H3C SecPath F100-C-A2_F100-C-A1 Series
Release time:2024-10-09
HomeSupportSecurityH3C SecPath F100-C-A FirewallSoftware DownloadF100-C-A
H3C SECPATHF100CSEA_WINET-CMW710-R9900P19
Release Notes
Introduction· 1
Version information· 1
Version number 1
Version history· 1
Hardware and software compatibility matrix· 2
Upgrade restrictions and guidelines· 4
Hardware feature updates· 4
Software feature and command updates· 4
MIB updates· 4
Operation changes· 5
Restrictions and cautions· 6
Restrictions· 6
Cautions· 6
License management 7
About licenses· 7
License application and installation· 7
Open problems and workarounds· 8
List of resolved problems· 8
Resolved problems in R9900P19· 8
Resolved problems in F9900P130101· 9
Resolved problems in R8590P14· 9
Resolved problems in R8560P39· 10
Resolved problems in R8560P38· 10
Resolved problems in R8560P36· 10
Resolved problems in R8560P32· 10
Resolved problems in E8460P2903· 10
Resolved problems in E8460P29· 11
Resolved problems in E8460P27· 12
Resolved problems in A8460P26· 12
Resolved problems in A8460P25· 13
Resolved problems in A8460P2301· 14
Related documentation· 14
Technical support 14
Appendix A Feature list 15
Hardware features· 15
Software features· 15
Appendix B List of severe vulnerabilities· 18
Severe vulnerabilities in F9900P130101 and earlier versions· 18
Appendix C Upgrading software· 20
Software images· 20
Software images types· 20
Software release forms· 20
Configuration files· 21
Upgrade methods· 21
Preparing for the upgrade· 21
Upgrading system software· 22
Upgrading system software from the Web interface· 22
Upgrading system software from the CLI 25
Upgrading system software from BootWare menus· 32
Upgrading the BootWare· 36
Upgrading the BootWare from the CLI 36
Upgrading BootWare from BootWare menus· 36
Handling software upgrade failures· 40
Appendix D Using BootWare menus· 40
Overview· 40
BootWare menus· 40
BootWare shortcut keys· 41
Using the BASIC-BOOTWARE menu· 42
Accessing the BASIC-BOOTWARE menu· 42
Modifying serial port parameters· 42
Upgrading the extended BootWare segment 43
Upgrading the entire BootWare· 43
Running the primary extended BootWare segment 43
Running the backup extended BootWare segment 44
Accessing the BASIC ASSISTANT menu· 44
Testing the memory· 44
Using the EXTENDED-BOOTWARE menu· 45
Accessing the EXTENDED-BOOTWARE menu· 45
Controlling the password recovery capability· 47
Running Comware images· 47
Accessing the Serial submenu· 48
Accessing the Ethernet submenu· 49
Managing files· 50
Restoring the factory-default configuration· 61
Skipping the configuration file· 62
Accessing the BootWare Operation submenu· 62
Skipping console login authentication· 63
Managing storage media· 63
Accessing the EXTEND ASSISTANT submenu· 63
Formatting the file system·· 64
List of tables
Table 1 Version history............................................................... 1
Table 2 Hardware and software compatibility matrix.................. 2
Table 3 MIB updates................................................................... 4
Table 4 Hardware specifications............................................... 15
Table 5 Firewall software features............................................ 15
Table 6 Default login information............................................. 22
Table 9 BootWare menus.......................................................... 41
Table 10 BootWare shortcut keys.............................................. 41
Table 12 BASIC ASSISTANT menu options............................ 44
Table 14 Serial submenu options.............................................. 48
Table 17 File Control submenu options..................................... 51
Table 18 BootWare Operation submenu options....................... 62
Table 19 DEVICE CONTROL menu options............................ 63
Table 20 EXTEND ASSISTANT submenu options................... 64
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version R9900O19. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with H3C SECPATHF100C_SECPATHF100C_WINET-CMW710- R9900O19 Release Notes (Software Feature Changes) and the documents listed in "Related documentation."
Version information
Version number
Comware software, Version 7.1.064, Release 9900P19
Note: You can see the version number with the display version command in any view.
Version history
Version number
Last version
Release date
Release type
Remarks
R990019
F9900P130101
2024-09-29
Feature
Release for the overseas market.
Fixed bugs and released for production and technical support.
F9900P130101
R8590P14
2024-06-28
Feature
Restricted release for use by Technical support.
R8590P14
R8560P41
2024-01-31
Release
Fixed bugs.
Released for technical support.
R8560P41
R8560P38
2023-09-25
Release
R8560P38
R8560P36
2023-08-31
Release
F100-C-A1/F100-C-A2/F100-C-G5-SI for Japan,Released for production and technical support.
R8560P36
R8560P32
2023-07-12
Release
F100-C-A1/F100-C-A2 for Japan,Released for production and technical support.
R8560P32
E8460P2903
2023-02-28
Release
TR6 version.
E8860P2903
E8460P29
2022-12-22
ESS
TR5 version for F1003-L-S and F1003-M.
E8460P29
E8460P27
2022-11-17
ESS
TR4A version for F1003-L-S and F1003-M.
E8460P27
A8460P26
2022-08-29
ESS
TR5 version for F100-C-A1 and F100-C-A2.
TR4A version for F1003-L-S.
A8460P26
A8460P25
2022-07-29
Alpha
Fixed bugs, added part numbers for F100-C-A1 and F100-C-A2 for overseas sales, and released for trial production.
A8460P25
A8460P2301
2022-06-29
Alpha
Fixed bugs and released for trial production.
A8460P2301
N/A
2022-05-13
Alpha
TR4A version.
Released for trial production.
CAUTION:
To avoid an upgrade failure, use Table 2 to verify the hardware and software compatibility before performing an upgrade.
Item
Specifications
Hardware platform
F100-C-A1 (overseas version + Japan special version)/F100-C-A2 (overseas version + Japan special version)
Memory
2 GB
Nand Flash (stores the IPE file)
512 MB
Boot ROM version
1.04 (Note: Execute the display version command in any view to view the version information.)
Host software (MD5 checksum)
SvpnClient.exe:618a3a4caa354e6e8f21ce7c7f6a71f2;
SECPATHF100CSEA_WiNet-CMW710-R9900P19.ipe: 7db4ccb6d9c3535afc2ff3872078cda7
f100Cfw-sea-cmw710-boot-R9900P19.bin:
6ee45b41cd135afffe3dfb76ab5aea3e
f100Cfw-sea-cmw710-system-R9900P19.bin: 8fc111b46927fc1573f1051fbd54689b
iMC version
iMC PLAT 7.3 (E0705P12)
iMC PLAT(ACLM) 7.3 (E0705P12)
iMC PLAT(DM) 7.3 (E0705P12 )
iMC PLAT(ICC) 7.3 (E0705P12)
iMC PLAT(VLAN)(E0705P12)
iMC UBA 7.3 (E0707L06)
iMC IVM 7.3 (E0506)
iMC EIA 7.3 (E0611P13)
iMC SHM 7.3 (E0707L06)
iNode PC 7.3(E0585)
H3C SecCenter CSAP-S version
E1143P0601
H3C SecCenter SMP version
E1112P02
H3C SecCloud OMP version
E1301P01
U-Center
Not support
AD-NET
E0709
U-Center AOM
E0706P01
AD-Campus
Not support
ADDC
Not support
AD-WAN
Not support
CloudNet
OASIS V100R001
Remarks
1.       The time on the iMC server must be consistent with the time on the device.
2.       As a best practice, do not use the wildcard subnet address type when you configure address groups on the device management page of security services on iMC.
3.       Enable action parameters before you configure them on the device management page of security services on iMC.
4.       The iNode version is not packaged in the IPE file and needs to be downloaded from the official website.
Sample: To display the host software and BootWare version of F100-A-XI, execute the following command:
<H3C> display  version
H3C Comware Software, Version 7.1.064, Release 9900P19
Copyright (c) 2004-2024 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath F100 uptime is 0 weeks, 0 days, 0 hours, 19 minutes
Last reboot reason: User rebootBoot
image: flash:/f100Cxiaobeifw-cmw710-boot-R9900P19.bin
Boot image version: 7.1.064, Release 9900P19
Compiled Sep 19 2024 15:00:00
System image: flash:/f100Cxiaobeifw-cmw710-system-R9900P19.bin
System image version: 7.1.064, Release 9900P19
SLOT 1
CPU type: Single-core CPU
DDR4 SDRAM Memory        : 2004 MB
Board PCB        Version : Ver.A
Basic  BootWare  Version :  1.04
Extend BootWare  Version :  1.04 (Hardware)Ver.A, (Driver)1.0
·           ISSU is not supported because the flash memory does not have sufficient space.
·           To ensure hardware compatibility, do not downgrade the factory software version.
·           The BootWare version is packaged into the IPE file. When the device reboots, it compares the current BootWare version with that in the IPE file. If the BootWare version in the IPE file is higher, the device automatically upgrades with the BootWare version in the IPE file.
·           When you manually upgrade the AV/URL signature database, follow these restrictions and guidelines: For the signature databases for anti-virus and URL filtering, the official website provides two sizes for different device storage spaces. The letter H in the name indicates a large signature database. For example, V7-AV-H-1.0.68.dat is a large signature database and V7-AV-1.0.68.dat is a small one. When you perform a manual upgrade, examine your device storage capacity to determine which signature database should be downloaded. The large signature databases are supported when the memory is larger than 8 GB, and the capacity of the storage medium (flash memory, SD card, or CF card) is larger than 1 GB. Otherwise, only the small signature databases are supported.
None
This version has the following feature changes:
·           Modified feature:Firewall feature library updates using https
·           New feature: DPI - Application Layer Detection Engine (Parameters used by DPI Business Proxy Server (New))
·           New feature: DPI - Application Layer Detection Engine (Configure Application Layer Detection Engine Unpacking Parameters)
For information about the software feature and command update history, see the H3C SECPATHF100C_SECPATHF100C_WINET-CMW710- R9900P19 Release Notes (Software Feature Changes).
MIB updates
Table 3 MIB updates
Item
MIB file
Module
R9900P19
New
None
None
None
Modified
None
None
None
F9900P130101
New
None
None
None
Modified
None
None
None
R8590P14
New
None
None
None
Modified
None
None
None
R8560P39
None
None
None
None
None
None
R8560P38
New
None
None
None
Modified
None
None
None
R8560P36
None
None
None
None
None
None
R8560P32
None
None
None
None
None
None
E8460P2903
New
None
None
None
Modified
None
None
None
E8460P29
New
None
None
None
Modified
None
None
None
A8460P26
New
None
None
None
Modified
None
None
None
A8460P25
New
None
None
None
Modified
None
None
None
A8460P2301
New
None
None
None
Modified
None
None
None
Operation changes
None.
Before performing an upgrade, see H3C SECPATHF100CSEA-CMW710- F9900P19 Release Notes (Software Feature Changes) and related documentation to see the software feature changes and evaluate the influence on the service.
