H3C SecCenter SMP
Release time:2024-10-29
HomeSupportSecurityH3C SecCenter SMPSoftware DownloadSecCenter SMP
H3C SecCenterSMP-E1704P05 Release Notes
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 1
Upgrade restrictions and guidelines· 2
Hardware feature updates· 2
Software feature updates· 2
Software feature updates in SecCenterSMP-E1704P05· 2
MIB updates· 2
Operation changes· 2
Restrictions and cautions· 3
Licensing· 3
About licensing· 3
Registering and installing licenses· 3
Open problems and workarounds· 3
List of resolved problems· 4
Resolved problems in SecCenterSMP-E1704P05· 4
Resolved problems in SecCenterSMP-E1704P04· 5
Resolved problems in SecCenterSMP-E1704P03· 6
Resolved problems in SecCenterSMP-E1704P02· 6
Resolved problems in SecCenterSMP-E1704P01· 6
Resolved problems in SecCenterSMP-E1704· 6
Troubleshooting resources· 7
Related documentation· 7
Documentation set 7
Obtaining documentation· 7
Technical support 7
Appendix A Feature list 8
Hardware features· 8
Software features· 8
Appendix B Upgrading software· 10
List of tables
Table 1 Compatibility matrix. 1
Table 2 Software features of SMP. 8
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version SecCenterSMP-E1704P04. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with the documents listed in Related documentation.
Version information
Version number
Version history
Version number
Last version
Release date
Release type
Remarks
2024/09/29
ESS
Fixed bugs.
2023/12/28
ESS
Fixed bugs.
2023/11/02
ESS
Fixed bugs.
2022/06/28
ESS
Fixed bugs.
SecCenterSMP-E1704
2022/04/22
ESS
Fixed bugs.
SecCenterSMP-E1704
SecCenterSMP-E1110P06
2021/06/29
ESS
Fixed bugs.
CAUTION:
To avoid an upgrade failure, use the following to verify the hardware and software compatibility before performing an upgrade.
Item
H3C SecCenterSMP series
Model
SecCenterSMP
Installation file
SecCenterSMP_E1704P05.iso (package for virtualized deployment)
Server version
H3Linux 1.1.1
Installation host OS
N/A
Browsers
Google Chrome 57 or higher
Ucenter
E0713
Ucenter-IOM E0711
Remarks
N/A
Only E1704P02-- E1704P04 can be upgraded to E1704P05.
SMP is a software product and contains no hardware features.
Add features
·            Firewall routing management:
·            Firewall interface management:
·            Firewall security policies support users and user groups.
·            Firewall license expiration warning:
Modified features
None.
Removed features
None.
MIB updates
N/A
Operation changes
N/A
For browsers
To get better display, use browsers Google Chrome 57 or higher.
For the operating system
Set the time zone in the operating system to Shanghai East 8 district.
For device version compatibility
·            Compatible device versions are D032 and D045.
·            Configure the device to use the local time in the log timestamp. If you configure the device to use the standard GMT, the log timestamp displayed on the SMP will be different from that on the device.
·            The system supports receiving a maximum of 10000 log messages per second from devices. Exceeding logs will be dropped.
Licensing
About licensing
H3C offers licensing options for you to deploy features and expand resource capacity on an as needed basis. To use license-based features, purchase licenses from H3C and install the licenses.
To register and transfer licenses, access H3C license services at http://www.h3c.com/en/License.
For information about registering licenses, installing activation files, and transferring licenses, see H3C SecCenter SMP Licensing Guide-5W100.
202206281627
·            Symptom: The device cannot be upgraded from the Web interface.
·            Condition: None.
·            Workaround: None. Contact Technical Support for help.
202204221172
·            Symptom: On the Web interface, some error messages contain Chinese.
·            Condition: This symptom occurs when you add an area, device group, role, or administrator with the same name as an existing one.
·            Workaround: None. This issue does not affect the functionality of the feature and will be fixed in a later version.
202204220794
·            Symptom: The System Settings > Logging page and the Log Audit pages contain Chinese.
·            Condition: This symptom occurs when you generate logs in the Chinese version and switch from the Chinese language to the English language.
202311031218
·            Symptom: On the Log Audit > Security Logs > Vulnerability Attack Log page, the Time Span text box cannot display the complete the time span. This symptom exists on all other pages under Log Audit.
·            Condition: None.
202409291244
·            Symptom: Vulnerabilities of high risk level in version E1704P05:
·            Condition: None.
