Operating:
¡  Without hard disks: 0°C to 45°C (32°F to 113°F)
¡  With hard disks: 5°C to 40°C (41°F to 104°F)
·          Storage: –40°C to 70°C (–40°F to 158°F)
Relative humidity (noncondensing)
·          Operating:
¡  Without hard disks: 5% RH to 95% RH
¡  With hard disks: 10% RH to 90% RH
·          Storage: 5% RH to 95% RH
Software features
Category
Features
AAA
RADIUS/HWTACACS+ authentication.
CHAP authentication.
PAP authentication.
Domain authentication.
Firewall
Packet filtering.
Security zone-based access control.
Time-based access control.
ASPF.
Virtual firewall.
Attack defense.
Detecting and preventing Land, Smurf, Fraggle, WinNuke, Ping of Death, Tear Drop, IP Spoofing, IP fragment, fragment, TCP flag, large ICMP packet, address scanning, port scanning, SYN flood, ICMP flood attacks.
Control of ICMP redirection and destination unreachable messages.
Tracert message control.
Control of IP packets with the RR option.
Static and dynamic blacklists
Security management
Real-time attack protection logs.
Blacklist logs.
Session logs.
Binary logs.
Traffic statistic collection and analysis.
Security event statistics.
NAT
NAT support for address pools.
NAT control using ACLs.
Easy IP.
NAT server.
Effective period of NAT.
NAT ALGs, including FTP, DNS, QQ, MSN, H323, NBT, ILS, RTSP, SQLNET, SIP, RSH, and MGCP.
NAT444.
Content filtering and audit
Recipient and sender filtering
Attachment name and content checking
Email subject and content checking
FTP upload and download file filtering
APR signature library.
PBAR.
NBAR.
Application group.
Bandwidth management
Maximum uplink bandwidth
Maximum downlink bandwidth
Guaranteed uplink bandwidth
Guaranteed downlink bandwidth
Traffic policy (source security zone, destination security zone, source address, destination address, application or application group, time range, and user)
Child traffic profile.
Interface bandwidth limit.
Reports and logs.
IPS
IPS policy.
IPS working mode.
IPS signature.
IPS signature action.
Reports and logs.
IPSec/IKE
AH and ESP.
Manual SA setup and IKE SA setup.
ESP support for DES, 3DES, and AES encryption algorithms.
Support for MD5 and SHA-1 authentication algorithms.
Support for IKE main mode and aggressive mode.
DPD.
NAT traversal.
L2TP
L2TP.
GRE
GRE tunnel.
SSL VPN
IP access.
TCP access.
Smart terminal access.
User authentication.
LAN
Ethernet_II.
VLAN.
IP services
ARP.
Static domain name resolution.
IP address borrowing.
DHCP relay.
DHCP server.
DHCP client.
IP routing
Static route management.
RIP-1/RIP-2.
OSPF.
BGP.
Routing policy.
PBR.
Basic IPv6 protocols.
Protocol processing.
Ethernet link layer.
ICMPv6.
IPv6 address management.
PMTU.
Socket.
TCP6.
UDP6.
RAWIP6.
Ping6.
DNS6.
Tracert6.
Telnet6.
FIB6.
DHCPv6 client.
DHCPv6 relay.
IPv6 routing and multicast
RIPng.
OSPFv3.
BGP4+.
Static routes.
PBR.
PIM-SM.
PIM-DM.
IPv6 security
NAT-PT.
Manual tunnel.
IPv6 over IPv4 GRE tunnel (RFC 2784).
6to4 tunnel (RFC 3056).
ISATAP tunnel.
IPv6 packet filtering.
RADIUS.
DS-Lite
VRRP
VRRP.
IRF
IRF fabric.
Hot backup
Session hot backup.
Configuration synchronization.
CLI
Local configuration through a console port.
Local or remote configuration through Telnet or SSH.
Control of user access to commands.
Debugging.
Network diagnostic tools, including tracert and ping.
Telnetting from the device to other devices.
FTP server/client, and file and application upload and download.
TFTP file transmission.
Logging.
File system management.
User line configuration.
Web management interface
Web administrator timeout (logout).
Web login authentication and authorization.
Web-based device management, device monitoring, and firewall policy configuration.
Network management
Support for SNMPv3 and compatibility with SNMPv2C and SNMPv1.
NTP time synchronization.
CVE-2017-3735
An attacker can exploit this vulnerability to bypass security protections and execute unauthorized operations.
CVE-2019-3855
An integer overflow flaw which could lead to an out of bounds write was discovered in libssh2 in the way packets are read from the server. libssh2 is a client-side C library implementing the SSH2 protocol. A remote attacker who compromises an SSH server may be able to execute code on the client system when a user connects to the server.
HSVD-201904-001
TCP/IP SYN + FIN packet filtering vulnerability: A remote host does not discard TCP SYN packets with the FIN flag set. An attacker might bypass the firewall, depending on the type of firewall used.
HSVD-201902-001
A remote host can exploit the TCP timestamp vulnerability to obtain the online time.
HSVD-201901-016
CVE-2019-0548: A Linux kernel vulnerability that can cause information revealing.
JavaScript library vulnerability
Internal IP addresses in destination URLs might be revealed.
CVE-2020-10188
utility.c in telnetd in netkit telnet through 0.17 allows remote attackers to execute arbitrary code via short writes or urgent data, because of a buffer overflow involving the netclear and nextitem functions.
Web JavaScript vulnerability
 A medium-risk vulnerability found during Web vulnerability scanning.
Web CSRF vulnerability
An CSRF vulnerability was found on the SSL VPN Web login interface.
HTTP method vulnerability
An attacker can use the OPTIONS method to determine the HTTP methods allowed by each directory.
CRLF injection vulnerability
This vulnerability can be exploited when an HTTP request contains a user-configured domain in the cookies or the request is GET /enterdomain.cgi?domain=%0d%0aSomeCustomInjectedHeader:%0d%0aset-cookie:iamyy HTTP1/1.
CVE-2019-1547
An attacker can exploit this vulnerability to obtain sensitive information.
CVE-2019-1563
An attacker, after sending a very large number of messages to be decrypted, can recover a CMS/PKCS7 transported encryption key or decrypt any RSA encrypted message that was encrypted with the public RSA key.
CVE-2016-7056
A timing attack flaw was found in OpenSSL 1.0.1u and before that could allow a malicious user with local access to recover ECDSA P-256 private keys.
CVE-2018-0739
Constructed ASN.1 types with a recursive definition (such as can be found in PKCS7) could eventually exceed the stack given malicious input with excessive recursion. This could result in a Denial Of Service attack.
CVE-2019-1559
An attacker can exploit this vulnerability to bypass access controls and obtain sensitive information.
CVE-2018-0737
An attacker with sufficient access to mount cache timing attacks during the RSA key generation process could recover the private key.
CVE-2018-0732
An attacker can exploit this vulnerability to launch a DoS attack.
CVE-2019-1552
This vulnerability is related to OpenSSL. An attacker can exploit this vulnerability to bypass security controls.
CVE-2019-1563
CVE-2018-5407
This vulnerability is related to OpenSSL. An attacker can exploit this vulnerability to obtain sensitive information and launch more attacks.
X-Frame-Options vulnerability
A missing X-Frame-Options header can cause a clickjacking attack.
CVE-2011-1473
SSL in the kernel does not process the field for disabling SSL renegotiation. As a result, an SSL client can renegotiate successfully.
CVE-2021-23841/CVE-2021-23840/CVE-2020-1971
This vulnerability is related to OpenSSL. The X.509 GeneralName type is a generic type for representing different types of names. One of those name types is known as EDIPartyName. OpenSSL provides a function GENERAL_NAME_cmp that compares different instances of a GENERAL_NAME to see if they are equal or not. This function behaves incorrectly and NULL pointer dereference might occur when both GENERAL_NAMEs contain an EDIPARTYNAME.