To avoid abnormality and configuration failure, follow these restrictions:
Restrictions
·           The equipment does not support stacking, custom Context, VSYS, server load balancing.
·           For the same feature module, command line and web configuration cannot be used at the same time.
·           After ISSU upgrade, when there are differences in feature modules between two versions, the browser cache needs to be cleared for the web to display configuration information correctly.
·           The MAC addresses of the main interface and sub-interface need to be consistent.
·           Cloud management is not supported after the device is simplified.
Cautions
·           The browser supports Chrome 40 and above, Firefox 19 and above, Internet Explorer 10 and above.
·           Please ensure that the encoding format of CLI is GB18030, otherwise the web page display will appear garbled.
·           When accessing WeChat, Alipay, hao123 and other pages via SSL VPN Web access, some content is not URL rewritten, resulting in login or page display failure.
·           After solving the vulnerability issue caused by insufficient password algorithm strength, the earlier version of the INODE client (default using TLS 1.0 negotiation) cannot successfully log in to the SSL VPN gateway, and the new E0582 version or later of the INode client is required.
·           When using INode (E0568) to connect to the SSL VPN gateway, there is a memory leak in the TCP_proxy and SSLVPN related processes, so an upgrade to iNode (E0574) is needed.
·           The device does not support stacking.
·           From A8460P2301, global NAT is supported, but currently does not support VPN and dns-mapping; only supports new opening, does not support replacement interface NAT.
·           Because global NAT can only determine the safe domain based on the FIB table, when matching traffic forwarded by PBR or llb using global NAT for address translation, the out-of-domain cannot be used as a matching item, otherwise the global NAT rule cannot be hit or business interruption may occur when there is an appchange/configuration change.
·           Starting from A8460P2301, the mail server address on the report subscription page supports IP address or hostname.
·           RBM running backup cannot handle SSL VPN dial-up traffic.
·           Starting from version A8460P2301, AFT supports session backup function, but does not support:
·           Dynamic port block hot standby function
·           Static port block function
·           Output carrier logs, including port block allocation, recovery, and alarm types.
·           If the mail protocol of the operating system (such as IMAP/POP/SMTP protocol) and the corresponding format is non-MIME format (except for Uuencode format), then DPI does not support this format of processing.
·           Zombie network analysis can only read data in the trust-untrust domain.
·           When RBM uses track interface, it does not support joint configuration with other RBM linkage modules, such as track vlan, vrrp, track id, adjust cost.
·           SSL VPN does not support RBM dual master scenario.
·           If the device is in a stacking network environment and the following configuration is performed after the abnormal restart of the SSLVPN main process on-site, it will cause the business to be unavailable:
¡  When configuring multiple resource groups in the SSLVPN access instance, the resource group name is not configured in dictionary order, but in any order;
¡  If the main SSLVPN process of the stack restarts abnormally, and the stack backup device is not restarted, SSLVPN users log in from the stack backup device through iNode.
·           The above problems can be avoided by taking the following measures:
¡  When configuring multiple resource groups in the SSLVPN access instance, the resource group names need to be configured in dictionary order;
¡  If the main SSLVPN process of the stack restarts abnormally, the stack backup device needs to be restarted to avoid subsequent main and backup switching, or SSLVPN users log in via iNo if the mail protocol of the operating system (such as IMAP/POP/SMTP protocol) and the corresponding format is non-MIME format (except Uuencode format), then DPI does not support this format of processing.
·           Virtual addresses are only supported in RBM scenarios (reason: in non-RBM scenarios, IPv4 virtual addresses are inactive, and IPv6 virtual addresses are in tentative state, and cannot be used.), and the device-role of the 2 RBM devices needs to be configured as auto (reason: the management master does not switch with the running master, and the configuration issued through the virtual address interface cannot be made active.)
·           The undo cfg-change log enable command does not take effect on some configuration logs (such as security policy, blacklist configuration logs).
·           In the environment of router + firewall + switch + AP, when the DHCP server leaves the network, the security device is not aware, and the DHCP server does not switch to the new TM device in time.
·           The firewall self-networking online defaults to transparent mode and does not need to be manually configured. If the transparent mode is manually enabled according to the web page prompts, it will cause conflicts in the security domain and security policy configuration, and the devices behind the firewall will be offline, with traffic only passing in one direction.
License management
About licenses
To use license-based features, you must purchase licenses from H3C and install the licenses.
For license-based features, see H3C SecPath F100 Firewall Series License Matrixes.
H3C allows you to register, install, or transfer a license at the following URL: http://www.h3c.com/en/License/
For more information about license registrtion, installation, and transfer, see H3C Security Products Licensing Configuration Demonstration Video(Comware 7), H3C Security Products Licensing Configuration Demonstration (Comware 7), H3C Security Products Licensing Configuration Examples (Comware 7), and H3C Security Products Licensing Guide(Comware V7).
For license-related FAQs, see H3C Security Products Licensing FAQ (Comware 7).
202302201881
·           Symptom: One minute after the secondary RBM device is switched to the primary role, the device reboots because of deadloop.
·           Condition: This symptom occurs if the connection limit policy references an ACL with multiple rules (for example, 500 rules) and RBM primary/secondary switchover is performed when traffic is being forwarded on an RBM+VRRP active/standby network.
·           Workaround: Configure acceleration for the ACL.
202407180457
• Symptom: Non-issue, new requirement, finally implemented as follows:
Model
BOM
Embedded Domain Name
F100-C-XI
9801A2TT
Domain Name:uclouddev.h3c.com,Port:19443
F100-S-XI
9801A2TX
F100-A-XI
9801A4KP
F1000-E-XI
0235A3AL
F1000-D-XI
0235A50S
F100-C-A1
9801A41X
Domain Name:cloudnet.h3c.com,Port:19443
F100-C-A2
9801A41U
F100-C-A1
9801A5KY
F100-C-A2
9801A5L1
Except for the above-mentioned types(overseas version + Japan special version)
Domain Name:secnet.h3c.com,Port:19443
·           Condition:Please distinguish between domestic Xiaobei safety products, overseas version cloud-based Jian models, and embedded domain names of domestic and foreign non-Xiaobei safety products.
202406121439
·           Symptom:Upgrade failure.
·           Condition:UWEB--firewall online upgrade.
202405280481
·           Symptom:Unable to quickly perform address reallocation, devices need to increase DHCP detection mechanism.
·           Condition: Slow DHCPC address aging time.
202404111993
·           Symptom:Security domain & security policy configuration lost.
·           Condition:Firewall device reset to factory settings after startup.
202405081184
·           Condition: Firewall device reset to factory settings after startup.
202405081179
·           Symptom:Restart failure.
·           Condition: Select "Device list->Select firewall->Restart".
202406170201
·           Symptom:NAT address management not issued.
·           Condition: After device restart.
202405280529
·           Symptom:Automatically save every 1 minute, should not automatically save when there is no configuration change.
·           Condition: No configuration change in firewall.
202404171681
·           Symptom:There is no prohibition on changing the device password in the local web of the device, it should be changed to prohibit changing the device password in the local Web of the device.
·           Condition:After self-organizing network startup.
202303281904
·           Symptom:The device resatarts.
·           Condition: The device transmits special and improper mime meassage.
202208101422
·           Symptom: The efault action in the domain name library and URL reputation library does not take effect after the libraries are loaded onto the device.
·           Condition: This symptom occurs if the default action is block.
None.
202101071262
·           Symptom: The system is in the deadloop, and the usage of CPU is high.
·           Condition: After the user of IPoE is online or offline in IRF,the main and backup exchange.
202211290204
·           Symptom: The device reboots unexpectedly.
·           Condition: This symptom occurs if the following operations are performed:
a.     A user repeatedly logs in to and exits a context or configures 10K EVPN instances and 1K static tunnels.
b.    BGP EVPN neighbors are configured to generate dynamic tunnels, and the dynamic tunnels are associated with 10K VXLANs.
202203010326
·           Symptom: During the running process, a device reboots unexpectedly due to CPU chip bugs.
·           Condition: This symptom occurs if the devices form an IRF fabric and the CPUs of the devices are Cavium Octeon III.
202211151880
·           Symptom: When an object group is deleted on a device, the CLI gets stuck.
·           Condition: This symptom occurs if an address object group is configured on the device and the address object group is referenced in an ACL.
202209050806
·           Symptom: The ntop process exits when the device reboots with a USB disk.
·           Condition: This symptom occurs if the device reboots with a USB disk.
202210271302
·           Symptom: The system prompts that the request is abnormal.
·           Condition: This symptom occurs if the device is connected to the cloud platform, and you click configuration management.
202108160775
·           Symptom: Source NAT is performed on IPsec traffic by default.
·           Condition: None.
202203011175
·           Symptom: The modification to a security policy cannot take effect.
·           Condition: This symptom occurs if you reference an object group containing a large number of domain names in the security policy and configure a DNS server.
202201171756
·           Symptom: The value of the hh3cCfgRunModifiedLast node is modified when no configuration change is performed.
·           Condition: This symptom occurs if you reference a time range in a security policy.
202203160772
·           Symptom: The BGP process is abnormal.
a.     Execute a script containing a large amount of EVPN remote host configuration.
b.    Perform a configuration rollback.
c.     Configure BGP.
202203160577
·           Symptom: On an IRF fabric, the device reboots after a configuration rollback is performed.
a.     Perform a configuration recovery.
b.    Perform a master/subordinate switchover.
c.     Perform a configuration rollback.
202112300922
·           Symptom: The packets on an interface are not processed by IPsec as expected.
·           Condition: This symptom occurs if the default of the ipsec no-nat-process enable command is used, and the ACL configured for NAT is not specific.
202206200415
·           Symptom: The configuration fails to be saved because the flash memory is write protected.
·           Condition: This symptom might occur after the device runs for  a long period of time.
202011020397
·           Symptom: The file filtering logs are updated slowly.
·           Condition: This symptom occurs when traffic matches a file filtering rule.
202112091675
·           Symptom: The device reboots when it receives the last ACK after a TCP connection is successfully established.
·           Condition: This symptom occurs if the window size of the last ACK is 0.
202111120744
·           Symptom: The Create SSL VPN Context page does not include the Associate with hot backup field.
·           Condition: This symptom occurs when you access the Create SSL VPN Context page.
202107220906
·           Symptom: Memory leaks occur.
·           Condition: This symptom occurs if you enable auto refresh and real-time traffic data collection for the Real-time user ranking and Real-time application ranking widgets from the Web interface.
202107151060
·           Symptom: Memory leaks occur for ntopd.
·           Condition: This symptom occurs if log aggregation is enabled from the Web interface and the device receives traffic.
202209200242
·           Symptom: The forwarding delay of traffic is long.
·           Condition: This symptom might occur if a large amount of traffic is present and the forwarding core is burdened.
202203291075
·           Symptom: An anti-virus policy cannot identify the matching packets.
·           Condition: This symptom occurs if the anti-virus policy is configured with the medium severity level.