202403010314
·            Symptom: In the security policy list page, some column names are in Chinese:
·            Condition: None.
202409190744
·            Symptom: Add IPS comprehensive report:
·            Condition: None.
202312190170
·            Symptom: The Alarm Events page displays no data.
·            Condition: None.
202312190158
·            Symptom: A signature library cannot updated in a NAT/VPN scenario because the file server upgrade function is unavailable.
·            Condition: This symptom occurs if you update a signature library in a NAT/VPN scenario.
202312190152
·            Symptom: No query conditions exist on the IPsec Tunnel Monitoring page.
·            Condition: None.
202312190141
·            Symptom: All existing device groups disappear after you add a device group with the same name as an existing one.
·            Condition: This symptom occurs when you add a device group with the same name as an existing one and click OK on the error message dialog box.
202312190137
·            Symptom: On the Asset Monitoring > Device Details page, the CPU usage area and memory usage area display no data.
·            Condition: None.
202312190118
·            Symptom: The associated device details contain no data.
·            Condition: This symptom occurs when you view the associated device details from O&M > Configuration Management > Deployment History.
202312190102
·            Symptom: The maximum number of source or destination IP addresses displayed in a security policy synchronized from the device is 7.
·            Condition: This symptom occurs if you synchronize a security policy with more than seven source or destination IP addresses from the device.
202312190089
·            Symptom: The system becomes abnormal after it is upgraded from E1704P03 to E1704P04.
·            Condition: This symptom occurs after you upgrade from E1704P03 to E1704P04.
202207150057
·            Symptom: Home page device log reception trend graph, description optimization.
·            Condition: View homepage.
202311030301
·            Symptom: Device monitoring optimization under network exceptions.
·            Condition: network exceptions.
202206140791
·            Symptom: Some Belt and Road Initiative countries are not available in the country list for SMP license registration.
·            Condition: This symptom occurs when you request and register the SMP license.
202205251156
·            Symptom: The H3Linux interface displays information in Chinese when you install the English version SMP system by using an ISO file.
·            Condition: This symptom occurs when you install English version SMP system by using an ISO file.
202106290415
·            Symptom: For initial import of licenses to the platform, if the licenses imported include the hierarchical management license, the number of the hierarchical management license generated in the platform is greater than 1, and the license cannot be activated. For additional import of licenses to the platform, if the licenses imported include the hierarchical management license, the platform prompts that you should import the correct license.
·            Condition: None.
202106281458
·            Symptom: The cumulative number of licenses in the SMP platform is incorrect. It records only one Additional 1 Node License.
·            Condition: None.
To obtain troubleshooting resources for the product:
1.      Access Technical Documents at http://www.h3c.com/en/Technical_Documents.
2.      Select the device category and model.
3.      Select the Maintain or Maintenance menu.
Documentation set
·            H3C SecCenter SMP Web Configuration Guides(E1704)-5W100
·            H3C SecCenter SMP Configuration Examples (E1704)-5W100
·            H3C SecCenter SMP FAQ(E1704)-5W100
·            H3C SecCenter SMP Troubleshooting Guide(E1704)-5W100
To obtain related documents from the H3C website at
https://www.h3c.com/en/Support/Resource_Center/Technical_Documents/
Technical support
To obtain technical assistance, contact H3C by using one of the following methods:
·            Email:
[email protected] (countries and regions except Hong Kong, China)
[email protected] (Hong Kong, China)
·            Technical support hotline number. To obtain your local technical support hotline number, go to the H3C Service Hotlines website: https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
To access documentation, go to the H3C website at http://www.h3c.com/en/.
Hardware features
Software features
Categories
Features
Dashboard
CPU Usage
Memory Usage
Session Trend
IPS Attack Destination IPs
IPS Attack Source and Destination IPs
IPS Blocked Events
Attack Trend Chart
Device Log Receiving Trend Chart
Alarm Events
Alarm Events
Alarm Rules
Alarm Notification Policies
Alarm Notification Records
Log Audit
Virus Attack Log
NAT Session Log
NAT444 Port Block Log
NAT444 Session Log
Application Audit Logs
Security Analysis
Security Event Analysis
Reports
Report Files
Report Tasks
Report Templates
O&M
Areas
Device Groups
Monitored Assets
Security Services
Signature Libraries
System Settings
Global Settings
System Monitoring
Roles & Privileges
Logging
Customization
System Info
Licenses
Hierarchy
For how to perform an upgrade, contact Technical Support.