CAUTION:
Do not power off or reboot the device during the upgrade process.
The software upgrade procedure is the same for all security devices. This chapter describes how to upgrade software from the CLI, Web interface, and BootWare menus. The default storage medium varies by device model. This chapter uses the CF card as the default storage medium.
Software images
The following software types are available:
·            BootWare image—A .btw file that contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the device cannot start up correctly.
·            System software image—Includes the following image subcategories:
¡  Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡  System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡  Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
You can assign the following attributes to a system software image:
¡  Main—The image is the primary image. The system always attempts to load the main image at startup in preference to the backup image.
¡  Backup—The image is the backup image. It is used only if the primary image is corrupt or not available.
Software images are released in one of the following forms:
·            Separate .bin files. You must verify compatibility between software images.
·            As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Configuration files
You can save settings you made to a configuration file so they can survive a reboot.
The device supports .cfg configuration files. The default .cfg configuration file is named startup.cfg.
Upgrade methods
To upgrade system software, use one of the following methods:
·            Upgrading system software from the CLI
·            Upgrading system software from the Web interface
·            Upgrading system software from BootWare menus
To upgrade the BootWare, use either of the following methods:
·            Upgrading the BootWare from the CLI
·            Upgrading BootWare from BootWare menus
You must reboot the device after a system software or BootWare upgrade. A device reboot interrupts services.
Before a software upgrade, read the release notes to identify the command changes. Some commands in the configuration file might not be supported after a software upgrade.
The device can function as the TFTP client, FTP client, or FTP server. In the following examples that use TFTP or FTP, the device functions as the TFTP or FTP client.
To use a PC as the TFTP or FTP server, prepare the TFTP or FTP server software by yourself. The device is not shipped with the software.
Before you upgrade system software, complete the following tasks:
·            Set up the upgrade environment as shown in Figure 1. The IP address and subnet mask of the PC are 192.168.0.2 and 255.255.255.0, respectively.
·            Run a TFTP or FTP server on the file server. (Skip this task if you upgrade software from the Web interface.)
·            Assign an IP address to the file server. Make sure the management Ethernet port on the device and the file server can reach each other.
By default, the IP address of the management Ethernet port GigabitEthernet 1/0/0 is 192.168.0.1/24 and the management Ethernet port belongs to the Management security zone. The Management security zone and the Local security zone can communicate with each other.
You can also change the IP address of the management Ethernet port from its default and add it to a security zone other than Management. Then, you configure a zone pair to make sure the security zone and the Local security zone can communicate with each other. For more information about security zones and zone pairs, see the security zone configuration in the fundamentals configuration guide.
·            Transfer the software upgrade file to the file server and set the working directory on the TFTP or FTP server.
·            Log in to the CLI of the device through the console port. (Skip this task if you upgrade software from the Web interface.)
·            Make sure the upgrade has minimal impact on the network services. During the upgrade, the device cannot provide any services.
Figure 1 Setting up the upgrade environment
This configuration example upgrades system software from R8513 to R8514. The system software image file name is main.ipe.
You can use TFTP or FTP on the device to access the TFTP or FTP server to back up or download software files.
Using TFTP to upgrade system software
1.      Back up the running system software image and configuration file:
a.    Display current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
  cfa0:/main-cmw710-boot-R8513.bin
  cfa0:/main-cmw710-system-R8513.bin
Main startup software images:
Backup startup software images:
  None
b.    Back up the current software images.
<Sysname> copy main-cmw710-boot-R8513.bin boot_backup.bin
<Sysname> copy main-cmw710-system-R8513.bin system_backup.bin
c.    Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin backup
d.    Execute the save command in any view to save the running configuration.
<Sysname> save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
e.    Execute the dir command in user view to identify the system software image and configuration file names and verify that the CF card has sufficient space for the new system software image.
<Sysname> dir
Directory of cfa0:
   0 -rw-        4269 Jul 12 2018 13:34:36   + attachmentname + .ak
   1 -rw-     5723136 Oct 24 2018 13:03:16   boot_backup.bin
   2 drw-           - Sep 26 2018 15:21:36   diagfile
   3 drw-           - Sep 14 2018 08:04:50   dpi
   4 -rw-     5723136 Oct 23 2018 16:52:51   main-cmw710-boot-R8513.bin
   5 -rw-   137090048 Oct 23 2018 16:58:19   main-cmw710-system-R8513.bin
   6 -rw-         735 Sep 13 2018 19:16:22   hostkey
   7 -rw-         730 Oct 23 2018 16:58:50   ifindex.dat
   8 drw-           - Jul 12 2018 13:34:36   license
   9 drw-           - Sep 13 2018 18:29:20   logfile
  10 drw-           - Sep 13 2018 19:16:24   pki
  11 drw-           - Sep 13 2018 18:33:24   seclog
  12 -rw-         591 Sep 13 2018 19:16:24   serverkey
  13 -rw-        5109 Oct 23 2018 16:58:50   startup.cfg
  14 -rw-      134782 Oct 23 2018 16:58:51   startup.mdb
  15 -rw-   137090048 Oct 24 2018 13:11:57   system_backup.bin
  16 drw-           - Oct 23 2018 17:04:21   versionInfo
4088468 KB total (3972960 KB free)
f.     Execute the tftp put command in user view to upload the startup.cfg file to the TFTP server.
<Sysname> tftp 192.168.0.2 put startup.cfg
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  3950    0     0  100  3950      0   204k --:--:-- --:--:-- --:--:--  642k
2.      Upgrade the system software:
a.    Execute the tftp get command in user view to download the system software image file to the CF card on the device.
<Sysname> tftp 192.168.0.2 get main.ipe
100  102M  100  102M    0     0   461k      0  0:03:48  0:03:48 --:--:--  554k
Writing file...Done.
<Sysname>
b.    Execute the boot-loader file command in user view to load the main.ipe file and specify it as the main image file at the next reboot.
<Sysname> boot-loader file cfa0:/main.ipe all main
Verifying the file cfa0:/main.ipe on slot 1.........Done.
H3C SecPath T5020 images in IPE:
  main-cmw710-boot-R8514.bin
  main-cmw710-system-R8514.bin
This command will set the main startup software images. Please do not reboot any MPU during the upgrade. Continue? [Y/N]:y
Add images to slot 1.
File cfa0:/main-cmw710-boot-R8514.bin already exists on slot 1.
File cfa0:/main-cmw710-system-R8514.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:y
Decompressing file main-cmw710-boot-R8514.bin to cfa0:/main-cmw710-boot-R8514.bin..........Done.
Decompressing file main-cmw710-system-R8514.bin to cfa0:/main-cmw710-system-R8514.bin............................................................................................................................................................................Done.
Verifying the file cfa0:/main-cmw710-boot-R8514.bin on slot 1...Done.
Verifying the file cfa0:/main-cmw710-system-R8514.bin on slot 1.........Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
Decompression completed.
Do you want to delete cfa0:/main.ipe now? [Y/N]:N
<Sysname>
c.    Execute the display boot-loader command in user view to verify that the file has been loaded.
<Sysname>
d.    Execute the reboot command in user view to reboot the device.
<Sysname> reboot
 Start to check configuration with next startup configuration file, please wait.
........DONE!