202203080753
·           Symptom: The device operates incorrectly after security policy logging is enabled.
·           Condition: This symptom occurs if you enable security policy logging.
202208020581
·           Symptom: Interface fail to forward traffic after the device starts up.
·           Condition: This symptom occurs if you power cycle the device repeatedly.
202208100406
·           Symptom: SMS authentication with the SSL VPN gateway fails due to communication timeout between the iNode client and SSL VPN gateway.
·           Condition: This symptom occurs because the connection timeout time (30 seconds) of the gateway is greater than the wait time (10 seconds) of the iNode client.
202203080753
·           Symptom: The device cannot work correctly after security policy logging is enabled.
·           Condition: This symptom occurs after you enable security policy logging.
202206161431
·           Symptom: The System Logs section is loaded slowly.
·           Condition: This symptom occurs when you access the Dashboard page.
202203011175
a.     Configure a large number of domain names in an object group.
b.    Reference the object group in the security policy, and configure a DNS server.
c.     Modify the security policy.
d.    Workaround: Use the object-group dns-aging command to enable aging of DNS-resolved IP addresses from host names.
202207051665
·           Symptom: The System > Upgrade Center > Signature Upgrade page is loaded slowly and does not display the signature version information.
·           Condition: This symptom occurs after auto signature upgrade is performed.
202203311440
·           Symptom: On the Modify Interface Settings page, the link mode fails to be modified.
·           Condition: This symptom occurs when you modify the link mode on the Modify Interface Settings page.
202206281707
·           Symptom: In an RBM network, it takes 10 seconds for the backup device to become the master after the original master is powered off.
·           Condition: This symptom occurs if you  power off the master device in an RBM network.
202206230647
·           Symptom: The device reports that the bjpd process is always in the starting state and it takes more than 40 minutes to start.
·           Condition: This symptom occurs if a large number of inter-zone policies exist on the device, the whole device is rebooted to upgrade the software, and the contexts are restored by using a .txt configuration file.
202205310884
·           Symptom: Address 1.1.1.1 newly added to the address object group of the fuzzy domain name might not be deployed to the kernel.
·           Condition: This symptom occurs if the newly added address is lower than the existing address in the current address object group of the fuzzy domain name (for example, the translated address is 2.2.2.2, and the newly added address is 1.1.1.1).
202205201435
·           Symptom: On the original backup host, the VRRP state is correct, and the RBM state is master. However, both the VRRP state and RBM state might be backup on the original master device.
·           Condition: This symptom occurs if the backup host is restarted and then the master host is immediately rebooted in the VRRP+RBM dual-master environment.
None. First release.
·           H3C SecPath F100-C-A Firewall Series Installation Guide
·           H3C SecPath F100-C-A Firewall Series Installation Quick Start
·           H3C SecPath Firewall Command References(V7)
·           H3C SecPath Firewall Configuration Guides(V7)
·           H3C Firewall Products Comware 7 Web Configuration Guide
·           H3C Security Products Comware 7 System Log Messages Reference
Technical support
[email protected]
Hardware features
Item
Specifications
Dimensions (H × W × D)
F100-C-A1 (overseas version + Japan special version):  44× 266 × 161 mm (1.73 × 10.47 × 6.34 in)
F100-C-A2 (overseas version + Japan special version): 44 × 330 × 230 mm (1.73 × 12.99 × 9.06 in)
Weight (fully configured)
F100-C-A1 (overseas version + Japan special version):  1 kg (2.20 lb)
F100-C-A2 (overseas version + Japan special version): 1.6 kg (3.53 lb)
Ports
F100-C-A1(overseas version + Japan special version):
·         5 GE copper ports (inlcuding one management port)
·         2 SFP+ ports
·         1 console port
·         1 USB 2.0 port
·         10 GE copper ports (inlcuding one management port)
·         2 SFP+ ports
·         1 console port
·         1 USB 2.0 port
Expansion slots
None.
Hard disk slots
None.
Memory
2 GB DDR4 SDRAM
NOR flash
512 MB
Power supply
< 36 W
Operating temperature
·         Operating: 0°C to 45°C (32°F to 113°F)
·         Storage: –40°C to 70°C (–40°F to 158°F)
Relative humidity
5% RH to 95% RH, noncondensing
Software features
Category
Features
AAA
RADIUS/HWTACACS+ authentication.
CHAP authentication.
PAP authentication.
Domain authentication.
Firewall
Packet filtering.
Security zone-based access control.
Time-based access control.
ASPF.
Control of ICMP redirection and destination unreachable messages.
Tracert message control.
Control of IP packets with the RR option.
Security management
Real-time attack protection logs.
Blacklist logs.
Session logs.
Binary logs.
Traffic statistic collection and analysis.
Security event statistics.
NAT
NAT support for address pools.
Easy IP.
NAT server.
Effective period of NAT.
NAT ALGs, including FTP, DNS, QQ, MSN, H323, NBT, ILS, RTSP, SQLNET, SIP, RSH, and MGCP.
NAT444.
Application recognition
APR signature library.
PBAR.
NBAR.
Application group.
Bandwidth management
Traffic profile.
Traffic policy
Interface bandwidth limit.
Reports and logs.
IPS
IPS policy.
IPS working mode.
IPS signature.
IPS signature action.
Reports and logs.
IPSec/IKE
AH and ESP.
Manual SA setup and IKE SA setup.
ESP support for DES, 3DES, and AES encryption algorithms.
Support for MD5 and SHA-1 authentication algorithms.
Support for IKE main mode and aggressive mode.
DPD.
NAT traversal.
L2TP
L2TP.
GRE
GRE tunnel.
SSL VPN
IP access.
TCP access.
Smart terminal access.
User authentication.
LAN
Ethernet_II.
VLAN.
IP services
ARP.
Static domain name resolution.
IP address borrowing.
DHCP relay.
DHCP server.
DHCP client.
IP routing
Static route management.
RIP-1/RIP-2.
OSPF.
BGP.
Routing policy.
PBR.
Basic IPv6 protocols.
Protocol processing.
Ethernet link layer.
ICMPv6.
IPv6 address management.
PMTU.
Socket.
TCP6.
UDP6.
RAWIP6.
Ping6.
DNS6.
Tracert6.
Telnet6.
FIB6.
DHCPv6 client.
DHCPv6 relay.
IPv6 routing and multicast
RIPng.
OSPFv3.
BGP4+.
Static routes.
PBR.
PIM-SM.
PIM-DM.
IPv6 security
NAT-PT.
IPv6 packet filtering.
RADIUS.
VRRP
VRRP.
CLI
Local configuration through a console port.
Local or remote configuration through Telnet or SSH.
Control of user access to commands.
Debugging.
Network diagnostic tools, including tracert and ping.
Telnetting from the device to other devices.
FTP server/client, and file and application upload and download.
TFTP file transmission.
Logging.
File system management.
User line configuration.
Network management
Support for SNMPv3 and compatibility with SNMPv2C and SNMPv1.
NTP time synchronization.
CVE-2017-3735
An attacker can exploit this vulnerability to bypass security protections and execute unauthorized operations.
CVE-2019-3855
An integer overflow flaw which could lead to an out of bounds write was discovered in libssh2 in the way packets are read from the server. libssh2 is a client-side C library implementing the SSH2 protocol. A remote attacker who compromises an SSH server may be able to execute code on the client system when a user connects to the server.
HSVD-201904-001
A TCP/IP SYN + FIN packet filtering vulnerability. A remote host does not discard TCP SYN packets with the FIN flag set. An attacker might bypass the firewall, depending on the type of firewall used.
HSVD-201902-001
A remote host can exploit the TCP timestamp vulnerability to obtain the online time.
[HSVD-201901-016] CVE-2019-0548
A Linux kernel vulnerability that can cause information revealing.
JavaScript library vulnerability
Internal IP addresses in destination URLs might be revealed.
CVE-2020-10188
utility.c in telnetd in netkit telnet through 0.17 allows remote attackers to execute arbitrary code via short writes or urgent data, because of a buffer overflow involving the netclear and nextitem functions.
Web JavaScript vulnerability
A medium-risk vulnerability found during Web vulnerability scanning.
Web CSRF vulnerability
A CSRF vulnerability was found on the SSL VPN Web login interface.
HTTP method vulnerability
An attacker can use the OPTIONS method to determine the HTTP methods allowed by each directory.
CRLF injection vulnerability
This vulnerability can be exploited when an HTTP request contains a user-configured domain in the cookies or the request is GET /enterdomain.cgi?domain=%0d%0aSomeCustomInjectedHeader:%0d%0aset-cookie:iamyy HTTP1/1.
CVE-2019-1547
An attacker can exploit this vulnerability to obtain sensitive information.
CVE-2019-1563
An attacker, after sending a very large number of messages to be decrypted, can recover a CMS/PKCS7 transported encryption key or decrypt any RSA encrypted message that was encrypted with the public RSA key.
CVE-2016-7056
A malicious user with local access can exploit this vulnerability to recover Elliptic Curve Digital Signature Algorithm (ECDSA) P-256 private keys. This vulnerability is due to incorrect setting of the BN_FLG_CONSTTIME identifier by the ecdsa_sign_setup() function in the crypto/ec/ecdsa_ossl.c file.
CVE-2018-0739
Constructed ASN.1 types with a recursive definition (such as can be found in PKCS7) could eventually exceed the stack given malicious input with excessive recursion. This could result in a DoS attack.
CVE-2019-1559
An attacker can exploit this vulnerability to bypass access controls and obtain sensitive information.
CVE-2018-0737
An attacker with sufficient access to mount cache timing attacks during the RSA key generation process could recover the private key.
CVE-2018-0732
An attacker can exploit this vulnerability to launch a DoS attack.
CVE-2019-1552
This vulnerability is related to OpenSSL. An attacker can exploit this vulnerability to bypass security controls.
CVE-2018-5407
This vulnerability is related to OpenSSL. An attacker can exploit this vulnerability to obtain sensitive information and launch more attacks.
X-Frame-Options vulnerability
The absence of the X-Frame-Options header in HTTP packets can cause a clickjacking attack.
CVE-2011-1473
SSL in the kernel does not process the field for disabling SSL renegotiation. As a result, an SSL client can renegotiate successfully.
CVE-2021-23841/CVE-2021-23840/CVE-2020-1971
This vulnerability is related to OpenSSL. The X.509 GeneralName type is a generic type for representing different types of names. One of those name types is known as EDIPartyName. OpenSSL provides a function GENERAL_NAME_cmp that compares different instances of a GENERAL_NAME to see if they are equal or not. This function behaves incorrectly and NULL pointer dereference might occur when both GENERAL_NAMEs contain an EDIPARTYNAME.
CAUTION:
Do not power off or reboot the device during the upgrade process.
The software upgrade procedure is the same for all security devices. This chapter describes how to upgrade software from the CLI, Web interface, and BootWare menus. The default storage medium varies by device model. This chapter uses the CF card as the default storage medium.
