WAF Signature V7-WAF-1.0.38
Release time:2025-02-22
HomeSupportSecuritySignature Database ServicesSoftware DownloadSignature Database Services
Download
Title Size Downloads
V7-WAF-1.0.38.dat 2.16 MB
Version number
V7-WAF-1.0.38
MD5 number
65092740a6988c26c45f6f29807a8f9d
Update time
2025-02-12
Update attack list
Key new rules:
49490 Backdoor.WebShell.Godzilla_TZB_Connect_Success_JSP_Chunk
---- Category: Vulnerability
---- Description:
---- Godzilla is an enhanced tool of new generation which is developed by a security researcher based on the former tools ,eg China Chopper,Cknife and China AntSword.Because its communication data is encrypted by AES,so it's difficult to detect this kind of tools.
49493 Detected_BCEL_WebShell_Upload
---- Description:
---- This rule indicates the detection of excessive use of related code functions in BCEL webshell, possibly exploiting deserialization vulnerabilities for remote loading. However, it cannot be ruled out that normal business directly transmitting code in plain text or accessing code on websites may trigger the detection conditions of this rule. Therefore, it is necessary to further investigate the legitimacy of the source and destination IP sources based on actual traffic.
49498 CVE-2024-11680_ProjectSend_Authentication_Bypass(php_webshell_upload_exploit)
---- Description:
---- ProjectSend versions prior to r1720 are affected by an improper authentication vulnerability. Remote, unauthenticated attackers can exploit this flaw by sending crafted HTTP requests to options.php, enabling unauthorized modification of the application's configuration. Successful exploitation allows attackers to create accounts, upload webshells, and embed malicious JavaScript.
49505 Detected_ScriptEngine_WebShell_Upload
---- Description:
---- This rule indicates the detection of excessive use of related code functions in ScriptEngine webshell, possibly exploiting deserialization vulnerabilities for remote loading. However, it cannot be ruled out that normal business directly transmitting code in plain text or accessing code on websites may trigger the detection conditions of this rule. Therefore, it is necessary to further investigate the legitimacy of the source and destination IP sources based on actual traffic.