System is starting...
e.    After the reboot is complete, execute the display version command to verify that the system software image is correct.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Release 8514
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath T5020 uptime is 0 weeks, 2 days, 5 hours, 53 minutes
Boot image: cfa0:/main-cmw710-boot-R8514.bin
Boot image version: 7.1.064, Release 8514
  Compiled Sep 18 2018 15:00:00
System image: cfa0:/main-cmw710-system-R8514.bin
System image version: 7.1.064, Release 8514
SLOT 1
Uptime is 0 weeks, 2 days, 5 hours, 53 minutes
CPU type: Multi-core CPU
DDR3 SDRAM Memory      32766M bytes
CF0 Card         4002M bytes
Board PCB        Version:Ver.A
CPLD_A           Version:  1.0
CPLD_B           Version:  2.0
Release          Version:SecPath T5020-8514
Basic  BootWare  Version: 2.04
Extend BootWare  Version: 2.04
<Sysname>
Using FTP to upgrade system software
  None
<Sysname>
<Sysname> save
<Sysname>
<Sysname> dir
Directory of cfa0:
<Sysname>
f.     Execute the ftp command in user view to access the FTP server.
<Sysname> ftp 192.168.0.2
Connected to 192.168.0.2 (192.168.0.2).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.0.2:(none)): user123
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
ftp>
g.    Execute the put command in FTP client view to upload the startup.cfg file to the FTP server.
ftp> put startup.cfg
227 Entering passive mode (192,168,0,2,26,3).
125 Using existing data connection.
226 Closing data connection; File transfer successful.
3950 bytes sent in 0.001 seconds (4.13 Mbytes/s)
ftp>
a.    Execute the get command in FTP client view to download the system software image file to the CF card on the device.
ftp> get main.ipe
227 Entering passive mode (192,168,0,2,8,252)
107934720 bytes received in 187.994 seconds (560.68 Kbytes/s)
ftp>
b.    Execute the quit command in FTP client view to return to user view.
ftp> quit
221 Service closing control connection
<Sysname>
c.    Execute the boot-loader file command in user view to load the main.ipe file and specify it as the main image file at the next reboot.
<Sysname>
d.    Execute the display boot-loader command in user view to verify that the file has been loaded.
Software images on slot 2:
<Sysname>
e.    Execute the reboot command in user view to reboot the device.
<Sysname> reboot
........DONE!
f.     After the reboot is complete, execute the display version command to verify that the system software image is correct.
SLOT 1
CPLD_A           Version:  1.0
CPLD_B           Version:  2.0
<Sysname>
CAUTION:
·       You can use the default account settings or create a new account to log in to the Web interface for the first time. This section uses the default account settings. For security purposes, if you use the default account settings, modify the default password or create a new account and delete the default account after the first login.
·       Do not perform any operation on the Web interface while the system is upgrading software.
Table 9 describes the default settings for you to log in to the Web interface.
Login information
Default setting
Username
admin
Password
admin
IP address of GigabitEthernet 1/0/0
192.168.0.1/24
The default management Ethernet port varies by device model. In this example, the default management Ethernet port is GigabitEthernet 1/0/0.
To upgrade the system software from the Web interface:
3.      Use an Ethernet cable to connect the PC to an Ethernet port on the device. As a best practice, connect the PC to the management Ethernet port on the device.
4.      Assign an IP address on the same subnet as the management port GigabitEthernet 1/0/0 to the PC.
In this example, assign 192.168.0.2 to the PC.
5.      Launch the Web browser, and enter 192.168.0.1 in the address bar.
The Web login page appears.
6.      Type the default username and password, and click Login.
7.      Select System > Upgrade Center > Software Upgrade from the navigation tree.
8.      Click Upgrade immediately on the Software Upgrade page.
9.      Select the startup file to be used, and click OK.
Figure 2 Upgrade Immediately page
To upgrade Comware images from BootWare menus, use one of the following methods:
·            Using TFTP to upgrade system software through the management Ethernet port
·            Using FTP to upgrade system software through the management Ethernet port
1.      Connect the configuration terminal to the MPU's console port.
2.      Connect the MPU's management Ethernet port to the TFTP or FTP file server.
The TFTP or FTP server can be co-located with the configuration terminal (typically, a PC).
3.      Prepare the upgrade file:
¡  If you are using TFTP, store the upgrade file on the TFTP server, and specify the directory.
¡  If you are using FTP, store the upgrade file on the FTP server, and specify the directory, FTP username, and password.
4.      Run the terminal emulation program on the configuration terminal.
5.      Power on the device, and then press Ctrl+B within 5 seconds at prompt to access the EXTEND-BOOTWARE menu (see "Using the EXTENDED-BOOTWARE menu").
1.      Enter 3 in the EXTEND-BOOTWARE menu to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is sda0                                         |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5):
2.      Enter 5 in the Ethernet submenu to configure the network settings.
To use the existing setting for a field, press Enter without modifying the setting.
======================<ETHERNET PARAMETER SET>==============================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP):tftp
Load File Name        :main.ipe
Target File Name      :main.ipe
Server IP Address     :192.168.0.2
Local IP Address      :192.168.0.1
Subnet Mask            :255.255.255.0
Gateway IP Address    :0.0.0.0
Table 10 Network parameter fields and shortcut keys
'.' = Clear field
Press a dot (.) and then press Enter to clear the setting for a field.
Press a hyphen (-) and then press Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl+D to exit the ETHERNET PARAMETER SET menu.
Set the file transfer protocol to TFTP.
Load File Name
Set the name of the file to be downloaded.
Target File Name
Set a file name for saving the file on the device. The target file name must have the same extension as the source file.
By default, the target file name is the same as the source file name.
Server IP Address
Set the IP address of the TFTP server.
Local IP Address
Set the IP address of the Ethernet interface that connects to the TFTP server.
Subnet Mask
Set the IP address mask.
Gateway IP Address
Set a gateway IP address if the device is on a different network than the server.
After you finish setting the TFTP parameters, the system returns to the Ethernet submenu.
3.      Enter 2 or 3 in the Ethernet submenu to upgrade the main or backup software images. For example, enter 2 to upgrade the main software images.
Loading.....................................................................
.........................Done!
94786560 bytes downloaded!
Image file main-cmw710-boot-A9615.bin is self-decompressing...
Saving file sda0:/main-cmw710-boot-A9615.bin ......Done.
Image file main-cmw710-system-A9615.bin is self-decompressing...
Saving file sda0:/main-cmw710-system-A9615.bin .......................
..................Done.  .
4.      Enter 0 in the Ethernet submenu to return to the EXTEND-BOOTWARE menu.
5.      Enter 1 in the EXTEND-BOOTWARE menu to run the new Comware images.
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP):ftp
FTP User Name         :admin
FTP User Password     :******
Table 11 Network parameter fields and shortcut keys
'.' = Clear field
Ctrl+D = Quit
Set the file transfer protocol to FTP.
Load File Name
Target File Name
Server IP Address
Set the IP address of the FTP or TFTP server.
Local IP Address
Set the IP address of the Ethernet interface that connects to the TFTP or FTP server.
Subnet Mask
Gateway IP Address
FTP User Name
Set the username for accessing the FTP server. This username must be the same as the username configured on the FTP server.
FTP User Password
Set the password for accessing the FTP server. This password must be the same as the password configured on the FTP server.
After you finish setting the FTP parameters, the system returns to the Ethernet submenu.
5.      Enter 1 in the EXTEND-BOOTWARE menu to run the new system software.
You can upgrade the BootWare from the CLI or BootWare menus.
Whether a .btw file is compressed together with an .ipe file depends on the device model and software release. Please check it with H3C technical support. This section describes only how to upgrade the BootWare from the CLI.
To upgrade the BootWare from the CLI:
1.      Use FTP or TFTP to download or upload the new BootWare image file to the root directory of the storage medium on the device.
2.      Execute the bootrom update command to upgrade the BootWare.
<System> bootrom update file cfa0:/main.btw slot 2
  This command will update bootrom file, Continue? [Y/N]:y
  Now updating bootrom, please wait...