Software images
The following software types are available:
·           BootWare image—A .btw file that contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. You can use these menus to load software and the startup configuration file or manage files when the device cannot start up correctly.
·           System software image—Includes the following image subcategories:
¡  Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
¡  System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
¡  Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
You can assign the following attributes to a system software image:
¡  Main—The image is the primary image. The system always attempts to load the main image at startup in preference to the backup image.
¡  Backup—The image is the backup image. It is used only if the primary image is corrupt or not available.
Software images are released in one of the following forms:
·           Separate .bin files. You must verify compatibility between software images.
·           As a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Configuration files
You can save settings you made to a configuration file so they can survive a reboot.
The device supports .cfg configuration files. The default .cfg configuration file is named startup.cfg.
Upgrade methods
To upgrade system software, use one of the following methods:
·           Upgrading system software from the Web interface
·           Upgrading system software from the CLI
·           Upgrading system software from BootWare menus
To upgrade the BootWare, use either of the following methods:
·           Upgrading the BootWare from the CLI
·           Upgrading BootWare from BootWare menus
You must reboot the device after a system software or BootWare upgrade. A device reboot interrupts services.
Before a software upgrade, read the release notes to identify the command changes. Some commands in the configuration file might not be supported after a software upgrade.
The device can function as the TFTP client, FTP client, or FTP server. In the following examples that use TFTP or FTP, the device functions as the TFTP or FTP client.
To use a PC as the TFTP or FTP server, prepare the TFTP or FTP server software by yourself. The device is not shipped with the software.
Before you upgrade system software, complete the following tasks:
·           Set up the upgrade environment as shown in Figure 1. The IP address and subnet mask of the PC are 192.168.0.2 and 255.255.255.0, respectively.
·           Run a TFTP or FTP server on the file server. (Skip this task if you upgrade software from the Web interface.)
·           Assign an IP address to the file server. Make sure the management Ethernet port on the device and the file server can reach each other.
By default, the IP address of the management Ethernet port GigabitEthernet 1/0/0 is 192.168.0.1/24 and the management Ethernet port belongs to the Management security zone. The Management security zone and the Local security zone can communicate with each other.
You can also change the IP address of the management Ethernet port from its default and add it to a security zone other than Management. Then, you configure a zone pair to make sure the security zone and the Local security zone can communicate with each other. For more information about security zones and zone pairs, see the security zone configuration in the fundamentals configuration guide.
·           Transfer the software upgrade file to the file server and set the working directory on the TFTP or FTP server.
·           Log in to the CLI of the device through the console port. (Skip this task if you upgrade software from the Web interface.)
·           Make sure the upgrade has minimal impact on the network services. During the upgrade, the device cannot provide any services.
Figure 1 Setting up the upgrade environment
The startup files used in this example are for illustration only. The actual file names might differ on your device.
To upgrade system software from the Web interface, use one of the following methods:
·           Using BIN files to upgrade the system software
·           Using an IPE file to upgrade the system software
CAUTION:
·      You can use the default account settings or create a new account to log in to the Web interface for the first time. This section uses the default account settings. For security purposes, if you use the default account settings, modify the default password or create a new account and delete the default account after the first login.
·      Do not perform any operation on the Web interface while the system is upgrading software.
Table 6 describes the default settings for you to log in to the Web interface.
Login information
Default setting
Username
admin
Password
admin
IP address of GigabitEthernet 1/0/0
192.168.0.1/24
The default management Ethernet port varies by device model. In this example, the default management Ethernet port is GigabitEthernet 1/0/0.
1.         Use an Ethernet cable to connect the PC to an Ethernet port on the device. As a best practice, connect the PC to the management Ethernet port on the device.
2.         Assign an IP address on the same subnet as the management port GigabitEthernet 1/0/0 to the PC.
In this example, assign 192.168.0.2 to the PC.
3.         Launch the Web browser, and enter 192.168.0.1 in the address bar.
The Web login page opens.
4.         Type the default username and password, and click Login.
5.         Select System > Upgrade Center > Software Upgrade from the navigation tree.
6.         Click Upgrade immediately on the Software Upgrade page.
7.         Select the bin startup file type.
Figure 2 Upgrade Immediately page
8.         Select Delete all startup files, and then click Yes.
·      As a best practice, select Delete all startup files if the size of the BIN files is larger than the free disk space.
·      The device cannot start up without a startup file. If you choose to delete all startup files but the upgrade fails, the device cannot start up.
Figure 3 Deleting all startup files
9.         Select the startup files to be used, and then click OK to start upgrading the system software.
Figure 4 Selecting startup files
7.         Select the ipe startup file type, select the startup file, and then click OK.
Figure 5 Upgrade Immediately page
You can use TFTP or FTP on the device to access the TFTP or FTP server to back up or download software files.
Using TFTP to upgrade system software
1.         Back up the running system software image and configuration file:
a.     Display current software images and startup software images.
<Sysname> display boot-loader
Software images on slot 1:
Current software images:
  cfa0:/main-cmw710-boot-R8513.bin
  cfa0:/main-cmw710-system-R8513.bin
Main startup software images:
Backup startup software images:
  None
b.    Back up the current software images.
<Sysname> copy main-cmw710-boot-R8513.bin boot_backup.bin
<Sysname> copy main-cmw710-system-R8513.bin system_backup.bin
c.     Specify boot_backup.bin and system_backup.bin as the backup startup image files.
<Sysname> boot-loader file boot cfa0:/boot_backup.bin system cfa0:/system_backup.bin backup
d.    Execute the save command in any view to save the running configuration.
<Sysname> save
Please input the file name(*.cfg)[cfa0:/startup.cfg]
cfa0:/startup.cfg exists, overwrite? [Y/N]:y
e.     Execute the dir command in user view to identify the system software image and configuration file names and verify that the CF card has sufficient space for the new system software image.
<Sysname> dir
Directory of cfa0:
   0 -rw-        4269 Jul 12 2018 13:34:36   + attachmentname + .ak
   1 -rw-     5723136 Oct 24 2018 13:03:16   boot_backup.bin
   2 drw-           - Sep 26 2018 15:21:36   diagfile
   3 drw-           - Sep 14 2018 08:04:50   dpi
   4 -rw-     5723136 Oct 23 2018 16:52:51   main-cmw710-boot-R8513.bin
   5 -rw-   137090048 Oct 23 2018 16:58:19   main-cmw710-system-R8513.bin
   6 -rw-         735 Sep 13 2018 19:16:22   hostkey
   7 -rw-         730 Oct 23 2018 16:58:50   ifindex.dat
   8 drw-           - Jul 12 2018 13:34:36   license
   9 drw-           - Sep 13 2018 18:29:20   logfile
  10 drw-           - Sep 13 2018 19:16:24   pki
  11 drw-           - Sep 13 2018 18:33:24   seclog
  12 -rw-         591 Sep 13 2018 19:16:24   serverkey
  13 -rw-        5109 Oct 23 2018 16:58:50   startup.cfg
  14 -rw-      134782 Oct 23 2018 16:58:51   startup.mdb
  15 -rw-   137090048 Oct 24 2018 13:11:57   system_backup.bin
  16 drw-           - Oct 23 2018 17:04:21   versionInfo
4088468 KB total (3972960 KB free)
f.      Execute the tftp put command in user view to upload the startup.cfg file to the TFTP server.
<Sysname> tftp 192.168.0.2 put startup.cfg
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100  3950    0     0  100  3950      0   204k --:--:-- --:--:-- --:--:--  642k
2.         Upgrade the system software:
a.     Execute the tftp get command in user view to download the system software image file to the CF card on the device.
<Sysname> tftp 192.168.0.2 get main.ipe
100  102M  100  102M    0     0   461k      0  0:03:48  0:03:48 --:--:--  554k
Writing file...Done.
<Sysname>
b.    Execute the boot-loader file command in user view to load the main.ipe file and specify it as the main image file at the next reboot.
<Sysname> boot-loader file cfa0:/main.ipe all main
Verifying the file cfa0:/main.ipe on slot 1.........Done.
H3C SecPath T5020 images in IPE:
  main-cmw710-boot-R8514.bin
  main-cmw710-system-R8514.bin
This command will set the main startup software images. Please do not reboot any MPU during the upgrade. Continue? [Y/N]:y
Add images to slot 1.
File cfa0:/main-cmw710-boot-R8514.bin already exists on slot 1.
File cfa0:/main-cmw710-system-R8514.bin already exists on slot 1.
Overwrite the existing files? [Y/N]:y
Decompressing file main-cmw710-boot-R8514.bin to cfa0:/main-cmw710-boot-R8514.bin..........Done.
Decompressing file main-cmw710-system-R8514.bin to cfa0:/main-cmw710-system-R8514.bin............................................................................................................................................................................Done.
Verifying the file cfa0:/main-cmw710-boot-R8514.bin on slot 1...Done.
Verifying the file cfa0:/main-cmw710-system-R8514.bin on slot 1.........Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
Decompression completed.
Do you want to delete cfa0:/main.ipe now? [Y/N]:N
<Sysname>
c.     Execute the display boot-loader command in user view to verify that the file has been loaded.
<Sysname>
d.    Execute the reboot command in user view to reboot the device.
<Sysname> reboot
 Start to check configuration with next startup configuration file, please wait.
........DONE!
System is starting...
e.     After the reboot is complete, execute the display version command to verify that the system software image is correct.
<Sysname> display version
H3C Comware Software, Version 7.1.064, Release 8514
Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.
H3C SecPath T5020 uptime is 0 weeks, 2 days, 5 hours, 53 minutes
Boot image: cfa0:/main-cmw710-boot-R8514.bin
Boot image version: 7.1.064, Release 8514
  Compiled Sep 18 2018 15:00:00
System image: cfa0:/main-cmw710-system-R8514.bin
System image version: 7.1.064, Release 8514
SLOT 1
Uptime is 0 weeks, 2 days, 5 hours, 53 minutes
CPU type: Multi-core CPU
DDR3 SDRAM Memory      32766M bytes
CF0 Card         4002M bytes
Board PCB        Version:Ver.A
CPLD_A           Version:  1.0
CPLD_B           Version:  2.0
Release          Version:SecPath T5020-8514
Basic  BootWare  Version: 2.04
Extend BootWare  Version: 2.04
<Sysname>
Using FTP to upgrade system software
  None
<Sysname>
<Sysname> save
<Sysname>
<Sysname> dir
Directory of cfa0:
<Sysname>
f.      Execute the ftp command in user view to access the FTP server.
<Sysname> ftp 192.168.0.2
Connected to 192.168.0.2 (192.168.0.2).
220 3Com 3CDaemon FTP Server Version 2.0
User (192.168.0.2:(none)): user123
331 User name ok, need password
Password:
230 User logged in
Remote system type is UNIX.
Using binary mode to transfer files.
ftp>
g.    Execute the put command in FTP client view to upload the startup.cfg file to the FTP server.
ftp> put startup.cfg
227 Entering passive mode (192,168,0,2,26,3).
125 Using existing data connection.
226 Closing data connection; File transfer successful.
3950 bytes sent in 0.001 seconds (4.13 Mbytes/s)
ftp>
a.     Execute the get command in FTP client view to download the system software image file to the CF card on the device.
ftp> get main.ipe
227 Entering passive mode (192,168,0,2,8,252)
107934720 bytes received in 187.994 seconds (560.68 Kbytes/s)
ftp>
b.    Execute the quit command in FTP client view to return to user view.
ftp> quit
221 Service closing control connection
<Sysname>
c.     Execute the boot-loader file command in user view to load the main.ipe file and specify it as the main image file at the next reboot.
<Sysname>
d.    Execute the display boot-loader command in user view to verify that the file has been loaded.
Software images on slot 2:
<Sysname>
e.     Execute the reboot command in user view to reboot the device.
<Sysname> reboot
........DONE!
f.      After the reboot is complete, execute the display version command to verify that the system software image is correct.
SLOT 1
CPLD_A           Version:  1.0
CPLD_B           Version:  2.0
<Sysname>
To upgrade Comware images from BootWare menus, use one of the following methods:
·           Using TFTP to upgrade system software through the management Ethernet port
·           Using FTP to upgrade system software through the management Ethernet port
1.         Connect the configuration terminal to the MPU's console port.
2.         Connect the MPU's management Ethernet port to the TFTP or FTP file server.
The TFTP or FTP server can be co-located with the configuration terminal (typically, a PC).
3.         Prepare the upgrade file:
¡  If you are using TFTP, store the upgrade file on the TFTP server, and specify the directory.
¡  If you are using FTP, store the upgrade file on the FTP server, and specify the directory, FTP username, and password.
4.         Run the terminal emulation program on the configuration terminal.
5.         Power on the device, and then press Ctrl+B within 5 seconds at prompt to access the EXTEND-BOOTWARE menu (see "Using the EXTENDED-BOOTWARE menu").
1.         Enter 3 in the EXTEND-BOOTWARE menu to access the Ethernet submenu.
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is sda0                                         |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5):
2.         Enter 5 in the Ethernet submenu to configure the network settings.
To use the existing setting for a field, press Enter without modifying the setting.
======================<ETHERNET PARAMETER SET>==============================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP):tftp
Load File Name        :main.ipe
Target File Name      :main.ipe
Server IP Address     :192.168.0.2
Local IP Address      :192.168.0.1
Subnet Mask            :255.255.255.0
Gateway IP Address    :0.0.0.0
Table 7 Network parameter fields and shortcut keys
'.' = Clear field
Press a dot (.) and then press Enter to clear the setting for a field.
Press a hyphen (-) and then press Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl+D to exit the ETHERNET PARAMETER SET menu.
Set the file transfer protocol to TFTP.
Load File Name
Set the name of the file to be downloaded.
Target File Name
Set a file name for saving the file on the device. The target file name must have the same extension as the source file.
By default, the target file name is the same as the source file name.
Server IP Address
Set the IP address of the TFTP server.
Local IP Address
Set the IP address of the Ethernet interface that connects to the TFTP server.
Subnet Mask
Set the IP address mask.
Gateway IP Address
Set a gateway IP address if the device is on a different network than the server.
After you finish setting the TFTP parameters, the system returns to the Ethernet submenu.
3.         Enter 2 or 3 in the Ethernet submenu to upgrade the main or backup software images. For example, enter 2 to upgrade the main software images.
Loading.....................................................................
.........................Done!
94786560 bytes downloaded!
Image file main-cmw710-boot-A9615.bin is self-decompressing...
Saving file sda0:/main-cmw710-boot-A9615.bin ......Done.
Image file main-cmw710-system-A9615.bin is self-decompressing...
Saving file sda0:/main-cmw710-system-A9615.bin .......................
..................Done.  .
4.         Enter 0 in the Ethernet submenu to return to the EXTEND-BOOTWARE menu.
5.         Enter 1 in the EXTEND-BOOTWARE menu to run the new Comware images.
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP):ftp
FTP User Name         :admin
FTP User Password     :******
Table 8 Network parameter fields and shortcut keys
'.' = Clear field
Ctrl+D = Quit
Set the file transfer protocol to FTP.
Load File Name
Target File Name
Server IP Address
Set the IP address of the FTP or TFTP server.
Local IP Address
Set the IP address of the Ethernet interface that connects to the TFTP or FTP server.
Subnet Mask
Gateway IP Address
FTP User Name
Set the username for accessing the FTP server. This username must be the same as the username configured on the FTP server.
FTP User Password
Set the password for accessing the FTP server. This password must be the same as the password configured on the FTP server.
After you finish setting the FTP parameters, the system returns to the Ethernet submenu.
5.         Enter 1 in the EXTEND-BOOTWARE menu to run the new system software.
You can upgrade the BootWare from the CLI or BootWare menus.
Whether a .btw file is compressed together with an .ipe file depends on the device model and software release. Please check it with H3C technical support. This section describes only how to upgrade the BootWare from the CLI.
To upgrade the BootWare from the CLI:
1.         Use FTP or TFTP to download or upload the new BootWare image file to the root directory of the storage medium on the device.
2.         Execute the bootrom update command to upgrade the BootWare.
<System> bootrom update file cfa0:/main.btw slot 2
  This command will update bootrom file, Continue? [Y/N]:y
  Now updating bootrom, please wait...
 Updating basic bootrom!
 Update basic bootrom success!
 Updating extended bootrom!
 Update extended bootrom success!
 Update bootrom success!
<System>
3.         Execute the reboot command to reboot the device.
To upgrade the BootWare image from BootWare menus, use one of the following methods:
·           Using TFTP to upgrade BootWare through the management Ethernet port
·           Using FTP to upgrade BootWare through the management Ethernet port
For more information about BootWare menus, see "Using BootWare menus."
This section uses the MPU as an example to describe how to upgrade BootWare.
1.         Connect the MPU's console port to the configuration terminal.
¡  If you are using TFTP, store the upgrade file on the TFTP server, and specify the file directory.
¡  If you are using FTP, store the upgrade file on the FTP server, and specify the file directory, FTP username, and password.
1.         Enter 7 in the BootWare menu to access the BootWare Operation submenu.
=========================<BootWare Operation Menu>==========================
|<1> Backup Full BootWare                                                  |
|<2> Restore Full BootWare                                                 |
|<3> Update BootWare By Serial                                             |
|<4> Update BootWare By Ethernet                                           |
Enter your choice(0-4):
2.         Enter 4 in the BootWare Operation submenu to enter the Ethernet submenu.
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare                                                  |
|<2> Update Extended BootWare                                              |
|<3> Update Basic BootWare                                                 |
|<4> Modify Ethernet Parameter                                             |
3.         Enter 4 in the Ethernet submenu to configure the network settings.
==========================<ETHERNET PARAMETER SET>==========================
|          Ctrl+D = Quit.                                                  |
Load File Name         :Main.btw
Target File Name       :Main.btw
For more information about the fields, see Table 7.
After you finish setting the TFTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
4.         Choose an option from options 1 to 3. For example, enter 1 to upgrade the entire BootWare image.
Loading..............Done.
64245 bytes downloaded!
Updating Basic BootWare? [Y/N]
5.         Enter Y to upgrade the basic BootWare segment.
Updating Basic BootWare........Done.
Updating Extended BootWare? [Y/N]
6.         Enter Y to upgrade the extended BootWare segment.
Updating Extended BootWare.........Done!
7.         Enter 0 to return to the BootWare Operation menu.
8.         Enter 0 in the BootWare Operation menu to return to the EXTEND-BOOTWARE menu.
9.         Enter 0 in the EXTEND-BOOTWARE menu to reboot the system.
|          Ctrl+D = Quit.                                                  |
Protocol (FTP or TFTP) :ftp
For more information about the fields, see Table 8.
After you finish setting the FTP parameters, the system returns to the BOOTWARE OPERATION ETHERNET submenu.
Loading.......Done.
Updating Extended BootWare.........Done.
If a software upgrade fails, the system runs the old software version. To handle a software failure:
1.         Check the physical ports for a loose or incorrect connection, and verify that the LEDs are reflecting the correct port status.
2.         If you are using the console port for file transfer, check the HyperTerminal settings (including the baud rate and data bits) for any wrong setting.
3.         Check the file transfer settings:
¡  If TFTP is used, you must enter the same server IP addresses, file name, and working directory as set on the TFTP server.
¡  If FTP is used, you must enter the same FTP server IP address, source file name, working directory, and FTP username and password as set on the FTP server.
4.         Check the FTP or TFTP server for incorrect settings.
5.         Check that the CF card has sufficient space for the upgrade file.
6.         If the message "Something is wrong with the file" appears, check the file for file corruption.
Overview
BootWare provides a menu method to perform basic file operations, software upgrade, and system management when the Comware CLI is inaccessible because of image corruption.
BootWare is stored in each MPU's built-in the SD card. It has one basic segment and one extended segment. The basic segment enables the system to complete basic initialization, and the extended segment bootstraps the Comware images.
BootWare menus
Table 9 lists the menus that each segment provides and the major tasks you can perform using these menus. You can access these menus only during system startup.
BootWare segment
Menu
Tasks
Reference
Basic
BASIC-BOOTWARE
·         Modify serial port parameters.
·         Upgrade BootWare.
·         Start the primary or backup BootWare extended segment.
Basic
BASIC ASSISTANT
Perform RAM test.
Extended
EXTEND-BOOTWARE
·         Upgrade Comware software.
·         Manage files.
·         Access the system when the console login password is lost.
·         Clear user privilege passwords.
Extended
EXTEND-ASSISTANT
·         Examine system memory.
·         Search system memory.
BootWare provides the shortcut keys listed in Table 10.
Shortcut keys
Prompt message
Function
Ctrl+B
access EXTENDED-BOOTWARE MENU
Accesses the EXTENDED-BOOTWARE menu while the device is starting up.
Ctrl+C
Please Start To Transfer File, Press <Ctrl+C> To Exit.
Stops the ongoing file transfer and exits the current operation interface.
Info: Press Ctrl+C to abort or return to EXTENDED ASSISTANT MENU.
Returns to the EXTENDED ASSISTANT menu. If the system is outputting the result of an operation, this shortcut key combination aborts the display first.
Ctrl+D
Press Ctrl+D to access BASIC-BOOTWARE MENU
Accesses the BASIC-BOOTWARE menu while the device is starting up.
Ctrl+D = Quit
Exits the parameter settings menu.
Ctrl+E
Memory Test(press Ctrl+C to skip it,press Ctrl+E to ECHO INFO)
Prints information during the memory test.
Ctrl+F
Ctrl+F: Format File System
Formats the current storage medium.
Ctrl+T
Press Ctrl+T to start memory test
Performs a memory test.
Ctrl+U
Access BASIC ASSISTANT MENU
Accesses the BASIC ASSISTANT menu from the BASIC-BOOTWARE menu.