 Updating basic bootrom!
 Update basic bootrom success!
 Updating extended bootrom!
 Update extended bootrom success!
 Update bootrom success!
<System>
3.      Execute the reboot command to reboot the device.
To upgrade the BootWare image from BootWare menus, use one of the following methods:
·            Using TFTP to upgrade BootWare through the management Ethernet port
·            Using FTP to upgrade BootWare through the management Ethernet port
For more information about BootWare menus, see "Using BootWare menus."
This section uses the MPU as an example to describe how to upgrade BootWare.
1.      Connect the MPU's console port to the configuration terminal.
¡  If you are using TFTP, store the upgrade file on the TFTP server, and specify the file directory.
¡  If you are using FTP, store the upgrade file on the FTP server, and specify the file directory, FTP username, and password.
1.      Enter 7 in the BootWare menu to access the BootWare Operation submenu.
=========================<BootWare Operation Menu>==========================
|<1> Backup Full BootWare                                                  |
|<2> Restore Full BootWare                                                 |
|<3> Update BootWare By Serial                                             |
|<4> Update BootWare By Ethernet                                           |
Enter your choice(0-4):
2.      Enter 4 in the BootWare Operation submenu to enter the Ethernet submenu.
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare                                                  |
|<2> Update Extended BootWare                                              |
|<3> Update Basic BootWare                                                 |
|<4> Modify Ethernet Parameter                                             |
3.      Enter 4 in the Ethernet submenu to configure the network settings.
==========================<ETHERNET PARAMETER SET>==========================
|          Ctrl+D = Quit.                                                  |
Load File Name         :Main.btw
Target File Name       :Main.btw
For more information about the fields, see Table 10.
After you finish setting the TFTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
4.      Choose an option from options 1 to 3. For example, enter 1 to upgrade the entire BootWare image.
Loading..............Done.
64245 bytes downloaded!
Updating Basic BootWare? [Y/N]
5.      Enter Y to upgrade the basic BootWare segment.
Updating Basic BootWare........Done.
Updating Extended BootWare? [Y/N]
6.      Enter Y to upgrade the extended BootWare segment.
Updating Extended BootWare.........Done!
7.      Enter 0 to return to the BootWare Operation menu.
8.      Enter 0 in the BootWare Operation menu to return to the EXTEND-BOOTWARE menu.
9.      Enter 0 in the EXTEND-BOOTWARE menu to reboot the system.
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :ftp
For more information about the fields, see Table 11.
After you finish setting the FTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
Loading.......Done.
Updating Extended BootWare.........Done.
Handling software upgrade failures
If a software upgrade fails, the system runs the old software version. To handle a software failure:
1.      Check the physical ports for a loose or incorrect connection, and verify that the LEDs are reflecting the correct port status.
2.      If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
3.      Check the file transfer settings:
¡  If TFTP is used, you must enter the same server IP addresses, file name, and working directory as set on the TFTP server.
¡  If FTP is used, you must enter the same FTP server IP address, source file name, working directory, and FTP username and password as set on the FTP server.
4.      Check the FTP or TFTP server for incorrect settings.
5.      Check that the CF card has sufficient space for the upgrade file.
6.      If the message "Something is wrong with the file" appears, check the file for file corruption.
Appendix D Using BootWare menus
Overview
BootWare provides a menu method to perform basic file operations, software upgrade, and system management when the Comware CLI is inaccessible because of image corruption.
BootWare is stored in each MPU's built-in the SD card. It has one basic segment and one extended segment. The basic segment enables the system to complete basic initialization, and the extended segment bootstraps the Comware images.
BootWare menus
Table 12 lists the menus that each segment provides and the major tasks you can perform using these menus. You can access these menus only during system startup.
Table 12 BootWare menus
BootWare segment
Menu
Tasks
Reference
Basic
BASIC-BOOTWARE
·          Modify serial port parameters.
·          Upgrade BootWare.
·          Start the primary or backup BootWare extended segment.
Using the BASIC-BOOTWARE menu
Basic
BASIC ASSISTANT
Perform RAM test.
Accessing the BASIC-BOOTWARE menu
Extended
EXTEND-BOOTWARE
·          Upgrade Comware software.
·          Manage files.
·          Access the system when the console login password is lost.
·          Clear user privilege passwords.
Extended
EXTEND-ASSISTANT
·          Examine system memory.
·          Search system memory.
Accessing the EXTEND ASSISTANT submenu
BootWare shortcut keys
BootWare provides the shortcut keys listed in Table 13.
Table 13 BootWare shortcut keys
Shortcut keys
Prompt message
Function
Ctrl+B
access EXTENDED-BOOTWARE MENU
Accesses the EXTENDED-BOOTWARE menu while the device is starting up.
Ctrl+C
Please Start To Transfer File, Press <Ctrl+C> To Exit.
Stops the ongoing file transfer and exits the current operation interface.
Info: Press Ctrl+C to abort or return to EXTENDED ASSISTANT MENU.
Returns to the EXTENDED ASSISTANT menu. If the system is outputting the result of an operation, this shortcut key combination aborts the display first.
Ctrl+D
Press Ctrl+D to access BASIC-BOOTWARE MENU
Accesses the BASIC-BOOTWARE menu while the device is starting up.
Ctrl+D = Quit
Exits the parameter settings menu.
Ctrl+E
Memory Test(press Ctrl+C to skip it,press Ctrl+E to ECHO INFO)
Prints information during the memory test.
Ctrl+F
Ctrl+F: Format File System
Formats the current storage medium.
Ctrl+T
Press Ctrl+T to start memory test
Performs a memory test.
Ctrl+U
Access BASIC ASSISTANT MENU
Accesses the BASIC ASSISTANT menu from the BASIC-BOOTWARE menu.
Ctrl+Z
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Accesses the EXTENDED ASSISTANT menu from the EXTENDED-BOOTWARE menu.
1.      Power on the device.
2.      Press Ctrl+D within 4 seconds after the "Press Ctrl+D to access BASIC-BOOTWARE MENU" prompt message appears. If you fail to do this within the time limit, the system starts to run the extended BootWare segment.
======================<BASIC-BOOTWARE MENU(Ver 1.19)>=======================
|<1> Modify Serial Interface Parameter                                     |
|<3> Update Full BootWare                                                  |
|<4> Boot Extended BootWare                                                |
|<5> Boot Backup Extended BootWare                                         |
|<0> Reboot        |
Ctrl+U: Access BASIC ASSISTANT MENU
Table 14 BASIC-BOOTWARE menu options
Option
Reference
Change the baud rate of the console port.
Perform this task before downloading an image through the console port for software upgrade.
Modifying serial port parameters
Upgrade the extended BootWare segment.
If the extended segment is corrupt, choose this option to repair it.
Upgrading the extended BootWare segment
Upgrade the entire BootWare, including the basic segment and the extended segment.
Upgrading the entire BootWare
Run the primary extended BootWare segment.
Running the primary extended BootWare segment
<5> Boot Backup Extend BootWare
Run the backup extended BootWare segment.
Running the backup extended BootWare segment
<0> Reboot
Reboot the device.
N/A
Press Ctrl+U to access the BASIC ASSISTANT menu.
Accessing the BASIC ASSISTANT menu
To change the baud rate of the console port:
1.      Enter 1 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 1
===============================<BAUDRATE SET>===============================
|Note:'*'indicates the current baudrate                                    |
|     Change The HyperTerminal's Baudrate Accordingly                      |
|---------------------------<Baudrate Available>---------------- ----------|
|<1> 9600(Default)*                                                        |
|<2> 19200        |
|<3> 38400        |
|<4> 57600        |
|<5> 115200        |
|<0> Exit        |
2.      Enter the number that represents the baud rate you want to choose. For example, enter 5 to set the baud rate to 115200 bps.
Baud rate change is a one-time operation. The baud rate will restore to the default (9600 bps) at reboot. To set up a console session with the device after a reboot, you must change the baud rate of the configuration terminal back to 9600 bps.
Enter 2 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 2
Waiting ...CCC
Enter 3 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 3
Waiting ...CCC
Enter 4 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 4
Booting Normal Extended BootWare.
The Extended BootWare is self-decompressing....Done.
*                   H3C SecPath BootWare, Version 1.05                     *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Aug 31 2017
Memory Type         : DDR3 SDRAM
Memory Size         : 16384MB
Sda0 Size          : 8MB
sda0 Size           : 3728MB
CPLD Version        : 1.0
PCB Version         : Ver.B
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
Loading file sda0:/Main-CMW710-SYSTEM-A9615.bin. ......................
Image file sda0:/Main-CMW710-BOOT-A9615.bin is self-decompressing......
System image is starting...
Enter 5 in the BASIC-BOOTWARE menu.
For information about backing up the extended BootWare segment, see "Accessing the BootWare Operation submenu."
Enter your choice(0-5): 5
Booting Backup Extended BootWare.
The Extended BootWare is self-decompressing............................Done!
This option is not supported if the password recovery capability is enabled. For more information about configuring the password recovery capability at the CLI, see "Controlling the password recovery capability."
Press Ctrl+U in the BASIC-BOOTWARE menu.
===========================<BASIC-ASSISTANT MENU>===========================
|<1> RAM Test                                                              |
Enter your choice(0-1):
Table 15 BASIC ASSISTANT menu options
Option
<1> RAM Test
Test the memory.
<2> Exit To Main Menu
Return to the BASIC-BOOTWARE menu.
Testing the memory
IMPORTANT:
To avoid unexpected exceptions, perform this task under the guidance of H3C Support.
To test the memory, use one of the following methods:
·            In the BASIC-BOOTWARE menu, press Ctrl+T within 4 seconds after the "Press Ctrl+T to start memory test" prompt message appears.
·            In the BASIC-BOOTWARE menu, press Ctrl+U to access the BASIC ASSISTANT menu.
Accessing the EXTENDED-BOOTWARE menu
2.      Press Ctrl+B within 5 seconds after the "Press Ctrl+B to access EXTENDED-BOOTWARE MENU..." prompt message appears. If you fail to do this within the time limit, the system starts up.
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test..
Sda0 Size          : 8MB
sda0 Size           : 3728MB
CPLD Version        : 1.0
PCB Version         : Ver.B
Password recovery capability is enabled.
Note: The current operating device is sda0
Enter < Storage Device Operation > to select device.
3.      Press Enter to access the EXTENDED-BOOTWARE menu.
===========================<EXTENDED-BOOTWARE MENU>=========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Enter your choice(0-9):
Availability of some options in this menu depends on the password recovery capability state (displayed on top of the EXTEND-BOOTWARE menu). For more information about the feature, see "Controlling the password recovery capability."
Table 16 EXTENDED-BOOTWARE menu options
Option
Tasks
Reference
<1> Boot System
Run the Comware software without rebooting the device.
Choose this option after completing operations in the EXTENDED-BOOTWARE menu.
N/A
Accessing the Serial submenu.
Use FTP or TFTP to upgrade Comware images through the management Ethernet port.
Accessing the Ethernet submenu
<4> File Control
·          Display files on the current storage medium.
·          Set a Comware image file as the main or backup startup software image file.
·          Delete files to release storage space.
Managing files
Restore the factory-default configuration.
This option is available only if password recovery capability is disabled.
Restoring the factory-default configuration
Start the device with the factory-default configuration without loading any configuration file.
This option is available only if password recovery capability is enabled.
Skipping the configuration file
Back up, recover, and upgrade the BootWare image.
Skip console login authentication.
This is a one-time operation and takes effect only for the first system boot or reboot after you choose this option.
Skipping console login authentication
Set the storage medium from which the device will start up.
Set the storage medium where file operations are performed. This storage medium is referred to as the "current storage medium."
Managing storage media
Format the file system.
Formatting the file system
Access the EXTENDED ASSISTANT menu.
<0> Reboot
Reboot the device.
N/A
Password recovery capability controls console user access to the device configuration from BootWare menus. This feature decides the method to handle a password loss situation.
·            If password recovery capability is enabled, a console user can handle a password loss situation as follows:
¡  If the console login password is lost, the user can skip console login authentication, and then access the CLI to configure a new password.
¡  If a user role password is lost, the user can skip the configuration file, and then access the CLI to configure a new password.
·            If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords.
To enhance system security, disable password recovery capability.
To enable or disable password recovery capability:
Step
Remarks
4.      Enter system view.
N/A
5.      Enable or disabled password recovery capability.
·          Enable the feature:
password-recovery enable
·          Disable the feature:
undo password-recovery enable
By default, password recovery capability is enabled.
Running Comware images
Enter 1 in the EXTEND-BOOTWARE menu.
Enter your choice(0-9): 1
Loading file cfa0:/main-cmw710-system-e8526.bin.........................
Loading file cfa0:/main-cmw710-boot-e8526.bin...........................
Image file cfa0:/main-cmw710-boot-e8526.bin is self-decompressing.......
........Done.
Enter 2 in the EXTEND-BOOTWARE menu.
Enter your choice(0-9): 2
===========================<Enter Serial SubMenu>===========================
|<5> Modify Serial Interface Parameter                                     |
Table 17 Serial submenu options
Option
Tasks
Load and run Comware images in SDRAM.
Download Comware images to the current storage medium as the main images (the file attribute is set to M).
As a result, the M file attribute of the original main images is removed.
Download Comware images to the current storage medium as backup images (the file attribute is set to B).
As a result, the B file attribute of the original backup images is removed.
Download files from the server to the device.
The baud rate change is a one-time operation. The baud rate will restore to the default (9600 bps) at reboot. To set up a console session with the device after a reboot, you must change the baud rate setting on the configuration terminal to 9600 bps.
Return to the EXTENDED-BOOTWARE menu.
To set the current storage medium, see "Managing storage media."
You can upgrade the Comware software through the management Ethernet port from the Ethernet submenu and configure file transfer settings.
1.      Enter 3 in the EXTENDED-BOOTWARE menu and press Enter to access the Ethernet submenu.
Enter your choice(0-9):3
Table 18 Ethernet submenu options
Option
Load and run software images in SDRAM.
If password recovery capability is enabled, this option is not available.
Download software images to the current storage medium as main images (the file attribute is set to M).
Download software images to the current storage medium as backup images (the file attribute is set to B).
Configure FTP or TFTP file transfer settings.
2.      Enter 4 in the Ethernet submenu to configure file transfer settings on the MPU.
Enter your choice(0-4):4
|          Ctrl+D = Quit.                                                 |
Table 19 Setting Ethernet parameters for file transfer
'.' = Clear field
Press the dot (.), and then press Enter to clear the setting for a field.
Press the hyphen (-), and then press Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl + D to exit the Ethernet parameter settings menu.
Set the file transfer protocol to FTP or TFTP.
Load File Name
Target File Name
Set a file name for saving the file in the current storage medium on the device.
Server IP Address
Local IP Address
Set the IP address of the device.
Subnet Mask
Gateway IP Address
FTP User Name
Set the username for accessing the FTP server. This username must be the same as configured on the FTP server. This field is not available for TFTP.
FTP User Password
Set the password for accessing the FTP server. This password must be the same as configured on the FTP server. This field is not available for TFTP.
Managing files
You can display all files, set the attribute for a file, and delete a file from the File Control submenu.