Ctrl+Z
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Accesses the EXTENDED ASSISTANT menu from the EXTENDED-BOOTWARE menu.
1.         Power on the device.
2.         Press Ctrl+D within 4 seconds after the "Press Ctrl+D to access BASIC-BOOTWARE MENU" prompt message appears. If you fail to do this within the time limit, the system starts to run the extended BootWare segment.
======================<BASIC-BOOTWARE MENU(Ver 1.19)>=======================
|<1> Modify Serial Interface Parameter                                     |
|<3> Update Full BootWare                                                  |
|<4> Boot Extended BootWare                                                |
|<5> Boot Backup Extended BootWare                                         |
|<0> Reboot        |
Ctrl+U: Access BASIC ASSISTANT MENU
Table 11 BASIC-BOOTWARE menu options
Option
Reference
Change the baud rate of the console port.
Perform this task before downloading an image through the console port for software upgrade.
Upgrade the extended BootWare segment.
If the extended segment is corrupt, choose this option to repair it.
Upgrade the entire BootWare, including the basic segment and the extended segment.
Run the primary extended BootWare segment.
<5> Boot Backup Extend BootWare
Run the backup extended BootWare segment.
<0> Reboot
Reboot the device.
N/A
Press Ctrl+U to access the BASIC ASSISTANT menu.
To change the baud rate of the console port:
1.         Enter 1 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 1
===============================<BAUDRATE SET>===============================
|Note:'*'indicates the current baudrate                                    |
|     Change The HyperTerminal's Baudrate Accordingly                      |
|---------------------------<Baudrate Available>---------------- ----------|
|<1> 9600(Default)*                                                        |
|<2> 19200        |
|<3> 38400        |
|<4> 57600        |
|<5> 115200        |
|<0> Exit        |
2.         Enter the number that represents the baud rate you want to choose. For example, enter 5 to set the baud rate to 115200 bps.
Baud rate change is a one-time operation. The baud rate will restore to the default (9600 bps) at reboot. To set up a console session with the device after a reboot, you must change the baud rate of the configuration terminal back to 9600 bps.
Enter 2 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 2
Waiting ...CCC
Enter 3 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 3
Waiting ...CCC
Enter 4 in the BASIC-BOOTWARE menu.
Enter your choice(0-5): 4
Booting Normal Extended BootWare.
The Extended BootWare is self-decompressing....Done.
*                   H3C SecPath BootWare, Version 1.05                     *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Aug 31 2017
Memory Type         : DDR3 SDRAM
Memory Size         : 16384MB
Sda0 Size          : 8MB
sda0 Size           : 3728MB
CPLD Version        : 1.0
PCB Version         : Ver.B
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading the main image files...
Loading file sda0:/Main-CMW710-SYSTEM-A9615.bin. ......................
Image file sda0:/Main-CMW710-BOOT-A9615.bin is self-decompressing......
System image is starting...
Enter 5 in the BASIC-BOOTWARE menu.
For information about backing up the extended BootWare segment, see "Accessing the BootWare Operation submenu."
Enter your choice(0-5): 5
Booting Backup Extended BootWare.
The Extended BootWare is self-decompressing............................Done!
This option is not supported if the password recovery capability is enabled. For more information about configuring the password recovery capability at the CLI, see "Controlling the password recovery capability."
Accessing the BASIC ASSISTANT menu
Press Ctrl+U in the BASIC-BOOTWARE menu.
===========================<BASIC-ASSISTANT MENU>===========================
|<1> RAM Test                                                              |
Enter your choice(0-1):
Option
<1> RAM Test
Test the memory.
<2> Exit To Main Menu
Return to the BASIC-BOOTWARE menu.
Testing the memory
IMPORTANT:
To avoid unexpected exceptions, perform this task under the guidance of H3C Support.
To test the memory, use one of the following methods:
·           In the BASIC-BOOTWARE menu, press Ctrl+T within 4 seconds after the "Press Ctrl+T to start memory test" prompt message appears.
·           In the BASIC-BOOTWARE menu, press Ctrl+U to access the BASIC ASSISTANT menu.
Accessing the EXTENDED-BOOTWARE menu
2.         Press Ctrl+B within 5 seconds after the "Press Ctrl+B to access EXTENDED-BOOTWARE MENU..." prompt message appears. If you fail to do this within the time limit, the system starts up.
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Press Ctrl+T to start heavy memory test..
Sda0 Size          : 8MB
sda0 Size           : 3728MB
CPLD Version        : 1.0
PCB Version         : Ver.B
Password recovery capability is enabled.
Note: The current operating device is sda0
Enter < Storage Device Operation > to select device.
3.         Press Enter to access the EXTENDED-BOOTWARE menu.
===========================<EXTENDED-BOOTWARE MENU>=========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Enter your choice(0-9):
Availability of some options in this menu depends on the password recovery capability state (displayed on top of the EXTEND-BOOTWARE menu). For more information about the feature, see "Controlling the password recovery capability."
Table 13 EXTENDED-BOOTWARE menu options
Option
Tasks
Reference
<1> Boot System
Run the Comware software without rebooting the device.
Choose this option after completing operations in the EXTENDED-BOOTWARE menu.
N/A
Accessing the Serial submenu.
Use FTP or TFTP to upgrade Comware images through the management Ethernet port.
Accessing the Ethernet submenu
<4> File Control
·         Display files on the current storage medium.
·         Set a Comware image file as the main or backup startup software image file.
·         Delete files to release storage space.
Managing files
Restore the factory-default configuration.
This option is available only if password recovery capability is disabled.
Restoring the factory-default configuration
Start the device with the factory-default configuration without loading any configuration file.
This option is available only if password recovery capability is enabled.
Skipping the configuration file
Back up, recover, and upgrade the BootWare image.
Skip console login authentication.
This is a one-time operation and takes effect only for the first system boot or reboot after you choose this option.
Skipping console login authentication
Set the storage medium from which the device will start up.
Set the storage medium where file operations are performed. This storage medium is referred to as the "current storage medium."
Managing storage media
Format the file system.
Formatting the file system
Access the EXTENDED ASSISTANT menu.
Accessing the EXTEND ASSISTANT submenu
<0> Reboot
Reboot the device.
N/A
Password recovery capability controls console user access to the device configuration from BootWare menus. This feature decides the method to handle a password loss situation.
·           If password recovery capability is enabled, a console user can handle a password loss situation as follows:
¡  If the console login password is lost, the user can skip console login authentication, and then access the CLI to configure a new password.
¡  If a user role password is lost, the user can skip the configuration file, and then access the CLI to configure a new password.
·           If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords.
To enhance system security, disable password recovery capability.
To enable or disable password recovery capability:
Step
Remarks
5.       Enter system view.
N/A
6.       Enable or disabled password recovery capability.
·         Enable the feature:
password-recovery enable
·         Disable the feature:
undo password-recovery enable
By default, password recovery capability is enabled.
Running Comware images
Enter 1 in the EXTEND-BOOTWARE menu.
Enter your choice(0-9): 1
Loading file cfa0:/main-cmw710-system-e8526.bin.........................
Loading file cfa0:/main-cmw710-boot-e8526.bin...........................
Image file cfa0:/main-cmw710-boot-e8526.bin is self-decompressing.......
........Done.
Enter 2 in the EXTEND-BOOTWARE menu.
Enter your choice(0-9): 2
===========================<Enter Serial SubMenu>===========================
|<5> Modify Serial Interface Parameter                                     |
Table 14 Serial submenu options
Option
Tasks
Load and run Comware images in SDRAM.
Download Comware images to the current storage medium as the main images (the file attribute is set to M).
As a result, the M file attribute of the original main images is removed.
Download Comware images to the current storage medium as backup images (the file attribute is set to B).
As a result, the B file attribute of the original backup images is removed.
Download files from the server to the device.
The baud rate change is a one-time operation. The baud rate will restore to the default (9600 bps) at reboot. To set up a console session with the device after a reboot, you must change the baud rate setting on the configuration terminal to 9600 bps.
Return to the EXTENDED-BOOTWARE menu.
To set the current storage medium, see "Managing storage media."
You can upgrade the Comware software through the management Ethernet port from the Ethernet submenu and configure file transfer settings.
1.         Enter 3 in the EXTENDED-BOOTWARE menu and press Enter to access the Ethernet submenu.
Enter your choice(0-9):3
Table 15 Ethernet submenu options
Option
Load and run software images in SDRAM.
If password recovery capability is enabled, this option is not available.
Download software images to the current storage medium as main images (the file attribute is set to M).
Download software images to the current storage medium as backup images (the file attribute is set to B).
Configure FTP or TFTP file transfer settings.
2.         Enter 4 in the Ethernet submenu to configure file transfer settings on the MPU.
Enter your choice(0-4):4
|          Ctrl+D = Quit.                                                 |
Table 16 Setting Ethernet parameters for file transfer
'.' = Clear field
Press the dot (.), and then press Enter to clear the setting for a field.
Press the hyphen (-), and then press Enter to return to the previous field.
Ctrl+D = Quit
Press Ctrl + D to exit the Ethernet parameter settings menu.
Set the file transfer protocol to FTP or TFTP.
Load File Name
Target File Name
Set a file name for saving the file in the current storage medium on the device.
Server IP Address
Local IP Address
Set the IP address of the device.
Subnet Mask
Gateway IP Address
FTP User Name
Set the username for accessing the FTP server. This username must be the same as configured on the FTP server. This field is not available for TFTP.
FTP User Password
Set the password for accessing the FTP server. This password must be the same as configured on the FTP server. This field is not available for TFTP.
Managing files
You can display all files, set the attribute for a file, and delete a file from the File Control submenu.
Enter 4 in the EXTEND-BOOTWARE menu and then press Enter to access the File Control submenu.
Enter your choice(0-9):4
===============================<File CONTROL>===============================
|Note:the operating device is cfa0                                         |
|<1> Display All File(s)                                                   |
|<2> Set Image File type                                                   |
|<3> Set Bin File type                                                     |
|<4> Set Configuration File type                                           |
|<5> Delete File                                                           |
Table 17 File Control submenu options
Option
Display all files.
Set the attribute for a software image file.
Set the attribute for a .bin file.
Set the type for a configuration file.
<5> Delete File
Delete a file.
Return to the EXTEND-BOOTWARE menu.
Displaying all files
Enter 1 in the File Control submenu.