Enter 4 in the EXTEND-BOOTWARE menu and then press Enter to access the File Control submenu.
Enter your choice(0-9):4
===============================<File CONTROL>===============================
|Note:the operating device is cfa0                                         |
|<1> Display All File(s)                                                   |
|<2> Set Image File type                                                   |
|<3> Set Bin File type                                                     |
|<4> Set Configuration File type                                           |
|<5> Delete File                                                           |
Table 20 File Control submenu options
Option
Display all files.
Set the attribute for a software image file.
Set the attribute for a .bin file.
Set the type for a configuration file.
<5> Delete File
Delete a file.
Return to the EXTEND-BOOTWARE menu.
Displaying all files
Enter 1 in the File Control submenu.
Display all file(s) in cfa0:
 'M' = MAIN      'B' = BACKUP      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   956       Jan/21/2019 17:59:34 N/A    cfa0:/ifindex.dat               |
|2   24671     Mar/28/2018 09:08:56 N/A    cfa0:/wdydiudie.cfg             |
|3   735       Mar/28/2018 09:18:22 N/A    cfa0:/hostkey                   |
|4   116549    Oct/09/2017 13:51:02 N/A    cfa0:/lwb-t5k.cfg               |
|5   963       Mar/27/2018 15:24:12 N/A    cfa0:/license/history/deviceid_2|
|0180327152412.did                                                         |
|6   965       Mar/27/2018 15:24:12 N/A    cfa0:/license/210235a1rsh1640000|
|06.did        |
|7   3237      Dec/25/2017 15:14:54 N/A    cfa0:/license/ngips2017122515235|
|923325.ak        |
|8   3249      Apr/16/2018 16:40:28 N/A    cfa0:/license/ngips2018041616523|
|608292.ak        |
|9   1611429   Jan/22/2019 14:14:22 N/A    cfa0:/logfile/logfile.log       |
|10  1048575   Apr/16/2018 17:57:26 N/A    cfa0:/logfile/ips.log           |
|11  5230      Mar/19/2018 14:40:30 N/A    cfa0:/logfile/uflt.log          |
|12  1048405   Apr/16/2018 17:57:26 N/A    cfa0:/logfile/anti-vir.log      |
|13  44840     Aug/10/2017 15:25:46 N/A    cfa0:/logfile/dfilter.log       |
|14  14195     Jan/21/2019 16:47:54 N/A    cfa0:/logfile/cfglog.log        |
|15  251751    Jan/03/2019 09:09:56 N/A    cfa0:/diagfile/diagfile.log     |
|16  69784     Mar/28/2018 09:18:28 N/A    cfa0:/dpi/ips/predefined/ips_sig|
|pack_curr.dat                                                             |
|17  2373992   Mar/28/2018 09:18:28 N/A    cfa0:/dpi/ips/predefined/ips_sig|
|pack_back.dat                                                             |
|18  32027352  Apr/16/2018 16:56:28 N/A    cfa0:/dpi/av/predefined/av_sigpa|
|ck_curr.dat                                                               |
|19  9574536   Apr/16/2018 16:48:00 N/A    cfa0:/dpi/av/predefined/av_sigpa|
|ck_back.dat                                                               |
|20  68040     Mar/28/2018 09:18:28 N/A    cfa0:/dpi/uflt/predefined/uflt_s|
|igpack_curr.dat                                                           |
|21  10330760  Mar/28/2018 09:18:36 N/A    cfa0:/dpi/uflt/predefined/uflt_s|
|igpack_back.dat                                                           |
|22  342232    Mar/28/2018 09:18:24 N/A    cfa0:/dpi/apr/predefined/apr_sig|
|pack_curr.dat                                                             |
|23  979448    Mar/28/2018 09:18:24 N/A    cfa0:/dpi/apr/predefined/apr_sig|
|pack_back.dat                                                             |
|24  2840      Jan/22/2019 14:12:46 N/A    cfa0:/dpi/filereg/predefined/fil|
|ereg_sigpack_curr.dat                                                     |
|25  30        Jan/21/2019 16:53:16 N/A    cfa0:/dpi/dpi_sigpack.log       |
|26  1566      Mar/28/2018 09:18:20 N/A    cfa0:/pki/https-server.p12      |
|27  591       Mar/28/2018 09:18:22 N/A    cfa0:/serverkey                 |
|28  259308    Mar/28/2018 09:08:58 N/A    cfa0:/wdydiudie.mdb             |
|29  723419    Oct/09/2017 13:51:04 N/A    cfa0:/lwb-t5k.mdb               |
|30  22692     Jan/21/2019 17:59:36 M      cfa0:/startup.cfg               |
|31  686202    May/20/2017 19:15:56 N/A    cfa0:/pn.cfg                    |
|32  9275      Oct/28/2017 13:50:12 N/A    cfa0:/zp.cfg                    |
|33  807       Oct/09/2017 15:59:54 N/A    cfa0:/.trash/.trashinfo         |
|34  5327872   Aug/15/2017 13:06:42 N/A    cfa0:/.trash/main-cmw710-boo|
|t-e8518.bin_0001                                                          |
|35  5331968   Aug/15/2017 10:30:04 N/A    cfa0:/.trash/main-cmw710-boo|
|t-e8519.bin_0001                                                          |
|36  9048064   Aug/21/2017 13:54:12 N/A    cfa0:/.trash/main-cmw710-boo|
|t-e8520.bin_0001                                                          |
|37  2056192   Aug/12/2017 18:05:54 N/A    cfa0:/.trash/main-cmw710-dev|
|kit-e8518.bin_0001                                                        |
|38  163840    Aug/14/2017 16:57:06 N/A    cfa0:/.trash/main-cmw710-dev|
|kit-e8519.bin_0001                                                        |
|39  163840    Aug/21/2017 14:07:26 N/A    cfa0:/.trash/main-cmw710-dev|
|kit-e8520.bin_0001                                                        |
|40  103891968 Aug/15/2017 13:07:04 N/A    cfa0:/.trash/main-cmw710-sys|
|tem-e8518.bin_0001                                                        |
|41  107120640 Aug/15/2017 10:30:58 N/A    cfa0:/.trash/main-cmw710-sys|
|tem-e8519.bin_0001                                                        |
|42  171900928 Aug/21/2017 14:07:02 N/A    cfa0:/.trash/main-cmw710-sys|
|tem-e8520.bin_0001                                                        |
|43  2238      Jan/22/2019 14:14:22 N/A    cfa0:/context/context3/logfile/l|
|ogfile.log        |
|44  24        Jan/21/2019 17:59:50 N/A    cfa0:/context/context3/ifindex.d|
|at        |
|45  1192      Jan/21/2019 17:59:50 N/A    cfa0:/context/context3/startup.c|
|fg        |
|46  34023     Jan/21/2019 17:59:50 N/A    cfa0:/context/context3/startup.m|
|db        |
|47  18468     Jan/22/2019 14:14:22 N/A    cfa0:/context/context4/logfile/l|
|ogfile.log        |
|48  1566      Mar/28/2018 09:19:08 N/A    cfa0:/context/context4/pki/https|
|-server.p12                                                               |
|49  1671      Jan/22/2019 09:27:00 N/A    cfa0:/context/context4/startup.c|
|fg        |
|50  37050     Jan/22/2019 09:27:00 N/A    cfa0:/context/context4/startup.m|
|db        |
|51  52        Jan/22/2019 09:27:00 N/A    cfa0:/context/context4/ifindex.d|
|at        |
|52  9054208   Apr/20/2018 13:27:02 N/A    cfa0:/main-cmw710-boot-e8526|
|.bin        |
|53  227919    Jan/21/2019 17:59:36 N/A    cfa0:/startup.mdb               |
|54  186294272 Apr/20/2018 13:27:30 N/A    cfa0:/main-cmw710-system-e85|
|26.bin        |
|55  123384832 Jan/21/2019 17:20:04 N/A    cfa0:/main.ipe             |
|56  3920      Jul/19/2017 18:32:04 N/A    cfa0:/86.raw                    |
|57  3242      Jul/07/2017 09:36:50 N/A    cfa0:/ngips2017070709142354252.a|
|k        |
|58  120804    Jun/17/2017 17:00:30 N/A    cfa0:/1.cfg                     |
|59  822025    Jun/17/2017 17:00:34 N/A    cfa0:/1.mdb                     |
|60  120727    Jun/17/2017 17:01:02 N/A    cfa0:/2.cfg                     |
|61  821866    Jun/17/2017 17:01:06 N/A    cfa0:/2.mdb                     |
|62  16        Jan/21/2019 17:48:10 N/A    cfa0:/versioninfo/versionctl.dat|
|63  536       Jan/21/2019 17:48:10 N/A    cfa0:/versioninfo/version0.dat  |
|64  796       Mar/20/2018 16:23:44 N/A    cfa0:/versioninfo/version1.dat  |
|65  796       Mar/20/2018 16:30:22 N/A    cfa0:/versioninfo/version2.dat  |
|66  796       Mar/20/2018 16:32:22 N/A    cfa0:/versioninfo/version3.dat  |
|67  796       Mar/20/2018 16:39:04 N/A    cfa0:/versioninfo/version4.dat  |
|68  536       Mar/27/2018 12:36:40 N/A    cfa0:/versioninfo/version5.dat  |
|69  796       Mar/27/2018 14:23:12 N/A    cfa0:/versioninfo/version6.dat  |
|70  536       Mar/28/2018 09:18:16 N/A    cfa0:/versioninfo/version7.dat  |
|71  796       Apr/16/2018 18:06:04 N/A    cfa0:/versioninfo/version8.dat  |
|72  536       Jul/24/2018 11:50:02 N/A    cfa0:/versioninfo/version9.dat  |
|73  9696      Sep/11/2017 17:41:56 N/A    cfa0:/libpty.so                 |
|74  500446    Jul/29/2017 17:59:46 N/A    cfa0:/ips.rules                 |
|75  19586056  Oct/16/2017 17:58:08 N/A    cfa0:/50w-2.dat                 |
|76  117405304 Oct/16/2017 15:38:20 N/A    cfa0:/500w-2.dat                |
|77  7125      Sep/11/2017 19:43:30 N/A    cfa0:/new1.rules                |
|78  963       Oct/16/2017 17:12:58 N/A    cfa0:/210235a1rsh164000006.did  |
|79  9172      Oct/26/2017 11:30:30 N/A    cfa0:/uzi.cfg                   |
|80  792001    May/20/2017 19:15:58 N/A    cfa0:/pn.mdb                    |
|81  554834    May/18/2017 15:40:52 N/A    cfa0:/fullconfig.cfg            |
|82  684919    May/19/2017 13:50:20 N/A    cfa0:/fullconfig2.cfg           |
|83  554834    May/18/2017 16:20:36 N/A    cfa0:/fullconfig1.cfg           |
|84  788347    May/19/2017 13:50:22 N/A    cfa0:/fullconfig2.mdb           |
|85  154433    Oct/26/2017 11:30:30 N/A    cfa0:/uzi.mdb                   |
|86  685411    May/23/2017 14:08:56 N/A    cfa0:/wdy0523.cfg               |
|87  791322    May/23/2017 14:08:58 N/A    cfa0:/wdy0523.mdb               |
|88  3246      Oct/16/2017 17:38:58 N/A    cfa0:/ngips2017101617275868747.a|
|k        |
|89  164864    Apr/20/2018 13:36:44 N/A    cfa0:/main-cmw710-devkit-e85|
|26.bin        |
|90  582397    Dec/25/2017 16:17:00 N/A    cfa0:/1024.rules                |
|91  93544     Dec/25/2017 16:17:30 N/A    cfa0:/url.dat                   |
|92  5684224   Jul/24/2018 11:39:04 N/A    cfa0:/main-cmw710-boot-e8530|
|.bin        |
|93  154961    Oct/28/2017 13:50:14 N/A    cfa0:/zp.mdb                    |
|94  504464    Oct/28/2017 19:22:12 N/A    cfa0:/5e9dd320d3c7fd6fbec3a81a85|
|788002.6d9ada99                                                           |
|95  2491008   Oct/29/2017 15:57:14 N/A    cfa0:/8ac3b6bff681d9be6a20f865ac|
|e15a14        |
|96  20        Jan/31/2018 14:20:10 N/A    cfa0:/.snmpboots                |
|97  2216      Apr/16/2018 18:05:22 N/A    cfa0:/pcap/excpt-currentcpu11-20|
|180117140659.cap                                                          |
|98  128016    Jan/17/2018 14:29:32 N/A    cfa0:/firewall.exp              |
|99  2812      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/subthreatrep|
|ort.html        |
|100 1139      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatid.htm|
|l        |
|101 2148      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatlog.ht|
|ml        |
|102 2370      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatrank.h|
|tml        |
|103 2067      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatrankdl|
|g.html        |
|104 4122      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatreport|
|.html        |
|105 3571      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threattrend.|
|html        |
|106 2857      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/subthreatrep|
|ort.html        |
|107 1429      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatlog.ht|
|ml        |
|108 2651      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatrank.h|
|tml        |
|109 2419      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatrankdl|
|g.html        |
|110 4213      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatreport|
|.html        |
|111 2721      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threattrend.|
|html        |
|112 14068     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/nc.js          |
|113 36539     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/netconf.rbac   |
|114 19541     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/subthreatreport|
|.js        |
|115 13032     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/threatid.js    |
|116 98591     Jan/17/2018 20:10:04 N/A    cfa0:/web/threat/threatlog.js   |
|117 55749     Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threatrank.js  |
|118 37582     Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threatrankdlg.j|
|s        |
|119 31328     Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threatreport.js|
|120 133659    Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threattrend.js |
|121 106004480 Jul/24/2018 11:39:24 N/A    cfa0:/main-cmw710-system-e85|
|30.bin        |
|122 5692416   Jan/21/2019 17:29:52 M      cfa0:/main-cmw710-boot-e8524|
|p15.bin        |
|123 117685248 Jan/21/2019 17:30:12 M      cfa0:/main-cmw710-system-e85|
|24p15.bin        |
|124 7300      Jan/24/2018 08:53:08 N/A    cfa0:/0a704f6998e9602ac5203b1306|
|7b2317        |
|125 151348    Jun/05/2017 16:40:44 N/A    cfa0:/o.mdb                     |
|126 17704     Jan/31/2018 09:44:08 N/A    cfa0:/dpi.cfg                   |
|127 235207    Jan/31/2018 09:44:10 N/A    cfa0:/dpi.mdb                   |
|128 17659     Jan/31/2018 10:53:24 N/A    cfa0:/dpi1.cfg                  |
|129 231817    Jan/31/2018 10:53:26 N/A    cfa0:/dpi1.mdb                  |
|130 110592    Jan/31/2018 14:31:18 N/A    cfa0:/core/node16_dpid_202565_11|
|_20180131-143118_1517409078.core                                          |
|131 118784    Jul/24/2018 11:51:10 N/A    cfa0:/core/node16_ntopd_820_11_2|
|0180724-115110_1532433070.core                                            |
|132 118784    Dec/17/2018 08:32:20 N/A    cfa0:/core/node16_ntopd_803_11_2|
|0181217-083220_1545035540.core                                            |
|133 3249      Apr/16/2018 16:40:28 N/A    cfa0:/ngips2018041616523608292.a|
|k        |
Setting the attribute for software images
1.      Enter 2 in the File Control submenu.
|<5> Delete File                                                           |
|1   123384832 Jan/21/2019 17:20:04 N/A    cfa0:/main.ipe             |
|0   Exit        |
2.      Enter the numbers of the files you are working with. For example, enter 1.
Enter file No.:1
Modify the file attribute:
|<1>+Main        |
|<2>+Backup        |
|<0> Exit        |
Enter your choice(0-2):
3.      Enter a number in the range of 0 to 2 to add or delete a file attribute for the files. For example, enter 1 to assign the M attribute to the files.