Display all file(s) in cfa0:
 'M' = MAIN      'B' = BACKUP      'N/A' = NOT ASSIGNED
|NO. Size(B)   Time                 Type   Name                            |
|1   956       Jan/21/2019 17:59:34 N/A    cfa0:/ifindex.dat               |
|2   24671     Mar/28/2018 09:08:56 N/A    cfa0:/wdydiudie.cfg             |
|3   735       Mar/28/2018 09:18:22 N/A    cfa0:/hostkey                   |
|4   116549    Oct/09/2017 13:51:02 N/A    cfa0:/lwb-t5k.cfg               |
|5   963       Mar/27/2018 15:24:12 N/A    cfa0:/license/history/deviceid_2|
|0180327152412.did                                                         |
|6   965       Mar/27/2018 15:24:12 N/A    cfa0:/license/210235a1rsh1640000|
|06.did        |
|7   3237      Dec/25/2017 15:14:54 N/A    cfa0:/license/ngips2017122515235|
|923325.ak        |
|8   3249      Apr/16/2018 16:40:28 N/A    cfa0:/license/ngips2018041616523|
|608292.ak        |
|9   1611429   Jan/22/2019 14:14:22 N/A    cfa0:/logfile/logfile.log       |
|10  1048575   Apr/16/2018 17:57:26 N/A    cfa0:/logfile/ips.log           |
|11  5230      Mar/19/2018 14:40:30 N/A    cfa0:/logfile/uflt.log          |
|12  1048405   Apr/16/2018 17:57:26 N/A    cfa0:/logfile/anti-vir.log      |
|13  44840     Aug/10/2017 15:25:46 N/A    cfa0:/logfile/dfilter.log       |
|14  14195     Jan/21/2019 16:47:54 N/A    cfa0:/logfile/cfglog.log        |
|15  251751    Jan/03/2019 09:09:56 N/A    cfa0:/diagfile/diagfile.log     |
|16  69784     Mar/28/2018 09:18:28 N/A    cfa0:/dpi/ips/predefined/ips_sig|
|pack_curr.dat                                                             |
|17  2373992   Mar/28/2018 09:18:28 N/A    cfa0:/dpi/ips/predefined/ips_sig|
|pack_back.dat                                                             |
|18  32027352  Apr/16/2018 16:56:28 N/A    cfa0:/dpi/av/predefined/av_sigpa|
|ck_curr.dat                                                               |
|19  9574536   Apr/16/2018 16:48:00 N/A    cfa0:/dpi/av/predefined/av_sigpa|
|ck_back.dat                                                               |
|20  68040     Mar/28/2018 09:18:28 N/A    cfa0:/dpi/uflt/predefined/uflt_s|
|igpack_curr.dat                                                           |
|21  10330760  Mar/28/2018 09:18:36 N/A    cfa0:/dpi/uflt/predefined/uflt_s|
|igpack_back.dat                                                           |
|22  342232    Mar/28/2018 09:18:24 N/A    cfa0:/dpi/apr/predefined/apr_sig|
|pack_curr.dat                                                             |
|23  979448    Mar/28/2018 09:18:24 N/A    cfa0:/dpi/apr/predefined/apr_sig|
|pack_back.dat                                                             |
|24  2840      Jan/22/2019 14:12:46 N/A    cfa0:/dpi/filereg/predefined/fil|
|ereg_sigpack_curr.dat                                                     |
|25  30        Jan/21/2019 16:53:16 N/A    cfa0:/dpi/dpi_sigpack.log       |
|26  1566      Mar/28/2018 09:18:20 N/A    cfa0:/pki/https-server.p12      |
|27  591       Mar/28/2018 09:18:22 N/A    cfa0:/serverkey                 |
|28  259308    Mar/28/2018 09:08:58 N/A    cfa0:/wdydiudie.mdb             |
|29  723419    Oct/09/2017 13:51:04 N/A    cfa0:/lwb-t5k.mdb               |
|30  22692     Jan/21/2019 17:59:36 M      cfa0:/startup.cfg               |
|31  686202    May/20/2017 19:15:56 N/A    cfa0:/pn.cfg                    |
|32  9275      Oct/28/2017 13:50:12 N/A    cfa0:/zp.cfg                    |
|33  807       Oct/09/2017 15:59:54 N/A    cfa0:/.trash/.trashinfo         |
|34  5327872   Aug/15/2017 13:06:42 N/A    cfa0:/.trash/main-cmw710-boo|
|t-e8518.bin_0001                                                          |
|35  5331968   Aug/15/2017 10:30:04 N/A    cfa0:/.trash/main-cmw710-boo|
|t-e8519.bin_0001                                                          |
|36  9048064   Aug/21/2017 13:54:12 N/A    cfa0:/.trash/main-cmw710-boo|
|t-e8520.bin_0001                                                          |
|37  2056192   Aug/12/2017 18:05:54 N/A    cfa0:/.trash/main-cmw710-dev|
|kit-e8518.bin_0001                                                        |
|38  163840    Aug/14/2017 16:57:06 N/A    cfa0:/.trash/main-cmw710-dev|
|kit-e8519.bin_0001                                                        |
|39  163840    Aug/21/2017 14:07:26 N/A    cfa0:/.trash/main-cmw710-dev|
|kit-e8520.bin_0001                                                        |
|40  103891968 Aug/15/2017 13:07:04 N/A    cfa0:/.trash/main-cmw710-sys|
|tem-e8518.bin_0001                                                        |
|41  107120640 Aug/15/2017 10:30:58 N/A    cfa0:/.trash/main-cmw710-sys|
|tem-e8519.bin_0001                                                        |
|42  171900928 Aug/21/2017 14:07:02 N/A    cfa0:/.trash/main-cmw710-sys|
|tem-e8520.bin_0001                                                        |
|43  2238      Jan/22/2019 14:14:22 N/A    cfa0:/context/context3/logfile/l|
|ogfile.log        |
|44  24        Jan/21/2019 17:59:50 N/A    cfa0:/context/context3/ifindex.d|
|at        |
|45  1192      Jan/21/2019 17:59:50 N/A    cfa0:/context/context3/startup.c|
|fg        |
|46  34023     Jan/21/2019 17:59:50 N/A    cfa0:/context/context3/startup.m|
|db        |
|47  18468     Jan/22/2019 14:14:22 N/A    cfa0:/context/context4/logfile/l|
|ogfile.log        |
|48  1566      Mar/28/2018 09:19:08 N/A    cfa0:/context/context4/pki/https|
|-server.p12                                                               |
|49  1671      Jan/22/2019 09:27:00 N/A    cfa0:/context/context4/startup.c|
|fg        |
|50  37050     Jan/22/2019 09:27:00 N/A    cfa0:/context/context4/startup.m|
|db        |
|51  52        Jan/22/2019 09:27:00 N/A    cfa0:/context/context4/ifindex.d|
|at        |
|52  9054208   Apr/20/2018 13:27:02 N/A    cfa0:/main-cmw710-boot-e8526|
|.bin        |
|53  227919    Jan/21/2019 17:59:36 N/A    cfa0:/startup.mdb               |
|54  186294272 Apr/20/2018 13:27:30 N/A    cfa0:/main-cmw710-system-e85|
|26.bin        |
|55  123384832 Jan/21/2019 17:20:04 N/A    cfa0:/main.ipe             |
|56  3920      Jul/19/2017 18:32:04 N/A    cfa0:/86.raw                    |
|57  3242      Jul/07/2017 09:36:50 N/A    cfa0:/ngips2017070709142354252.a|
|k        |
|58  120804    Jun/17/2017 17:00:30 N/A    cfa0:/1.cfg                     |
|59  822025    Jun/17/2017 17:00:34 N/A    cfa0:/1.mdb                     |
|60  120727    Jun/17/2017 17:01:02 N/A    cfa0:/2.cfg                     |
|61  821866    Jun/17/2017 17:01:06 N/A    cfa0:/2.mdb                     |
|62  16        Jan/21/2019 17:48:10 N/A    cfa0:/versioninfo/versionctl.dat|
|63  536       Jan/21/2019 17:48:10 N/A    cfa0:/versioninfo/version0.dat  |
|64  796       Mar/20/2018 16:23:44 N/A    cfa0:/versioninfo/version1.dat  |
|65  796       Mar/20/2018 16:30:22 N/A    cfa0:/versioninfo/version2.dat  |
|66  796       Mar/20/2018 16:32:22 N/A    cfa0:/versioninfo/version3.dat  |
|67  796       Mar/20/2018 16:39:04 N/A    cfa0:/versioninfo/version4.dat  |
|68  536       Mar/27/2018 12:36:40 N/A    cfa0:/versioninfo/version5.dat  |
|69  796       Mar/27/2018 14:23:12 N/A    cfa0:/versioninfo/version6.dat  |
|70  536       Mar/28/2018 09:18:16 N/A    cfa0:/versioninfo/version7.dat  |
|71  796       Apr/16/2018 18:06:04 N/A    cfa0:/versioninfo/version8.dat  |
|72  536       Jul/24/2018 11:50:02 N/A    cfa0:/versioninfo/version9.dat  |
|73  9696      Sep/11/2017 17:41:56 N/A    cfa0:/libpty.so                 |
|74  500446    Jul/29/2017 17:59:46 N/A    cfa0:/ips.rules                 |
|75  19586056  Oct/16/2017 17:58:08 N/A    cfa0:/50w-2.dat                 |
|76  117405304 Oct/16/2017 15:38:20 N/A    cfa0:/500w-2.dat                |
|77  7125      Sep/11/2017 19:43:30 N/A    cfa0:/new1.rules                |
|78  963       Oct/16/2017 17:12:58 N/A    cfa0:/210235a1rsh164000006.did  |
|79  9172      Oct/26/2017 11:30:30 N/A    cfa0:/uzi.cfg                   |
|80  792001    May/20/2017 19:15:58 N/A    cfa0:/pn.mdb                    |
|81  554834    May/18/2017 15:40:52 N/A    cfa0:/fullconfig.cfg            |
|82  684919    May/19/2017 13:50:20 N/A    cfa0:/fullconfig2.cfg           |
|83  554834    May/18/2017 16:20:36 N/A    cfa0:/fullconfig1.cfg           |
|84  788347    May/19/2017 13:50:22 N/A    cfa0:/fullconfig2.mdb           |
|85  154433    Oct/26/2017 11:30:30 N/A    cfa0:/uzi.mdb                   |
|86  685411    May/23/2017 14:08:56 N/A    cfa0:/wdy0523.cfg               |
|87  791322    May/23/2017 14:08:58 N/A    cfa0:/wdy0523.mdb               |
|88  3246      Oct/16/2017 17:38:58 N/A    cfa0:/ngips2017101617275868747.a|
|k        |
|89  164864    Apr/20/2018 13:36:44 N/A    cfa0:/main-cmw710-devkit-e85|
|26.bin        |
|90  582397    Dec/25/2017 16:17:00 N/A    cfa0:/1024.rules                |
|91  93544     Dec/25/2017 16:17:30 N/A    cfa0:/url.dat                   |
|92  5684224   Jul/24/2018 11:39:04 N/A    cfa0:/main-cmw710-boot-e8530|
|.bin        |
|93  154961    Oct/28/2017 13:50:14 N/A    cfa0:/zp.mdb                    |
|94  504464    Oct/28/2017 19:22:12 N/A    cfa0:/5e9dd320d3c7fd6fbec3a81a85|
|788002.6d9ada99                                                           |
|95  2491008   Oct/29/2017 15:57:14 N/A    cfa0:/8ac3b6bff681d9be6a20f865ac|
|e15a14        |
|96  20        Jan/31/2018 14:20:10 N/A    cfa0:/.snmpboots                |
|97  2216      Apr/16/2018 18:05:22 N/A    cfa0:/pcap/excpt-currentcpu11-20|
|180117140659.cap                                                          |
|98  128016    Jan/17/2018 14:29:32 N/A    cfa0:/firewall.exp              |
|99  2812      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/subthreatrep|
|ort.html        |
|100 1139      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatid.htm|
|l        |
|101 2148      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatlog.ht|
|ml        |
|102 2370      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatrank.h|
|tml        |
|103 2067      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatrankdl|
|g.html        |
|104 4122      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threatreport|
|.html        |
|105 3571      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/cn/threattrend.|
|html        |
|106 2857      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/subthreatrep|
|ort.html        |
|107 1429      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatlog.ht|
|ml        |
|108 2651      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatrank.h|
|tml        |
|109 2419      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatrankdl|
|g.html        |
|110 4213      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threatreport|
|.html        |
|111 2721      Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/en/threattrend.|
|html        |