Enter your choice(0-2):1
This operation may take several minutes. Please wait....
The file is exist,will you overwrite it? [Y/N]Y
Image file main-cmw710-boot-E8524P15.bin is self-decompressing...
Saving file cfa0:/main-cmw710-boot-E8524P15.bin ........................
Image file main-cmw710-system-E8524P15.bin is self-decompressing...
Saving file cfa0:/main-cmw710-system-E8524P15.bin ......................
Set the file attribute success!
Setting the attribute for .bin files
Enter 3 in the File Control submenu.
|1   9054208   Apr/20/2018 13:27:02 N/A    cfa0:/main-cmw710-boot-e8526|
|.bin        |
|2   186294272 Apr/20/2018 13:27:30 N/A    cfa0:/main-cmw710-system-e85|
|26.bin        |
|3   164864    Apr/20/2018 13:36:44 N/A    cfa0:/main-cmw710-devkit-e85|
|26.bin        |
|4   5684224   Jul/24/2018 11:39:04 N/A    cfa0:/main-cmw710-boot-e8530|
|.bin        |
|5   106004480 Jul/24/2018 11:39:24 N/A    cfa0:/main-cmw710-system-e85|
|30.bin        |
|6   5692416   Jan/22/2019 14:47:32 M      cfa0:/main-cmw710-boot-e8524|
|p15.bin        |
|7   117685248 Jan/22/2019 14:47:50 M      cfa0:/main-cmw710-system-e85|
|24p15.bin        |
|0   Exit        |
Note:Select .bin files. One but only one boot image and system image must
be included.
Enter file No.(Allows multiple selection):1
Enter another file No.(0-Finish choice):2
Enter another file No.(0-Finish choice):0
You have selected:
|<1>+Main        |
|<2>+Backup        |
|<0> Exit        |
Deleting a file
1.      Enter 5 in the File Control submenu.
Deleting the file in cfa0:
|0180327152412.did                                                         |
|06.did        |
|923325.ak        |
|608292.ak        |
|pack_curr.dat                                                             |
|pack_back.dat                                                             |
|ck_curr.dat                                                               |
|ck_back.dat                                                               |
|igpack_curr.dat                                                           |
|igpack_back.dat                                                           |
|pack_curr.dat                                                             |
|pack_back.dat                                                             |
|t-e8518.bin_0001                                                          |
|t-e8519.bin_0001                                                          |
|t-e8520.bin_0001                                                          |
|ogfile.log        |
|at        |
|fg        |
|db        |
|ogfile.log        |
|-server.p12                                                               |
|fg        |
|db        |
|at        |
|52  9054208   Apr/20/2018 13:27:02 M      cfa0:/main-cmw710-boot-e8526|
|.bin        |
|54  186294272 Apr/20/2018 13:27:30 M      cfa0:/main-cmw710-system-e85|
|26.bin        |
|k        |
|k        |
|26.bin        |
|.bin        |
|788002.6d9ada99                                                           |
|e15a14        |
|180117140659.cap                                                          |
|ort.html        |
|l        |
|ml        |
|tml        |
|g.html        |
|.html        |
|html        |
|ort.html        |
|ml        |
|tml        |
|g.html        |
|.html        |
|html        |
|.js        |
|s        |
|30.bin        |
|122 5692416   Jan/22/2019 14:47:32 N/A    cfa0:/main-cmw710-boot-e8524|
|p15.bin        |
|123 117685248 Jan/22/2019 14:47:50 N/A    cfa0:/main-cmw710-system-e85|
|24p15.bin        |
|7b2317        |
|k        |
|0   Exit        |
Enter file No.:
2.      Enter the number of the file to delete. For example, enter 13 to delete the sda0:/test.cfg file.
3.      When the following message appears, enter Y.
The file you selected is sda0:/test.cfg,Delete it? [Y/N]
If the following message appears, the file is successfully deleted.
Deleting.....Done!
CAUTION:
Restoring the factory-default configuration will permanently delete startup configuration files and backup configuration files in the current storage medium.
To restore the factory-default configuration from the EXTENDED-BOOTWARE menu, make sure password recovery capability is disabled. If the capability is enabled, you cannot perform the task.
After you perform this task, the device uses the factory-default configuration instead of the configuration file for the next startup.
To restore the factory-default configuration:
1.      Enter 5 in the EXTEND-BOOTWARE menu and then press Enter.
Enter your choice(0-9): 5
2.      Follow the system instruction to complete the task.
¡  If password recovery capability is enabled, first disable the capability from the CLI, and then reboot the device to access the EXTENDED-BOOTWARE menu.
Password recovery capability is enabled. To perform this operation, first disable the password recovery capability using the undo password-recovery enable command in CLI.
¡  If password recovery capability is disabled, enter Y at the prompt to complete the task.
Because the password recovery capability is disabled, this operation can cause the configuration files to be deleted, and the system will start up with factory defaults. Are you sure to continue?[Y/N]Y
Setting...Done.
To perform this task, make sure password recovery capability is enabled. If the capability is disabled, you cannot perform the task.
To start the device with the factory-default configuration:
1.      Enter 6 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 6
Flag Set Success.
¡  If password recovery capability is enabled, the device uses the factory-default configuration instead of the configuration file for the next startup.
¡  If password recovery capability is disabled, first enable the capability from the CLI, and then reboot the device to access the EXTENDED-BOOTWARE menu.
Password recovery capability is disabled. To perform this operation, first enable the password recovery capability using the password-recovery enable command in CLI.
Enter 7 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 7
Table 21 BootWare Operation submenu options
Option
Back up the entire BootWare image.
Recover the entire BootWare image.
Upgrade the BootWare image through the serial port.
Upgrade BootWare through the management Ethernet port.
To perform this task, make sure password recovery capability is enabled. If the capability is disabled, you cannot perform this task.
This is a one-time operation and takes effect only for the reboot after you perform this task.
To enable the device to load the next-startup configuration file with the console login password ignored:
1.      Enter 8 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 8
¡  If password recovery capability is enabled, the device clears the password for user privilege change.
Clear Image Password Success!
Enter 9 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9):9
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s)                   |
|<2> Set The Operating Device                                              |
|<3> Set The Default Boot Device                                           |
Enter your choice(0-3):
Table 22 DEVICE CONTROL menu options
Option
Display all storage media on the MPU you are working with.
Set the current storage medium. All file operations in BootWare menus are performed on the current storage medium.
Set the default storage medium from which the system will start up.
Press Ctrl+Z in the EXTEND-BOOTWARE menu.
==========================<EXTENDED ASSISTANT MENU>=========================
|<1> Display Memory                                                        |
|<2> Search Memory                                                         |
Table 23 EXTEND ASSISTANT submenu options
Option
<1> Display Memory
View memory information that meets certain requirements.
<2> Search Memory
Search memory for data that meets certain requirements.
CAUTION:
Formatting the file system clears all files and directories in a storage medium permanently. The cleared files and directories cannot be recovered.
Press Ctrl+F in the EXTEND-BOOTWARE menu.
Warning:All files on sda0 will be lost! Are you sure to format? [Y/N]