|112 14068     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/nc.js          |
|113 36539     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/netconf.rbac   |
|114 19541     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/subthreatreport|
|.js        |
|115 13032     Jan/17/2018 20:07:28 N/A    cfa0:/web/threat/threatid.js    |
|116 98591     Jan/17/2018 20:10:04 N/A    cfa0:/web/threat/threatlog.js   |
|117 55749     Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threatrank.js  |
|118 37582     Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threatrankdlg.j|
|s        |
|119 31328     Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threatreport.js|
|120 133659    Jan/17/2018 20:07:30 N/A    cfa0:/web/threat/threattrend.js |
|121 106004480 Jul/24/2018 11:39:24 N/A    cfa0:/main-cmw710-system-e85|
|30.bin        |
|122 5692416   Jan/21/2019 17:29:52 M      cfa0:/main-cmw710-boot-e8524|
|p15.bin        |
|123 117685248 Jan/21/2019 17:30:12 M      cfa0:/main-cmw710-system-e85|
|24p15.bin        |
|124 7300      Jan/24/2018 08:53:08 N/A    cfa0:/0a704f6998e9602ac5203b1306|
|7b2317        |
|125 151348    Jun/05/2017 16:40:44 N/A    cfa0:/o.mdb                     |
|126 17704     Jan/31/2018 09:44:08 N/A    cfa0:/dpi.cfg                   |
|127 235207    Jan/31/2018 09:44:10 N/A    cfa0:/dpi.mdb                   |
|128 17659     Jan/31/2018 10:53:24 N/A    cfa0:/dpi1.cfg                  |
|129 231817    Jan/31/2018 10:53:26 N/A    cfa0:/dpi1.mdb                  |
|130 110592    Jan/31/2018 14:31:18 N/A    cfa0:/core/node16_dpid_202565_11|
|_20180131-143118_1517409078.core                                          |
|131 118784    Jul/24/2018 11:51:10 N/A    cfa0:/core/node16_ntopd_820_11_2|
|0180724-115110_1532433070.core                                            |
|132 118784    Dec/17/2018 08:32:20 N/A    cfa0:/core/node16_ntopd_803_11_2|
|0181217-083220_1545035540.core                                            |
|133 3249      Apr/16/2018 16:40:28 N/A    cfa0:/ngips2018041616523608292.a|
|k        |
Setting the attribute for software images
1.         Enter 2 in the File Control submenu.
|<5> Delete File                                                           |
|1   123384832 Jan/21/2019 17:20:04 N/A    cfa0:/main.ipe             |
|0   Exit        |
2.         Enter the numbers of the files you are working with. For example, enter 1.
Enter file No.:1
Modify the file attribute:
|<1>+Main        |
|<2>+Backup        |
|<0> Exit        |
Enter your choice(0-2):
3.         Enter a number in the range of 0 to 2 to add or delete a file attribute for the files. For example, enter 1 to assign the M attribute to the files.
Enter your choice(0-2):1
This operation may take several minutes. Please wait....
The file is exist,will you overwrite it? [Y/N]Y
Image file main-cmw710-boot-E8524P15.bin is self-decompressing...
Saving file cfa0:/main-cmw710-boot-E8524P15.bin ........................
Image file main-cmw710-system-E8524P15.bin is self-decompressing...
Saving file cfa0:/main-cmw710-system-E8524P15.bin ......................
Set the file attribute success!
Setting the attribute for .bin files
Enter 3 in the File Control submenu.
|1   9054208   Apr/20/2018 13:27:02 N/A    cfa0:/main-cmw710-boot-e8526|
|.bin        |
|2   186294272 Apr/20/2018 13:27:30 N/A    cfa0:/main-cmw710-system-e85|
|26.bin        |
|3   164864    Apr/20/2018 13:36:44 N/A    cfa0:/main-cmw710-devkit-e85|
|26.bin        |
|4   5684224   Jul/24/2018 11:39:04 N/A    cfa0:/main-cmw710-boot-e8530|
|.bin        |
|5   106004480 Jul/24/2018 11:39:24 N/A    cfa0:/main-cmw710-system-e85|
|30.bin        |
|6   5692416   Jan/22/2019 14:47:32 M      cfa0:/main-cmw710-boot-e8524|
|p15.bin        |
|7   117685248 Jan/22/2019 14:47:50 M      cfa0:/main-cmw710-system-e85|
|24p15.bin        |
|0   Exit        |
Note:Select .bin files. One but only one boot image and system image must
be included.
Enter file No.(Allows multiple selection):1
Enter another file No.(0-Finish choice):2
Enter another file No.(0-Finish choice):0
You have selected:
|<1>+Main        |
|<2>+Backup        |
|<0> Exit        |
Deleting a file
1.         Enter 5 in the File Control submenu.
Deleting the file in cfa0:
|0180327152412.did                                                         |
|06.did        |
|923325.ak        |
|608292.ak        |
|pack_curr.dat                                                             |
|pack_back.dat                                                             |
|ck_curr.dat                                                               |
|ck_back.dat                                                               |
|igpack_curr.dat                                                           |
|igpack_back.dat                                                           |
|pack_curr.dat                                                             |
|pack_back.dat                                                             |
|t-e8518.bin_0001                                                          |
|t-e8519.bin_0001                                                          |
|t-e8520.bin_0001                                                          |
|ogfile.log        |
|at        |
|fg        |
|db        |
|ogfile.log        |
|-server.p12                                                               |
|fg        |
|db        |
|at        |
|52  9054208   Apr/20/2018 13:27:02 M      cfa0:/main-cmw710-boot-e8526|
|.bin        |
|54  186294272 Apr/20/2018 13:27:30 M      cfa0:/main-cmw710-system-e85|
|26.bin        |
|k        |
|k        |
|26.bin        |
|.bin        |
|788002.6d9ada99                                                           |
|e15a14        |
|180117140659.cap                                                          |
|ort.html        |
|l        |
|ml        |
|tml        |
|g.html        |
|.html        |
|html        |
|ort.html        |
|ml        |
|tml        |
|g.html        |
|.html        |
|html        |
|.js        |
|s        |
|30.bin        |
|122 5692416   Jan/22/2019 14:47:32 N/A    cfa0:/main-cmw710-boot-e8524|
|p15.bin        |
|123 117685248 Jan/22/2019 14:47:50 N/A    cfa0:/main-cmw710-system-e85|
|24p15.bin        |
|7b2317        |
|k        |
|0   Exit        |
Enter file No.:
2.         Enter the number of the file to delete. For example, enter 13 to delete the sda0:/test.cfg file.
3.         When the following message appears, enter Y.
The file you selected is sda0:/test.cfg,Delete it? [Y/N]
If the following message appears, the file is successfully deleted.
Deleting.....Done!
CAUTION:
Restoring the factory-default configuration will permanently delete startup configuration files and backup configuration files in the current storage medium.
To restore the factory-default configuration from the EXTENDED-BOOTWARE menu, make sure password recovery capability is disabled. If the capability is enabled, you cannot perform the task.
After you perform this task, the device uses the factory-default configuration instead of the configuration file for the next startup.
To restore the factory-default configuration:
1.         Enter 5 in the EXTEND-BOOTWARE menu and then press Enter.
Enter your choice(0-9): 5
2.         Follow the system instruction to complete the task.
¡  If password recovery capability is enabled, first disable the capability from the CLI, and then reboot the device to access the EXTENDED-BOOTWARE menu.
Password recovery capability is enabled. To perform this operation, first disable the password recovery capability using the undo password-recovery enable command in CLI.
¡  If password recovery capability is disabled, enter Y at the prompt to complete the task.
Because the password recovery capability is disabled, this operation can cause the configuration files to be deleted, and the system will start up with factory defaults. Are you sure to continue?[Y/N]Y
Setting...Done.
To perform this task, make sure password recovery capability is enabled. If the capability is disabled, you cannot perform the task.
To start the device with the factory-default configuration:
1.         Enter 6 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 6
Flag Set Success.
¡  If password recovery capability is enabled, the device uses the factory-default configuration instead of the configuration file for the next startup.
¡  If password recovery capability is disabled, first enable the capability from the CLI, and then reboot the device to access the EXTENDED-BOOTWARE menu.
Password recovery capability is disabled. To perform this operation, first enable the password recovery capability using the password-recovery enable command in CLI.
Enter 7 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 7
Table 18 BootWare Operation submenu options
Option
Back up the entire BootWare image.
Recover the entire BootWare image.
Upgrade the BootWare image through the serial port.
Upgrade BootWare through the management Ethernet port.
To perform this task, make sure password recovery capability is enabled. If the capability is disabled, you cannot perform this task.
This is a one-time operation and takes effect only for the reboot after you perform this task.
To enable the device to load the next-startup configuration file with the console login password ignored:
1.         Enter 8 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9): 8
¡  If password recovery capability is enabled, the device clears the password for user privilege change.
Clear Image Password Success!
Enter 9 in the EXTEND-BOOTWARE menu and press Enter.
Enter your choice(0-9):9
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s)                   |
|<2> Set The Operating Device                                              |
|<3> Set The Default Boot Device                                           |
Enter your choice(0-3):
Table 19 DEVICE CONTROL menu options
Option
Display all storage media on the MPU you are working with.
Set the current storage medium. All file operations in BootWare menus are performed on the current storage medium.
Set the default storage medium from which the system will start up.
Press Ctrl+Z in the EXTEND-BOOTWARE menu.
==========================<EXTENDED ASSISTANT MENU>=========================
|<1> Display Memory                                                        |
|<2> Search Memory                                                         |
Table 20 EXTEND ASSISTANT submenu options
Option
<1> Display Memory
View memory information that meets certain requirements.
<2> Search Memory
Search memory for data that meets certain requirements.
CAUTION:
Formatting the file system clears all files and directories in a storage medium permanently. The cleared files and directories cannot be recovered.
Press Ctrl+F in the EXTEND-BOOTWARE menu.
Warning:All files on sda0 will be lost! Are you sure to format? [Y/N]
